[Nek5000-users] Convection velocity and outlet BC
Sun Sep 17 12:03:24 CDT 2017
for the convective conditions, you need a convection velocity, and there
are different ways to do that, e.g. averaging over a plane, time
relaxation, or taking the mean velocity (e.g. from statistics). The
important point is that you need to make sure that the global mass flux
is correct.
The Dong condition does not need a convection velocity, as the two
parameters can be combined into a single parameter.
I will get back to you with our implementation of the convective
condition, sorry that I haven't done it yet as I was travelling.
Philipp
On 2017-09-17 18:59, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks,
> for different convective boundary conditions there is a parameter I need
> to calculate: the convection velocity, which can be aproximated as
> the mean streamwise velocity averaged at the exit plane.
> Is there a quick way to calculate Uc for each time step?
> Now I'm using Dong (2014) BC, but it also needs a convection velocity,
> and I'm using an aproximate number, but I'd like to calculate the right one.
> On the other hand, the BC I'd like to try now is:
> (du_i/dt)+Uc*(du_i/dy)=0
> (dT/dt)+Uc*(dT/dy)=0
> where the stramwise direction is y, since it is a free convection flow,
> and Uc is the convection velocity.
> And, any idea or help to implement those BC?
> Thank you very much,
> Juan Pablo.
> Nek5000-users mailing list
