[Nek5000-users] time integration scheme for temperature/scalar equations
Fri Sep 15 05:11:50 CDT 2017
Hi Bolun Xu,
Yes,
you can see that in the conduct.f file( in which convection-diffusion
equation for temperature is solved):
http://www.mcs.anl.gov/research/projects/nek5/docs/html/conduct_8f_source.html
In the subroutine "makeabq"  the same Adam-Bashforth coefficients AB()
are called and in the subroutine "makebdq", the BD() coefficients are
used again.
best,
Pierre-Emmanuel
On 2017-09-15 11:47, nek5000-users at lists.mcs.anl.gov wrote:
> Hi! All,
> I learned from the subroutines makeabf and makebdf in navier1.f that the
> time integration scheme for momentum equation is the AB-CN scheme, that
> explicit schemes for nonlinear and forcing term, and implicit ones for
> viscous term. The prefactors of those schemes are stored in AB() and BD()
> arrays. Now my question is, whether the temperature/scalar equations also
> use the same schemes as momentum ones and also share the same prefactors in
> AB() / BD() arrays.
> Any help is appreciated.
> Regards.
> Bolun Xu
> University of Science and Technology of China
> Department of Modern Mechanics
> Hefei, Anhui, China
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170915/087f8efb/attachment-0001.html>
