[Nek5000-users] Corner elements giving large values
Thu Jun 1 14:20:36 CDT 2017
Hi Swarandeep,
Sorry - I misunderstood.  I guess my question was more about the
temperature bcs at the bottom and top of the domain?
In general, however, there should be no difficulty.  What happens
when you reduce your dt ?
You need to keep the CFL <  ~0.5 in general.  CFL is printed in the logfile,
grep tep logfile
and you'll see it  "C= ....."
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Thursday, June 01, 2017 1:57 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Corner elements giving large values
Hi NekForum, Paul
      I intent to have isothermal conditions at the inner and outer
cylinders. The differential heating is achieved by imposing a
temperature difference across the two cylinders. I have used T = 1 and
0 values for non-dimensional temperature. I think it should be fine.
Do you see any problem here.
Thank you
Swarandeep
On Thu, Jun 1, 2017 at 11:28 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Swarandeep,
> Is 0/1 a realistic BC for T ?
> Best,
> Paul
> Sent: Thursday, June 01, 2017 12:53 PM
>  Hi Nek Forum, Paul
>        I am having temp = 1 and temp = 0 at the inner and outer
> boundaries. Gravity is pointing in the -ve z-direction along the axis
> of the
>      annulus.  The top and bottom planes have zero heat flux conditions.
>        I have Coriolis force added as a body force.
>        The Rayleigh number is around 10000. The resolution is 8, 25,
> 24 elements in the r, phi and z directions respectively with order 9.
>        My initial condition is very low arbitrary velocity
> perturbation (~10^(-8)). The time resolution is set to 10^(-5) for
> param12. The CFL is
> set to 0.5. Please indicate how to control it.
>       As you have rightly mentioned, I start the simulation with a
> very low value of the Rayleigh number and gradually increase it. Yet,
> the corner values only get large. Other regions of the domain are
> fine.
> Thank you
> Swarandeep
> On Thu, Jun 1, 2017 at 7:38 PM,  <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Swarandeep,
>> How large is your Rayleigh number and what is your resolution?
>> What are your thermal bcs?  What are your ICs?
>> There should be no particular issue with your configuration - but you do need to
>> control spatial and temporal resolution.
>> For RB, you often have to start at low Ra and/or small dt because the nonlinear
>> response can often drive the velocities to be quite high very rapidly before the
>> CFL constraint kicks in.   RB flows are one of the rare instances where I use
>> variable time step size (param 12 > 0), but even then you have to keep the target
>> CFL quite small until the flow is established.
>> hth,
>> Paul
>> Sent: Thursday, June 01, 2017 7:27 AM
>> Subject: [Nek5000-users] Corner elements giving large values
>> Dear Nek forum,
>>       I am simulating Rayleigh Benard flow in a 3D finite cylindrical annulus.
>>       I am getting spurious large values of velocity at the corner regions
>>       of the annulus i.e. the edges where the inner cylinder joins the
>> top and bottom
>>       planes. The boundary condition is no-slip and no penetration for velocity
>>       at these edges. Can someone point out a plausible reason.
>> Thank you
>> Swarandeep
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
