[Nek5000-users] IFCHAR option in rea file
Mon Nov 6 07:34:18 CST 2017
Thanks very much Paul.
Sincerely,
NN.
On Monday 06 November 2017 01:30 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Dear NN,
> If your flow is turbulent the answer is definitely Yes (they will be
> different) because of the standard sensitivity to initial condition
> concerns.
> Despite this, both schemes are O(dt^k) accurate, meaning  that as
> dt-->0, the error goes to _zero_ as dt^k, where k=Torder is the
> prescribed temporal order.   Since the error goes to zero, both will
> deliver the same answer provided that the physical solution is stable
> and has an attractor. [Understanding when such conditions prevail is
> often a challenge.]
> Paul
> *From:* Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on
> behalf of nek5000-users at lists.mcs.anl.gov
> <nek5000-users at lists.mcs.anl.gov>
> *Sent:* Monday, November 6, 2017 6:13:11 AM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* [Nek5000-users] IFCHAR option in rea file
> Hello,
>   I have been using IFCHAR = TRUE in my simulations. The CFL number is
> around
> 1.2 and the computations appear to go on nicely. I would like to know
> if the flow field computed using IFCHAR=TRUE option is different than the
> one obtained with IFCHAR=FALSE (albeit with smaller dt)? If yes, can the
> difference
> be significant?
> Many thanks,
> NN
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171106/f6e863b7/attachment.html>
