[Nek5000-users] Using an external file for forcing in 'ffx'
Wed Jul 11 10:34:26 CDT 2018
 Hey All,
I have been stuck in this problem for a while now but I think it should be
simple and probably you can tell where I am going wrong.
- So I have a forcing function on a finite difference X-Y grid, which I am
reading in as a text file in the 'userdat2' subroutine.
- I am then parallelizing it using a previous suggestion by Paul, here is a
snippet of the routine.
     subroutine usrdat2
      include 'SIZE'
      include 'TOTAL'
       double precision :: my_array(651)
       integer m
        common /myarray/ my_array
        parameter (my_array_size=651)
        real  work(my_array_size)
        n = my_array_size
        call rzero(my_array,n)
        call rzero(work,n)
        if (nid.eq.0) then
          open (unit=49,file='fint41.txt')
             do k = 1,n
                read(49,*) my_array(k)
             enddo
          close(49)
        endif
         call gop(my_array,work,'+  ',n)   !  Sum over all processors
      return
      end
- Next I am interpolating this forcing function to the GLL grid points in
the userf routine, by a piecewise linear interpolant, here's how,
     subroutine userf  (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      EQUIVALENCE    (prandtl,param(2))
         double precision :: shaped_array(31,21)
         real new_array(nx1,ny1,nz1,nelv)
         double precision :: xin(21),yin(31)
         double precision :: xn(nx1*ny1*nelv),yn(nx1*ny1*nelv)
         double precision :: fo(nx1*ny1*nelv)
         integer i,j,k,l,p,q
         integer e,eg
         open(16,file='xin.txt')
         do p=1,21
         read(16,*) xin(p)
         end do
         close(16)
         open(12,file='yin.txt')
         do q=1,31
         read(12,*) yin(q)
         end do
         close(12)
         shaped_array = reshape(my_array,(/31,21/))
         do i=1,nx1*ny1*nelv
         xn(i) = xm1(i,1,1,1)
         yn(i) = ym1(i,1,1,1)
         end do
         call pwl_interp_2d(31,21,yin,xin,shaped_array,nx1*ny1*nelv,yn,xn,
fo)
        new_array=reshape(fo,(/nx1,ny1,nz1,nelv/))
                 do e=1,nelv
                      eg = lglel(e)
                      ffx = new_array(ix,iy,iz,eg)
                 end do
         ffy = 0.0
         ffz = 0.0
      return
      end
This is a test domain I made, with 6 elements. It seems to be working when
I am using only 1 core, i.e., in series. In parallel, it seems to be giving
me a different flowfield. My actual domain has 252 elements which I intend
to parallelize with 48 cores. So would like to ask you how to proceed. I
think I am close but I am slightly confused about part of the code that I
have made red.
When I am trying this in my actual domain, I get an error, "Segmentation
fault occurred." I think the key here is parallelization and identifying
the elements correctly which I am not sure I am doing right. Thanks for
reading this lengthy email. Will be eager to hear from you.
Saikat
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180711/06424308/attachment-0001.html>
