[Nek5000-users] Short test : dfh_cav
Wed Oct 11 02:06:22 CDT 2017
Thank you very much Stefan and Aleks for your wise advices.
Samuel
Message: 1
Date: Tue, 10 Oct 2017 15:39:23 +0200
To: nek5000-users at lists.mcs.anl.gov
<nek5000-users at lists.mcs.anl.gov>
Subject: Re: [Nek5000-users] Short test : dfh_cav
Message-ID:
     <mailman.59.1507642769.19102.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset=utf-8
Just call gen_rea_full(0) and you're all set.
btw: re2torea works as well but you have to provide (in addition to
.re2) a rea template!
Cheers,
Stefan
-----Original message-----
     Sent: Tuesday 10th October 2017 15:21
     Hi Samuel,
     try calling gen_rea(0) from your usrdat2() and modify the ASCII mesh
& BC file newrea.out for the .rea's header and bottom part taken from,
e.g., svn's examples/vortex/r1854a.rea but make sure that your first
field file has coordinates. ?
     Also note that the .rea's p66 for postx has to be 4 for .fld and 6
for .f field files.
     Aleks
     From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on
behalf of nek5000-users at lists.mcs.anl.gov
     Sent: Tuesday, October 10, 2017 8:08:08 AM
     Hi again,
     As I'm trying to visualize the case using postx, I get the error
"can't
     open the file lin_dfh_cav_dir.rea". It seems normal because this
file
     doesn't exist.
     I tried to use re2torea to create the file but it is not working.
     Does anyone has any suggestion ?
     Samuel
     Le 2017-10-09 11:48, Samuel a ?crit?:
         Thank you for your quick answer guys.
         Best regards,
         Samuel
     Nek5000-users mailing list
     Nek5000-users at lists.mcs.anl.gov
     https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
