[Nek5000-users] Dimensionfull passive scalar
Fri Mar 24 03:47:01 CDT 2017
Hi!
I am simulating a flow where thermodynamic processes takes place.
Since these thermodynamic processes are rather complicated I decided that developing the set up is best done in dimensionfull variables. Here I ran into unexpected problems since it seems as if the parameters in the .rea file do not work as I thought they would.
The temperature solution works well. Putting in the "rhocp" and "conduct" of my fluid into "p007" and "p008" gives the results that I expect.
However, I also have two passive scalars. For them I am not sure what the meaning of "rhocp" actually is.
>From eqn (1.4) of Ref. [*] I would assume that setting up a passive scalar \phi with diffusivity a = 2.14E-5 m^2/s evolving as
D \phi /D t = a Laplacian(\phi)        [D/Dt = total derivative]
means using "rhocp = 1" and "a = 2.14E-5". However, this seems to not be the case, since under these assumptions the corresponding dimensionless set-up gives totally different results.
If my understanding was correct it would only be the ratio of "rhocp" and "conduct" that matters fo a scalar, but I have found that the individual values matter.
This leads me to the questions:
* What is the meaning of "rhocp" and "conduct" for a scalar?
* In which dimensions "rhocp" and "conduct" for a scalar?
* Why does the individual values of "rhocp" and "conduct" matter, when they should no according to eqn (1.4) of Ref. [*]?
Best,
Johan
[*]: User Documentation: http://nek5000.github.io/NekDoc/Nek_users.pdf
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170324/a06505ff/attachment-0001.html>
