[Nek5000-users] Interpolation between two meshes
Mon Mar 27 06:56:02 CDT 2017
Hi Tony,
I have encountered the same issue with g2gi when interpolating very
large meshes. I don't know what is causing the issue but a workaround is
to reduce the polynomial order. You obviously loose accuracy by doing
this, but I still find it better than starting from scratch with the new
mesh. Hope this helps.
Best,
Mattias
On 03/27/2017 06:37 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks,
> I have been using 'g2gi' to do interpolation between different meshes.
> Recently, I have noticed that when I interpolate between two big
> meshes (say 300000 elements in each mesh), the interpolation hangs at
> 'call findpts' and never moves on. I tried increasing number of
> processors and changing 'lpart', but none of these worked.
> I'm wondering what could cause the interpolation to hang at 'findpts'.
> Has anyone encountered similar issue?
> Hope anyone could give me some advice. Thank you very much in advance.
> Best regards,
> Tony
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170327/031d792f/attachment-0001.html>
