[Nek5000-users] Base velocity problem
Wed Feb 28 03:50:45 CST 2018
Hi Neks,
I am bit stuck on this occasion for past 2 days, the code below shows a part of the example called ocyl2.usr (from subroutine my_base_meshv(basev,h1,h2,rhs,msk,tmp) ). This code is to generate a base velocity (where basev=1 at wall of object and 0 at the boundary of the domain). I assume that I have a blending coefficient h1.(using Paul's method or volume of elements method). This subroutine working perfectly for the 2D cases. That is I have the base velocity ranges between 0 and 1. But when I tried it on an aero dynamic foil case(its a 3D case where just 1 element in Y direction), the value of base velocity does not even exceed 0. Almsot all values are like -0.0021564... Could you please tell me is there anything that I have to change in this subroutine to make it working.
Tha value of m1 and z0 are just explicity giving the base velocity to the elements right? for example on the W or M.V conditions basev becomes 1 and on boundaries of the domain it becomes 0.0
m1 = -1.
z0 = 0.0
nface = 2*ndim
do e=1,nelv
do f=1,nface
c Set Dirichlet for mesh velocity on all boundaries
if (cbc(f,e,1).ne.'E ') call facev(msk,e,f,z0,nx1,ny1,nz1)
c Inhomogeneous Dirichlet on cylinder only
if (cbc(f,e,1).eq.'mv ') then
call fcaver(xavg,xm1,e,f)
if (xavg.gt.-3.0) call facev(tmp,e,f,m1,nx1,ny1,nz1)
endif
enddo
enddo
call axhelm (rhs,tmp,h1,h2,1,1)
tol = 1.e-4
imsh = 1
ifield = 1
call hmholtz('mshv',basev,rhs,h1,h2,msk,vmult,imsh,tol,200,1)
call sub2(basev,tmp,n)
c call outpost(basev,basev,basev,basev,basev,' ')
c stop
Regards
Sijo
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180228/365bb186/attachment.html>
