[Nek5000-users] why I can`t change .rea with 2.1M elements to .re2
Fri Jun 1 11:11:30 CDT 2018
Change MAXNEL in /tools/maketools
then
rm reatore2/*.o
maketools reatore2
Do you have periodic boundary conditions in your ascii .rea file?
If so, I would be careful because it's not clear that the Nek Rea file will always properly represent the element-to-element connectivity for periodic bcs in ascii once nel > 100,000...
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Friday, June 1, 2018 10:20:42 AM
To: nek5000-users
Subject: Re: [Nek5000-users] why I can`t change .rea with 2.1M elements to .re2
HI,
goto reatore2.f file and change this line
if(nel.ge.lelt) then
set lelt is greater than 2.1M
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
Envoyé: Vendredi 1 Juin 2018 03:53:51
Objet: [Nek5000-users] why I can`t change .rea with 2.1M elements to .re2
[https://ssl.gstatic.com/docs/doclist/images/icon_10_generic_list.png] pipe.tar.gz<https://drive.google.com/file/d/1shdsB_kjr-VXaJsu83JZ1emIB_EUZxCT/view?usp=drive_web>[X]
hi,manager.I have a problam that I want to make a example with 2.1M elements but I can`t change .rea to .re2, and reatore2 will give me wrong answer as below:
Start converting ...
read:  **MESH DATA** 6 lines are X,Y,Z;X,Y,Z. Columns corners 1-4;5-8
 Abort: number of elements too large     2100000
 change MAXNEL and recompile
How to solve this problem?
if I can`t change reatore2,when I run the example also have a wrong problem:
EXIT:Problem size  requires .re2
I have sent you my file..~!!
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180601/8835a8e4/attachment-0001.html>
