[Nek5000-users] Converting Mesh using exo2nek
Mon Nov 13 21:23:04 CST 2017
- Yes, this is correct
- Check usrdat2() of short_test/ethier.usr - exo2nek stores the side set ID in bc(5,ifc,iel,1)
- Yes!
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Tuesday 14th November 2017 3:52
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Converting Mesh using exo2nek
> Dear Neks,
> The latest version of Nek doesnt suport MOAB for mesh convertion, so the only way to import a complex mesh (e.g. from Trelis/CUBIT) is using exo2nek. Am I right?
> Is there any example case to understand how does it work? The old examples to understand MOAB cases showed how to set the BCs using the sidesets in the rea file, but now I dont know how to set the BCs in the usr file, and I havent found any guide or example for this.
> And, finally, if Im using an old Nek version, (.rea instead of .par for parameters) would it work having the .rea and the .re2 file, for the parameters and for the mesh respectively?
> Thanks in advance,
> Juan Pablo.
> Nek5000-users mailing list
