[Nek5000-users] ifort Issues; Runtime Error
Thu Jun 8 11:06:01 CDT 2017
Is this with the master? Note only makenek realclean will delete all 3rd party objects. Please open an issue if maketools clean doesn't work for you.
On 8 Jun 2017, at 17:19, "nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> " <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> > wrote:
Hi NEKS...
I'm running my problem on a new machine (Comet at SDSC), and they
recommend the Intel compilers, which I tried...  Got compilation to
work; then run started and crashed with "... error reading .re2
file...".  Made sure all scripts, .re2 file, basename, etc... appeared
OK; finally re-compiler with GNU and it then ran fine... Any ideas?  Are
there any compiler options I should be using with ifort that I'm missing?
Also, just wanted to note that the makefiles for tools and core do not
descend into all the sub-directories when running "make clean"; for
tools, you have to go to each sub-directory to clean the objects; in
core, the 3rd-party folders have to be manually cleaned or the existing
objects will be used instead of the recompiled versions...
Murph
This email has been checked for viruses by AVG.
http://www.avg.com <http://www.avg.com>
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170608/ef533ae6/attachment.html>
