[Nek5000-users] Outflow Boundary Condition Clarification
Fri Feb 2 13:27:50 CST 2018
I think you should try the stabilised O condition, as described in a
paper by Dong (2014). We have an implementation of that, we should
probably provide it as a module in the repository.
best regards,
Philipp
On 2018-02-02 20:10, nek5000-users at lists.mcs.anl.gov wrote:
> Im trying to simulate the formation of shear layer when a jet exits a
> nozzle and enters the flow domain. As the FIRST vortex leaves the outlet
> ( at which I have provided 'O' boundary condition using genbox) the
> solution diverges. I tried to implement the 'turbulent outflow'
> subroutine as suggested in the forum but now the vortex affects the
> upstream flow. But when I run the flow past circular cylinder example,
> the vortices leave the domain without any issue even though only 'O'
> boundary condition is used'. What is the difference between the two
> cases and what can i do to prevent the issue?
> Nitish Kovalam
> Aerospace Engineering
> Indian Institute of Space Science and Technology
> Nek5000-users mailing list
