[Nek5000-users] Nek: abnormal termination by signal 11
Fri Feb 17 08:48:48 CST 2017
Hi all,
I have recently encountered the following error during the first time step when running on an IBM/BlueGene Cluster:
1  Hmholtz VELZ       5   6.4574E-08   1.0000E-04   1.0000E-08   1.0000E+03   F
          1  Hmholtz VELZ       6   2.6260E-09   1.0000E-04   1.0000E-08   1.0000E+03   F
          1  Hmholtz VELZ       5   2.6260E-09   1.9523E-01   1.0000E-08
2017-02-10 13:50:24.545 (WARN ) [0x400011c9030] :3236143:ibm.runjob.client.Job: terminated by signal 11
2017-02-10 13:50:24.545 (WARN ) [0x400011c9030] :3236143:ibm.runjob.client.Job: abnormal termination by signal 11 from rank 0
This has happened for different user files, different parameters and resolutions, so I am not sure where to start looking. Has anyone else seen this problem? Is this likely a Nek or an IBM related problem?
Best wishes,
Jan
