[Nek5000-users] Reynolds number setting in the turbChannel example
Mon Jan 8 12:38:20 CST 2018
Dear Zhenrong,
Did you seed your initial conditions with any perturbation?
Did you fix your flow rate with p54/p55 in the .rea file?
Best,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Monday, January 8, 2018 4:05:11 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Reynolds number setting in the turbChannel example
Hello Neks
Thanks very much for all your kindly replys. And I am really sorry for not following this discussion in time because of the vacation. I will works on the example more deeply in the following days.
I still have a problem which might be very stupid, but I have no clue where the proleme is. I set p02 = -2800 and the grid domain is pi * [-1,1] * 2pi in z,y,x direction to reproduce the Re_tau = 180 case. But the simulation results is laminar! which is really strange.
And is there any existing post-code for calculate two points correlation and energy spectral?
Thanks again
Regards
Zhenrong JING
PhD école centrale de Nantes
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180108/b2fed221/attachment.html>
