[Nek5000-users] Lagrangian Particle Tracking (again)
Sat Jun 9 11:39:42 CDT 2018
Are you saying the hemi example of v17.0 is not compiling? It works for me. Are you use you are using the source + examples of v17.0?
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Saturday 9th June 2018 15:47
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] Lagrangian Particle Tracking (again)
> Hi all,
> I'm working on implementing LPT in my simulations in Nek5000.  I've looked through all the other posts on this subject and they all mention the hemi example (and some mention Azad Noorani but he doesn't seem to have an
>  implementation).  I managed to get LPT working, using Hemi, in the previous version of NEK.  Since updating though, the code no longer complies.  I end up with a lot of error messages of this form:
> Error: Parameter 'lpart' at (1) has not been declared or is a variable, which does not reduce to a constant expression
> and just
> Error: Variable 'lpart' cannot appear in the expression at (1).
> As I'm not an expert in the use of Fortran I was wondering if anyone could help me update this example to work with the newest version of NEK.
> Thanks,
> Daniel
> Nek5000-users mailing list
