[Nek5000-users] Nek5000-users Digest, Vol 108, Issue 18
Mon Feb 12 12:08:18 CST 2018
Hi Amitvikram,
for all practical purposes there shouldn't be any backward compatibility
issues between the
two versions of Nek5000.
It is recommended to use the latest, because there has been some
improvements which
has been found to reduce the solution time.
Also, there is no installation involved with Nek5000, if you have v16
working,
you can just download the v17 into your home folder and build/compile
exactly the same way you built the previous version.
I hope this helps.
cheers
Som
Som Dutta
Post Doctoral Research Associate
Dept. of Computer Science
University of Illinois at Urbana-Champaign
On Mon, Feb 12, 2018 at 12:00 PM, <nek5000-users-request at lists.mcs.anl.gov>
wrote:
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>    1. Transitioning from v16 to v17 (nek5000-users at lists.mcs.anl.gov)
>    2. Re: Transitioning from v16 to v17
> Message: 1
> Date: Sun, 11 Feb 2018 22:57:55 +0000
> From: nek5000-users at lists.mcs.anl.gov
> To: "nek5000-users at lists.mcs.anl.gov"
>         <nek5000-users at lists.mcs.anl.gov>
> Subject: [Nek5000-users] Transitioning from v16 to v17
> Message-ID:
>         <mailman.8402.1518389888.19102.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="utf-8"
> Hi all,
> I'm thinking of transitioning from v16 to v17. I do however have a large
> number of previous simulations in v16. I'd like to be able to keep using
> them in v17. Additionally the cluster I have acess to has only v16
> installed and the process to upgrade the version could take a significant
> amount of time.
> What is the back-compatibility level between v16 and v17? What factors must
> I keep in mind so that I can run my v16 versions on v17?
> Sincerely,
> *Amitvikram Dutta*
> Graduate Research Assistant
> Fluid Mechanics Research Lab
> Multi-Physics Interaction Lab
> University of Waterloo
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/
> attachments/20180211/b07455fe/attachment-0001.html>
> Message: 2
> Date: Mon, 12 Feb 2018 11:03:35 +0100
> To: nek5000-users at lists.mcs.anl.gov     <nek5000-users at lists.mcs.anl.gov>
> Subject: Re: [Nek5000-users] Transitioning from v16 to v17
> Message-ID:
>         <mailman.8419.1518429828.19102.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset=utf-8
> Note, 16.0 was a development version of the code and not an official
> release. We do strongly recommend to update to v17.0. There is no
> installation process. Just untar the tarball and compile the code. In less
> than 2-3min you are done. The code is fully backward compatbile. For more
> details please check the release notes.
> -----Original message-----
> > From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> > Sent: Sunday 11th February 2018 23:58
> > Hi all,
> > Im thinking of transitioning from v16 to v17. I do however have a large
> number of previous simulations in v16. Id like to be able to keep using
> amount of time.
> must I keep in mind so that I can run my v16 versions on v17?
> > Sincerely,
> > Amitvikram Dutta
> > _______________________________________________
> > Nek5000-users at lists.mcs.anl.gov
> Subject: Digest Footer
> End of Nek5000-users Digest, Vol 108, Issue 18
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180212/0791dad8/attachment.html>
