[Nek5000-users] Nek5000-users Digest, Vol 108, Issue 18
Mon Feb 12 18:46:27 CST 2018
Thanks Som
On Mon, Feb 12, 2018 at 6:13 PM <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Amitvikram,
> for all practical purposes there shouldn't be any backward compatibility
> issues between the
> two versions of Nek5000.
> It is recommended to use the latest, because there has been some
> improvements which
> has been found to reduce the solution time.
> Also, there is no installation involved with Nek5000, if you have v16
> working,
> you can just download the v17 into your home folder and build/compile
> exactly the same way you built the previous version.
> I hope this helps.
> cheers
> Som
> Som Dutta
> Post Doctoral Research Associate
> Dept. of Computer Science
> University of Illinois at Urbana-Champaign
> On Mon, Feb 12, 2018 at 12:00 PM, <nek5000-users-request at lists.mcs.anl.gov
> > wrote:
>> Send Nek5000-users mailing list submissions to
>> To subscribe or unsubscribe via the World Wide Web, visit
>>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>         nek5000-users-owner at lists.mcs.anl.gov
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of Nek5000-users digest..."
>> Today's Topics:
>>    1. Transitioning from v16 to v17 (nek5000-users at lists.mcs.anl.gov)
>>    2. Re: Transitioning from v16 to v17
>> Message: 1
>> Date: Sun, 11 Feb 2018 22:57:55 +0000
>> From: nek5000-users at lists.mcs.anl.gov
>> To: "nek5000-users at lists.mcs.anl.gov"
>> Subject: [Nek5000-users] Transitioning from v16 to v17
>> Message-ID:
>>         <mailman.8402.1518389888.19102.nek5000-users at lists.mcs.anl.gov>
>> Content-Type: text/plain; charset="utf-8"
>> Hi all,
>> I'm thinking of transitioning from v16 to v17. I do however have a large
>> number of previous simulations in v16. I'd like to be able to keep using
>> them in v17. Additionally the cluster I have acess to has only v16
>> installed and the process to upgrade the version could take a significant
>> amount of time.
>> What is the back-compatibility level between v16 and v17? What factors
>> must
>> I keep in mind so that I can run my v16 versions on v17?
>> Sincerely,
>> *Amitvikram Dutta*
>> Graduate Research Assistant
>> Fluid Mechanics Research Lab
>> Multi-Physics Interaction Lab
>> University of Waterloo
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180211/b07455fe/attachment-0001.html
>> Message: 2
>> Date: Mon, 12 Feb 2018 11:03:35 +0100
>> To: nek5000-users at lists.mcs.anl.gov     <nek5000-users at lists.mcs.anl.gov>
>> Subject: Re: [Nek5000-users] Transitioning from v16 to v17
>> Message-ID:
>>         <mailman.8419.1518429828.19102.nek5000-users at lists.mcs.anl.gov>
>> Content-Type: text/plain; charset=utf-8
>> Note, 16.0 was a development version of the code and not an official
>> release. We do strongly recommend to update to v17.0. There is no
>> installation process. Just untar the tarball and compile the code. In less
>> than 2-3min you are done. The code is fully backward compatbile. For more
>> details please check the release notes.
>> -----Original message-----
>> > From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>> > Sent: Sunday 11th February 2018 23:58
>> > Hi all,
>> > Im thinking of transitioning from v16 to v17. I do however have a large
>> number of previous simulations in v16. Id like to be able to keep using
>> amount of time.
>> must I keep in mind so that I can run my v16 versions on v17?
>> > Sincerely,
>> > Amitvikram Dutta
>> > _______________________________________________
>> > Nek5000-users at lists.mcs.anl.gov
>> Subject: Digest Footer
>> End of Nek5000-users Digest, Vol 108, Issue 18
*Amitvikram Dutta*
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180213/b83de73e/attachment-0001.html>
