[Nek5000-users] Example turbChannel restart issue
Tue Jan 23 06:23:59 CST 2018
Looks like the data in your restart file is messed up. Can you please double check with VisIt.
Note, .re2 is a binary not an ASCII file. What makes you thinking that the format of other .re2 files is different?
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Tuesday 23rd January 2018 1:24
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Example turbChannel restart issue
> Dear Nek team,
> Currently I am working on the example turbChannel (NEK5000 v17.0) and have successfully generated some statistics results using the default settings. Now I would like to restart from where I stopped so this is what I did: In the .par file,
>  I activated the line startFrom = turbChannel0.f00001, where turbChannel0.f00001 is one of two files generated from the previous simulation. However, this did not work and produced error,
>  i.e. NAN. I also tried to use another file, turbChannel0.f00002 and I got the same error message. The complete logfile is at the end of this email. I am wondering is there anything else I need to modify other than what I did? Or the way I did was not correct?
> Another thing I got to mention is that, in the latest version of turbChannel (Nek5000 v17.0), the file .re2 is not readable; more specifically, it does not retain the same format as other .re2 or .rea files in other examples, and looks
>  messy and contains unreadable characters. So the Reynolds number in my case was changed in the .par file.
> Thank you for your time and help!
> Regards,
> Ming
> *****************Complete Logfile*****************************
> Number of processors:                 4
> REAL    wdsize          :                     8
> INTEGER wdsize      :                      4
> Timer accuracy        :                       9.40E-07
>  Reading /global/home/hpc4076/Nek5000/run/turbChannel/turbChannel.par
> general = [(null)]
> general:startfrom = [turbChannel0.f00001]
> general:stopat = [endTime]
> general:endtime = [200]
> general:dt = [0]
> general:timestepper = [bdf2]
> general:extrapolation = [OIFS]
> general:variabledt = [yes]
> general:targetcfl = [2.0]
> general:writecontrol = [runTime]
> general:writeinterval = [100.0]
> general:userparam01 = [100]
> general:userparam02 = [20]
> general:userparam03 = [1]
> general:filtering = [hpfrt]
> general:filterweight = [10]
> general:filtercutoffratio = [0.9]
> problemtype = [(null)]
> problemtype:variableproperties = [no]
> problemtype:equation = [incompNS]
> pressure = [(null)]
> pressure:preconditioner = [semg_amg]
> pressure:residualtol = [1e-04]
> pressure:residualproj = [yes]
> velocity = [(null)]
> velocity:residualtol = [1e-07]
> velocity:density = [1]
> velocity:viscosity = [-2950]
> Reading /global/home/hpc4076/Nek5000/run/turbChannel/turbChannel.re2
>  mapping elements to processors
> Reading /global/home/hpc4076/Nek5000/run/turbChannel/turbChannel.ma2
>            1         384         384        1536        1536  NELV
>            2         384         384        1536        1536  NELV
>            3         384         384        1536        1536  NELV
>            0         384         384        1536        1536  NELV
> RANK     0 IEG      44      45      49      50      51      54      55      56
>                      57      58      59      60      61      62      63      64
>                      65      66      67      68      69      70      71      72
>                      73      74      75      76      77      78      79      80
>                      81      82      83      84      85      86      87      88
>                      89      90      91      92      93      94      95      96
>                     236     237     241     242     243     246     247     248
>                     249     250     251     252     253     254     255     256
>                     257     258     259     260     261     262     263     264
>                     265     266     267     268     269     270     271     272
>                     273     274     275     276     277     278     279     280
>                     281     282     283     284     285     286     287     288
>                     428     429     433     434     435     438     439     440
>                     441     442     443     444     445     446     447     448
>                     449     450     451     452     453     454     455     456
>                     457     458     459     460     461     462     463     464
>                     465     466     467     468     469     470     471     472
>                     473     474     475     476     477     478     479     480
>                     620     621     625     626     627     630     631     632
>                     633     634     635     636     637     638     639     640
>                     641     642     643     644     645     646     647     648
>                     649     650     651     652     653     654     655     656
>                     657     658     659     660     661     662     663     664
>                     665     666     667     668     669     670     671     672
>                     812     813     817     818     819     822     823     824
>                     825     826     827     828     829     830     831     832
>                     833     834     835     836     837     838     839     840
>                     841     842     843     844     845     846     847     848
>                     849     850     851     852     853     854     855     856
>                     857     858     859     860     861     862     863     864
>                    1004    1005    1009    1010    1011    1014    1015    1016
>                    1017    1018    1019    1020    1021    1022    1023    1024
>                    1025    1026    1027    1028    1029    1030    1031    1032
>                    1033    1034    1035    1036    1037    1038    1039    1040
>                    1041    1042    1043    1044    1045    1046    1047    1048
>                    1049    1050    1051    1052    1053    1054    1055    1056
>                    1196    1197    1201    1202    1203    1206    1207    1208
>                    1209    1210    1211    1212    1213    1214    1215    1216
>                    1217    1218    1219    1220    1221    1222    1223    1224
>                    1225    1226    1227    1228    1229    1230    1231    1232
>                    1233    1234    1235    1236    1237    1238    1239    1240
>                    1241    1242    1243    1244    1245    1246    1247    1248
>                    1388    1389    1393    1394    1395    1398    1399    1400
>                    1401    1402    1403    1404    1405    1406    1407    1408
>                    1409    1410    1411    1412    1413    1414    1415    1416
>                    1417    1418    1419    1420    1421    1422    1423    1424
>                    1425    1426    1427    1428    1429    1430    1431    1432
>                    1433    1434    1435    1436    1437    1438    1439    1440
>  element load imbalance:            0         384         384
> done :: mapping   0.29167     sec
>   preading mesh
>   preading bc for ifld           1
> done :: read .re2 file   0.51     sec
> nelgt/nelgv/lelt:        1536        1536         387
> lx1  /lx2  /lx3 :           8           8           8
> setup mesh topology
>    Right-handed check complete for    1536 elements. OK.
>    setvert3d:   8      201344      533120      201344      201344
> call usrsetvert
> done :: usrsetvert
> gs_setup: 21952 unique labels shared
>    pairwise times (avg, min, max): 2.92127e-05 2.76451e-05 3.00083e-05
>    crystal router                : 7.82046e-05 7.75443e-05 7.88275e-05
>    all reduce                    : 0.000228323 0.000227655 0.000228766
>    used all_to_all method: pairwise
>    handle bytes (avg, min, max): 1.45061e06 1375332 1525892
>    buffer bytes (avg, min, max): 175616 125440 225792
>    setupds time 9.2419E-02 seconds   0  8      201344        1536
>            8  max multiplicity
> done :: setup mesh topology
>  call usrdat
> done :: usrdat
> generate geometry data
> NOTE: All elements deformed , param(59) ^=0
> done :: generate geometry data
>  call usrdat2
> done :: usrdat2
> regenerate geometry data           1
> done :: regenerate geometry data           1
>  verify mesh topology
>   0.000000000000000E000   6.28318530717959       Xrange
>   -1.00000000000000        1.00000000000000       Yrange
>   0.000000000000000E000   3.14159265358979       Zrange
> done :: verify mesh topology
>  IFTRAN   = T
> IFFLOW   = T
> IFHEAT   = F
> IFSPLIT  = T
> IFLOMACH = F
> IFUSERVP = F
> IFUSERMV = F
> IFPERT   = F
> IFADJ    = F
> IFSTRS   = F
> IFCHAR   = T
> IFCYCLIC = F
> IFAXIS   = F
> IFMVBD   = F
> IFMELT   = F
> IFNEKNEK = F
> IFSYNC   = F
>  IFVCOR   = T
> IFINTQ   = F
> IFGEOM   = F
> IFSURT   = F
> IFWCNO   = F
>  IFTMSH for field           1    =  F
> IFADVC for field           1    =  T
> IFNONL for field           1    =  F
>  Dealiasing enabled, lxd=           8
>  Estimated eigenvalues
> EIGAA =    1.23913370009078
>  EIGGA =    1862221.21607236
>  EIGAE =   0.250000000000000
>  EIGAS =   1.681282119258565E-002
> EIGGE =    1862221.21607236
>  EIGGS =    2.00000000000000
>   E-solver strategy:  0 itr
> mg_nx:           1           3           7
> mg_ny:           1           3           7
> mg_nz:           1           3           7
> call usrsetvert
> done :: usrsetvert
> gs_setup: 448 unique labels shared
>    pairwise times (avg, min, max): 7.93538e-06 7.8488e-06 8.0526e-06
>    crystal router                : 6.85905e-06 6.72e-06 6.9978e-06
>    all reduce                    : 1.20532e-05 1.11753e-05 1.28944e-05
>    used all_to_all method: crystal router
>    handle bytes (avg, min, max): 50812 44668 56956
>    buffer bytes (avg, min, max): 6144 5120 7168
>    setupds time 3.1089E-03 seconds   1  2        1664        1536
>    setvert3d:   4       30336       42624       30336       30336
> call usrsetvert
> done :: usrsetvert
> gs_setup: 4032 unique labels shared
>    pairwise times (avg, min, max): 8.37387e-06 8.2548e-06 8.5004e-06
>    crystal router                : 1.86812e-05 1.83826e-05 1.89784e-05
>    all reduce                    : 4.4251e-05 4.40251e-05 4.44275e-05
>    handle bytes (avg, min, max): 269940 256100 283780
>    buffer bytes (avg, min, max): 32256 23040 41472
>    setupds time 2.4576E-02 seconds   2  4       30336        1536
> call usrsetvert
> done :: usrsetvert
>    pairwise times (avg, min, max): 8.65523e-06 8.5168e-06 8.7977e-06
>    crystal router                : 1.94818e-05 1.93217e-05 1.96357e-05
>    all reduce                    : 5.97892e-05 5.95374e-05 5.99737e-05
>    setupds time 1.4160E-02 seconds   3  4       30336        1536
>    setvert3d:   6       96896      195200       96896       96896
> call usrsetvert
> done :: usrsetvert
> gs_setup: 11200 unique labels shared
>    pairwise times (avg, min, max): 1.61057e-05 1.58103e-05 1.62982e-05
>    crystal router                : 3.86536e-05 3.8384e-05 3.89447e-05
>    all reduce                    : 8.92118e-05 8.88703e-05 8.94562e-05
>    handle bytes (avg, min, max): 742004 703588 780420
>    buffer bytes (avg, min, max): 89600 64000 115200
>    setupds time 4.3098E-02 seconds   4  6       96896        1536
>  h1_mg_nx:           1           3           7
> h1_mg_ny:           1           3           7
> h1_mg_nz:           1           3           7
> call usrsetvert
> done :: usrsetvert
>    pairwise times (avg, min, max): 4.10923e-06 2.5509e-06 4.7765e-06
>    crystal router                : 3.94603e-06 3.7989e-06 4.0103e-06
>    all reduce                    : 6.54198e-06 6.442e-06 6.5947e-06
>    setupds time 1.6990E-03 seconds   5  2        1664        1536
> call usrsetvert
> done :: usrsetvert
>    pairwise times (avg, min, max): 7.51525e-06 7.3863e-06 7.68e-06
>    crystal router                : 1.7878e-05 1.76051e-05 1.81134e-05
>    all reduce                    : 5.29887e-05 5.27139e-05 5.32422e-05
>    setupds time 2.5044E-02 seconds   6  4       30336        1536
> call usrsetvert
> done :: usrsetvert
>    pairwise times (avg, min, max): 1.11506e-05 1.07538e-05 1.1453e-05
>    crystal router                : 2.78917e-05 2.74376e-05 2.83874e-05
>    all reduce                    : 6.8896e-05 6.84774e-05 6.92927e-05
>    setupds time 2.0265E-02 seconds   7  4       30336        1536
> call usrsetvert
> done :: usrsetvert
>    pairwise times (avg, min, max): 1.44095e-05 1.43056e-05 1.45192e-05
>    crystal router                : 3.94263e-05 3.90332e-05 3.98261e-05
>    all reduce                    : 9.67785e-05 9.63923e-05 9.71425e-05
>    setupds time 4.3436E-02 seconds   8  6       96896        1536
> call usrsetvert
> done :: usrsetvert
>    pairwise times (avg, min, max): 5.80216e-05 4.95078e-05 6.16774e-05
>    crystal router                : 7.1144e-05 7.08725e-05 7.14649e-05
>    all reduce                    : 0.000235607 0.000234486 0.000236793
>    setupds time 8.4090E-02 seconds   9  8      201344        1536
>    setvert3d:  10      343680     1130112      343680      343680
> call usrsetvert
> done :: usrsetvert
> gs_setup: 36288 unique labels shared
>    pairwise times (avg, min, max): 3.15373e-05 3.06691e-05 3.2104e-05
>    crystal router                : 9.24712e-05 9.09459e-05 9.39815e-05
>    all reduce                    : 0.000254788 0.00025378 0.000255437
>    handle bytes (avg, min, max): 2.39576e06 2271332 2520196
>    buffer bytes (avg, min, max): 290304 207360 373248
>    setupds time 1.3027E-01 seconds  10 10      343680        1536
> setup h1 coarse grid, nx_crs=           2
> call usrsetvert
> done :: usrsetvert
>    pairwise times (avg, min, max): 5.59047e-06 5.5171e-06 5.677e-06
>    crystal router                : 3.78503e-06 3.7079e-06 3.8472e-06
>    all reduce                    : 5.5058e-06 5.4973e-06 5.5169e-06
>    pairwise times (avg, min, max): 1.01072e-05 9.958e-06 1.01904e-05
>    crystal router                : 4.22242e-06 4.1446e-06 4.331e-06
>    all reduce                    : 8.35538e-06 8.1712e-06 8.4627e-06
>    handle bytes (avg, min, max): 27068 23868 30268
>    buffer bytes (avg, min, max): 4736 3840 5632
> AMG version 2.01
> AMG: 8 levels
> AMG Chebyshev smoother data:
> AMG  level 1: 3 iterations with rho = 0.79256
> AMG  level 2: 2 iterations with rho = 0.668297
> AMG  level 3: 2 iterations with rho = 0.481307
> AMG  level 4: 2 iterations with rho = 0.409707
> AMG  level 5: 2 iterations with rho = 0.458605
> AMG  level 6: 3 iterations with rho = 0.696293
> AMG  level 7: 2 iterations with rho = 0.666743
> AMG: 1664 rows
> AMG: preading through rows ... done
> gs_setup: 431 unique labels shared
>    pairwise times (avg, min, max): 2.78895e-06 2.5582e-06 2.8915e-06
>    crystal router                : 4.09068e-06 3.9897e-06 4.2042e-06
>    all reduce                    : 1.05099e-05 9.6558e-06 1.14097e-05
>    handle bytes (avg, min, max): 3261 2620 3832
>    buffer bytes (avg, min, max): 1724 1408 2040
> gs_setup: 664 unique labels shared
>    pairwise times (avg, min, max): 3.73e-06 3.6492e-06 3.8419e-06
>    crystal router                : 4.80688e-06 4.7581e-06 4.8544e-06
>    all reduce                    : 1.91924e-05 1.88961e-05 1.95428e-05
>    handle bytes (avg, min, max): 5588 3840 7948
>    buffer bytes (avg, min, max): 3200 2072 4328
> gs_setup: 311 unique labels shared
>    pairwise times (avg, min, max): 3.59183e-06 3.4744e-06 3.6762e-06
>    crystal router                : 3.48463e-06 3.4264e-06 3.5338e-06
>    all reduce                    : 7.03768e-06 6.9313e-06 7.1389e-06
>    handle bytes (avg, min, max): 9301 8788 9740
>    buffer bytes (avg, min, max): 3588 2992 4048
> gs_setup: 421 unique labels shared
>    pairwise times (avg, min, max): 4.046e-06 3.8288e-06 4.2149e-06
>    crystal router                : 5.71768e-06 5.6236e-06 5.8628e-06
>    all reduce                    : 9.28628e-06 9.1472e-06 9.4127e-06
>    handle bytes (avg, min, max): 4913 3240 6956
>    buffer bytes (avg, min, max): 3036 2088 4128
> gs_setup: 151 unique labels shared
>    pairwise times (avg, min, max): 2.19068e-06 2.1424e-06 2.242e-06
>    crystal router                : 3.61935e-06 3.5275e-06 3.683e-06
>    all reduce                    : 1.15655e-05 1.14062e-05 1.16404e-05
>    handle bytes (avg, min, max): 1331 940 1700
>    buffer bytes (avg, min, max): 628 448 808
> gs_setup: 194 unique labels shared
>    pairwise times (avg, min, max): 3.61092e-06 3.5012e-06 3.7449e-06
>    crystal router                : 4.24627e-06 4.2222e-06 4.2926e-06
>    all reduce                    : 5.85915e-06 5.651e-06 6.022e-06
>    handle bytes (avg, min, max): 3380 3208 3588
>    buffer bytes (avg, min, max): 2160 2032 2368
> gs_setup: 80 unique labels shared
>    pairwise times (avg, min, max): 2.38705e-06 2.3152e-06 2.4211e-06
>    crystal router                : 2.44917e-06 2.3604e-06 2.5157e-06
>    all reduce                    : 3.76915e-06 3.6987e-06 3.8185e-06
>    handle bytes (avg, min, max): 985 788 1228
>    buffer bytes (avg, min, max): 452 320 648
> gs_setup: 98 unique labels shared
>    pairwise times (avg, min, max): 3.19185e-06 3.1425e-06 3.2323e-06
>    crystal router                : 2.91045e-06 2.8317e-06 3.0279e-06
>    all reduce                    : 4.24988e-06 4.1918e-06 4.3256e-06
>    handle bytes (avg, min, max): 5506 5136 5876
>    buffer bytes (avg, min, max): 2352 2192 2512
> gs_setup: 33 unique labels shared
>    pairwise times (avg, min, max): 2.20093e-06 2.1362e-06 2.3165e-06
>    crystal router                : 3.15857e-06 3.0855e-06 3.2308e-06
>    all reduce                    : 4.0025e-06 3.9097e-06 4.0784e-06
>    handle bytes (avg, min, max): 616 512 788
>    buffer bytes (avg, min, max): 232 160 376
> gs_setup: 39 unique labels shared
>    pairwise times (avg, min, max): 2.55118e-06 2.5145e-06 2.5821e-06
>    crystal router                : 3.45955e-06 3.3809e-06 3.5407e-06
>    all reduce                    : 4.61387e-06 4.495e-06 4.7137e-06
>    handle bytes (avg, min, max): 955 936 972
>    buffer bytes (avg, min, max): 468 392 536
> gs_setup: 8 unique labels shared
>    pairwise times (avg, min, max): 2.7896e-06 2.684e-06 2.8771e-06
>    crystal router                : 3.3584e-06 3.2604e-06 3.4714e-06
>    all reduce                    : 3.8325e-06 3.7504e-06 3.9734e-06
>    handle bytes (avg, min, max): 413 392 424
>    buffer bytes (avg, min, max): 84 64 96
>    pairwise times (avg, min, max): 2.76598e-06 2.7364e-06 2.8357e-06
>    crystal router                : 2.47192e-06 2.4054e-06 2.5145e-06
>    all reduce                    : 2.75563e-06 2.6928e-06 2.8295e-06
>    handle bytes (avg, min, max): 916 860 972
>    buffer bytes (avg, min, max): 192 176 208
> gs_setup: 1 unique labels shared
>    pairwise times (avg, min, max): 7.2665e-07 6.456e-07 7.68e-07
>    crystal router                : 2.4244e-06 2.3879e-06 2.4719e-06
>    all reduce                    : 2.57698e-06 2.5591e-06 2.5873e-06
>    handle bytes (avg, min, max): 237 228 264
>    buffer bytes (avg, min, max): 12 8 24
>    pairwise times (avg, min, max): 7.836e-07 6.3e-07 8.848e-07
>    crystal router                : 2.57503e-06 2.4694e-06 2.6345e-06
>    all reduce                    : 2.86405e-06 2.8357e-06 2.9139e-06
> gs_setup: 405 unique labels shared
>    pairwise times (avg, min, max): 2.43873e-06 2.2721e-06 2.5217e-06
>    crystal router                : 3.87707e-06 3.8341e-06 3.9225e-06
>    all reduce                    : 7.58878e-06 7.5007e-06 7.6681e-06
>    handle bytes (avg, min, max): 3079 2020 4152
>    buffer bytes (avg, min, max): 1620 1024 2216
> gs_setup: 235 unique labels shared
>    pairwise times (avg, min, max): 3.03253e-06 2.9581e-06 3.1371e-06
>    crystal router                : 4.62493e-06 4.5157e-06 4.7079e-06
>    all reduce                    : 6.30792e-06 6.2306e-06 6.4236e-06
>    handle bytes (avg, min, max): 2456 1268 3872
>    buffer bytes (avg, min, max): 1368 600 2224
> gs_setup: 232 unique labels shared
>    pairwise times (avg, min, max): 3.3132e-06 3.2543e-06 3.3618e-06
>    crystal router                : 3.97125e-06 3.9468e-06 3.9908e-06
>    all reduce                    : 9.85658e-06 9.7844e-06 9.8952e-06
>    handle bytes (avg, min, max): 3335 2484 4152
>    buffer bytes (avg, min, max): 2076 1568 2664
> gs_setup: 96 unique labels shared
>    pairwise times (avg, min, max): 8.03052e-06 7.9335e-06 8.1011e-06
>    crystal router                : 3.56828e-06 3.5204e-06 3.6189e-06
>    all reduce                    : 6.4523e-06 6.3963e-06 6.5105e-06
>    handle bytes (avg, min, max): 5404 5100 5568
>    buffer bytes (avg, min, max): 2304 2256 2352
> gs_setup: 59 unique labels shared
>    pairwise times (avg, min, max): 3.0593e-06 2.967e-06 3.1159e-06
>    crystal router                : 3.37507e-06 3.315e-06 3.443e-06
>    all reduce                    : 8.04967e-06 8.032e-06 8.0607e-06
>   handle bytes (avg, min, max): 1295 1288 1304
>    buffer bytes (avg, min, max): 708 680 744
> gs_setup: 31 unique labels shared
>    pairwise times (avg, min, max): 2.94198e-06 2.8528e-06 2.9872e-06
>    crystal router                : 2.7749e-06 2.6955e-06 2.8159e-06
>    all reduce                    : 4.59447e-06 4.5455e-06 4.6566e-06
>    handle bytes (avg, min, max): 2089 1864 2336
>    buffer bytes (avg, min, max): 744 640 848
> gs_setup: 7 unique labels shared
>    pairwise times (avg, min, max): 2.88287e-06 2.8044e-06 2.9556e-06
>    crystal router                : 2.52328e-06 2.4726e-06 2.5612e-06
>    all reduce                    : 2.83837e-06 2.7564e-06 2.9157e-06
>    handle bytes (avg, min, max): 865 832 888
>    buffer bytes (avg, min, max): 168 160 176
> done :: setup h1 coarse grid    2.36721729199780       sec
>  call usrdat3
> done :: usrdat3
> set initial conditions
> Checking restart options: turbChannel0.f00001
>  nekuic (1) for ifld            1
> Reading checkpoint data
>        FILE:
> turbChannel0.f00001
>         0  2.0000E02 done :: Read checkpoint data
>                               avg data-throughput =     2.5MBps
>                               io-nodes =     4
> xyz min     0.0000      -1.0000       0.0000
>  uvwpt min          NaN          NaN          NaN          NaN   0.0000
>  PS min     0.99000E22
> xyz max     6.2832       1.0000       3.1416
>  uvwpt max          NaN          NaN          NaN          NaN   0.0000
>  PS max    -0.99000E22
> Restart: recompute geom. factors.
>  done :: set initial conditions
>  call userchk
>    2.0000E02          NaN          NaN monitor
> Start collecting statistics ...
> done :: userchk
> gridpoints unique/tot:        533120       786432
>   dofs:                520576                533120
>  Initial time: 0.2000000E03
> Initialization successfully completed    13.736     sec
> Starting time loop ...
> WARNING: DT<0 or DTFS<0
>           Reset DT
>  WARNING: Set DT=0.001 (arbitrarily)
> Final time step =   0.000000000000000E000
>    HPF : 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 1.000000
>              Solving for fluid
>     1 1.00000E-04         NaN         NaN         NaN       1 Divergence
>     2 1.00000E-04         NaN         NaN         NaN       1 Divergence
>     3 1.00000E-04         NaN         NaN         NaN       1 Divergence
>     4 1.00000E-04         NaN         NaN         NaN       1 Divergence
>     5 1.00000E-04         NaN         NaN         NaN       1 Divergence
>     6 1.00000E-04         NaN         NaN         NaN       1 Divergence
>     7 1.00000E-04         NaN         NaN         NaN       1 Divergence
>     8 1.00000E-04         NaN         NaN         NaN       1 Divergence
>     9 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    10 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    11 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    12 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    13 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   14 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    15 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    16 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    17 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    18 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    19 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    20 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    21 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    22 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    23 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    24 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    25 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    26 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    27 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    28 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    29 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    30 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    31 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    32 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    33 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    34 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    35 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    36 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    37 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    38 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    39 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    40 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    41 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   42 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    43 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    44 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    45 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    46 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    47 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    48 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    49 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    50 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    51 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    52 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    53 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    54 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    55 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    56 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    57 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    58 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    59 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    60 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    61 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    62 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    63 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    64 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    65 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    66 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    67 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    68 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    69 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   70 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    71 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    72 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    73 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    74 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    75 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    76 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    77 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    78 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    79 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    80 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    81 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    82 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    83 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    84 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    85 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    86 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    87 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    88 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    89 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    90 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    91 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    92 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    93 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    94 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    95 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    96 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    97 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   98 1.00000E-04         NaN         NaN         NaN       1 Divergence
>    99 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   100 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   101 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   102 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   103 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   104 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   105 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   106 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   107 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   108 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   109 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   110 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   111 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   112 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   113 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   114 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   115 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   116 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   117 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   118 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   119 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   120 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   121 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   122 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   123 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   124 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   125 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   126 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   127 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   128 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  129 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   130 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   131 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   132 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   133 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   134 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   135 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   136 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   137 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   138 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   139 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   140 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   141 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   142 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   143 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   144 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   145 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   146 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   147 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   148 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   149 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   150 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   151 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   152 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   153 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   154 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   155 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   156 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  157 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   158 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   159 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   160 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   161 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   162 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   163 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   164 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   165 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   166 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   167 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   168 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   169 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   170 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   171 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   172 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   173 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   174 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   175 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   176 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   177 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   178 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   179 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   180 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   181 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   182 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   183 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   184 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  185 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   186 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   187 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   188 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   189 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   190 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   191 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   192 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   193 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   194 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   195 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   196 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   197 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   198 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   199 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   200 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   201 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   202 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   203 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   204 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   205 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   206 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   207 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   208 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   209 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   210 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   211 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   212 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   213 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   214 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   215 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  216 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   217 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   218 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   219 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   220 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   221 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   222 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   223 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   224 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   225 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   226 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   227 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   228 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   229 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   230 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   231 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   232 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   233 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   234 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   235 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   236 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   237 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   238 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   239 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   240 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   241 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   242 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   243 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  244 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   245 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   246 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   247 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   248 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   249 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   250 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   251 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   252 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   253 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   254 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   255 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   256 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   257 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   258 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   259 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   260 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   261 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   262 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   263 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   264 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   265 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   266 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   267 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   268 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   269 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   270 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   271 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  272 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   273 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   274 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   275 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   276 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   277 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   278 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   279 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   280 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   281 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   282 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   283 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   284 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   285 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   286 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   287 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   288 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   289 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   290 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   291 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   292 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   293 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   294 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   295 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   296 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   297 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   298 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   299 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   300 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   301 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   302 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  303 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   304 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   305 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   306 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   307 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   308 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   309 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   310 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   311 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   312 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   313 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   314 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   315 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   316 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   317 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   318 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   319 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   320 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   321 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   322 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   323 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   324 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   325 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   326 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   327 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   328 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   329 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   330 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  331 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   332 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   333 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   334 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   335 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   336 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   337 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   338 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   339 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   340 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   341 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   342 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   343 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   344 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   345 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   346 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   347 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   348 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   349 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   350 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   351 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   352 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   353 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   354 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   355 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   356 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   357 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   358 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  359 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   360 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   361 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   362 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   363 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   364 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   365 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   366 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   367 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   368 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   369 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   370 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   371 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   372 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   373 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   374 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   375 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   376 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   377 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   378 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   379 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   380 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   381 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   382 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   383 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   384 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   385 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   386 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   387 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   388 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   389 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  390 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   391 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   392 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   393 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   394 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   395 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   396 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   397 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   398 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   399 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   400 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   401 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   402 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   403 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   404 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   405 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   406 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   407 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   408 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   409 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   410 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   411 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   412 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   413 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   414 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   415 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   416 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   417 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  418 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   419 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   420 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   421 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   422 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   423 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   424 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   425 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   426 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   427 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   428 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   429 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   430 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   431 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   432 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   433 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   434 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   435 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   436 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   437 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   438 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   439 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   440 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   441 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   442 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   443 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   444 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   445 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  446 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   447 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   448 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   449 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   450 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   451 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   452 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   453 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   454 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   455 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   456 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   457 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   458 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   459 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   460 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   461 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   462 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   463 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   464 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   465 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   466 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   467 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   468 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   469 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   470 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   471 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   472 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   473 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   474 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   475 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   476 1.00000E-04         NaN         NaN         NaN       1 Divergence
>  477 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   478 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   479 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   480 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   481 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   482 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   483 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   484 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   485 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   486 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   487 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   488 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   489 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   490 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   491 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   492 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   493 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   494 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   495 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   496 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   497 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   498 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   499 1.00000E-04         NaN         NaN         NaN       1 Divergence
>   500 1.00000E-04         NaN         NaN         NaN       1 Divergence
>           1  PRES gmres       500          NaN          NaN   1.0000E-04   1.3084E01   2.1669E01    F
>           1  Hmholtz VELX       1          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX       2          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX       3          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX       4          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX       5          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX       6          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX       7          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX       8          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX       9          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      10          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      11          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      12          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      13          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      14          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      15          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      16          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      17          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      18          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      19          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      20          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      21          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      22          NaN   3.3898E-04   1.0000E-07     Infinity   F
>          1  Hmholtz VELX      23          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      24          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      25          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      26          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      27          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      28          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      29          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      30          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      31          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      32          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      33          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      34          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      35          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      36          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      37          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      38          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      39          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      40          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      41          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      42          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      43          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      44          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      45          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      46          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      47          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      48          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      49          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      50          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      51          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      52          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      53          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      54          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      55          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      56          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      57          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      58          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      59          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      60          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      61          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      62          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      63          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      64          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      65          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      66          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      67          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      68          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      69          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      70          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      71          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      72          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      73          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      74          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      75          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      76          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      77          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      78          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      79          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      80          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      81          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      82          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      83          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      84          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      85          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      86          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      87          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      88          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      89          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      90          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      91          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      92          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      93          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      94          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      95          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      96          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      97          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      98          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX      99          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELX     100          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Error Hmholtz VELX     100          NaN          NaN   1.0000E-07
>           1  Hmholtz VELY       1          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY       2          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY       3          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY       4          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY       5          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY       6          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY       7          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY       8          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY       9          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      10          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      11          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      12          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      13          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      14          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      15          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      16          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      17          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      18          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      19          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      20          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      21          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      22          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      23          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      24          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      25          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      26          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      27          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      28          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      29          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      30          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      31          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      32          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      33          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      34          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      35          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      36          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      37          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      38          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      39          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      40          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      41          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      42          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      43          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      44          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      45          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      46          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      47          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      48          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      49          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      50          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      51          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      52          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      53          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      54          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      55          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      56          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      57          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      58          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      59          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      60          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      61          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      62          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      63          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      64          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      65          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      66          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      67          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      68          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      69          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      70          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      71          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      72          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      73          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      74          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      75          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      76          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      77          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      78          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      79          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      80          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      81          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      82          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      83          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      84          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      85          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      86          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      87          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      88          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      89          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      90          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      91          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      92          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      93          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      94          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      95          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      96          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      97          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      98          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY      99          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY     100          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Error Hmholtz VELY     100          NaN          NaN   1.0000E-07
>           1  Hmholtz VELZ       1          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ       2          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ       3          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ       4          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ       5          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ       6          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ       7          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ       8          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ       9          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      10          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      11          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      12          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      13          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      14          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      15          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      16          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      17          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      18          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      19          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      20          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      21          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      22          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      23          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      24          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      25          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      26          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      27          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      28          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      29          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      30          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      31          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      32          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      33          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      34          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      35          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      36          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      37          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      38          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      39          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      40          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      41          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      42          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      43          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      44          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      45          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      46          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      47          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      48          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      49          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      50          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      51          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      52          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      53          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      54          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      55          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      56          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      57          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      58          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      59          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      60          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      61          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      62          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      63          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      64          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      65          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      66          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      67          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      68          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      69          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      70          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      71          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      72          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      73          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      74          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      75          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      76          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      77          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      78          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      79          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      80          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      81          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      82          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      83          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      84          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      85          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      86          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      87          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      88          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      89          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      90          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      91          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      92          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      93          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      94          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      95          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      96          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      97          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      98          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ      99          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ     100          NaN   3.3898E-04   1.0000E-07     Infinity   F
>           1  Error Hmholtz VELZ     100          NaN          NaN   1.0000E-07
>     1 1.00000E-04 1.04290E-15 1.48092E-15 7.04224E-01       1 Divergence
>           1  PRES gmres         1   1.0429E-15   1.4809E-15   1.0000E-04   2.3331E-02   5.0854E-02    F
>           1  Hmholtz VELX       1   9.9982E-01   3.3898E-04   1.0000E-07     Infinity   F
>           1  Error Hmholtz VELX     100          NaN   9.9982E-01   1.0000E-07
>           1  Hmholtz VELY       1   8.0937E-16   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELY       0   8.0937E-16   8.0937E-16   1.0000E-07
>           1  Hmholtz VELZ       1   7.1883E-16   3.3898E-04   1.0000E-07     Infinity   F
>           1  Hmholtz VELZ       0   7.1883E-16   7.1883E-16   1.0000E-07
>           1  volflow X                     NaN          NaN          NaN   6.2832E00
>              L1/L2 DIV(V)                  NaN          NaN
>              L1/L2 QTL              0.0000E00   0.0000E00
>              L1/L2 DIV(V)-QTL              NaN          NaN
>           1  Fluid done  2.0000E02  2.6895E01
> filt amp 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.5000
> filt trn 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 0.5000
>        1 sfilt:         NaN     vortx
>         1  2.0000E02 Write checkpoint
>        FILE:
> /global/home/hpc4076/Nek5000/run/turbChannel/turbChannel0.f00001
>         1  2.0000E02 done :: Write checkpoint
>                               file size =      21.    MB
>                               avg data-throughput =    11.3MB/s
>                               io-nodes =     4
> end of time-step loop
> runtime statistics:
> init time   13.7358070529990       0.462004458987539
>  prep time           1   1.87108852800156       6.293414284007534E-002
> pres time           1   21.7905451879997       0.732925921409712
>  crsl time         501  0.183691413072665       6.178468552291153E-003
> crsl min   0.183063570999366
>  crsl max   0.260289230038325
>  crsl avg   0.221352905275126
>  hmhz time           6   4.94836180700077       0.166438361480831
>  eslv time           0  0.000000000000000E000  0.000000000000000E000
> proj time           0  0.000000000000000E000  0.000000000000000E000
> usvp time           2  8.829280013742391E-004  2.969732117129529E-005
> usfq time           0  1.237174799825880E-002  4.161242742134884E-004
> usbc time           1  2.739972998824669E-003  9.215910925933331E-005
> usbc min   2.302368000528077E-003
> usbc max   1.831457500156830E-002
> usb  avg   6.439937250434014E-003
> mltd time           3  1.305026299814926E-002  4.389461553180925E-004
> cdtp time           4  1.176028400368523E-002  3.955576565467353E-004
> axhm time         945   6.36171776202173       0.213976649608845
>  advc time           1  0.178863899000135       6.016094909539131E-003
> mxmf time  0.000000000000000E000  0.000000000000000E000
> adc3 time  0.000000000000000E000  0.000000000000000E000
> col2 time  0.000000000000000E000  0.000000000000000E000
> col3 time  0.000000000000000E000  0.000000000000000E000
> a2s2 time  0.000000000000000E000  0.000000000000000E000
> add2 time  0.000000000000000E000  0.000000000000000E000
> invc time  0.000000000000000E000  0.000000000000000E000
> tgop time        2480   1.02037628088146       3.432039994398663E-002
> dadd time           0   3.58888928988017       0.120712445096209
>  vdss time           4  6.298328000411857E-003  2.118445322600121E-004
> vdss min   6.298328000411857E-003
> vdss max   2.789256400137674E-002
> vdss avg   2.080069274961716E-002
> dsum time        1463   1.95680818695473       6.581732724317946E-002
> dsum min    1.52674149705126
>  dsum max    2.28399024302780
>  dsum avg    1.90933237102490
>  ddsl time           0  0.000000000000000E000  0.000000000000000E000
> #  nid       tusbc       tdadd       tcrsl       tvdss       tdsum        tgop    qqq    F
>            0  2.7400E-03  3.5889E00  1.8369E-01  6.2983E-03  1.9568E00  1.0204E00 qqq
>            1  2.3024E-03  3.7084E00  2.5837E-01  2.7040E-02  1.8698E00  1.7594E00 qqq
>            2  1.8315E-02  3.7437E00  2.6029E-01  2.1972E-02  1.5267E00  1.9577E00 qqq
>            3  2.4028E-03  3.6736E00  1.8306E-01  2.7893E-02  2.2840E00  1.0771E00 qqq
> run successful: dying ...
> total elapsed time             :   4.35605E01 sec
> total solver time w/o IO       :   2.78598E01 sec
> time/timestep                  :   2.78598E01 sec
> avg throughput per timestep    :   4.78395E03 gridpts/CPUs
> total max memory usage         :   2.00808E00 GB
> Nek5000-users mailing list
