[Nek5000-users] Example turbChannel restart issue
Tue Jan 23 10:08:40 CST 2018
Hello,
Thank you for the reply. I think it might due to the re-posting, the original file does not look as messy as it is now, I am reattaching it at the end here (Hopefully it looks good now). For the restart file, am I supposed to post-process it using Visit or other command prior to calling it?
For the .re2 file here in the turbChannel, I am aware of that it is ASCII file. The only difference I noticed is that the one here is not readable using any software whereas others are readable.
Ming
********************Log file*****************************
Number of processors:                 4
REAL    wdsize          :                      8
INTEGER wdsize      :                      4
Timer accuracy        :                      9.40E-07
 Reading /global/home/hpc4076/Nek5000/run/turbChannel/turbChannel.par
general = [(null)]
general:startfrom = [turbChannel0.f00001]
general:stopat = [endTime]
general:endtime = [200]
general:dt = [0]
general:timestepper = [bdf2]
general:extrapolation = [OIFS]
general:variabledt = [yes]
general:targetcfl = [2.0]
general:writecontrol = [runTime]
general:writeinterval = [100.0]
general:userparam01 = [100]
general:userparam02 = [20]
general:userparam03 = [1]
general:filtering = [hpfrt]
general:filterweight = [10]
general:filtercutoffratio = [0.9]
problemtype = [(null)]
problemtype:variableproperties = [no]
problemtype:equation = [incompNS]
pressure = [(null)]
pressure:preconditioner = [semg_amg]
pressure:residualtol = [1e-04]
pressure:residualproj = [yes]
velocity = [(null)]
velocity:residualtol = [1e-07]
velocity:density = [1]
velocity:viscosity = [-2950]
Reading /global/home/hpc4076/Nek5000/run/turbChannel/turbChannel.re2
 mapping elements to processors
Reading /global/home/hpc4076/Nek5000/run/turbChannel/turbChannel.ma2
           1         384         384        1536        1536  NELV
           2         384         384        1536        1536  NELV
           3         384         384        1536        1536  NELV
           0         384         384        1536        1536  NELV
RANK     0 IEG      44      45      49      50      51      54      55      56
                     57      58      59      60      61      62      63      64
                     65      66      67      68      69      70      71      72
                     73      74      75      76      77      78      79      80
                     81      82      83      84      85      86      87      88
                     89      90      91      92      93      94      95      96
                    236     237     241     242     243     246     247     248
                    249     250     251     252     253     254     255     256
                    257     258     259     260     261     262     263     264
                    265     266     267     268     269     270     271     272
                    273     274     275     276     277     278     279     280
                    281     282     283     284     285     286     287     288
                    428     429     433     434     435     438     439     440
                    441     442     443     444     445     446     447     448
                    449     450     451     452     453     454     455     456
                    457     458     459     460     461     462     463     464
                    465     466     467     468     469     470     471     472
                    473     474     475     476     477     478     479     480
                    620     621     625     626     627     630     631     632
                    633     634     635     636     637     638     639     640
                    641     642     643     644     645     646     647     648
                    649     650     651     652     653     654     655     656
                    657     658     659     660     661     662     663     664
                    665     666     667     668     669     670     671     672
                    812     813     817     818     819     822     823     824
                    825     826     827     828     829     830     831     832
                    833     834     835     836     837     838     839     840
                    841     842     843     844     845     846     847     848
                    849     850     851     852     853     854     855     856
                    857     858     859     860     861     862     863     864
                   1004    1005    1009    1010    1011    1014    1015    1016
                   1017    1018    1019    1020    1021    1022    1023    1024
                   1025    1026    1027    1028    1029    1030    1031    1032
                   1033    1034    1035    1036    1037    1038    1039    1040
                   1041    1042    1043    1044    1045    1046    1047    1048
                   1049    1050    1051    1052    1053    1054    1055    1056
                   1196    1197    1201    1202    1203    1206    1207    1208
                   1209    1210    1211    1212    1213    1214    1215    1216
                   1217    1218    1219    1220    1221    1222    1223    1224
                   1225    1226    1227    1228    1229    1230    1231    1232
                   1233    1234    1235    1236    1237    1238    1239    1240
                   1241    1242    1243    1244    1245    1246    1247    1248
                   1388    1389    1393    1394    1395    1398    1399    1400
                   1401    1402    1403    1404    1405    1406    1407    1408
                   1409    1410    1411    1412    1413    1414    1415    1416
                   1417    1418    1419    1420    1421    1422    1423    1424
                   1425    1426    1427    1428    1429    1430    1431    1432
                   1433    1434    1435    1436    1437    1438    1439    1440
 element load imbalance:            0         384         384
done :: mapping   0.29167     sec
  preading mesh
  preading bc for ifld           1
done :: read .re2 file   0.51     sec
nelgt/nelgv/lelt:        1536        1536         387
lx1  /lx2  /lx3 :           8           8           8
setup mesh topology
   Right-handed check complete for    1536 elements. OK.
   setvert3d:   8      201344      533120      201344      201344
call usrsetvert
done :: usrsetvert
gs_setup: 21952 unique labels shared
   pairwise times (avg, min, max): 2.92127e-05 2.76451e-05 3.00083e-05
   crystal router                : 7.82046e-05 7.75443e-05 7.88275e-05
   all reduce                    : 0.000228323 0.000227655 0.000228766
   used all_to_all method: pairwise
   handle bytes (avg, min, max): 1.45061e+06 1375332 1525892
   buffer bytes (avg, min, max): 175616 125440 225792
   setupds time 9.2419E-02 seconds   0  8      201344        1536
           8  max multiplicity
done :: setup mesh topology
 call usrdat
done :: usrdat
generate geometry data
NOTE: All elements deformed , param(59) ^=0
done :: generate geometry data
 call usrdat2
done :: usrdat2
regenerate geometry data           1
done :: regenerate geometry data           1
 verify mesh topology
  0.000000000000000E+000   6.28318530717959       Xrange
  -1.00000000000000        1.00000000000000       Yrange
  0.000000000000000E+000   3.14159265358979       Zrange
done :: verify mesh topology
 IFTRAN   = T
IFFLOW   = T
IFHEAT   = F
IFSPLIT  = T
IFLOMACH = F
IFUSERVP = F
IFUSERMV = F
IFPERT   = F
IFADJ    = F
IFSTRS   = F
IFCHAR   = T
IFCYCLIC = F
IFAXIS   = F
IFMVBD   = F
IFMELT   = F
IFNEKNEK = F
IFSYNC   = F
 IFVCOR   = T
IFINTQ   = F
IFGEOM   = F
IFSURT   = F
IFWCNO   = F
 IFTMSH for field           1    =  F
IFADVC for field           1    =  T
IFNONL for field           1    =  F
 Dealiasing enabled, lxd=           8
 Estimated eigenvalues
EIGAA =    1.23913370009078
 EIGGA =    1862221.21607236
 EIGAE =   0.250000000000000
 EIGAS =   1.681282119258565E-002
EIGGE =    1862221.21607236
 EIGGS =    2.00000000000000
  E-solver strategy:  0 itr
mg_nx:           1           3           7
mg_ny:           1           3           7
mg_nz:           1           3           7
call usrsetvert
done :: usrsetvert
gs_setup: 448 unique labels shared
   pairwise times (avg, min, max): 7.93538e-06 7.8488e-06 8.0526e-06
   crystal router                : 6.85905e-06 6.72e-06 6.9978e-06
   all reduce                    : 1.20532e-05 1.11753e-05 1.28944e-05
   used all_to_all method: crystal router
   handle bytes (avg, min, max): 50812 44668 56956
   buffer bytes (avg, min, max): 6144 5120 7168
   setupds time 3.1089E-03 seconds   1  2        1664        1536
   setvert3d:   4       30336       42624       30336       30336
call usrsetvert
done :: usrsetvert
gs_setup: 4032 unique labels shared
   pairwise times (avg, min, max): 8.37387e-06 8.2548e-06 8.5004e-06
   crystal router                : 1.86812e-05 1.83826e-05 1.89784e-05
   all reduce                    : 4.4251e-05 4.40251e-05 4.44275e-05
   handle bytes (avg, min, max): 269940 256100 283780
   buffer bytes (avg, min, max): 32256 23040 41472
   setupds time 2.4576E-02 seconds   2  4       30336        1536
call usrsetvert
done :: usrsetvert
   pairwise times (avg, min, max): 8.65523e-06 8.5168e-06 8.7977e-06
   crystal router                : 1.94818e-05 1.93217e-05 1.96357e-05
   all reduce                    : 5.97892e-05 5.95374e-05 5.99737e-05
   setupds time 1.4160E-02 seconds   3  4       30336        1536
   setvert3d:   6       96896      195200       96896       96896
call usrsetvert
done :: usrsetvert
gs_setup: 11200 unique labels shared
   pairwise times (avg, min, max): 1.61057e-05 1.58103e-05 1.62982e-05
   crystal router                : 3.86536e-05 3.8384e-05 3.89447e-05
   all reduce                    : 8.92118e-05 8.88703e-05 8.94562e-05
   handle bytes (avg, min, max): 742004 703588 780420
   buffer bytes (avg, min, max): 89600 64000 115200
   setupds time 4.3098E-02 seconds   4  6       96896        1536
 h1_mg_nx:           1           3           7
h1_mg_ny:           1           3           7
h1_mg_nz:           1           3           7
call usrsetvert
done :: usrsetvert
   pairwise times (avg, min, max): 4.10923e-06 2.5509e-06 4.7765e-06
   crystal router                : 3.94603e-06 3.7989e-06 4.0103e-06
   all reduce                    : 6.54198e-06 6.442e-06 6.5947e-06
   setupds time 1.6990E-03 seconds   5  2        1664        1536
call usrsetvert
done :: usrsetvert
   pairwise times (avg, min, max): 7.51525e-06 7.3863e-06 7.68e-06
   crystal router                : 1.7878e-05 1.76051e-05 1.81134e-05
   all reduce                    : 5.29887e-05 5.27139e-05 5.32422e-05
   setupds time 2.5044E-02 seconds   6  4       30336        1536
call usrsetvert
done :: usrsetvert
   pairwise times (avg, min, max): 1.11506e-05 1.07538e-05 1.1453e-05
   crystal router                : 2.78917e-05 2.74376e-05 2.83874e-05
   all reduce                    : 6.8896e-05 6.84774e-05 6.92927e-05
   setupds time 2.0265E-02 seconds   7  4       30336        1536
call usrsetvert
done :: usrsetvert
   pairwise times (avg, min, max): 1.44095e-05 1.43056e-05 1.45192e-05
   crystal router                : 3.94263e-05 3.90332e-05 3.98261e-05
   all reduce                    : 9.67785e-05 9.63923e-05 9.71425e-05
   setupds time 4.3436E-02 seconds   8  6       96896        1536
call usrsetvert
done :: usrsetvert
   pairwise times (avg, min, max): 5.80216e-05 4.95078e-05 6.16774e-05
   crystal router                : 7.1144e-05 7.08725e-05 7.14649e-05
   all reduce                    : 0.000235607 0.000234486 0.000236793
   setupds time 8.4090E-02 seconds   9  8      201344        1536
   setvert3d:  10      343680     1130112      343680      343680
call usrsetvert
done :: usrsetvert
gs_setup: 36288 unique labels shared
   pairwise times (avg, min, max): 3.15373e-05 3.06691e-05 3.2104e-05
   crystal router                : 9.24712e-05 9.09459e-05 9.39815e-05
   all reduce                    : 0.000254788 0.00025378 0.000255437
   handle bytes (avg, min, max): 2.39576e+06 2271332 2520196
   buffer bytes (avg, min, max): 290304 207360 373248
   setupds time 1.3027E-01 seconds  10 10      343680        1536
setup h1 coarse grid, nx_crs=           2
call usrsetvert
done :: usrsetvert
   pairwise times (avg, min, max): 5.59047e-06 5.5171e-06 5.677e-06
   crystal router                : 3.78503e-06 3.7079e-06 3.8472e-06
   all reduce                    : 5.5058e-06 5.4973e-06 5.5169e-06
   pairwise times (avg, min, max): 1.01072e-05 9.958e-06 1.01904e-05
   crystal router                : 4.22242e-06 4.1446e-06 4.331e-06
   all reduce                    : 8.35538e-06 8.1712e-06 8.4627e-06
   handle bytes (avg, min, max): 27068 23868 30268
   buffer bytes (avg, min, max): 4736 3840 5632
AMG version 2.01
AMG: 8 levels
AMG Chebyshev smoother data:
AMG  level 1: 3 iterations with rho = 0.79256
AMG  level 2: 2 iterations with rho = 0.668297
AMG  level 3: 2 iterations with rho = 0.481307
AMG  level 4: 2 iterations with rho = 0.409707
AMG  level 5: 2 iterations with rho = 0.458605
AMG  level 6: 3 iterations with rho = 0.696293
AMG  level 7: 2 iterations with rho = 0.666743
AMG: 1664 rows
AMG: preading through rows ... done
gs_setup: 431 unique labels shared
   pairwise times (avg, min, max): 2.78895e-06 2.5582e-06 2.8915e-06
   crystal router                : 4.09068e-06 3.9897e-06 4.2042e-06
   all reduce                    : 1.05099e-05 9.6558e-06 1.14097e-05
   handle bytes (avg, min, max): 3261 2620 3832
   buffer bytes (avg, min, max): 1724 1408 2040
gs_setup: 664 unique labels shared
   pairwise times (avg, min, max): 3.73e-06 3.6492e-06 3.8419e-06
   crystal router                : 4.80688e-06 4.7581e-06 4.8544e-06
   all reduce                    : 1.91924e-05 1.88961e-05 1.95428e-05
   handle bytes (avg, min, max): 5588 3840 7948
   buffer bytes (avg, min, max): 3200 2072 4328
gs_setup: 311 unique labels shared
   pairwise times (avg, min, max): 3.59183e-06 3.4744e-06 3.6762e-06
   crystal router                : 3.48463e-06 3.4264e-06 3.5338e-06
   all reduce                    : 7.03768e-06 6.9313e-06 7.1389e-06
   handle bytes (avg, min, max): 9301 8788 9740
   buffer bytes (avg, min, max): 3588 2992 4048
gs_setup: 421 unique labels shared
   pairwise times (avg, min, max): 4.046e-06 3.8288e-06 4.2149e-06
   crystal router                : 5.71768e-06 5.6236e-06 5.8628e-06
   all reduce                    : 9.28628e-06 9.1472e-06 9.4127e-06
   handle bytes (avg, min, max): 4913 3240 6956
   buffer bytes (avg, min, max): 3036 2088 4128
gs_setup: 151 unique labels shared
   pairwise times (avg, min, max): 2.19068e-06 2.1424e-06 2.242e-06
   crystal router                : 3.61935e-06 3.5275e-06 3.683e-06
   all reduce                    : 1.15655e-05 1.14062e-05 1.16404e-05
   handle bytes (avg, min, max): 1331 940 1700
   buffer bytes (avg, min, max): 628 448 808
gs_setup: 194 unique labels shared
   pairwise times (avg, min, max): 3.61092e-06 3.5012e-06 3.7449e-06
   crystal router                : 4.24627e-06 4.2222e-06 4.2926e-06
   all reduce                    : 5.85915e-06 5.651e-06 6.022e-06
   handle bytes (avg, min, max): 3380 3208 3588
   buffer bytes (avg, min, max): 2160 2032 2368
gs_setup: 80 unique labels shared
   pairwise times (avg, min, max): 2.38705e-06 2.3152e-06 2.4211e-06
   crystal router                : 2.44917e-06 2.3604e-06 2.5157e-06
   all reduce                    : 3.76915e-06 3.6987e-06 3.8185e-06
   handle bytes (avg, min, max): 985 788 1228
   buffer bytes (avg, min, max): 452 320 648
gs_setup: 98 unique labels shared
   pairwise times (avg, min, max): 3.19185e-06 3.1425e-06 3.2323e-06
   crystal router                : 2.91045e-06 2.8317e-06 3.0279e-06
   all reduce                    : 4.24988e-06 4.1918e-06 4.3256e-06
   handle bytes (avg, min, max): 5506 5136 5876
   buffer bytes (avg, min, max): 2352 2192 2512
gs_setup: 33 unique labels shared
   pairwise times (avg, min, max): 2.20093e-06 2.1362e-06 2.3165e-06
   crystal router                : 3.15857e-06 3.0855e-06 3.2308e-06
   all reduce                    : 4.0025e-06 3.9097e-06 4.0784e-06
   handle bytes (avg, min, max): 616 512 788
   buffer bytes (avg, min, max): 232 160 376
gs_setup: 39 unique labels shared
   pairwise times (avg, min, max): 2.55118e-06 2.5145e-06 2.5821e-06
   crystal router                : 3.45955e-06 3.3809e-06 3.5407e-06
   all reduce                    : 4.61387e-06 4.495e-06 4.7137e-06
   handle bytes (avg, min, max): 955 936 972
   buffer bytes (avg, min, max): 468 392 536
gs_setup: 8 unique labels shared
   pairwise times (avg, min, max): 2.7896e-06 2.684e-06 2.8771e-06
   crystal router                : 3.3584e-06 3.2604e-06 3.4714e-06
   all reduce                    : 3.8325e-06 3.7504e-06 3.9734e-06
   handle bytes (avg, min, max): 413 392 424
   buffer bytes (avg, min, max): 84 64 96
   pairwise times (avg, min, max): 2.76598e-06 2.7364e-06 2.8357e-06
   crystal router                : 2.47192e-06 2.4054e-06 2.5145e-06
   all reduce                    : 2.75563e-06 2.6928e-06 2.8295e-06
   handle bytes (avg, min, max): 916 860 972
   buffer bytes (avg, min, max): 192 176 208
gs_setup: 1 unique labels shared
   pairwise times (avg, min, max): 7.2665e-07 6.456e-07 7.68e-07
   crystal router                : 2.4244e-06 2.3879e-06 2.4719e-06
   all reduce                    : 2.57698e-06 2.5591e-06 2.5873e-06
   handle bytes (avg, min, max): 237 228 264
   buffer bytes (avg, min, max): 12 8 24
   pairwise times (avg, min, max): 7.836e-07 6.3e-07 8.848e-07
   crystal router                : 2.57503e-06 2.4694e-06 2.6345e-06
   all reduce                    : 2.86405e-06 2.8357e-06 2.9139e-06
gs_setup: 405 unique labels shared
   pairwise times (avg, min, max): 2.43873e-06 2.2721e-06 2.5217e-06
   crystal router                : 3.87707e-06 3.8341e-06 3.9225e-06
   all reduce                    : 7.58878e-06 7.5007e-06 7.6681e-06
   handle bytes (avg, min, max): 3079 2020 4152
   buffer bytes (avg, min, max): 1620 1024 2216
gs_setup: 235 unique labels shared
   pairwise times (avg, min, max): 3.03253e-06 2.9581e-06 3.1371e-06
   crystal router                : 4.62493e-06 4.5157e-06 4.7079e-06
   all reduce                    : 6.30792e-06 6.2306e-06 6.4236e-06
   handle bytes (avg, min, max): 2456 1268 3872
   buffer bytes (avg, min, max): 1368 600 2224
gs_setup: 232 unique labels shared
   pairwise times (avg, min, max): 3.3132e-06 3.2543e-06 3.3618e-06
   crystal router                : 3.97125e-06 3.9468e-06 3.9908e-06
   all reduce                    : 9.85658e-06 9.7844e-06 9.8952e-06
   handle bytes (avg, min, max): 3335 2484 4152
   buffer bytes (avg, min, max): 2076 1568 2664
gs_setup: 96 unique labels shared
   pairwise times (avg, min, max): 8.03052e-06 7.9335e-06 8.1011e-06
   crystal router                : 3.56828e-06 3.5204e-06 3.6189e-06
   all reduce                    : 6.4523e-06 6.3963e-06 6.5105e-06
   handle bytes (avg, min, max): 5404 5100 5568
   buffer bytes (avg, min, max): 2304 2256 2352
gs_setup: 59 unique labels shared
   pairwise times (avg, min, max): 3.0593e-06 2.967e-06 3.1159e-06
   crystal router                : 3.37507e-06 3.315e-06 3.443e-06
   all reduce                    : 8.04967e-06 8.032e-06 8.0607e-06
  handle bytes (avg, min, max): 1295 1288 1304
   buffer bytes (avg, min, max): 708 680 744
gs_setup: 31 unique labels shared
   pairwise times (avg, min, max): 2.94198e-06 2.8528e-06 2.9872e-06
   crystal router                : 2.7749e-06 2.6955e-06 2.8159e-06
   all reduce                    : 4.59447e-06 4.5455e-06 4.6566e-06
   handle bytes (avg, min, max): 2089 1864 2336
   buffer bytes (avg, min, max): 744 640 848
gs_setup: 7 unique labels shared
   pairwise times (avg, min, max): 2.88287e-06 2.8044e-06 2.9556e-06
   crystal router                : 2.52328e-06 2.4726e-06 2.5612e-06
   all reduce                    : 2.83837e-06 2.7564e-06 2.9157e-06
   handle bytes (avg, min, max): 865 832 888
   buffer bytes (avg, min, max): 168 160 176
done :: setup h1 coarse grid    2.36721729199780       sec
 call usrdat3
done :: usrdat3
set initial conditions
Checking restart options: turbChannel0.f00001
 nekuic (1) for ifld            1
Reading checkpoint data
       FILE:
turbChannel0.f00001
        0  2.0000E+02 done :: Read checkpoint data
                              avg data-throughput =     2.5MBps
                              io-nodes =     4
xyz min     0.0000      -1.0000       0.0000
 uvwpt min          NaN          NaN          NaN          NaN   0.0000
 PS min     0.99000E+22
xyz max     6.2832       1.0000       3.1416
 uvwpt max          NaN          NaN          NaN          NaN   0.0000
 PS max    -0.99000E+22
Restart: recompute geom. factors.
 done :: set initial conditions
 call userchk
   2.0000E+02          NaN          NaN monitor
Start collecting statistics ...
done :: userchk
gridpoints unique/tot:        533120       786432
  dofs:                520576                533120
 Initial time: 0.2000000E+03
Initialization successfully completed    13.736     sec
Starting time loop ...
WARNING: DT<0 or DTFS<0
          Reset DT
 WARNING: Set DT=0.001 (arbitrarily)
Final time step =   0.000000000000000E+000
   HPF : 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1.000000
             Solving for fluid
    1 1.00000E-04         NaN         NaN         NaN       1 Divergence
    2 1.00000E-04         NaN         NaN         NaN       1 Divergence
    3 1.00000E-04         NaN         NaN         NaN       1 Divergence
    4 1.00000E-04         NaN         NaN         NaN       1 Divergence
    5 1.00000E-04         NaN         NaN         NaN       1 Divergence
    6 1.00000E-04         NaN         NaN         NaN       1 Divergence
    7 1.00000E-04         NaN         NaN         NaN       1 Divergence
    8 1.00000E-04         NaN         NaN         NaN       1 Divergence
    9 1.00000E-04         NaN         NaN         NaN       1 Divergence
   10 1.00000E-04         NaN         NaN         NaN       1 Divergence
   11 1.00000E-04         NaN         NaN         NaN       1 Divergence
   12 1.00000E-04         NaN         NaN         NaN       1 Divergence
   13 1.00000E-04         NaN         NaN         NaN       1 Divergence
  14 1.00000E-04         NaN         NaN         NaN       1 Divergence
   15 1.00000E-04         NaN         NaN         NaN       1 Divergence
   16 1.00000E-04         NaN         NaN         NaN       1 Divergence
   17 1.00000E-04         NaN         NaN         NaN       1 Divergence
   18 1.00000E-04         NaN         NaN         NaN       1 Divergence
   19 1.00000E-04         NaN         NaN         NaN       1 Divergence
   20 1.00000E-04         NaN         NaN         NaN       1 Divergence
   21 1.00000E-04         NaN         NaN         NaN       1 Divergence
   22 1.00000E-04         NaN         NaN         NaN       1 Divergence
   23 1.00000E-04         NaN         NaN         NaN       1 Divergence
   24 1.00000E-04         NaN         NaN         NaN       1 Divergence
   25 1.00000E-04         NaN         NaN         NaN       1 Divergence
   26 1.00000E-04         NaN         NaN         NaN       1 Divergence
   27 1.00000E-04         NaN         NaN         NaN       1 Divergence
   28 1.00000E-04         NaN         NaN         NaN       1 Divergence
   29 1.00000E-04         NaN         NaN         NaN       1 Divergence
   30 1.00000E-04         NaN         NaN         NaN       1 Divergence
   31 1.00000E-04         NaN         NaN         NaN       1 Divergence
   32 1.00000E-04         NaN         NaN         NaN       1 Divergence
   33 1.00000E-04         NaN         NaN         NaN       1 Divergence
   34 1.00000E-04         NaN         NaN         NaN       1 Divergence
   35 1.00000E-04         NaN         NaN         NaN       1 Divergence
   36 1.00000E-04         NaN         NaN         NaN       1 Divergence
   37 1.00000E-04         NaN         NaN         NaN       1 Divergence
   38 1.00000E-04         NaN         NaN         NaN       1 Divergence
   39 1.00000E-04         NaN         NaN         NaN       1 Divergence
   40 1.00000E-04         NaN         NaN         NaN       1 Divergence
   41 1.00000E-04         NaN         NaN         NaN       1 Divergence
  42 1.00000E-04         NaN         NaN         NaN       1 Divergence
   43 1.00000E-04         NaN         NaN         NaN       1 Divergence
   44 1.00000E-04         NaN         NaN         NaN       1 Divergence
   45 1.00000E-04         NaN         NaN         NaN       1 Divergence
   46 1.00000E-04         NaN         NaN         NaN       1 Divergence
   47 1.00000E-04         NaN         NaN         NaN       1 Divergence
   48 1.00000E-04         NaN         NaN         NaN       1 Divergence
   49 1.00000E-04         NaN         NaN         NaN       1 Divergence
   50 1.00000E-04         NaN         NaN         NaN       1 Divergence
   51 1.00000E-04         NaN         NaN         NaN       1 Divergence
   52 1.00000E-04         NaN         NaN         NaN       1 Divergence
   53 1.00000E-04         NaN         NaN         NaN       1 Divergence
   54 1.00000E-04         NaN         NaN         NaN       1 Divergence
   55 1.00000E-04         NaN         NaN         NaN       1 Divergence
   56 1.00000E-04         NaN         NaN         NaN       1 Divergence
   57 1.00000E-04         NaN         NaN         NaN       1 Divergence
   58 1.00000E-04         NaN         NaN         NaN       1 Divergence
   59 1.00000E-04         NaN         NaN         NaN       1 Divergence
   60 1.00000E-04         NaN         NaN         NaN       1 Divergence
   61 1.00000E-04         NaN         NaN         NaN       1 Divergence
   62 1.00000E-04         NaN         NaN         NaN       1 Divergence
   63 1.00000E-04         NaN         NaN         NaN       1 Divergence
   64 1.00000E-04         NaN         NaN         NaN       1 Divergence
   65 1.00000E-04         NaN         NaN         NaN       1 Divergence
   66 1.00000E-04         NaN         NaN         NaN       1 Divergence
   67 1.00000E-04         NaN         NaN         NaN       1 Divergence
   68 1.00000E-04         NaN         NaN         NaN       1 Divergence
   69 1.00000E-04         NaN         NaN         NaN       1 Divergence
  70 1.00000E-04         NaN         NaN         NaN       1 Divergence
   71 1.00000E-04         NaN         NaN         NaN       1 Divergence
   72 1.00000E-04         NaN         NaN         NaN       1 Divergence
   73 1.00000E-04         NaN         NaN         NaN       1 Divergence
   74 1.00000E-04         NaN         NaN         NaN       1 Divergence
   75 1.00000E-04         NaN         NaN         NaN       1 Divergence
   76 1.00000E-04         NaN         NaN         NaN       1 Divergence
   77 1.00000E-04         NaN         NaN         NaN       1 Divergence
   78 1.00000E-04         NaN         NaN         NaN       1 Divergence
   79 1.00000E-04         NaN         NaN         NaN       1 Divergence
   80 1.00000E-04         NaN         NaN         NaN       1 Divergence
   81 1.00000E-04         NaN         NaN         NaN       1 Divergence
   82 1.00000E-04         NaN         NaN         NaN       1 Divergence
   83 1.00000E-04         NaN         NaN         NaN       1 Divergence
   84 1.00000E-04         NaN         NaN         NaN       1 Divergence
   85 1.00000E-04         NaN         NaN         NaN       1 Divergence
   86 1.00000E-04         NaN         NaN         NaN       1 Divergence
   87 1.00000E-04         NaN         NaN         NaN       1 Divergence
   88 1.00000E-04         NaN         NaN         NaN       1 Divergence
   89 1.00000E-04         NaN         NaN         NaN       1 Divergence
   90 1.00000E-04         NaN         NaN         NaN       1 Divergence
   91 1.00000E-04         NaN         NaN         NaN       1 Divergence
   92 1.00000E-04         NaN         NaN         NaN       1 Divergence
   93 1.00000E-04         NaN         NaN         NaN       1 Divergence
   94 1.00000E-04         NaN         NaN         NaN       1 Divergence
   95 1.00000E-04         NaN         NaN         NaN       1 Divergence
   96 1.00000E-04         NaN         NaN         NaN       1 Divergence
   97 1.00000E-04         NaN         NaN         NaN       1 Divergence
  98 1.00000E-04         NaN         NaN         NaN       1 Divergence
   99 1.00000E-04         NaN         NaN         NaN       1 Divergence
  100 1.00000E-04         NaN         NaN         NaN       1 Divergence
  101 1.00000E-04         NaN         NaN         NaN       1 Divergence
  102 1.00000E-04         NaN         NaN         NaN       1 Divergence
  103 1.00000E-04         NaN         NaN         NaN       1 Divergence
  104 1.00000E-04         NaN         NaN         NaN       1 Divergence
  105 1.00000E-04         NaN         NaN         NaN       1 Divergence
  106 1.00000E-04         NaN         NaN         NaN       1 Divergence
  107 1.00000E-04         NaN         NaN         NaN       1 Divergence
  108 1.00000E-04         NaN         NaN         NaN       1 Divergence
  109 1.00000E-04         NaN         NaN         NaN       1 Divergence
  110 1.00000E-04         NaN         NaN         NaN       1 Divergence
  111 1.00000E-04         NaN         NaN         NaN       1 Divergence
  112 1.00000E-04         NaN         NaN         NaN       1 Divergence
  113 1.00000E-04         NaN         NaN         NaN       1 Divergence
  114 1.00000E-04         NaN         NaN         NaN       1 Divergence
  115 1.00000E-04         NaN         NaN         NaN       1 Divergence
  116 1.00000E-04         NaN         NaN         NaN       1 Divergence
  117 1.00000E-04         NaN         NaN         NaN       1 Divergence
  118 1.00000E-04         NaN         NaN         NaN       1 Divergence
  119 1.00000E-04         NaN         NaN         NaN       1 Divergence
  120 1.00000E-04         NaN         NaN         NaN       1 Divergence
  121 1.00000E-04         NaN         NaN         NaN       1 Divergence
  122 1.00000E-04         NaN         NaN         NaN       1 Divergence
  123 1.00000E-04         NaN         NaN         NaN       1 Divergence
  124 1.00000E-04         NaN         NaN         NaN       1 Divergence
  125 1.00000E-04         NaN         NaN         NaN       1 Divergence
  126 1.00000E-04         NaN         NaN         NaN       1 Divergence
  127 1.00000E-04         NaN         NaN         NaN       1 Divergence
  128 1.00000E-04         NaN         NaN         NaN       1 Divergence
 129 1.00000E-04         NaN         NaN         NaN       1 Divergence
  130 1.00000E-04         NaN         NaN         NaN       1 Divergence
  131 1.00000E-04         NaN         NaN         NaN       1 Divergence
  132 1.00000E-04         NaN         NaN         NaN       1 Divergence
  133 1.00000E-04         NaN         NaN         NaN       1 Divergence
  134 1.00000E-04         NaN         NaN         NaN       1 Divergence
  135 1.00000E-04         NaN         NaN         NaN       1 Divergence
  136 1.00000E-04         NaN         NaN         NaN       1 Divergence
  137 1.00000E-04         NaN         NaN         NaN       1 Divergence
  138 1.00000E-04         NaN         NaN         NaN       1 Divergence
  139 1.00000E-04         NaN         NaN         NaN       1 Divergence
  140 1.00000E-04         NaN         NaN         NaN       1 Divergence
  141 1.00000E-04         NaN         NaN         NaN       1 Divergence
  142 1.00000E-04         NaN         NaN         NaN       1 Divergence
  143 1.00000E-04         NaN         NaN         NaN       1 Divergence
  144 1.00000E-04         NaN         NaN         NaN       1 Divergence
  145 1.00000E-04         NaN         NaN         NaN       1 Divergence
  146 1.00000E-04         NaN         NaN         NaN       1 Divergence
  147 1.00000E-04         NaN         NaN         NaN       1 Divergence
  148 1.00000E-04         NaN         NaN         NaN       1 Divergence
  149 1.00000E-04         NaN         NaN         NaN       1 Divergence
  150 1.00000E-04         NaN         NaN         NaN       1 Divergence
  151 1.00000E-04         NaN         NaN         NaN       1 Divergence
  152 1.00000E-04         NaN         NaN         NaN       1 Divergence
  153 1.00000E-04         NaN         NaN         NaN       1 Divergence
  154 1.00000E-04         NaN         NaN         NaN       1 Divergence
  155 1.00000E-04         NaN         NaN         NaN       1 Divergence
  156 1.00000E-04         NaN         NaN         NaN       1 Divergence
 157 1.00000E-04         NaN         NaN         NaN       1 Divergence
  158 1.00000E-04         NaN         NaN         NaN       1 Divergence
  159 1.00000E-04         NaN         NaN         NaN       1 Divergence
  160 1.00000E-04         NaN         NaN         NaN       1 Divergence
  161 1.00000E-04         NaN         NaN         NaN       1 Divergence
  162 1.00000E-04         NaN         NaN         NaN       1 Divergence
  163 1.00000E-04         NaN         NaN         NaN       1 Divergence
  164 1.00000E-04         NaN         NaN         NaN       1 Divergence
  165 1.00000E-04         NaN         NaN         NaN       1 Divergence
  166 1.00000E-04         NaN         NaN         NaN       1 Divergence
  167 1.00000E-04         NaN         NaN         NaN       1 Divergence
  168 1.00000E-04         NaN         NaN         NaN       1 Divergence
  169 1.00000E-04         NaN         NaN         NaN       1 Divergence
  170 1.00000E-04         NaN         NaN         NaN       1 Divergence
  171 1.00000E-04         NaN         NaN         NaN       1 Divergence
  172 1.00000E-04         NaN         NaN         NaN       1 Divergence
  173 1.00000E-04         NaN         NaN         NaN       1 Divergence
  174 1.00000E-04         NaN         NaN         NaN       1 Divergence
  175 1.00000E-04         NaN         NaN         NaN       1 Divergence
  176 1.00000E-04         NaN         NaN         NaN       1 Divergence
  177 1.00000E-04         NaN         NaN         NaN       1 Divergence
  178 1.00000E-04         NaN         NaN         NaN       1 Divergence
  179 1.00000E-04         NaN         NaN         NaN       1 Divergence
  180 1.00000E-04         NaN         NaN         NaN       1 Divergence
  181 1.00000E-04         NaN         NaN         NaN       1 Divergence
  182 1.00000E-04         NaN         NaN         NaN       1 Divergence
  183 1.00000E-04         NaN         NaN         NaN       1 Divergence
  184 1.00000E-04         NaN         NaN         NaN       1 Divergence
 185 1.00000E-04         NaN         NaN         NaN       1 Divergence
  186 1.00000E-04         NaN         NaN         NaN       1 Divergence
  187 1.00000E-04         NaN         NaN         NaN       1 Divergence
  188 1.00000E-04         NaN         NaN         NaN       1 Divergence
  189 1.00000E-04         NaN         NaN         NaN       1 Divergence
  190 1.00000E-04         NaN         NaN         NaN       1 Divergence
  191 1.00000E-04         NaN         NaN         NaN       1 Divergence
  192 1.00000E-04         NaN         NaN         NaN       1 Divergence
  193 1.00000E-04         NaN         NaN         NaN       1 Divergence
  194 1.00000E-04         NaN         NaN         NaN       1 Divergence
  195 1.00000E-04         NaN         NaN         NaN       1 Divergence
  196 1.00000E-04         NaN         NaN         NaN       1 Divergence
  197 1.00000E-04         NaN         NaN         NaN       1 Divergence
  198 1.00000E-04         NaN         NaN         NaN       1 Divergence
  199 1.00000E-04         NaN         NaN         NaN       1 Divergence
  200 1.00000E-04         NaN         NaN         NaN       1 Divergence
  201 1.00000E-04         NaN         NaN         NaN       1 Divergence
  202 1.00000E-04         NaN         NaN         NaN       1 Divergence
  203 1.00000E-04         NaN         NaN         NaN       1 Divergence
  204 1.00000E-04         NaN         NaN         NaN       1 Divergence
  205 1.00000E-04         NaN         NaN         NaN       1 Divergence
  206 1.00000E-04         NaN         NaN         NaN       1 Divergence
  207 1.00000E-04         NaN         NaN         NaN       1 Divergence
  208 1.00000E-04         NaN         NaN         NaN       1 Divergence
  209 1.00000E-04         NaN         NaN         NaN       1 Divergence
  210 1.00000E-04         NaN         NaN         NaN       1 Divergence
  211 1.00000E-04         NaN         NaN         NaN       1 Divergence
  212 1.00000E-04         NaN         NaN         NaN       1 Divergence
  213 1.00000E-04         NaN         NaN         NaN       1 Divergence
  214 1.00000E-04         NaN         NaN         NaN       1 Divergence
  215 1.00000E-04         NaN         NaN         NaN       1 Divergence
 216 1.00000E-04         NaN         NaN         NaN       1 Divergence
  217 1.00000E-04         NaN         NaN         NaN       1 Divergence
  218 1.00000E-04         NaN         NaN         NaN       1 Divergence
  219 1.00000E-04         NaN         NaN         NaN       1 Divergence
  220 1.00000E-04         NaN         NaN         NaN       1 Divergence
  221 1.00000E-04         NaN         NaN         NaN       1 Divergence
  222 1.00000E-04         NaN         NaN         NaN       1 Divergence
  223 1.00000E-04         NaN         NaN         NaN       1 Divergence
  224 1.00000E-04         NaN         NaN         NaN       1 Divergence
  225 1.00000E-04         NaN         NaN         NaN       1 Divergence
  226 1.00000E-04         NaN         NaN         NaN       1 Divergence
  227 1.00000E-04         NaN         NaN         NaN       1 Divergence
  228 1.00000E-04         NaN         NaN         NaN       1 Divergence
  229 1.00000E-04         NaN         NaN         NaN       1 Divergence
  230 1.00000E-04         NaN         NaN         NaN       1 Divergence
  231 1.00000E-04         NaN         NaN         NaN       1 Divergence
  232 1.00000E-04         NaN         NaN         NaN       1 Divergence
  233 1.00000E-04         NaN         NaN         NaN       1 Divergence
  234 1.00000E-04         NaN         NaN         NaN       1 Divergence
  235 1.00000E-04         NaN         NaN         NaN       1 Divergence
  236 1.00000E-04         NaN         NaN         NaN       1 Divergence
  237 1.00000E-04         NaN         NaN         NaN       1 Divergence
  238 1.00000E-04         NaN         NaN         NaN       1 Divergence
  239 1.00000E-04         NaN         NaN         NaN       1 Divergence
  240 1.00000E-04         NaN         NaN         NaN       1 Divergence
  241 1.00000E-04         NaN         NaN         NaN       1 Divergence
  242 1.00000E-04         NaN         NaN         NaN       1 Divergence
  243 1.00000E-04         NaN         NaN         NaN       1 Divergence
 244 1.00000E-04         NaN         NaN         NaN       1 Divergence
  245 1.00000E-04         NaN         NaN         NaN       1 Divergence
  246 1.00000E-04         NaN         NaN         NaN       1 Divergence
  247 1.00000E-04         NaN         NaN         NaN       1 Divergence
  248 1.00000E-04         NaN         NaN         NaN       1 Divergence
  249 1.00000E-04         NaN         NaN         NaN       1 Divergence
  250 1.00000E-04         NaN         NaN         NaN       1 Divergence
  251 1.00000E-04         NaN         NaN         NaN       1 Divergence
  252 1.00000E-04         NaN         NaN         NaN       1 Divergence
  253 1.00000E-04         NaN         NaN         NaN       1 Divergence
  254 1.00000E-04         NaN         NaN         NaN       1 Divergence
  255 1.00000E-04         NaN         NaN         NaN       1 Divergence
  256 1.00000E-04         NaN         NaN         NaN       1 Divergence
  257 1.00000E-04         NaN         NaN         NaN       1 Divergence
  258 1.00000E-04         NaN         NaN         NaN       1 Divergence
  259 1.00000E-04         NaN         NaN         NaN       1 Divergence
  260 1.00000E-04         NaN         NaN         NaN       1 Divergence
  261 1.00000E-04         NaN         NaN         NaN       1 Divergence
  262 1.00000E-04         NaN         NaN         NaN       1 Divergence
  263 1.00000E-04         NaN         NaN         NaN       1 Divergence
  264 1.00000E-04         NaN         NaN         NaN       1 Divergence
  265 1.00000E-04         NaN         NaN         NaN       1 Divergence
  266 1.00000E-04         NaN         NaN         NaN       1 Divergence
  267 1.00000E-04         NaN         NaN         NaN       1 Divergence
  268 1.00000E-04         NaN         NaN         NaN       1 Divergence
  269 1.00000E-04         NaN         NaN         NaN       1 Divergence
  270 1.00000E-04         NaN         NaN         NaN       1 Divergence
  271 1.00000E-04         NaN         NaN         NaN       1 Divergence
 272 1.00000E-04         NaN         NaN         NaN       1 Divergence
  273 1.00000E-04         NaN         NaN         NaN       1 Divergence
  274 1.00000E-04         NaN         NaN         NaN       1 Divergence
  275 1.00000E-04         NaN         NaN         NaN       1 Divergence
  276 1.00000E-04         NaN         NaN         NaN       1 Divergence
  277 1.00000E-04         NaN         NaN         NaN       1 Divergence
  278 1.00000E-04         NaN         NaN         NaN       1 Divergence
  279 1.00000E-04         NaN         NaN         NaN       1 Divergence
  280 1.00000E-04         NaN         NaN         NaN       1 Divergence
  281 1.00000E-04         NaN         NaN         NaN       1 Divergence
  282 1.00000E-04         NaN         NaN         NaN       1 Divergence
  283 1.00000E-04         NaN         NaN         NaN       1 Divergence
  284 1.00000E-04         NaN         NaN         NaN       1 Divergence
  285 1.00000E-04         NaN         NaN         NaN       1 Divergence
  286 1.00000E-04         NaN         NaN         NaN       1 Divergence
  287 1.00000E-04         NaN         NaN         NaN       1 Divergence
  288 1.00000E-04         NaN         NaN         NaN       1 Divergence
  289 1.00000E-04         NaN         NaN         NaN       1 Divergence
  290 1.00000E-04         NaN         NaN         NaN       1 Divergence
  291 1.00000E-04         NaN         NaN         NaN       1 Divergence
  292 1.00000E-04         NaN         NaN         NaN       1 Divergence
  293 1.00000E-04         NaN         NaN         NaN       1 Divergence
  294 1.00000E-04         NaN         NaN         NaN       1 Divergence
  295 1.00000E-04         NaN         NaN         NaN       1 Divergence
  296 1.00000E-04         NaN         NaN         NaN       1 Divergence
  297 1.00000E-04         NaN         NaN         NaN       1 Divergence
  298 1.00000E-04         NaN         NaN         NaN       1 Divergence
  299 1.00000E-04         NaN         NaN         NaN       1 Divergence
  300 1.00000E-04         NaN         NaN         NaN       1 Divergence
  301 1.00000E-04         NaN         NaN         NaN       1 Divergence
  302 1.00000E-04         NaN         NaN         NaN       1 Divergence
 303 1.00000E-04         NaN         NaN         NaN       1 Divergence
  304 1.00000E-04         NaN         NaN         NaN       1 Divergence
  305 1.00000E-04         NaN         NaN         NaN       1 Divergence
  306 1.00000E-04         NaN         NaN         NaN       1 Divergence
  307 1.00000E-04         NaN         NaN         NaN       1 Divergence
  308 1.00000E-04         NaN         NaN         NaN       1 Divergence
  309 1.00000E-04         NaN         NaN         NaN       1 Divergence
  310 1.00000E-04         NaN         NaN         NaN       1 Divergence
  311 1.00000E-04         NaN         NaN         NaN       1 Divergence
  312 1.00000E-04         NaN         NaN         NaN       1 Divergence
  313 1.00000E-04         NaN         NaN         NaN       1 Divergence
  314 1.00000E-04         NaN         NaN         NaN       1 Divergence
  315 1.00000E-04         NaN         NaN         NaN       1 Divergence
  316 1.00000E-04         NaN         NaN         NaN       1 Divergence
  317 1.00000E-04         NaN         NaN         NaN       1 Divergence
  318 1.00000E-04         NaN         NaN         NaN       1 Divergence
  319 1.00000E-04         NaN         NaN         NaN       1 Divergence
  320 1.00000E-04         NaN         NaN         NaN       1 Divergence
  321 1.00000E-04         NaN         NaN         NaN       1 Divergence
  322 1.00000E-04         NaN         NaN         NaN       1 Divergence
  323 1.00000E-04         NaN         NaN         NaN       1 Divergence
  324 1.00000E-04         NaN         NaN         NaN       1 Divergence
  325 1.00000E-04         NaN         NaN         NaN       1 Divergence
  326 1.00000E-04         NaN         NaN         NaN       1 Divergence
  327 1.00000E-04         NaN         NaN         NaN       1 Divergence
  328 1.00000E-04         NaN         NaN         NaN       1 Divergence
  329 1.00000E-04         NaN         NaN         NaN       1 Divergence
  330 1.00000E-04         NaN         NaN         NaN       1 Divergence
 331 1.00000E-04         NaN         NaN         NaN       1 Divergence
  332 1.00000E-04         NaN         NaN         NaN       1 Divergence
  333 1.00000E-04         NaN         NaN         NaN       1 Divergence
  334 1.00000E-04         NaN         NaN         NaN       1 Divergence
  335 1.00000E-04         NaN         NaN         NaN       1 Divergence
  336 1.00000E-04         NaN         NaN         NaN       1 Divergence
  337 1.00000E-04         NaN         NaN         NaN       1 Divergence
  338 1.00000E-04         NaN         NaN         NaN       1 Divergence
  339 1.00000E-04         NaN         NaN         NaN       1 Divergence
  340 1.00000E-04         NaN         NaN         NaN       1 Divergence
  341 1.00000E-04         NaN         NaN         NaN       1 Divergence
  342 1.00000E-04         NaN         NaN         NaN       1 Divergence
  343 1.00000E-04         NaN         NaN         NaN       1 Divergence
  344 1.00000E-04         NaN         NaN         NaN       1 Divergence
  345 1.00000E-04         NaN         NaN         NaN       1 Divergence
  346 1.00000E-04         NaN         NaN         NaN       1 Divergence
  347 1.00000E-04         NaN         NaN         NaN       1 Divergence
  348 1.00000E-04         NaN         NaN         NaN       1 Divergence
  349 1.00000E-04         NaN         NaN         NaN       1 Divergence
  350 1.00000E-04         NaN         NaN         NaN       1 Divergence
  351 1.00000E-04         NaN         NaN         NaN       1 Divergence
  352 1.00000E-04         NaN         NaN         NaN       1 Divergence
  353 1.00000E-04         NaN         NaN         NaN       1 Divergence
  354 1.00000E-04         NaN         NaN         NaN       1 Divergence
  355 1.00000E-04         NaN         NaN         NaN       1 Divergence
  356 1.00000E-04         NaN         NaN         NaN       1 Divergence
  357 1.00000E-04         NaN         NaN         NaN       1 Divergence
  358 1.00000E-04         NaN         NaN         NaN       1 Divergence
 359 1.00000E-04         NaN         NaN         NaN       1 Divergence
  360 1.00000E-04         NaN         NaN         NaN       1 Divergence
  361 1.00000E-04         NaN         NaN         NaN       1 Divergence
  362 1.00000E-04         NaN         NaN         NaN       1 Divergence
  363 1.00000E-04         NaN         NaN         NaN       1 Divergence
  364 1.00000E-04         NaN         NaN         NaN       1 Divergence
  365 1.00000E-04         NaN         NaN         NaN       1 Divergence
  366 1.00000E-04         NaN         NaN         NaN       1 Divergence
  367 1.00000E-04         NaN         NaN         NaN       1 Divergence
  368 1.00000E-04         NaN         NaN         NaN       1 Divergence
  369 1.00000E-04         NaN         NaN         NaN       1 Divergence
  370 1.00000E-04         NaN         NaN         NaN       1 Divergence
  371 1.00000E-04         NaN         NaN         NaN       1 Divergence
  372 1.00000E-04         NaN         NaN         NaN       1 Divergence
  373 1.00000E-04         NaN         NaN         NaN       1 Divergence
  374 1.00000E-04         NaN         NaN         NaN       1 Divergence
  375 1.00000E-04         NaN         NaN         NaN       1 Divergence
  376 1.00000E-04         NaN         NaN         NaN       1 Divergence
  377 1.00000E-04         NaN         NaN         NaN       1 Divergence
  378 1.00000E-04         NaN         NaN         NaN       1 Divergence
  379 1.00000E-04         NaN         NaN         NaN       1 Divergence
  380 1.00000E-04         NaN         NaN         NaN       1 Divergence
  381 1.00000E-04         NaN         NaN         NaN       1 Divergence
  382 1.00000E-04         NaN         NaN         NaN       1 Divergence
  383 1.00000E-04         NaN         NaN         NaN       1 Divergence
  384 1.00000E-04         NaN         NaN         NaN       1 Divergence
  385 1.00000E-04         NaN         NaN         NaN       1 Divergence
  386 1.00000E-04         NaN         NaN         NaN       1 Divergence
  387 1.00000E-04         NaN         NaN         NaN       1 Divergence
  388 1.00000E-04         NaN         NaN         NaN       1 Divergence
  389 1.00000E-04         NaN         NaN         NaN       1 Divergence
 390 1.00000E-04         NaN         NaN         NaN       1 Divergence
  391 1.00000E-04         NaN         NaN         NaN       1 Divergence
  392 1.00000E-04         NaN         NaN         NaN       1 Divergence
  393 1.00000E-04         NaN         NaN         NaN       1 Divergence
  394 1.00000E-04         NaN         NaN         NaN       1 Divergence
  395 1.00000E-04         NaN         NaN         NaN       1 Divergence
  396 1.00000E-04         NaN         NaN         NaN       1 Divergence
  397 1.00000E-04         NaN         NaN         NaN       1 Divergence
  398 1.00000E-04         NaN         NaN         NaN       1 Divergence
  399 1.00000E-04         NaN         NaN         NaN       1 Divergence
  400 1.00000E-04         NaN         NaN         NaN       1 Divergence
  401 1.00000E-04         NaN         NaN         NaN       1 Divergence
  402 1.00000E-04         NaN         NaN         NaN       1 Divergence
  403 1.00000E-04         NaN         NaN         NaN       1 Divergence
  404 1.00000E-04         NaN         NaN         NaN       1 Divergence
  405 1.00000E-04         NaN         NaN         NaN       1 Divergence
  406 1.00000E-04         NaN         NaN         NaN       1 Divergence
  407 1.00000E-04         NaN         NaN         NaN       1 Divergence
  408 1.00000E-04         NaN         NaN         NaN       1 Divergence
  409 1.00000E-04         NaN         NaN         NaN       1 Divergence
  410 1.00000E-04         NaN         NaN         NaN       1 Divergence
  411 1.00000E-04         NaN         NaN         NaN       1 Divergence
  412 1.00000E-04         NaN         NaN         NaN       1 Divergence
  413 1.00000E-04         NaN         NaN         NaN       1 Divergence
  414 1.00000E-04         NaN         NaN         NaN       1 Divergence
  415 1.00000E-04         NaN         NaN         NaN       1 Divergence
  416 1.00000E-04         NaN         NaN         NaN       1 Divergence
  417 1.00000E-04         NaN         NaN         NaN       1 Divergence
 418 1.00000E-04         NaN         NaN         NaN       1 Divergence
  419 1.00000E-04         NaN         NaN         NaN       1 Divergence
  420 1.00000E-04         NaN         NaN         NaN       1 Divergence
  421 1.00000E-04         NaN         NaN         NaN       1 Divergence
  422 1.00000E-04         NaN         NaN         NaN       1 Divergence
  423 1.00000E-04         NaN         NaN         NaN       1 Divergence
  424 1.00000E-04         NaN         NaN         NaN       1 Divergence
  425 1.00000E-04         NaN         NaN         NaN       1 Divergence
  426 1.00000E-04         NaN         NaN         NaN       1 Divergence
  427 1.00000E-04         NaN         NaN         NaN       1 Divergence
  428 1.00000E-04         NaN         NaN         NaN       1 Divergence
  429 1.00000E-04         NaN         NaN         NaN       1 Divergence
  430 1.00000E-04         NaN         NaN         NaN       1 Divergence
  431 1.00000E-04         NaN         NaN         NaN       1 Divergence
  432 1.00000E-04         NaN         NaN         NaN       1 Divergence
  433 1.00000E-04         NaN         NaN         NaN       1 Divergence
  434 1.00000E-04         NaN         NaN         NaN       1 Divergence
  435 1.00000E-04         NaN         NaN         NaN       1 Divergence
  436 1.00000E-04         NaN         NaN         NaN       1 Divergence
  437 1.00000E-04         NaN         NaN         NaN       1 Divergence
  438 1.00000E-04         NaN         NaN         NaN       1 Divergence
  439 1.00000E-04         NaN         NaN         NaN       1 Divergence
  440 1.00000E-04         NaN         NaN         NaN       1 Divergence
  441 1.00000E-04         NaN         NaN         NaN       1 Divergence
  442 1.00000E-04         NaN         NaN         NaN       1 Divergence
  443 1.00000E-04         NaN         NaN         NaN       1 Divergence
  444 1.00000E-04         NaN         NaN         NaN       1 Divergence
  445 1.00000E-04         NaN         NaN         NaN       1 Divergence
 446 1.00000E-04         NaN         NaN         NaN       1 Divergence
  447 1.00000E-04         NaN         NaN         NaN       1 Divergence
  448 1.00000E-04         NaN         NaN         NaN       1 Divergence
  449 1.00000E-04         NaN         NaN         NaN       1 Divergence
  450 1.00000E-04         NaN         NaN         NaN       1 Divergence
  451 1.00000E-04         NaN         NaN         NaN       1 Divergence
  452 1.00000E-04         NaN         NaN         NaN       1 Divergence
  453 1.00000E-04         NaN         NaN         NaN       1 Divergence
  454 1.00000E-04         NaN         NaN         NaN       1 Divergence
  455 1.00000E-04         NaN         NaN         NaN       1 Divergence
  456 1.00000E-04         NaN         NaN         NaN       1 Divergence
  457 1.00000E-04         NaN         NaN         NaN       1 Divergence
  458 1.00000E-04         NaN         NaN         NaN       1 Divergence
  459 1.00000E-04         NaN         NaN         NaN       1 Divergence
  460 1.00000E-04         NaN         NaN         NaN       1 Divergence
  461 1.00000E-04         NaN         NaN         NaN       1 Divergence
  462 1.00000E-04         NaN         NaN         NaN       1 Divergence
  463 1.00000E-04         NaN         NaN         NaN       1 Divergence
  464 1.00000E-04         NaN         NaN         NaN       1 Divergence
  465 1.00000E-04         NaN         NaN         NaN       1 Divergence
  466 1.00000E-04         NaN         NaN         NaN       1 Divergence
  467 1.00000E-04         NaN         NaN         NaN       1 Divergence
  468 1.00000E-04         NaN         NaN         NaN       1 Divergence
  469 1.00000E-04         NaN         NaN         NaN       1 Divergence
  470 1.00000E-04         NaN         NaN         NaN       1 Divergence
  471 1.00000E-04         NaN         NaN         NaN       1 Divergence
  472 1.00000E-04         NaN         NaN         NaN       1 Divergence
  473 1.00000E-04         NaN         NaN         NaN       1 Divergence
  474 1.00000E-04         NaN         NaN         NaN       1 Divergence
  475 1.00000E-04         NaN         NaN         NaN       1 Divergence
  476 1.00000E-04         NaN         NaN         NaN       1 Divergence
 477 1.00000E-04         NaN         NaN         NaN       1 Divergence
  478 1.00000E-04         NaN         NaN         NaN       1 Divergence
  479 1.00000E-04         NaN         NaN         NaN       1 Divergence
  480 1.00000E-04         NaN         NaN         NaN       1 Divergence
  481 1.00000E-04         NaN         NaN         NaN       1 Divergence
  482 1.00000E-04         NaN         NaN         NaN       1 Divergence
  483 1.00000E-04         NaN         NaN         NaN       1 Divergence
  484 1.00000E-04         NaN         NaN         NaN       1 Divergence
  485 1.00000E-04         NaN         NaN         NaN       1 Divergence
  486 1.00000E-04         NaN         NaN         NaN       1 Divergence
  487 1.00000E-04         NaN         NaN         NaN       1 Divergence
  488 1.00000E-04         NaN         NaN         NaN       1 Divergence
  489 1.00000E-04         NaN         NaN         NaN       1 Divergence
  490 1.00000E-04         NaN         NaN         NaN       1 Divergence
  491 1.00000E-04         NaN         NaN         NaN       1 Divergence
  492 1.00000E-04         NaN         NaN         NaN       1 Divergence
  493 1.00000E-04         NaN         NaN         NaN       1 Divergence
  494 1.00000E-04         NaN         NaN         NaN       1 Divergence
  495 1.00000E-04         NaN         NaN         NaN       1 Divergence
  496 1.00000E-04         NaN         NaN         NaN       1 Divergence
  497 1.00000E-04         NaN         NaN         NaN       1 Divergence
  498 1.00000E-04         NaN         NaN         NaN       1 Divergence
  499 1.00000E-04         NaN         NaN         NaN       1 Divergence
  500 1.00000E-04         NaN         NaN         NaN       1 Divergence
          1  PRES gmres       500          NaN          NaN   1.0000E-04   1.3084E+01   2.1669E+01    F
          1  Hmholtz VELX       1          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX       2          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX       3          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX       4          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX       5          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX       6          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX       7          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX       8          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX       9          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      10          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      11          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      12          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      13          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      14          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      15          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      16          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      17          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      18          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      19          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      20          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      21          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      22          NaN   3.3898E-04   1.0000E-07     Infinity   F
         1  Hmholtz VELX      23          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      24          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      25          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      26          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      27          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      28          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      29          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      30          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      31          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      32          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      33          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      34          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      35          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      36          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      37          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      38          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      39          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      40          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      41          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      42          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      43          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      44          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      45          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      46          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      47          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      48          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      49          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      50          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      51          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      52          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      53          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      54          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      55          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      56          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      57          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      58          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      59          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      60          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      61          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      62          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      63          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      64          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      65          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      66          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      67          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      68          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      69          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      70          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      71          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      72          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      73          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      74          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      75          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      76          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      77          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      78          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      79          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      80          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      81          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      82          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      83          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      84          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      85          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      86          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      87          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      88          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      89          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      90          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      91          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      92          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      93          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      94          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      95          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      96          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      97          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      98          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX      99          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELX     100          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Error Hmholtz VELX     100          NaN          NaN   1.0000E-07
          1  Hmholtz VELY       1          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY       2          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY       3          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY       4          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY       5          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY       6          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY       7          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY       8          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY       9          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      10          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      11          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      12          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      13          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      14          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      15          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      16          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      17          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      18          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      19          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      20          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      21          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      22          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      23          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      24          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      25          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      26          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      27          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      28          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      29          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      30          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      31          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      32          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      33          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      34          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      35          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      36          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      37          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      38          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      39          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      40          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      41          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      42          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      43          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      44          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      45          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      46          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      47          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      48          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      49          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      50          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      51          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      52          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      53          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      54          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      55          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      56          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      57          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      58          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      59          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      60          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      61          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      62          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      63          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      64          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      65          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      66          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      67          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      68          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      69          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      70          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      71          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      72          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      73          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      74          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      75          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      76          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      77          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      78          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      79          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      80          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      81          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      82          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      83          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      84          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      85          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      86          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      87          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      88          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      89          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      90          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      91          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      92          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      93          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      94          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      95          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      96          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      97          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      98          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY      99          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY     100          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Error Hmholtz VELY     100          NaN          NaN   1.0000E-07
          1  Hmholtz VELZ       1          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ       2          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ       3          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ       4          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ       5          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ       6          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ       7          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ       8          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ       9          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      10          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      11          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      12          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      13          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      14          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      15          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      16          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      17          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      18          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      19          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      20          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      21          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      22          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      23          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      24          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      25          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      26          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      27          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      28          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      29          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      30          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      31          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      32          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      33          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      34          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      35          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      36          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      37          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      38          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      39          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      40          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      41          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      42          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      43          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      44          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      45          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      46          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      47          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      48          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      49          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      50          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      51          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      52          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      53          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      54          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      55          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      56          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      57          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      58          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      59          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      60          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      61          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      62          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      63          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      64          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      65          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      66          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      67          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      68          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      69          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      70          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      71          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      72          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      73          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      74          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      75          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      76          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      77          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      78          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      79          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      80          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      81          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      82          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      83          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      84          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      85          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      86          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      87          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      88          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      89          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      90          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      91          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      92          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      93          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      94          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      95          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      96          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      97          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      98          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ      99          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ     100          NaN   3.3898E-04   1.0000E-07     Infinity   F
          1  Error Hmholtz VELZ     100          NaN          NaN   1.0000E-07
    1 1.00000E-04 1.04290E-15 1.48092E-15 7.04224E-01       1 Divergence
          1  PRES gmres         1   1.0429E-15   1.4809E-15   1.0000E-04   2.3331E-02   5.0854E-02    F
          1  Hmholtz VELX       1   9.9982E-01   3.3898E-04   1.0000E-07     Infinity   F
          1  Error Hmholtz VELX     100          NaN   9.9982E-01   1.0000E-07
          1  Hmholtz VELY       1   8.0937E-16   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELY       0   8.0937E-16   8.0937E-16   1.0000E-07
          1  Hmholtz VELZ       1   7.1883E-16   3.3898E-04   1.0000E-07     Infinity   F
          1  Hmholtz VELZ       0   7.1883E-16   7.1883E-16   1.0000E-07
          1  volflow X                     NaN          NaN          NaN   6.2832E+00
             L1/L2 DIV(V)                  NaN          NaN
             L1/L2 QTL              0.0000E+00   0.0000E+00
             L1/L2 DIV(V)-QTL              NaN          NaN
          1  Fluid done  2.0000E+02  2.6895E+01
filt amp 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.5000
filt trn 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 0.5000
       1 sfilt:         NaN     vortx
        1  2.0000E+02 Write checkpoint
       FILE:
/global/home/hpc4076/Nek5000/run/turbChannel/turbChannel0.f00001
        1  2.0000E+02 done :: Write checkpoint
                              file size =      21.    MB
                              avg data-throughput =    11.3MB/s
                              io-nodes =     4
end of time-step loop
runtime statistics:
init time   13.7358070529990       0.462004458987539
 prep time           1   1.87108852800156       6.293414284007534E-002
pres time           1   21.7905451879997       0.732925921409712
 crsl time         501  0.183691413072665       6.178468552291153E-003
crsl min   0.183063570999366
 crsl max   0.260289230038325
 crsl avg   0.221352905275126
 hmhz time           6   4.94836180700077       0.166438361480831
 eslv time           0  0.000000000000000E+000  0.000000000000000E+000
proj time           0  0.000000000000000E+000  0.000000000000000E+000
usvp time           2  8.829280013742391E-004  2.969732117129529E-005
usfq time           0  1.237174799825880E-002  4.161242742134884E-004
usbc time           1  2.739972998824669E-003  9.215910925933331E-005
usbc min   2.302368000528077E-003
usbc max   1.831457500156830E-002
usb  avg   6.439937250434014E-003
mltd time           3  1.305026299814926E-002  4.389461553180925E-004
cdtp time           4  1.176028400368523E-002  3.955576565467353E-004
axhm time         945   6.36171776202173       0.213976649608845
 advc time           1  0.178863899000135       6.016094909539131E-003
mxmf time  0.000000000000000E+000  0.000000000000000E+000
adc3 time  0.000000000000000E+000  0.000000000000000E+000
col2 time  0.000000000000000E+000  0.000000000000000E+000
col3 time  0.000000000000000E+000  0.000000000000000E+000
a2s2 time  0.000000000000000E+000  0.000000000000000E+000
add2 time  0.000000000000000E+000  0.000000000000000E+000
invc time  0.000000000000000E+000  0.000000000000000E+000
tgop time        2480   1.02037628088146       3.432039994398663E-002
dadd time           0   3.58888928988017       0.120712445096209
 vdss time           4  6.298328000411857E-003  2.118445322600121E-004
vdss min   6.298328000411857E-003
vdss max   2.789256400137674E-002
vdss avg   2.080069274961716E-002
dsum time        1463   1.95680818695473       6.581732724317946E-002
dsum min    1.52674149705126
 dsum max    2.28399024302780
 dsum avg    1.90933237102490
 ddsl time           0  0.000000000000000E+000  0.000000000000000E+000
#  nid       tusbc       tdadd       tcrsl       tvdss       tdsum        tgop    qqq    F
           0  2.7400E-03  3.5889E+00  1.8369E-01  6.2983E-03  1.9568E+00  1.0204E+00 qqq
           1  2.3024E-03  3.7084E+00  2.5837E-01  2.7040E-02  1.8698E+00  1.7594E+00 qqq
           2  1.8315E-02  3.7437E+00  2.6029E-01  2.1972E-02  1.5267E+00  1.9577E+00 qqq
           3  2.4028E-03  3.6736E+00  1.8306E-01  2.7893E-02  2.2840E+00  1.0771E+00 qqq
run successful: dying ...
total elapsed time             :   4.35605E+01 sec
total solver time w/o IO       :   2.78598E+01 sec
time/timestep                  :   2.78598E+01 sec
avg throughput per timestep    :   4.78395E+03 gridpts/CPUs
total max memory usage         :   2.00808E+00 GB
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180123/c02c8e08/attachment-0001.html>
