[Nek5000-users] Specifying the Froude Number
Thu Nov 23 11:49:17 CST 2017
I guess the Froude number and the way to exactly specify it depends on
the scaling of your equations. Your numbers indicate that your gravity
is in the x/y plane, 4 degrees off the x axis?
But in principle, this is the correct place, you just need to add the
correct factor in front of "temp". I suggest also to use a cos/sin for
specifying the direction (if I understand your code).
Philipp
On 2017-11-23 18:05, nek5000-users at lists.mcs.anl.gov wrote:
> Hi All,
> I'm trying to work out how to specify the Froude number in my simulation
> of a buoyant plume.  I can specify Reynolds and Peclet in the .rea file
> but there doesn't seem to be anywhere analogous for Fr.  I thought it
> might be in the .usr function in the subroutine userf, mine currently
> looks like this:
>        subroutine userf  (ix,iy,iz,iel)
>        include 'SIZE'
>        include 'TSTEP'
> c     include 'TOTAL'
>        include 'NEKUSE'
>        integer e,f,eg
>        ffx = -0.06976*temp
>        ffy = 0.9976*temp
>        ffz = 0.0
>        return
>        end
> Does anyone have any idea (if this is the correct place, and) how I can
> specify Fr here.  I also want to ensure gravity is in the correct
> direction (namely, towards the floor), and how does what I have at the
> moment do this?  My simulation outputs do have gravity in the correct
> direction, so it must be correct.
> Thank you in advance.
> Best,
> Daniel
> Nek5000-users mailing list
