[Nek5000-users] Error while compiling exo2nek
Tue Nov 21 09:40:48 CST 2017
No, I ran it without sudo as well, and cchanged to sudo when I got the
permission error.
On an additional issue, I'm generating my meshes in the exodusII format by
using PoinWise and then exporting the exodusII file. exo2nek fails with the
following error message when I try to use it on these files.
EXODUS: ERROR: Attempting to open the netcdf-4 file:
    'pw_exo1.exo'
    . Either the netcdf library does not support netcdf-4 or there is a
filesystem or some other issue
ERROR: cannot open file pw_exo1.exo
On checking the properties of the .exo file I found that its an HDF
document and not a netcdf file.
Since Marco's file converts without problems I'm sure the issue lies in how
pointwise is exporting the exodusII files.
Is exo2nek not a viable alternative for exodusII files then?
On Tue, Nov 21, 2017 at 10:33 AM <nek5000-users at lists.mcs.anl.gov> wrote:
> I guess the mistake was to run ./maketools exo2nek with sudo.
> -----Original message-----
> > From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> > Sent: Tuesday 21st November 2017 16:13
> > To: nek5000-users at lists.mcs.anl.gov
> > Subject: Re: [Nek5000-users] Error while compiling exo2nek
> > Changed the permission of the install file and it works fine now.
> > Also the mesh supplied by Marco has been converted sucessfully and a
> .re2 file has been generated.
> > Thanks all!
> > On Tue, Nov 21, 2017 at 9:45 AM <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
> > > env: ‘./install’: Permission denied
> > Looks like you cannot run the install. Can you check the permissions.
> > > From:nek5000-users at lists.mcs.anl.gov <mailto:
> From%3Anek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov
> > > Sent: Tuesday 21st November 2017 15:38
> > > To: nek5000-users at lists.mcs.anl.gov <mailto:
> > > Hi Marco,
> > > I cant get exo2nek to compile properly at all. After downloading the
> latest version I get the following error messages when I run sudo
> ./maketools exo2nek
> > > Make exo2nek...
> > > make[1]: Entering directory /home/adutta/Nek5000/tools/exo2nek
> > > make[1]: Warning: File makefile has modification time 17453 s in the
> future
> > > makefile:19: recipe for target lib failed
> > > make[1]: *** [lib] Error 126
> > > make[1]: Leaving directory /home/adutta/Nek5000/tools/exo2nek
> > > ERROR: exo2nek failed to compile!
> > > makefile:4: recipe for target all failed
> > > make: *** [all] Error 1
> > > On Tue, Nov 21, 2017 at 9:33 AM <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov> <mailto:
> nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>>>
> wrote:
> > > Can you try the exo2nek script on the attached exo mesh file and see
> if it works. It works on my machine. It has 2496 elements and 3 sidesets.
> > > Marco
> > > _______________________________________________
> > > Nek5000-users mailing list
> > > Nek5000-users at lists.mcs.anl.gov <mailto:
> Nek5000-users at lists.mcs.anl.gov> <mailto:Nek5000-users at lists.mcs.anl.gov
> <mailto:Nek5000-users at lists.mcs.anl.gov>>
> > > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users <
> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users> <
> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>>
> > > Amitvikram Dutta
> > > Graduate Research Assistant
> > > Fluid Mechanics Research Lab
> > > University of Waterloo
> > Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
> > Amitvikram Dutta
*Amitvikram Dutta*
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171121/7547552d/attachment-0001.html>
