[Nek5000-users] Nek5000-users Digest, Vol 103, Issue 12
Fri Sep 15 08:43:32 CDT 2017
Thank you all.
I will refer to the new version in doxygen for more information.
Bolun
-----邮件原件-----
发件人: nek5000-users-bounces at lists.mcs.anl.gov
[mailto:nek5000-users-bounces at lists.mcs.anl.gov] 代表
nek5000-users-request at lists.mcs.anl.gov
发送时间: 2017年9月15日 20:05
收件人: nek5000-users at lists.mcs.anl.gov
主题: Nek5000-users Digest, Vol 103, Issue 12
Send Nek5000-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	nek5000-users-owner at lists.mcs.anl.gov
When replying, please edit your Subject line so it is more specific than
"Re: Contents of Nek5000-users digest..."
Today's Topics:
   1. Re: time integration scheme for temperature/scalar equations
      (nek5000-users at lists.mcs.anl.gov)
   2. Re: Nek5000-users Digest, Vol 103, Issue 9
Message: 1
Date: Fri, 15 Sep 2017 13:02:20 +0200
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] time integration scheme for
Message-ID:
	<mailman.839.1505473384.10190.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="windows-1252"; Format="flowed"
To be more precise. Routines "makeabq" and "makebdq" are called if you use
hemholtz solver for passive scalars. The other option is cvode, which uses
slightly different scheme. I guess hemholtz is default and to use cvode you
have to add CVODE to preprocessing flag. About the link to doxygen. This one
is outdated so it could be dangerous to use it. There is doxygen showing
current beta2 version under
https://adampep.github.io/KTH_Framework/files.html
Regards
Adam
On 15/09/17 12:11, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Bolun Xu,
> Yes,
> you can see that in the conduct.f file( in which convection-diffusion
> equation for temperature is solved):
> http://www.mcs.anl.gov/research/projects/nek5/docs/html/conduct_8f_sou
> rce.html
> In the subroutine "makeabq"  the same Adam-Bashforth coefficients AB()
> are called and in the subroutine "makebdq", the BD() coefficients are
> used again.
> best,
> Pierre-Emmanuel
> On 2017-09-15 11:47, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi! All,
>> I learned from the subroutines makeabf and makebdf in navier1.f that
>> the time integration scheme for momentum equation is the AB-CN
>> scheme, that explicit schemes for nonlinear and forcing term, and
>> implicit ones for viscous term. The prefactors of those schemes are
>> stored in AB() and BD() arrays. Now my question is, whether the
>> temperature/scalar equations also use the same schemes as momentum
>> ones and also share the same prefactors in
>> AB() / BD() arrays.
>> Any help is appreciated.
>> Regards.
>> Bolun Xu
>> University of Science and Technology of China
>> Department of Modern Mechanics
>> Hefei, Anhui, China
>> Nek5000-users at lists.mcs.anl.gov
URL:
<http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170915/b385a
e23/attachment-0001.html>
Message: 2
Date: Fri, 15 Sep 2017 07:51:15 +0000
To: "nek5000-users at lists.mcs.anl.gov"
	<nek5000-users at lists.mcs.anl.gov>
Subject: Re: [Nek5000-users] Nek5000-users Digest, Vol 103, Issue 9
Message-ID:
	<mailman.845.1505477125.10190.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="us-ascii"
Hi Goran,
First of all thanks for having a look, my box file is as follows:
plume_v2_largeIni.rea
2                      spatial dimension
2                      number of fields
Box_1
-20 -50                    nel_1, nel_2
0. 50.  0.8                x0, x1
0. 100.  1.1               y0, y1
W  ,E  ,W  ,W              (bc's) velocity (west, east, south, north)
T  ,E  ,t  ,W              (bc's) temperature (west, east, south, north)
Box_2
50. 100.  1.2              x0, x1
0. 100.  1.1               y0, y1
E  ,W  ,W  ,W              (bc's) velocity (west, east, south, north)
E  ,T  ,t  ,W              (bc's) temperature (west, east, south, north)
I think where I'm struggling is in working out how the output (0.f#####)
files are structured, or how their structure relates to the actual solution.
I've managed to get the (2000, in this case) element mappings out of the
files, I just can't then get this mapping to actually map the elements
correctly.
Thanks again,
Daniel
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of
<nek5000-users-request at lists.mcs.anl.gov>
Sent: 14 September 2017 17:29:13
Subject: Nek5000-users Digest, Vol 103, Issue 9
Today's Topics:
   1. Problems with post-processing multiple-boxes in MATLAB and
      Python (nek5000-users at lists.mcs.anl.gov)
   2. Re: Problems with post-processing multiple-boxes in MATLAB
      and Python (nek5000-users at lists.mcs.anl.gov)
   3. Re: Problems with post-processing multiple-boxes in MATLAB
   4. Re: proj_ortho error in pipe flow
   5. problem with applying boundary conditions
Message: 1
Date: Thu, 14 Sep 2017 14:57:27 +0000
Subject: [Nek5000-users] Problems with post-processing multiple-boxes
        in MATLAB and Python
Message-ID:
        <mailman.763.1505402018.10190.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="iso-8859-1"
Hi All,
I am using Nek5000 to simulate a buoyant plume rising from the centre of the
floor of a square 2D domain.  I am trying to use MATLAB and/or Python to
post-process my data.  Everything works fine when I post-process a
simulation that was initialised with only one box in my .box file.  When,
however, I run a simulation with multiple boxes (i.e. to cluster nodes), the
local to global mapping of elements appears to go wrong and puts data into
the wrong places.  When plotting a contour plot of coordinates for example,
where I would expect a constantly changing colour gradient, I instead get
back colour gradients in four quarters.
I haven't used this list before so if I need to provide examples of images
or code I can do.  If anybody else has had this problem and has found a way
to overcome it by finding the correct mapping some help would be very much
appreciated.
Best regards,
Daniel Ward
URL:
<http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170914/94fe0
7e8/attachment-0001.html>
Message: 2
Date: Thu, 14 Sep 2017 15:20:27 +0000
To: shivang agarwal <nek5000-users at lists.mcs.anl.gov>
Subject: Re: [Nek5000-users] Problems with post-processing
        multiple-boxes in MATLAB and Python
Message-ID:
        <mailman.765.1505402478.10190.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="utf-8"
Hi Daniel,
I've had a similar problem before. Can you send your .box file so we can
have a look?
Best regards,
Goran
On Sep 14, 2017, at 11:13,
"nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>"
<nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
wrote:
Hi All,
appreciated.
Best regards,
Daniel Ward
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
URL:
<http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170914/e8a27
1d0/attachment-0001.html>
Message: 3
Date: Thu, 14 Sep 2017 15:33:07 +0000
Message-ID:
        <mailman.767.1505403191.10190.nek5000-users at lists.mcs.anl.gov>
Hi All,
Genbox generates a tensor-product array of elements with layout:
   (ix , iy, iz)    (ix fastest moving, iy 2nd fastest, iz 3rd fastest)
If you want to have multiple boxes that continue in this ordering, you could
do the following, say:
box (1)
-5 -5 -5
-1 1 1.0
-1 1 1.0
0 2   1.0
box(2)
-5 -5 -10
-1 1 1
-1 1 1
1.0 9.0
etc
This would stack a 5x5x10 box on top of a 5x5x5 box
and topologically is the same as a 5x5 x (15) box
... i.e., things get concatenated in the z direction.
Also, note that you can use custom distributions in each direction, e.g.,
box
3  3  -5
0 0.1 0.3  10
0  .9   22 33
-5  9  1.5
which would give spacing [ 0 .1 .3 10] in the x direction
[0 .9 22 33] in y
and geometric partition of 5 elements in z on [-5:9]
with size ratio 1.5 between each adjacent z level.
hth
Paul
nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Thursday, September 14, 2017 10:20:27 AM
To: shivang agarwal
Subject: Re: [Nek5000-users] Problems with post-processing multiple-boxes in
MATLAB and Python
Hi Daniel,
have a look?
Best regards,
Goran
wrote:
Hi All,
appreciated.
Best regards,
Daniel Ward
URL:
<http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170914/4ab97
69c/attachment-0001.html>
Message: 4
Date: Thu, 14 Sep 2017 15:34:39 +0000
Subject: Re: [Nek5000-users] proj_ortho error in pipe flow
Message-ID:
        <mailman.770.1505403282.10190.nek5000-users at lists.mcs.anl.gov>
Hi Steffen,
Thanks for bringing this to our attention.
Adam and I have been looking into this... (no doubt, it's something
stupid done by me awhile back).
Hope to have it resolved by next week.
Best,
Paul
Sent: Thursday, September 14, 2017 8:18:27 AM
I have made some more tests to find the cause of this issue.
Attached is a laminar pipe flow simulation with temperature and one passive
scalar. The original setup is from Paul's "nusselt.tgz", where he answered
another question of mine.
I found that I can reproduce the same error I see in my turbulent
simulations when there is an additional passive scalar with a different type
of boundary condition, i.e. Neumann boundary condition at the pipe wall for
temperature and Dirichlet boundary condition for the passive scalar.
Can someone please check my setup and tell me why this causes the projection
to fail?
I hope to save some computational resources by using the projection.
However, if it is not possible, I will keep param(94) = 0.
Kind Regards,
Steffen Straub
Karlsruhe Institute of Technology (KIT)
Institute of Fluid Mechanics
M.Sc. Steffen Straub
Doctoral Researcher
Kaiserstra?e 10
Building 10.23
76131 Karlsruhe, Germany
Phone: +49 721 608-43027
E-mail: steffen.straub at kit.edu
Web: http://www.istm.kit.edu
KIT ? The Research University in the Helmholtz Association
Since 2010, the KIT has been certified as a family-friendly university.
URL:
<http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170914/33060
82d/attachment-0001.html>
Message: 5
Date: Thu, 14 Sep 2017 12:29:10 -0400
Subject: [Nek5000-users] problem with applying boundary conditions
Message-ID:
        <mailman.778.1505406553.10190.nek5000-users at lists.mcs.anl.gov>
Dear Neks,
I am trying to run a simulation, replicating the Nek5000 run from this
youtube video:
https://www.youtube.com/watch?v=RmmN-KFSvAY
The inlet BC is constant velocity (which is set to 1.0), and as can be seen
from the video, the velocity magnitude reasonably away from the inlet is
zero at starting times. However, in all of my simulations, I see the
velocity magnitude as one at all the interior points away from the inlet
from the beginning (the inlet BC ux=1.0 I am applying is somehow propagated
to all interior elements). Am I doing something wrong somewhere, or is this
the expected behavior? Please see my userbc() and useric() from my .usr file
below:
      subroutine userbc (ix,iy,iz,iside,eg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      integer ix,iy,iz,eg,e,i,n
CC "My inlet is at x=0"
      if (x.le.1e-4) then
        ux=1.0
      endif
      return
      end
      subroutine useric (ix,iy,iz,eg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ux=0
      uy=0
      return
      end
I believe userbc() is executed for only 'v' in my case. For the other
constraints on the elements (like 'W', 'O', 'E'),  I think userbc() would
not run (please correct me if I am wrong, I am learning here). Since the
above functions wouldn't work as expected, I changed userchk() and removed
the above if statements in userbc(). My userchk() is as follows:
      subroutine userchk
      include 'SIZE'
      include 'TOTAL'
      integer i,n
      n = nx1*ny1*nz1*nelv
      if (istep.eq.0) then
        do i=1,n
          if (xm1(i,1,1,1).le.1e-4) then
            vx(i,1,1,1)=1
          endif
        enddo
      endif
      return
      end
This didn't work either. Can somebody point me in the right direction?
Ajay
URL:
<http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170914/bb155
242/attachment.html>
Subject: Digest Footer
End of Nek5000-users Digest, Vol 103, Issue 9
URL:
<http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170915/322d1
3e9/attachment.html>
End of Nek5000-users Digest, Vol 103, Issue 12
