[Nek5000-users] Regarding base velocity (Mesh deformation)
Wed Feb 28 12:14:32 CST 2018
Hi Neks,
I had sent you a detailed problem regarding base velocity (mesh motion and mesh deformation) in the morning unfortunately i have not get any replay yet . I think you guys are busy otherwise you guys are very resposive. I appreciate that. Even though I investigated my problem and I think i found where actually the problem is even though I still need some clarifications in that.
The problem were in the boundary conditions since there are two type of B.Cs Homogenous (zero on all non- interior boundary faces ) and Inhomogenous( 1 at moving boundary faces). When i was trying on 2D there were no problem with B.Cs. But when i i tried my 3D mesh where a new B.C has come which is called SYMMETRY b.c. I imposed the SYM conditions on the horizontal walls of the fluid domain (not on the object) and also the exterior to the fluid domain on 3rd dimension.(3D means i put a thinkess as size of one element, which makes my foil case into 3D) As a result, for one element near the moving body, I have a m.v condition, SYM conditon on the exterior of the fluid domain in 3rd direction (lets say Z direction, so SYM on both sides) and E on the interior of the fluid domain.
So the condition I gave is given below :
m1 = -1.
y0 = 0.0
nface = 2*ndim
do e=1,nelv
do f=1,nface
c Set Dirichlet for mesh velocity on all boundaries
if (cbc(f,e,1).ne.'E ') call facev(msk,e,f,y0,nx1,ny1,nz1)
c Inhomogeneous Dirichlet on foil only
if (cbc(f,e,1).eq.'mv '.or. cbc(f,e,1).eq.'SYM ') then
if((ym1(1,1,f,e).lt.6.0).and.(ym1(1,1,f,e).gt.-6.0)) then !! where my domain +6 to -6 in Y direction and 0 to 0.1 in Z direction and -8 to 8 in X direction
call facev(tmp,e,f,m1,nx1,ny1,nz1)
endif
endif
enddo
enddo
Now I get a better basev (the values ranges between 0 and 1.2 before it was less than zero). But still I am getting a value which is slightly greater than 1.0 which is not good. So could you please tell me what should I do in this case, to have a nice smoothing velocity to all the mesh.
Thanks with Regards
Sijo GEORGE
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180228/3982ab93/attachment.html>
