[Nek5000-users] neknek new version
Tue Sep 26 07:03:11 CDT 2017
Dear Vatslav,
It's not clear to me how your approach should function if your intent
is to change a Periodic BC to an overlapping-domain-interpolation one.
I guess what you are trying to do is to have one domain that is periodic
and use that to drive the flow in another domain, which is presumably
inflow-outflow?   If that is your goal, you might find that recirculating BCs
would be of value (possibly a bit more efficient), depending on your setup.
If we understand the objective we might be able to help.
Best,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Tuesday, September 26, 2017 3:06:33 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] neknek new version
Hi, Neks.
I use neknek script in my simulation. I write the function like set_intflag in multimesh.f to find special bc and mark it:
      nfaces = 2*ndim
      nel    = nelfld(ifield)
      nflag=nel*nfaces
      call izero(intflag,nflag)
      do j=1,ifield
      do e=1,nel
      do f=1,nfaces
        if ( session.eq.'pipe_per1' ) then
          if ( cbc(f,e,j).eq.'P  ' ) intflag(f,e) = 1
        endif
        if ( session.eq.'pipe_per2' ) then
          if ( cbc(f,e,j).eq.'v  ' ) intflag(f,e) = 1
        endif
      enddo
      enddo
      enddo
( from periodic bc in one nek-session to inlet bc in another nek-session ).
So, it works very well on old version of nek, but on the latest version of Nek5000 i can't interpolate boundary slice between two session in such way anymore. And I absolutely no idea why.
Can anyone say how it can be fixed?
Regard, Vatslav
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170926/193abf89/attachment.html>
