[Nek5000-users] Volume integral time derivative vorticity
Wed Sep 20 04:20:23 CDT 2017
Thanks for your help.
I successfully oet volume integrals thanks to your suggestions. I was
integrating with some do loops, but the idea of the mask is nice. I
got vorticity at the previous timestep with lag variables.
Now, to end the work, I also need a surface integral around the
rectangle, so defined:
F=int | x ^ [n ^( vor ^ V)] dS
      /S_r
Where x is the position vector, n is the normal versor, vor is the
vorticity and V is the velocity. The tricky issue is how to select the
faces where to integrate. I've found functions area and unx,uny,unz to
get the area of each face, and their normal versors. I've also found
this example in the documentation
   integer e,f
   call facind (i0,i1,j0,j1,k0,k1,f)
   ia   = 0
   flux = 0
   do k=k0,k1
   do j=j0,j1
   do i=i0,i1
   ia = ia + 1
   flux = flux + ( vx(i,j,k,e)*unx(ia,1,f,e)+
      $  +vy(i,j,k,e)*uny(ia,1,f,e)
      $  +vz(i,j,k,e)*unz(ia,1,f,e) )*area(ia,1,f,e)
   enddo
   enddo
   enddo
If I succeed in selecting the faces, maybe I can do something similar
to get the surface integral. Is there a way to get the adjacent cells
to a given face? I'm thinking about a loop over the mask function
selecting the cells where the mask function is 0 and in the adjacent
cell is 0, choosing in this way the face where to integrate (by now I
didn't set a smoothing on the mask function). Have you any other idea?
Thank you very much
Mario
Quoting nek5000-users at lists.mcs.anl.gov:
> another way would be to just compute the vorticity at the previous
> time, and store it. Regarding the integration, I would suggest that
> you define a mask function (based on coordinate values) which is 0
> and 1 depending on whether you are outside/inside of the integration
> domain (potentially with some smoothing), and then multiply your
> vorticity before multiplying with bm1 and summing.
> Philipp
> On 2017-09-19 19:42, nek5000-users at lists.mcs.anl.gov wrote:
>> You'll find the previous velocity in the vxlag array. Integration
>> is easy, just multiply by bm1 and sum up. The tricky part might be
>> to identify your sub-domain i.e. the elements.
>> -----Original message-----
>>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>>> Sent: Tuesday 19th September 2017 18:46
>>> To: nek5000-users at lists.mcs.anl.gov	 <nek5000-users at lists.mcs.anl.gov>
>>> Subject: [Nek5000-users] Volume integral time derivative vorticity
>>> I performed some simulations around a plunging flat plate.
>>> I have to compute the volume integral over a choosen domain (a
>>> rectangle around the body with a fixed geometrical dimension) of
>>> the eulerian time derivative of the vorticity field multiplied by
>>> the local position vector components. I found a subroutine to
>>> compute the vorticity. How should I compute vorticity at the
>>> previous timestep? And how can I perform the integrations?
>>> Thanks
>>> Mario
>>> Mario Ostieri
>>> Ph.D. Student
>>> University of Naples Federico II
>>> Department of Industrial Engineering
>>> Piazzale V. Tecchio 80
>>> 80125 Napoli, Italy
>>> tel. +390817682184
>>> email: mario.ostieri at unina.it
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Mario Ostieri
Ph.D. Student
80125 Napoli, Italy
tel. +390817682184
