[Nek5000-users] genmap error
Fri Nov 10 00:46:04 CST 2017
I guess you convert does somehow not produce the expected format.
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Friday 10th November 2017 5:48
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] genmap error
> Hey neks,
> Im having a wierd genmap error while trying to convert from a gmsh format to nek format using cpraveens script. The .rea file generates correctly but I cannot run genmap after that. trying to compile the case without running genmap also gives an error.
> The error message from genmap is
> ERROR: error reading    1           1         891
>   aborting 510 in routine rdbdry.
> I can email the .geo and .msh files if required
> Sincerely,
> Amitvikram Dutta
> Graduate Research Assistant
> Fluid Mechanics Research Lab
> University of Waterloo
> Nek5000-users mailing list
