[Nek5000-users] Output file temperature looks corrupted
Wed Oct 4 04:42:43 CDT 2017
Hi all, after using visnek to create a .nek5000 file and viewing the data in ParaView I found that the temperature data for the bottom half of my domain looks corrupted. As you can see in the image the top half of the domain is correct. This corrupted data only effects the temperature, the velocity and pressure are ok for the whole domain. I only started seeing this issue after switching from 7th order to 11th order.
Thanks for any help.
Andrew
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171004/69165dd4/attachment-0001.html>
Type: image/png
Desc: nek_temperature.PNG
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171004/69165dd4/attachment-0001.png>
