[Nek5000-users] ?==?utf-8?q? ?==?utf-8?q? ?= Output format of Nek5000 fil
Mon Feb 27 04:10:31 CST 2017
Hello,
Thank you Paul, I tried your method and it worked. But offsetting the slide trouble me, and I would like to really handle the data freely. I got almost all the ingredient I needed, I just need a function that when I feed it the cell information, it give me the coordinates of points. It must be somewhere in the source code, or may be on Internet, is anyone know about it?
Thank you very much.
On Friday, February 24, 2017 18:33 CET, nek5000-users at lists.mcs.anl.gov wrote:
> Sometimes visit will have dropouts if your slice corresponds precisely to the location of an element
> interface.
> Offsetting the slice by, say, .00001, will often correct that issue...
> Paul
> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Friday, February 24, 2017 9:15 AM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] ?==?utf-8?q?  Output format of Nek5000 file
>  Thank you for your quick response. I just feel more comfortable working interactively with data. The reading tool of data and mesh with Matlab are already there, I just need a way to map the coordinate of those data with the mesh information.
> More specific reason is I read the data with Visit, and when I take slides, it appear a strange white band in my fields, and I don't know the reason so I need an alternative way to visualize my fields.
> On Friday, February 24, 2017 17:45 CET, nek5000-users at lists.mcs.anl.gov wrote:
> > * Yes the .fXXXXX files are the binary fld files. The ASCII and the old binary format ends with .fldXX.
> > * Is there any special reason why you want to load the data into MATLAB?
> > -----Original message-----
> > > From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> > > Sent: Friday 24th February 2017 16:46
> > > Subject: [Nek5000-users] Output format of Nek5000 file
> > > Hello everyone,
> > > I have recently started to work with Nek5000, I have few question about the output format:
> > > -In all the documents available, they talk about .fld file, but I launched the quickstart tutorial, and I got only .f000... data file. Is this the same?
> > > -I found a Matlab script that read binary data into Matlab, and the data I received is a matrix of : nel .  N^3 .  fields
> > > So I guess for each spectral element, and for each field, the file store N^3 numbers, corresponding to the values. But I have read somewhere that you can't mix the equally spaced value with GLL points. So in the binary file I got, what type of mapping is using? GLL abscissas or equally spaced?
> > > -About GLL points, I got it in 1D, but when it come to 3D, with curved elements, it become a bit complex, do you know where in the program or are there any pre-made tool that map the GLL points coordinates base on coordinate of vertices and curvature?
> > > Thank you,
> > > _______________________________________________
> > > Nek5000-users mailing list
> > > Nek5000-users at lists.mcs.anl.gov
> > > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
