[Nek5000-users] Number of Elements per Characteristic Length for DNS
Thu Jul 12 09:22:15 CDT 2018
Hello Philipp,
Thanks again for getting back to me and for sending these references.
Tommy
On Thu, Jul 12, 2018 at 9:07 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> I guess the El Khoury paper might be a good starting point; we really
> tried to make sure that the resolution is sufficient for good DNS.
> Otherwise, there is a resolution discussion for spectral methods in the
> paper by Coleman, Johnstone and Spalart:
> https://aip.scitation.org/doi/abs/10.1063/1.3247176
> Philipp
> On 2018-07-12 14:56, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Philipp,
>> Thank you for getting back to me. Do you have any references that you
>> could provide so that I can look into this further?
>> Thanks,
>> Tommy
>> On Thu, Jul 12, 2018 at 4:25 AM, <nek5000-users at lists.mcs.anl.gov
>> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>>     Hi,
>>     typically, in wall bounded turbulence you would design the mesh
>>     based on inner scaled quantities (i.e. based on the viscous length
>>     scale l*). This is what we have done in the paper by El Khoury, in
>>     accordance to studies in channel flow. TOwards the centre, one can
>>     then also use Kolmogorov units (not sure whether Taylor units are so
>>     useful). I am quite convinced that the El Khoury simulations are
>>     well-resolved DNS, which can also be seen when looking at spectra.
>>     Philipp
>>     On 2018-07-11 20:58, nek5000-users at lists.mcs.anl.gov
>>     <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>>         Hello All,
>>         I am currently investigating the turbulence in a pipe with
>>         periodic boundary conditions. I am working on building my mesh
>>         and was planning on using Re^(3/4) as the number of elements per
>>         characteristic length, but I have found differing methods in
>>         literature detailing the number of elements used for DNS. One
>>         paper in particular (G.K. El Khoury et al, Direct Numerical
>>         Simulation of Turbulent Pipe Flow at Moderately High Reynolds
>>         Numbers,  Flow Turbulence Combust, 2013) uses Nek5000 to
>>         simulate turbulent flow in a pipe at different Reynolds numbers.
>>         The number of elements calculated in this paper seem to be in
>>         between the LES and DNS suggested number of elements (element
>>         size between the Taylor microscale and the Kolmogorov scale).
>>         Turbulent Flows by Pope however suggests a number of elements
>>         that is slightly larger than Re^(3/4), and is dependent on the
>>         Taylor microscale Reynolds number.
>>         Any suggestions on the correct way to determine the number of
>>         spectral elements in a characteristic length would be appreciated.
>>         Regards,
>>         Tommy
>>         _______________________________________________
>>         Nek5000-users mailing list
>>         Nek5000-users at lists.mcs.anl.gov
>>         <mailto:Nek5000-users at lists.mcs.anl.gov>
>>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>         <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>     Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mc
>> s.anl.gov>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180712/b5066fc5/attachment-0001.html>
