[Nek5000-users] Problems with post-processing multiple-boxes in MATLAB and Python
Thu Sep 14 10:20:27 CDT 2017
Hi Daniel,
I've had a similar problem before. Can you send your .box file so we can have a look?
Best regards,
Goran
On Sep 14, 2017, at 11:13, "nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>" <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
Hi All,
I am using Nek5000 to simulate a buoyant plume rising from the centre of the floor of a square 2D domain.  I am trying to use MATLAB and/or Python to post-process my data.  Everything works fine when I post-process a simulation that was initialised with only one box in my .box file.  When, however, I run a simulation with multiple boxes (i.e. to cluster nodes), the local to global mapping of elements appears to go wrong and puts data into the wrong places.  When plotting a contour plot of coordinates for example, where I would expect a constantly changing colour gradient, I instead get back colour gradients in four quarters.
I haven't used this list before so if I need to provide examples of images or code I can do.  If anybody else has had this problem and has found a way to overcome it by finding the correct mapping some help would be very much appreciated.
Best regards,
Daniel Ward
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170914/e8a271d0/attachment.html>
