[Nek5000-users] Interpolation on a finer mesh
Wed Jun 21 04:12:19 CDT 2017
Hello Stefan,
thanks for your quick reply.
I have just tested the generic fld reader gfldr as you suggested.
It is super easy and works like a charm.
Cheers,
Steffen
On 06/20/2017 07:00 PM, nek5000-users-request at lists.mcs.anl.gov wrote:
> Message: 2 Date: Tue, 20 Jun 2017 15:39:10 +0200 From:
> nek5000-users at lists.mcs.anl.gov To: nek5000-users at lists.mcs.anl.gov
> <nek5000-users at lists.mcs.anl.gov> Subject: Re: [Nek5000-users]
> Interpolation on a finer mesh Message-ID:
> <mailman.9088.1497966043.2967.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset=utf-8 You can use our generic fld
> reader. Just add this to userchk(): if(istep.eq.0) call
> gfldr('myfldfilename') This will interpolate your field file data to
> your new mesh. You're all set :) Cheers, Stefan -----Original
> message-----
>> From:nek5000-users at lists.mcs.anl.gov  <nek5000-users at lists.mcs.anl.gov>
>> Sent: Tuesday 20th June 2017 15:19
>> To:nek5000-users at lists.mcs.anl.gov
>> Subject: [Nek5000-users] Interpolation on a finer mesh
>> Dear Neks,
>> I am simulating turbulent pipe flow with Nek5000. As a first step, I
>> have generated a fully developed turbulent pipe flow within a domain of
>> L_z = 5 D at Re_\tau = 360. Now, I would like to use this flow field as
>> an initial / restart condition for a turbulent flow at a Re_\tau=720
>> with a finer mesh.
>> The geometry of the finer mesh is contained in a .rea file.
>> For doing the interpolation, I have found the "interpolation wrapper for
>> usage in .usr file" in core/intp_usr.f.
>> Can someone give a short example on how to use these subroutines to
>> interpolate results from 3 or 4 restart files onto my new geometry?
>> Kind Regards,
>> Steffen Straub
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170621/9771ff3b/attachment.html>
