[Nek5000-users] neknek new version
Tue Sep 26 08:50:04 CDT 2017
"I guess what you are trying to do is to have one domain that is periodic
and use that to drive the flow in another domain, which is presumably
inflow-outflow?"
Yes. This is what I mean. And with old nek version (September 2015) my
function works very well, but now (after upgrade) it doesn't interpolate
velocity slice.
In my function I take two slice from each of session, change bc from P->inP
and v->inv, then set intflag = 1 for face with inv and inP and then i
change bc back to P and v as it was before.
Dear Vatslav,
It's not clear to me how your approach should function if your intent
is to change a Periodic BC to an overlapping-domain-interpolation one.
inflow-outflow? If that is your goal, you might find that recirculating BCs
would be of value (possibly a bit more efficient), depending on your setup.
If we understand the objective we might be able to help.
Best,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov
<https://vk.com/write?email=nek5000-users-bounces@lists.mcs.anl.gov>> on
behalf of nek5000-users at lists.mcs.anl.gov
<https://vk.com/write?email=nek5000-users@lists.mcs.anl.gov> <
<https://vk.com/write?email=nek5000-users@lists.mcs.anl.gov>>
Sent: Tuesday, September 26, 2017 3:06:33 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] neknek new version
Hi, Neks.
I use neknek script in my simulation. I write the function like set_intflag
in multimesh.f to find special bc and mark it:
nfaces = 2*ndim
nel = nelfld(ifield)
nflag=nel*nfaces
call izero(intflag,nflag)
do j=1,ifield
do e=1,nel
do f=1,nfaces
if ( session.eq.'pipe_per1' ) then
if ( cbc(f,e,j).eq.'P ' ) intflag(f,e) = 1
endif
if ( session.eq.'pipe_per2' ) then
if ( cbc(f,e,j).eq.'v ' ) intflag(f,e) = 1
endif
enddo
enddo
enddo
( from periodic bc in one nek-session to inlet bc in another nek-session ).
So, it works very well on old version of nek, but on the latest version of
Nek5000 i can't interpolate boundary slice between two session in such way
anymore. And I absolutely no idea why.
Can anyone say how it can be fixed?
Regard, Vatslav
С уважением, Владимир Рыженьков
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170926/04e70264/attachment.html>
