[Nek5000-users] Reynolds number setting in the turbChannel example
Mon Jan 8 12:37:22 CST 2018
Is this email part of another discussion?
Did you start from the Nek5000 example?
Can you please send your .rea file?
Did you like at the instantaneous velocity field?
Marco
On Jan 8, 2018, at 5:05 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hello Neks
Thanks very much for all your kindly replys. And I am really sorry for not following this discussion in time because of the vacation. I will works on the example more deeply in the following days.
I still have a problem which might be very stupid, but I have no clue where the proleme is. I set p02 = -2800 and the grid domain is pi * [-1,1] * 2pi in z,y,x direction to reproduce the Re_tau = 180 case. But the simulation results is laminar! which is really strange.
And is there any existing post-code for calculate two points correlation and energy spectral?
Thanks again
Regards
Zhenrong JING
PhD école centrale de Nantes
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180108/3ea4e6a5/attachment.html>
