[Nek5000-users] Finite-amplitude disturbance based on os7000
Fri Apr 27 20:20:18 CDT 2018
Dear Emily,
At that amplitude, you are seeing the nonlinear
effects - this is at it should be.
If you wish to compare against linear theory, then
the amplitude needs to be small enough such that the
u.grad u term is quite small.
I'm not certain of your ultimate objective -- if you're
trying to measure convergence, then a small amplitude
is important.  If you are interested in large amplitude
effects, then you won't be able to compare with linear
theory results.
hth,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Friday, April 27, 2018 10:34:51 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Finite-amplitude disturbance based on os7000
Dear all,
First of all, thank you a lot for your help and feedback. The amplitude of ux’  in my case is 1.82E-1 which is superimposed on the base flow u = 1 – y**2 along with uy’ (this setting is identical to the literature paper). An order of BDF 3 is employed. Polynomial order is 8 with 4 elements in streamwise direction and 12 elements in the wall-normal direction. 1 wave length is simulated in the channel.
The default setting of os7000 was what I started. I have also tried to increase the spatial resolution, and reduce the time steps (dt = 0.05, 0.01, 0.005). However, it did not really change anything.  The distortion is less obvious if the magnitude of perturbation is decreased and totally disappears if it is as small as 1.82E-3.
Again, thank you a lot for the help and I will further explore the parameters and see what I can find.
Emily
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180428/9145854c/attachment.html>
