[Nek5000-users] Nek5000-users Digest, Vol 108, Issue 2
Fri Feb 2 22:33:35 CST 2018
Thank you Paul and Phillip for such a quick reply. I will run the jet case
attached. So why was there no such problem when the first vortex from the
wake of a circular cylinder was leaving the domain?
On Sat, Feb 3, 2018 at 1:49 AM, <nek5000-users-request at lists.mcs.anl.gov>
wrote:
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>    1. Outflow Boundary Condition Clarification
>       (nek5000-users at lists.mcs.anl.gov)
>    2. Re: Outflow Boundary Condition Clarification
>    3. Re: Outflow Boundary Condition Clarification
> Message: 1
> Date: Sat, 3 Feb 2018 00:40:32 +0530
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] Outflow Boundary Condition Clarification
> Message-ID:
>         <mailman.7741.1517598636.19102.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="utf-8"
> Im trying to simulate the formation of shear layer when a jet exits a
> nozzle and enters the flow domain. As the FIRST vortex leaves the outlet (
> at which I have provided 'O' boundary condition using genbox) the solution
> diverges. I tried to implement the 'turbulent outflow' subroutine as
> suggested in the forum but now the vortex affects the upstream flow. But
> when I run the flow past circular cylinder example, the vortices leave the
> domain without any issue even though only 'O' boundary condition is used'.
> What is the difference between the two cases and what can i do to prevent
> the issue?
> Nitish Kovalam
> Aerospace Engineering
> Indian Institute of Space Science and Technology
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/
> attachments/20180203/87028828/attachment-0001.html>
> Message: 2
> Date: Fri, 2 Feb 2018 20:27:50 +0100
> Subject: Re: [Nek5000-users] Outflow Boundary Condition Clarification
> Message-ID:
>         <mailman.7745.1517601585.19102.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset=utf-8; format=flowed
> I think you should try the stabilised O condition, as described in a
> paper by Dong (2014). We have an implementation of that, we should
> probably provide it as a module in the repository.
> best regards,
> Philipp
> > ( at which I have provided 'O' boundary condition using genbox) the
> > solution diverges. I tried to implement the 'turbulent outflow'
> > subroutine as suggested in the forum but now the vortex affects the
> > upstream flow. But when I run the flow past circular cylinder example,
> > the vortices leave the domain without any issue even though only 'O'
> > boundary condition is used'. What is the difference between the two
> > cases and what can i do to prevent the issue?
> > Nitish Kovalam
> > _______________________________________________
> > Nek5000-users at lists.mcs.anl.gov
> Message: 3
> Date: Fri, 2 Feb 2018 20:19:54 +0000
> To: "nek5000-users at lists.mcs.anl.gov"
>         <nek5000-users at lists.mcs.anl.gov>
> Message-ID:
>         <mailman.7749.1517602797.19102.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="us-ascii"
> Attached is a .usr with turb_outflow that works for this case---there is
> no difficulty if you use the prescribed input values, as shown in the
> attached
> files.
> Here is a movie of the result - you can see that turb_outflow is turned on
> prior to the jet reaching the top of the domain.
> http://mcs.anl.gov/~obabko/jet_vm.mpeg
> This mesh is a bit under-resolved in the z-direction.
> The files for a new case, with more axial resolution, are posted here
> www.mcs.anl.gov/~fischer/jet2.tgz<http://www.mcs.anl.gov/~fischer/jet2.tgz
> I'll be posting an example with a script on how to build this geometry to
> nekexamples soon.
> Paul
> From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf
> of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Friday, February 2, 2018 1:10:32 PM
> the issue?
> Nitish Kovalam
> attachments/20180202/7cbaf33d/attachment.html>
> A non-text attachment was scrubbed...
> Type: application/octet-stream
> Desc: jet2.usr
> attachments/20180202/7cbaf33d/attachment.obj>
> Subject: Digest Footer
> End of Nek5000-users Digest, Vol 108, Issue 2
Nitish Kovalam
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180203/cda9c730/attachment.html>
