[Nek5000-users] Problem in obtaining eigenvalues through Arnoldi (using NEK5000 with the ARPACK library)
Thu Jul 12 03:07:59 CDT 2018
 Hi Neks
    I am running a 3D simulation for a flow over a cylinder. My domain size
for simulation is 100Dx100D. where D is the diameter of a cylinder. We have
obtained the base flow through SFD. The base flow is used to calculate the
stability analysis through NEK5000 with the ARPACK library (Implemented by
A.  Peplinski).
we have used the following parameters.....
  90.0000     p111 : ARNOLDI: size of Krylov space
   30.0000     p112 : ARNOLDI: number of eigenvectors
We have run the Arnoldi with restart but we are not able to get the output
file (eigenvalues.txt and egvext_cyl0.f0..) even after almost 20 restarts.
Also, we tried to run with increasing the size of Krylov space but the
eigenvalues are not converging.
The log file shows no changes in converged ritz values after around 20-22
values.
The part of the log file is shown below...........
Kindly,  help me out and let me know where I am going wrong.....
Alok Mishra
ARNOLDI: after  520 stepper phase
 _naup2: Corresponding B-norm of the residual
    1 -    1:   6.623D-01
 _naup2: no. of "converged" Ritz values at this iter.
    1 -    1:    22
 _naup2: NEV and NP are
    1 -    2:    52   128
 _naup2: "wanted" Ritz values -- real part
    1 -    5:   9.905D-01   9.905D-01   9.854D-01   9.854D-01   9.855D-01
    6 -   10:   9.855D-01   9.897D-01   9.897D-01   9.924D-01   9.930D-01
   11 -   15:   9.930D-01   9.905D-01   9.905D-01   9.943D-01   9.943D-01
   16 -   20:   9.938D-01   9.938D-01   9.948D-01   9.948D-01   9.949D-01
   21 -   25:   9.949D-01   9.951D-01   9.958D-01   9.960D-01   9.962D-01
   26 -   30:   9.962D-01   9.966D-01   9.970D-01   9.970D-01   9.969D-01
   31 -   35:   9.969D-01   9.973D-01   9.974D-01   9.975D-01   9.976D-01
   36 -   40:   9.976D-01   9.971D-01   9.971D-01   9.978D-01   9.979D-01
   41 -   45:   9.979D-01   9.982D-01   9.982D-01   1.000D+00   9.908D-01
   46 -   50:   9.908D-01   1.004D+00   1.004D+00   1.005D+00   1.005D+00
   51 -   52:   1.006D+00   1.006D+00
 _naup2: "wanted" Ritz values -- imag part
    1 -    5:   5.038D-02  -5.038D-02  -1.127D-01   1.127D-01  -1.119D-01
    6 -   10:   1.119D-01   6.954D-02  -6.954D-02   0.000D+00   3.705D-03
   11 -   15:  -3.705D-03  -7.103D-02   7.103D-02  -9.233D-04   9.233D-04
   16 -   20:   4.345D-02  -4.345D-02   6.799D-04  -6.799D-04  -1.821D-02
   21 -   25:   1.821D-02   0.000D+00   0.000D+00   0.000D+00  -2.047D-03
   26 -   30:   2.047D-03   0.000D+00   7.200D-05  -7.200D-05   2.386D-02
   31 -   35:  -2.386D-02   0.000D+00   0.000D+00   0.000D+00  -1.140D-04
   36 -   40:   1.140D-04   3.125D-02  -3.125D-02   0.000D+00  -1.248D-04
   41 -   45:   1.248D-04  -1.673D-03   1.673D-03   0.000D+00  -1.508D-01
   46 -   50:   1.508D-01  -1.863D-02   1.863D-02  -2.109D-02   2.109D-02
   51 -   52:  -1.152D-02   1.152D-02
 _naup2: Ritz estimates of the "wanted" values
    1 -    5:   3.315D-02   3.315D-02   3.244D-05   3.244D-05   7.035D-05
    6 -   10:   7.035D-05   6.072D-11   6.072D-11   1.314D-02   2.772D-06
   11 -   15:   2.772D-06   6.796D-15   6.796D-15   9.719D-04   9.719D-04
   16 -   20:   7.467D-17   7.467D-17   5.506D-04   5.506D-04   2.437D-16
   21 -   25:   2.437D-16   2.977D-03   7.238D-04   6.054D-04   3.914D-11
   26 -   30:   3.914D-11   1.827D-04   1.138D-04   1.138D-04   1.048D-16
   31 -   35:   1.048D-16   1.198D-04   6.358D-05   3.013D-05   3.490D-07
   36 -   40:   3.490D-07   9.960D-18   9.960D-18   1.340D-07   2.518D-10
   41 -   45:   2.518D-10   1.827D-16   1.827D-16   1.781D-16   7.278D-17
   46 -   50:   7.278D-17   0.000D+00   0.000D+00   0.000D+00   0.000D+00
   51 -   52:   0.000D+00   0.000D+00
 Reached max iteration number; settingido=-2 for checkpointing.
 ARNOLDI:
 IDOARP  =           -2
 Writing checkpoint
       0      40 OPEN: ARPm11800.f00002
       0      40 OPEN: ARVm11800.f00002
       40  2.0000E-01 done :: Write checkpoint
                              file size =     621.E+00MB
                              avg data-throughput =   624.1MB/s
                              io-nodes =     1
 ARNOLDI: finalize
    Number of stepper cycles            520
    Time spent in ARNOLDI         60.3302609920502
    Average stepper phase time    10.9141681075096
 call outfld: ifpsco: F
       40  2.0000E-01 Write checkpoint:
       0      40 OPEN: m11800.f00001
                              file size =      4.0    MB
                              avg data-throughput =   303.2MB/s
                              io-nodes =     1
end of time-step loop
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180712/e6a551e5/attachment.html>
