[Nek5000-users] turbChannel: history points and instantaneous velocity field
Tue Feb 20 11:04:37 CST 2018
Hi Emily,
Could you send me your case off-list so that I could have a look?
Sincerely,
On Tue, Feb 20, 2018 at 10:55 AM <nek5000-users at lists.mcs.anl.gov> wrote:
> Hello,
> Thank you for the reply. The istep loop shall be fine. I tried some other lines in the “if..endif” loop here and they all worked.
> I also commented the if loop and I had the same error information. I really do not know why.
> Regards,
> Emily
> _______________________________________________________________________
> Hi Emily,
> Did you call the hpts() subroutine without calling the istep loop?
> Sincerely,
> On Mon, Feb 19, 2018 at 3:41 PM <nek5000-users at lists.mcs.anl.gov <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>> wrote:
> >* Dear Nek users,*
> >* I am attempting to use History Points features in turbChannel example and*
> >* unfortunately I run into an issue. In the subroutine userchck, I added:*
> >* if(istep. eq. 1) then*
> >*               call hpts()                       !checkpoints*
> >* endif*
> >* where the file is name “check.his” , the format of which follows the user*
> >* guide:*
> >* 2             !number of checkpoints*
> >* 1. -0.98 1.   !x,y,z locations*
> >* 2. -0.67 4.*
> >* However, I received an error saying: Cannot open history file in*
> >* subroutine hpts(). Has anyone run into this error before?*
> >* Another question really bothering me is that I could not figure out how to*
> >* write out the instantaneous velocity field (u(x,y,z),v(x,y,z),w(x,y,z)) at*
> >* a specific time step (istep). Could anyone please help me on this as well?*
> >* Regards,*
> >* Emily*
> Nek5000-users mailing list
*Amitvikram Dutta*
Graduate Research Assistant
Fluid Mechanics Research Lab
Multi-Physics Interaction Lab
University of Waterloo
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180220/c4178bdc/attachment.html>
