[Nek5000-users] Output file temperature looks corrupted
Wed Oct 4 04:46:00 CDT 2017
What version of Nek5000 are you using?
Do you use .fXXXXX field files? Single or double precision?
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Wednesday 4th October 2017 11:43
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] Output file temperature looks corrupted
> Hi all, after using visnek to create a .nek5000 file and viewing the data in ParaView I found that the temperature data for the bottom half of my domain looks corrupted. As you can see in the image the top half of the domain is correct.
>  This corrupted data only effects the temperature, the velocity and pressure are ok for the whole domain. I only started seeing this issue after switching from 7th order to 11th order.
> Thanks for any help.
> Andrew
> Nek5000-users mailing list
