[Nek5000-users] Visualizing avg_all outputs
Thu Jul 5 12:49:21 CDT 2018
Hi Paul,
I have avg_all dump frequency defined as equal to iostep so on every run i
got the same amount of blah0.f**** and avgblah0.f**** files. The thing is,
after I execute visnek and open the *.nek5000 with paraview, the
blah.nek5000 has, let's say, 50 timesteps and the avgblah.nek5000 only
shows 3 timesteps out of the same amount of files.
I tried with p68=0 (wich makes iastep=iostep) and p68=10 with the same
result.
Nicolás
Hi Nicolas,
> Frequency of the average output is controlled by param 68.
> Default I believe is 500 if p68=0.
> Note that if you output avg files every time step it will look just like
> a regular f0000 file because each avg file is just an average over the
> steps from the previous avg output step.  So, in the case of p68=500,
> avgx0.f00001 would have the average for steps 1-500; ...02 would have
> 501 to 1000; etc.
> hth,
> Paul
> Dear Neks,
>> I'm running some cases of natural convection flows inside a box domain and I want to compute and visualize turbulent statistics of the velocity fields.
>> I tried this workflow:
>> - Call avg_all on every usrchk execution, thus I got a avg/rms/rm2-blah0.f* file for each iostep.
>> - Execute visnek for each series of *blah0.f* files
>> - Open the *.nek5000 files on paraview.
>> blah.nek5000 works fine, showing all fields on every timestep, but for the avg,rms and rm2 series I only a few timesteps 'frames' out of all the *blah0.f* files.
>> Last test I ran was:
>> p010 = 100 seconds
>> p015 = 50
>> p068 = 0
>> which outputted 200 *blah0.f* from where I got 200 timesteps frames for regular blah0.f* and only 4 timesteps for the avg_all fields.
>> I would like some advice on how to properly generate the avg_all files or the post-processing workflow requiered to get a 'smooth' visualizing of the statistics.
>> Regards,
>> Nicolás
*Nicolás Andrés Órdenes Leiva*
Estudiante de Ingeniería Civil Mecánica
Universidad Técnica Federico Santa María
Tel: +56 9 7619 2857
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180705/c1a2e9dc/attachment.html>
