[Nek5000-users] Statistics toolbox for Nek5000
Tue Aug 28 12:18:30 CDT 2018
we are working on a version of this toolbox that is compatible with the
latest version of Nek5000, and should deliver statistics properly
oriented in any coordinate system one needs (e.g. Reynolds stresses
tangential/normal to surfaces), in 2D (assuming one homogeneous
direction) and 3D. There is also a (slightly outdated) manual of the
toolbox here:
https://www.osti.gov/biblio/1349052-turbulence-statistics-spectral-element-code-toolbox-high-fidelity-simulations
We will hopefully be able to provide the improved package soon.
Philipp
On 2018-08-28 19:08, nek5000-users at lists.mcs.anl.gov wrote:
> Hello everyone,
> I found this statistics toolbox for Nek5000
> https://github.com/Mopolino8/StatsToolbox
> However, according to the accompanying PDF documentation, there should
> be some folders called cpost3d, post3d and post2d, which are not in the
> repository. Does anyone have access to those folders?
> I am trying to compute transport equation budget terms but part of my
> results are strange, so I want to compare how the statistics toolbox
> computes them to verify if there is bug in my code.
> Thank you!
> Juan Diego
> Nek5000-users mailing list
