[Nek5000-users] Corner elements giving large values
Fri Jun 2 01:04:08 CDT 2017
Hi Nek Forum, Paul
     The top and bottom BC are zero heat flux. Please let me n=know
how to control the CFL. It is 0.5 in the logfile. I am having no
particular difficulty except these corner elements at the junction of
inner cylinder and the top/bottom planes. Is there a better way to
treat edge boundary elements. Also is it possible to have different
order of elements at different locations.
Thank you
Swarandeep
On Fri, Jun 2, 2017 at 12:50 AM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Swarandeep,
> Sorry - I misunderstood.  I guess my question was more about the
> temperature bcs at the bottom and top of the domain?
> In general, however, there should be no difficulty.  What happens
> when you reduce your dt ?
> You need to keep the CFL <  ~0.5 in general.  CFL is printed in the logfile,
> grep tep logfile
> and you'll see it  "C= ....."
> Paul
> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Thursday, June 01, 2017 1:57 PM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Corner elements giving large values
> Hi NekForum, Paul
>       I intent to have isothermal conditions at the inner and outer
> cylinders. The differential heating is achieved by imposing a
> temperature difference across the two cylinders. I have used T = 1 and
> 0 values for non-dimensional temperature. I think it should be fine.
> Do you see any problem here.
> Thank you
> Swarandeep
> On Thu, Jun 1, 2017 at 11:28 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Swarandeep,
>> Is 0/1 a realistic BC for T ?
>> Best,
>> Paul
>> Sent: Thursday, June 01, 2017 12:53 PM
>>  Hi Nek Forum, Paul
>>        I am having temp = 1 and temp = 0 at the inner and outer
>> boundaries. Gravity is pointing in the -ve z-direction along the axis
>> of the
>>      annulus.  The top and bottom planes have zero heat flux conditions.
>>        I have Coriolis force added as a body force.
>>        The Rayleigh number is around 10000. The resolution is 8, 25,
>> 24 elements in the r, phi and z directions respectively with order 9.
>>        My initial condition is very low arbitrary velocity
>> perturbation (~10^(-8)). The time resolution is set to 10^(-5) for
>> param12. The CFL is
>> set to 0.5. Please indicate how to control it.
>>       As you have rightly mentioned, I start the simulation with a
>> very low value of the Rayleigh number and gradually increase it. Yet,
>> the corner values only get large. Other regions of the domain are
>> fine.
>> Thank you
>> Swarandeep
>> On Thu, Jun 1, 2017 at 7:38 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi Swarandeep,
>>> How large is your Rayleigh number and what is your resolution?
>>> What are your thermal bcs?  What are your ICs?
>>> There should be no particular issue with your configuration - but you do need to
>>> control spatial and temporal resolution.
>>> For RB, you often have to start at low Ra and/or small dt because the nonlinear
>>> response can often drive the velocities to be quite high very rapidly before the
>>> CFL constraint kicks in.   RB flows are one of the rare instances where I use
>>> variable time step size (param 12 > 0), but even then you have to keep the target
>>> CFL quite small until the flow is established.
>>> hth,
>>> Paul
>>> Sent: Thursday, June 01, 2017 7:27 AM
>>> Subject: [Nek5000-users] Corner elements giving large values
>>> Dear Nek forum,
>>>       I am simulating Rayleigh Benard flow in a 3D finite cylindrical annulus.
>>>       I am getting spurious large values of velocity at the corner regions
>>>       of the annulus i.e. the edges where the inner cylinder joins the
>>> top and bottom
>>>       planes. The boundary condition is no-slip and no penetration for velocity
>>>       at these edges. Can someone point out a plausible reason.
>>> Thank you
>>> Swarandeep
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
