[Nek5000-users] why I can`t change .rea with 2.1M elements to .re2
Fri Jun 1 10:20:42 CDT 2018
HI,
goto reatore2.f file and change this line
if(nel.ge.lelt) then
set lelt is greater than 2.1M
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
Envoyé: Vendredi 1 Juin 2018 03:53:51
Objet: [Nek5000-users] why I can`t change .rea with 2.1M elements to .re2
[ https://drive.google.com/file/d/1shdsB_kjr-VXaJsu83JZ1emIB_EUZxCT/view?usp=drive_web |  pipe.tar.gz ]
hi,manager.I have a problam that I want to make a example with 2.1M elements but I can`t change .rea to .re2, and reatore2 will give me wrong answer as below:
Start converting ...
read: **MESH DATA** 6 lines are X,Y,Z;X,Y,Z. Columns corners 1-4;5-8
Abort: number of elements too large 2100000
change MAXNEL and recompile
How to solve this problem?
if I can`t change reatore2,when I run the example also have a wrong problem:
EXIT:Problem size requires .re2
I have sent you my file..~!!
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180601/33fa7c16/attachment.html>
