[Nek5000-users] Error while compiling exo2nek
Tue Nov 21 09:26:51 CST 2017
I guess the mistake was to run ./maketools exo2nek with sudo.
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Tuesday 21st November 2017 16:13
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Error while compiling exo2nek
> Changed the permission of the install file and it works fine now.
> Also the mesh supplied by Marco has been converted sucessfully and a .re2 file has been generated.
> Thanks all!
> On Tue, Nov 21, 2017 at 9:45 AM <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
> > env: ‘./install’: Permission denied
> Looks like you cannot run the install. Can you check the permissions.
> > From:nek5000-users at lists.mcs.anl.gov <mailto:From%3Anek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>>
> > Sent: Tuesday 21st November 2017 15:38
> > To: nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>
> > Hi Marco,
> > I cant get exo2nek to compile properly at all. After downloading the latest version I get the following error messages when I run sudo ./maketools exo2nek
> > Make exo2nek...
> > make[1]: Entering directory /home/adutta/Nek5000/tools/exo2nek
> > make[1]: Warning: File makefile has modification time 17453 s in the future
> > makefile:19: recipe for target lib failed
> > make[1]: *** [lib] Error 126
> > make[1]: Leaving directory /home/adutta/Nek5000/tools/exo2nek
> > ERROR: exo2nek failed to compile!
> > makefile:4: recipe for target all failed
> > make: *** [all] Error 1
> > On Tue, Nov 21, 2017 at 9:33 AM <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> <mailto:nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>>> wrote:
> > Can you try the exo2nek script on the attached exo mesh file and see if it works. It works on my machine. It has 2496 elements and 3 sidesets.
> > Marco
> > _______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov> <mailto:Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>>
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users> <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>>
> > Amitvikram Dutta
> > Graduate Research Assistant
> > Fluid Mechanics Research Lab
> > University of Waterloo
> Amitvikram Dutta
