[Nek5000-users] Element mesh mismatch with mesh in re2 file
Fri Aug 25 08:46:50 CDT 2017
Hello Neks,
I am trying to confirm a methodology of using icem to create an extruded
hex20 mesh, converting it to hex27 in cubit, and then using exo2nek to
create an re2 file. I am recreating the 3d annulus example problem for this
test. I copied the rea, SIZE, and usr files from the example directory. I
have also updated the usr file to convert the generic boundary conditions
from the exo2nek conversion to the correct boundary conditions using the
side set info. The files compile, but when I try and run the simulation I
get an element mesh mismatch error. I have attached the log file of the run
for reference. Any suggestions on how to fix this would be great.
Tommy​
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170825/51c6fae2/attachment-0001.html>
|      _   __ ______ __ __  ______  ____   ____   ____     |
|     / | / // ____// //_/ / ____/ / __ \\/ __ \\/ __ \\   |
|    /  |/ // __/  / ,<   /___ \\ / / / // / / // / / /    |
|   / /|  // /___ / /| | ____/ / / /_/ // /_/ // /_/ /     |
|  /_/ |_//_____//_/ |_|/_____/  \\___/ \\___/ \\___/      |
| NEK5000:  Open Source Spectral Element Solver            |
| COPYRIGHT (c) 2008-2017 UCHICAGO ARGONNE, LLC            |
| Version:  17.0.0                                         |
| Web:      http://nek5000.mcs.anl.gov                     |
 Number of processors:           1
 REAL    wdsize      :           8
 INTEGER wdsize      :           4
 Timer accuracy      : 2.15E-07
 Reading /home/v9g/Nek5000-Projects/Projects/3Dannulus/icem/3da.rea
 Reading /home/v9g/Nek5000-Projects/Projects/3Dannulus/icem/3da.re2
 mapping elements to processors
 Reading /home/v9g/Nek5000-Projects/Projects/3Dannulus/icem/3da.map
           0         240         240         240         240  NELV
 RANK     0 IEG       1       2       3       4       5       6       7       8
                      9      10      11      12      13      14      15      16
                     17      18      19      20      21      22      23      24
                     25      26      27      28      29      30      31      32
                     33      34      35      36      37      38      39      40
                     41      42      43      44      45      46      47      48
                     49      50      51      52      53      54      55      56
                     57      58      59      60      61      62      63      64
                     65      66      67      68      69      70      71      72
                     73      74      75      76      77      78      79      80
                     81      82      83      84      85      86      87      88
                     89      90      91      92      93      94      95      96
                     97      98      99     100     101     102     103     104
                    105     106     107     108     109     110     111     112
                    113     114     115     116     117     118     119     120
                    121     122     123     124     125     126     127     128
                    129     130     131     132     133     134     135     136
                    137     138     139     140     141     142     143     144
                    145     146     147     148     149     150     151     152
                    153     154     155     156     157     158     159     160
                    161     162     163     164     165     166     167     168
                    169     170     171     172     173     174     175     176
                    177     178     179     180     181     182     183     184
                    185     186     187     188     189     190     191     192
                    193     194     195     196     197     198     199     200
                    201     202     203     204     205     206     207     208
                    209     210     211     212     213     214     215     216
                    217     218     219     220     221     222     223     224
                    225     226     227     228     229     230     231     232
                    233     234     235     236     237     238     239     240
 element load imbalance:            0         240         240
gs_setup: 0 unique labels shared
   handle bytes (avg, min, max): 372868 372868 372868
   buffer bytes (avg, min, max): 0 0 0
 done :: mapping   0.47300E-02 sec
  preading mesh
  preading curved sides
  preading bc for ifld           1
 done :: read .re2 file   0.27E-02 sec
           0  objects found
 103   Parameters from file:
   1          1.000000         p01 DENSITY
   2         -100.0000         p02 VISCOS
   7          1.000000         p07 RHOCP
   8          1.000000         p08 CONDUCT
  11          2000.000         p11 NSTEPS
  12         5.0000000E-02     p12 DT
  15         1.0000000E+02     p15 IOSTEP
  21         1.0000000E-06     p21 DIVERGENCE
  22         1.0000000E-08     p22 HELMHOLTZ
  24         1.0000000E-10     p24 TOLREL
  25         1.0000000E-10     p25 TOLABS
  26         0.5200000         p26 COURANT/NTAU
  27          3.000000         p27 TORDER
  32         1.0000000E+00     p32 #BCs in re2 file, if > 0
  59         0.0000000E+00     p59 !=0 --> use std axhelm for all elem
  66          6.000000         p66 write fmt:ONLY postx uses rea value
  67          6.000000         p67 read fmt: same modes as p66
  84         1.0000000E-06     p84 !=0 -->sets initial timestep if p12>0
  99          3.000000         p99    dealiasing:if <0 disable
 103         5.0000001E-02     p103   weight of stabilizing filter (.01)
 done :: read .rea file   0.99001E-02 sec
 nelgt/nelgv/lelt:         240         240         244
 lx1  /lx2  /lx3 :           6           4           6
 Reset the target Courant number to .5
 setup mesh topology
   Right-handed check complete for     240 elements. OK.
   setvert3d:   6       17400       32760       17400       17400
 call usrsetvert
 done :: usrsetvert
   setupds time 1.2862E-02 seconds   0  6       17400         240
           8  max multiplicity
 done :: setup mesh topology
 call usrdat
 done :: usrdat
 generate geometry data
 NOTE: All elements deformed , param(59) ^=0
 done :: generate geometry data
 call usrdat2
 done :: usrdat2
 regenerate geometry data           1
 done :: regenerate geometry data           1
 verify mesh topology
  -1.5000000000000000        1.4999999999995755       Xrange
  -1.4999999964113584        1.4999999999999134       Yrange
   0.0000000000000000       0.99999999973500064       Zrange
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    1    1    1           1
 Near X =  -1.2977934      0.75195052       0.0000000    , d:   1.8604349       0.0000000      0.66666667
 i,j,k,ie:    2    1    1           1
 Near X =  -1.2977934      0.75195052      0.15785898E-01, d:   1.8604349       0.0000000      0.66666667
 i,j,k,ie:    3    1    1           1
 Near X =  -1.2977934      0.75195052      0.48025188E-01, d:   1.8604349       0.0000000      0.66666667
 i,j,k,ie:    4    1    1           1
 Near X =  -1.2977934      0.75195052      0.86354515E-01, d:   1.8604349       0.0000000      0.66666667
 i,j,k,ie:    5    1    1           1
 Near X =  -1.2977934      0.75195052      0.11859381    , d:   1.8604349       0.0000000      0.66666667
 i,j,k,ie:    6    1    1           1
 Near X =  -1.2977934      0.75195052      0.13437970    , d:   1.8604349       0.0000000      0.66666667
 i,j,k,ie:    6    2    1           1
 Near X =  -1.3421555      0.66915597      0.13437970    , d:  0.51133186       0.0000000      0.66666667
 i,j,k,ie:    6    3    1           1
 Near X =  -1.4157117      0.49548517      0.13437970    , d:  0.43586751       0.0000000      0.66666667
 i,j,k,ie:    6    4    1           1
 Near X =  -1.4733874      0.28100518      0.13437970    , d:  0.33782134       0.0000000      0.66666667
 i,j,k,ie:    6    5    1           1
 Near X =  -1.4968548      0.93872225E-01  0.13437970    , d:  0.24834989       0.0000000      0.66666667
 i,j,k,ie:    1    6    1           1
 Near X =  -1.5000000     -0.18369701E-15   0.0000000    , d:   2.7978518       0.0000000      0.66666667
 i,j,k,ie:    2    6    1           1
 Near X =  -1.5000000     -0.18369701E-15  0.15785898E-01, d:   2.7978518       0.0000000      0.66666667
 i,j,k,ie:    3    6    1           1
 Near X =  -1.5000000     -0.18369701E-15  0.48025188E-01, d:   2.7978518       0.0000000      0.66666667
 i,j,k,ie:    4    6    1           1
 Near X =  -1.5000000     -0.18369701E-15  0.86354515E-01, d:   2.7978518       0.0000000      0.66666667
 i,j,k,ie:    5    6    1           1
 Near X =  -1.5000000     -0.18369701E-15  0.11859381    , d:   2.7978518       0.0000000      0.66666667
 i,j,k,ie:    6    6    1           1
 Near X =  -1.5000000     -0.18369701E-15  0.13437970    , d:   3.0000000       0.0000000      0.66666667
 i,j,k,ie:    1    1    2           1
 Near X =  -1.2826095      0.74288826       0.0000000    , d:   1.8299767       0.0000000      0.66666667
 i,j,k,ie:    2    1    2           1
 Near X =  -1.2826095      0.74288826      0.15785898E-01, d:   1.8299767       0.0000000      0.66666667
 i,j,k,ie:    3    1    2           1
 Near X =  -1.2826095      0.74288826      0.48025188E-01, d:   1.8299767       0.0000000      0.66666667
 i,j,k,ie:    4    1    2           1
 Near X =  -1.2826095      0.74288826      0.86354515E-01, d:   1.8299767       0.0000000      0.66666667
 i,j,k,ie:    5    1    2           1
 Near X =  -1.2826095      0.74288826      0.11859381    , d:   1.8299767       0.0000000      0.66666667
 i,j,k,ie:    6    1    2           1
 Near X =  -1.2826095      0.74288826      0.13437970    , d:   1.8299767       0.0000000      0.66666667
 i,j,k,ie:    6    2    2           1
 Near X =  -1.3242644      0.66050762      0.13437970    , d:  0.50495436       0.0000000      0.66666667
 i,j,k,ie:    6    3    2           1
 Near X =  -1.3942939      0.48822024      0.13437970    , d:  0.42955448       0.0000000      0.66666667
 i,j,k,ie:    6    4    2           1
 Near X =  -1.4512745      0.27632510      0.13437970    , d:  0.33256309       0.0000000      0.66666667
 i,j,k,ie:    6    5    2           1
 Near X =  -1.4770993      0.92157000E-01  0.13437970    , d:  0.24480155       0.0000000      0.66666667
 i,j,k,ie:    1    6    2           1
 Near X =  -1.4823792     -0.20096047E-15   0.0000000    , d:   2.7650431       0.0000000      0.66666667
 i,j,k,ie:    2    6    2           1
 Near X =  -1.4823792     -0.20096047E-15  0.15785898E-01, d:   2.7650431       0.0000000      0.66666667
 i,j,k,ie:    3    6    2           1
 Near X =  -1.4823792     -0.20096047E-15  0.48025188E-01, d:   2.7650431       0.0000000      0.66666667
 i,j,k,ie:    4    6    2           1
 Near X =  -1.4823792     -0.20096047E-15  0.86354515E-01, d:   2.7650431       0.0000000      0.66666667
 i,j,k,ie:    5    6    2           1
 Near X =  -1.4823792     -0.20096047E-15  0.11859381    , d:   2.7650431       0.0000000      0.66666667
 i,j,k,ie:    6    6    2           1
 Near X =  -1.4823792     -0.20096047E-15  0.13437970    , d:   2.9647583       0.0000000      0.66666667
 i,j,k,ie:    1    1    3           1
 Near X =  -1.2515996      0.72438055       0.0000000    , d:   1.7677725       0.0000000      0.66666667
 i,j,k,ie:    2    1    3           1
 Near X =  -1.2515996      0.72438055      0.15785898E-01, d:   1.7677725       0.0000000      0.66666667
 i,j,k,ie:    3    1    3           1
 Near X =  -1.2515996      0.72438055      0.48025188E-01, d:   1.7677725       0.0000000      0.66666667
 i,j,k,ie:    4    1    3           1
 Near X =  -1.2515996      0.72438055      0.86354515E-01, d:   1.7677725       0.0000000      0.66666667
 i,j,k,ie:    5    1    3           1
 Near X =  -1.2515996      0.72438055      0.11859381    , d:   1.7677725       0.0000000      0.66666667
 i,j,k,ie:    6    1    3           1
 Near X =  -1.2515996      0.72438055      0.13437970    , d:   1.7677725       0.0000000      0.66666667
 i,j,k,ie:    6    2    3           1
 Near X =  -1.2877257      0.64284522      0.13437970    , d:  0.49192969       0.0000000      0.66666667
 i,j,k,ie:    6    3    3           1
 Near X =  -1.3505527      0.47338320      0.13437970    , d:  0.41666147       0.0000000      0.66666667
 i,j,k,ie:    6    4    3           1
 Near X =  -1.4061137      0.26676704      0.13437970    , d:  0.32182424       0.0000000      0.66666667
 i,j,k,ie:    6    5    3           1
 Near X =  -1.4367529      0.88654022E-01  0.13437970    , d:  0.23755484       0.0000000      0.66666667
 i,j,k,ie:    1    6    3           1
 Near X =  -1.4463924     -0.23621735E-15   0.0000000    , d:   2.6980384       0.0000000      0.66666667
 i,j,k,ie:    2    6    3           1
 Near X =  -1.4463924     -0.23621735E-15  0.15785898E-01, d:   2.6980384       0.0000000      0.66666667
 i,j,k,ie:    3    6    3           1
 Near X =  -1.4463924     -0.23621735E-15  0.48025188E-01, d:   2.6980384       0.0000000      0.66666667
 i,j,k,ie:    4    6    3           1
 Near X =  -1.4463924     -0.23621735E-15  0.86354515E-01, d:   2.6980384       0.0000000      0.66666667
 i,j,k,ie:    5    6    3           1
 Near X =  -1.4463924     -0.23621735E-15  0.11859381    , d:   2.6980384       0.0000000      0.66666667
 i,j,k,ie:    6    6    3           1
 Near X =  -1.4463924     -0.23621735E-15  0.13437970    , d:   2.8927847       0.0000000      0.66666667
 i,j,k,ie:    1    1    4           1
 Near X =  -1.2147319      0.70237671       0.0000000    , d:   1.6938178       0.0000000      0.66666667
 i,j,k,ie:    2    1    4           1
 Near X =  -1.2147319      0.70237671      0.15785898E-01, d:   1.6938178       0.0000000      0.66666667
 i,j,k,ie:    3    1    4           1
 Near X =  -1.2147319      0.70237671      0.48025188E-01, d:   1.6938178       0.0000000      0.66666667
 i,j,k,ie:    4    1    4           1
 Near X =  -1.2147319      0.70237671      0.86354515E-01, d:   1.6938178       0.0000000      0.66666667
 i,j,k,ie:    5    1    4           1
 Near X =  -1.2147319      0.70237671      0.11859381    , d:   1.6938178       0.0000000      0.66666667
 i,j,k,ie:    6    1    4           1
 Near X =  -1.2147319      0.70237671      0.13437970    , d:   1.6938178       0.0000000      0.66666667
 i,j,k,ie:    6    2    4           1
 Near X =  -1.2442847      0.62184637      0.13437970    , d:  0.47644464       0.0000000      0.66666667
 i,j,k,ie:    6    3    4           1
 Near X =  -1.2985487      0.45574342      0.13437970    , d:  0.40133295       0.0000000      0.66666667
 i,j,k,ie:    6    4    4           1
 Near X =  -1.3524220      0.25540344      0.13437970    , d:  0.30905682       0.0000000      0.66666667
 i,j,k,ie:    6    5    4           1
 Near X =  -1.3887851      0.84489329E-01  0.13437970    , d:  0.22893921       0.0000000      0.66666667
 i,j,k,ie:    1    6    4           1
 Near X =  -1.4036077     -0.27813430E-15   0.0000000    , d:   2.6183765       0.0000000      0.66666667
 i,j,k,ie:    2    6    4           1
 Near X =  -1.4036077     -0.27813430E-15  0.15785898E-01, d:   2.6183765       0.0000000      0.66666667
 i,j,k,ie:    3    6    4           1
 Near X =  -1.4036077     -0.27813430E-15  0.48025188E-01, d:   2.6183765       0.0000000      0.66666667
 i,j,k,ie:    4    6    4           1
 Near X =  -1.4036077     -0.27813430E-15  0.86354515E-01, d:   2.6183765       0.0000000      0.66666667
 i,j,k,ie:    5    6    4           1
 Near X =  -1.4036077     -0.27813430E-15  0.11859381    , d:   2.6183765       0.0000000      0.66666667
 i,j,k,ie:    6    6    4           1
 Near X =  -1.4036077     -0.27813430E-15  0.13437970    , d:   2.8072153       0.0000000      0.66666667
 i,j,k,ie:    1    1    5           1
 Near X =  -1.1837220      0.68386900       0.0000000    , d:   1.6316135       0.0000000      0.66666667
 i,j,k,ie:    2    1    5           1
 Near X =  -1.1837220      0.68386900      0.15785898E-01, d:   1.6316135       0.0000000      0.66666667
 i,j,k,ie:    3    1    5           1
 Near X =  -1.1837220      0.68386900      0.48025188E-01, d:   1.6316135       0.0000000      0.66666667
 i,j,k,ie:    4    1    5           1
 Near X =  -1.1837220      0.68386900      0.86354515E-01, d:   1.6316135       0.0000000      0.66666667
 i,j,k,ie:    5    1    5           1
 Near X =  -1.1837220      0.68386900      0.11859381    , d:   1.6316135       0.0000000      0.66666667
 i,j,k,ie:    6    1    5           1
 Near X =  -1.1837220      0.68386900      0.13437970    , d:   1.6316135       0.0000000      0.66666667
 i,j,k,ie:    6    2    5           1
 Near X =  -1.2077460      0.60418397      0.13437970    , d:  0.46341997       0.0000000      0.66666667
 i,j,k,ie:    6    3    5           1
 Near X =  -1.2548075      0.44090637      0.13437970    , d:  0.38843994       0.0000000      0.66666667
 i,j,k,ie:    6    4    5           1
 Near X =  -1.3072613      0.24584538      0.13437970    , d:  0.29831797       0.0000000      0.66666667
 i,j,k,ie:    6    5    5           1
 Near X =  -1.3484388      0.80986351E-01  0.13437970    , d:  0.22169249       0.0000000      0.66666667
 i,j,k,ie:    1    6    5           1
 Near X =  -1.3676209     -0.31339119E-15   0.0000000    , d:   2.5513718       0.0000000      0.66666667
 i,j,k,ie:    2    6    5           1
 Near X =  -1.3676209     -0.31339119E-15  0.15785898E-01, d:   2.5513718       0.0000000      0.66666667
 i,j,k,ie:    3    6    5           1
 Near X =  -1.3676209     -0.31339119E-15  0.48025188E-01, d:   2.5513718       0.0000000      0.66666667
 i,j,k,ie:    4    6    5           1
 Near X =  -1.3676209     -0.31339119E-15  0.86354515E-01, d:   2.5513718       0.0000000      0.66666667
 i,j,k,ie:    5    6    5           1
 Near X =  -1.3676209     -0.31339119E-15  0.11859381    , d:   2.5513718       0.0000000      0.66666667
 i,j,k,ie:    6    6    5           1
 Near X =  -1.3676209     -0.31339119E-15  0.13437970    , d:   2.7352417       0.0000000      0.66666667
 i,j,k,ie:    1    1    6           1
 Near X =  -1.1685381      0.67480674       0.0000000    , d:   1.7311796     -0.12925528      0.66666667
 i,j,k,ie:    2    1    6           1
 Near X =  -1.1685381      0.67480674      0.15785898E-01, d:   1.7311796     -0.12925528      0.66666667
 i,j,k,ie:    3    1    6           1
 Near X =  -1.1685381      0.67480674      0.48025188E-01, d:   1.7311796     -0.12925528      0.66666667
 i,j,k,ie:    4    1    6           1
 Near X =  -1.1685381      0.67480674      0.86354515E-01, d:   1.7311796     -0.12925528      0.66666667
 i,j,k,ie:    5    1    6           1
 Near X =  -1.1685381      0.67480674      0.11859381    , d:   1.7311796     -0.12925528      0.66666667
 i,j,k,ie:    6    1    6           1
 Near X =  -1.1685381      0.67480674      0.13437970    , d:   1.7311796     -0.12925528      0.66666667
 i,j,k,ie:    1    2    6           1
 Near X =  -1.1898549      0.59553562       0.0000000    , d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    2    2    6           1
 Near X =  -1.1898549      0.59553562      0.15785898E-01, d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    3    2    6           1
 Near X =  -1.1898549      0.59553562      0.48025188E-01, d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    4    2    6           1
 Near X =  -1.1898549      0.59553562      0.86354515E-01, d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    5    2    6           1
 Near X =  -1.1898549      0.59553562      0.11859381    , d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    6    2    6           1
 Near X =  -1.1898549      0.59553562      0.13437970    , d:  0.45704247     -0.15230065      0.66666667
 i,j,k,ie:    1    3    6           1
 Near X =  -1.2333897      0.43364145       0.0000000    , d:   0.0000000     -0.18232197      0.66666667
 i,j,k,ie:    2    3    6           1
 Near X =  -1.2333897      0.43364145      0.15785898E-01, d:   0.0000000     -0.18232197      0.66666667
 i,j,k,ie:    3    3    6           1
 Near X =  -1.2333897      0.43364145      0.48025188E-01, d:   0.0000000     -0.18232197      0.66666667
 i,j,k,ie:    4    3    6           1
 Near X =  -1.2333897      0.43364145      0.86354515E-01, d:   0.0000000     -0.18232197      0.66666667
 i,j,k,ie:    5    3    6           1
 Near X =  -1.2333897      0.43364145      0.11859381    , d:   0.0000000     -0.18232197      0.66666667
 i,j,k,ie:    6    3    6           1
 Near X =  -1.2333897      0.43364145      0.13437970    , d:  0.38212691     -0.18232197      0.66666667
 i,j,k,ie:    1    4    6           1
 Near X =  -1.2851484      0.24116530       0.0000000    , d:   0.0000000     -0.18823901      0.66666667
 i,j,k,ie:    2    4    6           1
 Near X =  -1.2851484      0.24116530      0.15785898E-01, d:   0.0000000     -0.18823901      0.66666667
 i,j,k,ie:    3    4    6           1
 Near X =  -1.2851484      0.24116530      0.48025188E-01, d:   0.0000000     -0.18823901      0.66666667
 i,j,k,ie:    4    4    6           1
 Near X =  -1.2851484      0.24116530      0.86354515E-01, d:   0.0000000     -0.18823901      0.66666667
 i,j,k,ie:    5    4    6           1
 Near X =  -1.2851484      0.24116530      0.11859381    , d:   0.0000000     -0.18823901      0.66666667
 i,j,k,ie:    6    4    6           1
 Near X =  -1.2851484      0.24116530      0.13437970    , d:  0.29305972     -0.18823901      0.66666667
 i,j,k,ie:    1    5    6           1
 Near X =  -1.3286833      0.79271126E-01   0.0000000    , d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    2    5    6           1
 Near X =  -1.3286833      0.79271126E-01  0.15785898E-01, d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    3    5    6           1
 Near X =  -1.3286833      0.79271126E-01  0.48025188E-01, d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    4    5    6           1
 Near X =  -1.3286833      0.79271126E-01  0.86354515E-01, d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    5    5    6           1
 Near X =  -1.3286833      0.79271126E-01  0.11859381    , d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    6    5    6           1
 Near X =  -1.3286833      0.79271126E-01  0.13437970    , d:  0.21814416     -0.16817149      0.66666667
 i,j,k,ie:    1    6    6           1
 Near X =  -1.3500000     -0.33065464E-15   0.0000000    , d:   2.6478518     -0.14999998      0.66666667
 i,j,k,ie:    2    6    6           1
 Near X =  -1.3500000     -0.33065464E-15  0.15785898E-01, d:   2.6478518     -0.14999998      0.66666667
 i,j,k,ie:    3    6    6           1
 Near X =  -1.3500000     -0.33065464E-15  0.48025188E-01, d:   2.6478518     -0.14999998      0.66666667
 i,j,k,ie:    4    6    6           1
 Near X =  -1.3500000     -0.33065464E-15  0.86354515E-01, d:   2.6478518     -0.14999998      0.66666667
 i,j,k,ie:    5    6    6           1
 Near X =  -1.3500000     -0.33065464E-15  0.11859381    , d:   2.6478518     -0.14999998      0.66666667
 i,j,k,ie:    6    6    6           1
 Near X =  -1.3500000     -0.33065464E-15  0.13437970    , d:   2.8500000     -0.14999998      0.66666667
 i,j,k,ie:    1    1    1           2
 Near X = -0.75184436       1.2978517       0.0000000    , d:   1.3144858     -0.54594903      0.77053868
 i,j,k,ie:    2    1    1           2
 Near X = -0.75184436       1.2978517      0.15785898E-01, d:  0.10184438       0.0000000      0.77053868
 i,j,k,ie:    3    1    1           2
 Near X = -0.75184436       1.2978517      0.48025188E-01, d:  0.10184438       0.0000000      0.77053868
 i,j,k,ie:    4    1    1           2
 Near X = -0.75184436       1.2978517      0.86354515E-01, d:  0.10184438       0.0000000      0.77053868
 i,j,k,ie:    5    1    1           2
 Near X = -0.75184436       1.2978517      0.11859381    , d:  0.10184438       0.0000000      0.77053868
 i,j,k,ie:    6    1    1           2
 Near X = -0.75184436       1.2978517      0.13437970    , d:  0.75184442       0.0000000      0.77053868
 i,j,k,ie:    1    2    1           2
 Near X = -0.83082366       1.2485700       0.0000000    , d:   0.0000000     -0.51133186      0.77053868
 i,j,k,ie:    6    2    1           2
 Near X = -0.83082366       1.2485700      0.13437970    , d:  0.73696634       0.0000000      0.77053868
 i,j,k,ie:    1    3    1           2
 Near X = -0.97984419       1.1356441       0.0000000    , d:   0.0000000     -0.43586751      0.77053868
 i,j,k,ie:    6    3    1           2
 Near X = -0.97984419       1.1356441      0.13437970    , d:  0.69888227       0.0000000      0.77053868
 i,j,k,ie:    1    4    1           2
 Near X =  -1.1355661      0.97993591       0.0000000    , d:   0.0000000     -0.33782134      0.77053868
 i,j,k,ie:    6    4    1           2
 Near X =  -1.1355661      0.97993591      0.13437970    , d:  0.64015442       0.0000000      0.77053868
 i,j,k,ie:    1    5    1           2
 Near X =  -1.2485049      0.83092539       0.0000000    , d:   0.0000000     -0.24834989      0.77053868
 i,j,k,ie:    6    5    1           2
 Near X =  -1.2485049      0.83092539      0.13437970    , d:  0.57944498       0.0000000      0.77053868
 i,j,k,ie:    1    6    1           2
 Near X =  -1.2977934      0.75195052       0.0000000    , d:   2.7977934     -0.20220661      0.77053868
 i,j,k,ie:    2    6    1           2
 Near X =  -1.2977934      0.75195052      0.15785898E-01, d:   2.7977934       0.0000000      0.77053868
 i,j,k,ie:    3    6    1           2
 Near X =  -1.2977934      0.75195052      0.48025188E-01, d:   2.7977934       0.0000000      0.77053868
 i,j,k,ie:    4    6    1           2
 Near X =  -1.2977934      0.75195052      0.86354515E-01, d:   2.7977934       0.0000000      0.77053868
 i,j,k,ie:    5    6    1           2
 Near X =  -1.2977934      0.75195052      0.11859381    , d:   2.7977934       0.0000000      0.77053868
 i,j,k,ie:    6    6    1           2
 Near X =  -1.2977934      0.75195052      0.13437970    , d:   2.7977934       0.0000000      0.77053868
 i,j,k,ie:    1    1    2           2
 Near X = -0.74279535       1.2826639       0.0000000    , d:   1.2901626     -0.53981412      0.77053868
 i,j,k,ie:    2    1    2           2
 Near X = -0.74279535       1.2826639      0.15785898E-01, d:  0.11041622       0.0000000      0.77053868
 i,j,k,ie:    3    1    2           2
 Near X = -0.74279535       1.2826639      0.48025188E-01, d:  0.11041622       0.0000000      0.77053868
 i,j,k,ie:    4    1    2           2
 Near X = -0.74279535       1.2826639      0.86354515E-01, d:  0.11041622       0.0000000      0.77053868
 i,j,k,ie:    5    1    2           2
 Near X = -0.74279535       1.2826639      0.11859381    , d:  0.11041622       0.0000000      0.77053868
 i,j,k,ie:    6    1    2           2
 Near X = -0.74279535       1.2826639      0.13437970    , d:  0.74279541       0.0000000      0.77053868
 i,j,k,ie:    1    2    2           2
 Near X = -0.81931004       1.2323577       0.0000000    , d:   0.0000000     -0.50495436      0.77053868
 i,j,k,ie:    6    2    2           2
 Near X = -0.81931004       1.2323577      0.13437970    , d:  0.72716612       0.0000000      0.77053868
 i,j,k,ie:    1    3    2           2
 Near X = -0.96473944       1.1187820       0.0000000    , d:   0.0000000     -0.42955448      0.77053868
 i,j,k,ie:    6    3    2           2
 Near X = -0.96473944       1.1187820      0.13437970    , d:  0.68845225       0.0000000      0.77053868
 i,j,k,ie:    1    4    2           2
 Near X =  -1.1187114      0.96482093       0.0000000    , d:   0.0000000     -0.33256309      0.77053868
 i,j,k,ie:    6    4    2           2
 Near X =  -1.1187114      0.96482093      0.13437970    , d:  0.63055559       0.0000000      0.77053868
 i,j,k,ie:    1    5    2           2
 Near X =  -1.2322977      0.81939948       0.0000000    , d:   0.0000000     -0.24480155      0.77053868
 i,j,k,ie:    6    5    2           2
 Near X =  -1.2322977      0.81939948      0.13437970    , d:  0.57187420       0.0000000      0.77053868
 i,j,k,ie:    1    6    2           2
 Near X =  -1.2826095      0.74288826       0.0000000    , d:   2.7649886     -0.19976968      0.77053868
 i,j,k,ie:    2    6    2           2
 Near X =  -1.2826095      0.74288826      0.15785898E-01, d:   2.7649886       0.0000000      0.77053868
 i,j,k,ie:    3    6    2           2
 Near X =  -1.2826095      0.74288826      0.48025188E-01, d:   2.7649886       0.0000000      0.77053868
 i,j,k,ie:    4    6    2           2
 Near X =  -1.2826095      0.74288826      0.86354515E-01, d:   2.7649886       0.0000000      0.77053868
 i,j,k,ie:    5    6    2           2
 Near X =  -1.2826095      0.74288826      0.11859381    , d:   2.7649886       0.0000000      0.77053868
 i,j,k,ie:    6    6    2           2
 Near X =  -1.2826095      0.74288826      0.13437970    , d:   2.7649886       0.0000000      0.77053868
 i,j,k,ie:    1    1    3           2
 Near X = -0.72431471       1.2516460       0.0000000    , d:   1.2404876     -0.52728488      0.77053868
 i,j,k,ie:    2    1    3           2
 Near X = -0.72431471       1.2516460      0.15785898E-01, d:  0.12792236       0.0000000      0.77053868
 i,j,k,ie:    3    1    3           2
 Near X = -0.72431471       1.2516460      0.48025188E-01, d:  0.12792236       0.0000000      0.77053868
 i,j,k,ie:    4    1    3           2
 Near X = -0.72431471       1.2516460      0.86354515E-01, d:  0.12792236       0.0000000      0.77053868
 i,j,k,ie:    5    1    3           2
 Near X = -0.72431471       1.2516460      0.11859381    , d:  0.12792236       0.0000000      0.77053868
 i,j,k,ie:    6    1    3           2
 Near X = -0.72431471       1.2516460      0.13437970    , d:  0.72431477       0.0000000      0.77053868
 i,j,k,ie:    1    2    3           2
 Near X = -0.79579598       1.1992475       0.0000000    , d:   0.0000000     -0.49192969      0.77053868
 i,j,k,ie:    6    2    3           2
 Near X = -0.79579598       1.1992475      0.13437970    , d:  0.70715127       0.0000000      0.77053868
 i,j,k,ie:    1    3    3           2
 Near X = -0.93389124       1.0843446       0.0000000    , d:   0.0000000     -0.41666147      0.77053868
 i,j,k,ie:    6    3    3           2
 Near X = -0.93389124       1.0843446      0.13437970    , d:  0.66715117       0.0000000      0.77053868
 i,j,k,ie:    1    4    3           2
 Near X =  -1.0842895      0.93395184       0.0000000    , d:   0.0000000     -0.32182424      0.77053868
 i,j,k,ie:    6    4    3           2
 Near X =  -1.0842895      0.93395184      0.13437970    , d:  0.61095204       0.0000000      0.77053868
 i,j,k,ie:    1    5    3           2
 Near X =  -1.1991981      0.79586030       0.0000000    , d:   0.0000000     -0.23755484      0.77053868
 i,j,k,ie:    6    5    3           2
 Near X =  -1.1991981      0.79586030      0.13437970    , d:  0.55641251       0.0000000      0.77053868
 i,j,k,ie:    1    6    3           2
 Near X =  -1.2515996      0.72438055       0.0000000    , d:   2.6979920     -0.19479278      0.77053868
 i,j,k,ie:    2    6    3           2
 Near X =  -1.2515996      0.72438055      0.15785898E-01, d:   2.6979920       0.0000000      0.77053868
 i,j,k,ie:    3    6    3           2
 Near X =  -1.2515996      0.72438055      0.48025188E-01, d:   2.6979920       0.0000000      0.77053868
 i,j,k,ie:    4    6    3           2
 Near X =  -1.2515996      0.72438055      0.86354515E-01, d:   2.6979920       0.0000000      0.77053868
 i,j,k,ie:    5    6    3           2
 Near X =  -1.2515996      0.72438055      0.11859381    , d:   2.6979920       0.0000000      0.77053868
 i,j,k,ie:    6    6    3           2
 Near X =  -1.2515996      0.72438055      0.13437970    , d:   2.6979920       0.0000000      0.77053868
 i,j,k,ie:    1    1    4           2
 Near X = -0.70234305       1.2147688       0.0000000    , d:   1.1814289     -0.51238886      0.77053868
 i,j,k,ie:    2    1    4           2
 Near X = -0.70234305       1.2147688      0.15785898E-01, d:  0.14873542       0.0000000      0.77053868
 i,j,k,ie:    3    1    4           2
 Near X = -0.70234305       1.2147688      0.48025188E-01, d:  0.14873542       0.0000000      0.77053868
 i,j,k,ie:    4    1    4           2
 Near X = -0.70234305       1.2147688      0.86354515E-01, d:  0.14873542       0.0000000      0.77053868
 i,j,k,ie:    5    1    4           2
 Near X = -0.70234305       1.2147688      0.11859381    , d:  0.14873542       0.0000000      0.77053868
 i,j,k,ie:    6    1    4           2
 Near X = -0.70234305       1.2147688      0.13437970    , d:  0.70234311       0.0000000      0.77053868
 i,j,k,ie:    1    2    4           2
 Near X = -0.76784008       1.1598828       0.0000000    , d:   0.0000000     -0.47644464      0.77053868
 i,j,k,ie:    6    2    4           2
 Near X = -0.76784008       1.1598828      0.13437970    , d:  0.68335560       0.0000000      0.77053868
 i,j,k,ie:    1    3    4           2
 Near X = -0.89721578       1.0434019       0.0000000    , d:   0.0000000     -0.40133295      0.77053868
 i,j,k,ie:    6    3    4           2
 Near X = -0.89721578       1.0434019      0.13437970    , d:  0.64182629       0.0000000      0.77053868
 i,j,k,ie:    1    4    4           2
 Near X =  -1.0433652      0.89725154       0.0000000    , d:   0.0000000     -0.30905682      0.77053868
 i,j,k,ie:    6    4    4           2
 Near X =  -1.0433652      0.89725154      0.13437970    , d:  0.58764536       0.0000000      0.77053868
 i,j,k,ie:    1    5    4           2
 Near X =  -1.1598459      0.76787454       0.0000000    , d:   0.0000000     -0.22893921      0.77053868
 i,j,k,ie:    6    5    4           2
 Near X =  -1.1598459      0.76787454      0.13437970    , d:  0.53803009       0.0000000      0.77053868
 i,j,k,ie:    1    6    4           2
 Near X =  -1.2147319      0.70237671       0.0000000    , d:   2.6183396     -0.18887574      0.77053868
 i,j,k,ie:    2    6    4           2
 Near X =  -1.2147319      0.70237671      0.15785898E-01, d:   2.6183396       0.0000000      0.77053868
 i,j,k,ie:    3    6    4           2
 Near X =  -1.2147319      0.70237671      0.48025188E-01, d:   2.6183396       0.0000000      0.77053868
 i,j,k,ie:    4    6    4           2
 Near X =  -1.2147319      0.70237671      0.86354515E-01, d:   2.6183396       0.0000000      0.77053868
 i,j,k,ie:    5    6    4           2
 Near X =  -1.2147319      0.70237671      0.11859381    , d:   2.6183396       0.0000000      0.77053868
 i,j,k,ie:    6    6    4           2
 Near X =  -1.2147319      0.70237671      0.13437970    , d:   2.6183396       0.0000000      0.77053868
 i,j,k,ie:    1    1    5           2
 Near X = -0.68386241       1.1837509       0.0000000    , d:   1.1317539     -0.49985962      0.77053868
 i,j,k,ie:    2    1    5           2
 Near X = -0.68386241       1.1837509      0.15785898E-01, d:  0.16624156       0.0000000      0.77053868
 i,j,k,ie:    3    1    5           2
 Near X = -0.68386241       1.1837509      0.48025188E-01, d:  0.16624156       0.0000000      0.77053868
 i,j,k,ie:    4    1    5           2
 Near X = -0.68386241       1.1837509      0.86354515E-01, d:  0.16624156       0.0000000      0.77053868
 i,j,k,ie:    5    1    5           2
 Near X = -0.68386241       1.1837509      0.11859381    , d:  0.16624156       0.0000000      0.77053868
 i,j,k,ie:    6    1    5           2
 Near X = -0.68386241       1.1837509      0.13437970    , d:  0.68386246       0.0000000      0.77053868
 i,j,k,ie:    1    2    5           2
 Near X = -0.74432601       1.1267727       0.0000000    , d:   0.0000000     -0.46341997      0.77053868
 i,j,k,ie:    6    2    5           2
 Near X = -0.74432601       1.1267727      0.13437970    , d:  0.66334076       0.0000000      0.77053868
 i,j,k,ie:    1    3    5           2
 Near X = -0.86636758       1.0089645       0.0000000    , d:   0.0000000     -0.38843994      0.77053868
 i,j,k,ie:    6    3    5           2
 Near X = -0.86636758       1.0089645      0.13437970    , d:  0.62052522       0.0000000      0.77053868
 i,j,k,ie:    1    4    5           2
 Near X =  -1.0089433      0.86638245       0.0000000    , d:   0.0000000     -0.29831797      0.77053868
 i,j,k,ie:    6    4    5           2
 Near X =  -1.0089433      0.86638245      0.13437970    , d:  0.56804181       0.0000000      0.77053868
 i,j,k,ie:    1    5    5           2
 Near X =  -1.1267463      0.74433536       0.0000000    , d:   0.0000000     -0.22169249      0.77053868
 i,j,k,ie:    6    5    5           2
 Near X =  -1.1267463      0.74433536      0.13437970    , d:  0.52256841       0.0000000      0.77053868
 i,j,k,ie:    1    6    5           2
 Near X =  -1.1837220      0.68386900       0.0000000    , d:   2.5513429     -0.18389884      0.77053868
 i,j,k,ie:    2    6    5           2
 Near X =  -1.1837220      0.68386900      0.15785898E-01, d:   2.5513429       0.0000000      0.77053868
 i,j,k,ie:    3    6    5           2
 Near X =  -1.1837220      0.68386900      0.48025188E-01, d:   2.5513429       0.0000000      0.77053868
 i,j,k,ie:    4    6    5           2
 Near X =  -1.1837220      0.68386900      0.86354515E-01, d:   2.5513429       0.0000000      0.77053868
 i,j,k,ie:    5    6    5           2
 Near X =  -1.1837220      0.68386900      0.11859381    , d:   2.5513429       0.0000000      0.77053868
 i,j,k,ie:    6    6    5           2
 Near X =  -1.1837220      0.68386900      0.13437970    , d:   2.5513429       0.0000000      0.77053868
 i,j,k,ie:    1    1    6           2
 Near X = -0.67481340       1.1685631       0.0000000    , d:   1.2374549     -0.62297999      0.77053868
 i,j,k,ie:    2    1    6           2
 Near X = -0.67481340       1.1685631      0.15785898E-01, d:  0.17481340     -0.77030957E-01  0.77053868
 i,j,k,ie:    3    1    6           2
 Near X = -0.67481340       1.1685631      0.48025188E-01, d:  0.17481340     -0.77030957E-01  0.77053868
 i,j,k,ie:    4    1    6           2
 Near X = -0.67481340       1.1685631      0.86354515E-01, d:  0.17481340     -0.77030957E-01  0.77053868
 i,j,k,ie:    5    1    6           2
 Near X = -0.67481340       1.1685631      0.11859381    , d:  0.17481340     -0.77030957E-01  0.77053868
 i,j,k,ie:    6    1    6           2
 Near X = -0.67481340       1.1685631      0.13437970    , d:  0.67481346     -0.77030957E-01  0.77053868
 i,j,k,ie:    1    2    6           2
 Near X = -0.73281240       1.1105604       0.0000000    , d:   0.0000000     -0.60934312      0.77053868
 i,j,k,ie:    2    2    6           2
 Near X = -0.73281240       1.1105604      0.15785898E-01, d:   0.0000000     -0.98011259E-01  0.77053868
 i,j,k,ie:    3    2    6           2
 Near X = -0.73281240       1.1105604      0.48025188E-01, d:   0.0000000     -0.98011259E-01  0.77053868
 i,j,k,ie:    4    2    6           2
 Near X = -0.73281240       1.1105604      0.86354515E-01, d:   0.0000000     -0.98011259E-01  0.77053868
 i,j,k,ie:    5    2    6           2
 Near X = -0.73281240       1.1105604      0.11859381    , d:   0.0000000     -0.98011259E-01  0.77053868
 i,j,k,ie:    6    2    6           2
 Near X = -0.73281240       1.1105604      0.13437970    , d:  0.65354054     -0.98011259E-01  0.77053868
 i,j,k,ie:    1    3    6           2
 Near X = -0.85126283      0.99210234       0.0000000    , d:   0.0000000     -0.56444888      0.77053868
 i,j,k,ie:    2    3    6           2
 Near X = -0.85126283      0.99210234      0.15785898E-01, d:   0.0000000     -0.12858136      0.77053868
 i,j,k,ie:    3    3    6           2
 Near X = -0.85126283      0.99210234      0.48025188E-01, d:   0.0000000     -0.12858136      0.77053868
 i,j,k,ie:    4    3    6           2
 Near X = -0.85126283      0.99210234      0.86354515E-01, d:   0.0000000     -0.12858136      0.77053868
 i,j,k,ie:    5    3    6           2
 Near X = -0.85126283      0.99210234      0.11859381    , d:   0.0000000     -0.12858136      0.77053868
 i,j,k,ie:    6    3    6           2
 Near X = -0.85126283      0.99210234      0.13437970    , d:  0.61009519     -0.12858136      0.77053868
 i,j,k,ie:    1    4    6           2
 Near X = -0.99208868      0.85126747       0.0000000    , d:   0.0000000     -0.48129873      0.77053868
 i,j,k,ie:    2    4    6           2
 Near X = -0.99208868      0.85126747      0.15785898E-01, d:   0.0000000     -0.14347739      0.77053868
 i,j,k,ie:    3    4    6           2
 Near X = -0.99208868      0.85126747      0.48025188E-01, d:   0.0000000     -0.14347739      0.77053868
 i,j,k,ie:    4    4    6           2
 Near X = -0.99208868      0.85126747      0.86354515E-01, d:   0.0000000     -0.14347739      0.77053868
 i,j,k,ie:    5    4    6           2
 Near X = -0.99208868      0.85126747      0.11859381    , d:   0.0000000     -0.14347739      0.77053868
 i,j,k,ie:    6    4    6           2
 Near X = -0.99208868      0.85126747      0.13437970    , d:  0.55844297     -0.14347739      0.77053868
 i,j,k,ie:    1    5    6           2
 Near X =  -1.1105391      0.73280945       0.0000000    , d:   0.0000000     -0.38631565      0.77053868
 i,j,k,ie:    2    5    6           2
 Near X =  -1.1105391      0.73280945      0.15785898E-01, d:   0.0000000     -0.13796576      0.77053868
 i,j,k,ie:    3    5    6           2
 Near X =  -1.1105391      0.73280945      0.48025188E-01, d:   0.0000000     -0.13796576      0.77053868
 i,j,k,ie:    4    5    6           2
 Near X =  -1.1105391      0.73280945      0.86354515E-01, d:   0.0000000     -0.13796576      0.77053868
 i,j,k,ie:    5    5    6           2
 Near X =  -1.1105391      0.73280945      0.11859381    , d:   0.0000000     -0.13796576      0.77053868
 i,j,k,ie:    6    5    6           2
 Near X =  -1.1105391      0.73280945      0.13437970    , d:  0.51499762     -0.13796576      0.77053868
 i,j,k,ie:    1    6    6           2
 Near X =  -1.1685381      0.67480674       0.0000000    , d:   2.6685381     -0.33146189      0.77053868
 i,j,k,ie:    2    6    6           2
 Near X =  -1.1685381      0.67480674      0.15785898E-01, d:   2.6685381     -0.12925528      0.77053868
 i,j,k,ie:    3    6    6           2
 Near X =  -1.1685381      0.67480674      0.48025188E-01, d:   2.6685381     -0.12925528      0.77053868
 i,j,k,ie:    4    6    6           2
 Near X =  -1.1685381      0.67480674      0.86354515E-01, d:   2.6685381     -0.12925528      0.77053868
 i,j,k,ie:    5    6    6           2
 Near X =  -1.1685381      0.67480674      0.11859381    , d:   2.6685381     -0.12925528      0.77053868
 i,j,k,ie:    6    6    6           2
 Near X =  -1.1685381      0.67480674      0.13437970    , d:   2.6685381     -0.12925528      0.77053868
 i,j,k,ie:    1    1    1           3
 Near X =  0.59034952E-07   1.5000000       0.0000000    , d:   0.0000000     -0.75184442       1.3300624
 i,j,k,ie:    2    1    1           3
 Near X =  0.59034952E-07   1.5000000      0.15785898E-01, d:   0.0000000     -0.56262949       1.3300624
 i,j,k,ie:    3    1    1           3
 Near X =  0.59034952E-07   1.5000000      0.48025188E-01, d:   0.0000000     -0.56262949       1.3300624
 i,j,k,ie:    4    1    1           3
 Near X =  0.59034952E-07   1.5000000      0.86354515E-01, d:   0.0000000     -0.56262949       1.3300624
 i,j,k,ie:    5    1    1           3
 Near X =  0.59034952E-07   1.5000000      0.11859381    , d:   0.0000000     -0.56262949       1.3300624
 i,j,k,ie:    6    1    1           3
 Near X =  0.59034952E-07   1.5000000      0.13437970    , d:  0.75195051     -0.56262949       1.3300624
 i,j,k,ie:    1    2    1           3
 Near X = -0.93857316E-01   1.4968561       0.0000000    , d:   0.0000000     -0.73696634       1.3300624
 i,j,k,ie:    6    2    1           3
 Near X = -0.93857316E-01   1.4968561      0.13437970    , d:  0.76301334       0.0000000       1.3300624
 i,j,k,ie:    1    3    1           3
 Near X = -0.28096192       1.4733960       0.0000000    , d:   0.0000000     -0.69888227       1.3300624
 i,j,k,ie:    6    3    1           3
 Near X = -0.28096192       1.4733960      0.13437970    , d:  0.77644714       0.0000000       1.3300624
 i,j,k,ie:    1    4    1           3
 Near X = -0.49541164       1.4157369       0.0000000    , d:   0.0000000     -0.64015442       1.3300624
 i,j,k,ie:    6    4    1           3
 Near X = -0.49541164       1.4157369      0.13437970    , d:  0.77641688       0.0000000       1.3300624
 i,j,k,ie:    1    5    1           3
 Near X = -0.66905989       1.3422015       0.0000000    , d:   0.0000000     -0.57944498       1.3300624
 i,j,k,ie:    6    5    1           3
 Near X = -0.66905989       1.3422015      0.13437970    , d:  0.76293217       0.0000000       1.3300624
 i,j,k,ie:    1    6    1           3
 Near X = -0.75184436       1.2978517       0.0000000    , d:   2.2518444     -0.54594903       1.3300624
 i,j,k,ie:    2    6    1           3
 Near X = -0.75184436       1.2978517      0.15785898E-01, d:   2.0496377       0.0000000       1.3300624
 i,j,k,ie:    3    6    1           3
 Near X = -0.75184436       1.2978517      0.48025188E-01, d:   2.0496377       0.0000000       1.3300624
 i,j,k,ie:    4    6    1           3
 Near X = -0.75184436       1.2978517      0.86354515E-01, d:   2.0496377       0.0000000       1.3300624
 i,j,k,ie:    5    6    1           3
 Near X = -0.75184436       1.2978517      0.11859381    , d:   2.0496377       0.0000000       1.3300624
 i,j,k,ie:    6    6    1           3
 Near X = -0.75184436       1.2978517      0.13437970    , d:   2.0496377       0.0000000       1.3300624
 i,j,k,ie:    1    1    2           3
 Near X =  0.58341455E-07   1.4823792       0.0000000    , d:   0.0000000     -0.74279541       1.3300624
 i,j,k,ie:    2    1    2           3
 Near X =  0.58341455E-07   1.4823792      0.15785898E-01, d:   0.0000000     -0.54735437       1.3300624
 i,j,k,ie:    3    1    2           3
 Near X =  0.58341455E-07   1.4823792      0.48025188E-01, d:   0.0000000     -0.54735437       1.3300624
 i,j,k,ie:    4    1    2           3
 Near X =  0.58341455E-07   1.4823792      0.86354515E-01, d:   0.0000000     -0.54735437       1.3300624
 i,j,k,ie:    5    1    2           3
 Near X =  0.58341455E-07   1.4823792      0.11859381    , d:   0.0000000     -0.54735437       1.3300624
 i,j,k,ie:    6    1    2           3
 Near X =  0.58341455E-07   1.4823792      0.13437970    , d:  0.74288825     -0.54735437       1.3300624
 i,j,k,ie:    1    2    2           3
 Near X = -0.92143928E-01   1.4771008       0.0000000    , d:   0.0000000     -0.72716612       1.3300624
 i,j,k,ie:    6    2    2           3
 Near X = -0.92143928E-01   1.4771008      0.13437970    , d:  0.75265160       0.0000000       1.3300624
 i,j,k,ie:    1    3    2           3
 Near X = -0.27628719       1.4512832       0.0000000    , d:   0.0000000     -0.68845225       1.3300624
 i,j,k,ie:    6    3    2           3
 Near X = -0.27628719       1.4512832      0.13437970    , d:  0.76450749       0.0000000       1.3300624
 i,j,k,ie:    1    4    2           3
 Near X = -0.48815585       1.3943181       0.0000000    , d:   0.0000000     -0.63055559       1.3300624
 i,j,k,ie:    6    4    2           3
 Near X = -0.48815585       1.3943181      0.13437970    , d:  0.76448101       0.0000000       1.3300624
 i,j,k,ie:    1    5    2           3
 Near X = -0.66042351       1.3243076       0.0000000    , d:   0.0000000     -0.57187420       1.3300624
 i,j,k,ie:    6    5    2           3
 Near X = -0.66042351       1.3243076      0.13437970    , d:  0.75258057       0.0000000       1.3300624
 i,j,k,ie:    1    6    2           3
 Near X = -0.74279535       1.2826639       0.0000000    , d:   2.2251745     -0.53981412       1.3300624
 i,j,k,ie:    2    6    2           3
 Near X = -0.74279535       1.2826639      0.15785898E-01, d:   2.0254048       0.0000000       1.3300624
 i,j,k,ie:    3    6    2           3
 Near X = -0.74279535       1.2826639      0.48025188E-01, d:   2.0254048       0.0000000       1.3300624
 i,j,k,ie:    4    6    2           3
 Near X = -0.74279535       1.2826639      0.86354515E-01, d:   2.0254048       0.0000000       1.3300624
 i,j,k,ie:    5    6    2           3
 Near X = -0.74279535       1.2826639      0.11859381    , d:   2.0254048       0.0000000       1.3300624
 i,j,k,ie:    6    6    2           3
 Near X = -0.74279535       1.2826639      0.13437970    , d:   2.0254048       0.0000000       1.3300624
 i,j,k,ie:    1    1    3           3
 Near X =  0.56925137E-07   1.4463924       0.0000000    , d:   0.0000000     -0.72431477       1.3300624
 i,j,k,ie:    2    1    3           3
 Near X =  0.56925137E-07   1.4463924      0.15785898E-01, d:   0.0000000     -0.51615823       1.3300624
 i,j,k,ie:    3    1    3           3
 Near X =  0.56925137E-07   1.4463924      0.48025188E-01, d:   0.0000000     -0.51615823       1.3300624
 i,j,k,ie:    4    1    3           3
 Near X =  0.56925137E-07   1.4463924      0.86354515E-01, d:   0.0000000     -0.51615823       1.3300624
 i,j,k,ie:    5    1    3           3
 Near X =  0.56925137E-07   1.4463924      0.11859381    , d:   0.0000000     -0.51615823       1.3300624
 i,j,k,ie:    6    1    3           3
 Near X =  0.56925137E-07   1.4463924      0.13437970    , d:  0.72438054     -0.51615823       1.3300624
 i,j,k,ie:    1    2    3           3
 Near X = -0.88644704E-01   1.4367548       0.0000000    , d:   0.0000000     -0.70715127       1.3300624
 i,j,k,ie:    6    2    3           3
 Near X = -0.88644704E-01   1.4367548      0.13437970    , d:  0.73148997       0.0000000       1.3300624
 i,j,k,ie:    1    3    3           3
 Near X = -0.26674007       1.4061225       0.0000000    , d:   0.0000000     -0.66715117       1.3300624
 i,j,k,ie:    6    3    3           3
 Near X = -0.26674007       1.4061225      0.13437970    , d:  0.74012332       0.0000000       1.3300624
 i,j,k,ie:    1    4    3           3
 Near X = -0.47333747       1.3505747       0.0000000    , d:   0.0000000     -0.61095204       1.3300624
 i,j,k,ie:    6    4    3           3
 Near X = -0.47333747       1.3505747      0.13437970    , d:  0.74010456       0.0000000       1.3300624
 i,j,k,ie:    1    5    3           3
 Near X = -0.64278557       1.2877631       0.0000000    , d:   0.0000000     -0.55641251       1.3300624
 i,j,k,ie:    6    5    3           3
 Near X = -0.64278557       1.2877631      0.13437970    , d:  0.73143965       0.0000000       1.3300624
 i,j,k,ie:    1    6    3           3
 Near X = -0.72431471       1.2516460       0.0000000    , d:   2.1707071     -0.52728488       1.3300624
 i,j,k,ie:    2    6    3           3
 Near X = -0.72431471       1.2516460      0.15785898E-01, d:   1.9759142       0.0000000       1.3300624
 i,j,k,ie:    3    6    3           3
 Near X = -0.72431471       1.2516460      0.48025188E-01, d:   1.9759142       0.0000000       1.3300624
 i,j,k,ie:    4    6    3           3
 Near X = -0.72431471       1.2516460      0.86354515E-01, d:   1.9759142       0.0000000       1.3300624
 i,j,k,ie:    5    6    3           3
 Near X = -0.72431471       1.2516460      0.11859381    , d:   1.9759142       0.0000000       1.3300624
 i,j,k,ie:    6    6    3           3
 Near X = -0.72431471       1.2516460      0.13437970    , d:   1.9759142       0.0000000       1.3300624
 i,j,k,ie:    1    1    4           3
 Near X =  0.55241275E-07   1.4036077       0.0000000    , d:   0.0000000     -0.70234311       1.3300624
 i,j,k,ie:    2    1    4           3
 Near X =  0.55241275E-07   1.4036077      0.15785898E-01, d:   0.0000000     -0.47906911       1.3300624
 i,j,k,ie:    3    1    4           3
 Near X =  0.55241275E-07   1.4036077      0.48025188E-01, d:   0.0000000     -0.47906911       1.3300624
 i,j,k,ie:    4    1    4           3
 Near X =  0.55241275E-07   1.4036077      0.86354515E-01, d:   0.0000000     -0.47906911       1.3300624
 i,j,k,ie:    5    1    4           3
 Near X =  0.55241275E-07   1.4036077      0.11859381    , d:   0.0000000     -0.47906911       1.3300624
 i,j,k,ie:    6    1    4           3
 Near X =  0.55241275E-07   1.4036077      0.13437970    , d:  0.70237671     -0.47906911       1.3300624
 i,j,k,ie:    1    2    4           3
 Near X = -0.84484473E-01   1.3887875       0.0000000    , d:   0.0000000     -0.68335560       1.3300624
 i,j,k,ie:    6    2    4           3
 Near X = -0.84484473E-01   1.3887875      0.13437970    , d:  0.70633089       0.0000000       1.3300624
 i,j,k,ie:    1    3    4           3
 Near X = -0.25538949       1.3524309       0.0000000    , d:   0.0000000     -0.64182629       1.3300624
 i,j,k,ie:    6    3    4           3
 Near X = -0.25538949       1.3524309      0.13437970    , d:  0.71113296       0.0000000       1.3300624
 i,j,k,ie:    1    4    4           3
 Near X = -0.45571988       1.2985681       0.0000000    , d:   0.0000000     -0.58764536       1.3300624
 i,j,k,ie:    6    4    4           3
 Near X = -0.45571988       1.2985681      0.13437970    , d:  0.71112338       0.0000000       1.3300624
 i,j,k,ie:    1    5    4           3
 Near X = -0.62181581       1.2443153       0.0000000    , d:   0.0000000     -0.53803009       1.3300624
 i,j,k,ie:    6    5    4           3
 Near X = -0.62181581       1.2443153      0.13437970    , d:  0.70630519       0.0000000       1.3300624
 i,j,k,ie:    1    6    4           3
 Near X = -0.70234305       1.2147688       0.0000000    , d:   2.1059507     -0.51238886       1.3300624
 i,j,k,ie:    2    6    4           3
 Near X = -0.70234305       1.2147688      0.15785898E-01, d:   1.9170749       0.0000000       1.3300624
 i,j,k,ie:    3    6    4           3
 Near X = -0.70234305       1.2147688      0.48025188E-01, d:   1.9170749       0.0000000       1.3300624
 i,j,k,ie:    4    6    4           3
 Near X = -0.70234305       1.2147688      0.86354515E-01, d:   1.9170749       0.0000000       1.3300624
 i,j,k,ie:    5    6    4           3
 Near X = -0.70234305       1.2147688      0.11859381    , d:   1.9170749       0.0000000       1.3300624
 i,j,k,ie:    6    6    4           3
 Near X = -0.70234305       1.2147688      0.13437970    , d:   1.9170749       0.0000000       1.3300624
 i,j,k,ie:    1    1    5           3
 Near X =  0.53824957E-07   1.3676209       0.0000000    , d:   0.0000000     -0.68386246       1.3300624
 i,j,k,ie:    2    1    5           3
 Near X =  0.53824957E-07   1.3676209      0.15785898E-01, d:   0.0000000     -0.44787297       1.3300624
 i,j,k,ie:    3    1    5           3
 Near X =  0.53824957E-07   1.3676209      0.48025188E-01, d:   0.0000000     -0.44787297       1.3300624
 i,j,k,ie:    4    1    5           3
 Near X =  0.53824957E-07   1.3676209      0.86354515E-01, d:   0.0000000     -0.44787297       1.3300624
 i,j,k,ie:    5    1    5           3
 Near X =  0.53824957E-07   1.3676209      0.11859381    , d:   0.0000000     -0.44787297       1.3300624
 i,j,k,ie:    6    1    5           3
 Near X =  0.53824957E-07   1.3676209      0.13437970    , d:  0.68386900     -0.44787297       1.3300624
 i,j,k,ie:    1    2    5           3
 Near X = -0.80985249E-01   1.3484415       0.0000000    , d:   0.0000000     -0.66334076       1.3300624
 i,j,k,ie:    6    2    5           3
 Near X = -0.80985249E-01   1.3484415      0.13437970    , d:  0.68516927       0.0000000       1.3300624
 i,j,k,ie:    1    3    5           3
 Near X = -0.24584237       1.3072702       0.0000000    , d:   0.0000000     -0.62052522       1.3300624
 i,j,k,ie:    6    3    5           3
 Near X = -0.24584237       1.3072702      0.13437970    , d:  0.68674879       0.0000000       1.3300624
 i,j,k,ie:    1    4    5           3
 Near X = -0.44090150       1.2548246       0.0000000    , d:   0.0000000     -0.56804181       1.3300624
 i,j,k,ie:    6    4    5           3
 Near X = -0.44090150       1.2548246      0.13437970    , d:  0.68674693       0.0000000       1.3300624
 i,j,k,ie:    1    5    5           3
 Near X = -0.60417787       1.2077708       0.0000000    , d:   0.0000000     -0.52256841       1.3300624
 i,j,k,ie:    6    5    5           3
 Near X = -0.60417787       1.2077708      0.13437970    , d:  0.68516427       0.0000000       1.3300624
 i,j,k,ie:    1    6    5           3
 Near X = -0.68386241       1.1837509       0.0000000    , d:   2.0514833     -0.49985962       1.3300624
 i,j,k,ie:    2    6    5           3
 Near X = -0.68386241       1.1837509      0.15785898E-01, d:   1.8675844       0.0000000       1.3300624
 i,j,k,ie:    3    6    5           3
 Near X = -0.68386241       1.1837509      0.48025188E-01, d:   1.8675844       0.0000000       1.3300624
 i,j,k,ie:    4    6    5           3
 Near X = -0.68386241       1.1837509      0.86354515E-01, d:   1.8675844       0.0000000       1.3300624
 i,j,k,ie:    5    6    5           3
 Near X = -0.68386241       1.1837509      0.11859381    , d:   1.8675844       0.0000000       1.3300624
 i,j,k,ie:    6    6    5           3
 Near X = -0.68386241       1.1837509      0.13437970    , d:   1.8675844       0.0000000       1.3300624
 i,j,k,ie:    1    1    6           3
 Near X =  0.53131460E-07   1.3500000       0.0000000    , d:  0.59034925E-08 -0.75184441       1.3300624
 i,j,k,ie:    2    1    6           3
 Near X =  0.53131460E-07   1.3500000      0.15785898E-01, d:  0.59034925E-08 -0.56262948       1.3300624
 i,j,k,ie:    3    1    6           3
 Near X =  0.53131460E-07   1.3500000      0.48025188E-01, d:  0.59034925E-08 -0.56262948       1.3300624
 i,j,k,ie:    4    1    6           3
 Near X =  0.53131460E-07   1.3500000      0.86354515E-01, d:  0.59034925E-08 -0.56262948       1.3300624
 i,j,k,ie:    5    1    6           3
 Near X =  0.53131460E-07   1.3500000      0.11859381    , d:  0.59034925E-08 -0.56262948       1.3300624
 i,j,k,ie:    6    1    6           3
 Near X =  0.53131460E-07   1.3500000      0.13437970    , d:  0.75195052     -0.56262948       1.3300624
 i,j,k,ie:    1    2    6           3
 Near X = -0.79271861E-01   1.3286862       0.0000000    , d:   0.0000000     -0.75155180       1.3300624
 i,j,k,ie:    2    2    6           3
 Near X = -0.79271861E-01   1.3286862      0.15785898E-01, d:   0.0000000     -0.14585455E-01   1.3300624
 i,j,k,ie:    3    2    6           3
 Near X = -0.79271861E-01   1.3286862      0.48025188E-01, d:   0.0000000     -0.14585455E-01   1.3300624
 i,j,k,ie:    4    2    6           3
 Near X = -0.79271861E-01   1.3286862      0.86354515E-01, d:   0.0000000     -0.14585455E-01   1.3300624
 i,j,k,ie:    5    2    6           3
 Near X = -0.79271861E-01   1.3286862      0.11859381    , d:   0.0000000     -0.14585455E-01   1.3300624
 i,j,k,ie:    6    2    6           3
 Near X = -0.79271861E-01   1.3286862      0.13437970    , d:  0.74842789     -0.14585455E-01   1.3300624
 i,j,k,ie:    1    3    6           3
 Near X = -0.24116764       1.2851573       0.0000000    , d:   0.0000000     -0.73867655       1.3300624
 i,j,k,ie:    2    3    6           3
 Near X = -0.24116764       1.2851573      0.15785898E-01, d:   0.0000000     -0.39794277E-01   1.3300624
 i,j,k,ie:    3    3    6           3
 Near X = -0.24116764       1.2851573      0.48025188E-01, d:   0.0000000     -0.39794277E-01   1.3300624
 i,j,k,ie:    4    3    6           3
 Near X = -0.24116764       1.2851573      0.86354515E-01, d:   0.0000000     -0.39794277E-01   1.3300624
 i,j,k,ie:    5    3    6           3
 Near X = -0.24116764       1.2851573      0.11859381    , d:   0.0000000     -0.39794277E-01   1.3300624
 i,j,k,ie:    6    3    6           3
 Near X = -0.24116764       1.2851573      0.13437970    , d:  0.73665287     -0.39794277E-01   1.3300624
 i,j,k,ie:    1    4    6           3
 Near X = -0.43364571       1.2334058       0.0000000    , d:   0.0000000     -0.70192036       1.3300624
 i,j,k,ie:    2    4    6           3
 Near X = -0.43364571       1.2334058      0.15785898E-01, d:   0.0000000     -0.61765935E-01   1.3300624
 i,j,k,ie:    3    4    6           3
 Near X = -0.43364571       1.2334058      0.48025188E-01, d:   0.0000000     -0.61765935E-01   1.3300624
 i,j,k,ie:    4    4    6           3
 Near X = -0.43364571       1.2334058      0.86354515E-01, d:   0.0000000     -0.61765935E-01   1.3300624
 i,j,k,ie:    5    4    6           3
 Near X = -0.43364571       1.2334058      0.11859381    , d:   0.0000000     -0.61765935E-01   1.3300624
 i,j,k,ie:    6    4    6           3
 Near X = -0.43364571       1.2334058      0.13437970    , d:  0.71465095     -0.61765935E-01   1.3300624
 i,j,k,ie:    1    5    6           3
 Near X = -0.59554149       1.1898769       0.0000000    , d:   0.0000000     -0.65296338       1.3300624
 i,j,k,ie:    2    5    6           3
 Near X = -0.59554149       1.1898769      0.15785898E-01, d:   0.0000000     -0.73518403E-01   1.3300624
 i,j,k,ie:    3    5    6           3
 Near X = -0.59554149       1.1898769      0.48025188E-01, d:   0.0000000     -0.73518403E-01   1.3300624
 i,j,k,ie:    4    5    6           3
 Near X = -0.59554149       1.1898769      0.86354515E-01, d:   0.0000000     -0.73518403E-01   1.3300624
 i,j,k,ie:    5    5    6           3
 Near X = -0.59554149       1.1898769      0.11859381    , d:   0.0000000     -0.73518403E-01   1.3300624
 i,j,k,ie:    6    5    6           3
 Near X = -0.59554149       1.1898769      0.13437970    , d:  0.68941377     -0.73518403E-01   1.3300624
 i,j,k,ie:    1    6    6           3
 Near X = -0.67481340       1.1685631       0.0000000    , d:   2.1748134     -0.62297999       1.3300624
 i,j,k,ie:    2    6    6           3
 Near X = -0.67481340       1.1685631      0.15785898E-01, d:   1.9726067     -0.77030957E-01   1.3300624
 i,j,k,ie:    3    6    6           3
 Near X = -0.67481340       1.1685631      0.48025188E-01, d:   1.9726067     -0.77030957E-01   1.3300624
 i,j,k,ie:    4    6    6           3
 Near X = -0.67481340       1.1685631      0.86354515E-01, d:   1.9726067     -0.77030957E-01   1.3300624
 i,j,k,ie:    5    6    6           3
 Near X = -0.67481340       1.1685631      0.11859381    , d:   1.9726067     -0.77030957E-01   1.3300624
 i,j,k,ie:    6    6    6           3
 Near X = -0.67481340       1.1685631      0.13437970    , d:   1.9726067     -0.77030957E-01   1.3300624
 i,j,k,ie:    1    1    1           4
 Near X =  0.75195057       1.2977934       0.0000000    , d:   0.0000000      -1.3145800       1.3298746
 i,j,k,ie:    2    1    1           4
 Near X =  0.75195057       1.2977934      0.15785898E-01, d:   0.0000000      -1.0768607       1.3298746
 i,j,k,ie:    3    1    1           4
 Near X =  0.75195057       1.2977934      0.48025188E-01, d:   0.0000000      -1.0768607       1.3298746
 i,j,k,ie:    4    1    1           4
 Near X =  0.75195057       1.2977934      0.86354515E-01, d:   0.0000000      -1.0768607       1.3298746
 i,j,k,ie:    5    1    1           4
 Near X =  0.75195057       1.2977934      0.11859381    , d:   0.0000000      -1.0768607       1.3298746
 i,j,k,ie:    6    1    1           4
 Near X =  0.75195057       1.2977934      0.13437970    , d:   0.0000000      -1.0768607       1.3298746
 i,j,k,ie:    1    2    1           4
 Near X =  0.66915603       1.3421555       0.0000000    , d:   0.0000000     -0.76301334       1.3298746
 i,j,k,ie:    1    3    1           4
 Near X =  0.49548523       1.4157117       0.0000000    , d:   0.0000000     -0.77644714       1.3298746
 i,j,k,ie:    1    4    1           4
 Near X =  0.28100524       1.4733874       0.0000000    , d:   0.0000000     -0.77641688       1.3298746
 i,j,k,ie:    1    5    1           4
 Near X =  0.93872284E-01   1.4968548       0.0000000    , d:   0.0000000     -0.76293217       1.3298746
 i,j,k,ie:    1    6    1           4
 Near X =  0.59034952E-07   1.5000000       0.0000000    , d:   1.2977933     -0.75184442       1.3298746
 i,j,k,ie:    2    6    1           4
 Near X =  0.59034952E-07   1.5000000      0.15785898E-01, d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    3    6    1           4
 Near X =  0.59034952E-07   1.5000000      0.48025188E-01, d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    4    6    1           4
 Near X =  0.59034952E-07   1.5000000      0.86354515E-01, d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    5    6    1           4
 Near X =  0.59034952E-07   1.5000000      0.11859381    , d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    6    6    1           4
 Near X =  0.59034952E-07   1.5000000      0.13437970    , d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    1    1    2           4
 Near X =  0.74288831       1.2826094       0.0000000    , d:   0.0000000      -1.2902426       1.3298746
 i,j,k,ie:    2    1    2           4
 Near X =  0.74288831       1.2826094      0.15785898E-01, d:   0.0000000      -1.0590708       1.3298746
 i,j,k,ie:    3    1    2           4
 Near X =  0.74288831       1.2826094      0.48025188E-01, d:   0.0000000      -1.0590708       1.3298746
 i,j,k,ie:    4    1    2           4
 Near X =  0.74288831       1.2826094      0.86354515E-01, d:   0.0000000      -1.0590708       1.3298746
 i,j,k,ie:    5    1    2           4
 Near X =  0.74288831       1.2826094      0.11859381    , d:   0.0000000      -1.0590708       1.3298746
 i,j,k,ie:    6    1    2           4
 Near X =  0.74288831       1.2826094      0.13437970    , d:   0.0000000      -1.0590708       1.3298746
 i,j,k,ie:    1    2    2           4
 Near X =  0.66050767       1.3242644       0.0000000    , d:   0.0000000     -0.75265160       1.3298746
 i,j,k,ie:    1    3    2           4
 Near X =  0.48822030       1.3942939       0.0000000    , d:   0.0000000     -0.76450749       1.3298746
 i,j,k,ie:    1    4    2           4
 Near X =  0.27632516       1.4512745       0.0000000    , d:   0.0000000     -0.76448101       1.3298746
 i,j,k,ie:    1    5    2           4
 Near X =  0.92157058E-01   1.4770993       0.0000000    , d:   0.0000000     -0.75258057       1.3298746
 i,j,k,ie:    1    6    2           4
 Near X =  0.58341455E-07   1.4823792       0.0000000    , d:   1.2826094     -0.74279541       1.3298746
 i,j,k,ie:    2    6    2           4
 Near X =  0.58341455E-07   1.4823792      0.15785898E-01, d:  0.74279518       0.0000000       1.3298746
 i,j,k,ie:    3    6    2           4
 Near X =  0.58341455E-07   1.4823792      0.48025188E-01, d:  0.74279518       0.0000000       1.3298746
 i,j,k,ie:    4    6    2           4
 Near X =  0.58341455E-07   1.4823792      0.86354515E-01, d:  0.74279518       0.0000000       1.3298746
 i,j,k,ie:    5    6    2           4
 Near X =  0.58341455E-07   1.4823792      0.11859381    , d:  0.74279518       0.0000000       1.3298746
 i,j,k,ie:    6    6    2           4
 Near X =  0.58341455E-07   1.4823792      0.13437970    , d:  0.74279518       0.0000000       1.3298746
 i,j,k,ie:    1    1    3           4
 Near X =  0.72438060       1.2515996       0.0000000    , d:   0.0000000      -1.2405388       1.3298746
 i,j,k,ie:    2    1    3           4
 Near X =  0.72438060       1.2515996      0.15785898E-01, d:   0.0000000      -1.0227388       1.3298746
 i,j,k,ie:    3    1    3           4
 Near X =  0.72438060       1.2515996      0.48025188E-01, d:   0.0000000      -1.0227388       1.3298746
 i,j,k,ie:    4    1    3           4
 Near X =  0.72438060       1.2515996      0.86354515E-01, d:   0.0000000      -1.0227388       1.3298746
 i,j,k,ie:    5    1    3           4
 Near X =  0.72438060       1.2515996      0.11859381    , d:   0.0000000      -1.0227388       1.3298746
 i,j,k,ie:    6    1    3           4
 Near X =  0.72438060       1.2515996      0.13437970    , d:   0.0000000      -1.0227388       1.3298746
 i,j,k,ie:    1    2    3           4
 Near X =  0.64284527       1.2877256       0.0000000    , d:   0.0000000     -0.73148997       1.3298746
 i,j,k,ie:    1    3    3           4
 Near X =  0.47338325       1.3505527       0.0000000    , d:   0.0000000     -0.74012332       1.3298746
 i,j,k,ie:    1    4    3           4
 Near X =  0.26676709       1.4061137       0.0000000    , d:   0.0000000     -0.74010456       1.3298746
 i,j,k,ie:    1    5    3           4
 Near X =  0.88654079E-01   1.4367529       0.0000000    , d:   0.0000000     -0.73143965       1.3298746
 i,j,k,ie:    1    6    3           4
 Near X =  0.56925137E-07   1.4463924       0.0000000    , d:   1.2515995     -0.72431477       1.3298746
 i,j,k,ie:    2    6    3           4
 Near X =  0.56925137E-07   1.4463924      0.15785898E-01, d:  0.72431454       0.0000000       1.3298746
 i,j,k,ie:    3    6    3           4
 Near X =  0.56925137E-07   1.4463924      0.48025188E-01, d:  0.72431454       0.0000000       1.3298746
 i,j,k,ie:    4    6    3           4
 Near X =  0.56925137E-07   1.4463924      0.86354515E-01, d:  0.72431454       0.0000000       1.3298746
 i,j,k,ie:    5    6    3           4
 Near X =  0.56925137E-07   1.4463924      0.11859381    , d:  0.72431454       0.0000000       1.3298746
 i,j,k,ie:    6    6    3           4
 Near X =  0.56925137E-07   1.4463924      0.13437970    , d:  0.72431454       0.0000000       1.3298746
 i,j,k,ie:    1    1    4           4
 Near X =  0.70237676       1.2147319       0.0000000    , d:   0.0000000      -1.1814458       1.3298746
 i,j,k,ie:    2    1    4           4
 Near X =  0.70237676       1.2147319      0.15785898E-01, d:   0.0000000     -0.97954354       1.3298746
 i,j,k,ie:    3    1    4           4
 Near X =  0.70237676       1.2147319      0.48025188E-01, d:   0.0000000     -0.97954354       1.3298746
 i,j,k,ie:    4    1    4           4
 Near X =  0.70237676       1.2147319      0.86354515E-01, d:   0.0000000     -0.97954354       1.3298746
 i,j,k,ie:    5    1    4           4
 Near X =  0.70237676       1.2147319      0.11859381    , d:   0.0000000     -0.97954354       1.3298746
 i,j,k,ie:    6    1    4           4
 Near X =  0.70237676       1.2147319      0.13437970    , d:   0.0000000     -0.97954354       1.3298746
 i,j,k,ie:    1    2    4           4
 Near X =  0.62184642       1.2442847       0.0000000    , d:   0.0000000     -0.70633089       1.3298746
 i,j,k,ie:    1    3    4           4
 Near X =  0.45574347       1.2985487       0.0000000    , d:   0.0000000     -0.71113296       1.3298746
 i,j,k,ie:    1    4    4           4
 Near X =  0.25540350       1.3524220       0.0000000    , d:   0.0000000     -0.71112338       1.3298746
 i,j,k,ie:    1    5    4           4
 Near X =  0.84489383E-01   1.3887851       0.0000000    , d:   0.0000000     -0.70630519       1.3298746
 i,j,k,ie:    1    6    4           4
 Near X =  0.55241275E-07   1.4036077       0.0000000    , d:   1.2147318     -0.70234311       1.3298746
 i,j,k,ie:    2    6    4           4
 Near X =  0.55241275E-07   1.4036077      0.15785898E-01, d:  0.70234289       0.0000000       1.3298746
 i,j,k,ie:    3    6    4           4
 Near X =  0.55241275E-07   1.4036077      0.48025188E-01, d:  0.70234289       0.0000000       1.3298746
 i,j,k,ie:    4    6    4           4
 Near X =  0.55241275E-07   1.4036077      0.86354515E-01, d:  0.70234289       0.0000000       1.3298746
 i,j,k,ie:    5    6    4           4
 Near X =  0.55241275E-07   1.4036077      0.11859381    , d:  0.70234289       0.0000000       1.3298746
 i,j,k,ie:    6    6    4           4
 Near X =  0.55241275E-07   1.4036077      0.13437970    , d:  0.70234289       0.0000000       1.3298746
 i,j,k,ie:    1    1    5           4
 Near X =  0.68386905       1.1837220       0.0000000    , d:   0.0000000      -1.1317420       1.3298746
 i,j,k,ie:    2    1    5           4
 Near X =  0.68386905       1.1837220      0.15785898E-01, d:   0.0000000     -0.94321148       1.3298746
 i,j,k,ie:    3    1    5           4
 Near X =  0.68386905       1.1837220      0.48025188E-01, d:   0.0000000     -0.94321148       1.3298746
 i,j,k,ie:    4    1    5           4
 Near X =  0.68386905       1.1837220      0.86354515E-01, d:   0.0000000     -0.94321148       1.3298746
 i,j,k,ie:    5    1    5           4
 Near X =  0.68386905       1.1837220      0.11859381    , d:   0.0000000     -0.94321148       1.3298746
 i,j,k,ie:    6    1    5           4
 Near X =  0.68386905       1.1837220      0.13437970    , d:   0.0000000     -0.94321148       1.3298746
 i,j,k,ie:    1    2    5           4
 Near X =  0.60418402       1.2077460       0.0000000    , d:   0.0000000     -0.68516927       1.3298746
 i,j,k,ie:    1    3    5           4
 Near X =  0.44090642       1.2548075       0.0000000    , d:   0.0000000     -0.68674879       1.3298746
 i,j,k,ie:    1    4    5           4
 Near X =  0.24584543       1.3072613       0.0000000    , d:   0.0000000     -0.68674693       1.3298746
 i,j,k,ie:    1    5    5           4
 Near X =  0.80986404E-01   1.3484388       0.0000000    , d:   0.0000000     -0.68516427       1.3298746
 i,j,k,ie:    1    6    5           4
 Near X =  0.53824957E-07   1.3676209       0.0000000    , d:   1.1837219     -0.68386246       1.3298746
 i,j,k,ie:    2    6    5           4
 Near X =  0.53824957E-07   1.3676209      0.15785898E-01, d:  0.68386225       0.0000000       1.3298746
 i,j,k,ie:    3    6    5           4
 Near X =  0.53824957E-07   1.3676209      0.48025188E-01, d:  0.68386225       0.0000000       1.3298746
 i,j,k,ie:    4    6    5           4
 Near X =  0.53824957E-07   1.3676209      0.86354515E-01, d:  0.68386225       0.0000000       1.3298746
 i,j,k,ie:    5    6    5           4
 Near X =  0.53824957E-07   1.3676209      0.11859381    , d:  0.68386225       0.0000000       1.3298746
 i,j,k,ie:    6    6    5           4
 Near X =  0.53824957E-07   1.3676209      0.13437970    , d:  0.68386225       0.0000000       1.3298746
 i,j,k,ie:    1    1    6           4
 Near X =  0.67480679       1.1685381       0.0000000    , d:  0.77143782E-01  -1.2374362       1.3298746
 i,j,k,ie:    2    1    6           4
 Near X =  0.67480679       1.1685381      0.15785898E-01, d:  0.77143782E-01 -0.99971693       1.3298746
 i,j,k,ie:    3    1    6           4
 Near X =  0.67480679       1.1685381      0.48025188E-01, d:  0.77143782E-01 -0.99971693       1.3298746
 i,j,k,ie:    4    1    6           4
 Near X =  0.67480679       1.1685381      0.86354515E-01, d:  0.77143782E-01 -0.99971693       1.3298746
 i,j,k,ie:    5    1    6           4
 Near X =  0.67480679       1.1685381      0.11859381    , d:  0.77143782E-01 -0.99971693       1.3298746
 i,j,k,ie:    6    1    6           4
 Near X =  0.67480679       1.1685381      0.13437970    , d:  0.77143782E-01 -0.99971693       1.3298746
 i,j,k,ie:    1    2    6           4
 Near X =  0.59553566       1.1898548       0.0000000    , d:  0.73620363E-01 -0.68939298       1.3298746
 i,j,k,ie:    2    2    6           4
 Near X =  0.59553566       1.1898548      0.15785898E-01, d:  0.73620363E-01   0.0000000       1.3298746
 i,j,k,ie:    3    2    6           4
 Near X =  0.59553566       1.1898548      0.48025188E-01, d:  0.73620363E-01   0.0000000       1.3298746
 i,j,k,ie:    4    2    6           4
 Near X =  0.59553566       1.1898548      0.86354515E-01, d:  0.73620363E-01   0.0000000       1.3298746
 i,j,k,ie:    5    2    6           4
 Near X =  0.59553566       1.1898548      0.11859381    , d:  0.73620363E-01   0.0000000       1.3298746
 i,j,k,ie:    6    2    6           4
 Near X =  0.59553566       1.1898548      0.13437970    , d:  0.73620363E-01   0.0000000       1.3298746
 i,j,k,ie:    1    3    6           4
 Near X =  0.43364150       1.2333897       0.0000000    , d:  0.61843731E-01 -0.71460341       1.3298746
 i,j,k,ie:    2    3    6           4
 Near X =  0.43364150       1.2333897      0.15785898E-01, d:  0.61843731E-01   0.0000000       1.3298746
 i,j,k,ie:    3    3    6           4
 Near X =  0.43364150       1.2333897      0.48025188E-01, d:  0.61843731E-01   0.0000000       1.3298746
 i,j,k,ie:    4    3    6           4
 Near X =  0.43364150       1.2333897      0.86354515E-01, d:  0.61843731E-01   0.0000000       1.3298746
 i,j,k,ie:    5    3    6           4
 Near X =  0.43364150       1.2333897      0.11859381    , d:  0.61843731E-01   0.0000000       1.3298746
 i,j,k,ie:    6    3    6           4
 Near X =  0.43364150       1.2333897      0.13437970    , d:  0.61843731E-01   0.0000000       1.3298746
 i,j,k,ie:    1    4    6           4
 Near X =  0.24116535       1.2851484       0.0000000    , d:  0.39839894E-01 -0.73657699       1.3298746
 i,j,k,ie:    2    4    6           4
 Near X =  0.24116535       1.2851484      0.15785898E-01, d:  0.39839894E-01   0.0000000       1.3298746
 i,j,k,ie:    3    4    6           4
 Near X =  0.24116535       1.2851484      0.48025188E-01, d:  0.39839894E-01   0.0000000       1.3298746
 i,j,k,ie:    4    4    6           4
 Near X =  0.24116535       1.2851484      0.86354515E-01, d:  0.39839894E-01   0.0000000       1.3298746
 i,j,k,ie:    5    4    6           4
 Near X =  0.24116535       1.2851484      0.11859381    , d:  0.39839894E-01   0.0000000       1.3298746
 i,j,k,ie:    6    4    6           4
 Near X =  0.24116535       1.2851484      0.13437970    , d:  0.39839894E-01   0.0000000       1.3298746
 i,j,k,ie:    1    5    6           4
 Near X =  0.79271178E-01   1.3286833       0.0000000    , d:  0.14601106E-01 -0.74833107       1.3298746
 i,j,k,ie:    2    5    6           4
 Near X =  0.79271178E-01   1.3286833      0.15785898E-01, d:  0.14601106E-01   0.0000000       1.3298746
 i,j,k,ie:    3    5    6           4
 Near X =  0.79271178E-01   1.3286833      0.48025188E-01, d:  0.14601106E-01   0.0000000       1.3298746
 i,j,k,ie:    4    5    6           4
 Near X =  0.79271178E-01   1.3286833      0.86354515E-01, d:  0.14601106E-01   0.0000000       1.3298746
 i,j,k,ie:    5    5    6           4
 Near X =  0.79271178E-01   1.3286833      0.11859381    , d:  0.14601106E-01   0.0000000       1.3298746
 i,j,k,ie:    6    5    6           4
 Near X =  0.79271178E-01   1.3286833      0.13437970    , d:  0.14601106E-01   0.0000000       1.3298746
 i,j,k,ie:    1    6    6           4
 Near X =  0.53131460E-07   1.3500000       0.0000000    , d:   1.2977933     -0.75184441       1.3298746
 i,j,k,ie:    2    6    6           4
 Near X =  0.53131460E-07   1.3500000      0.15785898E-01, d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    3    6    6           4
 Near X =  0.53131460E-07   1.3500000      0.48025188E-01, d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    4    6    6           4
 Near X =  0.53131460E-07   1.3500000      0.86354515E-01, d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    5    6    6           4
 Near X =  0.53131460E-07   1.3500000      0.11859381    , d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    6    6    6           4
 Near X =  0.53131460E-07   1.3500000      0.13437970    , d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    1    1    1           5
 Near X =   1.2978518      0.75184431       0.0000000    , d:   0.0000000      -2.7978518      0.77050401
 i,j,k,ie:    2    1    1           5
 Near X =   1.2978518      0.75184431      0.15785898E-01, d:   0.0000000      -2.7978518      0.77050401
 i,j,k,ie:    3    1    1           5
 Near X =   1.2978518      0.75184431      0.48025188E-01, d:   0.0000000      -2.7978518      0.77050401
 i,j,k,ie:    4    1    1           5
 Near X =   1.2978518      0.75184431      0.86354515E-01, d:   0.0000000      -2.7978518      0.77050401
 i,j,k,ie:    5    1    1           5
 Near X =   1.2978518      0.75184431      0.11859381    , d:   0.0000000      -2.7978518      0.77050401
 i,j,k,ie:    6    1    1           5
 Near X =   1.2978518      0.75184431      0.13437970    , d:  0.20214822      -2.7978518      0.77050401
 i,j,k,ie:    6    2    1           5
 Near X =   1.2485701      0.83082361      0.13437970    , d:  0.24828601       0.0000000      0.77050401
 i,j,k,ie:    6    3    1           5
 Near X =   1.1356442      0.97984415      0.13437970    , d:  0.33775182       0.0000000      0.77050401
 i,j,k,ie:    6    4    1           5
 Near X =  0.97993595       1.1355660      0.13437970    , d:  0.43580100       0.0000000      0.77050401
 i,j,k,ie:    6    5    1           5
 Near X =  0.83092544       1.2485048      0.13437970    , d:  0.51127606       0.0000000      0.77050401
 i,j,k,ie:    1    6    1           5
 Near X =  0.75195057       1.2977934       0.0000000    , d:   0.0000000     -0.75195075      0.77050401
 i,j,k,ie:    2    6    1           5
 Near X =  0.75195057       1.2977934      0.15785898E-01, d:   0.0000000     -0.75195075      0.77050401
 i,j,k,ie:    3    6    1           5
 Near X =  0.75195057       1.2977934      0.48025188E-01, d:   0.0000000     -0.75195075      0.77050401
 i,j,k,ie:    4    6    1           5
 Near X =  0.75195057       1.2977934      0.86354515E-01, d:   0.0000000     -0.75195075      0.77050401
 i,j,k,ie:    5    6    1           5
 Near X =  0.75195057       1.2977934      0.11859381    , d:   0.0000000     -0.75195075      0.77050401
 i,j,k,ie:    6    6    1           5
 Near X =  0.75195057       1.2977934      0.13437970    , d:  0.54590121      -1.5039012      0.77050401
 i,j,k,ie:    1    1    2           5
 Near X =   1.2826639      0.74279531       0.0000000    , d:   0.0000000      -2.7650431      0.77050401
 i,j,k,ie:    2    1    2           5
 Near X =   1.2826639      0.74279531      0.15785898E-01, d:   0.0000000      -2.7650431      0.77050401
 i,j,k,ie:    3    1    2           5
 Near X =   1.2826639      0.74279531      0.48025188E-01, d:   0.0000000      -2.7650431      0.77050401
 i,j,k,ie:    4    1    2           5
 Near X =   1.2826639      0.74279531      0.86354515E-01, d:   0.0000000      -2.7650431      0.77050401
 i,j,k,ie:    5    1    2           5
 Near X =   1.2826639      0.74279531      0.11859381    , d:   0.0000000      -2.7650431      0.77050401
 i,j,k,ie:    6    1    2           5
 Near X =   1.2826639      0.74279531      0.13437970    , d:  0.19971522      -2.7650431      0.77050401
 i,j,k,ie:    6    2    2           5
 Near X =   1.2323577      0.81931000      0.13437970    , d:  0.24474302       0.0000000      0.77050401
 i,j,k,ie:    6    3    2           5
 Near X =   1.1187820      0.96473940      0.13437970    , d:  0.33250117       0.0000000      0.77050401
 i,j,k,ie:    6    4    2           5
 Near X =  0.96482097       1.1187114      0.13437970    , d:  0.42949712       0.0000000      0.77050401
 i,j,k,ie:    6    5    2           5
 Near X =  0.81939953       1.2322977      0.13437970    , d:  0.50490805       0.0000000      0.77050401
 i,j,k,ie:    1    6    2           5
 Near X =  0.74288831       1.2826094       0.0000000    , d:   0.0000000     -0.74288849      0.77050401
 i,j,k,ie:    2    6    2           5
 Near X =  0.74288831       1.2826094      0.15785898E-01, d:   0.0000000     -0.74288849      0.77050401
 i,j,k,ie:    3    6    2           5
 Near X =  0.74288831       1.2826094      0.48025188E-01, d:   0.0000000     -0.74288849      0.77050401
 i,j,k,ie:    4    6    2           5
 Near X =  0.74288831       1.2826094      0.86354515E-01, d:   0.0000000     -0.74288849      0.77050401
 i,j,k,ie:    5    6    2           5
 Near X =  0.74288831       1.2826094      0.11859381    , d:   0.0000000     -0.74288849      0.77050401
 i,j,k,ie:    6    6    2           5
 Near X =  0.74288831       1.2826094      0.13437970    , d:  0.53977562      -1.4857767      0.77050401
 i,j,k,ie:    1    1    3           5
 Near X =   1.2516460      0.72431467       0.0000000    , d:   0.0000000      -2.6980384      0.77050401
 i,j,k,ie:    2    1    3           5
 Near X =   1.2516460      0.72431467      0.15785898E-01, d:   0.0000000      -2.6980384      0.77050401
 i,j,k,ie:    3    1    3           5
 Near X =   1.2516460      0.72431467      0.48025188E-01, d:   0.0000000      -2.6980384      0.77050401
 i,j,k,ie:    4    1    3           5
 Near X =   1.2516460      0.72431467      0.86354515E-01, d:   0.0000000      -2.6980384      0.77050401
 i,j,k,ie:    5    1    3           5
 Near X =   1.2516460      0.72431467      0.11859381    , d:   0.0000000      -2.6980384      0.77050401
 i,j,k,ie:    6    1    3           5
 Near X =   1.2516460      0.72431467      0.13437970    , d:  0.19474633      -2.6980384      0.77050401
 i,j,k,ie:    6    2    3           5
 Near X =   1.1992476      0.79579594      0.13437970    , d:  0.23750723       0.0000000      0.77050401
 i,j,k,ie:    6    3    3           5
 Near X =   1.0843446      0.93389120      0.13437970    , d:  0.32177786       0.0000000      0.77050401
 i,j,k,ie:    6    4    3           5
 Near X =  0.93395188       1.0842895      0.13437970    , d:  0.41662279       0.0000000      0.77050401
 i,j,k,ie:    6    5    3           5
 Near X =  0.79586035       1.1991981      0.13437970    , d:  0.49190275       0.0000000      0.77050401
 i,j,k,ie:    1    6    3           5
 Near X =  0.72438060       1.2515996       0.0000000    , d:   0.0000000     -0.72438077      0.77050401
 i,j,k,ie:    2    6    3           5
 Near X =  0.72438060       1.2515996      0.15785898E-01, d:   0.0000000     -0.72438077      0.77050401
 i,j,k,ie:    3    6    3           5
 Near X =  0.72438060       1.2515996      0.48025188E-01, d:   0.0000000     -0.72438077      0.77050401
 i,j,k,ie:    4    6    3           5
 Near X =  0.72438060       1.2515996      0.86354515E-01, d:   0.0000000     -0.72438077      0.77050401
 i,j,k,ie:    5    6    3           5
 Near X =  0.72438060       1.2515996      0.11859381    , d:   0.0000000     -0.72438077      0.77050401
 i,j,k,ie:    6    6    3           5
 Near X =  0.72438060       1.2515996      0.13437970    , d:  0.52726544      -1.4487612      0.77050401
 i,j,k,ie:    1    1    4           5
 Near X =   1.2147688      0.70234302       0.0000000    , d:   0.0000000      -2.6183765      0.77050401
 i,j,k,ie:    2    1    4           5
 Near X =   1.2147688      0.70234302      0.15785898E-01, d:   0.0000000      -2.6183765      0.77050401
 i,j,k,ie:    3    1    4           5
 Near X =   1.2147688      0.70234302      0.48025188E-01, d:   0.0000000      -2.6183765      0.77050401
 i,j,k,ie:    4    1    4           5
 Near X =   1.2147688      0.70234302      0.86354515E-01, d:   0.0000000      -2.6183765      0.77050401
 i,j,k,ie:    5    1    4           5
 Near X =   1.2147688      0.70234302      0.11859381    , d:   0.0000000      -2.6183765      0.77050401
 i,j,k,ie:    6    1    4           5
 Near X =   1.2147688      0.70234302      0.13437970    , d:  0.18883882      -2.6183765      0.77050401
 i,j,k,ie:    6    2    4           5
 Near X =   1.1598829      0.76784004      0.13437970    , d:  0.22890459       0.0000000      0.77050401
 i,j,k,ie:    6    3    4           5
 Near X =   1.0434020      0.89721575      0.13437970    , d:  0.30902891       0.0000000      0.77050401
 i,j,k,ie:    6    4    4           5
 Near X =  0.89725159       1.0433652      0.13437970    , d:  0.40131649       0.0000000      0.77050401
 i,j,k,ie:    6    5    4           5
 Near X =  0.76787459       1.1598459      0.13437970    , d:  0.47644073       0.0000000      0.77050401
 i,j,k,ie:    1    6    4           5
 Near X =  0.70237676       1.2147319       0.0000000    , d:   0.0000000     -0.70237693      0.77050401
 i,j,k,ie:    2    6    4           5
 Near X =  0.70237676       1.2147319      0.15785898E-01, d:   0.0000000     -0.70237693      0.77050401
 i,j,k,ie:    3    6    4           5
 Near X =  0.70237676       1.2147319      0.48025188E-01, d:   0.0000000     -0.70237693      0.77050401
 i,j,k,ie:    4    6    4           5
 Near X =  0.70237676       1.2147319      0.86354515E-01, d:   0.0000000     -0.70237693      0.77050401
 i,j,k,ie:    5    6    4           5
 Near X =  0.70237676       1.2147319      0.11859381    , d:   0.0000000     -0.70237693      0.77050401
 i,j,k,ie:    6    6    4           5
 Near X =  0.70237676       1.2147319      0.13437970    , d:  0.51239207      -1.4047536      0.77050401
 i,j,k,ie:    1    1    5           5
 Near X =   1.1837509      0.68386238       0.0000000    , d:   0.0000000      -2.5513718      0.77050401
 i,j,k,ie:    2    1    5           5
 Near X =   1.1837509      0.68386238      0.15785898E-01, d:   0.0000000      -2.5513718      0.77050401
 i,j,k,ie:    3    1    5           5
 Near X =   1.1837509      0.68386238      0.48025188E-01, d:   0.0000000      -2.5513718      0.77050401
 i,j,k,ie:    4    1    5           5
 Near X =   1.1837509      0.68386238      0.86354515E-01, d:   0.0000000      -2.5513718      0.77050401
 i,j,k,ie:    5    1    5           5
 Near X =   1.1837509      0.68386238      0.11859381    , d:   0.0000000      -2.5513718      0.77050401
 i,j,k,ie:    6    1    5           5
 Near X =   1.1837509      0.68386238      0.13437970    , d:  0.18386993      -2.5513718      0.77050401
 i,j,k,ie:    6    2    5           5
 Near X =   1.1267727      0.74432598      0.13437970    , d:  0.22166880       0.0000000      0.77050401
 i,j,k,ie:    6    3    5           5
 Near X =   1.0089646      0.86636756      0.13437970    , d:  0.29830560       0.0000000      0.77050401
 i,j,k,ie:    6    4    5           5
 Near X =  0.86638250       1.0089433      0.13437970    , d:  0.38844217       0.0000000      0.77050401
 i,j,k,ie:    6    5    5           5
 Near X =  0.74433541       1.1267463      0.13437970    , d:  0.46343544       0.0000000      0.77050401
 i,j,k,ie:    1    6    5           5
 Near X =  0.68386905       1.1837220       0.0000000    , d:   0.0000000     -0.68386921      0.77050401
 i,j,k,ie:    2    6    5           5
 Near X =  0.68386905       1.1837220      0.15785898E-01, d:   0.0000000     -0.68386921      0.77050401
 i,j,k,ie:    3    6    5           5
 Near X =  0.68386905       1.1837220      0.48025188E-01, d:   0.0000000     -0.68386921      0.77050401
 i,j,k,ie:    4    6    5           5
 Near X =  0.68386905       1.1837220      0.86354515E-01, d:   0.0000000     -0.68386921      0.77050401
 i,j,k,ie:    5    6    5           5
 Near X =  0.68386905       1.1837220      0.11859381    , d:   0.0000000     -0.68386921      0.77050401
 i,j,k,ie:    6    6    5           5
 Near X =  0.68386905       1.1837220      0.13437970    , d:  0.49988189      -1.3677381      0.77050401
 i,j,k,ie:    1    1    6           5
 Near X =   1.1685631      0.67481338       0.0000000    , d:  0.12928868      -2.6685631      0.77050401
 i,j,k,ie:    2    1    6           5
 Near X =   1.1685631      0.67481338      0.15785898E-01, d:  0.12928868      -2.6685631      0.77050401
 i,j,k,ie:    3    1    6           5
 Near X =   1.1685631      0.67481338      0.48025188E-01, d:  0.12928868      -2.6685631      0.77050401
 i,j,k,ie:    4    1    6           5
 Near X =   1.1685631      0.67481338      0.86354515E-01, d:  0.12928868      -2.6685631      0.77050401
 i,j,k,ie:    5    1    6           5
 Near X =   1.1685631      0.67481338      0.11859381    , d:  0.12928868      -2.6685631      0.77050401
 i,j,k,ie:    6    1    6           5
 Near X =   1.1685631      0.67481338      0.13437970    , d:  0.33143690      -2.6685631      0.77050401
 i,j,k,ie:    1    2    6           5
 Near X =   1.1105604      0.73281237       0.0000000    , d:  0.13800968       0.0000000      0.77050401
 i,j,k,ie:    2    2    6           5
 Near X =   1.1105604      0.73281237      0.15785898E-01, d:  0.13800968       0.0000000      0.77050401
 i,j,k,ie:    3    2    6           5
 Near X =   1.1105604      0.73281237      0.48025188E-01, d:  0.13800968       0.0000000      0.77050401
 i,j,k,ie:    4    2    6           5
 Near X =   1.1105604      0.73281237      0.86354515E-01, d:  0.13800968       0.0000000      0.77050401
 i,j,k,ie:    5    2    6           5
 Near X =   1.1105604      0.73281237      0.11859381    , d:  0.13800968       0.0000000      0.77050401
 i,j,k,ie:    6    2    6           5
 Near X =   1.1105604      0.73281237      0.13437970    , d:  0.38629569       0.0000000      0.77050401
 i,j,k,ie:    1    3    6           5
 Near X =  0.99210237      0.85126281       0.0000000    , d:  0.14354181       0.0000000      0.77050401
 i,j,k,ie:    2    3    6           5
 Near X =  0.99210237      0.85126281      0.15785898E-01, d:  0.14354181       0.0000000      0.77050401
 i,j,k,ie:    3    3    6           5
 Near X =  0.99210237      0.85126281      0.48025188E-01, d:  0.14354181       0.0000000      0.77050401
 i,j,k,ie:    4    3    6           5
 Near X =  0.99210237      0.85126281      0.86354515E-01, d:  0.14354181       0.0000000      0.77050401
 i,j,k,ie:    5    3    6           5
 Near X =  0.99210237      0.85126281      0.11859381    , d:  0.14354181       0.0000000      0.77050401
 i,j,k,ie:    6    3    6           5
 Near X =  0.99210237      0.85126281      0.13437970    , d:  0.48129363       0.0000000      0.77050401
 i,j,k,ie:    1    4    6           5
 Near X =  0.85126751      0.99208866       0.0000000    , d:  0.12866844       0.0000000      0.77050401
 i,j,k,ie:    2    4    6           5
 Near X =  0.85126751      0.99208866      0.15785898E-01, d:  0.12866844       0.0000000      0.77050401
 i,j,k,ie:    3    4    6           5
 Near X =  0.85126751      0.99208866      0.48025188E-01, d:  0.12866844       0.0000000      0.77050401
 i,j,k,ie:    4    4    6           5
 Near X =  0.85126751      0.99208866      0.86354515E-01, d:  0.12866844       0.0000000      0.77050401
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    5    4    6           5
 Near X =  0.85126751      0.99208866      0.11859381    , d:  0.12866844       0.0000000      0.77050401
 i,j,k,ie:    6    4    6           5
 Near X =  0.85126751      0.99208866      0.13437970    , d:  0.56446944       0.0000000      0.77050401
 i,j,k,ie:    1    5    6           5
 Near X =  0.73280950       1.1105391       0.0000000    , d:  0.98115945E-01   0.0000000      0.77050401
 i,j,k,ie:    2    5    6           5
 Near X =  0.73280950       1.1105391      0.15785898E-01, d:  0.98115945E-01   0.0000000      0.77050401
 i,j,k,ie:    3    5    6           5
 Near X =  0.73280950       1.1105391      0.48025188E-01, d:  0.98115945E-01   0.0000000      0.77050401
 i,j,k,ie:    4    5    6           5
 Near X =  0.73280950       1.1105391      0.86354515E-01, d:  0.98115945E-01   0.0000000      0.77050401
 i,j,k,ie:    5    5    6           5
 Near X =  0.73280950       1.1105391      0.11859381    , d:  0.98115945E-01   0.0000000      0.77050401
 i,j,k,ie:    6    5    6           5
 Near X =  0.73280950       1.1105391      0.13437970    , d:  0.60939201       0.0000000      0.77050401
 i,j,k,ie:    1    6    6           5
 Near X =  0.67480679       1.1685381       0.0000000    , d:  0.77143782E-01 -0.67480697      0.77050401
 i,j,k,ie:    2    6    6           5
 Near X =  0.67480679       1.1685381      0.15785898E-01, d:  0.77143782E-01 -0.67480697      0.77050401
 i,j,k,ie:    3    6    6           5
 Near X =  0.67480679       1.1685381      0.48025188E-01, d:  0.77143782E-01 -0.67480697      0.77050401
 i,j,k,ie:    4    6    6           5
 Near X =  0.67480679       1.1685381      0.86354515E-01, d:  0.77143782E-01 -0.67480697      0.77050401
 i,j,k,ie:    5    6    6           5
 Near X =  0.67480679       1.1685381      0.11859381    , d:  0.77143782E-01 -0.67480697      0.77050401
 i,j,k,ie:    6    6    6           5
 Near X =  0.67480679       1.1685381      0.13437970    , d:  0.62304499      -1.4267574      0.77050401
 i,j,k,ie:    1    1    1           6
 Near X =   1.5000000     -0.11808106E-06   0.0000000    , d:   0.0000000      -3.0000000      0.66666667
 i,j,k,ie:    2    1    1           6
 Near X =   1.5000000     -0.11808106E-06  0.15785898E-01, d:   0.0000000      -2.7977934      0.66666667
 i,j,k,ie:    3    1    1           6
 Near X =   1.5000000     -0.11808106E-06  0.48025188E-01, d:   0.0000000      -2.7977934      0.66666667
 i,j,k,ie:    4    1    1           6
 Near X =   1.5000000     -0.11808106E-06  0.86354515E-01, d:   0.0000000      -2.7977934      0.66666667
 i,j,k,ie:    5    1    1           6
 Near X =   1.5000000     -0.11808106E-06  0.11859381    , d:   0.0000000      -2.7977934      0.66666667
 i,j,k,ie:    6    1    1           6
 Near X =   1.5000000     -0.11808106E-06  0.13437970    , d:   0.0000000      -2.7977934      0.66666667
 i,j,k,ie:    1    2    1           6
 Near X =   1.4968561      0.93857256E-01   0.0000000    , d:   0.0000000     -0.24828601      0.66666667
 i,j,k,ie:    6    2    1           6
 Near X =   1.4968561      0.93857256E-01  0.13437970    , d:   0.0000000     -0.15470061      0.66666667
 i,j,k,ie:    1    3    1           6
 Near X =   1.4733960      0.28096186       0.0000000    , d:   0.0000000     -0.33775182      0.66666667
 i,j,k,ie:    6    3    1           6
 Near X =   1.4733960      0.28096186      0.13437970    , d:   0.0000000     -0.57684330E-01  0.66666667
 i,j,k,ie:    1    4    1           6
 Near X =   1.4157370      0.49541159       0.0000000    , d:   0.0000000     -0.43580100      0.66666667
 i,j,k,ie:    6    4    1           6
 Near X =   1.4157370      0.49541159      0.13437970    , d:  0.57650427E-01   0.0000000      0.66666667
 i,j,k,ie:    1    5    1           6
 Near X =   1.3422015      0.66905984       0.0000000    , d:   0.0000000     -0.51127606      0.66666667
 i,j,k,ie:    6    5    1           6
 Near X =   1.3422015      0.66905984      0.13437970    , d:  0.15465325       0.0000000      0.66666667
 i,j,k,ie:    1    6    1           6
 Near X =   1.2978518      0.75184431       0.0000000    , d:   0.0000000      -2.0498024      0.66666667
 i,j,k,ie:    2    6    1           6
 Near X =   1.2978518      0.75184431      0.15785898E-01, d:   0.0000000      -2.0498024      0.66666667
 i,j,k,ie:    3    6    1           6
 Near X =   1.2978518      0.75184431      0.48025188E-01, d:   0.0000000      -2.0498024      0.66666667
 i,j,k,ie:    4    6    1           6
 Near X =   1.2978518      0.75184431      0.86354515E-01, d:   0.0000000      -2.0498024      0.66666667
 i,j,k,ie:    5    6    1           6
 Near X =   1.2978518      0.75184431      0.11859381    , d:   0.0000000      -2.0498024      0.66666667
 i,j,k,ie:    6    6    1           6
 Near X =   1.2978518      0.75184431      0.13437970    , d:  0.20214822      -2.5957035      0.66666667
 i,j,k,ie:    1    1    2           6
 Near X =   1.4823792     -0.11334424E-06   0.0000000    , d:   0.0000000      -2.9647583      0.66666667
 i,j,k,ie:    2    1    2           6
 Near X =   1.4823792     -0.11334424E-06  0.15785898E-01, d:   0.0000000      -2.7649886      0.66666667
 i,j,k,ie:    3    1    2           6
 Near X =   1.4823792     -0.11334424E-06  0.48025188E-01, d:   0.0000000      -2.7649886      0.66666667
 i,j,k,ie:    4    1    2           6
 Near X =   1.4823792     -0.11334424E-06  0.86354515E-01, d:   0.0000000      -2.7649886      0.66666667
 i,j,k,ie:    5    1    2           6
 Near X =   1.4823792     -0.11334424E-06  0.11859381    , d:   0.0000000      -2.7649886      0.66666667
 i,j,k,ie:    6    1    2           6
 Near X =   1.4823792     -0.11334424E-06  0.13437970    , d:   0.0000000      -2.7649886      0.66666667
 i,j,k,ie:    1    2    2           6
 Near X =   1.4771008      0.92143873E-01   0.0000000    , d:   0.0000000     -0.24474302      0.66666667
 i,j,k,ie:    6    2    2           6
 Near X =   1.4771008      0.92143873E-01  0.13437970    , d:   0.0000000     -0.15283642      0.66666667
 i,j,k,ie:    1    3    2           6
 Near X =   1.4512832      0.27628714       0.0000000    , d:   0.0000000     -0.33250117      0.66666667
 i,j,k,ie:    6    3    2           6
 Near X =   1.4512832      0.27628714      0.13437970    , d:   0.0000000     -0.56989280E-01  0.66666667
 i,j,k,ie:    1    4    2           6
 Near X =   1.3943181      0.48815580       0.0000000    , d:   0.0000000     -0.42949712      0.66666667
 i,j,k,ie:    6    4    2           6
 Near X =   1.3943181      0.48815580      0.13437970    , d:  0.56956418E-01   0.0000000      0.66666667
 i,j,k,ie:    1    5    2           6
 Near X =   1.3243076      0.66042346       0.0000000    , d:   0.0000000     -0.50490805      0.66666667
 i,j,k,ie:    6    5    2           6
 Near X =   1.3243076      0.66042346      0.13437970    , d:  0.15279167       0.0000000      0.66666667
 i,j,k,ie:    1    6    2           6
 Near X =   1.2826639      0.74279531       0.0000000    , d:   0.0000000      -2.0255523      0.66666667
 i,j,k,ie:    2    6    2           6
 Near X =   1.2826639      0.74279531      0.15785898E-01, d:   0.0000000      -2.0255523      0.66666667
 i,j,k,ie:    3    6    2           6
 Near X =   1.2826639      0.74279531      0.48025188E-01, d:   0.0000000      -2.0255523      0.66666667
 i,j,k,ie:    4    6    2           6
 Near X =   1.2826639      0.74279531      0.86354515E-01, d:   0.0000000      -2.0255523      0.66666667
 i,j,k,ie:    5    6    2           6
 Near X =   1.2826639      0.74279531      0.11859381    , d:   0.0000000      -2.0255523      0.66666667
 i,j,k,ie:    6    6    2           6
 Near X =   1.2826639      0.74279531      0.13437970    , d:  0.19971522      -2.5653278      0.66666667
 i,j,k,ie:    1    1    3           6
 Near X =   1.4463924     -0.10367029E-06   0.0000000    , d:   0.0000000      -2.8927847      0.66666667
 i,j,k,ie:    2    1    3           6
 Near X =   1.4463924     -0.10367029E-06  0.15785898E-01, d:   0.0000000      -2.6979920      0.66666667
 i,j,k,ie:    3    1    3           6
 Near X =   1.4463924     -0.10367029E-06  0.48025188E-01, d:   0.0000000      -2.6979920      0.66666667
 i,j,k,ie:    4    1    3           6
 Near X =   1.4463924     -0.10367029E-06  0.86354515E-01, d:   0.0000000      -2.6979920      0.66666667
 i,j,k,ie:    5    1    3           6
 Near X =   1.4463924     -0.10367029E-06  0.11859381    , d:   0.0000000      -2.6979920      0.66666667
 i,j,k,ie:    6    1    3           6
 Near X =   1.4463924     -0.10367029E-06  0.13437970    , d:   0.0000000      -2.6979920      0.66666667
 i,j,k,ie:    1    2    3           6
 Near X =   1.4367548      0.88644657E-01   0.0000000    , d:   0.0000000     -0.23750723      0.66666667
 i,j,k,ie:    6    2    3           6
 Near X =   1.4367548      0.88644657E-01  0.13437970    , d:   0.0000000     -0.14902920      0.66666667
 i,j,k,ie:    1    3    3           6
 Near X =   1.4061225      0.26674002       0.0000000    , d:   0.0000000     -0.32177786      0.66666667
 i,j,k,ie:    6    3    3           6
 Near X =   1.4061225      0.26674002      0.13437970    , d:   0.0000000     -0.55569791E-01  0.66666667
 i,j,k,ie:    1    4    3           6
 Near X =   1.3505747      0.47333743       0.0000000    , d:   0.0000000     -0.41662279      0.66666667
 i,j,k,ie:    6    4    3           6
 Near X =   1.3505747      0.47333743      0.13437970    , d:  0.55539056E-01   0.0000000      0.66666667
 i,j,k,ie:    1    5    3           6
 Near X =   1.2877631      0.64278553       0.0000000    , d:   0.0000000     -0.49190275      0.66666667
 i,j,k,ie:    6    5    3           6
 Near X =   1.2877631      0.64278553      0.13437970    , d:  0.14898981       0.0000000      0.66666667
 i,j,k,ie:    1    6    3           6
 Near X =   1.2516460      0.72431467       0.0000000    , d:   0.0000000      -1.9760267      0.66666667
 i,j,k,ie:    2    6    3           6
 Near X =   1.2516460      0.72431467      0.15785898E-01, d:   0.0000000      -1.9760267      0.66666667
 i,j,k,ie:    3    6    3           6
 Near X =   1.2516460      0.72431467      0.48025188E-01, d:   0.0000000      -1.9760267      0.66666667
 i,j,k,ie:    4    6    3           6
 Near X =   1.2516460      0.72431467      0.86354515E-01, d:   0.0000000      -1.9760267      0.66666667
 i,j,k,ie:    5    6    3           6
 Near X =   1.2516460      0.72431467      0.11859381    , d:   0.0000000      -1.9760267      0.66666667
 i,j,k,ie:    6    6    3           6
 Near X =   1.2516460      0.72431467      0.13437970    , d:  0.19474633      -2.5032921      0.66666667
 i,j,k,ie:    1    1    4           6
 Near X =   1.4036077     -0.92168933E-07   0.0000000    , d:   0.0000000      -2.8072153      0.66666667
 i,j,k,ie:    2    1    4           6
 Near X =   1.4036077     -0.92168933E-07  0.15785898E-01, d:   0.0000000      -2.6183396      0.66666667
 i,j,k,ie:    3    1    4           6
 Near X =   1.4036077     -0.92168933E-07  0.48025188E-01, d:   0.0000000      -2.6183396      0.66666667
 i,j,k,ie:    4    1    4           6
 Near X =   1.4036077     -0.92168933E-07  0.86354515E-01, d:   0.0000000      -2.6183396      0.66666667
 i,j,k,ie:    5    1    4           6
 Near X =   1.4036077     -0.92168933E-07  0.11859381    , d:   0.0000000      -2.6183396      0.66666667
 i,j,k,ie:    6    1    4           6
 Near X =   1.4036077     -0.92168933E-07  0.13437970    , d:   0.0000000      -2.6183396      0.66666667
 i,j,k,ie:    1    2    4           6
 Near X =   1.3887875      0.84484436E-01   0.0000000    , d:   0.0000000     -0.22890459      0.66666667
 i,j,k,ie:    6    2    4           6
 Near X =   1.3887875      0.84484436E-01  0.13437970    , d:   0.0000000     -0.14450280      0.66666667
 i,j,k,ie:    1    3    4           6
 Near X =   1.3524309      0.25538945       0.0000000    , d:   0.0000000     -0.30902891      0.66666667
 i,j,k,ie:    6    3    4           6
 Near X =   1.3524309      0.25538945      0.13437970    , d:   0.0000000     -0.53882159E-01  0.66666667
 i,j,k,ie:    1    4    4           6
 Near X =   1.2985681      0.45571984       0.0000000    , d:   0.0000000     -0.40131649      0.66666667
 i,j,k,ie:    6    4    4           6
 Near X =   1.2985681      0.45571984      0.13437970    , d:  0.53853952E-01   0.0000000      0.66666667
 i,j,k,ie:    1    5    4           6
 Near X =   1.2443153      0.62181577       0.0000000    , d:   0.0000000     -0.47644073      0.66666667
 i,j,k,ie:    6    5    4           6
 Near X =   1.2443153      0.62181577      0.13437970    , d:  0.14446978       0.0000000      0.66666667
 i,j,k,ie:    1    6    4           6
 Near X =   1.2147688      0.70234302       0.0000000    , d:   0.0000000      -1.9171456      0.66666667
 i,j,k,ie:    2    6    4           6
 Near X =   1.2147688      0.70234302      0.15785898E-01, d:   0.0000000      -1.9171456      0.66666667
 i,j,k,ie:    3    6    4           6
 Near X =   1.2147688      0.70234302      0.48025188E-01, d:   0.0000000      -1.9171456      0.66666667
 i,j,k,ie:    4    6    4           6
 Near X =   1.2147688      0.70234302      0.86354515E-01, d:   0.0000000      -1.9171456      0.66666667
 i,j,k,ie:    5    6    4           6
 Near X =   1.2147688      0.70234302      0.11859381    , d:   0.0000000      -1.9171456      0.66666667
 i,j,k,ie:    6    6    4           6
 Near X =   1.2147688      0.70234302      0.13437970    , d:  0.18883882      -2.4295376      0.66666667
 i,j,k,ie:    1    1    5           6
 Near X =   1.3676209     -0.82494990E-07   0.0000000    , d:   0.0000000      -2.7352417      0.66666667
 i,j,k,ie:    2    1    5           6
 Near X =   1.3676209     -0.82494990E-07  0.15785898E-01, d:   0.0000000      -2.5513429      0.66666667
 i,j,k,ie:    3    1    5           6
 Near X =   1.3676209     -0.82494990E-07  0.48025188E-01, d:   0.0000000      -2.5513429      0.66666667
 i,j,k,ie:    4    1    5           6
 Near X =   1.3676209     -0.82494990E-07  0.86354515E-01, d:   0.0000000      -2.5513429      0.66666667
 i,j,k,ie:    5    1    5           6
 Near X =   1.3676209     -0.82494990E-07  0.11859381    , d:   0.0000000      -2.5513429      0.66666667
 i,j,k,ie:    6    1    5           6
 Near X =   1.3676209     -0.82494990E-07  0.13437970    , d:   0.0000000      -2.5513429      0.66666667
 i,j,k,ie:    1    2    5           6
 Near X =   1.3484415      0.80985220E-01   0.0000000    , d:   0.0000000     -0.22166880      0.66666667
 i,j,k,ie:    6    2    5           6
 Near X =   1.3484415      0.80985220E-01  0.13437970    , d:   0.0000000     -0.14069558      0.66666667
 i,j,k,ie:    1    3    5           6
 Near X =   1.3072702      0.24584234       0.0000000    , d:   0.0000000     -0.29830560      0.66666667
 i,j,k,ie:    6    3    5           6
 Near X =   1.3072702      0.24584234      0.13437970    , d:   0.0000000     -0.52462670E-01  0.66666667
 i,j,k,ie:    1    4    5           6
 Near X =   1.2548247      0.44090147       0.0000000    , d:   0.0000000     -0.38844217      0.66666667
 i,j,k,ie:    6    4    5           6
 Near X =   1.2548247      0.44090147      0.13437970    , d:  0.52436589E-01   0.0000000      0.66666667
 i,j,k,ie:    1    5    5           6
 Near X =   1.2077708      0.60417784       0.0000000    , d:   0.0000000     -0.46343544      0.66666667
 i,j,k,ie:    6    5    5           6
 Near X =   1.2077708      0.60417784      0.13437970    , d:  0.14066792       0.0000000      0.66666667
 i,j,k,ie:    1    6    5           6
 Near X =   1.1837509      0.68386238       0.0000000    , d:   0.0000000      -1.8676200      0.66666667
 i,j,k,ie:    2    6    5           6
 Near X =   1.1837509      0.68386238      0.15785898E-01, d:   0.0000000      -1.8676200      0.66666667
 i,j,k,ie:    3    6    5           6
 Near X =   1.1837509      0.68386238      0.48025188E-01, d:   0.0000000      -1.8676200      0.66666667
 i,j,k,ie:    4    6    5           6
 Near X =   1.1837509      0.68386238      0.86354515E-01, d:   0.0000000      -1.8676200      0.66666667
 i,j,k,ie:    5    6    5           6
 Near X =   1.1837509      0.68386238      0.11859381    , d:   0.0000000      -1.8676200      0.66666667
 i,j,k,ie:    6    6    5           6
 Near X =   1.1837509      0.68386238      0.13437970    , d:  0.18386993      -2.3675019      0.66666667
 i,j,k,ie:    1    1    6           6
 Near X =   1.3500000     -0.77758166E-07   0.0000000    , d:  0.14999998      -2.8500000      0.66666667
 i,j,k,ie:    2    1    6           6
 Near X =   1.3500000     -0.77758166E-07  0.15785898E-01, d:  0.14999998      -2.6477934      0.66666667
 i,j,k,ie:    3    1    6           6
 Near X =   1.3500000     -0.77758166E-07  0.48025188E-01, d:  0.14999998      -2.6477934      0.66666667
 i,j,k,ie:    4    1    6           6
 Near X =   1.3500000     -0.77758166E-07  0.86354515E-01, d:  0.14999998      -2.6477934      0.66666667
 i,j,k,ie:    5    1    6           6
 Near X =   1.3500000     -0.77758166E-07  0.11859381    , d:  0.14999998      -2.6477934      0.66666667
 i,j,k,ie:    6    1    6           6
 Near X =   1.3500000     -0.77758166E-07  0.13437970    , d:  0.14999998      -2.6477934      0.66666667
 i,j,k,ie:    1    2    6           6
 Near X =   1.3286862      0.79271836E-01   0.0000000    , d:  0.16816987     -0.21812581      0.66666667
 i,j,k,ie:    2    2    6           6
 Near X =   1.3286862      0.79271836E-01  0.15785898E-01, d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    3    2    6           6
 Near X =   1.3286862      0.79271836E-01  0.48025188E-01, d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    4    2    6           6
 Near X =   1.3286862      0.79271836E-01  0.86354515E-01, d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    5    2    6           6
 Near X =   1.3286862      0.79271836E-01  0.11859381    , d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    6    2    6           6
 Near X =   1.3286862      0.79271836E-01  0.13437970    , d:  0.16816987     -0.13883138      0.66666667
 i,j,k,ie:    1    3    6           6
 Near X =   1.2851573      0.24116762       0.0000000    , d:  0.18823867     -0.29305495      0.66666667
 i,j,k,ie:    2    3    6           6
 Near X =   1.2851573      0.24116762      0.15785898E-01, d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    3    3    6           6
 Near X =   1.2851573      0.24116762      0.48025188E-01, d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    4    3    6           6
 Near X =   1.2851573      0.24116762      0.86354515E-01, d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    5    3    6           6
 Near X =   1.2851573      0.24116762      0.11859381    , d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    6    3    6           6
 Near X =   1.2851573      0.24116762      0.13437970    , d:  0.18823867     -0.51767620E-01  0.66666667
 i,j,k,ie:    1    4    6           6
 Near X =   1.2334058      0.43364568       0.0000000    , d:  0.18233116     -0.38213828      0.66666667
 i,j,k,ie:    2    4    6           6
 Near X =   1.2334058      0.43364568      0.15785898E-01, d:  0.18233116       0.0000000      0.66666667
 i,j,k,ie:    3    4    6           6
 Near X =   1.2334058      0.43364568      0.48025188E-01, d:  0.18233116       0.0000000      0.66666667
 i,j,k,ie:    4    4    6           6
 Near X =   1.2334058      0.43364568      0.86354515E-01, d:  0.18233116       0.0000000      0.66666667
 i,j,k,ie:    5    4    6           6
 Near X =   1.2334058      0.43364568      0.11859381    , d:  0.18233116       0.0000000      0.66666667
 i,j,k,ie:    6    4    6           6
 Near X =   1.2334058      0.43364568      0.13437970    , d:  0.23998159       0.0000000      0.66666667
 i,j,k,ie:    1    5    6           6
 Near X =   1.1898769      0.59554146       0.0000000    , d:  0.15232459     -0.45706742      0.66666667
 i,j,k,ie:    2    5    6           6
 Near X =   1.1898769      0.59554146      0.15785898E-01, d:  0.15232459       0.0000000      0.66666667
 i,j,k,ie:    3    5    6           6
 Near X =   1.1898769      0.59554146      0.48025188E-01, d:  0.15232459       0.0000000      0.66666667
 i,j,k,ie:    4    5    6           6
 Near X =   1.1898769      0.59554146      0.86354515E-01, d:  0.15232459       0.0000000      0.66666667
 i,j,k,ie:    5    5    6           6
 Near X =   1.1898769      0.59554146      0.11859381    , d:  0.15232459       0.0000000      0.66666667
 i,j,k,ie:    6    5    6           6
 Near X =   1.1898769      0.59554146      0.13437970    , d:  0.30697783       0.0000000      0.66666667
 i,j,k,ie:    1    6    6           6
 Near X =   1.1685631      0.67481338       0.0000000    , d:  0.12928868      -1.9205137      0.66666667
 i,j,k,ie:    2    6    6           6
 Near X =   1.1685631      0.67481338      0.15785898E-01, d:  0.12928868      -1.9205137      0.66666667
 i,j,k,ie:    3    6    6           6
 Near X =   1.1685631      0.67481338      0.48025188E-01, d:  0.12928868      -1.9205137      0.66666667
 i,j,k,ie:    4    6    6           6
 Near X =   1.1685631      0.67481338      0.86354515E-01, d:  0.12928868      -1.9205137      0.66666667
 i,j,k,ie:    5    6    6           6
 Near X =   1.1685631      0.67481338      0.11859381    , d:  0.12928868      -1.9205137      0.66666667
 i,j,k,ie:    6    6    6           6
 Near X =   1.1685631      0.67481338      0.13437970    , d:  0.33143690      -2.4664149      0.66666667
 i,j,k,ie:    1    1    1           7
 Near X =   1.2977933     -0.75195062       0.0000000    , d:  0.20220666      -2.5955867      0.66666667
 i,j,k,ie:    2    1    1           7
 Near X =   1.2977933     -0.75195062      0.15785898E-01, d:   0.0000000      -2.0496377      0.66666667
 i,j,k,ie:    3    1    1           7
 Near X =   1.2977933     -0.75195062      0.48025188E-01, d:   0.0000000      -2.0496377      0.66666667
 i,j,k,ie:    4    1    1           7
 Near X =   1.2977933     -0.75195062      0.86354515E-01, d:   0.0000000      -2.0496377      0.66666667
 i,j,k,ie:    5    1    1           7
 Near X =   1.2977933     -0.75195062      0.11859381    , d:   0.0000000      -2.0496377      0.66666667
 i,j,k,ie:    6    1    1           7
 Near X =   1.2977933     -0.75195062      0.13437970    , d:   0.0000000      -2.0496377      0.66666667
 i,j,k,ie:    1    2    1           7
 Near X =   1.3421555     -0.66915608       0.0000000    , d:  0.15470061       0.0000000      0.66666667
 i,j,k,ie:    6    2    1           7
 Near X =   1.3421555     -0.66915608      0.13437970    , d:   0.0000000     -0.51133191      0.66666667
 i,j,k,ie:    1    3    1           7
 Near X =   1.4157117     -0.49548528       0.0000000    , d:  0.57684330E-01   0.0000000      0.66666667
 i,j,k,ie:    6    3    1           7
 Near X =   1.4157117     -0.49548528      0.13437970    , d:   0.0000000     -0.43586756      0.66666667
 i,j,k,ie:    1    4    1           7
 Near X =   1.4733874     -0.28100530       0.0000000    , d:   0.0000000     -0.57650427E-01  0.66666667
 i,j,k,ie:    6    4    1           7
 Near X =   1.4733874     -0.28100530      0.13437970    , d:   0.0000000     -0.33782139      0.66666667
 i,j,k,ie:    1    5    1           7
 Near X =   1.4968548     -0.93872343E-01   0.0000000    , d:   0.0000000     -0.15465325      0.66666667
 i,j,k,ie:    6    5    1           7
 Near X =   1.4968548     -0.93872343E-01  0.13437970    , d:   0.0000000     -0.24834994      0.66666667
 i,j,k,ie:    1    6    1           7
 Near X =   1.5000000     -0.11808106E-06   0.0000000    , d:   0.0000000      -2.7978518      0.66666667
 i,j,k,ie:    2    6    1           7
 Near X =   1.5000000     -0.11808106E-06  0.15785898E-01, d:   0.0000000      -2.7978518      0.66666667
 i,j,k,ie:    3    6    1           7
 Near X =   1.5000000     -0.11808106E-06  0.48025188E-01, d:   0.0000000      -2.7978518      0.66666667
 i,j,k,ie:    4    6    1           7
 Near X =   1.5000000     -0.11808106E-06  0.86354515E-01, d:   0.0000000      -2.7978518      0.66666667
 i,j,k,ie:    5    6    1           7
 Near X =   1.5000000     -0.11808106E-06  0.11859381    , d:   0.0000000      -2.7978518      0.66666667
 i,j,k,ie:    6    6    1           7
 Near X =   1.5000000     -0.11808106E-06  0.13437970    , d:   0.0000000      -3.0000000      0.66666667
 i,j,k,ie:    1    1    2           7
 Near X =   1.2826094     -0.74288836       0.0000000    , d:  0.19976973      -2.5652189      0.66666667
 i,j,k,ie:    2    1    2           7
 Near X =   1.2826094     -0.74288836      0.15785898E-01, d:   0.0000000      -2.0254048      0.66666667
 i,j,k,ie:    3    1    2           7
 Near X =   1.2826094     -0.74288836      0.48025188E-01, d:   0.0000000      -2.0254048      0.66666667
 i,j,k,ie:    4    1    2           7
 Near X =   1.2826094     -0.74288836      0.86354515E-01, d:   0.0000000      -2.0254048      0.66666667
 i,j,k,ie:    5    1    2           7
 Near X =   1.2826094     -0.74288836      0.11859381    , d:   0.0000000      -2.0254048      0.66666667
 i,j,k,ie:    6    1    2           7
 Near X =   1.2826094     -0.74288836      0.13437970    , d:   0.0000000      -2.0254048      0.66666667
 i,j,k,ie:    1    2    2           7
 Near X =   1.3242644     -0.66050772       0.0000000    , d:  0.15283642       0.0000000      0.66666667
 i,j,k,ie:    6    2    2           7
 Near X =   1.3242644     -0.66050772      0.13437970    , d:   0.0000000     -0.50495441      0.66666667
 i,j,k,ie:    1    3    2           7
 Near X =   1.3942939     -0.48822035       0.0000000    , d:  0.56989280E-01   0.0000000      0.66666667
 i,j,k,ie:    6    3    2           7
 Near X =   1.3942939     -0.48822035      0.13437970    , d:   0.0000000     -0.42955453      0.66666667
 i,j,k,ie:    1    4    2           7
 Near X =   1.4512745     -0.27632521       0.0000000    , d:   0.0000000     -0.56956418E-01  0.66666667
 i,j,k,ie:    6    4    2           7
 Near X =   1.4512745     -0.27632521      0.13437970    , d:   0.0000000     -0.33256314      0.66666667
 i,j,k,ie:    1    5    2           7
 Near X =   1.4770993     -0.92157113E-01   0.0000000    , d:   0.0000000     -0.15279167      0.66666667
 i,j,k,ie:    6    5    2           7
 Near X =   1.4770993     -0.92157113E-01  0.13437970    , d:   0.0000000     -0.24480160      0.66666667
 i,j,k,ie:    1    6    2           7
 Near X =   1.4823792     -0.11334424E-06   0.0000000    , d:   0.0000000      -2.7650431      0.66666667
 i,j,k,ie:    2    6    2           7
 Near X =   1.4823792     -0.11334424E-06  0.15785898E-01, d:   0.0000000      -2.7650431      0.66666667
 i,j,k,ie:    3    6    2           7
 Near X =   1.4823792     -0.11334424E-06  0.48025188E-01, d:   0.0000000      -2.7650431      0.66666667
 i,j,k,ie:    4    6    2           7
 Near X =   1.4823792     -0.11334424E-06  0.86354515E-01, d:   0.0000000      -2.7650431      0.66666667
 i,j,k,ie:    5    6    2           7
 Near X =   1.4823792     -0.11334424E-06  0.11859381    , d:   0.0000000      -2.7650431      0.66666667
 i,j,k,ie:    6    6    2           7
 Near X =   1.4823792     -0.11334424E-06  0.13437970    , d:   0.0000000      -2.9647583      0.66666667
 i,j,k,ie:    1    1    3           7
 Near X =   1.2515995     -0.72438064       0.0000000    , d:  0.19479283      -2.5031991      0.66666667
 i,j,k,ie:    2    1    3           7
 Near X =   1.2515995     -0.72438064      0.15785898E-01, d:   0.0000000      -1.9759142      0.66666667
 i,j,k,ie:    3    1    3           7
 Near X =   1.2515995     -0.72438064      0.48025188E-01, d:   0.0000000      -1.9759142      0.66666667
 i,j,k,ie:    4    1    3           7
 Near X =   1.2515995     -0.72438064      0.86354515E-01, d:   0.0000000      -1.9759142      0.66666667
 i,j,k,ie:    5    1    3           7
 Near X =   1.2515995     -0.72438064      0.11859381    , d:   0.0000000      -1.9759142      0.66666667
 i,j,k,ie:    6    1    3           7
 Near X =   1.2515995     -0.72438064      0.13437970    , d:   0.0000000      -1.9759142      0.66666667
 i,j,k,ie:    1    2    3           7
 Near X =   1.2877256     -0.64284531       0.0000000    , d:  0.14902920       0.0000000      0.66666667
 i,j,k,ie:    6    2    3           7
 Near X =   1.2877256     -0.64284531      0.13437970    , d:   0.0000000     -0.49192974      0.66666667
 i,j,k,ie:    1    3    3           7
 Near X =   1.3505527     -0.47338329       0.0000000    , d:  0.55569791E-01   0.0000000      0.66666667
 i,j,k,ie:    6    3    3           7
 Near X =   1.3505527     -0.47338329      0.13437970    , d:   0.0000000     -0.41666152      0.66666667
 i,j,k,ie:    1    4    3           7
 Near X =   1.4061137     -0.26676714       0.0000000    , d:   0.0000000     -0.55539056E-01  0.66666667
 i,j,k,ie:    6    4    3           7
 Near X =   1.4061137     -0.26676714      0.13437970    , d:   0.0000000     -0.32182429      0.66666667
 i,j,k,ie:    1    5    3           7
 Near X =   1.4367529     -0.88654125E-01   0.0000000    , d:   0.0000000     -0.14898981      0.66666667
 i,j,k,ie:    6    5    3           7
 Near X =   1.4367529     -0.88654125E-01  0.13437970    , d:   0.0000000     -0.23755489      0.66666667
 i,j,k,ie:    1    6    3           7
 Near X =   1.4463924     -0.10367029E-06   0.0000000    , d:   0.0000000      -2.6980384      0.66666667
 i,j,k,ie:    2    6    3           7
 Near X =   1.4463924     -0.10367029E-06  0.15785898E-01, d:   0.0000000      -2.6980384      0.66666667
 i,j,k,ie:    3    6    3           7
 Near X =   1.4463924     -0.10367029E-06  0.48025188E-01, d:   0.0000000      -2.6980384      0.66666667
 i,j,k,ie:    4    6    3           7
 Near X =   1.4463924     -0.10367029E-06  0.86354515E-01, d:   0.0000000      -2.6980384      0.66666667
 i,j,k,ie:    5    6    3           7
 Near X =   1.4463924     -0.10367029E-06  0.11859381    , d:   0.0000000      -2.6980384      0.66666667
 i,j,k,ie:    6    6    3           7
 Near X =   1.4463924     -0.10367029E-06  0.13437970    , d:   0.0000000      -2.8927847      0.66666667
 i,j,k,ie:    1    1    4           7
 Near X =   1.2147319     -0.70237679       0.0000000    , d:  0.18887579      -2.4294638      0.66666667
 i,j,k,ie:    2    1    4           7
 Near X =   1.2147319     -0.70237679      0.15785898E-01, d:   0.0000000      -1.9170749      0.66666667
 i,j,k,ie:    3    1    4           7
 Near X =   1.2147319     -0.70237679      0.48025188E-01, d:   0.0000000      -1.9170749      0.66666667
 i,j,k,ie:    4    1    4           7
 Near X =   1.2147319     -0.70237679      0.86354515E-01, d:   0.0000000      -1.9170749      0.66666667
 i,j,k,ie:    5    1    4           7
 Near X =   1.2147319     -0.70237679      0.11859381    , d:   0.0000000      -1.9170749      0.66666667
 i,j,k,ie:    6    1    4           7
 Near X =   1.2147319     -0.70237679      0.13437970    , d:   0.0000000      -1.9170749      0.66666667
 i,j,k,ie:    1    2    4           7
 Near X =   1.2442847     -0.62184646       0.0000000    , d:  0.14450280       0.0000000      0.66666667
 i,j,k,ie:    6    2    4           7
 Near X =   1.2442847     -0.62184646      0.13437970    , d:   0.0000000     -0.47644469      0.66666667
 i,j,k,ie:    1    3    4           7
 Near X =   1.2985487     -0.45574351       0.0000000    , d:  0.53882159E-01   0.0000000      0.66666667
 i,j,k,ie:    6    3    4           7
 Near X =   1.2985487     -0.45574351      0.13437970    , d:   0.0000000     -0.40133300      0.66666667
 i,j,k,ie:    1    4    4           7
 Near X =   1.3524220     -0.25540353       0.0000000    , d:   0.0000000     -0.53853952E-01  0.66666667
 i,j,k,ie:    6    4    4           7
 Near X =   1.3524220     -0.25540353      0.13437970    , d:   0.0000000     -0.30905687      0.66666667
 i,j,k,ie:    1    5    4           7
 Near X =   1.3887851     -0.84489420E-01   0.0000000    , d:   0.0000000     -0.14446978      0.66666667
 i,j,k,ie:    6    5    4           7
 Near X =   1.3887851     -0.84489420E-01  0.13437970    , d:   0.0000000     -0.22893926      0.66666667
 i,j,k,ie:    1    6    4           7
 Near X =   1.4036077     -0.92168933E-07   0.0000000    , d:   0.0000000      -2.6183765      0.66666667
 i,j,k,ie:    2    6    4           7
 Near X =   1.4036077     -0.92168933E-07  0.15785898E-01, d:   0.0000000      -2.6183765      0.66666667
 i,j,k,ie:    3    6    4           7
 Near X =   1.4036077     -0.92168933E-07  0.48025188E-01, d:   0.0000000      -2.6183765      0.66666667
 i,j,k,ie:    4    6    4           7
 Near X =   1.4036077     -0.92168933E-07  0.86354515E-01, d:   0.0000000      -2.6183765      0.66666667
 i,j,k,ie:    5    6    4           7
 Near X =   1.4036077     -0.92168933E-07  0.11859381    , d:   0.0000000      -2.6183765      0.66666667
 i,j,k,ie:    6    6    4           7
 Near X =   1.4036077     -0.92168933E-07  0.13437970    , d:   0.0000000      -2.8072153      0.66666667
 i,j,k,ie:    1    1    5           7
 Near X =   1.1837220     -0.68386908       0.0000000    , d:  0.18389889      -2.3674440      0.66666667
 i,j,k,ie:    2    1    5           7
 Near X =   1.1837220     -0.68386908      0.15785898E-01, d:   0.0000000      -1.8675844      0.66666667
 i,j,k,ie:    3    1    5           7
 Near X =   1.1837220     -0.68386908      0.48025188E-01, d:   0.0000000      -1.8675844      0.66666667
 i,j,k,ie:    4    1    5           7
 Near X =   1.1837220     -0.68386908      0.86354515E-01, d:   0.0000000      -1.8675844      0.66666667
 i,j,k,ie:    5    1    5           7
 Near X =   1.1837220     -0.68386908      0.11859381    , d:   0.0000000      -1.8675844      0.66666667
 i,j,k,ie:    6    1    5           7
 Near X =   1.1837220     -0.68386908      0.13437970    , d:   0.0000000      -1.8675844      0.66666667
 i,j,k,ie:    1    2    5           7
 Near X =   1.2077459     -0.60418405       0.0000000    , d:  0.14069558       0.0000000      0.66666667
 i,j,k,ie:    6    2    5           7
 Near X =   1.2077459     -0.60418405      0.13437970    , d:   0.0000000     -0.46342002      0.66666667
 i,j,k,ie:    1    3    5           7
 Near X =   1.2548075     -0.44090645       0.0000000    , d:  0.52462670E-01   0.0000000      0.66666667
 i,j,k,ie:    6    3    5           7
 Near X =   1.2548075     -0.44090645      0.13437970    , d:   0.0000000     -0.38843999      0.66666667
 i,j,k,ie:    1    4    5           7
 Near X =   1.3072613     -0.24584546       0.0000000    , d:   0.0000000     -0.52436589E-01  0.66666667
 i,j,k,ie:    6    4    5           7
 Near X =   1.3072613     -0.24584546      0.13437970    , d:   0.0000000     -0.29831802      0.66666667
 i,j,k,ie:    1    5    5           7
 Near X =   1.3484388     -0.80986433E-01   0.0000000    , d:   0.0000000     -0.14066792      0.66666667
 i,j,k,ie:    6    5    5           7
 Near X =   1.3484388     -0.80986433E-01  0.13437970    , d:   0.0000000     -0.22169254      0.66666667
 i,j,k,ie:    1    6    5           7
 Near X =   1.3676209     -0.82494990E-07   0.0000000    , d:   0.0000000      -2.5513718      0.66666667
 i,j,k,ie:    2    6    5           7
 Near X =   1.3676209     -0.82494990E-07  0.15785898E-01, d:   0.0000000      -2.5513718      0.66666667
 i,j,k,ie:    3    6    5           7
 Near X =   1.3676209     -0.82494990E-07  0.48025188E-01, d:   0.0000000      -2.5513718      0.66666667
 i,j,k,ie:    4    6    5           7
 Near X =   1.3676209     -0.82494990E-07  0.86354515E-01, d:   0.0000000      -2.5513718      0.66666667
 i,j,k,ie:    5    6    5           7
 Near X =   1.3676209     -0.82494990E-07  0.11859381    , d:   0.0000000      -2.5513718      0.66666667
 i,j,k,ie:    6    6    5           7
 Near X =   1.3676209     -0.82494990E-07  0.13437970    , d:   0.0000000      -2.7352417      0.66666667
 i,j,k,ie:    1    1    6           7
 Near X =   1.1685381     -0.67480681       0.0000000    , d:  0.33146194      -2.4663314      0.66666667
 i,j,k,ie:    2    1    6           7
 Near X =   1.1685381     -0.67480681      0.15785898E-01, d:  0.12925528      -1.9203824      0.66666667
 i,j,k,ie:    3    1    6           7
 Near X =   1.1685381     -0.67480681      0.48025188E-01, d:  0.12925528      -1.9203824      0.66666667
 i,j,k,ie:    4    1    6           7
 Near X =   1.1685381     -0.67480681      0.86354515E-01, d:  0.12925528      -1.9203824      0.66666667
 i,j,k,ie:    5    1    6           7
 Near X =   1.1685381     -0.67480681      0.11859381    , d:  0.12925528      -1.9203824      0.66666667
 i,j,k,ie:    6    1    6           7
 Near X =   1.1685381     -0.67480681      0.13437970    , d:  0.12925528      -1.9203824      0.66666667
 i,j,k,ie:    1    2    6           7
 Near X =   1.1898548     -0.59553569       0.0000000    , d:  0.30700126       0.0000000      0.66666667
 i,j,k,ie:    2    2    6           7
 Near X =   1.1898548     -0.59553569      0.15785898E-01, d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    3    2    6           7
 Near X =   1.1898548     -0.59553569      0.48025188E-01, d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    4    2    6           7
 Near X =   1.1898548     -0.59553569      0.86354515E-01, d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    5    2    6           7
 Near X =   1.1898548     -0.59553569      0.11859381    , d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    6    2    6           7
 Near X =   1.1898548     -0.59553569      0.13437970    , d:  0.15230065     -0.45704252      0.66666667
 i,j,k,ie:    1    3    6           7
 Near X =   1.2333897     -0.43364152       0.0000000    , d:  0.24000629       0.0000000      0.66666667
 i,j,k,ie:    2    3    6           7
 Near X =   1.2333897     -0.43364152      0.15785898E-01, d:  0.18232196       0.0000000      0.66666667
 i,j,k,ie:    3    3    6           7
 Near X =   1.2333897     -0.43364152      0.48025188E-01, d:  0.18232196       0.0000000      0.66666667
 i,j,k,ie:    4    3    6           7
 Near X =   1.2333897     -0.43364152      0.86354515E-01, d:  0.18232196       0.0000000      0.66666667
 i,j,k,ie:    5    3    6           7
 Near X =   1.2333897     -0.43364152      0.11859381    , d:  0.18232196       0.0000000      0.66666667
 i,j,k,ie:    6    3    6           7
 Near X =   1.2333897     -0.43364152      0.13437970    , d:  0.18232196     -0.38212696      0.66666667
 i,j,k,ie:    1    4    6           7
 Near X =   1.2851484     -0.24116537       0.0000000    , d:  0.18823900     -0.51742581E-01  0.66666667
 i,j,k,ie:    2    4    6           7
 Near X =   1.2851484     -0.24116537      0.15785898E-01, d:  0.18823900       0.0000000      0.66666667
 i,j,k,ie:    3    4    6           7
 Near X =   1.2851484     -0.24116537      0.48025188E-01, d:  0.18823900       0.0000000      0.66666667
 i,j,k,ie:    4    4    6           7
 Near X =   1.2851484     -0.24116537      0.86354515E-01, d:  0.18823900       0.0000000      0.66666667
 i,j,k,ie:    5    4    6           7
 Near X =   1.2851484     -0.24116537      0.11859381    , d:  0.18823900       0.0000000      0.66666667
 i,j,k,ie:    6    4    6           7
 Near X =   1.2851484     -0.24116537      0.13437970    , d:  0.18823900     -0.29305977      0.66666667
 i,j,k,ie:    1    5    6           7
 Near X =   1.3286833     -0.79271203E-01   0.0000000    , d:  0.16817149     -0.13880634      0.66666667
 i,j,k,ie:    2    5    6           7
 Near X =   1.3286833     -0.79271203E-01  0.15785898E-01, d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    3    5    6           7
 Near X =   1.3286833     -0.79271203E-01  0.48025188E-01, d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    4    5    6           7
 Near X =   1.3286833     -0.79271203E-01  0.86354515E-01, d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    5    5    6           7
 Near X =   1.3286833     -0.79271203E-01  0.11859381    , d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    6    5    6           7
 Near X =   1.3286833     -0.79271203E-01  0.13437970    , d:  0.16817149     -0.21814421      0.66666667
 i,j,k,ie:    1    6    6           7
 Near X =   1.3500000     -0.77758166E-07   0.0000000    , d:  0.14999998      -2.6478518      0.66666667
 i,j,k,ie:    2    6    6           7
 Near X =   1.3500000     -0.77758166E-07  0.15785898E-01, d:  0.14999998      -2.6478518      0.66666667
 i,j,k,ie:    3    6    6           7
 Near X =   1.3500000     -0.77758166E-07  0.48025188E-01, d:  0.14999998      -2.6478518      0.66666667
 i,j,k,ie:    4    6    6           7
 Near X =   1.3500000     -0.77758166E-07  0.86354515E-01, d:  0.14999998      -2.6478518      0.66666667
 i,j,k,ie:    5    6    6           7
 Near X =   1.3500000     -0.77758166E-07  0.11859381    , d:  0.14999998      -2.6478518      0.66666667
 i,j,k,ie:    6    6    6           7
 Near X =   1.3500000     -0.77758166E-07  0.13437970    , d:  0.14999998      -2.8500000      0.66666667
 i,j,k,ie:    1    1    1           8
 Near X =  0.75184425      -1.2978518       0.0000000    , d:  0.54594909      -1.5036886      0.77053871
 i,j,k,ie:    2    1    1           8
 Near X =  0.75184425      -1.2978518      0.15785898E-01, d:   0.0000000     -0.75184419      0.77053871
 i,j,k,ie:    3    1    1           8
 Near X =  0.75184425      -1.2978518      0.48025188E-01, d:   0.0000000     -0.75184419      0.77053871
 i,j,k,ie:    4    1    1           8
 Near X =  0.75184425      -1.2978518      0.86354515E-01, d:   0.0000000     -0.75184419      0.77053871
 i,j,k,ie:    5    1    1           8
 Near X =  0.75184425      -1.2978518      0.11859381    , d:   0.0000000     -0.75184419      0.77053871
 i,j,k,ie:    6    1    1           8
 Near X =  0.75184425      -1.2978518      0.13437970    , d:   0.0000000     -0.75184419      0.77053871
 i,j,k,ie:    1    2    1           8
 Near X =  0.83082355      -1.2485701       0.0000000    , d:  0.51133191       0.0000000      0.77053871
 i,j,k,ie:    1    3    1           8
 Near X =  0.97984411      -1.1356442       0.0000000    , d:  0.43586756       0.0000000      0.77053871
 i,j,k,ie:    1    4    1           8
 Near X =   1.1355660     -0.97993599       0.0000000    , d:  0.33782139       0.0000000      0.77053871
 i,j,k,ie:    1    5    1           8
 Near X =   1.2485048     -0.83092549       0.0000000    , d:  0.24834994       0.0000000      0.77053871
 i,j,k,ie:    1    6    1           8
 Near X =   1.2977933     -0.75195062       0.0000000    , d:  0.20220666      -2.7977933      0.77053871
 i,j,k,ie:    2    6    1           8
 Near X =   1.2977933     -0.75195062      0.15785898E-01, d:   0.0000000      -2.7977933      0.77053871
 i,j,k,ie:    3    6    1           8
 Near X =   1.2977933     -0.75195062      0.48025188E-01, d:   0.0000000      -2.7977933      0.77053871
 i,j,k,ie:    4    6    1           8
 Near X =   1.2977933     -0.75195062      0.86354515E-01, d:   0.0000000      -2.7977933      0.77053871
 i,j,k,ie:    5    6    1           8
 Near X =   1.2977933     -0.75195062      0.11859381    , d:   0.0000000      -2.7977933      0.77053871
 i,j,k,ie:    6    6    1           8
 Near X =   1.2977933     -0.75195062      0.13437970    , d:   0.0000000      -2.7977933      0.77053871
 i,j,k,ie:    1    1    2           8
 Near X =  0.74279524      -1.2826639       0.0000000    , d:  0.53981418      -1.4855906      0.77053871
 i,j,k,ie:    2    1    2           8
 Near X =  0.74279524      -1.2826639      0.15785898E-01, d:   0.0000000     -0.74279518      0.77053871
 i,j,k,ie:    3    1    2           8
 Near X =  0.74279524      -1.2826639      0.48025188E-01, d:   0.0000000     -0.74279518      0.77053871
 i,j,k,ie:    4    1    2           8
 Near X =  0.74279524      -1.2826639      0.86354515E-01, d:   0.0000000     -0.74279518      0.77053871
 i,j,k,ie:    5    1    2           8
 Near X =  0.74279524      -1.2826639      0.11859381    , d:   0.0000000     -0.74279518      0.77053871
 i,j,k,ie:    6    1    2           8
 Near X =  0.74279524      -1.2826639      0.13437970    , d:   0.0000000     -0.74279518      0.77053871
 i,j,k,ie:    1    2    2           8
 Near X =  0.81930994      -1.2323578       0.0000000    , d:  0.50495441       0.0000000      0.77053871
 i,j,k,ie:    1    3    2           8
 Near X =  0.96473935      -1.1187820       0.0000000    , d:  0.42955453       0.0000000      0.77053871
 i,j,k,ie:    1    4    2           8
 Near X =   1.1187114     -0.96482101       0.0000000    , d:  0.33256314       0.0000000      0.77053871
 i,j,k,ie:    1    5    2           8
 Near X =   1.2322977     -0.81939958       0.0000000    , d:  0.24480160       0.0000000      0.77053871
 i,j,k,ie:    1    6    2           8
 Near X =   1.2826094     -0.74288836       0.0000000    , d:  0.19976973      -2.7649886      0.77053871
 i,j,k,ie:    2    6    2           8
 Near X =   1.2826094     -0.74288836      0.15785898E-01, d:   0.0000000      -2.7649886      0.77053871
 i,j,k,ie:    3    6    2           8
 Near X =   1.2826094     -0.74288836      0.48025188E-01, d:   0.0000000      -2.7649886      0.77053871
 i,j,k,ie:    4    6    2           8
 Near X =   1.2826094     -0.74288836      0.86354515E-01, d:   0.0000000      -2.7649886      0.77053871
 i,j,k,ie:    5    6    2           8
 Near X =   1.2826094     -0.74288836      0.11859381    , d:   0.0000000      -2.7649886      0.77053871
 i,j,k,ie:    6    6    2           8
 Near X =   1.2826094     -0.74288836      0.13437970    , d:   0.0000000      -2.7649886      0.77053871
 i,j,k,ie:    1    1    3           8
 Near X =  0.72431460      -1.2516460       0.0000000    , d:  0.52728494      -1.4486293      0.77053871
 i,j,k,ie:    2    1    3           8
 Near X =  0.72431460      -1.2516460      0.15785898E-01, d:   0.0000000     -0.72431454      0.77053871
 i,j,k,ie:    3    1    3           8
 Near X =  0.72431460      -1.2516460      0.48025188E-01, d:   0.0000000     -0.72431454      0.77053871
 i,j,k,ie:    4    1    3           8
 Near X =  0.72431460      -1.2516460      0.86354515E-01, d:   0.0000000     -0.72431454      0.77053871
 i,j,k,ie:    5    1    3           8
 Near X =  0.72431460      -1.2516460      0.11859381    , d:   0.0000000     -0.72431454      0.77053871
 i,j,k,ie:    6    1    3           8
 Near X =  0.72431460      -1.2516460      0.13437970    , d:   0.0000000     -0.72431454      0.77053871
 i,j,k,ie:    1    2    3           8
 Near X =  0.79579588      -1.1992476       0.0000000    , d:  0.49192974       0.0000000      0.77053871
 i,j,k,ie:    1    3    3           8
 Near X =  0.93389116      -1.0843446       0.0000000    , d:  0.41666152       0.0000000      0.77053871
 i,j,k,ie:    1    4    3           8
 Near X =   1.0842894     -0.93395191       0.0000000    , d:  0.32182429       0.0000000      0.77053871
 i,j,k,ie:    1    5    3           8
 Near X =   1.1991980     -0.79586039       0.0000000    , d:  0.23755489       0.0000000      0.77053871
 i,j,k,ie:    1    6    3           8
 Near X =   1.2515995     -0.72438064       0.0000000    , d:  0.19479283      -2.6979919      0.77053871
 i,j,k,ie:    2    6    3           8
 Near X =   1.2515995     -0.72438064      0.15785898E-01, d:   0.0000000      -2.6979919      0.77053871
 i,j,k,ie:    3    6    3           8
 Near X =   1.2515995     -0.72438064      0.48025188E-01, d:   0.0000000      -2.6979919      0.77053871
 i,j,k,ie:    4    6    3           8
 Near X =   1.2515995     -0.72438064      0.86354515E-01, d:   0.0000000      -2.6979919      0.77053871
 i,j,k,ie:    5    6    3           8
 Near X =   1.2515995     -0.72438064      0.11859381    , d:   0.0000000      -2.6979919      0.77053871
 i,j,k,ie:    6    6    3           8
 Near X =   1.2515995     -0.72438064      0.13437970    , d:   0.0000000      -2.6979919      0.77053871
 i,j,k,ie:    1    1    4           8
 Near X =  0.70234295      -1.2147688       0.0000000    , d:  0.51238891      -1.4046860      0.77053871
 i,j,k,ie:    2    1    4           8
 Near X =  0.70234295      -1.2147688      0.15785898E-01, d:   0.0000000     -0.70234289      0.77053871
 i,j,k,ie:    3    1    4           8
 Near X =  0.70234295      -1.2147688      0.48025188E-01, d:   0.0000000     -0.70234289      0.77053871
 i,j,k,ie:    4    1    4           8
 Near X =  0.70234295      -1.2147688      0.86354515E-01, d:   0.0000000     -0.70234289      0.77053871
 i,j,k,ie:    5    1    4           8
 Near X =  0.70234295      -1.2147688      0.11859381    , d:   0.0000000     -0.70234289      0.77053871
 i,j,k,ie:    6    1    4           8
 Near X =  0.70234295      -1.2147688      0.13437970    , d:   0.0000000     -0.70234289      0.77053871
 i,j,k,ie:    1    2    4           8
 Near X =  0.76783998      -1.1598829       0.0000000    , d:  0.47644469       0.0000000      0.77053871
 i,j,k,ie:    1    3    4           8
 Near X =  0.89721570      -1.0434020       0.0000000    , d:  0.40133300       0.0000000      0.77053871
 i,j,k,ie:    1    4    4           8
 Near X =   1.0433652     -0.89725161       0.0000000    , d:  0.30905687       0.0000000      0.77053871
 i,j,k,ie:    1    5    4           8
 Near X =   1.1598458     -0.76787462       0.0000000    , d:  0.22893926       0.0000000      0.77053871
 i,j,k,ie:    1    6    4           8
 Near X =   1.2147319     -0.70237679       0.0000000    , d:  0.18887579      -2.6183395      0.77053871
 i,j,k,ie:    2    6    4           8
 Near X =   1.2147319     -0.70237679      0.15785898E-01, d:   0.0000000      -2.6183395      0.77053871
 i,j,k,ie:    3    6    4           8
 Near X =   1.2147319     -0.70237679      0.48025188E-01, d:   0.0000000      -2.6183395      0.77053871
 i,j,k,ie:    4    6    4           8
 Near X =   1.2147319     -0.70237679      0.86354515E-01, d:   0.0000000      -2.6183395      0.77053871
 i,j,k,ie:    5    6    4           8
 Near X =   1.2147319     -0.70237679      0.11859381    , d:   0.0000000      -2.6183395      0.77053871
 i,j,k,ie:    6    6    4           8
 Near X =   1.2147319     -0.70237679      0.13437970    , d:   0.0000000      -2.6183395      0.77053871
 i,j,k,ie:    1    1    5           8
 Near X =  0.68386231      -1.1837509       0.0000000    , d:  0.49985967      -1.3677247      0.77053871
 i,j,k,ie:    2    1    5           8
 Near X =  0.68386231      -1.1837509      0.15785898E-01, d:   0.0000000     -0.68386225      0.77053871
 i,j,k,ie:    3    1    5           8
 Near X =  0.68386231      -1.1837509      0.48025188E-01, d:   0.0000000     -0.68386225      0.77053871
 i,j,k,ie:    4    1    5           8
 Near X =  0.68386231      -1.1837509      0.86354515E-01, d:   0.0000000     -0.68386225      0.77053871
 i,j,k,ie:    5    1    5           8
 Near X =  0.68386231      -1.1837509      0.11859381    , d:   0.0000000     -0.68386225      0.77053871
 i,j,k,ie:    6    1    5           8
 Near X =  0.68386231      -1.1837509      0.13437970    , d:   0.0000000     -0.68386225      0.77053871
 i,j,k,ie:    1    2    5           8
 Near X =  0.74432591      -1.1267727       0.0000000    , d:  0.46342002       0.0000000      0.77053871
 i,j,k,ie:    1    3    5           8
 Near X =  0.86636750      -1.0089646       0.0000000    , d:  0.38843999       0.0000000      0.77053871
 i,j,k,ie:    1    4    5           8
 Near X =   1.0089432     -0.86638251       0.0000000    , d:  0.29831802       0.0000000      0.77053871
 i,j,k,ie:    1    5    5           8
 Near X =   1.1267462     -0.74433543       0.0000000    , d:  0.22169254       0.0000000      0.77053871
 i,j,k,ie:    1    6    5           8
 Near X =   1.1837220     -0.68386908       0.0000000    , d:  0.18389889      -2.5513429      0.77053871
 i,j,k,ie:    2    6    5           8
 Near X =   1.1837220     -0.68386908      0.15785898E-01, d:   0.0000000      -2.5513429      0.77053871
 i,j,k,ie:    3    6    5           8
 Near X =   1.1837220     -0.68386908      0.48025188E-01, d:   0.0000000      -2.5513429      0.77053871
 i,j,k,ie:    4    6    5           8
 Near X =   1.1837220     -0.68386908      0.86354515E-01, d:   0.0000000      -2.5513429      0.77053871
 i,j,k,ie:    5    6    5           8
 Near X =   1.1837220     -0.68386908      0.11859381    , d:   0.0000000      -2.5513429      0.77053871
 i,j,k,ie:    6    6    5           8
 Near X =   1.1837220     -0.68386908      0.13437970    , d:   0.0000000      -2.5513429      0.77053871
 i,j,k,ie:    1    1    6           8
 Near X =  0.67481330      -1.1685631       0.0000000    , d:  0.62298004      -1.4266577      0.77053871
 i,j,k,ie:    2    1    6           8
 Near X =  0.67481330      -1.1685631      0.15785898E-01, d:  0.77030946E-01 -0.67481325      0.77053871
 i,j,k,ie:    3    1    6           8
 Near X =  0.67481330      -1.1685631      0.48025188E-01, d:  0.77030946E-01 -0.67481325      0.77053871
 i,j,k,ie:    4    1    6           8
 Near X =  0.67481330      -1.1685631      0.86354515E-01, d:  0.77030946E-01 -0.67481325      0.77053871
 i,j,k,ie:    5    1    6           8
 Near X =  0.67481330      -1.1685631      0.11859381    , d:  0.77030946E-01 -0.67481325      0.77053871
 i,j,k,ie:    6    1    6           8
 Near X =  0.67481330      -1.1685631      0.13437970    , d:  0.77030946E-01 -0.67481325      0.77053871
 i,j,k,ie:    1    2    6           8
 Near X =  0.73281230      -1.1105604       0.0000000    , d:  0.60934316       0.0000000      0.77053871
 i,j,k,ie:    2    2    6           8
 Near X =  0.73281230      -1.1105604      0.15785898E-01, d:  0.98011250E-01   0.0000000      0.77053871
 i,j,k,ie:    3    2    6           8
 Near X =  0.73281230      -1.1105604      0.48025188E-01, d:  0.98011250E-01   0.0000000      0.77053871
 i,j,k,ie:    4    2    6           8
 Near X =  0.73281230      -1.1105604      0.86354515E-01, d:  0.98011250E-01   0.0000000      0.77053871
 i,j,k,ie:    5    2    6           8
 Near X =  0.73281230      -1.1105604      0.11859381    , d:  0.98011250E-01   0.0000000      0.77053871
 i,j,k,ie:    6    2    6           8
 Near X =  0.73281230      -1.1105604      0.13437970    , d:  0.98011250E-01   0.0000000      0.77053871
 i,j,k,ie:    1    3    6           8
 Near X =  0.85126275     -0.99210238       0.0000000    , d:  0.56444892       0.0000000      0.77053871
 i,j,k,ie:    2    3    6           8
 Near X =  0.85126275     -0.99210238      0.15785898E-01, d:  0.12858136       0.0000000      0.77053871
 i,j,k,ie:    3    3    6           8
 Near X =  0.85126275     -0.99210238      0.48025188E-01, d:  0.12858136       0.0000000      0.77053871
 i,j,k,ie:    4    3    6           8
 Near X =  0.85126275     -0.99210238      0.86354515E-01, d:  0.12858136       0.0000000      0.77053871
 i,j,k,ie:    5    3    6           8
 Near X =  0.85126275     -0.99210238      0.11859381    , d:  0.12858136       0.0000000      0.77053871
 i,j,k,ie:    6    3    6           8
 Near X =  0.85126275     -0.99210238      0.13437970    , d:  0.12858136       0.0000000      0.77053871
 i,j,k,ie:    1    4    6           8
 Near X =  0.99208861     -0.85126753       0.0000000    , d:  0.48129877       0.0000000      0.77053871
 i,j,k,ie:    2    4    6           8
 Near X =  0.99208861     -0.85126753      0.15785898E-01, d:  0.14347738       0.0000000      0.77053871
 i,j,k,ie:    3    4    6           8
 Near X =  0.99208861     -0.85126753      0.48025188E-01, d:  0.14347738       0.0000000      0.77053871
 i,j,k,ie:    4    4    6           8
 Near X =  0.99208861     -0.85126753      0.86354515E-01, d:  0.14347738       0.0000000      0.77053871
 i,j,k,ie:    5    4    6           8
 Near X =  0.99208861     -0.85126753      0.11859381    , d:  0.14347738       0.0000000      0.77053871
 i,j,k,ie:    6    4    6           8
 Near X =  0.99208861     -0.85126753      0.13437970    , d:  0.14347738       0.0000000      0.77053871
 i,j,k,ie:    1    5    6           8
 Near X =   1.1105391     -0.73280952       0.0000000    , d:  0.38631569       0.0000000      0.77053871
 i,j,k,ie:    2    5    6           8
 Near X =   1.1105391     -0.73280952      0.15785898E-01, d:  0.13796575       0.0000000      0.77053871
 i,j,k,ie:    3    5    6           8
 Near X =   1.1105391     -0.73280952      0.48025188E-01, d:  0.13796575       0.0000000      0.77053871
 i,j,k,ie:    4    5    6           8
 Near X =   1.1105391     -0.73280952      0.86354515E-01, d:  0.13796575       0.0000000      0.77053871
 i,j,k,ie:    5    5    6           8
 Near X =   1.1105391     -0.73280952      0.11859381    , d:  0.13796575       0.0000000      0.77053871
 i,j,k,ie:    6    5    6           8
 Near X =   1.1105391     -0.73280952      0.13437970    , d:  0.13796575       0.0000000      0.77053871
 i,j,k,ie:    1    6    6           8
 Near X =   1.1685381     -0.67480681       0.0000000    , d:  0.33146194      -2.6685381      0.77053871
 i,j,k,ie:    2    6    6           8
 Near X =   1.1685381     -0.67480681      0.15785898E-01, d:  0.12925528      -2.6685381      0.77053871
 i,j,k,ie:    3    6    6           8
 Near X =   1.1685381     -0.67480681      0.48025188E-01, d:  0.12925528      -2.6685381      0.77053871
 i,j,k,ie:    4    6    6           8
 Near X =   1.1685381     -0.67480681      0.86354515E-01, d:  0.12925528      -2.6685381      0.77053871
 i,j,k,ie:    5    6    6           8
 Near X =   1.1685381     -0.67480681      0.11859381    , d:  0.12925528      -2.6685381      0.77053871
 i,j,k,ie:    6    6    6           8
 Near X =   1.1685381     -0.67480681      0.13437970    , d:  0.12925528      -2.6685381      0.77053871
 i,j,k,ie:    1    1    1           9
 Near X = -0.17702063E-06  -1.5000000       0.0000000    , d:  0.75195075       0.0000000       1.3300624
 i,j,k,ie:    2    1    1           9
 Near X = -0.17702063E-06  -1.5000000      0.15785898E-01, d:  0.75195075       0.0000000       1.3300624
 i,j,k,ie:    3    1    1           9
 Near X = -0.17702063E-06  -1.5000000      0.48025188E-01, d:  0.75195075       0.0000000       1.3300624
 i,j,k,ie:    4    1    1           9
 Near X = -0.17702063E-06  -1.5000000      0.86354515E-01, d:  0.75195075       0.0000000       1.3300624
 i,j,k,ie:    5    1    1           9
 Near X = -0.17702063E-06  -1.5000000      0.11859381    , d:  0.75195075       0.0000000       1.3300624
 i,j,k,ie:    6    1    1           9
 Near X = -0.17702063E-06  -1.5000000      0.13437970    , d:   1.2978520     -0.75195043       1.3300624
 i,j,k,ie:    6    2    1           9
 Near X =  0.93857198E-01  -1.4968561      0.13437970    , d:   0.0000000     -0.76301327       1.3300624
 i,j,k,ie:    6    3    1           9
 Near X =  0.28096180      -1.4733960      0.13437970    , d:   0.0000000     -0.77644709       1.3300624
 i,j,k,ie:    6    4    1           9
 Near X =  0.49541153      -1.4157370      0.13437970    , d:   0.0000000     -0.77641686       1.3300624
 i,j,k,ie:    6    5    1           9
 Near X =  0.66905978      -1.3422015      0.13437970    , d:   0.0000000     -0.76293217       1.3300624
 i,j,k,ie:    1    6    1           9
 Near X =  0.75184425      -1.2978518       0.0000000    , d:   0.0000000      -1.4266511       1.3300624
 i,j,k,ie:    2    6    1           9
 Near X =  0.75184425      -1.2978518      0.15785898E-01, d:   0.0000000      -1.4266511       1.3300624
 i,j,k,ie:    3    6    1           9
 Near X =  0.75184425      -1.2978518      0.48025188E-01, d:   0.0000000      -1.4266511       1.3300624
 i,j,k,ie:    4    6    1           9
 Near X =  0.75184425      -1.2978518      0.86354515E-01, d:   0.0000000      -1.4266511       1.3300624
 i,j,k,ie:    5    6    1           9
 Near X =  0.75184425      -1.2978518      0.11859381    , d:   0.0000000      -1.4266511       1.3300624
 i,j,k,ie:    6    6    1           9
 Near X =  0.75184425      -1.2978518      0.13437970    , d:   0.0000000      -1.9204073       1.3300624
 i,j,k,ie:    1    1    2           9
 Near X = -0.17494016E-06  -1.4823791       0.0000000    , d:  0.74288849       0.0000000       1.3300624
 i,j,k,ie:    2    1    2           9
 Near X = -0.17494016E-06  -1.4823791      0.15785898E-01, d:  0.74288849       0.0000000       1.3300624
 i,j,k,ie:    3    1    2           9
 Near X = -0.17494016E-06  -1.4823791      0.48025188E-01, d:  0.74288849       0.0000000       1.3300624
 i,j,k,ie:    4    1    2           9
 Near X = -0.17494016E-06  -1.4823791      0.86354515E-01, d:  0.74288849       0.0000000       1.3300624
 i,j,k,ie:    5    1    2           9
 Near X = -0.17494016E-06  -1.4823791      0.11859381    , d:  0.74288849       0.0000000       1.3300624
 i,j,k,ie:    6    1    2           9
 Near X = -0.17494016E-06  -1.4823791      0.13437970    , d:   1.2826641     -0.74288817       1.3300624
 i,j,k,ie:    6    2    2           9
 Near X =  0.92143812E-01  -1.4771008      0.13437970    , d:   0.0000000     -0.75265153       1.3300624
 i,j,k,ie:    6    3    2           9
 Near X =  0.27628708      -1.4512832      0.13437970    , d:   0.0000000     -0.76450744       1.3300624
 i,j,k,ie:    6    4    2           9
 Near X =  0.48815574      -1.3943181      0.13437970    , d:   0.0000000     -0.76448098       1.3300624
 i,j,k,ie:    6    5    2           9
 Near X =  0.66042340      -1.3243076      0.13437970    , d:   0.0000000     -0.75258056       1.3300624
 i,j,k,ie:    1    6    2           9
 Near X =  0.74279524      -1.2826639       0.0000000    , d:   0.0000000      -1.3970503       1.3300624
 i,j,k,ie:    2    6    2           9
 Near X =  0.74279524      -1.2826639      0.15785898E-01, d:   0.0000000      -1.3970503       1.3300624
 i,j,k,ie:    3    6    2           9
 Near X =  0.74279524      -1.2826639      0.48025188E-01, d:   0.0000000      -1.3970503       1.3300624
 i,j,k,ie:    4    6    2           9
 Near X =  0.74279524      -1.2826639      0.86354515E-01, d:   0.0000000      -1.3970503       1.3300624
 i,j,k,ie:    5    6    2           9
 Near X =  0.74279524      -1.2826639      0.11859381    , d:   0.0000000      -1.3970503       1.3300624
 i,j,k,ie:    6    6    2           9
 Near X =  0.74279524      -1.2826639      0.13437970    , d:   0.0000000      -1.8757688       1.3300624
 i,j,k,ie:    1    1    3           9
 Near X = -0.17069125E-06  -1.4463924       0.0000000    , d:  0.72438077       0.0000000       1.3300624
 i,j,k,ie:    2    1    3           9
 Near X = -0.17069125E-06  -1.4463924      0.15785898E-01, d:  0.72438077       0.0000000       1.3300624
 i,j,k,ie:    3    1    3           9
 Near X = -0.17069125E-06  -1.4463924      0.48025188E-01, d:  0.72438077       0.0000000       1.3300624
 i,j,k,ie:    4    1    3           9
 Near X = -0.17069125E-06  -1.4463924      0.86354515E-01, d:  0.72438077       0.0000000       1.3300624
 i,j,k,ie:    5    1    3           9
 Near X = -0.17069125E-06  -1.4463924      0.11859381    , d:  0.72438077       0.0000000       1.3300624
 i,j,k,ie:    6    1    3           9
 Near X = -0.17069125E-06  -1.4463924      0.13437970    , d:   1.2516462     -0.72438047       1.3300624
 i,j,k,ie:    6    2    3           9
 Near X =  0.88644591E-01  -1.4367548      0.13437970    , d:   0.0000000     -0.73148991       1.3300624
 i,j,k,ie:    6    3    3           9
 Near X =  0.26673996      -1.4061225      0.13437970    , d:   0.0000000     -0.74012327       1.3300624
 i,j,k,ie:    6    4    3           9
 Near X =  0.47333736      -1.3505747      0.13437970    , d:   0.0000000     -0.74010454       1.3300624
 i,j,k,ie:    6    5    3           9
 Near X =  0.64278546      -1.2877631      0.13437970    , d:   0.0000000     -0.73143965       1.3300624
 i,j,k,ie:    1    6    3           9
 Near X =  0.72431460      -1.2516460       0.0000000    , d:   0.0000000      -1.3365971       1.3300624
 i,j,k,ie:    2    6    3           9
 Near X =  0.72431460      -1.2516460      0.15785898E-01, d:   0.0000000      -1.3365971       1.3300624
 i,j,k,ie:    3    6    3           9
 Near X =  0.72431460      -1.2516460      0.48025188E-01, d:   0.0000000      -1.3365971       1.3300624
 i,j,k,ie:    4    6    3           9
 Near X =  0.72431460      -1.2516460      0.86354515E-01, d:   0.0000000      -1.3365971       1.3300624
 i,j,k,ie:    5    6    3           9
 Near X =  0.72431460      -1.2516460      0.11859381    , d:   0.0000000      -1.3365971       1.3300624
 i,j,k,ie:    6    6    3           9
 Near X =  0.72431460      -1.2516460      0.13437970    , d:   0.0000000      -1.7846043       1.3300624
 i,j,k,ie:    1    1    4           9
 Near X = -0.16563971E-06  -1.4036076       0.0000000    , d:  0.70237693       0.0000000       1.3300624
 i,j,k,ie:    2    1    4           9
 Near X = -0.16563971E-06  -1.4036076      0.15785898E-01, d:  0.70237693       0.0000000       1.3300624
 i,j,k,ie:    3    1    4           9
 Near X = -0.16563971E-06  -1.4036076      0.48025188E-01, d:  0.70237693       0.0000000       1.3300624
 i,j,k,ie:    4    1    4           9
 Near X = -0.16563971E-06  -1.4036076      0.86354515E-01, d:  0.70237693       0.0000000       1.3300624
 i,j,k,ie:    5    1    4           9
 Near X = -0.16563971E-06  -1.4036076      0.11859381    , d:  0.70237693       0.0000000       1.3300624
 i,j,k,ie:    6    1    4           9
 Near X = -0.16563971E-06  -1.4036076      0.13437970    , d:   1.2147690     -0.70237663       1.3300624
 i,j,k,ie:    6    2    4           9
 Near X =  0.84484363E-01  -1.3887875      0.13437970    , d:   0.0000000     -0.70633083       1.3300624
 i,j,k,ie:    6    3    4           9
 Near X =  0.25538938      -1.3524309      0.13437970    , d:   0.0000000     -0.71113291       1.3300624
 i,j,k,ie:    6    4    4           9
 Near X =  0.45571977      -1.2985681      0.13437970    , d:   0.0000000     -0.71112335       1.3300624
 i,j,k,ie:    6    5    4           9
 Near X =  0.62181570      -1.2443153      0.13437970    , d:   0.0000000     -0.70630519       1.3300624
 i,j,k,ie:    1    6    4           9
 Near X =  0.70234295      -1.2147688       0.0000000    , d:   0.0000000      -1.2647242       1.3300624
 i,j,k,ie:    2    6    4           9
 Near X =  0.70234295      -1.2147688      0.15785898E-01, d:   0.0000000      -1.2647242       1.3300624
 i,j,k,ie:    3    6    4           9
 Near X =  0.70234295      -1.2147688      0.48025188E-01, d:   0.0000000      -1.2647242       1.3300624
 i,j,k,ie:    4    6    4           9
 Near X =  0.70234295      -1.2147688      0.86354515E-01, d:   0.0000000      -1.2647242       1.3300624
 i,j,k,ie:    5    6    4           9
 Near X =  0.70234295      -1.2147688      0.11859381    , d:   0.0000000      -1.2647242       1.3300624
 i,j,k,ie:    6    6    4           9
 Near X =  0.70234295      -1.2147688      0.13437970    , d:   0.0000000      -1.6762186       1.3300624
 i,j,k,ie:    1    1    5           9
 Near X = -0.16139079E-06  -1.3676209       0.0000000    , d:  0.68386921       0.0000000       1.3300624
 i,j,k,ie:    2    1    5           9
 Near X = -0.16139079E-06  -1.3676209      0.15785898E-01, d:  0.68386921       0.0000000       1.3300624
 i,j,k,ie:    3    1    5           9
 Near X = -0.16139079E-06  -1.3676209      0.48025188E-01, d:  0.68386921       0.0000000       1.3300624
 i,j,k,ie:    4    1    5           9
 Near X = -0.16139079E-06  -1.3676209      0.86354515E-01, d:  0.68386921       0.0000000       1.3300624
 i,j,k,ie:    5    1    5           9
 Near X = -0.16139079E-06  -1.3676209      0.11859381    , d:  0.68386921       0.0000000       1.3300624
 i,j,k,ie:    6    1    5           9
 Near X = -0.16139079E-06  -1.3676209      0.13437970    , d:   1.1837511     -0.68386892       1.3300624
 i,j,k,ie:    6    2    5           9
 Near X =  0.80985142E-01  -1.3484415      0.13437970    , d:   0.0000000     -0.68516921       1.3300624
 i,j,k,ie:    6    3    5           9
 Near X =  0.24584226      -1.3072702      0.13437970    , d:   0.0000000     -0.68674875       1.3300624
 i,j,k,ie:    6    4    5           9
 Near X =  0.44090139      -1.2548247      0.13437970    , d:   0.0000000     -0.68674691       1.3300624
 i,j,k,ie:    6    5    5           9
 Near X =  0.60417776      -1.2077708      0.13437970    , d:   0.0000000     -0.68516427       1.3300624
 i,j,k,ie:    1    6    5           9
 Near X =  0.68386231      -1.1837509       0.0000000    , d:   0.0000000      -1.2042710       1.3300624
 i,j,k,ie:    2    6    5           9
 Near X =  0.68386231      -1.1837509      0.15785898E-01, d:   0.0000000      -1.2042710       1.3300624
 i,j,k,ie:    3    6    5           9
 Near X =  0.68386231      -1.1837509      0.48025188E-01, d:   0.0000000      -1.2042710       1.3300624
 i,j,k,ie:    4    6    5           9
 Near X =  0.68386231      -1.1837509      0.86354515E-01, d:   0.0000000      -1.2042710       1.3300624
 i,j,k,ie:    5    6    5           9
 Near X =  0.68386231      -1.1837509      0.11859381    , d:   0.0000000      -1.2042710       1.3300624
 i,j,k,ie:    6    6    5           9
 Near X =  0.68386231      -1.1837509      0.13437970    , d:   0.0000000      -1.5850541       1.3300624
 i,j,k,ie:    1    1    6           9
 Near X = -0.15931032E-06  -1.3500000       0.0000000    , d:  0.75195073     -0.17710317E-07   1.3300624
 i,j,k,ie:    2    1    6           9
 Near X = -0.15931032E-06  -1.3500000      0.15785898E-01, d:  0.75195073     -0.17710317E-07   1.3300624
 i,j,k,ie:    3    1    6           9
 Near X = -0.15931032E-06  -1.3500000      0.48025188E-01, d:  0.75195073     -0.17710317E-07   1.3300624
 i,j,k,ie:    4    1    6           9
 Near X = -0.15931032E-06  -1.3500000      0.86354515E-01, d:  0.75195073     -0.17710317E-07   1.3300624
 i,j,k,ie:    5    1    6           9
 Near X = -0.15931032E-06  -1.3500000      0.11859381    , d:  0.75195073     -0.17710317E-07   1.3300624
 i,j,k,ie:    6    1    6           9
 Near X = -0.15931032E-06  -1.3500000      0.13437970    , d:   1.2978519     -0.75195045       1.3300624
 i,j,k,ie:    1    2    6           9
 Near X =  0.79271756E-01  -1.3286862       0.0000000    , d:  0.14585443E-01   0.0000000       1.3300624
 i,j,k,ie:    2    2    6           9
 Near X =  0.79271756E-01  -1.3286862      0.15785898E-01, d:  0.14585443E-01   0.0000000       1.3300624
 i,j,k,ie:    3    2    6           9
 Near X =  0.79271756E-01  -1.3286862      0.48025188E-01, d:  0.14585443E-01   0.0000000       1.3300624
 i,j,k,ie:    4    2    6           9
 Near X =  0.79271756E-01  -1.3286862      0.86354515E-01, d:  0.14585443E-01   0.0000000       1.3300624
 i,j,k,ie:    5    2    6           9
 Near X =  0.79271756E-01  -1.3286862      0.11859381    , d:  0.14585443E-01   0.0000000       1.3300624
 i,j,k,ie:    6    2    6           9
 Near X =  0.79271756E-01  -1.3286862      0.13437970    , d:  0.14585443E-01 -0.74842783       1.3300624
 i,j,k,ie:    1    3    6           9
 Near X =  0.24116754      -1.2851573       0.0000000    , d:  0.39794265E-01   0.0000000       1.3300624
 i,j,k,ie:    2    3    6           9
 Near X =  0.24116754      -1.2851573      0.15785898E-01, d:  0.39794265E-01   0.0000000       1.3300624
 i,j,k,ie:    3    3    6           9
 Near X =  0.24116754      -1.2851573      0.48025188E-01, d:  0.39794265E-01   0.0000000       1.3300624
 i,j,k,ie:    4    3    6           9
 Near X =  0.24116754      -1.2851573      0.86354515E-01, d:  0.39794265E-01   0.0000000       1.3300624
 i,j,k,ie:    5    3    6           9
 Near X =  0.24116754      -1.2851573      0.11859381    , d:  0.39794265E-01   0.0000000       1.3300624
 i,j,k,ie:    6    3    6           9
 Near X =  0.24116754      -1.2851573      0.13437970    , d:  0.39794265E-01 -0.73665283       1.3300624
 i,j,k,ie:    1    4    6           9
 Near X =  0.43364560      -1.2334058       0.0000000    , d:  0.61765923E-01   0.0000000       1.3300624
 i,j,k,ie:    2    4    6           9
 Near X =  0.43364560      -1.2334058      0.15785898E-01, d:  0.61765923E-01   0.0000000       1.3300624
 i,j,k,ie:    3    4    6           9
 Near X =  0.43364560      -1.2334058      0.48025188E-01, d:  0.61765923E-01   0.0000000       1.3300624
 i,j,k,ie:    4    4    6           9
 Near X =  0.43364560      -1.2334058      0.86354515E-01, d:  0.61765923E-01   0.0000000       1.3300624
 i,j,k,ie:    5    4    6           9
 Near X =  0.43364560      -1.2334058      0.11859381    , d:  0.61765923E-01   0.0000000       1.3300624
 i,j,k,ie:    6    4    6           9
 Near X =  0.43364560      -1.2334058      0.13437970    , d:  0.61765923E-01 -0.71465093       1.3300624
 i,j,k,ie:    1    5    6           9
 Near X =  0.59554139      -1.1898769       0.0000000    , d:  0.73518391E-01   0.0000000       1.3300624
 i,j,k,ie:    2    5    6           9
 Near X =  0.59554139      -1.1898769      0.15785898E-01, d:  0.73518391E-01   0.0000000       1.3300624
 i,j,k,ie:    3    5    6           9
 Near X =  0.59554139      -1.1898769      0.48025188E-01, d:  0.73518391E-01   0.0000000       1.3300624
 i,j,k,ie:    4    5    6           9
 Near X =  0.59554139      -1.1898769      0.86354515E-01, d:  0.73518391E-01   0.0000000       1.3300624
 i,j,k,ie:    5    5    6           9
 Near X =  0.59554139      -1.1898769      0.11859381    , d:  0.73518391E-01   0.0000000       1.3300624
 i,j,k,ie:    6    5    6           9
 Near X =  0.59554139      -1.1898769      0.13437970    , d:  0.73518391E-01 -0.68941378       1.3300624
 i,j,k,ie:    1    6    6           9
 Near X =  0.67481330      -1.1685631       0.0000000    , d:  0.77030946E-01  -1.3496201       1.3300624
 i,j,k,ie:    2    6    6           9
 Near X =  0.67481330      -1.1685631      0.15785898E-01, d:  0.77030946E-01  -1.3496201       1.3300624
 i,j,k,ie:    3    6    6           9
 Near X =  0.67481330      -1.1685631      0.48025188E-01, d:  0.77030946E-01  -1.3496201       1.3300624
 i,j,k,ie:    4    6    6           9
 Near X =  0.67481330      -1.1685631      0.86354515E-01, d:  0.77030946E-01  -1.3496201       1.3300624
 i,j,k,ie:    5    6    6           9
 Near X =  0.67481330      -1.1685631      0.11859381    , d:  0.77030946E-01  -1.3496201       1.3300624
 i,j,k,ie:    6    6    6           9
 Near X =  0.67481330      -1.1685631      0.13437970    , d:  0.77030946E-01  -1.8433764       1.3300624
 i,j,k,ie:    1    1    1          10
 Near X = -0.75195061      -1.2977934       0.0000000    , d:   2.0498024       0.0000000       1.3298746
 i,j,k,ie:    2    1    1          10
 Near X = -0.75195061      -1.2977934      0.15785898E-01, d:   2.0498024       0.0000000       1.3298746
 i,j,k,ie:    3    1    1          10
 Near X = -0.75195061      -1.2977934      0.48025188E-01, d:   2.0498024       0.0000000       1.3298746
 i,j,k,ie:    4    1    1          10
 Near X = -0.75195061      -1.2977934      0.86354515E-01, d:   2.0498024       0.0000000       1.3298746
 i,j,k,ie:    5    1    1          10
 Near X = -0.75195061      -1.2977934      0.11859381    , d:   2.0498024       0.0000000       1.3298746
 i,j,k,ie:    6    1    1          10
 Near X = -0.75195061      -1.2977934      0.13437970    , d:   2.2519506     -0.54590114       1.3298746
 i,j,k,ie:    1    2    1          10
 Near X = -0.66915607      -1.3421555       0.0000000    , d:  0.76301327       0.0000000       1.3298746
 i,j,k,ie:    6    2    1          10
 Near X = -0.66915607      -1.3421555      0.13437970    , d:   0.0000000     -0.57941397       1.3298746
 i,j,k,ie:    1    3    1          10
 Near X = -0.49548529      -1.4157117       0.0000000    , d:  0.77644709       0.0000000       1.3298746
 i,j,k,ie:    6    3    1          10
 Near X = -0.49548529      -1.4157117      0.13437970    , d:   0.0000000     -0.64015888       1.3298746
 i,j,k,ie:    1    4    1          10
 Near X = -0.28100533      -1.4733874       0.0000000    , d:  0.77641686       0.0000000       1.3298746
 i,j,k,ie:    6    4    1          10
 Near X = -0.28100533      -1.4733874      0.13437970    , d:   0.0000000     -0.69893063       1.3298746
 i,j,k,ie:    1    5    1          10
 Near X = -0.93872392E-01  -1.4968547       0.0000000    , d:  0.76293217       0.0000000       1.3298746
 i,j,k,ie:    6    5    1          10
 Near X = -0.93872392E-01  -1.4968547      0.13437970    , d:   0.0000000     -0.73705308       1.3298746
 i,j,k,ie:    1    6    1          10
 Near X = -0.17702063E-06  -1.5000000       0.0000000    , d:  0.75184442      -1.1685629       1.3298746
 i,j,k,ie:    2    6    1          10
 Near X = -0.17702063E-06  -1.5000000      0.15785898E-01, d:   0.0000000      -1.1685629       1.3298746
 i,j,k,ie:    3    6    1          10
 Near X = -0.17702063E-06  -1.5000000      0.48025188E-01, d:   0.0000000      -1.1685629       1.3298746
 i,j,k,ie:    4    6    1          10
 Near X = -0.17702063E-06  -1.5000000      0.86354515E-01, d:   0.0000000      -1.1685629       1.3298746
 i,j,k,ie:    5    6    1          10
 Near X = -0.17702063E-06  -1.5000000      0.11859381    , d:   0.0000000      -1.1685629       1.3298746
 i,j,k,ie:    6    6    1          10
 Near X = -0.17702063E-06  -1.5000000      0.13437970    , d:   0.0000000      -1.3499998       1.3298746
 i,j,k,ie:    1    1    2          10
 Near X = -0.74288835      -1.2826094       0.0000000    , d:   2.0255523       0.0000000       1.3298746
 i,j,k,ie:    2    1    2          10
 Near X = -0.74288835      -1.2826094      0.15785898E-01, d:   2.0255523       0.0000000       1.3298746
 i,j,k,ie:    3    1    2          10
 Near X = -0.74288835      -1.2826094      0.48025188E-01, d:   2.0255523       0.0000000       1.3298746
 i,j,k,ie:    4    1    2          10
 Near X = -0.74288835      -1.2826094      0.86354515E-01, d:   2.0255523       0.0000000       1.3298746
 i,j,k,ie:    5    1    2          10
 Near X = -0.74288835      -1.2826094      0.11859381    , d:   2.0255523       0.0000000       1.3298746
 i,j,k,ie:    6    1    2          10
 Near X = -0.74288835      -1.2826094      0.13437970    , d:   2.2252675     -0.53977556       1.3298746
 i,j,k,ie:    1    2    2          10
 Near X = -0.66050772      -1.3242644       0.0000000    , d:  0.75265153       0.0000000       1.3298746
 i,j,k,ie:    6    2    2          10
 Near X = -0.66050772      -1.3242644      0.13437970    , d:   0.0000000     -0.57185001       1.3298746
 i,j,k,ie:    1    3    2          10
 Near X = -0.48822036      -1.3942939       0.0000000    , d:  0.76450744       0.0000000       1.3298746
 i,j,k,ie:    6    3    2          10
 Near X = -0.48822036      -1.3942939      0.13437970    , d:   0.0000000     -0.63056161       1.3298746
 i,j,k,ie:    1    4    2          10
 Near X = -0.27632524      -1.4512745       0.0000000    , d:  0.76448098       0.0000000       1.3298746
 i,j,k,ie:    6    4    2          10
 Near X = -0.27632524      -1.4512745      0.13437970    , d:   0.0000000     -0.68849573       1.3298746
 i,j,k,ie:    1    5    2          10
 Near X = -0.92157165E-01  -1.4770992       0.0000000    , d:  0.75258056       0.0000000       1.3298746
 i,j,k,ie:    6    5    2          10
 Near X = -0.92157165E-01  -1.4770992      0.13437970    , d:   0.0000000     -0.72724239       1.3298746
 i,j,k,ie:    1    6    2          10
 Near X = -0.17494016E-06  -1.4823791       0.0000000    , d:  0.74279542      -1.1329734       1.3298746
 i,j,k,ie:    2    6    2          10
 Near X = -0.17494016E-06  -1.4823791      0.15785898E-01, d:   0.0000000      -1.1329734       1.3298746
 i,j,k,ie:    3    6    2          10
 Near X = -0.17494016E-06  -1.4823791      0.48025188E-01, d:   0.0000000      -1.1329734       1.3298746
 i,j,k,ie:    4    6    2          10
 Near X = -0.17494016E-06  -1.4823791      0.86354515E-01, d:   0.0000000      -1.1329734       1.3298746
 i,j,k,ie:    5    6    2          10
 Near X = -0.17494016E-06  -1.4823791      0.11859381    , d:   0.0000000      -1.1329734       1.3298746
 i,j,k,ie:    6    6    2          10
 Near X = -0.17494016E-06  -1.4823791      0.13437970    , d:   0.0000000      -1.3088845       1.3298746
 i,j,k,ie:    1    1    3          10
 Near X = -0.72438064      -1.2515996       0.0000000    , d:   1.9760267       0.0000000       1.3298746
 i,j,k,ie:    2    1    3          10
 Near X = -0.72438064      -1.2515996      0.15785898E-01, d:   1.9760267       0.0000000       1.3298746
 i,j,k,ie:    3    1    3          10
 Near X = -0.72438064      -1.2515996      0.48025188E-01, d:   1.9760267       0.0000000       1.3298746
 i,j,k,ie:    4    1    3          10
 Near X = -0.72438064      -1.2515996      0.86354515E-01, d:   1.9760267       0.0000000       1.3298746
 i,j,k,ie:    5    1    3          10
 Near X = -0.72438064      -1.2515996      0.11859381    , d:   1.9760267       0.0000000       1.3298746
 i,j,k,ie:    6    1    3          10
 Near X = -0.72438064      -1.2515996      0.13437970    , d:   2.1707730     -0.52726538       1.3298746
 i,j,k,ie:    1    2    3          10
 Near X = -0.64284532      -1.2877256       0.0000000    , d:  0.73148991       0.0000000       1.3298746
 i,j,k,ie:    6    2    3          10
 Near X = -0.64284532      -1.2877256      0.13437970    , d:   0.0000000     -0.55640225       1.3298746
 i,j,k,ie:    1    3    3          10
 Near X = -0.47338332      -1.3505527       0.0000000    , d:  0.74012327       0.0000000       1.3298746
 i,j,k,ie:    6    3    3          10
 Near X = -0.47338332      -1.3505527      0.13437970    , d:   0.0000000     -0.61096128       1.3298746
 i,j,k,ie:    1    4    3          10
 Near X = -0.26676718      -1.4061137       0.0000000    , d:  0.74010454       0.0000000       1.3298746
 i,j,k,ie:    6    4    3          10
 Near X = -0.26676718      -1.4061137      0.13437970    , d:   0.0000000     -0.66718471       1.3298746
 i,j,k,ie:    1    5    3          10
 Near X = -0.88654183E-01  -1.4367529       0.0000000    , d:  0.73143965       0.0000000       1.3298746
 i,j,k,ie:    6    5    3          10
 Near X = -0.88654183E-01  -1.4367529      0.13437970    , d:   0.0000000     -0.70720619       1.3298746
 i,j,k,ie:    1    6    3          10
 Near X = -0.17069125E-06  -1.4463924       0.0000000    , d:  0.72431477      -1.0602895       1.3298746
 i,j,k,ie:    2    6    3          10
 Near X = -0.17069125E-06  -1.4463924      0.15785898E-01, d:   0.0000000      -1.0602895       1.3298746
 i,j,k,ie:    3    6    3          10
 Near X = -0.17069125E-06  -1.4463924      0.48025188E-01, d:   0.0000000      -1.0602895       1.3298746
 i,j,k,ie:    4    6    3          10
 Near X = -0.17069125E-06  -1.4463924      0.86354515E-01, d:   0.0000000      -1.0602895       1.3298746
 i,j,k,ie:    5    6    3          10
 Near X = -0.17069125E-06  -1.4463924      0.11859381    , d:   0.0000000      -1.0602895       1.3298746
 i,j,k,ie:    6    6    3          10
 Near X = -0.17069125E-06  -1.4463924      0.13437970    , d:   0.0000000      -1.2249154       1.3298746
 i,j,k,ie:    1    1    4          10
 Near X = -0.70237680      -1.2147319       0.0000000    , d:   1.9171456       0.0000000       1.3298746
 i,j,k,ie:    2    1    4          10
 Near X = -0.70237680      -1.2147319      0.15785898E-01, d:   1.9171456       0.0000000       1.3298746
 i,j,k,ie:    3    1    4          10
 Near X = -0.70237680      -1.2147319      0.48025188E-01, d:   1.9171456       0.0000000       1.3298746
 i,j,k,ie:    4    1    4          10
 Near X = -0.70237680      -1.2147319      0.86354515E-01, d:   1.9171456       0.0000000       1.3298746
 i,j,k,ie:    5    1    4          10
 Near X = -0.70237680      -1.2147319      0.11859381    , d:   1.9171456       0.0000000       1.3298746
 i,j,k,ie:    6    1    4          10
 Near X = -0.70237680      -1.2147319      0.13437970    , d:   2.1059845     -0.51239201       1.3298746
 i,j,k,ie:    1    2    4          10
 Near X = -0.62184647      -1.2442847       0.0000000    , d:  0.70633083       0.0000000       1.3298746
 i,j,k,ie:    6    2    4          10
 Near X = -0.62184647      -1.2442847      0.13437970    , d:   0.0000000     -0.53803639       1.3298746
 i,j,k,ie:    1    3    4          10
 Near X = -0.45574353      -1.2985487       0.0000000    , d:  0.71113291       0.0000000       1.3298746
 i,j,k,ie:    6    3    4          10
 Near X = -0.45574353      -1.2985487      0.13437970    , d:   0.0000000     -0.58765842       1.3298746
 i,j,k,ie:    1    4    4          10
 Near X = -0.25540358      -1.3524220       0.0000000    , d:  0.71112335       0.0000000       1.3298746
 i,j,k,ie:    6    4    4          10
 Near X = -0.25540358      -1.3524220      0.13437970    , d:   0.0000000     -0.64184802       1.3298746
 i,j,k,ie:    1    5    4          10
 Near X = -0.84489485E-01  -1.3887851       0.0000000    , d:  0.70630519       0.0000000       1.3298746
 i,j,k,ie:    6    5    4          10
 Near X = -0.84489485E-01  -1.3887851      0.13437970    , d:   0.0000000     -0.68338513       1.3298746
 i,j,k,ie:    1    6    4          10
 Near X = -0.16563971E-06  -1.4036076       0.0000000    , d:  0.70234311     -0.97387552       1.3298746
 i,j,k,ie:    2    6    4          10
 Near X = -0.16563971E-06  -1.4036076      0.15785898E-01, d:   0.0000000     -0.97387552       1.3298746
 i,j,k,ie:    3    6    4          10
 Near X = -0.16563971E-06  -1.4036076      0.48025188E-01, d:   0.0000000     -0.97387552       1.3298746
 i,j,k,ie:    4    6    4          10
 Near X = -0.16563971E-06  -1.4036076      0.86354515E-01, d:   0.0000000     -0.97387552       1.3298746
 i,j,k,ie:    5    6    4          10
 Near X = -0.16563971E-06  -1.4036076      0.11859381    , d:   0.0000000     -0.97387552       1.3298746
 i,j,k,ie:    6    6    4          10
 Near X = -0.16563971E-06  -1.4036076      0.13437970    , d:   0.0000000      -1.1250843       1.3298746
 i,j,k,ie:    1    1    5          10
 Near X = -0.68386909      -1.1837220       0.0000000    , d:   1.8676200       0.0000000       1.3298746
 i,j,k,ie:    2    1    5          10
 Near X = -0.68386909      -1.1837220      0.15785898E-01, d:   1.8676200       0.0000000       1.3298746
 i,j,k,ie:    3    1    5          10
 Near X = -0.68386909      -1.1837220      0.48025188E-01, d:   1.8676200       0.0000000       1.3298746
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    4    1    5          10
 Near X = -0.68386909      -1.1837220      0.86354515E-01, d:   1.8676200       0.0000000       1.3298746
 i,j,k,ie:    5    1    5          10
 Near X = -0.68386909      -1.1837220      0.11859381    , d:   1.8676200       0.0000000       1.3298746
 i,j,k,ie:    6    1    5          10
 Near X = -0.68386909      -1.1837220      0.13437970    , d:   2.0514900     -0.49988183       1.3298746
 i,j,k,ie:    1    2    5          10
 Near X = -0.60418407      -1.2077459       0.0000000    , d:  0.68516921       0.0000000       1.3298746
 i,j,k,ie:    6    2    5          10
 Near X = -0.60418407      -1.2077459      0.13437970    , d:   0.0000000     -0.52258863       1.3298746
 i,j,k,ie:    1    3    5          10
 Near X = -0.44090648      -1.2548075       0.0000000    , d:  0.68674875       0.0000000       1.3298746
 i,j,k,ie:    6    3    5          10
 Near X = -0.44090648      -1.2548075      0.13437970    , d:   0.0000000     -0.56805808       1.3298746
 i,j,k,ie:    1    4    5          10
 Near X = -0.24584551      -1.3072613       0.0000000    , d:  0.68674691       0.0000000       1.3298746
 i,j,k,ie:    6    4    5          10
 Near X = -0.24584551      -1.3072613      0.13437970    , d:   0.0000000     -0.62053700       1.3298746
 i,j,k,ie:    1    5    5          10
 Near X = -0.80986503E-01  -1.3484388       0.0000000    , d:  0.68516427       0.0000000       1.3298746
 i,j,k,ie:    6    5    5          10
 Near X = -0.80986503E-01  -1.3484388      0.13437970    , d:   0.0000000     -0.66334893       1.3298746
 i,j,k,ie:    1    6    5          10
 Near X = -0.16139079E-06  -1.3676209       0.0000000    , d:  0.68386247     -0.90119162       1.3298746
 i,j,k,ie:    2    6    5          10
 Near X = -0.16139079E-06  -1.3676209      0.15785898E-01, d:   0.0000000     -0.90119162       1.3298746
 i,j,k,ie:    3    6    5          10
 Near X = -0.16139079E-06  -1.3676209      0.48025188E-01, d:   0.0000000     -0.90119162       1.3298746
 i,j,k,ie:    4    6    5          10
 Near X = -0.16139079E-06  -1.3676209      0.86354515E-01, d:   0.0000000     -0.90119162       1.3298746
 i,j,k,ie:    5    6    5          10
 Near X = -0.16139079E-06  -1.3676209      0.11859381    , d:   0.0000000     -0.90119162       1.3298746
 i,j,k,ie:    6    6    5          10
 Near X = -0.16139079E-06  -1.3676209      0.13437970    , d:   0.0000000      -1.0411152       1.3298746
 i,j,k,ie:    1    1    6          10
 Near X = -0.67480683      -1.1685381       0.0000000    , d:   1.9726586     -0.77143785E-01   1.3298746
 i,j,k,ie:    2    1    6          10
 Near X = -0.67480683      -1.1685381      0.15785898E-01, d:   1.9726586     -0.77143785E-01   1.3298746
 i,j,k,ie:    3    1    6          10
 Near X = -0.67480683      -1.1685381      0.48025188E-01, d:   1.9726586     -0.77143785E-01   1.3298746
 i,j,k,ie:    4    1    6          10
 Near X = -0.67480683      -1.1685381      0.86354515E-01, d:   1.9726586     -0.77143785E-01   1.3298746
 i,j,k,ie:    5    1    6          10
 Near X = -0.67480683      -1.1685381      0.11859381    , d:   1.9726586     -0.77143785E-01   1.3298746
 i,j,k,ie:    6    1    6          10
 Near X = -0.67480683      -1.1685381      0.13437970    , d:   2.1748068     -0.62304493       1.3298746
 i,j,k,ie:    1    2    6          10
 Near X = -0.59553571      -1.1898548       0.0000000    , d:  0.68939291     -0.73620366E-01   1.3298746
 i,j,k,ie:    2    2    6          10
 Near X = -0.59553571      -1.1898548      0.15785898E-01, d:   0.0000000     -0.73620366E-01   1.3298746
 i,j,k,ie:    3    2    6          10
 Near X = -0.59553571      -1.1898548      0.48025188E-01, d:   0.0000000     -0.73620366E-01   1.3298746
 i,j,k,ie:    4    2    6          10
 Near X = -0.59553571      -1.1898548      0.86354515E-01, d:   0.0000000     -0.73620366E-01   1.3298746
 i,j,k,ie:    5    2    6          10
 Near X = -0.59553571      -1.1898548      0.11859381    , d:   0.0000000     -0.73620366E-01   1.3298746
 i,j,k,ie:    6    2    6          10
 Near X = -0.59553571      -1.1898548      0.13437970    , d:   0.0000000     -0.65303434       1.3298746
 i,j,k,ie:    1    3    6          10
 Near X = -0.43364156      -1.2333897       0.0000000    , d:  0.71460336     -0.61843735E-01   1.3298746
 i,j,k,ie:    2    3    6          10
 Near X = -0.43364156      -1.2333897      0.15785898E-01, d:   0.0000000     -0.61843735E-01   1.3298746
 i,j,k,ie:    3    3    6          10
 Near X = -0.43364156      -1.2333897      0.48025188E-01, d:   0.0000000     -0.61843735E-01   1.3298746
 i,j,k,ie:    4    3    6          10
 Near X = -0.43364156      -1.2333897      0.86354515E-01, d:   0.0000000     -0.61843735E-01   1.3298746
 i,j,k,ie:    5    3    6          10
 Near X = -0.43364156      -1.2333897      0.11859381    , d:   0.0000000     -0.61843735E-01   1.3298746
 i,j,k,ie:    6    3    6          10
 Near X = -0.43364156      -1.2333897      0.13437970    , d:   0.0000000     -0.70200261       1.3298746
 i,j,k,ie:    1    4    6          10
 Near X = -0.24116543      -1.2851484       0.0000000    , d:  0.73657696     -0.39839901E-01   1.3298746
 i,j,k,ie:    2    4    6          10
 Near X = -0.24116543      -1.2851484      0.15785898E-01, d:   0.0000000     -0.39839901E-01   1.3298746
 i,j,k,ie:    3    4    6          10
 Near X = -0.24116543      -1.2851484      0.48025188E-01, d:   0.0000000     -0.39839901E-01   1.3298746
 i,j,k,ie:    4    4    6          10
 Near X = -0.24116543      -1.2851484      0.86354515E-01, d:   0.0000000     -0.39839901E-01   1.3298746
 i,j,k,ie:    5    4    6          10
 Near X = -0.24116543      -1.2851484      0.11859381    , d:   0.0000000     -0.39839901E-01   1.3298746
 i,j,k,ie:    6    4    6          10
 Near X = -0.24116543      -1.2851484      0.13437970    , d:   0.0000000     -0.73877053       1.3298746
 i,j,k,ie:    1    5    6          10
 Near X = -0.79271276E-01  -1.3286833       0.0000000    , d:  0.74833105     -0.14601116E-01   1.3298746
 i,j,k,ie:    2    5    6          10
 Near X = -0.79271276E-01  -1.3286833      0.15785898E-01, d:   0.0000000     -0.14601116E-01   1.3298746
 i,j,k,ie:    3    5    6          10
 Near X = -0.79271276E-01  -1.3286833      0.48025188E-01, d:   0.0000000     -0.14601116E-01   1.3298746
 i,j,k,ie:    4    5    6          10
 Near X = -0.79271276E-01  -1.3286833      0.86354515E-01, d:   0.0000000     -0.14601116E-01   1.3298746
 i,j,k,ie:    5    5    6          10
 Near X = -0.79271276E-01  -1.3286833      0.11859381    , d:   0.0000000     -0.14601116E-01   1.3298746
 i,j,k,ie:    6    5    6          10
 Near X = -0.79271276E-01  -1.3286833      0.13437970    , d:   0.0000000     -0.75165419       1.3298746
 i,j,k,ie:    1    6    6          10
 Near X = -0.15931032E-06  -1.3500000       0.0000000    , d:  0.75184441      -1.1685629       1.3298746
 i,j,k,ie:    2    6    6          10
 Near X = -0.15931032E-06  -1.3500000      0.15785898E-01, d:   0.0000000      -1.1685629       1.3298746
 i,j,k,ie:    3    6    6          10
 Near X = -0.15931032E-06  -1.3500000      0.48025188E-01, d:   0.0000000      -1.1685629       1.3298746
 i,j,k,ie:    4    6    6          10
 Near X = -0.15931032E-06  -1.3500000      0.86354515E-01, d:   0.0000000      -1.1685629       1.3298746
 i,j,k,ie:    5    6    6          10
 Near X = -0.15931032E-06  -1.3500000      0.11859381    , d:   0.0000000      -1.1685629       1.3298746
 i,j,k,ie:    6    6    6          10
 Near X = -0.15931032E-06  -1.3500000      0.13437970    , d:   0.0000000      -1.3499999       1.3298746
 i,j,k,ie:    1    1    1          11
 Near X =  -1.2978518     -0.75184434       0.0000000    , d:   2.7978518       0.0000000      0.77050402
 i,j,k,ie:    2    1    1          11
 Near X =  -1.2978518     -0.75184434      0.15785898E-01, d:   2.7978518       0.0000000      0.77050402
 i,j,k,ie:    3    1    1          11
 Near X =  -1.2978518     -0.75184434      0.48025188E-01, d:   2.7978518       0.0000000      0.77050402
 i,j,k,ie:    4    1    1          11
 Near X =  -1.2978518     -0.75184434      0.86354515E-01, d:   2.7978518       0.0000000      0.77050402
 i,j,k,ie:    5    1    1          11
 Near X =  -1.2978518     -0.75184434      0.11859381    , d:   2.7978518       0.0000000      0.77050402
 i,j,k,ie:    6    1    1          11
 Near X =  -1.2978518     -0.75184434      0.13437970    , d:   2.7978518     -0.20214825      0.77050402
 i,j,k,ie:    1    2    1          11
 Near X =  -1.2485700     -0.83082363       0.0000000    , d:  0.57941397       0.0000000      0.77050402
 i,j,k,ie:    6    2    1          11
 Near X =  -1.2485700     -0.83082363      0.13437970    , d:   0.0000000     -0.24828603      0.77050402
 i,j,k,ie:    1    3    1          11
 Near X =  -1.1356442     -0.97984416       0.0000000    , d:  0.64015888       0.0000000      0.77050402
 i,j,k,ie:    6    3    1          11
 Near X =  -1.1356442     -0.97984416      0.13437970    , d:   0.0000000     -0.33775181      0.77050402
 i,j,k,ie:    1    4    1          11
 Near X = -0.97993596      -1.1355660       0.0000000    , d:  0.69893063       0.0000000      0.77050402
 i,j,k,ie:    6    4    1          11
 Near X = -0.97993596      -1.1355660      0.13437970    , d:   0.0000000     -0.43580097      0.77050402
 i,j,k,ie:    1    5    1          11
 Near X = -0.83092547      -1.2485048       0.0000000    , d:  0.73705308       0.0000000      0.77050402
 i,j,k,ie:    6    5    1          11
 Near X = -0.83092547      -1.2485048      0.13437970    , d:   0.0000000     -0.51127601      0.77050402
 i,j,k,ie:    1    6    1          11
 Near X = -0.75195061      -1.2977934       0.0000000    , d:  0.75195043     -0.59804941      0.77050402
 i,j,k,ie:    2    6    1          11
 Near X = -0.75195061      -1.2977934      0.15785898E-01, d:   0.0000000     -0.59804941      0.77050402
 i,j,k,ie:    3    6    1          11
 Near X = -0.75195061      -1.2977934      0.48025188E-01, d:   0.0000000     -0.59804941      0.77050402
 i,j,k,ie:    4    6    1          11
 Near X = -0.75195061      -1.2977934      0.86354515E-01, d:   0.0000000     -0.59804941      0.77050402
 i,j,k,ie:    5    6    1          11
 Near X = -0.75195061      -1.2977934      0.11859381    , d:   0.0000000     -0.59804941      0.77050402
 i,j,k,ie:    6    6    1          11
 Near X = -0.75195061      -1.2977934      0.13437970    , d:   1.9204887     -0.59804941      0.77050402
 i,j,k,ie:    1    1    2          11
 Near X =  -1.2826639     -0.74279534       0.0000000    , d:   2.7650431       0.0000000      0.77050402
 i,j,k,ie:    2    1    2          11
 Near X =  -1.2826639     -0.74279534      0.15785898E-01, d:   2.7650431       0.0000000      0.77050402
 i,j,k,ie:    3    1    2          11
 Near X =  -1.2826639     -0.74279534      0.48025188E-01, d:   2.7650431       0.0000000      0.77050402
 i,j,k,ie:    4    1    2          11
 Near X =  -1.2826639     -0.74279534      0.86354515E-01, d:   2.7650431       0.0000000      0.77050402
 i,j,k,ie:    5    1    2          11
 Near X =  -1.2826639     -0.74279534      0.11859381    , d:   2.7650431       0.0000000      0.77050402
 i,j,k,ie:    6    1    2          11
 Near X =  -1.2826639     -0.74279534      0.13437970    , d:   2.7650431     -0.19971524      0.77050402
 i,j,k,ie:    1    2    2          11
 Near X =  -1.2323577     -0.81931002       0.0000000    , d:  0.57185001       0.0000000      0.77050402
 i,j,k,ie:    6    2    2          11
 Near X =  -1.2323577     -0.81931002      0.13437970    , d:   0.0000000     -0.24474304      0.77050402
 i,j,k,ie:    1    3    2          11
 Near X =  -1.1187820     -0.96473941       0.0000000    , d:  0.63056161       0.0000000      0.77050402
 i,j,k,ie:    6    3    2          11
 Near X =  -1.1187820     -0.96473941      0.13437970    , d:   0.0000000     -0.33250117      0.77050402
 i,j,k,ie:    1    4    2          11
 Near X = -0.96482098      -1.1187114       0.0000000    , d:  0.68849573       0.0000000      0.77050402
 i,j,k,ie:    6    4    2          11
 Near X = -0.96482098      -1.1187114      0.13437970    , d:   0.0000000     -0.42949709      0.77050402
 i,j,k,ie:    1    5    2          11
 Near X = -0.81939956      -1.2322977       0.0000000    , d:  0.72724239       0.0000000      0.77050402
 i,j,k,ie:    6    5    2          11
 Near X = -0.81939956      -1.2322977      0.13437970    , d:   0.0000000     -0.50490800      0.77050402
 i,j,k,ie:    1    6    2          11
 Near X = -0.74288835      -1.2826094       0.0000000    , d:  0.74288817     -0.56599635      0.77050402
 i,j,k,ie:    2    6    2          11
 Near X = -0.74288835      -1.2826094      0.15785898E-01, d:   0.0000000     -0.56599635      0.77050402
 i,j,k,ie:    3    6    2          11
 Near X = -0.74288835      -1.2826094      0.48025188E-01, d:   0.0000000     -0.56599635      0.77050402
 i,j,k,ie:    4    6    2          11
 Near X = -0.74288835      -1.2826094      0.86354515E-01, d:   0.0000000     -0.56599635      0.77050402
 i,j,k,ie:    5    6    2          11
 Near X = -0.74288835      -1.2826094      0.11859381    , d:   0.0000000     -0.56599635      0.77050402
 i,j,k,ie:    6    6    2          11
 Near X = -0.74288835      -1.2826094      0.13437970    , d:   1.8758377     -0.56599635      0.77050402
 i,j,k,ie:    1    1    3          11
 Near X =  -1.2516460     -0.72431469       0.0000000    , d:   2.6980384       0.0000000      0.77050402
 i,j,k,ie:    2    1    3          11
 Near X =  -1.2516460     -0.72431469      0.15785898E-01, d:   2.6980384       0.0000000      0.77050402
 i,j,k,ie:    3    1    3          11
 Near X =  -1.2516460     -0.72431469      0.48025188E-01, d:   2.6980384       0.0000000      0.77050402
 i,j,k,ie:    4    1    3          11
 Near X =  -1.2516460     -0.72431469      0.86354515E-01, d:   2.6980384       0.0000000      0.77050402
 i,j,k,ie:    5    1    3          11
 Near X =  -1.2516460     -0.72431469      0.11859381    , d:   2.6980384       0.0000000      0.77050402
 i,j,k,ie:    6    1    3          11
 Near X =  -1.2516460     -0.72431469      0.13437970    , d:   2.6980384     -0.19474635      0.77050402
 i,j,k,ie:    1    2    3          11
 Near X =  -1.1992476     -0.79579596       0.0000000    , d:  0.55640225       0.0000000      0.77050402
 i,j,k,ie:    6    2    3          11
 Near X =  -1.1992476     -0.79579596      0.13437970    , d:   0.0000000     -0.23750725      0.77050402
 i,j,k,ie:    1    3    3          11
 Near X =  -1.0843446     -0.93389121       0.0000000    , d:  0.61096128       0.0000000      0.77050402
 i,j,k,ie:    6    3    3          11
 Near X =  -1.0843446     -0.93389121      0.13437970    , d:   0.0000000     -0.32177786      0.77050402
 i,j,k,ie:    1    4    3          11
 Near X = -0.93395189      -1.0842895       0.0000000    , d:  0.66718471       0.0000000      0.77050402
 i,j,k,ie:    6    4    3          11
 Near X = -0.93395189      -1.0842895      0.13437970    , d:   0.0000000     -0.41662276      0.77050402
 i,j,k,ie:    1    5    3          11
 Near X = -0.79586038      -1.1991980       0.0000000    , d:  0.70720619       0.0000000      0.77050402
 i,j,k,ie:    6    5    3          11
 Near X = -0.79586038      -1.1991980      0.13437970    , d:   0.0000000     -0.49190270      0.77050402
 i,j,k,ie:    1    6    3          11
 Near X = -0.72438064      -1.2515996       0.0000000    , d:  0.72438047     -0.50053490      0.77050402
 i,j,k,ie:    2    6    3          11
 Near X = -0.72438064      -1.2515996      0.15785898E-01, d:   0.0000000     -0.50053490      0.77050402
 i,j,k,ie:    3    6    3          11
 Near X = -0.72438064      -1.2515996      0.48025188E-01, d:   0.0000000     -0.50053490      0.77050402
 i,j,k,ie:    4    6    3          11
 Near X = -0.72438064      -1.2515996      0.86354515E-01, d:   0.0000000     -0.50053490      0.77050402
 i,j,k,ie:    5    6    3          11
 Near X = -0.72438064      -1.2515996      0.11859381    , d:   0.0000000     -0.50053490      0.77050402
 i,j,k,ie:    6    6    3          11
 Near X = -0.72438064      -1.2515996      0.13437970    , d:   1.7846476     -0.52726538      0.77050402
 i,j,k,ie:    1    1    4          11
 Near X =  -1.2147688     -0.70234304       0.0000000    , d:   2.6183765       0.0000000      0.77050402
 i,j,k,ie:    2    1    4          11
 Near X =  -1.2147688     -0.70234304      0.15785898E-01, d:   2.6183765       0.0000000      0.77050402
 i,j,k,ie:    3    1    4          11
 Near X =  -1.2147688     -0.70234304      0.48025188E-01, d:   2.6183765       0.0000000      0.77050402
 i,j,k,ie:    4    1    4          11
 Near X =  -1.2147688     -0.70234304      0.86354515E-01, d:   2.6183765       0.0000000      0.77050402
 i,j,k,ie:    5    1    4          11
 Near X =  -1.2147688     -0.70234304      0.11859381    , d:   2.6183765       0.0000000      0.77050402
 i,j,k,ie:    6    1    4          11
 Near X =  -1.2147688     -0.70234304      0.13437970    , d:   2.6183765     -0.18883884      0.77050402
 i,j,k,ie:    1    2    4          11
 Near X =  -1.1598829     -0.76784006       0.0000000    , d:  0.53803639       0.0000000      0.77050402
 i,j,k,ie:    6    2    4          11
 Near X =  -1.1598829     -0.76784006      0.13437970    , d:   0.0000000     -0.22890461      0.77050402
 i,j,k,ie:    1    3    4          11
 Near X =  -1.0434019     -0.89721576       0.0000000    , d:  0.58765842       0.0000000      0.77050402
 i,j,k,ie:    6    3    4          11
 Near X =  -1.0434019     -0.89721576      0.13437970    , d:   0.0000000     -0.30902890      0.77050402
 i,j,k,ie:    1    4    4          11
 Near X = -0.89725160      -1.0433652       0.0000000    , d:  0.64184802       0.0000000      0.77050402
 i,j,k,ie:    6    4    4          11
 Near X = -0.89725160      -1.0433652      0.13437970    , d:   0.0000000     -0.40131646      0.77050402
 i,j,k,ie:    1    5    4          11
 Near X = -0.76787462      -1.1598459       0.0000000    , d:  0.68338513       0.0000000      0.77050402
 i,j,k,ie:    6    5    4          11
 Near X = -0.76787462      -1.1598459      0.13437970    , d:   0.0000000     -0.47644069      0.77050402
 i,j,k,ie:    1    6    4          11
 Near X = -0.70237680      -1.2147319       0.0000000    , d:  0.70237663     -0.42270770      0.77050402
 i,j,k,ie:    2    6    4          11
 Near X = -0.70237680      -1.2147319      0.15785898E-01, d:   0.0000000     -0.42270770      0.77050402
 i,j,k,ie:    3    6    4          11
 Near X = -0.70237680      -1.2147319      0.48025188E-01, d:   0.0000000     -0.42270770      0.77050402
 i,j,k,ie:    4    6    4          11
 Near X = -0.70237680      -1.2147319      0.86354515E-01, d:   0.0000000     -0.42270770      0.77050402
 i,j,k,ie:    5    6    4          11
 Near X = -0.70237680      -1.2147319      0.11859381    , d:   0.0000000     -0.42270770      0.77050402
 i,j,k,ie:    6    6    4          11
 Near X = -0.70237680      -1.2147319      0.13437970    , d:   1.6762316     -0.51239201      0.77050402
 i,j,k,ie:    1    1    5          11
 Near X =  -1.1837509     -0.68386239       0.0000000    , d:   2.5513718       0.0000000      0.77050402
 i,j,k,ie:    2    1    5          11
 Near X =  -1.1837509     -0.68386239      0.15785898E-01, d:   2.5513718       0.0000000      0.77050402
 i,j,k,ie:    3    1    5          11
 Near X =  -1.1837509     -0.68386239      0.48025188E-01, d:   2.5513718       0.0000000      0.77050402
 i,j,k,ie:    4    1    5          11
 Near X =  -1.1837509     -0.68386239      0.86354515E-01, d:   2.5513718       0.0000000      0.77050402
 i,j,k,ie:    5    1    5          11
 Near X =  -1.1837509     -0.68386239      0.11859381    , d:   2.5513718       0.0000000      0.77050402
 i,j,k,ie:    6    1    5          11
 Near X =  -1.1837509     -0.68386239      0.13437970    , d:   2.5513718     -0.18386995      0.77050402
 i,j,k,ie:    1    2    5          11
 Near X =  -1.1267727     -0.74432599       0.0000000    , d:  0.52258863       0.0000000      0.77050402
 i,j,k,ie:    6    2    5          11
 Near X =  -1.1267727     -0.74432599      0.13437970    , d:   0.0000000     -0.22166882      0.77050402
 i,j,k,ie:    1    3    5          11
 Near X =  -1.0089646     -0.86636756       0.0000000    , d:  0.56805808       0.0000000      0.77050402
 i,j,k,ie:    6    3    5          11
 Near X =  -1.0089646     -0.86636756      0.13437970    , d:   0.0000000     -0.29830559      0.77050402
 i,j,k,ie:    1    4    5          11
 Near X = -0.86638251      -1.0089433       0.0000000    , d:  0.62053700       0.0000000      0.77050402
 i,j,k,ie:    6    4    5          11
 Near X = -0.86638251      -1.0089433      0.13437970    , d:   0.0000000     -0.38844214      0.77050402
 i,j,k,ie:    1    5    5          11
 Near X = -0.74433544      -1.1267462       0.0000000    , d:  0.66334893       0.0000000      0.77050402
 i,j,k,ie:    6    5    5          11
 Near X = -0.74433544      -1.1267462      0.13437970    , d:   0.0000000     -0.46343539      0.77050402
 i,j,k,ie:    1    6    5          11
 Near X = -0.68386909      -1.1837220       0.0000000    , d:  0.68386892     -0.35724624      0.77050402
 i,j,k,ie:    2    6    5          11
 Near X = -0.68386909      -1.1837220      0.15785898E-01, d:   0.0000000     -0.35724624      0.77050402
 i,j,k,ie:    3    6    5          11
 Near X = -0.68386909      -1.1837220      0.48025188E-01, d:   0.0000000     -0.35724624      0.77050402
 i,j,k,ie:    4    6    5          11
 Near X = -0.68386909      -1.1837220      0.86354515E-01, d:   0.0000000     -0.35724624      0.77050402
 i,j,k,ie:    5    6    5          11
 Near X = -0.68386909      -1.1837220      0.11859381    , d:   0.0000000     -0.35724624      0.77050402
 i,j,k,ie:    6    6    5          11
 Near X = -0.68386909      -1.1837220      0.13437970    , d:   1.5850416     -0.49988183      0.77050402
 i,j,k,ie:    1    1    6          11
 Near X =  -1.1685631     -0.67481339       0.0000000    , d:   2.6685631     -0.12928868      0.77050402
 i,j,k,ie:    2    1    6          11
 Near X =  -1.1685631     -0.67481339      0.15785898E-01, d:   2.6685631     -0.12928868      0.77050402
 i,j,k,ie:    3    1    6          11
 Near X =  -1.1685631     -0.67481339      0.48025188E-01, d:   2.6685631     -0.12928868      0.77050402
 i,j,k,ie:    4    1    6          11
 Near X =  -1.1685631     -0.67481339      0.86354515E-01, d:   2.6685631     -0.12928868      0.77050402
 i,j,k,ie:    5    1    6          11
 Near X =  -1.1685631     -0.67481339      0.11859381    , d:   2.6685631     -0.12928868      0.77050402
 i,j,k,ie:    6    1    6          11
 Near X =  -1.1685631     -0.67481339      0.13437970    , d:   2.6685631     -0.33143692      0.77050402
 i,j,k,ie:    1    2    6          11
 Near X =  -1.1105604     -0.73281238       0.0000000    , d:  0.51502467     -0.13800967      0.77050402
 i,j,k,ie:    2    2    6          11
 Near X =  -1.1105604     -0.73281238      0.15785898E-01, d:   0.0000000     -0.13800967      0.77050402
 i,j,k,ie:    3    2    6          11
 Near X =  -1.1105604     -0.73281238      0.48025188E-01, d:   0.0000000     -0.13800967      0.77050402
 i,j,k,ie:    4    2    6          11
 Near X =  -1.1105604     -0.73281238      0.86354515E-01, d:   0.0000000     -0.13800967      0.77050402
 i,j,k,ie:    5    2    6          11
 Near X =  -1.1105604     -0.73281238      0.11859381    , d:   0.0000000     -0.13800967      0.77050402
 i,j,k,ie:    6    2    6          11
 Near X =  -1.1105604     -0.73281238      0.13437970    , d:   0.0000000     -0.38629570      0.77050402
 i,j,k,ie:    1    3    6          11
 Near X = -0.99210237     -0.85126281       0.0000000    , d:  0.55846082     -0.14354180      0.77050402
 i,j,k,ie:    2    3    6          11
 Near X = -0.99210237     -0.85126281      0.15785898E-01, d:   0.0000000     -0.14354180      0.77050402
 i,j,k,ie:    3    3    6          11
 Near X = -0.99210237     -0.85126281      0.48025188E-01, d:   0.0000000     -0.14354180      0.77050402
 i,j,k,ie:    4    3    6          11
 Near X = -0.99210237     -0.85126281      0.86354515E-01, d:   0.0000000     -0.14354180      0.77050402
 i,j,k,ie:    5    3    6          11
 Near X = -0.99210237     -0.85126281      0.11859381    , d:   0.0000000     -0.14354180      0.77050402
 i,j,k,ie:    6    3    6          11
 Near X = -0.99210237     -0.85126281      0.13437970    , d:   0.0000000     -0.48129361      0.77050402
 i,j,k,ie:    1    4    6          11
 Near X = -0.85126753     -0.99208865       0.0000000    , d:  0.61010210     -0.12866843      0.77050402
 i,j,k,ie:    2    4    6          11
 Near X = -0.85126753     -0.99208865      0.15785898E-01, d:   0.0000000     -0.12866843      0.77050402
 i,j,k,ie:    3    4    6          11
 Near X = -0.85126753     -0.99208865      0.48025188E-01, d:   0.0000000     -0.12866843      0.77050402
 i,j,k,ie:    4    4    6          11
 Near X = -0.85126753     -0.99208865      0.86354515E-01, d:   0.0000000     -0.12866843      0.77050402
 i,j,k,ie:    5    4    6          11
 Near X = -0.85126753     -0.99208865      0.11859381    , d:   0.0000000     -0.12866843      0.77050402
 i,j,k,ie:    6    4    6          11
 Near X = -0.85126753     -0.99208865      0.13437970    , d:   0.0000000     -0.56446940      0.77050402
 i,j,k,ie:    1    5    6          11
 Near X = -0.73280953      -1.1105391       0.0000000    , d:  0.65353825     -0.98115942E-01  0.77050402
 i,j,k,ie:    2    5    6          11
 Near X = -0.73280953      -1.1105391      0.15785898E-01, d:   0.0000000     -0.98115942E-01  0.77050402
 i,j,k,ie:    3    5    6          11
 Near X = -0.73280953      -1.1105391      0.48025188E-01, d:   0.0000000     -0.98115942E-01  0.77050402
 i,j,k,ie:    4    5    6          11
 Near X = -0.73280953      -1.1105391      0.86354515E-01, d:   0.0000000     -0.98115942E-01  0.77050402
 i,j,k,ie:    5    5    6          11
 Near X = -0.73280953      -1.1105391      0.11859381    , d:   0.0000000     -0.98115942E-01  0.77050402
 i,j,k,ie:    6    5    6          11
 Near X = -0.73280953      -1.1105391      0.13437970    , d:   0.0000000     -0.60939195      0.77050402
 i,j,k,ie:    1    6    6          11
 Near X = -0.67480683      -1.1685381       0.0000000    , d:  0.67480667     -0.67519320      0.77050402
 i,j,k,ie:    2    6    6          11
 Near X = -0.67480683      -1.1685381      0.15785898E-01, d:   0.0000000     -0.67519320      0.77050402
 i,j,k,ie:    3    6    6          11
 Near X = -0.67480683      -1.1685381      0.48025188E-01, d:   0.0000000     -0.67519320      0.77050402
 i,j,k,ie:    4    6    6          11
 Near X = -0.67480683      -1.1685381      0.86354515E-01, d:   0.0000000     -0.67519320      0.77050402
 i,j,k,ie:    5    6    6          11
 Near X = -0.67480683      -1.1685381      0.11859381    , d:   0.0000000     -0.67519320      0.77050402
 i,j,k,ie:    6    6    6          11
 Near X = -0.67480683      -1.1685381      0.13437970    , d:   1.8433449     -0.67519320      0.77050402
 i,j,k,ie:    1    1    1          12
 Near X =  -1.5000000     -0.18369701E-15   0.0000000    , d:   3.0000000       0.0000000      0.66666667
 i,j,k,ie:    2    1    1          12
 Near X =  -1.5000000     -0.18369701E-15  0.15785898E-01, d:   2.7977933       0.0000000      0.66666667
 i,j,k,ie:    3    1    1          12
 Near X =  -1.5000000     -0.18369701E-15  0.48025188E-01, d:   2.7977933       0.0000000      0.66666667
 i,j,k,ie:    4    1    1          12
 Near X =  -1.5000000     -0.18369701E-15  0.86354515E-01, d:   2.7977933       0.0000000      0.66666667
 i,j,k,ie:    5    1    1          12
 Near X =  -1.5000000     -0.18369701E-15  0.11859381    , d:   2.7977933       0.0000000      0.66666667
 i,j,k,ie:    6    1    1          12
 Near X =  -1.5000000     -0.18369701E-15  0.13437970    , d:   2.7977933       0.0000000      0.66666667
 i,j,k,ie:    1    2    1          12
 Near X =  -1.4968561     -0.93857365E-01   0.0000000    , d:  0.24828603       0.0000000      0.66666667
 i,j,k,ie:    1    3    1          12
 Near X =  -1.4733960     -0.28096195       0.0000000    , d:  0.33775181       0.0000000      0.66666667
 i,j,k,ie:    1    4    1          12
 Near X =  -1.4157369     -0.49541165       0.0000000    , d:  0.43580097       0.0000000      0.66666667
 i,j,k,ie:    1    5    1          12
 Near X =  -1.3422015     -0.66905988       0.0000000    , d:  0.51127601       0.0000000      0.66666667
 i,j,k,ie:    1    6    1          12
 Near X =  -1.2978518     -0.75184434       0.0000000    , d:   2.4663898     -0.52148270E-01  0.66666667
 i,j,k,ie:    2    6    1          12
 Near X =  -1.2978518     -0.75184434      0.15785898E-01, d:   2.4663898       0.0000000      0.66666667
 i,j,k,ie:    3    6    1          12
 Near X =  -1.2978518     -0.75184434      0.48025188E-01, d:   2.4663898       0.0000000      0.66666667
 i,j,k,ie:    4    6    1          12
 Near X =  -1.2978518     -0.75184434      0.86354515E-01, d:   2.4663898       0.0000000      0.66666667
 i,j,k,ie:    5    6    1          12
 Near X =  -1.2978518     -0.75184434      0.11859381    , d:   2.4663898       0.0000000      0.66666667
 i,j,k,ie:    6    6    1          12
 Near X =  -1.2978518     -0.75184434      0.13437970    , d:   2.4663898       0.0000000      0.66666667
 i,j,k,ie:    1    1    2          12
 Near X =  -1.4823792     -0.20096047E-15   0.0000000    , d:   2.9647583       0.0000000      0.66666667
 i,j,k,ie:    2    1    2          12
 Near X =  -1.4823792     -0.20096047E-15  0.15785898E-01, d:   2.7649886       0.0000000      0.66666667
 i,j,k,ie:    3    1    2          12
 Near X =  -1.4823792     -0.20096047E-15  0.48025188E-01, d:   2.7649886       0.0000000      0.66666667
 i,j,k,ie:    4    1    2          12
 Near X =  -1.4823792     -0.20096047E-15  0.86354515E-01, d:   2.7649886       0.0000000      0.66666667
 i,j,k,ie:    5    1    2          12
 Near X =  -1.4823792     -0.20096047E-15  0.11859381    , d:   2.7649886       0.0000000      0.66666667
 i,j,k,ie:    6    1    2          12
 Near X =  -1.4823792     -0.20096047E-15  0.13437970    , d:   2.7649886       0.0000000      0.66666667
 i,j,k,ie:    1    2    2          12
 Near X =  -1.4771008     -0.92143977E-01   0.0000000    , d:  0.24474304       0.0000000      0.66666667
 i,j,k,ie:    1    3    2          12
 Near X =  -1.4512831     -0.27628722       0.0000000    , d:  0.33250117       0.0000000      0.66666667
 i,j,k,ie:    1    4    2          12
 Near X =  -1.3943181     -0.48815586       0.0000000    , d:  0.42949709       0.0000000      0.66666667
 i,j,k,ie:    1    5    2          12
 Near X =  -1.3243076     -0.66042350       0.0000000    , d:  0.50490800       0.0000000      0.66666667
 i,j,k,ie:    1    6    2          12
 Near X =  -1.2826639     -0.74279534       0.0000000    , d:   2.4156132     -0.26220793E-01  0.66666667
 i,j,k,ie:    2    6    2          12
 Near X =  -1.2826639     -0.74279534      0.15785898E-01, d:   2.4156132       0.0000000      0.66666667
 i,j,k,ie:    3    6    2          12
 Near X =  -1.2826639     -0.74279534      0.48025188E-01, d:   2.4156132       0.0000000      0.66666667
 i,j,k,ie:    4    6    2          12
 Near X =  -1.2826639     -0.74279534      0.86354515E-01, d:   2.4156132       0.0000000      0.66666667
 i,j,k,ie:    5    6    2          12
 Near X =  -1.2826639     -0.74279534      0.11859381    , d:   2.4156132       0.0000000      0.66666667
 i,j,k,ie:    6    6    2          12
 Near X =  -1.2826639     -0.74279534      0.13437970    , d:   2.4156132       0.0000000      0.66666667
 i,j,k,ie:    1    1    3          12
 Near X =  -1.4463924     -0.23621735E-15   0.0000000    , d:   2.8927847       0.0000000      0.66666667
 i,j,k,ie:    2    1    3          12
 Near X =  -1.4463924     -0.23621735E-15  0.15785898E-01, d:   2.6979919       0.0000000      0.66666667
 i,j,k,ie:    3    1    3          12
 Near X =  -1.4463924     -0.23621735E-15  0.48025188E-01, d:   2.6979919       0.0000000      0.66666667
 i,j,k,ie:    4    1    3          12
 Near X =  -1.4463924     -0.23621735E-15  0.86354515E-01, d:   2.6979919       0.0000000      0.66666667
 i,j,k,ie:    5    1    3          12
 Near X =  -1.4463924     -0.23621735E-15  0.11859381    , d:   2.6979919       0.0000000      0.66666667
 i,j,k,ie:    6    1    3          12
 Near X =  -1.4463924     -0.23621735E-15  0.13437970    , d:   2.6979919       0.0000000      0.66666667
 i,j,k,ie:    1    2    3          12
 Near X =  -1.4367548     -0.88644752E-01   0.0000000    , d:  0.23750725       0.0000000      0.66666667
 i,j,k,ie:    1    3    3          12
 Near X =  -1.4061225     -0.26674010       0.0000000    , d:  0.32177786       0.0000000      0.66666667
 i,j,k,ie:    1    4    3          12
 Near X =  -1.3505747     -0.47333748       0.0000000    , d:  0.41662276       0.0000000      0.66666667
 i,j,k,ie:    1    5    3          12
 Near X =  -1.2877631     -0.64278556       0.0000000    , d:  0.49190270       0.0000000      0.66666667
 i,j,k,ie:    1    6    3          12
 Near X =  -1.2516460     -0.72431469       0.0000000    , d:   2.3119130       0.0000000      0.66666667
 i,j,k,ie:    2    6    3          12
 Near X =  -1.2516460     -0.72431469      0.15785898E-01, d:   2.3119130       0.0000000      0.66666667
 i,j,k,ie:    3    6    3          12
 Near X =  -1.2516460     -0.72431469      0.48025188E-01, d:   2.3119130       0.0000000      0.66666667
 i,j,k,ie:    4    6    3          12
 Near X =  -1.2516460     -0.72431469      0.86354515E-01, d:   2.3119130       0.0000000      0.66666667
 i,j,k,ie:    5    6    3          12
 Near X =  -1.2516460     -0.72431469      0.11859381    , d:   2.3119130       0.0000000      0.66666667
 i,j,k,ie:    6    6    3          12
 Near X =  -1.2516460     -0.72431469      0.13437970    , d:   2.3119130       0.0000000      0.66666667
 i,j,k,ie:    1    1    4          12
 Near X =  -1.4036077     -0.27813430E-15   0.0000000    , d:   2.8072153       0.0000000      0.66666667
 i,j,k,ie:    2    1    4          12
 Near X =  -1.4036077     -0.27813430E-15  0.15785898E-01, d:   2.6183395       0.0000000      0.66666667
 i,j,k,ie:    3    1    4          12
 Near X =  -1.4036077     -0.27813430E-15  0.48025188E-01, d:   2.6183395       0.0000000      0.66666667
 i,j,k,ie:    4    1    4          12
 Near X =  -1.4036077     -0.27813430E-15  0.86354515E-01, d:   2.6183395       0.0000000      0.66666667
 i,j,k,ie:    5    1    4          12
 Near X =  -1.4036077     -0.27813430E-15  0.11859381    , d:   2.6183395       0.0000000      0.66666667
 i,j,k,ie:    6    1    4          12
 Near X =  -1.4036077     -0.27813430E-15  0.13437970    , d:   2.6183395       0.0000000      0.66666667
 i,j,k,ie:    1    2    4          12
 Near X =  -1.3887875     -0.84484519E-01   0.0000000    , d:  0.22890461       0.0000000      0.66666667
 i,j,k,ie:    1    3    4          12
 Near X =  -1.3524309     -0.25538952       0.0000000    , d:  0.30902890       0.0000000      0.66666667
 i,j,k,ie:    1    4    4          12
 Near X =  -1.2985681     -0.45571989       0.0000000    , d:  0.40131646       0.0000000      0.66666667
 i,j,k,ie:    1    5    4          12
 Near X =  -1.2443153     -0.62181580       0.0000000    , d:  0.47644069       0.0000000      0.66666667
 i,j,k,ie:    1    6    4          12
 Near X =  -1.2147688     -0.70234304       0.0000000    , d:   2.1886237       0.0000000      0.66666667
 i,j,k,ie:    2    6    4          12
 Near X =  -1.2147688     -0.70234304      0.15785898E-01, d:   2.1886237       0.0000000      0.66666667
 i,j,k,ie:    3    6    4          12
 Near X =  -1.2147688     -0.70234304      0.48025188E-01, d:   2.1886237       0.0000000      0.66666667
 i,j,k,ie:    4    6    4          12
 Near X =  -1.2147688     -0.70234304      0.86354515E-01, d:   2.1886237       0.0000000      0.66666667
 i,j,k,ie:    5    6    4          12
 Near X =  -1.2147688     -0.70234304      0.11859381    , d:   2.1886237       0.0000000      0.66666667
 i,j,k,ie:    6    6    4          12
 Near X =  -1.2147688     -0.70234304      0.13437970    , d:   2.1886237       0.0000000      0.66666667
 i,j,k,ie:    1    1    5          12
 Near X =  -1.3676209     -0.31339119E-15   0.0000000    , d:   2.7352417       0.0000000      0.66666667
 i,j,k,ie:    2    1    5          12
 Near X =  -1.3676209     -0.31339119E-15  0.15785898E-01, d:   2.5513429       0.0000000      0.66666667
 i,j,k,ie:    3    1    5          12
 Near X =  -1.3676209     -0.31339119E-15  0.48025188E-01, d:   2.5513429       0.0000000      0.66666667
 i,j,k,ie:    4    1    5          12
 Near X =  -1.3676209     -0.31339119E-15  0.86354515E-01, d:   2.5513429       0.0000000      0.66666667
 i,j,k,ie:    5    1    5          12
 Near X =  -1.3676209     -0.31339119E-15  0.11859381    , d:   2.5513429       0.0000000      0.66666667
 i,j,k,ie:    6    1    5          12
 Near X =  -1.3676209     -0.31339119E-15  0.13437970    , d:   2.5513429       0.0000000      0.66666667
 i,j,k,ie:    1    2    5          12
 Near X =  -1.3484415     -0.80985294E-01   0.0000000    , d:  0.22166882       0.0000000      0.66666667
 i,j,k,ie:    1    3    5          12
 Near X =  -1.3072702     -0.24584240       0.0000000    , d:  0.29830559       0.0000000      0.66666667
 i,j,k,ie:    1    4    5          12
 Near X =  -1.2548246     -0.44090151       0.0000000    , d:  0.38844214       0.0000000      0.66666667
 i,j,k,ie:    1    5    5          12
 Near X =  -1.2077708     -0.60417786       0.0000000    , d:  0.46343539       0.0000000      0.66666667
 i,j,k,ie:    1    6    5          12
 Near X =  -1.1837509     -0.68386239       0.0000000    , d:   2.0849234       0.0000000      0.66666667
 i,j,k,ie:    2    6    5          12
 Near X =  -1.1837509     -0.68386239      0.15785898E-01, d:   2.0849234       0.0000000      0.66666667
 i,j,k,ie:    3    6    5          12
 Near X =  -1.1837509     -0.68386239      0.48025188E-01, d:   2.0849234       0.0000000      0.66666667
 i,j,k,ie:    4    6    5          12
 Near X =  -1.1837509     -0.68386239      0.86354515E-01, d:   2.0849234       0.0000000      0.66666667
 i,j,k,ie:    5    6    5          12
 Near X =  -1.1837509     -0.68386239      0.11859381    , d:   2.0849234       0.0000000      0.66666667
 i,j,k,ie:    6    6    5          12
 Near X =  -1.1837509     -0.68386239      0.13437970    , d:   2.0849234       0.0000000      0.66666667
 i,j,k,ie:    1    1    6          12
 Near X =  -1.3500000     -0.33065464E-15   0.0000000    , d:   2.8500000     -0.14999998      0.66666667
 i,j,k,ie:    2    1    6          12
 Near X =  -1.3500000     -0.33065464E-15  0.15785898E-01, d:   2.6477934     -0.14999998      0.66666667
 i,j,k,ie:    3    1    6          12
 Near X =  -1.3500000     -0.33065464E-15  0.48025188E-01, d:   2.6477934     -0.14999998      0.66666667
 i,j,k,ie:    4    1    6          12
 Near X =  -1.3500000     -0.33065464E-15  0.86354515E-01, d:   2.6477934     -0.14999998      0.66666667
 i,j,k,ie:    5    1    6          12
 Near X =  -1.3500000     -0.33065464E-15  0.11859381    , d:   2.6477934     -0.14999998      0.66666667
 i,j,k,ie:    6    1    6          12
 Near X =  -1.3500000     -0.33065464E-15  0.13437970    , d:   2.6477934     -0.14999998      0.66666667
 i,j,k,ie:    1    2    6          12
 Near X =  -1.3286862     -0.79271906E-01   0.0000000    , d:  0.21812583     -0.16816987      0.66666667
 i,j,k,ie:    2    2    6          12
 Near X =  -1.3286862     -0.79271906E-01  0.15785898E-01, d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    3    2    6          12
 Near X =  -1.3286862     -0.79271906E-01  0.48025188E-01, d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    4    2    6          12
 Near X =  -1.3286862     -0.79271906E-01  0.86354515E-01, d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    5    2    6          12
 Near X =  -1.3286862     -0.79271906E-01  0.11859381    , d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    6    2    6          12
 Near X =  -1.3286862     -0.79271906E-01  0.13437970    , d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    1    3    6          12
 Near X =  -1.2851573     -0.24116767       0.0000000    , d:  0.29305495     -0.18823867      0.66666667
 i,j,k,ie:    2    3    6          12
 Near X =  -1.2851573     -0.24116767      0.15785898E-01, d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    3    3    6          12
 Near X =  -1.2851573     -0.24116767      0.48025188E-01, d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    4    3    6          12
 Near X =  -1.2851573     -0.24116767      0.86354515E-01, d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    5    3    6          12
 Near X =  -1.2851573     -0.24116767      0.11859381    , d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    6    3    6          12
 Near X =  -1.2851573     -0.24116767      0.13437970    , d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    1    4    6          12
 Near X =  -1.2334058     -0.43364572       0.0000000    , d:  0.38213825     -0.18233115      0.66666667
 i,j,k,ie:    2    4    6          12
 Near X =  -1.2334058     -0.43364572      0.15785898E-01, d:   0.0000000     -0.18233115      0.66666667
 i,j,k,ie:    3    4    6          12
 Near X =  -1.2334058     -0.43364572      0.48025188E-01, d:   0.0000000     -0.18233115      0.66666667
 i,j,k,ie:    4    4    6          12
 Near X =  -1.2334058     -0.43364572      0.86354515E-01, d:   0.0000000     -0.18233115      0.66666667
 i,j,k,ie:    5    4    6          12
 Near X =  -1.2334058     -0.43364572      0.11859381    , d:   0.0000000     -0.18233115      0.66666667
 i,j,k,ie:    6    4    6          12
 Near X =  -1.2334058     -0.43364572      0.13437970    , d:   0.0000000     -0.18233115      0.66666667
 i,j,k,ie:    1    5    6          12
 Near X =  -1.1898769     -0.59554148       0.0000000    , d:  0.45706737     -0.15232458      0.66666667
 i,j,k,ie:    2    5    6          12
 Near X =  -1.1898769     -0.59554148      0.15785898E-01, d:   0.0000000     -0.15232458      0.66666667
 i,j,k,ie:    3    5    6          12
 Near X =  -1.1898769     -0.59554148      0.48025188E-01, d:   0.0000000     -0.15232458      0.66666667
 i,j,k,ie:    4    5    6          12
 Near X =  -1.1898769     -0.59554148      0.86354515E-01, d:   0.0000000     -0.15232458      0.66666667
 i,j,k,ie:    5    5    6          12
 Near X =  -1.1898769     -0.59554148      0.11859381    , d:   0.0000000     -0.15232458      0.66666667
 i,j,k,ie:    6    5    6          12
 Near X =  -1.1898769     -0.59554148      0.13437970    , d:   0.0000000     -0.15232458      0.66666667
 i,j,k,ie:    1    6    6          12
 Near X =  -1.1685631     -0.67481339       0.0000000    , d:   2.3371011     -0.18143695      0.66666667
 i,j,k,ie:    2    6    6          12
 Near X =  -1.1685631     -0.67481339      0.15785898E-01, d:   2.3371011     -0.12928868      0.66666667
 i,j,k,ie:    3    6    6          12
 Near X =  -1.1685631     -0.67481339      0.48025188E-01, d:   2.3371011     -0.12928868      0.66666667
 i,j,k,ie:    4    6    6          12
 Near X =  -1.1685631     -0.67481339      0.86354515E-01, d:   2.3371011     -0.12928868      0.66666667
 i,j,k,ie:    5    6    6          12
 Near X =  -1.1685631     -0.67481339      0.11859381    , d:   2.3371011     -0.12928868      0.66666667
 i,j,k,ie:    6    6    6          12
 Near X =  -1.1685631     -0.67481339      0.13437970    , d:   2.3371011     -0.12928868      0.66666667
 i,j,k,ie:    1    1    1          13
 Near X = -0.67480683      -1.1685381       0.0000000    , d:   1.4266511       0.0000000       1.4819056
 i,j,k,ie:    2    1    1          13
 Near X = -0.67480683      -1.1685381      0.15785898E-01, d:   1.4266511       0.0000000       1.4819056
 i,j,k,ie:    3    1    1          13
 Near X = -0.67480683      -1.1685381      0.48025188E-01, d:   1.4266511       0.0000000       1.4819056
 i,j,k,ie:    4    1    1          13
 Near X = -0.67480683      -1.1685381      0.86354515E-01, d:   1.4266511       0.0000000       1.4819056
 i,j,k,ie:    5    1    1          13
 Near X = -0.67480683      -1.1685381      0.11859381    , d:   1.4266511       0.0000000       1.4819056
 i,j,k,ie:    6    1    1          13
 Near X = -0.67480683      -1.1685381      0.13437970    , d:   1.4266511     -0.49375625       1.4819056
 i,j,k,ie:    6    2    1          13
 Near X = -0.59553571      -1.1898548      0.13437970    , d:   0.0000000     -0.51502467       1.4819056
 i,j,k,ie:    6    3    1          13
 Near X = -0.43364156      -1.2333897      0.13437970    , d:   0.0000000     -0.55846082       1.4819056
 i,j,k,ie:    6    4    1          13
 Near X = -0.24116543      -1.2851484      0.13437970    , d:   0.0000000     -0.61010210       1.4819056
 i,j,k,ie:    6    5    1          13
 Near X = -0.79271276E-01  -1.3286833      0.13437970    , d:   0.0000000     -0.65353825       1.4819056
 i,j,k,ie:    1    6    1          13
 Near X = -0.15931032E-06  -1.3500000       0.0000000    , d:  0.67481346       0.0000000       1.4819056
 i,j,k,ie:    2    6    1          13
 Near X = -0.15931032E-06  -1.3500000      0.15785898E-01, d:  0.67481346       0.0000000       1.4819056
 i,j,k,ie:    3    6    1          13
 Near X = -0.15931032E-06  -1.3500000      0.48025188E-01, d:  0.67481346       0.0000000       1.4819056
 i,j,k,ie:    4    6    1          13
 Near X = -0.15931032E-06  -1.3500000      0.86354515E-01, d:  0.67481346       0.0000000       1.4819056
 i,j,k,ie:    5    6    1          13
 Near X = -0.15931032E-06  -1.3500000      0.11859381    , d:  0.67481346       0.0000000       1.4819056
 i,j,k,ie:    6    6    1          13
 Near X = -0.15931032E-06  -1.3500000      0.13437970    , d:  0.67481346     -0.67480667       1.4819056
 i,j,k,ie:    1    1    2          13
 Near X = -0.65425505      -1.1329493       0.0000000    , d:   1.3970503       0.0000000       1.4819056
 i,j,k,ie:    2    1    2          13
 Near X = -0.65425505      -1.1329493      0.15785898E-01, d:   1.3970503       0.0000000       1.4819056
 i,j,k,ie:    3    1    2          13
 Near X = -0.65425505      -1.1329493      0.48025188E-01, d:   1.3970503       0.0000000       1.4819056
 i,j,k,ie:    4    1    2          13
 Near X = -0.65425505      -1.1329493      0.86354515E-01, d:   1.3970503       0.0000000       1.4819056
 i,j,k,ie:    5    1    2          13
 Near X = -0.65425505      -1.1329493      0.11859381    , d:   1.3970503       0.0000000       1.4819056
 i,j,k,ie:    6    1    2          13
 Near X = -0.65425505      -1.1329493      0.13437970    , d:   1.3970503     -0.47871851       1.4819056
 i,j,k,ie:    6    2    2          13
 Near X = -0.57739820      -1.1536169      0.13437970    , d:   0.0000000     -0.49933918       1.4819056
 i,j,k,ie:    6    3    2          13
 Near X = -0.42043466      -1.1958259      0.13437970    , d:   0.0000000     -0.54145245       1.4819056
 i,j,k,ie:    6    4    2          13
 Near X = -0.23382054      -1.2460082      0.13437970    , d:   0.0000000     -0.59152096       1.4819056
 i,j,k,ie:    6    5    2          13
 Near X = -0.76857007E-01  -1.2882172      0.13437970    , d:   0.0000000     -0.63363423       1.4819056
 i,j,k,ie:    1    6    2          13
 Near X = -0.15445840E-06  -1.3088847       0.0000000    , d:  0.65426148       0.0000000       1.4819056
 i,j,k,ie:    2    6    2          13
 Near X = -0.15445840E-06  -1.3088847      0.15785898E-01, d:  0.65426148       0.0000000       1.4819056
 i,j,k,ie:    3    6    2          13
 Near X = -0.15445840E-06  -1.3088847      0.48025188E-01, d:  0.65426148       0.0000000       1.4819056
 i,j,k,ie:    4    6    2          13
 Near X = -0.15445840E-06  -1.3088847      0.86354515E-01, d:  0.65426148       0.0000000       1.4819056
 i,j,k,ie:    5    6    2          13
 Near X = -0.15445840E-06  -1.3088847      0.11859381    , d:  0.65426148       0.0000000       1.4819056
 i,j,k,ie:    6    6    2          13
 Near X = -0.15445840E-06  -1.3088847      0.13437970    , d:  0.65426148     -0.65425489       1.4819056
 i,j,k,ie:    1    1    3          13
 Near X = -0.61228248      -1.0602670       0.0000000    , d:   1.3365971       0.0000000       1.4819056
 i,j,k,ie:    2    1    3          13
 Near X = -0.61228248      -1.0602670      0.15785898E-01, d:   1.3365971       0.0000000       1.4819056
 i,j,k,ie:    3    1    3          13
 Near X = -0.61228248      -1.0602670      0.48025188E-01, d:   1.3365971       0.0000000       1.4819056
 i,j,k,ie:    4    1    3          13
 Near X = -0.61228248      -1.0602670      0.86354515E-01, d:   1.3365971       0.0000000       1.4819056
 i,j,k,ie:    5    1    3          13
 Near X = -0.61228248      -1.0602670      0.11859381    , d:   1.3365971       0.0000000       1.4819056
 i,j,k,ie:    6    1    3          13
 Near X = -0.61228248      -1.0602670      0.13437970    , d:   1.3365971     -0.44800718       1.4819056
 i,j,k,ie:    6    2    3          13
 Near X = -0.54035624      -1.0796086      0.13437970    , d:   0.0000000     -0.46730496       1.4819056
 i,j,k,ie:    6    3    3          13
 Near X = -0.39346242      -1.1191098      0.13437970    , d:   0.0000000     -0.50671653       1.4819056
 i,j,k,ie:    6    4    3          13
 Near X = -0.21882020      -1.1660727      0.13437970    , d:   0.0000000     -0.55357298       1.4819056
 i,j,k,ie:    6    5    3          13
 Near X = -0.71926382E-01  -1.2055739      0.13437970    , d:   0.0000000     -0.59298455       1.4819056
 i,j,k,ie:    1    6    3          13
 Near X = -0.14454939E-06  -1.2249155       0.0000000    , d:  0.61228850       0.0000000       1.4819056
 i,j,k,ie:    2    6    3          13
 Near X = -0.14454939E-06  -1.2249155      0.15785898E-01, d:  0.61228850       0.0000000       1.4819056
 i,j,k,ie:    3    6    3          13
 Near X = -0.14454939E-06  -1.2249155      0.48025188E-01, d:  0.61228850       0.0000000       1.4819056
 i,j,k,ie:    4    6    3          13
 Near X = -0.14454939E-06  -1.2249155      0.86354515E-01, d:  0.61228850       0.0000000       1.4819056
 i,j,k,ie:    5    6    3          13
 Near X = -0.14454939E-06  -1.2249155      0.11859381    , d:  0.61228850       0.0000000       1.4819056
 i,j,k,ie:    6    6    3          13
 Near X = -0.14454939E-06  -1.2249155      0.13437970    , d:  0.61228850     -0.61228234       1.4819056
 i,j,k,ie:    1    1    4          13
 Near X = -0.56238125     -0.97385485       0.0000000    , d:   1.2647242       0.0000000       1.4819056
 i,j,k,ie:    2    1    4          13
 Near X = -0.56238125     -0.97385485      0.15785898E-01, d:   1.2647242       0.0000000       1.4819056
 i,j,k,ie:    3    1    4          13
 Near X = -0.56238125     -0.97385485      0.48025188E-01, d:   1.2647242       0.0000000       1.4819056
 i,j,k,ie:    4    1    4          13
 Near X = -0.56238125     -0.97385485      0.86354515E-01, d:   1.2647242       0.0000000       1.4819056
 i,j,k,ie:    5    1    4          13
 Near X = -0.56238125     -0.97385485      0.11859381    , d:   1.2647242       0.0000000       1.4819056
 i,j,k,ie:    6    1    4          13
 Near X = -0.56238125     -0.97385485      0.13437970    , d:   1.2647242     -0.41149444       1.4819056
 i,j,k,ie:    6    2    4          13
 Near X = -0.49631702     -0.99162015      0.13437970    , d:   0.0000000     -0.42921945       1.4819056
 i,j,k,ie:    6    3    4          13
 Near X = -0.36139510      -1.0279019      0.13437970    , d:   0.0000000     -0.46541896       1.4819056
 i,j,k,ie:    6    4    4          13
 Near X = -0.20098628      -1.0710374      0.13437970    , d:   0.0000000     -0.50845660       1.4819056
 i,j,k,ie:    6    5    4          13
 Near X = -0.66064357E-01  -1.1073192      0.13437970    , d:   0.0000000     -0.54465611       1.4819056
 i,j,k,ie:    1    6    4          13
 Near X = -0.13276857E-06  -1.1250845       0.0000000    , d:  0.56238678       0.0000000       1.4819056
 i,j,k,ie:    2    6    4          13
 Near X = -0.13276857E-06  -1.1250845      0.15785898E-01, d:  0.56238678       0.0000000       1.4819056
 i,j,k,ie:    3    6    4          13
 Near X = -0.13276857E-06  -1.1250845      0.48025188E-01, d:  0.56238678       0.0000000       1.4819056
 i,j,k,ie:    4    6    4          13
 Near X = -0.13276857E-06  -1.1250845      0.86354515E-01, d:  0.56238678       0.0000000       1.4819056
 i,j,k,ie:    5    6    4          13
 Near X = -0.13276857E-06  -1.1250845      0.11859381    , d:  0.56238678       0.0000000       1.4819056
 i,j,k,ie:    6    6    4          13
 Near X = -0.13276857E-06  -1.1250845      0.13437970    , d:  0.56238678     -0.56238112       1.4819056
 i,j,k,ie:    1    1    5          13
 Near X = -0.52040868     -0.90117250       0.0000000    , d:   1.2042710       0.0000000       1.4819056
 i,j,k,ie:    2    1    5          13
 Near X = -0.52040868     -0.90117250      0.15785898E-01, d:   1.2042710       0.0000000       1.4819056
 i,j,k,ie:    3    1    5          13
 Near X = -0.52040868     -0.90117250      0.48025188E-01, d:   1.2042710       0.0000000       1.4819056
 i,j,k,ie:    4    1    5          13
 Near X = -0.52040868     -0.90117250      0.86354515E-01, d:   1.2042710       0.0000000       1.4819056
 i,j,k,ie:    5    1    5          13
 Near X = -0.52040868     -0.90117250      0.11859381    , d:   1.2042710       0.0000000       1.4819056
 i,j,k,ie:    6    1    5          13
 Near X = -0.52040868     -0.90117250      0.13437970    , d:   1.2042710     -0.38078311       1.4819056
 i,j,k,ie:    6    2    5          13
 Near X = -0.45927507     -0.91761192      0.13437970    , d:   0.0000000     -0.39718523       1.4819056
 i,j,k,ie:    6    3    5          13
 Near X = -0.33442286     -0.95118586      0.13437970    , d:   0.0000000     -0.43068304       1.4819056
 i,j,k,ie:    6    4    5          13
 Near X = -0.18598594     -0.99110197      0.13437970    , d:   0.0000000     -0.47050862       1.4819056
 i,j,k,ie:    6    5    5          13
 Near X = -0.61133733E-01  -1.0246759      0.13437970    , d:   0.0000000     -0.50400643       1.4819056
 i,j,k,ie:    1    6    5          13
 Near X = -0.12285956E-06  -1.0411153       0.0000000    , d:  0.52041380       0.0000000       1.4819056
 i,j,k,ie:    2    6    5          13
 Near X = -0.12285956E-06  -1.0411153      0.15785898E-01, d:  0.52041380       0.0000000       1.4819056
 i,j,k,ie:    3    6    5          13
 Near X = -0.12285956E-06  -1.0411153      0.48025188E-01, d:  0.52041380       0.0000000       1.4819056
 i,j,k,ie:    4    6    5          13
 Near X = -0.12285956E-06  -1.0411153      0.86354515E-01, d:  0.52041380       0.0000000       1.4819056
 i,j,k,ie:    5    6    5          13
 Near X = -0.12285956E-06  -1.0411153      0.11859381    , d:  0.52041380       0.0000000       1.4819056
 i,j,k,ie:    6    6    5          13
 Near X = -0.12285956E-06  -1.0411153      0.13437970    , d:  0.52041380     -0.52040856       1.4819056
 i,j,k,ie:    1    1    6          13
 Near X = -0.49985690     -0.86558375       0.0000000    , d:   1.2517012     -0.17494992       1.4819056
 i,j,k,ie:    2    1    6          13
 Near X = -0.49985690     -0.86558375      0.15785898E-01, d:   1.2517012     -0.17494992       1.4819056
 i,j,k,ie:    3    1    6          13
 Near X = -0.49985690     -0.86558375      0.48025188E-01, d:   1.2517012     -0.17494992       1.4819056
 i,j,k,ie:    4    1    6          13
 Near X = -0.49985690     -0.86558375      0.86354515E-01, d:   1.2517012     -0.17494992       1.4819056
 i,j,k,ie:    5    1    6          13
 Near X = -0.49985690     -0.86558375      0.11859381    , d:   1.2517012     -0.17494992       1.4819056
 i,j,k,ie:    6    1    6          13
 Near X = -0.49985690     -0.86558375      0.13437970    , d:   1.2517012     -0.66870617       1.4819056
 i,j,k,ie:    1    2    6          13
 Near X = -0.44113756     -0.88137394       0.0000000    , d:   0.0000000     -0.15439815       1.4819056
 i,j,k,ie:    2    2    6          13
 Near X = -0.44113756     -0.88137394      0.15785898E-01, d:   0.0000000     -0.15439815       1.4819056
 i,j,k,ie:    3    2    6          13
 Near X = -0.44113756     -0.88137394      0.48025188E-01, d:   0.0000000     -0.15439815       1.4819056
 i,j,k,ie:    4    2    6          13
 Near X = -0.44113756     -0.88137394      0.86354515E-01, d:   0.0000000     -0.15439815       1.4819056
 i,j,k,ie:    5    2    6          13
 Near X = -0.44113756     -0.88137394      0.11859381    , d:   0.0000000     -0.15439815       1.4819056
 i,j,k,ie:    6    2    6          13
 Near X = -0.44113756     -0.88137394      0.13437970    , d:   0.0000000     -0.66942282       1.4819056
 i,j,k,ie:    1    3    6          13
 Near X = -0.32121597     -0.91362200       0.0000000    , d:   0.0000000     -0.11242559       1.4819056
 i,j,k,ie:    2    3    6          13
 Near X = -0.32121597     -0.91362200      0.15785898E-01, d:   0.0000000     -0.11242559       1.4819056
 i,j,k,ie:    3    3    6          13
 Near X = -0.32121597     -0.91362200      0.48025188E-01, d:   0.0000000     -0.11242559       1.4819056
 i,j,k,ie:    4    3    6          13
 Near X = -0.32121597     -0.91362200      0.86354515E-01, d:   0.0000000     -0.11242559       1.4819056
 i,j,k,ie:    5    3    6          13
 Near X = -0.32121597     -0.91362200      0.11859381    , d:   0.0000000     -0.11242559       1.4819056
 i,j,k,ie:    6    3    6          13
 Near X = -0.32121597     -0.91362200      0.13437970    , d:   0.0000000     -0.67088641       1.4819056
 i,j,k,ie:    1    4    6          13
 Near X = -0.17864106     -0.95196176       0.0000000    , d:   0.0000000     -0.62524372E-01   1.4819056
 i,j,k,ie:    2    4    6          13
 Near X = -0.17864106     -0.95196176      0.15785898E-01, d:   0.0000000     -0.62524372E-01   1.4819056
 i,j,k,ie:    3    4    6          13
 Near X = -0.17864106     -0.95196176      0.48025188E-01, d:   0.0000000     -0.62524372E-01   1.4819056
 i,j,k,ie:    4    4    6          13
 Near X = -0.17864106     -0.95196176      0.86354515E-01, d:   0.0000000     -0.62524372E-01   1.4819056
 i,j,k,ie:    5    4    6          13
 Near X = -0.17864106     -0.95196176      0.11859381    , d:   0.0000000     -0.62524372E-01   1.4819056
 i,j,k,ie:    6    4    6          13
 Near X = -0.17864106     -0.95196176      0.13437970    , d:   0.0000000     -0.67262647       1.4819056
 i,j,k,ie:    1    5    6          13
 Near X = -0.58719463E-01 -0.98420982       0.0000000    , d:   0.0000000     -0.20551813E-01   1.4819056
 i,j,k,ie:    2    5    6          13
 Near X = -0.58719463E-01 -0.98420982      0.15785898E-01, d:   0.0000000     -0.20551813E-01   1.4819056
 i,j,k,ie:    3    5    6          13
 Near X = -0.58719463E-01 -0.98420982      0.48025188E-01, d:   0.0000000     -0.20551813E-01   1.4819056
 i,j,k,ie:    4    5    6          13
 Near X = -0.58719463E-01 -0.98420982      0.86354515E-01, d:   0.0000000     -0.20551813E-01   1.4819056
 i,j,k,ie:    5    5    6          13
 Near X = -0.58719463E-01 -0.98420982      0.11859381    , d:   0.0000000     -0.20551813E-01   1.4819056
 i,j,k,ie:    6    5    6          13
 Near X = -0.58719463E-01 -0.98420982      0.13437970    , d:   0.0000000     -0.67409006       1.4819056
 i,j,k,ie:    1    6    6          13
 Near X = -0.11800764E-06  -1.0000000       0.0000000    , d:  0.67481342     -0.41302676E-07   1.4819056
 i,j,k,ie:    2    6    6          13
 Near X = -0.11800764E-06  -1.0000000      0.15785898E-01, d:  0.67481342     -0.41302676E-07   1.4819056
 i,j,k,ie:    3    6    6          13
 Near X = -0.11800764E-06  -1.0000000      0.48025188E-01, d:  0.67481342     -0.41302676E-07   1.4819056
 i,j,k,ie:    4    6    6          13
 Near X = -0.11800764E-06  -1.0000000      0.86354515E-01, d:  0.67481342     -0.41302676E-07   1.4819056
 i,j,k,ie:    5    6    6          13
 Near X = -0.11800764E-06  -1.0000000      0.11859381    , d:  0.67481342     -0.41302676E-07   1.4819056
 i,j,k,ie:    6    6    6          13
 Near X = -0.11800764E-06  -1.0000000      0.13437970    , d:  0.67481342     -0.67480671       1.4819056
 i,j,k,ie:    1    1    1          14
 Near X =  -1.1685631     -0.67481339       0.0000000    , d:   1.9204073       0.0000000      0.85575184
 i,j,k,ie:    2    1    1          14
 Near X =  -1.1685631     -0.67481339      0.15785898E-01, d:   1.1685629       0.0000000      0.85575184
 i,j,k,ie:    3    1    1          14
 Near X =  -1.1685631     -0.67481339      0.48025188E-01, d:   1.1685629       0.0000000      0.85575184
 i,j,k,ie:    4    1    1          14
 Near X =  -1.1685631     -0.67481339      0.86354515E-01, d:   1.1685629       0.0000000      0.85575184
 i,j,k,ie:    5    1    1          14
 Near X =  -1.1685631     -0.67481339      0.11859381    , d:   1.1685629       0.0000000      0.85575184
 i,j,k,ie:    6    1    1          14
 Near X =  -1.1685631     -0.67481339      0.13437970    , d:   1.1685629     -0.18143695      0.85575184
 i,j,k,ie:    1    2    1          14
 Near X =  -1.1105604     -0.73281238       0.0000000    , d:  0.51502467       0.0000000      0.85575184
 i,j,k,ie:    6    2    1          14
 Near X =  -1.1105604     -0.73281238      0.13437970    , d:   0.0000000     -0.21812583      0.85575184
 i,j,k,ie:    1    3    1          14
 Near X = -0.99210237     -0.85126281       0.0000000    , d:  0.55846082       0.0000000      0.85575184
 i,j,k,ie:    6    3    1          14
 Near X = -0.99210237     -0.85126281      0.13437970    , d:   0.0000000     -0.29305495      0.85575184
 i,j,k,ie:    1    4    1          14
 Near X = -0.85126753     -0.99208865       0.0000000    , d:  0.61010210       0.0000000      0.85575184
 i,j,k,ie:    6    4    1          14
 Near X = -0.85126753     -0.99208865      0.13437970    , d:   0.0000000     -0.38213825      0.85575184
 i,j,k,ie:    1    5    1          14
 Near X = -0.73280953      -1.1105391       0.0000000    , d:  0.65353825       0.0000000      0.85575184
 i,j,k,ie:    6    5    1          14
 Near X = -0.73280953      -1.1105391      0.13437970    , d:   0.0000000     -0.45706737      0.85575184
 i,j,k,ie:    1    6    1          14
 Near X = -0.67480683      -1.1685381       0.0000000    , d:   1.3496201       0.0000000      0.85575184
 i,j,k,ie:    2    6    1          14
 Near X = -0.67480683      -1.1685381      0.15785898E-01, d:  0.67480667       0.0000000      0.85575184
 i,j,k,ie:    3    6    1          14
 Near X = -0.67480683      -1.1685381      0.48025188E-01, d:  0.67480667       0.0000000      0.85575184
 i,j,k,ie:    4    6    1          14
 Near X = -0.67480683      -1.1685381      0.86354515E-01, d:  0.67480667       0.0000000      0.85575184
 i,j,k,ie:    5    6    1          14
 Near X = -0.67480683      -1.1685381      0.11859381    , d:  0.67480667       0.0000000      0.85575184
 i,j,k,ie:    6    6    1          14
 Near X = -0.67480683      -1.1685381      0.13437970    , d:   1.3496136     -0.49375625      0.85575184
 i,j,k,ie:    1    1    2          14
 Near X =  -1.1329736     -0.65426141       0.0000000    , d:   1.8757688       0.0000000      0.85575184
 i,j,k,ie:    2    1    2          14
 Near X =  -1.1329736     -0.65426141      0.15785898E-01, d:   1.1329734       0.0000000      0.85575184
 i,j,k,ie:    3    1    2          14
 Near X =  -1.1329736     -0.65426141      0.48025188E-01, d:   1.1329734       0.0000000      0.85575184
 i,j,k,ie:    4    1    2          14
 Near X =  -1.1329736     -0.65426141      0.86354515E-01, d:   1.1329734       0.0000000      0.85575184
 i,j,k,ie:    5    1    2          14
 Near X =  -1.1329736     -0.65426141      0.11859381    , d:   1.1329734       0.0000000      0.85575184
 i,j,k,ie:    6    1    2          14
 Near X =  -1.1329736     -0.65426141      0.13437970    , d:   1.1329734     -0.17591114      0.85575184
 i,j,k,ie:    1    2    2          14
 Near X =  -1.0767374     -0.71049400       0.0000000    , d:  0.49933918       0.0000000      0.85575184
 i,j,k,ie:    6    2    2          14
 Near X =  -1.0767374     -0.71049400      0.13437970    , d:   0.0000000     -0.21148263      0.85575184
 i,j,k,ie:    1    3    2          14
 Near X = -0.96188711     -0.82533693       0.0000000    , d:  0.54145245       0.0000000      0.85575184
 i,j,k,ie:    6    3    2          14
 Near X = -0.96188711     -0.82533693      0.13437970    , d:   0.0000000     -0.28412972      0.85575184
 i,j,k,ie:    1    4    2          14
 Near X = -0.82534150     -0.96187381       0.0000000    , d:  0.59152096       0.0000000      0.85575184
 i,j,k,ie:    6    4    2          14
 Near X = -0.82534150     -0.96187381      0.13437970    , d:   0.0000000     -0.37049993      0.85575184
 i,j,k,ie:    1    5    2          14
 Near X = -0.71049123      -1.0767167       0.0000000    , d:  0.63363423       0.0000000      0.85575184
 i,j,k,ie:    6    5    2          14
 Near X = -0.71049123      -1.0767167      0.13437970    , d:   0.0000000     -0.44314702      0.85575184
 i,j,k,ie:    1    6    2          14
 Near X = -0.65425505      -1.1329493       0.0000000    , d:   1.3085164       0.0000000      0.85575184
 i,j,k,ie:    2    6    2          14
 Near X = -0.65425505      -1.1329493      0.15785898E-01, d:  0.65425489       0.0000000      0.85575184
 i,j,k,ie:    3    6    2          14
 Near X = -0.65425505      -1.1329493      0.48025188E-01, d:  0.65425489       0.0000000      0.85575184
 i,j,k,ie:    4    6    2          14
 Near X = -0.65425505      -1.1329493      0.86354515E-01, d:  0.65425489       0.0000000      0.85575184
 i,j,k,ie:    5    6    2          14
 Near X = -0.65425505      -1.1329493      0.11859381    , d:  0.65425489       0.0000000      0.85575184
 i,j,k,ie:    6    6    2          14
 Near X = -0.65425505      -1.1329493      0.13437970    , d:   1.3085101     -0.47871851      0.85575184
 i,j,k,ie:    1    1    3          14
 Near X =  -1.0602897     -0.61228843       0.0000000    , d:   1.7846043       0.0000000      0.85575184
 i,j,k,ie:    2    1    3          14
 Near X =  -1.0602897     -0.61228843      0.15785898E-01, d:   1.0602895       0.0000000      0.85575184
 i,j,k,ie:    3    1    3          14
 Near X =  -1.0602897     -0.61228843      0.48025188E-01, d:   1.0602895       0.0000000      0.85575184
 i,j,k,ie:    4    1    3          14
 Near X =  -1.0602897     -0.61228843      0.86354515E-01, d:   1.0602895       0.0000000      0.85575184
 i,j,k,ie:    5    1    3          14
 Near X =  -1.0602897     -0.61228843      0.11859381    , d:   1.0602895       0.0000000      0.85575184
 i,j,k,ie:    6    1    3          14
 Near X =  -1.0602897     -0.61228843      0.13437970    , d:   1.0602895     -0.16462588      0.85575184
 i,j,k,ie:    1    2    3          14
 Near X =  -1.0076612     -0.66491352       0.0000000    , d:  0.46730496       0.0000000      0.85575184
 i,j,k,ie:    6    2    3          14
 Near X =  -1.0076612     -0.66491352      0.13437970    , d:   0.0000000     -0.19791534      0.85575184
 i,j,k,ie:    1    3    3          14
 Near X = -0.90017895     -0.77238891       0.0000000    , d:  0.50671653       0.0000000      0.85575184
 i,j,k,ie:    6    3    3          14
 Near X = -0.90017895     -0.77238891      0.13437970    , d:   0.0000000     -0.26590189      0.85575184
 i,j,k,ie:    1    4    3          14
 Near X = -0.77239319     -0.90016650       0.0000000    , d:  0.55357298       0.0000000      0.85575184
 i,j,k,ie:    6    4    3          14
 Near X = -0.77239319     -0.90016650      0.13437970    , d:   0.0000000     -0.34673117      0.85575184
 i,j,k,ie:    1    5    3          14
 Near X = -0.66491093      -1.0076419       0.0000000    , d:  0.59298455       0.0000000      0.85575184
 i,j,k,ie:    6    5    3          14
 Near X = -0.66491093      -1.0076419      0.13437970    , d:   0.0000000     -0.41471771      0.85575184
 i,j,k,ie:    1    6    3          14
 Near X = -0.61228248      -1.0602670       0.0000000    , d:   1.2245708       0.0000000      0.85575184
 i,j,k,ie:    2    6    3          14
 Near X = -0.61228248      -1.0602670      0.15785898E-01, d:  0.61228234       0.0000000      0.85575184
 i,j,k,ie:    3    6    3          14
 Near X = -0.61228248      -1.0602670      0.48025188E-01, d:  0.61228234       0.0000000      0.85575184
 i,j,k,ie:    4    6    3          14
 Near X = -0.61228248      -1.0602670      0.86354515E-01, d:  0.61228234       0.0000000      0.85575184
 i,j,k,ie:    5    6    3          14
 Near X = -0.61228248      -1.0602670      0.11859381    , d:  0.61228234       0.0000000      0.85575184
 i,j,k,ie:    6    6    3          14
 Near X = -0.61228248      -1.0602670      0.13437970    , d:   1.2245649     -0.44800718      0.85575184
 i,j,k,ie:    1    1    4          14
 Near X = -0.97387569     -0.56238672       0.0000000    , d:   1.6762186       0.0000000      0.85575184
 i,j,k,ie:    2    1    4          14
 Near X = -0.97387569     -0.56238672      0.15785898E-01, d:  0.97387552       0.0000000      0.85575184
 i,j,k,ie:    3    1    4          14
 Near X = -0.97387569     -0.56238672      0.48025188E-01, d:  0.97387552       0.0000000      0.85575184
 i,j,k,ie:    4    1    4          14
 Near X = -0.97387569     -0.56238672      0.86354515E-01, d:  0.97387552       0.0000000      0.85575184
 i,j,k,ie:    5    1    4          14
 Near X = -0.97387569     -0.56238672      0.11859381    , d:  0.97387552       0.0000000      0.85575184
 i,j,k,ie:    6    1    4          14
 Near X = -0.97387569     -0.56238672      0.13437970    , d:  0.97387552     -0.15120881      0.85575184
 i,j,k,ie:    1    2    4          14
 Near X = -0.92553647     -0.61072284       0.0000000    , d:  0.42921945       0.0000000      0.85575184
 i,j,k,ie:    6    2    4          14
 Near X = -0.92553647     -0.61072284      0.13437970    , d:   0.0000000     -0.18178517      0.85575184
 i,j,k,ie:    1    3    4          14
 Near X = -0.82681406     -0.70943895       0.0000000    , d:  0.46541896       0.0000000      0.85575184
 i,j,k,ie:    6    3    4          14
 Near X = -0.82681406     -0.70943895      0.13437970    , d:   0.0000000     -0.24423079      0.85575184
 i,j,k,ie:    1    4    4          14
 Near X = -0.70944288     -0.82680263       0.0000000    , d:  0.50845660       0.0000000      0.85575184
 i,j,k,ie:    6    4    4          14
 Near X = -0.70944288     -0.82680263      0.13437970    , d:   0.0000000     -0.31847246      0.85575184
 i,j,k,ie:    1    5    4          14
 Near X = -0.61072046     -0.92551873       0.0000000    , d:  0.54465611       0.0000000      0.85575184
 i,j,k,ie:    6    5    4          14
 Near X = -0.61072046     -0.92551873      0.13437970    , d:   0.0000000     -0.38091808      0.85575184
 i,j,k,ie:    1    6    4          14
 Near X = -0.56238125     -0.97385485       0.0000000    , d:   1.1247679       0.0000000      0.85575184
 i,j,k,ie:    2    6    4          14
 Near X = -0.56238125     -0.97385485      0.15785898E-01, d:  0.56238112       0.0000000      0.85575184
 i,j,k,ie:    3    6    4          14
 Near X = -0.56238125     -0.97385485      0.48025188E-01, d:  0.56238112       0.0000000      0.85575184
 i,j,k,ie:    4    6    4          14
 Near X = -0.56238125     -0.97385485      0.86354515E-01, d:  0.56238112       0.0000000      0.85575184
 i,j,k,ie:    5    6    4          14
 Near X = -0.56238125     -0.97385485      0.11859381    , d:  0.56238112       0.0000000      0.85575184
 i,j,k,ie:    6    6    4          14
 Near X = -0.56238125     -0.97385485      0.13437970    , d:   1.1247625     -0.41149444      0.85575184
 i,j,k,ie:    1    1    5          14
 Near X = -0.90119179     -0.52041374       0.0000000    , d:   1.5850541       0.0000000      0.85575184
 i,j,k,ie:    2    1    5          14
 Near X = -0.90119179     -0.52041374      0.15785898E-01, d:  0.90119162       0.0000000      0.85575184
 i,j,k,ie:    3    1    5          14
 Near X = -0.90119179     -0.52041374      0.48025188E-01, d:  0.90119162       0.0000000      0.85575184
 i,j,k,ie:    4    1    5          14
 Near X = -0.90119179     -0.52041374      0.86354515E-01, d:  0.90119162       0.0000000      0.85575184
 i,j,k,ie:    5    1    5          14
 Near X = -0.90119179     -0.52041374      0.11859381    , d:  0.90119162       0.0000000      0.85575184
 i,j,k,ie:    6    1    5          14
 Near X = -0.90119179     -0.52041374      0.13437970    , d:  0.90119162     -0.13992354      0.85575184
 i,j,k,ie:    1    2    5          14
 Near X = -0.85646030     -0.56514236       0.0000000    , d:  0.39718523       0.0000000      0.85575184
 i,j,k,ie:    6    2    5          14
 Near X = -0.85646030     -0.56514236      0.13437970    , d:   0.0000000     -0.16821788      0.85575184
 i,j,k,ie:    1    3    5          14
 Near X = -0.76510590     -0.65649092       0.0000000    , d:  0.43068304       0.0000000      0.85575184
 i,j,k,ie:    6    3    5          14
 Near X = -0.76510590     -0.65649092      0.13437970    , d:   0.0000000     -0.22600296      0.85575184
 i,j,k,ie:    1    4    5          14
 Near X = -0.65649456     -0.76509532       0.0000000    , d:  0.47050862       0.0000000      0.85575184
 i,j,k,ie:    6    4    5          14
 Near X = -0.65649456     -0.76509532      0.13437970    , d:   0.0000000     -0.29470369      0.85575184
 i,j,k,ie:    1    5    5          14
 Near X = -0.56514016     -0.85644388       0.0000000    , d:  0.50400643       0.0000000      0.85575184
 i,j,k,ie:    6    5    5          14
 Near X = -0.56514016     -0.85644388      0.13437970    , d:   0.0000000     -0.35248877      0.85575184
 i,j,k,ie:    1    6    5          14
 Near X = -0.52040868     -0.90117250       0.0000000    , d:   1.0408224       0.0000000      0.85575184
 i,j,k,ie:    2    6    5          14
 Near X = -0.52040868     -0.90117250      0.15785898E-01, d:  0.52040856       0.0000000      0.85575184
 i,j,k,ie:    3    6    5          14
 Near X = -0.52040868     -0.90117250      0.48025188E-01, d:  0.52040856       0.0000000      0.85575184
 i,j,k,ie:    4    6    5          14
 Near X = -0.52040868     -0.90117250      0.86354515E-01, d:  0.52040856       0.0000000      0.85575184
 i,j,k,ie:    5    6    5          14
 Near X = -0.52040868     -0.90117250      0.11859381    , d:  0.52040856       0.0000000      0.85575184
 i,j,k,ie:    6    6    5          14
 Near X = -0.52040868     -0.90117250      0.13437970    , d:   1.0408173     -0.38078311      0.85575184
 i,j,k,ie:    1    1    6          14
 Near X = -0.86560227     -0.49986176       0.0000000    , d:   1.6174465     -0.30296080      0.85575184
 i,j,k,ie:    2    1    6          14
 Near X = -0.86560227     -0.49986176      0.15785898E-01, d:  0.86560211     -0.30296080      0.85575184
 i,j,k,ie:    3    1    6          14
 Near X = -0.86560227     -0.49986176      0.48025188E-01, d:  0.86560211     -0.30296080      0.85575184
 i,j,k,ie:    4    1    6          14
 Near X = -0.86560227     -0.49986176      0.86354515E-01, d:  0.86560211     -0.30296080      0.85575184
 i,j,k,ie:    5    1    6          14
 Near X = -0.86560227     -0.49986176      0.11859381    , d:  0.86560211     -0.30296080      0.85575184
 i,j,k,ie:    6    1    6          14
 Near X = -0.86560227     -0.49986176      0.13437970    , d:  0.86560211     -0.48439775      0.85575184
 i,j,k,ie:    1    2    6          14
 Near X = -0.82263731     -0.54282398       0.0000000    , d:  0.38149975     -0.28792307      0.85575184
 i,j,k,ie:    2    2    6          14
 Near X = -0.82263731     -0.54282398      0.15785898E-01, d:   0.0000000     -0.28792307      0.85575184
 i,j,k,ie:    3    2    6          14
 Near X = -0.82263731     -0.54282398      0.48025188E-01, d:   0.0000000     -0.28792307      0.85575184
 i,j,k,ie:    4    2    6          14
 Near X = -0.82263731     -0.54282398      0.86354515E-01, d:   0.0000000     -0.28792307      0.85575184
 i,j,k,ie:    5    2    6          14
 Near X = -0.82263731     -0.54282398      0.11859381    , d:   0.0000000     -0.28792307      0.85575184
 i,j,k,ie:    6    2    6          14
 Near X = -0.82263731     -0.54282398      0.13437970    , d:   0.0000000     -0.50604889      0.85575184
 i,j,k,ie:    1    3    6          14
 Near X = -0.73489064     -0.63056504       0.0000000    , d:  0.41367468     -0.25721173      0.85575184
 i,j,k,ie:    2    3    6          14
 Near X = -0.73489064     -0.63056504      0.15785898E-01, d:   0.0000000     -0.25721173      0.85575184
 i,j,k,ie:    3    3    6          14
 Near X = -0.73489064     -0.63056504      0.48025188E-01, d:   0.0000000     -0.25721173      0.85575184
 i,j,k,ie:    4    3    6          14
 Near X = -0.73489064     -0.63056504      0.86354515E-01, d:   0.0000000     -0.25721173      0.85575184
 i,j,k,ie:    5    3    6          14
 Near X = -0.73489064     -0.63056504      0.11859381    , d:   0.0000000     -0.25721173      0.85575184
 i,j,k,ie:    6    3    6          14
 Near X = -0.73489064     -0.63056504      0.13437970    , d:   0.0000000     -0.55026668      0.85575184
 i,j,k,ie:    1    4    6          14
 Near X = -0.63056853     -0.73488048       0.0000000    , d:  0.45192748     -0.22069899      0.85575184
 i,j,k,ie:    2    4    6          14
 Near X = -0.63056853     -0.73488048      0.15785898E-01, d:   0.0000000     -0.22069899      0.85575184
 i,j,k,ie:    3    4    6          14
 Near X = -0.63056853     -0.73488048      0.48025188E-01, d:   0.0000000     -0.22069899      0.85575184
 i,j,k,ie:    4    4    6          14
 Near X = -0.63056853     -0.73488048      0.86354515E-01, d:   0.0000000     -0.22069899      0.85575184
 i,j,k,ie:    5    4    6          14
 Near X = -0.63056853     -0.73488048      0.11859381    , d:   0.0000000     -0.22069899      0.85575184
 i,j,k,ie:    6    4    6          14
 Near X = -0.63056853     -0.73488048      0.13437970    , d:   0.0000000     -0.60283725      0.85575184
 i,j,k,ie:    1    5    6          14
 Near X = -0.54282187     -0.82262154       0.0000000    , d:  0.48410240     -0.18998766      0.85575184
 i,j,k,ie:    2    5    6          14
 Near X = -0.54282187     -0.82262154      0.15785898E-01, d:   0.0000000     -0.18998766      0.85575184
 i,j,k,ie:    3    5    6          14
 Near X = -0.54282187     -0.82262154      0.48025188E-01, d:   0.0000000     -0.18998766      0.85575184
 i,j,k,ie:    4    5    6          14
 Near X = -0.54282187     -0.82262154      0.86354515E-01, d:   0.0000000     -0.18998766      0.85575184
 i,j,k,ie:    5    5    6          14
 Near X = -0.54282187     -0.82262154      0.11859381    , d:   0.0000000     -0.18998766      0.85575184
 i,j,k,ie:    6    5    6          14
 Near X = -0.54282187     -0.82262154      0.13437970    , d:   0.0000000     -0.64705503      0.85575184
 i,j,k,ie:    1    6    6          14
 Near X = -0.49985690     -0.86558375       0.0000000    , d:   1.1746702     -0.17494992      0.85575184
 i,j,k,ie:    2    6    6          14
 Near X = -0.49985690     -0.86558375      0.15785898E-01, d:  0.49985679     -0.17494992      0.85575184
 i,j,k,ie:    3    6    6          14
 Near X = -0.49985690     -0.86558375      0.48025188E-01, d:  0.49985679     -0.17494992      0.85575184
 i,j,k,ie:    4    6    6          14
 Near X = -0.49985690     -0.86558375      0.86354515E-01, d:  0.49985679     -0.17494992      0.85575184
 i,j,k,ie:    5    6    6          14
 Near X = -0.49985690     -0.86558375      0.11859381    , d:  0.49985679     -0.17494992      0.85575184
 i,j,k,ie:    6    6    6          14
 Near X = -0.49985690     -0.86558375      0.13437970    , d:   1.1746637     -0.66870617      0.85575184
 i,j,k,ie:    1    1    1          15
 Near X =  -1.3500000     -0.33065464E-15   0.0000000    , d:   1.3499998       0.0000000      0.74074073
 i,j,k,ie:    2    1    1          15
 Near X =  -1.3500000     -0.33065464E-15  0.15785898E-01, d:  0.59804941       0.0000000      0.74074073
 i,j,k,ie:    3    1    1          15
 Near X =  -1.3500000     -0.33065464E-15  0.48025188E-01, d:  0.59804941       0.0000000      0.74074073
 i,j,k,ie:    4    1    1          15
 Near X =  -1.3500000     -0.33065464E-15  0.86354515E-01, d:  0.59804941       0.0000000      0.74074073
 i,j,k,ie:    5    1    1          15
 Near X =  -1.3500000     -0.33065464E-15  0.11859381    , d:  0.59804941       0.0000000      0.74074073
 i,j,k,ie:    6    1    1          15
 Near X =  -1.3500000     -0.33065464E-15  0.13437970    , d:   2.5185381       0.0000000      0.74074073
 i,j,k,ie:    1    2    1          15
 Near X =  -1.3286862     -0.79271906E-01   0.0000000    , d:  0.21812583       0.0000000      0.74074073
 i,j,k,ie:    6    2    1          15
 Near X =  -1.3286862     -0.79271906E-01  0.13437970    , d:   2.5185410       0.0000000      0.74074073
 i,j,k,ie:    1    3    1          15
 Near X =  -1.2851573     -0.24116767       0.0000000    , d:  0.29305495       0.0000000      0.74074073
 i,j,k,ie:    6    3    1          15
 Near X =  -1.2851573     -0.24116767      0.13437970    , d:   2.5185470       0.0000000      0.74074073
 i,j,k,ie:    1    4    1          15
 Near X =  -1.2334058     -0.43364572       0.0000000    , d:  0.38213825       0.0000000      0.74074073
 i,j,k,ie:    6    4    1          15
 Near X =  -1.2334058     -0.43364572      0.13437970    , d:   2.5185542       0.0000000      0.74074073
 i,j,k,ie:    1    5    1          15
 Near X =  -1.1898769     -0.59554148       0.0000000    , d:  0.45706737       0.0000000      0.74074073
 i,j,k,ie:    6    5    1          15
 Near X =  -1.1898769     -0.59554148      0.13437970    , d:   2.5185602       0.0000000      0.74074073
 i,j,k,ie:    1    6    1          15
 Near X =  -1.1685631     -0.67481339       0.0000000    , d:   1.8433699       0.0000000      0.74074073
 i,j,k,ie:    2    6    1          15
 Near X =  -1.1685631     -0.67481339      0.15785898E-01, d:   1.8433699       0.0000000      0.74074073
 i,j,k,ie:    3    6    1          15
 Near X =  -1.1685631     -0.67481339      0.48025188E-01, d:   1.8433699       0.0000000      0.74074073
 i,j,k,ie:    4    6    1          15
 Near X =  -1.1685631     -0.67481339      0.86354515E-01, d:   1.8433699       0.0000000      0.74074073
 i,j,k,ie:    5    6    1          15
 Near X =  -1.1685631     -0.67481339      0.11859381    , d:   1.8433699       0.0000000      0.74074073
 i,j,k,ie:    6    6    1          15
 Near X =  -1.1685631     -0.67481339      0.13437970    , d:   2.5185631       0.0000000      0.74074073
 i,j,k,ie:    1    1    2          15
 Near X =  -1.3088847     -0.32058429E-15   0.0000000    , d:   1.3088845       0.0000000      0.74074073
 i,j,k,ie:    2    1    2          15
 Near X =  -1.3088847     -0.32058429E-15  0.15785898E-01, d:  0.56599635       0.0000000      0.74074073
 i,j,k,ie:    3    1    2          15
 Near X =  -1.3088847     -0.32058429E-15  0.48025188E-01, d:  0.56599635       0.0000000      0.74074073
 i,j,k,ie:    4    1    2          15
 Near X =  -1.3088847     -0.32058429E-15  0.86354515E-01, d:  0.56599635       0.0000000      0.74074073
 i,j,k,ie:    5    1    2          15
 Near X =  -1.3088847     -0.32058429E-15  0.11859381    , d:  0.56599635       0.0000000      0.74074073
 i,j,k,ie:    6    1    2          15
 Near X =  -1.3088847     -0.32058429E-15  0.13437970    , d:   2.4418340       0.0000000      0.74074073
 i,j,k,ie:    1    2    2          15
 Near X =  -1.2882200     -0.76857618E-01   0.0000000    , d:  0.21148263       0.0000000      0.74074073
 i,j,k,ie:    6    2    2          15
 Near X =  -1.2882200     -0.76857618E-01  0.13437970    , d:   2.4418369       0.0000000      0.74074073
 i,j,k,ie:    1    3    2          15
 Near X =  -1.2460168     -0.23382272       0.0000000    , d:  0.28412972       0.0000000      0.74074073
 i,j,k,ie:    6    3    2          15
 Near X =  -1.2460168     -0.23382272      0.13437970    , d:   2.4418427       0.0000000      0.74074073
 i,j,k,ie:    1    4    2          15
 Near X =  -1.1958414     -0.42043869       0.0000000    , d:  0.37049993       0.0000000      0.74074073
 i,j,k,ie:    6    4    2          15
 Near X =  -1.1958414     -0.42043869      0.13437970    , d:   2.4418496       0.0000000      0.74074073
 i,j,k,ie:    1    5    2          15
 Near X =  -1.1536383     -0.57740379       0.0000000    , d:  0.44314702       0.0000000      0.74074073
 i,j,k,ie:    6    5    2          15
 Near X =  -1.1536383     -0.57740379      0.13437970    , d:   2.4418554       0.0000000      0.74074073
 i,j,k,ie:    1    6    2          15
 Near X =  -1.1329736     -0.65426141       0.0000000    , d:   1.7872286       0.0000000      0.74074073
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    2    6    2          15
 Near X =  -1.1329736     -0.65426141      0.15785898E-01, d:   1.7872286       0.0000000      0.74074073
 i,j,k,ie:    3    6    2          15
 Near X =  -1.1329736     -0.65426141      0.48025188E-01, d:   1.7872286       0.0000000      0.74074073
 i,j,k,ie:    4    6    2          15
 Near X =  -1.1329736     -0.65426141      0.86354515E-01, d:   1.7872286       0.0000000      0.74074073
 i,j,k,ie:    5    6    2          15
 Near X =  -1.1329736     -0.65426141      0.11859381    , d:   1.7872286       0.0000000      0.74074073
 i,j,k,ie:    6    6    2          15
 Near X =  -1.1329736     -0.65426141      0.13437970    , d:   2.4418583       0.0000000      0.74074073
 i,j,k,ie:    1    1    3          15
 Near X =  -1.2249155     -0.30001778E-15   0.0000000    , d:   1.2249154       0.0000000      0.74074073
 i,j,k,ie:    2    1    3          15
 Near X =  -1.2249155     -0.30001778E-15  0.15785898E-01, d:  0.50053490       0.0000000      0.74074073
 i,j,k,ie:    3    1    3          15
 Near X =  -1.2249155     -0.30001778E-15  0.48025188E-01, d:  0.50053490       0.0000000      0.74074073
 i,j,k,ie:    4    1    3          15
 Near X =  -1.2249155     -0.30001778E-15  0.86354515E-01, d:  0.50053490       0.0000000      0.74074073
 i,j,k,ie:    5    1    3          15
 Near X =  -1.2249155     -0.30001778E-15  0.11859381    , d:  0.50053490       0.0000000      0.74074073
 i,j,k,ie:    6    1    3          15
 Near X =  -1.2249155     -0.30001778E-15  0.13437970    , d:   2.2851825     -0.26730483E-01  0.74074073
 i,j,k,ie:    1    2    3          15
 Near X =  -1.2055765     -0.71926954E-01   0.0000000    , d:  0.19791534       0.0000000      0.74074073
 i,j,k,ie:    6    2    3          15
 Near X =  -1.2055765     -0.71926954E-01  0.13437970    , d:   2.2851852       0.0000000      0.74074073
 i,j,k,ie:    1    3    3          15
 Near X =  -1.1660808     -0.21882224       0.0000000    , d:  0.26590189       0.0000000      0.74074073
 i,j,k,ie:    6    3    3          15
 Near X =  -1.1660808     -0.21882224      0.13437970    , d:   2.2851906       0.0000000      0.74074073
 i,j,k,ie:    1    4    3          15
 Near X =  -1.1191244     -0.39346620       0.0000000    , d:  0.34673117       0.0000000      0.74074073
 i,j,k,ie:    6    4    3          15
 Near X =  -1.1191244     -0.39346620      0.13437970    , d:   2.2851971       0.0000000      0.74074073
 i,j,k,ie:    1    5    3          15
 Near X =  -1.0796286     -0.54036148       0.0000000    , d:  0.41471771       0.0000000      0.74074073
 i,j,k,ie:    6    5    3          15
 Near X =  -1.0796286     -0.54036148      0.13437970    , d:   2.2852025       0.0000000      0.74074073
 i,j,k,ie:    1    6    3          15
 Near X =  -1.0602897     -0.61228843       0.0000000    , d:   1.6725721       0.0000000      0.74074073
 i,j,k,ie:    2    6    3          15
 Near X =  -1.0602897     -0.61228843      0.15785898E-01, d:   1.6725721       0.0000000      0.74074073
 i,j,k,ie:    3    6    3          15
 Near X =  -1.0602897     -0.61228843      0.48025188E-01, d:   1.6725721       0.0000000      0.74074073
 i,j,k,ie:    4    6    3          15
 Near X =  -1.0602897     -0.61228843      0.86354515E-01, d:   1.6725721       0.0000000      0.74074073
 i,j,k,ie:    5    6    3          15
 Near X =  -1.0602897     -0.61228843      0.11859381    , d:   1.6725721       0.0000000      0.74074073
 i,j,k,ie:    6    6    3          15
 Near X =  -1.0602897     -0.61228843      0.13437970    , d:   2.2852052       0.0000000      0.74074073
 i,j,k,ie:    1    1    4          15
 Near X =  -1.1250845     -0.27556623E-15   0.0000000    , d:   1.1250843       0.0000000      0.74074073
 i,j,k,ie:    2    1    4          15
 Near X =  -1.1250845     -0.27556623E-15  0.15785898E-01, d:  0.42270770       0.0000000      0.74074073
 i,j,k,ie:    3    1    4          15
 Near X =  -1.1250845     -0.27556623E-15  0.48025188E-01, d:  0.42270770       0.0000000      0.74074073
 i,j,k,ie:    4    1    4          15
 Near X =  -1.1250845     -0.27556623E-15  0.86354515E-01, d:  0.42270770       0.0000000      0.74074073
 i,j,k,ie:    5    1    4          15
 Near X =  -1.1250845     -0.27556623E-15  0.11859381    , d:  0.42270770       0.0000000      0.74074073
 i,j,k,ie:    6    1    4          15
 Near X =  -1.1250845     -0.27556623E-15  0.13437970    , d:   2.0989393     -0.89684313E-01  0.74074073
 i,j,k,ie:    1    2    4          15
 Near X =  -1.1073216     -0.66064883E-01   0.0000000    , d:  0.18178517       0.0000000      0.74074073
 i,j,k,ie:    6    2    4          15
 Near X =  -1.1073216     -0.66064883E-01  0.13437970    , d:   2.0989418       0.0000000      0.74074073
 i,j,k,ie:    1    3    4          15
 Near X =  -1.0710449     -0.20098815       0.0000000    , d:  0.24423079       0.0000000      0.74074073
 i,j,k,ie:    6    3    4          15
 Near X =  -1.0710449     -0.20098815      0.13437970    , d:   2.0989468       0.0000000      0.74074073
 i,j,k,ie:    1    4    4          15
 Near X =  -1.0279153     -0.36139857       0.0000000    , d:  0.31847246       0.0000000      0.74074073
 i,j,k,ie:    6    4    4          15
 Near X =  -1.0279153     -0.36139857      0.13437970    , d:   2.0989527       0.0000000      0.74074073
 i,j,k,ie:    1    5    4          15
 Near X = -0.99163854     -0.49632184       0.0000000    , d:  0.38091808       0.0000000      0.74074073
 i,j,k,ie:    6    5    4          15
 Near X = -0.99163854     -0.49632184      0.13437970    , d:   2.0989577       0.0000000      0.74074073
 i,j,k,ie:    1    6    4          15
 Near X = -0.97387569     -0.56238672       0.0000000    , d:   1.5362569       0.0000000      0.74074073
 i,j,k,ie:    2    6    4          15
 Near X = -0.97387569     -0.56238672      0.15785898E-01, d:   1.5362569       0.0000000      0.74074073
 i,j,k,ie:    3    6    4          15
 Near X = -0.97387569     -0.56238672      0.48025188E-01, d:   1.5362569       0.0000000      0.74074073
 i,j,k,ie:    4    6    4          15
 Near X = -0.97387569     -0.56238672      0.86354515E-01, d:   1.5362569       0.0000000      0.74074073
 i,j,k,ie:    5    6    4          15
 Near X = -0.97387569     -0.56238672      0.11859381    , d:   1.5362569       0.0000000      0.74074073
 i,j,k,ie:    6    6    4          15
 Near X = -0.97387569     -0.56238672      0.13437970    , d:   2.0989602       0.0000000      0.74074073
 i,j,k,ie:    1    1    5          15
 Near X =  -1.0411153     -0.25499971E-15   0.0000000    , d:   1.0411152       0.0000000      0.74074073
 i,j,k,ie:    2    1    5          15
 Near X =  -1.0411153     -0.25499971E-15  0.15785898E-01, d:  0.35724624       0.0000000      0.74074073
 i,j,k,ie:    3    1    5          15
 Near X =  -1.0411153     -0.25499971E-15  0.48025188E-01, d:  0.35724624       0.0000000      0.74074073
 i,j,k,ie:    4    1    5          15
 Near X =  -1.0411153     -0.25499971E-15  0.86354515E-01, d:  0.35724624       0.0000000      0.74074073
 i,j,k,ie:    5    1    5          15
 Near X =  -1.0411153     -0.25499971E-15  0.11859381    , d:  0.35724624       0.0000000      0.74074073
 i,j,k,ie:    6    1    5          15
 Near X =  -1.0411153     -0.25499971E-15  0.13437970    , d:   1.9422878     -0.14263559      0.74074073
 i,j,k,ie:    1    2    5          15
 Near X =  -1.0246782     -0.61134219E-01   0.0000000    , d:  0.16821788       0.0000000      0.74074073
 i,j,k,ie:    6    2    5          15
 Near X =  -1.0246782     -0.61134219E-01  0.13437970    , d:   1.9422901       0.0000000      0.74074073
 i,j,k,ie:    1    3    5          15
 Near X = -0.99110886     -0.18598767       0.0000000    , d:  0.22600296       0.0000000      0.74074073
 i,j,k,ie:    6    3    5          15
 Near X = -0.99110886     -0.18598767      0.13437970    , d:   1.9422947       0.0000000      0.74074073
 i,j,k,ie:    1    4    5          15
 Near X = -0.95119826     -0.33442607       0.0000000    , d:  0.29470369       0.0000000      0.74074073
 i,j,k,ie:    6    4    5          15
 Near X = -0.95119826     -0.33442607      0.13437970    , d:   1.9423002       0.0000000      0.74074073
 i,j,k,ie:    1    5    5          15
 Near X = -0.91762893     -0.45927952       0.0000000    , d:  0.35248877       0.0000000      0.74074073
 i,j,k,ie:    6    5    5          15
 Near X = -0.91762893     -0.45927952      0.13437970    , d:   1.9423048       0.0000000      0.74074073
 i,j,k,ie:    1    6    5          15
 Near X = -0.90119179     -0.52041374       0.0000000    , d:   1.4216004       0.0000000      0.74074073
 i,j,k,ie:    2    6    5          15
 Near X = -0.90119179     -0.52041374      0.15785898E-01, d:   1.4216004       0.0000000      0.74074073
 i,j,k,ie:    3    6    5          15
 Near X = -0.90119179     -0.52041374      0.48025188E-01, d:   1.4216004       0.0000000      0.74074073
 i,j,k,ie:    4    6    5          15
 Near X = -0.90119179     -0.52041374      0.86354515E-01, d:   1.4216004       0.0000000      0.74074073
 i,j,k,ie:    5    6    5          15
 Near X = -0.90119179     -0.52041374      0.11859381    , d:   1.4216004       0.0000000      0.74074073
 i,j,k,ie:    6    6    5          15
 Near X = -0.90119179     -0.52041374      0.13437970    , d:   1.9423071       0.0000000      0.74074073
 i,j,k,ie:    1    1    6          15
 Near X =  -1.0000000     -0.24492936E-15   0.0000000    , d:  0.99999985     -0.35000001      0.74074073
 i,j,k,ie:    2    1    6          15
 Near X =  -1.0000000     -0.24492936E-15  0.15785898E-01, d:  0.32519318     -0.35000001      0.74074073
 i,j,k,ie:    3    1    6          15
 Near X =  -1.0000000     -0.24492936E-15  0.48025188E-01, d:  0.32519318     -0.35000001      0.74074073
 i,j,k,ie:    4    1    6          15
 Near X =  -1.0000000     -0.24492936E-15  0.86354515E-01, d:  0.32519318     -0.35000001      0.74074073
 i,j,k,ie:    5    1    6          15
 Near X =  -1.0000000     -0.24492936E-15  0.11859381    , d:  0.32519318     -0.35000001      0.74074073
 i,j,k,ie:    6    1    6          15
 Near X =  -1.0000000     -0.24492936E-15  0.13437970    , d:   2.1685381     -0.35000001      0.74074073
 i,j,k,ie:    1    2    6          15
 Near X = -0.98421199     -0.58719930E-01   0.0000000    , d:  0.16157469     -0.34447421      0.74074073
 i,j,k,ie:    2    2    6          15
 Near X = -0.98421199     -0.58719930E-01  0.15785898E-01, d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    3    2    6          15
 Near X = -0.98421199     -0.58719930E-01  0.48025188E-01, d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    4    2    6          15
 Near X = -0.98421199     -0.58719930E-01  0.86354515E-01, d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    5    2    6          15
 Near X = -0.98421199     -0.58719930E-01  0.11859381    , d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    6    2    6          15
 Near X = -0.98421199     -0.58719930E-01  0.13437970    , d:   2.1740668     -0.34447421      0.74074073
 i,j,k,ie:    1    3    6          15
 Near X = -0.95196838     -0.17864272       0.0000000    , d:  0.21707774     -0.33318894      0.74074073
 i,j,k,ie:    2    3    6          15
 Near X = -0.95196838     -0.17864272      0.15785898E-01, d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    3    3    6          15
 Near X = -0.95196838     -0.17864272      0.48025188E-01, d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    4    3    6          15
 Near X = -0.95196838     -0.17864272      0.86354515E-01, d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    5    3    6          15
 Near X = -0.95196838     -0.17864272      0.11859381    , d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    6    3    6          15
 Near X = -0.95196838     -0.17864272      0.13437970    , d:   2.1853581     -0.33318894      0.74074073
 i,j,k,ie:    1    4    6          15
 Near X = -0.91363391     -0.32121905       0.0000000    , d:  0.28306537     -0.31977188      0.74074073
 i,j,k,ie:    2    4    6          15
 Near X = -0.91363391     -0.32121905      0.15785898E-01, d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    3    4    6          15
 Near X = -0.91363391     -0.32121905      0.48025188E-01, d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    4    4    6          15
 Near X = -0.91363391     -0.32121905      0.86354515E-01, d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    5    4    6          15
 Near X = -0.91363391     -0.32121905      0.11859381    , d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    6    4    6          15
 Near X = -0.91363391     -0.32121905      0.13437970    , d:   2.1987823     -0.31977188      0.74074073
 i,j,k,ie:    1    5    6          15
 Near X = -0.88139029     -0.44114183       0.0000000    , d:  0.33856842     -0.30848661      0.74074073
 i,j,k,ie:    2    5    6          15
 Near X = -0.88139029     -0.44114183      0.15785898E-01, d:   0.0000000     -0.30848661      0.74074073
 i,j,k,ie:    3    5    6          15
 Near X = -0.88139029     -0.44114183      0.48025188E-01, d:   0.0000000     -0.30848661      0.74074073
 i,j,k,ie:    4    5    6          15
 Near X = -0.88139029     -0.44114183      0.86354515E-01, d:   0.0000000     -0.30848661      0.74074073
 i,j,k,ie:    5    5    6          15
 Near X = -0.88139029     -0.44114183      0.11859381    , d:   0.0000000     -0.30848661      0.74074073
 i,j,k,ie:    6    5    6          15
 Near X = -0.88139029     -0.44114183      0.13437970    , d:   2.2100736     -0.30848661      0.74074073
 i,j,k,ie:    1    6    6          15
 Near X = -0.86560227     -0.49986176       0.0000000    , d:   1.5404091     -0.30296080      0.74074073
 i,j,k,ie:    2    6    6          15
 Near X = -0.86560227     -0.49986176      0.15785898E-01, d:   1.5404091     -0.30296080      0.74074073
 i,j,k,ie:    3    6    6          15
 Near X = -0.86560227     -0.49986176      0.48025188E-01, d:   1.5404091     -0.30296080      0.74074073
 i,j,k,ie:    4    6    6          15
 Near X = -0.86560227     -0.49986176      0.86354515E-01, d:   1.5404091     -0.30296080      0.74074073
 i,j,k,ie:    5    6    6          15
 Near X = -0.86560227     -0.49986176      0.11859381    , d:   1.5404091     -0.30296080      0.74074073
 i,j,k,ie:    6    6    6          15
 Near X = -0.86560227     -0.49986176      0.13437970    , d:   2.2156023     -0.30296080      0.74074073
 i,j,k,ie:    1    1    1          16
 Near X =   1.1685381     -0.67480681       0.0000000    , d:   0.0000000      -2.5185381      0.74074073
 i,j,k,ie:    2    1    1          16
 Near X =   1.1685381     -0.67480681      0.15785898E-01, d:   0.0000000      -2.4663898      0.74074073
 i,j,k,ie:    3    1    1          16
 Near X =   1.1685381     -0.67480681      0.48025188E-01, d:   0.0000000      -2.4663898      0.74074073
 i,j,k,ie:    4    1    1          16
 Near X =   1.1685381     -0.67480681      0.86354515E-01, d:   0.0000000      -2.4663898      0.74074073
 i,j,k,ie:    5    1    1          16
 Near X =   1.1685381     -0.67480681      0.11859381    , d:   0.0000000      -2.4663898      0.74074073
 i,j,k,ie:    6    1    1          16
 Near X =   1.1685381     -0.67480681      0.13437970    , d:   0.0000000      -2.4663898      0.74074073
 i,j,k,ie:    1    2    1          16
 Near X =   1.1898548     -0.59553569       0.0000000    , d:   0.0000000      -2.5185410      0.74074073
 i,j,k,ie:    1    3    1          16
 Near X =   1.2333897     -0.43364152       0.0000000    , d:   0.0000000      -2.5185470      0.74074073
 i,j,k,ie:    1    4    1          16
 Near X =   1.2851484     -0.24116537       0.0000000    , d:   0.0000000      -2.5185542      0.74074073
 i,j,k,ie:    1    5    1          16
 Near X =   1.3286833     -0.79271203E-01   0.0000000    , d:   0.0000000      -2.5185602      0.74074073
 i,j,k,ie:    1    6    1          16
 Near X =   1.3500000     -0.77758166E-07   0.0000000    , d:   0.0000000      -2.5185631      0.74074073
 i,j,k,ie:    2    6    1          16
 Near X =   1.3500000     -0.77758166E-07  0.15785898E-01, d:   0.0000000     -0.18143693      0.74074073
 i,j,k,ie:    3    6    1          16
 Near X =   1.3500000     -0.77758166E-07  0.48025188E-01, d:   0.0000000     -0.18143693      0.74074073
 i,j,k,ie:    4    6    1          16
 Near X =   1.3500000     -0.77758166E-07  0.86354515E-01, d:   0.0000000     -0.18143693      0.74074073
 i,j,k,ie:    5    6    1          16
 Near X =   1.3500000     -0.77758166E-07  0.11859381    , d:   0.0000000     -0.18143693      0.74074073
 i,j,k,ie:    6    6    1          16
 Near X =   1.3500000     -0.77758166E-07  0.13437970    , d:   0.0000000     -0.18143693      0.74074073
 i,j,k,ie:    1    1    2          16
 Near X =   1.1329493     -0.65425504       0.0000000    , d:   0.0000000      -2.4418340      0.74074073
 i,j,k,ie:    2    1    2          16
 Near X =   1.1329493     -0.65425504      0.15785898E-01, d:   0.0000000      -2.4156132      0.74074073
 i,j,k,ie:    3    1    2          16
 Near X =   1.1329493     -0.65425504      0.48025188E-01, d:   0.0000000      -2.4156132      0.74074073
 i,j,k,ie:    4    1    2          16
 Near X =   1.1329493     -0.65425504      0.86354515E-01, d:   0.0000000      -2.4156132      0.74074073
 i,j,k,ie:    5    1    2          16
 Near X =   1.1329493     -0.65425504      0.11859381    , d:   0.0000000      -2.4156132      0.74074073
 i,j,k,ie:    6    1    2          16
 Near X =   1.1329493     -0.65425504      0.13437970    , d:   0.0000000      -2.4156132      0.74074073
 i,j,k,ie:    1    2    2          16
 Near X =   1.1536168     -0.57739818       0.0000000    , d:   0.0000000      -2.4418369      0.74074073
 i,j,k,ie:    1    3    2          16
 Near X =   1.1958258     -0.42043462       0.0000000    , d:   0.0000000      -2.4418427      0.74074073
 i,j,k,ie:    1    4    2          16
 Near X =   1.2460082     -0.23382049       0.0000000    , d:   0.0000000      -2.4418496      0.74074073
 i,j,k,ie:    1    5    2          16
 Near X =   1.2882172     -0.76856934E-01   0.0000000    , d:   0.0000000      -2.4418554      0.74074073
 i,j,k,ie:    1    6    2          16
 Near X =   1.3088847     -0.74046641E-07   0.0000000    , d:   0.0000000      -2.4418583      0.74074073
 i,j,k,ie:    2    6    2          16
 Near X =   1.3088847     -0.74046641E-07  0.15785898E-01, d:   0.0000000     -0.17591112      0.74074073
 i,j,k,ie:    3    6    2          16
 Near X =   1.3088847     -0.74046641E-07  0.48025188E-01, d:   0.0000000     -0.17591112      0.74074073
 i,j,k,ie:    4    6    2          16
 Near X =   1.3088847     -0.74046641E-07  0.86354515E-01, d:   0.0000000     -0.17591112      0.74074073
 i,j,k,ie:    5    6    2          16
 Near X =   1.3088847     -0.74046641E-07  0.11859381    , d:   0.0000000     -0.17591112      0.74074073
 i,j,k,ie:    6    6    2          16
 Near X =   1.3088847     -0.74046641E-07  0.13437970    , d:   0.0000000     -0.17591112      0.74074073
 i,j,k,ie:    1    1    3          16
 Near X =   1.0602670     -0.61228247       0.0000000    , d:   0.0000000      -2.3119130      0.74074073
 i,j,k,ie:    2    1    3          16
 Near X =   1.0602670     -0.61228247      0.15785898E-01, d:   0.0000000      -2.3119130      0.74074073
 i,j,k,ie:    3    1    3          16
 Near X =   1.0602670     -0.61228247      0.48025188E-01, d:   0.0000000      -2.3119130      0.74074073
 i,j,k,ie:    4    1    3          16
 Near X =   1.0602670     -0.61228247      0.86354515E-01, d:   0.0000000      -2.3119130      0.74074073
 i,j,k,ie:    5    1    3          16
 Near X =   1.0602670     -0.61228247      0.11859381    , d:   0.0000000      -2.3119130      0.74074073
 i,j,k,ie:    6    1    3          16
 Near X =   1.0602670     -0.61228247      0.13437970    , d:   0.0000000      -2.3119130      0.74074073
 i,j,k,ie:    1    2    3          16
 Near X =   1.0796086     -0.54035622       0.0000000    , d:   0.0000000      -2.2851852      0.74074073
 i,j,k,ie:    1    3    3          16
 Near X =   1.1191098     -0.39346239       0.0000000    , d:   0.0000000      -2.2851906      0.74074073
 i,j,k,ie:    1    4    3          16
 Near X =   1.1660727     -0.21882015       0.0000000    , d:   0.0000000      -2.2851971      0.74074073
 i,j,k,ie:    1    5    3          16
 Near X =   1.2055739     -0.71926312E-01   0.0000000    , d:   0.0000000      -2.2852025      0.74074073
 i,j,k,ie:    1    6    3          16
 Near X =   1.2249155     -0.66466653E-07   0.0000000    , d:   0.0000000      -2.2852052      0.74074073
 i,j,k,ie:    2    6    3          16
 Near X =   1.2249155     -0.66466653E-07  0.15785898E-01, d:   0.0000000     -0.16462586      0.74074073
 i,j,k,ie:    3    6    3          16
 Near X =   1.2249155     -0.66466653E-07  0.48025188E-01, d:   0.0000000     -0.16462586      0.74074073
 i,j,k,ie:    4    6    3          16
 Near X =   1.2249155     -0.66466653E-07  0.86354515E-01, d:   0.0000000     -0.16462586      0.74074073
 i,j,k,ie:    5    6    3          16
 Near X =   1.2249155     -0.66466653E-07  0.11859381    , d:   0.0000000     -0.16462586      0.74074073
 i,j,k,ie:    6    6    3          16
 Near X =   1.2249155     -0.66466653E-07  0.13437970    , d:   0.0000000     -0.16462586      0.74074073
 i,j,k,ie:    1    1    4          16
 Near X =  0.97385484     -0.56238123       0.0000000    , d:   0.0000000      -2.1886237      0.74074073
 i,j,k,ie:    2    1    4          16
 Near X =  0.97385484     -0.56238123      0.15785898E-01, d:   0.0000000      -2.1886237      0.74074073
 i,j,k,ie:    3    1    4          16
 Near X =  0.97385484     -0.56238123      0.48025188E-01, d:   0.0000000      -2.1886237      0.74074073
 i,j,k,ie:    4    1    4          16
 Near X =  0.97385484     -0.56238123      0.86354515E-01, d:   0.0000000      -2.1886237      0.74074073
 i,j,k,ie:    5    1    4          16
 Near X =  0.97385484     -0.56238123      0.11859381    , d:   0.0000000      -2.1886237      0.74074073
 i,j,k,ie:    6    1    4          16
 Near X =  0.97385484     -0.56238123      0.13437970    , d:   0.0000000      -2.1886237      0.74074073
 i,j,k,ie:    1    2    4          16
 Near X =  0.99162014     -0.49631700       0.0000000    , d:   0.0000000      -2.0989418      0.74074073
 i,j,k,ie:    1    3    4          16
 Near X =   1.0279019     -0.36139506       0.0000000    , d:   0.0000000      -2.0989468      0.74074073
 i,j,k,ie:    1    4    4          16
 Near X =   1.0710374     -0.20098623       0.0000000    , d:   0.0000000      -2.0989527      0.74074073
 i,j,k,ie:    1    5    4          16
 Near X =   1.1073192     -0.66064289E-01   0.0000000    , d:   0.0000000      -2.0989577      0.74074073
 i,j,k,ie:    1    6    4          16
 Near X =   1.1250845     -0.57454798E-07   0.0000000    , d:   0.0000000      -2.0989602      0.74074073
 i,j,k,ie:    2    6    4          16
 Near X =   1.1250845     -0.57454798E-07  0.15785898E-01, d:   0.0000000     -0.15120879      0.74074073
 i,j,k,ie:    3    6    4          16
 Near X =   1.1250845     -0.57454798E-07  0.48025188E-01, d:   0.0000000     -0.15120879      0.74074073
 i,j,k,ie:    4    6    4          16
 Near X =   1.1250845     -0.57454798E-07  0.86354515E-01, d:   0.0000000     -0.15120879      0.74074073
 i,j,k,ie:    5    6    4          16
 Near X =   1.1250845     -0.57454798E-07  0.11859381    , d:   0.0000000     -0.15120879      0.74074073
 i,j,k,ie:    6    6    4          16
 Near X =   1.1250845     -0.57454798E-07  0.13437970    , d:   0.0000000     -0.15120879      0.74074073
 i,j,k,ie:    1    1    5          16
 Near X =  0.90117249     -0.52040866       0.0000000    , d:   0.0000000      -2.0849234      0.74074073
 i,j,k,ie:    2    1    5          16
 Near X =  0.90117249     -0.52040866      0.15785898E-01, d:   0.0000000      -2.0849234      0.74074073
 i,j,k,ie:    3    1    5          16
 Near X =  0.90117249     -0.52040866      0.48025188E-01, d:   0.0000000      -2.0849234      0.74074073
 i,j,k,ie:    4    1    5          16
 Near X =  0.90117249     -0.52040866      0.86354515E-01, d:   0.0000000      -2.0849234      0.74074073
 i,j,k,ie:    5    1    5          16
 Near X =  0.90117249     -0.52040866      0.11859381    , d:   0.0000000      -2.0849234      0.74074073
 i,j,k,ie:    6    1    5          16
 Near X =  0.90117249     -0.52040866      0.13437970    , d:   0.0000000      -2.0849234      0.74074073
 i,j,k,ie:    1    2    5          16
 Near X =  0.91761190     -0.45927505       0.0000000    , d:   0.0000000      -1.9422901      0.74074073
 i,j,k,ie:    1    3    5          16
 Near X =  0.95118586     -0.33442283       0.0000000    , d:   0.0000000      -1.9422947      0.74074073
 i,j,k,ie:    1    4    5          16
 Near X =  0.99110196     -0.18598589       0.0000000    , d:   0.0000000      -1.9423002      0.74074073
 i,j,k,ie:    1    5    5          16
 Near X =   1.0246759     -0.61133666E-01   0.0000000    , d:   0.0000000      -1.9423048      0.74074073
 i,j,k,ie:    1    6    5          16
 Near X =   1.0411153     -0.49874810E-07   0.0000000    , d:   0.0000000      -1.9423071      0.74074073
 i,j,k,ie:    2    6    5          16
 Near X =   1.0411153     -0.49874810E-07  0.15785898E-01, d:   0.0000000     -0.13992353      0.74074073
 i,j,k,ie:    3    6    5          16
 Near X =   1.0411153     -0.49874810E-07  0.48025188E-01, d:   0.0000000     -0.13992353      0.74074073
 i,j,k,ie:    4    6    5          16
 Near X =   1.0411153     -0.49874810E-07  0.86354515E-01, d:   0.0000000     -0.13992353      0.74074073
 i,j,k,ie:    5    6    5          16
 Near X =   1.0411153     -0.49874810E-07  0.11859381    , d:   0.0000000     -0.13992353      0.74074073
 i,j,k,ie:    6    6    5          16
 Near X =   1.0411153     -0.49874810E-07  0.13437970    , d:   0.0000000     -0.13992353      0.74074073
 i,j,k,ie:    1    1    6          16
 Near X =  0.86558374     -0.49985689       0.0000000    , d:  0.30295432      -2.2155838      0.74074073
 i,j,k,ie:    2    1    6          16
 Near X =  0.86558374     -0.49985689      0.15785898E-01, d:  0.30295432      -2.1634355      0.74074073
 i,j,k,ie:    3    1    6          16
 Near X =  0.86558374     -0.49985689      0.48025188E-01, d:  0.30295432      -2.1634355      0.74074073
 i,j,k,ie:    4    1    6          16
 Near X =  0.86558374     -0.49985689      0.86354515E-01, d:  0.30295432      -2.1634355      0.74074073
 i,j,k,ie:    5    1    6          16
 Near X =  0.86558374     -0.49985689      0.11859381    , d:  0.30295432      -2.1634355      0.74074073
 i,j,k,ie:    6    1    6          16
 Near X =  0.86558374     -0.49985689      0.13437970    , d:  0.30295432      -2.1634355      0.74074073
 i,j,k,ie:    1    2    6          16
 Near X =  0.88137393     -0.44113754       0.0000000    , d:  0.30848089      -2.2100601      0.74074073
 i,j,k,ie:    2    2    6          16
 Near X =  0.88137393     -0.44113754      0.15785898E-01, d:  0.30848089       0.0000000      0.74074073
 i,j,k,ie:    3    2    6          16
 Near X =  0.88137393     -0.44113754      0.48025188E-01, d:  0.30848089       0.0000000      0.74074073
 i,j,k,ie:    4    2    6          16
 Near X =  0.88137393     -0.44113754      0.86354515E-01, d:  0.30848089       0.0000000      0.74074073
 i,j,k,ie:    5    2    6          16
 Near X =  0.88137393     -0.44113754      0.11859381    , d:  0.30848089       0.0000000      0.74074073
 i,j,k,ie:    6    2    6          16
 Near X =  0.88137393     -0.44113754      0.13437970    , d:  0.30848089       0.0000000      0.74074073
 i,j,k,ie:    1    3    6          16
 Near X =  0.91362200     -0.32121593       0.0000000    , d:  0.31976771      -2.1987793      0.74074073
 i,j,k,ie:    2    3    6          16
 Near X =  0.91362200     -0.32121593      0.15785898E-01, d:  0.31976771       0.0000000      0.74074073
 i,j,k,ie:    3    3    6          16
 Near X =  0.91362200     -0.32121593      0.48025188E-01, d:  0.31976771       0.0000000      0.74074073
 i,j,k,ie:    4    3    6          16
 Near X =  0.91362200     -0.32121593      0.86354515E-01, d:  0.31976771       0.0000000      0.74074073
 i,j,k,ie:    5    3    6          16
 Near X =  0.91362200     -0.32121593      0.11859381    , d:  0.31976771       0.0000000      0.74074073
 i,j,k,ie:    6    3    6          16
 Near X =  0.91362200     -0.32121593      0.13437970    , d:  0.31976771       0.0000000      0.74074073
 i,j,k,ie:    1    4    6          16
 Near X =  0.95196175     -0.17864100       0.0000000    , d:  0.33318662      -2.1853675      0.74074073
 i,j,k,ie:    2    4    6          16
 Near X =  0.95196175     -0.17864100      0.15785898E-01, d:  0.33318662       0.0000000      0.74074073
 i,j,k,ie:    3    4    6          16
 Near X =  0.95196175     -0.17864100      0.48025188E-01, d:  0.33318662       0.0000000      0.74074073
 i,j,k,ie:    4    4    6          16
 Near X =  0.95196175     -0.17864100      0.86354515E-01, d:  0.33318662       0.0000000      0.74074073
 i,j,k,ie:    5    4    6          16
 Near X =  0.95196175     -0.17864100      0.11859381    , d:  0.33318662       0.0000000      0.74074073
 i,j,k,ie:    6    4    6          16
 Near X =  0.95196175     -0.17864100      0.13437970    , d:  0.33318662       0.0000000      0.74074073
 i,j,k,ie:    1    5    6          16
 Near X =  0.98420982     -0.58719398E-01   0.0000000    , d:  0.34447345      -2.1740867      0.74074073
 i,j,k,ie:    2    5    6          16
 Near X =  0.98420982     -0.58719398E-01  0.15785898E-01, d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    3    5    6          16
 Near X =  0.98420982     -0.58719398E-01  0.48025188E-01, d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    4    5    6          16
 Near X =  0.98420982     -0.58719398E-01  0.86354515E-01, d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    5    5    6          16
 Near X =  0.98420982     -0.58719398E-01  0.11859381    , d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    6    5    6          16
 Near X =  0.98420982     -0.58719398E-01  0.13437970    , d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    1    6    6          16
 Near X =   1.0000000     -0.46163286E-07   0.0000000    , d:  0.35000001      -2.1685631      0.74074073
 i,j,k,ie:    2    6    6          16
 Near X =   1.0000000     -0.46163286E-07  0.15785898E-01, d:  0.35000001     -0.13439772      0.74074073
 i,j,k,ie:    3    6    6          16
 Near X =   1.0000000     -0.46163286E-07  0.48025188E-01, d:  0.35000001     -0.13439772      0.74074073
 i,j,k,ie:    4    6    6          16
 Near X =   1.0000000     -0.46163286E-07  0.86354515E-01, d:  0.35000001     -0.13439772      0.74074073
 i,j,k,ie:    5    6    6          16
 Near X =   1.0000000     -0.46163286E-07  0.11859381    , d:  0.35000001     -0.13439772      0.74074073
 i,j,k,ie:    6    6    6          16
 Near X =   1.0000000     -0.46163286E-07  0.13437970    , d:  0.35000001     -0.13439772      0.74074073
 i,j,k,ie:    1    1    1          17
 Near X =  0.67481330      -1.1685631       0.0000000    , d:   0.0000000     -0.67481346      0.85577016
 i,j,k,ie:    2    1    1          17
 Near X =  0.67481330      -1.1685631      0.15785898E-01, d:   0.0000000     -0.67481346      0.85577016
 i,j,k,ie:    3    1    1          17
 Near X =  0.67481330      -1.1685631      0.48025188E-01, d:   0.0000000     -0.67481346      0.85577016
 i,j,k,ie:    4    1    1          17
 Near X =  0.67481330      -1.1685631      0.86354515E-01, d:   0.0000000     -0.67481346      0.85577016
 i,j,k,ie:    5    1    1          17
 Near X =  0.67481330      -1.1685631      0.11859381    , d:   0.0000000     -0.67481346      0.85577016
 i,j,k,ie:    6    1    1          17
 Near X =  0.67481330      -1.1685631      0.13437970    , d:   0.0000000      -1.3496201      0.85577016
 i,j,k,ie:    6    2    1          17
 Near X =  0.73281230      -1.1105604      0.13437970    , d:   0.0000000     -0.65354055      0.85577016
 i,j,k,ie:    6    3    1          17
 Near X =  0.85126275     -0.99210238      0.13437970    , d:   0.0000000     -0.61009521      0.85577016
 i,j,k,ie:    6    4    1          17
 Near X =  0.99208861     -0.85126753      0.13437970    , d:   0.0000000     -0.55844301      0.85577016
 i,j,k,ie:    6    5    1          17
 Near X =   1.1105391     -0.73280952      0.13437970    , d:   0.0000000     -0.51499767      0.85577016
 i,j,k,ie:    1    6    1          17
 Near X =   1.1685381     -0.67480681       0.0000000    , d:  0.18146197       0.0000000      0.85577016
 i,j,k,ie:    2    6    1          17
 Near X =   1.1685381     -0.67480681      0.15785898E-01, d:  0.18146197       0.0000000      0.85577016
 i,j,k,ie:    3    6    1          17
 Near X =   1.1685381     -0.67480681      0.48025188E-01, d:  0.18146197       0.0000000      0.85577016
 i,j,k,ie:    4    6    1          17
 Near X =   1.1685381     -0.67480681      0.86354515E-01, d:  0.18146197       0.0000000      0.85577016
 i,j,k,ie:    5    6    1          17
 Near X =   1.1685381     -0.67480681      0.11859381    , d:  0.18146197       0.0000000      0.85577016
 i,j,k,ie:    6    6    1          17
 Near X =   1.1685381     -0.67480681      0.13437970    , d:  0.18146197      -2.3370762      0.85577016
 i,j,k,ie:    1    1    2          17
 Near X =  0.65426133      -1.1329736       0.0000000    , d:   0.0000000     -0.65426148      0.85577016
 i,j,k,ie:    2    1    2          17
 Near X =  0.65426133      -1.1329736      0.15785898E-01, d:   0.0000000     -0.65426148      0.85577016
 i,j,k,ie:    3    1    2          17
 Near X =  0.65426133      -1.1329736      0.48025188E-01, d:   0.0000000     -0.65426148      0.85577016
 i,j,k,ie:    4    1    2          17
 Near X =  0.65426133      -1.1329736      0.86354515E-01, d:   0.0000000     -0.65426148      0.85577016
 i,j,k,ie:    5    1    2          17
 Near X =  0.65426133      -1.1329736      0.11859381    , d:   0.0000000     -0.65426148      0.85577016
 i,j,k,ie:    6    1    2          17
 Near X =  0.65426133      -1.1329736      0.13437970    , d:   0.0000000      -1.3085164      0.85577016
 i,j,k,ie:    6    2    2          17
 Near X =  0.71049392      -1.0767374      0.13437970    , d:   0.0000000     -0.63363645      0.85577016
 i,j,k,ie:    6    3    2          17
 Near X =  0.82533687     -0.96188711      0.13437970    , d:   0.0000000     -0.59151428      0.85577016
 i,j,k,ie:    6    4    2          17
 Near X =  0.96187377     -0.82534150      0.13437970    , d:   0.0000000     -0.54143518      0.85577016
 i,j,k,ie:    6    5    2          17
 Near X =   1.0767167     -0.71049122      0.13437970    , d:   0.0000000     -0.49931301      0.85577016
 i,j,k,ie:    1    6    2          17
 Near X =   1.1329493     -0.65425504       0.0000000    , d:  0.17593540       0.0000000      0.85577016
 i,j,k,ie:    2    6    2          17
 Near X =   1.1329493     -0.65425504      0.15785898E-01, d:  0.17593540       0.0000000      0.85577016
 i,j,k,ie:    3    6    2          17
 Near X =   1.1329493     -0.65425504      0.48025188E-01, d:  0.17593540       0.0000000      0.85577016
 i,j,k,ie:    4    6    2          17
 Near X =   1.1329493     -0.65425504      0.86354515E-01, d:  0.17593540       0.0000000      0.85577016
 i,j,k,ie:    5    6    2          17
 Near X =   1.1329493     -0.65425504      0.11859381    , d:  0.17593540       0.0000000      0.85577016
 i,j,k,ie:    6    6    2          17
 Near X =   1.1329493     -0.65425504      0.13437970    , d:  0.17593540      -2.2658987      0.85577016
 i,j,k,ie:    1    1    3          17
 Near X =  0.61228836      -1.0602897       0.0000000    , d:   0.0000000     -0.61228850      0.85577016
 i,j,k,ie:    2    1    3          17
 Near X =  0.61228836      -1.0602897      0.15785898E-01, d:   0.0000000     -0.61228850      0.85577016
 i,j,k,ie:    3    1    3          17
 Near X =  0.61228836      -1.0602897      0.48025188E-01, d:   0.0000000     -0.61228850      0.85577016
 i,j,k,ie:    4    1    3          17
 Near X =  0.61228836      -1.0602897      0.86354515E-01, d:   0.0000000     -0.61228850      0.85577016
 i,j,k,ie:    5    1    3          17
 Near X =  0.61228836      -1.0602897      0.11859381    , d:   0.0000000     -0.61228850      0.85577016
 i,j,k,ie:    6    1    3          17
 Near X =  0.61228836      -1.0602897      0.13437970    , d:   0.0000000      -1.2245708      0.85577016
 i,j,k,ie:    6    2    3          17
 Near X =  0.66491345      -1.0076612      0.13437970    , d:   0.0000000     -0.59298663      0.85577016
 i,j,k,ie:    6    3    3          17
 Near X =  0.77238885     -0.90017896      0.13437970    , d:   0.0000000     -0.55356673      0.85577016
 i,j,k,ie:    6    4    3          17
 Near X =  0.90016647     -0.77239318      0.13437970    , d:   0.0000000     -0.50670037      0.85577016
 i,j,k,ie:    6    5    3          17
 Near X =   1.0076419     -0.66491092      0.13437970    , d:   0.0000000     -0.46728047      0.85577016
 i,j,k,ie:    1    6    3          17
 Near X =   1.0602670     -0.61228247       0.0000000    , d:  0.16464857       0.0000000      0.85577016
 i,j,k,ie:    2    6    3          17
 Near X =   1.0602670     -0.61228247      0.15785898E-01, d:  0.16464857       0.0000000      0.85577016
 i,j,k,ie:    3    6    3          17
 Near X =   1.0602670     -0.61228247      0.48025188E-01, d:  0.16464857       0.0000000      0.85577016
 i,j,k,ie:    4    6    3          17
 Near X =   1.0602670     -0.61228247      0.86354515E-01, d:  0.16464857       0.0000000      0.85577016
 i,j,k,ie:    5    6    3          17
 Near X =   1.0602670     -0.61228247      0.11859381    , d:  0.16464857       0.0000000      0.85577016
 i,j,k,ie:    6    6    3          17
 Near X =   1.0602670     -0.61228247      0.13437970    , d:  0.16464857      -2.1205340      0.85577016
 i,j,k,ie:    1    1    4          17
 Near X =  0.56238665     -0.97387570       0.0000000    , d:   0.0000000     -0.56238678      0.85577016
 i,j,k,ie:    2    1    4          17
 Near X =  0.56238665     -0.97387570      0.15785898E-01, d:   0.0000000     -0.56238678      0.85577016
 i,j,k,ie:    3    1    4          17
 Near X =  0.56238665     -0.97387570      0.48025188E-01, d:   0.0000000     -0.56238678      0.85577016
 i,j,k,ie:    4    1    4          17
 Near X =  0.56238665     -0.97387570      0.86354515E-01, d:   0.0000000     -0.56238678      0.85577016
 i,j,k,ie:    5    1    4          17
 Near X =  0.56238665     -0.97387570      0.11859381    , d:   0.0000000     -0.56238678      0.85577016
 i,j,k,ie:    6    1    4          17
 Near X =  0.56238665     -0.97387570      0.13437970    , d:   0.0000000      -1.1247679      0.85577016
 i,j,k,ie:    6    2    4          17
 Near X =  0.61072278     -0.92553648      0.13437970    , d:   0.0000000     -0.54465802      0.85577016
 i,j,k,ie:    6    3    4          17
 Near X =  0.70943889     -0.82681406      0.13437970    , d:   0.0000000     -0.50845085      0.85577016
 i,j,k,ie:    6    4    4          17
 Near X =  0.82680259     -0.70944287      0.13437970    , d:   0.0000000     -0.46540412      0.85577016
 i,j,k,ie:    6    5    4          17
 Near X =  0.92551871     -0.61072045      0.13437970    , d:   0.0000000     -0.42919695      0.85577016
 i,j,k,ie:    1    6    4          17
 Near X =  0.97385484     -0.56238123       0.0000000    , d:  0.15122966       0.0000000      0.85577016
 i,j,k,ie:    2    6    4          17
 Near X =  0.97385484     -0.56238123      0.15785898E-01, d:  0.15122966       0.0000000      0.85577016
 i,j,k,ie:    3    6    4          17
 Near X =  0.97385484     -0.56238123      0.48025188E-01, d:  0.15122966       0.0000000      0.85577016
 i,j,k,ie:    4    6    4          17
 Near X =  0.97385484     -0.56238123      0.86354515E-01, d:  0.15122966       0.0000000      0.85577016
 i,j,k,ie:    5    6    4          17
 Near X =  0.97385484     -0.56238123      0.11859381    , d:  0.15122966       0.0000000      0.85577016
 i,j,k,ie:    6    6    4          17
 Near X =  0.97385484     -0.56238123      0.13437970    , d:  0.15122966      -1.9477097      0.85577016
 i,j,k,ie:    1    1    5          17
 Near X =  0.52041367     -0.90119179       0.0000000    , d:   0.0000000     -0.52041380      0.85577016
 i,j,k,ie:    2    1    5          17
 Near X =  0.52041367     -0.90119179      0.15785898E-01, d:   0.0000000     -0.52041380      0.85577016
 i,j,k,ie:    3    1    5          17
 Near X =  0.52041367     -0.90119179      0.48025188E-01, d:   0.0000000     -0.52041380      0.85577016
 i,j,k,ie:    4    1    5          17
 Near X =  0.52041367     -0.90119179      0.86354515E-01, d:   0.0000000     -0.52041380      0.85577016
 i,j,k,ie:    5    1    5          17
 Near X =  0.52041367     -0.90119179      0.11859381    , d:   0.0000000     -0.52041380      0.85577016
 i,j,k,ie:    6    1    5          17
 Near X =  0.52041367     -0.90119179      0.13437970    , d:   0.0000000      -1.0408224      0.85577016
 i,j,k,ie:    6    2    5          17
 Near X =  0.56514230     -0.85646031      0.13437970    , d:   0.0000000     -0.50400820      0.85577016
 i,j,k,ie:    6    3    5          17
 Near X =  0.65649088     -0.76510590      0.13437970    , d:   0.0000000     -0.47050331      0.85577016
 i,j,k,ie:    6    4    5          17
 Near X =  0.76509529     -0.65649455      0.13437970    , d:   0.0000000     -0.43066931      0.85577016
 i,j,k,ie:    6    5    5          17
 Near X =  0.85644386     -0.56514015      0.13437970    , d:   0.0000000     -0.39716442      0.85577016
 i,j,k,ie:    1    6    5          17
 Near X =  0.90117249     -0.52040866       0.0000000    , d:  0.13994284       0.0000000      0.85577016
 i,j,k,ie:    2    6    5          17
 Near X =  0.90117249     -0.52040866      0.15785898E-01, d:  0.13994284       0.0000000      0.85577016
 i,j,k,ie:    3    6    5          17
 Near X =  0.90117249     -0.52040866      0.48025188E-01, d:  0.13994284       0.0000000      0.85577016
 i,j,k,ie:    4    6    5          17
 Near X =  0.90117249     -0.52040866      0.86354515E-01, d:  0.13994284       0.0000000      0.85577016
 i,j,k,ie:    5    6    5          17
 Near X =  0.90117249     -0.52040866      0.11859381    , d:  0.13994284       0.0000000      0.85577016
 i,j,k,ie:    6    6    5          17
 Near X =  0.90117249     -0.52040866      0.13437970    , d:  0.13994284      -1.8023450      0.85577016
 i,j,k,ie:    1    1    6          17
 Near X =  0.49986170     -0.86560228       0.0000000    , d:  0.17495160     -0.49986186      0.85577016
 i,j,k,ie:    2    1    6          17
 Near X =  0.49986170     -0.86560228      0.15785898E-01, d:  0.17495160     -0.49986186      0.85577016
 i,j,k,ie:    3    1    6          17
 Near X =  0.49986170     -0.86560228      0.48025188E-01, d:  0.17495160     -0.49986186      0.85577016
 i,j,k,ie:    4    1    6          17
 Near X =  0.49986170     -0.86560228      0.86354515E-01, d:  0.17495160     -0.49986186      0.85577016
 i,j,k,ie:    5    1    6          17
 Near X =  0.49986170     -0.86560228      0.11859381    , d:  0.17495160     -0.49986186      0.85577016
 i,j,k,ie:    6    1    6          17
 Near X =  0.49986170     -0.86560228      0.13437970    , d:  0.17495160      -1.1746685      0.85577016
 i,j,k,ie:    1    2    6          17
 Near X =  0.54282392     -0.82263731       0.0000000    , d:  0.18998838       0.0000000      0.85577016
 i,j,k,ie:    2    2    6          17
 Near X =  0.54282392     -0.82263731      0.15785898E-01, d:  0.18998838       0.0000000      0.85577016
 i,j,k,ie:    3    2    6          17
 Near X =  0.54282392     -0.82263731      0.48025188E-01, d:  0.18998838       0.0000000      0.85577016
 i,j,k,ie:    4    2    6          17
 Near X =  0.54282392     -0.82263731      0.86354515E-01, d:  0.18998838       0.0000000      0.85577016
 i,j,k,ie:    5    2    6          17
 Near X =  0.54282392     -0.82263731      0.11859381    , d:  0.18998838       0.0000000      0.85577016
 i,j,k,ie:    6    2    6          17
 Near X =  0.54282392     -0.82263731      0.13437970    , d:  0.18998838     -0.48410410      0.85577016
 i,j,k,ie:    1    3    6          17
 Near X =  0.63056499     -0.73489064       0.0000000    , d:  0.22069775       0.0000000      0.85577016
 i,j,k,ie:    2    3    6          17
 Near X =  0.63056499     -0.73489064      0.15785898E-01, d:  0.22069775       0.0000000      0.85577016
 i,j,k,ie:    3    3    6          17
 Near X =  0.63056499     -0.73489064      0.48025188E-01, d:  0.22069775       0.0000000      0.85577016
 i,j,k,ie:    4    3    6          17
 Near X =  0.63056499     -0.73489064      0.86354515E-01, d:  0.22069775       0.0000000      0.85577016
 i,j,k,ie:    5    3    6          17
 Near X =  0.63056499     -0.73489064      0.11859381    , d:  0.22069775       0.0000000      0.85577016
 i,j,k,ie:    6    3    6          17
 Near X =  0.63056499     -0.73489064      0.13437970    , d:  0.22069775     -0.45192238      0.85577016
 i,j,k,ie:    1    4    6          17
 Near X =  0.73488045     -0.63056853       0.0000000    , d:  0.25720816       0.0000000      0.85577016
 i,j,k,ie:    2    4    6          17
 Near X =  0.73488045     -0.63056853      0.15785898E-01, d:  0.25720816       0.0000000      0.85577016
 i,j,k,ie:    3    4    6          17
 Near X =  0.73488045     -0.63056853      0.48025188E-01, d:  0.25720816       0.0000000      0.85577016
 i,j,k,ie:    4    4    6          17
 Near X =  0.73488045     -0.63056853      0.86354515E-01, d:  0.25720816       0.0000000      0.85577016
 i,j,k,ie:    5    4    6          17
 Near X =  0.73488045     -0.63056853      0.11859381    , d:  0.25720816       0.0000000      0.85577016
 i,j,k,ie:    6    4    6          17
 Near X =  0.73488045     -0.63056853      0.13437970    , d:  0.25720816     -0.41366148      0.85577016
 i,j,k,ie:    1    5    6          17
 Near X =  0.82262152     -0.54282185       0.0000000    , d:  0.28791754       0.0000000      0.85577016
 i,j,k,ie:    2    5    6          17
 Near X =  0.82262152     -0.54282185      0.15785898E-01, d:  0.28791754       0.0000000      0.85577016
 i,j,k,ie:    3    5    6          17
 Near X =  0.82262152     -0.54282185      0.48025188E-01, d:  0.28791754       0.0000000      0.85577016
 i,j,k,ie:    4    5    6          17
 Near X =  0.82262152     -0.54282185      0.86354515E-01, d:  0.28791754       0.0000000      0.85577016
 i,j,k,ie:    5    5    6          17
 Near X =  0.82262152     -0.54282185      0.11859381    , d:  0.28791754       0.0000000      0.85577016
 i,j,k,ie:    6    5    6          17
 Near X =  0.82262152     -0.54282185      0.13437970    , d:  0.28791754     -0.38147975      0.85577016
 i,j,k,ie:    1    6    6          17
 Near X =  0.86558374     -0.49985689       0.0000000    , d:  0.48441628       0.0000000      0.85577016
 i,j,k,ie:    2    6    6          17
 Near X =  0.86558374     -0.49985689      0.15785898E-01, d:  0.48441628       0.0000000      0.85577016
 i,j,k,ie:    3    6    6          17
 Near X =  0.86558374     -0.49985689      0.48025188E-01, d:  0.48441628       0.0000000      0.85577016
 i,j,k,ie:    4    6    6          17
 Near X =  0.86558374     -0.49985689      0.86354515E-01, d:  0.48441628       0.0000000      0.85577016
 i,j,k,ie:    5    6    6          17
 Near X =  0.86558374     -0.49985689      0.11859381    , d:  0.48441628       0.0000000      0.85577016
 i,j,k,ie:    6    6    6          17
 Near X =  0.86558374     -0.49985689      0.13437970    , d:  0.48441628      -2.0341218      0.85577016
 i,j,k,ie:    1    1    1          18
 Near X = -0.15931032E-06  -1.3500000       0.0000000    , d:  0.67481346     -0.67480667       1.4818910
 i,j,k,ie:    2    1    1          18
 Near X = -0.15931032E-06  -1.3500000      0.15785898E-01, d:   0.0000000     -0.67480667       1.4818910
 i,j,k,ie:    3    1    1          18
 Near X = -0.15931032E-06  -1.3500000      0.48025188E-01, d:   0.0000000     -0.67480667       1.4818910
 i,j,k,ie:    4    1    1          18
 Near X = -0.15931032E-06  -1.3500000      0.86354515E-01, d:   0.0000000     -0.67480667       1.4818910
 i,j,k,ie:    5    1    1          18
 Near X = -0.15931032E-06  -1.3500000      0.11859381    , d:   0.0000000     -0.67480667       1.4818910
 i,j,k,ie:    6    1    1          18
 Near X = -0.15931032E-06  -1.3500000      0.13437970    , d:  0.67480695      -1.1685629       1.4818910
 i,j,k,ie:    1    2    1          18
 Near X =  0.79271756E-01  -1.3286862       0.0000000    , d:  0.65354055       0.0000000       1.4818910
 i,j,k,ie:    6    2    1          18
 Near X =  0.79271756E-01  -1.3286862      0.13437970    , d:  0.51626391       0.0000000       1.4818910
 i,j,k,ie:    1    3    1          18
 Near X =  0.24116754      -1.2851573       0.0000000    , d:  0.61009521       0.0000000       1.4818910
 i,j,k,ie:    6    3    1          18
 Near X =  0.24116754      -1.2851573      0.13437970    , d:  0.19247396       0.0000000       1.4818910
 i,j,k,ie:    1    4    1          18
 Near X =  0.43364560      -1.2334058       0.0000000    , d:  0.55844301       0.0000000       1.4818910
 i,j,k,ie:    6    4    1          18
 Near X =  0.43364560      -1.2334058      0.13437970    , d:   0.0000000     -0.19248026       1.4818910
 i,j,k,ie:    1    5    1          18
 Near X =  0.59554139      -1.1898769       0.0000000    , d:  0.51499767       0.0000000       1.4818910
 i,j,k,ie:    6    5    1          18
 Near X =  0.59554139      -1.1898769      0.13437970    , d:   0.0000000     -0.51627021       1.4818910
 i,j,k,ie:    1    6    1          18
 Near X =  0.67481330      -1.1685631       0.0000000    , d:  0.67518672      -1.8433514       1.4818910
 i,j,k,ie:    2    6    1          18
 Near X =  0.67481330      -1.1685631      0.15785898E-01, d:   0.0000000      -1.8433514       1.4818910
 i,j,k,ie:    3    6    1          18
 Near X =  0.67481330      -1.1685631      0.48025188E-01, d:   0.0000000      -1.8433514       1.4818910
 i,j,k,ie:    4    6    1          18
 Near X =  0.67481330      -1.1685631      0.86354515E-01, d:   0.0000000      -1.8433514       1.4818910
 i,j,k,ie:    5    6    1          18
 Near X =  0.67481330      -1.1685631      0.11859381    , d:   0.0000000      -1.8433514       1.4818910
 i,j,k,ie:    6    6    1          18
 Near X =  0.67481330      -1.1685631      0.13437970    , d:   0.0000000      -1.8433514       1.4818910
 i,j,k,ie:    1    1    2          18
 Near X = -0.15445840E-06  -1.3088847       0.0000000    , d:  0.65426148     -0.65425489       1.4818910
 i,j,k,ie:    2    1    2          18
 Near X = -0.15445840E-06  -1.3088847      0.15785898E-01, d:   0.0000000     -0.65425489       1.4818910
 i,j,k,ie:    3    1    2          18
 Near X = -0.15445840E-06  -1.3088847      0.48025188E-01, d:   0.0000000     -0.65425489       1.4818910
 i,j,k,ie:    4    1    2          18
 Near X = -0.15445840E-06  -1.3088847      0.86354515E-01, d:   0.0000000     -0.65425489       1.4818910
 i,j,k,ie:    5    1    2          18
 Near X = -0.15445840E-06  -1.3088847      0.11859381    , d:   0.0000000     -0.65425489       1.4818910
 i,j,k,ie:    6    1    2          18
 Near X = -0.15445840E-06  -1.3088847      0.13437970    , d:  0.65425517      -1.1329734       1.4818910
 i,j,k,ie:    1    2    2          18
 Near X =  0.76857471E-01  -1.2882200       0.0000000    , d:  0.63363645       0.0000000       1.4818910
 i,j,k,ie:    6    2    2          18
 Near X =  0.76857471E-01  -1.2882200      0.13437970    , d:  0.50054068       0.0000000       1.4818910
 i,j,k,ie:    1    3    2          18
 Near X =  0.23382259      -1.2460168       0.0000000    , d:  0.59151428       0.0000000       1.4818910
 i,j,k,ie:    6    3    2          18
 Near X =  0.23382259      -1.2460168      0.13437970    , d:  0.18661201       0.0000000       1.4818910
 i,j,k,ie:    1    4    2          18
 Near X =  0.42043858      -1.1958414       0.0000000    , d:  0.54143518       0.0000000       1.4818910
 i,j,k,ie:    6    4    2          18
 Near X =  0.42043858      -1.1958414      0.13437970    , d:   0.0000000     -0.18661812       1.4818910
 i,j,k,ie:    1    5    2          18
 Near X =  0.57740370      -1.1536383       0.0000000    , d:  0.49931301       0.0000000       1.4818910
 i,j,k,ie:    6    5    2          18
 Near X =  0.57740370      -1.1536383      0.13437970    , d:   0.0000000     -0.50054679       1.4818910
 i,j,k,ie:    1    6    2          18
 Near X =  0.65426133      -1.1329736       0.0000000    , d:  0.65462338      -1.7872107       1.4818910
 i,j,k,ie:    2    6    2          18
 Near X =  0.65426133      -1.1329736      0.15785898E-01, d:   0.0000000      -1.7872107       1.4818910
 i,j,k,ie:    3    6    2          18
 Near X =  0.65426133      -1.1329736      0.48025188E-01, d:   0.0000000      -1.7872107       1.4818910
 i,j,k,ie:    4    6    2          18
 Near X =  0.65426133      -1.1329736      0.86354515E-01, d:   0.0000000      -1.7872107       1.4818910
 i,j,k,ie:    5    6    2          18
 Near X =  0.65426133      -1.1329736      0.11859381    , d:   0.0000000      -1.7872107       1.4818910
 i,j,k,ie:    6    6    2          18
 Near X =  0.65426133      -1.1329736      0.13437970    , d:   0.0000000      -1.7872107       1.4818910
 i,j,k,ie:    1    1    3          18
 Near X = -0.14454939E-06  -1.2249155       0.0000000    , d:  0.61228850     -0.61228234       1.4818910
 i,j,k,ie:    2    1    3          18
 Near X = -0.14454939E-06  -1.2249155      0.15785898E-01, d:   0.0000000     -0.61228234       1.4818910
 i,j,k,ie:    3    1    3          18
 Near X = -0.14454939E-06  -1.2249155      0.48025188E-01, d:   0.0000000     -0.61228234       1.4818910
 i,j,k,ie:    4    1    3          18
 Near X = -0.14454939E-06  -1.2249155      0.86354515E-01, d:   0.0000000     -0.61228234       1.4818910
 i,j,k,ie:    5    1    3          18
 Near X = -0.14454939E-06  -1.2249155      0.11859381    , d:   0.0000000     -0.61228234       1.4818910
 i,j,k,ie:    6    1    3          18
 Near X = -0.14454939E-06  -1.2249155      0.13437970    , d:  0.61228259      -1.0602895       1.4818910
 i,j,k,ie:    1    2    3          18
 Near X =  0.71926817E-01  -1.2055765       0.0000000    , d:  0.59298663       0.0000000       1.4818910
 i,j,k,ie:    6    2    3          18
 Near X =  0.71926817E-01  -1.2055765      0.13437970    , d:  0.46842939       0.0000000       1.4818910
 i,j,k,ie:    1    3    3          18
 Near X =  0.21882212      -1.1660808       0.0000000    , d:  0.55356673       0.0000000       1.4818910
 i,j,k,ie:    6    3    3          18
 Near X =  0.21882212      -1.1660808      0.13437970    , d:  0.17464025       0.0000000       1.4818910
 i,j,k,ie:    1    4    3          18
 Near X =  0.39346609      -1.1191244       0.0000000    , d:  0.50670037       0.0000000       1.4818910
 i,j,k,ie:    6    4    3          18
 Near X =  0.39346609      -1.1191244      0.13437970    , d:   0.0000000     -0.17464597       1.4818910
 i,j,k,ie:    1    5    3          18
 Near X =  0.54036139      -1.0796287       0.0000000    , d:  0.46728047       0.0000000       1.4818910
 i,j,k,ie:    6    5    3          18
 Near X =  0.54036139      -1.0796287      0.13437970    , d:   0.0000000     -0.46843510       1.4818910
 i,j,k,ie:    1    6    3          18
 Near X =  0.61228836      -1.0602897       0.0000000    , d:  0.61262718      -1.6725554       1.4818910
 i,j,k,ie:    2    6    3          18
 Near X =  0.61228836      -1.0602897      0.15785898E-01, d:   0.0000000      -1.6725554       1.4818910
 i,j,k,ie:    3    6    3          18
 Near X =  0.61228836      -1.0602897      0.48025188E-01, d:   0.0000000      -1.6725554       1.4818910
 i,j,k,ie:    4    6    3          18
 Near X =  0.61228836      -1.0602897      0.86354515E-01, d:   0.0000000      -1.6725554       1.4818910
 i,j,k,ie:    5    6    3          18
 Near X =  0.61228836      -1.0602897      0.11859381    , d:   0.0000000      -1.6725554       1.4818910
 i,j,k,ie:    6    6    3          18
 Near X =  0.61228836      -1.0602897      0.13437970    , d:   0.0000000      -1.6725554       1.4818910
 i,j,k,ie:    1    1    4          18
 Near X = -0.13276857E-06  -1.1250845       0.0000000    , d:  0.56238678     -0.56238112       1.4818910
 i,j,k,ie:    2    1    4          18
 Near X = -0.13276857E-06  -1.1250845      0.15785898E-01, d:   0.0000000     -0.56238112       1.4818910
 i,j,k,ie:    3    1    4          18
 Near X = -0.13276857E-06  -1.1250845      0.48025188E-01, d:   0.0000000     -0.56238112       1.4818910
 i,j,k,ie:    4    1    4          18
 Near X = -0.13276857E-06  -1.1250845      0.86354515E-01, d:   0.0000000     -0.56238112       1.4818910
 i,j,k,ie:    5    1    4          18
 Near X = -0.13276857E-06  -1.1250845      0.11859381    , d:   0.0000000     -0.56238112       1.4818910
 i,j,k,ie:    6    1    4          18
 Near X = -0.13276857E-06  -1.1250845      0.13437970    , d:  0.56238135     -0.97387556       1.4818910
 i,j,k,ie:    1    2    4          18
 Near X =  0.66064757E-01  -1.1073216       0.0000000    , d:  0.54465802       0.0000000       1.4818910
 i,j,k,ie:    6    2    4          18
 Near X =  0.66064757E-01  -1.1073216      0.13437970    , d:  0.43025223       0.0000000       1.4818910
 i,j,k,ie:    1    3    4          18
 Near X =  0.20098804      -1.0710449       0.0000000    , d:  0.50845085       0.0000000       1.4818910
 i,j,k,ie:    6    3    4          18
 Near X =  0.20098804      -1.0710449      0.13437970    , d:  0.16040701       0.0000000       1.4818910
 i,j,k,ie:    1    4    4          18
 Near X =  0.36139847      -1.0279153       0.0000000    , d:  0.46540412       0.0000000       1.4818910
 i,j,k,ie:    6    4    4          18
 Near X =  0.36139847      -1.0279153      0.13437970    , d:   0.0000000     -0.16041226       1.4818910
 i,j,k,ie:    1    5    4          18
 Near X =  0.49632176     -0.99163855       0.0000000    , d:  0.42919695       0.0000000       1.4818910
 i,j,k,ie:    6    5    4          18
 Near X =  0.49632176     -0.99163855      0.13437970    , d:   0.0000000     -0.43025748       1.4818910
 i,j,k,ie:    1    6    4          18
 Near X =  0.56238665     -0.97387570       0.0000000    , d:  0.56269785      -1.5362415       1.4818910
 i,j,k,ie:    2    6    4          18
 Near X =  0.56238665     -0.97387570      0.15785898E-01, d:   0.0000000      -1.5362415       1.4818910
 i,j,k,ie:    3    6    4          18
 Near X =  0.56238665     -0.97387570      0.48025188E-01, d:   0.0000000      -1.5362415       1.4818910
 i,j,k,ie:    4    6    4          18
 Near X =  0.56238665     -0.97387570      0.86354515E-01, d:   0.0000000      -1.5362415       1.4818910
 i,j,k,ie:    5    6    4          18
 Near X =  0.56238665     -0.97387570      0.11859381    , d:   0.0000000      -1.5362415       1.4818910
 i,j,k,ie:    6    6    4          18
 Near X =  0.56238665     -0.97387570      0.13437970    , d:   0.0000000      -1.5362415       1.4818910
 i,j,k,ie:    1    1    5          18
 Near X = -0.12285956E-06  -1.0411153       0.0000000    , d:  0.52041380     -0.52040856       1.4818910
 i,j,k,ie:    2    1    5          18
 Near X = -0.12285956E-06  -1.0411153      0.15785898E-01, d:   0.0000000     -0.52040856       1.4818910
 i,j,k,ie:    3    1    5          18
 Near X = -0.12285956E-06  -1.0411153      0.48025188E-01, d:   0.0000000     -0.52040856       1.4818910
 i,j,k,ie:    4    1    5          18
 Near X = -0.12285956E-06  -1.0411153      0.86354515E-01, d:   0.0000000     -0.52040856       1.4818910
 i,j,k,ie:    5    1    5          18
 Near X = -0.12285956E-06  -1.0411153      0.11859381    , d:   0.0000000     -0.52040856       1.4818910
 i,j,k,ie:    6    1    5          18
 Near X = -0.12285956E-06  -1.0411153      0.13437970    , d:  0.52040877     -0.90119166       1.4818910
 i,j,k,ie:    1    2    5          18
 Near X =  0.61134103E-01  -1.0246782       0.0000000    , d:  0.50400820       0.0000000       1.4818910
 i,j,k,ie:    6    2    5          18
 Near X =  0.61134103E-01  -1.0246782      0.13437970    , d:  0.39814093       0.0000000       1.4818910
 i,j,k,ie:    1    3    5          18
 Near X =  0.18598757     -0.99110886       0.0000000    , d:  0.47050331       0.0000000       1.4818910
 i,j,k,ie:    6    3    5          18
 Near X =  0.18598757     -0.99110886      0.13437970    , d:  0.14843525       0.0000000       1.4818910
 i,j,k,ie:    1    4    5          18
 Near X =  0.33442598     -0.95119826       0.0000000    , d:  0.43066931       0.0000000       1.4818910
 i,j,k,ie:    6    4    5          18
 Near X =  0.33442598     -0.95119826      0.13437970    , d:   0.0000000     -0.14844011       1.4818910
 i,j,k,ie:    1    5    5          18
 Near X =  0.45927945     -0.91762894       0.0000000    , d:  0.39716442       0.0000000       1.4818910
 i,j,k,ie:    6    5    5          18
 Near X =  0.45927945     -0.91762894      0.13437970    , d:   0.0000000     -0.39814579       1.4818910
 i,j,k,ie:    1    6    5          18
 Near X =  0.52041367     -0.90119179       0.0000000    , d:  0.52070166      -1.4215862       1.4818910
 i,j,k,ie:    2    6    5          18
 Near X =  0.52041367     -0.90119179      0.15785898E-01, d:   0.0000000      -1.4215862       1.4818910
 i,j,k,ie:    3    6    5          18
 Near X =  0.52041367     -0.90119179      0.48025188E-01, d:   0.0000000      -1.4215862       1.4818910
 i,j,k,ie:    4    6    5          18
 Near X =  0.52041367     -0.90119179      0.86354515E-01, d:   0.0000000      -1.4215862       1.4818910
 i,j,k,ie:    5    6    5          18
 Near X =  0.52041367     -0.90119179      0.11859381    , d:   0.0000000      -1.4215862       1.4818910
 i,j,k,ie:    6    6    5          18
 Near X =  0.52041367     -0.90119179      0.13437970    , d:   0.0000000      -1.4215862       1.4818910
 i,j,k,ie:    1    1    6          18
 Near X = -0.11800764E-06  -1.0000000       0.0000000    , d:  0.67481342     -0.67480671       1.4818910
 i,j,k,ie:    2    1    6          18
 Near X = -0.11800764E-06  -1.0000000      0.15785898E-01, d:   0.0000000     -0.67480671       1.4818910
 i,j,k,ie:    3    1    6          18
 Near X = -0.11800764E-06  -1.0000000      0.48025188E-01, d:   0.0000000     -0.67480671       1.4818910
 i,j,k,ie:    4    1    6          18
 Near X = -0.11800764E-06  -1.0000000      0.86354515E-01, d:   0.0000000     -0.67480671       1.4818910
 i,j,k,ie:    5    1    6          18
 Near X = -0.11800764E-06  -1.0000000      0.11859381    , d:   0.0000000     -0.67480671       1.4818910
 i,j,k,ie:    6    1    6          18
 Near X = -0.11800764E-06  -1.0000000      0.13437970    , d:  0.67480691      -1.1685630       1.4818910
 i,j,k,ie:    1    2    6          18
 Near X =  0.58719818E-01 -0.98421199       0.0000000    , d:  0.67409248       0.0000000       1.4818910
 i,j,k,ie:    2    2    6          18
 Near X =  0.58719818E-01 -0.98421199      0.15785898E-01, d:  0.20551937E-01   0.0000000       1.4818910
 i,j,k,ie:    3    2    6          18
 Near X =  0.58719818E-01 -0.98421199      0.48025188E-01, d:  0.20551937E-01   0.0000000       1.4818910
 i,j,k,ie:    4    2    6          18
 Near X =  0.58719818E-01 -0.98421199      0.86354515E-01, d:  0.20551937E-01   0.0000000       1.4818910
 i,j,k,ie:    5    2    6          18
 Near X =  0.58719818E-01 -0.98421199      0.11859381    , d:  0.20551937E-01   0.0000000       1.4818910
 i,j,k,ie:    6    2    6          18
 Near X =  0.58719818E-01 -0.98421199      0.13437970    , d:  0.53681585       0.0000000       1.4818910
 i,j,k,ie:    1    3    6          18
 Near X =  0.17864262     -0.95196838       0.0000000    , d:  0.67262013       0.0000000       1.4818910
 i,j,k,ie:    2    3    6          18
 Near X =  0.17864262     -0.95196838      0.15785898E-01, d:  0.62524919E-01   0.0000000       1.4818910
 i,j,k,ie:    3    3    6          18
 Near X =  0.17864262     -0.95196838      0.48025188E-01, d:  0.62524919E-01   0.0000000       1.4818910
 i,j,k,ie:    4    3    6          18
 Near X =  0.17864262     -0.95196838      0.86354515E-01, d:  0.62524919E-01   0.0000000       1.4818910
 i,j,k,ie:    5    3    6          18
 Near X =  0.17864262     -0.95196838      0.11859381    , d:  0.62524919E-01   0.0000000       1.4818910
 i,j,k,ie:    6    3    6          18
 Near X =  0.17864262     -0.95196838      0.13437970    , d:  0.25499888       0.0000000       1.4818910
 i,j,k,ie:    1    4    6          18
 Near X =  0.32121896     -0.91363391       0.0000000    , d:  0.67086965       0.0000000       1.4818910
 i,j,k,ie:    2    4    6          18
 Near X =  0.32121896     -0.91363391      0.15785898E-01, d:  0.11242664       0.0000000       1.4818910
 i,j,k,ie:    3    4    6          18
 Near X =  0.32121896     -0.91363391      0.48025188E-01, d:  0.11242664       0.0000000       1.4818910
 i,j,k,ie:    4    4    6          18
 Near X =  0.32121896     -0.91363391      0.86354515E-01, d:  0.11242664       0.0000000       1.4818910
 i,j,k,ie:    5    4    6          18
 Near X =  0.32121896     -0.91363391      0.11859381    , d:  0.11242664       0.0000000       1.4818910
 i,j,k,ie:    6    4    6          18
 Near X =  0.32121896     -0.91363391      0.13437970    , d:  0.11242664     -0.14257797       1.4818910
 i,j,k,ie:    1    5    6          18
 Near X =  0.44114176     -0.88139029       0.0000000    , d:  0.66939729       0.0000000       1.4818910
 i,j,k,ie:    2    5    6          18
 Near X =  0.44114176     -0.88139029      0.15785898E-01, d:  0.15439962       0.0000000       1.4818910
 i,j,k,ie:    3    5    6          18
 Near X =  0.44114176     -0.88139029      0.48025188E-01, d:  0.15439962       0.0000000       1.4818910
 i,j,k,ie:    4    5    6          18
 Near X =  0.44114176     -0.88139029      0.86354515E-01, d:  0.15439962       0.0000000       1.4818910
 i,j,k,ie:    5    5    6          18
 Near X =  0.44114176     -0.88139029      0.11859381    , d:  0.15439962       0.0000000       1.4818910
 i,j,k,ie:    6    5    6          18
 Near X =  0.44114176     -0.88139029      0.13437970    , d:  0.15439962     -0.38242237       1.4818910
 i,j,k,ie:    1    6    6          18
 Near X =  0.49986170     -0.86560228       0.0000000    , d:  0.85013832      -1.6683998       1.4818910
 i,j,k,ie:    2    6    6          18
 Near X =  0.49986170     -0.86560228      0.15785898E-01, d:  0.17495160      -1.6683998       1.4818910
 i,j,k,ie:    3    6    6          18
 Near X =  0.49986170     -0.86560228      0.48025188E-01, d:  0.17495160      -1.6683998       1.4818910
 i,j,k,ie:    4    6    6          18
 Near X =  0.49986170     -0.86560228      0.86354515E-01, d:  0.17495160      -1.6683998       1.4818910
 i,j,k,ie:    5    6    6          18
 Near X =  0.49986170     -0.86560228      0.11859381    , d:  0.17495160      -1.6683998       1.4818910
 i,j,k,ie:    6    6    6          18
 Near X =  0.49986170     -0.86560228      0.13437970    , d:  0.17495160      -1.6683998       1.4818910
 i,j,k,ie:    1    1    1          19
 Near X =  0.67480679       1.1685381       0.0000000    , d:   0.0000000      -1.8433699       1.4819057
 i,j,k,ie:    2    1    1          19
 Near X =  0.67480679       1.1685381      0.15785898E-01, d:   0.0000000      -1.8433699       1.4819057
 i,j,k,ie:    3    1    1          19
 Near X =  0.67480679       1.1685381      0.48025188E-01, d:   0.0000000      -1.8433699       1.4819057
 i,j,k,ie:    4    1    1          19
 Near X =  0.67480679       1.1685381      0.86354515E-01, d:   0.0000000      -1.8433699       1.4819057
 i,j,k,ie:    5    1    1          19
 Near X =  0.67480679       1.1685381      0.11859381    , d:   0.0000000      -1.8433699       1.4819057
 i,j,k,ie:    6    1    1          19
 Near X =  0.67480679       1.1685381      0.13437970    , d:  0.67519323      -1.8433699       1.4819057
 i,j,k,ie:    1    2    1          19
 Near X =  0.59553566       1.1898548       0.0000000    , d:   0.0000000     -0.51626391       1.4819057
 i,j,k,ie:    6    2    1          19
 Near X =  0.59553566       1.1898548      0.13437970    , d:  0.51502473       0.0000000       1.4819057
 i,j,k,ie:    1    3    1          19
 Near X =  0.43364150       1.2333897       0.0000000    , d:   0.0000000     -0.19247396       1.4819057
 i,j,k,ie:    6    3    1          19
 Near X =  0.43364150       1.2333897      0.13437970    , d:  0.55846088       0.0000000       1.4819057
 i,j,k,ie:    1    4    1          19
 Near X =  0.24116535       1.2851484       0.0000000    , d:  0.19248026       0.0000000       1.4819057
 i,j,k,ie:    6    4    1          19
 Near X =  0.24116535       1.2851484      0.13437970    , d:  0.61010217       0.0000000       1.4819057
 i,j,k,ie:    1    5    1          19
 Near X =  0.79271178E-01   1.3286833       0.0000000    , d:  0.51627021       0.0000000       1.4819057
 i,j,k,ie:    6    5    1          19
 Near X =  0.79271178E-01   1.3286833      0.13437970    , d:  0.65353832       0.0000000       1.4819057
 i,j,k,ie:    1    6    1          19
 Near X =  0.53131460E-07   1.3500000       0.0000000    , d:  0.67481325      -1.1685382       1.4819057
 i,j,k,ie:    2    6    1          19
 Near X =  0.53131460E-07   1.3500000      0.15785898E-01, d:   0.0000000     -0.67481345       1.4819057
 i,j,k,ie:    3    6    1          19
 Near X =  0.53131460E-07   1.3500000      0.48025188E-01, d:   0.0000000     -0.67481345       1.4819057
 i,j,k,ie:    4    6    1          19
 Near X =  0.53131460E-07   1.3500000      0.86354515E-01, d:   0.0000000     -0.67481345       1.4819057
 i,j,k,ie:    5    6    1          19
 Near X =  0.53131460E-07   1.3500000      0.11859381    , d:   0.0000000     -0.67481345       1.4819057
 i,j,k,ie:    6    6    1          19
 Near X =  0.53131460E-07   1.3500000      0.13437970    , d:  0.67480674     -0.67481345       1.4819057
 i,j,k,ie:    1    1    2          19
 Near X =  0.65425501       1.1329493       0.0000000    , d:   0.0000000      -1.7872286       1.4819057
 i,j,k,ie:    2    1    2          19
 Near X =  0.65425501       1.1329493      0.15785898E-01, d:   0.0000000      -1.7872286       1.4819057
 i,j,k,ie:    3    1    2          19
 Near X =  0.65425501       1.1329493      0.48025188E-01, d:   0.0000000      -1.7872286       1.4819057
 i,j,k,ie:    4    1    2          19
 Near X =  0.65425501       1.1329493      0.86354515E-01, d:   0.0000000      -1.7872286       1.4819057
 i,j,k,ie:    5    1    2          19
 Near X =  0.65425501       1.1329493      0.11859381    , d:   0.0000000      -1.7872286       1.4819057
 i,j,k,ie:    6    1    2          19
 Near X =  0.65425501       1.1329493      0.13437970    , d:  0.65462969      -1.7872286       1.4819057
 i,j,k,ie:    1    2    2          19
 Near X =  0.57739815       1.1536169       0.0000000    , d:   0.0000000     -0.50054068       1.4819057
 i,j,k,ie:    6    2    2          19
 Near X =  0.57739815       1.1536169      0.13437970    , d:  0.49933924       0.0000000       1.4819057
 i,j,k,ie:    1    3    2          19
 Near X =  0.42043460       1.1958259       0.0000000    , d:   0.0000000     -0.18661201       1.4819057
 i,j,k,ie:    6    3    2          19
 Near X =  0.42043460       1.1958259      0.13437970    , d:  0.54145251       0.0000000       1.4819057
 i,j,k,ie:    1    4    2          19
 Near X =  0.23382047       1.2460082       0.0000000    , d:  0.18661812       0.0000000       1.4819057
 i,j,k,ie:    6    4    2          19
 Near X =  0.23382047       1.2460082      0.13437970    , d:  0.59152102       0.0000000       1.4819057
 i,j,k,ie:    1    5    2          19
 Near X =  0.76856912E-01   1.2882172       0.0000000    , d:  0.50054679       0.0000000       1.4819057
 i,j,k,ie:    6    5    2          19
 Near X =  0.76856912E-01   1.2882172      0.13437970    , d:  0.63363429       0.0000000       1.4819057
 i,j,k,ie:    1    6    2          19
 Near X =  0.51513299E-07   1.3088847       0.0000000    , d:  0.65426128      -1.1329494       1.4819057
 i,j,k,ie:    2    6    2          19
 Near X =  0.51513299E-07   1.3088847      0.15785898E-01, d:   0.0000000     -0.65426148       1.4819057
 i,j,k,ie:    3    6    2          19
 Near X =  0.51513299E-07   1.3088847      0.48025188E-01, d:   0.0000000     -0.65426148       1.4819057
 i,j,k,ie:    4    6    2          19
 Near X =  0.51513299E-07   1.3088847      0.86354515E-01, d:   0.0000000     -0.65426148       1.4819057
 i,j,k,ie:    5    6    2          19
 Near X =  0.51513299E-07   1.3088847      0.11859381    , d:   0.0000000     -0.65426148       1.4819057
 i,j,k,ie:    6    6    2          19
 Near X =  0.51513299E-07   1.3088847      0.13437970    , d:  0.65425496     -0.65426148       1.4819057
 i,j,k,ie:    1    1    3          19
 Near X =  0.61228245       1.0602670       0.0000000    , d:   0.0000000      -1.6725721       1.4819057
 i,j,k,ie:    2    1    3          19
 Near X =  0.61228245       1.0602670      0.15785898E-01, d:   0.0000000      -1.6725721       1.4819057
 i,j,k,ie:    3    1    3          19
 Near X =  0.61228245       1.0602670      0.48025188E-01, d:   0.0000000      -1.6725721       1.4819057
 i,j,k,ie:    4    1    3          19
 Near X =  0.61228245       1.0602670      0.86354515E-01, d:   0.0000000      -1.6725721       1.4819057
 i,j,k,ie:    5    1    3          19
 Near X =  0.61228245       1.0602670      0.11859381    , d:   0.0000000      -1.6725721       1.4819057
 i,j,k,ie:    6    1    3          19
 Near X =  0.61228245       1.0602670      0.13437970    , d:  0.61263309      -1.6725721       1.4819057
 i,j,k,ie:    1    2    3          19
 Near X =  0.54035620       1.0796086       0.0000000    , d:   0.0000000     -0.46842939       1.4819057
 i,j,k,ie:    6    2    3          19
 Near X =  0.54035620       1.0796086      0.13437970    , d:  0.46730502       0.0000000       1.4819057
 i,j,k,ie:    1    3    3          19
 Near X =  0.39346237       1.1191098       0.0000000    , d:   0.0000000     -0.17464025       1.4819057
 i,j,k,ie:    6    3    3          19
 Near X =  0.39346237       1.1191098      0.13437970    , d:  0.50671659       0.0000000       1.4819057
 i,j,k,ie:    1    4    3          19
 Near X =  0.21882013       1.1660727       0.0000000    , d:  0.17464597       0.0000000       1.4819057
 i,j,k,ie:    6    4    3          19
 Near X =  0.21882013       1.1660727      0.13437970    , d:  0.55357304       0.0000000       1.4819057
 i,j,k,ie:    1    5    3          19
 Near X =  0.71926293E-01   1.2055739       0.0000000    , d:  0.46843510       0.0000000       1.4819057
 i,j,k,ie:    6    5    3          19
 Near X =  0.71926293E-01   1.2055739      0.13437970    , d:  0.59298461       0.0000000       1.4819057
 i,j,k,ie:    1    6    3          19
 Near X =  0.48208555E-07   1.2249155       0.0000000    , d:  0.61228831      -1.0602671       1.4819057
 i,j,k,ie:    2    6    3          19
 Near X =  0.48208555E-07   1.2249155      0.15785898E-01, d:   0.0000000     -0.61228850       1.4819057
 i,j,k,ie:    3    6    3          19
 Near X =  0.48208555E-07   1.2249155      0.48025188E-01, d:   0.0000000     -0.61228850       1.4819057
 i,j,k,ie:    4    6    3          19
 Near X =  0.48208555E-07   1.2249155      0.86354515E-01, d:   0.0000000     -0.61228850       1.4819057
 i,j,k,ie:    5    6    3          19
 Near X =  0.48208555E-07   1.2249155      0.11859381    , d:   0.0000000     -0.61228850       1.4819057
 i,j,k,ie:    6    6    3          19
 Near X =  0.48208555E-07   1.2249155      0.13437970    , d:  0.61228240     -0.61228850       1.4819057
 i,j,k,ie:    1    1    4          19
 Near X =  0.56238122      0.97385487       0.0000000    , d:   0.0000000      -1.5362569       1.4819057
 i,j,k,ie:    2    1    4          19
 Near X =  0.56238122      0.97385487      0.15785898E-01, d:   0.0000000      -1.5362569       1.4819057
 i,j,k,ie:    3    1    4          19
 Near X =  0.56238122      0.97385487      0.48025188E-01, d:   0.0000000      -1.5362569       1.4819057
 i,j,k,ie:    4    1    4          19
 Near X =  0.56238122      0.97385487      0.86354515E-01, d:   0.0000000      -1.5362569       1.4819057
 i,j,k,ie:    5    1    4          19
 Near X =  0.56238122      0.97385487      0.11859381    , d:   0.0000000      -1.5362569       1.4819057
 i,j,k,ie:    6    1    4          19
 Near X =  0.56238122      0.97385487      0.13437970    , d:  0.56270328      -1.5362569       1.4819057
 i,j,k,ie:    1    2    4          19
 Near X =  0.49631699      0.99162017       0.0000000    , d:   0.0000000     -0.43025223       1.4819057
 i,j,k,ie:    6    2    4          19
 Near X =  0.49631699      0.99162017      0.13437970    , d:  0.42921950       0.0000000       1.4819057
 i,j,k,ie:    1    3    4          19
 Near X =  0.36139505       1.0279020       0.0000000    , d:   0.0000000     -0.16040701       1.4819057
 i,j,k,ie:    6    3    4          19
 Near X =  0.36139505       1.0279020      0.13437970    , d:  0.46541901       0.0000000       1.4819057
 i,j,k,ie:    1    4    4          19
 Near X =  0.20098621       1.0710374       0.0000000    , d:  0.16041226       0.0000000       1.4819057
 i,j,k,ie:    6    4    4          19
 Near X =  0.20098621       1.0710374      0.13437970    , d:  0.50845665       0.0000000       1.4819057
 i,j,k,ie:    1    5    4          19
 Near X =  0.66064276E-01   1.1073192       0.0000000    , d:  0.43025748       0.0000000       1.4819057
 i,j,k,ie:    6    5    4          19
 Near X =  0.66064276E-01   1.1073192      0.13437970    , d:  0.54465616       0.0000000       1.4819057
 i,j,k,ie:    1    6    4          19
 Near X =  0.44279542E-07   1.1250845       0.0000000    , d:  0.56238660     -0.97385492       1.4819057
 i,j,k,ie:    2    6    4          19
 Near X =  0.44279542E-07   1.1250845      0.15785898E-01, d:   0.0000000     -0.56238677       1.4819057
 i,j,k,ie:    3    6    4          19
 Near X =  0.44279542E-07   1.1250845      0.48025188E-01, d:   0.0000000     -0.56238677       1.4819057
 i,j,k,ie:    4    6    4          19
 Near X =  0.44279542E-07   1.1250845      0.86354515E-01, d:   0.0000000     -0.56238677       1.4819057
 i,j,k,ie:    5    6    4          19
 Near X =  0.44279542E-07   1.1250845      0.11859381    , d:   0.0000000     -0.56238677       1.4819057
 i,j,k,ie:    6    6    4          19
 Near X =  0.44279542E-07   1.1250845      0.13437970    , d:  0.56238117     -0.56238677       1.4819057
 i,j,k,ie:    1    1    5          19
 Near X =  0.52040865      0.90117252       0.0000000    , d:   0.0000000      -1.4216004       1.4819057
 i,j,k,ie:    2    1    5          19
 Near X =  0.52040865      0.90117252      0.15785898E-01, d:   0.0000000      -1.4216004       1.4819057
 i,j,k,ie:    3    1    5          19
 Near X =  0.52040865      0.90117252      0.48025188E-01, d:   0.0000000      -1.4216004       1.4819057
 i,j,k,ie:    4    1    5          19
 Near X =  0.52040865      0.90117252      0.86354515E-01, d:   0.0000000      -1.4216004       1.4819057
 i,j,k,ie:    5    1    5          19
 Near X =  0.52040865      0.90117252      0.11859381    , d:   0.0000000      -1.4216004       1.4819057
 i,j,k,ie:    6    1    5          19
 Near X =  0.52040865      0.90117252      0.13437970    , d:  0.52070668      -1.4216004       1.4819057
 i,j,k,ie:    1    2    5          19
 Near X =  0.45927504      0.91761193       0.0000000    , d:   0.0000000     -0.39814093       1.4819057
 i,j,k,ie:    6    2    5          19
 Near X =  0.45927504      0.91761193      0.13437970    , d:  0.39718528       0.0000000       1.4819057
 i,j,k,ie:    1    3    5          19
 Near X =  0.33442282      0.95118587       0.0000000    , d:   0.0000000     -0.14843525       1.4819057
 i,j,k,ie:    6    3    5          19
 Near X =  0.33442282      0.95118587      0.13437970    , d:  0.43068309       0.0000000       1.4819057
 i,j,k,ie:    1    4    5          19
 Near X =  0.18598588      0.99110197       0.0000000    , d:  0.14844011       0.0000000       1.4819057
 i,j,k,ie:    6    4    5          19
 Near X =  0.18598588      0.99110197      0.13437970    , d:  0.47050867       0.0000000       1.4819057
 i,j,k,ie:    1    5    5          19
 Near X =  0.61133657E-01   1.0246759       0.0000000    , d:  0.39814579       0.0000000       1.4819057
 i,j,k,ie:    6    5    5          19
 Near X =  0.61133657E-01   1.0246759      0.13437970    , d:  0.50400648       0.0000000       1.4819057
 i,j,k,ie:    1    6    5          19
 Near X =  0.40974798E-07   1.0411153       0.0000000    , d:  0.52041363     -0.90117257       1.4819057
 i,j,k,ie:    2    6    5          19
 Near X =  0.40974798E-07   1.0411153      0.15785898E-01, d:   0.0000000     -0.52041379       1.4819057
 i,j,k,ie:    3    6    5          19
 Near X =  0.40974798E-07   1.0411153      0.48025188E-01, d:   0.0000000     -0.52041379       1.4819057
 i,j,k,ie:    4    6    5          19
 Near X =  0.40974798E-07   1.0411153      0.86354515E-01, d:   0.0000000     -0.52041379       1.4819057
 i,j,k,ie:    5    6    5          19
 Near X =  0.40974798E-07   1.0411153      0.11859381    , d:   0.0000000     -0.52041379       1.4819057
 i,j,k,ie:    6    6    5          19
 Near X =  0.40974798E-07   1.0411153      0.13437970    , d:  0.52040861     -0.52041379       1.4819057
 i,j,k,ie:    1    1    6          19
 Near X =  0.49985688      0.86558377       0.0000000    , d:  0.17494991      -1.6684200       1.4819057
 i,j,k,ie:    2    1    6          19
 Near X =  0.49985688      0.86558377      0.15785898E-01, d:  0.17494991      -1.6684200       1.4819057
 i,j,k,ie:    3    1    6          19
 Near X =  0.49985688      0.86558377      0.48025188E-01, d:  0.17494991      -1.6684200       1.4819057
 i,j,k,ie:    4    1    6          19
 Near X =  0.49985688      0.86558377      0.86354515E-01, d:  0.17494991      -1.6684200       1.4819057
 i,j,k,ie:    5    1    6          19
 Near X =  0.49985688      0.86558377      0.11859381    , d:  0.17494991      -1.6684200       1.4819057
 i,j,k,ie:    6    1    6          19
 Near X =  0.49985688      0.86558377      0.13437970    , d:  0.85014315      -1.6684200       1.4819057
 i,j,k,ie:    1    2    6          19
 Near X =  0.44113753      0.88137396       0.0000000    , d:  0.15439814     -0.38241771       1.4819057
 i,j,k,ie:    2    2    6          19
 Near X =  0.44113753      0.88137396      0.15785898E-01, d:  0.15439814       0.0000000       1.4819057
 i,j,k,ie:    3    2    6          19
 Near X =  0.44113753      0.88137396      0.48025188E-01, d:  0.15439814       0.0000000       1.4819057
 i,j,k,ie:    4    2    6          19
 Near X =  0.44113753      0.88137396      0.86354515E-01, d:  0.15439814       0.0000000       1.4819057
 i,j,k,ie:    5    2    6          19
 Near X =  0.44113753      0.88137396      0.11859381    , d:  0.15439814       0.0000000       1.4819057
 i,j,k,ie:    6    2    6          19
 Near X =  0.44113753      0.88137396      0.13437970    , d:  0.66942286       0.0000000       1.4819057
 i,j,k,ie:    1    3    6          19
 Near X =  0.32121592      0.91362201       0.0000000    , d:  0.11242558     -0.14257330       1.4819057
 i,j,k,ie:    2    3    6          19
 Near X =  0.32121592      0.91362201      0.15785898E-01, d:  0.11242558       0.0000000       1.4819057
 i,j,k,ie:    3    3    6          19
 Near X =  0.32121592      0.91362201      0.48025188E-01, d:  0.11242558       0.0000000       1.4819057
 i,j,k,ie:    4    3    6          19
 Near X =  0.32121592      0.91362201      0.86354515E-01, d:  0.11242558       0.0000000       1.4819057
 i,j,k,ie:    5    3    6          19
 Near X =  0.32121592      0.91362201      0.11859381    , d:  0.11242558       0.0000000       1.4819057
 i,j,k,ie:    6    3    6          19
 Near X =  0.32121592      0.91362201      0.13437970    , d:  0.67088645       0.0000000       1.4819057
 i,j,k,ie:    1    4    6          19
 Near X =  0.17864100      0.95196176       0.0000000    , d:  0.25500461       0.0000000       1.4819057
 i,j,k,ie:    2    4    6          19
 Near X =  0.17864100      0.95196176      0.15785898E-01, d:  0.62524351E-01   0.0000000       1.4819057
 i,j,k,ie:    3    4    6          19
 Near X =  0.17864100      0.95196176      0.48025188E-01, d:  0.62524351E-01   0.0000000       1.4819057
 i,j,k,ie:    4    4    6          19
 Near X =  0.17864100      0.95196176      0.86354515E-01, d:  0.62524351E-01   0.0000000       1.4819057
 i,j,k,ie:    5    4    6          19
 Near X =  0.17864100      0.95196176      0.11859381    , d:  0.62524351E-01   0.0000000       1.4819057
 i,j,k,ie:    6    4    6          19
 Near X =  0.17864100      0.95196176      0.13437970    , d:  0.67262652       0.0000000       1.4819057
 i,j,k,ie:    1    5    6          19
 Near X =  0.58719391E-01  0.98420982       0.0000000    , d:  0.53682200       0.0000000       1.4819057
 i,j,k,ie:    2    5    6          19
 Near X =  0.58719391E-01  0.98420982      0.15785898E-01, d:  0.20551787E-01   0.0000000       1.4819057
 i,j,k,ie:    3    5    6          19
 Near X =  0.58719391E-01  0.98420982      0.48025188E-01, d:  0.20551787E-01   0.0000000       1.4819057
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    4    5    6          19
 Near X =  0.58719391E-01  0.98420982      0.86354515E-01, d:  0.20551787E-01   0.0000000       1.4819057
 i,j,k,ie:    5    5    6          19
 Near X =  0.58719391E-01  0.98420982      0.11859381    , d:  0.20551787E-01   0.0000000       1.4819057
 i,j,k,ie:    6    5    6          19
 Near X =  0.58719391E-01  0.98420982      0.13437970    , d:  0.67409011       0.0000000       1.4819057
 i,j,k,ie:    1    6    6          19
 Near X =  0.39356637E-07   1.0000000       0.0000000    , d:  0.67481326      -1.1685381       1.4819057
 i,j,k,ie:    2    6    6          19
 Near X =  0.39356637E-07   1.0000000      0.15785898E-01, d:  0.13774823E-07 -0.67481344       1.4819057
 i,j,k,ie:    3    6    6          19
 Near X =  0.39356637E-07   1.0000000      0.48025188E-01, d:  0.13774823E-07 -0.67481344       1.4819057
 i,j,k,ie:    4    6    6          19
 Near X =  0.39356637E-07   1.0000000      0.86354515E-01, d:  0.13774823E-07 -0.67481344       1.4819057
 i,j,k,ie:    5    6    6          19
 Near X =  0.39356637E-07   1.0000000      0.11859381    , d:  0.13774823E-07 -0.67481344       1.4819057
 i,j,k,ie:    6    6    6          19
 Near X =  0.39356637E-07   1.0000000      0.13437970    , d:  0.67480675     -0.67481344       1.4819057
 i,j,k,ie:    1    1    1          20
 Near X =   1.1685631      0.67481338       0.0000000    , d:  0.18143693      -2.3371262      0.85575182
 i,j,k,ie:    2    1    1          20
 Near X =   1.1685631      0.67481338      0.15785898E-01, d:  0.18143693       0.0000000      0.85575182
 i,j,k,ie:    3    1    1          20
 Near X =   1.1685631      0.67481338      0.48025188E-01, d:  0.18143693       0.0000000      0.85575182
 i,j,k,ie:    4    1    1          20
 Near X =   1.1685631      0.67481338      0.86354515E-01, d:  0.18143693       0.0000000      0.85575182
 i,j,k,ie:    5    1    1          20
 Near X =   1.1685631      0.67481338      0.11859381    , d:  0.18143693       0.0000000      0.85575182
 i,j,k,ie:    6    1    1          20
 Near X =   1.1685631      0.67481338      0.13437970    , d:  0.18143693       0.0000000      0.85575182
 i,j,k,ie:    1    2    1          20
 Near X =   1.1105604      0.73281237       0.0000000    , d:   0.0000000     -0.51502473      0.85575182
 i,j,k,ie:    1    3    1          20
 Near X =  0.99210237      0.85126281       0.0000000    , d:   0.0000000     -0.55846088      0.85575182
 i,j,k,ie:    1    4    1          20
 Near X =  0.85126751      0.99208866       0.0000000    , d:   0.0000000     -0.61010217      0.85575182
 i,j,k,ie:    1    5    1          20
 Near X =  0.73280950       1.1105391       0.0000000    , d:   0.0000000     -0.65353832      0.85575182
 i,j,k,ie:    1    6    1          20
 Near X =  0.67480679       1.1685381       0.0000000    , d:   0.0000000      -1.3496202      0.85575182
 i,j,k,ie:    2    6    1          20
 Near X =  0.67480679       1.1685381      0.15785898E-01, d:   0.0000000     -0.67480674      0.85575182
 i,j,k,ie:    3    6    1          20
 Near X =  0.67480679       1.1685381      0.48025188E-01, d:   0.0000000     -0.67480674      0.85575182
 i,j,k,ie:    4    6    1          20
 Near X =  0.67480679       1.1685381      0.86354515E-01, d:   0.0000000     -0.67480674      0.85575182
 i,j,k,ie:    5    6    1          20
 Near X =  0.67480679       1.1685381      0.11859381    , d:   0.0000000     -0.67480674      0.85575182
 i,j,k,ie:    6    6    1          20
 Near X =  0.67480679       1.1685381      0.13437970    , d:   0.0000000     -0.67480674      0.85575182
 i,j,k,ie:    1    1    2          20
 Near X =   1.1329736      0.65426140       0.0000000    , d:  0.17591112      -2.2659471      0.85575182
 i,j,k,ie:    2    1    2          20
 Near X =   1.1329736      0.65426140      0.15785898E-01, d:  0.17591112       0.0000000      0.85575182
 i,j,k,ie:    3    1    2          20
 Near X =   1.1329736      0.65426140      0.48025188E-01, d:  0.17591112       0.0000000      0.85575182
 i,j,k,ie:    4    1    2          20
 Near X =   1.1329736      0.65426140      0.86354515E-01, d:  0.17591112       0.0000000      0.85575182
 i,j,k,ie:    5    1    2          20
 Near X =   1.1329736      0.65426140      0.11859381    , d:  0.17591112       0.0000000      0.85575182
 i,j,k,ie:    6    1    2          20
 Near X =   1.1329736      0.65426140      0.13437970    , d:  0.17591112       0.0000000      0.85575182
 i,j,k,ie:    1    2    2          20
 Near X =   1.0767374      0.71049399       0.0000000    , d:   0.0000000     -0.49933924      0.85575182
 i,j,k,ie:    1    3    2          20
 Near X =  0.96188711      0.82533693       0.0000000    , d:   0.0000000     -0.54145251      0.85575182
 i,j,k,ie:    1    4    2          20
 Near X =  0.82534149      0.96187381       0.0000000    , d:   0.0000000     -0.59152102      0.85575182
 i,j,k,ie:    1    5    2          20
 Near X =  0.71049120       1.0767167       0.0000000    , d:   0.0000000     -0.63363429      0.85575182
 i,j,k,ie:    1    6    2          20
 Near X =  0.65425501       1.1329493       0.0000000    , d:   0.0000000      -1.3085164      0.85575182
 i,j,k,ie:    2    6    2          20
 Near X =  0.65425501       1.1329493      0.15785898E-01, d:   0.0000000     -0.65425496      0.85575182
 i,j,k,ie:    3    6    2          20
 Near X =  0.65425501       1.1329493      0.48025188E-01, d:   0.0000000     -0.65425496      0.85575182
 i,j,k,ie:    4    6    2          20
 Near X =  0.65425501       1.1329493      0.86354515E-01, d:   0.0000000     -0.65425496      0.85575182
 i,j,k,ie:    5    6    2          20
 Near X =  0.65425501       1.1329493      0.11859381    , d:   0.0000000     -0.65425496      0.85575182
 i,j,k,ie:    6    6    2          20
 Near X =  0.65425501       1.1329493      0.13437970    , d:   0.0000000     -0.65425496      0.85575182
 i,j,k,ie:    1    1    3          20
 Near X =   1.0602897      0.61228843       0.0000000    , d:  0.16462586      -2.1205793      0.85575182
 i,j,k,ie:    2    1    3          20
 Near X =   1.0602897      0.61228843      0.15785898E-01, d:  0.16462586       0.0000000      0.85575182
 i,j,k,ie:    3    1    3          20
 Near X =   1.0602897      0.61228843      0.48025188E-01, d:  0.16462586       0.0000000      0.85575182
 i,j,k,ie:    4    1    3          20
 Near X =   1.0602897      0.61228843      0.86354515E-01, d:  0.16462586       0.0000000      0.85575182
 i,j,k,ie:    5    1    3          20
 Near X =   1.0602897      0.61228843      0.11859381    , d:  0.16462586       0.0000000      0.85575182
 i,j,k,ie:    6    1    3          20
 Near X =   1.0602897      0.61228843      0.13437970    , d:  0.16462586       0.0000000      0.85575182
 i,j,k,ie:    1    2    3          20
 Near X =   1.0076612      0.66491352       0.0000000    , d:   0.0000000     -0.46730502      0.85575182
 i,j,k,ie:    1    3    3          20
 Near X =  0.90017895      0.77238891       0.0000000    , d:   0.0000000     -0.50671659      0.85575182
 i,j,k,ie:    1    4    3          20
 Near X =  0.77239317      0.90016651       0.0000000    , d:   0.0000000     -0.55357304      0.85575182
 i,j,k,ie:    1    5    3          20
 Near X =  0.66491090       1.0076419       0.0000000    , d:   0.0000000     -0.59298461      0.85575182
 i,j,k,ie:    1    6    3          20
 Near X =  0.61228245       1.0602670       0.0000000    , d:   0.0000000      -1.2245709      0.85575182
 i,j,k,ie:    2    6    3          20
 Near X =  0.61228245       1.0602670      0.15785898E-01, d:   0.0000000     -0.61228240      0.85575182
 i,j,k,ie:    3    6    3          20
 Near X =  0.61228245       1.0602670      0.48025188E-01, d:   0.0000000     -0.61228240      0.85575182
 i,j,k,ie:    4    6    3          20
 Near X =  0.61228245       1.0602670      0.86354515E-01, d:   0.0000000     -0.61228240      0.85575182
 i,j,k,ie:    5    6    3          20
 Near X =  0.61228245       1.0602670      0.11859381    , d:   0.0000000     -0.61228240      0.85575182
 i,j,k,ie:    6    6    3          20
 Near X =  0.61228245       1.0602670      0.13437970    , d:   0.0000000     -0.61228240      0.85575182
 i,j,k,ie:    1    1    4          20
 Near X =  0.97387571      0.56238671       0.0000000    , d:  0.15120879      -1.9477514      0.85575182
 i,j,k,ie:    2    1    4          20
 Near X =  0.97387571      0.56238671      0.15785898E-01, d:  0.15120879       0.0000000      0.85575182
 i,j,k,ie:    3    1    4          20
 Near X =  0.97387571      0.56238671      0.48025188E-01, d:  0.15120879       0.0000000      0.85575182
 i,j,k,ie:    4    1    4          20
 Near X =  0.97387571      0.56238671      0.86354515E-01, d:  0.15120879       0.0000000      0.85575182
 i,j,k,ie:    5    1    4          20
 Near X =  0.97387571      0.56238671      0.11859381    , d:  0.15120879       0.0000000      0.85575182
 i,j,k,ie:    6    1    4          20
 Near X =  0.97387571      0.56238671      0.13437970    , d:  0.15120879       0.0000000      0.85575182
 i,j,k,ie:    1    2    4          20
 Near X =  0.92553649      0.61072284       0.0000000    , d:   0.0000000     -0.42921950      0.85575182
 i,j,k,ie:    1    3    4          20
 Near X =  0.82681406      0.70943895       0.0000000    , d:   0.0000000     -0.46541901      0.85575182
 i,j,k,ie:    1    4    4          20
 Near X =  0.70944286      0.82680263       0.0000000    , d:   0.0000000     -0.50845665      0.85575182
 i,j,k,ie:    1    5    4          20
 Near X =  0.61072044      0.92551874       0.0000000    , d:   0.0000000     -0.54465616      0.85575182
 i,j,k,ie:    1    6    4          20
 Near X =  0.56238122      0.97385487       0.0000000    , d:   0.0000000      -1.1247679      0.85575182
 i,j,k,ie:    2    6    4          20
 Near X =  0.56238122      0.97385487      0.15785898E-01, d:   0.0000000     -0.56238117      0.85575182
 i,j,k,ie:    3    6    4          20
 Near X =  0.56238122      0.97385487      0.48025188E-01, d:   0.0000000     -0.56238117      0.85575182
 i,j,k,ie:    4    6    4          20
 Near X =  0.56238122      0.97385487      0.86354515E-01, d:   0.0000000     -0.56238117      0.85575182
 i,j,k,ie:    5    6    4          20
 Near X =  0.56238122      0.97385487      0.11859381    , d:   0.0000000     -0.56238117      0.85575182
 i,j,k,ie:    6    6    4          20
 Near X =  0.56238122      0.97385487      0.13437970    , d:   0.0000000     -0.56238117      0.85575182
 i,j,k,ie:    1    1    5          20
 Near X =  0.90119180      0.52041374       0.0000000    , d:  0.13992353      -1.8023836      0.85575182
 i,j,k,ie:    2    1    5          20
 Near X =  0.90119180      0.52041374      0.15785898E-01, d:  0.13992353       0.0000000      0.85575182
 i,j,k,ie:    3    1    5          20
 Near X =  0.90119180      0.52041374      0.48025188E-01, d:  0.13992353       0.0000000      0.85575182
 i,j,k,ie:    4    1    5          20
 Near X =  0.90119180      0.52041374      0.86354515E-01, d:  0.13992353       0.0000000      0.85575182
 i,j,k,ie:    5    1    5          20
 Near X =  0.90119180      0.52041374      0.11859381    , d:  0.13992353       0.0000000      0.85575182
 i,j,k,ie:    6    1    5          20
 Near X =  0.90119180      0.52041374      0.13437970    , d:  0.13992353       0.0000000      0.85575182
 i,j,k,ie:    1    2    5          20
 Near X =  0.85646032      0.56514236       0.0000000    , d:   0.0000000     -0.39718528      0.85575182
 i,j,k,ie:    1    3    5          20
 Near X =  0.76510591      0.65649093       0.0000000    , d:   0.0000000     -0.43068309      0.85575182
 i,j,k,ie:    1    4    5          20
 Near X =  0.65649455      0.76509533       0.0000000    , d:   0.0000000     -0.47050867      0.85575182
 i,j,k,ie:    1    5    5          20
 Near X =  0.56514014      0.85644389       0.0000000    , d:   0.0000000     -0.50400648      0.85575182
 i,j,k,ie:    1    6    5          20
 Near X =  0.52040865      0.90117252       0.0000000    , d:   0.0000000      -1.0408224      0.85575182
 i,j,k,ie:    2    6    5          20
 Near X =  0.52040865      0.90117252      0.15785898E-01, d:   0.0000000     -0.52040861      0.85575182
 i,j,k,ie:    3    6    5          20
 Near X =  0.52040865      0.90117252      0.48025188E-01, d:   0.0000000     -0.52040861      0.85575182
 i,j,k,ie:    4    6    5          20
 Near X =  0.52040865      0.90117252      0.86354515E-01, d:   0.0000000     -0.52040861      0.85575182
 i,j,k,ie:    5    6    5          20
 Near X =  0.52040865      0.90117252      0.11859381    , d:   0.0000000     -0.52040861      0.85575182
 i,j,k,ie:    6    6    5          20
 Near X =  0.52040865      0.90117252      0.13437970    , d:   0.0000000     -0.52040861      0.85575182
 i,j,k,ie:    1    1    6          20
 Near X =  0.86560229      0.49986176       0.0000000    , d:  0.48439774      -2.0341654      0.85575182
 i,j,k,ie:    2    1    6          20
 Near X =  0.86560229      0.49986176      0.15785898E-01, d:  0.48439774       0.0000000      0.85575182
 i,j,k,ie:    3    1    6          20
 Near X =  0.86560229      0.49986176      0.48025188E-01, d:  0.48439774       0.0000000      0.85575182
 i,j,k,ie:    4    1    6          20
 Near X =  0.86560229      0.49986176      0.86354515E-01, d:  0.48439774       0.0000000      0.85575182
 i,j,k,ie:    5    1    6          20
 Near X =  0.86560229      0.49986176      0.11859381    , d:  0.48439774       0.0000000      0.85575182
 i,j,k,ie:    6    1    6          20
 Near X =  0.86560229      0.49986176      0.13437970    , d:  0.48439774       0.0000000      0.85575182
 i,j,k,ie:    1    2    6          20
 Near X =  0.82263732      0.54282398       0.0000000    , d:  0.28792307     -0.38149979      0.85575182
 i,j,k,ie:    2    2    6          20
 Near X =  0.82263732      0.54282398      0.15785898E-01, d:  0.28792307       0.0000000      0.85575182
 i,j,k,ie:    3    2    6          20
 Near X =  0.82263732      0.54282398      0.48025188E-01, d:  0.28792307       0.0000000      0.85575182
 i,j,k,ie:    4    2    6          20
 Near X =  0.82263732      0.54282398      0.86354515E-01, d:  0.28792307       0.0000000      0.85575182
 i,j,k,ie:    5    2    6          20
 Near X =  0.82263732      0.54282398      0.11859381    , d:  0.28792307       0.0000000      0.85575182
 i,j,k,ie:    6    2    6          20
 Near X =  0.82263732      0.54282398      0.13437970    , d:  0.28792307       0.0000000      0.85575182
 i,j,k,ie:    1    3    6          20
 Near X =  0.73489064      0.63056504       0.0000000    , d:  0.25721173     -0.41367472      0.85575182
 i,j,k,ie:    2    3    6          20
 Near X =  0.73489064      0.63056504      0.15785898E-01, d:  0.25721173       0.0000000      0.85575182
 i,j,k,ie:    3    3    6          20
 Near X =  0.73489064      0.63056504      0.48025188E-01, d:  0.25721173       0.0000000      0.85575182
 i,j,k,ie:    4    3    6          20
 Near X =  0.73489064      0.63056504      0.86354515E-01, d:  0.25721173       0.0000000      0.85575182
 i,j,k,ie:    5    3    6          20
 Near X =  0.73489064      0.63056504      0.11859381    , d:  0.25721173       0.0000000      0.85575182
 i,j,k,ie:    6    3    6          20
 Near X =  0.73489064      0.63056504      0.13437970    , d:  0.25721173       0.0000000      0.85575182
 i,j,k,ie:    1    4    6          20
 Near X =  0.63056852      0.73488049       0.0000000    , d:  0.22069899     -0.45192753      0.85575182
 i,j,k,ie:    2    4    6          20
 Near X =  0.63056852      0.73488049      0.15785898E-01, d:  0.22069899       0.0000000      0.85575182
 i,j,k,ie:    3    4    6          20
 Near X =  0.63056852      0.73488049      0.48025188E-01, d:  0.22069899       0.0000000      0.85575182
 i,j,k,ie:    4    4    6          20
 Near X =  0.63056852      0.73488049      0.86354515E-01, d:  0.22069899       0.0000000      0.85575182
 i,j,k,ie:    5    4    6          20
 Near X =  0.63056852      0.73488049      0.11859381    , d:  0.22069899       0.0000000      0.85575182
 i,j,k,ie:    6    4    6          20
 Near X =  0.63056852      0.73488049      0.13437970    , d:  0.22069899       0.0000000      0.85575182
 i,j,k,ie:    1    5    6          20
 Near X =  0.54282185      0.82262155       0.0000000    , d:  0.18998765     -0.48410245      0.85575182
 i,j,k,ie:    2    5    6          20
 Near X =  0.54282185      0.82262155      0.15785898E-01, d:  0.18998765       0.0000000      0.85575182
 i,j,k,ie:    3    5    6          20
 Near X =  0.54282185      0.82262155      0.48025188E-01, d:  0.18998765       0.0000000      0.85575182
 i,j,k,ie:    4    5    6          20
 Near X =  0.54282185      0.82262155      0.86354515E-01, d:  0.18998765       0.0000000      0.85575182
 i,j,k,ie:    5    5    6          20
 Near X =  0.54282185      0.82262155      0.11859381    , d:  0.18998765       0.0000000      0.85575182
 i,j,k,ie:    6    5    6          20
 Near X =  0.54282185      0.82262155      0.13437970    , d:  0.18998765       0.0000000      0.85575182
 i,j,k,ie:    1    6    6          20
 Near X =  0.49985688      0.86558377       0.0000000    , d:  0.17494991      -1.1746703      0.85575182
 i,j,k,ie:    2    6    6          20
 Near X =  0.49985688      0.86558377      0.15785898E-01, d:  0.17494991     -0.49985684      0.85575182
 i,j,k,ie:    3    6    6          20
 Near X =  0.49985688      0.86558377      0.48025188E-01, d:  0.17494991     -0.49985684      0.85575182
 i,j,k,ie:    4    6    6          20
 Near X =  0.49985688      0.86558377      0.86354515E-01, d:  0.17494991     -0.49985684      0.85575182
 i,j,k,ie:    5    6    6          20
 Near X =  0.49985688      0.86558377      0.11859381    , d:  0.17494991     -0.49985684      0.85575182
 i,j,k,ie:    6    6    6          20
 Near X =  0.49985688      0.86558377      0.13437970    , d:  0.17494991     -0.49985684      0.85575182
 i,j,k,ie:    1    1    1          21
 Near X =   1.3500000     -0.77758166E-07   0.0000000    , d:   0.0000000     -0.18146197      0.74074073
 i,j,k,ie:    2    1    1          21
 Near X =   1.3500000     -0.77758166E-07  0.15785898E-01, d:   0.0000000     -0.18146197      0.74074073
 i,j,k,ie:    3    1    1          21
 Near X =   1.3500000     -0.77758166E-07  0.48025188E-01, d:   0.0000000     -0.18146197      0.74074073
 i,j,k,ie:    4    1    1          21
 Near X =   1.3500000     -0.77758166E-07  0.86354515E-01, d:   0.0000000     -0.18146197      0.74074073
 i,j,k,ie:    5    1    1          21
 Near X =   1.3500000     -0.77758166E-07  0.11859381    , d:   0.0000000     -0.18146197      0.74074073
 i,j,k,ie:    6    1    1          21
 Near X =   1.3500000     -0.77758166E-07  0.13437970    , d:   0.0000000      -2.5185381      0.74074073
 i,j,k,ie:    6    2    1          21
 Near X =   1.3286862      0.79271836E-01  0.13437970    , d:   0.0000000      -2.5185411      0.74074073
 i,j,k,ie:    6    3    1          21
 Near X =   1.2851573      0.24116762      0.13437970    , d:   0.0000000      -2.5185471      0.74074073
 i,j,k,ie:    6    4    1          21
 Near X =   1.2334058      0.43364568      0.13437970    , d:   0.0000000      -2.5185542      0.74074073
 i,j,k,ie:    6    5    1          21
 Near X =   1.1898769      0.59554146      0.13437970    , d:   0.0000000      -2.5185602      0.74074073
 i,j,k,ie:    1    6    1          21
 Near X =   1.1685631      0.67481338       0.0000000    , d:   0.0000000      -2.0341469      0.74074073
 i,j,k,ie:    2    6    1          21
 Near X =   1.1685631      0.67481338      0.15785898E-01, d:   0.0000000      -2.0341469      0.74074073
 i,j,k,ie:    3    6    1          21
 Near X =   1.1685631      0.67481338      0.48025188E-01, d:   0.0000000      -2.0341469      0.74074073
 i,j,k,ie:    4    6    1          21
 Near X =   1.1685631      0.67481338      0.86354515E-01, d:   0.0000000      -2.0341469      0.74074073
 i,j,k,ie:    5    6    1          21
 Near X =   1.1685631      0.67481338      0.11859381    , d:   0.0000000      -2.0341469      0.74074073
 i,j,k,ie:    6    6    1          21
 Near X =   1.1685631      0.67481338      0.13437970    , d:   0.0000000      -2.5185631      0.74074073
 i,j,k,ie:    1    1    2          21
 Near X =   1.3088847     -0.74046641E-07   0.0000000    , d:   0.0000000     -0.17593540      0.74074073
 i,j,k,ie:    2    1    2          21
 Near X =   1.3088847     -0.74046641E-07  0.15785898E-01, d:   0.0000000     -0.17593540      0.74074073
 i,j,k,ie:    3    1    2          21
 Near X =   1.3088847     -0.74046641E-07  0.48025188E-01, d:   0.0000000     -0.17593540      0.74074073
 i,j,k,ie:    4    1    2          21
 Near X =   1.3088847     -0.74046641E-07  0.86354515E-01, d:   0.0000000     -0.17593540      0.74074073
 i,j,k,ie:    5    1    2          21
 Near X =   1.3088847     -0.74046641E-07  0.11859381    , d:   0.0000000     -0.17593540      0.74074073
 i,j,k,ie:    6    1    2          21
 Near X =   1.3088847     -0.74046641E-07  0.13437970    , d:   0.0000000      -2.4418341      0.74074073
 i,j,k,ie:    6    2    2          21
 Near X =   1.2882200      0.76857551E-01  0.13437970    , d:   0.0000000      -2.4418369      0.74074073
 i,j,k,ie:    6    3    2          21
 Near X =   1.2460168      0.23382267      0.13437970    , d:   0.0000000      -2.4418427      0.74074073
 i,j,k,ie:    6    4    2          21
 Near X =   1.1958414      0.42043866      0.13437970    , d:   0.0000000      -2.4418496      0.74074073
 i,j,k,ie:    6    5    2          21
 Near X =   1.1536383      0.57740378      0.13437970    , d:   0.0000000      -2.4418554      0.74074073
 i,j,k,ie:    1    6    2          21
 Near X =   1.1329736      0.65426140       0.0000000    , d:   0.0000000      -1.9629686      0.74074073
 i,j,k,ie:    2    6    2          21
 Near X =   1.1329736      0.65426140      0.15785898E-01, d:   0.0000000      -1.9629686      0.74074073
 i,j,k,ie:    3    6    2          21
 Near X =   1.1329736      0.65426140      0.48025188E-01, d:   0.0000000      -1.9629686      0.74074073
 i,j,k,ie:    4    6    2          21
 Near X =   1.1329736      0.65426140      0.86354515E-01, d:   0.0000000      -1.9629686      0.74074073
 i,j,k,ie:    5    6    2          21
 Near X =   1.1329736      0.65426140      0.11859381    , d:   0.0000000      -1.9629686      0.74074073
 i,j,k,ie:    6    6    2          21
 Near X =   1.1329736      0.65426140      0.13437970    , d:   0.0000000      -2.4418583      0.74074073
 i,j,k,ie:    1    1    3          21
 Near X =   1.2249155     -0.66466653E-07   0.0000000    , d:   0.0000000     -0.16464857      0.74074073
 i,j,k,ie:    2    1    3          21
 Near X =   1.2249155     -0.66466653E-07  0.15785898E-01, d:   0.0000000     -0.16464857      0.74074073
 i,j,k,ie:    3    1    3          21
 Near X =   1.2249155     -0.66466653E-07  0.48025188E-01, d:   0.0000000     -0.16464857      0.74074073
 i,j,k,ie:    4    1    3          21
 Near X =   1.2249155     -0.66466653E-07  0.86354515E-01, d:   0.0000000     -0.16464857      0.74074073
 i,j,k,ie:    5    1    3          21
 Near X =   1.2249155     -0.66466653E-07  0.11859381    , d:   0.0000000     -0.16464857      0.74074073
 i,j,k,ie:    6    1    3          21
 Near X =   1.2249155     -0.66466653E-07  0.13437970    , d:   0.0000000      -2.2851825      0.74074073
 i,j,k,ie:    6    2    3          21
 Near X =   1.2055765      0.71926894E-01  0.13437970    , d:   0.0000000      -2.2851852      0.74074073
 i,j,k,ie:    6    3    3          21
 Near X =   1.1660808      0.21882219      0.13437970    , d:   0.0000000      -2.2851906      0.74074073
 i,j,k,ie:    6    4    3          21
 Near X =   1.1191244      0.39346617      0.13437970    , d:   0.0000000      -2.2851971      0.74074073
 i,j,k,ie:    6    5    3          21
 Near X =   1.0796287      0.54036147      0.13437970    , d:   0.0000000      -2.2852025      0.74074073
 i,j,k,ie:    1    6    3          21
 Near X =   1.0602897      0.61228843       0.0000000    , d:   0.0000000      -1.8176023      0.74074073
 i,j,k,ie:    2    6    3          21
 Near X =   1.0602897      0.61228843      0.15785898E-01, d:   0.0000000      -1.8176023      0.74074073
 i,j,k,ie:    3    6    3          21
 Near X =   1.0602897      0.61228843      0.48025188E-01, d:   0.0000000      -1.8176023      0.74074073
 i,j,k,ie:    4    6    3          21
 Near X =   1.0602897      0.61228843      0.86354515E-01, d:   0.0000000      -1.8176023      0.74074073
 i,j,k,ie:    5    6    3          21
 Near X =   1.0602897      0.61228843      0.11859381    , d:   0.0000000      -1.8176023      0.74074073
 i,j,k,ie:    6    6    3          21
 Near X =   1.0602897      0.61228843      0.13437970    , d:   0.0000000      -2.2852052      0.74074073
 i,j,k,ie:    1    1    4          21
 Near X =   1.1250845     -0.57454798E-07   0.0000000    , d:   0.0000000     -0.15122966      0.74074073
 i,j,k,ie:    2    1    4          21
 Near X =   1.1250845     -0.57454798E-07  0.15785898E-01, d:   0.0000000     -0.15122966      0.74074073
 i,j,k,ie:    3    1    4          21
 Near X =   1.1250845     -0.57454798E-07  0.48025188E-01, d:   0.0000000     -0.15122966      0.74074073
 i,j,k,ie:    4    1    4          21
 Near X =   1.1250845     -0.57454798E-07  0.86354515E-01, d:   0.0000000     -0.15122966      0.74074073
 i,j,k,ie:    5    1    4          21
 Near X =   1.1250845     -0.57454798E-07  0.11859381    , d:   0.0000000     -0.15122966      0.74074073
 i,j,k,ie:    6    1    4          21
 Near X =   1.1250845     -0.57454798E-07  0.13437970    , d:   0.0000000      -2.0989394      0.74074073
 i,j,k,ie:    6    2    4          21
 Near X =   1.1073216      0.66064831E-01  0.13437970    , d:   0.0000000      -2.0989418      0.74074073
 i,j,k,ie:    6    3    4          21
 Near X =   1.0710449      0.20098811      0.13437970    , d:   0.0000000      -2.0989468      0.74074073
 i,j,k,ie:    6    4    4          21
 Near X =   1.0279153      0.36139854      0.13437970    , d:   0.0000000      -2.0989528      0.74074073
 i,j,k,ie:    6    5    4          21
 Near X =  0.99163856      0.49632182      0.13437970    , d:   0.0000000      -2.0989578      0.74074073
 i,j,k,ie:    1    6    4          21
 Near X =  0.97387571      0.56238671       0.0000000    , d:   0.0000000      -1.6447762      0.74074073
 i,j,k,ie:    2    6    4          21
 Near X =  0.97387571      0.56238671      0.15785898E-01, d:   0.0000000      -1.6447762      0.74074073
 i,j,k,ie:    3    6    4          21
 Near X =  0.97387571      0.56238671      0.48025188E-01, d:   0.0000000      -1.6447762      0.74074073
 i,j,k,ie:    4    6    4          21
 Near X =  0.97387571      0.56238671      0.86354515E-01, d:   0.0000000      -1.6447762      0.74074073
 i,j,k,ie:    5    6    4          21
 Near X =  0.97387571      0.56238671      0.11859381    , d:   0.0000000      -1.6447762      0.74074073
 i,j,k,ie:    6    6    4          21
 Near X =  0.97387571      0.56238671      0.13437970    , d:   0.0000000      -2.0989602      0.74074073
 i,j,k,ie:    1    1    5          21
 Near X =   1.0411153     -0.49874810E-07   0.0000000    , d:   0.0000000     -0.13994284      0.74074073
 i,j,k,ie:    2    1    5          21
 Near X =   1.0411153     -0.49874810E-07  0.15785898E-01, d:   0.0000000     -0.13994284      0.74074073
 i,j,k,ie:    3    1    5          21
 Near X =   1.0411153     -0.49874810E-07  0.48025188E-01, d:   0.0000000     -0.13994284      0.74074073
 i,j,k,ie:    4    1    5          21
 Near X =   1.0411153     -0.49874810E-07  0.86354515E-01, d:   0.0000000     -0.13994284      0.74074073
 i,j,k,ie:    5    1    5          21
 Near X =   1.0411153     -0.49874810E-07  0.11859381    , d:   0.0000000     -0.13994284      0.74074073
 i,j,k,ie:    6    1    5          21
 Near X =   1.0411153     -0.49874810E-07  0.13437970    , d:   0.0000000      -1.9422879      0.74074073
 i,j,k,ie:    6    2    5          21
 Near X =   1.0246782      0.61134175E-01  0.13437970    , d:   0.0000000      -1.9422901      0.74074073
 i,j,k,ie:    6    3    5          21
 Near X =  0.99110887      0.18598764      0.13437970    , d:   0.0000000      -1.9422947      0.74074073
 i,j,k,ie:    6    4    5          21
 Near X =  0.95119827      0.33442605      0.13437970    , d:   0.0000000      -1.9423002      0.74074073
 i,j,k,ie:    6    5    5          21
 Near X =  0.91762895      0.45927951      0.13437970    , d:   0.0000000      -1.9423049      0.74074073
 i,j,k,ie:    1    6    5          21
 Near X =  0.90119180      0.52041374       0.0000000    , d:   0.0000000      -1.4994100      0.74074073
 i,j,k,ie:    2    6    5          21
 Near X =  0.90119180      0.52041374      0.15785898E-01, d:   0.0000000      -1.4994100      0.74074073
 i,j,k,ie:    3    6    5          21
 Near X =  0.90119180      0.52041374      0.48025188E-01, d:   0.0000000      -1.4994100      0.74074073
 i,j,k,ie:    4    6    5          21
 Near X =  0.90119180      0.52041374      0.86354515E-01, d:   0.0000000      -1.4994100      0.74074073
 i,j,k,ie:    5    6    5          21
 Near X =  0.90119180      0.52041374      0.11859381    , d:   0.0000000      -1.4994100      0.74074073
 i,j,k,ie:    6    6    5          21
 Near X =  0.90119180      0.52041374      0.13437970    , d:   0.0000000      -1.9423071      0.74074073
 i,j,k,ie:    1    1    6          21
 Near X =   1.0000000     -0.46163286E-07   0.0000000    , d:  0.35000001     -0.13441627      0.74074073
 i,j,k,ie:    2    1    6          21
 Near X =   1.0000000     -0.46163286E-07  0.15785898E-01, d:  0.35000001     -0.13441627      0.74074073
 i,j,k,ie:    3    1    6          21
 Near X =   1.0000000     -0.46163286E-07  0.48025188E-01, d:  0.35000001     -0.13441627      0.74074073
 i,j,k,ie:    4    1    6          21
 Near X =   1.0000000     -0.46163286E-07  0.86354515E-01, d:  0.35000001     -0.13441627      0.74074073
 i,j,k,ie:    5    1    6          21
 Near X =   1.0000000     -0.46163286E-07  0.11859381    , d:  0.35000001     -0.13441627      0.74074073
 i,j,k,ie:    6    1    6          21
 Near X =   1.0000000     -0.46163286E-07  0.13437970    , d:  0.35000001      -2.1685381      0.74074073
 i,j,k,ie:    1    2    6          21
 Near X =  0.98421199      0.58719889E-01   0.0000000    , d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    2    2    6          21
 Near X =  0.98421199      0.58719889E-01  0.15785898E-01, d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    3    2    6          21
 Near X =  0.98421199      0.58719889E-01  0.48025188E-01, d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    4    2    6          21
 Near X =  0.98421199      0.58719889E-01  0.86354515E-01, d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    5    2    6          21
 Near X =  0.98421199      0.58719889E-01  0.11859381    , d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    6    2    6          21
 Near X =  0.98421199      0.58719889E-01  0.13437970    , d:  0.34447421      -2.1740669      0.74074073
 i,j,k,ie:    1    3    6          21
 Near X =  0.95196838      0.17864269       0.0000000    , d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    2    3    6          21
 Near X =  0.95196838      0.17864269      0.15785898E-01, d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    3    3    6          21
 Near X =  0.95196838      0.17864269      0.48025188E-01, d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    4    3    6          21
 Near X =  0.95196838      0.17864269      0.86354515E-01, d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    5    3    6          21
 Near X =  0.95196838      0.17864269      0.11859381    , d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    6    3    6          21
 Near X =  0.95196838      0.17864269      0.13437970    , d:  0.33318894      -2.1853581      0.74074073
 i,j,k,ie:    1    4    6          21
 Near X =  0.91363392      0.32121903       0.0000000    , d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    2    4    6          21
 Near X =  0.91363392      0.32121903      0.15785898E-01, d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    3    4    6          21
 Near X =  0.91363392      0.32121903      0.48025188E-01, d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    4    4    6          21
 Near X =  0.91363392      0.32121903      0.86354515E-01, d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    5    4    6          21
 Near X =  0.91363392      0.32121903      0.11859381    , d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    6    4    6          21
 Near X =  0.91363392      0.32121903      0.13437970    , d:  0.31977188      -2.1987823      0.74074073
 i,j,k,ie:    1    5    6          21
 Near X =  0.88139030      0.44114183       0.0000000    , d:  0.30848662       0.0000000      0.74074073
 i,j,k,ie:    2    5    6          21
 Near X =  0.88139030      0.44114183      0.15785898E-01, d:  0.30848662       0.0000000      0.74074073
 i,j,k,ie:    3    5    6          21
 Near X =  0.88139030      0.44114183      0.48025188E-01, d:  0.30848662       0.0000000      0.74074073
 i,j,k,ie:    4    5    6          21
 Near X =  0.88139030      0.44114183      0.86354515E-01, d:  0.30848662       0.0000000      0.74074073
 i,j,k,ie:    5    5    6          21
 Near X =  0.88139030      0.44114183      0.11859381    , d:  0.30848662       0.0000000      0.74074073
 i,j,k,ie:    6    5    6          21
 Near X =  0.88139030      0.44114183      0.13437970    , d:  0.30848662      -2.2100736      0.74074073
 i,j,k,ie:    1    6    6          21
 Near X =  0.86560229      0.49986176       0.0000000    , d:  0.30296081      -1.7311861      0.74074073
 i,j,k,ie:    2    6    6          21
 Near X =  0.86560229      0.49986176      0.15785898E-01, d:  0.30296081      -1.7311861      0.74074073
 i,j,k,ie:    3    6    6          21
 Near X =  0.86560229      0.49986176      0.48025188E-01, d:  0.30296081      -1.7311861      0.74074073
 i,j,k,ie:    4    6    6          21
 Near X =  0.86560229      0.49986176      0.86354515E-01, d:  0.30296081      -1.7311861      0.74074073
 i,j,k,ie:    5    6    6          21
 Near X =  0.86560229      0.49986176      0.11859381    , d:  0.30296081      -1.7311861      0.74074073
 i,j,k,ie:    6    6    6          21
 Near X =  0.86560229      0.49986176      0.13437970    , d:  0.30296081      -2.2156023      0.74074073
 i,j,k,ie:    1    1    1          22
 Near X =  -1.1685381      0.67480674       0.0000000    , d:   2.5185381       0.0000000      0.74074073
 i,j,k,ie:    2    1    1          22
 Near X =  -1.1685381      0.67480674      0.15785898E-01, d:   1.8433514       0.0000000      0.74074073
 i,j,k,ie:    3    1    1          22
 Near X =  -1.1685381      0.67480674      0.48025188E-01, d:   1.8433514       0.0000000      0.74074073
 i,j,k,ie:    4    1    1          22
 Near X =  -1.1685381      0.67480674      0.86354515E-01, d:   1.8433514       0.0000000      0.74074073
 i,j,k,ie:    5    1    1          22
 Near X =  -1.1685381      0.67480674      0.11859381    , d:   1.8433514       0.0000000      0.74074073
 i,j,k,ie:    6    1    1          22
 Near X =  -1.1685381      0.67480674      0.13437970    , d:   1.8433514       0.0000000      0.74074073
 i,j,k,ie:    1    2    1          22
 Near X =  -1.1898549      0.59553562       0.0000000    , d:   2.5185411       0.0000000      0.74074073
 i,j,k,ie:    6    2    1          22
 Near X =  -1.1898549      0.59553562      0.13437970    , d:  0.45704247       0.0000000      0.74074073
 i,j,k,ie:    1    3    1          22
 Near X =  -1.2333897      0.43364145       0.0000000    , d:   2.5185471       0.0000000      0.74074073
 i,j,k,ie:    6    3    1          22
 Near X =  -1.2333897      0.43364145      0.13437970    , d:  0.38212691       0.0000000      0.74074073
 i,j,k,ie:    1    4    1          22
 Near X =  -1.2851484      0.24116530       0.0000000    , d:   2.5185542       0.0000000      0.74074073
 i,j,k,ie:    6    4    1          22
 Near X =  -1.2851484      0.24116530      0.13437970    , d:  0.29305972       0.0000000      0.74074073
 i,j,k,ie:    1    5    1          22
 Near X =  -1.3286833      0.79271126E-01   0.0000000    , d:   2.5185602       0.0000000      0.74074073
 i,j,k,ie:    6    5    1          22
 Near X =  -1.3286833      0.79271126E-01  0.13437970    , d:  0.21814416       0.0000000      0.74074073
 i,j,k,ie:    1    6    1          22
 Near X =  -1.3500000     -0.33065464E-15   0.0000000    , d:   2.5185631       0.0000000      0.74074073
 i,j,k,ie:    2    6    1          22
 Near X =  -1.3500000     -0.33065464E-15  0.15785898E-01, d:  0.85013825       0.0000000      0.74074073
 i,j,k,ie:    3    6    1          22
 Near X =  -1.3500000     -0.33065464E-15  0.48025188E-01, d:  0.85013825       0.0000000      0.74074073
 i,j,k,ie:    4    6    1          22
 Near X =  -1.3500000     -0.33065464E-15  0.86354515E-01, d:  0.85013825       0.0000000      0.74074073
 i,j,k,ie:    5    6    1          22
 Near X =  -1.3500000     -0.33065464E-15  0.11859381    , d:  0.85013825       0.0000000      0.74074073
 i,j,k,ie:    6    6    1          22
 Near X =  -1.3500000     -0.33065464E-15  0.13437970    , d:   1.3500001       0.0000000      0.74074073
 i,j,k,ie:    1    1    2          22
 Near X =  -1.1329494      0.65425497       0.0000000    , d:   2.4418341       0.0000000      0.74074073
 i,j,k,ie:    2    1    2          22
 Near X =  -1.1329494      0.65425497      0.15785898E-01, d:   1.7872107       0.0000000      0.74074073
 i,j,k,ie:    3    1    2          22
 Near X =  -1.1329494      0.65425497      0.48025188E-01, d:   1.7872107       0.0000000      0.74074073
 i,j,k,ie:    4    1    2          22
 Near X =  -1.1329494      0.65425497      0.86354515E-01, d:   1.7872107       0.0000000      0.74074073
 i,j,k,ie:    5    1    2          22
 Near X =  -1.1329494      0.65425497      0.11859381    , d:   1.7872107       0.0000000      0.74074073
 i,j,k,ie:    6    1    2          22
 Near X =  -1.1329494      0.65425497      0.13437970    , d:   1.7872107       0.0000000      0.74074073
 i,j,k,ie:    1    2    2          22
 Near X =  -1.1536169      0.57739811       0.0000000    , d:   2.4418369       0.0000000      0.74074073
 i,j,k,ie:    6    2    2          22
 Near X =  -1.1536169      0.57739811      0.13437970    , d:  0.44312288       0.0000000      0.74074073
 i,j,k,ie:    1    3    2          22
 Near X =  -1.1958259      0.42043455       0.0000000    , d:   2.4418427       0.0000000      0.74074073
 i,j,k,ie:    6    3    2          22
 Near X =  -1.1958259      0.42043455      0.13437970    , d:  0.37048893       0.0000000      0.74074073
 i,j,k,ie:    1    4    2          22
 Near X =  -1.2460082      0.23382042       0.0000000    , d:   2.4418496       0.0000000      0.74074073
 i,j,k,ie:    6    4    2          22
 Near X =  -1.2460082      0.23382042      0.13437970    , d:  0.28413435       0.0000000      0.74074073
 i,j,k,ie:    1    5    2          22
 Near X =  -1.2882172      0.76856861E-01   0.0000000    , d:   2.4418554       0.0000000      0.74074073
 i,j,k,ie:    6    5    2          22
 Near X =  -1.2882172      0.76856861E-01  0.13437970    , d:  0.21150040       0.0000000      0.74074073
 i,j,k,ie:    1    6    2          22
 Near X =  -1.3088847     -0.32058429E-15   0.0000000    , d:   2.4418583       0.0000000      0.74074073
 i,j,k,ie:    2    6    2          22
 Near X =  -1.3088847     -0.32058429E-15  0.15785898E-01, d:  0.82957491       0.0000000      0.74074073
 i,j,k,ie:    3    6    2          22
 Near X =  -1.3088847     -0.32058429E-15  0.48025188E-01, d:  0.82957491       0.0000000      0.74074073
 i,j,k,ie:    4    6    2          22
 Near X =  -1.3088847     -0.32058429E-15  0.86354515E-01, d:  0.82957491       0.0000000      0.74074073
 i,j,k,ie:    5    6    2          22
 Near X =  -1.3088847     -0.32058429E-15  0.11859381    , d:  0.82957491       0.0000000      0.74074073
 i,j,k,ie:    6    6    2          22
 Near X =  -1.3088847     -0.32058429E-15  0.13437970    , d:   1.3088847       0.0000000      0.74074073
 i,j,k,ie:    1    1    3          22
 Near X =  -1.0602670      0.61228241       0.0000000    , d:   2.2851825       0.0000000      0.74074073
 i,j,k,ie:    2    1    3          22
 Near X =  -1.0602670      0.61228241      0.15785898E-01, d:   1.6725554       0.0000000      0.74074073
 i,j,k,ie:    3    1    3          22
 Near X =  -1.0602670      0.61228241      0.48025188E-01, d:   1.6725554       0.0000000      0.74074073
 i,j,k,ie:    4    1    3          22
 Near X =  -1.0602670      0.61228241      0.86354515E-01, d:   1.6725554       0.0000000      0.74074073
 i,j,k,ie:    5    1    3          22
 Near X =  -1.0602670      0.61228241      0.11859381    , d:   1.6725554       0.0000000      0.74074073
 i,j,k,ie:    6    1    3          22
 Near X =  -1.0602670      0.61228241      0.13437970    , d:   1.6725554       0.0000000      0.74074073
 i,j,k,ie:    1    2    3          22
 Near X =  -1.0796087      0.54035616       0.0000000    , d:   2.2851852       0.0000000      0.74074073
 i,j,k,ie:    6    2    3          22
 Near X =  -1.0796087      0.54035616      0.13437970    , d:  0.41469512       0.0000000      0.74074073
 i,j,k,ie:    1    3    3          22
 Near X =  -1.1191098      0.39346232       0.0000000    , d:   2.2851906       0.0000000      0.74074073
 i,j,k,ie:    6    3    3          22
 Near X =  -1.1191098      0.39346232      0.13437970    , d:  0.34672087       0.0000000      0.74074073
 i,j,k,ie:    1    4    3          22
 Near X =  -1.1660727      0.21882008       0.0000000    , d:   2.2851971       0.0000000      0.74074073
 i,j,k,ie:    6    4    3          22
 Near X =  -1.1660727      0.21882008      0.13437970    , d:  0.26590622       0.0000000      0.74074073
 i,j,k,ie:    1    5    3          22
 Near X =  -1.2055739      0.71926246E-01   0.0000000    , d:   2.2852025       0.0000000      0.74074073
 i,j,k,ie:    6    5    3          22
 Near X =  -1.2055739      0.71926246E-01  0.13437970    , d:  0.19793197       0.0000000      0.74074073
 i,j,k,ie:    1    6    3          22
 Near X =  -1.2249155     -0.30001778E-15   0.0000000    , d:   2.2852052       0.0000000      0.74074073
 i,j,k,ie:    2    6    3          22
 Near X =  -1.2249155     -0.30001778E-15  0.15785898E-01, d:  0.78757872       0.0000000      0.74074073
 i,j,k,ie:    3    6    3          22
 Near X =  -1.2249155     -0.30001778E-15  0.48025188E-01, d:  0.78757872       0.0000000      0.74074073
 i,j,k,ie:    4    6    3          22
 Near X =  -1.2249155     -0.30001778E-15  0.86354515E-01, d:  0.78757872       0.0000000      0.74074073
 i,j,k,ie:    5    6    3          22
 Near X =  -1.2249155     -0.30001778E-15  0.11859381    , d:  0.78757872       0.0000000      0.74074073
 i,j,k,ie:    6    6    3          22
 Near X =  -1.2249155     -0.30001778E-15  0.13437970    , d:   1.2249156       0.0000000      0.74074073
 i,j,k,ie:    1    1    4          22
 Near X = -0.97385488      0.56238118       0.0000000    , d:   2.0989394       0.0000000      0.74074073
 i,j,k,ie:    2    1    4          22
 Near X = -0.97385488      0.56238118      0.15785898E-01, d:   1.5362415       0.0000000      0.74074073
 i,j,k,ie:    3    1    4          22
 Near X = -0.97385488      0.56238118      0.48025188E-01, d:   1.5362415       0.0000000      0.74074073
 i,j,k,ie:    4    1    4          22
 Near X = -0.97385488      0.56238118      0.86354515E-01, d:   1.5362415       0.0000000      0.74074073
 i,j,k,ie:    5    1    4          22
 Near X = -0.97385488      0.56238118      0.11859381    , d:   1.5362415       0.0000000      0.74074073
 i,j,k,ie:    6    1    4          22
 Near X = -0.97385488      0.56238118      0.13437970    , d:   1.5362415       0.0000000      0.74074073
 i,j,k,ie:    1    2    4          22
 Near X = -0.99162018      0.49631695       0.0000000    , d:   2.0989418       0.0000000      0.74074073
 i,j,k,ie:    6    2    4          22
 Near X = -0.99162018      0.49631695      0.13437970    , d:  0.38089732       0.0000000      0.74074073
 i,j,k,ie:    1    3    4          22
 Near X =  -1.0279020      0.36139501       0.0000000    , d:   2.0989468       0.0000000      0.74074073
 i,j,k,ie:    6    3    4          22
 Near X =  -1.0279020      0.36139501      0.13437970    , d:  0.31846300       0.0000000      0.74074073
 i,j,k,ie:    1    4    4          22
 Near X =  -1.0710374      0.20098617       0.0000000    , d:   2.0989528       0.0000000      0.74074073
 i,j,k,ie:    6    4    4          22
 Near X =  -1.0710374      0.20098617      0.13437970    , d:  0.24423477       0.0000000      0.74074073
 i,j,k,ie:    1    5    4          22
 Near X =  -1.1073192      0.66064232E-01   0.0000000    , d:   2.0989578       0.0000000      0.74074073
 i,j,k,ie:    6    5    4          22
 Near X =  -1.1073192      0.66064232E-01  0.13437970    , d:  0.18180045       0.0000000      0.74074073
 i,j,k,ie:    1    6    4          22
 Near X =  -1.1250845     -0.27556623E-15   0.0000000    , d:   2.0989602       0.0000000      0.74074073
 i,j,k,ie:    2    6    4          22
 Near X =  -1.1250845     -0.27556623E-15  0.15785898E-01, d:  0.73764940       0.0000000      0.74074073
 i,j,k,ie:    3    6    4          22
 Near X =  -1.1250845     -0.27556623E-15  0.48025188E-01, d:  0.73764940       0.0000000      0.74074073
 i,j,k,ie:    4    6    4          22
 Near X =  -1.1250845     -0.27556623E-15  0.86354515E-01, d:  0.73764940       0.0000000      0.74074073
 i,j,k,ie:    5    6    4          22
 Near X =  -1.1250845     -0.27556623E-15  0.11859381    , d:  0.73764940       0.0000000      0.74074073
 i,j,k,ie:    6    6    4          22
 Near X =  -1.1250845     -0.27556623E-15  0.13437970    , d:   1.1250845       0.0000000      0.74074073
 i,j,k,ie:    1    1    5          22
 Near X = -0.90117253      0.52040862       0.0000000    , d:   1.9422879       0.0000000      0.74074073
 i,j,k,ie:    2    1    5          22
 Near X = -0.90117253      0.52040862      0.15785898E-01, d:   1.4215862       0.0000000      0.74074073
 i,j,k,ie:    3    1    5          22
 Near X = -0.90117253      0.52040862      0.48025188E-01, d:   1.4215862       0.0000000      0.74074073
 i,j,k,ie:    4    1    5          22
 Near X = -0.90117253      0.52040862      0.86354515E-01, d:   1.4215862       0.0000000      0.74074073
 i,j,k,ie:    5    1    5          22
 Near X = -0.90117253      0.52040862      0.11859381    , d:   1.4215862       0.0000000      0.74074073
 i,j,k,ie:    6    1    5          22
 Near X = -0.90117253      0.52040862      0.13437970    , d:   1.4215862       0.0000000      0.74074073
 i,j,k,ie:    1    2    5          22
 Near X = -0.91761194      0.45927500       0.0000000    , d:   1.9422901       0.0000000      0.74074073
 i,j,k,ie:    6    2    5          22
 Near X = -0.91761194      0.45927500      0.13437970    , d:  0.35246956       0.0000000      0.74074073
 i,j,k,ie:    1    3    5          22
 Near X = -0.95118588      0.33442278       0.0000000    , d:   1.9422947       0.0000000      0.74074073
 i,j,k,ie:    6    3    5          22
 Near X = -0.95118588      0.33442278      0.13437970    , d:  0.29469494       0.0000000      0.74074073
 i,j,k,ie:    1    4    5          22
 Near X = -0.99110198      0.18598584       0.0000000    , d:   1.9423002       0.0000000      0.74074073
 i,j,k,ie:    6    4    5          22
 Near X = -0.99110198      0.18598584      0.13437970    , d:  0.22600664       0.0000000      0.74074073
 i,j,k,ie:    1    5    5          22
 Near X =  -1.0246759      0.61133617E-01   0.0000000    , d:   1.9423049       0.0000000      0.74074073
 i,j,k,ie:    6    5    5          22
 Near X =  -1.0246759      0.61133617E-01  0.13437970    , d:  0.16823202       0.0000000      0.74074073
 i,j,k,ie:    1    6    5          22
 Near X =  -1.0411153     -0.25499971E-15   0.0000000    , d:   1.9423071       0.0000000      0.74074073
 i,j,k,ie:    2    6    5          22
 Near X =  -1.0411153     -0.25499971E-15  0.15785898E-01, d:  0.69565321       0.0000000      0.74074073
 i,j,k,ie:    3    6    5          22
 Near X =  -1.0411153     -0.25499971E-15  0.48025188E-01, d:  0.69565321       0.0000000      0.74074073
 i,j,k,ie:    4    6    5          22
 Near X =  -1.0411153     -0.25499971E-15  0.86354515E-01, d:  0.69565321       0.0000000      0.74074073
 i,j,k,ie:    5    6    5          22
 Near X =  -1.0411153     -0.25499971E-15  0.11859381    , d:  0.69565321       0.0000000      0.74074073
 i,j,k,ie:    6    6    5          22
 Near X =  -1.0411153     -0.25499971E-15  0.13437970    , d:   1.0411154       0.0000000      0.74074073
 i,j,k,ie:    1    1    6          22
 Near X = -0.86558378      0.49985684       0.0000000    , d:   2.2155838     -0.30295433      0.74074073
 i,j,k,ie:    2    1    6          22
 Near X = -0.86558378      0.49985684      0.15785898E-01, d:   1.5403971     -0.30295433      0.74074073
 i,j,k,ie:    3    1    6          22
 Near X = -0.86558378      0.49985684      0.48025188E-01, d:   1.5403971     -0.30295433      0.74074073
 i,j,k,ie:    4    1    6          22
 Near X = -0.86558378      0.49985684      0.86354515E-01, d:   1.5403971     -0.30295433      0.74074073
 i,j,k,ie:    5    1    6          22
 Near X = -0.86558378      0.49985684      0.11859381    , d:   1.5403971     -0.30295433      0.74074073
 i,j,k,ie:    6    1    6          22
 Near X = -0.86558378      0.49985684      0.13437970    , d:   1.5403971     -0.30295433      0.74074073
 i,j,k,ie:    1    2    6          22
 Near X = -0.88137396      0.44113749       0.0000000    , d:   2.2100602     -0.30848090      0.74074073
 i,j,k,ie:    2    2    6          22
 Near X = -0.88137396      0.44113749      0.15785898E-01, d:   0.0000000     -0.30848090      0.74074073
 i,j,k,ie:    3    2    6          22
 Near X = -0.88137396      0.44113749      0.48025188E-01, d:   0.0000000     -0.30848090      0.74074073
 i,j,k,ie:    4    2    6          22
 Near X = -0.88137396      0.44113749      0.86354515E-01, d:   0.0000000     -0.30848090      0.74074073
 i,j,k,ie:    5    2    6          22
 Near X = -0.88137396      0.44113749      0.11859381    , d:   0.0000000     -0.30848090      0.74074073
 i,j,k,ie:    6    2    6          22
 Near X = -0.88137396      0.44113749      0.13437970    , d:  0.33854997     -0.30848090      0.74074073
 i,j,k,ie:    1    3    6          22
 Near X = -0.91362202      0.32121588       0.0000000    , d:   2.1987793     -0.31976772      0.74074073
 i,j,k,ie:    2    3    6          22
 Near X = -0.91362202      0.32121588      0.15785898E-01, d:   0.0000000     -0.31976772      0.74074073
 i,j,k,ie:    3    3    6          22
 Near X = -0.91362202      0.32121588      0.48025188E-01, d:   0.0000000     -0.31976772      0.74074073
 i,j,k,ie:    4    3    6          22
 Near X = -0.91362202      0.32121588      0.86354515E-01, d:   0.0000000     -0.31976772      0.74074073
 i,j,k,ie:    5    3    6          22
 Near X = -0.91362202      0.32121588      0.11859381    , d:   0.0000000     -0.31976772      0.74074073
 i,j,k,ie:    6    3    6          22
 Near X = -0.91362202      0.32121588      0.13437970    , d:  0.28305696     -0.31976772      0.74074073
 i,j,k,ie:    1    4    6          22
 Near X = -0.95196177      0.17864096       0.0000000    , d:   2.1853676     -0.33318663      0.74074073
 i,j,k,ie:    2    4    6          22
 Near X = -0.95196177      0.17864096      0.15785898E-01, d:   0.0000000     -0.33318663      0.74074073
 i,j,k,ie:    3    4    6          22
 Near X = -0.95196177      0.17864096      0.48025188E-01, d:   0.0000000     -0.33318663      0.74074073
 i,j,k,ie:    4    4    6          22
 Near X = -0.95196177      0.17864096      0.86354515E-01, d:   0.0000000     -0.33318663      0.74074073
 i,j,k,ie:    5    4    6          22
 Near X = -0.95196177      0.17864096      0.11859381    , d:   0.0000000     -0.33318663      0.74074073
 i,j,k,ie:    6    4    6          22
 Near X = -0.95196177      0.17864096      0.13437970    , d:  0.21708127     -0.33318663      0.74074073
 i,j,k,ie:    1    5    6          22
 Near X = -0.98420982      0.58719352E-01   0.0000000    , d:   2.1740867     -0.34447345      0.74074073
 i,j,k,ie:    2    5    6          22
 Near X = -0.98420982      0.58719352E-01  0.15785898E-01, d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    3    5    6          22
 Near X = -0.98420982      0.58719352E-01  0.48025188E-01, d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    4    5    6          22
 Near X = -0.98420982      0.58719352E-01  0.86354515E-01, d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    5    5    6          22
 Near X = -0.98420982      0.58719352E-01  0.11859381    , d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    6    5    6          22
 Near X = -0.98420982      0.58719352E-01  0.13437970    , d:  0.16158826     -0.34447345      0.74074073
 i,j,k,ie:    1    6    6          22
 Near X =  -1.0000000     -0.24492936E-15   0.0000000    , d:   2.1685631     -0.35000001      0.74074073
 i,j,k,ie:    2    6    6          22
 Near X =  -1.0000000     -0.24492936E-15  0.15785898E-01, d:  0.67508987     -0.35000001      0.74074073
 i,j,k,ie:    3    6    6          22
 Near X =  -1.0000000     -0.24492936E-15  0.48025188E-01, d:  0.67508987     -0.35000001      0.74074073
 i,j,k,ie:    4    6    6          22
 Near X =  -1.0000000     -0.24492936E-15  0.86354515E-01, d:  0.67508987     -0.35000001      0.74074073
 i,j,k,ie:    5    6    6          22
 Near X =  -1.0000000     -0.24492936E-15  0.11859381    , d:  0.67508987     -0.35000001      0.74074073
 i,j,k,ie:    6    6    6          22
 Near X =  -1.0000000     -0.24492936E-15  0.13437970    , d:   1.0000000     -0.35000001      0.74074073
 i,j,k,ie:    1    1    1          23
 Near X = -0.67481340       1.1685631       0.0000000    , d:   1.3496267     -0.49372471      0.85577012
 i,j,k,ie:    2    1    1          23
 Near X = -0.67481340       1.1685631      0.15785898E-01, d:  0.67481345       0.0000000      0.85577012
 i,j,k,ie:    3    1    1          23
 Near X = -0.67481340       1.1685631      0.48025188E-01, d:  0.67481345       0.0000000      0.85577012
 i,j,k,ie:    4    1    1          23
 Near X = -0.67481340       1.1685631      0.86354515E-01, d:  0.67481345       0.0000000      0.85577012
 i,j,k,ie:    5    1    1          23
 Near X = -0.67481340       1.1685631      0.11859381    , d:  0.67481345       0.0000000      0.85577012
 i,j,k,ie:    6    1    1          23
 Near X = -0.67481340       1.1685631      0.13437970    , d:   1.3496202       0.0000000      0.85577012
 i,j,k,ie:    1    2    1          23
 Near X = -0.73281240       1.1105604       0.0000000    , d:   0.0000000     -0.45704247      0.85577012
 i,j,k,ie:    6    2    1          23
 Near X = -0.73281240       1.1105604      0.13437970    , d:  0.65354054       0.0000000      0.85577012
 i,j,k,ie:    1    3    1          23
 Near X = -0.85126283      0.99210234       0.0000000    , d:   0.0000000     -0.38212691      0.85577012
 i,j,k,ie:    6    3    1          23
 Near X = -0.85126283      0.99210234      0.13437970    , d:  0.61009519       0.0000000      0.85577012
 i,j,k,ie:    1    4    1          23
 Near X = -0.99208868      0.85126747       0.0000000    , d:   0.0000000     -0.29305972      0.85577012
 i,j,k,ie:    6    4    1          23
 Near X = -0.99208868      0.85126747      0.13437970    , d:  0.55844297       0.0000000      0.85577012
 i,j,k,ie:    1    5    1          23
 Near X =  -1.1105391      0.73280945       0.0000000    , d:   0.0000000     -0.21814416      0.85577012
 i,j,k,ie:    6    5    1          23
 Near X =  -1.1105391      0.73280945      0.13437970    , d:  0.51499762       0.0000000      0.85577012
 i,j,k,ie:    1    6    1          23
 Near X =  -1.1685381      0.67480674       0.0000000    , d:   1.1685381     -0.18146192      0.85577012
 i,j,k,ie:    2    6    1          23
 Near X =  -1.1685381      0.67480674      0.15785898E-01, d:   1.1685381       0.0000000      0.85577012
 i,j,k,ie:    3    6    1          23
 Near X =  -1.1685381      0.67480674      0.48025188E-01, d:   1.1685381       0.0000000      0.85577012
 i,j,k,ie:    4    6    1          23
 Near X =  -1.1685381      0.67480674      0.86354515E-01, d:   1.1685381       0.0000000      0.85577012
 i,j,k,ie:    5    6    1          23
 Near X =  -1.1685381      0.67480674      0.11859381    , d:   1.1685381       0.0000000      0.85577012
 i,j,k,ie:    6    6    1          23
 Near X =  -1.1685381      0.67480674      0.13437970    , d:   1.6683950       0.0000000      0.85577012
 i,j,k,ie:    1    1    2          23
 Near X = -0.65426142       1.1329736       0.0000000    , d:   1.3085228     -0.47868793      0.85577012
 i,j,k,ie:    2    1    2          23
 Near X = -0.65426142       1.1329736      0.15785898E-01, d:  0.65426148       0.0000000      0.85577012
 i,j,k,ie:    3    1    2          23
 Near X = -0.65426142       1.1329736      0.48025188E-01, d:  0.65426148       0.0000000      0.85577012
 i,j,k,ie:    4    1    2          23
 Near X = -0.65426142       1.1329736      0.86354515E-01, d:  0.65426148       0.0000000      0.85577012
 i,j,k,ie:    5    1    2          23
 Near X = -0.65426142       1.1329736      0.11859381    , d:  0.65426148       0.0000000      0.85577012
 i,j,k,ie:    6    1    2          23
 Near X = -0.65426142       1.1329736      0.13437970    , d:   1.3085164       0.0000000      0.85577012
 i,j,k,ie:    1    2    2          23
 Near X = -0.71049401       1.0767374       0.0000000    , d:   0.0000000     -0.44312288      0.85577012
 i,j,k,ie:    6    2    2          23
 Near X = -0.71049401       1.0767374      0.13437970    , d:  0.63363644       0.0000000      0.85577012
 i,j,k,ie:    1    3    2          23
 Near X = -0.82533695      0.96188708       0.0000000    , d:   0.0000000     -0.37048893      0.85577012
 i,j,k,ie:    6    3    2          23
 Near X = -0.82533695      0.96188708      0.13437970    , d:  0.59151426       0.0000000      0.85577012
 i,j,k,ie:    1    4    2          23
 Near X = -0.96187383      0.82534145       0.0000000    , d:   0.0000000     -0.28413435      0.85577012
 i,j,k,ie:    6    4    2          23
 Near X = -0.96187383      0.82534145      0.13437970    , d:  0.54143515       0.0000000      0.85577012
 i,j,k,ie:    1    5    2          23
 Near X =  -1.0767168      0.71049116       0.0000000    , d:   0.0000000     -0.21150040      0.85577012
 i,j,k,ie:    6    5    2          23
 Near X =  -1.0767168      0.71049116      0.13437970    , d:  0.49931296       0.0000000      0.85577012
 i,j,k,ie:    1    6    2          23
 Near X =  -1.1329494      0.65425497       0.0000000    , d:   1.1329494     -0.17593535      0.85577012
 i,j,k,ie:    2    6    2          23
 Near X =  -1.1329494      0.65425497      0.15785898E-01, d:   1.1329494       0.0000000      0.85577012
 i,j,k,ie:    3    6    2          23
 Near X =  -1.1329494      0.65425497      0.48025188E-01, d:   1.1329494       0.0000000      0.85577012
 i,j,k,ie:    4    6    2          23
 Near X =  -1.1329494      0.65425497      0.86354515E-01, d:   1.1329494       0.0000000      0.85577012
 i,j,k,ie:    5    6    2          23
 Near X =  -1.1329494      0.65425497      0.11859381    , d:   1.1329494       0.0000000      0.85577012
 i,j,k,ie:    6    6    2          23
 Near X =  -1.1329494      0.65425497      0.13437970    , d:   1.6122545       0.0000000      0.85577012
 i,j,k,ie:    1    1    3          23
 Near X = -0.61228845       1.0602897       0.0000000    , d:   1.2245768     -0.44797856      0.85577012
 i,j,k,ie:    2    1    3          23
 Near X = -0.61228845       1.0602897      0.15785898E-01, d:  0.61228850       0.0000000      0.85577012
 i,j,k,ie:    3    1    3          23
 Near X = -0.61228845       1.0602897      0.48025188E-01, d:  0.61228850       0.0000000      0.85577012
 i,j,k,ie:    4    1    3          23
 Near X = -0.61228845       1.0602897      0.86354515E-01, d:  0.61228850       0.0000000      0.85577012
 i,j,k,ie:    5    1    3          23
 Near X = -0.61228845       1.0602897      0.11859381    , d:  0.61228850       0.0000000      0.85577012
 i,j,k,ie:    6    1    3          23
 Near X = -0.61228845       1.0602897      0.13437970    , d:   1.2245709       0.0000000      0.85577012
 i,j,k,ie:    1    2    3          23
 Near X = -0.66491354       1.0076612       0.0000000    , d:   0.0000000     -0.41469512      0.85577012
 i,j,k,ie:    6    2    3          23
 Near X = -0.66491354       1.0076612      0.13437970    , d:  0.59298662       0.0000000      0.85577012
 i,j,k,ie:    1    3    3          23
 Near X = -0.77238892      0.90017892       0.0000000    , d:   0.0000000     -0.34672087      0.85577012
 i,j,k,ie:    6    3    3          23
 Near X = -0.77238892      0.90017892      0.13437970    , d:  0.55356671       0.0000000      0.85577012
 i,j,k,ie:    1    4    3          23
 Near X = -0.90016653      0.77239314       0.0000000    , d:   0.0000000     -0.26590622      0.85577012
 i,j,k,ie:    6    4    3          23
 Near X = -0.90016653      0.77239314      0.13437970    , d:  0.50670034       0.0000000      0.85577012
 i,j,k,ie:    1    5    3          23
 Near X =  -1.0076419      0.66491086       0.0000000    , d:   0.0000000     -0.19793197      0.85577012
 i,j,k,ie:    6    5    3          23
 Near X =  -1.0076419      0.66491086      0.13437970    , d:  0.46728043       0.0000000      0.85577012
 i,j,k,ie:    1    6    3          23
 Near X =  -1.0602670      0.61228241       0.0000000    , d:   1.0602670     -0.16464853      0.85577012
 i,j,k,ie:    2    6    3          23
 Near X =  -1.0602670      0.61228241      0.15785898E-01, d:   1.0602670       0.0000000      0.85577012
 i,j,k,ie:    3    6    3          23
 Near X =  -1.0602670      0.61228241      0.48025188E-01, d:   1.0602670       0.0000000      0.85577012
 i,j,k,ie:    4    6    3          23
 Near X =  -1.0602670      0.61228241      0.86354515E-01, d:   1.0602670       0.0000000      0.85577012
 i,j,k,ie:    5    6    3          23
 Near X =  -1.0602670      0.61228241      0.11859381    , d:   1.0602670       0.0000000      0.85577012
 i,j,k,ie:    6    6    3          23
 Near X =  -1.0602670      0.61228241      0.13437970    , d:   1.4975995       0.0000000      0.85577012
 i,j,k,ie:    1    1    4          23
 Near X = -0.56238673      0.97387568       0.0000000    , d:   1.1247734     -0.41146815      0.85577012
 i,j,k,ie:    2    1    4          23
 Near X = -0.56238673      0.97387568      0.15785898E-01, d:  0.56238677       0.0000000      0.85577012
 i,j,k,ie:    3    1    4          23
 Near X = -0.56238673      0.97387568      0.48025188E-01, d:  0.56238677       0.0000000      0.85577012
 i,j,k,ie:    4    1    4          23
 Near X = -0.56238673      0.97387568      0.86354515E-01, d:  0.56238677       0.0000000      0.85577012
 i,j,k,ie:    5    1    4          23
 Near X = -0.56238673      0.97387568      0.11859381    , d:  0.56238677       0.0000000      0.85577012
 i,j,k,ie:    6    1    4          23
 Near X = -0.56238673      0.97387568      0.13437970    , d:   1.1247679       0.0000000      0.85577012
 i,j,k,ie:    1    2    4          23
 Near X = -0.61072285      0.92553646       0.0000000    , d:   0.0000000     -0.38089732      0.85577012
 i,j,k,ie:    6    2    4          23
 Near X = -0.61072285      0.92553646      0.13437970    , d:  0.54465801       0.0000000      0.85577012
 i,j,k,ie:    1    3    4          23
 Near X = -0.70943896      0.82681403       0.0000000    , d:   0.0000000     -0.31846300      0.85577012
 i,j,k,ie:    6    3    4          23
 Near X = -0.70943896      0.82681403      0.13437970    , d:  0.50845084       0.0000000      0.85577012
 i,j,k,ie:    1    4    4          23
 Near X = -0.82680265      0.70944283       0.0000000    , d:   0.0000000     -0.24423477      0.85577012
 i,j,k,ie:    6    4    4          23
 Near X = -0.82680265      0.70944283      0.13437970    , d:  0.46540409       0.0000000      0.85577012
 i,j,k,ie:    1    5    4          23
 Near X = -0.92551875      0.61072040       0.0000000    , d:   0.0000000     -0.18180045      0.85577012
 i,j,k,ie:    6    5    4          23
 Near X = -0.92551875      0.61072040      0.13437970    , d:  0.42919691       0.0000000      0.85577012
 i,j,k,ie:    1    6    4          23
 Near X = -0.97385488      0.56238118       0.0000000    , d:  0.97385491     -0.15122962      0.85577012
 i,j,k,ie:    2    6    4          23
 Near X = -0.97385488      0.56238118      0.15785898E-01, d:  0.97385491       0.0000000      0.85577012
 i,j,k,ie:    3    6    4          23
 Near X = -0.97385488      0.56238118      0.48025188E-01, d:  0.97385491       0.0000000      0.85577012
 i,j,k,ie:    4    6    4          23
 Near X = -0.97385488      0.56238118      0.86354515E-01, d:  0.97385491       0.0000000      0.85577012
 i,j,k,ie:    5    6    4          23
 Near X = -0.97385488      0.56238118      0.11859381    , d:  0.97385491       0.0000000      0.85577012
 i,j,k,ie:    6    6    4          23
 Near X = -0.97385488      0.56238118      0.13437970    , d:   1.3612862       0.0000000      0.85577012
 i,j,k,ie:    1    1    5          23
 Near X = -0.52041375      0.90119178       0.0000000    , d:   1.0408274     -0.38075878      0.85577012
 i,j,k,ie:    2    1    5          23
 Near X = -0.52041375      0.90119178      0.15785898E-01, d:  0.52041379       0.0000000      0.85577012
 i,j,k,ie:    3    1    5          23
 Near X = -0.52041375      0.90119178      0.48025188E-01, d:  0.52041379       0.0000000      0.85577012
 i,j,k,ie:    4    1    5          23
 Near X = -0.52041375      0.90119178      0.86354515E-01, d:  0.52041379       0.0000000      0.85577012
 i,j,k,ie:    5    1    5          23
 Near X = -0.52041375      0.90119178      0.11859381    , d:  0.52041379       0.0000000      0.85577012
 i,j,k,ie:    6    1    5          23
 Near X = -0.52041375      0.90119178      0.13437970    , d:   1.0408224       0.0000000      0.85577012
 i,j,k,ie:    1    2    5          23
 Near X = -0.56514238      0.85646029       0.0000000    , d:   0.0000000     -0.35246956      0.85577012
 i,j,k,ie:    6    2    5          23
 Near X = -0.56514238      0.85646029      0.13437970    , d:  0.50400819       0.0000000      0.85577012
 i,j,k,ie:    1    3    5          23
 Near X = -0.65649094      0.76510588       0.0000000    , d:   0.0000000     -0.29469494      0.85577012
 i,j,k,ie:    6    3    5          23
 Near X = -0.65649094      0.76510588      0.13437970    , d:  0.47050329       0.0000000      0.85577012
 i,j,k,ie:    1    4    5          23
 Near X = -0.76509534      0.65649452       0.0000000    , d:   0.0000000     -0.22600664      0.85577012
 i,j,k,ie:    6    4    5          23
 Near X = -0.76509534      0.65649452      0.13437970    , d:  0.43066928       0.0000000      0.85577012
 i,j,k,ie:    1    5    5          23
 Near X = -0.85644391      0.56514010       0.0000000    , d:   0.0000000     -0.16823202      0.85577012
 i,j,k,ie:    6    5    5          23
 Near X = -0.85644391      0.56514010      0.13437970    , d:  0.39716438       0.0000000      0.85577012
 i,j,k,ie:    1    6    5          23
 Near X = -0.90117253      0.52040862       0.0000000    , d:  0.90117256     -0.13994280      0.85577012
 i,j,k,ie:    2    6    5          23
 Near X = -0.90117253      0.52040862      0.15785898E-01, d:  0.90117256       0.0000000      0.85577012
 i,j,k,ie:    3    6    5          23
 Near X = -0.90117253      0.52040862      0.48025188E-01, d:  0.90117256       0.0000000      0.85577012
 i,j,k,ie:    4    6    5          23
 Near X = -0.90117253      0.52040862      0.86354515E-01, d:  0.90117256       0.0000000      0.85577012
 i,j,k,ie:    5    6    5          23
 Near X = -0.90117253      0.52040862      0.11859381    , d:  0.90117256       0.0000000      0.85577012
 i,j,k,ie:    6    6    5          23
 Near X = -0.90117253      0.52040862      0.13437970    , d:   1.2466313       0.0000000      0.85577012
 i,j,k,ie:    1    1    6          23
 Near X = -0.49986177      0.86560227       0.0000000    , d:   1.1746751     -0.66867633      0.85577012
 i,j,k,ie:    2    1    6          23
 Near X = -0.49986177      0.86560227      0.15785898E-01, d:  0.49986183     -0.17495163      0.85577012
 i,j,k,ie:    3    1    6          23
 Near X = -0.49986177      0.86560227      0.48025188E-01, d:  0.49986183     -0.17495163      0.85577012
 i,j,k,ie:    4    1    6          23
 Near X = -0.49986177      0.86560227      0.86354515E-01, d:  0.49986183     -0.17495163      0.85577012
 i,j,k,ie:    5    1    6          23
 Near X = -0.49986177      0.86560227      0.11859381    , d:  0.49986183     -0.17495163      0.85577012
 i,j,k,ie:    6    1    6          23
 Near X = -0.49986177      0.86560227      0.13437970    , d:   1.1746686     -0.17495163      0.85577012
 i,j,k,ie:    1    2    6          23
 Near X = -0.54282399      0.82263730       0.0000000    , d:   0.0000000     -0.64703087      0.85577012
 i,j,k,ie:    2    2    6          23
 Near X = -0.54282399      0.82263730      0.15785898E-01, d:   0.0000000     -0.18998840      0.85577012
 i,j,k,ie:    3    2    6          23
 Near X = -0.54282399      0.82263730      0.48025188E-01, d:   0.0000000     -0.18998840      0.85577012
 i,j,k,ie:    4    2    6          23
 Near X = -0.54282399      0.82263730      0.86354515E-01, d:   0.0000000     -0.18998840      0.85577012
 i,j,k,ie:    5    2    6          23
 Near X = -0.54282399      0.82263730      0.11859381    , d:   0.0000000     -0.18998840      0.85577012
 i,j,k,ie:    6    2    6          23
 Near X = -0.54282399      0.82263730      0.13437970    , d:  0.48410410     -0.18998840      0.85577012
 i,j,k,ie:    1    3    6          23
 Near X = -0.63056505      0.73489061       0.0000000    , d:   0.0000000     -0.60282468      0.85577012
 i,j,k,ie:    2    3    6          23
 Near X = -0.63056505      0.73489061      0.15785898E-01, d:   0.0000000     -0.22069778      0.85577012
 i,j,k,ie:    3    3    6          23
 Near X = -0.63056505      0.73489061      0.48025188E-01, d:   0.0000000     -0.22069778      0.85577012
 i,j,k,ie:    4    3    6          23
 Near X = -0.63056505      0.73489061      0.86354515E-01, d:   0.0000000     -0.22069778      0.85577012
 i,j,k,ie:    5    3    6          23
 Near X = -0.63056505      0.73489061      0.11859381    , d:   0.0000000     -0.22069778      0.85577012
 i,j,k,ie:    6    3    6          23
 Near X = -0.63056505      0.73489061      0.13437970    , d:  0.45192236     -0.22069778      0.85577012
 i,j,k,ie:    1    4    6          23
 Near X = -0.73488050      0.63056849       0.0000000    , d:   0.0000000     -0.55026790      0.85577012
 i,j,k,ie:    2    4    6          23
 Near X = -0.73488050      0.63056849      0.15785898E-01, d:   0.0000000     -0.25720818      0.85577012
 i,j,k,ie:    3    4    6          23
 Near X = -0.73488050      0.63056849      0.48025188E-01, d:   0.0000000     -0.25720818      0.85577012
 i,j,k,ie:    4    4    6          23
 Near X = -0.73488050      0.63056849      0.86354515E-01, d:   0.0000000     -0.25720818      0.85577012
 i,j,k,ie:    5    4    6          23
 Near X = -0.73488050      0.63056849      0.11859381    , d:   0.0000000     -0.25720818      0.85577012
 i,j,k,ie:    6    4    6          23
 Near X = -0.73488050      0.63056849      0.13437970    , d:  0.41366146     -0.25720818      0.85577012
 i,j,k,ie:    1    5    6          23
 Near X = -0.82262156      0.54282181       0.0000000    , d:   0.0000000     -0.50606171      0.85577012
 i,j,k,ie:    2    5    6          23
 Near X = -0.82262156      0.54282181      0.15785898E-01, d:   0.0000000     -0.28791755      0.85577012
 i,j,k,ie:    3    5    6          23
 Near X = -0.82262156      0.54282181      0.48025188E-01, d:   0.0000000     -0.28791755      0.85577012
 i,j,k,ie:    4    5    6          23
 Near X = -0.82262156      0.54282181      0.86354515E-01, d:   0.0000000     -0.28791755      0.85577012
 i,j,k,ie:    5    5    6          23
 Near X = -0.82262156      0.54282181      0.11859381    , d:   0.0000000     -0.28791755      0.85577012
 i,j,k,ie:    6    5    6          23
 Near X = -0.82262156      0.54282181      0.13437970    , d:  0.38147972     -0.28791755      0.85577012
 i,j,k,ie:    1    6    6          23
 Near X = -0.86558378      0.49985684       0.0000000    , d:  0.86558381     -0.48441625      0.85577012
 i,j,k,ie:    2    6    6          23
 Near X = -0.86558378      0.49985684      0.15785898E-01, d:  0.86558381     -0.30295433      0.85577012
 i,j,k,ie:    3    6    6          23
 Near X = -0.86558378      0.49985684      0.48025188E-01, d:  0.86558381     -0.30295433      0.85577012
 i,j,k,ie:    4    6    6          23
 Near X = -0.86558378      0.49985684      0.86354515E-01, d:  0.86558381     -0.30295433      0.85577012
 i,j,k,ie:    5    6    6          23
 Near X = -0.86558378      0.49985684      0.11859381    , d:  0.86558381     -0.30295433      0.85577012
 i,j,k,ie:    6    6    6          23
 Near X = -0.86558378      0.49985684      0.13437970    , d:   1.3654407     -0.30295433      0.85577012
 i,j,k,ie:    1    1    1          24
 Near X =  0.53131460E-07   1.3500000       0.0000000    , d:  0.67480674     -0.67481345       1.4818910
 i,j,k,ie:    2    1    1          24
 Near X =  0.53131460E-07   1.3500000      0.15785898E-01, d:  0.67480674       0.0000000       1.4818910
 i,j,k,ie:    3    1    1          24
 Near X =  0.53131460E-07   1.3500000      0.48025188E-01, d:  0.67480674       0.0000000       1.4818910
 i,j,k,ie:    4    1    1          24
 Near X =  0.53131460E-07   1.3500000      0.86354515E-01, d:  0.67480674       0.0000000       1.4818910
 i,j,k,ie:    5    1    1          24
 Near X =  0.53131460E-07   1.3500000      0.11859381    , d:  0.67480674       0.0000000       1.4818910
 i,j,k,ie:    6    1    1          24
 Near X =  0.53131460E-07   1.3500000      0.13437970    , d:  0.67480674       0.0000000       1.4818910
 i,j,k,ie:    1    2    1          24
 Near X = -0.79271861E-01   1.3286862       0.0000000    , d:   0.0000000     -0.65354054       1.4818910
 i,j,k,ie:    1    3    1          24
 Near X = -0.24116764       1.2851573       0.0000000    , d:   0.0000000     -0.61009519       1.4818910
 i,j,k,ie:    1    4    1          24
 Near X = -0.43364571       1.2334058       0.0000000    , d:   0.0000000     -0.55844297       1.4818910
 i,j,k,ie:    1    5    1          24
 Near X = -0.59554149       1.1898769       0.0000000    , d:   0.0000000     -0.51499762       1.4818910
 i,j,k,ie:    1    6    1          24
 Near X = -0.67481340       1.1685631       0.0000000    , d:   1.1746703     -0.49372471       1.4818910
 i,j,k,ie:    2    6    1          24
 Near X = -0.67481340       1.1685631      0.15785898E-01, d:   1.1746703       0.0000000       1.4818910
 i,j,k,ie:    3    6    1          24
 Near X = -0.67481340       1.1685631      0.48025188E-01, d:   1.1746703       0.0000000       1.4818910
 i,j,k,ie:    4    6    1          24
 Near X = -0.67481340       1.1685631      0.86354515E-01, d:   1.1746703       0.0000000       1.4818910
 i,j,k,ie:    5    6    1          24
 Near X = -0.67481340       1.1685631      0.11859381    , d:   1.1746703       0.0000000       1.4818910
 i,j,k,ie:    6    6    1          24
 Near X = -0.67481340       1.1685631      0.13437970    , d:   1.1746703       0.0000000       1.4818910
 i,j,k,ie:    1    1    2          24
 Near X =  0.51513299E-07   1.3088847       0.0000000    , d:  0.65425496     -0.65426148       1.4818910
 i,j,k,ie:    2    1    2          24
 Near X =  0.51513299E-07   1.3088847      0.15785898E-01, d:  0.65425496       0.0000000       1.4818910
 i,j,k,ie:    3    1    2          24
 Near X =  0.51513299E-07   1.3088847      0.48025188E-01, d:  0.65425496       0.0000000       1.4818910
 i,j,k,ie:    4    1    2          24
 Near X =  0.51513299E-07   1.3088847      0.86354515E-01, d:  0.65425496       0.0000000       1.4818910
 i,j,k,ie:    5    1    2          24
 Near X =  0.51513299E-07   1.3088847      0.11859381    , d:  0.65425496       0.0000000       1.4818910
 i,j,k,ie:    6    1    2          24
 Near X =  0.51513299E-07   1.3088847      0.13437970    , d:  0.65425496       0.0000000       1.4818910
 i,j,k,ie:    1    2    2          24
 Near X = -0.76857574E-01   1.2882200       0.0000000    , d:   0.0000000     -0.63363644       1.4818910
 i,j,k,ie:    1    3    2          24
 Near X = -0.23382269       1.2460168       0.0000000    , d:   0.0000000     -0.59151426       1.4818910
 i,j,k,ie:    1    4    2          24
 Near X = -0.42043868       1.1958414       0.0000000    , d:   0.0000000     -0.54143515       1.4818910
 i,j,k,ie:    1    5    2          24
 Near X = -0.57740380       1.1536382       0.0000000    , d:   0.0000000     -0.49931296       1.4818910
 i,j,k,ie:    1    6    2          24
 Near X = -0.65426142       1.1329736       0.0000000    , d:   1.1335665     -0.47868793       1.4818910
 i,j,k,ie:    2    6    2          24
 Near X = -0.65426142       1.1329736      0.15785898E-01, d:   1.1335665       0.0000000       1.4818910
 i,j,k,ie:    3    6    2          24
 Near X = -0.65426142       1.1329736      0.48025188E-01, d:   1.1335665       0.0000000       1.4818910
 i,j,k,ie:    4    6    2          24
 Near X = -0.65426142       1.1329736      0.86354515E-01, d:   1.1335665       0.0000000       1.4818910
 i,j,k,ie:    5    6    2          24
 Near X = -0.65426142       1.1329736      0.11859381    , d:   1.1335665       0.0000000       1.4818910
 i,j,k,ie:    6    6    2          24
 Near X = -0.65426142       1.1329736      0.13437970    , d:   1.1335665       0.0000000       1.4818910
 i,j,k,ie:    1    1    3          24
 Near X =  0.48208555E-07   1.2249155       0.0000000    , d:  0.61228240     -0.61228850       1.4818910
 i,j,k,ie:    2    1    3          24
 Near X =  0.48208555E-07   1.2249155      0.15785898E-01, d:  0.61228240       0.0000000       1.4818910
 i,j,k,ie:    3    1    3          24
 Near X =  0.48208555E-07   1.2249155      0.48025188E-01, d:  0.61228240       0.0000000       1.4818910
 i,j,k,ie:    4    1    3          24
 Near X =  0.48208555E-07   1.2249155      0.86354515E-01, d:  0.61228240       0.0000000       1.4818910
 i,j,k,ie:    5    1    3          24
 Near X =  0.48208555E-07   1.2249155      0.11859381    , d:  0.61228240       0.0000000       1.4818910
 i,j,k,ie:    6    1    3          24
 Near X =  0.48208555E-07   1.2249155      0.13437970    , d:  0.61228240       0.0000000       1.4818910
 i,j,k,ie:    1    2    3          24
 Near X = -0.71926913E-01   1.2055765       0.0000000    , d:   0.0000000     -0.59298662       1.4818910
 i,j,k,ie:    1    3    3          24
 Near X = -0.21882221       1.1660808       0.0000000    , d:   0.0000000     -0.55356671       1.4818910
 i,j,k,ie:    1    4    3          24
 Near X = -0.39346619       1.1191243       0.0000000    , d:   0.0000000     -0.50670034       1.4818910
 i,j,k,ie:    1    5    3          24
 Near X = -0.54036149       1.0796286       0.0000000    , d:   0.0000000     -0.46728043       1.4818910
 i,j,k,ie:    1    6    3          24
 Near X = -0.61228845       1.0602897       0.0000000    , d:   1.0496210     -0.44797856       1.4818910
 i,j,k,ie:    2    6    3          24
 Near X = -0.61228845       1.0602897      0.15785898E-01, d:   1.0496210       0.0000000       1.4818910
 i,j,k,ie:    3    6    3          24
 Near X = -0.61228845       1.0602897      0.48025188E-01, d:   1.0496210       0.0000000       1.4818910
 i,j,k,ie:    4    6    3          24
 Near X = -0.61228845       1.0602897      0.86354515E-01, d:   1.0496210       0.0000000       1.4818910
 i,j,k,ie:    5    6    3          24
 Near X = -0.61228845       1.0602897      0.11859381    , d:   1.0496210       0.0000000       1.4818910
 i,j,k,ie:    6    6    3          24
 Near X = -0.61228845       1.0602897      0.13437970    , d:   1.0496210       0.0000000       1.4818910
 i,j,k,ie:    1    1    4          24
 Near X =  0.44279542E-07   1.1250845       0.0000000    , d:  0.56238117     -0.56238677       1.4818910
 i,j,k,ie:    2    1    4          24
 Near X =  0.44279542E-07   1.1250845      0.15785898E-01, d:  0.56238117       0.0000000       1.4818910
 i,j,k,ie:    3    1    4          24
 Near X =  0.44279542E-07   1.1250845      0.48025188E-01, d:  0.56238117       0.0000000       1.4818910
 i,j,k,ie:    4    1    4          24
 Near X =  0.44279542E-07   1.1250845      0.86354515E-01, d:  0.56238117       0.0000000       1.4818910
 i,j,k,ie:    5    1    4          24
 Near X =  0.44279542E-07   1.1250845      0.11859381    , d:  0.56238117       0.0000000       1.4818910
 i,j,k,ie:    6    1    4          24
 Near X =  0.44279542E-07   1.1250845      0.13437970    , d:  0.56238117       0.0000000       1.4818910
 i,j,k,ie:    1    2    4          24
 Near X = -0.66064845E-01   1.1073216       0.0000000    , d:   0.0000000     -0.54465801       1.4818910
 i,j,k,ie:    1    3    4          24
 Near X = -0.20098813       1.0710449       0.0000000    , d:   0.0000000     -0.50845084       1.4818910
 i,j,k,ie:    1    4    4          24
 Near X = -0.36139856       1.0279153       0.0000000    , d:   0.0000000     -0.46540409       1.4818910
 i,j,k,ie:    1    5    4          24
 Near X = -0.49632184      0.99163854       0.0000000    , d:   0.0000000     -0.42919691       1.4818910
 i,j,k,ie:    1    6    4          24
 Near X = -0.56238673      0.97387568       0.0000000    , d:  0.94981803     -0.41146815       1.4818910
 i,j,k,ie:    2    6    4          24
 Near X = -0.56238673      0.97387568      0.15785898E-01, d:  0.94981803       0.0000000       1.4818910
 i,j,k,ie:    3    6    4          24
 Near X = -0.56238673      0.97387568      0.48025188E-01, d:  0.94981803       0.0000000       1.4818910
 i,j,k,ie:    4    6    4          24
 Near X = -0.56238673      0.97387568      0.86354515E-01, d:  0.94981803       0.0000000       1.4818910
 i,j,k,ie:    5    6    4          24
 Near X = -0.56238673      0.97387568      0.11859381    , d:  0.94981803       0.0000000       1.4818910
 i,j,k,ie:    6    6    4          24
 Near X = -0.56238673      0.97387568      0.13437970    , d:  0.94981803       0.0000000       1.4818910
 i,j,k,ie:    1    1    5          24
 Near X =  0.40974798E-07   1.0411153       0.0000000    , d:  0.52040861     -0.52041379       1.4818910
 i,j,k,ie:    2    1    5          24
 Near X =  0.40974798E-07   1.0411153      0.15785898E-01, d:  0.52040861       0.0000000       1.4818910
 i,j,k,ie:    3    1    5          24
 Near X =  0.40974798E-07   1.0411153      0.48025188E-01, d:  0.52040861       0.0000000       1.4818910
 i,j,k,ie:    4    1    5          24
 Near X =  0.40974798E-07   1.0411153      0.86354515E-01, d:  0.52040861       0.0000000       1.4818910
 i,j,k,ie:    5    1    5          24
 Near X =  0.40974798E-07   1.0411153      0.11859381    , d:  0.52040861       0.0000000       1.4818910
 i,j,k,ie:    6    1    5          24
 Near X =  0.40974798E-07   1.0411153      0.13437970    , d:  0.52040861       0.0000000       1.4818910
 i,j,k,ie:    1    2    5          24
 Near X = -0.61134184E-01   1.0246782       0.0000000    , d:   0.0000000     -0.50400819       1.4818910
 i,j,k,ie:    1    3    5          24
 Near X = -0.18598765      0.99110886       0.0000000    , d:   0.0000000     -0.47050329       1.4818910
 i,j,k,ie:    1    4    5          24
 Near X = -0.33442606      0.95119825       0.0000000    , d:   0.0000000     -0.43066928       1.4818910
 i,j,k,ie:    1    5    5          24
 Near X = -0.45927953      0.91762893       0.0000000    , d:   0.0000000     -0.39716438       1.4818910
 i,j,k,ie:    1    6    5          24
 Near X = -0.52041375      0.90119178       0.0000000    , d:  0.86587248     -0.38075878       1.4818910
 i,j,k,ie:    2    6    5          24
 Near X = -0.52041375      0.90119178      0.15785898E-01, d:  0.86587248       0.0000000       1.4818910
 i,j,k,ie:    3    6    5          24
 Near X = -0.52041375      0.90119178      0.48025188E-01, d:  0.86587248       0.0000000       1.4818910
 i,j,k,ie:    4    6    5          24
 Near X = -0.52041375      0.90119178      0.86354515E-01, d:  0.86587248       0.0000000       1.4818910
 i,j,k,ie:    5    6    5          24
 Near X = -0.52041375      0.90119178      0.11859381    , d:  0.86587248       0.0000000       1.4818910
 i,j,k,ie:    6    6    5          24
 Near X = -0.52041375      0.90119178      0.13437970    , d:  0.86587248       0.0000000       1.4818910
 i,j,k,ie:    1    1    6          24
 Near X =  0.39356637E-07   1.0000000       0.0000000    , d:  0.67480675     -0.67481344       1.4818910
 i,j,k,ie:    2    1    6          24
 Near X =  0.39356637E-07   1.0000000      0.15785898E-01, d:  0.67480675       0.0000000       1.4818910
 i,j,k,ie:    3    1    6          24
 Near X =  0.39356637E-07   1.0000000      0.48025188E-01, d:  0.67480675       0.0000000       1.4818910
 i,j,k,ie:    4    1    6          24
 Near X =  0.39356637E-07   1.0000000      0.86354515E-01, d:  0.67480675       0.0000000       1.4818910
 i,j,k,ie:    5    1    6          24
 Near X =  0.39356637E-07   1.0000000      0.11859381    , d:  0.67480675       0.0000000       1.4818910
 i,j,k,ie:    6    1    6          24
 Near X =  0.39356637E-07   1.0000000      0.13437970    , d:  0.67480675       0.0000000       1.4818910
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    1    2    6          24
 Near X = -0.58719897E-01  0.98421199       0.0000000    , d:   0.0000000     -0.67409250       1.4818910
 i,j,k,ie:    2    2    6          24
 Near X = -0.58719897E-01  0.98421199      0.15785898E-01, d:   0.0000000     -0.20551964E-01   1.4818910
 i,j,k,ie:    3    2    6          24
 Near X = -0.58719897E-01  0.98421199      0.48025188E-01, d:   0.0000000     -0.20551964E-01   1.4818910
 i,j,k,ie:    4    2    6          24
 Near X = -0.58719897E-01  0.98421199      0.86354515E-01, d:   0.0000000     -0.20551964E-01   1.4818910
 i,j,k,ie:    5    2    6          24
 Near X = -0.58719897E-01  0.98421199      0.11859381    , d:   0.0000000     -0.20551964E-01   1.4818910
 i,j,k,ie:    6    2    6          24
 Near X = -0.58719897E-01  0.98421199      0.13437970    , d:   0.0000000     -0.20551964E-01   1.4818910
 i,j,k,ie:    1    3    6          24
 Near X = -0.17864270      0.95196837       0.0000000    , d:   0.0000000     -0.67262013       1.4818910
 i,j,k,ie:    2    3    6          24
 Near X = -0.17864270      0.95196837      0.15785898E-01, d:   0.0000000     -0.62524946E-01   1.4818910
 i,j,k,ie:    3    3    6          24
 Near X = -0.17864270      0.95196837      0.48025188E-01, d:   0.0000000     -0.62524946E-01   1.4818910
 i,j,k,ie:    4    3    6          24
 Near X = -0.17864270      0.95196837      0.86354515E-01, d:   0.0000000     -0.62524946E-01   1.4818910
 i,j,k,ie:    5    3    6          24
 Near X = -0.17864270      0.95196837      0.11859381    , d:   0.0000000     -0.62524946E-01   1.4818910
 i,j,k,ie:    6    3    6          24
 Near X = -0.17864270      0.95196837      0.13437970    , d:   0.0000000     -0.62524946E-01   1.4818910
 i,j,k,ie:    1    4    6          24
 Near X = -0.32121904      0.91363390       0.0000000    , d:   0.0000000     -0.67086964       1.4818910
 i,j,k,ie:    2    4    6          24
 Near X = -0.32121904      0.91363390      0.15785898E-01, d:   0.0000000     -0.11242667       1.4818910
 i,j,k,ie:    3    4    6          24
 Near X = -0.32121904      0.91363390      0.48025188E-01, d:   0.0000000     -0.11242667       1.4818910
 i,j,k,ie:    4    4    6          24
 Near X = -0.32121904      0.91363390      0.86354515E-01, d:   0.0000000     -0.11242667       1.4818910
 i,j,k,ie:    5    4    6          24
 Near X = -0.32121904      0.91363390      0.11859381    , d:   0.0000000     -0.11242667       1.4818910
 i,j,k,ie:    6    4    6          24
 Near X = -0.32121904      0.91363390      0.13437970    , d:   0.0000000     -0.11242667       1.4818910
 i,j,k,ie:    1    5    6          24
 Near X = -0.44114184      0.88139028       0.0000000    , d:   0.0000000     -0.66939727       1.4818910
 i,j,k,ie:    2    5    6          24
 Near X = -0.44114184      0.88139028      0.15785898E-01, d:   0.0000000     -0.15439965       1.4818910
 i,j,k,ie:    3    5    6          24
 Near X = -0.44114184      0.88139028      0.48025188E-01, d:   0.0000000     -0.15439965       1.4818910
 i,j,k,ie:    4    5    6          24
 Near X = -0.44114184      0.88139028      0.86354515E-01, d:   0.0000000     -0.15439965       1.4818910
 i,j,k,ie:    5    5    6          24
 Near X = -0.44114184      0.88139028      0.11859381    , d:   0.0000000     -0.15439965       1.4818910
 i,j,k,ie:    6    5    6          24
 Near X = -0.44114184      0.88139028      0.13437970    , d:   0.0000000     -0.15439965       1.4818910
 i,j,k,ie:    1    6    6          24
 Near X = -0.49986177      0.86560227       0.0000000    , d:  0.99971865     -0.66867633       1.4818910
 i,j,k,ie:    2    6    6          24
 Near X = -0.49986177      0.86560227      0.15785898E-01, d:  0.99971865     -0.17495163       1.4818910
 i,j,k,ie:    3    6    6          24
 Near X = -0.49986177      0.86560227      0.48025188E-01, d:  0.99971865     -0.17495163       1.4818910
 i,j,k,ie:    4    6    6          24
 Near X = -0.49986177      0.86560227      0.86354515E-01, d:  0.99971865     -0.17495163       1.4818910
 i,j,k,ie:    5    6    6          24
 Near X = -0.49986177      0.86560227      0.11859381    , d:  0.99971865     -0.17495163       1.4818910
 i,j,k,ie:    6    6    6          24
 Near X = -0.49986177      0.86560227      0.13437970    , d:  0.99971865     -0.17495163       1.4818910
 i,j,k,ie:    1    1    1          25
 Near X = -0.86558378      0.49985684       0.0000000    , d:   2.0341469       0.0000000      0.99999999
 i,j,k,ie:    2    1    1          25
 Near X = -0.86558378      0.49985684      0.15785898E-01, d:   2.0341469       0.0000000      0.99999999
 i,j,k,ie:    3    1    1          25
 Near X = -0.86558378      0.49985684      0.48025188E-01, d:   2.0341469       0.0000000      0.99999999
 i,j,k,ie:    4    1    1          25
 Near X = -0.86558378      0.49985684      0.86354515E-01, d:   2.0341469       0.0000000      0.99999999
 i,j,k,ie:    5    1    1          25
 Near X = -0.86558378      0.49985684      0.11859381    , d:   2.0341469       0.0000000      0.99999999
 i,j,k,ie:    6    1    1          25
 Near X = -0.86558378      0.49985684      0.13437970    , d:   2.0341469     -0.48441625      0.99999999
 i,j,k,ie:    6    2    1          25
 Near X = -0.88137396      0.44113749      0.13437970    , d:  0.33854997       0.0000000      0.99999999
 i,j,k,ie:    6    3    1          25
 Near X = -0.91362202      0.32121588      0.13437970    , d:  0.28305696       0.0000000      0.99999999
 i,j,k,ie:    6    4    1          25
 Near X = -0.95196177      0.17864096      0.13437970    , d:  0.21708127       0.0000000      0.99999999
 i,j,k,ie:    6    5    1          25
 Near X = -0.98420982      0.58719352E-01  0.13437970    , d:  0.16158826       0.0000000      0.99999999
 i,j,k,ie:    1    6    1          25
 Near X =  -1.0000000     -0.24492936E-15   0.0000000    , d:   1.8656023       0.0000000      0.99999999
 i,j,k,ie:    2    6    1          25
 Near X =  -1.0000000     -0.24492936E-15  0.15785898E-01, d:   1.8656023       0.0000000      0.99999999
 i,j,k,ie:    3    6    1          25
 Near X =  -1.0000000     -0.24492936E-15  0.48025188E-01, d:   1.8656023       0.0000000      0.99999999
 i,j,k,ie:    4    6    1          25
 Near X =  -1.0000000     -0.24492936E-15  0.86354515E-01, d:   1.8656023       0.0000000      0.99999999
 i,j,k,ie:    5    6    1          25
 Near X =  -1.0000000     -0.24492936E-15  0.11859381    , d:   1.8656023       0.0000000      0.99999999
 i,j,k,ie:    6    6    1          25
 Near X =  -1.0000000     -0.24492936E-15  0.13437970    , d:   2.0000000       0.0000000      0.99999999
 i,j,k,ie:    1    1    2          25
 Near X = -0.82999502      0.47930507       0.0000000    , d:   1.9629686       0.0000000      0.99999999
 i,j,k,ie:    2    1    2          25
 Near X = -0.82999502      0.47930507      0.15785898E-01, d:   1.9629686       0.0000000      0.99999999
 i,j,k,ie:    3    1    2          25
 Near X = -0.82999502      0.47930507      0.48025188E-01, d:   1.9629686       0.0000000      0.99999999
 i,j,k,ie:    4    1    2          25
 Near X = -0.82999502      0.47930507      0.86354515E-01, d:   1.9629686       0.0000000      0.99999999
 i,j,k,ie:    5    1    2          25
 Near X = -0.82999502      0.47930507      0.11859381    , d:   1.9629686       0.0000000      0.99999999
 i,j,k,ie:    6    1    2          25
 Near X = -0.82999502      0.47930507      0.13437970    , d:   1.9629686     -0.47888968      0.99999999
 i,j,k,ie:    6    2    2          25
 Near X = -0.84513599      0.42299998      0.13437970    , d:  0.32463038       0.0000000      0.99999999
 i,j,k,ie:    6    3    2          25
 Near X = -0.87605816      0.30800899      0.13437970    , d:  0.27141899       0.0000000      0.99999999
 i,j,k,ie:    6    4    2          25
 Near X = -0.91282155      0.17129608      0.13437970    , d:  0.20815590       0.0000000      0.99999999
 i,j,k,ie:    6    5    2          25
 Near X = -0.94374372      0.56305087E-01  0.13437970    , d:  0.15494451       0.0000000      0.99999999
 i,j,k,ie:    1    6    2          25
 Near X = -0.95888469     -0.23485901E-15   0.0000000    , d:   1.7888975       0.0000000      0.99999999
 i,j,k,ie:    2    6    2          25
 Near X = -0.95888469     -0.23485901E-15  0.15785898E-01, d:   1.7888975       0.0000000      0.99999999
 i,j,k,ie:    3    6    2          25
 Near X = -0.95888469     -0.23485901E-15  0.48025188E-01, d:   1.7888975       0.0000000      0.99999999
 i,j,k,ie:    4    6    2          25
 Near X = -0.95888469     -0.23485901E-15  0.86354515E-01, d:   1.7888975       0.0000000      0.99999999
 i,j,k,ie:    5    6    2          25
 Near X = -0.95888469     -0.23485901E-15  0.11859381    , d:   1.7888975       0.0000000      0.99999999
 i,j,k,ie:    6    6    2          25
 Near X = -0.95888469     -0.23485901E-15  0.13437970    , d:   1.9177694       0.0000000      0.99999999
 i,j,k,ie:    1    1    3          25
 Near X = -0.75731267      0.43733250       0.0000000    , d:   1.8176023       0.0000000      0.99999999
 i,j,k,ie:    2    1    3          25
 Near X = -0.75731267      0.43733250      0.15785898E-01, d:   1.8176023       0.0000000      0.99999999
 i,j,k,ie:    3    1    3          25
 Near X = -0.75731267      0.43733250      0.48025188E-01, d:   1.8176023       0.0000000      0.99999999
 i,j,k,ie:    4    1    3          25
 Near X = -0.75731267      0.43733250      0.86354515E-01, d:   1.8176023       0.0000000      0.99999999
 i,j,k,ie:    5    1    3          25
 Near X = -0.75731267      0.43733250      0.11859381    , d:   1.8176023       0.0000000      0.99999999
 i,j,k,ie:    6    1    3          25
 Near X = -0.75731267      0.43733250      0.13437970    , d:   1.8176023     -0.46760287      0.99999999
 i,j,k,ie:    6    2    3          25
 Near X = -0.77112775      0.38595803      0.13437970    , d:  0.29620262       0.0000000      0.99999999
 i,j,k,ie:    6    3    3          25
 Near X = -0.79934207      0.28103676      0.13437970    , d:  0.24765093       0.0000000      0.99999999
 i,j,k,ie:    6    4    3          25
 Near X = -0.83288611      0.15629574      0.13437970    , d:  0.18992777       0.0000000      0.99999999
 i,j,k,ie:    6    5    3          25
 Near X = -0.86110043      0.51374472E-01  0.13437970    , d:  0.14137608       0.0000000      0.99999999
 i,j,k,ie:    1    6    3          25
 Near X = -0.87491551     -0.21429250E-15   0.0000000    , d:   1.6322444       0.0000000      0.99999999
 i,j,k,ie:    2    6    3          25
 Near X = -0.87491551     -0.21429250E-15  0.15785898E-01, d:   1.6322444       0.0000000      0.99999999
 i,j,k,ie:    3    6    3          25
 Near X = -0.87491551     -0.21429250E-15  0.48025188E-01, d:   1.6322444       0.0000000      0.99999999
 i,j,k,ie:    4    6    3          25
 Near X = -0.87491551     -0.21429250E-15  0.86354515E-01, d:   1.6322444       0.0000000      0.99999999
 i,j,k,ie:    5    6    3          25
 Near X = -0.87491551     -0.21429250E-15  0.11859381    , d:   1.6322444       0.0000000      0.99999999
 i,j,k,ie:    6    6    3          25
 Near X = -0.87491551     -0.21429250E-15  0.13437970    , d:   1.7498310       0.0000000      0.99999999
 i,j,k,ie:    1    1    4          25
 Near X = -0.67090054      0.38743127       0.0000000    , d:   1.6447762       0.0000000      0.99999999
 i,j,k,ie:    2    1    4          25
 Near X = -0.67090054      0.38743127      0.15785898E-01, d:   1.6447762       0.0000000      0.99999999
 i,j,k,ie:    3    1    4          25
 Near X = -0.67090054      0.38743127      0.48025188E-01, d:   1.6447762       0.0000000      0.99999999
 i,j,k,ie:    4    1    4          25
 Near X = -0.67090054      0.38743127      0.86354515E-01, d:   1.6447762       0.0000000      0.99999999
 i,j,k,ie:    5    1    4          25
 Near X = -0.67090054      0.38743127      0.11859381    , d:   1.6447762       0.0000000      0.99999999
 i,j,k,ie:    6    1    4          25
 Near X = -0.67090054      0.38743127      0.13437970    , d:   1.6447762     -0.45418396      0.99999999
 i,j,k,ie:    6    2    4          25
 Near X = -0.68313927      0.34191882      0.13437970    , d:  0.26240482       0.0000000      0.99999999
 i,j,k,ie:    6    3    4          25
 Near X = -0.70813424      0.24896944      0.13437970    , d:  0.21939306       0.0000000      0.99999999
 i,j,k,ie:    6    4    4          25
 Near X = -0.73785078      0.13846183      0.13437970    , d:  0.16825632       0.0000000      0.99999999
 i,j,k,ie:    6    5    4          25
 Near X = -0.76284574      0.45512458E-01  0.13437970    , d:  0.12524455       0.0000000      0.99999999
 i,j,k,ie:    1    6    4          25
 Near X = -0.77508447     -0.18984094E-15   0.0000000    , d:   1.4459994       0.0000000      0.99999999
 i,j,k,ie:    2    6    4          25
 Near X = -0.77508447     -0.18984094E-15  0.15785898E-01, d:   1.4459994       0.0000000      0.99999999
 i,j,k,ie:    3    6    4          25
 Near X = -0.77508447     -0.18984094E-15  0.48025188E-01, d:   1.4459994       0.0000000      0.99999999
 i,j,k,ie:    4    6    4          25
 Near X = -0.77508447     -0.18984094E-15  0.86354515E-01, d:   1.4459994       0.0000000      0.99999999
 i,j,k,ie:    5    6    4          25
 Near X = -0.77508447     -0.18984094E-15  0.11859381    , d:   1.4459994       0.0000000      0.99999999
 i,j,k,ie:    6    6    4          25
 Near X = -0.77508447     -0.18984094E-15  0.13437970    , d:   1.5501689       0.0000000      0.99999999
 i,j,k,ie:    1    1    5          25
 Near X = -0.59821819      0.34545871       0.0000000    , d:   1.4994100       0.0000000      0.99999999
 i,j,k,ie:    2    1    5          25
 Near X = -0.59821819      0.34545871      0.15785898E-01, d:   1.4994100       0.0000000      0.99999999
 i,j,k,ie:    3    1    5          25
 Near X = -0.59821819      0.34545871      0.48025188E-01, d:   1.4994100       0.0000000      0.99999999
 i,j,k,ie:    4    1    5          25
 Near X = -0.59821819      0.34545871      0.86354515E-01, d:   1.4994100       0.0000000      0.99999999
 i,j,k,ie:    5    1    5          25
 Near X = -0.59821819      0.34545871      0.11859381    , d:   1.4994100       0.0000000      0.99999999
 i,j,k,ie:    6    1    5          25
 Near X = -0.59821819      0.34545871      0.13437970    , d:   1.4994100     -0.44289714      0.99999999
 i,j,k,ie:    6    2    5          25
 Near X = -0.60913103      0.30487687      0.13437970    , d:  0.23397706       0.0000000      0.99999999
 i,j,k,ie:    6    3    5          25
 Near X = -0.63141815      0.22199721      0.13437970    , d:  0.19562500       0.0000000      0.99999999
 i,j,k,ie:    6    4    5          25
 Near X = -0.65791534      0.12346150      0.13437970    , d:  0.15002819       0.0000000      0.99999999
 i,j,k,ie:    6    5    5          25
 Near X = -0.68020246      0.40581842E-01  0.13437970    , d:  0.11167612       0.0000000      0.99999999
 i,j,k,ie:    1    6    5          25
 Near X = -0.69111530     -0.16927443E-15   0.0000000    , d:   1.2893463       0.0000000      0.99999999
 i,j,k,ie:    2    6    5          25
 Near X = -0.69111530     -0.16927443E-15  0.15785898E-01, d:   1.2893463       0.0000000      0.99999999
 i,j,k,ie:    3    6    5          25
 Near X = -0.69111530     -0.16927443E-15  0.48025188E-01, d:   1.2893463       0.0000000      0.99999999
 i,j,k,ie:    4    6    5          25
 Near X = -0.69111530     -0.16927443E-15  0.86354515E-01, d:   1.2893463       0.0000000      0.99999999
 i,j,k,ie:    5    6    5          25
 Near X = -0.69111530     -0.16927443E-15  0.11859381    , d:   1.2893463       0.0000000      0.99999999
 i,j,k,ie:    6    6    5          25
 Near X = -0.69111530     -0.16927443E-15  0.13437970    , d:   1.3822306       0.0000000      0.99999999
 i,j,k,ie:    1    1    6          25
 Near X = -0.56262943      0.32490693       0.0000000    , d:   1.7311925     -0.30295435      0.99999999
 i,j,k,ie:    2    1    6          25
 Near X = -0.56262943      0.32490693      0.15785898E-01, d:   1.7311925     -0.30295435      0.99999999
 i,j,k,ie:    3    1    6          25
 Near X = -0.56262943      0.32490693      0.48025188E-01, d:   1.7311925     -0.30295435      0.99999999
 i,j,k,ie:    4    1    6          25
 Near X = -0.56262943      0.32490693      0.86354515E-01, d:   1.7311925     -0.30295435      0.99999999
 i,j,k,ie:    5    1    6          25
 Near X = -0.56262943      0.32490693      0.11859381    , d:   1.7311925     -0.30295435      0.99999999
 i,j,k,ie:    6    1    6          25
 Near X = -0.56262943      0.32490693      0.13437970    , d:   1.7311925     -0.78737059      0.99999999
 i,j,k,ie:    1    2    6          25
 Near X = -0.57289305      0.28673936       0.0000000    , d:   0.0000000     -0.30848091      0.99999999
 i,j,k,ie:    2    2    6          25
 Near X = -0.57289305      0.28673936      0.15785898E-01, d:   0.0000000     -0.30848091      0.99999999
 i,j,k,ie:    3    2    6          25
 Near X = -0.57289305      0.28673936      0.48025188E-01, d:   0.0000000     -0.30848091      0.99999999
 i,j,k,ie:    4    2    6          25
 Near X = -0.57289305      0.28673936      0.86354515E-01, d:   0.0000000     -0.30848091      0.99999999
 i,j,k,ie:    5    2    6          25
 Near X = -0.57289305      0.28673936      0.11859381    , d:   0.0000000     -0.30848091      0.99999999
 i,j,k,ie:    6    2    6          25
 Near X = -0.57289305      0.28673936      0.13437970    , d:  0.22005747     -0.30848091      0.99999999
 i,j,k,ie:    1    3    6          25
 Near X = -0.59385429      0.20879032       0.0000000    , d:   0.0000000     -0.31976773      0.99999999
 i,j,k,ie:    2    3    6          25
 Near X = -0.59385429      0.20879032      0.15785898E-01, d:   0.0000000     -0.31976773      0.99999999
 i,j,k,ie:    3    3    6          25
 Near X = -0.59385429      0.20879032      0.48025188E-01, d:   0.0000000     -0.31976773      0.99999999
 i,j,k,ie:    4    3    6          25
 Near X = -0.59385429      0.20879032      0.86354515E-01, d:   0.0000000     -0.31976773      0.99999999
 i,j,k,ie:    5    3    6          25
 Near X = -0.59385429      0.20879032      0.11859381    , d:   0.0000000     -0.31976773      0.99999999
 i,j,k,ie:    6    3    6          25
 Near X = -0.59385429      0.20879032      0.13437970    , d:  0.18398702     -0.31976773      0.99999999
 i,j,k,ie:    1    4    6          25
 Near X = -0.61877512      0.11611662       0.0000000    , d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    2    4    6          25
 Near X = -0.61877512      0.11611662      0.15785898E-01, d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    3    4    6          25
 Near X = -0.61877512      0.11611662      0.48025188E-01, d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    4    4    6          25
 Near X = -0.61877512      0.11611662      0.86354515E-01, d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    5    4    6          25
 Near X = -0.61877512      0.11611662      0.11859381    , d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    6    4    6          25
 Near X = -0.61877512      0.11611662      0.13437970    , d:  0.14110282     -0.33318664      0.99999999
 i,j,k,ie:    1    5    6          25
 Near X = -0.63973636      0.38167577E-01   0.0000000    , d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    2    5    6          25
 Near X = -0.63973636      0.38167577E-01  0.15785898E-01, d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    3    5    6          25
 Near X = -0.63973636      0.38167577E-01  0.48025188E-01, d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    4    5    6          25
 Near X = -0.63973636      0.38167577E-01  0.86354515E-01, d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    5    5    6          25
 Near X = -0.63973636      0.38167577E-01  0.11859381    , d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    6    5    6          25
 Near X = -0.63973636      0.38167577E-01  0.13437970    , d:  0.10503237     -0.34447346      0.99999999
 i,j,k,ie:    1    6    6          25
 Near X = -0.64999998     -0.15920408E-15   0.0000000    , d:   1.5156023     -0.35000003      0.99999999
 i,j,k,ie:    2    6    6          25
 Near X = -0.64999998     -0.15920408E-15  0.15785898E-01, d:   1.5156023     -0.35000003      0.99999999
 i,j,k,ie:    3    6    6          25
 Near X = -0.64999998     -0.15920408E-15  0.48025188E-01, d:   1.5156023     -0.35000003      0.99999999
 i,j,k,ie:    4    6    6          25
 Near X = -0.64999998     -0.15920408E-15  0.86354515E-01, d:   1.5156023     -0.35000003      0.99999999
 i,j,k,ie:    5    6    6          25
 Near X = -0.64999998     -0.15920408E-15  0.11859381    , d:   1.5156023     -0.35000003      0.99999999
 i,j,k,ie:    6    6    6          25
 Near X = -0.64999998     -0.15920408E-15  0.13437970    , d:   1.6500000     -0.35000003      0.99999999
 i,j,k,ie:    1    1    1          26
 Near X = -0.49986177      0.86560227       0.0000000    , d:   1.6684249     -0.85013825       1.1552897
 i,j,k,ie:    2    1    1          26
 Near X = -0.49986177      0.86560227      0.15785898E-01, d:   0.0000000     -0.85013825       1.1552897
 i,j,k,ie:    3    1    1          26
 Near X = -0.49986177      0.86560227      0.48025188E-01, d:   0.0000000     -0.85013825       1.1552897
 i,j,k,ie:    4    1    1          26
 Near X = -0.49986177      0.86560227      0.86354515E-01, d:   0.0000000     -0.85013825       1.1552897
 i,j,k,ie:    5    1    1          26
 Near X = -0.49986177      0.86560227      0.11859381    , d:   0.0000000     -0.85013825       1.1552897
 i,j,k,ie:    6    1    1          26
 Near X = -0.49986177      0.86560227      0.13437970    , d:  0.49986181     -0.85013825       1.1552897
 i,j,k,ie:    1    2    1          26
 Near X = -0.54282399      0.82263730       0.0000000    , d:   0.0000000     -0.33854997       1.1552897
 i,j,k,ie:    6    2    1          26
 Near X = -0.54282399      0.82263730      0.13437970    , d:  0.48410410       0.0000000       1.1552897
 i,j,k,ie:    1    3    1          26
 Near X = -0.63056505      0.73489061       0.0000000    , d:   0.0000000     -0.28305696       1.1552897
 i,j,k,ie:    6    3    1          26
 Near X = -0.63056505      0.73489061      0.13437970    , d:  0.45192236       0.0000000       1.1552897
 i,j,k,ie:    1    4    1          26
 Near X = -0.73488050      0.63056849       0.0000000    , d:   0.0000000     -0.21708127       1.1552897
 i,j,k,ie:    6    4    1          26
 Near X = -0.73488050      0.63056849      0.13437970    , d:  0.41366146       0.0000000       1.1552897
 i,j,k,ie:    1    5    1          26
 Near X = -0.82262156      0.54282181       0.0000000    , d:   0.0000000     -0.16158826       1.1552897
 i,j,k,ie:    6    5    1          26
 Near X = -0.82262156      0.54282181      0.13437970    , d:  0.38147972       0.0000000       1.1552897
 i,j,k,ie:    1    6    1          26
 Near X = -0.86558378      0.49985684       0.0000000    , d:   1.8655838     -0.13441623       1.1552897
 i,j,k,ie:    2    6    1          26
 Near X = -0.86558378      0.49985684      0.15785898E-01, d:   1.8655838       0.0000000       1.1552897
 i,j,k,ie:    3    6    1          26
 Near X = -0.86558378      0.49985684      0.48025188E-01, d:   1.8655838       0.0000000       1.1552897
 i,j,k,ie:    4    6    1          26
 Near X = -0.86558378      0.49985684      0.86354515E-01, d:   1.8655838       0.0000000       1.1552897
 i,j,k,ie:    5    6    1          26
 Near X = -0.86558378      0.49985684      0.11859381    , d:   1.8655838       0.0000000       1.1552897
 i,j,k,ie:    6    6    1          26
 Near X = -0.86558378      0.49985684      0.13437970    , d:   1.8655838       0.0000000       1.1552897
 i,j,k,ie:    1    1    2          26
 Near X = -0.47930980      0.83001275       0.0000000    , d:   1.6122834     -0.82957491       1.1552897
 i,j,k,ie:    2    1    2          26
 Near X = -0.47930980      0.83001275      0.15785898E-01, d:   0.0000000     -0.82957491       1.1552897
 i,j,k,ie:    3    1    2          26
 Near X = -0.47930980      0.83001275      0.48025188E-01, d:   0.0000000     -0.82957491       1.1552897
 i,j,k,ie:    4    1    2          26
 Near X = -0.47930980      0.83001275      0.86354515E-01, d:   0.0000000     -0.82957491       1.1552897
 i,j,k,ie:    5    1    2          26
 Near X = -0.47930980      0.83001275      0.11859381    , d:   0.0000000     -0.82957491       1.1552897
 i,j,k,ie:    6    1    2          26
 Near X = -0.47930980      0.83001275      0.13437970    , d:  0.47930983     -0.82957491       1.1552897
 i,j,k,ie:    1    2    2          26
 Near X = -0.52050561      0.78881430       0.0000000    , d:   0.0000000     -0.32463038       1.1552897
 i,j,k,ie:    6    2    2          26
 Near X = -0.52050561      0.78881430      0.13437970    , d:  0.46420000       0.0000000       1.1552897
 i,j,k,ie:    1    3    2          26
 Near X = -0.60463917      0.70467535       0.0000000    , d:   0.0000000     -0.27141899       1.1552897
 i,j,k,ie:    6    3    2          26
 Near X = -0.60463917      0.70467535      0.13437970    , d:  0.43334143       0.0000000       1.1552897
 i,j,k,ie:    1    4    2          26
 Near X = -0.70466565      0.60464247       0.0000000    , d:   0.0000000     -0.20815590       1.1552897
 i,j,k,ie:    6    4    2          26
 Near X = -0.70466565      0.60464247      0.13437970    , d:  0.39665363       0.0000000       1.1552897
 i,j,k,ie:    1    5    2          26
 Near X = -0.78879921      0.52050352       0.0000000    , d:   0.0000000     -0.15494451       1.1552897
 i,j,k,ie:    6    5    2          26
 Near X = -0.78879921      0.52050352      0.13437970    , d:  0.36579506       0.0000000       1.1552897
 i,j,k,ie:    1    6    2          26
 Near X = -0.82999502      0.47930507       0.0000000    , d:   1.7888797     -0.12888967       1.1552897
 i,j,k,ie:    2    6    2          26
 Near X = -0.82999502      0.47930507      0.15785898E-01, d:   1.7888797       0.0000000       1.1552897
 i,j,k,ie:    3    6    2          26
 Near X = -0.82999502      0.47930507      0.48025188E-01, d:   1.7888797       0.0000000       1.1552897
 i,j,k,ie:    4    6    2          26
 Near X = -0.82999502      0.47930507      0.86354515E-01, d:   1.7888797       0.0000000       1.1552897
 i,j,k,ie:    5    6    2          26
 Near X = -0.82999502      0.47930507      0.11859381    , d:   1.7888797       0.0000000       1.1552897
 i,j,k,ie:    6    6    2          26
 Near X = -0.82999502      0.47930507      0.13437970    , d:   1.7888797       0.0000000       1.1552897
 i,j,k,ie:    1    1    3          26
 Near X = -0.43733682      0.75732884       0.0000000    , d:   1.4976265     -0.78757872       1.1552897
 i,j,k,ie:    2    1    3          26
 Near X = -0.43733682      0.75732884      0.15785898E-01, d:   0.0000000     -0.78757872       1.1552897
 i,j,k,ie:    3    1    3          26
 Near X = -0.43733682      0.75732884      0.48025188E-01, d:   0.0000000     -0.78757872       1.1552897
 i,j,k,ie:    4    1    3          26
 Near X = -0.43733682      0.75732884      0.86354515E-01, d:   0.0000000     -0.78757872       1.1552897
 i,j,k,ie:    5    1    3          26
 Near X = -0.43733682      0.75732884      0.11859381    , d:   0.0000000     -0.78757872       1.1552897
 i,j,k,ie:    6    1    3          26
 Near X = -0.43733682      0.75732884      0.13437970    , d:  0.43733685     -0.78757872       1.1552897
 i,j,k,ie:    1    2    3          26
 Near X = -0.47492513      0.71973813       0.0000000    , d:   0.0000000     -0.29620262       1.1552897
 i,j,k,ie:    6    2    3          26
 Near X = -0.47492513      0.71973813      0.13437970    , d:  0.42355018       0.0000000       1.1552897
 i,j,k,ie:    1    3    3          26
 Near X = -0.55169114      0.64296719       0.0000000    , d:   0.0000000     -0.24765093       1.1552897
 i,j,k,ie:    6    3    3          26
 Near X = -0.55169114      0.64296719      0.13437970    , d:  0.39539388       0.0000000       1.1552897
 i,j,k,ie:    1    4    3          26
 Near X = -0.64295834      0.55169415       0.0000000    , d:   0.0000000     -0.18992777       1.1552897
 i,j,k,ie:    6    4    3          26
 Near X = -0.64295834      0.55169415      0.13437970    , d:  0.36191882       0.0000000       1.1552897
 i,j,k,ie:    1    5    3          26
 Near X = -0.71972436      0.47492322       0.0000000    , d:   0.0000000     -0.14137608       1.1552897
 i,j,k,ie:    6    5    3          26
 Near X = -0.71972436      0.47492322      0.13437970    , d:  0.33376252       0.0000000       1.1552897
 i,j,k,ie:    1    6    3          26
 Near X = -0.75731267      0.43733250       0.0000000    , d:   1.6322282     -0.11760285       1.1552897
 i,j,k,ie:    2    6    3          26
 Near X = -0.75731267      0.43733250      0.15785898E-01, d:   1.6322282       0.0000000       1.1552897
 i,j,k,ie:    3    6    3          26
 Near X = -0.75731267      0.43733250      0.48025188E-01, d:   1.6322282       0.0000000       1.1552897
 i,j,k,ie:    4    6    3          26
 Near X = -0.75731267      0.43733250      0.86354515E-01, d:   1.6322282       0.0000000       1.1552897
 i,j,k,ie:    5    6    3          26
 Near X = -0.75731267      0.43733250      0.11859381    , d:   1.6322282       0.0000000       1.1552897
 i,j,k,ie:    6    6    3          26
 Near X = -0.75731267      0.43733250      0.13437970    , d:   1.6322282       0.0000000       1.1552897
 i,j,k,ie:    1    1    4          26
 Near X = -0.38743510      0.67091487       0.0000000    , d:   1.3613108     -0.73764940       1.1552897
 i,j,k,ie:    2    1    4          26
 Near X = -0.38743510      0.67091487      0.15785898E-01, d:   0.0000000     -0.73764940       1.1552897
 i,j,k,ie:    3    1    4          26
 Near X = -0.38743510      0.67091487      0.48025188E-01, d:   0.0000000     -0.73764940       1.1552897
 i,j,k,ie:    4    1    4          26
 Near X = -0.38743510      0.67091487      0.86354515E-01, d:   0.0000000     -0.73764940       1.1552897
 i,j,k,ie:    5    1    4          26
 Near X = -0.38743510      0.67091487      0.11859381    , d:   0.0000000     -0.73764940       1.1552897
 i,j,k,ie:    6    1    4          26
 Near X = -0.38743510      0.67091487      0.13437970    , d:  0.38743513     -0.73764940       1.1552897
 i,j,k,ie:    1    2    4          26
 Near X = -0.42073445      0.63761339       0.0000000    , d:   0.0000000     -0.26240482       1.1552897
 i,j,k,ie:    6    2    4          26
 Near X = -0.42073445      0.63761339      0.13437970    , d:  0.37522157       0.0000000       1.1552897
 i,j,k,ie:    1    3    4          26
 Near X = -0.48874118      0.56960230       0.0000000    , d:   0.0000000     -0.21939306       1.1552897
 i,j,k,ie:    6    3    4          26
 Near X = -0.48874118      0.56960230      0.13437970    , d:  0.35027800       0.0000000       1.1552897
 i,j,k,ie:    1    4    4          26
 Near X = -0.56959446      0.48874384       0.0000000    , d:   0.0000000     -0.16825632       1.1552897
 i,j,k,ie:    6    4    4          26
 Near X = -0.56959446      0.48874384      0.13437970    , d:  0.32062257       0.0000000       1.1552897
 i,j,k,ie:    1    5    4          26
 Near X = -0.63760119      0.42073276       0.0000000    , d:   0.0000000     -0.12524455       1.1552897
 i,j,k,ie:    6    5    4          26
 Near X = -0.63760119      0.42073276      0.13437970    , d:  0.29567900       0.0000000       1.1552897
 i,j,k,ie:    1    6    4          26
 Near X = -0.67090054      0.38743127       0.0000000    , d:   1.4459850     -0.10418394       1.1552897
 i,j,k,ie:    2    6    4          26
 Near X = -0.67090054      0.38743127      0.15785898E-01, d:   1.4459850       0.0000000       1.1552897
 i,j,k,ie:    3    6    4          26
 Near X = -0.67090054      0.38743127      0.48025188E-01, d:   1.4459850       0.0000000       1.1552897
 i,j,k,ie:    4    6    4          26
 Near X = -0.67090054      0.38743127      0.86354515E-01, d:   1.4459850       0.0000000       1.1552897
 i,j,k,ie:    5    6    4          26
 Near X = -0.67090054      0.38743127      0.11859381    , d:   1.4459850       0.0000000       1.1552897
 i,j,k,ie:    6    6    4          26
 Near X = -0.67090054      0.38743127      0.13437970    , d:   1.4459850       0.0000000       1.1552897
 i,j,k,ie:    1    1    5          26
 Near X = -0.34546212      0.59823096       0.0000000    , d:   1.2466539     -0.69565321       1.1552897
 i,j,k,ie:    2    1    5          26
 Near X = -0.34546212      0.59823096      0.15785898E-01, d:   0.0000000     -0.69565321       1.1552897
 i,j,k,ie:    3    1    5          26
 Near X = -0.34546212      0.59823096      0.48025188E-01, d:   0.0000000     -0.69565321       1.1552897
 i,j,k,ie:    4    1    5          26
 Near X = -0.34546212      0.59823096      0.86354515E-01, d:   0.0000000     -0.69565321       1.1552897
 i,j,k,ie:    5    1    5          26
 Near X = -0.34546212      0.59823096      0.11859381    , d:   0.0000000     -0.69565321       1.1552897
 i,j,k,ie:    6    1    5          26
 Near X = -0.34546212      0.59823096      0.13437970    , d:  0.34546214     -0.69565321       1.1552897
 i,j,k,ie:    1    2    5          26
 Near X = -0.37515396      0.56853722       0.0000000    , d:   0.0000000     -0.23397706       1.1552897
 i,j,k,ie:    6    2    5          26
 Near X = -0.37515396      0.56853722      0.13437970    , d:  0.33457175       0.0000000       1.1552897
 i,j,k,ie:    1    3    5          26
 Near X = -0.43579315      0.50789414       0.0000000    , d:   0.0000000     -0.19562500       1.1552897
 i,j,k,ie:    6    3    5          26
 Near X = -0.43579315      0.50789414      0.13437970    , d:  0.31233045       0.0000000       1.1552897
 i,j,k,ie:    1    4    5          26
 Near X = -0.50788715      0.43579553       0.0000000    , d:   0.0000000     -0.15002819       1.1552897
 i,j,k,ie:    6    4    5          26
 Near X = -0.50788715      0.43579553      0.13437970    , d:  0.28588776       0.0000000       1.1552897
 i,j,k,ie:    1    5    5          26
 Near X = -0.56852634      0.37515246       0.0000000    , d:   0.0000000     -0.11167612       1.1552897
 i,j,k,ie:    6    5    5          26
 Near X = -0.56852634      0.37515246      0.13437970    , d:  0.26364647       0.0000000       1.1552897
 i,j,k,ie:    1    6    5          26
 Near X = -0.59821819      0.34545871       0.0000000    , d:   1.2893335     -0.92897115E-01   1.1552897
 i,j,k,ie:    2    6    5          26
 Near X = -0.59821819      0.34545871      0.15785898E-01, d:   1.2893335       0.0000000       1.1552897
 i,j,k,ie:    3    6    5          26
 Near X = -0.59821819      0.34545871      0.48025188E-01, d:   1.2893335       0.0000000       1.1552897
 i,j,k,ie:    4    6    5          26
 Near X = -0.59821819      0.34545871      0.86354515E-01, d:   1.2893335       0.0000000       1.1552897
 i,j,k,ie:    5    6    5          26
 Near X = -0.59821819      0.34545871      0.11859381    , d:   1.2893335       0.0000000       1.1552897
 i,j,k,ie:    6    6    5          26
 Near X = -0.59821819      0.34545871      0.13437970    , d:   1.2893335       0.0000000       1.1552897
 i,j,k,ie:    1    1    6          26
 Near X = -0.32491014      0.56264145       0.0000000    , d:   1.4934732      -1.0250899       1.1552897
 i,j,k,ie:    2    1    6          26
 Near X = -0.32491014      0.56264145      0.15785898E-01, d:   0.0000000      -1.0250899       1.1552897
 i,j,k,ie:    3    1    6          26
 Near X = -0.32491014      0.56264145      0.48025188E-01, d:   0.0000000      -1.0250899       1.1552897
 i,j,k,ie:    4    1    6          26
 Near X = -0.32491014      0.56264145      0.86354515E-01, d:   0.0000000      -1.0250899       1.1552897
 i,j,k,ie:    5    1    6          26
 Near X = -0.32491014      0.56264145      0.11859381    , d:   0.0000000      -1.0250899       1.1552897
 i,j,k,ie:    6    1    6          26
 Near X = -0.32491014      0.56264145      0.13437970    , d:  0.32491018      -1.0250899       1.1552897
 i,j,k,ie:    1    2    6          26
 Near X = -0.35283558      0.53471422       0.0000000    , d:   0.0000000     -0.52853838       1.1552897
 i,j,k,ie:    2    2    6          26
 Near X = -0.35283558      0.53471422      0.15785898E-01, d:   0.0000000     -0.18998841       1.1552897
 i,j,k,ie:    3    2    6          26
 Near X = -0.35283558      0.53471422      0.48025188E-01, d:   0.0000000     -0.18998841       1.1552897
 i,j,k,ie:    4    2    6          26
 Near X = -0.35283558      0.53471422      0.86354515E-01, d:   0.0000000     -0.18998841       1.1552897
 i,j,k,ie:    5    2    6          26
 Near X = -0.35283558      0.53471422      0.11859381    , d:   0.0000000     -0.18998841       1.1552897
 i,j,k,ie:    6    2    6          26
 Near X = -0.35283558      0.53471422      0.13437970    , d:  0.31466765     -0.18998841       1.1552897
 i,j,k,ie:    1    3    6          26
 Near X = -0.40986727      0.47767888       0.0000000    , d:   0.0000000     -0.50375475       1.1552897
 i,j,k,ie:    2    3    6          26
 Near X = -0.40986727      0.47767888      0.15785898E-01, d:   0.0000000     -0.22069779       1.1552897
 i,j,k,ie:    3    3    6          26
 Near X = -0.40986727      0.47767888      0.48025188E-01, d:   0.0000000     -0.22069779       1.1552897
 i,j,k,ie:    4    3    6          26
 Near X = -0.40986727      0.47767888      0.86354515E-01, d:   0.0000000     -0.22069779       1.1552897
 i,j,k,ie:    5    3    6          26
 Near X = -0.40986727      0.47767888      0.11859381    , d:   0.0000000     -0.22069779       1.1552897
 i,j,k,ie:    6    3    6          26
 Near X = -0.40986727      0.47767888      0.13437970    , d:  0.29374952     -0.22069779       1.1552897
 i,j,k,ie:    1    4    6          26
 Near X = -0.47767230      0.40986950       0.0000000    , d:   0.0000000     -0.47428946       1.1552897
 i,j,k,ie:    2    4    6          26
 Near X = -0.47767230      0.40986950      0.15785898E-01, d:   0.0000000     -0.25720819       1.1552897
 i,j,k,ie:    3    4    6          26
 Near X = -0.47767230      0.40986950      0.48025188E-01, d:   0.0000000     -0.25720819       1.1552897
 i,j,k,ie:    4    4    6          26
 Near X = -0.47767230      0.40986950      0.86354515E-01, d:   0.0000000     -0.25720819       1.1552897
 i,j,k,ie:    5    4    6          26
 Near X = -0.47767230      0.40986950      0.11859381    , d:   0.0000000     -0.25720819       1.1552897
 i,j,k,ie:    6    4    6          26
 Near X = -0.47767230      0.40986950      0.13437970    , d:  0.26887994     -0.25720819       1.1552897
 i,j,k,ie:    1    5    6          26
 Near X = -0.53470399      0.35283416       0.0000000    , d:   0.0000000     -0.44950583       1.1552897
 i,j,k,ie:    2    5    6          26
 Near X = -0.53470399      0.35283416      0.15785898E-01, d:   0.0000000     -0.28791757       1.1552897
 i,j,k,ie:    3    5    6          26
 Near X = -0.53470399      0.35283416      0.48025188E-01, d:   0.0000000     -0.28791757       1.1552897
 i,j,k,ie:    4    5    6          26
 Near X = -0.53470399      0.35283416      0.86354515E-01, d:   0.0000000     -0.28791757       1.1552897
 i,j,k,ie:    5    5    6          26
 Near X = -0.53470399      0.35283416      0.11859381    , d:   0.0000000     -0.28791757       1.1552897
 i,j,k,ie:    6    5    6          26
 Near X = -0.53470399      0.35283416      0.13437970    , d:  0.24796181     -0.28791757       1.1552897
 i,j,k,ie:    1    6    6          26
 Near X = -0.56262943      0.32490693       0.0000000    , d:   1.5626294     -0.43737058       1.1552897
 i,j,k,ie:    2    6    6          26
 Near X = -0.56262943      0.32490693      0.15785898E-01, d:   1.5626294     -0.30295435       1.1552897
 i,j,k,ie:    3    6    6          26
 Near X = -0.56262943      0.32490693      0.48025188E-01, d:   1.5626294     -0.30295435       1.1552897
 i,j,k,ie:    4    6    6          26
 Near X = -0.56262943      0.32490693      0.86354515E-01, d:   1.5626294     -0.30295435       1.1552897
 i,j,k,ie:    5    6    6          26
 Near X = -0.56262943      0.32490693      0.11859381    , d:   1.5626294     -0.30295435       1.1552897
 i,j,k,ie:    6    6    6          26
 Near X = -0.56262943      0.32490693      0.13437970    , d:   1.5626294     -0.30295435       1.1552897
 i,j,k,ie:    1    1    1          27
 Near X =  0.39356637E-07   1.0000000       0.0000000    , d:   0.0000000      -1.3500001       2.0005529
 i,j,k,ie:    2    1    1          27
 Near X =  0.39356637E-07   1.0000000      0.15785898E-01, d:   0.0000000      -1.1685381       2.0005529
 i,j,k,ie:    3    1    1          27
 Near X =  0.39356637E-07   1.0000000      0.48025188E-01, d:   0.0000000      -1.1685381       2.0005529
 i,j,k,ie:    4    1    1          27
 Near X =  0.39356637E-07   1.0000000      0.86354515E-01, d:   0.0000000      -1.1685381       2.0005529
 i,j,k,ie:    5    1    1          27
 Near X =  0.39356637E-07   1.0000000      0.11859381    , d:   0.0000000      -1.1685381       2.0005529
 i,j,k,ie:    6    1    1          27
 Near X =  0.39356637E-07   1.0000000      0.13437970    , d:  0.49985684      -1.1685381       2.0005529
 i,j,k,ie:    1    2    1          27
 Near X = -0.58719897E-01  0.98421199       0.0000000    , d:   0.0000000     -0.48410410       2.0005529
 i,j,k,ie:    6    2    1          27
 Near X = -0.58719897E-01  0.98421199      0.13437970    , d:  0.49985742       0.0000000       2.0005529
 i,j,k,ie:    1    3    1          27
 Near X = -0.17864270      0.95196837       0.0000000    , d:   0.0000000     -0.45192236       2.0005529
 i,j,k,ie:    6    3    1          27
 Near X = -0.17864270      0.95196837      0.13437970    , d:  0.49985862       0.0000000       2.0005529
 i,j,k,ie:    1    4    1          27
 Near X = -0.32121904      0.91363390       0.0000000    , d:   0.0000000     -0.41366146       2.0005529
 i,j,k,ie:    6    4    1          27
 Near X = -0.32121904      0.91363390      0.13437970    , d:  0.49986004       0.0000000       2.0005529
 i,j,k,ie:    1    5    1          27
 Near X = -0.44114184      0.88139028       0.0000000    , d:   0.0000000     -0.38147972       2.0005529
 i,j,k,ie:    6    5    1          27
 Near X = -0.44114184      0.88139028      0.13437970    , d:  0.49986123       0.0000000       2.0005529
 i,j,k,ie:    1    6    1          27
 Near X = -0.49986177      0.86560227       0.0000000    , d:   1.4998618     -0.36572200       2.0005529
 i,j,k,ie:    2    6    1          27
 Near X = -0.49986177      0.86560227      0.15785898E-01, d:   1.3654455       0.0000000       2.0005529
 i,j,k,ie:    3    6    1          27
 Near X = -0.49986177      0.86560227      0.48025188E-01, d:   1.3654455       0.0000000       2.0005529
 i,j,k,ie:    4    6    1          27
 Near X = -0.49986177      0.86560227      0.86354515E-01, d:   1.3654455       0.0000000       2.0005529
 i,j,k,ie:    5    6    1          27
 Near X = -0.49986177      0.86560227      0.11859381    , d:   1.3654455       0.0000000       2.0005529
 i,j,k,ie:    6    6    1          27
 Near X = -0.49986177      0.86560227      0.13437970    , d:   1.3654455       0.0000000       2.0005529
 i,j,k,ie:    1    1    2          27
 Near X =  0.37738476E-07  0.95888469       0.0000000    , d:   0.0000000      -1.3088847       2.0005529
 i,j,k,ie:    2    1    2          27
 Near X =  0.37738476E-07  0.95888469      0.15785898E-01, d:   0.0000000      -1.1329494       2.0005529
 i,j,k,ie:    3    1    2          27
 Near X =  0.37738476E-07  0.95888469      0.48025188E-01, d:   0.0000000      -1.1329494       2.0005529
 i,j,k,ie:    4    1    2          27
 Near X =  0.37738476E-07  0.95888469      0.86354515E-01, d:   0.0000000      -1.1329494       2.0005529
 i,j,k,ie:    5    1    2          27
 Near X =  0.37738476E-07  0.95888469      0.11859381    , d:   0.0000000      -1.1329494       2.0005529
 i,j,k,ie:    6    1    2          27
 Near X =  0.37738476E-07  0.95888469      0.13437970    , d:  0.47930506      -1.1329494       2.0005529
 i,j,k,ie:    1    2    2          27
 Near X = -0.56305609E-01  0.94374580       0.0000000    , d:   0.0000000     -0.46420000       2.0005529
 i,j,k,ie:    6    2    2          27
 Near X = -0.56305609E-01  0.94374580      0.13437970    , d:  0.47930562       0.0000000       2.0005529
 i,j,k,ie:    1    3    2          27
 Near X = -0.17129774      0.91282789       0.0000000    , d:   0.0000000     -0.43334143       2.0005529
 i,j,k,ie:    6    3    2          27
 Near X = -0.17129774      0.91282789      0.13437970    , d:  0.47930677       0.0000000       2.0005529
 i,j,k,ie:    1    4    2          27
 Near X = -0.30801202      0.87606955       0.0000000    , d:   0.0000000     -0.39665363       2.0005529
 i,j,k,ie:    6    4    2          27
 Near X = -0.30801202      0.87606955      0.13437970    , d:  0.47930813       0.0000000       2.0005529
 i,j,k,ie:    1    5    2          27
 Near X = -0.42300415      0.84515164       0.0000000    , d:   0.0000000     -0.36579506       2.0005529
 i,j,k,ie:    6    5    2          27
 Near X = -0.42300415      0.84515164      0.13437970    , d:  0.47930927       0.0000000       2.0005529
 i,j,k,ie:    1    6    2          27
 Near X = -0.47930980      0.83001275       0.0000000    , d:   1.4381945     -0.35068522       2.0005529
 i,j,k,ie:    2    6    2          27
 Near X = -0.47930980      0.83001275      0.15785898E-01, d:   1.3093048       0.0000000       2.0005529
 i,j,k,ie:    3    6    2          27
 Near X = -0.47930980      0.83001275      0.48025188E-01, d:   1.3093048       0.0000000       2.0005529
 i,j,k,ie:    4    6    2          27
 Near X = -0.47930980      0.83001275      0.86354515E-01, d:   1.3093048       0.0000000       2.0005529
 i,j,k,ie:    5    6    2          27
 Near X = -0.47930980      0.83001275      0.11859381    , d:   1.3093048       0.0000000       2.0005529
 i,j,k,ie:    6    6    2          27
 Near X = -0.47930980      0.83001275      0.13437970    , d:   1.3093048       0.0000000       2.0005529
 i,j,k,ie:    1    1    3          27
 Near X =  0.34433732E-07  0.87491551       0.0000000    , d:   0.0000000      -1.2249156       2.0005529
 i,j,k,ie:    2    1    3          27
 Near X =  0.34433732E-07  0.87491551      0.15785898E-01, d:   0.0000000      -1.0602670       2.0005529
 i,j,k,ie:    3    1    3          27
 Near X =  0.34433732E-07  0.87491551      0.48025188E-01, d:   0.0000000      -1.0602670       2.0005529
 i,j,k,ie:    4    1    3          27
 Near X =  0.34433732E-07  0.87491551      0.86354515E-01, d:   0.0000000      -1.0602670       2.0005529
 i,j,k,ie:    5    1    3          27
 Near X =  0.34433732E-07  0.87491551      0.11859381    , d:   0.0000000      -1.0602670       2.0005529
 i,j,k,ie:    6    1    3          27
 Near X =  0.34433732E-07  0.87491551      0.13437970    , d:  0.43733250      -1.0602670       2.0005529
 i,j,k,ie:    1    2    3          27
 Near X = -0.51374948E-01  0.86110233       0.0000000    , d:   0.0000000     -0.42355018       2.0005529
 i,j,k,ie:    6    2    3          27
 Near X = -0.51374948E-01  0.86110233      0.13437970    , d:  0.43733301       0.0000000       2.0005529
 i,j,k,ie:    1    3    3          27
 Near X = -0.15629726      0.83289189       0.0000000    , d:   0.0000000     -0.39539388       2.0005529
 i,j,k,ie:    6    3    3          27
 Near X = -0.15629726      0.83289189      0.13437970    , d:  0.43733405       0.0000000       2.0005529
 i,j,k,ie:    1    4    3          27
 Near X = -0.28103952      0.79935247       0.0000000    , d:   0.0000000     -0.36191882       2.0005529
 i,j,k,ie:    6    4    3          27
 Near X = -0.28103952      0.79935247      0.13437970    , d:  0.43733530       0.0000000       2.0005529
 i,j,k,ie:    1    5    3          27
 Near X = -0.38596183      0.77114202       0.0000000    , d:   0.0000000     -0.33376252       2.0005529
 i,j,k,ie:    6    5    3          27
 Near X = -0.38596183      0.77114202      0.13437970    , d:  0.43733634       0.0000000       2.0005529
 i,j,k,ie:    1    6    3          27
 Near X = -0.43733682      0.75732884       0.0000000    , d:   1.3122523     -0.31997585       2.0005529
 i,j,k,ie:    2    6    3          27
 Near X = -0.43733682      0.75732884      0.15785898E-01, d:   1.1946495       0.0000000       2.0005529
 i,j,k,ie:    3    6    3          27
 Near X = -0.43733682      0.75732884      0.48025188E-01, d:   1.1946495       0.0000000       2.0005529
 i,j,k,ie:    4    6    3          27
 Near X = -0.43733682      0.75732884      0.86354515E-01, d:   1.1946495       0.0000000       2.0005529
 i,j,k,ie:    5    6    3          27
 Near X = -0.43733682      0.75732884      0.11859381    , d:   1.1946495       0.0000000       2.0005529
 i,j,k,ie:    6    6    3          27
 Near X = -0.43733682      0.75732884      0.13437970    , d:   1.1946495       0.0000000       2.0005529
 i,j,k,ie:    1    1    4          27
 Near X =  0.30504718E-07  0.77508447       0.0000000    , d:   0.0000000      -1.1250845       2.0005529
 i,j,k,ie:    2    1    4          27
 Near X =  0.30504718E-07  0.77508447      0.15785898E-01, d:   0.0000000     -0.97385491       2.0005529
 i,j,k,ie:    3    1    4          27
 Near X =  0.30504718E-07  0.77508447      0.48025188E-01, d:   0.0000000     -0.97385491       2.0005529
 i,j,k,ie:    4    1    4          27
 Near X =  0.30504718E-07  0.77508447      0.86354515E-01, d:   0.0000000     -0.97385491       2.0005529
 i,j,k,ie:    5    1    4          27
 Near X =  0.30504718E-07  0.77508447      0.11859381    , d:   0.0000000     -0.97385491       2.0005529
 i,j,k,ie:    6    1    4          27
 Near X =  0.30504718E-07  0.77508447      0.13437970    , d:  0.38743127     -0.97385491       2.0005529
 i,j,k,ie:    1    2    4          27
 Near X = -0.45512880E-01  0.76284743       0.0000000    , d:   0.0000000     -0.37522157       2.0005529
 i,j,k,ie:    6    2    4          27
 Near X = -0.45512880E-01  0.76284743      0.13437970    , d:  0.38743172       0.0000000       2.0005529
 i,j,k,ie:    1    3    4          27
 Near X = -0.13846318      0.73785590       0.0000000    , d:   0.0000000     -0.35027800       2.0005529
 i,j,k,ie:    6    3    4          27
 Near X = -0.13846318      0.73785590      0.13437970    , d:  0.38743265       0.0000000       2.0005529
 i,j,k,ie:    1    4    4          27
 Near X = -0.24897189      0.70814345       0.0000000    , d:   0.0000000     -0.32062257       2.0005529
 i,j,k,ie:    6    4    4          27
 Near X = -0.24897189      0.70814345      0.13437970    , d:  0.38743375       0.0000000       2.0005529
 i,j,k,ie:    1    5    4          27
 Near X = -0.34192219      0.68315192       0.0000000    , d:   0.0000000     -0.29567900       2.0005529
 i,j,k,ie:    6    5    4          27
 Near X = -0.34192219      0.68315192      0.13437970    , d:  0.38743467       0.0000000       2.0005529
 i,j,k,ie:    1    6    4          27
 Near X = -0.38743510      0.67091487       0.0000000    , d:   1.1625196     -0.28346544       2.0005529
 i,j,k,ie:    2    6    4          27
 Near X = -0.38743510      0.67091487      0.15785898E-01, d:   1.0583356       0.0000000       2.0005529
 i,j,k,ie:    3    6    4          27
 Near X = -0.38743510      0.67091487      0.48025188E-01, d:   1.0583356       0.0000000       2.0005529
 i,j,k,ie:    4    6    4          27
 Near X = -0.38743510      0.67091487      0.86354515E-01, d:   1.0583356       0.0000000       2.0005529
 i,j,k,ie:    5    6    4          27
 Near X = -0.38743510      0.67091487      0.11859381    , d:   1.0583356       0.0000000       2.0005529
 i,j,k,ie:    6    6    4          27
 Near X = -0.38743510      0.67091487      0.13437970    , d:   1.0583356       0.0000000       2.0005529
 i,j,k,ie:    1    1    5          27
 Near X =  0.27199974E-07  0.69111530       0.0000000    , d:   0.0000000      -1.0411154       2.0005529
 i,j,k,ie:    2    1    5          27
 Near X =  0.27199974E-07  0.69111530      0.15785898E-01, d:   0.0000000     -0.90117256       2.0005529
 i,j,k,ie:    3    1    5          27
 Near X =  0.27199974E-07  0.69111530      0.48025188E-01, d:   0.0000000     -0.90117256       2.0005529
 i,j,k,ie:    4    1    5          27
 Near X =  0.27199974E-07  0.69111530      0.86354515E-01, d:   0.0000000     -0.90117256       2.0005529
 i,j,k,ie:    5    1    5          27
 Near X =  0.27199974E-07  0.69111530      0.11859381    , d:   0.0000000     -0.90117256       2.0005529
 i,j,k,ie:    6    1    5          27
 Near X =  0.27199974E-07  0.69111530      0.13437970    , d:  0.34545871     -0.90117256       2.0005529
 i,j,k,ie:    1    2    5          27
 Near X = -0.40582219E-01  0.68020396       0.0000000    , d:   0.0000000     -0.33457175       2.0005529
 i,j,k,ie:    6    2    5          27
 Near X = -0.40582219E-01  0.68020396      0.13437970    , d:  0.34545911       0.0000000       2.0005529
 i,j,k,ie:    1    3    5          27
 Near X = -0.12346270      0.65791990       0.0000000    , d:   0.0000000     -0.31233045       2.0005529
 i,j,k,ie:    6    3    5          27
 Near X = -0.12346270      0.65791990      0.13437970    , d:  0.34545993       0.0000000       2.0005529
 i,j,k,ie:    1    4    5          27
 Near X = -0.22199939      0.63142636       0.0000000    , d:   0.0000000     -0.28588776       2.0005529
 i,j,k,ie:    6    4    5          27
 Near X = -0.22199939      0.63142636      0.13437970    , d:  0.34546092       0.0000000       2.0005529
 i,j,k,ie:    1    5    5          27
 Near X = -0.30487987      0.60914230       0.0000000    , d:   0.0000000     -0.26364647       2.0005529
 i,j,k,ie:    6    5    5          27
 Near X = -0.30487987      0.60914230      0.13437970    , d:  0.34546174       0.0000000       2.0005529
 i,j,k,ie:    1    6    5          27
 Near X = -0.34546212      0.59823096       0.0000000    , d:   1.0365774     -0.25275607       2.0005529
 i,j,k,ie:    2    6    5          27
 Near X = -0.34546212      0.59823096      0.15785898E-01, d:  0.94368028       0.0000000       2.0005529
 i,j,k,ie:    3    6    5          27
 Near X = -0.34546212      0.59823096      0.48025188E-01, d:  0.94368028       0.0000000       2.0005529
 i,j,k,ie:    4    6    5          27
 Near X = -0.34546212      0.59823096      0.86354515E-01, d:  0.94368028       0.0000000       2.0005529
 i,j,k,ie:    5    6    5          27
 Near X = -0.34546212      0.59823096      0.11859381    , d:  0.94368028       0.0000000       2.0005529
 i,j,k,ie:    6    6    5          27
 Near X = -0.34546212      0.59823096      0.13437970    , d:  0.94368028       0.0000000       2.0005529
 i,j,k,ie:    1    1    6          27
 Near X =  0.25581813E-07  0.64999998       0.0000000    , d:  0.13774824E-07  -1.3500000       2.0005529
 i,j,k,ie:    2    1    6          27
 Near X =  0.25581813E-07  0.64999998      0.15785898E-01, d:  0.13774824E-07  -1.1685381       2.0005529
 i,j,k,ie:    3    1    6          27
 Near X =  0.25581813E-07  0.64999998      0.48025188E-01, d:  0.13774824E-07  -1.1685381       2.0005529
 i,j,k,ie:    4    1    6          27
 Near X =  0.25581813E-07  0.64999998      0.86354515E-01, d:  0.13774824E-07  -1.1685381       2.0005529
 i,j,k,ie:    5    1    6          27
 Near X =  0.25581813E-07  0.64999998      0.11859381    , d:  0.13774824E-07  -1.1685381       2.0005529
 i,j,k,ie:    6    1    6          27
 Near X =  0.25581813E-07  0.64999998      0.13437970    , d:  0.49985685      -1.1685381       2.0005529
 i,j,k,ie:    1    2    6          27
 Near X = -0.38167931E-01  0.63973777       0.0000000    , d:   0.0000000     -0.50465606       2.0005529
 i,j,k,ie:    2    2    6          27
 Near X = -0.38167931E-01  0.63973777      0.15785898E-01, d:   0.0000000     -0.20551965E-01   2.0005529
 i,j,k,ie:    3    2    6          27
 Near X = -0.38167931E-01  0.63973777      0.48025188E-01, d:   0.0000000     -0.20551965E-01   2.0005529
 i,j,k,ie:    4    2    6          27
 Near X = -0.38167931E-01  0.63973777      0.86354515E-01, d:   0.0000000     -0.20551965E-01   2.0005529
 i,j,k,ie:    5    2    6          27
 Near X = -0.38167931E-01  0.63973777      0.11859381    , d:   0.0000000     -0.20551965E-01   2.0005529
 i,j,k,ie:    6    2    6          27
 Near X = -0.38167931E-01  0.63973777      0.13437970    , d:  0.47930546     -0.20551965E-01   2.0005529
 i,j,k,ie:    1    3    6          27
 Near X = -0.11611775      0.61877942       0.0000000    , d:   0.0000000     -0.51444731       2.0005529
 i,j,k,ie:    2    3    6          27
 Near X = -0.11611775      0.61877942      0.15785898E-01, d:   0.0000000     -0.62524948E-01   2.0005529
 i,j,k,ie:    3    3    6          27
 Near X = -0.11611775      0.61877942      0.48025188E-01, d:   0.0000000     -0.62524948E-01   2.0005529
 i,j,k,ie:    4    3    6          27
 Near X = -0.11611775      0.61877942      0.86354515E-01, d:   0.0000000     -0.62524948E-01   2.0005529
 i,j,k,ie:    5    3    6          27
 Near X = -0.11611775      0.61877942      0.11859381    , d:   0.0000000     -0.62524948E-01   2.0005529
 i,j,k,ie:    6    3    6          27
 Near X = -0.11611775      0.61877942      0.13437970    , d:  0.43733367     -0.62524948E-01   2.0005529
 i,j,k,ie:    1    4    6          27
 Near X = -0.20879237      0.59386201       0.0000000    , d:   0.0000000     -0.52608813       2.0005529
 i,j,k,ie:    2    4    6          27
 Near X = -0.20879237      0.59386201      0.15785898E-01, d:   0.0000000     -0.11242667       2.0005529
 i,j,k,ie:    3    4    6          27
 Near X = -0.20879237      0.59386201      0.48025188E-01, d:   0.0000000     -0.11242667       2.0005529
 i,j,k,ie:    4    4    6          27
 Near X = -0.20879237      0.59386201      0.86354515E-01, d:   0.0000000     -0.11242667       2.0005529
 i,j,k,ie:    5    4    6          27
 Near X = -0.20879237      0.59386201      0.11859381    , d:   0.0000000     -0.11242667       2.0005529
 i,j,k,ie:    6    4    6          27
 Near X = -0.20879237      0.59386201      0.13437970    , d:  0.38743336     -0.11242667       2.0005529
 i,j,k,ie:    1    5    6          27
 Near X = -0.28674218      0.57290366       0.0000000    , d:   0.0000000     -0.53587937       2.0005529
 i,j,k,ie:    2    5    6          27
 Near X = -0.28674218      0.57290366      0.15785898E-01, d:   0.0000000     -0.15439966       2.0005529
 i,j,k,ie:    3    5    6          27
 Near X = -0.28674218      0.57290366      0.48025188E-01, d:   0.0000000     -0.15439966       2.0005529
 i,j,k,ie:    4    5    6          27
 Near X = -0.28674218      0.57290366      0.86354515E-01, d:   0.0000000     -0.15439966       2.0005529
 i,j,k,ie:    5    5    6          27
 Near X = -0.28674218      0.57290366      0.11859381    , d:   0.0000000     -0.15439966       2.0005529
 i,j,k,ie:    6    5    6          27
 Near X = -0.28674218      0.57290366      0.13437970    , d:  0.34546157     -0.15439966       2.0005529
 i,j,k,ie:    1    6    6          27
 Near X = -0.32491014      0.56264145       0.0000000    , d:   1.3249101     -0.54067364       2.0005529
 i,j,k,ie:    2    6    6          27
 Near X = -0.32491014      0.56264145      0.15785898E-01, d:   1.1904939     -0.17495163       2.0005529
 i,j,k,ie:    3    6    6          27
 Near X = -0.32491014      0.56264145      0.48025188E-01, d:   1.1904939     -0.17495163       2.0005529
 i,j,k,ie:    4    6    6          27
 Near X = -0.32491014      0.56264145      0.86354515E-01, d:   1.1904939     -0.17495163       2.0005529
 i,j,k,ie:    5    6    6          27
 Near X = -0.32491014      0.56264145      0.11859381    , d:   1.1904939     -0.17495163       2.0005529
 i,j,k,ie:    6    6    6          27
 Near X = -0.32491014      0.56264145      0.13437970    , d:   1.1904939     -0.17495163       2.0005529
 i,j,k,ie:    1    1    1          28
 Near X =  0.49985688      0.86558377       0.0000000    , d:   0.0000000      -1.6683950       2.0005727
 i,j,k,ie:    2    1    1          28
 Near X =  0.49985688      0.86558377      0.15785898E-01, d:   0.0000000      -1.1746703       2.0005727
 i,j,k,ie:    3    1    1          28
 Near X =  0.49985688      0.86558377      0.48025188E-01, d:   0.0000000      -1.1746703       2.0005727
 i,j,k,ie:    4    1    1          28
 Near X =  0.49985688      0.86558377      0.86354515E-01, d:   0.0000000      -1.1746703       2.0005727
 i,j,k,ie:    5    1    1          28
 Near X =  0.49985688      0.86558377      0.11859381    , d:   0.0000000      -1.1746703       2.0005727
 i,j,k,ie:    6    1    1          28
 Near X =  0.49985688      0.86558377      0.13437970    , d:   0.0000000      -1.1746703       2.0005727
 i,j,k,ie:    1    2    1          28
 Near X =  0.44113753      0.88137396       0.0000000    , d:   0.0000000     -0.49985742       2.0005727
 i,j,k,ie:    1    3    1          28
 Near X =  0.32121592      0.91362201       0.0000000    , d:   0.0000000     -0.49985862       2.0005727
 i,j,k,ie:    1    4    1          28
 Near X =  0.17864100      0.95196176       0.0000000    , d:   0.0000000     -0.49986004       2.0005727
 i,j,k,ie:    1    5    1          28
 Near X =  0.58719391E-01  0.98420982       0.0000000    , d:   0.0000000     -0.49986123       2.0005727
 i,j,k,ie:    1    6    1          28
 Near X =  0.39356637E-07   1.0000000       0.0000000    , d:  0.86558370     -0.49986181       2.0005727
 i,j,k,ie:    2    6    1          28
 Near X =  0.39356637E-07   1.0000000      0.15785898E-01, d:  0.49986166       0.0000000       2.0005727
 i,j,k,ie:    3    6    1          28
 Near X =  0.39356637E-07   1.0000000      0.48025188E-01, d:  0.49986166       0.0000000       2.0005727
 i,j,k,ie:    4    6    1          28
 Near X =  0.39356637E-07   1.0000000      0.86354515E-01, d:  0.49986166       0.0000000       2.0005727
 i,j,k,ie:    5    6    1          28
 Near X =  0.39356637E-07   1.0000000      0.11859381    , d:  0.49986166       0.0000000       2.0005727
 i,j,k,ie:    6    6    1          28
 Near X =  0.39356637E-07   1.0000000      0.13437970    , d:  0.49986166       0.0000000       2.0005727
 i,j,k,ie:    1    1    2          28
 Near X =  0.47930510      0.82999501       0.0000000    , d:   0.0000000      -1.6122545       2.0005727
 i,j,k,ie:    2    1    2          28
 Near X =  0.47930510      0.82999501      0.15785898E-01, d:   0.0000000      -1.1335665       2.0005727
 i,j,k,ie:    3    1    2          28
 Near X =  0.47930510      0.82999501      0.48025188E-01, d:   0.0000000      -1.1335665       2.0005727
 i,j,k,ie:    4    1    2          28
 Near X =  0.47930510      0.82999501      0.86354515E-01, d:   0.0000000      -1.1335665       2.0005727
 i,j,k,ie:    5    1    2          28
 Near X =  0.47930510      0.82999501      0.11859381    , d:   0.0000000      -1.1335665       2.0005727
 i,j,k,ie:    6    1    2          28
 Near X =  0.47930510      0.82999501      0.13437970    , d:   0.0000000      -1.1335665       2.0005727
 i,j,k,ie:    1    2    2          28
 Near X =  0.42300001      0.84513598       0.0000000    , d:   0.0000000     -0.47930562       2.0005727
 i,j,k,ie:    1    3    2          28
 Near X =  0.30800902      0.87605815       0.0000000    , d:   0.0000000     -0.47930677       2.0005727
 i,j,k,ie:    1    4    2          28
 Near X =  0.17129611      0.91282155       0.0000000    , d:   0.0000000     -0.47930813       2.0005727
 i,j,k,ie:    1    5    2          28
 Near X =  0.56305124E-01  0.94374372       0.0000000    , d:   0.0000000     -0.47930927       2.0005727
 i,j,k,ie:    1    6    2          28
 Near X =  0.37738476E-07  0.95888469       0.0000000    , d:  0.82999495     -0.47930983       2.0005727
 i,j,k,ie:    2    6    2          28
 Near X =  0.37738476E-07  0.95888469      0.15785898E-01, d:  0.47930969       0.0000000       2.0005727
 i,j,k,ie:    3    6    2          28
 Near X =  0.37738476E-07  0.95888469      0.48025188E-01, d:  0.47930969       0.0000000       2.0005727
 i,j,k,ie:    4    6    2          28
 Near X =  0.37738476E-07  0.95888469      0.86354515E-01, d:  0.47930969       0.0000000       2.0005727
 i,j,k,ie:    5    6    2          28
 Near X =  0.37738476E-07  0.95888469      0.11859381    , d:  0.47930969       0.0000000       2.0005727
 i,j,k,ie:    6    6    2          28
 Near X =  0.37738476E-07  0.95888469      0.13437970    , d:  0.47930969       0.0000000       2.0005727
 i,j,k,ie:    1    1    3          28
 Near X =  0.43733253      0.75731266       0.0000000    , d:   0.0000000      -1.4975995       2.0005727
 i,j,k,ie:    2    1    3          28
 Near X =  0.43733253      0.75731266      0.15785898E-01, d:   0.0000000      -1.0496210       2.0005727
 i,j,k,ie:    3    1    3          28
 Near X =  0.43733253      0.75731266      0.48025188E-01, d:   0.0000000      -1.0496210       2.0005727
 i,j,k,ie:    4    1    3          28
 Near X =  0.43733253      0.75731266      0.86354515E-01, d:   0.0000000      -1.0496210       2.0005727
 i,j,k,ie:    5    1    3          28
 Near X =  0.43733253      0.75731266      0.11859381    , d:   0.0000000      -1.0496210       2.0005727
 i,j,k,ie:    6    1    3          28
 Near X =  0.43733253      0.75731266      0.13437970    , d:   0.0000000      -1.0496210       2.0005727
 i,j,k,ie:    1    2    3          28
 Near X =  0.38595806      0.77112774       0.0000000    , d:   0.0000000     -0.43733301       2.0005727
 i,j,k,ie:    1    3    3          28
 Near X =  0.28103679      0.79934207       0.0000000    , d:   0.0000000     -0.43733405       2.0005727
 i,j,k,ie:    1    4    3          28
 Near X =  0.15629578      0.83288611       0.0000000    , d:   0.0000000     -0.43733530       2.0005727
 i,j,k,ie:    1    5    3          28
 Near X =  0.51374505E-01  0.86110043       0.0000000    , d:   0.0000000     -0.43733634       2.0005727
 i,j,k,ie:    1    6    3          28
 Near X =  0.34433732E-07  0.87491551       0.0000000    , d:  0.75731260     -0.43733685       2.0005727
 i,j,k,ie:    2    6    3          28
 Near X =  0.34433732E-07  0.87491551      0.15785898E-01, d:  0.43733672       0.0000000       2.0005727
 i,j,k,ie:    3    6    3          28
 Near X =  0.34433732E-07  0.87491551      0.48025188E-01, d:  0.43733672       0.0000000       2.0005727
 i,j,k,ie:    4    6    3          28
 Near X =  0.34433732E-07  0.87491551      0.86354515E-01, d:  0.43733672       0.0000000       2.0005727
 i,j,k,ie:    5    6    3          28
 Near X =  0.34433732E-07  0.87491551      0.11859381    , d:  0.43733672       0.0000000       2.0005727
 i,j,k,ie:    6    6    3          28
 Near X =  0.34433732E-07  0.87491551      0.13437970    , d:  0.43733672       0.0000000       2.0005727
 i,j,k,ie:    1    1    4          28
 Near X =  0.38743130      0.67090053       0.0000000    , d:   0.0000000      -1.3612862       2.0005727
 i,j,k,ie:    2    1    4          28
 Near X =  0.38743130      0.67090053      0.15785898E-01, d:   0.0000000     -0.94981803       2.0005727
 i,j,k,ie:    3    1    4          28
 Near X =  0.38743130      0.67090053      0.48025188E-01, d:   0.0000000     -0.94981803       2.0005727
 i,j,k,ie:    4    1    4          28
 Near X =  0.38743130      0.67090053      0.86354515E-01, d:   0.0000000     -0.94981803       2.0005727
 i,j,k,ie:    5    1    4          28
 Near X =  0.38743130      0.67090053      0.11859381    , d:   0.0000000     -0.94981803       2.0005727
 i,j,k,ie:    6    1    4          28
 Near X =  0.38743130      0.67090053      0.13437970    , d:   0.0000000     -0.94981803       2.0005727
 i,j,k,ie:    1    2    4          28
 Near X =  0.34191884      0.68313926       0.0000000    , d:   0.0000000     -0.38743172       2.0005727
 i,j,k,ie:    1    3    4          28
 Near X =  0.24896947      0.70813423       0.0000000    , d:   0.0000000     -0.38743265       2.0005727
 i,j,k,ie:    1    4    4          28
 Near X =  0.13846186      0.73785077       0.0000000    , d:   0.0000000     -0.38743375       2.0005727
 i,j,k,ie:    1    5    4          28
 Near X =  0.45512488E-01  0.76284574       0.0000000    , d:   0.0000000     -0.38743467       2.0005727
 i,j,k,ie:    1    6    4          28
 Near X =  0.30504718E-07  0.77508447       0.0000000    , d:  0.67090048     -0.38743513       2.0005727
 i,j,k,ie:    2    6    4          28
 Near X =  0.30504718E-07  0.77508447      0.15785898E-01, d:  0.38743501       0.0000000       2.0005727
 i,j,k,ie:    3    6    4          28
 Near X =  0.30504718E-07  0.77508447      0.48025188E-01, d:  0.38743501       0.0000000       2.0005727
 i,j,k,ie:    4    6    4          28
 Near X =  0.30504718E-07  0.77508447      0.86354515E-01, d:  0.38743501       0.0000000       2.0005727
 i,j,k,ie:    5    6    4          28
 Near X =  0.30504718E-07  0.77508447      0.11859381    , d:  0.38743501       0.0000000       2.0005727
 i,j,k,ie:    6    6    4          28
 Near X =  0.30504718E-07  0.77508447      0.13437970    , d:  0.38743501       0.0000000       2.0005727
 i,j,k,ie:    1    1    5          28
 Near X =  0.34545873      0.59821818       0.0000000    , d:   0.0000000      -1.2466313       2.0005727
 i,j,k,ie:    2    1    5          28
 Near X =  0.34545873      0.59821818      0.15785898E-01, d:   0.0000000     -0.86587248       2.0005727
 i,j,k,ie:    3    1    5          28
 Near X =  0.34545873      0.59821818      0.48025188E-01, d:   0.0000000     -0.86587248       2.0005727
 i,j,k,ie:    4    1    5          28
 Near X =  0.34545873      0.59821818      0.86354515E-01, d:   0.0000000     -0.86587248       2.0005727
 i,j,k,ie:    5    1    5          28
 Near X =  0.34545873      0.59821818      0.11859381    , d:   0.0000000     -0.86587248       2.0005727
 i,j,k,ie:    6    1    5          28
 Near X =  0.34545873      0.59821818      0.13437970    , d:   0.0000000     -0.86587248       2.0005727
 i,j,k,ie:    1    2    5          28
 Near X =  0.30487689      0.60913102       0.0000000    , d:   0.0000000     -0.34545911       2.0005727
 i,j,k,ie:    1    3    5          28
 Near X =  0.22199724      0.63141815       0.0000000    , d:   0.0000000     -0.34545993       2.0005727
 i,j,k,ie:    1    4    5          28
 Near X =  0.12346152      0.65791533       0.0000000    , d:   0.0000000     -0.34546092       2.0005727
 i,j,k,ie:    1    5    5          28
 Near X =  0.40581869E-01  0.68020246       0.0000000    , d:   0.0000000     -0.34546174       2.0005727
 i,j,k,ie:    1    6    5          28
 Near X =  0.27199974E-07  0.69111530       0.0000000    , d:  0.59821813     -0.34546214       2.0005727
 i,j,k,ie:    2    6    5          28
 Near X =  0.27199974E-07  0.69111530      0.15785898E-01, d:  0.34546204       0.0000000       2.0005727
 i,j,k,ie:    3    6    5          28
 Near X =  0.27199974E-07  0.69111530      0.48025188E-01, d:  0.34546204       0.0000000       2.0005727
 i,j,k,ie:    4    6    5          28
 Near X =  0.27199974E-07  0.69111530      0.86354515E-01, d:  0.34546204       0.0000000       2.0005727
 i,j,k,ie:    5    6    5          28
 Near X =  0.27199974E-07  0.69111530      0.11859381    , d:  0.34546204       0.0000000       2.0005727
 i,j,k,ie:    6    6    5          28
 Near X =  0.27199974E-07  0.69111530      0.13437970    , d:  0.34546204       0.0000000       2.0005727
 i,j,k,ie:    1    1    6          28
 Near X =  0.32490696      0.56262942       0.0000000    , d:  0.17494992      -1.4934451       2.0005727
 i,j,k,ie:    2    1    6          28
 Near X =  0.32490696      0.56262942      0.15785898E-01, d:  0.17494992     -0.99972036       2.0005727
 i,j,k,ie:    3    1    6          28
 Near X =  0.32490696      0.56262942      0.48025188E-01, d:  0.17494992     -0.99972036       2.0005727
 i,j,k,ie:    4    1    6          28
 Near X =  0.32490696      0.56262942      0.86354515E-01, d:  0.17494992     -0.99972036       2.0005727
 i,j,k,ie:    5    1    6          28
 Near X =  0.32490696      0.56262942      0.11859381    , d:  0.17494992     -0.99972036       2.0005727
 i,j,k,ie:    6    1    6          28
 Near X =  0.32490696      0.56262942      0.13437970    , d:  0.17494992     -0.99972036       2.0005727
 i,j,k,ie:    1    2    6          28
 Near X =  0.28673938      0.57289305       0.0000000    , d:  0.15439815     -0.34545928       2.0005727
 i,j,k,ie:    2    2    6          28
 Near X =  0.28673938      0.57289305      0.15785898E-01, d:  0.15439815       0.0000000       2.0005727
 i,j,k,ie:    3    2    6          28
 Near X =  0.28673938      0.57289305      0.48025188E-01, d:  0.15439815       0.0000000       2.0005727
 i,j,k,ie:    4    2    6          28
 Near X =  0.28673938      0.57289305      0.86354515E-01, d:  0.15439815       0.0000000       2.0005727
 i,j,k,ie:    5    2    6          28
 Near X =  0.28673938      0.57289305      0.11859381    , d:  0.15439815       0.0000000       2.0005727
 i,j,k,ie:    6    2    6          28
 Near X =  0.28673938      0.57289305      0.13437970    , d:  0.15439815       0.0000000       2.0005727
 i,j,k,ie:    1    3    6          28
 Near X =  0.20879034      0.59385428       0.0000000    , d:  0.11242558     -0.38743304       2.0005727
 i,j,k,ie:    2    3    6          28
 Near X =  0.20879034      0.59385428      0.15785898E-01, d:  0.11242558       0.0000000       2.0005727
 i,j,k,ie:    3    3    6          28
 Near X =  0.20879034      0.59385428      0.48025188E-01, d:  0.11242558       0.0000000       2.0005727
 i,j,k,ie:    4    3    6          28
 Near X =  0.20879034      0.59385428      0.86354515E-01, d:  0.11242558       0.0000000       2.0005727
 i,j,k,ie:    5    3    6          28
 Near X =  0.20879034      0.59385428      0.11859381    , d:  0.11242558       0.0000000       2.0005727
 i,j,k,ie:    6    3    6          28
 Near X =  0.20879034      0.59385428      0.13437970    , d:  0.11242558       0.0000000       2.0005727
 i,j,k,ie:    1    4    6          28
 Near X =  0.11611664      0.61877512       0.0000000    , d:  0.62524354E-01 -0.43733568       2.0005727
 i,j,k,ie:    2    4    6          28
 Near X =  0.11611664      0.61877512      0.15785898E-01, d:  0.62524354E-01   0.0000000       2.0005727
 i,j,k,ie:    3    4    6          28
 Near X =  0.11611664      0.61877512      0.48025188E-01, d:  0.62524354E-01   0.0000000       2.0005727
 i,j,k,ie:    4    4    6          28
 Near X =  0.11611664      0.61877512      0.86354515E-01, d:  0.62524354E-01   0.0000000       2.0005727
 i,j,k,ie:    5    4    6          28
 Near X =  0.11611664      0.61877512      0.11859381    , d:  0.62524354E-01   0.0000000       2.0005727
 i,j,k,ie:    6    4    6          28
 Near X =  0.11611664      0.61877512      0.13437970    , d:  0.62524354E-01   0.0000000       2.0005727
 i,j,k,ie:    1    5    6          28
 Near X =  0.38167602E-01  0.63973636       0.0000000    , d:  0.20551788E-01 -0.47930944       2.0005727
 i,j,k,ie:    2    5    6          28
 Near X =  0.38167602E-01  0.63973636      0.15785898E-01, d:  0.20551788E-01   0.0000000       2.0005727
 i,j,k,ie:    3    5    6          28
 Near X =  0.38167602E-01  0.63973636      0.48025188E-01, d:  0.20551788E-01   0.0000000       2.0005727
 i,j,k,ie:    4    5    6          28
 Near X =  0.38167602E-01  0.63973636      0.86354515E-01, d:  0.20551788E-01   0.0000000       2.0005727
 i,j,k,ie:    5    5    6          28
 Near X =  0.38167602E-01  0.63973636      0.11859381    , d:  0.20551788E-01   0.0000000       2.0005727
 i,j,k,ie:    6    5    6          28
 Near X =  0.38167602E-01  0.63973636      0.13437970    , d:  0.20551788E-01   0.0000000       2.0005727
 i,j,k,ie:    1    6    6          28
 Near X =  0.25581813E-07  0.64999998       0.0000000    , d:  0.86558371     -0.49986180       2.0005727
 i,j,k,ie:    2    6    6          28
 Near X =  0.25581813E-07  0.64999998      0.15785898E-01, d:  0.49986167       0.0000000       2.0005727
 i,j,k,ie:    3    6    6          28
 Near X =  0.25581813E-07  0.64999998      0.48025188E-01, d:  0.49986167       0.0000000       2.0005727
 i,j,k,ie:    4    6    6          28
 Near X =  0.25581813E-07  0.64999998      0.86354515E-01, d:  0.49986167       0.0000000       2.0005727
 i,j,k,ie:    5    6    6          28
 Near X =  0.25581813E-07  0.64999998      0.11859381    , d:  0.49986167       0.0000000       2.0005727
 i,j,k,ie:    6    6    6          28
 Near X =  0.25581813E-07  0.64999998      0.13437970    , d:  0.49986167       0.0000000       2.0005727
 i,j,k,ie:    1    1    1          29
 Near X =  0.86560229      0.49986176       0.0000000    , d:   0.0000000      -1.8656023       1.1552650
 i,j,k,ie:    2    1    1          29
 Near X =  0.86560229      0.49986176      0.15785898E-01, d:   0.0000000      -1.8656023       1.1552650
 i,j,k,ie:    3    1    1          29
 Near X =  0.86560229      0.49986176      0.48025188E-01, d:   0.0000000      -1.8656023       1.1552650
 i,j,k,ie:    4    1    1          29
 Near X =  0.86560229      0.49986176      0.86354515E-01, d:   0.0000000      -1.8656023       1.1552650
 i,j,k,ie:    5    1    1          29
 Near X =  0.86560229      0.49986176      0.11859381    , d:   0.0000000      -1.8656023       1.1552650
 i,j,k,ie:    6    1    1          29
 Near X =  0.86560229      0.49986176      0.13437970    , d:  0.13439772      -1.8656023       1.1552650
 i,j,k,ie:    6    2    1          29
 Near X =  0.82263732      0.54282398      0.13437970    , d:  0.16157468       0.0000000       1.1552650
 i,j,k,ie:    6    3    1          29
 Near X =  0.73489064      0.63056504      0.13437970    , d:  0.21707774       0.0000000       1.1552650
 i,j,k,ie:    6    4    1          29
 Near X =  0.63056852      0.73488049      0.13437970    , d:  0.28306539       0.0000000       1.1552650
 i,j,k,ie:    6    5    1          29
 Near X =  0.54282185      0.82262155      0.13437970    , d:  0.33856846       0.0000000       1.1552650
 i,j,k,ie:    1    6    1          29
 Near X =  0.49985688      0.86558377       0.0000000    , d:   0.0000000     -0.49985699       1.1552650
 i,j,k,ie:    2    6    1          29
 Near X =  0.49985688      0.86558377      0.15785898E-01, d:   0.0000000     -0.49985699       1.1552650
 i,j,k,ie:    3    6    1          29
 Near X =  0.49985688      0.86558377      0.48025188E-01, d:   0.0000000     -0.49985699       1.1552650
 i,j,k,ie:    4    6    1          29
 Near X =  0.49985688      0.86558377      0.86354515E-01, d:   0.0000000     -0.49985699       1.1552650
 i,j,k,ie:    5    6    1          29
 Near X =  0.49985688      0.86558377      0.11859381    , d:   0.0000000     -0.49985699       1.1552650
 i,j,k,ie:    6    6    1          29
 Near X =  0.49985688      0.86558377      0.13437970    , d:  0.36574541     -0.99971378       1.1552650
 i,j,k,ie:    1    1    2          29
 Near X =  0.83001277      0.47930979       0.0000000    , d:   0.0000000      -1.7888975       1.1552650
 i,j,k,ie:    2    1    2          29
 Near X =  0.83001277      0.47930979      0.15785898E-01, d:   0.0000000      -1.7888975       1.1552650
 i,j,k,ie:    3    1    2          29
 Near X =  0.83001277      0.47930979      0.48025188E-01, d:   0.0000000      -1.7888975       1.1552650
 i,j,k,ie:    4    1    2          29
 Near X =  0.83001277      0.47930979      0.86354515E-01, d:   0.0000000      -1.7888975       1.1552650
 i,j,k,ie:    5    1    2          29
 Near X =  0.83001277      0.47930979      0.11859381    , d:   0.0000000      -1.7888975       1.1552650
 i,j,k,ie:    6    1    2          29
 Near X =  0.83001277      0.47930979      0.13437970    , d:  0.12887192      -1.7888975       1.1552650
 i,j,k,ie:    6    2    2          29
 Near X =  0.78881432      0.52050560      0.13437970    , d:  0.15493148       0.0000000       1.1552650
 i,j,k,ie:    6    3    2          29
 Near X =  0.70467538      0.60463916      0.13437970    , d:  0.20815252       0.0000000       1.1552650
 i,j,k,ie:    6    4    2          29
 Near X =  0.60464250      0.70466564      0.13437970    , d:  0.27142707       0.0000000       1.1552650
 i,j,k,ie:    6    5    2          29
 Near X =  0.52050355      0.78879920      0.13437970    , d:  0.32464811       0.0000000       1.1552650
 i,j,k,ie:    1    6    2          29
 Near X =  0.47930510      0.82999501       0.0000000    , d:   0.0000000     -0.47930521       1.1552650
 i,j,k,ie:    2    6    2          29
 Near X =  0.47930510      0.82999501      0.15785898E-01, d:   0.0000000     -0.47930521       1.1552650
 i,j,k,ie:    3    6    2          29
 Near X =  0.47930510      0.82999501      0.48025188E-01, d:   0.0000000     -0.47930521       1.1552650
 i,j,k,ie:    4    6    2          29
 Near X =  0.47930510      0.82999501      0.86354515E-01, d:   0.0000000     -0.47930521       1.1552650
 i,j,k,ie:    5    6    2          29
 Near X =  0.47930510      0.82999501      0.11859381    , d:   0.0000000     -0.47930521       1.1552650
 i,j,k,ie:    6    6    2          29
 Near X =  0.47930510      0.82999501      0.13437970    , d:  0.35070767     -0.95861023       1.1552650
 i,j,k,ie:    1    1    3          29
 Near X =  0.75732886      0.43733681       0.0000000    , d:   0.0000000      -1.6322444       1.1552650
 i,j,k,ie:    2    1    3          29
 Near X =  0.75732886      0.43733681      0.15785898E-01, d:   0.0000000      -1.6322444       1.1552650
 i,j,k,ie:    3    1    3          29
 Near X =  0.75732886      0.43733681      0.48025188E-01, d:   0.0000000      -1.6322444       1.1552650
 i,j,k,ie:    4    1    3          29
 Near X =  0.75732886      0.43733681      0.86354515E-01, d:   0.0000000      -1.6322444       1.1552650
 i,j,k,ie:    5    1    3          29
 Near X =  0.75732886      0.43733681      0.11859381    , d:   0.0000000      -1.6322444       1.1552650
 i,j,k,ie:    6    1    3          29
 Near X =  0.75732886      0.43733681      0.13437970    , d:  0.11758665      -1.6322444       1.1552650
 i,j,k,ie:    6    2    3          29
 Near X =  0.71973815      0.47492512      0.13437970    , d:  0.14136419       0.0000000       1.1552650
 i,j,k,ie:    6    3    3          29
 Near X =  0.64296722      0.55169113      0.13437970    , d:  0.18992468       0.0000000       1.1552650
 i,j,k,ie:    6    4    3          29
 Near X =  0.55169418      0.64295833      0.13437970    , d:  0.24765830       0.0000000       1.1552650
 i,j,k,ie:    6    5    3          29
 Near X =  0.47492325      0.71972435      0.13437970    , d:  0.29621879       0.0000000       1.1552650
 i,j,k,ie:    1    6    3          29
 Near X =  0.43733253      0.75731266       0.0000000    , d:   0.0000000     -0.43733264       1.1552650
 i,j,k,ie:    2    6    3          29
 Near X =  0.43733253      0.75731266      0.15785898E-01, d:   0.0000000     -0.43733264       1.1552650
 i,j,k,ie:    3    6    3          29
 Near X =  0.43733253      0.75731266      0.48025188E-01, d:   0.0000000     -0.43733264       1.1552650
 i,j,k,ie:    4    6    3          29
 Near X =  0.43733253      0.75731266      0.86354515E-01, d:   0.0000000     -0.43733264       1.1552650
 i,j,k,ie:    5    6    3          29
 Near X =  0.43733253      0.75731266      0.11859381    , d:   0.0000000     -0.43733264       1.1552650
 i,j,k,ie:    6    6    3          29
 Near X =  0.43733253      0.75731266      0.13437970    , d:  0.31999633     -0.87466509       1.1552650
 i,j,k,ie:    1    1    4          29
 Near X =  0.67091489      0.38743509       0.0000000    , d:   0.0000000      -1.4459994       1.1552650
 i,j,k,ie:    2    1    4          29
 Near X =  0.67091489      0.38743509      0.15785898E-01, d:   0.0000000      -1.4459994       1.1552650
 i,j,k,ie:    3    1    4          29
 Near X =  0.67091489      0.38743509      0.48025188E-01, d:   0.0000000      -1.4459994       1.1552650
 i,j,k,ie:    4    1    4          29
 Near X =  0.67091489      0.38743509      0.86354515E-01, d:   0.0000000      -1.4459994       1.1552650
 i,j,k,ie:    5    1    4          29
 Near X =  0.67091489      0.38743509      0.11859381    , d:   0.0000000      -1.4459994       1.1552650
 i,j,k,ie:    6    1    4          29
 Near X =  0.67091489      0.38743509      0.13437970    , d:  0.10416959      -1.4459994       1.1552650
 i,j,k,ie:    6    2    4          29
 Near X =  0.63761341      0.42073443      0.13437970    , d:  0.12523402       0.0000000       1.1552650
 i,j,k,ie:    6    3    4          29
 Near X =  0.56960232      0.48874117      0.13437970    , d:  0.16825358       0.0000000       1.1552650
 i,j,k,ie:    6    4    4          29
 Near X =  0.48874387      0.56959445      0.13437970    , d:  0.21939959       0.0000000       1.1552650
 i,j,k,ie:    6    5    4          29
 Near X =  0.42073278      0.63760118      0.13437970    , d:  0.26241915       0.0000000       1.1552650
 i,j,k,ie:    1    6    4          29
 Near X =  0.38743130      0.67090053       0.0000000    , d:   0.0000000     -0.38743139       1.1552650
 i,j,k,ie:    2    6    4          29
 Near X =  0.38743130      0.67090053      0.15785898E-01, d:   0.0000000     -0.38743139       1.1552650
 i,j,k,ie:    3    6    4          29
 Near X =  0.38743130      0.67090053      0.48025188E-01, d:   0.0000000     -0.38743139       1.1552650
 i,j,k,ie:    4    6    4          29
 Near X =  0.38743130      0.67090053      0.86354515E-01, d:   0.0000000     -0.38743139       1.1552650
 i,j,k,ie:    5    6    4          29
 Near X =  0.38743130      0.67090053      0.11859381    , d:   0.0000000     -0.38743139       1.1552650
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    6    6    4          29
 Near X =  0.38743130      0.67090053      0.13437970    , d:  0.28348359     -0.77486262       1.1552650
 i,j,k,ie:    1    1    5          29
 Near X =  0.59823098      0.34546211       0.0000000    , d:   0.0000000      -1.2893463       1.1552650
 i,j,k,ie:    2    1    5          29
 Near X =  0.59823098      0.34546211      0.15785898E-01, d:   0.0000000      -1.2893463       1.1552650
 i,j,k,ie:    3    1    5          29
 Near X =  0.59823098      0.34546211      0.48025188E-01, d:   0.0000000      -1.2893463       1.1552650
 i,j,k,ie:    4    1    5          29
 Near X =  0.59823098      0.34546211      0.86354515E-01, d:   0.0000000      -1.2893463       1.1552650
 i,j,k,ie:    5    1    5          29
 Near X =  0.59823098      0.34546211      0.11859381    , d:   0.0000000      -1.2893463       1.1552650
 i,j,k,ie:    6    1    5          29
 Near X =  0.59823098      0.34546211      0.13437970    , d:  0.92884321E-01  -1.2893463       1.1552650
 i,j,k,ie:    6    2    5          29
 Near X =  0.56853723      0.37515395      0.13437970    , d:  0.11166673       0.0000000       1.1552650
 i,j,k,ie:    6    3    5          29
 Near X =  0.50789416      0.43579314      0.13437970    , d:  0.15002575       0.0000000       1.1552650
 i,j,k,ie:    6    4    5          29
 Near X =  0.43579555      0.50788714      0.13437970    , d:  0.19563082       0.0000000       1.1552650
 i,j,k,ie:    6    5    5          29
 Near X =  0.37515248      0.56852633      0.13437970    , d:  0.23398984       0.0000000       1.1552650
 i,j,k,ie:    1    6    5          29
 Near X =  0.34545873      0.59821818       0.0000000    , d:   0.0000000     -0.34545881       1.1552650
 i,j,k,ie:    2    6    5          29
 Near X =  0.34545873      0.59821818      0.15785898E-01, d:   0.0000000     -0.34545881       1.1552650
 i,j,k,ie:    3    6    5          29
 Near X =  0.34545873      0.59821818      0.48025188E-01, d:   0.0000000     -0.34545881       1.1552650
 i,j,k,ie:    4    6    5          29
 Near X =  0.34545873      0.59821818      0.86354515E-01, d:   0.0000000     -0.34545881       1.1552650
 i,j,k,ie:    5    6    5          29
 Near X =  0.34545873      0.59821818      0.11859381    , d:   0.0000000     -0.34545881       1.1552650
 i,j,k,ie:    6    6    5          29
 Near X =  0.34545873      0.59821818      0.13437970    , d:  0.25277225     -0.69091748       1.1552650
 i,j,k,ie:    1    1    6          29
 Near X =  0.56264146      0.32491013       0.0000000    , d:  0.30296082      -1.5626415       1.1552650
 i,j,k,ie:    2    1    6          29
 Near X =  0.56264146      0.32491013      0.15785898E-01, d:  0.30296082      -1.5626415       1.1552650
 i,j,k,ie:    3    1    6          29
 Near X =  0.56264146      0.32491013      0.48025188E-01, d:  0.30296082      -1.5626415       1.1552650
 i,j,k,ie:    4    1    6          29
 Near X =  0.56264146      0.32491013      0.86354515E-01, d:  0.30296082      -1.5626415       1.1552650
 i,j,k,ie:    5    1    6          29
 Near X =  0.56264146      0.32491013      0.11859381    , d:  0.30296082      -1.5626415       1.1552650
 i,j,k,ie:    6    1    6          29
 Near X =  0.56264146      0.32491013      0.13437970    , d:  0.43735855      -1.5626415       1.1552650
 i,j,k,ie:    1    2    6          29
 Near X =  0.53471424      0.35283557       0.0000000    , d:  0.28792308       0.0000000       1.1552650
 i,j,k,ie:    2    2    6          29
 Near X =  0.53471424      0.35283557      0.15785898E-01, d:  0.28792308       0.0000000       1.1552650
 i,j,k,ie:    3    2    6          29
 Near X =  0.53471424      0.35283557      0.48025188E-01, d:  0.28792308       0.0000000       1.1552650
 i,j,k,ie:    4    2    6          29
 Near X =  0.53471424      0.35283557      0.86354515E-01, d:  0.28792308       0.0000000       1.1552650
 i,j,k,ie:    5    2    6          29
 Near X =  0.53471424      0.35283557      0.11859381    , d:  0.28792308       0.0000000       1.1552650
 i,j,k,ie:    6    2    6          29
 Near X =  0.53471424      0.35283557      0.13437970    , d:  0.44949776       0.0000000       1.1552650
 i,j,k,ie:    1    3    6          29
 Near X =  0.47767890      0.40986726       0.0000000    , d:  0.25721174       0.0000000       1.1552650
 i,j,k,ie:    2    3    6          29
 Near X =  0.47767890      0.40986726      0.15785898E-01, d:  0.25721174       0.0000000       1.1552650
 i,j,k,ie:    3    3    6          29
 Near X =  0.47767890      0.40986726      0.48025188E-01, d:  0.25721174       0.0000000       1.1552650
 i,j,k,ie:    4    3    6          29
 Near X =  0.47767890      0.40986726      0.86354515E-01, d:  0.25721174       0.0000000       1.1552650
 i,j,k,ie:    5    3    6          29
 Near X =  0.47767890      0.40986726      0.11859381    , d:  0.25721174       0.0000000       1.1552650
 i,j,k,ie:    6    3    6          29
 Near X =  0.47767890      0.40986726      0.13437970    , d:  0.47428948       0.0000000       1.1552650
 i,j,k,ie:    1    4    6          29
 Near X =  0.40986952      0.47767229       0.0000000    , d:  0.22069900       0.0000000       1.1552650
 i,j,k,ie:    2    4    6          29
 Near X =  0.40986952      0.47767229      0.15785898E-01, d:  0.22069900       0.0000000       1.1552650
 i,j,k,ie:    3    4    6          29
 Near X =  0.40986952      0.47767229      0.48025188E-01, d:  0.22069900       0.0000000       1.1552650
 i,j,k,ie:    4    4    6          29
 Near X =  0.40986952      0.47767229      0.86354515E-01, d:  0.22069900       0.0000000       1.1552650
 i,j,k,ie:    5    4    6          29
 Near X =  0.40986952      0.47767229      0.11859381    , d:  0.22069900       0.0000000       1.1552650
 i,j,k,ie:    6    4    6          29
 Near X =  0.40986952      0.47767229      0.13437970    , d:  0.50376439       0.0000000       1.1552650
 i,j,k,ie:    1    5    6          29
 Near X =  0.35283418      0.53470398       0.0000000    , d:  0.18998766       0.0000000       1.1552650
 i,j,k,ie:    2    5    6          29
 Near X =  0.35283418      0.53470398      0.15785898E-01, d:  0.18998766       0.0000000       1.1552650
 i,j,k,ie:    3    5    6          29
 Near X =  0.35283418      0.53470398      0.48025188E-01, d:  0.18998766       0.0000000       1.1552650
 i,j,k,ie:    4    5    6          29
 Near X =  0.35283418      0.53470398      0.86354515E-01, d:  0.18998766       0.0000000       1.1552650
 i,j,k,ie:    5    5    6          29
 Near X =  0.35283418      0.53470398      0.11859381    , d:  0.18998766       0.0000000       1.1552650
 i,j,k,ie:    6    5    6          29
 Near X =  0.35283418      0.53470398      0.13437970    , d:  0.52855612       0.0000000       1.1552650
 i,j,k,ie:    1    6    6          29
 Near X =  0.32490696      0.56262942       0.0000000    , d:  0.17494992     -0.32490707       1.1552650
 i,j,k,ie:    2    6    6          29
 Near X =  0.32490696      0.56262942      0.15785898E-01, d:  0.17494992     -0.32490707       1.1552650
 i,j,k,ie:    3    6    6          29
 Near X =  0.32490696      0.56262942      0.48025188E-01, d:  0.17494992     -0.32490707       1.1552650
 i,j,k,ie:    4    6    6          29
 Near X =  0.32490696      0.56262942      0.86354515E-01, d:  0.17494992     -0.32490707       1.1552650
 i,j,k,ie:    5    6    6          29
 Near X =  0.32490696      0.56262942      0.11859381    , d:  0.17494992     -0.32490707       1.1552650
 i,j,k,ie:    6    6    6          29
 Near X =  0.32490696      0.56262942      0.13437970    , d:  0.54069533     -0.82476386       1.1552650
 i,j,k,ie:    1    1    1          30
 Near X =   1.0000000     -0.46163286E-07   0.0000000    , d:   0.0000000      -2.0000000      0.99999999
 i,j,k,ie:    2    1    1          30
 Near X =   1.0000000     -0.46163286E-07  0.15785898E-01, d:   0.0000000      -1.8655838      0.99999999
 i,j,k,ie:    3    1    1          30
 Near X =   1.0000000     -0.46163286E-07  0.48025188E-01, d:   0.0000000      -1.8655838      0.99999999
 i,j,k,ie:    4    1    1          30
 Near X =   1.0000000     -0.46163286E-07  0.86354515E-01, d:   0.0000000      -1.8655838      0.99999999
 i,j,k,ie:    5    1    1          30
 Near X =   1.0000000     -0.46163286E-07  0.11859381    , d:   0.0000000      -1.8655838      0.99999999
 i,j,k,ie:    6    1    1          30
 Near X =   1.0000000     -0.46163286E-07  0.13437970    , d:   0.0000000      -1.8655838      0.99999999
 i,j,k,ie:    1    2    1          30
 Near X =  0.98421199      0.58719889E-01   0.0000000    , d:   0.0000000     -0.16157468      0.99999999
 i,j,k,ie:    6    2    1          30
 Near X =  0.98421199      0.58719889E-01  0.13437970    , d:   0.0000000     -0.10283806      0.99999999
 i,j,k,ie:    1    3    1          30
 Near X =  0.95196838      0.17864269       0.0000000    , d:   0.0000000     -0.21707774      0.99999999
 i,j,k,ie:    6    3    1          30
 Near X =  0.95196838      0.17864269      0.13437970    , d:   0.0000000     -0.38346385E-01  0.99999999
 i,j,k,ie:    1    4    1          30
 Near X =  0.91363392      0.32121903       0.0000000    , d:   0.0000000     -0.28306539      0.99999999
 i,j,k,ie:    6    4    1          30
 Near X =  0.91363392      0.32121903      0.13437970    , d:  0.38327837E-01   0.0000000      0.99999999
 i,j,k,ie:    1    5    1          30
 Near X =  0.88139030      0.44114183       0.0000000    , d:   0.0000000     -0.33856846      0.99999999
 i,j,k,ie:    6    5    1          30
 Near X =  0.88139030      0.44114183      0.13437970    , d:  0.10281951       0.0000000      0.99999999
 i,j,k,ie:    1    6    1          30
 Near X =  0.86560229      0.49986176       0.0000000    , d:   0.0000000      -1.3654592      0.99999999
 i,j,k,ie:    2    6    1          30
 Near X =  0.86560229      0.49986176      0.15785898E-01, d:   0.0000000      -1.3654592      0.99999999
 i,j,k,ie:    3    6    1          30
 Near X =  0.86560229      0.49986176      0.48025188E-01, d:   0.0000000      -1.3654592      0.99999999
 i,j,k,ie:    4    6    1          30
 Near X =  0.86560229      0.49986176      0.86354515E-01, d:   0.0000000      -1.3654592      0.99999999
 i,j,k,ie:    5    6    1          30
 Near X =  0.86560229      0.49986176      0.11859381    , d:   0.0000000      -1.3654592      0.99999999
 i,j,k,ie:    6    6    1          30
 Near X =  0.86560229      0.49986176      0.13437970    , d:  0.13439772      -1.7312046      0.99999999
 i,j,k,ie:    1    1    2          30
 Near X =  0.95888469     -0.45029985E-07   0.0000000    , d:   0.0000000      -1.9177694      0.99999999
 i,j,k,ie:    2    1    2          30
 Near X =  0.95888469     -0.45029985E-07  0.15785898E-01, d:   0.0000000      -1.7888797      0.99999999
 i,j,k,ie:    3    1    2          30
 Near X =  0.95888469     -0.45029985E-07  0.48025188E-01, d:   0.0000000      -1.7888797      0.99999999
 i,j,k,ie:    4    1    2          30
 Near X =  0.95888469     -0.45029985E-07  0.86354515E-01, d:   0.0000000      -1.7888797      0.99999999
 i,j,k,ie:    5    1    2          30
 Near X =  0.95888469     -0.45029985E-07  0.11859381    , d:   0.0000000      -1.7888797      0.99999999
 i,j,k,ie:    6    1    2          30
 Near X =  0.95888469     -0.45029985E-07  0.13437970    , d:   0.0000000      -1.7888797      0.99999999
 i,j,k,ie:    1    2    2          30
 Near X =  0.94374580      0.56305601E-01   0.0000000    , d:   0.0000000     -0.15493148      0.99999999
 i,j,k,ie:    6    2    2          30
 Near X =  0.94374580      0.56305601E-01  0.13437970    , d:   0.0000000     -0.98609841E-01  0.99999999
 i,j,k,ie:    1    3    2          30
 Near X =  0.91282790      0.17129774       0.0000000    , d:   0.0000000     -0.20815252      0.99999999
 i,j,k,ie:    6    3    2          30
 Near X =  0.91282790      0.17129774      0.13437970    , d:   0.0000000     -0.36769761E-01  0.99999999
 i,j,k,ie:    1    4    2          30
 Near X =  0.87606956      0.30801201       0.0000000    , d:   0.0000000     -0.27142707      0.99999999
 i,j,k,ie:    6    4    2          30
 Near X =  0.87606956      0.30801201      0.13437970    , d:  0.36751976E-01   0.0000000      0.99999999
 i,j,k,ie:    1    5    2          30
 Near X =  0.84515166      0.42300414       0.0000000    , d:   0.0000000     -0.32464811      0.99999999
 i,j,k,ie:    6    5    2          30
 Near X =  0.84515166      0.42300414      0.13437970    , d:  0.98592056E-01   0.0000000      0.99999999
 i,j,k,ie:    1    6    2          30
 Near X =  0.83001277      0.47930979       0.0000000    , d:   0.0000000      -1.3093179      0.99999999
 i,j,k,ie:    2    6    2          30
 Near X =  0.83001277      0.47930979      0.15785898E-01, d:   0.0000000      -1.3093179      0.99999999
 i,j,k,ie:    3    6    2          30
 Near X =  0.83001277      0.47930979      0.48025188E-01, d:   0.0000000      -1.3093179      0.99999999
 i,j,k,ie:    4    6    2          30
 Near X =  0.83001277      0.47930979      0.86354515E-01, d:   0.0000000      -1.3093179      0.99999999
 i,j,k,ie:    5    6    2          30
 Near X =  0.83001277      0.47930979      0.11859381    , d:   0.0000000      -1.3093179      0.99999999
 i,j,k,ie:    6    6    2          30
 Near X =  0.83001277      0.47930979      0.13437970    , d:  0.12887192      -1.6600255      0.99999999
 i,j,k,ie:    1    1    3          30
 Near X =  0.87491551     -0.42715462E-07   0.0000000    , d:   0.0000000      -1.7498310      0.99999999
 i,j,k,ie:    2    1    3          30
 Near X =  0.87491551     -0.42715462E-07  0.15785898E-01, d:   0.0000000      -1.6322282      0.99999999
 i,j,k,ie:    3    1    3          30
 Near X =  0.87491551     -0.42715462E-07  0.48025188E-01, d:   0.0000000      -1.6322282      0.99999999
 i,j,k,ie:    4    1    3          30
 Near X =  0.87491551     -0.42715462E-07  0.86354515E-01, d:   0.0000000      -1.6322282      0.99999999
 i,j,k,ie:    5    1    3          30
 Near X =  0.87491551     -0.42715462E-07  0.11859381    , d:   0.0000000      -1.6322282      0.99999999
 i,j,k,ie:    6    1    3          30
 Near X =  0.87491551     -0.42715462E-07  0.13437970    , d:   0.0000000      -1.6322282      0.99999999
 i,j,k,ie:    1    2    3          30
 Near X =  0.86110234      0.51374939E-01   0.0000000    , d:   0.0000000     -0.14136419      0.99999999
 i,j,k,ie:    6    2    3          30
 Near X =  0.86110234      0.51374939E-01  0.13437970    , d:   0.0000000     -0.89974615E-01  0.99999999
 i,j,k,ie:    1    3    3          30
 Near X =  0.83289190      0.15629726       0.0000000    , d:   0.0000000     -0.18992468      0.99999999
 i,j,k,ie:    6    3    3          30
 Near X =  0.83289190      0.15629726      0.13437970    , d:   0.0000000     -0.33549847E-01  0.99999999
 i,j,k,ie:    1    4    3          30
 Near X =  0.79935248      0.28103951       0.0000000    , d:   0.0000000     -0.24765830      0.99999999
 i,j,k,ie:    6    4    3          30
 Near X =  0.79935248      0.28103951      0.13437970    , d:  0.33533619E-01   0.0000000      0.99999999
 i,j,k,ie:    1    5    3          30
 Near X =  0.77114204      0.38596182       0.0000000    , d:   0.0000000     -0.29621879      0.99999999
 i,j,k,ie:    6    5    3          30
 Near X =  0.77114204      0.38596182      0.13437970    , d:  0.89958387E-01   0.0000000      0.99999999
 i,j,k,ie:    1    6    3          30
 Near X =  0.75732886      0.43733681       0.0000000    , d:   0.0000000      -1.1946614      0.99999999
 i,j,k,ie:    2    6    3          30
 Near X =  0.75732886      0.43733681      0.15785898E-01, d:   0.0000000      -1.1946614      0.99999999
 i,j,k,ie:    3    6    3          30
 Near X =  0.75732886      0.43733681      0.48025188E-01, d:   0.0000000      -1.1946614      0.99999999
 i,j,k,ie:    4    6    3          30
 Near X =  0.75732886      0.43733681      0.86354515E-01, d:   0.0000000      -1.1946614      0.99999999
 i,j,k,ie:    5    6    3          30
 Near X =  0.75732886      0.43733681      0.11859381    , d:   0.0000000      -1.1946614      0.99999999
 i,j,k,ie:    6    6    3          30
 Near X =  0.75732886      0.43733681      0.13437970    , d:  0.11758665      -1.5146577      0.99999999
 i,j,k,ie:    1    1    4          30
 Near X =  0.77508447     -0.39963724E-07   0.0000000    , d:   0.0000000      -1.5501689      0.99999999
 i,j,k,ie:    2    1    4          30
 Near X =  0.77508447     -0.39963724E-07  0.15785898E-01, d:   0.0000000      -1.4459850      0.99999999
 i,j,k,ie:    3    1    4          30
 Near X =  0.77508447     -0.39963724E-07  0.48025188E-01, d:   0.0000000      -1.4459850      0.99999999
 i,j,k,ie:    4    1    4          30
 Near X =  0.77508447     -0.39963724E-07  0.86354515E-01, d:   0.0000000      -1.4459850      0.99999999
 i,j,k,ie:    5    1    4          30
 Near X =  0.77508447     -0.39963724E-07  0.11859381    , d:   0.0000000      -1.4459850      0.99999999
 i,j,k,ie:    6    1    4          30
 Near X =  0.77508447     -0.39963724E-07  0.13437970    , d:   0.0000000      -1.4459850      0.99999999
 i,j,k,ie:    1    2    4          30
 Near X =  0.76284743      0.45512870E-01   0.0000000    , d:   0.0000000     -0.12523402      0.99999999
 i,j,k,ie:    6    2    4          30
 Near X =  0.76284743      0.45512870E-01  0.13437970    , d:   0.0000000     -0.79708184E-01  0.99999999
 i,j,k,ie:    1    3    4          30
 Near X =  0.73785591      0.13846317       0.0000000    , d:   0.0000000     -0.16825358      0.99999999
 i,j,k,ie:    6    3    4          30
 Near X =  0.73785591      0.13846317      0.13437970    , d:   0.0000000     -0.29721687E-01  0.99999999
 i,j,k,ie:    1    4    4          30
 Near X =  0.70814346      0.24897188       0.0000000    , d:   0.0000000     -0.21939959      0.99999999
 i,j,k,ie:    6    4    4          30
 Near X =  0.70814346      0.24897188      0.13437970    , d:  0.29707311E-01   0.0000000      0.99999999
 i,j,k,ie:    1    5    4          30
 Near X =  0.68315193      0.34192218       0.0000000    , d:   0.0000000     -0.26241915      0.99999999
 i,j,k,ie:    6    5    4          30
 Near X =  0.68315193      0.34192218      0.13437970    , d:  0.79693808E-01   0.0000000      0.99999999
 i,j,k,ie:    1    6    4          30
 Near X =  0.67091489      0.38743509       0.0000000    , d:   0.0000000      -1.0583462      0.99999999
 i,j,k,ie:    2    6    4          30
 Near X =  0.67091489      0.38743509      0.15785898E-01, d:   0.0000000      -1.0583462      0.99999999
 i,j,k,ie:    3    6    4          30
 Near X =  0.67091489      0.38743509      0.48025188E-01, d:   0.0000000      -1.0583462      0.99999999
 i,j,k,ie:    4    6    4          30
 Near X =  0.67091489      0.38743509      0.86354515E-01, d:   0.0000000      -1.0583462      0.99999999
 i,j,k,ie:    5    6    4          30
 Near X =  0.67091489      0.38743509      0.11859381    , d:   0.0000000      -1.0583462      0.99999999
 i,j,k,ie:    6    6    4          30
 Near X =  0.67091489      0.38743509      0.13437970    , d:  0.10416959      -1.3418298      0.99999999
 i,j,k,ie:    1    1    5          30
 Near X =  0.69111530     -0.37649202E-07   0.0000000    , d:   0.0000000      -1.3822306      0.99999999
 i,j,k,ie:    2    1    5          30
 Near X =  0.69111530     -0.37649202E-07  0.15785898E-01, d:   0.0000000      -1.2893335      0.99999999
 i,j,k,ie:    3    1    5          30
 Near X =  0.69111530     -0.37649202E-07  0.48025188E-01, d:   0.0000000      -1.2893335      0.99999999
 i,j,k,ie:    4    1    5          30
 Near X =  0.69111530     -0.37649202E-07  0.86354515E-01, d:   0.0000000      -1.2893335      0.99999999
 i,j,k,ie:    5    1    5          30
 Near X =  0.69111530     -0.37649202E-07  0.11859381    , d:   0.0000000      -1.2893335      0.99999999
 i,j,k,ie:    6    1    5          30
 Near X =  0.69111530     -0.37649202E-07  0.13437970    , d:   0.0000000      -1.2893335      0.99999999
 i,j,k,ie:    1    2    5          30
 Near X =  0.68020396      0.40582208E-01   0.0000000    , d:   0.0000000     -0.11166673      0.99999999
 i,j,k,ie:    6    2    5          30
 Near X =  0.68020396      0.40582208E-01  0.13437970    , d:   0.0000000     -0.71072957E-01  0.99999999
 i,j,k,ie:    1    3    5          30
 Near X =  0.65791991      0.12346269       0.0000000    , d:   0.0000000     -0.15002575      0.99999999
 i,j,k,ie:    6    3    5          30
 Near X =  0.65791991      0.12346269      0.13437970    , d:   0.0000000     -0.26501773E-01  0.99999999
 i,j,k,ie:    1    4    5          30
 Near X =  0.63142637      0.22199938       0.0000000    , d:   0.0000000     -0.19563082      0.99999999
 i,j,k,ie:    6    4    5          30
 Near X =  0.63142637      0.22199938      0.13437970    , d:  0.26488955E-01   0.0000000      0.99999999
 i,j,k,ie:    1    5    5          30
 Near X =  0.60914232      0.30487986       0.0000000    , d:   0.0000000     -0.23398984      0.99999999
 i,j,k,ie:    6    5    5          30
 Near X =  0.60914232      0.30487986      0.13437970    , d:  0.71060138E-01   0.0000000      0.99999999
 i,j,k,ie:    1    6    5          30
 Near X =  0.59823098      0.34546211       0.0000000    , d:   0.0000000     -0.94368973      0.99999999
 i,j,k,ie:    2    6    5          30
 Near X =  0.59823098      0.34546211      0.15785898E-01, d:   0.0000000     -0.94368973      0.99999999
 i,j,k,ie:    3    6    5          30
 Near X =  0.59823098      0.34546211      0.48025188E-01, d:   0.0000000     -0.94368973      0.99999999
 i,j,k,ie:    4    6    5          30
 Near X =  0.59823098      0.34546211      0.86354515E-01, d:   0.0000000     -0.94368973      0.99999999
 i,j,k,ie:    5    6    5          30
 Near X =  0.59823098      0.34546211      0.11859381    , d:   0.0000000     -0.94368973      0.99999999
 i,j,k,ie:    6    6    5          30
 Near X =  0.59823098      0.34546211      0.13437970    , d:  0.92884321E-01  -1.1964619      0.99999999
 i,j,k,ie:    1    1    6          30
 Near X =  0.64999998     -0.36515901E-07   0.0000000    , d:  0.35000003      -1.6500000      0.99999999
 i,j,k,ie:    2    1    6          30
 Near X =  0.64999998     -0.36515901E-07  0.15785898E-01, d:  0.35000003      -1.5155838      0.99999999
 i,j,k,ie:    3    1    6          30
 Near X =  0.64999998     -0.36515901E-07  0.48025188E-01, d:  0.35000003      -1.5155838      0.99999999
 i,j,k,ie:    4    1    6          30
 Near X =  0.64999998     -0.36515901E-07  0.86354515E-01, d:  0.35000003      -1.5155838      0.99999999
 i,j,k,ie:    5    1    6          30
 Near X =  0.64999998     -0.36515901E-07  0.11859381    , d:  0.35000003      -1.5155838      0.99999999
 i,j,k,ie:    6    1    6          30
 Near X =  0.64999998     -0.36515901E-07  0.13437970    , d:  0.35000003      -1.5155838      0.99999999
 i,j,k,ie:    1    2    6          30
 Near X =  0.63973777      0.38167920E-01   0.0000000    , d:  0.34447422     -0.10502353      0.99999999
 i,j,k,ie:    2    2    6          30
 Near X =  0.63973777      0.38167920E-01  0.15785898E-01, d:  0.34447422       0.0000000      0.99999999
 i,j,k,ie:    3    2    6          30
 Near X =  0.63973777      0.38167920E-01  0.48025188E-01, d:  0.34447422       0.0000000      0.99999999
 i,j,k,ie:    4    2    6          30
 Near X =  0.63973777      0.38167920E-01  0.86354515E-01, d:  0.34447422       0.0000000      0.99999999
 i,j,k,ie:    5    2    6          30
 Near X =  0.63973777      0.38167920E-01  0.11859381    , d:  0.34447422       0.0000000      0.99999999
 i,j,k,ie:    6    2    6          30
 Near X =  0.63973777      0.38167920E-01  0.13437970    , d:  0.34447422     -0.66844737E-01  0.99999999
 i,j,k,ie:    1    3    6          30
 Near X =  0.61877942      0.11611774       0.0000000    , d:  0.33318896     -0.14110053      0.99999999
 i,j,k,ie:    2    3    6          30
 Near X =  0.61877942      0.11611774      0.15785898E-01, d:  0.33318896       0.0000000      0.99999999
 i,j,k,ie:    3    3    6          30
 Near X =  0.61877942      0.11611774      0.48025188E-01, d:  0.33318896       0.0000000      0.99999999
 i,j,k,ie:    4    3    6          30
 Near X =  0.61877942      0.11611774      0.86354515E-01, d:  0.33318896       0.0000000      0.99999999
 i,j,k,ie:    5    3    6          30
 Near X =  0.61877942      0.11611774      0.11859381    , d:  0.33318896       0.0000000      0.99999999
 i,j,k,ie:    6    3    6          30
 Near X =  0.61877942      0.11611774      0.13437970    , d:  0.33318896     -0.24925149E-01  0.99999999
 i,j,k,ie:    1    4    6          30
 Near X =  0.59386202      0.20879236       0.0000000    , d:  0.31977190     -0.18399250      0.99999999
 i,j,k,ie:    2    4    6          30
 Near X =  0.59386202      0.20879236      0.15785898E-01, d:  0.31977190       0.0000000      0.99999999
 i,j,k,ie:    3    4    6          30
 Near X =  0.59386202      0.20879236      0.48025188E-01, d:  0.31977190       0.0000000      0.99999999
 i,j,k,ie:    4    4    6          30
 Near X =  0.59386202      0.20879236      0.86354515E-01, d:  0.31977190       0.0000000      0.99999999
 i,j,k,ie:    5    4    6          30
 Near X =  0.59386202      0.20879236      0.11859381    , d:  0.31977190       0.0000000      0.99999999
 i,j,k,ie:    6    4    6          30
 Near X =  0.59386202      0.20879236      0.13437970    , d:  0.35809973       0.0000000      0.99999999
 i,j,k,ie:    1    5    6          30
 Near X =  0.57290367      0.28674217       0.0000000    , d:  0.30848663     -0.22006949      0.99999999
 i,j,k,ie:    2    5    6          30
 Near X =  0.57290367      0.28674217      0.15785898E-01, d:  0.30848663       0.0000000      0.99999999
 i,j,k,ie:    3    5    6          30
 Near X =  0.57290367      0.28674217      0.48025188E-01, d:  0.30848663       0.0000000      0.99999999
 i,j,k,ie:    4    5    6          30
 Near X =  0.57290367      0.28674217      0.86354515E-01, d:  0.30848663       0.0000000      0.99999999
 i,j,k,ie:    5    5    6          30
 Near X =  0.57290367      0.28674217      0.11859381    , d:  0.30848663       0.0000000      0.99999999
 i,j,k,ie:    6    5    6          30
 Near X =  0.57290367      0.28674217      0.13437970    , d:  0.41130614       0.0000000      0.99999999
 i,j,k,ie:    1    6    6          30
 Near X =  0.56264146      0.32491013       0.0000000    , d:  0.30296082      -1.0624984      0.99999999
 i,j,k,ie:    2    6    6          30
 Near X =  0.56264146      0.32491013      0.15785898E-01, d:  0.30296082      -1.0624984      0.99999999
 i,j,k,ie:    3    6    6          30
 Near X =  0.56264146      0.32491013      0.48025188E-01, d:  0.30296082      -1.0624984      0.99999999
 i,j,k,ie:    4    6    6          30
 Near X =  0.56264146      0.32491013      0.86354515E-01, d:  0.30296082      -1.0624984      0.99999999
 i,j,k,ie:    5    6    6          30
 Near X =  0.56264146      0.32491013      0.11859381    , d:  0.30296082      -1.0624984      0.99999999
 i,j,k,ie:    6    6    6          30
 Near X =  0.56264146      0.32491013      0.13437970    , d:  0.43735855      -1.4282437      0.99999999
 i,j,k,ie:    1    1    1          31
 Near X =  0.86558374     -0.49985689       0.0000000    , d:  0.13441627      -1.7311675      0.99999999
 i,j,k,ie:    2    1    1          31
 Near X =  0.86558374     -0.49985689      0.15785898E-01, d:   0.0000000      -1.3654455      0.99999999
 i,j,k,ie:    3    1    1          31
 Near X =  0.86558374     -0.49985689      0.48025188E-01, d:   0.0000000      -1.3654455      0.99999999
 i,j,k,ie:    4    1    1          31
 Near X =  0.86558374     -0.49985689      0.86354515E-01, d:   0.0000000      -1.3654455      0.99999999
 i,j,k,ie:    5    1    1          31
 Near X =  0.86558374     -0.49985689      0.11859381    , d:   0.0000000      -1.3654455      0.99999999
 i,j,k,ie:    6    1    1          31
 Near X =  0.86558374     -0.49985689      0.13437970    , d:   0.0000000      -1.3654455      0.99999999
 i,j,k,ie:    1    2    1          31
 Near X =  0.88137393     -0.44113754       0.0000000    , d:  0.10283806       0.0000000      0.99999999
 i,j,k,ie:    6    2    1          31
 Near X =  0.88137393     -0.44113754      0.13437970    , d:   0.0000000     -0.33855001      0.99999999
 i,j,k,ie:    1    3    1          31
 Near X =  0.91362200     -0.32121593       0.0000000    , d:  0.38346385E-01   0.0000000      0.99999999
 i,j,k,ie:    6    3    1          31
 Near X =  0.91362200     -0.32121593      0.13437970    , d:   0.0000000     -0.28305700      0.99999999
 i,j,k,ie:    1    4    1          31
 Near X =  0.95196175     -0.17864100       0.0000000    , d:   0.0000000     -0.38327837E-01  0.99999999
 i,j,k,ie:    6    4    1          31
 Near X =  0.95196175     -0.17864100      0.13437970    , d:   0.0000000     -0.21708131      0.99999999
 i,j,k,ie:    1    5    1          31
 Near X =  0.98420982     -0.58719398E-01   0.0000000    , d:   0.0000000     -0.10281951      0.99999999
 i,j,k,ie:    6    5    1          31
 Near X =  0.98420982     -0.58719398E-01  0.13437970    , d:   0.0000000     -0.16158830      0.99999999
 i,j,k,ie:    1    6    1          31
 Near X =   1.0000000     -0.46163286E-07   0.0000000    , d:   0.0000000      -1.8656023      0.99999999
 i,j,k,ie:    2    6    1          31
 Near X =   1.0000000     -0.46163286E-07  0.15785898E-01, d:   0.0000000      -1.8656023      0.99999999
 i,j,k,ie:    3    6    1          31
 Near X =   1.0000000     -0.46163286E-07  0.48025188E-01, d:   0.0000000      -1.8656023      0.99999999
 i,j,k,ie:    4    6    1          31
 Near X =   1.0000000     -0.46163286E-07  0.86354515E-01, d:   0.0000000      -1.8656023      0.99999999
 i,j,k,ie:    5    6    1          31
 Near X =   1.0000000     -0.46163286E-07  0.11859381    , d:   0.0000000      -1.8656023      0.99999999
 i,j,k,ie:    6    6    1          31
 Near X =   1.0000000     -0.46163286E-07  0.13437970    , d:   0.0000000      -2.0000000      0.99999999
 i,j,k,ie:    1    1    2          31
 Near X =  0.82999499     -0.47930511       0.0000000    , d:  0.12888970      -1.6599900      0.99999999
 i,j,k,ie:    2    1    2          31
 Near X =  0.82999499     -0.47930511      0.15785898E-01, d:   0.0000000      -1.3093048      0.99999999
 i,j,k,ie:    3    1    2          31
 Near X =  0.82999499     -0.47930511      0.48025188E-01, d:   0.0000000      -1.3093048      0.99999999
 i,j,k,ie:    4    1    2          31
 Near X =  0.82999499     -0.47930511      0.86354515E-01, d:   0.0000000      -1.3093048      0.99999999
 i,j,k,ie:    5    1    2          31
 Near X =  0.82999499     -0.47930511      0.11859381    , d:   0.0000000      -1.3093048      0.99999999
 i,j,k,ie:    6    1    2          31
 Near X =  0.82999499     -0.47930511      0.13437970    , d:   0.0000000      -1.3093048      0.99999999
 i,j,k,ie:    1    2    2          31
 Near X =  0.84513596     -0.42300002       0.0000000    , d:  0.98609841E-01   0.0000000      0.99999999
 i,j,k,ie:    6    2    2          31
 Near X =  0.84513596     -0.42300002      0.13437970    , d:   0.0000000     -0.32463042      0.99999999
 i,j,k,ie:    1    3    2          31
 Near X =  0.87605813     -0.30800903       0.0000000    , d:  0.36769761E-01   0.0000000      0.99999999
 i,j,k,ie:    6    3    2          31
 Near X =  0.87605813     -0.30800903      0.13437970    , d:   0.0000000     -0.27141902      0.99999999
 i,j,k,ie:    1    4    2          31
 Near X =  0.91282154     -0.17129612       0.0000000    , d:   0.0000000     -0.36751976E-01  0.99999999
 i,j,k,ie:    6    4    2          31
 Near X =  0.91282154     -0.17129612      0.13437970    , d:   0.0000000     -0.20815594      0.99999999
 i,j,k,ie:    1    5    2          31
 Near X =  0.94374371     -0.56305132E-01   0.0000000    , d:   0.0000000     -0.98592056E-01  0.99999999
 i,j,k,ie:    6    5    2          31
 Near X =  0.94374371     -0.56305132E-01  0.13437970    , d:   0.0000000     -0.15494454      0.99999999
 i,j,k,ie:    1    6    2          31
 Near X =  0.95888469     -0.45029985E-07   0.0000000    , d:   0.0000000      -1.7888974      0.99999999
 i,j,k,ie:    2    6    2          31
 Near X =  0.95888469     -0.45029985E-07  0.15785898E-01, d:   0.0000000      -1.7888974      0.99999999
 i,j,k,ie:    3    6    2          31
 Near X =  0.95888469     -0.45029985E-07  0.48025188E-01, d:   0.0000000      -1.7888974      0.99999999
 i,j,k,ie:    4    6    2          31
 Near X =  0.95888469     -0.45029985E-07  0.86354515E-01, d:   0.0000000      -1.7888974      0.99999999
 i,j,k,ie:    5    6    2          31
 Near X =  0.95888469     -0.45029985E-07  0.11859381    , d:   0.0000000      -1.7888974      0.99999999
 i,j,k,ie:    6    6    2          31
 Near X =  0.95888469     -0.45029985E-07  0.13437970    , d:   0.0000000      -1.9177694      0.99999999
 i,j,k,ie:    1    1    3          31
 Near X =  0.75731264     -0.43733254       0.0000000    , d:  0.11760288      -1.5146253      0.99999999
 i,j,k,ie:    2    1    3          31
 Near X =  0.75731264     -0.43733254      0.15785898E-01, d:   0.0000000      -1.1946495      0.99999999
 i,j,k,ie:    3    1    3          31
 Near X =  0.75731264     -0.43733254      0.48025188E-01, d:   0.0000000      -1.1946495      0.99999999
 i,j,k,ie:    4    1    3          31
 Near X =  0.75731264     -0.43733254      0.86354515E-01, d:   0.0000000      -1.1946495      0.99999999
 i,j,k,ie:    5    1    3          31
 Near X =  0.75731264     -0.43733254      0.11859381    , d:   0.0000000      -1.1946495      0.99999999
 i,j,k,ie:    6    1    3          31
 Near X =  0.75731264     -0.43733254      0.13437970    , d:   0.0000000      -1.1946495      0.99999999
 i,j,k,ie:    1    2    3          31
 Near X =  0.77112772     -0.38595807       0.0000000    , d:  0.89974615E-01   0.0000000      0.99999999
 i,j,k,ie:    6    2    3          31
 Near X =  0.77112772     -0.38595807      0.13437970    , d:   0.0000000     -0.29620265      0.99999999
 i,j,k,ie:    1    3    3          31
 Near X =  0.79934205     -0.28103680       0.0000000    , d:  0.33549847E-01   0.0000000      0.99999999
 i,j,k,ie:    6    3    3          31
 Near X =  0.79934205     -0.28103680      0.13437970    , d:   0.0000000     -0.24765096      0.99999999
 i,j,k,ie:    1    4    3          31
 Near X =  0.83288610     -0.15629579       0.0000000    , d:   0.0000000     -0.33533619E-01  0.99999999
 i,j,k,ie:    6    4    3          31
 Near X =  0.83288610     -0.15629579      0.13437970    , d:   0.0000000     -0.18992780      0.99999999
 i,j,k,ie:    1    5    3          31
 Near X =  0.86110043     -0.51374514E-01   0.0000000    , d:   0.0000000     -0.89958387E-01  0.99999999
 i,j,k,ie:    6    5    3          31
 Near X =  0.86110043     -0.51374514E-01  0.13437970    , d:   0.0000000     -0.14137611      0.99999999
 i,j,k,ie:    1    6    3          31
 Near X =  0.87491551     -0.42715462E-07   0.0000000    , d:   0.0000000      -1.6322444      0.99999999
 i,j,k,ie:    2    6    3          31
 Near X =  0.87491551     -0.42715462E-07  0.15785898E-01, d:   0.0000000      -1.6322444      0.99999999
 i,j,k,ie:    3    6    3          31
 Near X =  0.87491551     -0.42715462E-07  0.48025188E-01, d:   0.0000000      -1.6322444      0.99999999
 i,j,k,ie:    4    6    3          31
 Near X =  0.87491551     -0.42715462E-07  0.86354515E-01, d:   0.0000000      -1.6322444      0.99999999
 i,j,k,ie:    5    6    3          31
 Near X =  0.87491551     -0.42715462E-07  0.11859381    , d:   0.0000000      -1.6322444      0.99999999
 i,j,k,ie:    6    6    3          31
 Near X =  0.87491551     -0.42715462E-07  0.13437970    , d:   0.0000000      -1.7498310      0.99999999
 i,j,k,ie:    1    1    4          31
 Near X =  0.67090051     -0.38743131       0.0000000    , d:  0.10418396      -1.3418011      0.99999999
 i,j,k,ie:    2    1    4          31
 Near X =  0.67090051     -0.38743131      0.15785898E-01, d:   0.0000000      -1.0583356      0.99999999
 i,j,k,ie:    3    1    4          31
 Near X =  0.67090051     -0.38743131      0.48025188E-01, d:   0.0000000      -1.0583356      0.99999999
 i,j,k,ie:    4    1    4          31
 Near X =  0.67090051     -0.38743131      0.86354515E-01, d:   0.0000000      -1.0583356      0.99999999
 i,j,k,ie:    5    1    4          31
 Near X =  0.67090051     -0.38743131      0.11859381    , d:   0.0000000      -1.0583356      0.99999999
 i,j,k,ie:    6    1    4          31
 Near X =  0.67090051     -0.38743131      0.13437970    , d:   0.0000000      -1.0583356      0.99999999
 i,j,k,ie:    1    2    4          31
 Near X =  0.68313925     -0.34191885       0.0000000    , d:  0.79708184E-01   0.0000000      0.99999999
 i,j,k,ie:    6    2    4          31
 Near X =  0.68313925     -0.34191885      0.13437970    , d:   0.0000000     -0.26240485      0.99999999
 i,j,k,ie:    1    3    4          31
 Near X =  0.70813422     -0.24896948       0.0000000    , d:  0.29721687E-01   0.0000000      0.99999999
 i,j,k,ie:    6    3    4          31
 Near X =  0.70813422     -0.24896948      0.13437970    , d:   0.0000000     -0.21939309      0.99999999
 i,j,k,ie:    1    4    4          31
 Near X =  0.73785077     -0.13846187       0.0000000    , d:   0.0000000     -0.29707311E-01  0.99999999
 i,j,k,ie:    6    4    4          31
 Near X =  0.73785077     -0.13846187      0.13437970    , d:   0.0000000     -0.16825635      0.99999999
 i,j,k,ie:    1    5    4          31
 Near X =  0.76284574     -0.45512497E-01   0.0000000    , d:   0.0000000     -0.79693808E-01  0.99999999
 i,j,k,ie:    6    5    4          31
 Near X =  0.76284574     -0.45512497E-01  0.13437970    , d:   0.0000000     -0.12524458      0.99999999
 i,j,k,ie:    1    6    4          31
 Near X =  0.77508447     -0.39963724E-07   0.0000000    , d:   0.0000000      -1.4459993      0.99999999
 i,j,k,ie:    2    6    4          31
 Near X =  0.77508447     -0.39963724E-07  0.15785898E-01, d:   0.0000000      -1.4459993      0.99999999
 i,j,k,ie:    3    6    4          31
 Near X =  0.77508447     -0.39963724E-07  0.48025188E-01, d:   0.0000000      -1.4459993      0.99999999
 i,j,k,ie:    4    6    4          31
 Near X =  0.77508447     -0.39963724E-07  0.86354515E-01, d:   0.0000000      -1.4459993      0.99999999
 i,j,k,ie:    5    6    4          31
 Near X =  0.77508447     -0.39963724E-07  0.11859381    , d:   0.0000000      -1.4459993      0.99999999
 i,j,k,ie:    6    6    4          31
 Near X =  0.77508447     -0.39963724E-07  0.13437970    , d:   0.0000000      -1.5501689      0.99999999
 i,j,k,ie:    1    1    5          31
 Near X =  0.59821816     -0.34545874       0.0000000    , d:  0.92897140E-01  -1.1964363      0.99999999
 i,j,k,ie:    2    1    5          31
 Near X =  0.59821816     -0.34545874      0.15785898E-01, d:   0.0000000     -0.94368028      0.99999999
 i,j,k,ie:    3    1    5          31
 Near X =  0.59821816     -0.34545874      0.48025188E-01, d:   0.0000000     -0.94368028      0.99999999
 i,j,k,ie:    4    1    5          31
 Near X =  0.59821816     -0.34545874      0.86354515E-01, d:   0.0000000     -0.94368028      0.99999999
 i,j,k,ie:    5    1    5          31
 Near X =  0.59821816     -0.34545874      0.11859381    , d:   0.0000000     -0.94368028      0.99999999
 i,j,k,ie:    6    1    5          31
 Near X =  0.59821816     -0.34545874      0.13437970    , d:   0.0000000     -0.94368028      0.99999999
 i,j,k,ie:    1    2    5          31
 Near X =  0.60913101     -0.30487690       0.0000000    , d:  0.71072957E-01   0.0000000      0.99999999
 i,j,k,ie:    6    2    5          31
 Near X =  0.60913101     -0.30487690      0.13437970    , d:   0.0000000     -0.23397709      0.99999999
 i,j,k,ie:    1    3    5          31
 Near X =  0.63141814     -0.22199725       0.0000000    , d:  0.26501773E-01   0.0000000      0.99999999
 i,j,k,ie:    6    3    5          31
 Near X =  0.63141814     -0.22199725      0.13437970    , d:   0.0000000     -0.19562502      0.99999999
 i,j,k,ie:    1    4    5          31
 Near X =  0.65791533     -0.12346154       0.0000000    , d:   0.0000000     -0.26488955E-01  0.99999999
 i,j,k,ie:    6    4    5          31
 Near X =  0.65791533     -0.12346154      0.13437970    , d:   0.0000000     -0.15002821      0.99999999
 i,j,k,ie:    1    5    5          31
 Near X =  0.68020246     -0.40581880E-01   0.0000000    , d:   0.0000000     -0.71060138E-01  0.99999999
 i,j,k,ie:    6    5    5          31
 Near X =  0.68020246     -0.40581880E-01  0.13437970    , d:   0.0000000     -0.11167614      0.99999999
 i,j,k,ie:    1    6    5          31
 Near X =  0.69111530     -0.37649202E-07   0.0000000    , d:   0.0000000      -1.2893463      0.99999999
 i,j,k,ie:    2    6    5          31
 Near X =  0.69111530     -0.37649202E-07  0.15785898E-01, d:   0.0000000      -1.2893463      0.99999999
 i,j,k,ie:    3    6    5          31
 Near X =  0.69111530     -0.37649202E-07  0.48025188E-01, d:   0.0000000      -1.2893463      0.99999999
 i,j,k,ie:    4    6    5          31
 Near X =  0.69111530     -0.37649202E-07  0.86354515E-01, d:   0.0000000      -1.2893463      0.99999999
 i,j,k,ie:    5    6    5          31
 Near X =  0.69111530     -0.37649202E-07  0.11859381    , d:   0.0000000      -1.2893463      0.99999999
 i,j,k,ie:    6    6    5          31
 Near X =  0.69111530     -0.37649202E-07  0.13437970    , d:   0.0000000      -1.3822306      0.99999999
 i,j,k,ie:    1    1    6          31
 Near X =  0.56262941     -0.32490697       0.0000000    , d:  0.43737060      -1.4282132      0.99999999
 i,j,k,ie:    2    1    6          31
 Near X =  0.56262941     -0.32490697      0.15785898E-01, d:  0.30295433      -1.0624912      0.99999999
 i,j,k,ie:    3    1    6          31
 Near X =  0.56262941     -0.32490697      0.48025188E-01, d:  0.30295433      -1.0624912      0.99999999
 i,j,k,ie:    4    1    6          31
 Near X =  0.56262941     -0.32490697      0.86354515E-01, d:  0.30295433      -1.0624912      0.99999999
 i,j,k,ie:    5    1    6          31
 Near X =  0.56262941     -0.32490697      0.11859381    , d:  0.30295433      -1.0624912      0.99999999
 i,j,k,ie:    6    1    6          31
 Near X =  0.56262941     -0.32490697      0.13437970    , d:  0.30295433      -1.0624912      0.99999999
 i,j,k,ie:    1    2    6          31
 Near X =  0.57289303     -0.28673939       0.0000000    , d:  0.41131896       0.0000000      0.99999999
 i,j,k,ie:    2    2    6          31
 Near X =  0.57289303     -0.28673939      0.15785898E-01, d:  0.30848090       0.0000000      0.99999999
 i,j,k,ie:    3    2    6          31
 Near X =  0.57289303     -0.28673939      0.48025188E-01, d:  0.30848090       0.0000000      0.99999999
 i,j,k,ie:    4    2    6          31
 Near X =  0.57289303     -0.28673939      0.86354515E-01, d:  0.30848090       0.0000000      0.99999999
 i,j,k,ie:    5    2    6          31
 Near X =  0.57289303     -0.28673939      0.11859381    , d:  0.30848090       0.0000000      0.99999999
 i,j,k,ie:    6    2    6          31
 Near X =  0.57289303     -0.28673939      0.13437970    , d:  0.30848090     -0.22005750      0.99999999
 i,j,k,ie:    1    3    6          31
 Near X =  0.59385427     -0.20879035       0.0000000    , d:  0.35811411       0.0000000      0.99999999
 i,j,k,ie:    2    3    6          31
 Near X =  0.59385427     -0.20879035      0.15785898E-01, d:  0.31976772       0.0000000      0.99999999
 i,j,k,ie:    3    3    6          31
 Near X =  0.59385427     -0.20879035      0.48025188E-01, d:  0.31976772       0.0000000      0.99999999
 i,j,k,ie:    4    3    6          31
 Near X =  0.59385427     -0.20879035      0.86354515E-01, d:  0.31976772       0.0000000      0.99999999
 i,j,k,ie:    5    3    6          31
 Near X =  0.59385427     -0.20879035      0.11859381    , d:  0.31976772       0.0000000      0.99999999
 i,j,k,ie:    6    3    6          31
 Near X =  0.59385427     -0.20879035      0.13437970    , d:  0.31976772     -0.18398704      0.99999999
 i,j,k,ie:    1    4    6          31
 Near X =  0.61877511     -0.11611665       0.0000000    , d:  0.33318664     -0.24913093E-01  0.99999999
 i,j,k,ie:    2    4    6          31
 Near X =  0.61877511     -0.11611665      0.15785898E-01, d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    3    4    6          31
 Near X =  0.61877511     -0.11611665      0.48025188E-01, d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    4    4    6          31
 Near X =  0.61877511     -0.11611665      0.86354515E-01, d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    5    4    6          31
 Near X =  0.61877511     -0.11611665      0.11859381    , d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    6    4    6          31
 Near X =  0.61877511     -0.11611665      0.13437970    , d:  0.33318664     -0.14110284      0.99999999
 i,j,k,ie:    1    5    6          31
 Near X =  0.63973635     -0.38167613E-01   0.0000000    , d:  0.34447346     -0.66832681E-01  0.99999999
 i,j,k,ie:    2    5    6          31
 Near X =  0.63973635     -0.38167613E-01  0.15785898E-01, d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    3    5    6          31
 Near X =  0.63973635     -0.38167613E-01  0.48025188E-01, d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    4    5    6          31
 Near X =  0.63973635     -0.38167613E-01  0.86354515E-01, d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    5    5    6          31
 Near X =  0.63973635     -0.38167613E-01  0.11859381    , d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    6    5    6          31
 Near X =  0.63973635     -0.38167613E-01  0.13437970    , d:  0.34447346     -0.10503239      0.99999999
 i,j,k,ie:    1    6    6          31
 Near X =  0.64999998     -0.36515901E-07   0.0000000    , d:  0.35000003      -1.5156023      0.99999999
 i,j,k,ie:    2    6    6          31
 Near X =  0.64999998     -0.36515901E-07  0.15785898E-01, d:  0.35000003      -1.5156023      0.99999999
 i,j,k,ie:    3    6    6          31
 Near X =  0.64999998     -0.36515901E-07  0.48025188E-01, d:  0.35000003      -1.5156023      0.99999999
 i,j,k,ie:    4    6    6          31
 Near X =  0.64999998     -0.36515901E-07  0.86354515E-01, d:  0.35000003      -1.5156023      0.99999999
 i,j,k,ie:    5    6    6          31
 Near X =  0.64999998     -0.36515901E-07  0.11859381    , d:  0.35000003      -1.5156023      0.99999999
 i,j,k,ie:    6    6    6          31
 Near X =  0.64999998     -0.36515901E-07  0.13437970    , d:  0.35000003      -1.6500000      0.99999999
 i,j,k,ie:    1    1    1          32
 Near X =  0.49986170     -0.86560228       0.0000000    , d:  0.36572204     -0.99972348       1.1552897
 i,j,k,ie:    2    1    1          32
 Near X =  0.49986170     -0.86560228      0.15785898E-01, d:   0.0000000     -0.49986166       1.1552897
 i,j,k,ie:    3    1    1          32
 Near X =  0.49986170     -0.86560228      0.48025188E-01, d:   0.0000000     -0.49986166       1.1552897
 i,j,k,ie:    4    1    1          32
 Near X =  0.49986170     -0.86560228      0.86354515E-01, d:   0.0000000     -0.49986166       1.1552897
 i,j,k,ie:    5    1    1          32
 Near X =  0.49986170     -0.86560228      0.11859381    , d:   0.0000000     -0.49986166       1.1552897
 i,j,k,ie:    6    1    1          32
 Near X =  0.49986170     -0.86560228      0.13437970    , d:   0.0000000     -0.49986166       1.1552897
 i,j,k,ie:    1    2    1          32
 Near X =  0.54282392     -0.82263731       0.0000000    , d:  0.33855001       0.0000000       1.1552897
 i,j,k,ie:    1    3    1          32
 Near X =  0.63056499     -0.73489064       0.0000000    , d:  0.28305700       0.0000000       1.1552897
 i,j,k,ie:    1    4    1          32
 Near X =  0.73488045     -0.63056853       0.0000000    , d:  0.21708131       0.0000000       1.1552897
 i,j,k,ie:    1    5    1          32
 Near X =  0.82262152     -0.54282185       0.0000000    , d:  0.16158830       0.0000000       1.1552897
 i,j,k,ie:    1    6    1          32
 Near X =  0.86558374     -0.49985689       0.0000000    , d:  0.13441627      -1.8655837       1.1552897
 i,j,k,ie:    2    6    1          32
 Near X =  0.86558374     -0.49985689      0.15785898E-01, d:   0.0000000      -1.8655837       1.1552897
 i,j,k,ie:    3    6    1          32
 Near X =  0.86558374     -0.49985689      0.48025188E-01, d:   0.0000000      -1.8655837       1.1552897
 i,j,k,ie:    4    6    1          32
 Near X =  0.86558374     -0.49985689      0.86354515E-01, d:   0.0000000      -1.8655837       1.1552897
 i,j,k,ie:    5    6    1          32
 Near X =  0.86558374     -0.49985689      0.11859381    , d:   0.0000000      -1.8655837       1.1552897
 i,j,k,ie:    6    6    1          32
 Near X =  0.86558374     -0.49985689      0.13437970    , d:   0.0000000      -1.8655837       1.1552897
 i,j,k,ie:    1    1    2          32
 Near X =  0.47930973     -0.83001276       0.0000000    , d:  0.35068526     -0.95861952       1.1552897
 i,j,k,ie:    2    1    2          32
 Near X =  0.47930973     -0.83001276      0.15785898E-01, d:   0.0000000     -0.47930969       1.1552897
 i,j,k,ie:    3    1    2          32
 Near X =  0.47930973     -0.83001276      0.48025188E-01, d:   0.0000000     -0.47930969       1.1552897
 i,j,k,ie:    4    1    2          32
 Near X =  0.47930973     -0.83001276      0.86354515E-01, d:   0.0000000     -0.47930969       1.1552897
 i,j,k,ie:    5    1    2          32
 Near X =  0.47930973     -0.83001276      0.11859381    , d:   0.0000000     -0.47930969       1.1552897
 i,j,k,ie:    6    1    2          32
 Near X =  0.47930973     -0.83001276      0.13437970    , d:   0.0000000     -0.47930969       1.1552897
 i,j,k,ie:    1    2    2          32
 Near X =  0.52050554     -0.78881431       0.0000000    , d:  0.32463042       0.0000000       1.1552897
 i,j,k,ie:    1    3    2          32
 Near X =  0.60463911     -0.70467537       0.0000000    , d:  0.27141902       0.0000000       1.1552897
 i,j,k,ie:    1    4    2          32
 Near X =  0.70466560     -0.60464250       0.0000000    , d:  0.20815594       0.0000000       1.1552897
 i,j,k,ie:    1    5    2          32
 Near X =  0.78879917     -0.52050356       0.0000000    , d:  0.15494454       0.0000000       1.1552897
 i,j,k,ie:    1    6    2          32
 Near X =  0.82999499     -0.47930511       0.0000000    , d:  0.12888970      -1.7888797       1.1552897
 i,j,k,ie:    2    6    2          32
 Near X =  0.82999499     -0.47930511      0.15785898E-01, d:   0.0000000      -1.7888797       1.1552897
 i,j,k,ie:    3    6    2          32
 Near X =  0.82999499     -0.47930511      0.48025188E-01, d:   0.0000000      -1.7888797       1.1552897
 i,j,k,ie:    4    6    2          32
 Near X =  0.82999499     -0.47930511      0.86354515E-01, d:   0.0000000      -1.7888797       1.1552897
 i,j,k,ie:    5    6    2          32
 Near X =  0.82999499     -0.47930511      0.11859381    , d:   0.0000000      -1.7888797       1.1552897
 i,j,k,ie:    6    6    2          32
 Near X =  0.82999499     -0.47930511      0.13437970    , d:   0.0000000      -1.7888797       1.1552897
 i,j,k,ie:    1    1    3          32
 Near X =  0.43733675     -0.75732886       0.0000000    , d:  0.31997588     -0.87467357       1.1552897
 i,j,k,ie:    2    1    3          32
 Near X =  0.43733675     -0.75732886      0.15785898E-01, d:   0.0000000     -0.43733672       1.1552897
 i,j,k,ie:    3    1    3          32
 Near X =  0.43733675     -0.75732886      0.48025188E-01, d:   0.0000000     -0.43733672       1.1552897
 i,j,k,ie:    4    1    3          32
 Near X =  0.43733675     -0.75732886      0.86354515E-01, d:   0.0000000     -0.43733672       1.1552897
 i,j,k,ie:    5    1    3          32
 Near X =  0.43733675     -0.75732886      0.11859381    , d:   0.0000000     -0.43733672       1.1552897
 i,j,k,ie:    6    1    3          32
 Near X =  0.43733675     -0.75732886      0.13437970    , d:   0.0000000     -0.43733672       1.1552897
 i,j,k,ie:    1    2    3          32
 Near X =  0.47492507     -0.71973814       0.0000000    , d:  0.29620265       0.0000000       1.1552897
 i,j,k,ie:    1    3    3          32
 Near X =  0.55169109     -0.64296722       0.0000000    , d:  0.24765096       0.0000000       1.1552897
 i,j,k,ie:    1    4    3          32
 Near X =  0.64295830     -0.55169418       0.0000000    , d:  0.18992780       0.0000000       1.1552897
 i,j,k,ie:    1    5    3          32
 Near X =  0.71972432     -0.47492326       0.0000000    , d:  0.14137611       0.0000000       1.1552897
 i,j,k,ie:    1    6    3          32
 Near X =  0.75731264     -0.43733254       0.0000000    , d:  0.11760288      -1.6322281       1.1552897
 i,j,k,ie:    2    6    3          32
 Near X =  0.75731264     -0.43733254      0.15785898E-01, d:   0.0000000      -1.6322281       1.1552897
 i,j,k,ie:    3    6    3          32
 Near X =  0.75731264     -0.43733254      0.48025188E-01, d:   0.0000000      -1.6322281       1.1552897
 i,j,k,ie:    4    6    3          32
 Near X =  0.75731264     -0.43733254      0.86354515E-01, d:   0.0000000      -1.6322281       1.1552897
 i,j,k,ie:    5    6    3          32
 Near X =  0.75731264     -0.43733254      0.11859381    , d:   0.0000000      -1.6322281       1.1552897
 i,j,k,ie:    6    6    3          32
 Near X =  0.75731264     -0.43733254      0.13437970    , d:   0.0000000      -1.6322281       1.1552897
 i,j,k,ie:    1    1    4          32
 Near X =  0.38743504     -0.67091488       0.0000000    , d:  0.28346547     -0.77487014       1.1552897
 i,j,k,ie:    2    1    4          32
 Near X =  0.38743504     -0.67091488      0.15785898E-01, d:   0.0000000     -0.38743501       1.1552897
 i,j,k,ie:    3    1    4          32
 Near X =  0.38743504     -0.67091488      0.48025188E-01, d:   0.0000000     -0.38743501       1.1552897
 i,j,k,ie:    4    1    4          32
 Near X =  0.38743504     -0.67091488      0.86354515E-01, d:   0.0000000     -0.38743501       1.1552897
 i,j,k,ie:    5    1    4          32
 Near X =  0.38743504     -0.67091488      0.11859381    , d:   0.0000000     -0.38743501       1.1552897
 i,j,k,ie:    6    1    4          32
 Near X =  0.38743504     -0.67091488      0.13437970    , d:   0.0000000     -0.38743501       1.1552897
 i,j,k,ie:    1    2    4          32
 Near X =  0.42073439     -0.63761340       0.0000000    , d:  0.26240485       0.0000000       1.1552897
 i,j,k,ie:    1    3    4          32
 Near X =  0.48874113     -0.56960232       0.0000000    , d:  0.21939309       0.0000000       1.1552897
 i,j,k,ie:    1    4    4          32
 Near X =  0.56959442     -0.48874387       0.0000000    , d:  0.16825635       0.0000000       1.1552897
 i,j,k,ie:    1    5    4          32
 Near X =  0.63760116     -0.42073279       0.0000000    , d:  0.12524458       0.0000000       1.1552897
 i,j,k,ie:    1    6    4          32
 Near X =  0.67090051     -0.38743131       0.0000000    , d:  0.10418396      -1.4459850       1.1552897
 i,j,k,ie:    2    6    4          32
 Near X =  0.67090051     -0.38743131      0.15785898E-01, d:   0.0000000      -1.4459850       1.1552897
 i,j,k,ie:    3    6    4          32
 Near X =  0.67090051     -0.38743131      0.48025188E-01, d:   0.0000000      -1.4459850       1.1552897
 i,j,k,ie:    4    6    4          32
 Near X =  0.67090051     -0.38743131      0.86354515E-01, d:   0.0000000      -1.4459850       1.1552897
 i,j,k,ie:    5    6    4          32
 Near X =  0.67090051     -0.38743131      0.11859381    , d:   0.0000000      -1.4459850       1.1552897
 i,j,k,ie:    6    6    4          32
 Near X =  0.67090051     -0.38743131      0.13437970    , d:   0.0000000      -1.4459850       1.1552897
 i,j,k,ie:    1    1    5          32
 Near X =  0.34546207     -0.59823098       0.0000000    , d:  0.25275610     -0.69092418       1.1552897
 i,j,k,ie:    2    1    5          32
 Near X =  0.34546207     -0.59823098      0.15785898E-01, d:   0.0000000     -0.34546204       1.1552897
 i,j,k,ie:    3    1    5          32
 Near X =  0.34546207     -0.59823098      0.48025188E-01, d:   0.0000000     -0.34546204       1.1552897
 i,j,k,ie:    4    1    5          32
 Near X =  0.34546207     -0.59823098      0.86354515E-01, d:   0.0000000     -0.34546204       1.1552897
 i,j,k,ie:    5    1    5          32
 Near X =  0.34546207     -0.59823098      0.11859381    , d:   0.0000000     -0.34546204       1.1552897
 i,j,k,ie:    6    1    5          32
 Near X =  0.34546207     -0.59823098      0.13437970    , d:   0.0000000     -0.34546204       1.1552897
 i,j,k,ie:    1    2    5          32
 Near X =  0.37515392     -0.56853723       0.0000000    , d:  0.23397709       0.0000000       1.1552897
 i,j,k,ie:    1    3    5          32
 Near X =  0.43579311     -0.50789416       0.0000000    , d:  0.19562502       0.0000000       1.1552897
 i,j,k,ie:    1    4    5          32
 Near X =  0.50788712     -0.43579556       0.0000000    , d:  0.15002821       0.0000000       1.1552897
 i,j,k,ie:    1    5    5          32
 Near X =  0.56852631     -0.37515249       0.0000000    , d:  0.11167614       0.0000000       1.1552897
 i,j,k,ie:    1    6    5          32
 Near X =  0.59821816     -0.34545874       0.0000000    , d:  0.92897140E-01  -1.2893335       1.1552897
 i,j,k,ie:    2    6    5          32
 Near X =  0.59821816     -0.34545874      0.15785898E-01, d:   0.0000000      -1.2893335       1.1552897
 i,j,k,ie:    3    6    5          32
 Near X =  0.59821816     -0.34545874      0.48025188E-01, d:   0.0000000      -1.2893335       1.1552897
 i,j,k,ie:    4    6    5          32
 Near X =  0.59821816     -0.34545874      0.86354515E-01, d:   0.0000000      -1.2893335       1.1552897
 i,j,k,ie:    5    6    5          32
 Near X =  0.59821816     -0.34545874      0.11859381    , d:   0.0000000      -1.2893335       1.1552897
 i,j,k,ie:    6    6    5          32
 Near X =  0.59821816     -0.34545874      0.13437970    , d:   0.0000000      -1.2893335       1.1552897
 i,j,k,ie:    1    1    6          32
 Near X =  0.32491009     -0.56264146       0.0000000    , d:  0.54067365     -0.82477187       1.1552897
 i,j,k,ie:    2    1    6          32
 Near X =  0.32491009     -0.56264146      0.15785898E-01, d:  0.17495161     -0.32491007       1.1552897
 i,j,k,ie:    3    1    6          32
 Near X =  0.32491009     -0.56264146      0.48025188E-01, d:  0.17495161     -0.32491007       1.1552897
 i,j,k,ie:    4    1    6          32
 Near X =  0.32491009     -0.56264146      0.86354515E-01, d:  0.17495161     -0.32491007       1.1552897
 i,j,k,ie:    5    1    6          32
 Near X =  0.32491009     -0.56264146      0.11859381    , d:  0.17495161     -0.32491007       1.1552897
 i,j,k,ie:    6    1    6          32
 Near X =  0.32491009     -0.56264146      0.13437970    , d:  0.17495161     -0.32491007       1.1552897
 i,j,k,ie:    1    2    6          32
 Near X =  0.35283554     -0.53471423       0.0000000    , d:  0.52853840       0.0000000       1.1552897
 i,j,k,ie:    2    2    6          32
 Near X =  0.35283554     -0.53471423      0.15785898E-01, d:  0.18998839       0.0000000       1.1552897
 i,j,k,ie:    3    2    6          32
 Near X =  0.35283554     -0.53471423      0.48025188E-01, d:  0.18998839       0.0000000       1.1552897
 i,j,k,ie:    4    2    6          32
 Near X =  0.35283554     -0.53471423      0.86354515E-01, d:  0.18998839       0.0000000       1.1552897
 i,j,k,ie:    5    2    6          32
 Near X =  0.35283554     -0.53471423      0.11859381    , d:  0.18998839       0.0000000       1.1552897
 i,j,k,ie:    6    2    6          32
 Near X =  0.35283554     -0.53471423      0.13437970    , d:  0.18998839       0.0000000       1.1552897
 i,j,k,ie:    1    3    6          32
 Near X =  0.40986723     -0.47767890       0.0000000    , d:  0.50375477       0.0000000       1.1552897
 i,j,k,ie:    2    3    6          32
 Near X =  0.40986723     -0.47767890      0.15785898E-01, d:  0.22069777       0.0000000       1.1552897
 i,j,k,ie:    3    3    6          32
 Near X =  0.40986723     -0.47767890      0.48025188E-01, d:  0.22069777       0.0000000       1.1552897
 i,j,k,ie:    4    3    6          32
 Near X =  0.40986723     -0.47767890      0.86354515E-01, d:  0.22069777       0.0000000       1.1552897
 i,j,k,ie:    5    3    6          32
 Near X =  0.40986723     -0.47767890      0.11859381    , d:  0.22069777       0.0000000       1.1552897
 i,j,k,ie:    6    3    6          32
 Near X =  0.40986723     -0.47767890      0.13437970    , d:  0.22069777       0.0000000       1.1552897
 i,j,k,ie:    1    4    6          32
 Near X =  0.47767227     -0.40986953       0.0000000    , d:  0.47428948       0.0000000       1.1552897
 i,j,k,ie:    2    4    6          32
 Near X =  0.47767227     -0.40986953      0.15785898E-01, d:  0.25720818       0.0000000       1.1552897
 i,j,k,ie:    3    4    6          32
 Near X =  0.47767227     -0.40986953      0.48025188E-01, d:  0.25720818       0.0000000       1.1552897
 i,j,k,ie:    4    4    6          32
 Near X =  0.47767227     -0.40986953      0.86354515E-01, d:  0.25720818       0.0000000       1.1552897
 i,j,k,ie:    5    4    6          32
 Near X =  0.47767227     -0.40986953      0.11859381    , d:  0.25720818       0.0000000       1.1552897
 i,j,k,ie:    6    4    6          32
 Near X =  0.47767227     -0.40986953      0.13437970    , d:  0.25720818       0.0000000       1.1552897
 i,j,k,ie:    1    5    6          32
 Near X =  0.53470396     -0.35283419       0.0000000    , d:  0.44950585       0.0000000       1.1552897
 i,j,k,ie:    2    5    6          32
 Near X =  0.53470396     -0.35283419      0.15785898E-01, d:  0.28791755       0.0000000       1.1552897
 i,j,k,ie:    3    5    6          32
 Near X =  0.53470396     -0.35283419      0.48025188E-01, d:  0.28791755       0.0000000       1.1552897
 i,j,k,ie:    4    5    6          32
 Near X =  0.53470396     -0.35283419      0.86354515E-01, d:  0.28791755       0.0000000       1.1552897
 i,j,k,ie:    5    5    6          32
 Near X =  0.53470396     -0.35283419      0.11859381    , d:  0.28791755       0.0000000       1.1552897
 i,j,k,ie:    6    5    6          32
 Near X =  0.53470396     -0.35283419      0.13437970    , d:  0.28791755       0.0000000       1.1552897
 i,j,k,ie:    1    6    6          32
 Near X =  0.56262941     -0.32490697       0.0000000    , d:  0.43737060      -1.5626294       1.1552897
 i,j,k,ie:    2    6    6          32
 Near X =  0.56262941     -0.32490697      0.15785898E-01, d:  0.30295433      -1.5626294       1.1552897
 i,j,k,ie:    3    6    6          32
 Near X =  0.56262941     -0.32490697      0.48025188E-01, d:  0.30295433      -1.5626294       1.1552897
 i,j,k,ie:    4    6    6          32
 Near X =  0.56262941     -0.32490697      0.86354515E-01, d:  0.30295433      -1.5626294       1.1552897
 i,j,k,ie:    5    6    6          32
 Near X =  0.56262941     -0.32490697      0.11859381    , d:  0.30295433      -1.5626294       1.1552897
 i,j,k,ie:    6    6    6          32
 Near X =  0.56262941     -0.32490697      0.13437970    , d:  0.30295433      -1.5626294       1.1552897
 i,j,k,ie:    1    1    1          33
 Near X = -0.11800764E-06  -1.0000000       0.0000000    , d:  0.49985699       0.0000000       2.0005529
 i,j,k,ie:    2    1    1          33
 Near X = -0.11800764E-06  -1.0000000      0.15785898E-01, d:  0.49985699       0.0000000       2.0005529
 i,j,k,ie:    3    1    1          33
 Near X = -0.11800764E-06  -1.0000000      0.48025188E-01, d:  0.49985699       0.0000000       2.0005529
 i,j,k,ie:    4    1    1          33
 Near X = -0.11800764E-06  -1.0000000      0.86354515E-01, d:  0.49985699       0.0000000       2.0005529
 i,j,k,ie:    5    1    1          33
 Near X = -0.11800764E-06  -1.0000000      0.11859381    , d:  0.49985699       0.0000000       2.0005529
 i,j,k,ie:    6    1    1          33
 Near X = -0.11800764E-06  -1.0000000      0.13437970    , d:  0.86560241     -0.49985679       2.0005529
 i,j,k,ie:    6    2    1          33
 Near X =  0.58719818E-01 -0.98421199      0.13437970    , d:   0.0000000     -0.49985738       2.0005529
 i,j,k,ie:    6    3    1          33
 Near X =  0.17864262     -0.95196838      0.13437970    , d:   0.0000000     -0.49985858       2.0005529
 i,j,k,ie:    6    4    1          33
 Near X =  0.32121896     -0.91363391      0.13437970    , d:   0.0000000     -0.49986002       2.0005529
 i,j,k,ie:    6    5    1          33
 Near X =  0.44114176     -0.88139029      0.13437970    , d:   0.0000000     -0.49986123       2.0005529
 i,j,k,ie:    1    6    1          33
 Near X =  0.49986170     -0.86560228       0.0000000    , d:   0.0000000     -0.82476867       2.0005529
 i,j,k,ie:    2    6    1          33
 Near X =  0.49986170     -0.86560228      0.15785898E-01, d:   0.0000000     -0.82476867       2.0005529
 i,j,k,ie:    3    6    1          33
 Near X =  0.49986170     -0.86560228      0.48025188E-01, d:   0.0000000     -0.82476867       2.0005529
 i,j,k,ie:    4    6    1          33
 Near X =  0.49986170     -0.86560228      0.86354515E-01, d:   0.0000000     -0.82476867       2.0005529
 i,j,k,ie:    5    6    1          33
 Near X =  0.49986170     -0.86560228      0.11859381    , d:   0.0000000     -0.82476867       2.0005529
 i,j,k,ie:    6    6    1          33
 Near X =  0.49986170     -0.86560228      0.13437970    , d:   0.0000000      -1.0625032       2.0005529
 i,j,k,ie:    1    1    2          33
 Near X = -0.11315572E-06 -0.95888469       0.0000000    , d:  0.47930521       0.0000000       2.0005529
 i,j,k,ie:    2    1    2          33
 Near X = -0.11315572E-06 -0.95888469      0.15785898E-01, d:  0.47930521       0.0000000       2.0005529
 i,j,k,ie:    3    1    2          33
 Near X = -0.11315572E-06 -0.95888469      0.48025188E-01, d:  0.47930521       0.0000000       2.0005529
 i,j,k,ie:    4    1    2          33
 Near X = -0.11315572E-06 -0.95888469      0.86354515E-01, d:  0.47930521       0.0000000       2.0005529
 i,j,k,ie:    5    1    2          33
 Near X = -0.11315572E-06 -0.95888469      0.11859381    , d:  0.47930521       0.0000000       2.0005529
 i,j,k,ie:    6    1    2          33
 Near X = -0.11315572E-06 -0.95888469      0.13437970    , d:  0.83001288     -0.47930501       2.0005529
 i,j,k,ie:    6    2    2          33
 Near X =  0.56305534E-01 -0.94374580      0.13437970    , d:   0.0000000     -0.47930558       2.0005529
 i,j,k,ie:    6    3    2          33
 Near X =  0.17129767     -0.91282789      0.13437970    , d:   0.0000000     -0.47930674       2.0005529
 i,j,k,ie:    6    4    2          33
 Near X =  0.30801194     -0.87606956      0.13437970    , d:   0.0000000     -0.47930811       2.0005529
 i,j,k,ie:    6    5    2          33
 Near X =  0.42300408     -0.84515165      0.13437970    , d:   0.0000000     -0.47930927       2.0005529
 i,j,k,ie:    1    6    2          33
 Near X =  0.47930973     -0.83001276       0.0000000    , d:   0.0000000     -0.79549358       2.0005529
 i,j,k,ie:    2    6    2          33
 Near X =  0.47930973     -0.83001276      0.15785898E-01, d:   0.0000000     -0.79549358       2.0005529
 i,j,k,ie:    3    6    2          33
 Near X =  0.47930973     -0.83001276      0.48025188E-01, d:   0.0000000     -0.79549358       2.0005529
 i,j,k,ie:    4    6    2          33
 Near X =  0.47930973     -0.83001276      0.86354515E-01, d:   0.0000000     -0.79549358       2.0005529
 i,j,k,ie:    5    6    2          33
 Near X =  0.47930973     -0.83001276      0.11859381    , d:   0.0000000     -0.79549358       2.0005529
 i,j,k,ie:    6    6    2          33
 Near X =  0.47930973     -0.83001276      0.13437970    , d:   0.0000000      -1.0266769       2.0005529
 i,j,k,ie:    1    1    3          33
 Near X = -0.10324672E-06 -0.87491551       0.0000000    , d:  0.43733264       0.0000000       2.0005529
 i,j,k,ie:    2    1    3          33
 Near X = -0.10324672E-06 -0.87491551      0.15785898E-01, d:  0.43733264       0.0000000       2.0005529
 i,j,k,ie:    3    1    3          33
 Near X = -0.10324672E-06 -0.87491551      0.48025188E-01, d:  0.43733264       0.0000000       2.0005529
 i,j,k,ie:    4    1    3          33
 Near X = -0.10324672E-06 -0.87491551      0.86354515E-01, d:  0.43733264       0.0000000       2.0005529
 i,j,k,ie:    5    1    3          33
 Near X = -0.10324672E-06 -0.87491551      0.11859381    , d:  0.43733264       0.0000000       2.0005529
 i,j,k,ie:    6    1    3          33
 Near X = -0.10324672E-06 -0.87491551      0.13437970    , d:  0.75732897     -0.43733245       2.0005529
 i,j,k,ie:    6    2    3          33
 Near X =  0.51374880E-01 -0.86110233      0.13437970    , d:   0.0000000     -0.43733297       2.0005529
 i,j,k,ie:    6    3    3          33
 Near X =  0.15629720     -0.83289189      0.13437970    , d:   0.0000000     -0.43733403       2.0005529
 i,j,k,ie:    6    4    3          33
 Near X =  0.28103945     -0.79935247      0.13437970    , d:   0.0000000     -0.43733528       2.0005529
 i,j,k,ie:    6    5    3          33
 Near X =  0.38596177     -0.77114204      0.13437970    , d:   0.0000000     -0.43733634       2.0005529
 i,j,k,ie:    1    6    3          33
 Near X =  0.43733675     -0.75732886       0.0000000    , d:   0.0000000     -0.73570553       2.0005529
 i,j,k,ie:    2    6    3          33
 Near X =  0.43733675     -0.75732886      0.15785898E-01, d:   0.0000000     -0.73570553       2.0005529
 i,j,k,ie:    3    6    3          33
 Near X =  0.43733675     -0.75732886      0.48025188E-01, d:   0.0000000     -0.73570553       2.0005529
 i,j,k,ie:    4    6    3          33
 Near X =  0.43733675     -0.75732886      0.86354515E-01, d:   0.0000000     -0.73570553       2.0005529
 i,j,k,ie:    5    6    3          33
 Near X =  0.43733675     -0.75732886      0.11859381    , d:   0.0000000     -0.73570553       2.0005529
 i,j,k,ie:    6    6    3          33
 Near X =  0.43733675     -0.75732886      0.13437970    , d:   0.0000000     -0.95350960       2.0005529
 i,j,k,ie:    1    1    4          33
 Near X = -0.91465890E-07 -0.77508447       0.0000000    , d:  0.38743139       0.0000000       2.0005529
 i,j,k,ie:    2    1    4          33
 Near X = -0.91465890E-07 -0.77508447      0.15785898E-01, d:  0.38743139       0.0000000       2.0005529
 i,j,k,ie:    3    1    4          33
 Near X = -0.91465890E-07 -0.77508447      0.48025188E-01, d:  0.38743139       0.0000000       2.0005529
 i,j,k,ie:    4    1    4          33
 Near X = -0.91465890E-07 -0.77508447      0.86354515E-01, d:  0.38743139       0.0000000       2.0005529
 i,j,k,ie:    5    1    4          33
 Near X = -0.91465890E-07 -0.77508447      0.11859381    , d:  0.38743139       0.0000000       2.0005529
 i,j,k,ie:    6    1    4          33
 Near X = -0.91465890E-07 -0.77508447      0.13437970    , d:  0.67091498     -0.38743123       2.0005529
 i,j,k,ie:    6    2    4          33
 Near X =  0.45512819E-01 -0.76284743      0.13437970    , d:   0.0000000     -0.38743169       2.0005529
 i,j,k,ie:    6    3    4          33
 Near X =  0.13846312     -0.73785590      0.13437970    , d:   0.0000000     -0.38743262       2.0005529
 i,j,k,ie:    6    4    4          33
 Near X =  0.24897183     -0.70814345      0.13437970    , d:   0.0000000     -0.38743374       2.0005529
 i,j,k,ie:    6    5    4          33
 Near X =  0.34192213     -0.68315193      0.13437970    , d:   0.0000000     -0.38743467       2.0005529
 i,j,k,ie:    1    6    4          33
 Near X =  0.38743504     -0.67091488       0.0000000    , d:   0.0000000     -0.66462344       2.0005529
 i,j,k,ie:    2    6    4          33
 Near X =  0.38743504     -0.67091488      0.15785898E-01, d:   0.0000000     -0.66462344       2.0005529
 i,j,k,ie:    3    6    4          33
 Near X =  0.38743504     -0.67091488      0.48025188E-01, d:   0.0000000     -0.66462344       2.0005529
 i,j,k,ie:    4    6    4          33
 Near X =  0.38743504     -0.67091488      0.86354515E-01, d:   0.0000000     -0.66462344       2.0005529
 i,j,k,ie:    5    6    4          33
 Near X =  0.38743504     -0.67091488      0.11859381    , d:   0.0000000     -0.66462344       2.0005529
 i,j,k,ie:    6    6    4          33
 Near X =  0.38743504     -0.67091488      0.13437970    , d:   0.0000000     -0.86652089       2.0005529
 i,j,k,ie:    1    1    5          33
 Near X = -0.81556886E-07 -0.69111530       0.0000000    , d:  0.34545881       0.0000000       2.0005529
 i,j,k,ie:    2    1    5          33
 Near X = -0.81556886E-07 -0.69111530      0.15785898E-01, d:  0.34545881       0.0000000       2.0005529
 i,j,k,ie:    3    1    5          33
 Near X = -0.81556886E-07 -0.69111530      0.48025188E-01, d:  0.34545881       0.0000000       2.0005529
 i,j,k,ie:    4    1    5          33
 Near X = -0.81556886E-07 -0.69111530      0.86354515E-01, d:  0.34545881       0.0000000       2.0005529
 i,j,k,ie:    5    1    5          33
 Near X = -0.81556886E-07 -0.69111530      0.11859381    , d:  0.34545881       0.0000000       2.0005529
 i,j,k,ie:    6    1    5          33
 Near X = -0.81556886E-07 -0.69111530      0.13437970    , d:  0.59823106     -0.34545867       2.0005529
 i,j,k,ie:    6    2    5          33
 Near X =  0.40582165E-01 -0.68020396      0.13437970    , d:   0.0000000     -0.34545908       2.0005529
 i,j,k,ie:    6    3    5          33
 Near X =  0.12346265     -0.65791991      0.13437970    , d:   0.0000000     -0.34545991       2.0005529
 i,j,k,ie:    6    4    5          33
 Near X =  0.22199934     -0.63142637      0.13437970    , d:   0.0000000     -0.34546090       2.0005529
 i,j,k,ie:    6    5    5          33
 Near X =  0.30487982     -0.60914231      0.13437970    , d:   0.0000000     -0.34546174       2.0005529
 i,j,k,ie:    1    6    5          33
 Near X =  0.34546207     -0.59823098       0.0000000    , d:   0.0000000     -0.60483539       2.0005529
 i,j,k,ie:    2    6    5          33
 Near X =  0.34546207     -0.59823098      0.15785898E-01, d:   0.0000000     -0.60483539       2.0005529
 i,j,k,ie:    3    6    5          33
 Near X =  0.34546207     -0.59823098      0.48025188E-01, d:   0.0000000     -0.60483539       2.0005529
 i,j,k,ie:    4    6    5          33
 Near X =  0.34546207     -0.59823098      0.86354515E-01, d:   0.0000000     -0.60483539       2.0005529
 i,j,k,ie:    5    6    5          33
 Near X =  0.34546207     -0.59823098      0.11859381    , d:   0.0000000     -0.60483539       2.0005529
 i,j,k,ie:    6    6    5          33
 Near X =  0.34546207     -0.59823098      0.13437970    , d:   0.0000000     -0.79335356       2.0005529
 i,j,k,ie:    1    1    6          33
 Near X = -0.76704964E-07 -0.64999998       0.0000000    , d:  0.49985695     -0.41302678E-07   2.0005529
 i,j,k,ie:    2    1    6          33
 Near X = -0.76704964E-07 -0.64999998      0.15785898E-01, d:  0.49985695     -0.41302678E-07   2.0005529
 i,j,k,ie:    3    1    6          33
 Near X = -0.76704964E-07 -0.64999998      0.48025188E-01, d:  0.49985695     -0.41302678E-07   2.0005529
 i,j,k,ie:    4    1    6          33
 Near X = -0.76704964E-07 -0.64999998      0.86354515E-01, d:  0.49985695     -0.41302678E-07   2.0005529
 i,j,k,ie:    5    1    6          33
 Near X = -0.76704964E-07 -0.64999998      0.11859381    , d:  0.49985695     -0.41302678E-07   2.0005529
 i,j,k,ie:    6    1    6          33
 Near X = -0.76704964E-07 -0.64999998      0.13437970    , d:  0.86560236     -0.49985683       2.0005529
 i,j,k,ie:    1    2    6          33
 Near X =  0.38167880E-01 -0.63973777       0.0000000    , d:  0.20551938E-01   0.0000000       2.0005529
 i,j,k,ie:    2    2    6          33
 Near X =  0.38167880E-01 -0.63973777      0.15785898E-01, d:  0.20551938E-01   0.0000000       2.0005529
 i,j,k,ie:    3    2    6          33
 Near X =  0.38167880E-01 -0.63973777      0.48025188E-01, d:  0.20551938E-01   0.0000000       2.0005529
 i,j,k,ie:    4    2    6          33
 Near X =  0.38167880E-01 -0.63973777      0.86354515E-01, d:  0.20551938E-01   0.0000000       2.0005529
 i,j,k,ie:    5    2    6          33
 Near X =  0.38167880E-01 -0.63973777      0.11859381    , d:  0.20551938E-01   0.0000000       2.0005529
 i,j,k,ie:    6    2    6          33
 Near X =  0.38167880E-01 -0.63973777      0.13437970    , d:  0.20551938E-01 -0.47930544       2.0005529
 i,j,k,ie:    1    3    6          33
 Near X =  0.11611770     -0.61877942       0.0000000    , d:  0.62524921E-01   0.0000000       2.0005529
 i,j,k,ie:    2    3    6          33
 Near X =  0.11611770     -0.61877942      0.15785898E-01, d:  0.62524921E-01   0.0000000       2.0005529
 i,j,k,ie:    3    3    6          33
 Near X =  0.11611770     -0.61877942      0.48025188E-01, d:  0.62524921E-01   0.0000000       2.0005529
 i,j,k,ie:    4    3    6          33
 Near X =  0.11611770     -0.61877942      0.86354515E-01, d:  0.62524921E-01   0.0000000       2.0005529
 i,j,k,ie:    5    3    6          33
 Near X =  0.11611770     -0.61877942      0.11859381    , d:  0.62524921E-01   0.0000000       2.0005529
 i,j,k,ie:    6    3    6          33
 Near X =  0.11611770     -0.61877942      0.13437970    , d:  0.62524921E-01 -0.43733366       2.0005529
 i,j,k,ie:    1    4    6          33
 Near X =  0.20879232     -0.59386202       0.0000000    , d:  0.11242665       0.0000000       2.0005529
 i,j,k,ie:    2    4    6          33
 Near X =  0.20879232     -0.59386202      0.15785898E-01, d:  0.11242665       0.0000000       2.0005529
 i,j,k,ie:    3    4    6          33
 Near X =  0.20879232     -0.59386202      0.48025188E-01, d:  0.11242665       0.0000000       2.0005529
 i,j,k,ie:    4    4    6          33
 Near X =  0.20879232     -0.59386202      0.86354515E-01, d:  0.11242665       0.0000000       2.0005529
 i,j,k,ie:    5    4    6          33
 Near X =  0.20879232     -0.59386202      0.11859381    , d:  0.11242665       0.0000000       2.0005529
 i,j,k,ie:    6    4    6          33
 Near X =  0.20879232     -0.59386202      0.13437970    , d:  0.11242665     -0.38743337       2.0005529
 i,j,k,ie:    1    5    6          33
 Near X =  0.28674213     -0.57290367       0.0000000    , d:  0.15439963       0.0000000       2.0005529
 i,j,k,ie:    2    5    6          33
 Near X =  0.28674213     -0.57290367      0.15785898E-01, d:  0.15439963       0.0000000       2.0005529
 i,j,k,ie:    3    5    6          33
 Near X =  0.28674213     -0.57290367      0.48025188E-01, d:  0.15439963       0.0000000       2.0005529
 i,j,k,ie:    4    5    6          33
 Near X =  0.28674213     -0.57290367      0.86354515E-01, d:  0.15439963       0.0000000       2.0005529
 i,j,k,ie:    5    5    6          33
 Near X =  0.28674213     -0.57290367      0.11859381    , d:  0.15439963       0.0000000       2.0005529
 i,j,k,ie:    6    5    6          33
 Near X =  0.28674213     -0.57290367      0.13437970    , d:  0.15439963     -0.34546160       2.0005529
 i,j,k,ie:    1    6    6          33
 Near X =  0.32491009     -0.56264146       0.0000000    , d:  0.17495161     -0.64981707       2.0005529
 i,j,k,ie:    2    6    6          33
 Near X =  0.32491009     -0.56264146      0.15785898E-01, d:  0.17495161     -0.64981707       2.0005529
 i,j,k,ie:    3    6    6          33
 Near X =  0.32491009     -0.56264146      0.48025188E-01, d:  0.17495161     -0.64981707       2.0005529
 i,j,k,ie:    4    6    6          33
 Near X =  0.32491009     -0.56264146      0.86354515E-01, d:  0.17495161     -0.64981707       2.0005529
 i,j,k,ie:    5    6    6          33
 Near X =  0.32491009     -0.56264146      0.11859381    , d:  0.17495161     -0.64981707       2.0005529
 i,j,k,ie:    6    6    6          33
 Near X =  0.32491009     -0.56264146      0.13437970    , d:  0.17495161     -0.88755154       2.0005529
 i,j,k,ie:    1    1    1          34
 Near X = -0.49985690     -0.86558375       0.0000000    , d:   1.3654592       0.0000000       2.0005725
 i,j,k,ie:    2    1    1          34
 Near X = -0.49985690     -0.86558375      0.15785898E-01, d:   1.3654592       0.0000000       2.0005725
 i,j,k,ie:    3    1    1          34
 Near X = -0.49985690     -0.86558375      0.48025188E-01, d:   1.3654592       0.0000000       2.0005725
 i,j,k,ie:    4    1    1          34
 Near X = -0.49985690     -0.86558375      0.86354515E-01, d:   1.3654592       0.0000000       2.0005725
 i,j,k,ie:    5    1    1          34
 Near X = -0.49985690     -0.86558375      0.11859381    , d:   1.3654592       0.0000000       2.0005725
 i,j,k,ie:    6    1    1          34
 Near X = -0.49985690     -0.86558375      0.13437970    , d:   1.4998569     -0.36574537       2.0005725
 i,j,k,ie:    1    2    1          34
 Near X = -0.44113756     -0.88137394       0.0000000    , d:  0.49985738       0.0000000       2.0005725
 i,j,k,ie:    6    2    1          34
 Near X = -0.44113756     -0.88137394      0.13437970    , d:   0.0000000     -0.38149975       2.0005725
 i,j,k,ie:    1    3    1          34
 Near X = -0.32121597     -0.91362200       0.0000000    , d:  0.49985858       0.0000000       2.0005725
 i,j,k,ie:    6    3    1          34
 Near X = -0.32121597     -0.91362200      0.13437970    , d:   0.0000000     -0.41367468       2.0005725
 i,j,k,ie:    1    4    1          34
 Near X = -0.17864106     -0.95196176       0.0000000    , d:  0.49986002       0.0000000       2.0005725
 i,j,k,ie:    6    4    1          34
 Near X = -0.17864106     -0.95196176      0.13437970    , d:   0.0000000     -0.45192748       2.0005725
 i,j,k,ie:    1    5    1          34
 Near X = -0.58719463E-01 -0.98420982       0.0000000    , d:  0.49986123       0.0000000       2.0005725
 i,j,k,ie:    6    5    1          34
 Near X = -0.58719463E-01 -0.98420982      0.13437970    , d:   0.0000000     -0.48410240       2.0005725
 i,j,k,ie:    1    6    1          34
 Near X = -0.11800764E-06  -1.0000000       0.0000000    , d:  0.49986182     -0.56264133       2.0005725
 i,j,k,ie:    2    6    1          34
 Near X = -0.11800764E-06  -1.0000000      0.15785898E-01, d:   0.0000000     -0.56264133       2.0005725
 i,j,k,ie:    3    6    1          34
 Near X = -0.11800764E-06  -1.0000000      0.48025188E-01, d:   0.0000000     -0.56264133       2.0005725
 i,j,k,ie:    4    6    1          34
 Near X = -0.11800764E-06  -1.0000000      0.86354515E-01, d:   0.0000000     -0.56264133       2.0005725
 i,j,k,ie:    5    6    1          34
 Near X = -0.11800764E-06  -1.0000000      0.11859381    , d:   0.0000000     -0.56264133       2.0005725
 i,j,k,ie:    6    6    1          34
 Near X = -0.11800764E-06  -1.0000000      0.13437970    , d:   0.0000000     -0.64999986       2.0005725
 i,j,k,ie:    1    1    2          34
 Near X = -0.47930513     -0.82999500       0.0000000    , d:   1.3093179       0.0000000       2.0005725
 i,j,k,ie:    2    1    2          34
 Near X = -0.47930513     -0.82999500      0.15785898E-01, d:   1.3093179       0.0000000       2.0005725
 i,j,k,ie:    3    1    2          34
 Near X = -0.47930513     -0.82999500      0.48025188E-01, d:   1.3093179       0.0000000       2.0005725
 i,j,k,ie:    4    1    2          34
 Near X = -0.47930513     -0.82999500      0.86354515E-01, d:   1.3093179       0.0000000       2.0005725
 i,j,k,ie:    5    1    2          34
 Near X = -0.47930513     -0.82999500      0.11859381    , d:   1.3093179       0.0000000       2.0005725
 i,j,k,ie:    6    1    2          34
 Near X = -0.47930513     -0.82999500      0.13437970    , d:   1.4381898     -0.35070763       2.0005725
 i,j,k,ie:    1    2    2          34
 Near X = -0.42300005     -0.84513597       0.0000000    , d:  0.47930558       0.0000000       2.0005725
 i,j,k,ie:    6    2    2          34
 Near X = -0.42300005     -0.84513597      0.13437970    , d:   0.0000000     -0.36581426       2.0005725
 i,j,k,ie:    1    3    2          34
 Near X = -0.30800907     -0.87605814       0.0000000    , d:  0.47930674       0.0000000       2.0005725
 i,j,k,ie:    6    3    2          34
 Near X = -0.30800907     -0.87605814      0.13437970    , d:   0.0000000     -0.39666631       2.0005725
 i,j,k,ie:    1    4    2          34
 Near X = -0.17129617     -0.91282154       0.0000000    , d:  0.47930811       0.0000000       2.0005725
 i,j,k,ie:    6    4    2          34
 Near X = -0.17129617     -0.91282154      0.13437970    , d:   0.0000000     -0.43334633       2.0005725
 i,j,k,ie:    1    5    2          34
 Near X = -0.56305194E-01 -0.94374371       0.0000000    , d:  0.47930927       0.0000000       2.0005725
 i,j,k,ie:    6    5    2          34
 Near X = -0.56305194E-01 -0.94374371      0.13437970    , d:   0.0000000     -0.46419838       2.0005725
 i,j,k,ie:    1    6    2          34
 Near X = -0.11315572E-06 -0.95888469       0.0000000    , d:  0.47930984     -0.54736709       2.0005725
 i,j,k,ie:    2    6    2          34
 Near X = -0.11315572E-06 -0.95888469      0.15785898E-01, d:   0.0000000     -0.54736709       2.0005725
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    3    6    2          34
 Near X = -0.11315572E-06 -0.95888469      0.48025188E-01, d:   0.0000000     -0.54736709       2.0005725
 i,j,k,ie:    4    6    2          34
 Near X = -0.11315572E-06 -0.95888469      0.86354515E-01, d:   0.0000000     -0.54736709       2.0005725
 i,j,k,ie:    5    6    2          34
 Near X = -0.11315572E-06 -0.95888469      0.11859381    , d:   0.0000000     -0.54736709       2.0005725
 i,j,k,ie:    6    6    2          34
 Near X = -0.11315572E-06 -0.95888469      0.13437970    , d:   0.0000000     -0.63237902       2.0005725
 i,j,k,ie:    1    1    3          34
 Near X = -0.43733256     -0.75731265       0.0000000    , d:   1.1946614       0.0000000       2.0005725
 i,j,k,ie:    2    1    3          34
 Near X = -0.43733256     -0.75731265      0.15785898E-01, d:   1.1946614       0.0000000       2.0005725
 i,j,k,ie:    3    1    3          34
 Near X = -0.43733256     -0.75731265      0.48025188E-01, d:   1.1946614       0.0000000       2.0005725
 i,j,k,ie:    4    1    3          34
 Near X = -0.43733256     -0.75731265      0.86354515E-01, d:   1.1946614       0.0000000       2.0005725
 i,j,k,ie:    5    1    3          34
 Near X = -0.43733256     -0.75731265      0.11859381    , d:   1.1946614       0.0000000       2.0005725
 i,j,k,ie:    6    1    3          34
 Near X = -0.43733256     -0.75731265      0.13437970    , d:   1.3122481     -0.31999629       2.0005725
 i,j,k,ie:    1    2    3          34
 Near X = -0.38595809     -0.77112773       0.0000000    , d:  0.43733297       0.0000000       2.0005725
 i,j,k,ie:    6    2    3          34
 Near X = -0.38595809     -0.77112773      0.13437970    , d:   0.0000000     -0.33378005       2.0005725
 i,j,k,ie:    1    3    3          34
 Near X = -0.28103683     -0.79934206       0.0000000    , d:  0.43733403       0.0000000       2.0005725
 i,j,k,ie:    6    3    3          34
 Near X = -0.28103683     -0.79934206      0.13437970    , d:   0.0000000     -0.36193039       2.0005725
 i,j,k,ie:    1    4    3          34
 Near X = -0.15629583     -0.83288610       0.0000000    , d:  0.43733528       0.0000000       2.0005725
 i,j,k,ie:    6    4    3          34
 Near X = -0.15629583     -0.83288610      0.13437970    , d:   0.0000000     -0.39539836       2.0005725
 i,j,k,ie:    1    5    3          34
 Near X = -0.51374569E-01 -0.86110043       0.0000000    , d:  0.43733634       0.0000000       2.0005725
 i,j,k,ie:    6    5    3          34
 Near X = -0.51374569E-01 -0.86110043      0.13437970    , d:   0.0000000     -0.42354870       2.0005725
 i,j,k,ie:    1    6    3          34
 Near X = -0.10324672E-06 -0.87491551       0.0000000    , d:  0.43733686     -0.51617275       2.0005725
 i,j,k,ie:    2    6    3          34
 Near X = -0.10324672E-06 -0.87491551      0.15785898E-01, d:   0.0000000     -0.51617275       2.0005725
 i,j,k,ie:    3    6    3          34
 Near X = -0.10324672E-06 -0.87491551      0.48025188E-01, d:   0.0000000     -0.51617275       2.0005725
 i,j,k,ie:    4    6    3          34
 Near X = -0.10324672E-06 -0.87491551      0.86354515E-01, d:   0.0000000     -0.51617275       2.0005725
 i,j,k,ie:    5    6    3          34
 Near X = -0.10324672E-06 -0.87491551      0.11859381    , d:   0.0000000     -0.51617275       2.0005725
 i,j,k,ie:    6    6    3          34
 Near X = -0.10324672E-06 -0.87491551      0.13437970    , d:   0.0000000     -0.59639225       2.0005725
 i,j,k,ie:    1    1    4          34
 Near X = -0.38743132     -0.67090052       0.0000000    , d:   1.0583462       0.0000000       2.0005725
 i,j,k,ie:    2    1    4          34
 Near X = -0.38743132     -0.67090052      0.15785898E-01, d:   1.0583462       0.0000000       2.0005725
 i,j,k,ie:    3    1    4          34
 Near X = -0.38743132     -0.67090052      0.48025188E-01, d:   1.0583462       0.0000000       2.0005725
 i,j,k,ie:    4    1    4          34
 Near X = -0.38743132     -0.67090052      0.86354515E-01, d:   1.0583462       0.0000000       2.0005725
 i,j,k,ie:    5    1    4          34
 Near X = -0.38743132     -0.67090052      0.11859381    , d:   1.0583462       0.0000000       2.0005725
 i,j,k,ie:    6    1    4          34
 Near X = -0.38743132     -0.67090052      0.13437970    , d:   1.1625158     -0.28348355       2.0005725
 i,j,k,ie:    1    2    4          34
 Near X = -0.34191887     -0.68313925       0.0000000    , d:  0.38743169       0.0000000       2.0005725
 i,j,k,ie:    6    2    4          34
 Near X = -0.34191887     -0.68313925      0.13437970    , d:   0.0000000     -0.29569453       2.0005725
 i,j,k,ie:    1    3    4          34
 Near X = -0.24896951     -0.70813422       0.0000000    , d:  0.38743262       0.0000000       2.0005725
 i,j,k,ie:    6    3    4          34
 Near X = -0.24896951     -0.70813422      0.13437970    , d:   0.0000000     -0.32063282       2.0005725
 i,j,k,ie:    1    4    4          34
 Near X = -0.13846191     -0.73785077       0.0000000    , d:  0.38743374       0.0000000       2.0005725
 i,j,k,ie:    6    4    4          34
 Near X = -0.13846191     -0.73785077      0.13437970    , d:   0.0000000     -0.35028197       2.0005725
 i,j,k,ie:    1    5    4          34
 Near X = -0.45512544E-01 -0.76284574       0.0000000    , d:  0.38743467       0.0000000       2.0005725
 i,j,k,ie:    6    5    4          34
 Near X = -0.45512544E-01 -0.76284574      0.13437970    , d:   0.0000000     -0.37522025       2.0005725
 i,j,k,ie:    1    6    4          34
 Near X = -0.91465890E-07 -0.77508447       0.0000000    , d:  0.38743513     -0.47908576       2.0005725
 i,j,k,ie:    2    6    4          34
 Near X = -0.91465890E-07 -0.77508447      0.15785898E-01, d:   0.0000000     -0.47908576       2.0005725
 i,j,k,ie:    3    6    4          34
 Near X = -0.91465890E-07 -0.77508447      0.48025188E-01, d:   0.0000000     -0.47908576       2.0005725
 i,j,k,ie:    4    6    4          34
 Near X = -0.91465890E-07 -0.77508447      0.86354515E-01, d:   0.0000000     -0.47908576       2.0005725
 i,j,k,ie:    5    6    4          34
 Near X = -0.91465890E-07 -0.77508447      0.11859381    , d:   0.0000000     -0.47908576       2.0005725
 i,j,k,ie:    6    6    4          34
 Near X = -0.91465890E-07 -0.77508447      0.13437970    , d:   0.0000000     -0.55360754       2.0005725
 i,j,k,ie:    1    1    5          34
 Near X = -0.34545875     -0.59821817       0.0000000    , d:  0.94368973       0.0000000       2.0005725
 i,j,k,ie:    2    1    5          34
 Near X = -0.34545875     -0.59821817      0.15785898E-01, d:  0.94368973       0.0000000       2.0005725
 i,j,k,ie:    3    1    5          34
 Near X = -0.34545875     -0.59821817      0.48025188E-01, d:  0.94368973       0.0000000       2.0005725
 i,j,k,ie:    4    1    5          34
 Near X = -0.34545875     -0.59821817      0.86354515E-01, d:  0.94368973       0.0000000       2.0005725
 i,j,k,ie:    5    1    5          34
 Near X = -0.34545875     -0.59821817      0.11859381    , d:  0.94368973       0.0000000       2.0005725
 i,j,k,ie:    6    1    5          34
 Near X = -0.34545875     -0.59821817      0.13437970    , d:   1.0365741     -0.25277222       2.0005725
 i,j,k,ie:    1    2    5          34
 Near X = -0.30487691     -0.60913101       0.0000000    , d:  0.34545908       0.0000000       2.0005725
 i,j,k,ie:    6    2    5          34
 Near X = -0.30487691     -0.60913101      0.13437970    , d:   0.0000000     -0.26366031       2.0005725
 i,j,k,ie:    1    3    5          34
 Near X = -0.22199727     -0.63141814       0.0000000    , d:  0.34545991       0.0000000       2.0005725
 i,j,k,ie:    6    3    5          34
 Near X = -0.22199727     -0.63141814      0.13437970    , d:   0.0000000     -0.28589689       2.0005725
 i,j,k,ie:    1    4    5          34
 Near X = -0.12346157     -0.65791533       0.0000000    , d:  0.34546090       0.0000000       2.0005725
 i,j,k,ie:    6    4    5          34
 Near X = -0.12346157     -0.65791533      0.13437970    , d:   0.0000000     -0.31233399       2.0005725
 i,j,k,ie:    1    5    5          34
 Near X = -0.40581919E-01 -0.68020246       0.0000000    , d:  0.34546174       0.0000000       2.0005725
 i,j,k,ie:    6    5    5          34
 Near X = -0.40581919E-01 -0.68020246      0.13437970    , d:   0.0000000     -0.33457058       2.0005725
 i,j,k,ie:    1    6    5          34
 Near X = -0.81556886E-07 -0.69111530       0.0000000    , d:  0.34546215     -0.44789142       2.0005725
 i,j,k,ie:    2    6    5          34
 Near X = -0.81556886E-07 -0.69111530      0.15785898E-01, d:   0.0000000     -0.44789142       2.0005725
 i,j,k,ie:    3    6    5          34
 Near X = -0.81556886E-07 -0.69111530      0.48025188E-01, d:   0.0000000     -0.44789142       2.0005725
 i,j,k,ie:    4    6    5          34
 Near X = -0.81556886E-07 -0.69111530      0.86354515E-01, d:   0.0000000     -0.44789142       2.0005725
 i,j,k,ie:    5    6    5          34
 Near X = -0.81556886E-07 -0.69111530      0.11859381    , d:   0.0000000     -0.44789142       2.0005725
 i,j,k,ie:    6    6    5          34
 Near X = -0.81556886E-07 -0.69111530      0.13437970    , d:   0.0000000     -0.51762077       2.0005725
 i,j,k,ie:    1    1    6          34
 Near X = -0.32490697     -0.56262942       0.0000000    , d:   1.1905093     -0.17494993       2.0005725
 i,j,k,ie:    2    1    6          34
 Near X = -0.32490697     -0.56262942      0.15785898E-01, d:   1.1905093     -0.17494993       2.0005725
 i,j,k,ie:    3    1    6          34
 Near X = -0.32490697     -0.56262942      0.48025188E-01, d:   1.1905093     -0.17494993       2.0005725
 i,j,k,ie:    4    1    6          34
 Near X = -0.32490697     -0.56262942      0.86354515E-01, d:   1.1905093     -0.17494993       2.0005725
 i,j,k,ie:    5    1    6          34
 Near X = -0.32490697     -0.56262942      0.11859381    , d:   1.1905093     -0.17494993       2.0005725
 i,j,k,ie:    6    1    6          34
 Near X = -0.32490697     -0.56262942      0.13437970    , d:   1.3249070     -0.54069530       2.0005725
 i,j,k,ie:    1    2    6          34
 Near X = -0.28673940     -0.57289304       0.0000000    , d:  0.34545922     -0.15439816       2.0005725
 i,j,k,ie:    2    2    6          34
 Near X = -0.28673940     -0.57289304      0.15785898E-01, d:   0.0000000     -0.15439816       2.0005725
 i,j,k,ie:    3    2    6          34
 Near X = -0.28673940     -0.57289304      0.48025188E-01, d:   0.0000000     -0.15439816       2.0005725
 i,j,k,ie:    4    2    6          34
 Near X = -0.28673940     -0.57289304      0.86354515E-01, d:   0.0000000     -0.15439816       2.0005725
 i,j,k,ie:    5    2    6          34
 Near X = -0.28673940     -0.57289304      0.11859381    , d:   0.0000000     -0.15439816       2.0005725
 i,j,k,ie:    6    2    6          34
 Near X = -0.28673940     -0.57289304      0.13437970    , d:   0.0000000     -0.53589791       2.0005725
 i,j,k,ie:    1    3    6          34
 Near X = -0.20879037     -0.59385428       0.0000000    , d:  0.38743299     -0.11242560       2.0005725
 i,j,k,ie:    2    3    6          34
 Near X = -0.20879037     -0.59385428      0.15785898E-01, d:   0.0000000     -0.11242560       2.0005725
 i,j,k,ie:    3    3    6          34
 Near X = -0.20879037     -0.59385428      0.48025188E-01, d:   0.0000000     -0.11242560       2.0005725
 i,j,k,ie:    4    3    6          34
 Near X = -0.20879037     -0.59385428      0.86354515E-01, d:   0.0000000     -0.11242560       2.0005725
 i,j,k,ie:    5    3    6          34
 Near X = -0.20879037     -0.59385428      0.11859381    , d:   0.0000000     -0.11242560       2.0005725
 i,j,k,ie:    6    3    6          34
 Near X = -0.20879037     -0.59385428      0.13437970    , d:   0.0000000     -0.52610027       2.0005725
 i,j,k,ie:    1    4    6          34
 Near X = -0.11611668     -0.61877512       0.0000000    , d:  0.43733565     -0.62524375E-01   2.0005725
 i,j,k,ie:    2    4    6          34
 Near X = -0.11611668     -0.61877512      0.15785898E-01, d:   0.0000000     -0.62524375E-01   2.0005725
 i,j,k,ie:    3    4    6          34
 Near X = -0.11611668     -0.61877512      0.48025188E-01, d:   0.0000000     -0.62524375E-01   2.0005725
 i,j,k,ie:    4    4    6          34
 Near X = -0.11611668     -0.61877512      0.86354515E-01, d:   0.0000000     -0.62524375E-01   2.0005725
 i,j,k,ie:    5    4    6          34
 Near X = -0.11611668     -0.61877512      0.11859381    , d:   0.0000000     -0.62524375E-01   2.0005725
 i,j,k,ie:    6    4    6          34
 Near X = -0.11611668     -0.61877512      0.13437970    , d:   0.0000000     -0.51445185       2.0005725
 i,j,k,ie:    1    5    6          34
 Near X = -0.38167650E-01 -0.63973635       0.0000000    , d:  0.47930941     -0.20551814E-01   2.0005725
 i,j,k,ie:    2    5    6          34
 Near X = -0.38167650E-01 -0.63973635      0.15785898E-01, d:   0.0000000     -0.20551814E-01   2.0005725
 i,j,k,ie:    3    5    6          34
 Near X = -0.38167650E-01 -0.63973635      0.48025188E-01, d:   0.0000000     -0.20551814E-01   2.0005725
 i,j,k,ie:    4    5    6          34
 Near X = -0.38167650E-01 -0.63973635      0.86354515E-01, d:   0.0000000     -0.20551814E-01   2.0005725
 i,j,k,ie:    5    5    6          34
 Near X = -0.38167650E-01 -0.63973635      0.11859381    , d:   0.0000000     -0.20551814E-01   2.0005725
 i,j,k,ie:    6    5    6          34
 Near X = -0.38167650E-01 -0.63973635      0.13437970    , d:   0.0000000     -0.50465422       2.0005725
 i,j,k,ie:    1    6    6          34
 Near X = -0.76704964E-07 -0.64999998       0.0000000    , d:  0.49986178     -0.56264138       2.0005725
 i,j,k,ie:    2    6    6          34
 Near X = -0.76704964E-07 -0.64999998      0.15785898E-01, d:   0.0000000     -0.56264138       2.0005725
 i,j,k,ie:    3    6    6          34
 Near X = -0.76704964E-07 -0.64999998      0.48025188E-01, d:   0.0000000     -0.56264138       2.0005725
 i,j,k,ie:    4    6    6          34
 Near X = -0.76704964E-07 -0.64999998      0.86354515E-01, d:   0.0000000     -0.56264138       2.0005725
 i,j,k,ie:    5    6    6          34
 Near X = -0.76704964E-07 -0.64999998      0.11859381    , d:   0.0000000     -0.56264138       2.0005725
 i,j,k,ie:    6    6    6          34
 Near X = -0.76704964E-07 -0.64999998      0.13437970    , d:   0.0000000     -0.64999990       2.0005725
 i,j,k,ie:    1    1    1          35
 Near X = -0.86560227     -0.49986176       0.0000000    , d:   1.8656023       0.0000000       1.1552650
 i,j,k,ie:    2    1    1          35
 Near X = -0.86560227     -0.49986176      0.15785898E-01, d:   1.8656023       0.0000000       1.1552650
 i,j,k,ie:    3    1    1          35
 Near X = -0.86560227     -0.49986176      0.48025188E-01, d:   1.8656023       0.0000000       1.1552650
 i,j,k,ie:    4    1    1          35
 Near X = -0.86560227     -0.49986176      0.86354515E-01, d:   1.8656023       0.0000000       1.1552650
 i,j,k,ie:    5    1    1          35
 Near X = -0.86560227     -0.49986176      0.11859381    , d:   1.8656023       0.0000000       1.1552650
 i,j,k,ie:    6    1    1          35
 Near X = -0.86560227     -0.49986176      0.13437970    , d:   1.8656023     -0.13439774       1.1552650
 i,j,k,ie:    1    2    1          35
 Near X = -0.82263731     -0.54282398       0.0000000    , d:  0.38149975       0.0000000       1.1552650
 i,j,k,ie:    6    2    1          35
 Near X = -0.82263731     -0.54282398      0.13437970    , d:   0.0000000     -0.16157469       1.1552650
 i,j,k,ie:    1    3    1          35
 Near X = -0.73489064     -0.63056504       0.0000000    , d:  0.41367468       0.0000000       1.1552650
 i,j,k,ie:    6    3    1          35
 Near X = -0.73489064     -0.63056504      0.13437970    , d:   0.0000000     -0.21707774       1.1552650
 i,j,k,ie:    1    4    1          35
 Near X = -0.63056853     -0.73488048       0.0000000    , d:  0.45192748       0.0000000       1.1552650
 i,j,k,ie:    6    4    1          35
 Near X = -0.63056853     -0.73488048      0.13437970    , d:   0.0000000     -0.28306537       1.1552650
 i,j,k,ie:    1    5    1          35
 Near X = -0.54282187     -0.82262154       0.0000000    , d:  0.48410240       0.0000000       1.1552650
 i,j,k,ie:    6    5    1          35
 Near X = -0.54282187     -0.82262154      0.13437970    , d:   0.0000000     -0.33856842       1.1552650
 i,j,k,ie:    1    6    1          35
 Near X = -0.49985690     -0.86558375       0.0000000    , d:  0.49985679     -0.15014308       1.1552650
 i,j,k,ie:    2    6    1          35
 Near X = -0.49985690     -0.86558375      0.15785898E-01, d:   0.0000000     -0.15014308       1.1552650
 i,j,k,ie:    3    6    1          35
 Near X = -0.49985690     -0.86558375      0.48025188E-01, d:   0.0000000     -0.15014308       1.1552650
 i,j,k,ie:    4    6    1          35
 Near X = -0.49985690     -0.86558375      0.86354515E-01, d:   0.0000000     -0.15014308       1.1552650
 i,j,k,ie:    5    6    1          35
 Near X = -0.49985690     -0.86558375      0.11859381    , d:   0.0000000     -0.15014308       1.1552650
 i,j,k,ie:    6    6    1          35
 Near X = -0.49985690     -0.86558375      0.13437970    , d:   1.0624863     -0.36574537       1.1552650
 i,j,k,ie:    1    1    2          35
 Near X = -0.83001276     -0.47930979       0.0000000    , d:   1.7888974       0.0000000       1.1552650
 i,j,k,ie:    2    1    2          35
 Near X = -0.83001276     -0.47930979      0.15785898E-01, d:   1.7888974       0.0000000       1.1552650
 i,j,k,ie:    3    1    2          35
 Near X = -0.83001276     -0.47930979      0.48025188E-01, d:   1.7888974       0.0000000       1.1552650
 i,j,k,ie:    4    1    2          35
 Near X = -0.83001276     -0.47930979      0.86354515E-01, d:   1.7888974       0.0000000       1.1552650
 i,j,k,ie:    5    1    2          35
 Near X = -0.83001276     -0.47930979      0.11859381    , d:   1.7888974       0.0000000       1.1552650
 i,j,k,ie:    6    1    2          35
 Near X = -0.83001276     -0.47930979      0.13437970    , d:   1.7888974     -0.12887193       1.1552650
 i,j,k,ie:    1    2    2          35
 Near X = -0.78881431     -0.52050560       0.0000000    , d:  0.36581426       0.0000000       1.1552650
 i,j,k,ie:    6    2    2          35
 Near X = -0.78881431     -0.52050560      0.13437970    , d:   0.0000000     -0.15493149       1.1552650
 i,j,k,ie:    1    3    2          35
 Near X = -0.70467538     -0.60463916       0.0000000    , d:  0.39666631       0.0000000       1.1552650
 i,j,k,ie:    6    3    2          35
 Near X = -0.70467538     -0.60463916      0.13437970    , d:   0.0000000     -0.20815251       1.1552650
 i,j,k,ie:    1    4    2          35
 Near X = -0.60464251     -0.70466563       0.0000000    , d:  0.43334633       0.0000000       1.1552650
 i,j,k,ie:    6    4    2          35
 Near X = -0.60464251     -0.70466563      0.13437970    , d:   0.0000000     -0.27142705       1.1552650
 i,j,k,ie:    1    5    2          35
 Near X = -0.52050357     -0.78879919       0.0000000    , d:  0.46419838       0.0000000       1.1552650
 i,j,k,ie:    6    5    2          35
 Near X = -0.52050357     -0.78879919      0.13437970    , d:   0.0000000     -0.32464807       1.1552650
 i,j,k,ie:    1    6    2          35
 Near X = -0.47930513     -0.82999500       0.0000000    , d:  0.47930501     -0.15307400       1.1552650
 i,j,k,ie:    2    6    2          35
 Near X = -0.47930513     -0.82999500      0.15785898E-01, d:   0.0000000     -0.15307400       1.1552650
 i,j,k,ie:    3    6    2          35
 Near X = -0.47930513     -0.82999500      0.48025188E-01, d:   0.0000000     -0.15307400       1.1552650
 i,j,k,ie:    4    6    2          35
 Near X = -0.47930513     -0.82999500      0.86354515E-01, d:   0.0000000     -0.15307400       1.1552650
 i,j,k,ie:    5    6    2          35
 Near X = -0.47930513     -0.82999500      0.11859381    , d:   0.0000000     -0.15307400       1.1552650
 i,j,k,ie:    6    6    2          35
 Near X = -0.47930513     -0.82999500      0.13437970    , d:   1.0266594     -0.35070763       1.1552650
 i,j,k,ie:    1    1    3          35
 Near X = -0.75732885     -0.43733681       0.0000000    , d:   1.6322444       0.0000000       1.1552650
 i,j,k,ie:    2    1    3          35
 Near X = -0.75732885     -0.43733681      0.15785898E-01, d:   1.6322444       0.0000000       1.1552650
 i,j,k,ie:    3    1    3          35
 Near X = -0.75732885     -0.43733681      0.48025188E-01, d:   1.6322444       0.0000000       1.1552650
 i,j,k,ie:    4    1    3          35
 Near X = -0.75732885     -0.43733681      0.86354515E-01, d:   1.6322444       0.0000000       1.1552650
 i,j,k,ie:    5    1    3          35
 Near X = -0.75732885     -0.43733681      0.11859381    , d:   1.6322444       0.0000000       1.1552650
 i,j,k,ie:    6    1    3          35
 Near X = -0.75732885     -0.43733681      0.13437970    , d:   1.6322444     -0.11758667       1.1552650
 i,j,k,ie:    1    2    3          35
 Near X = -0.71973814     -0.47492512       0.0000000    , d:  0.33378005       0.0000000       1.1552650
 i,j,k,ie:    6    2    3          35
 Near X = -0.71973814     -0.47492512      0.13437970    , d:   0.0000000     -0.14136420       1.1552650
 i,j,k,ie:    1    3    3          35
 Near X = -0.64296722     -0.55169113       0.0000000    , d:  0.36193039       0.0000000       1.1552650
 i,j,k,ie:    6    3    3          35
 Near X = -0.64296722     -0.55169113      0.13437970    , d:   0.0000000     -0.18992468       1.1552650
 i,j,k,ie:    1    4    3          35
 Near X = -0.55169419     -0.64295832       0.0000000    , d:  0.39539836       0.0000000       1.1552650
 i,j,k,ie:    6    4    3          35
 Near X = -0.55169419     -0.64295832      0.13437970    , d:   0.0000000     -0.24765828       1.1552650
 i,j,k,ie:    1    5    3          35
 Near X = -0.47492327     -0.71972434       0.0000000    , d:  0.42354870       0.0000000       1.1552650
 i,j,k,ie:    6    5    3          35
 Near X = -0.47492327     -0.71972434      0.13437970    , d:   0.0000000     -0.29621876       1.1552650
 i,j,k,ie:    1    6    3          35
 Near X = -0.43733256     -0.75731265       0.0000000    , d:  0.43733245     -0.15905979       1.1552650
 i,j,k,ie:    2    6    3          35
 Near X = -0.43733256     -0.75731265      0.15785898E-01, d:   0.0000000     -0.15905979       1.1552650
 i,j,k,ie:    3    6    3          35
 Near X = -0.43733256     -0.75731265      0.48025188E-01, d:   0.0000000     -0.15905979       1.1552650
 i,j,k,ie:    4    6    3          35
 Near X = -0.43733256     -0.75731265      0.86354515E-01, d:   0.0000000     -0.15905979       1.1552650
 i,j,k,ie:    5    6    3          35
 Near X = -0.43733256     -0.75731265      0.11859381    , d:   0.0000000     -0.15905979       1.1552650
 i,j,k,ie:    6    6    3          35
 Near X = -0.43733256     -0.75731265      0.13437970    , d:  0.95349071     -0.31999629       1.1552650
 i,j,k,ie:    1    1    4          35
 Near X = -0.67091488     -0.38743509       0.0000000    , d:   1.4459993       0.0000000       1.1552650
 i,j,k,ie:    2    1    4          35
 Near X = -0.67091488     -0.38743509      0.15785898E-01, d:   1.4459993       0.0000000       1.1552650
 i,j,k,ie:    3    1    4          35
 Near X = -0.67091488     -0.38743509      0.48025188E-01, d:   1.4459993       0.0000000       1.1552650
 i,j,k,ie:    4    1    4          35
 Near X = -0.67091488     -0.38743509      0.86354515E-01, d:   1.4459993       0.0000000       1.1552650
 i,j,k,ie:    5    1    4          35
 Near X = -0.67091488     -0.38743509      0.11859381    , d:   1.4459993       0.0000000       1.1552650
 i,j,k,ie:    6    1    4          35
 Near X = -0.67091488     -0.38743509      0.13437970    , d:   1.4459993     -0.10416960       1.1552650
 i,j,k,ie:    1    2    4          35
 Near X = -0.63761340     -0.42073444       0.0000000    , d:  0.29569453       0.0000000       1.1552650
 i,j,k,ie:    6    2    4          35
 Near X = -0.63761340     -0.42073444      0.13437970    , d:   0.0000000     -0.12523403       1.1552650
 i,j,k,ie:    1    3    4          35
 Near X = -0.56960232     -0.48874117       0.0000000    , d:  0.32063282       0.0000000       1.1552650
 i,j,k,ie:    6    3    4          35
 Near X = -0.56960232     -0.48874117      0.13437970    , d:   0.0000000     -0.16825358       1.1552650
 i,j,k,ie:    1    4    4          35
 Near X = -0.48874388     -0.56959444       0.0000000    , d:  0.35028197       0.0000000       1.1552650
 i,j,k,ie:    6    4    4          35
 Near X = -0.48874388     -0.56959444      0.13437970    , d:   0.0000000     -0.21939957       1.1552650
 i,j,k,ie:    1    5    4          35
 Near X = -0.42073280     -0.63760117       0.0000000    , d:  0.37522025       0.0000000       1.1552650
 i,j,k,ie:    6    5    4          35
 Near X = -0.42073280     -0.63760117      0.13437970    , d:   0.0000000     -0.26241912       1.1552650
 i,j,k,ie:    1    6    4          35
 Near X = -0.38743132     -0.67090052       0.0000000    , d:  0.38743123     -0.16617631       1.1552650
 i,j,k,ie:    2    6    4          35
 Near X = -0.38743132     -0.67090052      0.15785898E-01, d:   0.0000000     -0.16617631       1.1552650
 i,j,k,ie:    3    6    4          35
 Near X = -0.38743132     -0.67090052      0.48025188E-01, d:   0.0000000     -0.16617631       1.1552650
 i,j,k,ie:    4    6    4          35
 Near X = -0.38743132     -0.67090052      0.86354515E-01, d:   0.0000000     -0.16617631       1.1552650
 i,j,k,ie:    5    6    4          35
 Near X = -0.38743132     -0.67090052      0.11859381    , d:   0.0000000     -0.16617631       1.1552650
 i,j,k,ie:    6    6    4          35
 Near X = -0.38743132     -0.67090052      0.13437970    , d:  0.86650036     -0.28348355       1.1552650
 i,j,k,ie:    1    1    5          35
 Near X = -0.59823097     -0.34546211       0.0000000    , d:   1.2893463       0.0000000       1.1552650
 i,j,k,ie:    2    1    5          35
 Near X = -0.59823097     -0.34546211      0.15785898E-01, d:   1.2893463       0.0000000       1.1552650
 i,j,k,ie:    3    1    5          35
 Near X = -0.59823097     -0.34546211      0.48025188E-01, d:   1.2893463       0.0000000       1.1552650
 i,j,k,ie:    4    1    5          35
 Near X = -0.59823097     -0.34546211      0.86354515E-01, d:   1.2893463       0.0000000       1.1552650
 i,j,k,ie:    5    1    5          35
 Near X = -0.59823097     -0.34546211      0.11859381    , d:   1.2893463       0.0000000       1.1552650
 i,j,k,ie:    6    1    5          35
 Near X = -0.59823097     -0.34546211      0.13437970    , d:   1.2893463     -0.92884332E-01   1.1552650
 i,j,k,ie:    1    2    5          35
 Near X = -0.56853723     -0.37515396       0.0000000    , d:  0.26366031       0.0000000       1.1552650
 i,j,k,ie:    6    2    5          35
 Near X = -0.56853723     -0.37515396      0.13437970    , d:   0.0000000     -0.11166674       1.1552650
 i,j,k,ie:    1    3    5          35
 Near X = -0.50789416     -0.43579314       0.0000000    , d:  0.28589689       0.0000000       1.1552650
 i,j,k,ie:    6    3    5          35
 Near X = -0.50789416     -0.43579314      0.13437970    , d:   0.0000000     -0.15002574       1.1552650
 i,j,k,ie:    1    4    5          35
 Near X = -0.43579556     -0.50788714       0.0000000    , d:  0.31233399       0.0000000       1.1552650
 i,j,k,ie:    6    4    5          35
 Near X = -0.43579556     -0.50788714      0.13437970    , d:   0.0000000     -0.19563081       1.1552650
 i,j,k,ie:    1    5    5          35
 Near X = -0.37515249     -0.56852632       0.0000000    , d:  0.33457058       0.0000000       1.1552650
 i,j,k,ie:    6    5    5          35
 Near X = -0.37515249     -0.56852632      0.13437970    , d:   0.0000000     -0.23398981       1.1552650
 i,j,k,ie:    1    6    5          35
 Near X = -0.34545875     -0.59821817       0.0000000    , d:  0.34545867     -0.17216210       1.1552650
 i,j,k,ie:    2    6    5          35
 Near X = -0.34545875     -0.59821817      0.15785898E-01, d:   0.0000000     -0.17216210       1.1552650
 i,j,k,ie:    3    6    5          35
 Near X = -0.34545875     -0.59821817      0.48025188E-01, d:   0.0000000     -0.17216210       1.1552650
 i,j,k,ie:    4    6    5          35
 Near X = -0.34545875     -0.59821817      0.86354515E-01, d:   0.0000000     -0.17216210       1.1552650
 i,j,k,ie:    5    6    5          35
 Near X = -0.34545875     -0.59821817      0.11859381    , d:   0.0000000     -0.17216210       1.1552650
 i,j,k,ie:    6    6    5          35
 Near X = -0.34545875     -0.59821817      0.13437970    , d:  0.79333165     -0.25277222       1.1552650
 i,j,k,ie:    1    1    6          35
 Near X = -0.56264145     -0.32491013       0.0000000    , d:   1.5626415     -0.30296082       1.1552650
 i,j,k,ie:    2    1    6          35
 Near X = -0.56264145     -0.32491013      0.15785898E-01, d:   1.5626415     -0.30296082       1.1552650
 i,j,k,ie:    3    1    6          35
 Near X = -0.56264145     -0.32491013      0.48025188E-01, d:   1.5626415     -0.30296082       1.1552650
 i,j,k,ie:    4    1    6          35
 Near X = -0.56264145     -0.32491013      0.86354515E-01, d:   1.5626415     -0.30296082       1.1552650
 i,j,k,ie:    5    1    6          35
 Near X = -0.56264145     -0.32491013      0.11859381    , d:   1.5626415     -0.30296082       1.1552650
 i,j,k,ie:    6    1    6          35
 Near X = -0.56264145     -0.32491013      0.13437970    , d:   1.5626415     -0.43735856       1.1552650
 i,j,k,ie:    1    2    6          35
 Near X = -0.53471423     -0.35283557       0.0000000    , d:  0.24797483     -0.28792308       1.1552650
 i,j,k,ie:    2    2    6          35
 Near X = -0.53471423     -0.35283557      0.15785898E-01, d:   0.0000000     -0.28792308       1.1552650
 i,j,k,ie:    3    2    6          35
 Near X = -0.53471423     -0.35283557      0.48025188E-01, d:   0.0000000     -0.28792308       1.1552650
 i,j,k,ie:    4    2    6          35
 Near X = -0.53471423     -0.35283557      0.86354515E-01, d:   0.0000000     -0.28792308       1.1552650
 i,j,k,ie:    5    2    6          35
 Near X = -0.53471423     -0.35283557      0.11859381    , d:   0.0000000     -0.28792308       1.1552650
 i,j,k,ie:    6    2    6          35
 Near X = -0.53471423     -0.35283557      0.13437970    , d:   0.0000000     -0.44949777       1.1552650
 i,j,k,ie:    1    3    6          35
 Near X = -0.47767890     -0.40986726       0.0000000    , d:  0.26888853     -0.25721174       1.1552650
 i,j,k,ie:    2    3    6          35
 Near X = -0.47767890     -0.40986726      0.15785898E-01, d:   0.0000000     -0.25721174       1.1552650
 i,j,k,ie:    3    3    6          35
 Near X = -0.47767890     -0.40986726      0.48025188E-01, d:   0.0000000     -0.25721174       1.1552650
 i,j,k,ie:    4    3    6          35
 Near X = -0.47767890     -0.40986726      0.86354515E-01, d:   0.0000000     -0.25721174       1.1552650
 i,j,k,ie:    5    3    6          35
 Near X = -0.47767890     -0.40986726      0.11859381    , d:   0.0000000     -0.25721174       1.1552650
 i,j,k,ie:    6    3    6          35
 Near X = -0.47767890     -0.40986726      0.13437970    , d:   0.0000000     -0.47428948       1.1552650
 i,j,k,ie:    1    4    6          35
 Near X = -0.40986953     -0.47767229       0.0000000    , d:  0.29375285     -0.22069900       1.1552650
 i,j,k,ie:    2    4    6          35
 Near X = -0.40986953     -0.47767229      0.15785898E-01, d:   0.0000000     -0.22069900       1.1552650
 i,j,k,ie:    3    4    6          35
 Near X = -0.40986953     -0.47767229      0.48025188E-01, d:   0.0000000     -0.22069900       1.1552650
 i,j,k,ie:    4    4    6          35
 Near X = -0.40986953     -0.47767229      0.86354515E-01, d:   0.0000000     -0.22069900       1.1552650
 i,j,k,ie:    5    4    6          35
 Near X = -0.40986953     -0.47767229      0.11859381    , d:   0.0000000     -0.22069900       1.1552650
 i,j,k,ie:    6    4    6          35
 Near X = -0.40986953     -0.47767229      0.13437970    , d:   0.0000000     -0.50376437       1.1552650
 i,j,k,ie:    1    5    6          35
 Near X = -0.35283420     -0.53470398       0.0000000    , d:  0.31466655     -0.18998767       1.1552650
 i,j,k,ie:    2    5    6          35
 Near X = -0.35283420     -0.53470398      0.15785898E-01, d:   0.0000000     -0.18998767       1.1552650
 i,j,k,ie:    3    5    6          35
 Near X = -0.35283420     -0.53470398      0.48025188E-01, d:   0.0000000     -0.18998767       1.1552650
 i,j,k,ie:    4    5    6          35
 Near X = -0.35283420     -0.53470398      0.86354515E-01, d:   0.0000000     -0.18998767       1.1552650
 i,j,k,ie:    5    5    6          35
 Near X = -0.35283420     -0.53470398      0.11859381    , d:   0.0000000     -0.18998767       1.1552650
 i,j,k,ie:    6    5    6          35
 Near X = -0.35283420     -0.53470398      0.13437970    , d:   0.0000000     -0.52855609       1.1552650
 i,j,k,ie:    1    6    6          35
 Near X = -0.32490697     -0.56262942       0.0000000    , d:  0.32490690     -0.32509301       1.1552650
 i,j,k,ie:    2    6    6          35
 Near X = -0.32490697     -0.56262942      0.15785898E-01, d:   0.0000000     -0.32509301       1.1552650
 i,j,k,ie:    3    6    6          35
 Near X = -0.32490697     -0.56262942      0.48025188E-01, d:   0.0000000     -0.32509301       1.1552650
 i,j,k,ie:    4    6    6          35
 Near X = -0.32490697     -0.56262942      0.86354515E-01, d:   0.0000000     -0.32509301       1.1552650
 i,j,k,ie:    5    6    6          35
 Near X = -0.32490697     -0.56262942      0.11859381    , d:   0.0000000     -0.32509301       1.1552650
 i,j,k,ie:    6    6    6          35
 Near X = -0.32490697     -0.56262942      0.13437970    , d:  0.88753638     -0.54069530       1.1552650
 i,j,k,ie:    1    1    1          36
 Near X =  -1.0000000     -0.24492936E-15   0.0000000    , d:   2.0000000       0.0000000      0.99999999
 i,j,k,ie:    2    1    1          36
 Near X =  -1.0000000     -0.24492936E-15  0.15785898E-01, d:   1.8655837       0.0000000      0.99999999
 i,j,k,ie:    3    1    1          36
 Near X =  -1.0000000     -0.24492936E-15  0.48025188E-01, d:   1.8655837       0.0000000      0.99999999
 i,j,k,ie:    4    1    1          36
 Near X =  -1.0000000     -0.24492936E-15  0.86354515E-01, d:   1.8655837       0.0000000      0.99999999
 i,j,k,ie:    5    1    1          36
 Near X =  -1.0000000     -0.24492936E-15  0.11859381    , d:   1.8655837       0.0000000      0.99999999
 i,j,k,ie:    6    1    1          36
 Near X =  -1.0000000     -0.24492936E-15  0.13437970    , d:   1.8655837       0.0000000      0.99999999
 i,j,k,ie:    1    2    1          36
 Near X = -0.98421199     -0.58719930E-01   0.0000000    , d:  0.16157469       0.0000000      0.99999999
 i,j,k,ie:    1    3    1          36
 Near X = -0.95196838     -0.17864272       0.0000000    , d:  0.21707774       0.0000000      0.99999999
 i,j,k,ie:    1    4    1          36
 Near X = -0.91363391     -0.32121905       0.0000000    , d:  0.28306537       0.0000000      0.99999999
 i,j,k,ie:    1    5    1          36
 Near X = -0.88139029     -0.44114183       0.0000000    , d:  0.33856842       0.0000000      0.99999999
 i,j,k,ie:    1    6    1          36
 Near X = -0.86560227     -0.49986176       0.0000000    , d:   1.4282317       0.0000000      0.99999999
 i,j,k,ie:    2    6    1          36
 Near X = -0.86560227     -0.49986176      0.15785898E-01, d:   1.4282317       0.0000000      0.99999999
 i,j,k,ie:    3    6    1          36
 Near X = -0.86560227     -0.49986176      0.48025188E-01, d:   1.4282317       0.0000000      0.99999999
 i,j,k,ie:    4    6    1          36
 Near X = -0.86560227     -0.49986176      0.86354515E-01, d:   1.4282317       0.0000000      0.99999999
 i,j,k,ie:    5    6    1          36
 Near X = -0.86560227     -0.49986176      0.11859381    , d:   1.4282317       0.0000000      0.99999999
 i,j,k,ie:    6    6    1          36
 Near X = -0.86560227     -0.49986176      0.13437970    , d:   1.4282317       0.0000000      0.99999999
 i,j,k,ie:    1    1    2          36
 Near X = -0.95888469     -0.23485901E-15   0.0000000    , d:   1.9177694       0.0000000      0.99999999
 i,j,k,ie:    2    1    2          36
 Near X = -0.95888469     -0.23485901E-15  0.15785898E-01, d:   1.7888797       0.0000000      0.99999999
 i,j,k,ie:    3    1    2          36
 Near X = -0.95888469     -0.23485901E-15  0.48025188E-01, d:   1.7888797       0.0000000      0.99999999
 i,j,k,ie:    4    1    2          36
 Near X = -0.95888469     -0.23485901E-15  0.86354515E-01, d:   1.7888797       0.0000000      0.99999999
 i,j,k,ie:    5    1    2          36
 Near X = -0.95888469     -0.23485901E-15  0.11859381    , d:   1.7888797       0.0000000      0.99999999
 i,j,k,ie:    6    1    2          36
 Near X = -0.95888469     -0.23485901E-15  0.13437970    , d:   1.7888797       0.0000000      0.99999999
 i,j,k,ie:    1    2    2          36
 Near X = -0.94374580     -0.56305641E-01   0.0000000    , d:  0.15493149       0.0000000      0.99999999
 i,j,k,ie:    1    3    2          36
 Near X = -0.91282789     -0.17129776       0.0000000    , d:  0.20815251       0.0000000      0.99999999
 i,j,k,ie:    1    4    2          36
 Near X = -0.87606955     -0.30801202       0.0000000    , d:  0.27142705       0.0000000      0.99999999
 i,j,k,ie:    1    5    2          36
 Near X = -0.84515164     -0.42300415       0.0000000    , d:  0.32464807       0.0000000      0.99999999
 i,j,k,ie:    1    6    2          36
 Near X = -0.83001276     -0.47930979       0.0000000    , d:   1.3773670       0.0000000      0.99999999
 i,j,k,ie:    2    6    2          36
 Near X = -0.83001276     -0.47930979      0.15785898E-01, d:   1.3773670       0.0000000      0.99999999
 i,j,k,ie:    3    6    2          36
 Near X = -0.83001276     -0.47930979      0.48025188E-01, d:   1.3773670       0.0000000      0.99999999
 i,j,k,ie:    4    6    2          36
 Near X = -0.83001276     -0.47930979      0.86354515E-01, d:   1.3773670       0.0000000      0.99999999
 i,j,k,ie:    5    6    2          36
 Near X = -0.83001276     -0.47930979      0.11859381    , d:   1.3773670       0.0000000      0.99999999
 i,j,k,ie:    6    6    2          36
 Near X = -0.83001276     -0.47930979      0.13437970    , d:   1.3773670       0.0000000      0.99999999
 i,j,k,ie:    1    1    3          36
 Near X = -0.87491551     -0.21429250E-15   0.0000000    , d:   1.7498310       0.0000000      0.99999999
 i,j,k,ie:    2    1    3          36
 Near X = -0.87491551     -0.21429250E-15  0.15785898E-01, d:   1.6322281       0.0000000      0.99999999
 i,j,k,ie:    3    1    3          36
 Near X = -0.87491551     -0.21429250E-15  0.48025188E-01, d:   1.6322281       0.0000000      0.99999999
 i,j,k,ie:    4    1    3          36
 Near X = -0.87491551     -0.21429250E-15  0.86354515E-01, d:   1.6322281       0.0000000      0.99999999
 i,j,k,ie:    5    1    3          36
 Near X = -0.87491551     -0.21429250E-15  0.11859381    , d:   1.6322281       0.0000000      0.99999999
 i,j,k,ie:    6    1    3          36
 Near X = -0.87491551     -0.21429250E-15  0.13437970    , d:   1.6322281       0.0000000      0.99999999
 i,j,k,ie:    1    2    3          36
 Near X = -0.86110233     -0.51374977E-01   0.0000000    , d:  0.14136420       0.0000000      0.99999999
 i,j,k,ie:    1    3    3          36
 Near X = -0.83289189     -0.15629728       0.0000000    , d:  0.18992468       0.0000000      0.99999999
 i,j,k,ie:    1    4    3          36
 Near X = -0.79935247     -0.28103952       0.0000000    , d:  0.24765828       0.0000000      0.99999999
 i,j,k,ie:    1    5    3          36
 Near X = -0.77114203     -0.38596183       0.0000000    , d:  0.29621876       0.0000000      0.99999999
 i,j,k,ie:    1    6    3          36
 Near X = -0.75732885     -0.43733681       0.0000000    , d:   1.2734870       0.0000000      0.99999999
 i,j,k,ie:    2    6    3          36
 Near X = -0.75732885     -0.43733681      0.15785898E-01, d:   1.2734870       0.0000000      0.99999999
 i,j,k,ie:    3    6    3          36
 Near X = -0.75732885     -0.43733681      0.48025188E-01, d:   1.2734870       0.0000000      0.99999999
 i,j,k,ie:    4    6    3          36
 Near X = -0.75732885     -0.43733681      0.86354515E-01, d:   1.2734870       0.0000000      0.99999999
 i,j,k,ie:    5    6    3          36
 Near X = -0.75732885     -0.43733681      0.11859381    , d:   1.2734870       0.0000000      0.99999999
 i,j,k,ie:    6    6    3          36
 Near X = -0.75732885     -0.43733681      0.13437970    , d:   1.2734870       0.0000000      0.99999999
 i,j,k,ie:    1    1    4          36
 Near X = -0.77508447     -0.18984094E-15   0.0000000    , d:   1.5501689       0.0000000      0.99999999
 i,j,k,ie:    2    1    4          36
 Near X = -0.77508447     -0.18984094E-15  0.15785898E-01, d:   1.4459850       0.0000000      0.99999999
 i,j,k,ie:    3    1    4          36
 Near X = -0.77508447     -0.18984094E-15  0.48025188E-01, d:   1.4459850       0.0000000      0.99999999
 i,j,k,ie:    4    1    4          36
 Near X = -0.77508447     -0.18984094E-15  0.86354515E-01, d:   1.4459850       0.0000000      0.99999999
 i,j,k,ie:    5    1    4          36
 Near X = -0.77508447     -0.18984094E-15  0.11859381    , d:   1.4459850       0.0000000      0.99999999
 i,j,k,ie:    6    1    4          36
 Near X = -0.77508447     -0.18984094E-15  0.13437970    , d:   1.4459850       0.0000000      0.99999999
 i,j,k,ie:    1    2    4          36
 Near X = -0.76284743     -0.45512906E-01   0.0000000    , d:  0.12523403       0.0000000      0.99999999
 i,j,k,ie:    1    3    4          36
 Near X = -0.73785590     -0.13846320       0.0000000    , d:  0.16825358       0.0000000      0.99999999
 i,j,k,ie:    1    4    4          36
 Near X = -0.70814345     -0.24897189       0.0000000    , d:  0.21939957       0.0000000      0.99999999
 i,j,k,ie:    1    5    4          36
 Near X = -0.68315192     -0.34192218       0.0000000    , d:  0.26241912       0.0000000      0.99999999
 i,j,k,ie:    1    6    4          36
 Near X = -0.67091488     -0.38743509       0.0000000    , d:   1.1499839       0.0000000      0.99999999
 i,j,k,ie:    2    6    4          36
 Near X = -0.67091488     -0.38743509      0.15785898E-01, d:   1.1499839       0.0000000      0.99999999
 i,j,k,ie:    3    6    4          36
 Near X = -0.67091488     -0.38743509      0.48025188E-01, d:   1.1499839       0.0000000      0.99999999
 i,j,k,ie:    4    6    4          36
 Near X = -0.67091488     -0.38743509      0.86354515E-01, d:   1.1499839       0.0000000      0.99999999
 i,j,k,ie:    5    6    4          36
 Near X = -0.67091488     -0.38743509      0.11859381    , d:   1.1499839       0.0000000      0.99999999
 i,j,k,ie:    6    6    4          36
 Near X = -0.67091488     -0.38743509      0.13437970    , d:   1.1499839       0.0000000      0.99999999
 i,j,k,ie:    1    1    5          36
 Near X = -0.69111530     -0.16927443E-15   0.0000000    , d:   1.3822306       0.0000000      0.99999999
 i,j,k,ie:    2    1    5          36
 Near X = -0.69111530     -0.16927443E-15  0.15785898E-01, d:   1.2893335       0.0000000      0.99999999
 i,j,k,ie:    3    1    5          36
 Near X = -0.69111530     -0.16927443E-15  0.48025188E-01, d:   1.2893335       0.0000000      0.99999999
 i,j,k,ie:    4    1    5          36
 Near X = -0.69111530     -0.16927443E-15  0.86354515E-01, d:   1.2893335       0.0000000      0.99999999
 i,j,k,ie:    5    1    5          36
 Near X = -0.69111530     -0.16927443E-15  0.11859381    , d:   1.2893335       0.0000000      0.99999999
 i,j,k,ie:    6    1    5          36
 Near X = -0.69111530     -0.16927443E-15  0.13437970    , d:   1.2893335       0.0000000      0.99999999
 i,j,k,ie:    1    2    5          36
 Near X = -0.68020396     -0.40582242E-01   0.0000000    , d:  0.11166674       0.0000000      0.99999999
 i,j,k,ie:    1    3    5          36
 Near X = -0.65791990     -0.12346271       0.0000000    , d:  0.15002574       0.0000000      0.99999999
 i,j,k,ie:    1    4    5          36
 Near X = -0.63142637     -0.22199940       0.0000000    , d:  0.19563081       0.0000000      0.99999999
 i,j,k,ie:    1    5    5          36
 Near X = -0.60914231     -0.30487987       0.0000000    , d:  0.23398981       0.0000000      0.99999999
 i,j,k,ie:    1    6    5          36
 Near X = -0.59823097     -0.34546211       0.0000000    , d:   1.0461039       0.0000000      0.99999999
 i,j,k,ie:    2    6    5          36
 Near X = -0.59823097     -0.34546211      0.15785898E-01, d:   1.0461039       0.0000000      0.99999999
 i,j,k,ie:    3    6    5          36
 Near X = -0.59823097     -0.34546211      0.48025188E-01, d:   1.0461039       0.0000000      0.99999999
 i,j,k,ie:    4    6    5          36
 Near X = -0.59823097     -0.34546211      0.86354515E-01, d:   1.0461039       0.0000000      0.99999999
 i,j,k,ie:    5    6    5          36
 Near X = -0.59823097     -0.34546211      0.11859381    , d:   1.0461039       0.0000000      0.99999999
 i,j,k,ie:    6    6    5          36
 Near X = -0.59823097     -0.34546211      0.13437970    , d:   1.0461039       0.0000000      0.99999999
 i,j,k,ie:    1    1    6          36
 Near X = -0.64999998     -0.15920408E-15   0.0000000    , d:   1.6500000     -0.35000003      0.99999999
 i,j,k,ie:    2    1    6          36
 Near X = -0.64999998     -0.15920408E-15  0.15785898E-01, d:   1.5155837     -0.35000003      0.99999999
 i,j,k,ie:    3    1    6          36
 Near X = -0.64999998     -0.15920408E-15  0.48025188E-01, d:   1.5155837     -0.35000003      0.99999999
 i,j,k,ie:    4    1    6          36
 Near X = -0.64999998     -0.15920408E-15  0.86354515E-01, d:   1.5155837     -0.35000003      0.99999999
 i,j,k,ie:    5    1    6          36
 Near X = -0.64999998     -0.15920408E-15  0.11859381    , d:   1.5155837     -0.35000003      0.99999999
 i,j,k,ie:    6    1    6          36
 Near X = -0.64999998     -0.15920408E-15  0.13437970    , d:   1.5155837     -0.35000003      0.99999999
 i,j,k,ie:    1    2    6          36
 Near X = -0.63973777     -0.38167953E-01   0.0000000    , d:  0.10502354     -0.34447422      0.99999999
 i,j,k,ie:    2    2    6          36
 Near X = -0.63973777     -0.38167953E-01  0.15785898E-01, d:   0.0000000     -0.34447422      0.99999999
 i,j,k,ie:    3    2    6          36
 Near X = -0.63973777     -0.38167953E-01  0.48025188E-01, d:   0.0000000     -0.34447422      0.99999999
 i,j,k,ie:    4    2    6          36
 Near X = -0.63973777     -0.38167953E-01  0.86354515E-01, d:   0.0000000     -0.34447422      0.99999999
 i,j,k,ie:    5    2    6          36
 Near X = -0.63973777     -0.38167953E-01  0.11859381    , d:   0.0000000     -0.34447422      0.99999999
 i,j,k,ie:    6    2    6          36
 Near X = -0.63973777     -0.38167953E-01  0.13437970    , d:   0.0000000     -0.34447422      0.99999999
 i,j,k,ie:    1    3    6          36
 Near X = -0.61877942     -0.11611776       0.0000000    , d:  0.14110052     -0.33318896      0.99999999
 i,j,k,ie:    2    3    6          36
 Near X = -0.61877942     -0.11611776      0.15785898E-01, d:   0.0000000     -0.33318896      0.99999999
 i,j,k,ie:    3    3    6          36
 Near X = -0.61877942     -0.11611776      0.48025188E-01, d:   0.0000000     -0.33318896      0.99999999
 i,j,k,ie:    4    3    6          36
 Near X = -0.61877942     -0.11611776      0.86354515E-01, d:   0.0000000     -0.33318896      0.99999999
 i,j,k,ie:    5    3    6          36
 Near X = -0.61877942     -0.11611776      0.11859381    , d:   0.0000000     -0.33318896      0.99999999
 i,j,k,ie:    6    3    6          36
 Near X = -0.61877942     -0.11611776      0.13437970    , d:   0.0000000     -0.33318896      0.99999999
 i,j,k,ie:    1    4    6          36
 Near X = -0.59386201     -0.20879237       0.0000000    , d:  0.18399248     -0.31977189      0.99999999
 i,j,k,ie:    2    4    6          36
 Near X = -0.59386201     -0.20879237      0.15785898E-01, d:   0.0000000     -0.31977189      0.99999999
 i,j,k,ie:    3    4    6          36
 Near X = -0.59386201     -0.20879237      0.48025188E-01, d:   0.0000000     -0.31977189      0.99999999
 i,j,k,ie:    4    4    6          36
 Near X = -0.59386201     -0.20879237      0.86354515E-01, d:   0.0000000     -0.31977189      0.99999999
 i,j,k,ie:    5    4    6          36
 Near X = -0.59386201     -0.20879237      0.11859381    , d:   0.0000000     -0.31977189      0.99999999
 i,j,k,ie:    6    4    6          36
 Near X = -0.59386201     -0.20879237      0.13437970    , d:   0.0000000     -0.31977189      0.99999999
 i,j,k,ie:    1    5    6          36
 Near X = -0.57290366     -0.28674218       0.0000000    , d:  0.22006946     -0.30848662      0.99999999
 i,j,k,ie:    2    5    6          36
 Near X = -0.57290366     -0.28674218      0.15785898E-01, d:   0.0000000     -0.30848662      0.99999999
 i,j,k,ie:    3    5    6          36
 Near X = -0.57290366     -0.28674218      0.48025188E-01, d:   0.0000000     -0.30848662      0.99999999
 i,j,k,ie:    4    5    6          36
 Near X = -0.57290366     -0.28674218      0.86354515E-01, d:   0.0000000     -0.30848662      0.99999999
 i,j,k,ie:    5    5    6          36
 Near X = -0.57290366     -0.28674218      0.11859381    , d:   0.0000000     -0.30848662      0.99999999
 i,j,k,ie:    6    5    6          36
 Near X = -0.57290366     -0.28674218      0.13437970    , d:   0.0000000     -0.30848662      0.99999999
 i,j,k,ie:    1    6    6          36
 Near X = -0.56264145     -0.32491013       0.0000000    , d:   1.1252709     -0.30296082      0.99999999
 i,j,k,ie:    2    6    6          36
 Near X = -0.56264145     -0.32491013      0.15785898E-01, d:   1.1252709     -0.30296082      0.99999999
 i,j,k,ie:    3    6    6          36
 Near X = -0.56264145     -0.32491013      0.48025188E-01, d:   1.1252709     -0.30296082      0.99999999
 i,j,k,ie:    4    6    6          36
 Near X = -0.56264145     -0.32491013      0.86354515E-01, d:   1.1252709     -0.30296082      0.99999999
 i,j,k,ie:    5    6    6          36
 Near X = -0.56264145     -0.32491013      0.11859381    , d:   1.1252709     -0.30296082      0.99999999
 i,j,k,ie:    6    6    6          36
 Near X = -0.56264145     -0.32491013      0.13437970    , d:   1.1252709     -0.30296082      0.99999999
 i,j,k,ie:    1    1    1          37
 Near X = -0.32490697     -0.56262942       0.0000000    , d:  0.82476867       0.0000000       3.0778041
 i,j,k,ie:    2    1    1          37
 Near X = -0.32490697     -0.56262942      0.15785898E-01, d:  0.82476867       0.0000000       3.0778041
 i,j,k,ie:    3    1    1          37
 Near X = -0.32490697     -0.56262942      0.48025188E-01, d:  0.82476867       0.0000000       3.0778041
 i,j,k,ie:    4    1    1          37
 Near X = -0.32490697     -0.56262942      0.86354515E-01, d:  0.82476867       0.0000000       3.0778041
 i,j,k,ie:    5    1    1          37
 Near X = -0.32490697     -0.56262942      0.11859381    , d:  0.82476867       0.0000000       3.0778041
 i,j,k,ie:    6    1    1          37
 Near X = -0.32490697     -0.56262942      0.13437970    , d:  0.82476867     -0.23773448       3.0778041
 i,j,k,ie:    6    2    1          37
 Near X = -0.28673940     -0.57289304      0.13437970    , d:   0.0000000     -0.24797483       3.0778041
 i,j,k,ie:    6    3    1          37
 Near X = -0.20879037     -0.59385428      0.13437970    , d:   0.0000000     -0.26888853       3.0778041
 i,j,k,ie:    6    4    1          37
 Near X = -0.11611668     -0.61877512      0.13437970    , d:   0.0000000     -0.29375285       3.0778041
 i,j,k,ie:    6    5    1          37
 Near X = -0.38167650E-01 -0.63973635      0.13437970    , d:   0.0000000     -0.31466655       3.0778041
 i,j,k,ie:    1    6    1          37
 Near X = -0.76704964E-07 -0.64999998       0.0000000    , d:  0.32491017       0.0000000       3.0778041
 i,j,k,ie:    2    6    1          37
 Near X = -0.76704964E-07 -0.64999998      0.15785898E-01, d:  0.32491017       0.0000000       3.0778041
 i,j,k,ie:    3    6    1          37
 Near X = -0.76704964E-07 -0.64999998      0.48025188E-01, d:  0.32491017       0.0000000       3.0778041
 i,j,k,ie:    4    6    1          37
 Near X = -0.76704964E-07 -0.64999998      0.86354515E-01, d:  0.32491017       0.0000000       3.0778041
 i,j,k,ie:    5    6    1          37
 Near X = -0.76704964E-07 -0.64999998      0.11859381    , d:  0.32491017       0.0000000       3.0778041
 i,j,k,ie:    6    6    1          37
 Near X = -0.76704964E-07 -0.64999998      0.13437970    , d:  0.32491017     -0.32490690       3.0778041
 i,j,k,ie:    1    1    2          37
 Near X = -0.31618386     -0.54735430       0.0000000    , d:  0.79549358       0.0000000       3.0778041
 i,j,k,ie:    2    1    2          37
 Near X = -0.31618386     -0.54735430      0.15785898E-01, d:  0.79549358       0.0000000       3.0778041
 i,j,k,ie:    3    1    2          37
 Near X = -0.31618386     -0.54735430      0.48025188E-01, d:  0.79549358       0.0000000       3.0778041
 i,j,k,ie:    4    1    2          37
 Near X = -0.31618386     -0.54735430      0.86354515E-01, d:  0.79549358       0.0000000       3.0778041
 i,j,k,ie:    5    1    2          37
 Near X = -0.31618386     -0.54735430      0.11859381    , d:  0.79549358       0.0000000       3.0778041
 i,j,k,ie:    6    1    2          37
 Near X = -0.31618386     -0.54735430      0.13437970    , d:  0.79549358     -0.23118335       3.0778041
 i,j,k,ie:    6    2    2          37
 Near X = -0.27925790     -0.55814934      0.13437970    , d:   0.0000000     -0.24153302       3.0778041
 i,j,k,ie:    6    3    2          37
 Near X = -0.20366521     -0.57952848      0.13437970    , d:   0.0000000     -0.26236855       3.0778041
 i,j,k,ie:    6    4    2          37
 Near X = -0.11347963     -0.60378024      0.13437970    , d:   0.0000000     -0.28661335       3.0778041
 i,j,k,ie:    6    5    2          37
 Near X = -0.37359810E-01 -0.62319804      0.13437970    , d:   0.0000000     -0.30656305       3.0778041
 i,j,k,ie:    1    6    2          37
 Near X = -0.74625580E-07 -0.63237913       0.0000000    , d:  0.31618252       0.0000000       3.0778041
 i,j,k,ie:    2    6    2          37
 Near X = -0.74625580E-07 -0.63237913      0.15785898E-01, d:  0.31618252       0.0000000       3.0778041
 i,j,k,ie:    3    6    2          37
 Near X = -0.74625580E-07 -0.63237913      0.48025188E-01, d:  0.31618252       0.0000000       3.0778041
 i,j,k,ie:    4    6    2          37
 Near X = -0.74625580E-07 -0.63237913      0.86354515E-01, d:  0.31618252       0.0000000       3.0778041
 i,j,k,ie:    5    6    2          37
 Near X = -0.74625580E-07 -0.63237913      0.11859381    , d:  0.31618252       0.0000000       3.0778041
 i,j,k,ie:    6    6    2          37
 Near X = -0.74625580E-07 -0.63237913      0.13437970    , d:  0.31618252     -0.31618378       3.0778041
 i,j,k,ie:    1    1    3          37
 Near X = -0.29836877     -0.51615816       0.0000000    , d:  0.73570553       0.0000000       3.0778041
 i,j,k,ie:    2    1    3          37
 Near X = -0.29836877     -0.51615816      0.15785898E-01, d:  0.73570553       0.0000000       3.0778041
 i,j,k,ie:    3    1    3          37
 Near X = -0.29836877     -0.51615816      0.48025188E-01, d:  0.73570553       0.0000000       3.0778041
 i,j,k,ie:    4    1    3          37
 Near X = -0.29836877     -0.51615816      0.86354515E-01, d:  0.73570553       0.0000000       3.0778041
 i,j,k,ie:    5    1    3          37
 Near X = -0.29836877     -0.51615816      0.11859381    , d:  0.73570553       0.0000000       3.0778041
 i,j,k,ie:    6    1    3          37
 Near X = -0.29836877     -0.51615816      0.13437970    , d:  0.73570553     -0.21780408       3.0778041
 i,j,k,ie:    6    2    3          37
 Near X = -0.26397854     -0.52803850      0.13437970    , d:   0.0000000     -0.22837701       3.0778041
 i,j,k,ie:    6    3    3          37
 Near X = -0.19319819     -0.55027113      0.13437970    , d:   0.0000000     -0.24905290       3.0778041
 i,j,k,ie:    6    4    3          37
 Near X = -0.10809403     -0.57315645      0.13437970    , d:   0.0000000     -0.27203247       3.0778041
 i,j,k,ie:    6    5    3          37
 Near X = -0.35709971E-01 -0.58942209      0.13437970    , d:   0.0000000     -0.29001340       3.0778041
 i,j,k,ie:    1    6    3          37
 Near X = -0.70378885E-07 -0.59639235       0.0000000    , d:  0.29835818       0.0000000       3.0778041
 i,j,k,ie:    2    6    3          37
 Near X = -0.70378885E-07 -0.59639235      0.15785898E-01, d:  0.29835818       0.0000000       3.0778041
 i,j,k,ie:    3    6    3          37
 Near X = -0.70378885E-07 -0.59639235      0.48025188E-01, d:  0.29835818       0.0000000       3.0778041
 i,j,k,ie:    4    6    3          37
 Near X = -0.70378885E-07 -0.59639235      0.86354515E-01, d:  0.29835818       0.0000000       3.0778041
 i,j,k,ie:    5    6    3          37
 Near X = -0.70378885E-07 -0.59639235      0.11859381    , d:  0.29835818       0.0000000       3.0778041
 i,j,k,ie:    6    6    3          37
 Near X = -0.70378885E-07 -0.59639235      0.13437970    , d:  0.29835818     -0.29836870       3.0778041
 i,j,k,ie:    1    1    4          37
 Near X = -0.27718840     -0.47906904       0.0000000    , d:  0.66462344       0.0000000       3.0778041
 i,j,k,ie:    2    1    4          37
 Near X = -0.27718840     -0.47906904      0.15785898E-01, d:  0.66462344       0.0000000       3.0778041
 i,j,k,ie:    3    1    4          37
 Near X = -0.27718840     -0.47906904      0.48025188E-01, d:  0.66462344       0.0000000       3.0778041
 i,j,k,ie:    4    1    4          37
 Near X = -0.27718840     -0.47906904      0.86354515E-01, d:  0.66462344       0.0000000       3.0778041
 i,j,k,ie:    5    1    4          37
 Near X = -0.27718840     -0.47906904      0.11859381    , d:  0.66462344       0.0000000       3.0778041
 i,j,k,ie:    6    1    4          37
 Near X = -0.27718840     -0.47906904      0.13437970    , d:  0.66462344     -0.20189745       3.0778041
 i,j,k,ie:    6    2    4          37
 Near X = -0.24581289     -0.49223970      0.13437970    , d:   0.0000000     -0.21273581       3.0778041
 i,j,k,ie:    6    3    4          37
 Near X = -0.18075394     -0.51548704      0.13437970    , d:   0.0000000     -0.23322192       3.0778041
 i,j,k,ie:    6    4    4          37
 Near X = -0.10169109     -0.53674779      0.13437970    , d:   0.0000000     -0.25469725       3.0778041
 i,j,k,ie:    6    5    4          37
 Near X = -0.33748476E-01 -0.54926584      0.13437970    , d:   0.0000000     -0.27033751       3.0778041
 i,j,k,ie:    1    6    4          37
 Near X = -0.65329986E-07 -0.55360763       0.0000000    , d:  0.27716680       0.0000000       3.0778041
 i,j,k,ie:    2    6    4          37
 Near X = -0.65329986E-07 -0.55360763      0.15785898E-01, d:  0.27716680       0.0000000       3.0778041
 i,j,k,ie:    3    6    4          37
 Near X = -0.65329986E-07 -0.55360763      0.48025188E-01, d:  0.27716680       0.0000000       3.0778041
 i,j,k,ie:    4    6    4          37
 Near X = -0.65329986E-07 -0.55360763      0.86354515E-01, d:  0.27716680       0.0000000       3.0778041
 i,j,k,ie:    5    6    4          37
 Near X = -0.65329986E-07 -0.55360763      0.11859381    , d:  0.27716680       0.0000000       3.0778041
 i,j,k,ie:    6    6    4          37
 Near X = -0.65329986E-07 -0.55360763      0.13437970    , d:  0.27716680     -0.27718834       3.0778041
 i,j,k,ie:    1    1    5          37
 Near X = -0.25937332     -0.44787291       0.0000000    , d:  0.60483539       0.0000000       3.0778041
 i,j,k,ie:    2    1    5          37
 Near X = -0.25937332     -0.44787291      0.15785898E-01, d:  0.60483539       0.0000000       3.0778041
 i,j,k,ie:    3    1    5          37
 Near X = -0.25937332     -0.44787291      0.48025188E-01, d:  0.60483539       0.0000000       3.0778041
 i,j,k,ie:    4    1    5          37
 Near X = -0.25937332     -0.44787291      0.86354515E-01, d:  0.60483539       0.0000000       3.0778041
 i,j,k,ie:    5    1    5          37
 Near X = -0.25937332     -0.44787291      0.11859381    , d:  0.60483539       0.0000000       3.0778041
 i,j,k,ie:    6    1    5          37
 Near X = -0.25937332     -0.44787291      0.13437970    , d:  0.60483539     -0.18851818       3.0778041
 i,j,k,ie:    6    2    5          37
 Near X = -0.23053353     -0.46212886      0.13437970    , d:   0.0000000     -0.19957980       3.0778041
 i,j,k,ie:    6    3    5          37
 Near X = -0.17028692     -0.48622969      0.13437970    , d:   0.0000000     -0.21990627       3.0778041
 i,j,k,ie:    6    4    5          37
 Near X = -0.96305490E-01 -0.50612400      0.13437970    , d:   0.0000000     -0.24011637       3.0778041
 i,j,k,ie:    6    5    5          37
 Near X = -0.32098637E-01 -0.51548990      0.13437970    , d:   0.0000000     -0.25378786       3.0778041
 i,j,k,ie:    1    6    5          37
 Near X = -0.61083291E-07 -0.51762085       0.0000000    , d:  0.25934246       0.0000000       3.0778041
 i,j,k,ie:    2    6    5          37
 Near X = -0.61083291E-07 -0.51762085      0.15785898E-01, d:  0.25934246       0.0000000       3.0778041
 i,j,k,ie:    3    6    5          37
 Near X = -0.61083291E-07 -0.51762085      0.48025188E-01, d:  0.25934246       0.0000000       3.0778041
 i,j,k,ie:    4    6    5          37
 Near X = -0.61083291E-07 -0.51762085      0.86354515E-01, d:  0.25934246       0.0000000       3.0778041
 i,j,k,ie:    5    6    5          37
 Near X = -0.61083291E-07 -0.51762085      0.11859381    , d:  0.25934246       0.0000000       3.0778041
 i,j,k,ie:    6    6    5          37
 Near X = -0.61083291E-07 -0.51762085      0.13437970    , d:  0.25934246     -0.25937326       3.0778041
 i,j,k,ie:    1    1    6          37
 Near X = -0.25065020     -0.43259779       0.0000000    , d:  0.75051190     -0.74256770E-01   3.0778041
 i,j,k,ie:    2    1    6          37
 Near X = -0.25065020     -0.43259779      0.15785898E-01, d:  0.75051190     -0.74256770E-01   3.0778041
 i,j,k,ie:    3    1    6          37
 Near X = -0.25065020     -0.43259779      0.48025188E-01, d:  0.75051190     -0.74256770E-01   3.0778041
 i,j,k,ie:    4    1    6          37
 Near X = -0.25065020     -0.43259779      0.86354515E-01, d:  0.75051190     -0.74256770E-01   3.0778041
 i,j,k,ie:    5    1    6          37
 Near X = -0.25065020     -0.43259779      0.11859381    , d:  0.75051190     -0.74256770E-01   3.0778041
 i,j,k,ie:    6    1    6          37
 Near X = -0.25065020     -0.43259779      0.13437970    , d:  0.75051190     -0.31199125       3.0778041
 i,j,k,ie:    1    2    6          37
 Near X = -0.22305202     -0.44738516       0.0000000    , d:   0.0000000     -0.63687376E-01   3.0778041
 i,j,k,ie:    2    2    6          37
 Near X = -0.22305202     -0.44738516      0.15785898E-01, d:   0.0000000     -0.63687376E-01   3.0778041
 i,j,k,ie:    3    2    6          37
 Near X = -0.22305202     -0.44738516      0.48025188E-01, d:   0.0000000     -0.63687376E-01   3.0778041
 i,j,k,ie:    4    2    6          37
 Near X = -0.22305202     -0.44738516      0.86354515E-01, d:   0.0000000     -0.63687376E-01   3.0778041
 i,j,k,ie:    5    2    6          37
 Near X = -0.22305202     -0.44738516      0.11859381    , d:   0.0000000     -0.63687376E-01   3.0778041
 i,j,k,ie:    6    2    6          37
 Near X = -0.22305202     -0.44738516      0.13437970    , d:   0.0000000     -0.31166220       3.0778041
 i,j,k,ie:    1    3    6          37
 Near X = -0.16516176     -0.47190389       0.0000000    , d:   0.0000000     -0.43628605E-01   3.0778041
 i,j,k,ie:    2    3    6          37
 Near X = -0.16516176     -0.47190389      0.15785898E-01, d:   0.0000000     -0.43628605E-01   3.0778041
 i,j,k,ie:    3    3    6          37
 Near X = -0.16516176     -0.47190389      0.48025188E-01, d:   0.0000000     -0.43628605E-01   3.0778041
 i,j,k,ie:    4    3    6          37
 Near X = -0.16516176     -0.47190389      0.86354515E-01, d:   0.0000000     -0.43628605E-01   3.0778041
 i,j,k,ie:    5    3    6          37
 Near X = -0.16516176     -0.47190389      0.11859381    , d:   0.0000000     -0.43628605E-01   3.0778041
 i,j,k,ie:    6    3    6          37
 Near X = -0.16516176     -0.47190389      0.13437970    , d:   0.0000000     -0.31251713       3.0778041
 i,j,k,ie:    1    4    6          37
 Near X = -0.93668443E-01 -0.49112912       0.0000000    , d:   0.0000000     -0.22448239E-01   3.0778041
 i,j,k,ie:    2    4    6          37
 Near X = -0.93668443E-01 -0.49112912      0.15785898E-01, d:   0.0000000     -0.22448239E-01   3.0778041
 i,j,k,ie:    3    4    6          37
 Near X = -0.93668443E-01 -0.49112912      0.48025188E-01, d:   0.0000000     -0.22448239E-01   3.0778041
 i,j,k,ie:    4    4    6          37
 Near X = -0.93668443E-01 -0.49112912      0.86354515E-01, d:   0.0000000     -0.22448239E-01   3.0778041
 i,j,k,ie:    5    4    6          37
 Near X = -0.93668443E-01 -0.49112912      0.11859381    , d:   0.0000000     -0.22448239E-01   3.0778041
 i,j,k,ie:    6    4    6          37
 Near X = -0.93668443E-01 -0.49112912      0.13437970    , d:   0.0000000     -0.31620109       3.0778041
 i,j,k,ie:    1    5    6          37
 Near X = -0.31290797E-01 -0.49895158       0.0000000    , d:   0.0000000     -0.68768523E-02   3.0778041
 i,j,k,ie:    2    5    6          37
 Near X = -0.31290797E-01 -0.49895158      0.15785898E-01, d:   0.0000000     -0.68768523E-02   3.0778041
 i,j,k,ie:    3    5    6          37
 Near X = -0.31290797E-01 -0.49895158      0.48025188E-01, d:   0.0000000     -0.68768523E-02   3.0778041
 i,j,k,ie:    4    5    6          37
 Near X = -0.31290797E-01 -0.49895158      0.86354515E-01, d:   0.0000000     -0.68768523E-02   3.0778041
 i,j,k,ie:    5    5    6          37
 Near X = -0.31290797E-01 -0.49895158      0.11859381    , d:   0.0000000     -0.68768523E-02   3.0778041
 i,j,k,ie:    6    5    6          37
 Near X = -0.31290797E-01 -0.49895158      0.13437970    , d:   0.0000000     -0.32154340       3.0778041
 i,j,k,ie:    1    6    6          37
 Near X = -0.59003907E-07 -0.50000000       0.0000000    , d:  0.32491015     -0.17701058E-07   3.0778041
 i,j,k,ie:    2    6    6          37
 Near X = -0.59003907E-07 -0.50000000      0.15785898E-01, d:  0.32491015     -0.17701058E-07   3.0778041
 i,j,k,ie:    3    6    6          37
 Near X = -0.59003907E-07 -0.50000000      0.48025188E-01, d:  0.32491015     -0.17701058E-07   3.0778041
 i,j,k,ie:    4    6    6          37
 Near X = -0.59003907E-07 -0.50000000      0.86354515E-01, d:  0.32491015     -0.17701058E-07   3.0778041
 i,j,k,ie:    5    6    6          37
 Near X = -0.59003907E-07 -0.50000000      0.11859381    , d:  0.32491015     -0.17701058E-07   3.0778041
 i,j,k,ie:    6    6    6          37
 Near X = -0.59003907E-07 -0.50000000      0.13437970    , d:  0.32491015     -0.32490691       3.0778041
 i,j,k,ie:    1    1    1          38
 Near X = -0.56264145     -0.32491013       0.0000000    , d:   1.0625032       0.0000000       1.7773308
 i,j,k,ie:    2    1    1          38
 Near X = -0.56264145     -0.32491013      0.15785898E-01, d:  0.56264133       0.0000000       1.7773308
 i,j,k,ie:    3    1    1          38
 Near X = -0.56264145     -0.32491013      0.48025188E-01, d:  0.56264133       0.0000000       1.7773308
 i,j,k,ie:    4    1    1          38
 Near X = -0.56264145     -0.32491013      0.86354515E-01, d:  0.56264133       0.0000000       1.7773308
 i,j,k,ie:    5    1    1          38
 Near X = -0.56264145     -0.32491013      0.11859381    , d:  0.56264133       0.0000000       1.7773308
 i,j,k,ie:    6    1    1          38
 Near X = -0.56264145     -0.32491013      0.13437970    , d:  0.56264133     -0.87358526E-01   1.7773308
 i,j,k,ie:    1    2    1          38
 Near X = -0.53471423     -0.35283557       0.0000000    , d:  0.24797483       0.0000000       1.7773308
 i,j,k,ie:    6    2    1          38
 Near X = -0.53471423     -0.35283557      0.13437970    , d:   0.0000000     -0.10502354       1.7773308
 i,j,k,ie:    1    3    1          38
 Near X = -0.47767890     -0.40986726       0.0000000    , d:  0.26888853       0.0000000       1.7773308
 i,j,k,ie:    6    3    1          38
 Near X = -0.47767890     -0.40986726      0.13437970    , d:   0.0000000     -0.14110052       1.7773308
 i,j,k,ie:    1    4    1          38
 Near X = -0.40986953     -0.47767229       0.0000000    , d:  0.29375285       0.0000000       1.7773308
 i,j,k,ie:    6    4    1          38
 Near X = -0.40986953     -0.47767229      0.13437970    , d:   0.0000000     -0.18399248       1.7773308
 i,j,k,ie:    1    5    1          38
 Near X = -0.35283420     -0.53470398       0.0000000    , d:  0.31466655       0.0000000       1.7773308
 i,j,k,ie:    6    5    1          38
 Near X = -0.35283420     -0.53470398      0.13437970    , d:   0.0000000     -0.22006946       1.7773308
 i,j,k,ie:    1    6    1          38
 Near X = -0.32490697     -0.56262942       0.0000000    , d:  0.64981707       0.0000000       1.7773308
 i,j,k,ie:    2    6    1          38
 Near X = -0.32490697     -0.56262942      0.15785898E-01, d:  0.32490690       0.0000000       1.7773308
 i,j,k,ie:    3    6    1          38
 Near X = -0.32490697     -0.56262942      0.48025188E-01, d:  0.32490690       0.0000000       1.7773308
 i,j,k,ie:    4    6    1          38
 Near X = -0.32490697     -0.56262942      0.86354515E-01, d:  0.32490690       0.0000000       1.7773308
 i,j,k,ie:    5    6    1          38
 Near X = -0.32490697     -0.56262942      0.11859381    , d:  0.32490690       0.0000000       1.7773308
 i,j,k,ie:    6    6    1          38
 Near X = -0.32490697     -0.56262942      0.13437970    , d:  0.64981393     -0.23773448       1.7773308
 i,j,k,ie:    1    1    2          38
 Near X = -0.54736721     -0.31618248       0.0000000    , d:   1.0266769       0.0000000       1.7773308
 i,j,k,ie:    2    1    2          38
 Near X = -0.54736721     -0.31618248      0.15785898E-01, d:  0.54736709       0.0000000       1.7773308
 i,j,k,ie:    3    1    2          38
 Near X = -0.54736721     -0.31618248      0.48025188E-01, d:  0.54736709       0.0000000       1.7773308
 i,j,k,ie:    4    1    2          38
 Near X = -0.54736721     -0.31618248      0.86354515E-01, d:  0.54736709       0.0000000       1.7773308
 i,j,k,ie:    5    1    2          38
 Near X = -0.54736721     -0.31618248      0.11859381    , d:  0.54736709       0.0000000       1.7773308
 i,j,k,ie:    6    1    2          38
 Near X = -0.54736721     -0.31618248      0.13437970    , d:  0.54736709     -0.85011925E-01   1.7773308
 i,j,k,ie:    1    2    2          38
 Near X = -0.52079091     -0.34392009       0.0000000    , d:  0.24153302       0.0000000       1.7773308
 i,j,k,ie:    6    2    2          38
 Near X = -0.52079091     -0.34392009      0.13437970    , d:   0.0000000     -0.10240843       1.7773308
 i,j,k,ie:    1    3    2          38
 Near X = -0.46603376     -0.40008739       0.0000000    , d:  0.26236855       0.0000000       1.7773308
 i,j,k,ie:    6    3    2          38
 Near X = -0.46603376     -0.40008739      0.13437970    , d:   0.0000000     -0.13775061       1.7773308
 i,j,k,ie:    1    4    2          38
 Near X = -0.40009299     -0.46602487       0.0000000    , d:  0.28661335       0.0000000       1.7773308
 i,j,k,ie:    6    4    2          38
 Near X = -0.40009299     -0.46602487      0.13437970    , d:   0.0000000     -0.17944331       1.7773308
 i,j,k,ie:    1    5    2          38
 Near X = -0.34392286     -0.52077931       0.0000000    , d:  0.30656305       0.0000000       1.7773308
 i,j,k,ie:    6    5    2          38
 Near X = -0.34392286     -0.52077931      0.13437970    , d:   0.0000000     -0.21423765       1.7773308
 i,j,k,ie:    1    6    2          38
 Near X = -0.31618386     -0.54735430       0.0000000    , d:  0.63236630       0.0000000       1.7773308
 i,j,k,ie:    2    6    2          38
 Near X = -0.31618386     -0.54735430      0.15785898E-01, d:  0.31618378       0.0000000       1.7773308
 i,j,k,ie:    3    6    2          38
 Near X = -0.31618386     -0.54735430      0.48025188E-01, d:  0.31618378       0.0000000       1.7773308
 i,j,k,ie:    4    6    2          38
 Near X = -0.31618386     -0.54735430      0.86354515E-01, d:  0.31618378       0.0000000       1.7773308
 i,j,k,ie:    5    6    2          38
 Near X = -0.31618386     -0.54735430      0.11859381    , d:  0.31618378       0.0000000       1.7773308
 i,j,k,ie:    6    6    2          38
 Near X = -0.31618386     -0.54735430      0.13437970    , d:  0.63236770     -0.23118335       1.7773308
 i,j,k,ie:    1    1    3          38
 Near X = -0.51617285     -0.29835815       0.0000000    , d:  0.95350960       0.0000000       1.7773308
 i,j,k,ie:    2    1    3          38
 Near X = -0.51617285     -0.29835815      0.15785898E-01, d:  0.51617275       0.0000000       1.7773308
 i,j,k,ie:    3    1    3          38
 Near X = -0.51617285     -0.29835815      0.48025188E-01, d:  0.51617275       0.0000000       1.7773308
 i,j,k,ie:    4    1    3          38
 Near X = -0.51617285     -0.29835815      0.86354515E-01, d:  0.51617275       0.0000000       1.7773308
 i,j,k,ie:    5    1    3          38
 Near X = -0.51617285     -0.29835815      0.11859381    , d:  0.51617275       0.0000000       1.7773308
 i,j,k,ie:    6    1    3          38
 Near X = -0.51617285     -0.29835815      0.13437970    , d:  0.51617275     -0.80219498E-01   1.7773308
 i,j,k,ie:    1    2    3          38
 Near X = -0.49235554     -0.32571212       0.0000000    , d:  0.22837701       0.0000000       1.7773308
 i,j,k,ie:    6    2    3          38
 Near X = -0.49235554     -0.32571212      0.13437970    , d:   0.0000000     -0.97067620E-01   1.7773308
 i,j,k,ie:    1    3    3          38
 Near X = -0.44225110     -0.38011411       0.0000000    , d:  0.24905290       0.0000000       1.7773308
 i,j,k,ie:    6    3    3          38
 Near X = -0.44225110     -0.38011411      0.13437970    , d:   0.0000000     -0.13090914       1.7773308
 i,j,k,ie:    1    4    3          38
 Near X = -0.38012651     -0.44223754       0.0000000    , d:  0.27203247       0.0000000       1.7773308
 i,j,k,ie:    6    4    3          38
 Near X = -0.38012651     -0.44223754      0.13437970    , d:   0.0000000     -0.17015260       1.7773308
 i,j,k,ie:    1    5    3          38
 Near X = -0.32572337     -0.49234118       0.0000000    , d:  0.29001340       0.0000000       1.7773308
 i,j,k,ie:    6    5    3          38
 Near X = -0.32572337     -0.49234118      0.13437970    , d:   0.0000000     -0.20232744       1.7773308
 i,j,k,ie:    1    6    3          38
 Near X = -0.29836877     -0.51615816       0.0000000    , d:  0.59672688       0.0000000       1.7773308
 i,j,k,ie:    2    6    3          38
 Near X = -0.29836877     -0.51615816      0.15785898E-01, d:  0.29836870       0.0000000       1.7773308
 i,j,k,ie:    3    6    3          38
 Near X = -0.29836877     -0.51615816      0.48025188E-01, d:  0.29836870       0.0000000       1.7773308
 i,j,k,ie:    4    6    3          38
 Near X = -0.29836877     -0.51615816      0.86354515E-01, d:  0.29836870       0.0000000       1.7773308
 i,j,k,ie:    5    6    3          38
 Near X = -0.29836877     -0.51615816      0.11859381    , d:  0.29836870       0.0000000       1.7773308
 i,j,k,ie:    6    6    3          38
 Near X = -0.29836877     -0.51615816      0.13437970    , d:  0.59673753     -0.21780408       1.7773308
 i,j,k,ie:    1    1    4          38
 Near X = -0.47908585     -0.27716677       0.0000000    , d:  0.86652089       0.0000000       1.7773308
 i,j,k,ie:    2    1    4          38
 Near X = -0.47908585     -0.27716677      0.15785898E-01, d:  0.47908576       0.0000000       1.7773308
 i,j,k,ie:    3    1    4          38
 Near X = -0.47908585     -0.27716677      0.48025188E-01, d:  0.47908576       0.0000000       1.7773308
 i,j,k,ie:    4    1    4          38
 Near X = -0.47908585     -0.27716677      0.86354515E-01, d:  0.47908576       0.0000000       1.7773308
 i,j,k,ie:    5    1    4          38
 Near X = -0.47908585     -0.27716677      0.11859381    , d:  0.47908576       0.0000000       1.7773308
 i,j,k,ie:    6    1    4          38
 Near X = -0.47908585     -0.27716677      0.13437970    , d:  0.47908576     -0.74521777E-01   1.7773308
 i,j,k,ie:    1    2    4          38
 Near X = -0.45854870     -0.30406466       0.0000000    , d:  0.21273581       0.0000000       1.7773308
 i,j,k,ie:    6    2    4          38
 Near X = -0.45854870     -0.30406466      0.13437970    , d:   0.0000000     -0.90717930E-01   1.7773308
 i,j,k,ie:    1    3    4          38
 Near X = -0.41397586     -0.35636786       0.0000000    , d:  0.23322192       0.0000000       1.7773308
 i,j,k,ie:    6    3    4          38
 Near X = -0.41397586     -0.35636786      0.13437970    , d:   0.0000000     -0.12277532       1.7773308
 i,j,k,ie:    1    4    4          38
 Near X = -0.35638834     -0.41395676       0.0000000    , d:  0.25469725       0.0000000       1.7773308
 i,j,k,ie:    6    4    4          38
 Near X = -0.35638834     -0.41395676      0.13437970    , d:   0.0000000     -0.15910687       1.7773308
 i,j,k,ie:    1    5    4          38
 Near X = -0.30408598     -0.45853107       0.0000000    , d:  0.27033751       0.0000000       1.7773308
 i,j,k,ie:    6    5    4          38
 Near X = -0.30408598     -0.45853107      0.13437970    , d:   0.0000000     -0.18816737       1.7773308
 i,j,k,ie:    1    6    4          38
 Near X = -0.27718840     -0.47906904       0.0000000    , d:  0.55435514       0.0000000       1.7773308
 i,j,k,ie:    2    6    4          38
 Near X = -0.27718840     -0.47906904      0.15785898E-01, d:  0.27718834       0.0000000       1.7773308
 i,j,k,ie:    3    6    4          38
 Near X = -0.27718840     -0.47906904      0.48025188E-01, d:  0.27718834       0.0000000       1.7773308
 i,j,k,ie:    4    6    4          38
 Near X = -0.27718840     -0.47906904      0.86354515E-01, d:  0.27718834       0.0000000       1.7773308
 i,j,k,ie:    5    6    4          38
 Near X = -0.27718840     -0.47906904      0.11859381    , d:  0.27718834       0.0000000       1.7773308
 i,j,k,ie:    6    6    4          38
 Near X = -0.27718840     -0.47906904      0.13437970    , d:  0.55437679     -0.20189745       1.7773308
 i,j,k,ie:    1    1    5          38
 Near X = -0.44789150     -0.25934243       0.0000000    , d:  0.79335356       0.0000000       1.7773308
 i,j,k,ie:    2    1    5          38
 Near X = -0.44789150     -0.25934243      0.15785898E-01, d:  0.44789142       0.0000000       1.7773308
 i,j,k,ie:    3    1    5          38
 Near X = -0.44789150     -0.25934243      0.48025188E-01, d:  0.44789142       0.0000000       1.7773308
 i,j,k,ie:    4    1    5          38
 Near X = -0.44789150     -0.25934243      0.86354515E-01, d:  0.44789142       0.0000000       1.7773308
 i,j,k,ie:    5    1    5          38
 Near X = -0.44789150     -0.25934243      0.11859381    , d:  0.44789142       0.0000000       1.7773308
 i,j,k,ie:    6    1    5          38
 Near X = -0.44789150     -0.25934243      0.13437970    , d:  0.44789142     -0.69729350E-01   1.7773308
 i,j,k,ie:    1    2    5          38
 Near X = -0.43011333     -0.28585670       0.0000000    , d:  0.19957980       0.0000000       1.7773308
 i,j,k,ie:    6    2    5          38
 Near X = -0.43011333     -0.28585670      0.13437970    , d:   0.0000000     -0.85377123E-01   1.7773308
 i,j,k,ie:    1    3    5          38
 Near X = -0.39019319     -0.33639459       0.0000000    , d:  0.21990627       0.0000000       1.7773308
 i,j,k,ie:    6    3    5          38
 Near X = -0.39019319     -0.33639459      0.13437970    , d:   0.0000000     -0.11593385       1.7773308
 i,j,k,ie:    1    4    5          38
 Near X = -0.33642186     -0.39016942       0.0000000    , d:  0.24011637       0.0000000       1.7773308
 i,j,k,ie:    6    4    5          38
 Near X = -0.33642186     -0.39016942      0.13437970    , d:   0.0000000     -0.14981617       1.7773308
 i,j,k,ie:    1    5    5          38
 Near X = -0.28588650     -0.43009294       0.0000000    , d:  0.25378786       0.0000000       1.7773308
 i,j,k,ie:    6    5    5          38
 Near X = -0.28588650     -0.43009294      0.13437970    , d:   0.0000000     -0.17625715       1.7773308
 i,j,k,ie:    1    6    5          38
 Near X = -0.25937332     -0.44787291       0.0000000    , d:  0.51871572       0.0000000       1.7773308
 i,j,k,ie:    2    6    5          38
 Near X = -0.25937332     -0.44787291      0.15785898E-01, d:  0.25937326       0.0000000       1.7773308
 i,j,k,ie:    3    6    5          38
 Near X = -0.25937332     -0.44787291      0.48025188E-01, d:  0.25937326       0.0000000       1.7773308
 i,j,k,ie:    4    6    5          38
 Near X = -0.25937332     -0.44787291      0.86354515E-01, d:  0.25937326       0.0000000       1.7773308
 i,j,k,ie:    5    6    5          38
 Near X = -0.25937332     -0.44787291      0.11859381    , d:  0.25937326       0.0000000       1.7773308
 i,j,k,ie:    6    6    5          38
 Near X = -0.25937332     -0.44787291      0.13437970    , d:  0.51874663     -0.18851818       1.7773308
 i,j,k,ie:    1    1    6          38
 Near X = -0.43261725     -0.25061478       0.0000000    , d:  0.93247895     -0.13002420       1.7773308
 i,j,k,ie:    2    1    6          38
 Near X = -0.43261725     -0.25061478      0.15785898E-01, d:  0.43261717     -0.13002420       1.7773308
 i,j,k,ie:    3    1    6          38
 Near X = -0.43261725     -0.25061478      0.48025188E-01, d:  0.43261717     -0.13002420       1.7773308
 i,j,k,ie:    4    1    6          38
 Near X = -0.43261725     -0.25061478      0.86354515E-01, d:  0.43261717     -0.13002420       1.7773308
 i,j,k,ie:    5    1    6          38
 Near X = -0.43261725     -0.25061478      0.11859381    , d:  0.43261717     -0.13002420       1.7773308
 i,j,k,ie:    6    1    6          38
 Near X = -0.43261725     -0.25061478      0.13437970    , d:  0.43261717     -0.21738273       1.7773308
 i,j,k,ie:    1    2    6          38
 Near X = -0.41619002     -0.27694121       0.0000000    , d:  0.19313799     -0.11852421       1.7773308
 i,j,k,ie:    2    2    6          38
 Near X = -0.41619002     -0.27694121      0.15785898E-01, d:   0.0000000     -0.11852421       1.7773308
 i,j,k,ie:    3    2    6          38
 Near X = -0.41619002     -0.27694121      0.48025188E-01, d:   0.0000000     -0.11852421       1.7773308
 i,j,k,ie:    4    2    6          38
 Near X = -0.41619002     -0.27694121      0.86354515E-01, d:   0.0000000     -0.11852421       1.7773308
 i,j,k,ie:    5    2    6          38
 Near X = -0.41619002     -0.27694121      0.11859381    , d:   0.0000000     -0.11852421       1.7773308
 i,j,k,ie:    6    2    6          38
 Near X = -0.41619002     -0.27694121      0.13437970    , d:   0.0000000     -0.22354775       1.7773308
 i,j,k,ie:    1    3    6          38
 Near X = -0.37854806     -0.32661472       0.0000000    , d:  0.21338629     -0.99130840E-01   1.7773308
 i,j,k,ie:    2    3    6          38
 Near X = -0.37854806     -0.32661472      0.15785898E-01, d:   0.0000000     -0.99130840E-01   1.7773308
 i,j,k,ie:    3    3    6          38
 Near X = -0.37854806     -0.32661472      0.48025188E-01, d:   0.0000000     -0.99130840E-01   1.7773308
 i,j,k,ie:    4    3    6          38
 Near X = -0.37854806     -0.32661472      0.86354515E-01, d:   0.0000000     -0.99130840E-01   1.7773308
 i,j,k,ie:    5    3    6          38
 Near X = -0.37854806     -0.32661472      0.11859381    , d:   0.0000000     -0.99130840E-01   1.7773308
 i,j,k,ie:    6    3    6          38
 Near X = -0.37854806     -0.32661472      0.13437970    , d:   0.0000000     -0.24023136       1.7773308
 i,j,k,ie:    1    4    6          38
 Near X = -0.32664532     -0.37852201       0.0000000    , d:  0.23297688     -0.83224211E-01   1.7773308
 i,j,k,ie:    2    4    6          38
 Near X = -0.32664532     -0.37852201      0.15785898E-01, d:   0.0000000     -0.83224211E-01   1.7773308
 i,j,k,ie:    3    4    6          38
 Near X = -0.32664532     -0.37852201      0.48025188E-01, d:   0.0000000     -0.83224211E-01   1.7773308
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    4    4    6          38
 Near X = -0.32664532     -0.37852201      0.86354515E-01, d:   0.0000000     -0.83224211E-01   1.7773308
 i,j,k,ie:    5    4    6          38
 Near X = -0.32664532     -0.37852201      0.11859381    , d:   0.0000000     -0.83224211E-01   1.7773308
 i,j,k,ie:    6    4    6          38
 Near X = -0.32664532     -0.37852201      0.13437970    , d:   0.0000000     -0.26721669       1.7773308
 i,j,k,ie:    1    5    6          38
 Near X = -0.27697516     -0.41616828       0.0000000    , d:  0.24568436     -0.75859042E-01   1.7773308
 i,j,k,ie:    2    5    6          38
 Near X = -0.27697516     -0.41616828      0.15785898E-01, d:   0.0000000     -0.75859042E-01   1.7773308
 i,j,k,ie:    3    5    6          38
 Near X = -0.27697516     -0.41616828      0.48025188E-01, d:   0.0000000     -0.75859042E-01   1.7773308
 i,j,k,ie:    4    5    6          38
 Near X = -0.27697516     -0.41616828      0.86354515E-01, d:   0.0000000     -0.75859042E-01   1.7773308
 i,j,k,ie:    5    5    6          38
 Near X = -0.27697516     -0.41616828      0.11859381    , d:   0.0000000     -0.75859042E-01   1.7773308
 i,j,k,ie:    6    5    6          38
 Near X = -0.27697516     -0.41616828      0.13437970    , d:   0.0000000     -0.29592851       1.7773308
 i,j,k,ie:    1    6    6          38
 Near X = -0.25065020     -0.43259779       0.0000000    , d:  0.57556030     -0.74256770E-01   1.7773308
 i,j,k,ie:    2    6    6          38
 Near X = -0.25065020     -0.43259779      0.15785898E-01, d:  0.25065014     -0.74256770E-01   1.7773308
 i,j,k,ie:    3    6    6          38
 Near X = -0.25065020     -0.43259779      0.48025188E-01, d:  0.25065014     -0.74256770E-01   1.7773308
 i,j,k,ie:    4    6    6          38
 Near X = -0.25065020     -0.43259779      0.86354515E-01, d:  0.25065014     -0.74256770E-01   1.7773308
 i,j,k,ie:    5    6    6          38
 Near X = -0.25065020     -0.43259779      0.11859381    , d:  0.25065014     -0.74256770E-01   1.7773308
 i,j,k,ie:    6    6    6          38
 Near X = -0.25065020     -0.43259779      0.13437970    , d:  0.57555716     -0.31199125       1.7773308
 i,j,k,ie:    1    1    1          39
 Near X = -0.64999998     -0.15920408E-15   0.0000000    , d:  0.64999986       0.0000000       1.5384616
 i,j,k,ie:    2    1    1          39
 Near X = -0.64999998     -0.15920408E-15  0.15785898E-01, d:  0.15014308       0.0000000       1.5384616
 i,j,k,ie:    3    1    1          39
 Near X = -0.64999998     -0.15920408E-15  0.48025188E-01, d:  0.15014308       0.0000000       1.5384616
 i,j,k,ie:    4    1    1          39
 Near X = -0.64999998     -0.15920408E-15  0.86354515E-01, d:  0.15014308       0.0000000       1.5384616
 i,j,k,ie:    5    1    1          39
 Near X = -0.64999998     -0.15920408E-15  0.11859381    , d:  0.15014308       0.0000000       1.5384616
 i,j,k,ie:    6    1    1          39
 Near X = -0.64999998     -0.15920408E-15  0.13437970    , d:   1.2126294     -0.21560229       1.5384616
 i,j,k,ie:    1    2    1          39
 Near X = -0.63973777     -0.38167953E-01   0.0000000    , d:  0.10502354       0.0000000       1.5384616
 i,j,k,ie:    6    2    1          39
 Near X = -0.63973777     -0.38167953E-01  0.13437970    , d:   1.2126308       0.0000000       1.5384616
 i,j,k,ie:    1    3    1          39
 Near X = -0.61877942     -0.11611776       0.0000000    , d:  0.14110052       0.0000000       1.5384616
 i,j,k,ie:    6    3    1          39
 Near X = -0.61877942     -0.11611776      0.13437970    , d:   1.2126337       0.0000000       1.5384616
 i,j,k,ie:    1    4    1          39
 Near X = -0.59386201     -0.20879237       0.0000000    , d:  0.18399248       0.0000000       1.5384616
 i,j,k,ie:    6    4    1          39
 Near X = -0.59386201     -0.20879237      0.13437970    , d:   1.2126371       0.0000000       1.5384616
 i,j,k,ie:    1    5    1          39
 Near X = -0.57290366     -0.28674218       0.0000000    , d:  0.22006946       0.0000000       1.5384616
 i,j,k,ie:    6    5    1          39
 Near X = -0.57290366     -0.28674218      0.13437970    , d:   1.2126400       0.0000000       1.5384616
 i,j,k,ie:    1    6    1          39
 Near X = -0.56264145     -0.32491013       0.0000000    , d:  0.88754841       0.0000000       1.5384616
 i,j,k,ie:    2    6    1          39
 Near X = -0.56264145     -0.32491013      0.15785898E-01, d:  0.88754841       0.0000000       1.5384616
 i,j,k,ie:    3    6    1          39
 Near X = -0.56264145     -0.32491013      0.48025188E-01, d:  0.88754841       0.0000000       1.5384616
 i,j,k,ie:    4    6    1          39
 Near X = -0.56264145     -0.32491013      0.86354515E-01, d:  0.88754841       0.0000000       1.5384616
 i,j,k,ie:    5    6    1          39
 Near X = -0.56264145     -0.32491013      0.11859381    , d:  0.88754841       0.0000000       1.5384616
 i,j,k,ie:    6    6    1          39
 Near X = -0.56264145     -0.32491013      0.13437970    , d:   1.2126414       0.0000000       1.5384616
 i,j,k,ie:    1    1    2          39
 Near X = -0.63237913     -0.14769511E-15   0.0000000    , d:  0.63237902       0.0000000       1.5384616
 i,j,k,ie:    2    1    2          39
 Near X = -0.63237913     -0.14769511E-15  0.15785898E-01, d:  0.15307400       0.0000000       1.5384616
 i,j,k,ie:    3    1    2          39
 Near X = -0.63237913     -0.14769511E-15  0.48025188E-01, d:  0.15307400       0.0000000       1.5384616
 i,j,k,ie:    4    1    2          39
 Near X = -0.63237913     -0.14769511E-15  0.86354515E-01, d:  0.15307400       0.0000000       1.5384616
 i,j,k,ie:    5    1    2          39
 Near X = -0.63237913     -0.14769511E-15  0.11859381    , d:  0.15307400       0.0000000       1.5384616
 i,j,k,ie:    6    1    2          39
 Near X = -0.63237913     -0.14769511E-15  0.13437970    , d:   1.1797334     -0.19763362       1.5384616
 i,j,k,ie:    1    2    2          39
 Near X = -0.62319934     -0.37359489E-01   0.0000000    , d:  0.10240843       0.0000000       1.5384616
 i,j,k,ie:    6    2    2          39
 Near X = -0.62319934     -0.37359489E-01  0.13437970    , d:   1.1813487       0.0000000       1.5384616
 i,j,k,ie:    1    3    2          39
 Near X = -0.60378438     -0.11347889       0.0000000    , d:  0.13775061       0.0000000       1.5384616
 i,j,k,ie:    6    3    2          39
 Near X = -0.60378438     -0.11347889      0.13437970    , d:   1.1833129       0.0000000       1.5384616
 i,j,k,ie:    1    4    2          39
 Near X = -0.57953630     -0.20366410       0.0000000    , d:  0.17944331       0.0000000       1.5384616
 i,j,k,ie:    6    4    2          39
 Near X = -0.57953630     -0.20366410      0.13437970    , d:   1.1833165       0.0000000       1.5384616
 i,j,k,ie:    1    5    2          39
 Near X = -0.55816051     -0.27925658       0.0000000    , d:  0.21423765       0.0000000       1.5384616
 i,j,k,ie:    6    5    2          39
 Near X = -0.55816051     -0.27925658      0.13437970    , d:   1.1813585       0.0000000       1.5384616
 i,j,k,ie:    1    6    2          39
 Near X = -0.54736721     -0.31618248       0.0000000    , d:  0.86355105       0.0000000       1.5384616
 i,j,k,ie:    2    6    2          39
 Near X = -0.54736721     -0.31618248      0.15785898E-01, d:  0.86355105       0.0000000       1.5384616
 i,j,k,ie:    3    6    2          39
 Near X = -0.54736721     -0.31618248      0.48025188E-01, d:  0.86355105       0.0000000       1.5384616
 i,j,k,ie:    4    6    2          39
 Near X = -0.54736721     -0.31618248      0.86354515E-01, d:  0.86355105       0.0000000       1.5384616
 i,j,k,ie:    5    6    2          39
 Near X = -0.54736721     -0.31618248      0.11859381    , d:  0.86355105       0.0000000       1.5384616
 i,j,k,ie:    6    6    2          39
 Near X = -0.54736721     -0.31618248      0.13437970    , d:   1.1797463       0.0000000       1.5384616
 i,j,k,ie:    1    1    3          39
 Near X = -0.59639235     -0.12419052E-15   0.0000000    , d:  0.59639225       0.0000000       1.5384616
 i,j,k,ie:    2    1    3          39
 Near X = -0.59639235     -0.12419052E-15  0.15785898E-01, d:  0.15905979       0.0000000       1.5384616
 i,j,k,ie:    3    1    3          39
 Near X = -0.59639235     -0.12419052E-15  0.48025188E-01, d:  0.15905979       0.0000000       1.5384616
 i,j,k,ie:    4    1    3          39
 Near X = -0.59639235     -0.12419052E-15  0.86354515E-01, d:  0.15905979       0.0000000       1.5384616
 i,j,k,ie:    5    1    3          39
 Near X = -0.59639235     -0.12419052E-15  0.11859381    , d:  0.15905979       0.0000000       1.5384616
 i,j,k,ie:    6    1    3          39
 Near X = -0.59639235     -0.12419052E-15  0.13437970    , d:   1.1125505     -0.16093650       1.5384616
 i,j,k,ie:    1    2    3          39
 Near X = -0.58942316     -0.35708376E-01   0.0000000    , d:  0.97067620E-01   0.0000000       1.5384616
 i,j,k,ie:    6    2    3          39
 Near X = -0.58942316     -0.35708376E-01  0.13437970    , d:   1.1174617       0.0000000       1.5384616
 i,j,k,ie:    1    3    3          39
 Near X = -0.57316024     -0.10808956       0.0000000    , d:  0.13090914       0.0000000       1.5384616
 i,j,k,ie:    6    3    3          39
 Near X = -0.57316024     -0.10808956      0.13437970    , d:   1.1234314       0.0000000       1.5384616
 i,j,k,ie:    1    4    3          39
 Near X = -0.55027911     -0.19319071       0.0000000    , d:  0.17015260       0.0000000       1.5384616
 i,j,k,ie:    6    4    3          39
 Near X = -0.55027911     -0.19319071      0.13437970    , d:   1.1234356       0.0000000       1.5384616
 i,j,k,ie:    1    5    3          39
 Near X = -0.52805081     -0.26396886       0.0000000    , d:  0.20232744       0.0000000       1.5384616
 i,j,k,ie:    6    5    3          39
 Near X = -0.52805081     -0.26396886      0.13437970    , d:   1.1174729       0.0000000       1.5384616
 i,j,k,ie:    1    6    3          39
 Near X = -0.51617285     -0.29835815       0.0000000    , d:  0.81454161       0.0000000       1.5384616
 i,j,k,ie:    2    6    3          39
 Near X = -0.51617285     -0.29835815      0.15785898E-01, d:  0.81454161       0.0000000       1.5384616
 i,j,k,ie:    3    6    3          39
 Near X = -0.51617285     -0.29835815      0.48025188E-01, d:  0.81454161       0.0000000       1.5384616
 i,j,k,ie:    4    6    3          39
 Near X = -0.51617285     -0.29835815      0.86354515E-01, d:  0.81454161       0.0000000       1.5384616
 i,j,k,ie:    5    6    3          39
 Near X = -0.51617285     -0.29835815      0.11859381    , d:  0.81454161       0.0000000       1.5384616
 i,j,k,ie:    6    6    3          39
 Near X = -0.51617285     -0.29835815      0.13437970    , d:   1.1125652       0.0000000       1.5384616
 i,j,k,ie:    1    1    4          39
 Near X = -0.55360763     -0.96245897E-16   0.0000000    , d:  0.55360754       0.0000000       1.5384616
 i,j,k,ie:    2    1    4          39
 Near X = -0.55360763     -0.96245897E-16  0.15785898E-01, d:  0.16617631       0.0000000       1.5384616
 i,j,k,ie:    3    1    4          39
 Near X = -0.55360763     -0.96245897E-16  0.48025188E-01, d:  0.16617631       0.0000000       1.5384616
 i,j,k,ie:    4    1    4          39
 Near X = -0.55360763     -0.96245897E-16  0.86354515E-01, d:  0.16617631       0.0000000       1.5384616
 i,j,k,ie:    5    1    4          39
 Near X = -0.55360763     -0.96245897E-16  0.11859381    , d:  0.16617631       0.0000000       1.5384616
 i,j,k,ie:    6    1    4          39
 Near X = -0.55360763     -0.96245897E-16  0.13437970    , d:   1.0326767     -0.11730725       1.5384616
 i,j,k,ie:    1    2    4          39
 Near X = -0.54926663     -0.33745365E-01   0.0000000    , d:  0.90717930E-01   0.0000000       1.5384616
 i,j,k,ie:    6    2    4          39
 Near X = -0.54926663     -0.33745365E-01  0.13437970    , d:   1.0415063       0.0000000       1.5384616
 i,j,k,ie:    1    3    4          39
 Near X = -0.53675117     -0.10168218       0.0000000    , d:  0.12277532       0.0000000       1.5384616
 i,j,k,ie:    6    3    4          39
 Near X = -0.53675117     -0.10168218      0.13437970    , d:   1.0522382       0.0000000       1.5384616
 i,j,k,ie:    1    4    4          39
 Near X = -0.51549521     -0.18073888       0.0000000    , d:  0.15910687       0.0000000       1.5384616
 i,j,k,ie:    6    4    4          39
 Near X = -0.51549521     -0.18073888      0.13437970    , d:   1.0522430       0.0000000       1.5384616
 i,j,k,ie:    1    5    4          39
 Near X = -0.49225335     -0.24579328       0.0000000    , d:  0.18816737       0.0000000       1.5384616
 i,j,k,ie:    6    5    4          39
 Near X = -0.49225335     -0.24579328      0.13437970    , d:   1.0415192       0.0000000       1.5384616
 i,j,k,ie:    1    6    4          39
 Near X = -0.47908585     -0.27716677       0.0000000    , d:  0.75627424       0.0000000       1.5384616
 i,j,k,ie:    2    6    4          39
 Near X = -0.47908585     -0.27716677      0.15785898E-01, d:  0.75627424       0.0000000       1.5384616
 i,j,k,ie:    3    6    4          39
 Near X = -0.47908585     -0.27716677      0.48025188E-01, d:  0.75627424       0.0000000       1.5384616
 i,j,k,ie:    4    6    4          39
 Near X = -0.47908585     -0.27716677      0.86354515E-01, d:  0.75627424       0.0000000       1.5384616
 i,j,k,ie:    5    6    4          39
 Near X = -0.47908585     -0.27716677      0.11859381    , d:  0.75627424       0.0000000       1.5384616
 i,j,k,ie:    6    6    4          39
 Near X = -0.47908585     -0.27716677      0.13437970    , d:   1.0326935       0.0000000       1.5384616
 i,j,k,ie:    1    1    5          39
 Near X = -0.51762085     -0.72741312E-16   0.0000000    , d:  0.51762077       0.0000000       1.5384616
 i,j,k,ie:    2    1    5          39
 Near X = -0.51762085     -0.72741312E-16  0.15785898E-01, d:  0.17216210       0.0000000       1.5384616
 i,j,k,ie:    3    1    5          39
 Near X = -0.51762085     -0.72741312E-16  0.48025188E-01, d:  0.17216210       0.0000000       1.5384616
 i,j,k,ie:    4    1    5          39
 Near X = -0.51762085     -0.72741312E-16  0.86354515E-01, d:  0.17216210       0.0000000       1.5384616
 i,j,k,ie:    5    1    5          39
 Near X = -0.51762085     -0.72741312E-16  0.11859381    , d:  0.17216210       0.0000000       1.5384616
 i,j,k,ie:    6    1    5          39
 Near X = -0.51762085     -0.72741312E-16  0.13437970    , d:  0.96549375     -0.80610120E-01   1.5384616
 i,j,k,ie:    1    2    5          39
 Near X = -0.51549045     -0.32094252E-01   0.0000000    , d:  0.85377123E-01   0.0000000       1.5384616
 i,j,k,ie:    6    2    5          39
 Near X = -0.51549045     -0.32094252E-01  0.13437970    , d:  0.97761931       0.0000000       1.5384616
 i,j,k,ie:    1    3    5          39
 Near X = -0.50612704     -0.96292855E-01   0.0000000    , d:  0.11593385       0.0000000       1.5384616
 i,j,k,ie:    6    3    5          39
 Near X = -0.50612704     -0.96292855E-01  0.13437970    , d:  0.99235672       0.0000000       1.5384616
 i,j,k,ie:    1    4    5          39
 Near X = -0.48623803     -0.17026549       0.0000000    , d:  0.14981617       0.0000000       1.5384616
 i,j,k,ie:    6    4    5          39
 Near X = -0.48623803     -0.17026549      0.13437970    , d:  0.99236203       0.0000000       1.5384616
 i,j,k,ie:    1    5    5          39
 Near X = -0.46214364     -0.23050556       0.0000000    , d:  0.17625715       0.0000000       1.5384616
 i,j,k,ie:    6    5    5          39
 Near X = -0.46214364     -0.23050556      0.13437970    , d:  0.97763354       0.0000000       1.5384616
 i,j,k,ie:    1    6    5          39
 Near X = -0.44789150     -0.25934243       0.0000000    , d:  0.70726480       0.0000000       1.5384616
 i,j,k,ie:    2    6    5          39
 Near X = -0.44789150     -0.25934243      0.15785898E-01, d:  0.70726480       0.0000000       1.5384616
 i,j,k,ie:    3    6    5          39
 Near X = -0.44789150     -0.25934243      0.48025188E-01, d:  0.70726480       0.0000000       1.5384616
 i,j,k,ie:    4    6    5          39
 Near X = -0.44789150     -0.25934243      0.86354515E-01, d:  0.70726480       0.0000000       1.5384616
 i,j,k,ie:    5    6    5          39
 Near X = -0.44789150     -0.25934243      0.11859381    , d:  0.70726480       0.0000000       1.5384616
 i,j,k,ie:    6    6    5          39
 Near X = -0.44789150     -0.25934243      0.13437970    , d:  0.96551235       0.0000000       1.5384616
 i,j,k,ie:    1    1    6          39
 Near X = -0.50000000     -0.61232343E-16   0.0000000    , d:  0.49999992     -0.14999998       1.5384616
 i,j,k,ie:    2    1    6          39
 Near X = -0.50000000     -0.61232343E-16  0.15785898E-01, d:  0.17509303     -0.14999998       1.5384616
 i,j,k,ie:    3    1    6          39
 Near X = -0.50000000     -0.61232343E-16  0.48025188E-01, d:  0.17509303     -0.14999998       1.5384616
 i,j,k,ie:    4    1    6          39
 Near X = -0.50000000     -0.61232343E-16  0.86354515E-01, d:  0.17509303     -0.14999998       1.5384616
 i,j,k,ie:    5    1    6          39
 Near X = -0.50000000     -0.61232343E-16  0.11859381    , d:  0.17509303     -0.14999998       1.5384616
 i,j,k,ie:    6    1    6          39
 Near X = -0.50000000     -0.61232343E-16  0.13437970    , d:   1.0626294     -0.36560227       1.5384616
 i,j,k,ie:    1    2    6          39
 Near X = -0.49895202     -0.31285788E-01   0.0000000    , d:  0.82762009E-01 -0.14078574       1.5384616
 i,j,k,ie:    2    2    6          39
 Near X = -0.49895202     -0.31285788E-01  0.15785898E-01, d:   0.0000000     -0.14078574       1.5384616
 i,j,k,ie:    3    2    6          39
 Near X = -0.49895202     -0.31285788E-01  0.48025188E-01, d:   0.0000000     -0.14078574       1.5384616
 i,j,k,ie:    4    2    6          39
 Near X = -0.49895202     -0.31285788E-01  0.86354515E-01, d:   0.0000000     -0.14078574       1.5384616
 i,j,k,ie:    5    2    6          39
 Near X = -0.49895202     -0.31285788E-01  0.11859381    , d:   0.0000000     -0.14078574       1.5384616
 i,j,k,ie:    6    2    6          39
 Near X = -0.49895202     -0.31285788E-01  0.13437970    , d:   1.0718451     -0.14078574       1.5384616
 i,j,k,ie:    1    3    6          39
 Near X = -0.49113199     -0.93653983E-01   0.0000000    , d:  0.11258394     -0.12764742       1.5384616
 i,j,k,ie:    2    3    6          39
 Near X = -0.49113199     -0.93653983E-01  0.15785898E-01, d:   0.0000000     -0.12764742       1.5384616
 i,j,k,ie:    3    3    6          39
 Near X = -0.49113199     -0.93653983E-01  0.48025188E-01, d:   0.0000000     -0.12764742       1.5384616
 i,j,k,ie:    4    3    6          39
 Near X = -0.49113199     -0.93653983E-01  0.86354515E-01, d:   0.0000000     -0.12764742       1.5384616
 i,j,k,ie:    5    3    6          39
 Near X = -0.49113199     -0.93653983E-01  0.11859381    , d:   0.0000000     -0.12764742       1.5384616
 i,j,k,ie:    6    3    6          39
 Near X = -0.49113199     -0.93653983E-01  0.13437970    , d:   1.0849863     -0.12764742       1.5384616
 i,j,k,ie:    1    4    6          39
 Near X = -0.47191231     -0.16513722       0.0000000    , d:  0.14526699     -0.12194970       1.5384616
 i,j,k,ie:    2    4    6          39
 Near X = -0.47191231     -0.16513722      0.15785898E-01, d:   0.0000000     -0.12194970       1.5384616
 i,j,k,ie:    3    4    6          39
 Near X = -0.47191231     -0.16513722      0.48025188E-01, d:   0.0000000     -0.12194970       1.5384616
 i,j,k,ie:    4    4    6          39
 Near X = -0.47191231     -0.16513722      0.86354515E-01, d:   0.0000000     -0.12194970       1.5384616
 i,j,k,ie:    5    4    6          39
 Near X = -0.47191231     -0.16513722      0.11859381    , d:   0.0000000     -0.12194970       1.5384616
 i,j,k,ie:    6    4    6          39
 Near X = -0.47191231     -0.16513722      0.13437970    , d:   1.0906874     -0.12194970       1.5384616
 i,j,k,ie:    1    5    6          39
 Near X = -0.44740049     -0.22301996       0.0000000    , d:  0.17042534     -0.12550317       1.5384616
 i,j,k,ie:    2    5    6          39
 Near X = -0.44740049     -0.22301996      0.15785898E-01, d:   0.0000000     -0.12550317       1.5384616
 i,j,k,ie:    3    5    6          39
 Near X = -0.44740049     -0.22301996      0.48025188E-01, d:   0.0000000     -0.12550317       1.5384616
 i,j,k,ie:    4    5    6          39
 Near X = -0.44740049     -0.22301996      0.86354515E-01, d:   0.0000000     -0.12550317       1.5384616
 i,j,k,ie:    5    5    6          39
 Near X = -0.44740049     -0.22301996      0.11859381    , d:   0.0000000     -0.12550317       1.5384616
 i,j,k,ie:    6    5    6          39
 Near X = -0.44740049     -0.22301996      0.13437970    , d:   1.0871368     -0.12550317       1.5384616
 i,j,k,ie:    1    6    6          39
 Near X = -0.43261725     -0.25061478       0.0000000    , d:  0.75752421     -0.13002420       1.5384616
 i,j,k,ie:    2    6    6          39
 Near X = -0.43261725     -0.25061478      0.15785898E-01, d:  0.75752421     -0.13002420       1.5384616
 i,j,k,ie:    3    6    6          39
 Near X = -0.43261725     -0.25061478      0.48025188E-01, d:  0.75752421     -0.13002420       1.5384616
 i,j,k,ie:    4    6    6          39
 Near X = -0.43261725     -0.25061478      0.86354515E-01, d:  0.75752421     -0.13002420       1.5384616
 i,j,k,ie:    5    6    6          39
 Near X = -0.43261725     -0.25061478      0.11859381    , d:  0.75752421     -0.13002420       1.5384616
 i,j,k,ie:    6    6    6          39
 Near X = -0.43261725     -0.25061478      0.13437970    , d:   1.0826172     -0.13002420       1.5384616
 i,j,k,ie:    1    1    1          40
 Near X =  0.56262941     -0.32490697       0.0000000    , d:   0.0000000      -1.4282317       1.5384616
 i,j,k,ie:    2    1    1          40
 Near X =  0.56262941     -0.32490697      0.15785898E-01, d:   0.0000000      -1.4282317       1.5384616
 i,j,k,ie:    3    1    1          40
 Near X =  0.56262941     -0.32490697      0.48025188E-01, d:   0.0000000      -1.4282317       1.5384616
 i,j,k,ie:    4    1    1          40
 Near X =  0.56262941     -0.32490697      0.86354515E-01, d:   0.0000000      -1.4282317       1.5384616
 i,j,k,ie:    5    1    1          40
 Near X =  0.56262941     -0.32490697      0.11859381    , d:   0.0000000      -1.4282317       1.5384616
 i,j,k,ie:    6    1    1          40
 Near X =  0.56262941     -0.32490697      0.13437970    , d:   0.0000000      -1.4282317       1.5384616
 i,j,k,ie:    1    2    1          40
 Near X =  0.57289303     -0.28673939       0.0000000    , d:   0.0000000      -1.2126308       1.5384616
 i,j,k,ie:    1    3    1          40
 Near X =  0.59385427     -0.20879035       0.0000000    , d:   0.0000000      -1.2126337       1.5384616
 i,j,k,ie:    1    4    1          40
 Near X =  0.61877511     -0.11611665       0.0000000    , d:   0.0000000      -1.2126371       1.5384616
 i,j,k,ie:    1    5    1          40
 Near X =  0.63973635     -0.38167613E-01   0.0000000    , d:   0.0000000      -1.2126400       1.5384616
 i,j,k,ie:    1    6    1          40
 Near X =  0.64999998     -0.36515901E-07   0.0000000    , d:   0.0000000      -1.2126414       1.5384616
 i,j,k,ie:    2    6    1          40
 Near X =  0.64999998     -0.36515901E-07  0.15785898E-01, d:   0.0000000     -0.87358516E-01   1.5384616
 i,j,k,ie:    3    6    1          40
 Near X =  0.64999998     -0.36515901E-07  0.48025188E-01, d:   0.0000000     -0.87358516E-01   1.5384616
 i,j,k,ie:    4    6    1          40
 Near X =  0.64999998     -0.36515901E-07  0.86354515E-01, d:   0.0000000     -0.87358516E-01   1.5384616
 i,j,k,ie:    5    6    1          40
 Near X =  0.64999998     -0.36515901E-07  0.11859381    , d:   0.0000000     -0.87358516E-01   1.5384616
 i,j,k,ie:    6    6    1          40
 Near X =  0.64999998     -0.36515901E-07  0.13437970    , d:   0.0000000     -0.87358516E-01   1.5384616
 i,j,k,ie:    1    1    2          40
 Near X =  0.54735429     -0.31618385       0.0000000    , d:   0.0000000      -1.3773670       1.5384616
 i,j,k,ie:    2    1    2          40
 Near X =  0.54735429     -0.31618385      0.15785898E-01, d:   0.0000000      -1.3773670       1.5384616
 i,j,k,ie:    3    1    2          40
 Near X =  0.54735429     -0.31618385      0.48025188E-01, d:   0.0000000      -1.3773670       1.5384616
 i,j,k,ie:    4    1    2          40
 Near X =  0.54735429     -0.31618385      0.86354515E-01, d:   0.0000000      -1.3773670       1.5384616
 i,j,k,ie:    5    1    2          40
 Near X =  0.54735429     -0.31618385      0.11859381    , d:   0.0000000      -1.3773670       1.5384616
 i,j,k,ie:    6    1    2          40
 Near X =  0.54735429     -0.31618385      0.13437970    , d:   0.0000000      -1.3773670       1.5384616
 i,j,k,ie:    1    2    2          40
 Near X =  0.55814933     -0.27925789       0.0000000    , d:   0.0000000      -1.1813487       1.5384616
 i,j,k,ie:    1    3    2          40
 Near X =  0.57952848     -0.20366520       0.0000000    , d:   0.0000000      -1.1833129       1.5384616
 i,j,k,ie:    1    4    2          40
 Near X =  0.60378024     -0.11347961       0.0000000    , d:   0.0000000      -1.1833165       1.5384616
 i,j,k,ie:    1    5    2          40
 Near X =  0.62319804     -0.37359776E-01   0.0000000    , d:   0.0000000      -1.1813585       1.5384616
 i,j,k,ie:    1    6    2          40
 Near X =  0.63237913     -0.36850045E-07   0.0000000    , d:   0.0000000      -1.1797463       1.5384616
 i,j,k,ie:    2    6    2          40
 Near X =  0.63237913     -0.36850045E-07  0.15785898E-01, d:   0.0000000     -0.85011915E-01   1.5384616
 i,j,k,ie:    3    6    2          40
 Near X =  0.63237913     -0.36850045E-07  0.48025188E-01, d:   0.0000000     -0.85011915E-01   1.5384616
 i,j,k,ie:    4    6    2          40
 Near X =  0.63237913     -0.36850045E-07  0.86354515E-01, d:   0.0000000     -0.85011915E-01   1.5384616
 i,j,k,ie:    5    6    2          40
 Near X =  0.63237913     -0.36850045E-07  0.11859381    , d:   0.0000000     -0.85011915E-01   1.5384616
 i,j,k,ie:    6    6    2          40
 Near X =  0.63237913     -0.36850045E-07  0.13437970    , d:   0.0000000     -0.85011915E-01   1.5384616
 i,j,k,ie:    1    1    3          40
 Near X =  0.51615815     -0.29836877       0.0000000    , d:   0.0000000      -1.2734870       1.5384616
 i,j,k,ie:    2    1    3          40
 Near X =  0.51615815     -0.29836877      0.15785898E-01, d:   0.0000000      -1.2734870       1.5384616
 i,j,k,ie:    3    1    3          40
 Near X =  0.51615815     -0.29836877      0.48025188E-01, d:   0.0000000      -1.2734870       1.5384616
 i,j,k,ie:    4    1    3          40
 Near X =  0.51615815     -0.29836877      0.86354515E-01, d:   0.0000000      -1.2734870       1.5384616
 i,j,k,ie:    5    1    3          40
 Near X =  0.51615815     -0.29836877      0.11859381    , d:   0.0000000      -1.2734870       1.5384616
 i,j,k,ie:    6    1    3          40
 Near X =  0.51615815     -0.29836877      0.13437970    , d:   0.0000000      -1.2734870       1.5384616
 i,j,k,ie:    1    2    3          40
 Near X =  0.52803850     -0.26397853       0.0000000    , d:   0.0000000      -1.1174617       1.5384616
 i,j,k,ie:    1    3    3          40
 Near X =  0.55027113     -0.19319818       0.0000000    , d:   0.0000000      -1.1234314       1.5384616
 i,j,k,ie:    1    4    3          40
 Near X =  0.57315645     -0.10809401       0.0000000    , d:   0.0000000      -1.1234356       1.5384616
 i,j,k,ie:    1    5    3          40
 Near X =  0.58942210     -0.35709942E-01   0.0000000    , d:   0.0000000      -1.1174729       1.5384616
 i,j,k,ie:    1    6    3          40
 Near X =  0.59639235     -0.37532464E-07   0.0000000    , d:   0.0000000      -1.1125652       1.5384616
 i,j,k,ie:    2    6    3          40
 Near X =  0.59639235     -0.37532464E-07  0.15785898E-01, d:   0.0000000     -0.80219488E-01   1.5384616
 i,j,k,ie:    3    6    3          40
 Near X =  0.59639235     -0.37532464E-07  0.48025188E-01, d:   0.0000000     -0.80219488E-01   1.5384616
 i,j,k,ie:    4    6    3          40
 Near X =  0.59639235     -0.37532464E-07  0.86354515E-01, d:   0.0000000     -0.80219488E-01   1.5384616
 i,j,k,ie:    5    6    3          40
 Near X =  0.59639235     -0.37532464E-07  0.11859381    , d:   0.0000000     -0.80219488E-01   1.5384616
 i,j,k,ie:    6    6    3          40
 Near X =  0.59639235     -0.37532464E-07  0.13437970    , d:   0.0000000     -0.80219488E-01   1.5384616
 i,j,k,ie:    1    1    4          40
 Near X =  0.47906903     -0.27718840       0.0000000    , d:   0.0000000      -1.1499839       1.5384616
 i,j,k,ie:    2    1    4          40
 Near X =  0.47906903     -0.27718840      0.15785898E-01, d:   0.0000000      -1.1499839       1.5384616
 i,j,k,ie:    3    1    4          40
 Near X =  0.47906903     -0.27718840      0.48025188E-01, d:   0.0000000      -1.1499839       1.5384616
 i,j,k,ie:    4    1    4          40
 Near X =  0.47906903     -0.27718840      0.86354515E-01, d:   0.0000000      -1.1499839       1.5384616
 i,j,k,ie:    5    1    4          40
 Near X =  0.47906903     -0.27718840      0.11859381    , d:   0.0000000      -1.1499839       1.5384616
 i,j,k,ie:    6    1    4          40
 Near X =  0.47906903     -0.27718840      0.13437970    , d:   0.0000000      -1.1499839       1.5384616
 i,j,k,ie:    1    2    4          40
 Near X =  0.49223969     -0.24581289       0.0000000    , d:   0.0000000      -1.0415063       1.5384616
 i,j,k,ie:    1    3    4          40
 Near X =  0.51548703     -0.18075393       0.0000000    , d:   0.0000000      -1.0522382       1.5384616
 i,j,k,ie:    1    4    4          40
 Near X =  0.53674779     -0.10169107       0.0000000    , d:   0.0000000      -1.0522430       1.5384616
 i,j,k,ie:    1    5    4          40
 Near X =  0.54926584     -0.33748452E-01   0.0000000    , d:   0.0000000      -1.0415192       1.5384616
 i,j,k,ie:    1    6    4          40
 Near X =  0.55360763     -0.38343791E-07   0.0000000    , d:   0.0000000      -1.0326935       1.5384616
 i,j,k,ie:    2    6    4          40
 Near X =  0.55360763     -0.38343791E-07  0.15785898E-01, d:   0.0000000     -0.74521768E-01   1.5384616
 i,j,k,ie:    3    6    4          40
 Near X =  0.55360763     -0.38343791E-07  0.48025188E-01, d:   0.0000000     -0.74521768E-01   1.5384616
 i,j,k,ie:    4    6    4          40
 Near X =  0.55360763     -0.38343791E-07  0.86354515E-01, d:   0.0000000     -0.74521768E-01   1.5384616
 i,j,k,ie:    5    6    4          40
 Near X =  0.55360763     -0.38343791E-07  0.11859381    , d:   0.0000000     -0.74521768E-01   1.5384616
 i,j,k,ie:    6    6    4          40
 Near X =  0.55360763     -0.38343791E-07  0.13437970    , d:   0.0000000     -0.74521768E-01   1.5384616
 i,j,k,ie:    1    1    5          40
 Near X =  0.44787290     -0.25937332       0.0000000    , d:   0.0000000      -1.0461039       1.5384616
 i,j,k,ie:    2    1    5          40
 Near X =  0.44787290     -0.25937332      0.15785898E-01, d:   0.0000000      -1.0461039       1.5384616
 i,j,k,ie:    3    1    5          40
 Near X =  0.44787290     -0.25937332      0.48025188E-01, d:   0.0000000      -1.0461039       1.5384616
 i,j,k,ie:    4    1    5          40
 Near X =  0.44787290     -0.25937332      0.86354515E-01, d:   0.0000000      -1.0461039       1.5384616
 i,j,k,ie:    5    1    5          40
 Near X =  0.44787290     -0.25937332      0.11859381    , d:   0.0000000      -1.0461039       1.5384616
 i,j,k,ie:    6    1    5          40
 Near X =  0.44787290     -0.25937332      0.13437970    , d:   0.0000000      -1.0461039       1.5384616
 i,j,k,ie:    1    2    5          40
 Near X =  0.46212886     -0.23053353       0.0000000    , d:   0.0000000     -0.97761931       1.5384616
 i,j,k,ie:    1    3    5          40
 Near X =  0.48622969     -0.17028691       0.0000000    , d:   0.0000000     -0.99235672       1.5384616
 i,j,k,ie:    1    4    5          40
 Near X =  0.50612400     -0.96305478E-01   0.0000000    , d:   0.0000000     -0.99236203       1.5384616
 i,j,k,ie:    1    5    5          40
 Near X =  0.51548990     -0.32098618E-01   0.0000000    , d:   0.0000000     -0.97763354       1.5384616
 i,j,k,ie:    1    6    5          40
 Near X =  0.51762085     -0.39026209E-07   0.0000000    , d:   0.0000000     -0.96551235       1.5384616
 i,j,k,ie:    2    6    5          40
 Near X =  0.51762085     -0.39026209E-07  0.15785898E-01, d:   0.0000000     -0.69729342E-01   1.5384616
 i,j,k,ie:    3    6    5          40
 Near X =  0.51762085     -0.39026209E-07  0.48025188E-01, d:   0.0000000     -0.69729342E-01   1.5384616
 i,j,k,ie:    4    6    5          40
 Near X =  0.51762085     -0.39026209E-07  0.86354515E-01, d:   0.0000000     -0.69729342E-01   1.5384616
 i,j,k,ie:    5    6    5          40
 Near X =  0.51762085     -0.39026209E-07  0.11859381    , d:   0.0000000     -0.69729342E-01   1.5384616
 i,j,k,ie:    6    6    5          40
 Near X =  0.51762085     -0.39026209E-07  0.13437970    , d:   0.0000000     -0.69729342E-01   1.5384616
 i,j,k,ie:    1    1    6          40
 Near X =  0.43259778     -0.25065021       0.0000000    , d:  0.13003163      -1.2982001       1.5384616
 i,j,k,ie:    2    1    6          40
 Near X =  0.43259778     -0.25065021      0.15785898E-01, d:  0.13003163      -1.2982001       1.5384616
 i,j,k,ie:    3    1    6          40
 Near X =  0.43259778     -0.25065021      0.48025188E-01, d:  0.13003163      -1.2982001       1.5384616
 i,j,k,ie:    4    1    6          40
 Near X =  0.43259778     -0.25065021      0.86354515E-01, d:  0.13003163      -1.2982001       1.5384616
 i,j,k,ie:    5    1    6          40
 Near X =  0.43259778     -0.25065021      0.11859381    , d:  0.13003163      -1.2982001       1.5384616
 i,j,k,ie:    6    1    6          40
 Near X =  0.43259778     -0.25065021      0.13437970    , d:  0.13003163      -1.2982001       1.5384616
 i,j,k,ie:    1    2    6          40
 Near X =  0.44738516     -0.22305203       0.0000000    , d:  0.12550788      -1.0871229       1.5384616
 i,j,k,ie:    2    2    6          40
 Near X =  0.44738516     -0.22305203      0.15785898E-01, d:  0.12550788       0.0000000       1.5384616
 i,j,k,ie:    3    2    6          40
 Near X =  0.44738516     -0.22305203      0.48025188E-01, d:  0.12550788       0.0000000       1.5384616
 i,j,k,ie:    4    2    6          40
 Near X =  0.44738516     -0.22305203      0.86354515E-01, d:  0.12550788       0.0000000       1.5384616
 i,j,k,ie:    5    2    6          40
 Near X =  0.44738516     -0.22305203      0.11859381    , d:  0.12550788       0.0000000       1.5384616
 i,j,k,ie:    6    2    6          40
 Near X =  0.44738516     -0.22305203      0.13437970    , d:  0.12550788       0.0000000       1.5384616
 i,j,k,ie:    1    3    6          40
 Near X =  0.47190389     -0.16516176       0.0000000    , d:  0.12195038      -1.0906833       1.5384616
 i,j,k,ie:    2    3    6          40
 Near X =  0.47190389     -0.16516176      0.15785898E-01, d:  0.12195038       0.0000000       1.5384616
 i,j,k,ie:    3    3    6          40
 Near X =  0.47190389     -0.16516176      0.48025188E-01, d:  0.12195038       0.0000000       1.5384616
 i,j,k,ie:    4    3    6          40
 Near X =  0.47190389     -0.16516176      0.86354515E-01, d:  0.12195038       0.0000000       1.5384616
 i,j,k,ie:    5    3    6          40
 Near X =  0.47190389     -0.16516176      0.11859381    , d:  0.12195038       0.0000000       1.5384616
 i,j,k,ie:    6    3    6          40
 Near X =  0.47190389     -0.16516176      0.13437970    , d:  0.12195038       0.0000000       1.5384616
 i,j,k,ie:    1    4    6          40
 Near X =  0.49112913     -0.93668433E-01   0.0000000    , d:  0.12764599      -1.0849911       1.5384616
 i,j,k,ie:    2    4    6          40
 Near X =  0.49112913     -0.93668433E-01  0.15785898E-01, d:  0.12764599       0.0000000       1.5384616
 i,j,k,ie:    3    4    6          40
 Near X =  0.49112913     -0.93668433E-01  0.48025188E-01, d:  0.12764599       0.0000000       1.5384616
 i,j,k,ie:    4    4    6          40
 Near X =  0.49112913     -0.93668433E-01  0.86354515E-01, d:  0.12764599       0.0000000       1.5384616
 i,j,k,ie:    5    4    6          40
 Near X =  0.49112913     -0.93668433E-01  0.11859381    , d:  0.12764599       0.0000000       1.5384616
 i,j,k,ie:    6    4    6          40
 Near X =  0.49112913     -0.93668433E-01  0.13437970    , d:  0.12764599       0.0000000       1.5384616
 i,j,k,ie:    1    5    6          40
 Near X =  0.49895158     -0.31290781E-01   0.0000000    , d:  0.14078477      -1.0718552       1.5384616
 i,j,k,ie:    2    5    6          40
 Near X =  0.49895158     -0.31290781E-01  0.15785898E-01, d:  0.14078477       0.0000000       1.5384616
 i,j,k,ie:    3    5    6          40
 Near X =  0.49895158     -0.31290781E-01  0.48025188E-01, d:  0.14078477       0.0000000       1.5384616
 i,j,k,ie:    4    5    6          40
 Near X =  0.49895158     -0.31290781E-01  0.86354515E-01, d:  0.14078477       0.0000000       1.5384616
 i,j,k,ie:    5    5    6          40
 Near X =  0.49895158     -0.31290781E-01  0.11859381    , d:  0.14078477       0.0000000       1.5384616
 i,j,k,ie:    6    5    6          40
 Near X =  0.49895158     -0.31290781E-01  0.13437970    , d:  0.14078477       0.0000000       1.5384616
 i,j,k,ie:    1    6    6          40
 Near X =  0.50000000     -0.39360354E-07   0.0000000    , d:  0.14999998      -1.0626415       1.5384616
 i,j,k,ie:    2    6    6          40
 Near X =  0.50000000     -0.39360354E-07  0.15785898E-01, d:  0.14999998     -0.67382741E-01   1.5384616
 i,j,k,ie:    3    6    6          40
 Near X =  0.50000000     -0.39360354E-07  0.48025188E-01, d:  0.14999998     -0.67382741E-01   1.5384616
 i,j,k,ie:    4    6    6          40
 Near X =  0.50000000     -0.39360354E-07  0.86354515E-01, d:  0.14999998     -0.67382741E-01   1.5384616
 i,j,k,ie:    5    6    6          40
 Near X =  0.50000000     -0.39360354E-07  0.11859381    , d:  0.14999998     -0.67382741E-01   1.5384616
 i,j,k,ie:    6    6    6          40
 Near X =  0.50000000     -0.39360354E-07  0.13437970    , d:  0.14999998     -0.67382741E-01   1.5384616
 i,j,k,ie:    1    1    1          41
 Near X =  0.32491009     -0.56264146       0.0000000    , d:   0.0000000     -0.32491017       1.7773689
 i,j,k,ie:    2    1    1          41
 Near X =  0.32491009     -0.56264146      0.15785898E-01, d:   0.0000000     -0.32491017       1.7773689
 i,j,k,ie:    3    1    1          41
 Near X =  0.32491009     -0.56264146      0.48025188E-01, d:   0.0000000     -0.32491017       1.7773689
 i,j,k,ie:    4    1    1          41
 Near X =  0.32491009     -0.56264146      0.86354515E-01, d:   0.0000000     -0.32491017       1.7773689
 i,j,k,ie:    5    1    1          41
 Near X =  0.32491009     -0.56264146      0.11859381    , d:   0.0000000     -0.32491017       1.7773689
 i,j,k,ie:    6    1    1          41
 Near X =  0.32491009     -0.56264146      0.13437970    , d:   0.0000000     -0.64981707       1.7773689
 i,j,k,ie:    6    2    1          41
 Near X =  0.35283554     -0.53471423      0.13437970    , d:   0.0000000     -0.31466766       1.7773689
 i,j,k,ie:    6    3    1          41
 Near X =  0.40986723     -0.47767890      0.13437970    , d:   0.0000000     -0.29374953       1.7773689
 i,j,k,ie:    6    4    1          41
 Near X =  0.47767227     -0.40986953      0.13437970    , d:   0.0000000     -0.26887995       1.7773689
 i,j,k,ie:    6    5    1          41
 Near X =  0.53470396     -0.35283419      0.13437970    , d:   0.0000000     -0.24796183       1.7773689
 i,j,k,ie:    1    6    1          41
 Near X =  0.56262941     -0.32490697       0.0000000    , d:  0.87370572E-01   0.0000000       1.7773689
 i,j,k,ie:    2    6    1          41
 Near X =  0.56262941     -0.32490697      0.15785898E-01, d:  0.87370572E-01   0.0000000       1.7773689
 i,j,k,ie:    3    6    1          41
 Near X =  0.56262941     -0.32490697      0.48025188E-01, d:  0.87370572E-01   0.0000000       1.7773689
 i,j,k,ie:    4    6    1          41
 Near X =  0.56262941     -0.32490697      0.86354515E-01, d:  0.87370572E-01   0.0000000       1.7773689
 i,j,k,ie:    5    6    1          41
 Near X =  0.56262941     -0.32490697      0.11859381    , d:  0.87370572E-01   0.0000000       1.7773689
 i,j,k,ie:    6    6    1          41
 Near X =  0.56262941     -0.32490697      0.13437970    , d:  0.87370572E-01  -1.1252588       1.7773689
 i,j,k,ie:    1    1    2          41
 Near X =  0.31618244     -0.54736721       0.0000000    , d:   0.0000000     -0.31618252       1.7773689
 i,j,k,ie:    2    1    2          41
 Near X =  0.31618244     -0.54736721      0.15785898E-01, d:   0.0000000     -0.31618252       1.7773689
 i,j,k,ie:    3    1    2          41
 Near X =  0.31618244     -0.54736721      0.48025188E-01, d:   0.0000000     -0.31618252       1.7773689
 i,j,k,ie:    4    1    2          41
 Near X =  0.31618244     -0.54736721      0.86354515E-01, d:   0.0000000     -0.31618252       1.7773689
 i,j,k,ie:    5    1    2          41
 Near X =  0.31618244     -0.54736721      0.11859381    , d:   0.0000000     -0.31618252       1.7773689
 i,j,k,ie:    6    1    2          41
 Near X =  0.31618244     -0.54736721      0.13437970    , d:   0.0000000     -0.63236630       1.7773689
 i,j,k,ie:    6    2    2          41
 Near X =  0.34392005     -0.52079092      0.13437970    , d:   0.0000000     -0.30656063       1.7773689
 i,j,k,ie:    6    3    2          41
 Near X =  0.40008736     -0.46603377      0.13437970    , d:   0.0000000     -0.28660853       1.7773689
 i,j,k,ie:    6    4    2          41
 Near X =  0.46602486     -0.40009299      0.13437970    , d:   0.0000000     -0.26236081       1.7773689
 i,j,k,ie:    6    5    2          41
 Near X =  0.52077930     -0.34392286      0.13437970    , d:   0.0000000     -0.24152276       1.7773689
 i,j,k,ie:    1    6    2          41
 Near X =  0.54735429     -0.31618385       0.0000000    , d:  0.85024843E-01   0.0000000       1.7773689
 i,j,k,ie:    2    6    2          41
 Near X =  0.54735429     -0.31618385      0.15785898E-01, d:  0.85024843E-01   0.0000000       1.7773689
 i,j,k,ie:    3    6    2          41
 Near X =  0.54735429     -0.31618385      0.48025188E-01, d:  0.85024843E-01   0.0000000       1.7773689
 i,j,k,ie:    4    6    2          41
 Near X =  0.54735429     -0.31618385      0.86354515E-01, d:  0.85024843E-01   0.0000000       1.7773689
 i,j,k,ie:    5    6    2          41
 Near X =  0.54735429     -0.31618385      0.11859381    , d:  0.85024843E-01   0.0000000       1.7773689
 i,j,k,ie:    6    6    2          41
 Near X =  0.54735429     -0.31618385      0.13437970    , d:  0.85024843E-01  -1.0947086       1.7773689
 i,j,k,ie:    1    1    3          41
 Near X =  0.29835811     -0.51617286       0.0000000    , d:   0.0000000     -0.29835818       1.7773689
 i,j,k,ie:    2    1    3          41
 Near X =  0.29835811     -0.51617286      0.15785898E-01, d:   0.0000000     -0.29835818       1.7773689
 i,j,k,ie:    3    1    3          41
 Near X =  0.29835811     -0.51617286      0.48025188E-01, d:   0.0000000     -0.29835818       1.7773689
 i,j,k,ie:    4    1    3          41
 Near X =  0.29835811     -0.51617286      0.86354515E-01, d:   0.0000000     -0.29835818       1.7773689
 i,j,k,ie:    5    1    3          41
 Near X =  0.29835811     -0.51617286      0.11859381    , d:   0.0000000     -0.29835818       1.7773689
 i,j,k,ie:    6    1    3          41
 Near X =  0.29835811     -0.51617286      0.13437970    , d:   0.0000000     -0.59672688       1.7773689
 i,j,k,ie:    6    2    3          41
 Near X =  0.32571209     -0.49235555      0.13437970    , d:   0.0000000     -0.29000378       1.7773689
 i,j,k,ie:    6    3    3          41
 Near X =  0.38011409     -0.44225110      0.13437970    , d:   0.0000000     -0.27202459       1.7773689
 i,j,k,ie:    6    4    3          41
 Near X =  0.44223753     -0.38012651      0.13437970    , d:   0.0000000     -0.24904687       1.7773689
 i,j,k,ie:    6    5    3          41
 Near X =  0.49234117     -0.32572337      0.13437970    , d:   0.0000000     -0.22837235       1.7773689
 i,j,k,ie:    1    6    3          41
 Near X =  0.51615815     -0.29836877       0.0000000    , d:  0.80234198E-01   0.0000000       1.7773689
 i,j,k,ie:    2    6    3          41
 Near X =  0.51615815     -0.29836877      0.15785898E-01, d:  0.80234198E-01   0.0000000       1.7773689
 i,j,k,ie:    3    6    3          41
 Near X =  0.51615815     -0.29836877      0.48025188E-01, d:  0.80234198E-01   0.0000000       1.7773689
 i,j,k,ie:    4    6    3          41
 Near X =  0.51615815     -0.29836877      0.86354515E-01, d:  0.80234198E-01   0.0000000       1.7773689
 i,j,k,ie:    5    6    3          41
 Near X =  0.51615815     -0.29836877      0.11859381    , d:  0.80234198E-01   0.0000000       1.7773689
 i,j,k,ie:    6    6    3          41
 Near X =  0.51615815     -0.29836877      0.13437970    , d:  0.80234198E-01  -1.0323163       1.7773689
 i,j,k,ie:    1    1    4          41
 Near X =  0.27716673     -0.47908586       0.0000000    , d:   0.0000000     -0.27716680       1.7773689
 i,j,k,ie:    2    1    4          41
 Near X =  0.27716673     -0.47908586      0.15785898E-01, d:   0.0000000     -0.27716680       1.7773689
 i,j,k,ie:    3    1    4          41
 Near X =  0.27716673     -0.47908586      0.48025188E-01, d:   0.0000000     -0.27716680       1.7773689
 i,j,k,ie:    4    1    4          41
 Near X =  0.27716673     -0.47908586      0.86354515E-01, d:   0.0000000     -0.27716680       1.7773689
 i,j,k,ie:    5    1    4          41
 Near X =  0.27716673     -0.47908586      0.11859381    , d:   0.0000000     -0.27716680       1.7773689
 i,j,k,ie:    6    1    4          41
 Near X =  0.27716673     -0.47908586      0.13437970    , d:   0.0000000     -0.55435514       1.7773689
 i,j,k,ie:    6    2    4          41
 Near X =  0.30406463     -0.45854871      0.13437970    , d:   0.0000000     -0.27031933       1.7773689
 i,j,k,ie:    6    3    4          41
 Near X =  0.35636784     -0.41397587      0.13437970    , d:   0.0000000     -0.25468571       1.7773689
 i,j,k,ie:    6    4    4          41
 Near X =  0.41395674     -0.35638835      0.13437970    , d:   0.0000000     -0.23321791       1.7773689
 i,j,k,ie:    6    5    4          41
 Near X =  0.45853106     -0.30408599      0.13437970    , d:   0.0000000     -0.21273782       1.7773689
 i,j,k,ie:    1    6    4          41
 Near X =  0.47906903     -0.27718840       0.0000000    , d:  0.74538595E-01   0.0000000       1.7773689
 i,j,k,ie:    2    6    4          41
 Near X =  0.47906903     -0.27718840      0.15785898E-01, d:  0.74538595E-01   0.0000000       1.7773689
 i,j,k,ie:    3    6    4          41
 Near X =  0.47906903     -0.27718840      0.48025188E-01, d:  0.74538595E-01   0.0000000       1.7773689
 i,j,k,ie:    4    6    4          41
 Near X =  0.47906903     -0.27718840      0.86354515E-01, d:  0.74538595E-01   0.0000000       1.7773689
 i,j,k,ie:    5    6    4          41
 Near X =  0.47906903     -0.27718840      0.11859381    , d:  0.74538595E-01   0.0000000       1.7773689
 i,j,k,ie:    6    6    4          41
 Near X =  0.47906903     -0.27718840      0.13437970    , d:  0.74538595E-01 -0.95813809       1.7773689
 i,j,k,ie:    1    1    5          41
 Near X =  0.25934240     -0.44789151       0.0000000    , d:   0.0000000     -0.25934246       1.7773689
 i,j,k,ie:    2    1    5          41
 Near X =  0.25934240     -0.44789151      0.15785898E-01, d:   0.0000000     -0.25934246       1.7773689
 i,j,k,ie:    3    1    5          41
 Near X =  0.25934240     -0.44789151      0.48025188E-01, d:   0.0000000     -0.25934246       1.7773689
 i,j,k,ie:    4    1    5          41
 Near X =  0.25934240     -0.44789151      0.86354515E-01, d:   0.0000000     -0.25934246       1.7773689
 i,j,k,ie:    5    1    5          41
 Near X =  0.25934240     -0.44789151      0.11859381    , d:   0.0000000     -0.25934246       1.7773689
 i,j,k,ie:    6    1    5          41
 Near X =  0.25934240     -0.44789151      0.13437970    , d:   0.0000000     -0.51871572       1.7773689
 i,j,k,ie:    6    2    5          41
 Near X =  0.28585667     -0.43011334      0.13437970    , d:   0.0000000     -0.25376248       1.7773689
 i,j,k,ie:    6    3    5          41
 Near X =  0.33639457     -0.39019320      0.13437970    , d:   0.0000000     -0.24010177       1.7773689
 i,j,k,ie:    6    4    5          41
 Near X =  0.39016941     -0.33642187      0.13437970    , d:   0.0000000     -0.21990396       1.7773689
 i,j,k,ie:    6    5    5          41
 Near X =  0.43009294     -0.28588650      0.13437970    , d:   0.0000000     -0.19958741       1.7773689
 i,j,k,ie:    1    6    5          41
 Near X =  0.44787290     -0.25937332       0.0000000    , d:  0.69747950E-01   0.0000000       1.7773689
 i,j,k,ie:    2    6    5          41
 Near X =  0.44787290     -0.25937332      0.15785898E-01, d:  0.69747950E-01   0.0000000       1.7773689
 i,j,k,ie:    3    6    5          41
 Near X =  0.44787290     -0.25937332      0.48025188E-01, d:  0.69747950E-01   0.0000000       1.7773689
 i,j,k,ie:    4    6    5          41
 Near X =  0.44787290     -0.25937332      0.86354515E-01, d:  0.69747950E-01   0.0000000       1.7773689
 i,j,k,ie:    5    6    5          41
 Near X =  0.44787290     -0.25937332      0.11859381    , d:  0.69747950E-01   0.0000000       1.7773689
 i,j,k,ie:    6    6    5          41
 Near X =  0.44787290     -0.25937332      0.13437970    , d:  0.69747950E-01 -0.89574582       1.7773689
 i,j,k,ie:    1    1    6          41
 Near X =  0.25061475     -0.43261726       0.0000000    , d:  0.74295343E-01 -0.25061483       1.7773689
 i,j,k,ie:    2    1    6          41
 Near X =  0.25061475     -0.43261726      0.15785898E-01, d:  0.74295343E-01 -0.25061483       1.7773689
 i,j,k,ie:    3    1    6          41
 Near X =  0.25061475     -0.43261726      0.48025188E-01, d:  0.74295343E-01 -0.25061483       1.7773689
 i,j,k,ie:    4    1    6          41
 Near X =  0.25061475     -0.43261726      0.86354515E-01, d:  0.74295343E-01 -0.25061483       1.7773689
 i,j,k,ie:    5    1    6          41
 Near X =  0.25061475     -0.43261726      0.11859381    , d:  0.74295343E-01 -0.25061483       1.7773689
 i,j,k,ie:    6    1    6          41
 Near X =  0.25061475     -0.43261726      0.13437970    , d:  0.74295343E-01 -0.57552172       1.7773689
 i,j,k,ie:    1    2    6          41
 Near X =  0.27694118     -0.41619003       0.0000000    , d:  0.75894351E-01   0.0000000       1.7773689
 i,j,k,ie:    2    2    6          41
 Near X =  0.27694118     -0.41619003      0.15785898E-01, d:  0.75894351E-01   0.0000000       1.7773689
 i,j,k,ie:    3    2    6          41
 Near X =  0.27694118     -0.41619003      0.48025188E-01, d:  0.75894351E-01   0.0000000       1.7773689
 i,j,k,ie:    4    2    6          41
 Near X =  0.27694118     -0.41619003      0.86354515E-01, d:  0.75894351E-01   0.0000000       1.7773689
 i,j,k,ie:    5    2    6          41
 Near X =  0.27694118     -0.41619003      0.11859381    , d:  0.75894351E-01   0.0000000       1.7773689
 i,j,k,ie:    6    2    6          41
 Near X =  0.27694118     -0.41619003      0.13437970    , d:  0.75894351E-01 -0.24565545       1.7773689
 i,j,k,ie:    1    3    6          41
 Near X =  0.32661470     -0.37854807       0.0000000    , d:  0.83252527E-01   0.0000000       1.7773689
 i,j,k,ie:    2    3    6          41
 Near X =  0.32661470     -0.37854807      0.15785898E-01, d:  0.83252527E-01   0.0000000       1.7773689
 i,j,k,ie:    3    3    6          41
 Near X =  0.32661470     -0.37854807      0.48025188E-01, d:  0.83252527E-01   0.0000000       1.7773689
 i,j,k,ie:    4    3    6          41
 Near X =  0.32661470     -0.37854807      0.86354515E-01, d:  0.83252527E-01   0.0000000       1.7773689
 i,j,k,ie:    5    3    6          41
 Near X =  0.32661470     -0.37854807      0.11859381    , d:  0.83252527E-01   0.0000000       1.7773689
 i,j,k,ie:    6    3    6          41
 Near X =  0.32661470     -0.37854807      0.13437970    , d:  0.83252527E-01 -0.23296077       1.7773689
 i,j,k,ie:    1    4    6          41
 Near X =  0.37852200     -0.32664533       0.0000000    , d:  0.99150273E-01   0.0000000       1.7773689
 i,j,k,ie:    2    4    6          41
 Near X =  0.37852200     -0.32664533      0.15785898E-01, d:  0.99150273E-01   0.0000000       1.7773689
 i,j,k,ie:    3    4    6          41
 Near X =  0.37852200     -0.32664533      0.48025188E-01, d:  0.99150273E-01   0.0000000       1.7773689
 i,j,k,ie:    4    4    6          41
 Near X =  0.37852200     -0.32664533      0.86354515E-01, d:  0.99150273E-01   0.0000000       1.7773689
 i,j,k,ie:    5    4    6          41
 Near X =  0.37852200     -0.32664533      0.11859381    , d:  0.99150273E-01   0.0000000       1.7773689
 i,j,k,ie:    6    4    6          41
 Near X =  0.37852200     -0.32664533      0.13437970    , d:  0.99150273E-01 -0.21338482       1.7773689
 i,j,k,ie:    1    5    6          41
 Near X =  0.41616827     -0.27697516       0.0000000    , d:  0.11853569       0.0000000       1.7773689
 i,j,k,ie:    2    5    6          41
 Near X =  0.41616827     -0.27697516      0.15785898E-01, d:  0.11853569       0.0000000       1.7773689
 i,j,k,ie:    3    5    6          41
 Near X =  0.41616827     -0.27697516      0.48025188E-01, d:  0.11853569       0.0000000       1.7773689
 i,j,k,ie:    4    5    6          41
 Near X =  0.41616827     -0.27697516      0.86354515E-01, d:  0.11853569       0.0000000       1.7773689
 i,j,k,ie:    5    5    6          41
 Near X =  0.41616827     -0.27697516      0.11859381    , d:  0.11853569       0.0000000       1.7773689
 i,j,k,ie:    6    5    6          41
 Near X =  0.41616827     -0.27697516      0.13437970    , d:  0.11853569     -0.19314834       1.7773689
 i,j,k,ie:    1    6    6          41
 Near X =  0.43259778     -0.25065021       0.0000000    , d:  0.21740220       0.0000000       1.7773689
 i,j,k,ie:    2    6    6          41
 Near X =  0.43259778     -0.25065021      0.15785898E-01, d:  0.21740220       0.0000000       1.7773689
 i,j,k,ie:    3    6    6          41
 Near X =  0.43259778     -0.25065021      0.48025188E-01, d:  0.21740220       0.0000000       1.7773689
 i,j,k,ie:    4    6    6          41
 Near X =  0.43259778     -0.25065021      0.86354515E-01, d:  0.21740220       0.0000000       1.7773689
 i,j,k,ie:    5    6    6          41
 Near X =  0.43259778     -0.25065021      0.11859381    , d:  0.21740220       0.0000000       1.7773689
 i,j,k,ie:    6    6    6          41
 Near X =  0.43259778     -0.25065021      0.13437970    , d:  0.21740220     -0.99522721       1.7773689
 i,j,k,ie:    1    1    1          42
 Near X = -0.76704964E-07 -0.64999998       0.0000000    , d:  0.32491017     -0.32490690       3.0777738
 i,j,k,ie:    2    1    1          42
 Near X = -0.76704964E-07 -0.64999998      0.15785898E-01, d:   0.0000000     -0.32490690       3.0777738
 i,j,k,ie:    3    1    1          42
 Near X = -0.76704964E-07 -0.64999998      0.48025188E-01, d:   0.0000000     -0.32490690       3.0777738
 i,j,k,ie:    4    1    1          42
 Near X = -0.76704964E-07 -0.64999998      0.86354515E-01, d:   0.0000000     -0.32490690       3.0777738
 i,j,k,ie:    5    1    1          42
 Near X = -0.76704964E-07 -0.64999998      0.11859381    , d:   0.0000000     -0.32490690       3.0777738
 i,j,k,ie:    6    1    1          42
 Near X = -0.76704964E-07 -0.64999998      0.13437970    , d:  0.32490703     -0.56264138       3.0777738
 i,j,k,ie:    1    2    1          42
 Near X =  0.38167880E-01 -0.63973777       0.0000000    , d:  0.31466766       0.0000000       3.0777738
 i,j,k,ie:    6    2    1          42
 Near X =  0.38167880E-01 -0.63973777      0.13437970    , d:  0.24857150       0.0000000       3.0777738
 i,j,k,ie:    1    3    1          42
 Near X =  0.11611770     -0.61877942       0.0000000    , d:  0.29374953       0.0000000       3.0777738
 i,j,k,ie:    6    3    1          42
 Near X =  0.11611770     -0.61877942      0.13437970    , d:  0.92672642E-01   0.0000000       3.0777738
 i,j,k,ie:    1    4    1          42
 Near X =  0.20879232     -0.59386202       0.0000000    , d:  0.26887995       0.0000000       3.0777738
 i,j,k,ie:    6    4    1          42
 Near X =  0.20879232     -0.59386202      0.13437970    , d:   0.0000000     -0.92675675E-01   3.0777738
 i,j,k,ie:    1    5    1          42
 Near X =  0.28674213     -0.57290367       0.0000000    , d:  0.24796183       0.0000000       3.0777738
 i,j,k,ie:    6    5    1          42
 Near X =  0.28674213     -0.57290367      0.13437970    , d:   0.0000000     -0.24857453       3.0777738
 i,j,k,ie:    1    6    1          42
 Near X =  0.32491009     -0.56264146       0.0000000    , d:  0.32508989     -0.88753952       3.0777738
 i,j,k,ie:    2    6    1          42
 Near X =  0.32491009     -0.56264146      0.15785898E-01, d:   0.0000000     -0.88753952       3.0777738
 i,j,k,ie:    3    6    1          42
 Near X =  0.32491009     -0.56264146      0.48025188E-01, d:   0.0000000     -0.88753952       3.0777738
 i,j,k,ie:    4    6    1          42
 Near X =  0.32491009     -0.56264146      0.86354515E-01, d:   0.0000000     -0.88753952       3.0777738
 i,j,k,ie:    5    6    1          42
 Near X =  0.32491009     -0.56264146      0.11859381    , d:   0.0000000     -0.88753952       3.0777738
 i,j,k,ie:    6    6    1          42
 Near X =  0.32491009     -0.56264146      0.13437970    , d:   0.0000000     -0.88753952       3.0777738
 i,j,k,ie:    1    1    2          42
 Near X = -0.74625580E-07 -0.63237913       0.0000000    , d:  0.31618252     -0.31618378       3.0777738
 i,j,k,ie:    2    1    2          42
 Near X = -0.74625580E-07 -0.63237913      0.15785898E-01, d:   0.0000000     -0.31618378       3.0777738
 i,j,k,ie:    3    1    2          42
 Near X = -0.74625580E-07 -0.63237913      0.48025188E-01, d:   0.0000000     -0.31618378       3.0777738
 i,j,k,ie:    4    1    2          42
 Near X = -0.74625580E-07 -0.63237913      0.86354515E-01, d:   0.0000000     -0.31618378       3.0777738
 i,j,k,ie:    5    1    2          42
 Near X = -0.74625580E-07 -0.63237913      0.11859381    , d:   0.0000000     -0.31618378       3.0777738
 i,j,k,ie:    6    1    2          42
 Near X = -0.74625580E-07 -0.63237913      0.13437970    , d:  0.31618392     -0.54736713       3.0777738
 i,j,k,ie:    1    2    2          42
 Near X =  0.37359418E-01 -0.62319934       0.0000000    , d:  0.30656063       0.0000000       3.0777738
 i,j,k,ie:    6    2    2          42
 Near X =  0.37359418E-01 -0.62319934      0.13437970    , d:  0.24189846       0.0000000       3.0777738
 i,j,k,ie:    1    3    2          42
 Near X =  0.11347883     -0.60378438       0.0000000    , d:  0.28660853       0.0000000       3.0777738
 i,j,k,ie:    6    3    2          42
 Near X =  0.11347883     -0.60378438      0.13437970    , d:  0.90186359E-01   0.0000000       3.0777738
 i,j,k,ie:    1    4    2          42
 Near X =  0.20366405     -0.57953630       0.0000000    , d:  0.26236081       0.0000000       3.0777738
 i,j,k,ie:    6    4    2          42
 Near X =  0.20366405     -0.57953630      0.13437970    , d:   0.0000000     -0.90184449E-01   3.0777738
 i,j,k,ie:    1    5    2          42
 Near X =  0.27925654     -0.55816052       0.0000000    , d:  0.24152276       0.0000000       3.0777738
 i,j,k,ie:    6    5    2          42
 Near X =  0.27925654     -0.55816052      0.13437970    , d:   0.0000000     -0.24189677       3.0777738
 i,j,k,ie:    1    6    2          42
 Near X =  0.31618244     -0.54736721       0.0000000    , d:  0.31619669     -0.86353675       3.0777738
 i,j,k,ie:    2    6    2          42
 Near X =  0.31618244     -0.54736721      0.15785898E-01, d:   0.0000000     -0.86353675       3.0777738
 i,j,k,ie:    3    6    2          42
 Near X =  0.31618244     -0.54736721      0.48025188E-01, d:   0.0000000     -0.86353675       3.0777738
 i,j,k,ie:    4    6    2          42
 Near X =  0.31618244     -0.54736721      0.86354515E-01, d:   0.0000000     -0.86353675       3.0777738
 i,j,k,ie:    5    6    2          42
 Near X =  0.31618244     -0.54736721      0.11859381    , d:   0.0000000     -0.86353675       3.0777738
 i,j,k,ie:    6    6    2          42
 Near X =  0.31618244     -0.54736721      0.13437970    , d:   0.0000000     -0.86353675       3.0777738
 i,j,k,ie:    1    1    3          42
 Near X = -0.70378885E-07 -0.59639235       0.0000000    , d:  0.29835818     -0.29836870       3.0777738
 i,j,k,ie:    2    1    3          42
 Near X = -0.70378885E-07 -0.59639235      0.15785898E-01, d:   0.0000000     -0.29836870       3.0777738
 i,j,k,ie:    3    1    3          42
 Near X = -0.70378885E-07 -0.59639235      0.48025188E-01, d:   0.0000000     -0.29836870       3.0777738
 i,j,k,ie:    4    1    3          42
 Near X = -0.70378885E-07 -0.59639235      0.86354515E-01, d:   0.0000000     -0.29836870       3.0777738
 i,j,k,ie:    5    1    3          42
 Near X = -0.70378885E-07 -0.59639235      0.11859381    , d:   0.0000000     -0.29836870       3.0777738
 i,j,k,ie:    6    1    3          42
 Near X = -0.70378885E-07 -0.59639235      0.13437970    , d:  0.29836883     -0.51617278       3.0777738
 i,j,k,ie:    1    2    3          42
 Near X =  0.35708309E-01 -0.58942316       0.0000000    , d:  0.29000378       0.0000000       3.0777738
 i,j,k,ie:    6    2    3          42
 Near X =  0.35708309E-01 -0.58942316      0.13437970    , d:  0.22827021       0.0000000       3.0777738
 i,j,k,ie:    1    3    3          42
 Near X =  0.10808950     -0.57316024       0.0000000    , d:  0.27202459       0.0000000       3.0777738
 i,j,k,ie:    6    3    3          42
 Near X =  0.10808950     -0.57316024      0.13437970    , d:  0.85108664E-01   0.0000000       3.0777738
 i,j,k,ie:    1    4    3          42
 Near X =  0.19319066     -0.55027912       0.0000000    , d:  0.24904687       0.0000000       3.0777738
 i,j,k,ie:    6    4    3          42
 Near X =  0.19319066     -0.55027912      0.13437970    , d:   0.0000000     -0.85096658E-01   3.0777738
 i,j,k,ie:    1    5    3          42
 Near X =  0.26396882     -0.52805082       0.0000000    , d:  0.22837235       0.0000000       3.0777738
 i,j,k,ie:    6    5    3          42
 Near X =  0.26396882     -0.52805082      0.13437970    , d:   0.0000000     -0.22825889       3.0777738
 i,j,k,ie:    1    6    3          42
 Near X =  0.29835811     -0.51617286       0.0000000    , d:  0.29803424     -0.81451628       3.0777738
 i,j,k,ie:    2    6    3          42
 Near X =  0.29835811     -0.51617286      0.15785898E-01, d:   0.0000000     -0.81451628       3.0777738
 i,j,k,ie:    3    6    3          42
 Near X =  0.29835811     -0.51617286      0.48025188E-01, d:   0.0000000     -0.81451628       3.0777738
 i,j,k,ie:    4    6    3          42
 Near X =  0.29835811     -0.51617286      0.86354515E-01, d:   0.0000000     -0.81451628       3.0777738
 i,j,k,ie:    5    6    3          42
 Near X =  0.29835811     -0.51617286      0.11859381    , d:   0.0000000     -0.81451628       3.0777738
 i,j,k,ie:    6    6    3          42
 Near X =  0.29835811     -0.51617286      0.13437970    , d:   0.0000000     -0.81451628       3.0777738
 i,j,k,ie:    1    1    4          42
 Near X = -0.65329986E-07 -0.55360763       0.0000000    , d:  0.27716680     -0.27718834       3.0777738
 i,j,k,ie:    2    1    4          42
 Near X = -0.65329986E-07 -0.55360763      0.15785898E-01, d:   0.0000000     -0.27718834       3.0777738
 i,j,k,ie:    3    1    4          42
 Near X = -0.65329986E-07 -0.55360763      0.48025188E-01, d:   0.0000000     -0.27718834       3.0777738
 i,j,k,ie:    4    1    4          42
 Near X = -0.65329986E-07 -0.55360763      0.86354515E-01, d:   0.0000000     -0.27718834       3.0777738
 i,j,k,ie:    5    1    4          42
 Near X = -0.65329986E-07 -0.55360763      0.11859381    , d:   0.0000000     -0.27718834       3.0777738
 i,j,k,ie:    6    1    4          42
 Near X = -0.65329986E-07 -0.55360763      0.13437970    , d:  0.27718845     -0.47908579       3.0777738
 i,j,k,ie:    1    2    4          42
 Near X =  0.33745304E-01 -0.54926663       0.0000000    , d:  0.27031933       0.0000000       3.0777738
 i,j,k,ie:    6    2    4          42
 Near X =  0.33745304E-01 -0.54926663      0.13437970    , d:  0.21206757       0.0000000       3.0777738
 i,j,k,ie:    1    3    4          42
 Near X =  0.10168213     -0.53675118       0.0000000    , d:  0.25468571       0.0000000       3.0777738
 i,j,k,ie:    6    3    4          42
 Near X =  0.10168213     -0.53675118      0.13437970    , d:  0.79071786E-01   0.0000000       3.0777738
 i,j,k,ie:    1    4    4          42
 Near X =  0.18073884     -0.51549522       0.0000000    , d:  0.23321791       0.0000000       3.0777738
 i,j,k,ie:    6    4    4          42
 Near X =  0.18073884     -0.51549522      0.13437970    , d:   0.0000000     -0.79047778E-01   3.0777738
 i,j,k,ie:    1    5    4          42
 Near X =  0.24579324     -0.49225336       0.0000000    , d:  0.21273782       0.0000000       3.0777738
 i,j,k,ie:    6    5    4          42
 Near X =  0.24579324     -0.49225336      0.13437970    , d:   0.0000000     -0.21204480       3.0777738
 i,j,k,ie:    1    6    4          42
 Near X =  0.27716673     -0.47908586       0.0000000    , d:  0.27644090     -0.75623579       3.0777738
 i,j,k,ie:    2    6    4          42
 Near X =  0.27716673     -0.47908586      0.15785898E-01, d:   0.0000000     -0.75623579       3.0777738
 i,j,k,ie:    3    6    4          42
 Near X =  0.27716673     -0.47908586      0.48025188E-01, d:   0.0000000     -0.75623579       3.0777738
 i,j,k,ie:    4    6    4          42
 Near X =  0.27716673     -0.47908586      0.86354515E-01, d:   0.0000000     -0.75623579       3.0777738
 i,j,k,ie:    5    6    4          42
 Near X =  0.27716673     -0.47908586      0.11859381    , d:   0.0000000     -0.75623579       3.0777738
 i,j,k,ie:    6    6    4          42
 Near X =  0.27716673     -0.47908586      0.13437970    , d:   0.0000000     -0.75623579       3.0777738
 i,j,k,ie:    1    1    5          42
 Near X = -0.61083291E-07 -0.51762085       0.0000000    , d:  0.25934246     -0.25937326       3.0777738
 i,j,k,ie:    2    1    5          42
 Near X = -0.61083291E-07 -0.51762085      0.15785898E-01, d:   0.0000000     -0.25937326       3.0777738
 i,j,k,ie:    3    1    5          42
 Near X = -0.61083291E-07 -0.51762085      0.48025188E-01, d:   0.0000000     -0.25937326       3.0777738
 i,j,k,ie:    4    1    5          42
 Near X = -0.61083291E-07 -0.51762085      0.86354515E-01, d:   0.0000000     -0.25937326       3.0777738
 i,j,k,ie:    5    1    5          42
 Near X = -0.61083291E-07 -0.51762085      0.11859381    , d:   0.0000000     -0.25937326       3.0777738
 i,j,k,ie:    6    1    5          42
 Near X = -0.61083291E-07 -0.51762085      0.13437970    , d:  0.25937337     -0.44789144       3.0777738
 i,j,k,ie:    1    2    5          42
 Near X =  0.32094195E-01 -0.51549046       0.0000000    , d:  0.25376248       0.0000000       3.0777738
 i,j,k,ie:    6    2    5          42
 Near X =  0.32094195E-01 -0.51549046      0.13437970    , d:  0.19843932       0.0000000       3.0777738
 i,j,k,ie:    1    3    5          42
 Near X =  0.96292805E-01 -0.50612704       0.0000000    , d:  0.24010177       0.0000000       3.0777738
 i,j,k,ie:    6    3    5          42
 Near X =  0.96292805E-01 -0.50612704      0.13437970    , d:  0.73994091E-01   0.0000000       3.0777738
 i,j,k,ie:    1    4    5          42
 Near X =  0.17026545     -0.48623804       0.0000000    , d:  0.21990396       0.0000000       3.0777738
 i,j,k,ie:    6    4    5          42
 Near X =  0.17026545     -0.48623804      0.13437970    , d:   0.0000000     -0.73959987E-01   3.0777738
 i,j,k,ie:    1    5    5          42
 Near X =  0.23050552     -0.46214365       0.0000000    , d:  0.19958741       0.0000000       3.0777738
 i,j,k,ie:    6    5    5          42
 Near X =  0.23050552     -0.46214365      0.13437970    , d:   0.0000000     -0.19840692       3.0777738
 i,j,k,ie:    1    6    5          42
 Near X =  0.25934240     -0.44789151       0.0000000    , d:  0.25827845     -0.70721531       3.0777738
 i,j,k,ie:    2    6    5          42
 Near X =  0.25934240     -0.44789151      0.15785898E-01, d:   0.0000000     -0.70721531       3.0777738
 i,j,k,ie:    3    6    5          42
 Near X =  0.25934240     -0.44789151      0.48025188E-01, d:   0.0000000     -0.70721531       3.0777738
 i,j,k,ie:    4    6    5          42
 Near X =  0.25934240     -0.44789151      0.86354515E-01, d:   0.0000000     -0.70721531       3.0777738
 i,j,k,ie:    5    6    5          42
 Near X =  0.25934240     -0.44789151      0.11859381    , d:   0.0000000     -0.70721531       3.0777738
 i,j,k,ie:    6    6    5          42
 Near X =  0.25934240     -0.44789151      0.13437970    , d:   0.0000000     -0.70721531       3.0777738
 i,j,k,ie:    1    1    6          42
 Near X = -0.59003907E-07 -0.50000000       0.0000000    , d:  0.32491015     -0.32490691       3.0777738
 i,j,k,ie:    2    1    6          42
 Near X = -0.59003907E-07 -0.50000000      0.15785898E-01, d:   0.0000000     -0.32490691       3.0777738
 i,j,k,ie:    3    1    6          42
 Near X = -0.59003907E-07 -0.50000000      0.48025188E-01, d:   0.0000000     -0.32490691       3.0777738
 i,j,k,ie:    4    1    6          42
 Near X = -0.59003907E-07 -0.50000000      0.86354515E-01, d:   0.0000000     -0.32490691       3.0777738
 i,j,k,ie:    5    1    6          42
 Near X = -0.59003907E-07 -0.50000000      0.11859381    , d:   0.0000000     -0.32490691       3.0777738
 i,j,k,ie:    6    1    6          42
 Near X = -0.59003907E-07 -0.50000000      0.13437970    , d:  0.32490702     -0.56264139       3.0777738
 i,j,k,ie:    1    2    6          42
 Near X =  0.31285733E-01 -0.49895203       0.0000000    , d:  0.32154980       0.0000000       3.0777738
 i,j,k,ie:    2    2    6          42
 Near X =  0.31285733E-01 -0.49895203      0.15785898E-01, d:  0.68821478E-02   0.0000000       3.0777738
 i,j,k,ie:    3    2    6          42
 Near X =  0.31285733E-01 -0.49895203      0.48025188E-01, d:  0.68821478E-02   0.0000000       3.0777738
 i,j,k,ie:    4    2    6          42
 Near X =  0.31285733E-01 -0.49895203      0.86354515E-01, d:  0.68821478E-02   0.0000000       3.0777738
 i,j,k,ie:    5    2    6          42
 Near X =  0.31285733E-01 -0.49895203      0.11859381    , d:  0.68821478E-02   0.0000000       3.0777738
 i,j,k,ie:    6    2    6          42
 Near X =  0.31285733E-01 -0.49895203      0.13437970    , d:  0.25545365       0.0000000       3.0777738
 i,j,k,ie:    1    3    6          42
 Near X =  0.93653934E-01 -0.49113200       0.0000000    , d:  0.31621330       0.0000000       3.0777738
 i,j,k,ie:    2    3    6          42
 Near X =  0.93653934E-01 -0.49113200      0.15785898E-01, d:  0.22463764E-01   0.0000000       3.0777738
 i,j,k,ie:    3    3    6          42
 Near X =  0.93653934E-01 -0.49113200      0.48025188E-01, d:  0.22463764E-01   0.0000000       3.0777738
 i,j,k,ie:    4    3    6          42
 Near X =  0.93653934E-01 -0.49113200      0.86354515E-01, d:  0.22463764E-01   0.0000000       3.0777738
 i,j,k,ie:    5    3    6          42
 Near X =  0.93653934E-01 -0.49113200      0.11859381    , d:  0.22463764E-01   0.0000000       3.0777738
 i,j,k,ie:    6    3    6          42
 Near X =  0.93653934E-01 -0.49113200      0.13437970    , d:  0.11513641       0.0000000       3.0777738
 i,j,k,ie:    1    4    6          42
 Near X =  0.16513718     -0.47191232       0.0000000    , d:  0.31253509       0.0000000       3.0777738
 i,j,k,ie:    2    4    6          42
 Near X =  0.16513718     -0.47191232      0.15785898E-01, d:  0.43655142E-01   0.0000000       3.0777738
 i,j,k,ie:    3    4    6          42
 Near X =  0.16513718     -0.47191232      0.48025188E-01, d:  0.43655142E-01   0.0000000       3.0777738
 i,j,k,ie:    4    4    6          42
 Near X =  0.16513718     -0.47191232      0.86354515E-01, d:  0.43655142E-01   0.0000000       3.0777738
 i,j,k,ie:    5    4    6          42
 Near X =  0.16513718     -0.47191232      0.11859381    , d:  0.43655142E-01   0.0000000       3.0777738
 i,j,k,ie:    6    4    6          42
 Near X =  0.16513718     -0.47191232      0.13437970    , d:  0.43655142E-01 -0.71468762E-01   3.0777738
 i,j,k,ie:    1    5    6          42
 Near X =  0.22301993     -0.44740050       0.0000000    , d:  0.31168404       0.0000000       3.0777738
 i,j,k,ie:    2    5    6          42
 Near X =  0.22301993     -0.44740050      0.15785898E-01, d:  0.63722209E-01   0.0000000       3.0777738
 i,j,k,ie:    3    5    6          42
 Near X =  0.22301993     -0.44740050      0.48025188E-01, d:  0.63722209E-01   0.0000000       3.0777738
 i,j,k,ie:    4    5    6          42
 Near X =  0.22301993     -0.44740050      0.86354515E-01, d:  0.63722209E-01   0.0000000       3.0777738
 i,j,k,ie:    5    5    6          42
 Near X =  0.22301993     -0.44740050      0.11859381    , d:  0.63722209E-01   0.0000000       3.0777738
 i,j,k,ie:    6    5    6          42
 Near X =  0.22301993     -0.44740050      0.13437970    , d:  0.63722209E-01 -0.19172916       3.0777738
 i,j,k,ie:    1    6    6          42
 Near X =  0.25061475     -0.43261726       0.0000000    , d:  0.39938523     -0.81324418       3.0777738
 i,j,k,ie:    2    6    6          42
 Near X =  0.25061475     -0.43261726      0.15785898E-01, d:  0.74295343E-01 -0.81324418       3.0777738
 i,j,k,ie:    3    6    6          42
 Near X =  0.25061475     -0.43261726      0.48025188E-01, d:  0.74295343E-01 -0.81324418       3.0777738
 i,j,k,ie:    4    6    6          42
 Near X =  0.25061475     -0.43261726      0.86354515E-01, d:  0.74295343E-01 -0.81324418       3.0777738
 i,j,k,ie:    5    6    6          42
 Near X =  0.25061475     -0.43261726      0.11859381    , d:  0.74295343E-01 -0.81324418       3.0777738
 i,j,k,ie:    6    6    6          42
 Near X =  0.25061475     -0.43261726      0.13437970    , d:  0.74295343E-01 -0.81324418       3.0777738
 i,j,k,ie:    1    1    1          43
 Near X =  0.32490696      0.56262942       0.0000000    , d:   0.0000000     -0.88754841       3.0778042
 i,j,k,ie:    2    1    1          43
 Near X =  0.32490696      0.56262942      0.15785898E-01, d:   0.0000000     -0.88754841       3.0778042
 i,j,k,ie:    3    1    1          43
 Near X =  0.32490696      0.56262942      0.48025188E-01, d:   0.0000000     -0.88754841       3.0778042
 i,j,k,ie:    4    1    1          43
 Near X =  0.32490696      0.56262942      0.86354515E-01, d:   0.0000000     -0.88754841       3.0778042
 i,j,k,ie:    5    1    1          43
 Near X =  0.32490696      0.56262942      0.11859381    , d:   0.0000000     -0.88754841       3.0778042
 i,j,k,ie:    6    1    1          43
 Near X =  0.32490696      0.56262942      0.13437970    , d:  0.32509302     -0.88754841       3.0778042
 i,j,k,ie:    1    2    1          43
 Near X =  0.28673938      0.57289305       0.0000000    , d:   0.0000000     -0.24857150       3.0778042
 i,j,k,ie:    6    2    1          43
 Near X =  0.28673938      0.57289305      0.13437970    , d:  0.24797486       0.0000000       3.0778042
 i,j,k,ie:    1    3    1          43
 Near X =  0.20879034      0.59385428       0.0000000    , d:   0.0000000     -0.92672642E-01   3.0778042
 i,j,k,ie:    6    3    1          43
 Near X =  0.20879034      0.59385428      0.13437970    , d:  0.26888856       0.0000000       3.0778042
 i,j,k,ie:    1    4    1          43
 Near X =  0.11611664      0.61877512       0.0000000    , d:  0.92675675E-01   0.0000000       3.0778042
 i,j,k,ie:    6    4    1          43
 Near X =  0.11611664      0.61877512      0.13437970    , d:  0.29375288       0.0000000       3.0778042
 i,j,k,ie:    1    5    1          43
 Near X =  0.38167602E-01  0.63973636       0.0000000    , d:  0.24857453       0.0000000       3.0778042
 i,j,k,ie:    6    5    1          43
 Near X =  0.38167602E-01  0.63973636      0.13437970    , d:  0.31466658       0.0000000       3.0778042
 i,j,k,ie:    1    6    1          43
 Near X =  0.25581813E-07  0.64999998       0.0000000    , d:  0.32491007     -0.56262946       3.0778042
 i,j,k,ie:    2    6    1          43
 Near X =  0.25581813E-07  0.64999998      0.15785898E-01, d:   0.0000000     -0.32491017       3.0778042
 i,j,k,ie:    3    6    1          43
 Near X =  0.25581813E-07  0.64999998      0.48025188E-01, d:   0.0000000     -0.32491017       3.0778042
 i,j,k,ie:    4    6    1          43
 Near X =  0.25581813E-07  0.64999998      0.86354515E-01, d:   0.0000000     -0.32491017       3.0778042
 i,j,k,ie:    5    6    1          43
 Near X =  0.25581813E-07  0.64999998      0.11859381    , d:   0.0000000     -0.32491017       3.0778042
 i,j,k,ie:    6    6    1          43
 Near X =  0.25581813E-07  0.64999998      0.13437970    , d:  0.32490693     -0.32491017       3.0778042
 i,j,k,ie:    1    1    2          43
 Near X =  0.31618384      0.54735430       0.0000000    , d:   0.0000000     -0.86355105       3.0778042
 i,j,k,ie:    2    1    2          43
 Near X =  0.31618384      0.54735430      0.15785898E-01, d:   0.0000000     -0.86355105       3.0778042
 i,j,k,ie:    3    1    2          43
 Near X =  0.31618384      0.54735430      0.48025188E-01, d:   0.0000000     -0.86355105       3.0778042
 i,j,k,ie:    4    1    2          43
 Near X =  0.31618384      0.54735430      0.86354515E-01, d:   0.0000000     -0.86355105       3.0778042
 i,j,k,ie:    5    1    2          43
 Near X =  0.31618384      0.54735430      0.11859381    , d:   0.0000000     -0.86355105       3.0778042
 i,j,k,ie:    6    1    2          43
 Near X =  0.31618384      0.54735430      0.13437970    , d:  0.31619529     -0.86355105       3.0778042
 i,j,k,ie:    1    2    2          43
 Near X =  0.27925788      0.55814934       0.0000000    , d:   0.0000000     -0.24189846       3.0778042
 i,j,k,ie:    6    2    2          43
 Near X =  0.27925788      0.55814934      0.13437970    , d:  0.24153304       0.0000000       3.0778042
 i,j,k,ie:    1    3    2          43
 Near X =  0.20366519      0.57952849       0.0000000    , d:   0.0000000     -0.90186359E-01   3.0778042
 i,j,k,ie:    6    3    2          43
 Near X =  0.20366519      0.57952849      0.13437970    , d:  0.26236858       0.0000000       3.0778042
 i,j,k,ie:    1    4    2          43
 Near X =  0.11347960      0.60378025       0.0000000    , d:  0.90184449E-01   0.0000000       3.0778042
 i,j,k,ie:    6    4    2          43
 Near X =  0.11347960      0.60378025      0.13437970    , d:  0.28661338       0.0000000       3.0778042
 i,j,k,ie:    1    5    2          43
 Near X =  0.37359764E-01  0.62319804       0.0000000    , d:  0.24189677       0.0000000       3.0778042
 i,j,k,ie:    6    5    2          43
 Near X =  0.37359764E-01  0.62319804      0.13437970    , d:  0.30656308       0.0000000       3.0778042
 i,j,k,ie:    1    6    2          43
 Near X =  0.24888316E-07  0.63237913       0.0000000    , d:  0.31618242     -0.54735434       3.0778042
 i,j,k,ie:    2    6    2          43
 Near X =  0.24888316E-07  0.63237913      0.15785898E-01, d:   0.0000000     -0.31618252       3.0778042
 i,j,k,ie:    3    6    2          43
 Near X =  0.24888316E-07  0.63237913      0.48025188E-01, d:   0.0000000     -0.31618252       3.0778042
 i,j,k,ie:    4    6    2          43
 Near X =  0.24888316E-07  0.63237913      0.86354515E-01, d:   0.0000000     -0.31618252       3.0778042
 i,j,k,ie:    5    6    2          43
 Near X =  0.24888316E-07  0.63237913      0.11859381    , d:   0.0000000     -0.31618252       3.0778042
 i,j,k,ie:    6    6    2          43
 Near X =  0.24888316E-07  0.63237913      0.13437970    , d:  0.31618382     -0.31618252       3.0778042
 i,j,k,ie:    1    1    3          43
 Near X =  0.29836876      0.51615817       0.0000000    , d:   0.0000000     -0.81454161       3.0778042
 i,j,k,ie:    2    1    3          43
 Near X =  0.29836876      0.51615817      0.15785898E-01, d:   0.0000000     -0.81454161       3.0778042
 i,j,k,ie:    3    1    3          43
 Near X =  0.29836876      0.51615817      0.48025188E-01, d:   0.0000000     -0.81454161       3.0778042
 i,j,k,ie:    4    1    3          43
 Near X =  0.29836876      0.51615817      0.86354515E-01, d:   0.0000000     -0.81454161       3.0778042
 i,j,k,ie:    5    1    3          43
 Near X =  0.29836876      0.51615817      0.11859381    , d:   0.0000000     -0.81454161       3.0778042
 i,j,k,ie:    6    1    3          43
 Near X =  0.29836876      0.51615817      0.13437970    , d:  0.29802359     -0.81454161       3.0778042
 i,j,k,ie:    1    2    3          43
 Near X =  0.26397852      0.52803851       0.0000000    , d:   0.0000000     -0.22827021       3.0778042
 i,j,k,ie:    6    2    3          43
 Near X =  0.26397852      0.52803851      0.13437970    , d:  0.22837703       0.0000000       3.0778042
 i,j,k,ie:    1    3    3          43
 Near X =  0.19319817      0.55027114       0.0000000    , d:   0.0000000     -0.85108664E-01   3.0778042
 i,j,k,ie:    6    3    3          43
 Near X =  0.19319817      0.55027114      0.13437970    , d:  0.24905293       0.0000000       3.0778042
 i,j,k,ie:    1    4    3          43
 Near X =  0.10809400      0.57315645       0.0000000    , d:  0.85096658E-01   0.0000000       3.0778042
 i,j,k,ie:    6    4    3          43
 Near X =  0.10809400      0.57315645      0.13437970    , d:  0.27203250       0.0000000       3.0778042
 i,j,k,ie:    1    5    3          43
 Near X =  0.35709928E-01  0.58942210       0.0000000    , d:  0.22825889       0.0000000       3.0778042
 i,j,k,ie:    6    5    3          43
 Near X =  0.35709928E-01  0.58942210      0.13437970    , d:  0.29001343       0.0000000       3.0778042
 i,j,k,ie:    1    6    3          43
 Near X =  0.23471997E-07  0.59639235       0.0000000    , d:  0.29835808     -0.51615820       3.0778042
 i,j,k,ie:    2    6    3          43
 Near X =  0.23471997E-07  0.59639235      0.15785898E-01, d:   0.0000000     -0.29835817       3.0778042
 i,j,k,ie:    3    6    3          43
 Near X =  0.23471997E-07  0.59639235      0.48025188E-01, d:   0.0000000     -0.29835817       3.0778042
 i,j,k,ie:    4    6    3          43
 Near X =  0.23471997E-07  0.59639235      0.86354515E-01, d:   0.0000000     -0.29835817       3.0778042
 i,j,k,ie:    5    6    3          43
 Near X =  0.23471997E-07  0.59639235      0.11859381    , d:   0.0000000     -0.29835817       3.0778042
 i,j,k,ie:    6    6    3          43
 Near X =  0.23471997E-07  0.59639235      0.13437970    , d:  0.29836873     -0.29835817       3.0778042
 i,j,k,ie:    1    1    4          43
 Near X =  0.27718839      0.47906904       0.0000000    , d:   0.0000000     -0.75627424       3.0778042
 i,j,k,ie:    2    1    4          43
 Near X =  0.27718839      0.47906904      0.15785898E-01, d:   0.0000000     -0.75627424       3.0778042
 i,j,k,ie:    3    1    4          43
 Near X =  0.27718839      0.47906904      0.48025188E-01, d:   0.0000000     -0.75627424       3.0778042
 i,j,k,ie:    4    1    4          43
 Near X =  0.27718839      0.47906904      0.86354515E-01, d:   0.0000000     -0.75627424       3.0778042
 i,j,k,ie:    5    1    4          43
 Near X =  0.27718839      0.47906904      0.11859381    , d:   0.0000000     -0.75627424       3.0778042
 i,j,k,ie:    6    1    4          43
 Near X =  0.27718839      0.47906904      0.13437970    , d:  0.27641924     -0.75627424       3.0778042
 i,j,k,ie:    1    2    4          43
 Near X =  0.24581287      0.49223970       0.0000000    , d:   0.0000000     -0.21206757       3.0778042
 i,j,k,ie:    6    2    4          43
 Near X =  0.24581287      0.49223970      0.13437970    , d:  0.21273584       0.0000000       3.0778042
 i,j,k,ie:    1    3    4          43
 Near X =  0.18075392      0.51548704       0.0000000    , d:   0.0000000     -0.79071786E-01   3.0778042
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    6    3    4          43
 Near X =  0.18075392      0.51548704      0.13437970    , d:  0.23322194       0.0000000       3.0778042
 i,j,k,ie:    1    4    4          43
 Near X =  0.10169106      0.53674780       0.0000000    , d:  0.79047778E-01   0.0000000       3.0778042
 i,j,k,ie:    6    4    4          43
 Near X =  0.10169106      0.53674780      0.13437970    , d:  0.25469728       0.0000000       3.0778042
 i,j,k,ie:    1    5    4          43
 Near X =  0.33748436E-01  0.54926584       0.0000000    , d:  0.21204480       0.0000000       3.0778042
 i,j,k,ie:    6    5    4          43
 Near X =  0.33748436E-01  0.54926584      0.13437970    , d:  0.27033754       0.0000000       3.0778042
 i,j,k,ie:    1    6    4          43
 Near X =  0.21788134E-07  0.55360763       0.0000000    , d:  0.27716671     -0.47906908       3.0778042
 i,j,k,ie:    2    6    4          43
 Near X =  0.21788134E-07  0.55360763      0.15785898E-01, d:   0.0000000     -0.27716680       3.0778042
 i,j,k,ie:    3    6    4          43
 Near X =  0.21788134E-07  0.55360763      0.48025188E-01, d:   0.0000000     -0.27716680       3.0778042
 i,j,k,ie:    4    6    4          43
 Near X =  0.21788134E-07  0.55360763      0.86354515E-01, d:   0.0000000     -0.27716680       3.0778042
 i,j,k,ie:    5    6    4          43
 Near X =  0.21788134E-07  0.55360763      0.11859381    , d:   0.0000000     -0.27716680       3.0778042
 i,j,k,ie:    6    6    4          43
 Near X =  0.21788134E-07  0.55360763      0.13437970    , d:  0.27718837     -0.27716680       3.0778042
 i,j,k,ie:    1    1    5          43
 Near X =  0.25937331      0.44787291       0.0000000    , d:   0.0000000     -0.70726480       3.0778042
 i,j,k,ie:    2    1    5          43
 Near X =  0.25937331      0.44787291      0.15785898E-01, d:   0.0000000     -0.70726480       3.0778042
 i,j,k,ie:    3    1    5          43
 Near X =  0.25937331      0.44787291      0.48025188E-01, d:   0.0000000     -0.70726480       3.0778042
 i,j,k,ie:    4    1    5          43
 Near X =  0.25937331      0.44787291      0.86354515E-01, d:   0.0000000     -0.70726480       3.0778042
 i,j,k,ie:    5    1    5          43
 Near X =  0.25937331      0.44787291      0.11859381    , d:   0.0000000     -0.70726480       3.0778042
 i,j,k,ie:    6    1    5          43
 Near X =  0.25937331      0.44787291      0.13437970    , d:  0.25824754     -0.70726480       3.0778042
 i,j,k,ie:    1    2    5          43
 Near X =  0.23053351      0.46212887       0.0000000    , d:   0.0000000     -0.19843932       3.0778042
 i,j,k,ie:    6    2    5          43
 Near X =  0.23053351      0.46212887      0.13437970    , d:  0.19957983       0.0000000       3.0778042
 i,j,k,ie:    1    3    5          43
 Near X =  0.17028690      0.48622969       0.0000000    , d:   0.0000000     -0.73994091E-01   3.0778042
 i,j,k,ie:    6    3    5          43
 Near X =  0.17028690      0.48622969      0.13437970    , d:  0.21990630       0.0000000       3.0778042
 i,j,k,ie:    1    4    5          43
 Near X =  0.96305460E-01  0.50612400       0.0000000    , d:  0.73959987E-01   0.0000000       3.0778042
 i,j,k,ie:    6    4    5          43
 Near X =  0.96305460E-01  0.50612400      0.13437970    , d:  0.24011640       0.0000000       3.0778042
 i,j,k,ie:    1    5    5          43
 Near X =  0.32098600E-01  0.51548990       0.0000000    , d:  0.19840692       0.0000000       3.0778042
 i,j,k,ie:    6    5    5          43
 Near X =  0.32098600E-01  0.51548990      0.13437970    , d:  0.25378789       0.0000000       3.0778042
 i,j,k,ie:    1    6    5          43
 Near X =  0.20371815E-07  0.51762085       0.0000000    , d:  0.25934238     -0.44787294       3.0778042
 i,j,k,ie:    2    6    5          43
 Near X =  0.20371815E-07  0.51762085      0.15785898E-01, d:   0.0000000     -0.25934246       3.0778042
 i,j,k,ie:    3    6    5          43
 Near X =  0.20371815E-07  0.51762085      0.48025188E-01, d:   0.0000000     -0.25934246       3.0778042
 i,j,k,ie:    4    6    5          43
 Near X =  0.20371815E-07  0.51762085      0.86354515E-01, d:   0.0000000     -0.25934246       3.0778042
 i,j,k,ie:    5    6    5          43
 Near X =  0.20371815E-07  0.51762085      0.11859381    , d:   0.0000000     -0.25934246       3.0778042
 i,j,k,ie:    6    6    5          43
 Near X =  0.20371815E-07  0.51762085      0.13437970    , d:  0.25937329     -0.25934246       3.0778042
 i,j,k,ie:    1    1    6          43
 Near X =  0.25065019      0.43259779       0.0000000    , d:  0.74256766E-01 -0.81329164       3.0778042
 i,j,k,ie:    2    1    6          43
 Near X =  0.25065019      0.43259779      0.15785898E-01, d:  0.74256766E-01 -0.81329164       3.0778042
 i,j,k,ie:    3    1    6          43
 Near X =  0.25065019      0.43259779      0.48025188E-01, d:  0.74256766E-01 -0.81329164       3.0778042
 i,j,k,ie:    4    1    6          43
 Near X =  0.25065019      0.43259779      0.86354515E-01, d:  0.74256766E-01 -0.81329164       3.0778042
 i,j,k,ie:    5    1    6          43
 Near X =  0.25065019      0.43259779      0.11859381    , d:  0.74256766E-01 -0.81329164       3.0778042
 i,j,k,ie:    6    1    6          43
 Near X =  0.25065019      0.43259779      0.13437970    , d:  0.39934979     -0.81329164       3.0778042
 i,j,k,ie:    1    2    6          43
 Near X =  0.22305201      0.44738516       0.0000000    , d:  0.63687370E-01 -0.19176628       3.0778042
 i,j,k,ie:    2    2    6          43
 Near X =  0.22305201      0.44738516      0.15785898E-01, d:  0.63687370E-01   0.0000000       3.0778042
 i,j,k,ie:    3    2    6          43
 Near X =  0.22305201      0.44738516      0.48025188E-01, d:  0.63687370E-01   0.0000000       3.0778042
 i,j,k,ie:    4    2    6          43
 Near X =  0.22305201      0.44738516      0.86354515E-01, d:  0.63687370E-01   0.0000000       3.0778042
 i,j,k,ie:    5    2    6          43
 Near X =  0.22305201      0.44738516      0.11859381    , d:  0.63687370E-01   0.0000000       3.0778042
 i,j,k,ie:    6    2    6          43
 Near X =  0.22305201      0.44738516      0.13437970    , d:  0.31166223       0.0000000       3.0778042
 i,j,k,ie:    1    3    6          43
 Near X =  0.16516174      0.47190390       0.0000000    , d:  0.43628597E-01 -0.71507808E-01   3.0778042
 i,j,k,ie:    2    3    6          43
 Near X =  0.16516174      0.47190390      0.15785898E-01, d:  0.43628597E-01   0.0000000       3.0778042
 i,j,k,ie:    3    3    6          43
 Near X =  0.16516174      0.47190390      0.48025188E-01, d:  0.43628597E-01   0.0000000       3.0778042
 i,j,k,ie:    4    3    6          43
 Near X =  0.16516174      0.47190390      0.86354515E-01, d:  0.43628597E-01   0.0000000       3.0778042
 i,j,k,ie:    5    3    6          43
 Near X =  0.16516174      0.47190390      0.11859381    , d:  0.43628597E-01   0.0000000       3.0778042
 i,j,k,ie:    6    3    6          43
 Near X =  0.16516174      0.47190390      0.13437970    , d:  0.31251715       0.0000000       3.0778042
 i,j,k,ie:    1    4    6          43
 Near X =  0.93668414E-01  0.49112913       0.0000000    , d:  0.11512390       0.0000000       3.0778042
 i,j,k,ie:    2    4    6          43
 Near X =  0.93668414E-01  0.49112913      0.15785898E-01, d:  0.22448229E-01   0.0000000       3.0778042
 i,j,k,ie:    3    4    6          43
 Near X =  0.93668414E-01  0.49112913      0.48025188E-01, d:  0.22448229E-01   0.0000000       3.0778042
 i,j,k,ie:    4    4    6          43
 Near X =  0.93668414E-01  0.49112913      0.86354515E-01, d:  0.22448229E-01   0.0000000       3.0778042
 i,j,k,ie:    5    4    6          43
 Near X =  0.93668414E-01  0.49112913      0.11859381    , d:  0.22448229E-01   0.0000000       3.0778042
 i,j,k,ie:    6    4    6          43
 Near X =  0.93668414E-01  0.49112913      0.13437970    , d:  0.31620111       0.0000000       3.0778042
 i,j,k,ie:    1    5    6          43
 Near X =  0.31290761E-01  0.49895158       0.0000000    , d:  0.25545137       0.0000000       3.0778042
 i,j,k,ie:    2    5    6          43
 Near X =  0.31290761E-01  0.49895158      0.15785898E-01, d:  0.68768409E-02   0.0000000       3.0778042
 i,j,k,ie:    3    5    6          43
 Near X =  0.31290761E-01  0.49895158      0.48025188E-01, d:  0.68768409E-02   0.0000000       3.0778042
 i,j,k,ie:    4    5    6          43
 Near X =  0.31290761E-01  0.49895158      0.86354515E-01, d:  0.68768409E-02   0.0000000       3.0778042
 i,j,k,ie:    5    5    6          43
 Near X =  0.31290761E-01  0.49895158      0.11859381    , d:  0.68768409E-02   0.0000000       3.0778042
 i,j,k,ie:    6    5    6          43
 Near X =  0.31290761E-01  0.49895158      0.13437970    , d:  0.32154342       0.0000000       3.0778042
 i,j,k,ie:    1    6    6          43
 Near X =  0.19678318E-07  0.50000000       0.0000000    , d:  0.32491007     -0.56262945       3.0778042
 i,j,k,ie:    2    6    6          43
 Near X =  0.19678318E-07  0.50000000      0.15785898E-01, d:  0.59034952E-08 -0.32491016       3.0778042
 i,j,k,ie:    3    6    6          43
 Near X =  0.19678318E-07  0.50000000      0.48025188E-01, d:  0.59034952E-08 -0.32491016       3.0778042
 i,j,k,ie:    4    6    6          43
 Near X =  0.19678318E-07  0.50000000      0.86354515E-01, d:  0.59034952E-08 -0.32491016       3.0778042
 i,j,k,ie:    5    6    6          43
 Near X =  0.19678318E-07  0.50000000      0.11859381    , d:  0.59034952E-08 -0.32491016       3.0778042
 i,j,k,ie:    6    6    6          43
 Near X =  0.19678318E-07  0.50000000      0.13437970    , d:  0.32490694     -0.32491016       3.0778042
 i,j,k,ie:    1    1    1          44
 Near X =  0.56264146      0.32491013       0.0000000    , d:  0.87358516E-01  -1.1252829       1.7773308
 i,j,k,ie:    2    1    1          44
 Near X =  0.56264146      0.32491013      0.15785898E-01, d:  0.87358516E-01   0.0000000       1.7773308
 i,j,k,ie:    3    1    1          44
 Near X =  0.56264146      0.32491013      0.48025188E-01, d:  0.87358516E-01   0.0000000       1.7773308
 i,j,k,ie:    4    1    1          44
 Near X =  0.56264146      0.32491013      0.86354515E-01, d:  0.87358516E-01   0.0000000       1.7773308
 i,j,k,ie:    5    1    1          44
 Near X =  0.56264146      0.32491013      0.11859381    , d:  0.87358516E-01   0.0000000       1.7773308
 i,j,k,ie:    6    1    1          44
 Near X =  0.56264146      0.32491013      0.13437970    , d:  0.87358516E-01   0.0000000       1.7773308
 i,j,k,ie:    1    2    1          44
 Near X =  0.53471424      0.35283557       0.0000000    , d:   0.0000000     -0.24797486       1.7773308
 i,j,k,ie:    1    3    1          44
 Near X =  0.47767890      0.40986726       0.0000000    , d:   0.0000000     -0.26888856       1.7773308
 i,j,k,ie:    1    4    1          44
 Near X =  0.40986952      0.47767229       0.0000000    , d:   0.0000000     -0.29375288       1.7773308
 i,j,k,ie:    1    5    1          44
 Near X =  0.35283418      0.53470398       0.0000000    , d:   0.0000000     -0.31466658       1.7773308
 i,j,k,ie:    1    6    1          44
 Near X =  0.32490696      0.56262942       0.0000000    , d:   0.0000000     -0.64981710       1.7773308
 i,j,k,ie:    2    6    1          44
 Near X =  0.32490696      0.56262942      0.15785898E-01, d:   0.0000000     -0.32490693       1.7773308
 i,j,k,ie:    3    6    1          44
 Near X =  0.32490696      0.56262942      0.48025188E-01, d:   0.0000000     -0.32490693       1.7773308
 i,j,k,ie:    4    6    1          44
 Near X =  0.32490696      0.56262942      0.86354515E-01, d:   0.0000000     -0.32490693       1.7773308
 i,j,k,ie:    5    6    1          44
 Near X =  0.32490696      0.56262942      0.11859381    , d:   0.0000000     -0.32490693       1.7773308
 i,j,k,ie:    6    6    1          44
 Near X =  0.32490696      0.56262942      0.13437970    , d:   0.0000000     -0.32490693       1.7773308
 i,j,k,ie:    1    1    2          44
 Near X =  0.54736722      0.31618248       0.0000000    , d:  0.85011915E-01  -1.0947344       1.7773308
 i,j,k,ie:    2    1    2          44
 Near X =  0.54736722      0.31618248      0.15785898E-01, d:  0.85011915E-01   0.0000000       1.7773308
 i,j,k,ie:    3    1    2          44
 Near X =  0.54736722      0.31618248      0.48025188E-01, d:  0.85011915E-01   0.0000000       1.7773308
 i,j,k,ie:    4    1    2          44
 Near X =  0.54736722      0.31618248      0.86354515E-01, d:  0.85011915E-01   0.0000000       1.7773308
 i,j,k,ie:    5    1    2          44
 Near X =  0.54736722      0.31618248      0.11859381    , d:  0.85011915E-01   0.0000000       1.7773308
 i,j,k,ie:    6    1    2          44
 Near X =  0.54736722      0.31618248      0.13437970    , d:  0.85011915E-01   0.0000000       1.7773308
 i,j,k,ie:    1    2    2          44
 Near X =  0.52079092      0.34392008       0.0000000    , d:   0.0000000     -0.24153304       1.7773308
 i,j,k,ie:    1    3    2          44
 Near X =  0.46603377      0.40008739       0.0000000    , d:   0.0000000     -0.26236858       1.7773308
 i,j,k,ie:    1    4    2          44
 Near X =  0.40009298      0.46602488       0.0000000    , d:   0.0000000     -0.28661338       1.7773308
 i,j,k,ie:    1    5    2          44
 Near X =  0.34392285      0.52077932       0.0000000    , d:   0.0000000     -0.30656308       1.7773308
 i,j,k,ie:    1    6    2          44
 Near X =  0.31618384      0.54735430       0.0000000    , d:   0.0000000     -0.63236633       1.7773308
 i,j,k,ie:    2    6    2          44
 Near X =  0.31618384      0.54735430      0.15785898E-01, d:   0.0000000     -0.31618382       1.7773308
 i,j,k,ie:    3    6    2          44
 Near X =  0.31618384      0.54735430      0.48025188E-01, d:   0.0000000     -0.31618382       1.7773308
 i,j,k,ie:    4    6    2          44
 Near X =  0.31618384      0.54735430      0.86354515E-01, d:   0.0000000     -0.31618382       1.7773308
 i,j,k,ie:    5    6    2          44
 Near X =  0.31618384      0.54735430      0.11859381    , d:   0.0000000     -0.31618382       1.7773308
 i,j,k,ie:    6    6    2          44
 Near X =  0.31618384      0.54735430      0.13437970    , d:   0.0000000     -0.31618382       1.7773308
 i,j,k,ie:    1    1    3          44
 Near X =  0.51617286      0.29835814       0.0000000    , d:  0.80219488E-01  -1.0323457       1.7773308
 i,j,k,ie:    2    1    3          44
 Near X =  0.51617286      0.29835814      0.15785898E-01, d:  0.80219488E-01   0.0000000       1.7773308
 i,j,k,ie:    3    1    3          44
 Near X =  0.51617286      0.29835814      0.48025188E-01, d:  0.80219488E-01   0.0000000       1.7773308
 i,j,k,ie:    4    1    3          44
 Near X =  0.51617286      0.29835814      0.86354515E-01, d:  0.80219488E-01   0.0000000       1.7773308
 i,j,k,ie:    5    1    3          44
 Near X =  0.51617286      0.29835814      0.11859381    , d:  0.80219488E-01   0.0000000       1.7773308
 i,j,k,ie:    6    1    3          44
 Near X =  0.51617286      0.29835814      0.13437970    , d:  0.80219488E-01   0.0000000       1.7773308
 i,j,k,ie:    1    2    3          44
 Near X =  0.49235555      0.32571212       0.0000000    , d:   0.0000000     -0.22837703       1.7773308
 i,j,k,ie:    1    3    3          44
 Near X =  0.44225110      0.38011411       0.0000000    , d:   0.0000000     -0.24905293       1.7773308
 i,j,k,ie:    1    4    3          44
 Near X =  0.38012650      0.44223754       0.0000000    , d:   0.0000000     -0.27203250       1.7773308
 i,j,k,ie:    1    5    3          44
 Near X =  0.32572336      0.49234119       0.0000000    , d:   0.0000000     -0.29001343       1.7773308
 i,j,k,ie:    1    6    3          44
 Near X =  0.29836876      0.51615817       0.0000000    , d:   0.0000000     -0.59672691       1.7773308
 i,j,k,ie:    2    6    3          44
 Near X =  0.29836876      0.51615817      0.15785898E-01, d:   0.0000000     -0.29836873       1.7773308
 i,j,k,ie:    3    6    3          44
 Near X =  0.29836876      0.51615817      0.48025188E-01, d:   0.0000000     -0.29836873       1.7773308
 i,j,k,ie:    4    6    3          44
 Near X =  0.29836876      0.51615817      0.86354515E-01, d:   0.0000000     -0.29836873       1.7773308
 i,j,k,ie:    5    6    3          44
 Near X =  0.29836876      0.51615817      0.11859381    , d:   0.0000000     -0.29836873       1.7773308
 i,j,k,ie:    6    6    3          44
 Near X =  0.29836876      0.51615817      0.13437970    , d:   0.0000000     -0.29836873       1.7773308
 i,j,k,ie:    1    1    4          44
 Near X =  0.47908586      0.27716676       0.0000000    , d:  0.74521768E-01 -0.95817171       1.7773308
 i,j,k,ie:    2    1    4          44
 Near X =  0.47908586      0.27716676      0.15785898E-01, d:  0.74521768E-01   0.0000000       1.7773308
 i,j,k,ie:    3    1    4          44
 Near X =  0.47908586      0.27716676      0.48025188E-01, d:  0.74521768E-01   0.0000000       1.7773308
 i,j,k,ie:    4    1    4          44
 Near X =  0.47908586      0.27716676      0.86354515E-01, d:  0.74521768E-01   0.0000000       1.7773308
 i,j,k,ie:    5    1    4          44
 Near X =  0.47908586      0.27716676      0.11859381    , d:  0.74521768E-01   0.0000000       1.7773308
 i,j,k,ie:    6    1    4          44
 Near X =  0.47908586      0.27716676      0.13437970    , d:  0.74521768E-01   0.0000000       1.7773308
 i,j,k,ie:    1    2    4          44
 Near X =  0.45854871      0.30406465       0.0000000    , d:   0.0000000     -0.21273584       1.7773308
 i,j,k,ie:    1    3    4          44
 Near X =  0.41397586      0.35636786       0.0000000    , d:   0.0000000     -0.23322194       1.7773308
 i,j,k,ie:    1    4    4          44
 Near X =  0.35638834      0.41395676       0.0000000    , d:   0.0000000     -0.25469728       1.7773308
 i,j,k,ie:    1    5    4          44
 Near X =  0.30408597      0.45853107       0.0000000    , d:   0.0000000     -0.27033754       1.7773308
 i,j,k,ie:    1    6    4          44
 Near X =  0.27718839      0.47906904       0.0000000    , d:   0.0000000     -0.55435516       1.7773308
 i,j,k,ie:    2    6    4          44
 Near X =  0.27718839      0.47906904      0.15785898E-01, d:   0.0000000     -0.27718837       1.7773308
 i,j,k,ie:    3    6    4          44
 Near X =  0.27718839      0.47906904      0.48025188E-01, d:   0.0000000     -0.27718837       1.7773308
 i,j,k,ie:    4    6    4          44
 Near X =  0.27718839      0.47906904      0.86354515E-01, d:   0.0000000     -0.27718837       1.7773308
 i,j,k,ie:    5    6    4          44
 Near X =  0.27718839      0.47906904      0.11859381    , d:   0.0000000     -0.27718837       1.7773308
 i,j,k,ie:    6    6    4          44
 Near X =  0.27718839      0.47906904      0.13437970    , d:   0.0000000     -0.27718837       1.7773308
 i,j,k,ie:    1    1    5          44
 Near X =  0.44789151      0.25934242       0.0000000    , d:  0.69729342E-01 -0.89578300       1.7773308
 i,j,k,ie:    2    1    5          44
 Near X =  0.44789151      0.25934242      0.15785898E-01, d:  0.69729342E-01   0.0000000       1.7773308
 i,j,k,ie:    3    1    5          44
 Near X =  0.44789151      0.25934242      0.48025188E-01, d:  0.69729342E-01   0.0000000       1.7773308
 i,j,k,ie:    4    1    5          44
 Near X =  0.44789151      0.25934242      0.86354515E-01, d:  0.69729342E-01   0.0000000       1.7773308
 i,j,k,ie:    5    1    5          44
 Near X =  0.44789151      0.25934242      0.11859381    , d:  0.69729342E-01   0.0000000       1.7773308
 i,j,k,ie:    6    1    5          44
 Near X =  0.44789151      0.25934242      0.13437970    , d:  0.69729342E-01   0.0000000       1.7773308
 i,j,k,ie:    1    2    5          44
 Near X =  0.43011334      0.28585669       0.0000000    , d:   0.0000000     -0.19957983       1.7773308
 i,j,k,ie:    1    3    5          44
 Near X =  0.39019319      0.33639459       0.0000000    , d:   0.0000000     -0.21990630       1.7773308
 i,j,k,ie:    1    4    5          44
 Near X =  0.33642186      0.39016942       0.0000000    , d:   0.0000000     -0.24011640       1.7773308
 i,j,k,ie:    1    5    5          44
 Near X =  0.28588649      0.43009294       0.0000000    , d:   0.0000000     -0.25378789       1.7773308
 i,j,k,ie:    1    6    5          44
 Near X =  0.25937331      0.44787291       0.0000000    , d:   0.0000000     -0.51871574       1.7773308
 i,j,k,ie:    2    6    5          44
 Near X =  0.25937331      0.44787291      0.15785898E-01, d:   0.0000000     -0.25937329       1.7773308
 i,j,k,ie:    3    6    5          44
 Near X =  0.25937331      0.44787291      0.48025188E-01, d:   0.0000000     -0.25937329       1.7773308
 i,j,k,ie:    4    6    5          44
 Near X =  0.25937331      0.44787291      0.86354515E-01, d:   0.0000000     -0.25937329       1.7773308
 i,j,k,ie:    5    6    5          44
 Near X =  0.25937331      0.44787291      0.11859381    , d:   0.0000000     -0.25937329       1.7773308
 i,j,k,ie:    6    6    5          44
 Near X =  0.25937331      0.44787291      0.13437970    , d:   0.0000000     -0.25937329       1.7773308
 i,j,k,ie:    1    1    6          44
 Near X =  0.43261726      0.25061477       0.0000000    , d:  0.21738272     -0.99525871       1.7773308
 i,j,k,ie:    2    1    6          44
 Near X =  0.43261726      0.25061477      0.15785898E-01, d:  0.21738272       0.0000000       1.7773308
 i,j,k,ie:    3    1    6          44
 Near X =  0.43261726      0.25061477      0.48025188E-01, d:  0.21738272       0.0000000       1.7773308
 i,j,k,ie:    4    1    6          44
 Near X =  0.43261726      0.25061477      0.86354515E-01, d:  0.21738272       0.0000000       1.7773308
 i,j,k,ie:    5    1    6          44
 Near X =  0.43261726      0.25061477      0.11859381    , d:  0.21738272       0.0000000       1.7773308
 i,j,k,ie:    6    1    6          44
 Near X =  0.43261726      0.25061477      0.13437970    , d:  0.21738272       0.0000000       1.7773308
 i,j,k,ie:    1    2    6          44
 Near X =  0.41619002      0.27694120       0.0000000    , d:  0.11852421     -0.19313801       1.7773308
 i,j,k,ie:    2    2    6          44
 Near X =  0.41619002      0.27694120      0.15785898E-01, d:  0.11852421       0.0000000       1.7773308
 i,j,k,ie:    3    2    6          44
 Near X =  0.41619002      0.27694120      0.48025188E-01, d:  0.11852421       0.0000000       1.7773308
 i,j,k,ie:    4    2    6          44
 Near X =  0.41619002      0.27694120      0.86354515E-01, d:  0.11852421       0.0000000       1.7773308
 i,j,k,ie:    5    2    6          44
 Near X =  0.41619002      0.27694120      0.11859381    , d:  0.11852421       0.0000000       1.7773308
 i,j,k,ie:    6    2    6          44
 Near X =  0.41619002      0.27694120      0.13437970    , d:  0.11852421       0.0000000       1.7773308
 i,j,k,ie:    1    3    6          44
 Near X =  0.37854806      0.32661472       0.0000000    , d:  0.99130836E-01 -0.21338632       1.7773308
 i,j,k,ie:    2    3    6          44
 Near X =  0.37854806      0.32661472      0.15785898E-01, d:  0.99130836E-01   0.0000000       1.7773308
 i,j,k,ie:    3    3    6          44
 Near X =  0.37854806      0.32661472      0.48025188E-01, d:  0.99130836E-01   0.0000000       1.7773308
 i,j,k,ie:    4    3    6          44
 Near X =  0.37854806      0.32661472      0.86354515E-01, d:  0.99130836E-01   0.0000000       1.7773308
 i,j,k,ie:    5    3    6          44
 Near X =  0.37854806      0.32661472      0.11859381    , d:  0.99130836E-01   0.0000000       1.7773308
 i,j,k,ie:    6    3    6          44
 Near X =  0.37854806      0.32661472      0.13437970    , d:  0.99130836E-01   0.0000000       1.7773308
 i,j,k,ie:    1    4    6          44
 Near X =  0.32664532      0.37852201       0.0000000    , d:  0.83224205E-01 -0.23297690       1.7773308
 i,j,k,ie:    2    4    6          44
 Near X =  0.32664532      0.37852201      0.15785898E-01, d:  0.83224205E-01   0.0000000       1.7773308
 i,j,k,ie:    3    4    6          44
 Near X =  0.32664532      0.37852201      0.48025188E-01, d:  0.83224205E-01   0.0000000       1.7773308
 i,j,k,ie:    4    4    6          44
 Near X =  0.32664532      0.37852201      0.86354515E-01, d:  0.83224205E-01   0.0000000       1.7773308
 i,j,k,ie:    5    4    6          44
 Near X =  0.32664532      0.37852201      0.11859381    , d:  0.83224205E-01   0.0000000       1.7773308
 i,j,k,ie:    6    4    6          44
 Near X =  0.32664532      0.37852201      0.13437970    , d:  0.83224205E-01   0.0000000       1.7773308
 i,j,k,ie:    1    5    6          44
 Near X =  0.27697515      0.41616828       0.0000000    , d:  0.75859037E-01 -0.24568439       1.7773308
 i,j,k,ie:    2    5    6          44
 Near X =  0.27697515      0.41616828      0.15785898E-01, d:  0.75859037E-01   0.0000000       1.7773308
 i,j,k,ie:    3    5    6          44
 Near X =  0.27697515      0.41616828      0.48025188E-01, d:  0.75859037E-01   0.0000000       1.7773308
 i,j,k,ie:    4    5    6          44
 Near X =  0.27697515      0.41616828      0.86354515E-01, d:  0.75859037E-01   0.0000000       1.7773308
 i,j,k,ie:    5    5    6          44
 Near X =  0.27697515      0.41616828      0.11859381    , d:  0.75859037E-01   0.0000000       1.7773308
 i,j,k,ie:    6    5    6          44
 Near X =  0.27697515      0.41616828      0.13437970    , d:  0.75859037E-01   0.0000000       1.7773308
 i,j,k,ie:    1    6    6          44
 Near X =  0.25065019      0.43259779       0.0000000    , d:  0.74256766E-01 -0.57556033       1.7773308
 i,j,k,ie:    2    6    6          44
 Near X =  0.25065019      0.43259779      0.15785898E-01, d:  0.74256766E-01 -0.25065017       1.7773308
 i,j,k,ie:    3    6    6          44
 Near X =  0.25065019      0.43259779      0.48025188E-01, d:  0.74256766E-01 -0.25065017       1.7773308
 i,j,k,ie:    4    6    6          44
 Near X =  0.25065019      0.43259779      0.86354515E-01, d:  0.74256766E-01 -0.25065017       1.7773308
 i,j,k,ie:    5    6    6          44
 Near X =  0.25065019      0.43259779      0.11859381    , d:  0.74256766E-01 -0.25065017       1.7773308
 i,j,k,ie:    6    6    6          44
 Near X =  0.25065019      0.43259779      0.13437970    , d:  0.74256766E-01 -0.25065017       1.7773308
 i,j,k,ie:    1    1    1          45
 Near X =  0.64999998     -0.36515901E-07   0.0000000    , d:   0.0000000     -0.87370572E-01   1.5384616
 i,j,k,ie:    2    1    1          45
 Near X =  0.64999998     -0.36515901E-07  0.15785898E-01, d:   0.0000000     -0.87370572E-01   1.5384616
 i,j,k,ie:    3    1    1          45
 Near X =  0.64999998     -0.36515901E-07  0.48025188E-01, d:   0.0000000     -0.87370572E-01   1.5384616
 i,j,k,ie:    4    1    1          45
 Near X =  0.64999998     -0.36515901E-07  0.86354515E-01, d:   0.0000000     -0.87370572E-01   1.5384616
 i,j,k,ie:    5    1    1          45
 Near X =  0.64999998     -0.36515901E-07  0.11859381    , d:   0.0000000     -0.87370572E-01   1.5384616
 i,j,k,ie:    6    1    1          45
 Near X =  0.64999998     -0.36515901E-07  0.13437970    , d:   0.0000000      -1.2126294       1.5384616
 i,j,k,ie:    6    2    1          45
 Near X =  0.63973777      0.38167920E-01  0.13437970    , d:   0.0000000      -1.2126308       1.5384616
 i,j,k,ie:    6    3    1          45
 Near X =  0.61877942      0.11611774      0.13437970    , d:   0.0000000      -1.2126337       1.5384616
 i,j,k,ie:    6    4    1          45
 Near X =  0.59386202      0.20879236      0.13437970    , d:   0.0000000      -1.2126371       1.5384616
 i,j,k,ie:    6    5    1          45
 Near X =  0.57290367      0.28674217      0.13437970    , d:   0.0000000      -1.2126400       1.5384616
 i,j,k,ie:    1    6    1          45
 Near X =  0.56264146      0.32491013       0.0000000    , d:   0.0000000      -1.8604349       1.5384616
 i,j,k,ie:    2    6    1          45
 Near X =  0.56264146      0.32491013      0.15785898E-01, d:   0.0000000      -1.8604349       1.5384616
 i,j,k,ie:    3    6    1          45
 Near X =  0.56264146      0.32491013      0.48025188E-01, d:   0.0000000      -1.8604349       1.5384616
 i,j,k,ie:    4    6    1          45
 Near X =  0.56264146      0.32491013      0.86354515E-01, d:   0.0000000      -1.8604349       1.5384616
 i,j,k,ie:    5    6    1          45
 Near X =  0.56264146      0.32491013      0.11859381    , d:   0.0000000      -1.8604349       1.5384616
 i,j,k,ie:    6    6    1          45
 Near X =  0.56264146      0.32491013      0.13437970    , d:   0.0000000      -1.8604349       1.5384616
 i,j,k,ie:    1    1    2          45
 Near X =  0.63237913     -0.36850045E-07   0.0000000    , d:   0.0000000     -0.85024843E-01   1.5384616
 i,j,k,ie:    2    1    2          45
 Near X =  0.63237913     -0.36850045E-07  0.15785898E-01, d:   0.0000000     -0.85024843E-01   1.5384616
 i,j,k,ie:    3    1    2          45
 Near X =  0.63237913     -0.36850045E-07  0.48025188E-01, d:   0.0000000     -0.85024843E-01   1.5384616
 i,j,k,ie:    4    1    2          45
 Near X =  0.63237913     -0.36850045E-07  0.86354515E-01, d:   0.0000000     -0.85024843E-01   1.5384616
 i,j,k,ie:    5    1    2          45
 Near X =  0.63237913     -0.36850045E-07  0.11859381    , d:   0.0000000     -0.85024843E-01   1.5384616
 i,j,k,ie:    6    1    2          45
 Near X =  0.63237913     -0.36850045E-07  0.13437970    , d:   0.0000000      -1.1797334       1.5384616
 i,j,k,ie:    6    2    2          45
 Near X =  0.62319934      0.37359456E-01  0.13437970    , d:   0.0000000      -1.1813487       1.5384616
 i,j,k,ie:    6    3    2          45
 Near X =  0.60378438      0.11347886      0.13437970    , d:   0.0000000      -1.1833129       1.5384616
 i,j,k,ie:    6    4    2          45
 Near X =  0.57953630      0.20366408      0.13437970    , d:   0.0000000      -1.1833166       1.5384616
 i,j,k,ie:    6    5    2          45
 Near X =  0.55816052      0.27925657      0.13437970    , d:   0.0000000      -1.1813586       1.5384616
 i,j,k,ie:    1    6    2          45
 Near X =  0.54736722      0.31618248       0.0000000    , d:   0.0000000      -1.8299767       1.5384616
 i,j,k,ie:    2    6    2          45
 Near X =  0.54736722      0.31618248      0.15785898E-01, d:   0.0000000      -1.8299767       1.5384616
 i,j,k,ie:    3    6    2          45
 Near X =  0.54736722      0.31618248      0.48025188E-01, d:   0.0000000      -1.8299767       1.5384616
 i,j,k,ie:    4    6    2          45
 Near X =  0.54736722      0.31618248      0.86354515E-01, d:   0.0000000      -1.8299767       1.5384616
 i,j,k,ie:    5    6    2          45
 Near X =  0.54736722      0.31618248      0.11859381    , d:   0.0000000      -1.8299767       1.5384616
 i,j,k,ie:    6    6    2          45
 Near X =  0.54736722      0.31618248      0.13437970    , d:   0.0000000      -1.8299767       1.5384616
 i,j,k,ie:    1    1    3          45
 Near X =  0.59639235     -0.37532464E-07   0.0000000    , d:   0.0000000     -0.80234198E-01   1.5384616
 i,j,k,ie:    2    1    3          45
 Near X =  0.59639235     -0.37532464E-07  0.15785898E-01, d:   0.0000000     -0.80234198E-01   1.5384616
 i,j,k,ie:    3    1    3          45
 Near X =  0.59639235     -0.37532464E-07  0.48025188E-01, d:   0.0000000     -0.80234198E-01   1.5384616
 i,j,k,ie:    4    1    3          45
 Near X =  0.59639235     -0.37532464E-07  0.86354515E-01, d:   0.0000000     -0.80234198E-01   1.5384616
 i,j,k,ie:    5    1    3          45
 Near X =  0.59639235     -0.37532464E-07  0.11859381    , d:   0.0000000     -0.80234198E-01   1.5384616
 i,j,k,ie:    6    1    3          45
 Near X =  0.59639235     -0.37532464E-07  0.13437970    , d:   0.0000000      -1.1125505       1.5384616
 i,j,k,ie:    6    2    3          45
 Near X =  0.58942316      0.35708342E-01  0.13437970    , d:   0.0000000      -1.1174617       1.5384616
 i,j,k,ie:    6    3    3          45
 Near X =  0.57316024      0.10808953      0.13437970    , d:   0.0000000      -1.1234314       1.5384616
 i,j,k,ie:    6    4    3          45
 Near X =  0.55027912      0.19319069      0.13437970    , d:   0.0000000      -1.1234356       1.5384616
 i,j,k,ie:    6    5    3          45
 Near X =  0.52805082      0.26396885      0.13437970    , d:   0.0000000      -1.1174729       1.5384616
 i,j,k,ie:    1    6    3          45
 Near X =  0.51617286      0.29835814       0.0000000    , d:   0.0000000      -1.7677725       1.5384616
 i,j,k,ie:    2    6    3          45
 Near X =  0.51617286      0.29835814      0.15785898E-01, d:   0.0000000      -1.7677725       1.5384616
 i,j,k,ie:    3    6    3          45
 Near X =  0.51617286      0.29835814      0.48025188E-01, d:   0.0000000      -1.7677725       1.5384616
 i,j,k,ie:    4    6    3          45
 Near X =  0.51617286      0.29835814      0.86354515E-01, d:   0.0000000      -1.7677725       1.5384616
 i,j,k,ie:    5    6    3          45
 Near X =  0.51617286      0.29835814      0.11859381    , d:   0.0000000      -1.7677725       1.5384616
 i,j,k,ie:    6    6    3          45
 Near X =  0.51617286      0.29835814      0.13437970    , d:   0.0000000      -1.7677725       1.5384616
 i,j,k,ie:    1    1    4          45
 Near X =  0.55360763     -0.38343791E-07   0.0000000    , d:   0.0000000     -0.74538595E-01   1.5384616
 i,j,k,ie:    2    1    4          45
 Near X =  0.55360763     -0.38343791E-07  0.15785898E-01, d:   0.0000000     -0.74538595E-01   1.5384616
 i,j,k,ie:    3    1    4          45
 Near X =  0.55360763     -0.38343791E-07  0.48025188E-01, d:   0.0000000     -0.74538595E-01   1.5384616
 i,j,k,ie:    4    1    4          45
 Near X =  0.55360763     -0.38343791E-07  0.86354515E-01, d:   0.0000000     -0.74538595E-01   1.5384616
 i,j,k,ie:    5    1    4          45
 Near X =  0.55360763     -0.38343791E-07  0.11859381    , d:   0.0000000     -0.74538595E-01   1.5384616
 i,j,k,ie:    6    1    4          45
 Near X =  0.55360763     -0.38343791E-07  0.13437970    , d:   0.0000000      -1.0326767       1.5384616
 i,j,k,ie:    6    2    4          45
 Near X =  0.54926663      0.33745331E-01  0.13437970    , d:   0.0000000      -1.0415063       1.5384616
 i,j,k,ie:    6    3    4          45
 Near X =  0.53675118      0.10168216      0.13437970    , d:   0.0000000      -1.0522382       1.5384616
 i,j,k,ie:    6    4    4          45
 Near X =  0.51549522      0.18073886      0.13437970    , d:   0.0000000      -1.0522430       1.5384616
 i,j,k,ie:    6    5    4          45
 Near X =  0.49225336      0.24579327      0.13437970    , d:   0.0000000      -1.0415192       1.5384616
 i,j,k,ie:    1    6    4          45
 Near X =  0.47908586      0.27716676       0.0000000    , d:   0.0000000      -1.6938178       1.5384616
 i,j,k,ie:    2    6    4          45
 Near X =  0.47908586      0.27716676      0.15785898E-01, d:   0.0000000      -1.6938178       1.5384616
 i,j,k,ie:    3    6    4          45
 Near X =  0.47908586      0.27716676      0.48025188E-01, d:   0.0000000      -1.6938178       1.5384616
 i,j,k,ie:    4    6    4          45
 Near X =  0.47908586      0.27716676      0.86354515E-01, d:   0.0000000      -1.6938178       1.5384616
 i,j,k,ie:    5    6    4          45
 Near X =  0.47908586      0.27716676      0.11859381    , d:   0.0000000      -1.6938178       1.5384616
 i,j,k,ie:    6    6    4          45
 Near X =  0.47908586      0.27716676      0.13437970    , d:   0.0000000      -1.6938178       1.5384616
 i,j,k,ie:    1    1    5          45
 Near X =  0.51762085     -0.39026209E-07   0.0000000    , d:   0.0000000     -0.69747950E-01   1.5384616
 i,j,k,ie:    2    1    5          45
 Near X =  0.51762085     -0.39026209E-07  0.15785898E-01, d:   0.0000000     -0.69747950E-01   1.5384616
 i,j,k,ie:    3    1    5          45
 Near X =  0.51762085     -0.39026209E-07  0.48025188E-01, d:   0.0000000     -0.69747950E-01   1.5384616
 i,j,k,ie:    4    1    5          45
 Near X =  0.51762085     -0.39026209E-07  0.86354515E-01, d:   0.0000000     -0.69747950E-01   1.5384616
 i,j,k,ie:    5    1    5          45
 Near X =  0.51762085     -0.39026209E-07  0.11859381    , d:   0.0000000     -0.69747950E-01   1.5384616
 i,j,k,ie:    6    1    5          45
 Near X =  0.51762085     -0.39026209E-07  0.13437970    , d:   0.0000000     -0.96549377       1.5384616
 i,j,k,ie:    6    2    5          45
 Near X =  0.51549046      0.32094217E-01  0.13437970    , d:   0.0000000     -0.97761933       1.5384616
 i,j,k,ie:    6    3    5          45
 Near X =  0.50612704      0.96292827E-01  0.13437970    , d:   0.0000000     -0.99235674       1.5384616
 i,j,k,ie:    6    4    5          45
 Near X =  0.48623803      0.17026547      0.13437970    , d:   0.0000000     -0.99236204       1.5384616
 i,j,k,ie:    6    5    5          45
 Near X =  0.46214365      0.23050555      0.13437970    , d:   0.0000000     -0.97763355       1.5384616
 i,j,k,ie:    1    6    5          45
 Near X =  0.44789151      0.25934242       0.0000000    , d:   0.0000000      -1.6316135       1.5384616
 i,j,k,ie:    2    6    5          45
 Near X =  0.44789151      0.25934242      0.15785898E-01, d:   0.0000000      -1.6316135       1.5384616
 i,j,k,ie:    3    6    5          45
 Near X =  0.44789151      0.25934242      0.48025188E-01, d:   0.0000000      -1.6316135       1.5384616
 i,j,k,ie:    4    6    5          45
 Near X =  0.44789151      0.25934242      0.86354515E-01, d:   0.0000000      -1.6316135       1.5384616
 i,j,k,ie:    5    6    5          45
 Near X =  0.44789151      0.25934242      0.11859381    , d:   0.0000000      -1.6316135       1.5384616
 i,j,k,ie:    6    6    5          45
 Near X =  0.44789151      0.25934242      0.13437970    , d:   0.0000000      -1.6316135       1.5384616
 i,j,k,ie:    1    1    6          45
 Near X =  0.50000000     -0.39360354E-07   0.0000000    , d:  0.14999998     -0.67402221E-01   1.5384616
 i,j,k,ie:    2    1    6          45
 Near X =  0.50000000     -0.39360354E-07  0.15785898E-01, d:  0.14999998     -0.67402221E-01   1.5384616
 i,j,k,ie:    3    1    6          45
 Near X =  0.50000000     -0.39360354E-07  0.48025188E-01, d:  0.14999998     -0.67402221E-01   1.5384616
 i,j,k,ie:    4    1    6          45
 Near X =  0.50000000     -0.39360354E-07  0.86354515E-01, d:  0.14999998     -0.67402221E-01   1.5384616
 i,j,k,ie:    5    1    6          45
 Near X =  0.50000000     -0.39360354E-07  0.11859381    , d:  0.14999998     -0.67402221E-01   1.5384616
 i,j,k,ie:    6    1    6          45
 Near X =  0.50000000     -0.39360354E-07  0.13437970    , d:  0.14999998      -1.0626294       1.5384616
 i,j,k,ie:    1    2    6          45
 Near X =  0.49895203      0.31285752E-01   0.0000000    , d:  0.14078574       0.0000000       1.5384616
 i,j,k,ie:    2    2    6          45
 Near X =  0.49895203      0.31285752E-01  0.15785898E-01, d:  0.14078574       0.0000000       1.5384616
 i,j,k,ie:    3    2    6          45
 Near X =  0.49895203      0.31285752E-01  0.48025188E-01, d:  0.14078574       0.0000000       1.5384616
 i,j,k,ie:    4    2    6          45
 Near X =  0.49895203      0.31285752E-01  0.86354515E-01, d:  0.14078574       0.0000000       1.5384616
 i,j,k,ie:    5    2    6          45
 Near X =  0.49895203      0.31285752E-01  0.11859381    , d:  0.14078574       0.0000000       1.5384616
 i,j,k,ie:    6    2    6          45
 Near X =  0.49895203      0.31285752E-01  0.13437970    , d:  0.14078574      -1.0718451       1.5384616
 i,j,k,ie:    1    3    6          45
 Near X =  0.49113200      0.93653953E-01   0.0000000    , d:  0.12764742       0.0000000       1.5384616
 i,j,k,ie:    2    3    6          45
 Near X =  0.49113200      0.93653953E-01  0.15785898E-01, d:  0.12764742       0.0000000       1.5384616
 i,j,k,ie:    3    3    6          45
 Near X =  0.49113200      0.93653953E-01  0.48025188E-01, d:  0.12764742       0.0000000       1.5384616
 i,j,k,ie:    4    3    6          45
 Near X =  0.49113200      0.93653953E-01  0.86354515E-01, d:  0.12764742       0.0000000       1.5384616
 i,j,k,ie:    5    3    6          45
 Near X =  0.49113200      0.93653953E-01  0.11859381    , d:  0.12764742       0.0000000       1.5384616
 i,j,k,ie:    6    3    6          45
 Near X =  0.49113200      0.93653953E-01  0.13437970    , d:  0.12764742      -1.0849863       1.5384616
 i,j,k,ie:    1    4    6          45
 Near X =  0.47191232      0.16513720       0.0000000    , d:  0.12194970       0.0000000       1.5384616
 i,j,k,ie:    2    4    6          45
 Near X =  0.47191232      0.16513720      0.15785898E-01, d:  0.12194970       0.0000000       1.5384616
 i,j,k,ie:    3    4    6          45
 Near X =  0.47191232      0.16513720      0.48025188E-01, d:  0.12194970       0.0000000       1.5384616
 i,j,k,ie:    4    4    6          45
 Near X =  0.47191232      0.16513720      0.86354515E-01, d:  0.12194970       0.0000000       1.5384616
 i,j,k,ie:    5    4    6          45
 Near X =  0.47191232      0.16513720      0.11859381    , d:  0.12194970       0.0000000       1.5384616
 i,j,k,ie:    6    4    6          45
 Near X =  0.47191232      0.16513720      0.13437970    , d:  0.12194970      -1.0906874       1.5384616
 i,j,k,ie:    1    5    6          45
 Near X =  0.44740050      0.22301995       0.0000000    , d:  0.12550317       0.0000000       1.5384616
 i,j,k,ie:    2    5    6          45
 Near X =  0.44740050      0.22301995      0.15785898E-01, d:  0.12550317       0.0000000       1.5384616
 i,j,k,ie:    3    5    6          45
 Near X =  0.44740050      0.22301995      0.48025188E-01, d:  0.12550317       0.0000000       1.5384616
 i,j,k,ie:    4    5    6          45
 Near X =  0.44740050      0.22301995      0.86354515E-01, d:  0.12550317       0.0000000       1.5384616
 i,j,k,ie:    5    5    6          45
 Near X =  0.44740050      0.22301995      0.11859381    , d:  0.12550317       0.0000000       1.5384616
 i,j,k,ie:    6    5    6          45
 Near X =  0.44740050      0.22301995      0.13437970    , d:  0.12550317      -1.0871369       1.5384616
 i,j,k,ie:    1    6    6          45
 Near X =  0.43261726      0.25061477       0.0000000    , d:  0.13002420      -1.7304107       1.5384616
 i,j,k,ie:    2    6    6          45
 Near X =  0.43261726      0.25061477      0.15785898E-01, d:  0.13002420      -1.7304107       1.5384616
 i,j,k,ie:    3    6    6          45
 Near X =  0.43261726      0.25061477      0.48025188E-01, d:  0.13002420      -1.7304107       1.5384616
 i,j,k,ie:    4    6    6          45
 Near X =  0.43261726      0.25061477      0.86354515E-01, d:  0.13002420      -1.7304107       1.5384616
 i,j,k,ie:    5    6    6          45
 Near X =  0.43261726      0.25061477      0.11859381    , d:  0.13002420      -1.7304107       1.5384616
 i,j,k,ie:    6    6    6          45
 Near X =  0.43261726      0.25061477      0.13437970    , d:  0.13002420      -1.7304107       1.5384616
 i,j,k,ie:    1    1    1          46
 Near X = -0.56262943      0.32490693       0.0000000    , d:   1.2126294       0.0000000       1.5384616
 i,j,k,ie:    2    1    1          46
 Near X = -0.56262943      0.32490693      0.15785898E-01, d:  0.88753952       0.0000000       1.5384616
 i,j,k,ie:    3    1    1          46
 Near X = -0.56262943      0.32490693      0.48025188E-01, d:  0.88753952       0.0000000       1.5384616
 i,j,k,ie:    4    1    1          46
 Near X = -0.56262943      0.32490693      0.86354515E-01, d:  0.88753952       0.0000000       1.5384616
 i,j,k,ie:    5    1    1          46
 Near X = -0.56262943      0.32490693      0.11859381    , d:  0.88753952       0.0000000       1.5384616
 i,j,k,ie:    6    1    1          46
 Near X = -0.56262943      0.32490693      0.13437970    , d:  0.88753952       0.0000000       1.5384616
 i,j,k,ie:    1    2    1          46
 Near X = -0.57289305      0.28673936       0.0000000    , d:   1.2126308       0.0000000       1.5384616
 i,j,k,ie:    6    2    1          46
 Near X = -0.57289305      0.28673936      0.13437970    , d:  0.22005747       0.0000000       1.5384616
 i,j,k,ie:    1    3    1          46
 Near X = -0.59385429      0.20879032       0.0000000    , d:   1.2126337       0.0000000       1.5384616
 i,j,k,ie:    6    3    1          46
 Near X = -0.59385429      0.20879032      0.13437970    , d:  0.18398702       0.0000000       1.5384616
 i,j,k,ie:    1    4    1          46
 Near X = -0.61877512      0.11611662       0.0000000    , d:   1.2126371       0.0000000       1.5384616
 i,j,k,ie:    6    4    1          46
 Near X = -0.61877512      0.11611662      0.13437970    , d:  0.14110282       0.0000000       1.5384616
 i,j,k,ie:    1    5    1          46
 Near X = -0.63973636      0.38167577E-01   0.0000000    , d:   1.2126400       0.0000000       1.5384616
 i,j,k,ie:    6    5    1          46
 Near X = -0.63973636      0.38167577E-01  0.13437970    , d:  0.10503237       0.0000000       1.5384616
 i,j,k,ie:    1    6    1          46
 Near X = -0.64999998     -0.15920408E-15   0.0000000    , d:   1.2126414     -0.64779341       1.5384616
 i,j,k,ie:    2    6    1          46
 Near X = -0.64999998     -0.15920408E-15  0.15785898E-01, d:   0.0000000     -0.10184438       1.5384616
 i,j,k,ie:    3    6    1          46
 Near X = -0.64999998     -0.15920408E-15  0.48025188E-01, d:   0.0000000     -0.10184438       1.5384616
 i,j,k,ie:    4    6    1          46
 Near X = -0.64999998     -0.15920408E-15  0.86354515E-01, d:   0.0000000     -0.10184438       1.5384616
 i,j,k,ie:    5    6    1          46
 Near X = -0.64999998     -0.15920408E-15  0.11859381    , d:   0.0000000     -0.10184438       1.5384616
 i,j,k,ie:    6    6    1          46
 Near X = -0.64999998     -0.15920408E-15  0.13437970    , d:  0.65000004     -0.10184438       1.5384616
 i,j,k,ie:    1    1    2          46
 Near X = -0.54735431      0.31618382       0.0000000    , d:   1.1797334       0.0000000       1.5384616
 i,j,k,ie:    2    1    2          46
 Near X = -0.54735431      0.31618382      0.15785898E-01, d:  0.86353675       0.0000000       1.5384616
 i,j,k,ie:    3    1    2          46
 Near X = -0.54735431      0.31618382      0.48025188E-01, d:  0.86353675       0.0000000       1.5384616
 i,j,k,ie:    4    1    2          46
 Near X = -0.54735431      0.31618382      0.86354515E-01, d:  0.86353675       0.0000000       1.5384616
 i,j,k,ie:    5    1    2          46
 Near X = -0.54735431      0.31618382      0.11859381    , d:  0.86353675       0.0000000       1.5384616
 i,j,k,ie:    6    1    2          46
 Near X = -0.54735431      0.31618382      0.13437970    , d:  0.86353675       0.0000000       1.5384616
 i,j,k,ie:    1    2    2          46
 Near X = -0.55814935      0.27925785       0.0000000    , d:   1.1813487       0.0000000       1.5384616
 i,j,k,ie:    6    2    2          46
 Near X = -0.55814935      0.27925785      0.13437970    , d:  0.21422926       0.0000000       1.5384616
 i,j,k,ie:    1    3    2          46
 Near X = -0.57952849      0.20366516       0.0000000    , d:   1.1833129       0.0000000       1.5384616
 i,j,k,ie:    6    3    2          46
 Near X = -0.57952849      0.20366516      0.13437970    , d:  0.17944109       0.0000000       1.5384616
 i,j,k,ie:    1    4    2          46
 Near X = -0.60378025      0.11347957       0.0000000    , d:   1.1833166       0.0000000       1.5384616
 i,j,k,ie:    6    4    2          46
 Near X = -0.60378025      0.11347957      0.13437970    , d:  0.13775536       0.0000000       1.5384616
 i,j,k,ie:    1    5    2          46
 Near X = -0.62319804      0.37359739E-01   0.0000000    , d:   1.1813586       0.0000000       1.5384616
 i,j,k,ie:    6    5    2          46
 Near X = -0.62319804      0.37359739E-01  0.13437970    , d:  0.10241872       0.0000000       1.5384616
 i,j,k,ie:    1    6    2          46
 Near X = -0.63237913     -0.14769511E-15   0.0000000    , d:   1.1797463     -0.65023034       1.5384616
 i,j,k,ie:    2    6    2          46
 Near X = -0.63237913     -0.14769511E-15  0.15785898E-01, d:   0.0000000     -0.11041622       1.5384616
 i,j,k,ie:    3    6    2          46
 Near X = -0.63237913     -0.14769511E-15  0.48025188E-01, d:   0.0000000     -0.11041622       1.5384616
 i,j,k,ie:    4    6    2          46
 Near X = -0.63237913     -0.14769511E-15  0.86354515E-01, d:   0.0000000     -0.11041622       1.5384616
 i,j,k,ie:    5    6    2          46
 Near X = -0.63237913     -0.14769511E-15  0.11859381    , d:   0.0000000     -0.11041622       1.5384616
 i,j,k,ie:    6    6    2          46
 Near X = -0.63237913     -0.14769511E-15  0.13437970    , d:  0.63237919     -0.11041622       1.5384616
 i,j,k,ie:    1    1    3          46
 Near X = -0.51615817      0.29836874       0.0000000    , d:   1.1125505       0.0000000       1.5384616
 i,j,k,ie:    2    1    3          46
 Near X = -0.51615817      0.29836874      0.15785898E-01, d:  0.81451628       0.0000000       1.5384616
 i,j,k,ie:    3    1    3          46
 Near X = -0.51615817      0.29836874      0.48025188E-01, d:  0.81451628       0.0000000       1.5384616
 i,j,k,ie:    4    1    3          46
 Near X = -0.51615817      0.29836874      0.86354515E-01, d:  0.81451628       0.0000000       1.5384616
 i,j,k,ie:    5    1    3          46
 Near X = -0.51615817      0.29836874      0.11859381    , d:  0.81451628       0.0000000       1.5384616
 i,j,k,ie:    6    1    3          46
 Near X = -0.51615817      0.29836874      0.13437970    , d:  0.81451628       0.0000000       1.5384616
 i,j,k,ie:    1    2    3          46
 Near X = -0.52803851      0.26397850       0.0000000    , d:   1.1174617       0.0000000       1.5384616
 i,j,k,ie:    6    2    3          46
 Near X = -0.52803851      0.26397850      0.13437970    , d:  0.20232638       0.0000000       1.5384616
 i,j,k,ie:    1    3    3          46
 Near X = -0.55027114      0.19319814       0.0000000    , d:   1.1234314       0.0000000       1.5384616
 i,j,k,ie:    6    3    3          46
 Near X = -0.55027114      0.19319814      0.13437970    , d:  0.17015702       0.0000000       1.5384616
 i,j,k,ie:    1    4    3          46
 Near X = -0.57315646      0.10809398       0.0000000    , d:   1.1234356       0.0000000       1.5384616
 i,j,k,ie:    6    4    3          46
 Near X = -0.57315646      0.10809398      0.13437970    , d:  0.13091890       0.0000000       1.5384616
 i,j,k,ie:    1    5    3          46
 Near X = -0.58942210      0.35709905E-01   0.0000000    , d:   1.1174729       0.0000000       1.5384616
 i,j,k,ie:    6    5    3          46
 Near X = -0.58942210      0.35709905E-01  0.13437970    , d:  0.97080900E-01   0.0000000       1.5384616
 i,j,k,ie:    1    6    3          46
 Near X = -0.59639235     -0.12419052E-15   0.0000000    , d:   1.1125652     -0.65520724       1.5384616
 i,j,k,ie:    2    6    3          46
 Near X = -0.59639235     -0.12419052E-15  0.15785898E-01, d:   0.0000000     -0.12792236       1.5384616
 i,j,k,ie:    3    6    3          46
 Near X = -0.59639235     -0.12419052E-15  0.48025188E-01, d:   0.0000000     -0.12792236       1.5384616
 i,j,k,ie:    4    6    3          46
 Near X = -0.59639235     -0.12419052E-15  0.86354515E-01, d:   0.0000000     -0.12792236       1.5384616
 i,j,k,ie:    5    6    3          46
 Near X = -0.59639235     -0.12419052E-15  0.11859381    , d:   0.0000000     -0.12792236       1.5384616
 i,j,k,ie:    6    6    3          46
 Near X = -0.59639235     -0.12419052E-15  0.13437970    , d:  0.59639241     -0.12792236       1.5384616
 i,j,k,ie:    1    1    4          46
 Near X = -0.47906905      0.27718837       0.0000000    , d:   1.0326767       0.0000000       1.5384616
 i,j,k,ie:    2    1    4          46
 Near X = -0.47906905      0.27718837      0.15785898E-01, d:  0.75623579       0.0000000       1.5384616
 i,j,k,ie:    3    1    4          46
 Near X = -0.47906905      0.27718837      0.48025188E-01, d:  0.75623579       0.0000000       1.5384616
 i,j,k,ie:    4    1    4          46
 Near X = -0.47906905      0.27718837      0.86354515E-01, d:  0.75623579       0.0000000       1.5384616
 i,j,k,ie:    5    1    4          46
 Near X = -0.47906905      0.27718837      0.11859381    , d:  0.75623579       0.0000000       1.5384616
 i,j,k,ie:    6    1    4          46
 Near X = -0.47906905      0.27718837      0.13437970    , d:  0.75623579       0.0000000       1.5384616
 i,j,k,ie:    1    2    4          46
 Near X = -0.49223971      0.24581285       0.0000000    , d:   1.0415063       0.0000000       1.5384616
 i,j,k,ie:    6    2    4          46
 Near X = -0.49223971      0.24581285      0.13437970    , d:  0.18817504       0.0000000       1.5384616
 i,j,k,ie:    1    3    4          46
 Near X = -0.51548705      0.18075389       0.0000000    , d:   1.0522382       0.0000000       1.5384616
 i,j,k,ie:    6    3    4          46
 Near X = -0.51548705      0.18075389      0.13437970    , d:  0.15911917       0.0000000       1.5384616
 i,j,k,ie:    1    4    4          46
 Near X = -0.53674780      0.10169104       0.0000000    , d:   1.0522430       0.0000000       1.5384616
 i,j,k,ie:    6    4    4          46
 Near X = -0.53674780      0.10169104      0.13437970    , d:  0.12279103       0.0000000       1.5384616
 i,j,k,ie:    1    5    4          46
 Near X = -0.54926584      0.33748414E-01   0.0000000    , d:   1.0415192       0.0000000       1.5384616
 i,j,k,ie:    6    5    4          46
 Near X = -0.54926584      0.33748414E-01  0.13437970    , d:  0.90734763E-01   0.0000000       1.5384616
 i,j,k,ie:    1    6    4          46
 Near X = -0.55360763     -0.96245897E-16   0.0000000    , d:   1.0326935     -0.66112428       1.5384616
 i,j,k,ie:    2    6    4          46
 Near X = -0.55360763     -0.96245897E-16  0.15785898E-01, d:   0.0000000     -0.14873542       1.5384616
 i,j,k,ie:    3    6    4          46
 Near X = -0.55360763     -0.96245897E-16  0.48025188E-01, d:   0.0000000     -0.14873542       1.5384616
 i,j,k,ie:    4    6    4          46
 Near X = -0.55360763     -0.96245897E-16  0.86354515E-01, d:   0.0000000     -0.14873542       1.5384616
 i,j,k,ie:    5    6    4          46
 Near X = -0.55360763     -0.96245897E-16  0.11859381    , d:   0.0000000     -0.14873542       1.5384616
 i,j,k,ie:    6    6    4          46
 Near X = -0.55360763     -0.96245897E-16  0.13437970    , d:  0.55360768     -0.14873542       1.5384616
 i,j,k,ie:    1    1    5          46
 Near X = -0.44787292      0.25937329       0.0000000    , d:  0.96549377       0.0000000       1.5384616
 i,j,k,ie:    2    1    5          46
 Near X = -0.44787292      0.25937329      0.15785898E-01, d:  0.70721531       0.0000000       1.5384616
 i,j,k,ie:    3    1    5          46
 Near X = -0.44787292      0.25937329      0.48025188E-01, d:  0.70721531       0.0000000       1.5384616
 i,j,k,ie:    4    1    5          46
 Near X = -0.44787292      0.25937329      0.86354515E-01, d:  0.70721531       0.0000000       1.5384616
 i,j,k,ie:    5    1    5          46
 Near X = -0.44787292      0.25937329      0.11859381    , d:  0.70721531       0.0000000       1.5384616
 i,j,k,ie:    6    1    5          46
 Near X = -0.44787292      0.25937329      0.13437970    , d:  0.70721531       0.0000000       1.5384616
 i,j,k,ie:    1    2    5          46
 Near X = -0.46212888      0.23053350       0.0000000    , d:  0.97761933       0.0000000       1.5384616
 i,j,k,ie:    6    2    5          46
 Near X = -0.46212888      0.23053350      0.13437970    , d:  0.17627217       0.0000000       1.5384616
 i,j,k,ie:    1    3    5          46
 Near X = -0.48622970      0.17028688       0.0000000    , d:  0.99235674       0.0000000       1.5384616
 i,j,k,ie:    6    3    5          46
 Near X = -0.48622970      0.17028688      0.13437970    , d:  0.14983510       0.0000000       1.5384616
 i,j,k,ie:    1    4    5          46
 Near X = -0.50612401      0.96305440E-01   0.0000000    , d:  0.99236204       0.0000000       1.5384616
 i,j,k,ie:    6    4    5          46
 Near X = -0.50612401      0.96305440E-01  0.13437970    , d:  0.11595457       0.0000000       1.5384616
 i,j,k,ie:    1    5    5          46
 Near X = -0.51548990      0.32098580E-01   0.0000000    , d:  0.97763355       0.0000000       1.5384616
 i,j,k,ie:    6    5    5          46
 Near X = -0.51548990      0.32098580E-01  0.13437970    , d:  0.85396947E-01   0.0000000       1.5384616
 i,j,k,ie:    1    6    5          46
 Near X = -0.51762085     -0.72741312E-16   0.0000000    , d:  0.96551235     -0.66610118       1.5384616
 i,j,k,ie:    2    6    5          46
 Near X = -0.51762085     -0.72741312E-16  0.15785898E-01, d:   0.0000000     -0.16624156       1.5384616
 i,j,k,ie:    3    6    5          46
 Near X = -0.51762085     -0.72741312E-16  0.48025188E-01, d:   0.0000000     -0.16624156       1.5384616
 i,j,k,ie:    4    6    5          46
 Near X = -0.51762085     -0.72741312E-16  0.86354515E-01, d:   0.0000000     -0.16624156       1.5384616
 i,j,k,ie:    5    6    5          46
 Near X = -0.51762085     -0.72741312E-16  0.11859381    , d:   0.0000000     -0.16624156       1.5384616
 i,j,k,ie:    6    6    5          46
 Near X = -0.51762085     -0.72741312E-16  0.13437970    , d:  0.51762090     -0.16624156       1.5384616
 i,j,k,ie:    1    1    6          46
 Near X = -0.43259780      0.25065017       0.0000000    , d:   1.0825978     -0.13003163       1.5384616
 i,j,k,ie:    2    1    6          46
 Near X = -0.43259780      0.25065017      0.15785898E-01, d:  0.75750789     -0.13003163       1.5384616
 i,j,k,ie:    3    1    6          46
 Near X = -0.43259780      0.25065017      0.48025188E-01, d:  0.75750789     -0.13003163       1.5384616
 i,j,k,ie:    4    1    6          46
 Near X = -0.43259780      0.25065017      0.86354515E-01, d:  0.75750789     -0.13003163       1.5384616
 i,j,k,ie:    5    1    6          46
 Near X = -0.43259780      0.25065017      0.11859381    , d:  0.75750789     -0.13003163       1.5384616
 i,j,k,ie:    6    1    6          46
 Near X = -0.43259780      0.25065017      0.13437970    , d:  0.75750789     -0.13003163       1.5384616
 i,j,k,ie:    1    2    6          46
 Near X = -0.44738517      0.22305199       0.0000000    , d:   1.0871229     -0.12550788       1.5384616
 i,j,k,ie:    2    2    6          46
 Near X = -0.44738517      0.22305199      0.15785898E-01, d:   0.0000000     -0.12550788       1.5384616
 i,j,k,ie:    3    2    6          46
 Near X = -0.44738517      0.22305199      0.48025188E-01, d:   0.0000000     -0.12550788       1.5384616
 i,j,k,ie:    4    2    6          46
 Near X = -0.44738517      0.22305199      0.86354515E-01, d:   0.0000000     -0.12550788       1.5384616
 i,j,k,ie:    5    2    6          46
 Near X = -0.44738517      0.22305199      0.11859381    , d:   0.0000000     -0.12550788       1.5384616
 i,j,k,ie:    6    2    6          46
 Near X = -0.44738517      0.22305199      0.13437970    , d:  0.17044395     -0.12550788       1.5384616
 i,j,k,ie:    1    3    6          46
 Near X = -0.47190390      0.16516172       0.0000000    , d:   1.0906833     -0.12195039       1.5384616
 i,j,k,ie:    2    3    6          46
 Near X = -0.47190390      0.16516172      0.15785898E-01, d:   0.0000000     -0.12195039       1.5384616
 i,j,k,ie:    3    3    6          46
 Near X = -0.47190390      0.16516172      0.48025188E-01, d:   0.0000000     -0.12195039       1.5384616
 i,j,k,ie:    4    3    6          46
 Near X = -0.47190390      0.16516172      0.86354515E-01, d:   0.0000000     -0.12195039       1.5384616
 i,j,k,ie:    5    3    6          46
 Near X = -0.47190390      0.16516172      0.11859381    , d:   0.0000000     -0.12195039       1.5384616
 i,j,k,ie:    6    3    6          46
 Near X = -0.47190390      0.16516172      0.13437970    , d:  0.14528917     -0.12195039       1.5384616
 i,j,k,ie:    1    4    6          46
 Near X = -0.49112913      0.93668394E-01   0.0000000    , d:   1.0849912     -0.12764599       1.5384616
 i,j,k,ie:    2    4    6          46
 Near X = -0.49112913      0.93668394E-01  0.15785898E-01, d:   0.0000000     -0.12764599       1.5384616
 i,j,k,ie:    3    4    6          46
 Near X = -0.49112913      0.93668394E-01  0.48025188E-01, d:   0.0000000     -0.12764599       1.5384616
 i,j,k,ie:    4    4    6          46
 Near X = -0.49112913      0.93668394E-01  0.86354515E-01, d:   0.0000000     -0.12764599       1.5384616
 i,j,k,ie:    5    4    6          46
 Near X = -0.49112913      0.93668394E-01  0.11859381    , d:   0.0000000     -0.12764599       1.5384616
 i,j,k,ie:    6    4    6          46
 Near X = -0.49112913      0.93668394E-01  0.13437970    , d:  0.11260711     -0.12764599       1.5384616
 i,j,k,ie:    1    5    6          46
 Near X = -0.49895159      0.31290742E-01   0.0000000    , d:   1.0718553     -0.14078477       1.5384616
 i,j,k,ie:    2    5    6          46
 Near X = -0.49895159      0.31290742E-01  0.15785898E-01, d:   0.0000000     -0.14078477       1.5384616
 i,j,k,ie:    3    5    6          46
 Near X = -0.49895159      0.31290742E-01  0.48025188E-01, d:   0.0000000     -0.14078477       1.5384616
 i,j,k,ie:    4    5    6          46
 Near X = -0.49895159      0.31290742E-01  0.86354515E-01, d:   0.0000000     -0.14078477       1.5384616
 i,j,k,ie:    5    5    6          46
 Near X = -0.49895159      0.31290742E-01  0.11859381    , d:   0.0000000     -0.14078477       1.5384616
 i,j,k,ie:    6    5    6          46
 Near X = -0.49895159      0.31290742E-01  0.13437970    , d:  0.82783296E-01 -0.14078477       1.5384616
 i,j,k,ie:    1    6    6          46
 Near X = -0.50000000     -0.61232343E-16   0.0000000    , d:   1.0626415     -0.79779339       1.5384616
 i,j,k,ie:    2    6    6          46
 Near X = -0.50000000     -0.61232343E-16  0.15785898E-01, d:   0.0000000     -0.25184436       1.5384616
 i,j,k,ie:    3    6    6          46
 Near X = -0.50000000     -0.61232343E-16  0.48025188E-01, d:   0.0000000     -0.25184436       1.5384616
 i,j,k,ie:    4    6    6          46
 Near X = -0.50000000     -0.61232343E-16  0.86354515E-01, d:   0.0000000     -0.25184436       1.5384616
 i,j,k,ie:    5    6    6          46
 Near X = -0.50000000     -0.61232343E-16  0.11859381    , d:   0.0000000     -0.25184436       1.5384616
 i,j,k,ie:    6    6    6          46
 Near X = -0.50000000     -0.61232343E-16  0.13437970    , d:  0.50000006     -0.25184436       1.5384616
 i,j,k,ie:    1    1    1          47
 Near X = -0.32491014      0.56264145       0.0000000    , d:  0.64982023     -0.23771929       1.7773688
 i,j,k,ie:    2    1    1          47
 Near X = -0.32491014      0.56264145      0.15785898E-01, d:  0.32491017       0.0000000       1.7773688
 i,j,k,ie:    3    1    1          47
 Near X = -0.32491014      0.56264145      0.48025188E-01, d:  0.32491017       0.0000000       1.7773688
 i,j,k,ie:    4    1    1          47
 Near X = -0.32491014      0.56264145      0.86354515E-01, d:  0.32491017       0.0000000       1.7773688
 i,j,k,ie:    5    1    1          47
 Near X = -0.32491014      0.56264145      0.11859381    , d:  0.32491017       0.0000000       1.7773688
 i,j,k,ie:    6    1    1          47
 Near X = -0.32491014      0.56264145      0.13437970    , d:  0.64981710       0.0000000       1.7773688
 i,j,k,ie:    1    2    1          47
 Near X = -0.35283558      0.53471422       0.0000000    , d:   0.0000000     -0.22005747       1.7773688
 i,j,k,ie:    6    2    1          47
 Near X = -0.35283558      0.53471422      0.13437970    , d:  0.31466765       0.0000000       1.7773688
 i,j,k,ie:    1    3    1          47
 Near X = -0.40986727      0.47767888       0.0000000    , d:   0.0000000     -0.18398702       1.7773688
 i,j,k,ie:    6    3    1          47
 Near X = -0.40986727      0.47767888      0.13437970    , d:  0.29374952       0.0000000       1.7773688
 i,j,k,ie:    1    4    1          47
 Near X = -0.47767230      0.40986950       0.0000000    , d:   0.0000000     -0.14110282       1.7773688
 i,j,k,ie:    6    4    1          47
 Near X = -0.47767230      0.40986950      0.13437970    , d:  0.26887994       0.0000000       1.7773688
 i,j,k,ie:    1    5    1          47
 Near X = -0.53470399      0.35283416       0.0000000    , d:   0.0000000     -0.10503237       1.7773688
 i,j,k,ie:    6    5    1          47
 Near X = -0.53470399      0.35283416      0.13437970    , d:  0.24796181       0.0000000       1.7773688
 i,j,k,ie:    1    6    1          47
 Near X = -0.56262943      0.32490693       0.0000000    , d:  0.56262949     -0.18921493       1.7773688
 i,j,k,ie:    2    6    1          47
 Near X = -0.56262943      0.32490693      0.15785898E-01, d:  0.56262949       0.0000000       1.7773688
 i,j,k,ie:    3    6    1          47
 Near X = -0.56262943      0.32490693      0.48025188E-01, d:  0.56262949       0.0000000       1.7773688
 i,j,k,ie:    4    6    1          47
 Near X = -0.56262943      0.32490693      0.86354515E-01, d:  0.56262949       0.0000000       1.7773688
 i,j,k,ie:    5    6    1          47
 Near X = -0.56262943      0.32490693      0.11859381    , d:  0.56262949       0.0000000       1.7773688
 i,j,k,ie:    6    6    1          47
 Near X = -0.56262943      0.32490693      0.13437970    , d:   1.3145800       0.0000000       1.7773688
 i,j,k,ie:    1    1    2          47
 Near X = -0.31618249      0.54736720       0.0000000    , d:  0.63236494     -0.23117182       1.7773688
 i,j,k,ie:    2    1    2          47
 Near X = -0.31618249      0.54736720      0.15785898E-01, d:  0.31618252       0.0000000       1.7773688
 i,j,k,ie:    3    1    2          47
 Near X = -0.31618249      0.54736720      0.48025188E-01, d:  0.31618252       0.0000000       1.7773688
 i,j,k,ie:    4    1    2          47
 Near X = -0.31618249      0.54736720      0.86354515E-01, d:  0.31618252       0.0000000       1.7773688
 i,j,k,ie:    5    1    2          47
 Near X = -0.31618249      0.54736720      0.11859381    , d:  0.31618252       0.0000000       1.7773688
 i,j,k,ie:    6    1    2          47
 Near X = -0.31618249      0.54736720      0.13437970    , d:  0.63236633       0.0000000       1.7773688
 i,j,k,ie:    1    2    2          47
 Near X = -0.34392009      0.52079090       0.0000000    , d:   0.0000000     -0.21422926       1.7773688
 i,j,k,ie:    6    2    2          47
 Near X = -0.34392009      0.52079090      0.13437970    , d:  0.30656062       0.0000000       1.7773688
 i,j,k,ie:    1    3    2          47
 Near X = -0.40008740      0.46603375       0.0000000    , d:   0.0000000     -0.17944109       1.7773688
 i,j,k,ie:    6    3    2          47
 Near X = -0.40008740      0.46603375      0.13437970    , d:  0.28660852       0.0000000       1.7773688
 i,j,k,ie:    1    4    2          47
 Near X = -0.46602489      0.40009296       0.0000000    , d:   0.0000000     -0.13775536       1.7773688
 i,j,k,ie:    6    4    2          47
 Near X = -0.46602489      0.40009296      0.13437970    , d:  0.26236079       0.0000000       1.7773688
 i,j,k,ie:    1    5    2          47
 Near X = -0.52077932      0.34392283       0.0000000    , d:   0.0000000     -0.10241872       1.7773688
 i,j,k,ie:    6    5    2          47
 Near X = -0.52077932      0.34392283      0.13437970    , d:  0.24152274       0.0000000       1.7773688
 i,j,k,ie:    1    6    2          47
 Near X = -0.54735431      0.31618382       0.0000000    , d:  0.54735437     -0.19544104       1.7773688
 i,j,k,ie:    2    6    2          47
 Near X = -0.54735431      0.31618382      0.15785898E-01, d:  0.54735437       0.0000000       1.7773688
 i,j,k,ie:    3    6    2          47
 Near X = -0.54735431      0.31618382      0.48025188E-01, d:  0.54735437       0.0000000       1.7773688
 i,j,k,ie:    4    6    2          47
 Near X = -0.54735431      0.31618382      0.86354515E-01, d:  0.54735437       0.0000000       1.7773688
 i,j,k,ie:    5    6    2          47
 Near X = -0.54735431      0.31618382      0.11859381    , d:  0.54735437       0.0000000       1.7773688
 i,j,k,ie:    6    6    2          47
 Near X = -0.54735431      0.31618382      0.13437970    , d:   1.2902426       0.0000000       1.7773688
 i,j,k,ie:    1    1    3          47
 Near X = -0.29835815      0.51617285       0.0000000    , d:  0.59671626     -0.21780002       1.7773688
 i,j,k,ie:    2    1    3          47
 Near X = -0.29835815      0.51617285      0.15785898E-01, d:  0.29835817       0.0000000       1.7773688
 i,j,k,ie:    3    1    3          47
 Near X = -0.29835815      0.51617285      0.48025188E-01, d:  0.29835817       0.0000000       1.7773688
 i,j,k,ie:    4    1    3          47
 Near X = -0.29835815      0.51617285      0.86354515E-01, d:  0.29835817       0.0000000       1.7773688
 i,j,k,ie:    5    1    3          47
 Near X = -0.29835815      0.51617285      0.11859381    , d:  0.29835817       0.0000000       1.7773688
 i,j,k,ie:    6    1    3          47
 Near X = -0.29835815      0.51617285      0.13437970    , d:  0.59672691       0.0000000       1.7773688
 i,j,k,ie:    1    2    3          47
 Near X = -0.32571213      0.49235554       0.0000000    , d:   0.0000000     -0.20232638       1.7773688
 i,j,k,ie:    6    2    3          47
 Near X = -0.32571213      0.49235554      0.13437970    , d:  0.29000378       0.0000000       1.7773688
 i,j,k,ie:    1    3    3          47
 Near X = -0.38011412      0.44225108       0.0000000    , d:   0.0000000     -0.17015702       1.7773688
 i,j,k,ie:    6    3    3          47
 Near X = -0.38011412      0.44225108      0.13437970    , d:  0.27202457       0.0000000       1.7773688
 i,j,k,ie:    1    4    3          47
 Near X = -0.44223755      0.38012649       0.0000000    , d:   0.0000000     -0.13091890       1.7773688
 i,j,k,ie:    6    4    3          47
 Near X = -0.44223755      0.38012649      0.13437970    , d:  0.24904685       0.0000000       1.7773688
 i,j,k,ie:    1    5    3          47
 Near X = -0.49234120      0.32572334       0.0000000    , d:   0.0000000     -0.97080900E-01   1.7773688
 i,j,k,ie:    6    5    3          47
 Near X = -0.49234120      0.32572334      0.13437970    , d:  0.22837233       0.0000000       1.7773688
 i,j,k,ie:    1    6    3          47
 Near X = -0.51615817      0.29836874       0.0000000    , d:  0.51615823     -0.20815653       1.7773688
 i,j,k,ie:    2    6    3          47
 Near X = -0.51615817      0.29836874      0.15785898E-01, d:  0.51615823       0.0000000       1.7773688
 i,j,k,ie:    3    6    3          47
 Near X = -0.51615817      0.29836874      0.48025188E-01, d:  0.51615823       0.0000000       1.7773688
 i,j,k,ie:    4    6    3          47
 Near X = -0.51615817      0.29836874      0.86354515E-01, d:  0.51615823       0.0000000       1.7773688
 i,j,k,ie:    5    6    3          47
 Near X = -0.51615817      0.29836874      0.11859381    , d:  0.51615823       0.0000000       1.7773688
 i,j,k,ie:    6    6    3          47
 Near X = -0.51615817      0.29836874      0.13437970    , d:   1.2405388       0.0000000       1.7773688
 i,j,k,ie:    1    1    4          47
 Near X = -0.27716677      0.47908585       0.0000000    , d:  0.55433351     -0.20190228       1.7773688
 i,j,k,ie:    2    1    4          47
 Near X = -0.27716677      0.47908585      0.15785898E-01, d:  0.27716680       0.0000000       1.7773688
 i,j,k,ie:    3    1    4          47
 Near X = -0.27716677      0.47908585      0.48025188E-01, d:  0.27716680       0.0000000       1.7773688
 i,j,k,ie:    4    1    4          47
 Near X = -0.27716677      0.47908585      0.86354515E-01, d:  0.27716680       0.0000000       1.7773688
 i,j,k,ie:    5    1    4          47
 Near X = -0.27716677      0.47908585      0.11859381    , d:  0.27716680       0.0000000       1.7773688
 i,j,k,ie:    6    1    4          47
 Near X = -0.27716677      0.47908585      0.13437970    , d:  0.55435516       0.0000000       1.7773688
 i,j,k,ie:    1    2    4          47
 Near X = -0.30406467      0.45854870       0.0000000    , d:   0.0000000     -0.18817504       1.7773688
 i,j,k,ie:    6    2    4          47
 Near X = -0.30406467      0.45854870      0.13437970    , d:  0.27031932       0.0000000       1.7773688
 i,j,k,ie:    1    3    4          47
 Near X = -0.35636788      0.41397584       0.0000000    , d:   0.0000000     -0.15911917       1.7773688
 i,j,k,ie:    6    3    4          47
 Near X = -0.35636788      0.41397584      0.13437970    , d:  0.25468570       0.0000000       1.7773688
 i,j,k,ie:    1    4    4          47
 Near X = -0.41395677      0.35638832       0.0000000    , d:   0.0000000     -0.12279103       1.7773688
 i,j,k,ie:    6    4    4          47
 Near X = -0.41395677      0.35638832      0.13437970    , d:  0.23321789       0.0000000       1.7773688
 i,j,k,ie:    1    5    4          47
 Near X = -0.45853108      0.30408595       0.0000000    , d:   0.0000000     -0.90734763E-01   1.7773688
 i,j,k,ie:    6    5    4          47
 Near X = -0.45853108      0.30408595      0.13437970    , d:  0.21273780       0.0000000       1.7773688
 i,j,k,ie:    1    6    4          47
 Near X = -0.47906905      0.27718837       0.0000000    , d:  0.47906911     -0.22327400       1.7773688
 i,j,k,ie:    2    6    4          47
 Near X = -0.47906905      0.27718837      0.15785898E-01, d:  0.47906911       0.0000000       1.7773688
 i,j,k,ie:    3    6    4          47
 Near X = -0.47906905      0.27718837      0.48025188E-01, d:  0.47906911       0.0000000       1.7773688
 i,j,k,ie:    4    6    4          47
 Near X = -0.47906905      0.27718837      0.86354515E-01, d:  0.47906911       0.0000000       1.7773688
 i,j,k,ie:    5    6    4          47
 Near X = -0.47906905      0.27718837      0.11859381    , d:  0.47906911       0.0000000       1.7773688
 i,j,k,ie:    6    6    4          47
 Near X = -0.47906905      0.27718837      0.13437970    , d:   1.1814458       0.0000000       1.7773688
 i,j,k,ie:    1    1    5          47
 Near X = -0.25934244      0.44789150       0.0000000    , d:  0.51868483     -0.18853048       1.7773688
 i,j,k,ie:    2    1    5          47
 Near X = -0.25934244      0.44789150      0.15785898E-01, d:  0.25934246       0.0000000       1.7773688
 i,j,k,ie:    3    1    5          47
 Near X = -0.25934244      0.44789150      0.48025188E-01, d:  0.25934246       0.0000000       1.7773688
 i,j,k,ie:    4    1    5          47
 Near X = -0.25934244      0.44789150      0.86354515E-01, d:  0.25934246       0.0000000       1.7773688
 i,j,k,ie:    5    1    5          47
 Near X = -0.25934244      0.44789150      0.11859381    , d:  0.25934246       0.0000000       1.7773688
 i,j,k,ie:    6    1    5          47
 Near X = -0.25934244      0.44789150      0.13437970    , d:  0.51871574       0.0000000       1.7773688
 i,j,k,ie:    1    2    5          47
 Near X = -0.28585671      0.43011333       0.0000000    , d:   0.0000000     -0.17627217       1.7773688
 i,j,k,ie:    6    2    5          47
 Near X = -0.28585671      0.43011333      0.13437970    , d:  0.25376247       0.0000000       1.7773688
 i,j,k,ie:    1    3    5          47
 Near X = -0.33639460      0.39019318       0.0000000    , d:   0.0000000     -0.14983510       1.7773688
 i,j,k,ie:    6    3    5          47
 Near X = -0.33639460      0.39019318      0.13437970    , d:  0.24010176       0.0000000       1.7773688
 i,j,k,ie:    1    4    5          47
 Near X = -0.39016944      0.33642184       0.0000000    , d:   0.0000000     -0.11595457       1.7773688
 i,j,k,ie:    6    4    5          47
 Near X = -0.39016944      0.33642184      0.13437970    , d:  0.21990395       0.0000000       1.7773688
 i,j,k,ie:    1    5    5          47
 Near X = -0.43009296      0.28588647       0.0000000    , d:   0.0000000     -0.85396947E-01   1.7773688
 i,j,k,ie:    6    5    5          47
 Near X = -0.43009296      0.28588647      0.13437970    , d:  0.19958739       0.0000000       1.7773688
 i,j,k,ie:    1    6    5          47
 Near X = -0.44787292      0.25937329       0.0000000    , d:  0.44787297     -0.23598949       1.7773688
 i,j,k,ie:    2    6    5          47
 Near X = -0.44787292      0.25937329      0.15785898E-01, d:  0.44787297       0.0000000       1.7773688
 i,j,k,ie:    3    6    5          47
 Near X = -0.44787292      0.25937329      0.48025188E-01, d:  0.44787297       0.0000000       1.7773688
 i,j,k,ie:    4    6    5          47
 Near X = -0.44787292      0.25937329      0.86354515E-01, d:  0.44787297       0.0000000       1.7773688
 i,j,k,ie:    5    6    5          47
 Near X = -0.44787292      0.25937329      0.11859381    , d:  0.44787297       0.0000000       1.7773688
 i,j,k,ie:    6    6    5          47
 Near X = -0.44787292      0.25937329      0.13437970    , d:   1.1317420       0.0000000       1.7773688
 i,j,k,ie:    1    1    6          47
 Near X = -0.25061479      0.43261725       0.0000000    , d:  0.57552488     -0.31201464       1.7773688
 i,j,k,ie:    2    1    6          47
 Near X = -0.25061479      0.43261725      0.15785898E-01, d:  0.25061481     -0.74295354E-01   1.7773688
 i,j,k,ie:    3    1    6          47
 Near X = -0.25061479      0.43261725      0.48025188E-01, d:  0.25061481     -0.74295354E-01   1.7773688
 i,j,k,ie:    4    1    6          47
 Near X = -0.25061479      0.43261725      0.86354515E-01, d:  0.25061481     -0.74295354E-01   1.7773688
 i,j,k,ie:    5    1    6          47
 Near X = -0.25061479      0.43261725      0.11859381    , d:  0.25061481     -0.74295354E-01   1.7773688
 i,j,k,ie:    6    1    6          47
 Near X = -0.25061479      0.43261725      0.13437970    , d:  0.57552174     -0.74295354E-01   1.7773688
 i,j,k,ie:    1    2    6          47
 Near X = -0.27694122      0.41619001       0.0000000    , d:   0.0000000     -0.29595183       1.7773688
 i,j,k,ie:    2    2    6          47
 Near X = -0.27694122      0.41619001      0.15785898E-01, d:   0.0000000     -0.75894362E-01   1.7773688
 i,j,k,ie:    3    2    6          47
 Near X = -0.27694122      0.41619001      0.48025188E-01, d:   0.0000000     -0.75894362E-01   1.7773688
 i,j,k,ie:    4    2    6          47
 Near X = -0.27694122      0.41619001      0.86354515E-01, d:   0.0000000     -0.75894362E-01   1.7773688
 i,j,k,ie:    5    2    6          47
 Near X = -0.27694122      0.41619001      0.11859381    , d:   0.0000000     -0.75894362E-01   1.7773688
 i,j,k,ie:    6    2    6          47
 Near X = -0.27694122      0.41619001      0.13437970    , d:  0.24565545     -0.75894362E-01   1.7773688
 i,j,k,ie:    1    3    6          47
 Near X = -0.32661473      0.37854805       0.0000000    , d:   0.0000000     -0.26723956       1.7773688
 i,j,k,ie:    2    3    6          47
 Near X = -0.32661473      0.37854805      0.15785898E-01, d:   0.0000000     -0.83252538E-01   1.7773688
 i,j,k,ie:    3    3    6          47
 Near X = -0.32661473      0.37854805      0.48025188E-01, d:   0.0000000     -0.83252538E-01   1.7773688
 i,j,k,ie:    4    3    6          47
 Near X = -0.32661473      0.37854805      0.86354515E-01, d:   0.0000000     -0.83252538E-01   1.7773688
 i,j,k,ie:    5    3    6          47
 Near X = -0.32661473      0.37854805      0.11859381    , d:   0.0000000     -0.83252538E-01   1.7773688
 i,j,k,ie:    6    3    6          47
 Near X = -0.32661473      0.37854805      0.13437970    , d:  0.23296076     -0.83252538E-01   1.7773688
 i,j,k,ie:    1    4    6          47
 Near X = -0.37852202      0.32664530       0.0000000    , d:   0.0000000     -0.24025310       1.7773688
 i,j,k,ie:    2    4    6          47
 Near X = -0.37852202      0.32664530      0.15785898E-01, d:   0.0000000     -0.99150281E-01   1.7773688
 i,j,k,ie:    3    4    6          47
 Near X = -0.37852202      0.32664530      0.48025188E-01, d:   0.0000000     -0.99150281E-01   1.7773688
 i,j,k,ie:    4    4    6          47
 Near X = -0.37852202      0.32664530      0.86354515E-01, d:   0.0000000     -0.99150281E-01   1.7773688
 i,j,k,ie:    5    4    6          47
 Near X = -0.37852202      0.32664530      0.11859381    , d:   0.0000000     -0.99150281E-01   1.7773688
 i,j,k,ie:    6    4    6          47
 Near X = -0.37852202      0.32664530      0.13437970    , d:  0.21338481     -0.99150281E-01   1.7773688
 i,j,k,ie:    1    5    6          47
 Near X = -0.41616829      0.27697513       0.0000000    , d:   0.0000000     -0.22356807       1.7773688
 i,j,k,ie:    2    5    6          47
 Near X = -0.41616829      0.27697513      0.15785898E-01, d:   0.0000000     -0.11853570       1.7773688
 i,j,k,ie:    3    5    6          47
 Near X = -0.41616829      0.27697513      0.48025188E-01, d:   0.0000000     -0.11853570       1.7773688
 i,j,k,ie:    4    5    6          47
 Near X = -0.41616829      0.27697513      0.86354515E-01, d:   0.0000000     -0.11853570       1.7773688
 i,j,k,ie:    5    5    6          47
 Near X = -0.41616829      0.27697513      0.11859381    , d:   0.0000000     -0.11853570       1.7773688
 i,j,k,ie:    6    5    6          47
 Near X = -0.41616829      0.27697513      0.13437970    , d:  0.19314833     -0.11853570       1.7773688
 i,j,k,ie:    1    6    6          47
 Near X = -0.43259780      0.25065017       0.0000000    , d:  0.43259786     -0.31924656       1.7773688
 i,j,k,ie:    2    6    6          47
 Near X = -0.43259780      0.25065017      0.15785898E-01, d:  0.43259786     -0.13003163       1.7773688
 i,j,k,ie:    3    6    6          47
 Near X = -0.43259780      0.25065017      0.48025188E-01, d:  0.43259786     -0.13003163       1.7773688
 i,j,k,ie:    4    6    6          47
 Near X = -0.43259780      0.25065017      0.86354515E-01, d:  0.43259786     -0.13003163       1.7773688
 i,j,k,ie:    5    6    6          47
 Near X = -0.43259780      0.25065017      0.11859381    , d:  0.43259786     -0.13003163       1.7773688
 i,j,k,ie:    6    6    6          47
 Near X = -0.43259780      0.25065017      0.13437970    , d:   1.1845484     -0.13003163       1.7773688
 i,j,k,ie:    1    1    1          48
 Near X =  0.25581813E-07  0.64999998       0.0000000    , d:  0.32490693     -0.32491017       3.0777738
 i,j,k,ie:    2    1    1          48
 Near X =  0.25581813E-07  0.64999998      0.15785898E-01, d:  0.32490693       0.0000000       3.0777738
 i,j,k,ie:    3    1    1          48
 Near X =  0.25581813E-07  0.64999998      0.48025188E-01, d:  0.32490693       0.0000000       3.0777738
 i,j,k,ie:    4    1    1          48
 Near X =  0.25581813E-07  0.64999998      0.86354515E-01, d:  0.32490693       0.0000000       3.0777738
 i,j,k,ie:    5    1    1          48
 Near X =  0.25581813E-07  0.64999998      0.11859381    , d:  0.32490693       0.0000000       3.0777738
 i,j,k,ie:    6    1    1          48
 Near X =  0.25581813E-07  0.64999998      0.13437970    , d:  0.32490693       0.0000000       3.0777738
 i,j,k,ie:    1    2    1          48
 Near X = -0.38167931E-01  0.63973777       0.0000000    , d:   0.0000000     -0.31466765       3.0777738
 i,j,k,ie:    1    3    1          48
 Near X = -0.11611775      0.61877942       0.0000000    , d:   0.0000000     -0.29374952       3.0777738
 i,j,k,ie:    1    4    1          48
 Near X = -0.20879237      0.59386201       0.0000000    , d:   0.0000000     -0.26887994       3.0777738
 i,j,k,ie:    1    5    1          48
 Near X = -0.28674218      0.57290366       0.0000000    , d:   0.0000000     -0.24796181       3.0777738
 i,j,k,ie:    1    6    1          48
 Near X = -0.32491014      0.56264145       0.0000000    , d:   1.0768607     -0.23771929       3.0777738
 i,j,k,ie:    2    6    1          48
 Near X = -0.32491014      0.56264145      0.15785898E-01, d:   1.0768607       0.0000000       3.0777738
 i,j,k,ie:    3    6    1          48
 Near X = -0.32491014      0.56264145      0.48025188E-01, d:   1.0768607       0.0000000       3.0777738
 i,j,k,ie:    4    6    1          48
 Near X = -0.32491014      0.56264145      0.86354515E-01, d:   1.0768607       0.0000000       3.0777738
 i,j,k,ie:    5    6    1          48
 Near X = -0.32491014      0.56264145      0.11859381    , d:   1.0768607       0.0000000       3.0777738
 i,j,k,ie:    6    6    1          48
 Near X = -0.32491014      0.56264145      0.13437970    , d:   1.0768607       0.0000000       3.0777738
 i,j,k,ie:    1    1    2          48
 Near X =  0.24888316E-07  0.63237913       0.0000000    , d:  0.31618382     -0.31618252       3.0777738
 i,j,k,ie:    2    1    2          48
 Near X =  0.24888316E-07  0.63237913      0.15785898E-01, d:  0.31618382       0.0000000       3.0777738
 i,j,k,ie:    3    1    2          48
 Near X =  0.24888316E-07  0.63237913      0.48025188E-01, d:  0.31618382       0.0000000       3.0777738
 i,j,k,ie:    4    1    2          48
 Near X =  0.24888316E-07  0.63237913      0.86354515E-01, d:  0.31618382       0.0000000       3.0777738
 i,j,k,ie:    5    1    2          48
 Near X =  0.24888316E-07  0.63237913      0.11859381    , d:  0.31618382       0.0000000       3.0777738
 i,j,k,ie:    6    1    2          48
 Near X =  0.24888316E-07  0.63237913      0.13437970    , d:  0.31618382       0.0000000       3.0777738
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    1    2    2          48
 Near X = -0.37359468E-01  0.62319934       0.0000000    , d:   0.0000000     -0.30656062       3.0777738
 i,j,k,ie:    1    3    2          48
 Near X = -0.11347888      0.60378438       0.0000000    , d:   0.0000000     -0.28660852       3.0777738
 i,j,k,ie:    1    4    2          48
 Near X = -0.20366409      0.57953629       0.0000000    , d:   0.0000000     -0.26236079       3.0777738
 i,j,k,ie:    1    5    2          48
 Near X = -0.27925659      0.55816051       0.0000000    , d:   0.0000000     -0.24152274       3.0777738
 i,j,k,ie:    1    6    2          48
 Near X = -0.31618249      0.54736720       0.0000000    , d:   1.0590708     -0.23117182       3.0777738
 i,j,k,ie:    2    6    2          48
 Near X = -0.31618249      0.54736720      0.15785898E-01, d:   1.0590708       0.0000000       3.0777738
 i,j,k,ie:    3    6    2          48
 Near X = -0.31618249      0.54736720      0.48025188E-01, d:   1.0590708       0.0000000       3.0777738
 i,j,k,ie:    4    6    2          48
 Near X = -0.31618249      0.54736720      0.86354515E-01, d:   1.0590708       0.0000000       3.0777738
 i,j,k,ie:    5    6    2          48
 Near X = -0.31618249      0.54736720      0.11859381    , d:   1.0590708       0.0000000       3.0777738
 i,j,k,ie:    6    6    2          48
 Near X = -0.31618249      0.54736720      0.13437970    , d:   1.0590708       0.0000000       3.0777738
 i,j,k,ie:    1    1    3          48
 Near X =  0.23471997E-07  0.59639235       0.0000000    , d:  0.29836873     -0.29835817       3.0777738
 i,j,k,ie:    2    1    3          48
 Near X =  0.23471997E-07  0.59639235      0.15785898E-01, d:  0.29836873       0.0000000       3.0777738
 i,j,k,ie:    3    1    3          48
 Near X =  0.23471997E-07  0.59639235      0.48025188E-01, d:  0.29836873       0.0000000       3.0777738
 i,j,k,ie:    4    1    3          48
 Near X =  0.23471997E-07  0.59639235      0.86354515E-01, d:  0.29836873       0.0000000       3.0777738
 i,j,k,ie:    5    1    3          48
 Near X =  0.23471997E-07  0.59639235      0.11859381    , d:  0.29836873       0.0000000       3.0777738
 i,j,k,ie:    6    1    3          48
 Near X =  0.23471997E-07  0.59639235      0.13437970    , d:  0.29836873       0.0000000       3.0777738
 i,j,k,ie:    1    2    3          48
 Near X = -0.35708356E-01  0.58942316       0.0000000    , d:   0.0000000     -0.29000378       3.0777738
 i,j,k,ie:    1    3    3          48
 Near X = -0.10808955      0.57316024       0.0000000    , d:   0.0000000     -0.27202457       3.0777738
 i,j,k,ie:    1    4    3          48
 Near X = -0.19319070      0.55027911       0.0000000    , d:   0.0000000     -0.24904685       3.0777738
 i,j,k,ie:    1    5    3          48
 Near X = -0.26396887      0.52805081       0.0000000    , d:   0.0000000     -0.22837233       3.0777738
 i,j,k,ie:    1    6    3          48
 Near X = -0.29835815      0.51617285       0.0000000    , d:   1.0227388     -0.21780002       3.0777738
 i,j,k,ie:    2    6    3          48
 Near X = -0.29835815      0.51617285      0.15785898E-01, d:   1.0227388       0.0000000       3.0777738
 i,j,k,ie:    3    6    3          48
 Near X = -0.29835815      0.51617285      0.48025188E-01, d:   1.0227388       0.0000000       3.0777738
 i,j,k,ie:    4    6    3          48
 Near X = -0.29835815      0.51617285      0.86354515E-01, d:   1.0227388       0.0000000       3.0777738
 i,j,k,ie:    5    6    3          48
 Near X = -0.29835815      0.51617285      0.11859381    , d:   1.0227388       0.0000000       3.0777738
 i,j,k,ie:    6    6    3          48
 Near X = -0.29835815      0.51617285      0.13437970    , d:   1.0227388       0.0000000       3.0777738
 i,j,k,ie:    1    1    4          48
 Near X =  0.21788134E-07  0.55360763       0.0000000    , d:  0.27718837     -0.27716680       3.0777738
 i,j,k,ie:    2    1    4          48
 Near X =  0.21788134E-07  0.55360763      0.15785898E-01, d:  0.27718837       0.0000000       3.0777738
 i,j,k,ie:    3    1    4          48
 Near X =  0.21788134E-07  0.55360763      0.48025188E-01, d:  0.27718837       0.0000000       3.0777738
 i,j,k,ie:    4    1    4          48
 Near X =  0.21788134E-07  0.55360763      0.86354515E-01, d:  0.27718837       0.0000000       3.0777738
 i,j,k,ie:    5    1    4          48
 Near X =  0.21788134E-07  0.55360763      0.11859381    , d:  0.27718837       0.0000000       3.0777738
 i,j,k,ie:    6    1    4          48
 Near X =  0.21788134E-07  0.55360763      0.13437970    , d:  0.27718837       0.0000000       3.0777738
 i,j,k,ie:    1    2    4          48
 Near X = -0.33745347E-01  0.54926663       0.0000000    , d:   0.0000000     -0.27031932       3.0777738
 i,j,k,ie:    1    3    4          48
 Near X = -0.10168217      0.53675117       0.0000000    , d:   0.0000000     -0.25468570       3.0777738
 i,j,k,ie:    1    4    4          48
 Near X = -0.18073888      0.51549521       0.0000000    , d:   0.0000000     -0.23321789       3.0777738
 i,j,k,ie:    1    5    4          48
 Near X = -0.24579328      0.49225335       0.0000000    , d:   0.0000000     -0.21273780       3.0777738
 i,j,k,ie:    1    6    4          48
 Near X = -0.27716677      0.47908585       0.0000000    , d:  0.97954354     -0.20190228       3.0777738
 i,j,k,ie:    2    6    4          48
 Near X = -0.27716677      0.47908585      0.15785898E-01, d:  0.97954354       0.0000000       3.0777738
 i,j,k,ie:    3    6    4          48
 Near X = -0.27716677      0.47908585      0.48025188E-01, d:  0.97954354       0.0000000       3.0777738
 i,j,k,ie:    4    6    4          48
 Near X = -0.27716677      0.47908585      0.86354515E-01, d:  0.97954354       0.0000000       3.0777738
 i,j,k,ie:    5    6    4          48
 Near X = -0.27716677      0.47908585      0.11859381    , d:  0.97954354       0.0000000       3.0777738
 i,j,k,ie:    6    6    4          48
 Near X = -0.27716677      0.47908585      0.13437970    , d:  0.97954354       0.0000000       3.0777738
 i,j,k,ie:    1    1    5          48
 Near X =  0.20371815E-07  0.51762085       0.0000000    , d:  0.25937329     -0.25934246       3.0777738
 i,j,k,ie:    2    1    5          48
 Near X =  0.20371815E-07  0.51762085      0.15785898E-01, d:  0.25937329       0.0000000       3.0777738
 i,j,k,ie:    3    1    5          48
 Near X =  0.20371815E-07  0.51762085      0.48025188E-01, d:  0.25937329       0.0000000       3.0777738
 i,j,k,ie:    4    1    5          48
 Near X =  0.20371815E-07  0.51762085      0.86354515E-01, d:  0.25937329       0.0000000       3.0777738
 i,j,k,ie:    5    1    5          48
 Near X =  0.20371815E-07  0.51762085      0.11859381    , d:  0.25937329       0.0000000       3.0777738
 i,j,k,ie:    6    1    5          48
 Near X =  0.20371815E-07  0.51762085      0.13437970    , d:  0.25937329       0.0000000       3.0777738
 i,j,k,ie:    1    2    5          48
 Near X = -0.32094235E-01  0.51549046       0.0000000    , d:   0.0000000     -0.25376247       3.0777738
 i,j,k,ie:    1    3    5          48
 Near X = -0.96292845E-01  0.50612704       0.0000000    , d:   0.0000000     -0.24010176       3.0777738
 i,j,k,ie:    1    4    5          48
 Near X = -0.17026549      0.48623803       0.0000000    , d:   0.0000000     -0.21990395       3.0777738
 i,j,k,ie:    1    5    5          48
 Near X = -0.23050556      0.46214364       0.0000000    , d:   0.0000000     -0.19958739       3.0777738
 i,j,k,ie:    1    6    5          48
 Near X = -0.25934244      0.44789150       0.0000000    , d:  0.94321148     -0.18853048       3.0777738
 i,j,k,ie:    2    6    5          48
 Near X = -0.25934244      0.44789150      0.15785898E-01, d:  0.94321148       0.0000000       3.0777738
 i,j,k,ie:    3    6    5          48
 Near X = -0.25934244      0.44789150      0.48025188E-01, d:  0.94321148       0.0000000       3.0777738
 i,j,k,ie:    4    6    5          48
 Near X = -0.25934244      0.44789150      0.86354515E-01, d:  0.94321148       0.0000000       3.0777738
 i,j,k,ie:    5    6    5          48
 Near X = -0.25934244      0.44789150      0.11859381    , d:  0.94321148       0.0000000       3.0777738
 i,j,k,ie:    6    6    5          48
 Near X = -0.25934244      0.44789150      0.13437970    , d:  0.94321148       0.0000000       3.0777738
 i,j,k,ie:    1    1    6          48
 Near X =  0.19678318E-07  0.50000000       0.0000000    , d:  0.32490694     -0.32491016       3.0777738
 i,j,k,ie:    2    1    6          48
 Near X =  0.19678318E-07  0.50000000      0.15785898E-01, d:  0.32490694       0.0000000       3.0777738
 i,j,k,ie:    3    1    6          48
 Near X =  0.19678318E-07  0.50000000      0.48025188E-01, d:  0.32490694       0.0000000       3.0777738
 i,j,k,ie:    4    1    6          48
 Near X =  0.19678318E-07  0.50000000      0.86354515E-01, d:  0.32490694       0.0000000       3.0777738
 i,j,k,ie:    5    1    6          48
 Near X =  0.19678318E-07  0.50000000      0.11859381    , d:  0.32490694       0.0000000       3.0777738
 i,j,k,ie:    6    1    6          48
 Near X =  0.19678318E-07  0.50000000      0.13437970    , d:  0.32490694       0.0000000       3.0777738
 i,j,k,ie:    1    2    6          48
 Near X = -0.31285772E-01  0.49895202       0.0000000    , d:   0.0000000     -0.32154981       3.0777738
 i,j,k,ie:    2    2    6          48
 Near X = -0.31285772E-01  0.49895202      0.15785898E-01, d:   0.0000000     -0.68821594E-02   3.0777738
 i,j,k,ie:    3    2    6          48
 Near X = -0.31285772E-01  0.49895202      0.48025188E-01, d:   0.0000000     -0.68821594E-02   3.0777738
 i,j,k,ie:    4    2    6          48
 Near X = -0.31285772E-01  0.49895202      0.86354515E-01, d:   0.0000000     -0.68821594E-02   3.0777738
 i,j,k,ie:    5    2    6          48
 Near X = -0.31285772E-01  0.49895202      0.11859381    , d:   0.0000000     -0.68821594E-02   3.0777738
 i,j,k,ie:    6    2    6          48
 Near X = -0.31285772E-01  0.49895202      0.13437970    , d:   0.0000000     -0.68821594E-02   3.0777738
 i,j,k,ie:    1    3    6          48
 Near X = -0.93653973E-01  0.49113200       0.0000000    , d:   0.0000000     -0.31621330       3.0777738
 i,j,k,ie:    2    3    6          48
 Near X = -0.93653973E-01  0.49113200      0.15785898E-01, d:   0.0000000     -0.22463775E-01   3.0777738
 i,j,k,ie:    3    3    6          48
 Near X = -0.93653973E-01  0.49113200      0.48025188E-01, d:   0.0000000     -0.22463775E-01   3.0777738
 i,j,k,ie:    4    3    6          48
 Near X = -0.93653973E-01  0.49113200      0.86354515E-01, d:   0.0000000     -0.22463775E-01   3.0777738
 i,j,k,ie:    5    3    6          48
 Near X = -0.93653973E-01  0.49113200      0.11859381    , d:   0.0000000     -0.22463775E-01   3.0777738
 i,j,k,ie:    6    3    6          48
 Near X = -0.93653973E-01  0.49113200      0.13437970    , d:   0.0000000     -0.22463775E-01   3.0777738
 i,j,k,ie:    1    4    6          48
 Near X = -0.16513721      0.47191231       0.0000000    , d:   0.0000000     -0.31253509       3.0777738
 i,j,k,ie:    2    4    6          48
 Near X = -0.16513721      0.47191231      0.15785898E-01, d:   0.0000000     -0.43655153E-01   3.0777738
 i,j,k,ie:    3    4    6          48
 Near X = -0.16513721      0.47191231      0.48025188E-01, d:   0.0000000     -0.43655153E-01   3.0777738
 i,j,k,ie:    4    4    6          48
 Near X = -0.16513721      0.47191231      0.86354515E-01, d:   0.0000000     -0.43655153E-01   3.0777738
 i,j,k,ie:    5    4    6          48
 Near X = -0.16513721      0.47191231      0.11859381    , d:   0.0000000     -0.43655153E-01   3.0777738
 i,j,k,ie:    6    4    6          48
 Near X = -0.16513721      0.47191231      0.13437970    , d:   0.0000000     -0.43655153E-01   3.0777738
 i,j,k,ie:    1    5    6          48
 Near X = -0.22301996      0.44740049       0.0000000    , d:   0.0000000     -0.31168403       3.0777738
 i,j,k,ie:    2    5    6          48
 Near X = -0.22301996      0.44740049      0.15785898E-01, d:   0.0000000     -0.63722220E-01   3.0777738
 i,j,k,ie:    3    5    6          48
 Near X = -0.22301996      0.44740049      0.48025188E-01, d:   0.0000000     -0.63722220E-01   3.0777738
 i,j,k,ie:    4    5    6          48
 Near X = -0.22301996      0.44740049      0.86354515E-01, d:   0.0000000     -0.63722220E-01   3.0777738
 i,j,k,ie:    5    5    6          48
 Near X = -0.22301996      0.44740049      0.11859381    , d:   0.0000000     -0.63722220E-01   3.0777738
 i,j,k,ie:    6    5    6          48
 Near X = -0.22301996      0.44740049      0.13437970    , d:   0.0000000     -0.63722220E-01   3.0777738
 i,j,k,ie:    1    6    6          48
 Near X = -0.25061479      0.43261725       0.0000000    , d:   1.0025654     -0.31201464       3.0777738
 i,j,k,ie:    2    6    6          48
 Near X = -0.25061479      0.43261725      0.15785898E-01, d:   1.0025654     -0.74295354E-01   3.0777738
 i,j,k,ie:    3    6    6          48
 Near X = -0.25061479      0.43261725      0.48025188E-01, d:   1.0025654     -0.74295354E-01   3.0777738
 i,j,k,ie:    4    6    6          48
 Near X = -0.25061479      0.43261725      0.86354515E-01, d:   1.0025654     -0.74295354E-01   3.0777738
 i,j,k,ie:    5    6    6          48
 Near X = -0.25061479      0.43261725      0.11859381    , d:   1.0025654     -0.74295354E-01   3.0777738
 i,j,k,ie:    6    6    6          48
 Near X = -0.25061479      0.43261725      0.13437970    , d:   1.0025654     -0.74295354E-01   3.0777738
 i,j,k,ie:    1    1    1          49
 Near X =  -1.2977934      0.75195052      0.13437970    , d:   1.8604349       0.0000000      0.66666667
 i,j,k,ie:    2    1    1          49
 Near X =  -1.2977934      0.75195052      0.15332278    , d:   1.8604349       0.0000000      0.66666667
 i,j,k,ie:    3    1    1          49
 Near X =  -1.2977934      0.75195052      0.19200993    , d:   1.8604349       0.0000000      0.66666667
 i,j,k,ie:    4    1    1          49
 Near X =  -1.2977934      0.75195052      0.23800512    , d:   1.8604349       0.0000000      0.66666667
 i,j,k,ie:    5    1    1          49
 Near X =  -1.2977934      0.75195052      0.27669227    , d:   1.8604349       0.0000000      0.66666667
 i,j,k,ie:    6    1    1          49
 Near X =  -1.2977934      0.75195052      0.29563535    , d:   1.8604349       0.0000000      0.66666667
 i,j,k,ie:    1    2    1          49
 Near X =  -1.3421555      0.66915597      0.13437970    , d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    2    2    1          49
 Near X =  -1.3421555      0.66915597      0.15332278    , d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    3    2    1          49
 Near X =  -1.3421555      0.66915597      0.19200993    , d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    4    2    1          49
 Near X =  -1.3421555      0.66915597      0.23800512    , d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    5    2    1          49
 Near X =  -1.3421555      0.66915597      0.27669227    , d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    6    2    1          49
 Near X =  -1.3421555      0.66915597      0.29563535    , d:  0.60934312       0.0000000      0.66666667
 i,j,k,ie:    1    3    1          49
 Near X =  -1.4157117      0.49548517      0.13437970    , d:  0.18232197       0.0000000      0.66666667
 i,j,k,ie:    2    3    1          49
 Near X =  -1.4157117      0.49548517      0.15332278    , d:  0.18232197       0.0000000      0.66666667
 i,j,k,ie:    3    3    1          49
 Near X =  -1.4157117      0.49548517      0.19200993    , d:  0.18232197       0.0000000      0.66666667
 i,j,k,ie:    4    3    1          49
 Near X =  -1.4157117      0.49548517      0.23800512    , d:  0.18232197       0.0000000      0.66666667
 i,j,k,ie:    5    3    1          49
 Near X =  -1.4157117      0.49548517      0.27669227    , d:  0.18232197       0.0000000      0.66666667
 i,j,k,ie:    6    3    1          49
 Near X =  -1.4157117      0.49548517      0.29563535    , d:  0.56444888       0.0000000      0.66666667
 i,j,k,ie:    1    4    1          49
 Near X =  -1.4733874      0.28100518      0.13437970    , d:  0.18823901       0.0000000      0.66666667
 i,j,k,ie:    2    4    1          49
 Near X =  -1.4733874      0.28100518      0.15332278    , d:  0.18823901       0.0000000      0.66666667
 i,j,k,ie:    3    4    1          49
 Near X =  -1.4733874      0.28100518      0.19200993    , d:  0.18823901       0.0000000      0.66666667
 i,j,k,ie:    4    4    1          49
 Near X =  -1.4733874      0.28100518      0.23800512    , d:  0.18823901       0.0000000      0.66666667
 i,j,k,ie:    5    4    1          49
 Near X =  -1.4733874      0.28100518      0.27669227    , d:  0.18823901       0.0000000      0.66666667
 i,j,k,ie:    6    4    1          49
 Near X =  -1.4733874      0.28100518      0.29563535    , d:  0.48129873       0.0000000      0.66666667
 i,j,k,ie:    1    5    1          49
 Near X =  -1.4968548      0.93872225E-01  0.13437970    , d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    2    5    1          49
 Near X =  -1.4968548      0.93872225E-01  0.15332278    , d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    3    5    1          49
 Near X =  -1.4968548      0.93872225E-01  0.19200993    , d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    4    5    1          49
 Near X =  -1.4968548      0.93872225E-01  0.23800512    , d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    5    5    1          49
 Near X =  -1.4968548      0.93872225E-01  0.27669227    , d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    6    5    1          49
 Near X =  -1.4968548      0.93872225E-01  0.29563535    , d:  0.38631565       0.0000000      0.66666667
 i,j,k,ie:    1    6    1          49
 Near X =  -1.5000000     -0.18369701E-15  0.13437970    , d:   2.7978518       0.0000000      0.66666667
 i,j,k,ie:    2    6    1          49
 Near X =  -1.5000000     -0.18369701E-15  0.15332278    , d:   2.7978518       0.0000000      0.66666667
 i,j,k,ie:    3    6    1          49
 Near X =  -1.5000000     -0.18369701E-15  0.19200993    , d:   2.7978518       0.0000000      0.66666667
 i,j,k,ie:    4    6    1          49
 Near X =  -1.5000000     -0.18369701E-15  0.23800512    , d:   2.7978518       0.0000000      0.66666667
 i,j,k,ie:    5    6    1          49
 Near X =  -1.5000000     -0.18369701E-15  0.27669227    , d:   2.7978518       0.0000000      0.66666667
 i,j,k,ie:    6    6    1          49
 Near X =  -1.5000000     -0.18369701E-15  0.29563535    , d:   3.0000000       0.0000000      0.66666667
 i,j,k,ie:    1    1    2          49
 Near X =  -1.2826095      0.74288826      0.13437970    , d:   1.8299767       0.0000000      0.66666667
 i,j,k,ie:    2    1    2          49
 Near X =  -1.2826095      0.74288826      0.15332278    , d:   1.8299767       0.0000000      0.66666667
 i,j,k,ie:    3    1    2          49
 Near X =  -1.2826095      0.74288826      0.19200993    , d:   1.8299767       0.0000000      0.66666667
 i,j,k,ie:    4    1    2          49
 Near X =  -1.2826095      0.74288826      0.23800512    , d:   1.8299767       0.0000000      0.66666667
 i,j,k,ie:    5    1    2          49
 Near X =  -1.2826095      0.74288826      0.27669227    , d:   1.8299767       0.0000000      0.66666667
 i,j,k,ie:    6    1    2          49
 Near X =  -1.2826095      0.74288826      0.29563535    , d:   1.8299767       0.0000000      0.66666667
 i,j,k,ie:    6    2    2          49
 Near X =  -1.3242644      0.66050762      0.29563535    , d:  0.50495436       0.0000000      0.66666667
 i,j,k,ie:    6    3    2          49
 Near X =  -1.3942939      0.48822024      0.29563535    , d:  0.42955448       0.0000000      0.66666667
 i,j,k,ie:    6    4    2          49
 Near X =  -1.4512745      0.27632510      0.29563535    , d:  0.33256309       0.0000000      0.66666667
 i,j,k,ie:    6    5    2          49
 Near X =  -1.4770993      0.92157000E-01  0.29563535    , d:  0.24480155       0.0000000      0.66666667
 i,j,k,ie:    1    6    2          49
 Near X =  -1.4823792     -0.20096047E-15  0.13437970    , d:   2.7650431       0.0000000      0.66666667
 i,j,k,ie:    2    6    2          49
 Near X =  -1.4823792     -0.20096047E-15  0.15332278    , d:   2.7650431       0.0000000      0.66666667
 i,j,k,ie:    3    6    2          49
 Near X =  -1.4823792     -0.20096047E-15  0.19200993    , d:   2.7650431       0.0000000      0.66666667
 i,j,k,ie:    4    6    2          49
 Near X =  -1.4823792     -0.20096047E-15  0.23800512    , d:   2.7650431       0.0000000      0.66666667
 i,j,k,ie:    5    6    2          49
 Near X =  -1.4823792     -0.20096047E-15  0.27669227    , d:   2.7650431       0.0000000      0.66666667
 i,j,k,ie:    6    6    2          49
 Near X =  -1.4823792     -0.20096047E-15  0.29563535    , d:   2.9647583       0.0000000      0.66666667
 i,j,k,ie:    1    1    3          49
 Near X =  -1.2515996      0.72438055      0.13437970    , d:   1.7677725       0.0000000      0.66666667
 i,j,k,ie:    2    1    3          49
 Near X =  -1.2515996      0.72438055      0.15332278    , d:   1.7677725       0.0000000      0.66666667
 i,j,k,ie:    3    1    3          49
 Near X =  -1.2515996      0.72438055      0.19200993    , d:   1.7677725       0.0000000      0.66666667
 i,j,k,ie:    4    1    3          49
 Near X =  -1.2515996      0.72438055      0.23800512    , d:   1.7677725       0.0000000      0.66666667
 i,j,k,ie:    5    1    3          49
 Near X =  -1.2515996      0.72438055      0.27669227    , d:   1.7677725       0.0000000      0.66666667
 i,j,k,ie:    6    1    3          49
 Near X =  -1.2515996      0.72438055      0.29563535    , d:   1.7677725       0.0000000      0.66666667
 i,j,k,ie:    6    2    3          49
 Near X =  -1.2877257      0.64284522      0.29563535    , d:  0.49192969       0.0000000      0.66666667
 i,j,k,ie:    6    3    3          49
 Near X =  -1.3505527      0.47338320      0.29563535    , d:  0.41666147       0.0000000      0.66666667
 i,j,k,ie:    6    4    3          49
 Near X =  -1.4061137      0.26676704      0.29563535    , d:  0.32182424       0.0000000      0.66666667
 i,j,k,ie:    6    5    3          49
 Near X =  -1.4367529      0.88654022E-01  0.29563535    , d:  0.23755484       0.0000000      0.66666667
 i,j,k,ie:    1    6    3          49
 Near X =  -1.4463924     -0.23621735E-15  0.13437970    , d:   2.6980384       0.0000000      0.66666667
 i,j,k,ie:    2    6    3          49
 Near X =  -1.4463924     -0.23621735E-15  0.15332278    , d:   2.6980384       0.0000000      0.66666667
 i,j,k,ie:    3    6    3          49
 Near X =  -1.4463924     -0.23621735E-15  0.19200993    , d:   2.6980384       0.0000000      0.66666667
 i,j,k,ie:    4    6    3          49
 Near X =  -1.4463924     -0.23621735E-15  0.23800512    , d:   2.6980384       0.0000000      0.66666667
 i,j,k,ie:    5    6    3          49
 Near X =  -1.4463924     -0.23621735E-15  0.27669227    , d:   2.6980384       0.0000000      0.66666667
 i,j,k,ie:    6    6    3          49
 Near X =  -1.4463924     -0.23621735E-15  0.29563535    , d:   2.8927847       0.0000000      0.66666667
 i,j,k,ie:    1    1    4          49
 Near X =  -1.2147319      0.70237671      0.13437970    , d:   1.6938178       0.0000000      0.66666667
 i,j,k,ie:    2    1    4          49
 Near X =  -1.2147319      0.70237671      0.15332278    , d:   1.6938178       0.0000000      0.66666667
 i,j,k,ie:    3    1    4          49
 Near X =  -1.2147319      0.70237671      0.19200993    , d:   1.6938178       0.0000000      0.66666667
 i,j,k,ie:    4    1    4          49
 Near X =  -1.2147319      0.70237671      0.23800512    , d:   1.6938178       0.0000000      0.66666667
 i,j,k,ie:    5    1    4          49
 Near X =  -1.2147319      0.70237671      0.27669227    , d:   1.6938178       0.0000000      0.66666667
 i,j,k,ie:    6    1    4          49
 Near X =  -1.2147319      0.70237671      0.29563535    , d:   1.6938178       0.0000000      0.66666667
 i,j,k,ie:    6    2    4          49
 Near X =  -1.2442847      0.62184637      0.29563535    , d:  0.47644464       0.0000000      0.66666667
 i,j,k,ie:    6    3    4          49
 Near X =  -1.2985487      0.45574342      0.29563535    , d:  0.40133295       0.0000000      0.66666667
 i,j,k,ie:    6    4    4          49
 Near X =  -1.3524220      0.25540344      0.29563535    , d:  0.30905682       0.0000000      0.66666667
 i,j,k,ie:    6    5    4          49
 Near X =  -1.3887851      0.84489329E-01  0.29563535    , d:  0.22893921       0.0000000      0.66666667
 i,j,k,ie:    1    6    4          49
 Near X =  -1.4036077     -0.27813430E-15  0.13437970    , d:   2.6183765       0.0000000      0.66666667
 i,j,k,ie:    2    6    4          49
 Near X =  -1.4036077     -0.27813430E-15  0.15332278    , d:   2.6183765       0.0000000      0.66666667
 i,j,k,ie:    3    6    4          49
 Near X =  -1.4036077     -0.27813430E-15  0.19200993    , d:   2.6183765       0.0000000      0.66666667
 i,j,k,ie:    4    6    4          49
 Near X =  -1.4036077     -0.27813430E-15  0.23800512    , d:   2.6183765       0.0000000      0.66666667
 i,j,k,ie:    5    6    4          49
 Near X =  -1.4036077     -0.27813430E-15  0.27669227    , d:   2.6183765       0.0000000      0.66666667
 i,j,k,ie:    6    6    4          49
 Near X =  -1.4036077     -0.27813430E-15  0.29563535    , d:   2.8072153       0.0000000      0.66666667
 i,j,k,ie:    1    1    5          49
 Near X =  -1.1837220      0.68386900      0.13437970    , d:   1.6316135       0.0000000      0.66666667
 i,j,k,ie:    2    1    5          49
 Near X =  -1.1837220      0.68386900      0.15332278    , d:   1.6316135       0.0000000      0.66666667
 i,j,k,ie:    3    1    5          49
 Near X =  -1.1837220      0.68386900      0.19200993    , d:   1.6316135       0.0000000      0.66666667
 i,j,k,ie:    4    1    5          49
 Near X =  -1.1837220      0.68386900      0.23800512    , d:   1.6316135       0.0000000      0.66666667
 i,j,k,ie:    5    1    5          49
 Near X =  -1.1837220      0.68386900      0.27669227    , d:   1.6316135       0.0000000      0.66666667
 i,j,k,ie:    6    1    5          49
 Near X =  -1.1837220      0.68386900      0.29563535    , d:   1.6316135       0.0000000      0.66666667
 i,j,k,ie:    6    2    5          49
 Near X =  -1.2077460      0.60418397      0.29563535    , d:  0.46341997       0.0000000      0.66666667
 i,j,k,ie:    6    3    5          49
 Near X =  -1.2548075      0.44090637      0.29563535    , d:  0.38843994       0.0000000      0.66666667
 i,j,k,ie:    6    4    5          49
 Near X =  -1.3072613      0.24584538      0.29563535    , d:  0.29831797       0.0000000      0.66666667
 i,j,k,ie:    6    5    5          49
 Near X =  -1.3484388      0.80986351E-01  0.29563535    , d:  0.22169249       0.0000000      0.66666667
 i,j,k,ie:    1    6    5          49
 Near X =  -1.3676209     -0.31339119E-15  0.13437970    , d:   2.5513718       0.0000000      0.66666667
 i,j,k,ie:    2    6    5          49
 Near X =  -1.3676209     -0.31339119E-15  0.15332278    , d:   2.5513718       0.0000000      0.66666667
 i,j,k,ie:    3    6    5          49
 Near X =  -1.3676209     -0.31339119E-15  0.19200993    , d:   2.5513718       0.0000000      0.66666667
 i,j,k,ie:    4    6    5          49
 Near X =  -1.3676209     -0.31339119E-15  0.23800512    , d:   2.5513718       0.0000000      0.66666667
 i,j,k,ie:    5    6    5          49
 Near X =  -1.3676209     -0.31339119E-15  0.27669227    , d:   2.5513718       0.0000000      0.66666667
 i,j,k,ie:    6    6    5          49
 Near X =  -1.3676209     -0.31339119E-15  0.29563535    , d:   2.7352417       0.0000000      0.66666667
 i,j,k,ie:    1    1    6          49
 Near X =  -1.1685381      0.67480674      0.13437970    , d:   1.7311796     -0.12925528      0.66666667
 i,j,k,ie:    2    1    6          49
 Near X =  -1.1685381      0.67480674      0.15332278    , d:   1.7311796     -0.12925528      0.66666667
 i,j,k,ie:    3    1    6          49
 Near X =  -1.1685381      0.67480674      0.19200993    , d:   1.7311796     -0.12925528      0.66666667
 i,j,k,ie:    4    1    6          49
 Near X =  -1.1685381      0.67480674      0.23800512    , d:   1.7311796     -0.12925528      0.66666667
 i,j,k,ie:    5    1    6          49
 Near X =  -1.1685381      0.67480674      0.27669227    , d:   1.7311796     -0.12925528      0.66666667
 i,j,k,ie:    6    1    6          49
 Near X =  -1.1685381      0.67480674      0.29563535    , d:   1.7311796     -0.12925528      0.66666667
 i,j,k,ie:    1    2    6          49
 Near X =  -1.1898549      0.59553562      0.13437970    , d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    2    2    6          49
 Near X =  -1.1898549      0.59553562      0.15332278    , d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    3    2    6          49
 Near X =  -1.1898549      0.59553562      0.19200993    , d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    4    2    6          49
 Near X =  -1.1898549      0.59553562      0.23800512    , d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    5    2    6          49
 Near X =  -1.1898549      0.59553562      0.27669227    , d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    6    2    6          49
 Near X =  -1.1898549      0.59553562      0.29563535    , d:  0.45704247     -0.15230065      0.66666667
 i,j,k,ie:    1    3    6          49
 Near X =  -1.2333897      0.43364145      0.13437970    , d:   0.0000000     -0.18232197      0.66666667
 i,j,k,ie:    2    3    6          49
 Near X =  -1.2333897      0.43364145      0.15332278    , d:   0.0000000     -0.18232197      0.66666667
 i,j,k,ie:    3    3    6          49
 Near X =  -1.2333897      0.43364145      0.19200993    , d:   0.0000000     -0.18232197      0.66666667
 i,j,k,ie:    4    3    6          49
 Near X =  -1.2333897      0.43364145      0.23800512    , d:   0.0000000     -0.18232197      0.66666667
 i,j,k,ie:    5    3    6          49
 Near X =  -1.2333897      0.43364145      0.27669227    , d:   0.0000000     -0.18232197      0.66666667
 i,j,k,ie:    6    3    6          49
 Near X =  -1.2333897      0.43364145      0.29563535    , d:  0.38212691     -0.18232197      0.66666667
 i,j,k,ie:    1    4    6          49
 Near X =  -1.2851484      0.24116530      0.13437970    , d:   0.0000000     -0.18823901      0.66666667
 i,j,k,ie:    2    4    6          49
 Near X =  -1.2851484      0.24116530      0.15332278    , d:   0.0000000     -0.18823901      0.66666667
 i,j,k,ie:    3    4    6          49
 Near X =  -1.2851484      0.24116530      0.19200993    , d:   0.0000000     -0.18823901      0.66666667
 i,j,k,ie:    4    4    6          49
 Near X =  -1.2851484      0.24116530      0.23800512    , d:   0.0000000     -0.18823901      0.66666667
 i,j,k,ie:    5    4    6          49
 Near X =  -1.2851484      0.24116530      0.27669227    , d:   0.0000000     -0.18823901      0.66666667
 i,j,k,ie:    6    4    6          49
 Near X =  -1.2851484      0.24116530      0.29563535    , d:  0.29305972     -0.18823901      0.66666667
 i,j,k,ie:    1    5    6          49
 Near X =  -1.3286833      0.79271126E-01  0.13437970    , d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    2    5    6          49
 Near X =  -1.3286833      0.79271126E-01  0.15332278    , d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    3    5    6          49
 Near X =  -1.3286833      0.79271126E-01  0.19200993    , d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    4    5    6          49
 Near X =  -1.3286833      0.79271126E-01  0.23800512    , d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    5    5    6          49
 Near X =  -1.3286833      0.79271126E-01  0.27669227    , d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    6    5    6          49
 Near X =  -1.3286833      0.79271126E-01  0.29563535    , d:  0.21814416     -0.16817149      0.66666667
 i,j,k,ie:    1    6    6          49
 Near X =  -1.3500000     -0.33065464E-15  0.13437970    , d:   2.6478518     -0.14999998      0.66666667
 i,j,k,ie:    2    6    6          49
 Near X =  -1.3500000     -0.33065464E-15  0.15332278    , d:   2.6478518     -0.14999998      0.66666667
 i,j,k,ie:    3    6    6          49
 Near X =  -1.3500000     -0.33065464E-15  0.19200993    , d:   2.6478518     -0.14999998      0.66666667
 i,j,k,ie:    4    6    6          49
 Near X =  -1.3500000     -0.33065464E-15  0.23800512    , d:   2.6478518     -0.14999998      0.66666667
 i,j,k,ie:    5    6    6          49
 Near X =  -1.3500000     -0.33065464E-15  0.27669227    , d:   2.6478518     -0.14999998      0.66666667
 i,j,k,ie:    6    6    6          49
 Near X =  -1.3500000     -0.33065464E-15  0.29563535    , d:   2.8500000     -0.14999998      0.66666667
 i,j,k,ie:    1    1    1          50
 Near X = -0.75184436       1.2978517      0.13437970    , d:   1.3144858     -0.54594903      0.77053868
 i,j,k,ie:    2    1    1          50
 Near X = -0.75184436       1.2978517      0.15332278    , d:  0.25184436       0.0000000      0.77053868
 i,j,k,ie:    3    1    1          50
 Near X = -0.75184436       1.2978517      0.19200993    , d:  0.25184436       0.0000000      0.77053868
 i,j,k,ie:    4    1    1          50
 Near X = -0.75184436       1.2978517      0.23800512    , d:  0.25184436       0.0000000      0.77053868
 i,j,k,ie:    5    1    1          50
 Near X = -0.75184436       1.2978517      0.27669227    , d:  0.25184436       0.0000000      0.77053868
 i,j,k,ie:    6    1    1          50
 Near X = -0.75184436       1.2978517      0.29563535    , d:  0.75184442       0.0000000      0.77053868
 i,j,k,ie:    1    2    1          50
 Near X = -0.83082366       1.2485700      0.13437970    , d:  0.98011259E-01 -0.51133186      0.77053868
 i,j,k,ie:    2    2    1          50
 Near X = -0.83082366       1.2485700      0.15332278    , d:  0.98011259E-01   0.0000000      0.77053868
 i,j,k,ie:    3    2    1          50
 Near X = -0.83082366       1.2485700      0.19200993    , d:  0.98011259E-01   0.0000000      0.77053868
 i,j,k,ie:    4    2    1          50
 Near X = -0.83082366       1.2485700      0.23800512    , d:  0.98011259E-01   0.0000000      0.77053868
 i,j,k,ie:    5    2    1          50
 Near X = -0.83082366       1.2485700      0.27669227    , d:  0.98011259E-01   0.0000000      0.77053868
 i,j,k,ie:    6    2    1          50
 Near X = -0.83082366       1.2485700      0.29563535    , d:  0.75155180       0.0000000      0.77053868
 i,j,k,ie:    1    3    1          50
 Near X = -0.97984419       1.1356441      0.13437970    , d:  0.12858136     -0.43586751      0.77053868
 i,j,k,ie:    2    3    1          50
 Near X = -0.97984419       1.1356441      0.15332278    , d:  0.12858136       0.0000000      0.77053868
 i,j,k,ie:    3    3    1          50
 Near X = -0.97984419       1.1356441      0.19200993    , d:  0.12858136       0.0000000      0.77053868
 i,j,k,ie:    4    3    1          50
 Near X = -0.97984419       1.1356441      0.23800512    , d:  0.12858136       0.0000000      0.77053868
 i,j,k,ie:    5    3    1          50
 Near X = -0.97984419       1.1356441      0.27669227    , d:  0.12858136       0.0000000      0.77053868
 i,j,k,ie:    6    3    1          50
 Near X = -0.97984419       1.1356441      0.29563535    , d:  0.73867655       0.0000000      0.77053868
 i,j,k,ie:    1    4    1          50
 Near X =  -1.1355661      0.97993591      0.13437970    , d:  0.14347739     -0.33782134      0.77053868
 i,j,k,ie:    2    4    1          50
 Near X =  -1.1355661      0.97993591      0.15332278    , d:  0.14347739       0.0000000      0.77053868
 i,j,k,ie:    3    4    1          50
 Near X =  -1.1355661      0.97993591      0.19200993    , d:  0.14347739       0.0000000      0.77053868
 i,j,k,ie:    4    4    1          50
 Near X =  -1.1355661      0.97993591      0.23800512    , d:  0.14347739       0.0000000      0.77053868
 i,j,k,ie:    5    4    1          50
 Near X =  -1.1355661      0.97993591      0.27669227    , d:  0.14347739       0.0000000      0.77053868
 i,j,k,ie:    6    4    1          50
 Near X =  -1.1355661      0.97993591      0.29563535    , d:  0.70192036       0.0000000      0.77053868
 i,j,k,ie:    1    5    1          50
 Near X =  -1.2485049      0.83092539      0.13437970    , d:  0.13796576     -0.24834989      0.77053868
 i,j,k,ie:    2    5    1          50
 Near X =  -1.2485049      0.83092539      0.15332278    , d:  0.13796576       0.0000000      0.77053868
 i,j,k,ie:    3    5    1          50
 Near X =  -1.2485049      0.83092539      0.19200993    , d:  0.13796576       0.0000000      0.77053868
 i,j,k,ie:    4    5    1          50
 Near X =  -1.2485049      0.83092539      0.23800512    , d:  0.13796576       0.0000000      0.77053868
 i,j,k,ie:    5    5    1          50
 Near X =  -1.2485049      0.83092539      0.27669227    , d:  0.13796576       0.0000000      0.77053868
 i,j,k,ie:    6    5    1          50
 Near X =  -1.2485049      0.83092539      0.29563535    , d:  0.65296338       0.0000000      0.77053868
 i,j,k,ie:    1    6    1          50
 Near X =  -1.2977934      0.75195052      0.13437970    , d:   2.7977934     -0.20220661      0.77053868
 i,j,k,ie:    2    6    1          50
 Near X =  -1.2977934      0.75195052      0.15332278    , d:   2.7977934       0.0000000      0.77053868
 i,j,k,ie:    3    6    1          50
 Near X =  -1.2977934      0.75195052      0.19200993    , d:   2.7977934       0.0000000      0.77053868
 i,j,k,ie:    4    6    1          50
 Near X =  -1.2977934      0.75195052      0.23800512    , d:   2.7977934       0.0000000      0.77053868
 i,j,k,ie:    5    6    1          50
 Near X =  -1.2977934      0.75195052      0.27669227    , d:   2.7977934       0.0000000      0.77053868
 i,j,k,ie:    6    6    1          50
 Near X =  -1.2977934      0.75195052      0.29563535    , d:   2.7977934       0.0000000      0.77053868
 i,j,k,ie:    1    1    2          50
 Near X = -0.74279535       1.2826639      0.13437970    , d:   1.2901626     -0.53981412      0.77053868
 i,j,k,ie:    2    1    2          50
 Near X = -0.74279535       1.2826639      0.15332278    , d:  0.11041622       0.0000000      0.77053868
 i,j,k,ie:    3    1    2          50
 Near X = -0.74279535       1.2826639      0.19200993    , d:  0.11041622       0.0000000      0.77053868
 i,j,k,ie:    4    1    2          50
 Near X = -0.74279535       1.2826639      0.23800512    , d:  0.11041622       0.0000000      0.77053868
 i,j,k,ie:    5    1    2          50
 Near X = -0.74279535       1.2826639      0.27669227    , d:  0.11041622       0.0000000      0.77053868
 i,j,k,ie:    6    1    2          50
 Near X = -0.74279535       1.2826639      0.29563535    , d:  0.74279541       0.0000000      0.77053868
 i,j,k,ie:    1    2    2          50
 Near X = -0.81931004       1.2323577      0.13437970    , d:   0.0000000     -0.50495436      0.77053868
 i,j,k,ie:    6    2    2          50
 Near X = -0.81931004       1.2323577      0.29563535    , d:  0.72716612       0.0000000      0.77053868
 i,j,k,ie:    1    3    2          50
 Near X = -0.96473944       1.1187820      0.13437970    , d:   0.0000000     -0.42955448      0.77053868
 i,j,k,ie:    6    3    2          50
 Near X = -0.96473944       1.1187820      0.29563535    , d:  0.68845225       0.0000000      0.77053868
 i,j,k,ie:    1    4    2          50
 Near X =  -1.1187114      0.96482093      0.13437970    , d:   0.0000000     -0.33256309      0.77053868
 i,j,k,ie:    6    4    2          50
 Near X =  -1.1187114      0.96482093      0.29563535    , d:  0.63055559       0.0000000      0.77053868
 i,j,k,ie:    1    5    2          50
 Near X =  -1.2322977      0.81939948      0.13437970    , d:   0.0000000     -0.24480155      0.77053868
 i,j,k,ie:    6    5    2          50
 Near X =  -1.2322977      0.81939948      0.29563535    , d:  0.57187420       0.0000000      0.77053868
 i,j,k,ie:    1    6    2          50
 Near X =  -1.2826095      0.74288826      0.13437970    , d:   2.7649886     -0.19976968      0.77053868
 i,j,k,ie:    2    6    2          50
 Near X =  -1.2826095      0.74288826      0.15332278    , d:   2.7649886       0.0000000      0.77053868
 i,j,k,ie:    3    6    2          50
 Near X =  -1.2826095      0.74288826      0.19200993    , d:   2.7649886       0.0000000      0.77053868
 i,j,k,ie:    4    6    2          50
 Near X =  -1.2826095      0.74288826      0.23800512    , d:   2.7649886       0.0000000      0.77053868
 i,j,k,ie:    5    6    2          50
 Near X =  -1.2826095      0.74288826      0.27669227    , d:   2.7649886       0.0000000      0.77053868
 i,j,k,ie:    6    6    2          50
 Near X =  -1.2826095      0.74288826      0.29563535    , d:   2.7649886       0.0000000      0.77053868
 i,j,k,ie:    1    1    3          50
 Near X = -0.72431471       1.2516460      0.13437970    , d:   1.2404876     -0.52728488      0.77053868
 i,j,k,ie:    2    1    3          50
 Near X = -0.72431471       1.2516460      0.15332278    , d:  0.12792236       0.0000000      0.77053868
 i,j,k,ie:    3    1    3          50
 Near X = -0.72431471       1.2516460      0.19200993    , d:  0.12792236       0.0000000      0.77053868
 i,j,k,ie:    4    1    3          50
 Near X = -0.72431471       1.2516460      0.23800512    , d:  0.12792236       0.0000000      0.77053868
 i,j,k,ie:    5    1    3          50
 Near X = -0.72431471       1.2516460      0.27669227    , d:  0.12792236       0.0000000      0.77053868
 i,j,k,ie:    6    1    3          50
 Near X = -0.72431471       1.2516460      0.29563535    , d:  0.72431477       0.0000000      0.77053868
 i,j,k,ie:    1    2    3          50
 Near X = -0.79579598       1.1992475      0.13437970    , d:   0.0000000     -0.49192969      0.77053868
 i,j,k,ie:    6    2    3          50
 Near X = -0.79579598       1.1992475      0.29563535    , d:  0.70715127       0.0000000      0.77053868
 i,j,k,ie:    1    3    3          50
 Near X = -0.93389124       1.0843446      0.13437970    , d:   0.0000000     -0.41666147      0.77053868
 i,j,k,ie:    6    3    3          50
 Near X = -0.93389124       1.0843446      0.29563535    , d:  0.66715117       0.0000000      0.77053868
 i,j,k,ie:    1    4    3          50
 Near X =  -1.0842895      0.93395184      0.13437970    , d:   0.0000000     -0.32182424      0.77053868
 i,j,k,ie:    6    4    3          50
 Near X =  -1.0842895      0.93395184      0.29563535    , d:  0.61095204       0.0000000      0.77053868
 i,j,k,ie:    1    5    3          50
 Near X =  -1.1991981      0.79586030      0.13437970    , d:   0.0000000     -0.23755484      0.77053868
 i,j,k,ie:    6    5    3          50
 Near X =  -1.1991981      0.79586030      0.29563535    , d:  0.55641251       0.0000000      0.77053868
 i,j,k,ie:    1    6    3          50
 Near X =  -1.2515996      0.72438055      0.13437970    , d:   2.6979920     -0.19479278      0.77053868
 i,j,k,ie:    2    6    3          50
 Near X =  -1.2515996      0.72438055      0.15332278    , d:   2.6979920       0.0000000      0.77053868
 i,j,k,ie:    3    6    3          50
 Near X =  -1.2515996      0.72438055      0.19200993    , d:   2.6979920       0.0000000      0.77053868
 i,j,k,ie:    4    6    3          50
 Near X =  -1.2515996      0.72438055      0.23800512    , d:   2.6979920       0.0000000      0.77053868
 i,j,k,ie:    5    6    3          50
 Near X =  -1.2515996      0.72438055      0.27669227    , d:   2.6979920       0.0000000      0.77053868
 i,j,k,ie:    6    6    3          50
 Near X =  -1.2515996      0.72438055      0.29563535    , d:   2.6979920       0.0000000      0.77053868
 i,j,k,ie:    1    1    4          50
 Near X = -0.70234305       1.2147688      0.13437970    , d:   1.1814289     -0.51238886      0.77053868
 i,j,k,ie:    2    1    4          50
 Near X = -0.70234305       1.2147688      0.15332278    , d:  0.14873542       0.0000000      0.77053868
 i,j,k,ie:    3    1    4          50
 Near X = -0.70234305       1.2147688      0.19200993    , d:  0.14873542       0.0000000      0.77053868
 i,j,k,ie:    4    1    4          50
 Near X = -0.70234305       1.2147688      0.23800512    , d:  0.14873542       0.0000000      0.77053868
 i,j,k,ie:    5    1    4          50
 Near X = -0.70234305       1.2147688      0.27669227    , d:  0.14873542       0.0000000      0.77053868
 i,j,k,ie:    6    1    4          50
 Near X = -0.70234305       1.2147688      0.29563535    , d:  0.70234311       0.0000000      0.77053868
 i,j,k,ie:    1    2    4          50
 Near X = -0.76784008       1.1598828      0.13437970    , d:   0.0000000     -0.47644464      0.77053868
 i,j,k,ie:    6    2    4          50
 Near X = -0.76784008       1.1598828      0.29563535    , d:  0.68335560       0.0000000      0.77053868
 i,j,k,ie:    1    3    4          50
 Near X = -0.89721578       1.0434019      0.13437970    , d:   0.0000000     -0.40133295      0.77053868
 i,j,k,ie:    6    3    4          50
 Near X = -0.89721578       1.0434019      0.29563535    , d:  0.64182629       0.0000000      0.77053868
 i,j,k,ie:    1    4    4          50
 Near X =  -1.0433652      0.89725154      0.13437970    , d:   0.0000000     -0.30905682      0.77053868
 i,j,k,ie:    6    4    4          50
 Near X =  -1.0433652      0.89725154      0.29563535    , d:  0.58764536       0.0000000      0.77053868
 i,j,k,ie:    1    5    4          50
 Near X =  -1.1598459      0.76787454      0.13437970    , d:   0.0000000     -0.22893921      0.77053868
 i,j,k,ie:    6    5    4          50
 Near X =  -1.1598459      0.76787454      0.29563535    , d:  0.53803009       0.0000000      0.77053868
 i,j,k,ie:    1    6    4          50
 Near X =  -1.2147319      0.70237671      0.13437970    , d:   2.6183396     -0.18887574      0.77053868
 i,j,k,ie:    2    6    4          50
 Near X =  -1.2147319      0.70237671      0.15332278    , d:   2.6183396       0.0000000      0.77053868
 i,j,k,ie:    3    6    4          50
 Near X =  -1.2147319      0.70237671      0.19200993    , d:   2.6183396       0.0000000      0.77053868
 i,j,k,ie:    4    6    4          50
 Near X =  -1.2147319      0.70237671      0.23800512    , d:   2.6183396       0.0000000      0.77053868
 i,j,k,ie:    5    6    4          50
 Near X =  -1.2147319      0.70237671      0.27669227    , d:   2.6183396       0.0000000      0.77053868
 i,j,k,ie:    6    6    4          50
 Near X =  -1.2147319      0.70237671      0.29563535    , d:   2.6183396       0.0000000      0.77053868
 i,j,k,ie:    1    1    5          50
 Near X = -0.68386241       1.1837509      0.13437970    , d:   1.1317539     -0.49985962      0.77053868
 i,j,k,ie:    2    1    5          50
 Near X = -0.68386241       1.1837509      0.15332278    , d:  0.16624156       0.0000000      0.77053868
 i,j,k,ie:    3    1    5          50
 Near X = -0.68386241       1.1837509      0.19200993    , d:  0.16624156       0.0000000      0.77053868
 i,j,k,ie:    4    1    5          50
 Near X = -0.68386241       1.1837509      0.23800512    , d:  0.16624156       0.0000000      0.77053868
 i,j,k,ie:    5    1    5          50
 Near X = -0.68386241       1.1837509      0.27669227    , d:  0.16624156       0.0000000      0.77053868
 i,j,k,ie:    6    1    5          50
 Near X = -0.68386241       1.1837509      0.29563535    , d:  0.68386246       0.0000000      0.77053868
 i,j,k,ie:    1    2    5          50
 Near X = -0.74432601       1.1267727      0.13437970    , d:   0.0000000     -0.46341997      0.77053868
 i,j,k,ie:    6    2    5          50
 Near X = -0.74432601       1.1267727      0.29563535    , d:  0.66334076       0.0000000      0.77053868
 i,j,k,ie:    1    3    5          50
 Near X = -0.86636758       1.0089645      0.13437970    , d:   0.0000000     -0.38843994      0.77053868
 i,j,k,ie:    6    3    5          50
 Near X = -0.86636758       1.0089645      0.29563535    , d:  0.62052522       0.0000000      0.77053868
 i,j,k,ie:    1    4    5          50
 Near X =  -1.0089433      0.86638245      0.13437970    , d:   0.0000000     -0.29831797      0.77053868
 i,j,k,ie:    6    4    5          50
 Near X =  -1.0089433      0.86638245      0.29563535    , d:  0.56804181       0.0000000      0.77053868
 i,j,k,ie:    1    5    5          50
 Near X =  -1.1267463      0.74433536      0.13437970    , d:   0.0000000     -0.22169249      0.77053868
 i,j,k,ie:    6    5    5          50
 Near X =  -1.1267463      0.74433536      0.29563535    , d:  0.52256841       0.0000000      0.77053868
 i,j,k,ie:    1    6    5          50
 Near X =  -1.1837220      0.68386900      0.13437970    , d:   2.5513429     -0.18389884      0.77053868
 i,j,k,ie:    2    6    5          50
 Near X =  -1.1837220      0.68386900      0.15332278    , d:   2.5513429       0.0000000      0.77053868
 i,j,k,ie:    3    6    5          50
 Near X =  -1.1837220      0.68386900      0.19200993    , d:   2.5513429       0.0000000      0.77053868
 i,j,k,ie:    4    6    5          50
 Near X =  -1.1837220      0.68386900      0.23800512    , d:   2.5513429       0.0000000      0.77053868
 i,j,k,ie:    5    6    5          50
 Near X =  -1.1837220      0.68386900      0.27669227    , d:   2.5513429       0.0000000      0.77053868
 i,j,k,ie:    6    6    5          50
 Near X =  -1.1837220      0.68386900      0.29563535    , d:   2.5513429       0.0000000      0.77053868
 i,j,k,ie:    1    1    6          50
 Near X = -0.67481340       1.1685631      0.13437970    , d:   1.2374549     -0.62297999      0.77053868
 i,j,k,ie:    2    1    6          50
 Near X = -0.67481340       1.1685631      0.15332278    , d:  0.17481340     -0.77030957E-01  0.77053868
 i,j,k,ie:    3    1    6          50
 Near X = -0.67481340       1.1685631      0.19200993    , d:  0.17481340     -0.77030957E-01  0.77053868
 i,j,k,ie:    4    1    6          50
 Near X = -0.67481340       1.1685631      0.23800512    , d:  0.17481340     -0.77030957E-01  0.77053868
 i,j,k,ie:    5    1    6          50
 Near X = -0.67481340       1.1685631      0.27669227    , d:  0.17481340     -0.77030957E-01  0.77053868
 i,j,k,ie:    6    1    6          50
 Near X = -0.67481340       1.1685631      0.29563535    , d:  0.67481346     -0.77030957E-01  0.77053868
 i,j,k,ie:    1    2    6          50
 Near X = -0.73281240       1.1105604      0.13437970    , d:   0.0000000     -0.60934312      0.77053868
 i,j,k,ie:    2    2    6          50
 Near X = -0.73281240       1.1105604      0.15332278    , d:   0.0000000     -0.98011259E-01  0.77053868
 i,j,k,ie:    3    2    6          50
 Near X = -0.73281240       1.1105604      0.19200993    , d:   0.0000000     -0.98011259E-01  0.77053868
 i,j,k,ie:    4    2    6          50
 Near X = -0.73281240       1.1105604      0.23800512    , d:   0.0000000     -0.98011259E-01  0.77053868
 i,j,k,ie:    5    2    6          50
 Near X = -0.73281240       1.1105604      0.27669227    , d:   0.0000000     -0.98011259E-01  0.77053868
 i,j,k,ie:    6    2    6          50
 Near X = -0.73281240       1.1105604      0.29563535    , d:  0.65354054     -0.98011259E-01  0.77053868
 i,j,k,ie:    1    3    6          50
 Near X = -0.85126283      0.99210234      0.13437970    , d:   0.0000000     -0.56444888      0.77053868
 i,j,k,ie:    2    3    6          50
 Near X = -0.85126283      0.99210234      0.15332278    , d:   0.0000000     -0.12858136      0.77053868
 i,j,k,ie:    3    3    6          50
 Near X = -0.85126283      0.99210234      0.19200993    , d:   0.0000000     -0.12858136      0.77053868
 i,j,k,ie:    4    3    6          50
 Near X = -0.85126283      0.99210234      0.23800512    , d:   0.0000000     -0.12858136      0.77053868
 i,j,k,ie:    5    3    6          50
 Near X = -0.85126283      0.99210234      0.27669227    , d:   0.0000000     -0.12858136      0.77053868
 i,j,k,ie:    6    3    6          50
 Near X = -0.85126283      0.99210234      0.29563535    , d:  0.61009519     -0.12858136      0.77053868
 i,j,k,ie:    1    4    6          50
 Near X = -0.99208868      0.85126747      0.13437970    , d:   0.0000000     -0.48129873      0.77053868
 i,j,k,ie:    2    4    6          50
 Near X = -0.99208868      0.85126747      0.15332278    , d:   0.0000000     -0.14347739      0.77053868
 i,j,k,ie:    3    4    6          50
 Near X = -0.99208868      0.85126747      0.19200993    , d:   0.0000000     -0.14347739      0.77053868
 i,j,k,ie:    4    4    6          50
 Near X = -0.99208868      0.85126747      0.23800512    , d:   0.0000000     -0.14347739      0.77053868
 i,j,k,ie:    5    4    6          50
 Near X = -0.99208868      0.85126747      0.27669227    , d:   0.0000000     -0.14347739      0.77053868
 i,j,k,ie:    6    4    6          50
 Near X = -0.99208868      0.85126747      0.29563535    , d:  0.55844297     -0.14347739      0.77053868
 i,j,k,ie:    1    5    6          50
 Near X =  -1.1105391      0.73280945      0.13437970    , d:   0.0000000     -0.38631565      0.77053868
 i,j,k,ie:    2    5    6          50
 Near X =  -1.1105391      0.73280945      0.15332278    , d:   0.0000000     -0.13796576      0.77053868
 i,j,k,ie:    3    5    6          50
 Near X =  -1.1105391      0.73280945      0.19200993    , d:   0.0000000     -0.13796576      0.77053868
 i,j,k,ie:    4    5    6          50
 Near X =  -1.1105391      0.73280945      0.23800512    , d:   0.0000000     -0.13796576      0.77053868
 i,j,k,ie:    5    5    6          50
 Near X =  -1.1105391      0.73280945      0.27669227    , d:   0.0000000     -0.13796576      0.77053868
 i,j,k,ie:    6    5    6          50
 Near X =  -1.1105391      0.73280945      0.29563535    , d:  0.51499762     -0.13796576      0.77053868
 i,j,k,ie:    1    6    6          50
 Near X =  -1.1685381      0.67480674      0.13437970    , d:   2.6685381     -0.33146189      0.77053868
 i,j,k,ie:    2    6    6          50
 Near X =  -1.1685381      0.67480674      0.15332278    , d:   2.6685381     -0.12925528      0.77053868
 i,j,k,ie:    3    6    6          50
 Near X =  -1.1685381      0.67480674      0.19200993    , d:   2.6685381     -0.12925528      0.77053868
 i,j,k,ie:    4    6    6          50
 Near X =  -1.1685381      0.67480674      0.23800512    , d:   2.6685381     -0.12925528      0.77053868
 i,j,k,ie:    5    6    6          50
 Near X =  -1.1685381      0.67480674      0.27669227    , d:   2.6685381     -0.12925528      0.77053868
 i,j,k,ie:    6    6    6          50
 Near X =  -1.1685381      0.67480674      0.29563535    , d:   2.6685381     -0.12925528      0.77053868
 i,j,k,ie:    1    1    1          51
 Near X =  0.59034952E-07   1.5000000      0.13437970    , d:   0.0000000     -0.75184442       1.3300624
 i,j,k,ie:    2    1    1          51
 Near X =  0.59034952E-07   1.5000000      0.15332278    , d:   0.0000000     -0.56262949       1.3300624
 i,j,k,ie:    3    1    1          51
 Near X =  0.59034952E-07   1.5000000      0.19200993    , d:   0.0000000     -0.56262949       1.3300624
 i,j,k,ie:    4    1    1          51
 Near X =  0.59034952E-07   1.5000000      0.23800512    , d:   0.0000000     -0.56262949       1.3300624
 i,j,k,ie:    5    1    1          51
 Near X =  0.59034952E-07   1.5000000      0.27669227    , d:   0.0000000     -0.56262949       1.3300624
 i,j,k,ie:    6    1    1          51
 Near X =  0.59034952E-07   1.5000000      0.29563535    , d:  0.75195051     -0.56262949       1.3300624
 i,j,k,ie:    1    2    1          51
 Near X = -0.93857316E-01   1.4968561      0.13437970    , d:  0.14585455E-01 -0.73696634       1.3300624
 i,j,k,ie:    2    2    1          51
 Near X = -0.93857316E-01   1.4968561      0.15332278    , d:  0.14585455E-01   0.0000000       1.3300624
 i,j,k,ie:    3    2    1          51
 Near X = -0.93857316E-01   1.4968561      0.19200993    , d:  0.14585455E-01   0.0000000       1.3300624
 i,j,k,ie:    4    2    1          51
 Near X = -0.93857316E-01   1.4968561      0.23800512    , d:  0.14585455E-01   0.0000000       1.3300624
 i,j,k,ie:    5    2    1          51
 Near X = -0.93857316E-01   1.4968561      0.27669227    , d:  0.14585455E-01   0.0000000       1.3300624
 i,j,k,ie:    6    2    1          51
 Near X = -0.93857316E-01   1.4968561      0.29563535    , d:  0.76301334       0.0000000       1.3300624
 i,j,k,ie:    1    3    1          51
 Near X = -0.28096192       1.4733960      0.13437970    , d:  0.39794277E-01 -0.69888227       1.3300624
 i,j,k,ie:    2    3    1          51
 Near X = -0.28096192       1.4733960      0.15332278    , d:  0.39794277E-01   0.0000000       1.3300624
 i,j,k,ie:    3    3    1          51
 Near X = -0.28096192       1.4733960      0.19200993    , d:  0.39794277E-01   0.0000000       1.3300624
 i,j,k,ie:    4    3    1          51
 Near X = -0.28096192       1.4733960      0.23800512    , d:  0.39794277E-01   0.0000000       1.3300624
 i,j,k,ie:    5    3    1          51
 Near X = -0.28096192       1.4733960      0.27669227    , d:  0.39794277E-01   0.0000000       1.3300624
 i,j,k,ie:    6    3    1          51
 Near X = -0.28096192       1.4733960      0.29563535    , d:  0.77644714       0.0000000       1.3300624
 i,j,k,ie:    1    4    1          51
 Near X = -0.49541164       1.4157369      0.13437970    , d:  0.61765935E-01 -0.64015442       1.3300624
 i,j,k,ie:    2    4    1          51
 Near X = -0.49541164       1.4157369      0.15332278    , d:  0.61765935E-01   0.0000000       1.3300624
 i,j,k,ie:    3    4    1          51
 Near X = -0.49541164       1.4157369      0.19200993    , d:  0.61765935E-01   0.0000000       1.3300624
 i,j,k,ie:    4    4    1          51
 Near X = -0.49541164       1.4157369      0.23800512    , d:  0.61765935E-01   0.0000000       1.3300624
 i,j,k,ie:    5    4    1          51
 Near X = -0.49541164       1.4157369      0.27669227    , d:  0.61765935E-01   0.0000000       1.3300624
 i,j,k,ie:    6    4    1          51
 Near X = -0.49541164       1.4157369      0.29563535    , d:  0.77641688       0.0000000       1.3300624
 i,j,k,ie:    1    5    1          51
 Near X = -0.66905989       1.3422015      0.13437970    , d:  0.73518403E-01 -0.57944498       1.3300624
 i,j,k,ie:    2    5    1          51
 Near X = -0.66905989       1.3422015      0.15332278    , d:  0.73518403E-01   0.0000000       1.3300624
 i,j,k,ie:    3    5    1          51
 Near X = -0.66905989       1.3422015      0.19200993    , d:  0.73518403E-01   0.0000000       1.3300624
 i,j,k,ie:    4    5    1          51
 Near X = -0.66905989       1.3422015      0.23800512    , d:  0.73518403E-01   0.0000000       1.3300624
 i,j,k,ie:    5    5    1          51
 Near X = -0.66905989       1.3422015      0.27669227    , d:  0.73518403E-01   0.0000000       1.3300624
 i,j,k,ie:    6    5    1          51
 Near X = -0.66905989       1.3422015      0.29563535    , d:  0.76293217       0.0000000       1.3300624
 i,j,k,ie:    1    6    1          51
 Near X = -0.75184436       1.2978517      0.13437970    , d:   2.2518444     -0.54594903       1.3300624
 i,j,k,ie:    2    6    1          51
 Near X = -0.75184436       1.2978517      0.15332278    , d:   2.0496377       0.0000000       1.3300624
 i,j,k,ie:    3    6    1          51
 Near X = -0.75184436       1.2978517      0.19200993    , d:   2.0496377       0.0000000       1.3300624
 i,j,k,ie:    4    6    1          51
 Near X = -0.75184436       1.2978517      0.23800512    , d:   2.0496377       0.0000000       1.3300624
 i,j,k,ie:    5    6    1          51
 Near X = -0.75184436       1.2978517      0.27669227    , d:   2.0496377       0.0000000       1.3300624
 i,j,k,ie:    6    6    1          51
 Near X = -0.75184436       1.2978517      0.29563535    , d:   2.0496377       0.0000000       1.3300624
 i,j,k,ie:    1    1    2          51
 Near X =  0.58341455E-07   1.4823792      0.13437970    , d:   0.0000000     -0.74279541       1.3300624
 i,j,k,ie:    2    1    2          51
 Near X =  0.58341455E-07   1.4823792      0.15332278    , d:   0.0000000     -0.54735437       1.3300624
 i,j,k,ie:    3    1    2          51
 Near X =  0.58341455E-07   1.4823792      0.19200993    , d:   0.0000000     -0.54735437       1.3300624
 i,j,k,ie:    4    1    2          51
 Near X =  0.58341455E-07   1.4823792      0.23800512    , d:   0.0000000     -0.54735437       1.3300624
 i,j,k,ie:    5    1    2          51
 Near X =  0.58341455E-07   1.4823792      0.27669227    , d:   0.0000000     -0.54735437       1.3300624
 i,j,k,ie:    6    1    2          51
 Near X =  0.58341455E-07   1.4823792      0.29563535    , d:  0.74288825     -0.54735437       1.3300624
 i,j,k,ie:    1    2    2          51
 Near X = -0.92143928E-01   1.4771008      0.13437970    , d:   0.0000000     -0.72716612       1.3300624
 i,j,k,ie:    6    2    2          51
 Near X = -0.92143928E-01   1.4771008      0.29563535    , d:  0.75265160       0.0000000       1.3300624
 i,j,k,ie:    1    3    2          51
 Near X = -0.27628719       1.4512832      0.13437970    , d:   0.0000000     -0.68845225       1.3300624
 i,j,k,ie:    6    3    2          51
 Near X = -0.27628719       1.4512832      0.29563535    , d:  0.76450749       0.0000000       1.3300624
 i,j,k,ie:    1    4    2          51
 Near X = -0.48815585       1.3943181      0.13437970    , d:   0.0000000     -0.63055559       1.3300624
 i,j,k,ie:    6    4    2          51
 Near X = -0.48815585       1.3943181      0.29563535    , d:  0.76448101       0.0000000       1.3300624
 i,j,k,ie:    1    5    2          51
 Near X = -0.66042351       1.3243076      0.13437970    , d:   0.0000000     -0.57187420       1.3300624
 i,j,k,ie:    6    5    2          51
 Near X = -0.66042351       1.3243076      0.29563535    , d:  0.75258057       0.0000000       1.3300624
 i,j,k,ie:    1    6    2          51
 Near X = -0.74279535       1.2826639      0.13437970    , d:   2.2251745     -0.53981412       1.3300624
 i,j,k,ie:    2    6    2          51
 Near X = -0.74279535       1.2826639      0.15332278    , d:   2.0254048       0.0000000       1.3300624
 i,j,k,ie:    3    6    2          51
 Near X = -0.74279535       1.2826639      0.19200993    , d:   2.0254048       0.0000000       1.3300624
 i,j,k,ie:    4    6    2          51
 Near X = -0.74279535       1.2826639      0.23800512    , d:   2.0254048       0.0000000       1.3300624
 i,j,k,ie:    5    6    2          51
 Near X = -0.74279535       1.2826639      0.27669227    , d:   2.0254048       0.0000000       1.3300624
 i,j,k,ie:    6    6    2          51
 Near X = -0.74279535       1.2826639      0.29563535    , d:   2.0254048       0.0000000       1.3300624
 i,j,k,ie:    1    1    3          51
 Near X =  0.56925137E-07   1.4463924      0.13437970    , d:   0.0000000     -0.72431477       1.3300624
 i,j,k,ie:    2    1    3          51
 Near X =  0.56925137E-07   1.4463924      0.15332278    , d:   0.0000000     -0.51615823       1.3300624
 i,j,k,ie:    3    1    3          51
 Near X =  0.56925137E-07   1.4463924      0.19200993    , d:   0.0000000     -0.51615823       1.3300624
 i,j,k,ie:    4    1    3          51
 Near X =  0.56925137E-07   1.4463924      0.23800512    , d:   0.0000000     -0.51615823       1.3300624
 i,j,k,ie:    5    1    3          51
 Near X =  0.56925137E-07   1.4463924      0.27669227    , d:   0.0000000     -0.51615823       1.3300624
 i,j,k,ie:    6    1    3          51
 Near X =  0.56925137E-07   1.4463924      0.29563535    , d:  0.72438054     -0.51615823       1.3300624
 i,j,k,ie:    1    2    3          51
 Near X = -0.88644704E-01   1.4367548      0.13437970    , d:   0.0000000     -0.70715127       1.3300624
 i,j,k,ie:    6    2    3          51
 Near X = -0.88644704E-01   1.4367548      0.29563535    , d:  0.73148997       0.0000000       1.3300624
 i,j,k,ie:    1    3    3          51
 Near X = -0.26674007       1.4061225      0.13437970    , d:   0.0000000     -0.66715117       1.3300624
 i,j,k,ie:    6    3    3          51
 Near X = -0.26674007       1.4061225      0.29563535    , d:  0.74012332       0.0000000       1.3300624
 i,j,k,ie:    1    4    3          51
 Near X = -0.47333747       1.3505747      0.13437970    , d:   0.0000000     -0.61095204       1.3300624
 i,j,k,ie:    6    4    3          51
 Near X = -0.47333747       1.3505747      0.29563535    , d:  0.74010456       0.0000000       1.3300624
 i,j,k,ie:    1    5    3          51
 Near X = -0.64278557       1.2877631      0.13437970    , d:   0.0000000     -0.55641251       1.3300624
 i,j,k,ie:    6    5    3          51
 Near X = -0.64278557       1.2877631      0.29563535    , d:  0.73143965       0.0000000       1.3300624
 i,j,k,ie:    1    6    3          51
 Near X = -0.72431471       1.2516460      0.13437970    , d:   2.1707071     -0.52728488       1.3300624
 i,j,k,ie:    2    6    3          51
 Near X = -0.72431471       1.2516460      0.15332278    , d:   1.9759142       0.0000000       1.3300624
 i,j,k,ie:    3    6    3          51
 Near X = -0.72431471       1.2516460      0.19200993    , d:   1.9759142       0.0000000       1.3300624
 i,j,k,ie:    4    6    3          51
 Near X = -0.72431471       1.2516460      0.23800512    , d:   1.9759142       0.0000000       1.3300624
 i,j,k,ie:    5    6    3          51
 Near X = -0.72431471       1.2516460      0.27669227    , d:   1.9759142       0.0000000       1.3300624
 i,j,k,ie:    6    6    3          51
 Near X = -0.72431471       1.2516460      0.29563535    , d:   1.9759142       0.0000000       1.3300624
 i,j,k,ie:    1    1    4          51
 Near X =  0.55241275E-07   1.4036077      0.13437970    , d:   0.0000000     -0.70234311       1.3300624
 i,j,k,ie:    2    1    4          51
 Near X =  0.55241275E-07   1.4036077      0.15332278    , d:   0.0000000     -0.47906911       1.3300624
 i,j,k,ie:    3    1    4          51
 Near X =  0.55241275E-07   1.4036077      0.19200993    , d:   0.0000000     -0.47906911       1.3300624
 i,j,k,ie:    4    1    4          51
 Near X =  0.55241275E-07   1.4036077      0.23800512    , d:   0.0000000     -0.47906911       1.3300624
 i,j,k,ie:    5    1    4          51
 Near X =  0.55241275E-07   1.4036077      0.27669227    , d:   0.0000000     -0.47906911       1.3300624
 i,j,k,ie:    6    1    4          51
 Near X =  0.55241275E-07   1.4036077      0.29563535    , d:  0.70237671     -0.47906911       1.3300624
 i,j,k,ie:    1    2    4          51
 Near X = -0.84484473E-01   1.3887875      0.13437970    , d:   0.0000000     -0.68335560       1.3300624
 i,j,k,ie:    6    2    4          51
 Near X = -0.84484473E-01   1.3887875      0.29563535    , d:  0.70633089       0.0000000       1.3300624
 i,j,k,ie:    1    3    4          51
 Near X = -0.25538949       1.3524309      0.13437970    , d:   0.0000000     -0.64182629       1.3300624
 i,j,k,ie:    6    3    4          51
 Near X = -0.25538949       1.3524309      0.29563535    , d:  0.71113296       0.0000000       1.3300624
 i,j,k,ie:    1    4    4          51
 Near X = -0.45571988       1.2985681      0.13437970    , d:   0.0000000     -0.58764536       1.3300624
 i,j,k,ie:    6    4    4          51
 Near X = -0.45571988       1.2985681      0.29563535    , d:  0.71112338       0.0000000       1.3300624
 i,j,k,ie:    1    5    4          51
 Near X = -0.62181581       1.2443153      0.13437970    , d:   0.0000000     -0.53803009       1.3300624
 i,j,k,ie:    6    5    4          51
 Near X = -0.62181581       1.2443153      0.29563535    , d:  0.70630519       0.0000000       1.3300624
 i,j,k,ie:    1    6    4          51
 Near X = -0.70234305       1.2147688      0.13437970    , d:   2.1059507     -0.51238886       1.3300624
 i,j,k,ie:    2    6    4          51
 Near X = -0.70234305       1.2147688      0.15332278    , d:   1.9170749       0.0000000       1.3300624
 i,j,k,ie:    3    6    4          51
 Near X = -0.70234305       1.2147688      0.19200993    , d:   1.9170749       0.0000000       1.3300624
 i,j,k,ie:    4    6    4          51
 Near X = -0.70234305       1.2147688      0.23800512    , d:   1.9170749       0.0000000       1.3300624
 i,j,k,ie:    5    6    4          51
 Near X = -0.70234305       1.2147688      0.27669227    , d:   1.9170749       0.0000000       1.3300624
 i,j,k,ie:    6    6    4          51
 Near X = -0.70234305       1.2147688      0.29563535    , d:   1.9170749       0.0000000       1.3300624
 i,j,k,ie:    1    1    5          51
 Near X =  0.53824957E-07   1.3676209      0.13437970    , d:   0.0000000     -0.68386246       1.3300624
 i,j,k,ie:    2    1    5          51
 Near X =  0.53824957E-07   1.3676209      0.15332278    , d:   0.0000000     -0.44787297       1.3300624
 i,j,k,ie:    3    1    5          51
 Near X =  0.53824957E-07   1.3676209      0.19200993    , d:   0.0000000     -0.44787297       1.3300624
 i,j,k,ie:    4    1    5          51
 Near X =  0.53824957E-07   1.3676209      0.23800512    , d:   0.0000000     -0.44787297       1.3300624
 i,j,k,ie:    5    1    5          51
 Near X =  0.53824957E-07   1.3676209      0.27669227    , d:   0.0000000     -0.44787297       1.3300624
 i,j,k,ie:    6    1    5          51
 Near X =  0.53824957E-07   1.3676209      0.29563535    , d:  0.68386900     -0.44787297       1.3300624
 i,j,k,ie:    1    2    5          51
 Near X = -0.80985249E-01   1.3484415      0.13437970    , d:   0.0000000     -0.66334076       1.3300624
 i,j,k,ie:    6    2    5          51
 Near X = -0.80985249E-01   1.3484415      0.29563535    , d:  0.68516927       0.0000000       1.3300624
 i,j,k,ie:    1    3    5          51
 Near X = -0.24584237       1.3072702      0.13437970    , d:   0.0000000     -0.62052522       1.3300624
 i,j,k,ie:    6    3    5          51
 Near X = -0.24584237       1.3072702      0.29563535    , d:  0.68674879       0.0000000       1.3300624
 i,j,k,ie:    1    4    5          51
 Near X = -0.44090150       1.2548246      0.13437970    , d:   0.0000000     -0.56804181       1.3300624
 i,j,k,ie:    6    4    5          51
 Near X = -0.44090150       1.2548246      0.29563535    , d:  0.68674693       0.0000000       1.3300624
 i,j,k,ie:    1    5    5          51
 Near X = -0.60417787       1.2077708      0.13437970    , d:   0.0000000     -0.52256841       1.3300624
 i,j,k,ie:    6    5    5          51
 Near X = -0.60417787       1.2077708      0.29563535    , d:  0.68516427       0.0000000       1.3300624
 i,j,k,ie:    1    6    5          51
 Near X = -0.68386241       1.1837509      0.13437970    , d:   2.0514833     -0.49985962       1.3300624
 i,j,k,ie:    2    6    5          51
 Near X = -0.68386241       1.1837509      0.15332278    , d:   1.8675844       0.0000000       1.3300624
 i,j,k,ie:    3    6    5          51
 Near X = -0.68386241       1.1837509      0.19200993    , d:   1.8675844       0.0000000       1.3300624
 i,j,k,ie:    4    6    5          51
 Near X = -0.68386241       1.1837509      0.23800512    , d:   1.8675844       0.0000000       1.3300624
 i,j,k,ie:    5    6    5          51
 Near X = -0.68386241       1.1837509      0.27669227    , d:   1.8675844       0.0000000       1.3300624
 i,j,k,ie:    6    6    5          51
 Near X = -0.68386241       1.1837509      0.29563535    , d:   1.8675844       0.0000000       1.3300624
 i,j,k,ie:    1    1    6          51
 Near X =  0.53131460E-07   1.3500000      0.13437970    , d:  0.59034925E-08 -0.75184441       1.3300624
 i,j,k,ie:    2    1    6          51
 Near X =  0.53131460E-07   1.3500000      0.15332278    , d:  0.59034925E-08 -0.56262948       1.3300624
 i,j,k,ie:    3    1    6          51
 Near X =  0.53131460E-07   1.3500000      0.19200993    , d:  0.59034925E-08 -0.56262948       1.3300624
 i,j,k,ie:    4    1    6          51
 Near X =  0.53131460E-07   1.3500000      0.23800512    , d:  0.59034925E-08 -0.56262948       1.3300624
 i,j,k,ie:    5    1    6          51
 Near X =  0.53131460E-07   1.3500000      0.27669227    , d:  0.59034925E-08 -0.56262948       1.3300624
 i,j,k,ie:    6    1    6          51
 Near X =  0.53131460E-07   1.3500000      0.29563535    , d:  0.75195052     -0.56262948       1.3300624
 i,j,k,ie:    1    2    6          51
 Near X = -0.79271861E-01   1.3286862      0.13437970    , d:   0.0000000     -0.75155180       1.3300624
 i,j,k,ie:    2    2    6          51
 Near X = -0.79271861E-01   1.3286862      0.15332278    , d:   0.0000000     -0.14585455E-01   1.3300624
 i,j,k,ie:    3    2    6          51
 Near X = -0.79271861E-01   1.3286862      0.19200993    , d:   0.0000000     -0.14585455E-01   1.3300624
 i,j,k,ie:    4    2    6          51
 Near X = -0.79271861E-01   1.3286862      0.23800512    , d:   0.0000000     -0.14585455E-01   1.3300624
 i,j,k,ie:    5    2    6          51
 Near X = -0.79271861E-01   1.3286862      0.27669227    , d:   0.0000000     -0.14585455E-01   1.3300624
 i,j,k,ie:    6    2    6          51
 Near X = -0.79271861E-01   1.3286862      0.29563535    , d:  0.74842789     -0.14585455E-01   1.3300624
 i,j,k,ie:    1    3    6          51
 Near X = -0.24116764       1.2851573      0.13437970    , d:   0.0000000     -0.73867655       1.3300624
 i,j,k,ie:    2    3    6          51
 Near X = -0.24116764       1.2851573      0.15332278    , d:   0.0000000     -0.39794277E-01   1.3300624
 i,j,k,ie:    3    3    6          51
 Near X = -0.24116764       1.2851573      0.19200993    , d:   0.0000000     -0.39794277E-01   1.3300624
 i,j,k,ie:    4    3    6          51
 Near X = -0.24116764       1.2851573      0.23800512    , d:   0.0000000     -0.39794277E-01   1.3300624
 i,j,k,ie:    5    3    6          51
 Near X = -0.24116764       1.2851573      0.27669227    , d:   0.0000000     -0.39794277E-01   1.3300624
 i,j,k,ie:    6    3    6          51
 Near X = -0.24116764       1.2851573      0.29563535    , d:  0.73665287     -0.39794277E-01   1.3300624
 i,j,k,ie:    1    4    6          51
 Near X = -0.43364571       1.2334058      0.13437970    , d:   0.0000000     -0.70192036       1.3300624
 i,j,k,ie:    2    4    6          51
 Near X = -0.43364571       1.2334058      0.15332278    , d:   0.0000000     -0.61765935E-01   1.3300624
 i,j,k,ie:    3    4    6          51
 Near X = -0.43364571       1.2334058      0.19200993    , d:   0.0000000     -0.61765935E-01   1.3300624
 i,j,k,ie:    4    4    6          51
 Near X = -0.43364571       1.2334058      0.23800512    , d:   0.0000000     -0.61765935E-01   1.3300624
 i,j,k,ie:    5    4    6          51
 Near X = -0.43364571       1.2334058      0.27669227    , d:   0.0000000     -0.61765935E-01   1.3300624
 i,j,k,ie:    6    4    6          51
 Near X = -0.43364571       1.2334058      0.29563535    , d:  0.71465095     -0.61765935E-01   1.3300624
 i,j,k,ie:    1    5    6          51
 Near X = -0.59554149       1.1898769      0.13437970    , d:   0.0000000     -0.65296338       1.3300624
 i,j,k,ie:    2    5    6          51
 Near X = -0.59554149       1.1898769      0.15332278    , d:   0.0000000     -0.73518403E-01   1.3300624
 i,j,k,ie:    3    5    6          51
 Near X = -0.59554149       1.1898769      0.19200993    , d:   0.0000000     -0.73518403E-01   1.3300624
 i,j,k,ie:    4    5    6          51
 Near X = -0.59554149       1.1898769      0.23800512    , d:   0.0000000     -0.73518403E-01   1.3300624
 i,j,k,ie:    5    5    6          51
 Near X = -0.59554149       1.1898769      0.27669227    , d:   0.0000000     -0.73518403E-01   1.3300624
 i,j,k,ie:    6    5    6          51
 Near X = -0.59554149       1.1898769      0.29563535    , d:  0.68941377     -0.73518403E-01   1.3300624
 i,j,k,ie:    1    6    6          51
 Near X = -0.67481340       1.1685631      0.13437970    , d:   2.1748134     -0.62297999       1.3300624
 i,j,k,ie:    2    6    6          51
 Near X = -0.67481340       1.1685631      0.15332278    , d:   1.9726067     -0.77030957E-01   1.3300624
 i,j,k,ie:    3    6    6          51
 Near X = -0.67481340       1.1685631      0.19200993    , d:   1.9726067     -0.77030957E-01   1.3300624
 i,j,k,ie:    4    6    6          51
 Near X = -0.67481340       1.1685631      0.23800512    , d:   1.9726067     -0.77030957E-01   1.3300624
 i,j,k,ie:    5    6    6          51
 Near X = -0.67481340       1.1685631      0.27669227    , d:   1.9726067     -0.77030957E-01   1.3300624
 i,j,k,ie:    6    6    6          51
 Near X = -0.67481340       1.1685631      0.29563535    , d:   1.9726067     -0.77030957E-01   1.3300624
 i,j,k,ie:    1    1    1          52
 Near X =  0.75195057       1.2977934      0.13437970    , d:   0.0000000      -1.3145800       1.3298746
 i,j,k,ie:    2    1    1          52
 Near X =  0.75195057       1.2977934      0.15332278    , d:   0.0000000      -1.0768607       1.3298746
 i,j,k,ie:    3    1    1          52
 Near X =  0.75195057       1.2977934      0.19200993    , d:   0.0000000      -1.0768607       1.3298746
 i,j,k,ie:    4    1    1          52
 Near X =  0.75195057       1.2977934      0.23800512    , d:   0.0000000      -1.0768607       1.3298746
 i,j,k,ie:    5    1    1          52
 Near X =  0.75195057       1.2977934      0.27669227    , d:   0.0000000      -1.0768607       1.3298746
 i,j,k,ie:    6    1    1          52
 Near X =  0.75195057       1.2977934      0.29563535    , d:   0.0000000      -1.0768607       1.3298746
 i,j,k,ie:    1    2    1          52
 Near X =  0.66915603       1.3421555      0.13437970    , d:   0.0000000     -0.76301334       1.3298746
 i,j,k,ie:    2    2    1          52
 Near X =  0.66915603       1.3421555      0.15332278    , d:   0.0000000     -0.73620363E-01   1.3298746
 i,j,k,ie:    3    2    1          52
 Near X =  0.66915603       1.3421555      0.19200993    , d:   0.0000000     -0.73620363E-01   1.3298746
 i,j,k,ie:    4    2    1          52
 Near X =  0.66915603       1.3421555      0.23800512    , d:   0.0000000     -0.73620363E-01   1.3298746
 i,j,k,ie:    5    2    1          52
 Near X =  0.66915603       1.3421555      0.27669227    , d:   0.0000000     -0.73620363E-01   1.3298746
 i,j,k,ie:    6    2    1          52
 Near X =  0.66915603       1.3421555      0.29563535    , d:   0.0000000     -0.73620363E-01   1.3298746
 i,j,k,ie:    1    3    1          52
 Near X =  0.49548523       1.4157117      0.13437970    , d:   0.0000000     -0.77644714       1.3298746
 i,j,k,ie:    2    3    1          52
 Near X =  0.49548523       1.4157117      0.15332278    , d:   0.0000000     -0.61843731E-01   1.3298746
 i,j,k,ie:    3    3    1          52
 Near X =  0.49548523       1.4157117      0.19200993    , d:   0.0000000     -0.61843731E-01   1.3298746
 i,j,k,ie:    4    3    1          52
 Near X =  0.49548523       1.4157117      0.23800512    , d:   0.0000000     -0.61843731E-01   1.3298746
 i,j,k,ie:    5    3    1          52
 Near X =  0.49548523       1.4157117      0.27669227    , d:   0.0000000     -0.61843731E-01   1.3298746
 i,j,k,ie:    6    3    1          52
 Near X =  0.49548523       1.4157117      0.29563535    , d:   0.0000000     -0.61843731E-01   1.3298746
 i,j,k,ie:    1    4    1          52
 Near X =  0.28100524       1.4733874      0.13437970    , d:   0.0000000     -0.77641688       1.3298746
 i,j,k,ie:    2    4    1          52
 Near X =  0.28100524       1.4733874      0.15332278    , d:   0.0000000     -0.39839894E-01   1.3298746
 i,j,k,ie:    3    4    1          52
 Near X =  0.28100524       1.4733874      0.19200993    , d:   0.0000000     -0.39839894E-01   1.3298746
 i,j,k,ie:    4    4    1          52
 Near X =  0.28100524       1.4733874      0.23800512    , d:   0.0000000     -0.39839894E-01   1.3298746
 i,j,k,ie:    5    4    1          52
 Near X =  0.28100524       1.4733874      0.27669227    , d:   0.0000000     -0.39839894E-01   1.3298746
 i,j,k,ie:    6    4    1          52
 Near X =  0.28100524       1.4733874      0.29563535    , d:   0.0000000     -0.39839894E-01   1.3298746
 i,j,k,ie:    1    5    1          52
 Near X =  0.93872284E-01   1.4968548      0.13437970    , d:   0.0000000     -0.76293217       1.3298746
 i,j,k,ie:    2    5    1          52
 Near X =  0.93872284E-01   1.4968548      0.15332278    , d:   0.0000000     -0.14601106E-01   1.3298746
 i,j,k,ie:    3    5    1          52
 Near X =  0.93872284E-01   1.4968548      0.19200993    , d:   0.0000000     -0.14601106E-01   1.3298746
 i,j,k,ie:    4    5    1          52
 Near X =  0.93872284E-01   1.4968548      0.23800512    , d:   0.0000000     -0.14601106E-01   1.3298746
 i,j,k,ie:    5    5    1          52
 Near X =  0.93872284E-01   1.4968548      0.27669227    , d:   0.0000000     -0.14601106E-01   1.3298746
 i,j,k,ie:    6    5    1          52
 Near X =  0.93872284E-01   1.4968548      0.29563535    , d:   0.0000000     -0.14601106E-01   1.3298746
 i,j,k,ie:    1    6    1          52
 Near X =  0.59034952E-07   1.5000000      0.13437970    , d:   1.2977933     -0.75184442       1.3298746
 i,j,k,ie:    2    6    1          52
 Near X =  0.59034952E-07   1.5000000      0.15332278    , d:  0.75184419     -0.59034925E-08   1.3298746
 i,j,k,ie:    3    6    1          52
 Near X =  0.59034952E-07   1.5000000      0.19200993    , d:  0.75184419     -0.59034925E-08   1.3298746
 i,j,k,ie:    4    6    1          52
 Near X =  0.59034952E-07   1.5000000      0.23800512    , d:  0.75184419     -0.59034925E-08   1.3298746
 i,j,k,ie:    5    6    1          52
 Near X =  0.59034952E-07   1.5000000      0.27669227    , d:  0.75184419     -0.59034925E-08   1.3298746
 i,j,k,ie:    6    6    1          52
 Near X =  0.59034952E-07   1.5000000      0.29563535    , d:  0.75184419     -0.59034925E-08   1.3298746
 i,j,k,ie:    1    1    2          52
 Near X =  0.74288831       1.2826094      0.13437970    , d:   0.0000000      -1.2902426       1.3298746
 i,j,k,ie:    2    1    2          52
 Near X =  0.74288831       1.2826094      0.15332278    , d:   0.0000000      -1.0590708       1.3298746
 i,j,k,ie:    3    1    2          52
 Near X =  0.74288831       1.2826094      0.19200993    , d:   0.0000000      -1.0590708       1.3298746
 i,j,k,ie:    4    1    2          52
 Near X =  0.74288831       1.2826094      0.23800512    , d:   0.0000000      -1.0590708       1.3298746
 i,j,k,ie:    5    1    2          52
 Near X =  0.74288831       1.2826094      0.27669227    , d:   0.0000000      -1.0590708       1.3298746
 i,j,k,ie:    6    1    2          52
 Near X =  0.74288831       1.2826094      0.29563535    , d:   0.0000000      -1.0590708       1.3298746
 i,j,k,ie:    1    2    2          52
 Near X =  0.66050767       1.3242644      0.13437970    , d:   0.0000000     -0.75265160       1.3298746
 i,j,k,ie:    1    3    2          52
 Near X =  0.48822030       1.3942939      0.13437970    , d:   0.0000000     -0.76450749       1.3298746
 i,j,k,ie:    1    4    2          52
 Near X =  0.27632516       1.4512745      0.13437970    , d:   0.0000000     -0.76448101       1.3298746
 i,j,k,ie:    1    5    2          52
 Near X =  0.92157058E-01   1.4770993      0.13437970    , d:   0.0000000     -0.75258057       1.3298746
 i,j,k,ie:    1    6    2          52
 Near X =  0.58341455E-07   1.4823792      0.13437970    , d:   1.2826094     -0.74279541       1.3298746
 i,j,k,ie:    2    6    2          52
 Near X =  0.58341455E-07   1.4823792      0.15332278    , d:  0.74279518       0.0000000       1.3298746
 i,j,k,ie:    3    6    2          52
 Near X =  0.58341455E-07   1.4823792      0.19200993    , d:  0.74279518       0.0000000       1.3298746
 i,j,k,ie:    4    6    2          52
 Near X =  0.58341455E-07   1.4823792      0.23800512    , d:  0.74279518       0.0000000       1.3298746
 i,j,k,ie:    5    6    2          52
 Near X =  0.58341455E-07   1.4823792      0.27669227    , d:  0.74279518       0.0000000       1.3298746
 i,j,k,ie:    6    6    2          52
 Near X =  0.58341455E-07   1.4823792      0.29563535    , d:  0.74279518       0.0000000       1.3298746
 i,j,k,ie:    1    1    3          52
 Near X =  0.72438060       1.2515996      0.13437970    , d:   0.0000000      -1.2405388       1.3298746
 i,j,k,ie:    2    1    3          52
 Near X =  0.72438060       1.2515996      0.15332278    , d:   0.0000000      -1.0227388       1.3298746
 i,j,k,ie:    3    1    3          52
 Near X =  0.72438060       1.2515996      0.19200993    , d:   0.0000000      -1.0227388       1.3298746
 i,j,k,ie:    4    1    3          52
 Near X =  0.72438060       1.2515996      0.23800512    , d:   0.0000000      -1.0227388       1.3298746
 i,j,k,ie:    5    1    3          52
 Near X =  0.72438060       1.2515996      0.27669227    , d:   0.0000000      -1.0227388       1.3298746
 i,j,k,ie:    6    1    3          52
 Near X =  0.72438060       1.2515996      0.29563535    , d:   0.0000000      -1.0227388       1.3298746
 i,j,k,ie:    1    2    3          52
 Near X =  0.64284527       1.2877256      0.13437970    , d:   0.0000000     -0.73148997       1.3298746
 i,j,k,ie:    1    3    3          52
 Near X =  0.47338325       1.3505527      0.13437970    , d:   0.0000000     -0.74012332       1.3298746
 i,j,k,ie:    1    4    3          52
 Near X =  0.26676709       1.4061137      0.13437970    , d:   0.0000000     -0.74010456       1.3298746
 i,j,k,ie:    1    5    3          52
 Near X =  0.88654079E-01   1.4367529      0.13437970    , d:   0.0000000     -0.73143965       1.3298746
 i,j,k,ie:    1    6    3          52
 Near X =  0.56925137E-07   1.4463924      0.13437970    , d:   1.2515995     -0.72431477       1.3298746
 i,j,k,ie:    2    6    3          52
 Near X =  0.56925137E-07   1.4463924      0.15332278    , d:  0.72431454       0.0000000       1.3298746
 i,j,k,ie:    3    6    3          52
 Near X =  0.56925137E-07   1.4463924      0.19200993    , d:  0.72431454       0.0000000       1.3298746
 i,j,k,ie:    4    6    3          52
 Near X =  0.56925137E-07   1.4463924      0.23800512    , d:  0.72431454       0.0000000       1.3298746
 i,j,k,ie:    5    6    3          52
 Near X =  0.56925137E-07   1.4463924      0.27669227    , d:  0.72431454       0.0000000       1.3298746
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    6    6    3          52
 Near X =  0.56925137E-07   1.4463924      0.29563535    , d:  0.72431454       0.0000000       1.3298746
 i,j,k,ie:    1    1    4          52
 Near X =  0.70237676       1.2147319      0.13437970    , d:   0.0000000      -1.1814458       1.3298746
 i,j,k,ie:    2    1    4          52
 Near X =  0.70237676       1.2147319      0.15332278    , d:   0.0000000     -0.97954354       1.3298746
 i,j,k,ie:    3    1    4          52
 Near X =  0.70237676       1.2147319      0.19200993    , d:   0.0000000     -0.97954354       1.3298746
 i,j,k,ie:    4    1    4          52
 Near X =  0.70237676       1.2147319      0.23800512    , d:   0.0000000     -0.97954354       1.3298746
 i,j,k,ie:    5    1    4          52
 Near X =  0.70237676       1.2147319      0.27669227    , d:   0.0000000     -0.97954354       1.3298746
 i,j,k,ie:    6    1    4          52
 Near X =  0.70237676       1.2147319      0.29563535    , d:   0.0000000     -0.97954354       1.3298746
 i,j,k,ie:    1    2    4          52
 Near X =  0.62184642       1.2442847      0.13437970    , d:   0.0000000     -0.70633089       1.3298746
 i,j,k,ie:    1    3    4          52
 Near X =  0.45574347       1.2985487      0.13437970    , d:   0.0000000     -0.71113296       1.3298746
 i,j,k,ie:    1    4    4          52
 Near X =  0.25540350       1.3524220      0.13437970    , d:   0.0000000     -0.71112338       1.3298746
 i,j,k,ie:    1    5    4          52
 Near X =  0.84489383E-01   1.3887851      0.13437970    , d:   0.0000000     -0.70630519       1.3298746
 i,j,k,ie:    1    6    4          52
 Near X =  0.55241275E-07   1.4036077      0.13437970    , d:   1.2147318     -0.70234311       1.3298746
 i,j,k,ie:    2    6    4          52
 Near X =  0.55241275E-07   1.4036077      0.15332278    , d:  0.70234289       0.0000000       1.3298746
 i,j,k,ie:    3    6    4          52
 Near X =  0.55241275E-07   1.4036077      0.19200993    , d:  0.70234289       0.0000000       1.3298746
 i,j,k,ie:    4    6    4          52
 Near X =  0.55241275E-07   1.4036077      0.23800512    , d:  0.70234289       0.0000000       1.3298746
 i,j,k,ie:    5    6    4          52
 Near X =  0.55241275E-07   1.4036077      0.27669227    , d:  0.70234289       0.0000000       1.3298746
 i,j,k,ie:    6    6    4          52
 Near X =  0.55241275E-07   1.4036077      0.29563535    , d:  0.70234289       0.0000000       1.3298746
 i,j,k,ie:    1    1    5          52
 Near X =  0.68386905       1.1837220      0.13437970    , d:   0.0000000      -1.1317420       1.3298746
 i,j,k,ie:    2    1    5          52
 Near X =  0.68386905       1.1837220      0.15332278    , d:   0.0000000     -0.94321148       1.3298746
 i,j,k,ie:    3    1    5          52
 Near X =  0.68386905       1.1837220      0.19200993    , d:   0.0000000     -0.94321148       1.3298746
 i,j,k,ie:    4    1    5          52
 Near X =  0.68386905       1.1837220      0.23800512    , d:   0.0000000     -0.94321148       1.3298746
 i,j,k,ie:    5    1    5          52
 Near X =  0.68386905       1.1837220      0.27669227    , d:   0.0000000     -0.94321148       1.3298746
 i,j,k,ie:    6    1    5          52
 Near X =  0.68386905       1.1837220      0.29563535    , d:   0.0000000     -0.94321148       1.3298746
 i,j,k,ie:    1    2    5          52
 Near X =  0.60418402       1.2077460      0.13437970    , d:   0.0000000     -0.68516927       1.3298746
 i,j,k,ie:    1    3    5          52
 Near X =  0.44090642       1.2548075      0.13437970    , d:   0.0000000     -0.68674879       1.3298746
 i,j,k,ie:    1    4    5          52
 Near X =  0.24584543       1.3072613      0.13437970    , d:   0.0000000     -0.68674693       1.3298746
 i,j,k,ie:    1    5    5          52
 Near X =  0.80986404E-01   1.3484388      0.13437970    , d:   0.0000000     -0.68516427       1.3298746
 i,j,k,ie:    1    6    5          52
 Near X =  0.53824957E-07   1.3676209      0.13437970    , d:   1.1837219     -0.68386246       1.3298746
 i,j,k,ie:    2    6    5          52
 Near X =  0.53824957E-07   1.3676209      0.15332278    , d:  0.68386225       0.0000000       1.3298746
 i,j,k,ie:    3    6    5          52
 Near X =  0.53824957E-07   1.3676209      0.19200993    , d:  0.68386225       0.0000000       1.3298746
 i,j,k,ie:    4    6    5          52
 Near X =  0.53824957E-07   1.3676209      0.23800512    , d:  0.68386225       0.0000000       1.3298746
 i,j,k,ie:    5    6    5          52
 Near X =  0.53824957E-07   1.3676209      0.27669227    , d:  0.68386225       0.0000000       1.3298746
 i,j,k,ie:    6    6    5          52
 Near X =  0.53824957E-07   1.3676209      0.29563535    , d:  0.68386225       0.0000000       1.3298746
 i,j,k,ie:    1    1    6          52
 Near X =  0.67480679       1.1685381      0.13437970    , d:  0.77143782E-01  -1.2374362       1.3298746
 i,j,k,ie:    2    1    6          52
 Near X =  0.67480679       1.1685381      0.15332278    , d:  0.77143782E-01 -0.99971693       1.3298746
 i,j,k,ie:    3    1    6          52
 Near X =  0.67480679       1.1685381      0.19200993    , d:  0.77143782E-01 -0.99971693       1.3298746
 i,j,k,ie:    4    1    6          52
 Near X =  0.67480679       1.1685381      0.23800512    , d:  0.77143782E-01 -0.99971693       1.3298746
 i,j,k,ie:    5    1    6          52
 Near X =  0.67480679       1.1685381      0.27669227    , d:  0.77143782E-01 -0.99971693       1.3298746
 i,j,k,ie:    6    1    6          52
 Near X =  0.67480679       1.1685381      0.29563535    , d:  0.77143782E-01 -0.99971693       1.3298746
 i,j,k,ie:    1    2    6          52
 Near X =  0.59553566       1.1898548      0.13437970    , d:  0.73620363E-01 -0.68939298       1.3298746
 i,j,k,ie:    2    2    6          52
 Near X =  0.59553566       1.1898548      0.15332278    , d:  0.73620363E-01   0.0000000       1.3298746
 i,j,k,ie:    3    2    6          52
 Near X =  0.59553566       1.1898548      0.19200993    , d:  0.73620363E-01   0.0000000       1.3298746
 i,j,k,ie:    4    2    6          52
 Near X =  0.59553566       1.1898548      0.23800512    , d:  0.73620363E-01   0.0000000       1.3298746
 i,j,k,ie:    5    2    6          52
 Near X =  0.59553566       1.1898548      0.27669227    , d:  0.73620363E-01   0.0000000       1.3298746
 i,j,k,ie:    6    2    6          52
 Near X =  0.59553566       1.1898548      0.29563535    , d:  0.73620363E-01   0.0000000       1.3298746
 i,j,k,ie:    1    3    6          52
 Near X =  0.43364150       1.2333897      0.13437970    , d:  0.61843731E-01 -0.71460341       1.3298746
 i,j,k,ie:    2    3    6          52
 Near X =  0.43364150       1.2333897      0.15332278    , d:  0.61843731E-01   0.0000000       1.3298746
 i,j,k,ie:    3    3    6          52
 Near X =  0.43364150       1.2333897      0.19200993    , d:  0.61843731E-01   0.0000000       1.3298746
 i,j,k,ie:    4    3    6          52
 Near X =  0.43364150       1.2333897      0.23800512    , d:  0.61843731E-01   0.0000000       1.3298746
 i,j,k,ie:    5    3    6          52
 Near X =  0.43364150       1.2333897      0.27669227    , d:  0.61843731E-01   0.0000000       1.3298746
 i,j,k,ie:    6    3    6          52
 Near X =  0.43364150       1.2333897      0.29563535    , d:  0.61843731E-01   0.0000000       1.3298746
 i,j,k,ie:    1    4    6          52
 Near X =  0.24116535       1.2851484      0.13437970    , d:  0.39839894E-01 -0.73657699       1.3298746
 i,j,k,ie:    2    4    6          52
 Near X =  0.24116535       1.2851484      0.15332278    , d:  0.39839894E-01   0.0000000       1.3298746
 i,j,k,ie:    3    4    6          52
 Near X =  0.24116535       1.2851484      0.19200993    , d:  0.39839894E-01   0.0000000       1.3298746
 i,j,k,ie:    4    4    6          52
 Near X =  0.24116535       1.2851484      0.23800512    , d:  0.39839894E-01   0.0000000       1.3298746
 i,j,k,ie:    5    4    6          52
 Near X =  0.24116535       1.2851484      0.27669227    , d:  0.39839894E-01   0.0000000       1.3298746
 i,j,k,ie:    6    4    6          52
 Near X =  0.24116535       1.2851484      0.29563535    , d:  0.39839894E-01   0.0000000       1.3298746
 i,j,k,ie:    1    5    6          52
 Near X =  0.79271178E-01   1.3286833      0.13437970    , d:  0.14601106E-01 -0.74833107       1.3298746
 i,j,k,ie:    2    5    6          52
 Near X =  0.79271178E-01   1.3286833      0.15332278    , d:  0.14601106E-01   0.0000000       1.3298746
 i,j,k,ie:    3    5    6          52
 Near X =  0.79271178E-01   1.3286833      0.19200993    , d:  0.14601106E-01   0.0000000       1.3298746
 i,j,k,ie:    4    5    6          52
 Near X =  0.79271178E-01   1.3286833      0.23800512    , d:  0.14601106E-01   0.0000000       1.3298746
 i,j,k,ie:    5    5    6          52
 Near X =  0.79271178E-01   1.3286833      0.27669227    , d:  0.14601106E-01   0.0000000       1.3298746
 i,j,k,ie:    6    5    6          52
 Near X =  0.79271178E-01   1.3286833      0.29563535    , d:  0.14601106E-01   0.0000000       1.3298746
 i,j,k,ie:    1    6    6          52
 Near X =  0.53131460E-07   1.3500000      0.13437970    , d:   1.2977933     -0.75184441       1.3298746
 i,j,k,ie:    2    6    6          52
 Near X =  0.53131460E-07   1.3500000      0.15332278    , d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    3    6    6          52
 Near X =  0.53131460E-07   1.3500000      0.19200993    , d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    4    6    6          52
 Near X =  0.53131460E-07   1.3500000      0.23800512    , d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    5    6    6          52
 Near X =  0.53131460E-07   1.3500000      0.27669227    , d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    6    6    6          52
 Near X =  0.53131460E-07   1.3500000      0.29563535    , d:  0.75184419       0.0000000       1.3298746
 i,j,k,ie:    1    1    1          53
 Near X =   1.2978518      0.75184431      0.13437970    , d:   0.0000000      -2.7978518      0.77050401
 i,j,k,ie:    2    1    1          53
 Near X =   1.2978518      0.75184431      0.15332278    , d:   0.0000000      -2.7978518      0.77050401
 i,j,k,ie:    3    1    1          53
 Near X =   1.2978518      0.75184431      0.19200993    , d:   0.0000000      -2.7978518      0.77050401
 i,j,k,ie:    4    1    1          53
 Near X =   1.2978518      0.75184431      0.23800512    , d:   0.0000000      -2.7978518      0.77050401
 i,j,k,ie:    5    1    1          53
 Near X =   1.2978518      0.75184431      0.27669227    , d:   0.0000000      -2.7978518      0.77050401
 i,j,k,ie:    6    1    1          53
 Near X =   1.2978518      0.75184431      0.29563535    , d:  0.20214822      -2.7978518      0.77050401
 i,j,k,ie:    1    2    1          53
 Near X =   1.2485701      0.83082361      0.13437970    , d:   0.0000000     -0.13800968      0.77050401
 i,j,k,ie:    2    2    1          53
 Near X =   1.2485701      0.83082361      0.15332278    , d:   0.0000000     -0.13800968      0.77050401
 i,j,k,ie:    3    2    1          53
 Near X =   1.2485701      0.83082361      0.19200993    , d:   0.0000000     -0.13800968      0.77050401
 i,j,k,ie:    4    2    1          53
 Near X =   1.2485701      0.83082361      0.23800512    , d:   0.0000000     -0.13800968      0.77050401
 i,j,k,ie:    5    2    1          53
 Near X =   1.2485701      0.83082361      0.27669227    , d:   0.0000000     -0.13800968      0.77050401
 i,j,k,ie:    6    2    1          53
 Near X =   1.2485701      0.83082361      0.29563535    , d:  0.24828601     -0.13800968      0.77050401
 i,j,k,ie:    1    3    1          53
 Near X =   1.1356442      0.97984415      0.13437970    , d:   0.0000000     -0.14354181      0.77050401
 i,j,k,ie:    2    3    1          53
 Near X =   1.1356442      0.97984415      0.15332278    , d:   0.0000000     -0.14354181      0.77050401
 i,j,k,ie:    3    3    1          53
 Near X =   1.1356442      0.97984415      0.19200993    , d:   0.0000000     -0.14354181      0.77050401
 i,j,k,ie:    4    3    1          53
 Near X =   1.1356442      0.97984415      0.23800512    , d:   0.0000000     -0.14354181      0.77050401
 i,j,k,ie:    5    3    1          53
 Near X =   1.1356442      0.97984415      0.27669227    , d:   0.0000000     -0.14354181      0.77050401
 i,j,k,ie:    6    3    1          53
 Near X =   1.1356442      0.97984415      0.29563535    , d:  0.33775182     -0.14354181      0.77050401
 i,j,k,ie:    1    4    1          53
 Near X =  0.97993595       1.1355660      0.13437970    , d:   0.0000000     -0.12866844      0.77050401
 i,j,k,ie:    2    4    1          53
 Near X =  0.97993595       1.1355660      0.15332278    , d:   0.0000000     -0.12866844      0.77050401
 i,j,k,ie:    3    4    1          53
 Near X =  0.97993595       1.1355660      0.19200993    , d:   0.0000000     -0.12866844      0.77050401
 i,j,k,ie:    4    4    1          53
 Near X =  0.97993595       1.1355660      0.23800512    , d:   0.0000000     -0.12866844      0.77050401
 i,j,k,ie:    5    4    1          53
 Near X =  0.97993595       1.1355660      0.27669227    , d:   0.0000000     -0.12866844      0.77050401
 i,j,k,ie:    6    4    1          53
 Near X =  0.97993595       1.1355660      0.29563535    , d:  0.43580100     -0.12866844      0.77050401
 i,j,k,ie:    1    5    1          53
 Near X =  0.83092544       1.2485048      0.13437970    , d:   0.0000000     -0.98115945E-01  0.77050401
 i,j,k,ie:    2    5    1          53
 Near X =  0.83092544       1.2485048      0.15332278    , d:   0.0000000     -0.98115945E-01  0.77050401
 i,j,k,ie:    3    5    1          53
 Near X =  0.83092544       1.2485048      0.19200993    , d:   0.0000000     -0.98115945E-01  0.77050401
 i,j,k,ie:    4    5    1          53
 Near X =  0.83092544       1.2485048      0.23800512    , d:   0.0000000     -0.98115945E-01  0.77050401
 i,j,k,ie:    5    5    1          53
 Near X =  0.83092544       1.2485048      0.27669227    , d:   0.0000000     -0.98115945E-01  0.77050401
 i,j,k,ie:    6    5    1          53
 Near X =  0.83092544       1.2485048      0.29563535    , d:  0.51127606     -0.98115945E-01  0.77050401
 i,j,k,ie:    1    6    1          53
 Near X =  0.75195057       1.2977934      0.13437970    , d:   0.0000000     -0.75195075      0.77050401
 i,j,k,ie:    2    6    1          53
 Near X =  0.75195057       1.2977934      0.15332278    , d:   0.0000000     -0.75195075      0.77050401
 i,j,k,ie:    3    6    1          53
 Near X =  0.75195057       1.2977934      0.19200993    , d:   0.0000000     -0.75195075      0.77050401
 i,j,k,ie:    4    6    1          53
 Near X =  0.75195057       1.2977934      0.23800512    , d:   0.0000000     -0.75195075      0.77050401
 i,j,k,ie:    5    6    1          53
 Near X =  0.75195057       1.2977934      0.27669227    , d:   0.0000000     -0.75195075      0.77050401
 i,j,k,ie:    6    6    1          53
 Near X =  0.75195057       1.2977934      0.29563535    , d:  0.54590121      -1.5039012      0.77050401
 i,j,k,ie:    1    1    2          53
 Near X =   1.2826639      0.74279531      0.13437970    , d:   0.0000000      -2.7650431      0.77050401
 i,j,k,ie:    2    1    2          53
 Near X =   1.2826639      0.74279531      0.15332278    , d:   0.0000000      -2.7650431      0.77050401
 i,j,k,ie:    3    1    2          53
 Near X =   1.2826639      0.74279531      0.19200993    , d:   0.0000000      -2.7650431      0.77050401
 i,j,k,ie:    4    1    2          53
 Near X =   1.2826639      0.74279531      0.23800512    , d:   0.0000000      -2.7650431      0.77050401
 i,j,k,ie:    5    1    2          53
 Near X =   1.2826639      0.74279531      0.27669227    , d:   0.0000000      -2.7650431      0.77050401
 i,j,k,ie:    6    1    2          53
 Near X =   1.2826639      0.74279531      0.29563535    , d:  0.19971522      -2.7650431      0.77050401
 i,j,k,ie:    6    2    2          53
 Near X =   1.2323577      0.81931000      0.29563535    , d:  0.24474302       0.0000000      0.77050401
 i,j,k,ie:    6    3    2          53
 Near X =   1.1187820      0.96473940      0.29563535    , d:  0.33250117       0.0000000      0.77050401
 i,j,k,ie:    6    4    2          53
 Near X =  0.96482097       1.1187114      0.29563535    , d:  0.42949712       0.0000000      0.77050401
 i,j,k,ie:    6    5    2          53
 Near X =  0.81939953       1.2322977      0.29563535    , d:  0.50490805       0.0000000      0.77050401
 i,j,k,ie:    1    6    2          53
 Near X =  0.74288831       1.2826094      0.13437970    , d:   0.0000000     -0.74288849      0.77050401
 i,j,k,ie:    2    6    2          53
 Near X =  0.74288831       1.2826094      0.15332278    , d:   0.0000000     -0.74288849      0.77050401
 i,j,k,ie:    3    6    2          53
 Near X =  0.74288831       1.2826094      0.19200993    , d:   0.0000000     -0.74288849      0.77050401
 i,j,k,ie:    4    6    2          53
 Near X =  0.74288831       1.2826094      0.23800512    , d:   0.0000000     -0.74288849      0.77050401
 i,j,k,ie:    5    6    2          53
 Near X =  0.74288831       1.2826094      0.27669227    , d:   0.0000000     -0.74288849      0.77050401
 i,j,k,ie:    6    6    2          53
 Near X =  0.74288831       1.2826094      0.29563535    , d:  0.53977562      -1.4857767      0.77050401
 i,j,k,ie:    1    1    3          53
 Near X =   1.2516460      0.72431467      0.13437970    , d:   0.0000000      -2.6980384      0.77050401
 i,j,k,ie:    2    1    3          53
 Near X =   1.2516460      0.72431467      0.15332278    , d:   0.0000000      -2.6980384      0.77050401
 i,j,k,ie:    3    1    3          53
 Near X =   1.2516460      0.72431467      0.19200993    , d:   0.0000000      -2.6980384      0.77050401
 i,j,k,ie:    4    1    3          53
 Near X =   1.2516460      0.72431467      0.23800512    , d:   0.0000000      -2.6980384      0.77050401
 i,j,k,ie:    5    1    3          53
 Near X =   1.2516460      0.72431467      0.27669227    , d:   0.0000000      -2.6980384      0.77050401
 i,j,k,ie:    6    1    3          53
 Near X =   1.2516460      0.72431467      0.29563535    , d:  0.19474633      -2.6980384      0.77050401
 i,j,k,ie:    6    2    3          53
 Near X =   1.1992476      0.79579594      0.29563535    , d:  0.23750723       0.0000000      0.77050401
 i,j,k,ie:    6    3    3          53
 Near X =   1.0843446      0.93389120      0.29563535    , d:  0.32177786       0.0000000      0.77050401
 i,j,k,ie:    6    4    3          53
 Near X =  0.93395188       1.0842895      0.29563535    , d:  0.41662279       0.0000000      0.77050401
 i,j,k,ie:    6    5    3          53
 Near X =  0.79586035       1.1991981      0.29563535    , d:  0.49190275       0.0000000      0.77050401
 i,j,k,ie:    1    6    3          53
 Near X =  0.72438060       1.2515996      0.13437970    , d:   0.0000000     -0.72438077      0.77050401
 i,j,k,ie:    2    6    3          53
 Near X =  0.72438060       1.2515996      0.15332278    , d:   0.0000000     -0.72438077      0.77050401
 i,j,k,ie:    3    6    3          53
 Near X =  0.72438060       1.2515996      0.19200993    , d:   0.0000000     -0.72438077      0.77050401
 i,j,k,ie:    4    6    3          53
 Near X =  0.72438060       1.2515996      0.23800512    , d:   0.0000000     -0.72438077      0.77050401
 i,j,k,ie:    5    6    3          53
 Near X =  0.72438060       1.2515996      0.27669227    , d:   0.0000000     -0.72438077      0.77050401
 i,j,k,ie:    6    6    3          53
 Near X =  0.72438060       1.2515996      0.29563535    , d:  0.52726544      -1.4487612      0.77050401
 i,j,k,ie:    1    1    4          53
 Near X =   1.2147688      0.70234302      0.13437970    , d:   0.0000000      -2.6183765      0.77050401
 i,j,k,ie:    2    1    4          53
 Near X =   1.2147688      0.70234302      0.15332278    , d:   0.0000000      -2.6183765      0.77050401
 i,j,k,ie:    3    1    4          53
 Near X =   1.2147688      0.70234302      0.19200993    , d:   0.0000000      -2.6183765      0.77050401
 i,j,k,ie:    4    1    4          53
 Near X =   1.2147688      0.70234302      0.23800512    , d:   0.0000000      -2.6183765      0.77050401
 i,j,k,ie:    5    1    4          53
 Near X =   1.2147688      0.70234302      0.27669227    , d:   0.0000000      -2.6183765      0.77050401
 i,j,k,ie:    6    1    4          53
 Near X =   1.2147688      0.70234302      0.29563535    , d:  0.18883882      -2.6183765      0.77050401
 i,j,k,ie:    6    2    4          53
 Near X =   1.1598829      0.76784004      0.29563535    , d:  0.22890459       0.0000000      0.77050401
 i,j,k,ie:    6    3    4          53
 Near X =   1.0434020      0.89721575      0.29563535    , d:  0.30902891       0.0000000      0.77050401
 i,j,k,ie:    6    4    4          53
 Near X =  0.89725159       1.0433652      0.29563535    , d:  0.40131649       0.0000000      0.77050401
 i,j,k,ie:    6    5    4          53
 Near X =  0.76787459       1.1598459      0.29563535    , d:  0.47644073       0.0000000      0.77050401
 i,j,k,ie:    1    6    4          53
 Near X =  0.70237676       1.2147319      0.13437970    , d:   0.0000000     -0.70237693      0.77050401
 i,j,k,ie:    2    6    4          53
 Near X =  0.70237676       1.2147319      0.15332278    , d:   0.0000000     -0.70237693      0.77050401
 i,j,k,ie:    3    6    4          53
 Near X =  0.70237676       1.2147319      0.19200993    , d:   0.0000000     -0.70237693      0.77050401
 i,j,k,ie:    4    6    4          53
 Near X =  0.70237676       1.2147319      0.23800512    , d:   0.0000000     -0.70237693      0.77050401
 i,j,k,ie:    5    6    4          53
 Near X =  0.70237676       1.2147319      0.27669227    , d:   0.0000000     -0.70237693      0.77050401
 i,j,k,ie:    6    6    4          53
 Near X =  0.70237676       1.2147319      0.29563535    , d:  0.51239207      -1.4047536      0.77050401
 i,j,k,ie:    1    1    5          53
 Near X =   1.1837509      0.68386238      0.13437970    , d:   0.0000000      -2.5513718      0.77050401
 i,j,k,ie:    2    1    5          53
 Near X =   1.1837509      0.68386238      0.15332278    , d:   0.0000000      -2.5513718      0.77050401
 i,j,k,ie:    3    1    5          53
 Near X =   1.1837509      0.68386238      0.19200993    , d:   0.0000000      -2.5513718      0.77050401
 i,j,k,ie:    4    1    5          53
 Near X =   1.1837509      0.68386238      0.23800512    , d:   0.0000000      -2.5513718      0.77050401
 i,j,k,ie:    5    1    5          53
 Near X =   1.1837509      0.68386238      0.27669227    , d:   0.0000000      -2.5513718      0.77050401
 i,j,k,ie:    6    1    5          53
 Near X =   1.1837509      0.68386238      0.29563535    , d:  0.18386993      -2.5513718      0.77050401
 i,j,k,ie:    6    2    5          53
 Near X =   1.1267727      0.74432598      0.29563535    , d:  0.22166880       0.0000000      0.77050401
 i,j,k,ie:    6    3    5          53
 Near X =   1.0089646      0.86636756      0.29563535    , d:  0.29830560       0.0000000      0.77050401
 i,j,k,ie:    6    4    5          53
 Near X =  0.86638250       1.0089433      0.29563535    , d:  0.38844217       0.0000000      0.77050401
 i,j,k,ie:    6    5    5          53
 Near X =  0.74433541       1.1267463      0.29563535    , d:  0.46343544       0.0000000      0.77050401
 i,j,k,ie:    1    6    5          53
 Near X =  0.68386905       1.1837220      0.13437970    , d:   0.0000000     -0.68386921      0.77050401
 i,j,k,ie:    2    6    5          53
 Near X =  0.68386905       1.1837220      0.15332278    , d:   0.0000000     -0.68386921      0.77050401
 i,j,k,ie:    3    6    5          53
 Near X =  0.68386905       1.1837220      0.19200993    , d:   0.0000000     -0.68386921      0.77050401
 i,j,k,ie:    4    6    5          53
 Near X =  0.68386905       1.1837220      0.23800512    , d:   0.0000000     -0.68386921      0.77050401
 i,j,k,ie:    5    6    5          53
 Near X =  0.68386905       1.1837220      0.27669227    , d:   0.0000000     -0.68386921      0.77050401
 i,j,k,ie:    6    6    5          53
 Near X =  0.68386905       1.1837220      0.29563535    , d:  0.49988189      -1.3677381      0.77050401
 i,j,k,ie:    1    1    6          53
 Near X =   1.1685631      0.67481338      0.13437970    , d:  0.12928868      -2.6685631      0.77050401
 i,j,k,ie:    2    1    6          53
 Near X =   1.1685631      0.67481338      0.15332278    , d:  0.12928868      -2.6685631      0.77050401
 i,j,k,ie:    3    1    6          53
 Near X =   1.1685631      0.67481338      0.19200993    , d:  0.12928868      -2.6685631      0.77050401
 i,j,k,ie:    4    1    6          53
 Near X =   1.1685631      0.67481338      0.23800512    , d:  0.12928868      -2.6685631      0.77050401
 i,j,k,ie:    5    1    6          53
 Near X =   1.1685631      0.67481338      0.27669227    , d:  0.12928868      -2.6685631      0.77050401
 i,j,k,ie:    6    1    6          53
 Near X =   1.1685631      0.67481338      0.29563535    , d:  0.33143690      -2.6685631      0.77050401
 i,j,k,ie:    1    2    6          53
 Near X =   1.1105604      0.73281237      0.13437970    , d:  0.13800968       0.0000000      0.77050401
 i,j,k,ie:    2    2    6          53
 Near X =   1.1105604      0.73281237      0.15332278    , d:  0.13800968       0.0000000      0.77050401
 i,j,k,ie:    3    2    6          53
 Near X =   1.1105604      0.73281237      0.19200993    , d:  0.13800968       0.0000000      0.77050401
 i,j,k,ie:    4    2    6          53
 Near X =   1.1105604      0.73281237      0.23800512    , d:  0.13800968       0.0000000      0.77050401
 i,j,k,ie:    5    2    6          53
 Near X =   1.1105604      0.73281237      0.27669227    , d:  0.13800968       0.0000000      0.77050401
 i,j,k,ie:    6    2    6          53
 Near X =   1.1105604      0.73281237      0.29563535    , d:  0.38629569       0.0000000      0.77050401
 i,j,k,ie:    1    3    6          53
 Near X =  0.99210237      0.85126281      0.13437970    , d:  0.14354181       0.0000000      0.77050401
 i,j,k,ie:    2    3    6          53
 Near X =  0.99210237      0.85126281      0.15332278    , d:  0.14354181       0.0000000      0.77050401
 i,j,k,ie:    3    3    6          53
 Near X =  0.99210237      0.85126281      0.19200993    , d:  0.14354181       0.0000000      0.77050401
 i,j,k,ie:    4    3    6          53
 Near X =  0.99210237      0.85126281      0.23800512    , d:  0.14354181       0.0000000      0.77050401
 i,j,k,ie:    5    3    6          53
 Near X =  0.99210237      0.85126281      0.27669227    , d:  0.14354181       0.0000000      0.77050401
 i,j,k,ie:    6    3    6          53
 Near X =  0.99210237      0.85126281      0.29563535    , d:  0.48129363       0.0000000      0.77050401
 i,j,k,ie:    1    4    6          53
 Near X =  0.85126751      0.99208866      0.13437970    , d:  0.12866844       0.0000000      0.77050401
 i,j,k,ie:    2    4    6          53
 Near X =  0.85126751      0.99208866      0.15332278    , d:  0.12866844       0.0000000      0.77050401
 i,j,k,ie:    3    4    6          53
 Near X =  0.85126751      0.99208866      0.19200993    , d:  0.12866844       0.0000000      0.77050401
 i,j,k,ie:    4    4    6          53
 Near X =  0.85126751      0.99208866      0.23800512    , d:  0.12866844       0.0000000      0.77050401
 i,j,k,ie:    5    4    6          53
 Near X =  0.85126751      0.99208866      0.27669227    , d:  0.12866844       0.0000000      0.77050401
 i,j,k,ie:    6    4    6          53
 Near X =  0.85126751      0.99208866      0.29563535    , d:  0.56446944       0.0000000      0.77050401
 i,j,k,ie:    1    5    6          53
 Near X =  0.73280950       1.1105391      0.13437970    , d:  0.98115945E-01   0.0000000      0.77050401
 i,j,k,ie:    2    5    6          53
 Near X =  0.73280950       1.1105391      0.15332278    , d:  0.98115945E-01   0.0000000      0.77050401
 i,j,k,ie:    3    5    6          53
 Near X =  0.73280950       1.1105391      0.19200993    , d:  0.98115945E-01   0.0000000      0.77050401
 i,j,k,ie:    4    5    6          53
 Near X =  0.73280950       1.1105391      0.23800512    , d:  0.98115945E-01   0.0000000      0.77050401
 i,j,k,ie:    5    5    6          53
 Near X =  0.73280950       1.1105391      0.27669227    , d:  0.98115945E-01   0.0000000      0.77050401
 i,j,k,ie:    6    5    6          53
 Near X =  0.73280950       1.1105391      0.29563535    , d:  0.60939201       0.0000000      0.77050401
 i,j,k,ie:    1    6    6          53
 Near X =  0.67480679       1.1685381      0.13437970    , d:  0.77143782E-01 -0.67480697      0.77050401
 i,j,k,ie:    2    6    6          53
 Near X =  0.67480679       1.1685381      0.15332278    , d:  0.77143782E-01 -0.67480697      0.77050401
 i,j,k,ie:    3    6    6          53
 Near X =  0.67480679       1.1685381      0.19200993    , d:  0.77143782E-01 -0.67480697      0.77050401
 i,j,k,ie:    4    6    6          53
 Near X =  0.67480679       1.1685381      0.23800512    , d:  0.77143782E-01 -0.67480697      0.77050401
 i,j,k,ie:    5    6    6          53
 Near X =  0.67480679       1.1685381      0.27669227    , d:  0.77143782E-01 -0.67480697      0.77050401
 i,j,k,ie:    6    6    6          53
 Near X =  0.67480679       1.1685381      0.29563535    , d:  0.62304499      -1.4267574      0.77050401
 i,j,k,ie:    1    1    1          54
 Near X =   1.5000000     -0.11808106E-06  0.13437970    , d:   0.0000000      -3.0000000      0.66666667
 i,j,k,ie:    2    1    1          54
 Near X =   1.5000000     -0.11808106E-06  0.15332278    , d:   0.0000000      -2.7977934      0.66666667
 i,j,k,ie:    3    1    1          54
 Near X =   1.5000000     -0.11808106E-06  0.19200993    , d:   0.0000000      -2.7977934      0.66666667
 i,j,k,ie:    4    1    1          54
 Near X =   1.5000000     -0.11808106E-06  0.23800512    , d:   0.0000000      -2.7977934      0.66666667
 i,j,k,ie:    5    1    1          54
 Near X =   1.5000000     -0.11808106E-06  0.27669227    , d:   0.0000000      -2.7977934      0.66666667
 i,j,k,ie:    6    1    1          54
 Near X =   1.5000000     -0.11808106E-06  0.29563535    , d:   0.0000000      -2.7977934      0.66666667
 i,j,k,ie:    1    2    1          54
 Near X =   1.4968561      0.93857256E-01  0.13437970    , d:   0.0000000     -0.38629569      0.66666667
 i,j,k,ie:    2    2    1          54
 Near X =   1.4968561      0.93857256E-01  0.15332278    , d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    3    2    1          54
 Near X =   1.4968561      0.93857256E-01  0.19200993    , d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    4    2    1          54
 Near X =   1.4968561      0.93857256E-01  0.23800512    , d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    5    2    1          54
 Near X =   1.4968561      0.93857256E-01  0.27669227    , d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    6    2    1          54
 Near X =   1.4968561      0.93857256E-01  0.29563535    , d:   0.0000000     -0.30700126      0.66666667
 i,j,k,ie:    1    3    1          54
 Near X =   1.4733960      0.28096186      0.13437970    , d:   0.0000000     -0.48129363      0.66666667
 i,j,k,ie:    2    3    1          54
 Near X =   1.4733960      0.28096186      0.15332278    , d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    3    3    1          54
 Near X =   1.4733960      0.28096186      0.19200993    , d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    4    3    1          54
 Near X =   1.4733960      0.28096186      0.23800512    , d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    5    3    1          54
 Near X =   1.4733960      0.28096186      0.27669227    , d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    6    3    1          54
 Near X =   1.4733960      0.28096186      0.29563535    , d:   0.0000000     -0.24000629      0.66666667
 i,j,k,ie:    1    4    1          54
 Near X =   1.4157370      0.49541159      0.13437970    , d:   0.0000000     -0.56446944      0.66666667
 i,j,k,ie:    2    4    1          54
 Near X =   1.4157370      0.49541159      0.15332278    , d:   0.0000000     -0.18233116      0.66666667
 i,j,k,ie:    3    4    1          54
 Near X =   1.4157370      0.49541159      0.19200993    , d:   0.0000000     -0.18233116      0.66666667
 i,j,k,ie:    4    4    1          54
 Near X =   1.4157370      0.49541159      0.23800512    , d:   0.0000000     -0.18233116      0.66666667
 i,j,k,ie:    5    4    1          54
 Near X =   1.4157370      0.49541159      0.27669227    , d:   0.0000000     -0.18233116      0.66666667
 i,j,k,ie:    6    4    1          54
 Near X =   1.4157370      0.49541159      0.29563535    , d:  0.57650427E-01 -0.18233116      0.66666667
 i,j,k,ie:    1    5    1          54
 Near X =   1.3422015      0.66905984      0.13437970    , d:   0.0000000     -0.60939201      0.66666667
 i,j,k,ie:    2    5    1          54
 Near X =   1.3422015      0.66905984      0.15332278    , d:   0.0000000     -0.15232459      0.66666667
 i,j,k,ie:    3    5    1          54
 Near X =   1.3422015      0.66905984      0.19200993    , d:   0.0000000     -0.15232459      0.66666667
 i,j,k,ie:    4    5    1          54
 Near X =   1.3422015      0.66905984      0.23800512    , d:   0.0000000     -0.15232459      0.66666667
 i,j,k,ie:    5    5    1          54
 Near X =   1.3422015      0.66905984      0.27669227    , d:   0.0000000     -0.15232459      0.66666667
 i,j,k,ie:    6    5    1          54
 Near X =   1.3422015      0.66905984      0.29563535    , d:  0.15465325     -0.15232459      0.66666667
 i,j,k,ie:    1    6    1          54
 Near X =   1.2978518      0.75184431      0.13437970    , d:   0.0000000      -2.0498024      0.66666667
 i,j,k,ie:    2    6    1          54
 Near X =   1.2978518      0.75184431      0.15332278    , d:   0.0000000      -2.0498024      0.66666667
 i,j,k,ie:    3    6    1          54
 Near X =   1.2978518      0.75184431      0.19200993    , d:   0.0000000      -2.0498024      0.66666667
 i,j,k,ie:    4    6    1          54
 Near X =   1.2978518      0.75184431      0.23800512    , d:   0.0000000      -2.0498024      0.66666667
 i,j,k,ie:    5    6    1          54
 Near X =   1.2978518      0.75184431      0.27669227    , d:   0.0000000      -2.0498024      0.66666667
 i,j,k,ie:    6    6    1          54
 Near X =   1.2978518      0.75184431      0.29563535    , d:  0.20214822      -2.5957035      0.66666667
 i,j,k,ie:    1    1    2          54
 Near X =   1.4823792     -0.11334424E-06  0.13437970    , d:   0.0000000      -2.9647583      0.66666667
 i,j,k,ie:    2    1    2          54
 Near X =   1.4823792     -0.11334424E-06  0.15332278    , d:   0.0000000      -2.7649886      0.66666667
 i,j,k,ie:    3    1    2          54
 Near X =   1.4823792     -0.11334424E-06  0.19200993    , d:   0.0000000      -2.7649886      0.66666667
 i,j,k,ie:    4    1    2          54
 Near X =   1.4823792     -0.11334424E-06  0.23800512    , d:   0.0000000      -2.7649886      0.66666667
 i,j,k,ie:    5    1    2          54
 Near X =   1.4823792     -0.11334424E-06  0.27669227    , d:   0.0000000      -2.7649886      0.66666667
 i,j,k,ie:    6    1    2          54
 Near X =   1.4823792     -0.11334424E-06  0.29563535    , d:   0.0000000      -2.7649886      0.66666667
 i,j,k,ie:    1    2    2          54
 Near X =   1.4771008      0.92143873E-01  0.13437970    , d:   0.0000000     -0.24474302      0.66666667
 i,j,k,ie:    6    2    2          54
 Near X =   1.4771008      0.92143873E-01  0.29563535    , d:   0.0000000     -0.15283642      0.66666667
 i,j,k,ie:    1    3    2          54
 Near X =   1.4512832      0.27628714      0.13437970    , d:   0.0000000     -0.33250117      0.66666667
 i,j,k,ie:    6    3    2          54
 Near X =   1.4512832      0.27628714      0.29563535    , d:   0.0000000     -0.56989280E-01  0.66666667
 i,j,k,ie:    1    4    2          54
 Near X =   1.3943181      0.48815580      0.13437970    , d:   0.0000000     -0.42949712      0.66666667
 i,j,k,ie:    6    4    2          54
 Near X =   1.3943181      0.48815580      0.29563535    , d:  0.56956418E-01   0.0000000      0.66666667
 i,j,k,ie:    1    5    2          54
 Near X =   1.3243076      0.66042346      0.13437970    , d:   0.0000000     -0.50490805      0.66666667
 i,j,k,ie:    6    5    2          54
 Near X =   1.3243076      0.66042346      0.29563535    , d:  0.15279167       0.0000000      0.66666667
 i,j,k,ie:    1    6    2          54
 Near X =   1.2826639      0.74279531      0.13437970    , d:   0.0000000      -2.0255523      0.66666667
 i,j,k,ie:    2    6    2          54
 Near X =   1.2826639      0.74279531      0.15332278    , d:   0.0000000      -2.0255523      0.66666667
 i,j,k,ie:    3    6    2          54
 Near X =   1.2826639      0.74279531      0.19200993    , d:   0.0000000      -2.0255523      0.66666667
 i,j,k,ie:    4    6    2          54
 Near X =   1.2826639      0.74279531      0.23800512    , d:   0.0000000      -2.0255523      0.66666667
 i,j,k,ie:    5    6    2          54
 Near X =   1.2826639      0.74279531      0.27669227    , d:   0.0000000      -2.0255523      0.66666667
 i,j,k,ie:    6    6    2          54
 Near X =   1.2826639      0.74279531      0.29563535    , d:  0.19971522      -2.5653278      0.66666667
 i,j,k,ie:    1    1    3          54
 Near X =   1.4463924     -0.10367029E-06  0.13437970    , d:   0.0000000      -2.8927847      0.66666667
 i,j,k,ie:    2    1    3          54
 Near X =   1.4463924     -0.10367029E-06  0.15332278    , d:   0.0000000      -2.6979920      0.66666667
 i,j,k,ie:    3    1    3          54
 Near X =   1.4463924     -0.10367029E-06  0.19200993    , d:   0.0000000      -2.6979920      0.66666667
 i,j,k,ie:    4    1    3          54
 Near X =   1.4463924     -0.10367029E-06  0.23800512    , d:   0.0000000      -2.6979920      0.66666667
 i,j,k,ie:    5    1    3          54
 Near X =   1.4463924     -0.10367029E-06  0.27669227    , d:   0.0000000      -2.6979920      0.66666667
 i,j,k,ie:    6    1    3          54
 Near X =   1.4463924     -0.10367029E-06  0.29563535    , d:   0.0000000      -2.6979920      0.66666667
 i,j,k,ie:    1    2    3          54
 Near X =   1.4367548      0.88644657E-01  0.13437970    , d:   0.0000000     -0.23750723      0.66666667
 i,j,k,ie:    6    2    3          54
 Near X =   1.4367548      0.88644657E-01  0.29563535    , d:   0.0000000     -0.14902920      0.66666667
 i,j,k,ie:    1    3    3          54
 Near X =   1.4061225      0.26674002      0.13437970    , d:   0.0000000     -0.32177786      0.66666667
 i,j,k,ie:    6    3    3          54
 Near X =   1.4061225      0.26674002      0.29563535    , d:   0.0000000     -0.55569791E-01  0.66666667
 i,j,k,ie:    1    4    3          54
 Near X =   1.3505747      0.47333743      0.13437970    , d:   0.0000000     -0.41662279      0.66666667
 i,j,k,ie:    6    4    3          54
 Near X =   1.3505747      0.47333743      0.29563535    , d:  0.55539056E-01   0.0000000      0.66666667
 i,j,k,ie:    1    5    3          54
 Near X =   1.2877631      0.64278553      0.13437970    , d:   0.0000000     -0.49190275      0.66666667
 i,j,k,ie:    6    5    3          54
 Near X =   1.2877631      0.64278553      0.29563535    , d:  0.14898981       0.0000000      0.66666667
 i,j,k,ie:    1    6    3          54
 Near X =   1.2516460      0.72431467      0.13437970    , d:   0.0000000      -1.9760267      0.66666667
 i,j,k,ie:    2    6    3          54
 Near X =   1.2516460      0.72431467      0.15332278    , d:   0.0000000      -1.9760267      0.66666667
 i,j,k,ie:    3    6    3          54
 Near X =   1.2516460      0.72431467      0.19200993    , d:   0.0000000      -1.9760267      0.66666667
 i,j,k,ie:    4    6    3          54
 Near X =   1.2516460      0.72431467      0.23800512    , d:   0.0000000      -1.9760267      0.66666667
 i,j,k,ie:    5    6    3          54
 Near X =   1.2516460      0.72431467      0.27669227    , d:   0.0000000      -1.9760267      0.66666667
 i,j,k,ie:    6    6    3          54
 Near X =   1.2516460      0.72431467      0.29563535    , d:  0.19474633      -2.5032921      0.66666667
 i,j,k,ie:    1    1    4          54
 Near X =   1.4036077     -0.92168933E-07  0.13437970    , d:   0.0000000      -2.8072153      0.66666667
 i,j,k,ie:    2    1    4          54
 Near X =   1.4036077     -0.92168933E-07  0.15332278    , d:   0.0000000      -2.6183396      0.66666667
 i,j,k,ie:    3    1    4          54
 Near X =   1.4036077     -0.92168933E-07  0.19200993    , d:   0.0000000      -2.6183396      0.66666667
 i,j,k,ie:    4    1    4          54
 Near X =   1.4036077     -0.92168933E-07  0.23800512    , d:   0.0000000      -2.6183396      0.66666667
 i,j,k,ie:    5    1    4          54
 Near X =   1.4036077     -0.92168933E-07  0.27669227    , d:   0.0000000      -2.6183396      0.66666667
 i,j,k,ie:    6    1    4          54
 Near X =   1.4036077     -0.92168933E-07  0.29563535    , d:   0.0000000      -2.6183396      0.66666667
 i,j,k,ie:    1    2    4          54
 Near X =   1.3887875      0.84484436E-01  0.13437970    , d:   0.0000000     -0.22890459      0.66666667
 i,j,k,ie:    6    2    4          54
 Near X =   1.3887875      0.84484436E-01  0.29563535    , d:   0.0000000     -0.14450280      0.66666667
 i,j,k,ie:    1    3    4          54
 Near X =   1.3524309      0.25538945      0.13437970    , d:   0.0000000     -0.30902891      0.66666667
 i,j,k,ie:    6    3    4          54
 Near X =   1.3524309      0.25538945      0.29563535    , d:   0.0000000     -0.53882159E-01  0.66666667
 i,j,k,ie:    1    4    4          54
 Near X =   1.2985681      0.45571984      0.13437970    , d:   0.0000000     -0.40131649      0.66666667
 i,j,k,ie:    6    4    4          54
 Near X =   1.2985681      0.45571984      0.29563535    , d:  0.53853952E-01   0.0000000      0.66666667
 i,j,k,ie:    1    5    4          54
 Near X =   1.2443153      0.62181577      0.13437970    , d:   0.0000000     -0.47644073      0.66666667
 i,j,k,ie:    6    5    4          54
 Near X =   1.2443153      0.62181577      0.29563535    , d:  0.14446978       0.0000000      0.66666667
 i,j,k,ie:    1    6    4          54
 Near X =   1.2147688      0.70234302      0.13437970    , d:   0.0000000      -1.9171456      0.66666667
 i,j,k,ie:    2    6    4          54
 Near X =   1.2147688      0.70234302      0.15332278    , d:   0.0000000      -1.9171456      0.66666667
 i,j,k,ie:    3    6    4          54
 Near X =   1.2147688      0.70234302      0.19200993    , d:   0.0000000      -1.9171456      0.66666667
 i,j,k,ie:    4    6    4          54
 Near X =   1.2147688      0.70234302      0.23800512    , d:   0.0000000      -1.9171456      0.66666667
 i,j,k,ie:    5    6    4          54
 Near X =   1.2147688      0.70234302      0.27669227    , d:   0.0000000      -1.9171456      0.66666667
 i,j,k,ie:    6    6    4          54
 Near X =   1.2147688      0.70234302      0.29563535    , d:  0.18883882      -2.4295376      0.66666667
 i,j,k,ie:    1    1    5          54
 Near X =   1.3676209     -0.82494990E-07  0.13437970    , d:   0.0000000      -2.7352417      0.66666667
 i,j,k,ie:    2    1    5          54
 Near X =   1.3676209     -0.82494990E-07  0.15332278    , d:   0.0000000      -2.5513429      0.66666667
 i,j,k,ie:    3    1    5          54
 Near X =   1.3676209     -0.82494990E-07  0.19200993    , d:   0.0000000      -2.5513429      0.66666667
 i,j,k,ie:    4    1    5          54
 Near X =   1.3676209     -0.82494990E-07  0.23800512    , d:   0.0000000      -2.5513429      0.66666667
 i,j,k,ie:    5    1    5          54
 Near X =   1.3676209     -0.82494990E-07  0.27669227    , d:   0.0000000      -2.5513429      0.66666667
 i,j,k,ie:    6    1    5          54
 Near X =   1.3676209     -0.82494990E-07  0.29563535    , d:   0.0000000      -2.5513429      0.66666667
 i,j,k,ie:    1    2    5          54
 Near X =   1.3484415      0.80985220E-01  0.13437970    , d:   0.0000000     -0.22166880      0.66666667
 i,j,k,ie:    6    2    5          54
 Near X =   1.3484415      0.80985220E-01  0.29563535    , d:   0.0000000     -0.14069558      0.66666667
 i,j,k,ie:    1    3    5          54
 Near X =   1.3072702      0.24584234      0.13437970    , d:   0.0000000     -0.29830560      0.66666667
 i,j,k,ie:    6    3    5          54
 Near X =   1.3072702      0.24584234      0.29563535    , d:   0.0000000     -0.52462670E-01  0.66666667
 i,j,k,ie:    1    4    5          54
 Near X =   1.2548247      0.44090147      0.13437970    , d:   0.0000000     -0.38844217      0.66666667
 i,j,k,ie:    6    4    5          54
 Near X =   1.2548247      0.44090147      0.29563535    , d:  0.52436589E-01   0.0000000      0.66666667
 i,j,k,ie:    1    5    5          54
 Near X =   1.2077708      0.60417784      0.13437970    , d:   0.0000000     -0.46343544      0.66666667
 i,j,k,ie:    6    5    5          54
 Near X =   1.2077708      0.60417784      0.29563535    , d:  0.14066792       0.0000000      0.66666667
 i,j,k,ie:    1    6    5          54
 Near X =   1.1837509      0.68386238      0.13437970    , d:   0.0000000      -1.8676200      0.66666667
 i,j,k,ie:    2    6    5          54
 Near X =   1.1837509      0.68386238      0.15332278    , d:   0.0000000      -1.8676200      0.66666667
 i,j,k,ie:    3    6    5          54
 Near X =   1.1837509      0.68386238      0.19200993    , d:   0.0000000      -1.8676200      0.66666667
 i,j,k,ie:    4    6    5          54
 Near X =   1.1837509      0.68386238      0.23800512    , d:   0.0000000      -1.8676200      0.66666667
 i,j,k,ie:    5    6    5          54
 Near X =   1.1837509      0.68386238      0.27669227    , d:   0.0000000      -1.8676200      0.66666667
 i,j,k,ie:    6    6    5          54
 Near X =   1.1837509      0.68386238      0.29563535    , d:  0.18386993      -2.3675019      0.66666667
 i,j,k,ie:    1    1    6          54
 Near X =   1.3500000     -0.77758166E-07  0.13437970    , d:  0.14999998      -2.8500000      0.66666667
 i,j,k,ie:    2    1    6          54
 Near X =   1.3500000     -0.77758166E-07  0.15332278    , d:  0.14999998      -2.6477934      0.66666667
 i,j,k,ie:    3    1    6          54
 Near X =   1.3500000     -0.77758166E-07  0.19200993    , d:  0.14999998      -2.6477934      0.66666667
 i,j,k,ie:    4    1    6          54
 Near X =   1.3500000     -0.77758166E-07  0.23800512    , d:  0.14999998      -2.6477934      0.66666667
 i,j,k,ie:    5    1    6          54
 Near X =   1.3500000     -0.77758166E-07  0.27669227    , d:  0.14999998      -2.6477934      0.66666667
 i,j,k,ie:    6    1    6          54
 Near X =   1.3500000     -0.77758166E-07  0.29563535    , d:  0.14999998      -2.6477934      0.66666667
 i,j,k,ie:    1    2    6          54
 Near X =   1.3286862      0.79271836E-01  0.13437970    , d:  0.16816987     -0.21812581      0.66666667
 i,j,k,ie:    2    2    6          54
 Near X =   1.3286862      0.79271836E-01  0.15332278    , d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    3    2    6          54
 Near X =   1.3286862      0.79271836E-01  0.19200993    , d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    4    2    6          54
 Near X =   1.3286862      0.79271836E-01  0.23800512    , d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    5    2    6          54
 Near X =   1.3286862      0.79271836E-01  0.27669227    , d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    6    2    6          54
 Near X =   1.3286862      0.79271836E-01  0.29563535    , d:  0.16816987     -0.13883138      0.66666667
 i,j,k,ie:    1    3    6          54
 Near X =   1.2851573      0.24116762      0.13437970    , d:  0.18823867     -0.29305495      0.66666667
 i,j,k,ie:    2    3    6          54
 Near X =   1.2851573      0.24116762      0.15332278    , d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    3    3    6          54
 Near X =   1.2851573      0.24116762      0.19200993    , d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    4    3    6          54
 Near X =   1.2851573      0.24116762      0.23800512    , d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    5    3    6          54
 Near X =   1.2851573      0.24116762      0.27669227    , d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    6    3    6          54
 Near X =   1.2851573      0.24116762      0.29563535    , d:  0.18823867     -0.51767620E-01  0.66666667
 i,j,k,ie:    1    4    6          54
 Near X =   1.2334058      0.43364568      0.13437970    , d:  0.18233116     -0.38213828      0.66666667
 i,j,k,ie:    2    4    6          54
 Near X =   1.2334058      0.43364568      0.15332278    , d:  0.18233116       0.0000000      0.66666667
 i,j,k,ie:    3    4    6          54
 Near X =   1.2334058      0.43364568      0.19200993    , d:  0.18233116       0.0000000      0.66666667
 i,j,k,ie:    4    4    6          54
 Near X =   1.2334058      0.43364568      0.23800512    , d:  0.18233116       0.0000000      0.66666667
 i,j,k,ie:    5    4    6          54
 Near X =   1.2334058      0.43364568      0.27669227    , d:  0.18233116       0.0000000      0.66666667
 i,j,k,ie:    6    4    6          54
 Near X =   1.2334058      0.43364568      0.29563535    , d:  0.23998159       0.0000000      0.66666667
 i,j,k,ie:    1    5    6          54
 Near X =   1.1898769      0.59554146      0.13437970    , d:  0.15232459     -0.45706742      0.66666667
 i,j,k,ie:    2    5    6          54
 Near X =   1.1898769      0.59554146      0.15332278    , d:  0.15232459       0.0000000      0.66666667
 i,j,k,ie:    3    5    6          54
 Near X =   1.1898769      0.59554146      0.19200993    , d:  0.15232459       0.0000000      0.66666667
 i,j,k,ie:    4    5    6          54
 Near X =   1.1898769      0.59554146      0.23800512    , d:  0.15232459       0.0000000      0.66666667
 i,j,k,ie:    5    5    6          54
 Near X =   1.1898769      0.59554146      0.27669227    , d:  0.15232459       0.0000000      0.66666667
 i,j,k,ie:    6    5    6          54
 Near X =   1.1898769      0.59554146      0.29563535    , d:  0.30697783       0.0000000      0.66666667
 i,j,k,ie:    1    6    6          54
 Near X =   1.1685631      0.67481338      0.13437970    , d:  0.12928868      -1.9205137      0.66666667
 i,j,k,ie:    2    6    6          54
 Near X =   1.1685631      0.67481338      0.15332278    , d:  0.12928868      -1.9205137      0.66666667
 i,j,k,ie:    3    6    6          54
 Near X =   1.1685631      0.67481338      0.19200993    , d:  0.12928868      -1.9205137      0.66666667
 i,j,k,ie:    4    6    6          54
 Near X =   1.1685631      0.67481338      0.23800512    , d:  0.12928868      -1.9205137      0.66666667
 i,j,k,ie:    5    6    6          54
 Near X =   1.1685631      0.67481338      0.27669227    , d:  0.12928868      -1.9205137      0.66666667
 i,j,k,ie:    6    6    6          54
 Near X =   1.1685631      0.67481338      0.29563535    , d:  0.33143690      -2.4664149      0.66666667
 i,j,k,ie:    1    1    1          55
 Near X =   1.2977933     -0.75195062      0.13437970    , d:  0.20220666      -2.5955867      0.66666667
 i,j,k,ie:    2    1    1          55
 Near X =   1.2977933     -0.75195062      0.15332278    , d:   0.0000000      -2.0496377      0.66666667
 i,j,k,ie:    3    1    1          55
 Near X =   1.2977933     -0.75195062      0.19200993    , d:   0.0000000      -2.0496377      0.66666667
 i,j,k,ie:    4    1    1          55
 Near X =   1.2977933     -0.75195062      0.23800512    , d:   0.0000000      -2.0496377      0.66666667
 i,j,k,ie:    5    1    1          55
 Near X =   1.2977933     -0.75195062      0.27669227    , d:   0.0000000      -2.0496377      0.66666667
 i,j,k,ie:    6    1    1          55
 Near X =   1.2977933     -0.75195062      0.29563535    , d:   0.0000000      -2.0496377      0.66666667
 i,j,k,ie:    1    2    1          55
 Near X =   1.3421555     -0.66915608      0.13437970    , d:  0.15470061     -0.15230065      0.66666667
 i,j,k,ie:    2    2    1          55
 Near X =   1.3421555     -0.66915608      0.15332278    , d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    3    2    1          55
 Near X =   1.3421555     -0.66915608      0.19200993    , d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    4    2    1          55
 Near X =   1.3421555     -0.66915608      0.23800512    , d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    5    2    1          55
 Near X =   1.3421555     -0.66915608      0.27669227    , d:   0.0000000     -0.15230065      0.66666667
 i,j,k,ie:    6    2    1          55
 Near X =   1.3421555     -0.66915608      0.29563535    , d:   0.0000000     -0.60934316      0.66666667
 i,j,k,ie:    1    3    1          55
 Near X =   1.4157117     -0.49548528      0.13437970    , d:  0.57684330E-01 -0.18232196      0.66666667
 i,j,k,ie:    2    3    1          55
 Near X =   1.4157117     -0.49548528      0.15332278    , d:   0.0000000     -0.18232196      0.66666667
 i,j,k,ie:    3    3    1          55
 Near X =   1.4157117     -0.49548528      0.19200993    , d:   0.0000000     -0.18232196      0.66666667
 i,j,k,ie:    4    3    1          55
 Near X =   1.4157117     -0.49548528      0.23800512    , d:   0.0000000     -0.18232196      0.66666667
 i,j,k,ie:    5    3    1          55
 Near X =   1.4157117     -0.49548528      0.27669227    , d:   0.0000000     -0.18232196      0.66666667
 i,j,k,ie:    6    3    1          55
 Near X =   1.4157117     -0.49548528      0.29563535    , d:   0.0000000     -0.56444892      0.66666667
 i,j,k,ie:    1    4    1          55
 Near X =   1.4733874     -0.28100530      0.13437970    , d:   0.0000000     -0.23998159      0.66666667
 i,j,k,ie:    2    4    1          55
 Near X =   1.4733874     -0.28100530      0.15332278    , d:   0.0000000     -0.18823900      0.66666667
 i,j,k,ie:    3    4    1          55
 Near X =   1.4733874     -0.28100530      0.19200993    , d:   0.0000000     -0.18823900      0.66666667
 i,j,k,ie:    4    4    1          55
 Near X =   1.4733874     -0.28100530      0.23800512    , d:   0.0000000     -0.18823900      0.66666667
 i,j,k,ie:    5    4    1          55
 Near X =   1.4733874     -0.28100530      0.27669227    , d:   0.0000000     -0.18823900      0.66666667
 i,j,k,ie:    6    4    1          55
 Near X =   1.4733874     -0.28100530      0.29563535    , d:   0.0000000     -0.48129877      0.66666667
 i,j,k,ie:    1    5    1          55
 Near X =   1.4968548     -0.93872343E-01  0.13437970    , d:   0.0000000     -0.30697783      0.66666667
 i,j,k,ie:    2    5    1          55
 Near X =   1.4968548     -0.93872343E-01  0.15332278    , d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    3    5    1          55
 Near X =   1.4968548     -0.93872343E-01  0.19200993    , d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    4    5    1          55
 Near X =   1.4968548     -0.93872343E-01  0.23800512    , d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    5    5    1          55
 Near X =   1.4968548     -0.93872343E-01  0.27669227    , d:   0.0000000     -0.16817149      0.66666667
 i,j,k,ie:    6    5    1          55
 Near X =   1.4968548     -0.93872343E-01  0.29563535    , d:   0.0000000     -0.38631569      0.66666667
 i,j,k,ie:    1    6    1          55
 Near X =   1.5000000     -0.11808106E-06  0.13437970    , d:   0.0000000      -2.7978518      0.66666667
 i,j,k,ie:    2    6    1          55
 Near X =   1.5000000     -0.11808106E-06  0.15332278    , d:   0.0000000      -2.7978518      0.66666667
 i,j,k,ie:    3    6    1          55
 Near X =   1.5000000     -0.11808106E-06  0.19200993    , d:   0.0000000      -2.7978518      0.66666667
 i,j,k,ie:    4    6    1          55
 Near X =   1.5000000     -0.11808106E-06  0.23800512    , d:   0.0000000      -2.7978518      0.66666667
 i,j,k,ie:    5    6    1          55
 Near X =   1.5000000     -0.11808106E-06  0.27669227    , d:   0.0000000      -2.7978518      0.66666667
 i,j,k,ie:    6    6    1          55
 Near X =   1.5000000     -0.11808106E-06  0.29563535    , d:   0.0000000      -3.0000000      0.66666667
 i,j,k,ie:    1    1    2          55
 Near X =   1.2826094     -0.74288836      0.13437970    , d:  0.19976973      -2.5652189      0.66666667
 i,j,k,ie:    2    1    2          55
 Near X =   1.2826094     -0.74288836      0.15332278    , d:   0.0000000      -2.0254048      0.66666667
 i,j,k,ie:    3    1    2          55
 Near X =   1.2826094     -0.74288836      0.19200993    , d:   0.0000000      -2.0254048      0.66666667
 i,j,k,ie:    4    1    2          55
 Near X =   1.2826094     -0.74288836      0.23800512    , d:   0.0000000      -2.0254048      0.66666667
 i,j,k,ie:    5    1    2          55
 Near X =   1.2826094     -0.74288836      0.27669227    , d:   0.0000000      -2.0254048      0.66666667
 i,j,k,ie:    6    1    2          55
 Near X =   1.2826094     -0.74288836      0.29563535    , d:   0.0000000      -2.0254048      0.66666667
 i,j,k,ie:    1    2    2          55
 Near X =   1.3242644     -0.66050772      0.13437970    , d:  0.15283642       0.0000000      0.66666667
 i,j,k,ie:    6    2    2          55
 Near X =   1.3242644     -0.66050772      0.29563535    , d:   0.0000000     -0.50495441      0.66666667
 i,j,k,ie:    1    3    2          55
 Near X =   1.3942939     -0.48822035      0.13437970    , d:  0.56989280E-01   0.0000000      0.66666667
 i,j,k,ie:    6    3    2          55
 Near X =   1.3942939     -0.48822035      0.29563535    , d:   0.0000000     -0.42955453      0.66666667
 i,j,k,ie:    1    4    2          55
 Near X =   1.4512745     -0.27632521      0.13437970    , d:   0.0000000     -0.56956418E-01  0.66666667
 i,j,k,ie:    6    4    2          55
 Near X =   1.4512745     -0.27632521      0.29563535    , d:   0.0000000     -0.33256314      0.66666667
 i,j,k,ie:    1    5    2          55
 Near X =   1.4770993     -0.92157113E-01  0.13437970    , d:   0.0000000     -0.15279167      0.66666667
 i,j,k,ie:    6    5    2          55
 Near X =   1.4770993     -0.92157113E-01  0.29563535    , d:   0.0000000     -0.24480160      0.66666667
 i,j,k,ie:    1    6    2          55
 Near X =   1.4823792     -0.11334424E-06  0.13437970    , d:   0.0000000      -2.7650431      0.66666667
 i,j,k,ie:    2    6    2          55
 Near X =   1.4823792     -0.11334424E-06  0.15332278    , d:   0.0000000      -2.7650431      0.66666667
 i,j,k,ie:    3    6    2          55
 Near X =   1.4823792     -0.11334424E-06  0.19200993    , d:   0.0000000      -2.7650431      0.66666667
 i,j,k,ie:    4    6    2          55
 Near X =   1.4823792     -0.11334424E-06  0.23800512    , d:   0.0000000      -2.7650431      0.66666667
 i,j,k,ie:    5    6    2          55
 Near X =   1.4823792     -0.11334424E-06  0.27669227    , d:   0.0000000      -2.7650431      0.66666667
 i,j,k,ie:    6    6    2          55
 Near X =   1.4823792     -0.11334424E-06  0.29563535    , d:   0.0000000      -2.9647583      0.66666667
 i,j,k,ie:    1    1    3          55
 Near X =   1.2515995     -0.72438064      0.13437970    , d:  0.19479283      -2.5031991      0.66666667
 i,j,k,ie:    2    1    3          55
 Near X =   1.2515995     -0.72438064      0.15332278    , d:   0.0000000      -1.9759142      0.66666667
 i,j,k,ie:    3    1    3          55
 Near X =   1.2515995     -0.72438064      0.19200993    , d:   0.0000000      -1.9759142      0.66666667
 i,j,k,ie:    4    1    3          55
 Near X =   1.2515995     -0.72438064      0.23800512    , d:   0.0000000      -1.9759142      0.66666667
 i,j,k,ie:    5    1    3          55
 Near X =   1.2515995     -0.72438064      0.27669227    , d:   0.0000000      -1.9759142      0.66666667
 i,j,k,ie:    6    1    3          55
 Near X =   1.2515995     -0.72438064      0.29563535    , d:   0.0000000      -1.9759142      0.66666667
 i,j,k,ie:    1    2    3          55
 Near X =   1.2877256     -0.64284531      0.13437970    , d:  0.14902920       0.0000000      0.66666667
 i,j,k,ie:    6    2    3          55
 Near X =   1.2877256     -0.64284531      0.29563535    , d:   0.0000000     -0.49192974      0.66666667
 i,j,k,ie:    1    3    3          55
 Near X =   1.3505527     -0.47338329      0.13437970    , d:  0.55569791E-01   0.0000000      0.66666667
 i,j,k,ie:    6    3    3          55
 Near X =   1.3505527     -0.47338329      0.29563535    , d:   0.0000000     -0.41666152      0.66666667
 i,j,k,ie:    1    4    3          55
 Near X =   1.4061137     -0.26676714      0.13437970    , d:   0.0000000     -0.55539056E-01  0.66666667
 i,j,k,ie:    6    4    3          55
 Near X =   1.4061137     -0.26676714      0.29563535    , d:   0.0000000     -0.32182429      0.66666667
 i,j,k,ie:    1    5    3          55
 Near X =   1.4367529     -0.88654125E-01  0.13437970    , d:   0.0000000     -0.14898981      0.66666667
 i,j,k,ie:    6    5    3          55
 Near X =   1.4367529     -0.88654125E-01  0.29563535    , d:   0.0000000     -0.23755489      0.66666667
 i,j,k,ie:    1    6    3          55
 Near X =   1.4463924     -0.10367029E-06  0.13437970    , d:   0.0000000      -2.6980384      0.66666667
 i,j,k,ie:    2    6    3          55
 Near X =   1.4463924     -0.10367029E-06  0.15332278    , d:   0.0000000      -2.6980384      0.66666667
 i,j,k,ie:    3    6    3          55
 Near X =   1.4463924     -0.10367029E-06  0.19200993    , d:   0.0000000      -2.6980384      0.66666667
 i,j,k,ie:    4    6    3          55
 Near X =   1.4463924     -0.10367029E-06  0.23800512    , d:   0.0000000      -2.6980384      0.66666667
 i,j,k,ie:    5    6    3          55
 Near X =   1.4463924     -0.10367029E-06  0.27669227    , d:   0.0000000      -2.6980384      0.66666667
 i,j,k,ie:    6    6    3          55
 Near X =   1.4463924     -0.10367029E-06  0.29563535    , d:   0.0000000      -2.8927847      0.66666667
 i,j,k,ie:    1    1    4          55
 Near X =   1.2147319     -0.70237679      0.13437970    , d:  0.18887579      -2.4294638      0.66666667
 i,j,k,ie:    2    1    4          55
 Near X =   1.2147319     -0.70237679      0.15332278    , d:   0.0000000      -1.9170749      0.66666667
 i,j,k,ie:    3    1    4          55
 Near X =   1.2147319     -0.70237679      0.19200993    , d:   0.0000000      -1.9170749      0.66666667
 i,j,k,ie:    4    1    4          55
 Near X =   1.2147319     -0.70237679      0.23800512    , d:   0.0000000      -1.9170749      0.66666667
 i,j,k,ie:    5    1    4          55
 Near X =   1.2147319     -0.70237679      0.27669227    , d:   0.0000000      -1.9170749      0.66666667
 i,j,k,ie:    6    1    4          55
 Near X =   1.2147319     -0.70237679      0.29563535    , d:   0.0000000      -1.9170749      0.66666667
 i,j,k,ie:    1    2    4          55
 Near X =   1.2442847     -0.62184646      0.13437970    , d:  0.14450280       0.0000000      0.66666667
 i,j,k,ie:    6    2    4          55
 Near X =   1.2442847     -0.62184646      0.29563535    , d:   0.0000000     -0.47644469      0.66666667
 i,j,k,ie:    1    3    4          55
 Near X =   1.2985487     -0.45574351      0.13437970    , d:  0.53882159E-01   0.0000000      0.66666667
 i,j,k,ie:    6    3    4          55
 Near X =   1.2985487     -0.45574351      0.29563535    , d:   0.0000000     -0.40133300      0.66666667
 i,j,k,ie:    1    4    4          55
 Near X =   1.3524220     -0.25540353      0.13437970    , d:   0.0000000     -0.53853952E-01  0.66666667
 i,j,k,ie:    6    4    4          55
 Near X =   1.3524220     -0.25540353      0.29563535    , d:   0.0000000     -0.30905687      0.66666667
 i,j,k,ie:    1    5    4          55
 Near X =   1.3887851     -0.84489420E-01  0.13437970    , d:   0.0000000     -0.14446978      0.66666667
 i,j,k,ie:    6    5    4          55
 Near X =   1.3887851     -0.84489420E-01  0.29563535    , d:   0.0000000     -0.22893926      0.66666667
 i,j,k,ie:    1    6    4          55
 Near X =   1.4036077     -0.92168933E-07  0.13437970    , d:   0.0000000      -2.6183765      0.66666667
 i,j,k,ie:    2    6    4          55
 Near X =   1.4036077     -0.92168933E-07  0.15332278    , d:   0.0000000      -2.6183765      0.66666667
 i,j,k,ie:    3    6    4          55
 Near X =   1.4036077     -0.92168933E-07  0.19200993    , d:   0.0000000      -2.6183765      0.66666667
 i,j,k,ie:    4    6    4          55
 Near X =   1.4036077     -0.92168933E-07  0.23800512    , d:   0.0000000      -2.6183765      0.66666667
 i,j,k,ie:    5    6    4          55
 Near X =   1.4036077     -0.92168933E-07  0.27669227    , d:   0.0000000      -2.6183765      0.66666667
 i,j,k,ie:    6    6    4          55
 Near X =   1.4036077     -0.92168933E-07  0.29563535    , d:   0.0000000      -2.8072153      0.66666667
 i,j,k,ie:    1    1    5          55
 Near X =   1.1837220     -0.68386908      0.13437970    , d:  0.18389889      -2.3674440      0.66666667
 i,j,k,ie:    2    1    5          55
 Near X =   1.1837220     -0.68386908      0.15332278    , d:   0.0000000      -1.8675844      0.66666667
 i,j,k,ie:    3    1    5          55
 Near X =   1.1837220     -0.68386908      0.19200993    , d:   0.0000000      -1.8675844      0.66666667
 i,j,k,ie:    4    1    5          55
 Near X =   1.1837220     -0.68386908      0.23800512    , d:   0.0000000      -1.8675844      0.66666667
 i,j,k,ie:    5    1    5          55
 Near X =   1.1837220     -0.68386908      0.27669227    , d:   0.0000000      -1.8675844      0.66666667
 i,j,k,ie:    6    1    5          55
 Near X =   1.1837220     -0.68386908      0.29563535    , d:   0.0000000      -1.8675844      0.66666667
 i,j,k,ie:    1    2    5          55
 Near X =   1.2077459     -0.60418405      0.13437970    , d:  0.14069558       0.0000000      0.66666667
 i,j,k,ie:    6    2    5          55
 Near X =   1.2077459     -0.60418405      0.29563535    , d:   0.0000000     -0.46342002      0.66666667
 i,j,k,ie:    1    3    5          55
 Near X =   1.2548075     -0.44090645      0.13437970    , d:  0.52462670E-01   0.0000000      0.66666667
 i,j,k,ie:    6    3    5          55
 Near X =   1.2548075     -0.44090645      0.29563535    , d:   0.0000000     -0.38843999      0.66666667
 i,j,k,ie:    1    4    5          55
 Near X =   1.3072613     -0.24584546      0.13437970    , d:   0.0000000     -0.52436589E-01  0.66666667
 i,j,k,ie:    6    4    5          55
 Near X =   1.3072613     -0.24584546      0.29563535    , d:   0.0000000     -0.29831802      0.66666667
 i,j,k,ie:    1    5    5          55
 Near X =   1.3484388     -0.80986433E-01  0.13437970    , d:   0.0000000     -0.14066792      0.66666667
 i,j,k,ie:    6    5    5          55
 Near X =   1.3484388     -0.80986433E-01  0.29563535    , d:   0.0000000     -0.22169254      0.66666667
 i,j,k,ie:    1    6    5          55
 Near X =   1.3676209     -0.82494990E-07  0.13437970    , d:   0.0000000      -2.5513718      0.66666667
 i,j,k,ie:    2    6    5          55
 Near X =   1.3676209     -0.82494990E-07  0.15332278    , d:   0.0000000      -2.5513718      0.66666667
 i,j,k,ie:    3    6    5          55
 Near X =   1.3676209     -0.82494990E-07  0.19200993    , d:   0.0000000      -2.5513718      0.66666667
 i,j,k,ie:    4    6    5          55
 Near X =   1.3676209     -0.82494990E-07  0.23800512    , d:   0.0000000      -2.5513718      0.66666667
 i,j,k,ie:    5    6    5          55
 Near X =   1.3676209     -0.82494990E-07  0.27669227    , d:   0.0000000      -2.5513718      0.66666667
 i,j,k,ie:    6    6    5          55
 Near X =   1.3676209     -0.82494990E-07  0.29563535    , d:   0.0000000      -2.7352417      0.66666667
 i,j,k,ie:    1    1    6          55
 Near X =   1.1685381     -0.67480681      0.13437970    , d:  0.33146194      -2.4663314      0.66666667
 i,j,k,ie:    2    1    6          55
 Near X =   1.1685381     -0.67480681      0.15332278    , d:  0.12925528      -1.9203824      0.66666667
 i,j,k,ie:    3    1    6          55
 Near X =   1.1685381     -0.67480681      0.19200993    , d:  0.12925528      -1.9203824      0.66666667
 i,j,k,ie:    4    1    6          55
 Near X =   1.1685381     -0.67480681      0.23800512    , d:  0.12925528      -1.9203824      0.66666667
 i,j,k,ie:    5    1    6          55
 Near X =   1.1685381     -0.67480681      0.27669227    , d:  0.12925528      -1.9203824      0.66666667
 i,j,k,ie:    6    1    6          55
 Near X =   1.1685381     -0.67480681      0.29563535    , d:  0.12925528      -1.9203824      0.66666667
 i,j,k,ie:    1    2    6          55
 Near X =   1.1898548     -0.59553569      0.13437970    , d:  0.30700126       0.0000000      0.66666667
 i,j,k,ie:    2    2    6          55
 Near X =   1.1898548     -0.59553569      0.15332278    , d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    3    2    6          55
 Near X =   1.1898548     -0.59553569      0.19200993    , d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    4    2    6          55
 Near X =   1.1898548     -0.59553569      0.23800512    , d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    5    2    6          55
 Near X =   1.1898548     -0.59553569      0.27669227    , d:  0.15230065       0.0000000      0.66666667
 i,j,k,ie:    6    2    6          55
 Near X =   1.1898548     -0.59553569      0.29563535    , d:  0.15230065     -0.45704252      0.66666667
 i,j,k,ie:    1    3    6          55
 Near X =   1.2333897     -0.43364152      0.13437970    , d:  0.24000629       0.0000000      0.66666667
 i,j,k,ie:    2    3    6          55
 Near X =   1.2333897     -0.43364152      0.15332278    , d:  0.18232196       0.0000000      0.66666667
 i,j,k,ie:    3    3    6          55
 Near X =   1.2333897     -0.43364152      0.19200993    , d:  0.18232196       0.0000000      0.66666667
 i,j,k,ie:    4    3    6          55
 Near X =   1.2333897     -0.43364152      0.23800512    , d:  0.18232196       0.0000000      0.66666667
 i,j,k,ie:    5    3    6          55
 Near X =   1.2333897     -0.43364152      0.27669227    , d:  0.18232196       0.0000000      0.66666667
 i,j,k,ie:    6    3    6          55
 Near X =   1.2333897     -0.43364152      0.29563535    , d:  0.18232196     -0.38212696      0.66666667
 i,j,k,ie:    1    4    6          55
 Near X =   1.2851484     -0.24116537      0.13437970    , d:  0.18823900     -0.51742581E-01  0.66666667
 i,j,k,ie:    2    4    6          55
 Near X =   1.2851484     -0.24116537      0.15332278    , d:  0.18823900       0.0000000      0.66666667
 i,j,k,ie:    3    4    6          55
 Near X =   1.2851484     -0.24116537      0.19200993    , d:  0.18823900       0.0000000      0.66666667
 i,j,k,ie:    4    4    6          55
 Near X =   1.2851484     -0.24116537      0.23800512    , d:  0.18823900       0.0000000      0.66666667
 i,j,k,ie:    5    4    6          55
 Near X =   1.2851484     -0.24116537      0.27669227    , d:  0.18823900       0.0000000      0.66666667
 i,j,k,ie:    6    4    6          55
 Near X =   1.2851484     -0.24116537      0.29563535    , d:  0.18823900     -0.29305977      0.66666667
 i,j,k,ie:    1    5    6          55
 Near X =   1.3286833     -0.79271203E-01  0.13437970    , d:  0.16817149     -0.13880634      0.66666667
 i,j,k,ie:    2    5    6          55
 Near X =   1.3286833     -0.79271203E-01  0.15332278    , d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    3    5    6          55
 Near X =   1.3286833     -0.79271203E-01  0.19200993    , d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    4    5    6          55
 Near X =   1.3286833     -0.79271203E-01  0.23800512    , d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    5    5    6          55
 Near X =   1.3286833     -0.79271203E-01  0.27669227    , d:  0.16817149       0.0000000      0.66666667
 i,j,k,ie:    6    5    6          55
 Near X =   1.3286833     -0.79271203E-01  0.29563535    , d:  0.16817149     -0.21814421      0.66666667
 i,j,k,ie:    1    6    6          55
 Near X =   1.3500000     -0.77758166E-07  0.13437970    , d:  0.14999998      -2.6478518      0.66666667
 i,j,k,ie:    2    6    6          55
 Near X =   1.3500000     -0.77758166E-07  0.15332278    , d:  0.14999998      -2.6478518      0.66666667
 i,j,k,ie:    3    6    6          55
 Near X =   1.3500000     -0.77758166E-07  0.19200993    , d:  0.14999998      -2.6478518      0.66666667
 i,j,k,ie:    4    6    6          55
 Near X =   1.3500000     -0.77758166E-07  0.23800512    , d:  0.14999998      -2.6478518      0.66666667
 i,j,k,ie:    5    6    6          55
 Near X =   1.3500000     -0.77758166E-07  0.27669227    , d:  0.14999998      -2.6478518      0.66666667
 i,j,k,ie:    6    6    6          55
 Near X =   1.3500000     -0.77758166E-07  0.29563535    , d:  0.14999998      -2.8500000      0.66666667
 i,j,k,ie:    1    1    1          56
 Near X =  0.75184425      -1.2978518      0.13437970    , d:  0.54594909      -1.5036886      0.77053871
 i,j,k,ie:    2    1    1          56
 Near X =  0.75184425      -1.2978518      0.15332278    , d:   0.0000000     -0.75184419      0.77053871
 i,j,k,ie:    3    1    1          56
 Near X =  0.75184425      -1.2978518      0.19200993    , d:   0.0000000     -0.75184419      0.77053871
 i,j,k,ie:    4    1    1          56
 Near X =  0.75184425      -1.2978518      0.23800512    , d:   0.0000000     -0.75184419      0.77053871
 i,j,k,ie:    5    1    1          56
 Near X =  0.75184425      -1.2978518      0.27669227    , d:   0.0000000     -0.75184419      0.77053871
 i,j,k,ie:    6    1    1          56
 Near X =  0.75184425      -1.2978518      0.29563535    , d:   0.0000000     -0.75184419      0.77053871
 i,j,k,ie:    1    2    1          56
 Near X =  0.83082355      -1.2485701      0.13437970    , d:  0.51133191     -0.98011250E-01  0.77053871
 i,j,k,ie:    2    2    1          56
 Near X =  0.83082355      -1.2485701      0.15332278    , d:   0.0000000     -0.98011250E-01  0.77053871
 i,j,k,ie:    3    2    1          56
 Near X =  0.83082355      -1.2485701      0.19200993    , d:   0.0000000     -0.98011250E-01  0.77053871
 i,j,k,ie:    4    2    1          56
 Near X =  0.83082355      -1.2485701      0.23800512    , d:   0.0000000     -0.98011250E-01  0.77053871
 i,j,k,ie:    5    2    1          56
 Near X =  0.83082355      -1.2485701      0.27669227    , d:   0.0000000     -0.98011250E-01  0.77053871
 i,j,k,ie:    6    2    1          56
 Near X =  0.83082355      -1.2485701      0.29563535    , d:   0.0000000     -0.98011250E-01  0.77053871
 i,j,k,ie:    1    3    1          56
 Near X =  0.97984411      -1.1356442      0.13437970    , d:  0.43586756     -0.12858136      0.77053871
 i,j,k,ie:    2    3    1          56
 Near X =  0.97984411      -1.1356442      0.15332278    , d:   0.0000000     -0.12858136      0.77053871
 i,j,k,ie:    3    3    1          56
 Near X =  0.97984411      -1.1356442      0.19200993    , d:   0.0000000     -0.12858136      0.77053871
 i,j,k,ie:    4    3    1          56
 Near X =  0.97984411      -1.1356442      0.23800512    , d:   0.0000000     -0.12858136      0.77053871
 i,j,k,ie:    5    3    1          56
 Near X =  0.97984411      -1.1356442      0.27669227    , d:   0.0000000     -0.12858136      0.77053871
 i,j,k,ie:    6    3    1          56
 Near X =  0.97984411      -1.1356442      0.29563535    , d:   0.0000000     -0.12858136      0.77053871
 i,j,k,ie:    1    4    1          56
 Near X =   1.1355660     -0.97993599      0.13437970    , d:  0.33782139     -0.14347738      0.77053871
 i,j,k,ie:    2    4    1          56
 Near X =   1.1355660     -0.97993599      0.15332278    , d:   0.0000000     -0.14347738      0.77053871
 i,j,k,ie:    3    4    1          56
 Near X =   1.1355660     -0.97993599      0.19200993    , d:   0.0000000     -0.14347738      0.77053871
 i,j,k,ie:    4    4    1          56
 Near X =   1.1355660     -0.97993599      0.23800512    , d:   0.0000000     -0.14347738      0.77053871
 i,j,k,ie:    5    4    1          56
 Near X =   1.1355660     -0.97993599      0.27669227    , d:   0.0000000     -0.14347738      0.77053871
 i,j,k,ie:    6    4    1          56
 Near X =   1.1355660     -0.97993599      0.29563535    , d:   0.0000000     -0.14347738      0.77053871
 i,j,k,ie:    1    5    1          56
 Near X =   1.2485048     -0.83092549      0.13437970    , d:  0.24834994     -0.13796575      0.77053871
 i,j,k,ie:    2    5    1          56
 Near X =   1.2485048     -0.83092549      0.15332278    , d:   0.0000000     -0.13796575      0.77053871
 i,j,k,ie:    3    5    1          56
 Near X =   1.2485048     -0.83092549      0.19200993    , d:   0.0000000     -0.13796575      0.77053871
 i,j,k,ie:    4    5    1          56
 Near X =   1.2485048     -0.83092549      0.23800512    , d:   0.0000000     -0.13796575      0.77053871
 i,j,k,ie:    5    5    1          56
 Near X =   1.2485048     -0.83092549      0.27669227    , d:   0.0000000     -0.13796575      0.77053871
 i,j,k,ie:    6    5    1          56
 Near X =   1.2485048     -0.83092549      0.29563535    , d:   0.0000000     -0.13796575      0.77053871
 i,j,k,ie:    1    6    1          56
 Near X =   1.2977933     -0.75195062      0.13437970    , d:  0.20220666      -2.7977933      0.77053871
 i,j,k,ie:    2    6    1          56
 Near X =   1.2977933     -0.75195062      0.15332278    , d:   0.0000000      -2.7977933      0.77053871
 i,j,k,ie:    3    6    1          56
 Near X =   1.2977933     -0.75195062      0.19200993    , d:   0.0000000      -2.7977933      0.77053871
 i,j,k,ie:    4    6    1          56
 Near X =   1.2977933     -0.75195062      0.23800512    , d:   0.0000000      -2.7977933      0.77053871
 i,j,k,ie:    5    6    1          56
 Near X =   1.2977933     -0.75195062      0.27669227    , d:   0.0000000      -2.7977933      0.77053871
 i,j,k,ie:    6    6    1          56
 Near X =   1.2977933     -0.75195062      0.29563535    , d:   0.0000000      -2.7977933      0.77053871
 i,j,k,ie:    1    1    2          56
 Near X =  0.74279524      -1.2826639      0.13437970    , d:  0.53981418      -1.4855906      0.77053871
 i,j,k,ie:    2    1    2          56
 Near X =  0.74279524      -1.2826639      0.15332278    , d:   0.0000000     -0.74279518      0.77053871
 i,j,k,ie:    3    1    2          56
 Near X =  0.74279524      -1.2826639      0.19200993    , d:   0.0000000     -0.74279518      0.77053871
 i,j,k,ie:    4    1    2          56
 Near X =  0.74279524      -1.2826639      0.23800512    , d:   0.0000000     -0.74279518      0.77053871
 i,j,k,ie:    5    1    2          56
 Near X =  0.74279524      -1.2826639      0.27669227    , d:   0.0000000     -0.74279518      0.77053871
 i,j,k,ie:    6    1    2          56
 Near X =  0.74279524      -1.2826639      0.29563535    , d:   0.0000000     -0.74279518      0.77053871
 i,j,k,ie:    1    2    2          56
 Near X =  0.81930994      -1.2323578      0.13437970    , d:  0.50495441       0.0000000      0.77053871
 i,j,k,ie:    1    3    2          56
 Near X =  0.96473935      -1.1187820      0.13437970    , d:  0.42955453       0.0000000      0.77053871
 i,j,k,ie:    1    4    2          56
 Near X =   1.1187114     -0.96482101      0.13437970    , d:  0.33256314       0.0000000      0.77053871
 i,j,k,ie:    1    5    2          56
 Near X =   1.2322977     -0.81939958      0.13437970    , d:  0.24480160       0.0000000      0.77053871
 i,j,k,ie:    1    6    2          56
 Near X =   1.2826094     -0.74288836      0.13437970    , d:  0.19976973      -2.7649886      0.77053871
 i,j,k,ie:    2    6    2          56
 Near X =   1.2826094     -0.74288836      0.15332278    , d:   0.0000000      -2.7649886      0.77053871
 i,j,k,ie:    3    6    2          56
 Near X =   1.2826094     -0.74288836      0.19200993    , d:   0.0000000      -2.7649886      0.77053871
 i,j,k,ie:    4    6    2          56
 Near X =   1.2826094     -0.74288836      0.23800512    , d:   0.0000000      -2.7649886      0.77053871
 i,j,k,ie:    5    6    2          56
 Near X =   1.2826094     -0.74288836      0.27669227    , d:   0.0000000      -2.7649886      0.77053871
 i,j,k,ie:    6    6    2          56
 Near X =   1.2826094     -0.74288836      0.29563535    , d:   0.0000000      -2.7649886      0.77053871
 i,j,k,ie:    1    1    3          56
 Near X =  0.72431460      -1.2516460      0.13437970    , d:  0.52728494      -1.4486293      0.77053871
 i,j,k,ie:    2    1    3          56
 Near X =  0.72431460      -1.2516460      0.15332278    , d:   0.0000000     -0.72431454      0.77053871
 i,j,k,ie:    3    1    3          56
 Near X =  0.72431460      -1.2516460      0.19200993    , d:   0.0000000     -0.72431454      0.77053871
 i,j,k,ie:    4    1    3          56
 Near X =  0.72431460      -1.2516460      0.23800512    , d:   0.0000000     -0.72431454      0.77053871
 i,j,k,ie:    5    1    3          56
 Near X =  0.72431460      -1.2516460      0.27669227    , d:   0.0000000     -0.72431454      0.77053871
 i,j,k,ie:    6    1    3          56
 Near X =  0.72431460      -1.2516460      0.29563535    , d:   0.0000000     -0.72431454      0.77053871
 i,j,k,ie:    1    2    3          56
 Near X =  0.79579588      -1.1992476      0.13437970    , d:  0.49192974       0.0000000      0.77053871
 i,j,k,ie:    1    3    3          56
 Near X =  0.93389116      -1.0843446      0.13437970    , d:  0.41666152       0.0000000      0.77053871
 i,j,k,ie:    1    4    3          56
 Near X =   1.0842894     -0.93395191      0.13437970    , d:  0.32182429       0.0000000      0.77053871
 i,j,k,ie:    1    5    3          56
 Near X =   1.1991980     -0.79586039      0.13437970    , d:  0.23755489       0.0000000      0.77053871
 i,j,k,ie:    1    6    3          56
 Near X =   1.2515995     -0.72438064      0.13437970    , d:  0.19479283      -2.6979919      0.77053871
 i,j,k,ie:    2    6    3          56
 Near X =   1.2515995     -0.72438064      0.15332278    , d:   0.0000000      -2.6979919      0.77053871
 i,j,k,ie:    3    6    3          56
 Near X =   1.2515995     -0.72438064      0.19200993    , d:   0.0000000      -2.6979919      0.77053871
 i,j,k,ie:    4    6    3          56
 Near X =   1.2515995     -0.72438064      0.23800512    , d:   0.0000000      -2.6979919      0.77053871
 i,j,k,ie:    5    6    3          56
 Near X =   1.2515995     -0.72438064      0.27669227    , d:   0.0000000      -2.6979919      0.77053871
 i,j,k,ie:    6    6    3          56
 Near X =   1.2515995     -0.72438064      0.29563535    , d:   0.0000000      -2.6979919      0.77053871
 i,j,k,ie:    1    1    4          56
 Near X =  0.70234295      -1.2147688      0.13437970    , d:  0.51238891      -1.4046860      0.77053871
 i,j,k,ie:    2    1    4          56
 Near X =  0.70234295      -1.2147688      0.15332278    , d:   0.0000000     -0.70234289      0.77053871
 i,j,k,ie:    3    1    4          56
 Near X =  0.70234295      -1.2147688      0.19200993    , d:   0.0000000     -0.70234289      0.77053871
 i,j,k,ie:    4    1    4          56
 Near X =  0.70234295      -1.2147688      0.23800512    , d:   0.0000000     -0.70234289      0.77053871
 i,j,k,ie:    5    1    4          56
 Near X =  0.70234295      -1.2147688      0.27669227    , d:   0.0000000     -0.70234289      0.77053871
 i,j,k,ie:    6    1    4          56
 Near X =  0.70234295      -1.2147688      0.29563535    , d:   0.0000000     -0.70234289      0.77053871
 i,j,k,ie:    1    2    4          56
 Near X =  0.76783998      -1.1598829      0.13437970    , d:  0.47644469       0.0000000      0.77053871
 i,j,k,ie:    1    3    4          56
 Near X =  0.89721570      -1.0434020      0.13437970    , d:  0.40133300       0.0000000      0.77053871
 i,j,k,ie:    1    4    4          56
 Near X =   1.0433652     -0.89725161      0.13437970    , d:  0.30905687       0.0000000      0.77053871
 i,j,k,ie:    1    5    4          56
 Near X =   1.1598458     -0.76787462      0.13437970    , d:  0.22893926       0.0000000      0.77053871
 i,j,k,ie:    1    6    4          56
 Near X =   1.2147319     -0.70237679      0.13437970    , d:  0.18887579      -2.6183395      0.77053871
 i,j,k,ie:    2    6    4          56
 Near X =   1.2147319     -0.70237679      0.15332278    , d:   0.0000000      -2.6183395      0.77053871
 i,j,k,ie:    3    6    4          56
 Near X =   1.2147319     -0.70237679      0.19200993    , d:   0.0000000      -2.6183395      0.77053871
 i,j,k,ie:    4    6    4          56
 Near X =   1.2147319     -0.70237679      0.23800512    , d:   0.0000000      -2.6183395      0.77053871
 i,j,k,ie:    5    6    4          56
 Near X =   1.2147319     -0.70237679      0.27669227    , d:   0.0000000      -2.6183395      0.77053871
 i,j,k,ie:    6    6    4          56
 Near X =   1.2147319     -0.70237679      0.29563535    , d:   0.0000000      -2.6183395      0.77053871
 i,j,k,ie:    1    1    5          56
 Near X =  0.68386231      -1.1837509      0.13437970    , d:  0.49985967      -1.3677247      0.77053871
 i,j,k,ie:    2    1    5          56
 Near X =  0.68386231      -1.1837509      0.15332278    , d:   0.0000000     -0.68386225      0.77053871
 i,j,k,ie:    3    1    5          56
 Near X =  0.68386231      -1.1837509      0.19200993    , d:   0.0000000     -0.68386225      0.77053871
 i,j,k,ie:    4    1    5          56
 Near X =  0.68386231      -1.1837509      0.23800512    , d:   0.0000000     -0.68386225      0.77053871
 i,j,k,ie:    5    1    5          56
 Near X =  0.68386231      -1.1837509      0.27669227    , d:   0.0000000     -0.68386225      0.77053871
 i,j,k,ie:    6    1    5          56
 Near X =  0.68386231      -1.1837509      0.29563535    , d:   0.0000000     -0.68386225      0.77053871
 i,j,k,ie:    1    2    5          56
 Near X =  0.74432591      -1.1267727      0.13437970    , d:  0.46342002       0.0000000      0.77053871
 i,j,k,ie:    1    3    5          56
 Near X =  0.86636750      -1.0089646      0.13437970    , d:  0.38843999       0.0000000      0.77053871
 i,j,k,ie:    1    4    5          56
 Near X =   1.0089432     -0.86638251      0.13437970    , d:  0.29831802       0.0000000      0.77053871
 i,j,k,ie:    1    5    5          56
 Near X =   1.1267462     -0.74433543      0.13437970    , d:  0.22169254       0.0000000      0.77053871
 i,j,k,ie:    1    6    5          56
 Near X =   1.1837220     -0.68386908      0.13437970    , d:  0.18389889      -2.5513429      0.77053871
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    2    6    5          56
 Near X =   1.1837220     -0.68386908      0.15332278    , d:   0.0000000      -2.5513429      0.77053871
 i,j,k,ie:    3    6    5          56
 Near X =   1.1837220     -0.68386908      0.19200993    , d:   0.0000000      -2.5513429      0.77053871
 i,j,k,ie:    4    6    5          56
 Near X =   1.1837220     -0.68386908      0.23800512    , d:   0.0000000      -2.5513429      0.77053871
 i,j,k,ie:    5    6    5          56
 Near X =   1.1837220     -0.68386908      0.27669227    , d:   0.0000000      -2.5513429      0.77053871
 i,j,k,ie:    6    6    5          56
 Near X =   1.1837220     -0.68386908      0.29563535    , d:   0.0000000      -2.5513429      0.77053871
 i,j,k,ie:    1    1    6          56
 Near X =  0.67481330      -1.1685631      0.13437970    , d:  0.62298004      -1.4266577      0.77053871
 i,j,k,ie:    2    1    6          56
 Near X =  0.67481330      -1.1685631      0.15332278    , d:  0.77030946E-01 -0.67481325      0.77053871
 i,j,k,ie:    3    1    6          56
 Near X =  0.67481330      -1.1685631      0.19200993    , d:  0.77030946E-01 -0.67481325      0.77053871
 i,j,k,ie:    4    1    6          56
 Near X =  0.67481330      -1.1685631      0.23800512    , d:  0.77030946E-01 -0.67481325      0.77053871
 i,j,k,ie:    5    1    6          56
 Near X =  0.67481330      -1.1685631      0.27669227    , d:  0.77030946E-01 -0.67481325      0.77053871
 i,j,k,ie:    6    1    6          56
 Near X =  0.67481330      -1.1685631      0.29563535    , d:  0.77030946E-01 -0.67481325      0.77053871
 i,j,k,ie:    1    2    6          56
 Near X =  0.73281230      -1.1105604      0.13437970    , d:  0.60934316       0.0000000      0.77053871
 i,j,k,ie:    2    2    6          56
 Near X =  0.73281230      -1.1105604      0.15332278    , d:  0.98011250E-01   0.0000000      0.77053871
 i,j,k,ie:    3    2    6          56
 Near X =  0.73281230      -1.1105604      0.19200993    , d:  0.98011250E-01   0.0000000      0.77053871
 i,j,k,ie:    4    2    6          56
 Near X =  0.73281230      -1.1105604      0.23800512    , d:  0.98011250E-01   0.0000000      0.77053871
 i,j,k,ie:    5    2    6          56
 Near X =  0.73281230      -1.1105604      0.27669227    , d:  0.98011250E-01   0.0000000      0.77053871
 i,j,k,ie:    6    2    6          56
 Near X =  0.73281230      -1.1105604      0.29563535    , d:  0.98011250E-01   0.0000000      0.77053871
 i,j,k,ie:    1    3    6          56
 Near X =  0.85126275     -0.99210238      0.13437970    , d:  0.56444892       0.0000000      0.77053871
 i,j,k,ie:    2    3    6          56
 Near X =  0.85126275     -0.99210238      0.15332278    , d:  0.12858136       0.0000000      0.77053871
 i,j,k,ie:    3    3    6          56
 Near X =  0.85126275     -0.99210238      0.19200993    , d:  0.12858136       0.0000000      0.77053871
 i,j,k,ie:    4    3    6          56
 Near X =  0.85126275     -0.99210238      0.23800512    , d:  0.12858136       0.0000000      0.77053871
 i,j,k,ie:    5    3    6          56
 Near X =  0.85126275     -0.99210238      0.27669227    , d:  0.12858136       0.0000000      0.77053871
 i,j,k,ie:    6    3    6          56
 Near X =  0.85126275     -0.99210238      0.29563535    , d:  0.12858136       0.0000000      0.77053871
 i,j,k,ie:    1    4    6          56
 Near X =  0.99208861     -0.85126753      0.13437970    , d:  0.48129877       0.0000000      0.77053871
 i,j,k,ie:    2    4    6          56
 Near X =  0.99208861     -0.85126753      0.15332278    , d:  0.14347738       0.0000000      0.77053871
 i,j,k,ie:    3    4    6          56
 Near X =  0.99208861     -0.85126753      0.19200993    , d:  0.14347738       0.0000000      0.77053871
 i,j,k,ie:    4    4    6          56
 Near X =  0.99208861     -0.85126753      0.23800512    , d:  0.14347738       0.0000000      0.77053871
 i,j,k,ie:    5    4    6          56
 Near X =  0.99208861     -0.85126753      0.27669227    , d:  0.14347738       0.0000000      0.77053871
 i,j,k,ie:    6    4    6          56
 Near X =  0.99208861     -0.85126753      0.29563535    , d:  0.14347738       0.0000000      0.77053871
 i,j,k,ie:    1    5    6          56
 Near X =   1.1105391     -0.73280952      0.13437970    , d:  0.38631569       0.0000000      0.77053871
 i,j,k,ie:    2    5    6          56
 Near X =   1.1105391     -0.73280952      0.15332278    , d:  0.13796575       0.0000000      0.77053871
 i,j,k,ie:    3    5    6          56
 Near X =   1.1105391     -0.73280952      0.19200993    , d:  0.13796575       0.0000000      0.77053871
 i,j,k,ie:    4    5    6          56
 Near X =   1.1105391     -0.73280952      0.23800512    , d:  0.13796575       0.0000000      0.77053871
 i,j,k,ie:    5    5    6          56
 Near X =   1.1105391     -0.73280952      0.27669227    , d:  0.13796575       0.0000000      0.77053871
 i,j,k,ie:    6    5    6          56
 Near X =   1.1105391     -0.73280952      0.29563535    , d:  0.13796575       0.0000000      0.77053871
 i,j,k,ie:    1    6    6          56
 Near X =   1.1685381     -0.67480681      0.13437970    , d:  0.33146194      -2.6685381      0.77053871
 i,j,k,ie:    2    6    6          56
 Near X =   1.1685381     -0.67480681      0.15332278    , d:  0.12925528      -2.6685381      0.77053871
 i,j,k,ie:    3    6    6          56
 Near X =   1.1685381     -0.67480681      0.19200993    , d:  0.12925528      -2.6685381      0.77053871
 i,j,k,ie:    4    6    6          56
 Near X =   1.1685381     -0.67480681      0.23800512    , d:  0.12925528      -2.6685381      0.77053871
 i,j,k,ie:    5    6    6          56
 Near X =   1.1685381     -0.67480681      0.27669227    , d:  0.12925528      -2.6685381      0.77053871
 i,j,k,ie:    6    6    6          56
 Near X =   1.1685381     -0.67480681      0.29563535    , d:  0.12925528      -2.6685381      0.77053871
 i,j,k,ie:    1    1    1          57
 Near X = -0.17702063E-06  -1.5000000      0.13437970    , d:  0.75195075       0.0000000       1.3300624
 i,j,k,ie:    2    1    1          57
 Near X = -0.17702063E-06  -1.5000000      0.15332278    , d:  0.75195075       0.0000000       1.3300624
 i,j,k,ie:    3    1    1          57
 Near X = -0.17702063E-06  -1.5000000      0.19200993    , d:  0.75195075       0.0000000       1.3300624
 i,j,k,ie:    4    1    1          57
 Near X = -0.17702063E-06  -1.5000000      0.23800512    , d:  0.75195075       0.0000000       1.3300624
 i,j,k,ie:    5    1    1          57
 Near X = -0.17702063E-06  -1.5000000      0.27669227    , d:  0.75195075       0.0000000       1.3300624
 i,j,k,ie:    6    1    1          57
 Near X = -0.17702063E-06  -1.5000000      0.29563535    , d:   1.2978520     -0.75195043       1.3300624
 i,j,k,ie:    1    2    1          57
 Near X =  0.93857198E-01  -1.4968561      0.13437970    , d:   0.0000000     -0.14585443E-01   1.3300624
 i,j,k,ie:    2    2    1          57
 Near X =  0.93857198E-01  -1.4968561      0.15332278    , d:   0.0000000     -0.14585443E-01   1.3300624
 i,j,k,ie:    3    2    1          57
 Near X =  0.93857198E-01  -1.4968561      0.19200993    , d:   0.0000000     -0.14585443E-01   1.3300624
 i,j,k,ie:    4    2    1          57
 Near X =  0.93857198E-01  -1.4968561      0.23800512    , d:   0.0000000     -0.14585443E-01   1.3300624
 i,j,k,ie:    5    2    1          57
 Near X =  0.93857198E-01  -1.4968561      0.27669227    , d:   0.0000000     -0.14585443E-01   1.3300624
 i,j,k,ie:    6    2    1          57
 Near X =  0.93857198E-01  -1.4968561      0.29563535    , d:   0.0000000     -0.76301327       1.3300624
 i,j,k,ie:    1    3    1          57
 Near X =  0.28096180      -1.4733960      0.13437970    , d:   0.0000000     -0.39794265E-01   1.3300624
 i,j,k,ie:    2    3    1          57
 Near X =  0.28096180      -1.4733960      0.15332278    , d:   0.0000000     -0.39794265E-01   1.3300624
 i,j,k,ie:    3    3    1          57
 Near X =  0.28096180      -1.4733960      0.19200993    , d:   0.0000000     -0.39794265E-01   1.3300624
 i,j,k,ie:    4    3    1          57
 Near X =  0.28096180      -1.4733960      0.23800512    , d:   0.0000000     -0.39794265E-01   1.3300624
 i,j,k,ie:    5    3    1          57
 Near X =  0.28096180      -1.4733960      0.27669227    , d:   0.0000000     -0.39794265E-01   1.3300624
 i,j,k,ie:    6    3    1          57
 Near X =  0.28096180      -1.4733960      0.29563535    , d:   0.0000000     -0.77644709       1.3300624
 i,j,k,ie:    1    4    1          57
 Near X =  0.49541153      -1.4157370      0.13437970    , d:   0.0000000     -0.61765923E-01   1.3300624
 i,j,k,ie:    2    4    1          57
 Near X =  0.49541153      -1.4157370      0.15332278    , d:   0.0000000     -0.61765923E-01   1.3300624
 i,j,k,ie:    3    4    1          57
 Near X =  0.49541153      -1.4157370      0.19200993    , d:   0.0000000     -0.61765923E-01   1.3300624
 i,j,k,ie:    4    4    1          57
 Near X =  0.49541153      -1.4157370      0.23800512    , d:   0.0000000     -0.61765923E-01   1.3300624
 i,j,k,ie:    5    4    1          57
 Near X =  0.49541153      -1.4157370      0.27669227    , d:   0.0000000     -0.61765923E-01   1.3300624
 i,j,k,ie:    6    4    1          57
 Near X =  0.49541153      -1.4157370      0.29563535    , d:   0.0000000     -0.77641686       1.3300624
 i,j,k,ie:    1    5    1          57
 Near X =  0.66905978      -1.3422015      0.13437970    , d:   0.0000000     -0.73518391E-01   1.3300624
 i,j,k,ie:    2    5    1          57
 Near X =  0.66905978      -1.3422015      0.15332278    , d:   0.0000000     -0.73518391E-01   1.3300624
 i,j,k,ie:    3    5    1          57
 Near X =  0.66905978      -1.3422015      0.19200993    , d:   0.0000000     -0.73518391E-01   1.3300624
 i,j,k,ie:    4    5    1          57
 Near X =  0.66905978      -1.3422015      0.23800512    , d:   0.0000000     -0.73518391E-01   1.3300624
 i,j,k,ie:    5    5    1          57
 Near X =  0.66905978      -1.3422015      0.27669227    , d:   0.0000000     -0.73518391E-01   1.3300624
 i,j,k,ie:    6    5    1          57
 Near X =  0.66905978      -1.3422015      0.29563535    , d:   0.0000000     -0.76293217       1.3300624
 i,j,k,ie:    1    6    1          57
 Near X =  0.75184425      -1.2978518      0.13437970    , d:   0.0000000      -1.4266511       1.3300624
 i,j,k,ie:    2    6    1          57
 Near X =  0.75184425      -1.2978518      0.15332278    , d:   0.0000000      -1.4266511       1.3300624
 i,j,k,ie:    3    6    1          57
 Near X =  0.75184425      -1.2978518      0.19200993    , d:   0.0000000      -1.4266511       1.3300624
 i,j,k,ie:    4    6    1          57
 Near X =  0.75184425      -1.2978518      0.23800512    , d:   0.0000000      -1.4266511       1.3300624
 i,j,k,ie:    5    6    1          57
 Near X =  0.75184425      -1.2978518      0.27669227    , d:   0.0000000      -1.4266511       1.3300624
 i,j,k,ie:    6    6    1          57
 Near X =  0.75184425      -1.2978518      0.29563535    , d:   0.0000000      -1.9204073       1.3300624
 i,j,k,ie:    1    1    2          57
 Near X = -0.17494016E-06  -1.4823791      0.13437970    , d:  0.74288849       0.0000000       1.3300624
 i,j,k,ie:    2    1    2          57
 Near X = -0.17494016E-06  -1.4823791      0.15332278    , d:  0.74288849       0.0000000       1.3300624
 i,j,k,ie:    3    1    2          57
 Near X = -0.17494016E-06  -1.4823791      0.19200993    , d:  0.74288849       0.0000000       1.3300624
 i,j,k,ie:    4    1    2          57
 Near X = -0.17494016E-06  -1.4823791      0.23800512    , d:  0.74288849       0.0000000       1.3300624
 i,j,k,ie:    5    1    2          57
 Near X = -0.17494016E-06  -1.4823791      0.27669227    , d:  0.74288849       0.0000000       1.3300624
 i,j,k,ie:    6    1    2          57
 Near X = -0.17494016E-06  -1.4823791      0.29563535    , d:   1.2826641     -0.74288817       1.3300624
 i,j,k,ie:    6    2    2          57
 Near X =  0.92143812E-01  -1.4771008      0.29563535    , d:   0.0000000     -0.75265153       1.3300624
 i,j,k,ie:    6    3    2          57
 Near X =  0.27628708      -1.4512832      0.29563535    , d:   0.0000000     -0.76450744       1.3300624
 i,j,k,ie:    6    4    2          57
 Near X =  0.48815574      -1.3943181      0.29563535    , d:   0.0000000     -0.76448098       1.3300624
 i,j,k,ie:    6    5    2          57
 Near X =  0.66042340      -1.3243076      0.29563535    , d:   0.0000000     -0.75258056       1.3300624
 i,j,k,ie:    1    6    2          57
 Near X =  0.74279524      -1.2826639      0.13437970    , d:   0.0000000      -1.3970503       1.3300624
 i,j,k,ie:    2    6    2          57
 Near X =  0.74279524      -1.2826639      0.15332278    , d:   0.0000000      -1.3970503       1.3300624
 i,j,k,ie:    3    6    2          57
 Near X =  0.74279524      -1.2826639      0.19200993    , d:   0.0000000      -1.3970503       1.3300624
 i,j,k,ie:    4    6    2          57
 Near X =  0.74279524      -1.2826639      0.23800512    , d:   0.0000000      -1.3970503       1.3300624
 i,j,k,ie:    5    6    2          57
 Near X =  0.74279524      -1.2826639      0.27669227    , d:   0.0000000      -1.3970503       1.3300624
 i,j,k,ie:    6    6    2          57
 Near X =  0.74279524      -1.2826639      0.29563535    , d:   0.0000000      -1.8757688       1.3300624
 i,j,k,ie:    1    1    3          57
 Near X = -0.17069125E-06  -1.4463924      0.13437970    , d:  0.72438077       0.0000000       1.3300624
 i,j,k,ie:    2    1    3          57
 Near X = -0.17069125E-06  -1.4463924      0.15332278    , d:  0.72438077       0.0000000       1.3300624
 i,j,k,ie:    3    1    3          57
 Near X = -0.17069125E-06  -1.4463924      0.19200993    , d:  0.72438077       0.0000000       1.3300624
 i,j,k,ie:    4    1    3          57
 Near X = -0.17069125E-06  -1.4463924      0.23800512    , d:  0.72438077       0.0000000       1.3300624
 i,j,k,ie:    5    1    3          57
 Near X = -0.17069125E-06  -1.4463924      0.27669227    , d:  0.72438077       0.0000000       1.3300624
 i,j,k,ie:    6    1    3          57
 Near X = -0.17069125E-06  -1.4463924      0.29563535    , d:   1.2516462     -0.72438047       1.3300624
 i,j,k,ie:    6    2    3          57
 Near X =  0.88644591E-01  -1.4367548      0.29563535    , d:   0.0000000     -0.73148991       1.3300624
 i,j,k,ie:    6    3    3          57
 Near X =  0.26673996      -1.4061225      0.29563535    , d:   0.0000000     -0.74012327       1.3300624
 i,j,k,ie:    6    4    3          57
 Near X =  0.47333736      -1.3505747      0.29563535    , d:   0.0000000     -0.74010454       1.3300624
 i,j,k,ie:    6    5    3          57
 Near X =  0.64278546      -1.2877631      0.29563535    , d:   0.0000000     -0.73143965       1.3300624
 i,j,k,ie:    1    6    3          57
 Near X =  0.72431460      -1.2516460      0.13437970    , d:   0.0000000      -1.3365971       1.3300624
 i,j,k,ie:    2    6    3          57
 Near X =  0.72431460      -1.2516460      0.15332278    , d:   0.0000000      -1.3365971       1.3300624
 i,j,k,ie:    3    6    3          57
 Near X =  0.72431460      -1.2516460      0.19200993    , d:   0.0000000      -1.3365971       1.3300624
 i,j,k,ie:    4    6    3          57
 Near X =  0.72431460      -1.2516460      0.23800512    , d:   0.0000000      -1.3365971       1.3300624
 i,j,k,ie:    5    6    3          57
 Near X =  0.72431460      -1.2516460      0.27669227    , d:   0.0000000      -1.3365971       1.3300624
 i,j,k,ie:    6    6    3          57
 Near X =  0.72431460      -1.2516460      0.29563535    , d:   0.0000000      -1.7846043       1.3300624
 i,j,k,ie:    1    1    4          57
 Near X = -0.16563971E-06  -1.4036076      0.13437970    , d:  0.70237693       0.0000000       1.3300624
 i,j,k,ie:    2    1    4          57
 Near X = -0.16563971E-06  -1.4036076      0.15332278    , d:  0.70237693       0.0000000       1.3300624
 i,j,k,ie:    3    1    4          57
 Near X = -0.16563971E-06  -1.4036076      0.19200993    , d:  0.70237693       0.0000000       1.3300624
 i,j,k,ie:    4    1    4          57
 Near X = -0.16563971E-06  -1.4036076      0.23800512    , d:  0.70237693       0.0000000       1.3300624
 i,j,k,ie:    5    1    4          57
 Near X = -0.16563971E-06  -1.4036076      0.27669227    , d:  0.70237693       0.0000000       1.3300624
 i,j,k,ie:    6    1    4          57
 Near X = -0.16563971E-06  -1.4036076      0.29563535    , d:   1.2147690     -0.70237663       1.3300624
 i,j,k,ie:    6    2    4          57
 Near X =  0.84484363E-01  -1.3887875      0.29563535    , d:   0.0000000     -0.70633083       1.3300624
 i,j,k,ie:    6    3    4          57
 Near X =  0.25538938      -1.3524309      0.29563535    , d:   0.0000000     -0.71113291       1.3300624
 i,j,k,ie:    6    4    4          57
 Near X =  0.45571977      -1.2985681      0.29563535    , d:   0.0000000     -0.71112335       1.3300624
 i,j,k,ie:    6    5    4          57
 Near X =  0.62181570      -1.2443153      0.29563535    , d:   0.0000000     -0.70630519       1.3300624
 i,j,k,ie:    1    6    4          57
 Near X =  0.70234295      -1.2147688      0.13437970    , d:   0.0000000      -1.2647242       1.3300624
 i,j,k,ie:    2    6    4          57
 Near X =  0.70234295      -1.2147688      0.15332278    , d:   0.0000000      -1.2647242       1.3300624
 i,j,k,ie:    3    6    4          57
 Near X =  0.70234295      -1.2147688      0.19200993    , d:   0.0000000      -1.2647242       1.3300624
 i,j,k,ie:    4    6    4          57
 Near X =  0.70234295      -1.2147688      0.23800512    , d:   0.0000000      -1.2647242       1.3300624
 i,j,k,ie:    5    6    4          57
 Near X =  0.70234295      -1.2147688      0.27669227    , d:   0.0000000      -1.2647242       1.3300624
 i,j,k,ie:    6    6    4          57
 Near X =  0.70234295      -1.2147688      0.29563535    , d:   0.0000000      -1.6762186       1.3300624
 i,j,k,ie:    1    1    5          57
 Near X = -0.16139079E-06  -1.3676209      0.13437970    , d:  0.68386921       0.0000000       1.3300624
 i,j,k,ie:    2    1    5          57
 Near X = -0.16139079E-06  -1.3676209      0.15332278    , d:  0.68386921       0.0000000       1.3300624
 i,j,k,ie:    3    1    5          57
 Near X = -0.16139079E-06  -1.3676209      0.19200993    , d:  0.68386921       0.0000000       1.3300624
 i,j,k,ie:    4    1    5          57
 Near X = -0.16139079E-06  -1.3676209      0.23800512    , d:  0.68386921       0.0000000       1.3300624
 i,j,k,ie:    5    1    5          57
 Near X = -0.16139079E-06  -1.3676209      0.27669227    , d:  0.68386921       0.0000000       1.3300624
 i,j,k,ie:    6    1    5          57
 Near X = -0.16139079E-06  -1.3676209      0.29563535    , d:   1.1837511     -0.68386892       1.3300624
 i,j,k,ie:    6    2    5          57
 Near X =  0.80985142E-01  -1.3484415      0.29563535    , d:   0.0000000     -0.68516921       1.3300624
 i,j,k,ie:    6    3    5          57
 Near X =  0.24584226      -1.3072702      0.29563535    , d:   0.0000000     -0.68674875       1.3300624
 i,j,k,ie:    6    4    5          57
 Near X =  0.44090139      -1.2548247      0.29563535    , d:   0.0000000     -0.68674691       1.3300624
 i,j,k,ie:    6    5    5          57
 Near X =  0.60417776      -1.2077708      0.29563535    , d:   0.0000000     -0.68516427       1.3300624
 i,j,k,ie:    1    6    5          57
 Near X =  0.68386231      -1.1837509      0.13437970    , d:   0.0000000      -1.2042710       1.3300624
 i,j,k,ie:    2    6    5          57
 Near X =  0.68386231      -1.1837509      0.15332278    , d:   0.0000000      -1.2042710       1.3300624
 i,j,k,ie:    3    6    5          57
 Near X =  0.68386231      -1.1837509      0.19200993    , d:   0.0000000      -1.2042710       1.3300624
 i,j,k,ie:    4    6    5          57
 Near X =  0.68386231      -1.1837509      0.23800512    , d:   0.0000000      -1.2042710       1.3300624
 i,j,k,ie:    5    6    5          57
 Near X =  0.68386231      -1.1837509      0.27669227    , d:   0.0000000      -1.2042710       1.3300624
 i,j,k,ie:    6    6    5          57
 Near X =  0.68386231      -1.1837509      0.29563535    , d:   0.0000000      -1.5850541       1.3300624
 i,j,k,ie:    1    1    6          57
 Near X = -0.15931032E-06  -1.3500000      0.13437970    , d:  0.75195073     -0.17710317E-07   1.3300624
 i,j,k,ie:    2    1    6          57
 Near X = -0.15931032E-06  -1.3500000      0.15332278    , d:  0.75195073     -0.17710317E-07   1.3300624
 i,j,k,ie:    3    1    6          57
 Near X = -0.15931032E-06  -1.3500000      0.19200993    , d:  0.75195073     -0.17710317E-07   1.3300624
 i,j,k,ie:    4    1    6          57
 Near X = -0.15931032E-06  -1.3500000      0.23800512    , d:  0.75195073     -0.17710317E-07   1.3300624
 i,j,k,ie:    5    1    6          57
 Near X = -0.15931032E-06  -1.3500000      0.27669227    , d:  0.75195073     -0.17710317E-07   1.3300624
 i,j,k,ie:    6    1    6          57
 Near X = -0.15931032E-06  -1.3500000      0.29563535    , d:   1.2978519     -0.75195045       1.3300624
 i,j,k,ie:    1    2    6          57
 Near X =  0.79271756E-01  -1.3286862      0.13437970    , d:  0.14585443E-01   0.0000000       1.3300624
 i,j,k,ie:    2    2    6          57
 Near X =  0.79271756E-01  -1.3286862      0.15332278    , d:  0.14585443E-01   0.0000000       1.3300624
 i,j,k,ie:    3    2    6          57
 Near X =  0.79271756E-01  -1.3286862      0.19200993    , d:  0.14585443E-01   0.0000000       1.3300624
 i,j,k,ie:    4    2    6          57
 Near X =  0.79271756E-01  -1.3286862      0.23800512    , d:  0.14585443E-01   0.0000000       1.3300624
 i,j,k,ie:    5    2    6          57
 Near X =  0.79271756E-01  -1.3286862      0.27669227    , d:  0.14585443E-01   0.0000000       1.3300624
 i,j,k,ie:    6    2    6          57
 Near X =  0.79271756E-01  -1.3286862      0.29563535    , d:  0.14585443E-01 -0.74842783       1.3300624
 i,j,k,ie:    1    3    6          57
 Near X =  0.24116754      -1.2851573      0.13437970    , d:  0.39794265E-01   0.0000000       1.3300624
 i,j,k,ie:    2    3    6          57
 Near X =  0.24116754      -1.2851573      0.15332278    , d:  0.39794265E-01   0.0000000       1.3300624
 i,j,k,ie:    3    3    6          57
 Near X =  0.24116754      -1.2851573      0.19200993    , d:  0.39794265E-01   0.0000000       1.3300624
 i,j,k,ie:    4    3    6          57
 Near X =  0.24116754      -1.2851573      0.23800512    , d:  0.39794265E-01   0.0000000       1.3300624
 i,j,k,ie:    5    3    6          57
 Near X =  0.24116754      -1.2851573      0.27669227    , d:  0.39794265E-01   0.0000000       1.3300624
 i,j,k,ie:    6    3    6          57
 Near X =  0.24116754      -1.2851573      0.29563535    , d:  0.39794265E-01 -0.73665283       1.3300624
 i,j,k,ie:    1    4    6          57
 Near X =  0.43364560      -1.2334058      0.13437970    , d:  0.61765923E-01   0.0000000       1.3300624
 i,j,k,ie:    2    4    6          57
 Near X =  0.43364560      -1.2334058      0.15332278    , d:  0.61765923E-01   0.0000000       1.3300624
 i,j,k,ie:    3    4    6          57
 Near X =  0.43364560      -1.2334058      0.19200993    , d:  0.61765923E-01   0.0000000       1.3300624
 i,j,k,ie:    4    4    6          57
 Near X =  0.43364560      -1.2334058      0.23800512    , d:  0.61765923E-01   0.0000000       1.3300624
 i,j,k,ie:    5    4    6          57
 Near X =  0.43364560      -1.2334058      0.27669227    , d:  0.61765923E-01   0.0000000       1.3300624
 i,j,k,ie:    6    4    6          57
 Near X =  0.43364560      -1.2334058      0.29563535    , d:  0.61765923E-01 -0.71465093       1.3300624
 i,j,k,ie:    1    5    6          57
 Near X =  0.59554139      -1.1898769      0.13437970    , d:  0.73518391E-01   0.0000000       1.3300624
 i,j,k,ie:    2    5    6          57
 Near X =  0.59554139      -1.1898769      0.15332278    , d:  0.73518391E-01   0.0000000       1.3300624
 i,j,k,ie:    3    5    6          57
 Near X =  0.59554139      -1.1898769      0.19200993    , d:  0.73518391E-01   0.0000000       1.3300624
 i,j,k,ie:    4    5    6          57
 Near X =  0.59554139      -1.1898769      0.23800512    , d:  0.73518391E-01   0.0000000       1.3300624
 i,j,k,ie:    5    5    6          57
 Near X =  0.59554139      -1.1898769      0.27669227    , d:  0.73518391E-01   0.0000000       1.3300624
 i,j,k,ie:    6    5    6          57
 Near X =  0.59554139      -1.1898769      0.29563535    , d:  0.73518391E-01 -0.68941378       1.3300624
 i,j,k,ie:    1    6    6          57
 Near X =  0.67481330      -1.1685631      0.13437970    , d:  0.77030946E-01  -1.3496201       1.3300624
 i,j,k,ie:    2    6    6          57
 Near X =  0.67481330      -1.1685631      0.15332278    , d:  0.77030946E-01  -1.3496201       1.3300624
 i,j,k,ie:    3    6    6          57
 Near X =  0.67481330      -1.1685631      0.19200993    , d:  0.77030946E-01  -1.3496201       1.3300624
 i,j,k,ie:    4    6    6          57
 Near X =  0.67481330      -1.1685631      0.23800512    , d:  0.77030946E-01  -1.3496201       1.3300624
 i,j,k,ie:    5    6    6          57
 Near X =  0.67481330      -1.1685631      0.27669227    , d:  0.77030946E-01  -1.3496201       1.3300624
 i,j,k,ie:    6    6    6          57
 Near X =  0.67481330      -1.1685631      0.29563535    , d:  0.77030946E-01  -1.8433764       1.3300624
 i,j,k,ie:    1    1    1          58
 Near X = -0.75195061      -1.2977934      0.13437970    , d:   2.0498024       0.0000000       1.3298746
 i,j,k,ie:    2    1    1          58
 Near X = -0.75195061      -1.2977934      0.15332278    , d:   2.0498024       0.0000000       1.3298746
 i,j,k,ie:    3    1    1          58
 Near X = -0.75195061      -1.2977934      0.19200993    , d:   2.0498024       0.0000000       1.3298746
 i,j,k,ie:    4    1    1          58
 Near X = -0.75195061      -1.2977934      0.23800512    , d:   2.0498024       0.0000000       1.3298746
 i,j,k,ie:    5    1    1          58
 Near X = -0.75195061      -1.2977934      0.27669227    , d:   2.0498024       0.0000000       1.3298746
 i,j,k,ie:    6    1    1          58
 Near X = -0.75195061      -1.2977934      0.29563535    , d:   2.2519506     -0.54590114       1.3298746
 i,j,k,ie:    1    2    1          58
 Near X = -0.66915607      -1.3421555      0.13437970    , d:  0.76301327       0.0000000       1.3298746
 i,j,k,ie:    2    2    1          58
 Near X = -0.66915607      -1.3421555      0.15332278    , d:  0.73620366E-01   0.0000000       1.3298746
 i,j,k,ie:    3    2    1          58
 Near X = -0.66915607      -1.3421555      0.19200993    , d:  0.73620366E-01   0.0000000       1.3298746
 i,j,k,ie:    4    2    1          58
 Near X = -0.66915607      -1.3421555      0.23800512    , d:  0.73620366E-01   0.0000000       1.3298746
 i,j,k,ie:    5    2    1          58
 Near X = -0.66915607      -1.3421555      0.27669227    , d:  0.73620366E-01   0.0000000       1.3298746
 i,j,k,ie:    6    2    1          58
 Near X = -0.66915607      -1.3421555      0.29563535    , d:  0.73620366E-01 -0.57941397       1.3298746
 i,j,k,ie:    1    3    1          58
 Near X = -0.49548529      -1.4157117      0.13437970    , d:  0.77644709       0.0000000       1.3298746
 i,j,k,ie:    2    3    1          58
 Near X = -0.49548529      -1.4157117      0.15332278    , d:  0.61843735E-01   0.0000000       1.3298746
 i,j,k,ie:    3    3    1          58
 Near X = -0.49548529      -1.4157117      0.19200993    , d:  0.61843735E-01   0.0000000       1.3298746
 i,j,k,ie:    4    3    1          58
 Near X = -0.49548529      -1.4157117      0.23800512    , d:  0.61843735E-01   0.0000000       1.3298746
 i,j,k,ie:    5    3    1          58
 Near X = -0.49548529      -1.4157117      0.27669227    , d:  0.61843735E-01   0.0000000       1.3298746
 i,j,k,ie:    6    3    1          58
 Near X = -0.49548529      -1.4157117      0.29563535    , d:  0.61843735E-01 -0.64015888       1.3298746
 i,j,k,ie:    1    4    1          58
 Near X = -0.28100533      -1.4733874      0.13437970    , d:  0.77641686       0.0000000       1.3298746
 i,j,k,ie:    2    4    1          58
 Near X = -0.28100533      -1.4733874      0.15332278    , d:  0.39839901E-01   0.0000000       1.3298746
 i,j,k,ie:    3    4    1          58
 Near X = -0.28100533      -1.4733874      0.19200993    , d:  0.39839901E-01   0.0000000       1.3298746
 i,j,k,ie:    4    4    1          58
 Near X = -0.28100533      -1.4733874      0.23800512    , d:  0.39839901E-01   0.0000000       1.3298746
 i,j,k,ie:    5    4    1          58
 Near X = -0.28100533      -1.4733874      0.27669227    , d:  0.39839901E-01   0.0000000       1.3298746
 i,j,k,ie:    6    4    1          58
 Near X = -0.28100533      -1.4733874      0.29563535    , d:  0.39839901E-01 -0.69893063       1.3298746
 i,j,k,ie:    1    5    1          58
 Near X = -0.93872392E-01  -1.4968547      0.13437970    , d:  0.76293217       0.0000000       1.3298746
 i,j,k,ie:    2    5    1          58
 Near X = -0.93872392E-01  -1.4968547      0.15332278    , d:  0.14601116E-01   0.0000000       1.3298746
 i,j,k,ie:    3    5    1          58
 Near X = -0.93872392E-01  -1.4968547      0.19200993    , d:  0.14601116E-01   0.0000000       1.3298746
 i,j,k,ie:    4    5    1          58
 Near X = -0.93872392E-01  -1.4968547      0.23800512    , d:  0.14601116E-01   0.0000000       1.3298746
 i,j,k,ie:    5    5    1          58
 Near X = -0.93872392E-01  -1.4968547      0.27669227    , d:  0.14601116E-01   0.0000000       1.3298746
 i,j,k,ie:    6    5    1          58
 Near X = -0.93872392E-01  -1.4968547      0.29563535    , d:  0.14601116E-01 -0.73705308       1.3298746
 i,j,k,ie:    1    6    1          58
 Near X = -0.17702063E-06  -1.5000000      0.13437970    , d:  0.75184442      -1.1685629       1.3298746
 i,j,k,ie:    2    6    1          58
 Near X = -0.17702063E-06  -1.5000000      0.15332278    , d:  0.17710317E-07  -1.1685629       1.3298746
 i,j,k,ie:    3    6    1          58
 Near X = -0.17702063E-06  -1.5000000      0.19200993    , d:  0.17710317E-07  -1.1685629       1.3298746
 i,j,k,ie:    4    6    1          58
 Near X = -0.17702063E-06  -1.5000000      0.23800512    , d:  0.17710317E-07  -1.1685629       1.3298746
 i,j,k,ie:    5    6    1          58
 Near X = -0.17702063E-06  -1.5000000      0.27669227    , d:  0.17710317E-07  -1.1685629       1.3298746
 i,j,k,ie:    6    6    1          58
 Near X = -0.17702063E-06  -1.5000000      0.29563535    , d:  0.17710317E-07  -1.3499998       1.3298746
 i,j,k,ie:    1    1    2          58
 Near X = -0.74288835      -1.2826094      0.13437970    , d:   2.0255523       0.0000000       1.3298746
 i,j,k,ie:    2    1    2          58
 Near X = -0.74288835      -1.2826094      0.15332278    , d:   2.0255523       0.0000000       1.3298746
 i,j,k,ie:    3    1    2          58
 Near X = -0.74288835      -1.2826094      0.19200993    , d:   2.0255523       0.0000000       1.3298746
 i,j,k,ie:    4    1    2          58
 Near X = -0.74288835      -1.2826094      0.23800512    , d:   2.0255523       0.0000000       1.3298746
 i,j,k,ie:    5    1    2          58
 Near X = -0.74288835      -1.2826094      0.27669227    , d:   2.0255523       0.0000000       1.3298746
 i,j,k,ie:    6    1    2          58
 Near X = -0.74288835      -1.2826094      0.29563535    , d:   2.2252675     -0.53977556       1.3298746
 i,j,k,ie:    1    2    2          58
 Near X = -0.66050772      -1.3242644      0.13437970    , d:  0.75265153       0.0000000       1.3298746
 i,j,k,ie:    6    2    2          58
 Near X = -0.66050772      -1.3242644      0.29563535    , d:   0.0000000     -0.57185001       1.3298746
 i,j,k,ie:    1    3    2          58
 Near X = -0.48822036      -1.3942939      0.13437970    , d:  0.76450744       0.0000000       1.3298746
 i,j,k,ie:    6    3    2          58
 Near X = -0.48822036      -1.3942939      0.29563535    , d:   0.0000000     -0.63056161       1.3298746
 i,j,k,ie:    1    4    2          58
 Near X = -0.27632524      -1.4512745      0.13437970    , d:  0.76448098       0.0000000       1.3298746
 i,j,k,ie:    6    4    2          58
 Near X = -0.27632524      -1.4512745      0.29563535    , d:   0.0000000     -0.68849573       1.3298746
 i,j,k,ie:    1    5    2          58
 Near X = -0.92157165E-01  -1.4770992      0.13437970    , d:  0.75258056       0.0000000       1.3298746
 i,j,k,ie:    6    5    2          58
 Near X = -0.92157165E-01  -1.4770992      0.29563535    , d:   0.0000000     -0.72724239       1.3298746
 i,j,k,ie:    1    6    2          58
 Near X = -0.17494016E-06  -1.4823791      0.13437970    , d:  0.74279542      -1.1329734       1.3298746
 i,j,k,ie:    2    6    2          58
 Near X = -0.17494016E-06  -1.4823791      0.15332278    , d:   0.0000000      -1.1329734       1.3298746
 i,j,k,ie:    3    6    2          58
 Near X = -0.17494016E-06  -1.4823791      0.19200993    , d:   0.0000000      -1.1329734       1.3298746
 i,j,k,ie:    4    6    2          58
 Near X = -0.17494016E-06  -1.4823791      0.23800512    , d:   0.0000000      -1.1329734       1.3298746
 i,j,k,ie:    5    6    2          58
 Near X = -0.17494016E-06  -1.4823791      0.27669227    , d:   0.0000000      -1.1329734       1.3298746
 i,j,k,ie:    6    6    2          58
 Near X = -0.17494016E-06  -1.4823791      0.29563535    , d:   0.0000000      -1.3088845       1.3298746
 i,j,k,ie:    1    1    3          58
 Near X = -0.72438064      -1.2515996      0.13437970    , d:   1.9760267       0.0000000       1.3298746
 i,j,k,ie:    2    1    3          58
 Near X = -0.72438064      -1.2515996      0.15332278    , d:   1.9760267       0.0000000       1.3298746
 i,j,k,ie:    3    1    3          58
 Near X = -0.72438064      -1.2515996      0.19200993    , d:   1.9760267       0.0000000       1.3298746
 i,j,k,ie:    4    1    3          58
 Near X = -0.72438064      -1.2515996      0.23800512    , d:   1.9760267       0.0000000       1.3298746
 i,j,k,ie:    5    1    3          58
 Near X = -0.72438064      -1.2515996      0.27669227    , d:   1.9760267       0.0000000       1.3298746
 i,j,k,ie:    6    1    3          58
 Near X = -0.72438064      -1.2515996      0.29563535    , d:   2.1707730     -0.52726538       1.3298746
 i,j,k,ie:    1    2    3          58
 Near X = -0.64284532      -1.2877256      0.13437970    , d:  0.73148991       0.0000000       1.3298746
 i,j,k,ie:    6    2    3          58
 Near X = -0.64284532      -1.2877256      0.29563535    , d:   0.0000000     -0.55640225       1.3298746
 i,j,k,ie:    1    3    3          58
 Near X = -0.47338332      -1.3505527      0.13437970    , d:  0.74012327       0.0000000       1.3298746
 i,j,k,ie:    6    3    3          58
 Near X = -0.47338332      -1.3505527      0.29563535    , d:   0.0000000     -0.61096128       1.3298746
 i,j,k,ie:    1    4    3          58
 Near X = -0.26676718      -1.4061137      0.13437970    , d:  0.74010454       0.0000000       1.3298746
 i,j,k,ie:    6    4    3          58
 Near X = -0.26676718      -1.4061137      0.29563535    , d:   0.0000000     -0.66718471       1.3298746
 i,j,k,ie:    1    5    3          58
 Near X = -0.88654183E-01  -1.4367529      0.13437970    , d:  0.73143965       0.0000000       1.3298746
 i,j,k,ie:    6    5    3          58
 Near X = -0.88654183E-01  -1.4367529      0.29563535    , d:   0.0000000     -0.70720619       1.3298746
 i,j,k,ie:    1    6    3          58
 Near X = -0.17069125E-06  -1.4463924      0.13437970    , d:  0.72431477      -1.0602895       1.3298746
 i,j,k,ie:    2    6    3          58
 Near X = -0.17069125E-06  -1.4463924      0.15332278    , d:   0.0000000      -1.0602895       1.3298746
 i,j,k,ie:    3    6    3          58
 Near X = -0.17069125E-06  -1.4463924      0.19200993    , d:   0.0000000      -1.0602895       1.3298746
 i,j,k,ie:    4    6    3          58
 Near X = -0.17069125E-06  -1.4463924      0.23800512    , d:   0.0000000      -1.0602895       1.3298746
 i,j,k,ie:    5    6    3          58
 Near X = -0.17069125E-06  -1.4463924      0.27669227    , d:   0.0000000      -1.0602895       1.3298746
 i,j,k,ie:    6    6    3          58
 Near X = -0.17069125E-06  -1.4463924      0.29563535    , d:   0.0000000      -1.2249154       1.3298746
 i,j,k,ie:    1    1    4          58
 Near X = -0.70237680      -1.2147319      0.13437970    , d:   1.9171456       0.0000000       1.3298746
 i,j,k,ie:    2    1    4          58
 Near X = -0.70237680      -1.2147319      0.15332278    , d:   1.9171456       0.0000000       1.3298746
 i,j,k,ie:    3    1    4          58
 Near X = -0.70237680      -1.2147319      0.19200993    , d:   1.9171456       0.0000000       1.3298746
 i,j,k,ie:    4    1    4          58
 Near X = -0.70237680      -1.2147319      0.23800512    , d:   1.9171456       0.0000000       1.3298746
 i,j,k,ie:    5    1    4          58
 Near X = -0.70237680      -1.2147319      0.27669227    , d:   1.9171456       0.0000000       1.3298746
 i,j,k,ie:    6    1    4          58
 Near X = -0.70237680      -1.2147319      0.29563535    , d:   2.1059845     -0.51239201       1.3298746
 i,j,k,ie:    1    2    4          58
 Near X = -0.62184647      -1.2442847      0.13437970    , d:  0.70633083       0.0000000       1.3298746
 i,j,k,ie:    6    2    4          58
 Near X = -0.62184647      -1.2442847      0.29563535    , d:   0.0000000     -0.53803639       1.3298746
 i,j,k,ie:    1    3    4          58
 Near X = -0.45574353      -1.2985487      0.13437970    , d:  0.71113291       0.0000000       1.3298746
 i,j,k,ie:    6    3    4          58
 Near X = -0.45574353      -1.2985487      0.29563535    , d:   0.0000000     -0.58765842       1.3298746
 i,j,k,ie:    1    4    4          58
 Near X = -0.25540358      -1.3524220      0.13437970    , d:  0.71112335       0.0000000       1.3298746
 i,j,k,ie:    6    4    4          58
 Near X = -0.25540358      -1.3524220      0.29563535    , d:   0.0000000     -0.64184802       1.3298746
 i,j,k,ie:    1    5    4          58
 Near X = -0.84489485E-01  -1.3887851      0.13437970    , d:  0.70630519       0.0000000       1.3298746
 i,j,k,ie:    6    5    4          58
 Near X = -0.84489485E-01  -1.3887851      0.29563535    , d:   0.0000000     -0.68338513       1.3298746
 i,j,k,ie:    1    6    4          58
 Near X = -0.16563971E-06  -1.4036076      0.13437970    , d:  0.70234311     -0.97387552       1.3298746
 i,j,k,ie:    2    6    4          58
 Near X = -0.16563971E-06  -1.4036076      0.15332278    , d:   0.0000000     -0.97387552       1.3298746
 i,j,k,ie:    3    6    4          58
 Near X = -0.16563971E-06  -1.4036076      0.19200993    , d:   0.0000000     -0.97387552       1.3298746
 i,j,k,ie:    4    6    4          58
 Near X = -0.16563971E-06  -1.4036076      0.23800512    , d:   0.0000000     -0.97387552       1.3298746
 i,j,k,ie:    5    6    4          58
 Near X = -0.16563971E-06  -1.4036076      0.27669227    , d:   0.0000000     -0.97387552       1.3298746
 i,j,k,ie:    6    6    4          58
 Near X = -0.16563971E-06  -1.4036076      0.29563535    , d:   0.0000000      -1.1250843       1.3298746
 i,j,k,ie:    1    1    5          58
 Near X = -0.68386909      -1.1837220      0.13437970    , d:   1.8676200       0.0000000       1.3298746
 i,j,k,ie:    2    1    5          58
 Near X = -0.68386909      -1.1837220      0.15332278    , d:   1.8676200       0.0000000       1.3298746
 i,j,k,ie:    3    1    5          58
 Near X = -0.68386909      -1.1837220      0.19200993    , d:   1.8676200       0.0000000       1.3298746
 i,j,k,ie:    4    1    5          58
 Near X = -0.68386909      -1.1837220      0.23800512    , d:   1.8676200       0.0000000       1.3298746
 i,j,k,ie:    5    1    5          58
 Near X = -0.68386909      -1.1837220      0.27669227    , d:   1.8676200       0.0000000       1.3298746
 i,j,k,ie:    6    1    5          58
 Near X = -0.68386909      -1.1837220      0.29563535    , d:   2.0514900     -0.49988183       1.3298746
 i,j,k,ie:    1    2    5          58
 Near X = -0.60418407      -1.2077459      0.13437970    , d:  0.68516921       0.0000000       1.3298746
 i,j,k,ie:    6    2    5          58
 Near X = -0.60418407      -1.2077459      0.29563535    , d:   0.0000000     -0.52258863       1.3298746
 i,j,k,ie:    1    3    5          58
 Near X = -0.44090648      -1.2548075      0.13437970    , d:  0.68674875       0.0000000       1.3298746
 i,j,k,ie:    6    3    5          58
 Near X = -0.44090648      -1.2548075      0.29563535    , d:   0.0000000     -0.56805808       1.3298746
 i,j,k,ie:    1    4    5          58
 Near X = -0.24584551      -1.3072613      0.13437970    , d:  0.68674691       0.0000000       1.3298746
 i,j,k,ie:    6    4    5          58
 Near X = -0.24584551      -1.3072613      0.29563535    , d:   0.0000000     -0.62053700       1.3298746
 i,j,k,ie:    1    5    5          58
 Near X = -0.80986503E-01  -1.3484388      0.13437970    , d:  0.68516427       0.0000000       1.3298746
 i,j,k,ie:    6    5    5          58
 Near X = -0.80986503E-01  -1.3484388      0.29563535    , d:   0.0000000     -0.66334893       1.3298746
 i,j,k,ie:    1    6    5          58
 Near X = -0.16139079E-06  -1.3676209      0.13437970    , d:  0.68386247     -0.90119162       1.3298746
 i,j,k,ie:    2    6    5          58
 Near X = -0.16139079E-06  -1.3676209      0.15332278    , d:   0.0000000     -0.90119162       1.3298746
 i,j,k,ie:    3    6    5          58
 Near X = -0.16139079E-06  -1.3676209      0.19200993    , d:   0.0000000     -0.90119162       1.3298746
 i,j,k,ie:    4    6    5          58
 Near X = -0.16139079E-06  -1.3676209      0.23800512    , d:   0.0000000     -0.90119162       1.3298746
 i,j,k,ie:    5    6    5          58
 Near X = -0.16139079E-06  -1.3676209      0.27669227    , d:   0.0000000     -0.90119162       1.3298746
 i,j,k,ie:    6    6    5          58
 Near X = -0.16139079E-06  -1.3676209      0.29563535    , d:   0.0000000      -1.0411152       1.3298746
 i,j,k,ie:    1    1    6          58
 Near X = -0.67480683      -1.1685381      0.13437970    , d:   1.9726586     -0.77143785E-01   1.3298746
 i,j,k,ie:    2    1    6          58
 Near X = -0.67480683      -1.1685381      0.15332278    , d:   1.9726586     -0.77143785E-01   1.3298746
 i,j,k,ie:    3    1    6          58
 Near X = -0.67480683      -1.1685381      0.19200993    , d:   1.9726586     -0.77143785E-01   1.3298746
 i,j,k,ie:    4    1    6          58
 Near X = -0.67480683      -1.1685381      0.23800512    , d:   1.9726586     -0.77143785E-01   1.3298746
 i,j,k,ie:    5    1    6          58
 Near X = -0.67480683      -1.1685381      0.27669227    , d:   1.9726586     -0.77143785E-01   1.3298746
 i,j,k,ie:    6    1    6          58
 Near X = -0.67480683      -1.1685381      0.29563535    , d:   2.1748068     -0.62304493       1.3298746
 i,j,k,ie:    1    2    6          58
 Near X = -0.59553571      -1.1898548      0.13437970    , d:  0.68939291     -0.73620366E-01   1.3298746
 i,j,k,ie:    2    2    6          58
 Near X = -0.59553571      -1.1898548      0.15332278    , d:   0.0000000     -0.73620366E-01   1.3298746
 i,j,k,ie:    3    2    6          58
 Near X = -0.59553571      -1.1898548      0.19200993    , d:   0.0000000     -0.73620366E-01   1.3298746
 i,j,k,ie:    4    2    6          58
 Near X = -0.59553571      -1.1898548      0.23800512    , d:   0.0000000     -0.73620366E-01   1.3298746
 i,j,k,ie:    5    2    6          58
 Near X = -0.59553571      -1.1898548      0.27669227    , d:   0.0000000     -0.73620366E-01   1.3298746
 i,j,k,ie:    6    2    6          58
 Near X = -0.59553571      -1.1898548      0.29563535    , d:   0.0000000     -0.65303434       1.3298746
 i,j,k,ie:    1    3    6          58
 Near X = -0.43364156      -1.2333897      0.13437970    , d:  0.71460336     -0.61843735E-01   1.3298746
 i,j,k,ie:    2    3    6          58
 Near X = -0.43364156      -1.2333897      0.15332278    , d:   0.0000000     -0.61843735E-01   1.3298746
 i,j,k,ie:    3    3    6          58
 Near X = -0.43364156      -1.2333897      0.19200993    , d:   0.0000000     -0.61843735E-01   1.3298746
 i,j,k,ie:    4    3    6          58
 Near X = -0.43364156      -1.2333897      0.23800512    , d:   0.0000000     -0.61843735E-01   1.3298746
 i,j,k,ie:    5    3    6          58
 Near X = -0.43364156      -1.2333897      0.27669227    , d:   0.0000000     -0.61843735E-01   1.3298746
 i,j,k,ie:    6    3    6          58
 Near X = -0.43364156      -1.2333897      0.29563535    , d:   0.0000000     -0.70200261       1.3298746
 i,j,k,ie:    1    4    6          58
 Near X = -0.24116543      -1.2851484      0.13437970    , d:  0.73657696     -0.39839901E-01   1.3298746
 i,j,k,ie:    2    4    6          58
 Near X = -0.24116543      -1.2851484      0.15332278    , d:   0.0000000     -0.39839901E-01   1.3298746
 i,j,k,ie:    3    4    6          58
 Near X = -0.24116543      -1.2851484      0.19200993    , d:   0.0000000     -0.39839901E-01   1.3298746
 i,j,k,ie:    4    4    6          58
 Near X = -0.24116543      -1.2851484      0.23800512    , d:   0.0000000     -0.39839901E-01   1.3298746
 i,j,k,ie:    5    4    6          58
 Near X = -0.24116543      -1.2851484      0.27669227    , d:   0.0000000     -0.39839901E-01   1.3298746
 i,j,k,ie:    6    4    6          58
 Near X = -0.24116543      -1.2851484      0.29563535    , d:   0.0000000     -0.73877053       1.3298746
 i,j,k,ie:    1    5    6          58
 Near X = -0.79271276E-01  -1.3286833      0.13437970    , d:  0.74833105     -0.14601116E-01   1.3298746
 i,j,k,ie:    2    5    6          58
 Near X = -0.79271276E-01  -1.3286833      0.15332278    , d:   0.0000000     -0.14601116E-01   1.3298746
 i,j,k,ie:    3    5    6          58
 Near X = -0.79271276E-01  -1.3286833      0.19200993    , d:   0.0000000     -0.14601116E-01   1.3298746
 i,j,k,ie:    4    5    6          58
 Near X = -0.79271276E-01  -1.3286833      0.23800512    , d:   0.0000000     -0.14601116E-01   1.3298746
 i,j,k,ie:    5    5    6          58
 Near X = -0.79271276E-01  -1.3286833      0.27669227    , d:   0.0000000     -0.14601116E-01   1.3298746
 i,j,k,ie:    6    5    6          58
 Near X = -0.79271276E-01  -1.3286833      0.29563535    , d:   0.0000000     -0.75165419       1.3298746
 i,j,k,ie:    1    6    6          58
 Near X = -0.15931032E-06  -1.3500000      0.13437970    , d:  0.75184441      -1.1685629       1.3298746
 i,j,k,ie:    2    6    6          58
 Near X = -0.15931032E-06  -1.3500000      0.15332278    , d:   0.0000000      -1.1685629       1.3298746
 i,j,k,ie:    3    6    6          58
 Near X = -0.15931032E-06  -1.3500000      0.19200993    , d:   0.0000000      -1.1685629       1.3298746
 i,j,k,ie:    4    6    6          58
 Near X = -0.15931032E-06  -1.3500000      0.23800512    , d:   0.0000000      -1.1685629       1.3298746
 i,j,k,ie:    5    6    6          58
 Near X = -0.15931032E-06  -1.3500000      0.27669227    , d:   0.0000000      -1.1685629       1.3298746
 i,j,k,ie:    6    6    6          58
 Near X = -0.15931032E-06  -1.3500000      0.29563535    , d:   0.0000000      -1.3499999       1.3298746
 i,j,k,ie:    1    1    1          59
 Near X =  -1.2978518     -0.75184434      0.13437970    , d:   2.7978518       0.0000000      0.77050402
 i,j,k,ie:    2    1    1          59
 Near X =  -1.2978518     -0.75184434      0.15332278    , d:   2.7978518       0.0000000      0.77050402
 i,j,k,ie:    3    1    1          59
 Near X =  -1.2978518     -0.75184434      0.19200993    , d:   2.7978518       0.0000000      0.77050402
 i,j,k,ie:    4    1    1          59
 Near X =  -1.2978518     -0.75184434      0.23800512    , d:   2.7978518       0.0000000      0.77050402
 i,j,k,ie:    5    1    1          59
 Near X =  -1.2978518     -0.75184434      0.27669227    , d:   2.7978518       0.0000000      0.77050402
 i,j,k,ie:    6    1    1          59
 Near X =  -1.2978518     -0.75184434      0.29563535    , d:   2.7978518     -0.20214825      0.77050402
 i,j,k,ie:    1    2    1          59
 Near X =  -1.2485700     -0.83082363      0.13437970    , d:  0.65303434       0.0000000      0.77050402
 i,j,k,ie:    2    2    1          59
 Near X =  -1.2485700     -0.83082363      0.15332278    , d:  0.13800967       0.0000000      0.77050402
 i,j,k,ie:    3    2    1          59
 Near X =  -1.2485700     -0.83082363      0.19200993    , d:  0.13800967       0.0000000      0.77050402
 i,j,k,ie:    4    2    1          59
 Near X =  -1.2485700     -0.83082363      0.23800512    , d:  0.13800967       0.0000000      0.77050402
 i,j,k,ie:    5    2    1          59
 Near X =  -1.2485700     -0.83082363      0.27669227    , d:  0.13800967       0.0000000      0.77050402
 i,j,k,ie:    6    2    1          59
 Near X =  -1.2485700     -0.83082363      0.29563535    , d:  0.13800967     -0.24828603      0.77050402
 i,j,k,ie:    1    3    1          59
 Near X =  -1.1356442     -0.97984416      0.13437970    , d:  0.70200261       0.0000000      0.77050402
 i,j,k,ie:    2    3    1          59
 Near X =  -1.1356442     -0.97984416      0.15332278    , d:  0.14354180       0.0000000      0.77050402
 i,j,k,ie:    3    3    1          59
 Near X =  -1.1356442     -0.97984416      0.19200993    , d:  0.14354180       0.0000000      0.77050402
 i,j,k,ie:    4    3    1          59
 Near X =  -1.1356442     -0.97984416      0.23800512    , d:  0.14354180       0.0000000      0.77050402
 i,j,k,ie:    5    3    1          59
 Near X =  -1.1356442     -0.97984416      0.27669227    , d:  0.14354180       0.0000000      0.77050402
 i,j,k,ie:    6    3    1          59
 Near X =  -1.1356442     -0.97984416      0.29563535    , d:  0.14354180     -0.33775181      0.77050402
 i,j,k,ie:    1    4    1          59
 Near X = -0.97993596      -1.1355660      0.13437970    , d:  0.73877053       0.0000000      0.77050402
 i,j,k,ie:    2    4    1          59
 Near X = -0.97993596      -1.1355660      0.15332278    , d:  0.12866843       0.0000000      0.77050402
 i,j,k,ie:    3    4    1          59
 Near X = -0.97993596      -1.1355660      0.19200993    , d:  0.12866843       0.0000000      0.77050402
 i,j,k,ie:    4    4    1          59
 Near X = -0.97993596      -1.1355660      0.23800512    , d:  0.12866843       0.0000000      0.77050402
 i,j,k,ie:    5    4    1          59
 Near X = -0.97993596      -1.1355660      0.27669227    , d:  0.12866843       0.0000000      0.77050402
 i,j,k,ie:    6    4    1          59
 Near X = -0.97993596      -1.1355660      0.29563535    , d:  0.12866843     -0.43580097      0.77050402
 i,j,k,ie:    1    5    1          59
 Near X = -0.83092547      -1.2485048      0.13437970    , d:  0.75165419       0.0000000      0.77050402
 i,j,k,ie:    2    5    1          59
 Near X = -0.83092547      -1.2485048      0.15332278    , d:  0.98115942E-01   0.0000000      0.77050402
 i,j,k,ie:    3    5    1          59
 Near X = -0.83092547      -1.2485048      0.19200993    , d:  0.98115942E-01   0.0000000      0.77050402
 i,j,k,ie:    4    5    1          59
 Near X = -0.83092547      -1.2485048      0.23800512    , d:  0.98115942E-01   0.0000000      0.77050402
 i,j,k,ie:    5    5    1          59
 Near X = -0.83092547      -1.2485048      0.27669227    , d:  0.98115942E-01   0.0000000      0.77050402
 i,j,k,ie:    6    5    1          59
 Near X = -0.83092547      -1.2485048      0.29563535    , d:  0.98115942E-01 -0.51127601      0.77050402
 i,j,k,ie:    1    6    1          59
 Near X = -0.75195061      -1.2977934      0.13437970    , d:  0.75195045     -0.59804941      0.77050402
 i,j,k,ie:    2    6    1          59
 Near X = -0.75195061      -1.2977934      0.15332278    , d:  0.77143785E-01 -0.59804941      0.77050402
 i,j,k,ie:    3    6    1          59
 Near X = -0.75195061      -1.2977934      0.19200993    , d:  0.77143785E-01 -0.59804941      0.77050402
 i,j,k,ie:    4    6    1          59
 Near X = -0.75195061      -1.2977934      0.23800512    , d:  0.77143785E-01 -0.59804941      0.77050402
 i,j,k,ie:    5    6    1          59
 Near X = -0.75195061      -1.2977934      0.27669227    , d:  0.77143785E-01 -0.59804941      0.77050402
 i,j,k,ie:    6    6    1          59
 Near X = -0.75195061      -1.2977934      0.29563535    , d:   1.9204887     -0.59804941      0.77050402
 i,j,k,ie:    1    1    2          59
 Near X =  -1.2826639     -0.74279534      0.13437970    , d:   2.7650431       0.0000000      0.77050402
 i,j,k,ie:    2    1    2          59
 Near X =  -1.2826639     -0.74279534      0.15332278    , d:   2.7650431       0.0000000      0.77050402
 i,j,k,ie:    3    1    2          59
 Near X =  -1.2826639     -0.74279534      0.19200993    , d:   2.7650431       0.0000000      0.77050402
 i,j,k,ie:    4    1    2          59
 Near X =  -1.2826639     -0.74279534      0.23800512    , d:   2.7650431       0.0000000      0.77050402
 i,j,k,ie:    5    1    2          59
 Near X =  -1.2826639     -0.74279534      0.27669227    , d:   2.7650431       0.0000000      0.77050402
 i,j,k,ie:    6    1    2          59
 Near X =  -1.2826639     -0.74279534      0.29563535    , d:   2.7650431     -0.19971524      0.77050402
 i,j,k,ie:    1    2    2          59
 Near X =  -1.2323577     -0.81931002      0.13437970    , d:  0.57185001       0.0000000      0.77050402
 i,j,k,ie:    6    2    2          59
 Near X =  -1.2323577     -0.81931002      0.29563535    , d:   0.0000000     -0.24474304      0.77050402
 i,j,k,ie:    1    3    2          59
 Near X =  -1.1187820     -0.96473941      0.13437970    , d:  0.63056161       0.0000000      0.77050402
 i,j,k,ie:    6    3    2          59
 Near X =  -1.1187820     -0.96473941      0.29563535    , d:   0.0000000     -0.33250117      0.77050402
 i,j,k,ie:    1    4    2          59
 Near X = -0.96482098      -1.1187114      0.13437970    , d:  0.68849573       0.0000000      0.77050402
 i,j,k,ie:    6    4    2          59
 Near X = -0.96482098      -1.1187114      0.29563535    , d:   0.0000000     -0.42949709      0.77050402
 i,j,k,ie:    1    5    2          59
 Near X = -0.81939956      -1.2322977      0.13437970    , d:  0.72724239       0.0000000      0.77050402
 i,j,k,ie:    6    5    2          59
 Near X = -0.81939956      -1.2322977      0.29563535    , d:   0.0000000     -0.50490800      0.77050402
 i,j,k,ie:    1    6    2          59
 Near X = -0.74288835      -1.2826094      0.13437970    , d:  0.74288817     -0.56599635      0.77050402
 i,j,k,ie:    2    6    2          59
 Near X = -0.74288835      -1.2826094      0.15332278    , d:   0.0000000     -0.56599635      0.77050402
 i,j,k,ie:    3    6    2          59
 Near X = -0.74288835      -1.2826094      0.19200993    , d:   0.0000000     -0.56599635      0.77050402
 i,j,k,ie:    4    6    2          59
 Near X = -0.74288835      -1.2826094      0.23800512    , d:   0.0000000     -0.56599635      0.77050402
 i,j,k,ie:    5    6    2          59
 Near X = -0.74288835      -1.2826094      0.27669227    , d:   0.0000000     -0.56599635      0.77050402
 i,j,k,ie:    6    6    2          59
 Near X = -0.74288835      -1.2826094      0.29563535    , d:   1.8758377     -0.56599635      0.77050402
 i,j,k,ie:    1    1    3          59
 Near X =  -1.2516460     -0.72431469      0.13437970    , d:   2.6980384       0.0000000      0.77050402
 i,j,k,ie:    2    1    3          59
 Near X =  -1.2516460     -0.72431469      0.15332278    , d:   2.6980384       0.0000000      0.77050402
 i,j,k,ie:    3    1    3          59
 Near X =  -1.2516460     -0.72431469      0.19200993    , d:   2.6980384       0.0000000      0.77050402
 i,j,k,ie:    4    1    3          59
 Near X =  -1.2516460     -0.72431469      0.23800512    , d:   2.6980384       0.0000000      0.77050402
 i,j,k,ie:    5    1    3          59
 Near X =  -1.2516460     -0.72431469      0.27669227    , d:   2.6980384       0.0000000      0.77050402
 i,j,k,ie:    6    1    3          59
 Near X =  -1.2516460     -0.72431469      0.29563535    , d:   2.6980384     -0.19474635      0.77050402
 i,j,k,ie:    1    2    3          59
 Near X =  -1.1992476     -0.79579596      0.13437970    , d:  0.55640225       0.0000000      0.77050402
 i,j,k,ie:    6    2    3          59
 Near X =  -1.1992476     -0.79579596      0.29563535    , d:   0.0000000     -0.23750725      0.77050402
 i,j,k,ie:    1    3    3          59
 Near X =  -1.0843446     -0.93389121      0.13437970    , d:  0.61096128       0.0000000      0.77050402
 i,j,k,ie:    6    3    3          59
 Near X =  -1.0843446     -0.93389121      0.29563535    , d:   0.0000000     -0.32177786      0.77050402
 i,j,k,ie:    1    4    3          59
 Near X = -0.93395189      -1.0842895      0.13437970    , d:  0.66718471       0.0000000      0.77050402
 i,j,k,ie:    6    4    3          59
 Near X = -0.93395189      -1.0842895      0.29563535    , d:   0.0000000     -0.41662276      0.77050402
 i,j,k,ie:    1    5    3          59
 Near X = -0.79586038      -1.1991980      0.13437970    , d:  0.70720619       0.0000000      0.77050402
 i,j,k,ie:    6    5    3          59
 Near X = -0.79586038      -1.1991980      0.29563535    , d:   0.0000000     -0.49190270      0.77050402
 i,j,k,ie:    1    6    3          59
 Near X = -0.72438064      -1.2515996      0.13437970    , d:  0.72438047     -0.50053490      0.77050402
 i,j,k,ie:    2    6    3          59
 Near X = -0.72438064      -1.2515996      0.15332278    , d:   0.0000000     -0.50053490      0.77050402
 i,j,k,ie:    3    6    3          59
 Near X = -0.72438064      -1.2515996      0.19200993    , d:   0.0000000     -0.50053490      0.77050402
 i,j,k,ie:    4    6    3          59
 Near X = -0.72438064      -1.2515996      0.23800512    , d:   0.0000000     -0.50053490      0.77050402
 i,j,k,ie:    5    6    3          59
 Near X = -0.72438064      -1.2515996      0.27669227    , d:   0.0000000     -0.50053490      0.77050402
 i,j,k,ie:    6    6    3          59
 Near X = -0.72438064      -1.2515996      0.29563535    , d:   1.7846476     -0.52726538      0.77050402
 i,j,k,ie:    1    1    4          59
 Near X =  -1.2147688     -0.70234304      0.13437970    , d:   2.6183765       0.0000000      0.77050402
 i,j,k,ie:    2    1    4          59
 Near X =  -1.2147688     -0.70234304      0.15332278    , d:   2.6183765       0.0000000      0.77050402
 i,j,k,ie:    3    1    4          59
 Near X =  -1.2147688     -0.70234304      0.19200993    , d:   2.6183765       0.0000000      0.77050402
 i,j,k,ie:    4    1    4          59
 Near X =  -1.2147688     -0.70234304      0.23800512    , d:   2.6183765       0.0000000      0.77050402
 i,j,k,ie:    5    1    4          59
 Near X =  -1.2147688     -0.70234304      0.27669227    , d:   2.6183765       0.0000000      0.77050402
 i,j,k,ie:    6    1    4          59
 Near X =  -1.2147688     -0.70234304      0.29563535    , d:   2.6183765     -0.18883884      0.77050402
 i,j,k,ie:    1    2    4          59
 Near X =  -1.1598829     -0.76784006      0.13437970    , d:  0.53803639       0.0000000      0.77050402
 i,j,k,ie:    6    2    4          59
 Near X =  -1.1598829     -0.76784006      0.29563535    , d:   0.0000000     -0.22890461      0.77050402
 i,j,k,ie:    1    3    4          59
 Near X =  -1.0434019     -0.89721576      0.13437970    , d:  0.58765842       0.0000000      0.77050402
 i,j,k,ie:    6    3    4          59
 Near X =  -1.0434019     -0.89721576      0.29563535    , d:   0.0000000     -0.30902890      0.77050402
 i,j,k,ie:    1    4    4          59
 Near X = -0.89725160      -1.0433652      0.13437970    , d:  0.64184802       0.0000000      0.77050402
 i,j,k,ie:    6    4    4          59
 Near X = -0.89725160      -1.0433652      0.29563535    , d:   0.0000000     -0.40131646      0.77050402
 i,j,k,ie:    1    5    4          59
 Near X = -0.76787462      -1.1598459      0.13437970    , d:  0.68338513       0.0000000      0.77050402
 i,j,k,ie:    6    5    4          59
 Near X = -0.76787462      -1.1598459      0.29563535    , d:   0.0000000     -0.47644069      0.77050402
 i,j,k,ie:    1    6    4          59
 Near X = -0.70237680      -1.2147319      0.13437970    , d:  0.70237663     -0.42270770      0.77050402
 i,j,k,ie:    2    6    4          59
 Near X = -0.70237680      -1.2147319      0.15332278    , d:   0.0000000     -0.42270770      0.77050402
 i,j,k,ie:    3    6    4          59
 Near X = -0.70237680      -1.2147319      0.19200993    , d:   0.0000000     -0.42270770      0.77050402
 i,j,k,ie:    4    6    4          59
 Near X = -0.70237680      -1.2147319      0.23800512    , d:   0.0000000     -0.42270770      0.77050402
 i,j,k,ie:    5    6    4          59
 Near X = -0.70237680      -1.2147319      0.27669227    , d:   0.0000000     -0.42270770      0.77050402
 i,j,k,ie:    6    6    4          59
 Near X = -0.70237680      -1.2147319      0.29563535    , d:   1.6762316     -0.51239201      0.77050402
 i,j,k,ie:    1    1    5          59
 Near X =  -1.1837509     -0.68386239      0.13437970    , d:   2.5513718       0.0000000      0.77050402
 i,j,k,ie:    2    1    5          59
 Near X =  -1.1837509     -0.68386239      0.15332278    , d:   2.5513718       0.0000000      0.77050402
 i,j,k,ie:    3    1    5          59
 Near X =  -1.1837509     -0.68386239      0.19200993    , d:   2.5513718       0.0000000      0.77050402
 i,j,k,ie:    4    1    5          59
 Near X =  -1.1837509     -0.68386239      0.23800512    , d:   2.5513718       0.0000000      0.77050402
 i,j,k,ie:    5    1    5          59
 Near X =  -1.1837509     -0.68386239      0.27669227    , d:   2.5513718       0.0000000      0.77050402
 i,j,k,ie:    6    1    5          59
 Near X =  -1.1837509     -0.68386239      0.29563535    , d:   2.5513718     -0.18386995      0.77050402
 i,j,k,ie:    1    2    5          59
 Near X =  -1.1267727     -0.74432599      0.13437970    , d:  0.52258863       0.0000000      0.77050402
 i,j,k,ie:    6    2    5          59
 Near X =  -1.1267727     -0.74432599      0.29563535    , d:   0.0000000     -0.22166882      0.77050402
 i,j,k,ie:    1    3    5          59
 Near X =  -1.0089646     -0.86636756      0.13437970    , d:  0.56805808       0.0000000      0.77050402
 i,j,k,ie:    6    3    5          59
 Near X =  -1.0089646     -0.86636756      0.29563535    , d:   0.0000000     -0.29830559      0.77050402
 i,j,k,ie:    1    4    5          59
 Near X = -0.86638251      -1.0089433      0.13437970    , d:  0.62053700       0.0000000      0.77050402
 i,j,k,ie:    6    4    5          59
 Near X = -0.86638251      -1.0089433      0.29563535    , d:   0.0000000     -0.38844214      0.77050402
 i,j,k,ie:    1    5    5          59
 Near X = -0.74433544      -1.1267462      0.13437970    , d:  0.66334893       0.0000000      0.77050402
 i,j,k,ie:    6    5    5          59
 Near X = -0.74433544      -1.1267462      0.29563535    , d:   0.0000000     -0.46343539      0.77050402
 i,j,k,ie:    1    6    5          59
 Near X = -0.68386909      -1.1837220      0.13437970    , d:  0.68386892     -0.35724624      0.77050402
 i,j,k,ie:    2    6    5          59
 Near X = -0.68386909      -1.1837220      0.15332278    , d:   0.0000000     -0.35724624      0.77050402
 i,j,k,ie:    3    6    5          59
 Near X = -0.68386909      -1.1837220      0.19200993    , d:   0.0000000     -0.35724624      0.77050402
 i,j,k,ie:    4    6    5          59
 Near X = -0.68386909      -1.1837220      0.23800512    , d:   0.0000000     -0.35724624      0.77050402
 i,j,k,ie:    5    6    5          59
 Near X = -0.68386909      -1.1837220      0.27669227    , d:   0.0000000     -0.35724624      0.77050402
 i,j,k,ie:    6    6    5          59
 Near X = -0.68386909      -1.1837220      0.29563535    , d:   1.5850416     -0.49988183      0.77050402
 i,j,k,ie:    1    1    6          59
 Near X =  -1.1685631     -0.67481339      0.13437970    , d:   2.6685631     -0.12928868      0.77050402
 i,j,k,ie:    2    1    6          59
 Near X =  -1.1685631     -0.67481339      0.15332278    , d:   2.6685631     -0.12928868      0.77050402
 i,j,k,ie:    3    1    6          59
 Near X =  -1.1685631     -0.67481339      0.19200993    , d:   2.6685631     -0.12928868      0.77050402
 i,j,k,ie:    4    1    6          59
 Near X =  -1.1685631     -0.67481339      0.23800512    , d:   2.6685631     -0.12928868      0.77050402
 i,j,k,ie:    5    1    6          59
 Near X =  -1.1685631     -0.67481339      0.27669227    , d:   2.6685631     -0.12928868      0.77050402
 i,j,k,ie:    6    1    6          59
 Near X =  -1.1685631     -0.67481339      0.29563535    , d:   2.6685631     -0.33143692      0.77050402
 i,j,k,ie:    1    2    6          59
 Near X =  -1.1105604     -0.73281238      0.13437970    , d:  0.51502467     -0.13800967      0.77050402
 i,j,k,ie:    2    2    6          59
 Near X =  -1.1105604     -0.73281238      0.15332278    , d:   0.0000000     -0.13800967      0.77050402
 i,j,k,ie:    3    2    6          59
 Near X =  -1.1105604     -0.73281238      0.19200993    , d:   0.0000000     -0.13800967      0.77050402
 i,j,k,ie:    4    2    6          59
 Near X =  -1.1105604     -0.73281238      0.23800512    , d:   0.0000000     -0.13800967      0.77050402
 i,j,k,ie:    5    2    6          59
 Near X =  -1.1105604     -0.73281238      0.27669227    , d:   0.0000000     -0.13800967      0.77050402
 i,j,k,ie:    6    2    6          59
 Near X =  -1.1105604     -0.73281238      0.29563535    , d:   0.0000000     -0.38629570      0.77050402
 i,j,k,ie:    1    3    6          59
 Near X = -0.99210237     -0.85126281      0.13437970    , d:  0.55846082     -0.14354180      0.77050402
 i,j,k,ie:    2    3    6          59
 Near X = -0.99210237     -0.85126281      0.15332278    , d:   0.0000000     -0.14354180      0.77050402
 i,j,k,ie:    3    3    6          59
 Near X = -0.99210237     -0.85126281      0.19200993    , d:   0.0000000     -0.14354180      0.77050402
 i,j,k,ie:    4    3    6          59
 Near X = -0.99210237     -0.85126281      0.23800512    , d:   0.0000000     -0.14354180      0.77050402
 i,j,k,ie:    5    3    6          59
 Near X = -0.99210237     -0.85126281      0.27669227    , d:   0.0000000     -0.14354180      0.77050402
 i,j,k,ie:    6    3    6          59
 Near X = -0.99210237     -0.85126281      0.29563535    , d:   0.0000000     -0.48129361      0.77050402
 i,j,k,ie:    1    4    6          59
 Near X = -0.85126753     -0.99208865      0.13437970    , d:  0.61010210     -0.12866843      0.77050402
 i,j,k,ie:    2    4    6          59
 Near X = -0.85126753     -0.99208865      0.15332278    , d:   0.0000000     -0.12866843      0.77050402
 i,j,k,ie:    3    4    6          59
 Near X = -0.85126753     -0.99208865      0.19200993    , d:   0.0000000     -0.12866843      0.77050402
 i,j,k,ie:    4    4    6          59
 Near X = -0.85126753     -0.99208865      0.23800512    , d:   0.0000000     -0.12866843      0.77050402
 i,j,k,ie:    5    4    6          59
 Near X = -0.85126753     -0.99208865      0.27669227    , d:   0.0000000     -0.12866843      0.77050402
 i,j,k,ie:    6    4    6          59
 Near X = -0.85126753     -0.99208865      0.29563535    , d:   0.0000000     -0.56446940      0.77050402
 i,j,k,ie:    1    5    6          59
 Near X = -0.73280953      -1.1105391      0.13437970    , d:  0.65353825     -0.98115942E-01  0.77050402
 i,j,k,ie:    2    5    6          59
 Near X = -0.73280953      -1.1105391      0.15332278    , d:   0.0000000     -0.98115942E-01  0.77050402
 i,j,k,ie:    3    5    6          59
 Near X = -0.73280953      -1.1105391      0.19200993    , d:   0.0000000     -0.98115942E-01  0.77050402
 i,j,k,ie:    4    5    6          59
 Near X = -0.73280953      -1.1105391      0.23800512    , d:   0.0000000     -0.98115942E-01  0.77050402
 i,j,k,ie:    5    5    6          59
 Near X = -0.73280953      -1.1105391      0.27669227    , d:   0.0000000     -0.98115942E-01  0.77050402
 i,j,k,ie:    6    5    6          59
 Near X = -0.73280953      -1.1105391      0.29563535    , d:   0.0000000     -0.60939195      0.77050402
 i,j,k,ie:    1    6    6          59
 Near X = -0.67480683      -1.1685381      0.13437970    , d:  0.67480667     -0.67519320      0.77050402
 i,j,k,ie:    2    6    6          59
 Near X = -0.67480683      -1.1685381      0.15332278    , d:   0.0000000     -0.67519320      0.77050402
 i,j,k,ie:    3    6    6          59
 Near X = -0.67480683      -1.1685381      0.19200993    , d:   0.0000000     -0.67519320      0.77050402
 i,j,k,ie:    4    6    6          59
 Near X = -0.67480683      -1.1685381      0.23800512    , d:   0.0000000     -0.67519320      0.77050402
 i,j,k,ie:    5    6    6          59
 Near X = -0.67480683      -1.1685381      0.27669227    , d:   0.0000000     -0.67519320      0.77050402
 i,j,k,ie:    6    6    6          59
 Near X = -0.67480683      -1.1685381      0.29563535    , d:   1.8433449     -0.67519320      0.77050402
 i,j,k,ie:    1    1    1          60
 Near X =  -1.5000000     -0.18369701E-15  0.13437970    , d:   3.0000000       0.0000000      0.66666667
 i,j,k,ie:    2    1    1          60
 Near X =  -1.5000000     -0.18369701E-15  0.15332278    , d:   2.7977933       0.0000000      0.66666667
 i,j,k,ie:    3    1    1          60
 Near X =  -1.5000000     -0.18369701E-15  0.19200993    , d:   2.7977933       0.0000000      0.66666667
 i,j,k,ie:    4    1    1          60
 Near X =  -1.5000000     -0.18369701E-15  0.23800512    , d:   2.7977933       0.0000000      0.66666667
 i,j,k,ie:    5    1    1          60
 Near X =  -1.5000000     -0.18369701E-15  0.27669227    , d:   2.7977933       0.0000000      0.66666667
 i,j,k,ie:    6    1    1          60
 Near X =  -1.5000000     -0.18369701E-15  0.29563535    , d:   2.7977933       0.0000000      0.66666667
 i,j,k,ie:    1    2    1          60
 Near X =  -1.4968561     -0.93857365E-01  0.13437970    , d:  0.38629570       0.0000000      0.66666667
 i,j,k,ie:    2    2    1          60
 Near X =  -1.4968561     -0.93857365E-01  0.15332278    , d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    3    2    1          60
 Near X =  -1.4968561     -0.93857365E-01  0.19200993    , d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    4    2    1          60
 Near X =  -1.4968561     -0.93857365E-01  0.23800512    , d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    5    2    1          60
 Near X =  -1.4968561     -0.93857365E-01  0.27669227    , d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    6    2    1          60
 Near X =  -1.4968561     -0.93857365E-01  0.29563535    , d:  0.16816987       0.0000000      0.66666667
 i,j,k,ie:    1    3    1          60
 Near X =  -1.4733960     -0.28096195      0.13437970    , d:  0.48129361       0.0000000      0.66666667
 i,j,k,ie:    2    3    1          60
 Near X =  -1.4733960     -0.28096195      0.15332278    , d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    3    3    1          60
 Near X =  -1.4733960     -0.28096195      0.19200993    , d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    4    3    1          60
 Near X =  -1.4733960     -0.28096195      0.23800512    , d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    5    3    1          60
 Near X =  -1.4733960     -0.28096195      0.27669227    , d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    6    3    1          60
 Near X =  -1.4733960     -0.28096195      0.29563535    , d:  0.18823867       0.0000000      0.66666667
 i,j,k,ie:    1    4    1          60
 Near X =  -1.4157369     -0.49541165      0.13437970    , d:  0.56446940       0.0000000      0.66666667
 i,j,k,ie:    2    4    1          60
 Near X =  -1.4157369     -0.49541165      0.15332278    , d:  0.18233115       0.0000000      0.66666667
 i,j,k,ie:    3    4    1          60
 Near X =  -1.4157369     -0.49541165      0.19200993    , d:  0.18233115       0.0000000      0.66666667
 i,j,k,ie:    4    4    1          60
 Near X =  -1.4157369     -0.49541165      0.23800512    , d:  0.18233115       0.0000000      0.66666667
 i,j,k,ie:    5    4    1          60
 Near X =  -1.4157369     -0.49541165      0.27669227    , d:  0.18233115       0.0000000      0.66666667
 i,j,k,ie:    6    4    1          60
 Near X =  -1.4157369     -0.49541165      0.29563535    , d:  0.18233115       0.0000000      0.66666667
 i,j,k,ie:    1    5    1          60
 Near X =  -1.3422015     -0.66905988      0.13437970    , d:  0.60939195       0.0000000      0.66666667
 i,j,k,ie:    2    5    1          60
 Near X =  -1.3422015     -0.66905988      0.15332278    , d:  0.15232458       0.0000000      0.66666667
 i,j,k,ie:    3    5    1          60
 Near X =  -1.3422015     -0.66905988      0.19200993    , d:  0.15232458       0.0000000      0.66666667
 i,j,k,ie:    4    5    1          60
 Near X =  -1.3422015     -0.66905988      0.23800512    , d:  0.15232458       0.0000000      0.66666667
 i,j,k,ie:    5    5    1          60
 Near X =  -1.3422015     -0.66905988      0.27669227    , d:  0.15232458       0.0000000      0.66666667
 i,j,k,ie:    6    5    1          60
 Near X =  -1.3422015     -0.66905988      0.29563535    , d:  0.15232458       0.0000000      0.66666667
 i,j,k,ie:    1    6    1          60
 Near X =  -1.2978518     -0.75184434      0.13437970    , d:   2.4663898     -0.52148270E-01  0.66666667
 i,j,k,ie:    2    6    1          60
 Near X =  -1.2978518     -0.75184434      0.15332278    , d:   2.4663898       0.0000000      0.66666667
 i,j,k,ie:    3    6    1          60
 Near X =  -1.2978518     -0.75184434      0.19200993    , d:   2.4663898       0.0000000      0.66666667
 i,j,k,ie:    4    6    1          60
 Near X =  -1.2978518     -0.75184434      0.23800512    , d:   2.4663898       0.0000000      0.66666667
 i,j,k,ie:    5    6    1          60
 Near X =  -1.2978518     -0.75184434      0.27669227    , d:   2.4663898       0.0000000      0.66666667
 i,j,k,ie:    6    6    1          60
 Near X =  -1.2978518     -0.75184434      0.29563535    , d:   2.4663898       0.0000000      0.66666667
 i,j,k,ie:    1    1    2          60
 Near X =  -1.4823792     -0.20096047E-15  0.13437970    , d:   2.9647583       0.0000000      0.66666667
 i,j,k,ie:    2    1    2          60
 Near X =  -1.4823792     -0.20096047E-15  0.15332278    , d:   2.7649886       0.0000000      0.66666667
 i,j,k,ie:    3    1    2          60
 Near X =  -1.4823792     -0.20096047E-15  0.19200993    , d:   2.7649886       0.0000000      0.66666667
 i,j,k,ie:    4    1    2          60
 Near X =  -1.4823792     -0.20096047E-15  0.23800512    , d:   2.7649886       0.0000000      0.66666667
 i,j,k,ie:    5    1    2          60
 Near X =  -1.4823792     -0.20096047E-15  0.27669227    , d:   2.7649886       0.0000000      0.66666667
 i,j,k,ie:    6    1    2          60
 Near X =  -1.4823792     -0.20096047E-15  0.29563535    , d:   2.7649886       0.0000000      0.66666667
 i,j,k,ie:    1    2    2          60
 Near X =  -1.4771008     -0.92143977E-01  0.13437970    , d:  0.24474304       0.0000000      0.66666667
 i,j,k,ie:    1    3    2          60
 Near X =  -1.4512831     -0.27628722      0.13437970    , d:  0.33250117       0.0000000      0.66666667
 i,j,k,ie:    1    4    2          60
 Near X =  -1.3943181     -0.48815586      0.13437970    , d:  0.42949709       0.0000000      0.66666667
 i,j,k,ie:    1    5    2          60
 Near X =  -1.3243076     -0.66042350      0.13437970    , d:  0.50490800       0.0000000      0.66666667
 i,j,k,ie:    1    6    2          60
 Near X =  -1.2826639     -0.74279534      0.13437970    , d:   2.4156132     -0.26220793E-01  0.66666667
 i,j,k,ie:    2    6    2          60
 Near X =  -1.2826639     -0.74279534      0.15332278    , d:   2.4156132       0.0000000      0.66666667
 i,j,k,ie:    3    6    2          60
 Near X =  -1.2826639     -0.74279534      0.19200993    , d:   2.4156132       0.0000000      0.66666667
 i,j,k,ie:    4    6    2          60
 Near X =  -1.2826639     -0.74279534      0.23800512    , d:   2.4156132       0.0000000      0.66666667
 i,j,k,ie:    5    6    2          60
 Near X =  -1.2826639     -0.74279534      0.27669227    , d:   2.4156132       0.0000000      0.66666667
 i,j,k,ie:    6    6    2          60
 Near X =  -1.2826639     -0.74279534      0.29563535    , d:   2.4156132       0.0000000      0.66666667
 i,j,k,ie:    1    1    3          60
 Near X =  -1.4463924     -0.23621735E-15  0.13437970    , d:   2.8927847       0.0000000      0.66666667
 i,j,k,ie:    2    1    3          60
 Near X =  -1.4463924     -0.23621735E-15  0.15332278    , d:   2.6979919       0.0000000      0.66666667
 i,j,k,ie:    3    1    3          60
 Near X =  -1.4463924     -0.23621735E-15  0.19200993    , d:   2.6979919       0.0000000      0.66666667
 i,j,k,ie:    4    1    3          60
 Near X =  -1.4463924     -0.23621735E-15  0.23800512    , d:   2.6979919       0.0000000      0.66666667
 i,j,k,ie:    5    1    3          60
 Near X =  -1.4463924     -0.23621735E-15  0.27669227    , d:   2.6979919       0.0000000      0.66666667
 i,j,k,ie:    6    1    3          60
 Near X =  -1.4463924     -0.23621735E-15  0.29563535    , d:   2.6979919       0.0000000      0.66666667
 i,j,k,ie:    1    2    3          60
 Near X =  -1.4367548     -0.88644752E-01  0.13437970    , d:  0.23750725       0.0000000      0.66666667
 i,j,k,ie:    1    3    3          60
 Near X =  -1.4061225     -0.26674010      0.13437970    , d:  0.32177786       0.0000000      0.66666667
 i,j,k,ie:    1    4    3          60
 Near X =  -1.3505747     -0.47333748      0.13437970    , d:  0.41662276       0.0000000      0.66666667
 i,j,k,ie:    1    5    3          60
 Near X =  -1.2877631     -0.64278556      0.13437970    , d:  0.49190270       0.0000000      0.66666667
 i,j,k,ie:    1    6    3          60
 Near X =  -1.2516460     -0.72431469      0.13437970    , d:   2.3119130       0.0000000      0.66666667
 i,j,k,ie:    2    6    3          60
 Near X =  -1.2516460     -0.72431469      0.15332278    , d:   2.3119130       0.0000000      0.66666667
 i,j,k,ie:    3    6    3          60
 Near X =  -1.2516460     -0.72431469      0.19200993    , d:   2.3119130       0.0000000      0.66666667
 i,j,k,ie:    4    6    3          60
 Near X =  -1.2516460     -0.72431469      0.23800512    , d:   2.3119130       0.0000000      0.66666667
 i,j,k,ie:    5    6    3          60
 Near X =  -1.2516460     -0.72431469      0.27669227    , d:   2.3119130       0.0000000      0.66666667
 i,j,k,ie:    6    6    3          60
 Near X =  -1.2516460     -0.72431469      0.29563535    , d:   2.3119130       0.0000000      0.66666667
 i,j,k,ie:    1    1    4          60
 Near X =  -1.4036077     -0.27813430E-15  0.13437970    , d:   2.8072153       0.0000000      0.66666667
 i,j,k,ie:    2    1    4          60
 Near X =  -1.4036077     -0.27813430E-15  0.15332278    , d:   2.6183395       0.0000000      0.66666667
 i,j,k,ie:    3    1    4          60
 Near X =  -1.4036077     -0.27813430E-15  0.19200993    , d:   2.6183395       0.0000000      0.66666667
 i,j,k,ie:    4    1    4          60
 Near X =  -1.4036077     -0.27813430E-15  0.23800512    , d:   2.6183395       0.0000000      0.66666667
 i,j,k,ie:    5    1    4          60
 Near X =  -1.4036077     -0.27813430E-15  0.27669227    , d:   2.6183395       0.0000000      0.66666667
 i,j,k,ie:    6    1    4          60
 Near X =  -1.4036077     -0.27813430E-15  0.29563535    , d:   2.6183395       0.0000000      0.66666667
 i,j,k,ie:    1    2    4          60
 Near X =  -1.3887875     -0.84484519E-01  0.13437970    , d:  0.22890461       0.0000000      0.66666667
 i,j,k,ie:    1    3    4          60
 Near X =  -1.3524309     -0.25538952      0.13437970    , d:  0.30902890       0.0000000      0.66666667
 i,j,k,ie:    1    4    4          60
 Near X =  -1.2985681     -0.45571989      0.13437970    , d:  0.40131646       0.0000000      0.66666667
 i,j,k,ie:    1    5    4          60
 Near X =  -1.2443153     -0.62181580      0.13437970    , d:  0.47644069       0.0000000      0.66666667
 i,j,k,ie:    1    6    4          60
 Near X =  -1.2147688     -0.70234304      0.13437970    , d:   2.1886237       0.0000000      0.66666667
 i,j,k,ie:    2    6    4          60
 Near X =  -1.2147688     -0.70234304      0.15332278    , d:   2.1886237       0.0000000      0.66666667
 i,j,k,ie:    3    6    4          60
 Near X =  -1.2147688     -0.70234304      0.19200993    , d:   2.1886237       0.0000000      0.66666667
 i,j,k,ie:    4    6    4          60
 Near X =  -1.2147688     -0.70234304      0.23800512    , d:   2.1886237       0.0000000      0.66666667
 i,j,k,ie:    5    6    4          60
 Near X =  -1.2147688     -0.70234304      0.27669227    , d:   2.1886237       0.0000000      0.66666667
 i,j,k,ie:    6    6    4          60
 Near X =  -1.2147688     -0.70234304      0.29563535    , d:   2.1886237       0.0000000      0.66666667
 i,j,k,ie:    1    1    5          60
 Near X =  -1.3676209     -0.31339119E-15  0.13437970    , d:   2.7352417       0.0000000      0.66666667
 i,j,k,ie:    2    1    5          60
 Near X =  -1.3676209     -0.31339119E-15  0.15332278    , d:   2.5513429       0.0000000      0.66666667
 i,j,k,ie:    3    1    5          60
 Near X =  -1.3676209     -0.31339119E-15  0.19200993    , d:   2.5513429       0.0000000      0.66666667
 i,j,k,ie:    4    1    5          60
 Near X =  -1.3676209     -0.31339119E-15  0.23800512    , d:   2.5513429       0.0000000      0.66666667
 i,j,k,ie:    5    1    5          60
 Near X =  -1.3676209     -0.31339119E-15  0.27669227    , d:   2.5513429       0.0000000      0.66666667
 i,j,k,ie:    6    1    5          60
 Near X =  -1.3676209     -0.31339119E-15  0.29563535    , d:   2.5513429       0.0000000      0.66666667
 i,j,k,ie:    1    2    5          60
 Near X =  -1.3484415     -0.80985294E-01  0.13437970    , d:  0.22166882       0.0000000      0.66666667
 i,j,k,ie:    1    3    5          60
 Near X =  -1.3072702     -0.24584240      0.13437970    , d:  0.29830559       0.0000000      0.66666667
 i,j,k,ie:    1    4    5          60
 Near X =  -1.2548246     -0.44090151      0.13437970    , d:  0.38844214       0.0000000      0.66666667
 i,j,k,ie:    1    5    5          60
 Near X =  -1.2077708     -0.60417786      0.13437970    , d:  0.46343539       0.0000000      0.66666667
 i,j,k,ie:    1    6    5          60
 Near X =  -1.1837509     -0.68386239      0.13437970    , d:   2.0849234       0.0000000      0.66666667
 i,j,k,ie:    2    6    5          60
 Near X =  -1.1837509     -0.68386239      0.15332278    , d:   2.0849234       0.0000000      0.66666667
 i,j,k,ie:    3    6    5          60
 Near X =  -1.1837509     -0.68386239      0.19200993    , d:   2.0849234       0.0000000      0.66666667
 i,j,k,ie:    4    6    5          60
 Near X =  -1.1837509     -0.68386239      0.23800512    , d:   2.0849234       0.0000000      0.66666667
 i,j,k,ie:    5    6    5          60
 Near X =  -1.1837509     -0.68386239      0.27669227    , d:   2.0849234       0.0000000      0.66666667
 i,j,k,ie:    6    6    5          60
 Near X =  -1.1837509     -0.68386239      0.29563535    , d:   2.0849234       0.0000000      0.66666667
 i,j,k,ie:    1    1    6          60
 Near X =  -1.3500000     -0.33065464E-15  0.13437970    , d:   2.8500000     -0.14999998      0.66666667
 i,j,k,ie:    2    1    6          60
 Near X =  -1.3500000     -0.33065464E-15  0.15332278    , d:   2.6477934     -0.14999998      0.66666667
 i,j,k,ie:    3    1    6          60
 Near X =  -1.3500000     -0.33065464E-15  0.19200993    , d:   2.6477934     -0.14999998      0.66666667
 i,j,k,ie:    4    1    6          60
 Near X =  -1.3500000     -0.33065464E-15  0.23800512    , d:   2.6477934     -0.14999998      0.66666667
 i,j,k,ie:    5    1    6          60
 Near X =  -1.3500000     -0.33065464E-15  0.27669227    , d:   2.6477934     -0.14999998      0.66666667
 i,j,k,ie:    6    1    6          60
 Near X =  -1.3500000     -0.33065464E-15  0.29563535    , d:   2.6477934     -0.14999998      0.66666667
 i,j,k,ie:    1    2    6          60
 Near X =  -1.3286862     -0.79271906E-01  0.13437970    , d:  0.21812583     -0.16816987      0.66666667
 i,j,k,ie:    2    2    6          60
 Near X =  -1.3286862     -0.79271906E-01  0.15332278    , d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    3    2    6          60
 Near X =  -1.3286862     -0.79271906E-01  0.19200993    , d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    4    2    6          60
 Near X =  -1.3286862     -0.79271906E-01  0.23800512    , d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    5    2    6          60
 Near X =  -1.3286862     -0.79271906E-01  0.27669227    , d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    6    2    6          60
 Near X =  -1.3286862     -0.79271906E-01  0.29563535    , d:   0.0000000     -0.16816987      0.66666667
 i,j,k,ie:    1    3    6          60
 Near X =  -1.2851573     -0.24116767      0.13437970    , d:  0.29305495     -0.18823867      0.66666667
 i,j,k,ie:    2    3    6          60
 Near X =  -1.2851573     -0.24116767      0.15332278    , d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    3    3    6          60
 Near X =  -1.2851573     -0.24116767      0.19200993    , d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    4    3    6          60
 Near X =  -1.2851573     -0.24116767      0.23800512    , d:   0.0000000     -0.18823867      0.66666667
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    5    3    6          60
 Near X =  -1.2851573     -0.24116767      0.27669227    , d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    6    3    6          60
 Near X =  -1.2851573     -0.24116767      0.29563535    , d:   0.0000000     -0.18823867      0.66666667
 i,j,k,ie:    1    4    6          60
 Near X =  -1.2334058     -0.43364572      0.13437970    , d:  0.38213825     -0.18233115      0.66666667
 i,j,k,ie:    2    4    6          60
 Near X =  -1.2334058     -0.43364572      0.15332278    , d:   0.0000000     -0.18233115      0.66666667
 i,j,k,ie:    3    4    6          60
 Near X =  -1.2334058     -0.43364572      0.19200993    , d:   0.0000000     -0.18233115      0.66666667
 i,j,k,ie:    4    4    6          60
 Near X =  -1.2334058     -0.43364572      0.23800512    , d:   0.0000000     -0.18233115      0.66666667
 i,j,k,ie:    5    4    6          60
 Near X =  -1.2334058     -0.43364572      0.27669227    , d:   0.0000000     -0.18233115      0.66666667
 i,j,k,ie:    6    4    6          60
 Near X =  -1.2334058     -0.43364572      0.29563535    , d:   0.0000000     -0.18233115      0.66666667
 i,j,k,ie:    1    5    6          60
 Near X =  -1.1898769     -0.59554148      0.13437970    , d:  0.45706737     -0.15232458      0.66666667
 i,j,k,ie:    2    5    6          60
 Near X =  -1.1898769     -0.59554148      0.15332278    , d:   0.0000000     -0.15232458      0.66666667
 i,j,k,ie:    3    5    6          60
 Near X =  -1.1898769     -0.59554148      0.19200993    , d:   0.0000000     -0.15232458      0.66666667
 i,j,k,ie:    4    5    6          60
 Near X =  -1.1898769     -0.59554148      0.23800512    , d:   0.0000000     -0.15232458      0.66666667
 i,j,k,ie:    5    5    6          60
 Near X =  -1.1898769     -0.59554148      0.27669227    , d:   0.0000000     -0.15232458      0.66666667
 i,j,k,ie:    6    5    6          60
 Near X =  -1.1898769     -0.59554148      0.29563535    , d:   0.0000000     -0.15232458      0.66666667
 i,j,k,ie:    1    6    6          60
 Near X =  -1.1685631     -0.67481339      0.13437970    , d:   2.3371011     -0.18143695      0.66666667
 i,j,k,ie:    2    6    6          60
 Near X =  -1.1685631     -0.67481339      0.15332278    , d:   2.3371011     -0.12928868      0.66666667
 i,j,k,ie:    3    6    6          60
 Near X =  -1.1685631     -0.67481339      0.19200993    , d:   2.3371011     -0.12928868      0.66666667
 i,j,k,ie:    4    6    6          60
 Near X =  -1.1685631     -0.67481339      0.23800512    , d:   2.3371011     -0.12928868      0.66666667
 i,j,k,ie:    5    6    6          60
 Near X =  -1.1685631     -0.67481339      0.27669227    , d:   2.3371011     -0.12928868      0.66666667
 i,j,k,ie:    6    6    6          60
 Near X =  -1.1685631     -0.67481339      0.29563535    , d:   2.3371011     -0.12928868      0.66666667
 i,j,k,ie:    1    1    1          61
 Near X = -0.67480683      -1.1685381      0.13437970    , d:   1.4266511       0.0000000       1.4819056
 i,j,k,ie:    2    1    1          61
 Near X = -0.67480683      -1.1685381      0.15332278    , d:   1.4266511       0.0000000       1.4819056
 i,j,k,ie:    3    1    1          61
 Near X = -0.67480683      -1.1685381      0.19200993    , d:   1.4266511       0.0000000       1.4819056
 i,j,k,ie:    4    1    1          61
 Near X = -0.67480683      -1.1685381      0.23800512    , d:   1.4266511       0.0000000       1.4819056
 i,j,k,ie:    5    1    1          61
 Near X = -0.67480683      -1.1685381      0.27669227    , d:   1.4266511       0.0000000       1.4819056
 i,j,k,ie:    6    1    1          61
 Near X = -0.67480683      -1.1685381      0.29563535    , d:   1.4266511     -0.49375625       1.4819056
 i,j,k,ie:    1    2    1          61
 Near X = -0.59553571      -1.1898548      0.13437970    , d:  0.15439815       0.0000000       1.4819056
 i,j,k,ie:    2    2    1          61
 Near X = -0.59553571      -1.1898548      0.15332278    , d:  0.15439815       0.0000000       1.4819056
 i,j,k,ie:    3    2    1          61
 Near X = -0.59553571      -1.1898548      0.19200993    , d:  0.15439815       0.0000000       1.4819056
 i,j,k,ie:    4    2    1          61
 Near X = -0.59553571      -1.1898548      0.23800512    , d:  0.15439815       0.0000000       1.4819056
 i,j,k,ie:    5    2    1          61
 Near X = -0.59553571      -1.1898548      0.27669227    , d:  0.15439815       0.0000000       1.4819056
 i,j,k,ie:    6    2    1          61
 Near X = -0.59553571      -1.1898548      0.29563535    , d:  0.15439815     -0.51502467       1.4819056
 i,j,k,ie:    1    3    1          61
 Near X = -0.43364156      -1.2333897      0.13437970    , d:  0.11242559       0.0000000       1.4819056
 i,j,k,ie:    2    3    1          61
 Near X = -0.43364156      -1.2333897      0.15332278    , d:  0.11242559       0.0000000       1.4819056
 i,j,k,ie:    3    3    1          61
 Near X = -0.43364156      -1.2333897      0.19200993    , d:  0.11242559       0.0000000       1.4819056
 i,j,k,ie:    4    3    1          61
 Near X = -0.43364156      -1.2333897      0.23800512    , d:  0.11242559       0.0000000       1.4819056
 i,j,k,ie:    5    3    1          61
 Near X = -0.43364156      -1.2333897      0.27669227    , d:  0.11242559       0.0000000       1.4819056
 i,j,k,ie:    6    3    1          61
 Near X = -0.43364156      -1.2333897      0.29563535    , d:  0.11242559     -0.55846082       1.4819056
 i,j,k,ie:    1    4    1          61
 Near X = -0.24116543      -1.2851484      0.13437970    , d:  0.62524372E-01   0.0000000       1.4819056
 i,j,k,ie:    2    4    1          61
 Near X = -0.24116543      -1.2851484      0.15332278    , d:  0.62524372E-01   0.0000000       1.4819056
 i,j,k,ie:    3    4    1          61
 Near X = -0.24116543      -1.2851484      0.19200993    , d:  0.62524372E-01   0.0000000       1.4819056
 i,j,k,ie:    4    4    1          61
 Near X = -0.24116543      -1.2851484      0.23800512    , d:  0.62524372E-01   0.0000000       1.4819056
 i,j,k,ie:    5    4    1          61
 Near X = -0.24116543      -1.2851484      0.27669227    , d:  0.62524372E-01   0.0000000       1.4819056
 i,j,k,ie:    6    4    1          61
 Near X = -0.24116543      -1.2851484      0.29563535    , d:  0.62524372E-01 -0.61010210       1.4819056
 i,j,k,ie:    1    5    1          61
 Near X = -0.79271276E-01  -1.3286833      0.13437970    , d:  0.20551813E-01   0.0000000       1.4819056
 i,j,k,ie:    2    5    1          61
 Near X = -0.79271276E-01  -1.3286833      0.15332278    , d:  0.20551813E-01   0.0000000       1.4819056
 i,j,k,ie:    3    5    1          61
 Near X = -0.79271276E-01  -1.3286833      0.19200993    , d:  0.20551813E-01   0.0000000       1.4819056
 i,j,k,ie:    4    5    1          61
 Near X = -0.79271276E-01  -1.3286833      0.23800512    , d:  0.20551813E-01   0.0000000       1.4819056
 i,j,k,ie:    5    5    1          61
 Near X = -0.79271276E-01  -1.3286833      0.27669227    , d:  0.20551813E-01   0.0000000       1.4819056
 i,j,k,ie:    6    5    1          61
 Near X = -0.79271276E-01  -1.3286833      0.29563535    , d:  0.20551813E-01 -0.65353825       1.4819056
 i,j,k,ie:    1    6    1          61
 Near X = -0.15931032E-06  -1.3500000      0.13437970    , d:  0.67481346       0.0000000       1.4819056
 i,j,k,ie:    2    6    1          61
 Near X = -0.15931032E-06  -1.3500000      0.15332278    , d:  0.67481346       0.0000000       1.4819056
 i,j,k,ie:    3    6    1          61
 Near X = -0.15931032E-06  -1.3500000      0.19200993    , d:  0.67481346       0.0000000       1.4819056
 i,j,k,ie:    4    6    1          61
 Near X = -0.15931032E-06  -1.3500000      0.23800512    , d:  0.67481346       0.0000000       1.4819056
 i,j,k,ie:    5    6    1          61
 Near X = -0.15931032E-06  -1.3500000      0.27669227    , d:  0.67481346       0.0000000       1.4819056
 i,j,k,ie:    6    6    1          61
 Near X = -0.15931032E-06  -1.3500000      0.29563535    , d:  0.67481346     -0.67480667       1.4819056
 i,j,k,ie:    1    1    2          61
 Near X = -0.65425505      -1.1329493      0.13437970    , d:   1.3970503       0.0000000       1.4819056
 i,j,k,ie:    2    1    2          61
 Near X = -0.65425505      -1.1329493      0.15332278    , d:   1.3970503       0.0000000       1.4819056
 i,j,k,ie:    3    1    2          61
 Near X = -0.65425505      -1.1329493      0.19200993    , d:   1.3970503       0.0000000       1.4819056
 i,j,k,ie:    4    1    2          61
 Near X = -0.65425505      -1.1329493      0.23800512    , d:   1.3970503       0.0000000       1.4819056
 i,j,k,ie:    5    1    2          61
 Near X = -0.65425505      -1.1329493      0.27669227    , d:   1.3970503       0.0000000       1.4819056
 i,j,k,ie:    6    1    2          61
 Near X = -0.65425505      -1.1329493      0.29563535    , d:   1.3970503     -0.47871851       1.4819056
 i,j,k,ie:    6    2    2          61
 Near X = -0.57739820      -1.1536169      0.29563535    , d:   0.0000000     -0.49933918       1.4819056
 i,j,k,ie:    6    3    2          61
 Near X = -0.42043466      -1.1958259      0.29563535    , d:   0.0000000     -0.54145245       1.4819056
 i,j,k,ie:    6    4    2          61
 Near X = -0.23382054      -1.2460082      0.29563535    , d:   0.0000000     -0.59152096       1.4819056
 i,j,k,ie:    6    5    2          61
 Near X = -0.76857007E-01  -1.2882172      0.29563535    , d:   0.0000000     -0.63363423       1.4819056
 i,j,k,ie:    1    6    2          61
 Near X = -0.15445840E-06  -1.3088847      0.13437970    , d:  0.65426148       0.0000000       1.4819056
 i,j,k,ie:    2    6    2          61
 Near X = -0.15445840E-06  -1.3088847      0.15332278    , d:  0.65426148       0.0000000       1.4819056
 i,j,k,ie:    3    6    2          61
 Near X = -0.15445840E-06  -1.3088847      0.19200993    , d:  0.65426148       0.0000000       1.4819056
 i,j,k,ie:    4    6    2          61
 Near X = -0.15445840E-06  -1.3088847      0.23800512    , d:  0.65426148       0.0000000       1.4819056
 i,j,k,ie:    5    6    2          61
 Near X = -0.15445840E-06  -1.3088847      0.27669227    , d:  0.65426148       0.0000000       1.4819056
 i,j,k,ie:    6    6    2          61
 Near X = -0.15445840E-06  -1.3088847      0.29563535    , d:  0.65426148     -0.65425489       1.4819056
 i,j,k,ie:    1    1    3          61
 Near X = -0.61228248      -1.0602670      0.13437970    , d:   1.3365971       0.0000000       1.4819056
 i,j,k,ie:    2    1    3          61
 Near X = -0.61228248      -1.0602670      0.15332278    , d:   1.3365971       0.0000000       1.4819056
 i,j,k,ie:    3    1    3          61
 Near X = -0.61228248      -1.0602670      0.19200993    , d:   1.3365971       0.0000000       1.4819056
 i,j,k,ie:    4    1    3          61
 Near X = -0.61228248      -1.0602670      0.23800512    , d:   1.3365971       0.0000000       1.4819056
 i,j,k,ie:    5    1    3          61
 Near X = -0.61228248      -1.0602670      0.27669227    , d:   1.3365971       0.0000000       1.4819056
 i,j,k,ie:    6    1    3          61
 Near X = -0.61228248      -1.0602670      0.29563535    , d:   1.3365971     -0.44800718       1.4819056
 i,j,k,ie:    6    2    3          61
 Near X = -0.54035624      -1.0796086      0.29563535    , d:   0.0000000     -0.46730496       1.4819056
 i,j,k,ie:    6    3    3          61
 Near X = -0.39346242      -1.1191098      0.29563535    , d:   0.0000000     -0.50671653       1.4819056
 i,j,k,ie:    6    4    3          61
 Near X = -0.21882020      -1.1660727      0.29563535    , d:   0.0000000     -0.55357298       1.4819056
 i,j,k,ie:    6    5    3          61
 Near X = -0.71926382E-01  -1.2055739      0.29563535    , d:   0.0000000     -0.59298455       1.4819056
 i,j,k,ie:    1    6    3          61
 Near X = -0.14454939E-06  -1.2249155      0.13437970    , d:  0.61228850       0.0000000       1.4819056
 i,j,k,ie:    2    6    3          61
 Near X = -0.14454939E-06  -1.2249155      0.15332278    , d:  0.61228850       0.0000000       1.4819056
 i,j,k,ie:    3    6    3          61
 Near X = -0.14454939E-06  -1.2249155      0.19200993    , d:  0.61228850       0.0000000       1.4819056
 i,j,k,ie:    4    6    3          61
 Near X = -0.14454939E-06  -1.2249155      0.23800512    , d:  0.61228850       0.0000000       1.4819056
 i,j,k,ie:    5    6    3          61
 Near X = -0.14454939E-06  -1.2249155      0.27669227    , d:  0.61228850       0.0000000       1.4819056
 i,j,k,ie:    6    6    3          61
 Near X = -0.14454939E-06  -1.2249155      0.29563535    , d:  0.61228850     -0.61228234       1.4819056
 i,j,k,ie:    1    1    4          61
 Near X = -0.56238125     -0.97385485      0.13437970    , d:   1.2647242       0.0000000       1.4819056
 i,j,k,ie:    2    1    4          61
 Near X = -0.56238125     -0.97385485      0.15332278    , d:   1.2647242       0.0000000       1.4819056
 i,j,k,ie:    3    1    4          61
 Near X = -0.56238125     -0.97385485      0.19200993    , d:   1.2647242       0.0000000       1.4819056
 i,j,k,ie:    4    1    4          61
 Near X = -0.56238125     -0.97385485      0.23800512    , d:   1.2647242       0.0000000       1.4819056
 i,j,k,ie:    5    1    4          61
 Near X = -0.56238125     -0.97385485      0.27669227    , d:   1.2647242       0.0000000       1.4819056
 i,j,k,ie:    6    1    4          61
 Near X = -0.56238125     -0.97385485      0.29563535    , d:   1.2647242     -0.41149444       1.4819056
 i,j,k,ie:    6    2    4          61
 Near X = -0.49631702     -0.99162015      0.29563535    , d:   0.0000000     -0.42921945       1.4819056
 i,j,k,ie:    6    3    4          61
 Near X = -0.36139510      -1.0279019      0.29563535    , d:   0.0000000     -0.46541896       1.4819056
 i,j,k,ie:    6    4    4          61
 Near X = -0.20098628      -1.0710374      0.29563535    , d:   0.0000000     -0.50845660       1.4819056
 i,j,k,ie:    6    5    4          61
 Near X = -0.66064357E-01  -1.1073192      0.29563535    , d:   0.0000000     -0.54465611       1.4819056
 i,j,k,ie:    1    6    4          61
 Near X = -0.13276857E-06  -1.1250845      0.13437970    , d:  0.56238678       0.0000000       1.4819056
 i,j,k,ie:    2    6    4          61
 Near X = -0.13276857E-06  -1.1250845      0.15332278    , d:  0.56238678       0.0000000       1.4819056
 i,j,k,ie:    3    6    4          61
 Near X = -0.13276857E-06  -1.1250845      0.19200993    , d:  0.56238678       0.0000000       1.4819056
 i,j,k,ie:    4    6    4          61
 Near X = -0.13276857E-06  -1.1250845      0.23800512    , d:  0.56238678       0.0000000       1.4819056
 i,j,k,ie:    5    6    4          61
 Near X = -0.13276857E-06  -1.1250845      0.27669227    , d:  0.56238678       0.0000000       1.4819056
 i,j,k,ie:    6    6    4          61
 Near X = -0.13276857E-06  -1.1250845      0.29563535    , d:  0.56238678     -0.56238112       1.4819056
 i,j,k,ie:    1    1    5          61
 Near X = -0.52040868     -0.90117250      0.13437970    , d:   1.2042710       0.0000000       1.4819056
 i,j,k,ie:    2    1    5          61
 Near X = -0.52040868     -0.90117250      0.15332278    , d:   1.2042710       0.0000000       1.4819056
 i,j,k,ie:    3    1    5          61
 Near X = -0.52040868     -0.90117250      0.19200993    , d:   1.2042710       0.0000000       1.4819056
 i,j,k,ie:    4    1    5          61
 Near X = -0.52040868     -0.90117250      0.23800512    , d:   1.2042710       0.0000000       1.4819056
 i,j,k,ie:    5    1    5          61
 Near X = -0.52040868     -0.90117250      0.27669227    , d:   1.2042710       0.0000000       1.4819056
 i,j,k,ie:    6    1    5          61
 Near X = -0.52040868     -0.90117250      0.29563535    , d:   1.2042710     -0.38078311       1.4819056
 i,j,k,ie:    6    2    5          61
 Near X = -0.45927507     -0.91761192      0.29563535    , d:   0.0000000     -0.39718523       1.4819056
 i,j,k,ie:    6    3    5          61
 Near X = -0.33442286     -0.95118586      0.29563535    , d:   0.0000000     -0.43068304       1.4819056
 i,j,k,ie:    6    4    5          61
 Near X = -0.18598594     -0.99110197      0.29563535    , d:   0.0000000     -0.47050862       1.4819056
 i,j,k,ie:    6    5    5          61
 Near X = -0.61133733E-01  -1.0246759      0.29563535    , d:   0.0000000     -0.50400643       1.4819056
 i,j,k,ie:    1    6    5          61
 Near X = -0.12285956E-06  -1.0411153      0.13437970    , d:  0.52041380       0.0000000       1.4819056
 i,j,k,ie:    2    6    5          61
 Near X = -0.12285956E-06  -1.0411153      0.15332278    , d:  0.52041380       0.0000000       1.4819056
 i,j,k,ie:    3    6    5          61
 Near X = -0.12285956E-06  -1.0411153      0.19200993    , d:  0.52041380       0.0000000       1.4819056
 i,j,k,ie:    4    6    5          61
 Near X = -0.12285956E-06  -1.0411153      0.23800512    , d:  0.52041380       0.0000000       1.4819056
 i,j,k,ie:    5    6    5          61
 Near X = -0.12285956E-06  -1.0411153      0.27669227    , d:  0.52041380       0.0000000       1.4819056
 i,j,k,ie:    6    6    5          61
 Near X = -0.12285956E-06  -1.0411153      0.29563535    , d:  0.52041380     -0.52040856       1.4819056
 i,j,k,ie:    1    1    6          61
 Near X = -0.49985690     -0.86558375      0.13437970    , d:   1.2517012     -0.17494992       1.4819056
 i,j,k,ie:    2    1    6          61
 Near X = -0.49985690     -0.86558375      0.15332278    , d:   1.2517012     -0.17494992       1.4819056
 i,j,k,ie:    3    1    6          61
 Near X = -0.49985690     -0.86558375      0.19200993    , d:   1.2517012     -0.17494992       1.4819056
 i,j,k,ie:    4    1    6          61
 Near X = -0.49985690     -0.86558375      0.23800512    , d:   1.2517012     -0.17494992       1.4819056
 i,j,k,ie:    5    1    6          61
 Near X = -0.49985690     -0.86558375      0.27669227    , d:   1.2517012     -0.17494992       1.4819056
 i,j,k,ie:    6    1    6          61
 Near X = -0.49985690     -0.86558375      0.29563535    , d:   1.2517012     -0.66870617       1.4819056
 i,j,k,ie:    1    2    6          61
 Near X = -0.44113756     -0.88137394      0.13437970    , d:   0.0000000     -0.15439815       1.4819056
 i,j,k,ie:    2    2    6          61
 Near X = -0.44113756     -0.88137394      0.15332278    , d:   0.0000000     -0.15439815       1.4819056
 i,j,k,ie:    3    2    6          61
 Near X = -0.44113756     -0.88137394      0.19200993    , d:   0.0000000     -0.15439815       1.4819056
 i,j,k,ie:    4    2    6          61
 Near X = -0.44113756     -0.88137394      0.23800512    , d:   0.0000000     -0.15439815       1.4819056
 i,j,k,ie:    5    2    6          61
 Near X = -0.44113756     -0.88137394      0.27669227    , d:   0.0000000     -0.15439815       1.4819056
 i,j,k,ie:    6    2    6          61
 Near X = -0.44113756     -0.88137394      0.29563535    , d:   0.0000000     -0.66942282       1.4819056
 i,j,k,ie:    1    3    6          61
 Near X = -0.32121597     -0.91362200      0.13437970    , d:   0.0000000     -0.11242559       1.4819056
 i,j,k,ie:    2    3    6          61
 Near X = -0.32121597     -0.91362200      0.15332278    , d:   0.0000000     -0.11242559       1.4819056
 i,j,k,ie:    3    3    6          61
 Near X = -0.32121597     -0.91362200      0.19200993    , d:   0.0000000     -0.11242559       1.4819056
 i,j,k,ie:    4    3    6          61
 Near X = -0.32121597     -0.91362200      0.23800512    , d:   0.0000000     -0.11242559       1.4819056
 i,j,k,ie:    5    3    6          61
 Near X = -0.32121597     -0.91362200      0.27669227    , d:   0.0000000     -0.11242559       1.4819056
 i,j,k,ie:    6    3    6          61
 Near X = -0.32121597     -0.91362200      0.29563535    , d:   0.0000000     -0.67088641       1.4819056
 i,j,k,ie:    1    4    6          61
 Near X = -0.17864106     -0.95196176      0.13437970    , d:   0.0000000     -0.62524372E-01   1.4819056
 i,j,k,ie:    2    4    6          61
 Near X = -0.17864106     -0.95196176      0.15332278    , d:   0.0000000     -0.62524372E-01   1.4819056
 i,j,k,ie:    3    4    6          61
 Near X = -0.17864106     -0.95196176      0.19200993    , d:   0.0000000     -0.62524372E-01   1.4819056
 i,j,k,ie:    4    4    6          61
 Near X = -0.17864106     -0.95196176      0.23800512    , d:   0.0000000     -0.62524372E-01   1.4819056
 i,j,k,ie:    5    4    6          61
 Near X = -0.17864106     -0.95196176      0.27669227    , d:   0.0000000     -0.62524372E-01   1.4819056
 i,j,k,ie:    6    4    6          61
 Near X = -0.17864106     -0.95196176      0.29563535    , d:   0.0000000     -0.67262647       1.4819056
 i,j,k,ie:    1    5    6          61
 Near X = -0.58719463E-01 -0.98420982      0.13437970    , d:   0.0000000     -0.20551813E-01   1.4819056
 i,j,k,ie:    2    5    6          61
 Near X = -0.58719463E-01 -0.98420982      0.15332278    , d:   0.0000000     -0.20551813E-01   1.4819056
 i,j,k,ie:    3    5    6          61
 Near X = -0.58719463E-01 -0.98420982      0.19200993    , d:   0.0000000     -0.20551813E-01   1.4819056
 i,j,k,ie:    4    5    6          61
 Near X = -0.58719463E-01 -0.98420982      0.23800512    , d:   0.0000000     -0.20551813E-01   1.4819056
 i,j,k,ie:    5    5    6          61
 Near X = -0.58719463E-01 -0.98420982      0.27669227    , d:   0.0000000     -0.20551813E-01   1.4819056
 i,j,k,ie:    6    5    6          61
 Near X = -0.58719463E-01 -0.98420982      0.29563535    , d:   0.0000000     -0.67409006       1.4819056
 i,j,k,ie:    1    6    6          61
 Near X = -0.11800764E-06  -1.0000000      0.13437970    , d:  0.67481342     -0.41302676E-07   1.4819056
 i,j,k,ie:    2    6    6          61
 Near X = -0.11800764E-06  -1.0000000      0.15332278    , d:  0.67481342     -0.41302676E-07   1.4819056
 i,j,k,ie:    3    6    6          61
 Near X = -0.11800764E-06  -1.0000000      0.19200993    , d:  0.67481342     -0.41302676E-07   1.4819056
 i,j,k,ie:    4    6    6          61
 Near X = -0.11800764E-06  -1.0000000      0.23800512    , d:  0.67481342     -0.41302676E-07   1.4819056
 i,j,k,ie:    5    6    6          61
 Near X = -0.11800764E-06  -1.0000000      0.27669227    , d:  0.67481342     -0.41302676E-07   1.4819056
 i,j,k,ie:    6    6    6          61
 Near X = -0.11800764E-06  -1.0000000      0.29563535    , d:  0.67481342     -0.67480671       1.4819056
 i,j,k,ie:    1    1    1          62
 Near X =  -1.1685631     -0.67481339      0.13437970    , d:   1.9204073       0.0000000      0.85575184
 i,j,k,ie:    2    1    1          62
 Near X =  -1.1685631     -0.67481339      0.15332278    , d:   1.1685629       0.0000000      0.85575184
 i,j,k,ie:    3    1    1          62
 Near X =  -1.1685631     -0.67481339      0.19200993    , d:   1.1685629       0.0000000      0.85575184
 i,j,k,ie:    4    1    1          62
 Near X =  -1.1685631     -0.67481339      0.23800512    , d:   1.1685629       0.0000000      0.85575184
 i,j,k,ie:    5    1    1          62
 Near X =  -1.1685631     -0.67481339      0.27669227    , d:   1.1685629       0.0000000      0.85575184
 i,j,k,ie:    6    1    1          62
 Near X =  -1.1685631     -0.67481339      0.29563535    , d:   1.1685629     -0.18143695      0.85575184
 i,j,k,ie:    1    2    1          62
 Near X =  -1.1105604     -0.73281238      0.13437970    , d:  0.66942282       0.0000000      0.85575184
 i,j,k,ie:    2    2    1          62
 Near X =  -1.1105604     -0.73281238      0.15332278    , d:  0.28792307       0.0000000      0.85575184
 i,j,k,ie:    3    2    1          62
 Near X =  -1.1105604     -0.73281238      0.19200993    , d:  0.28792307       0.0000000      0.85575184
 i,j,k,ie:    4    2    1          62
 Near X =  -1.1105604     -0.73281238      0.23800512    , d:  0.28792307       0.0000000      0.85575184
 i,j,k,ie:    5    2    1          62
 Near X =  -1.1105604     -0.73281238      0.27669227    , d:  0.28792307       0.0000000      0.85575184
 i,j,k,ie:    6    2    1          62
 Near X =  -1.1105604     -0.73281238      0.29563535    , d:  0.28792307     -0.21812583      0.85575184
 i,j,k,ie:    1    3    1          62
 Near X = -0.99210237     -0.85126281      0.13437970    , d:  0.67088641       0.0000000      0.85575184
 i,j,k,ie:    2    3    1          62
 Near X = -0.99210237     -0.85126281      0.15332278    , d:  0.25721173       0.0000000      0.85575184
 i,j,k,ie:    3    3    1          62
 Near X = -0.99210237     -0.85126281      0.19200993    , d:  0.25721173       0.0000000      0.85575184
 i,j,k,ie:    4    3    1          62
 Near X = -0.99210237     -0.85126281      0.23800512    , d:  0.25721173       0.0000000      0.85575184
 i,j,k,ie:    5    3    1          62
 Near X = -0.99210237     -0.85126281      0.27669227    , d:  0.25721173       0.0000000      0.85575184
 i,j,k,ie:    6    3    1          62
 Near X = -0.99210237     -0.85126281      0.29563535    , d:  0.25721173     -0.29305495      0.85575184
 i,j,k,ie:    1    4    1          62
 Near X = -0.85126753     -0.99208865      0.13437970    , d:  0.67262647       0.0000000      0.85575184
 i,j,k,ie:    2    4    1          62
 Near X = -0.85126753     -0.99208865      0.15332278    , d:  0.22069899       0.0000000      0.85575184
 i,j,k,ie:    3    4    1          62
 Near X = -0.85126753     -0.99208865      0.19200993    , d:  0.22069899       0.0000000      0.85575184
 i,j,k,ie:    4    4    1          62
 Near X = -0.85126753     -0.99208865      0.23800512    , d:  0.22069899       0.0000000      0.85575184
 i,j,k,ie:    5    4    1          62
 Near X = -0.85126753     -0.99208865      0.27669227    , d:  0.22069899       0.0000000      0.85575184
 i,j,k,ie:    6    4    1          62
 Near X = -0.85126753     -0.99208865      0.29563535    , d:  0.22069899     -0.38213825      0.85575184
 i,j,k,ie:    1    5    1          62
 Near X = -0.73280953      -1.1105391      0.13437970    , d:  0.67409006       0.0000000      0.85575184
 i,j,k,ie:    2    5    1          62
 Near X = -0.73280953      -1.1105391      0.15332278    , d:  0.18998766       0.0000000      0.85575184
 i,j,k,ie:    3    5    1          62
 Near X = -0.73280953      -1.1105391      0.19200993    , d:  0.18998766       0.0000000      0.85575184
 i,j,k,ie:    4    5    1          62
 Near X = -0.73280953      -1.1105391      0.23800512    , d:  0.18998766       0.0000000      0.85575184
 i,j,k,ie:    5    5    1          62
 Near X = -0.73280953      -1.1105391      0.27669227    , d:  0.18998766       0.0000000      0.85575184
 i,j,k,ie:    6    5    1          62
 Near X = -0.73280953      -1.1105391      0.29563535    , d:  0.18998766     -0.45706737      0.85575184
 i,j,k,ie:    1    6    1          62
 Near X = -0.67480683      -1.1685381      0.13437970    , d:   1.3496201       0.0000000      0.85575184
 i,j,k,ie:    2    6    1          62
 Near X = -0.67480683      -1.1685381      0.15332278    , d:  0.67480671       0.0000000      0.85575184
 i,j,k,ie:    3    6    1          62
 Near X = -0.67480683      -1.1685381      0.19200993    , d:  0.67480671       0.0000000      0.85575184
 i,j,k,ie:    4    6    1          62
 Near X = -0.67480683      -1.1685381      0.23800512    , d:  0.67480671       0.0000000      0.85575184
 i,j,k,ie:    5    6    1          62
 Near X = -0.67480683      -1.1685381      0.27669227    , d:  0.67480671       0.0000000      0.85575184
 i,j,k,ie:    6    6    1          62
 Near X = -0.67480683      -1.1685381      0.29563535    , d:   1.3496136     -0.49375625      0.85575184
 i,j,k,ie:    1    1    2          62
 Near X =  -1.1329736     -0.65426141      0.13437970    , d:   1.8757688       0.0000000      0.85575184
 i,j,k,ie:    2    1    2          62
 Near X =  -1.1329736     -0.65426141      0.15332278    , d:   1.1329734       0.0000000      0.85575184
 i,j,k,ie:    3    1    2          62
 Near X =  -1.1329736     -0.65426141      0.19200993    , d:   1.1329734       0.0000000      0.85575184
 i,j,k,ie:    4    1    2          62
 Near X =  -1.1329736     -0.65426141      0.23800512    , d:   1.1329734       0.0000000      0.85575184
 i,j,k,ie:    5    1    2          62
 Near X =  -1.1329736     -0.65426141      0.27669227    , d:   1.1329734       0.0000000      0.85575184
 i,j,k,ie:    6    1    2          62
 Near X =  -1.1329736     -0.65426141      0.29563535    , d:   1.1329734     -0.17591114      0.85575184
 i,j,k,ie:    1    2    2          62
 Near X =  -1.0767374     -0.71049400      0.13437970    , d:  0.49933918       0.0000000      0.85575184
 i,j,k,ie:    6    2    2          62
 Near X =  -1.0767374     -0.71049400      0.29563535    , d:   0.0000000     -0.21148263      0.85575184
 i,j,k,ie:    1    3    2          62
 Near X = -0.96188711     -0.82533693      0.13437970    , d:  0.54145245       0.0000000      0.85575184
 i,j,k,ie:    6    3    2          62
 Near X = -0.96188711     -0.82533693      0.29563535    , d:   0.0000000     -0.28412972      0.85575184
 i,j,k,ie:    1    4    2          62
 Near X = -0.82534150     -0.96187381      0.13437970    , d:  0.59152096       0.0000000      0.85575184
 i,j,k,ie:    6    4    2          62
 Near X = -0.82534150     -0.96187381      0.29563535    , d:   0.0000000     -0.37049993      0.85575184
 i,j,k,ie:    1    5    2          62
 Near X = -0.71049123      -1.0767167      0.13437970    , d:  0.63363423       0.0000000      0.85575184
 i,j,k,ie:    6    5    2          62
 Near X = -0.71049123      -1.0767167      0.29563535    , d:   0.0000000     -0.44314702      0.85575184
 i,j,k,ie:    1    6    2          62
 Near X = -0.65425505      -1.1329493      0.13437970    , d:   1.3085164       0.0000000      0.85575184
 i,j,k,ie:    2    6    2          62
 Near X = -0.65425505      -1.1329493      0.15332278    , d:  0.65425489       0.0000000      0.85575184
 i,j,k,ie:    3    6    2          62
 Near X = -0.65425505      -1.1329493      0.19200993    , d:  0.65425489       0.0000000      0.85575184
 i,j,k,ie:    4    6    2          62
 Near X = -0.65425505      -1.1329493      0.23800512    , d:  0.65425489       0.0000000      0.85575184
 i,j,k,ie:    5    6    2          62
 Near X = -0.65425505      -1.1329493      0.27669227    , d:  0.65425489       0.0000000      0.85575184
 i,j,k,ie:    6    6    2          62
 Near X = -0.65425505      -1.1329493      0.29563535    , d:   1.3085101     -0.47871851      0.85575184
 i,j,k,ie:    1    1    3          62
 Near X =  -1.0602897     -0.61228843      0.13437970    , d:   1.7846043       0.0000000      0.85575184
 i,j,k,ie:    2    1    3          62
 Near X =  -1.0602897     -0.61228843      0.15332278    , d:   1.0602895       0.0000000      0.85575184
 i,j,k,ie:    3    1    3          62
 Near X =  -1.0602897     -0.61228843      0.19200993    , d:   1.0602895       0.0000000      0.85575184
 i,j,k,ie:    4    1    3          62
 Near X =  -1.0602897     -0.61228843      0.23800512    , d:   1.0602895       0.0000000      0.85575184
 i,j,k,ie:    5    1    3          62
 Near X =  -1.0602897     -0.61228843      0.27669227    , d:   1.0602895       0.0000000      0.85575184
 i,j,k,ie:    6    1    3          62
 Near X =  -1.0602897     -0.61228843      0.29563535    , d:   1.0602895     -0.16462588      0.85575184
 i,j,k,ie:    1    2    3          62
 Near X =  -1.0076612     -0.66491352      0.13437970    , d:  0.46730496       0.0000000      0.85575184
 i,j,k,ie:    6    2    3          62
 Near X =  -1.0076612     -0.66491352      0.29563535    , d:   0.0000000     -0.19791534      0.85575184
 i,j,k,ie:    1    3    3          62
 Near X = -0.90017895     -0.77238891      0.13437970    , d:  0.50671653       0.0000000      0.85575184
 i,j,k,ie:    6    3    3          62
 Near X = -0.90017895     -0.77238891      0.29563535    , d:   0.0000000     -0.26590189      0.85575184
 i,j,k,ie:    1    4    3          62
 Near X = -0.77239319     -0.90016650      0.13437970    , d:  0.55357298       0.0000000      0.85575184
 i,j,k,ie:    6    4    3          62
 Near X = -0.77239319     -0.90016650      0.29563535    , d:   0.0000000     -0.34673117      0.85575184
 i,j,k,ie:    1    5    3          62
 Near X = -0.66491093      -1.0076419      0.13437970    , d:  0.59298455       0.0000000      0.85575184
 i,j,k,ie:    6    5    3          62
 Near X = -0.66491093      -1.0076419      0.29563535    , d:   0.0000000     -0.41471771      0.85575184
 i,j,k,ie:    1    6    3          62
 Near X = -0.61228248      -1.0602670      0.13437970    , d:   1.2245708       0.0000000      0.85575184
 i,j,k,ie:    2    6    3          62
 Near X = -0.61228248      -1.0602670      0.15332278    , d:  0.61228234       0.0000000      0.85575184
 i,j,k,ie:    3    6    3          62
 Near X = -0.61228248      -1.0602670      0.19200993    , d:  0.61228234       0.0000000      0.85575184
 i,j,k,ie:    4    6    3          62
 Near X = -0.61228248      -1.0602670      0.23800512    , d:  0.61228234       0.0000000      0.85575184
 i,j,k,ie:    5    6    3          62
 Near X = -0.61228248      -1.0602670      0.27669227    , d:  0.61228234       0.0000000      0.85575184
 i,j,k,ie:    6    6    3          62
 Near X = -0.61228248      -1.0602670      0.29563535    , d:   1.2245649     -0.44800718      0.85575184
 i,j,k,ie:    1    1    4          62
 Near X = -0.97387569     -0.56238672      0.13437970    , d:   1.6762186       0.0000000      0.85575184
 i,j,k,ie:    2    1    4          62
 Near X = -0.97387569     -0.56238672      0.15332278    , d:  0.97387552       0.0000000      0.85575184
 i,j,k,ie:    3    1    4          62
 Near X = -0.97387569     -0.56238672      0.19200993    , d:  0.97387552       0.0000000      0.85575184
 i,j,k,ie:    4    1    4          62
 Near X = -0.97387569     -0.56238672      0.23800512    , d:  0.97387552       0.0000000      0.85575184
 i,j,k,ie:    5    1    4          62
 Near X = -0.97387569     -0.56238672      0.27669227    , d:  0.97387552       0.0000000      0.85575184
 i,j,k,ie:    6    1    4          62
 Near X = -0.97387569     -0.56238672      0.29563535    , d:  0.97387552     -0.15120881      0.85575184
 i,j,k,ie:    1    2    4          62
 Near X = -0.92553647     -0.61072284      0.13437970    , d:  0.42921945       0.0000000      0.85575184
 i,j,k,ie:    6    2    4          62
 Near X = -0.92553647     -0.61072284      0.29563535    , d:   0.0000000     -0.18178517      0.85575184
 i,j,k,ie:    1    3    4          62
 Near X = -0.82681406     -0.70943895      0.13437970    , d:  0.46541896       0.0000000      0.85575184
 i,j,k,ie:    6    3    4          62
 Near X = -0.82681406     -0.70943895      0.29563535    , d:   0.0000000     -0.24423079      0.85575184
 i,j,k,ie:    1    4    4          62
 Near X = -0.70944288     -0.82680263      0.13437970    , d:  0.50845660       0.0000000      0.85575184
 i,j,k,ie:    6    4    4          62
 Near X = -0.70944288     -0.82680263      0.29563535    , d:   0.0000000     -0.31847246      0.85575184
 i,j,k,ie:    1    5    4          62
 Near X = -0.61072046     -0.92551873      0.13437970    , d:  0.54465611       0.0000000      0.85575184
 i,j,k,ie:    6    5    4          62
 Near X = -0.61072046     -0.92551873      0.29563535    , d:   0.0000000     -0.38091808      0.85575184
 i,j,k,ie:    1    6    4          62
 Near X = -0.56238125     -0.97385485      0.13437970    , d:   1.1247679       0.0000000      0.85575184
 i,j,k,ie:    2    6    4          62
 Near X = -0.56238125     -0.97385485      0.15332278    , d:  0.56238112       0.0000000      0.85575184
 i,j,k,ie:    3    6    4          62
 Near X = -0.56238125     -0.97385485      0.19200993    , d:  0.56238112       0.0000000      0.85575184
 i,j,k,ie:    4    6    4          62
 Near X = -0.56238125     -0.97385485      0.23800512    , d:  0.56238112       0.0000000      0.85575184
 i,j,k,ie:    5    6    4          62
 Near X = -0.56238125     -0.97385485      0.27669227    , d:  0.56238112       0.0000000      0.85575184
 i,j,k,ie:    6    6    4          62
 Near X = -0.56238125     -0.97385485      0.29563535    , d:   1.1247625     -0.41149444      0.85575184
 i,j,k,ie:    1    1    5          62
 Near X = -0.90119179     -0.52041374      0.13437970    , d:   1.5850541       0.0000000      0.85575184
 i,j,k,ie:    2    1    5          62
 Near X = -0.90119179     -0.52041374      0.15332278    , d:  0.90119162       0.0000000      0.85575184
 i,j,k,ie:    3    1    5          62
 Near X = -0.90119179     -0.52041374      0.19200993    , d:  0.90119162       0.0000000      0.85575184
 i,j,k,ie:    4    1    5          62
 Near X = -0.90119179     -0.52041374      0.23800512    , d:  0.90119162       0.0000000      0.85575184
 i,j,k,ie:    5    1    5          62
 Near X = -0.90119179     -0.52041374      0.27669227    , d:  0.90119162       0.0000000      0.85575184
 i,j,k,ie:    6    1    5          62
 Near X = -0.90119179     -0.52041374      0.29563535    , d:  0.90119162     -0.13992354      0.85575184
 i,j,k,ie:    1    2    5          62
 Near X = -0.85646030     -0.56514236      0.13437970    , d:  0.39718523       0.0000000      0.85575184
 i,j,k,ie:    6    2    5          62
 Near X = -0.85646030     -0.56514236      0.29563535    , d:   0.0000000     -0.16821788      0.85575184
 i,j,k,ie:    1    3    5          62
 Near X = -0.76510590     -0.65649092      0.13437970    , d:  0.43068304       0.0000000      0.85575184
 i,j,k,ie:    6    3    5          62
 Near X = -0.76510590     -0.65649092      0.29563535    , d:   0.0000000     -0.22600296      0.85575184
 i,j,k,ie:    1    4    5          62
 Near X = -0.65649456     -0.76509532      0.13437970    , d:  0.47050862       0.0000000      0.85575184
 i,j,k,ie:    6    4    5          62
 Near X = -0.65649456     -0.76509532      0.29563535    , d:   0.0000000     -0.29470369      0.85575184
 i,j,k,ie:    1    5    5          62
 Near X = -0.56514016     -0.85644388      0.13437970    , d:  0.50400643       0.0000000      0.85575184
 i,j,k,ie:    6    5    5          62
 Near X = -0.56514016     -0.85644388      0.29563535    , d:   0.0000000     -0.35248877      0.85575184
 i,j,k,ie:    1    6    5          62
 Near X = -0.52040868     -0.90117250      0.13437970    , d:   1.0408224       0.0000000      0.85575184
 i,j,k,ie:    2    6    5          62
 Near X = -0.52040868     -0.90117250      0.15332278    , d:  0.52040856       0.0000000      0.85575184
 i,j,k,ie:    3    6    5          62
 Near X = -0.52040868     -0.90117250      0.19200993    , d:  0.52040856       0.0000000      0.85575184
 i,j,k,ie:    4    6    5          62
 Near X = -0.52040868     -0.90117250      0.23800512    , d:  0.52040856       0.0000000      0.85575184
 i,j,k,ie:    5    6    5          62
 Near X = -0.52040868     -0.90117250      0.27669227    , d:  0.52040856       0.0000000      0.85575184
 i,j,k,ie:    6    6    5          62
 Near X = -0.52040868     -0.90117250      0.29563535    , d:   1.0408173     -0.38078311      0.85575184
 i,j,k,ie:    1    1    6          62
 Near X = -0.86560227     -0.49986176      0.13437970    , d:   1.6174465     -0.30296080      0.85575184
 i,j,k,ie:    2    1    6          62
 Near X = -0.86560227     -0.49986176      0.15332278    , d:  0.86560211     -0.30296080      0.85575184
 i,j,k,ie:    3    1    6          62
 Near X = -0.86560227     -0.49986176      0.19200993    , d:  0.86560211     -0.30296080      0.85575184
 i,j,k,ie:    4    1    6          62
 Near X = -0.86560227     -0.49986176      0.23800512    , d:  0.86560211     -0.30296080      0.85575184
 i,j,k,ie:    5    1    6          62
 Near X = -0.86560227     -0.49986176      0.27669227    , d:  0.86560211     -0.30296080      0.85575184
 i,j,k,ie:    6    1    6          62
 Near X = -0.86560227     -0.49986176      0.29563535    , d:  0.86560211     -0.48439775      0.85575184
 i,j,k,ie:    1    2    6          62
 Near X = -0.82263731     -0.54282398      0.13437970    , d:  0.38149975     -0.28792307      0.85575184
 i,j,k,ie:    2    2    6          62
 Near X = -0.82263731     -0.54282398      0.15332278    , d:   0.0000000     -0.28792307      0.85575184
 i,j,k,ie:    3    2    6          62
 Near X = -0.82263731     -0.54282398      0.19200993    , d:   0.0000000     -0.28792307      0.85575184
 i,j,k,ie:    4    2    6          62
 Near X = -0.82263731     -0.54282398      0.23800512    , d:   0.0000000     -0.28792307      0.85575184
 i,j,k,ie:    5    2    6          62
 Near X = -0.82263731     -0.54282398      0.27669227    , d:   0.0000000     -0.28792307      0.85575184
 i,j,k,ie:    6    2    6          62
 Near X = -0.82263731     -0.54282398      0.29563535    , d:   0.0000000     -0.50604889      0.85575184
 i,j,k,ie:    1    3    6          62
 Near X = -0.73489064     -0.63056504      0.13437970    , d:  0.41367468     -0.25721173      0.85575184
 i,j,k,ie:    2    3    6          62
 Near X = -0.73489064     -0.63056504      0.15332278    , d:   0.0000000     -0.25721173      0.85575184
 i,j,k,ie:    3    3    6          62
 Near X = -0.73489064     -0.63056504      0.19200993    , d:   0.0000000     -0.25721173      0.85575184
 i,j,k,ie:    4    3    6          62
 Near X = -0.73489064     -0.63056504      0.23800512    , d:   0.0000000     -0.25721173      0.85575184
 i,j,k,ie:    5    3    6          62
 Near X = -0.73489064     -0.63056504      0.27669227    , d:   0.0000000     -0.25721173      0.85575184
 i,j,k,ie:    6    3    6          62
 Near X = -0.73489064     -0.63056504      0.29563535    , d:   0.0000000     -0.55026668      0.85575184
 i,j,k,ie:    1    4    6          62
 Near X = -0.63056853     -0.73488048      0.13437970    , d:  0.45192748     -0.22069899      0.85575184
 i,j,k,ie:    2    4    6          62
 Near X = -0.63056853     -0.73488048      0.15332278    , d:   0.0000000     -0.22069899      0.85575184
 i,j,k,ie:    3    4    6          62
 Near X = -0.63056853     -0.73488048      0.19200993    , d:   0.0000000     -0.22069899      0.85575184
 i,j,k,ie:    4    4    6          62
 Near X = -0.63056853     -0.73488048      0.23800512    , d:   0.0000000     -0.22069899      0.85575184
 i,j,k,ie:    5    4    6          62
 Near X = -0.63056853     -0.73488048      0.27669227    , d:   0.0000000     -0.22069899      0.85575184
 i,j,k,ie:    6    4    6          62
 Near X = -0.63056853     -0.73488048      0.29563535    , d:   0.0000000     -0.60283725      0.85575184
 i,j,k,ie:    1    5    6          62
 Near X = -0.54282187     -0.82262154      0.13437970    , d:  0.48410240     -0.18998766      0.85575184
 i,j,k,ie:    2    5    6          62
 Near X = -0.54282187     -0.82262154      0.15332278    , d:   0.0000000     -0.18998766      0.85575184
 i,j,k,ie:    3    5    6          62
 Near X = -0.54282187     -0.82262154      0.19200993    , d:   0.0000000     -0.18998766      0.85575184
 i,j,k,ie:    4    5    6          62
 Near X = -0.54282187     -0.82262154      0.23800512    , d:   0.0000000     -0.18998766      0.85575184
 i,j,k,ie:    5    5    6          62
 Near X = -0.54282187     -0.82262154      0.27669227    , d:   0.0000000     -0.18998766      0.85575184
 i,j,k,ie:    6    5    6          62
 Near X = -0.54282187     -0.82262154      0.29563535    , d:   0.0000000     -0.64705503      0.85575184
 i,j,k,ie:    1    6    6          62
 Near X = -0.49985690     -0.86558375      0.13437970    , d:   1.1746702     -0.17494992      0.85575184
 i,j,k,ie:    2    6    6          62
 Near X = -0.49985690     -0.86558375      0.15332278    , d:  0.49985679     -0.17494992      0.85575184
 i,j,k,ie:    3    6    6          62
 Near X = -0.49985690     -0.86558375      0.19200993    , d:  0.49985679     -0.17494992      0.85575184
 i,j,k,ie:    4    6    6          62
 Near X = -0.49985690     -0.86558375      0.23800512    , d:  0.49985679     -0.17494992      0.85575184
 i,j,k,ie:    5    6    6          62
 Near X = -0.49985690     -0.86558375      0.27669227    , d:  0.49985679     -0.17494992      0.85575184
 i,j,k,ie:    6    6    6          62
 Near X = -0.49985690     -0.86558375      0.29563535    , d:   1.1746637     -0.66870617      0.85575184
 i,j,k,ie:    1    1    1          63
 Near X =  -1.3500000     -0.33065464E-15  0.13437970    , d:   1.3499999       0.0000000      0.74074073
 i,j,k,ie:    2    1    1          63
 Near X =  -1.3500000     -0.33065464E-15  0.15332278    , d:  0.67519320       0.0000000      0.74074073
 i,j,k,ie:    3    1    1          63
 Near X =  -1.3500000     -0.33065464E-15  0.19200993    , d:  0.67519320       0.0000000      0.74074073
 i,j,k,ie:    4    1    1          63
 Near X =  -1.3500000     -0.33065464E-15  0.23800512    , d:  0.67519320       0.0000000      0.74074073
 i,j,k,ie:    5    1    1          63
 Near X =  -1.3500000     -0.33065464E-15  0.27669227    , d:  0.67519320       0.0000000      0.74074073
 i,j,k,ie:    6    1    1          63
 Near X =  -1.3500000     -0.33065464E-15  0.29563535    , d:   2.5185381       0.0000000      0.74074073
 i,j,k,ie:    1    2    1          63
 Near X =  -1.3286862     -0.79271906E-01  0.13437970    , d:  0.50604889       0.0000000      0.74074073
 i,j,k,ie:    2    2    1          63
 Near X =  -1.3286862     -0.79271906E-01  0.15332278    , d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    3    2    1          63
 Near X =  -1.3286862     -0.79271906E-01  0.19200993    , d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    4    2    1          63
 Near X =  -1.3286862     -0.79271906E-01  0.23800512    , d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    5    2    1          63
 Near X =  -1.3286862     -0.79271906E-01  0.27669227    , d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    6    2    1          63
 Near X =  -1.3286862     -0.79271906E-01  0.29563535    , d:   2.5185410       0.0000000      0.74074073
 i,j,k,ie:    1    3    1          63
 Near X =  -1.2851573     -0.24116767      0.13437970    , d:  0.55026668       0.0000000      0.74074073
 i,j,k,ie:    2    3    1          63
 Near X =  -1.2851573     -0.24116767      0.15332278    , d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    3    3    1          63
 Near X =  -1.2851573     -0.24116767      0.19200993    , d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    4    3    1          63
 Near X =  -1.2851573     -0.24116767      0.23800512    , d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    5    3    1          63
 Near X =  -1.2851573     -0.24116767      0.27669227    , d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    6    3    1          63
 Near X =  -1.2851573     -0.24116767      0.29563535    , d:   2.5185470       0.0000000      0.74074073
 i,j,k,ie:    1    4    1          63
 Near X =  -1.2334058     -0.43364572      0.13437970    , d:  0.60283725       0.0000000      0.74074073
 i,j,k,ie:    2    4    1          63
 Near X =  -1.2334058     -0.43364572      0.15332278    , d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    3    4    1          63
 Near X =  -1.2334058     -0.43364572      0.19200993    , d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    4    4    1          63
 Near X =  -1.2334058     -0.43364572      0.23800512    , d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    5    4    1          63
 Near X =  -1.2334058     -0.43364572      0.27669227    , d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    6    4    1          63
 Near X =  -1.2334058     -0.43364572      0.29563535    , d:   2.5185542       0.0000000      0.74074073
 i,j,k,ie:    1    5    1          63
 Near X =  -1.1898769     -0.59554148      0.13437970    , d:  0.64705503       0.0000000      0.74074073
 i,j,k,ie:    2    5    1          63
 Near X =  -1.1898769     -0.59554148      0.15332278    , d:  0.30848661       0.0000000      0.74074073
 i,j,k,ie:    3    5    1          63
 Near X =  -1.1898769     -0.59554148      0.19200993    , d:  0.30848661       0.0000000      0.74074073
 i,j,k,ie:    4    5    1          63
 Near X =  -1.1898769     -0.59554148      0.23800512    , d:  0.30848661       0.0000000      0.74074073
 i,j,k,ie:    5    5    1          63
 Near X =  -1.1898769     -0.59554148      0.27669227    , d:  0.30848661       0.0000000      0.74074073
 i,j,k,ie:    6    5    1          63
 Near X =  -1.1898769     -0.59554148      0.29563535    , d:   2.5185602       0.0000000      0.74074073
 i,j,k,ie:    1    6    1          63
 Near X =  -1.1685631     -0.67481339      0.13437970    , d:   1.8433699       0.0000000      0.74074073
 i,j,k,ie:    2    6    1          63
 Near X =  -1.1685631     -0.67481339      0.15332278    , d:   1.8433699       0.0000000      0.74074073
 i,j,k,ie:    3    6    1          63
 Near X =  -1.1685631     -0.67481339      0.19200993    , d:   1.8433699       0.0000000      0.74074073
 i,j,k,ie:    4    6    1          63
 Near X =  -1.1685631     -0.67481339      0.23800512    , d:   1.8433699       0.0000000      0.74074073
 i,j,k,ie:    5    6    1          63
 Near X =  -1.1685631     -0.67481339      0.27669227    , d:   1.8433699       0.0000000      0.74074073
 i,j,k,ie:    6    6    1          63
 Near X =  -1.1685631     -0.67481339      0.29563535    , d:   2.5185631       0.0000000      0.74074073
 i,j,k,ie:    1    1    2          63
 Near X =  -1.3088847     -0.32058429E-15  0.13437970    , d:   1.3088845       0.0000000      0.74074073
 i,j,k,ie:    2    1    2          63
 Near X =  -1.3088847     -0.32058429E-15  0.15332278    , d:  0.56599635       0.0000000      0.74074073
 i,j,k,ie:    3    1    2          63
 Near X =  -1.3088847     -0.32058429E-15  0.19200993    , d:  0.56599635       0.0000000      0.74074073
 i,j,k,ie:    4    1    2          63
 Near X =  -1.3088847     -0.32058429E-15  0.23800512    , d:  0.56599635       0.0000000      0.74074073
 i,j,k,ie:    5    1    2          63
 Near X =  -1.3088847     -0.32058429E-15  0.27669227    , d:  0.56599635       0.0000000      0.74074073
 i,j,k,ie:    6    1    2          63
 Near X =  -1.3088847     -0.32058429E-15  0.29563535    , d:   2.4418340       0.0000000      0.74074073
 i,j,k,ie:    1    2    2          63
 Near X =  -1.2882200     -0.76857618E-01  0.13437970    , d:  0.21148263       0.0000000      0.74074073
 i,j,k,ie:    6    2    2          63
 Near X =  -1.2882200     -0.76857618E-01  0.29563535    , d:   2.4418369       0.0000000      0.74074073
 i,j,k,ie:    1    3    2          63
 Near X =  -1.2460168     -0.23382272      0.13437970    , d:  0.28412972       0.0000000      0.74074073
 i,j,k,ie:    6    3    2          63
 Near X =  -1.2460168     -0.23382272      0.29563535    , d:   2.4418427       0.0000000      0.74074073
 i,j,k,ie:    1    4    2          63
 Near X =  -1.1958414     -0.42043869      0.13437970    , d:  0.37049993       0.0000000      0.74074073
 i,j,k,ie:    6    4    2          63
 Near X =  -1.1958414     -0.42043869      0.29563535    , d:   2.4418496       0.0000000      0.74074073
 i,j,k,ie:    1    5    2          63
 Near X =  -1.1536383     -0.57740379      0.13437970    , d:  0.44314702       0.0000000      0.74074073
 i,j,k,ie:    6    5    2          63
 Near X =  -1.1536383     -0.57740379      0.29563535    , d:   2.4418554       0.0000000      0.74074073
 i,j,k,ie:    1    6    2          63
 Near X =  -1.1329736     -0.65426141      0.13437970    , d:   1.7872286       0.0000000      0.74074073
 i,j,k,ie:    2    6    2          63
 Near X =  -1.1329736     -0.65426141      0.15332278    , d:   1.7872286       0.0000000      0.74074073
 i,j,k,ie:    3    6    2          63
 Near X =  -1.1329736     -0.65426141      0.19200993    , d:   1.7872286       0.0000000      0.74074073
 i,j,k,ie:    4    6    2          63
 Near X =  -1.1329736     -0.65426141      0.23800512    , d:   1.7872286       0.0000000      0.74074073
 i,j,k,ie:    5    6    2          63
 Near X =  -1.1329736     -0.65426141      0.27669227    , d:   1.7872286       0.0000000      0.74074073
 i,j,k,ie:    6    6    2          63
 Near X =  -1.1329736     -0.65426141      0.29563535    , d:   2.4418583       0.0000000      0.74074073
 i,j,k,ie:    1    1    3          63
 Near X =  -1.2249155     -0.30001778E-15  0.13437970    , d:   1.2249154       0.0000000      0.74074073
 i,j,k,ie:    2    1    3          63
 Near X =  -1.2249155     -0.30001778E-15  0.15332278    , d:  0.50053490       0.0000000      0.74074073
 i,j,k,ie:    3    1    3          63
 Near X =  -1.2249155     -0.30001778E-15  0.19200993    , d:  0.50053490       0.0000000      0.74074073
 i,j,k,ie:    4    1    3          63
 Near X =  -1.2249155     -0.30001778E-15  0.23800512    , d:  0.50053490       0.0000000      0.74074073
 i,j,k,ie:    5    1    3          63
 Near X =  -1.2249155     -0.30001778E-15  0.27669227    , d:  0.50053490       0.0000000      0.74074073
 i,j,k,ie:    6    1    3          63
 Near X =  -1.2249155     -0.30001778E-15  0.29563535    , d:   2.2851825     -0.26730483E-01  0.74074073
 i,j,k,ie:    1    2    3          63
 Near X =  -1.2055765     -0.71926954E-01  0.13437970    , d:  0.19791534       0.0000000      0.74074073
 i,j,k,ie:    6    2    3          63
 Near X =  -1.2055765     -0.71926954E-01  0.29563535    , d:   2.2851852       0.0000000      0.74074073
 i,j,k,ie:    1    3    3          63
 Near X =  -1.1660808     -0.21882224      0.13437970    , d:  0.26590189       0.0000000      0.74074073
 i,j,k,ie:    6    3    3          63
 Near X =  -1.1660808     -0.21882224      0.29563535    , d:   2.2851906       0.0000000      0.74074073
 i,j,k,ie:    1    4    3          63
 Near X =  -1.1191244     -0.39346620      0.13437970    , d:  0.34673117       0.0000000      0.74074073
 i,j,k,ie:    6    4    3          63
 Near X =  -1.1191244     -0.39346620      0.29563535    , d:   2.2851971       0.0000000      0.74074073
 i,j,k,ie:    1    5    3          63
 Near X =  -1.0796286     -0.54036148      0.13437970    , d:  0.41471771       0.0000000      0.74074073
 i,j,k,ie:    6    5    3          63
 Near X =  -1.0796286     -0.54036148      0.29563535    , d:   2.2852025       0.0000000      0.74074073
 i,j,k,ie:    1    6    3          63
 Near X =  -1.0602897     -0.61228843      0.13437970    , d:   1.6725721       0.0000000      0.74074073
 i,j,k,ie:    2    6    3          63
 Near X =  -1.0602897     -0.61228843      0.15332278    , d:   1.6725721       0.0000000      0.74074073
 i,j,k,ie:    3    6    3          63
 Near X =  -1.0602897     -0.61228843      0.19200993    , d:   1.6725721       0.0000000      0.74074073
 i,j,k,ie:    4    6    3          63
 Near X =  -1.0602897     -0.61228843      0.23800512    , d:   1.6725721       0.0000000      0.74074073
 i,j,k,ie:    5    6    3          63
 Near X =  -1.0602897     -0.61228843      0.27669227    , d:   1.6725721       0.0000000      0.74074073
 i,j,k,ie:    6    6    3          63
 Near X =  -1.0602897     -0.61228843      0.29563535    , d:   2.2852052       0.0000000      0.74074073
 i,j,k,ie:    1    1    4          63
 Near X =  -1.1250845     -0.27556623E-15  0.13437970    , d:   1.1250843       0.0000000      0.74074073
 i,j,k,ie:    2    1    4          63
 Near X =  -1.1250845     -0.27556623E-15  0.15332278    , d:  0.42270770       0.0000000      0.74074073
 i,j,k,ie:    3    1    4          63
 Near X =  -1.1250845     -0.27556623E-15  0.19200993    , d:  0.42270770       0.0000000      0.74074073
 i,j,k,ie:    4    1    4          63
 Near X =  -1.1250845     -0.27556623E-15  0.23800512    , d:  0.42270770       0.0000000      0.74074073
 i,j,k,ie:    5    1    4          63
 Near X =  -1.1250845     -0.27556623E-15  0.27669227    , d:  0.42270770       0.0000000      0.74074073
 i,j,k,ie:    6    1    4          63
 Near X =  -1.1250845     -0.27556623E-15  0.29563535    , d:   2.0989393     -0.89684313E-01  0.74074073
 i,j,k,ie:    1    2    4          63
 Near X =  -1.1073216     -0.66064883E-01  0.13437970    , d:  0.18178517       0.0000000      0.74074073
 i,j,k,ie:    6    2    4          63
 Near X =  -1.1073216     -0.66064883E-01  0.29563535    , d:   2.0989418       0.0000000      0.74074073
 i,j,k,ie:    1    3    4          63
 Near X =  -1.0710449     -0.20098815      0.13437970    , d:  0.24423079       0.0000000      0.74074073
 i,j,k,ie:    6    3    4          63
 Near X =  -1.0710449     -0.20098815      0.29563535    , d:   2.0989468       0.0000000      0.74074073
 i,j,k,ie:    1    4    4          63
 Near X =  -1.0279153     -0.36139857      0.13437970    , d:  0.31847246       0.0000000      0.74074073
 i,j,k,ie:    6    4    4          63
 Near X =  -1.0279153     -0.36139857      0.29563535    , d:   2.0989527       0.0000000      0.74074073
 i,j,k,ie:    1    5    4          63
 Near X = -0.99163854     -0.49632184      0.13437970    , d:  0.38091808       0.0000000      0.74074073
 i,j,k,ie:    6    5    4          63
 Near X = -0.99163854     -0.49632184      0.29563535    , d:   2.0989577       0.0000000      0.74074073
 i,j,k,ie:    1    6    4          63
 Near X = -0.97387569     -0.56238672      0.13437970    , d:   1.5362569       0.0000000      0.74074073
 i,j,k,ie:    2    6    4          63
 Near X = -0.97387569     -0.56238672      0.15332278    , d:   1.5362569       0.0000000      0.74074073
 i,j,k,ie:    3    6    4          63
 Near X = -0.97387569     -0.56238672      0.19200993    , d:   1.5362569       0.0000000      0.74074073
 i,j,k,ie:    4    6    4          63
 Near X = -0.97387569     -0.56238672      0.23800512    , d:   1.5362569       0.0000000      0.74074073
 i,j,k,ie:    5    6    4          63
 Near X = -0.97387569     -0.56238672      0.27669227    , d:   1.5362569       0.0000000      0.74074073
 i,j,k,ie:    6    6    4          63
 Near X = -0.97387569     -0.56238672      0.29563535    , d:   2.0989602       0.0000000      0.74074073
 i,j,k,ie:    1    1    5          63
 Near X =  -1.0411153     -0.25499971E-15  0.13437970    , d:   1.0411152       0.0000000      0.74074073
 i,j,k,ie:    2    1    5          63
 Near X =  -1.0411153     -0.25499971E-15  0.15332278    , d:  0.35724624       0.0000000      0.74074073
 i,j,k,ie:    3    1    5          63
 Near X =  -1.0411153     -0.25499971E-15  0.19200993    , d:  0.35724624       0.0000000      0.74074073
 i,j,k,ie:    4    1    5          63
 Near X =  -1.0411153     -0.25499971E-15  0.23800512    , d:  0.35724624       0.0000000      0.74074073
 i,j,k,ie:    5    1    5          63
 Near X =  -1.0411153     -0.25499971E-15  0.27669227    , d:  0.35724624       0.0000000      0.74074073
 i,j,k,ie:    6    1    5          63
 Near X =  -1.0411153     -0.25499971E-15  0.29563535    , d:   1.9422878     -0.14263559      0.74074073
 i,j,k,ie:    1    2    5          63
 Near X =  -1.0246782     -0.61134219E-01  0.13437970    , d:  0.16821788       0.0000000      0.74074073
 i,j,k,ie:    6    2    5          63
 Near X =  -1.0246782     -0.61134219E-01  0.29563535    , d:   1.9422901       0.0000000      0.74074073
 i,j,k,ie:    1    3    5          63
 Near X = -0.99110886     -0.18598767      0.13437970    , d:  0.22600296       0.0000000      0.74074073
 i,j,k,ie:    6    3    5          63
 Near X = -0.99110886     -0.18598767      0.29563535    , d:   1.9422947       0.0000000      0.74074073
 i,j,k,ie:    1    4    5          63
 Near X = -0.95119826     -0.33442607      0.13437970    , d:  0.29470369       0.0000000      0.74074073
 i,j,k,ie:    6    4    5          63
 Near X = -0.95119826     -0.33442607      0.29563535    , d:   1.9423002       0.0000000      0.74074073
 i,j,k,ie:    1    5    5          63
 Near X = -0.91762893     -0.45927952      0.13437970    , d:  0.35248877       0.0000000      0.74074073
 i,j,k,ie:    6    5    5          63
 Near X = -0.91762893     -0.45927952      0.29563535    , d:   1.9423048       0.0000000      0.74074073
 i,j,k,ie:    1    6    5          63
 Near X = -0.90119179     -0.52041374      0.13437970    , d:   1.4216004       0.0000000      0.74074073
 i,j,k,ie:    2    6    5          63
 Near X = -0.90119179     -0.52041374      0.15332278    , d:   1.4216004       0.0000000      0.74074073
 i,j,k,ie:    3    6    5          63
 Near X = -0.90119179     -0.52041374      0.19200993    , d:   1.4216004       0.0000000      0.74074073
 i,j,k,ie:    4    6    5          63
 Near X = -0.90119179     -0.52041374      0.23800512    , d:   1.4216004       0.0000000      0.74074073
 i,j,k,ie:    5    6    5          63
 Near X = -0.90119179     -0.52041374      0.27669227    , d:   1.4216004       0.0000000      0.74074073
 i,j,k,ie:    6    6    5          63
 Near X = -0.90119179     -0.52041374      0.29563535    , d:   1.9423071       0.0000000      0.74074073
 i,j,k,ie:    1    1    6          63
 Near X =  -1.0000000     -0.24492936E-15  0.13437970    , d:  0.99999985     -0.35000001      0.74074073
 i,j,k,ie:    2    1    6          63
 Near X =  -1.0000000     -0.24492936E-15  0.15332278    , d:  0.32519318     -0.35000001      0.74074073
 i,j,k,ie:    3    1    6          63
 Near X =  -1.0000000     -0.24492936E-15  0.19200993    , d:  0.32519318     -0.35000001      0.74074073
 i,j,k,ie:    4    1    6          63
 Near X =  -1.0000000     -0.24492936E-15  0.23800512    , d:  0.32519318     -0.35000001      0.74074073
 i,j,k,ie:    5    1    6          63
 Near X =  -1.0000000     -0.24492936E-15  0.27669227    , d:  0.32519318     -0.35000001      0.74074073
 i,j,k,ie:    6    1    6          63
 Near X =  -1.0000000     -0.24492936E-15  0.29563535    , d:   2.1685381     -0.35000001      0.74074073
 i,j,k,ie:    1    2    6          63
 Near X = -0.98421199     -0.58719930E-01  0.13437970    , d:  0.16157469     -0.34447421      0.74074073
 i,j,k,ie:    2    2    6          63
 Near X = -0.98421199     -0.58719930E-01  0.15332278    , d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    3    2    6          63
 Near X = -0.98421199     -0.58719930E-01  0.19200993    , d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    4    2    6          63
 Near X = -0.98421199     -0.58719930E-01  0.23800512    , d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    5    2    6          63
 Near X = -0.98421199     -0.58719930E-01  0.27669227    , d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    6    2    6          63
 Near X = -0.98421199     -0.58719930E-01  0.29563535    , d:   2.1740668     -0.34447421      0.74074073
 i,j,k,ie:    1    3    6          63
 Near X = -0.95196838     -0.17864272      0.13437970    , d:  0.21707774     -0.33318894      0.74074073
 i,j,k,ie:    2    3    6          63
 Near X = -0.95196838     -0.17864272      0.15332278    , d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    3    3    6          63
 Near X = -0.95196838     -0.17864272      0.19200993    , d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    4    3    6          63
 Near X = -0.95196838     -0.17864272      0.23800512    , d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    5    3    6          63
 Near X = -0.95196838     -0.17864272      0.27669227    , d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    6    3    6          63
 Near X = -0.95196838     -0.17864272      0.29563535    , d:   2.1853581     -0.33318894      0.74074073
 i,j,k,ie:    1    4    6          63
 Near X = -0.91363391     -0.32121905      0.13437970    , d:  0.28306537     -0.31977188      0.74074073
 i,j,k,ie:    2    4    6          63
 Near X = -0.91363391     -0.32121905      0.15332278    , d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    3    4    6          63
 Near X = -0.91363391     -0.32121905      0.19200993    , d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    4    4    6          63
 Near X = -0.91363391     -0.32121905      0.23800512    , d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    5    4    6          63
 Near X = -0.91363391     -0.32121905      0.27669227    , d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    6    4    6          63
 Near X = -0.91363391     -0.32121905      0.29563535    , d:   2.1987823     -0.31977188      0.74074073
 i,j,k,ie:    1    5    6          63
 Near X = -0.88139029     -0.44114183      0.13437970    , d:  0.33856842     -0.30848661      0.74074073
 i,j,k,ie:    2    5    6          63
 Near X = -0.88139029     -0.44114183      0.15332278    , d:   0.0000000     -0.30848661      0.74074073
 i,j,k,ie:    3    5    6          63
 Near X = -0.88139029     -0.44114183      0.19200993    , d:   0.0000000     -0.30848661      0.74074073
 i,j,k,ie:    4    5    6          63
 Near X = -0.88139029     -0.44114183      0.23800512    , d:   0.0000000     -0.30848661      0.74074073
 i,j,k,ie:    5    5    6          63
 Near X = -0.88139029     -0.44114183      0.27669227    , d:   0.0000000     -0.30848661      0.74074073
 i,j,k,ie:    6    5    6          63
 Near X = -0.88139029     -0.44114183      0.29563535    , d:   2.2100736     -0.30848661      0.74074073
 i,j,k,ie:    1    6    6          63
 Near X = -0.86560227     -0.49986176      0.13437970    , d:   1.5404091     -0.30296080      0.74074073
 i,j,k,ie:    2    6    6          63
 Near X = -0.86560227     -0.49986176      0.15332278    , d:   1.5404091     -0.30296080      0.74074073
 i,j,k,ie:    3    6    6          63
 Near X = -0.86560227     -0.49986176      0.19200993    , d:   1.5404091     -0.30296080      0.74074073
 i,j,k,ie:    4    6    6          63
 Near X = -0.86560227     -0.49986176      0.23800512    , d:   1.5404091     -0.30296080      0.74074073
 i,j,k,ie:    5    6    6          63
 Near X = -0.86560227     -0.49986176      0.27669227    , d:   1.5404091     -0.30296080      0.74074073
 i,j,k,ie:    6    6    6          63
 Near X = -0.86560227     -0.49986176      0.29563535    , d:   2.2156023     -0.30296080      0.74074073
 i,j,k,ie:    1    1    1          64
 Near X =   1.1685381     -0.67480681      0.13437970    , d:   0.0000000      -2.5185381      0.74074073
 i,j,k,ie:    2    1    1          64
 Near X =   1.1685381     -0.67480681      0.15332278    , d:   0.0000000      -2.4663898      0.74074073
 i,j,k,ie:    3    1    1          64
 Near X =   1.1685381     -0.67480681      0.19200993    , d:   0.0000000      -2.4663898      0.74074073
 i,j,k,ie:    4    1    1          64
 Near X =   1.1685381     -0.67480681      0.23800512    , d:   0.0000000      -2.4663898      0.74074073
 i,j,k,ie:    5    1    1          64
 Near X =   1.1685381     -0.67480681      0.27669227    , d:   0.0000000      -2.4663898      0.74074073
 i,j,k,ie:    6    1    1          64
 Near X =   1.1685381     -0.67480681      0.29563535    , d:   0.0000000      -2.4663898      0.74074073
 i,j,k,ie:    1    2    1          64
 Near X =   1.1898548     -0.59553569      0.13437970    , d:   0.0000000      -2.5185410      0.74074073
 i,j,k,ie:    2    2    1          64
 Near X =   1.1898548     -0.59553569      0.15332278    , d:   0.0000000     -0.30848089      0.74074073
 i,j,k,ie:    3    2    1          64
 Near X =   1.1898548     -0.59553569      0.19200993    , d:   0.0000000     -0.30848089      0.74074073
 i,j,k,ie:    4    2    1          64
 Near X =   1.1898548     -0.59553569      0.23800512    , d:   0.0000000     -0.30848089      0.74074073
 i,j,k,ie:    5    2    1          64
 Near X =   1.1898548     -0.59553569      0.27669227    , d:   0.0000000     -0.30848089      0.74074073
 i,j,k,ie:    6    2    1          64
 Near X =   1.1898548     -0.59553569      0.29563535    , d:   0.0000000     -0.30848089      0.74074073
 i,j,k,ie:    1    3    1          64
 Near X =   1.2333897     -0.43364152      0.13437970    , d:   0.0000000      -2.5185470      0.74074073
 i,j,k,ie:    2    3    1          64
 Near X =   1.2333897     -0.43364152      0.15332278    , d:   0.0000000     -0.31976771      0.74074073
 i,j,k,ie:    3    3    1          64
 Near X =   1.2333897     -0.43364152      0.19200993    , d:   0.0000000     -0.31976771      0.74074073
 i,j,k,ie:    4    3    1          64
 Near X =   1.2333897     -0.43364152      0.23800512    , d:   0.0000000     -0.31976771      0.74074073
 i,j,k,ie:    5    3    1          64
 Near X =   1.2333897     -0.43364152      0.27669227    , d:   0.0000000     -0.31976771      0.74074073
 i,j,k,ie:    6    3    1          64
 Near X =   1.2333897     -0.43364152      0.29563535    , d:   0.0000000     -0.31976771      0.74074073
 i,j,k,ie:    1    4    1          64
 Near X =   1.2851484     -0.24116537      0.13437970    , d:   0.0000000      -2.5185542      0.74074073
 i,j,k,ie:    2    4    1          64
 Near X =   1.2851484     -0.24116537      0.15332278    , d:   0.0000000     -0.33318662      0.74074073
 i,j,k,ie:    3    4    1          64
 Near X =   1.2851484     -0.24116537      0.19200993    , d:   0.0000000     -0.33318662      0.74074073
 i,j,k,ie:    4    4    1          64
 Near X =   1.2851484     -0.24116537      0.23800512    , d:   0.0000000     -0.33318662      0.74074073
 i,j,k,ie:    5    4    1          64
 Near X =   1.2851484     -0.24116537      0.27669227    , d:   0.0000000     -0.33318662      0.74074073
 i,j,k,ie:    6    4    1          64
 Near X =   1.2851484     -0.24116537      0.29563535    , d:   0.0000000     -0.33318662      0.74074073
 i,j,k,ie:    1    5    1          64
 Near X =   1.3286833     -0.79271203E-01  0.13437970    , d:   0.0000000      -2.5185602      0.74074073
 i,j,k,ie:    2    5    1          64
 Near X =   1.3286833     -0.79271203E-01  0.15332278    , d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    3    5    1          64
 Near X =   1.3286833     -0.79271203E-01  0.19200993    , d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    4    5    1          64
 Near X =   1.3286833     -0.79271203E-01  0.23800512    , d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    5    5    1          64
 Near X =   1.3286833     -0.79271203E-01  0.27669227    , d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    6    5    1          64
 Near X =   1.3286833     -0.79271203E-01  0.29563535    , d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    1    6    1          64
 Near X =   1.3500000     -0.77758166E-07  0.13437970    , d:   0.0000000      -2.5185631      0.74074073
 i,j,k,ie:    2    6    1          64
 Near X =   1.3500000     -0.77758166E-07  0.15332278    , d:   0.0000000     -0.48439774      0.74074073
 i,j,k,ie:    3    6    1          64
 Near X =   1.3500000     -0.77758166E-07  0.19200993    , d:   0.0000000     -0.48439774      0.74074073
 i,j,k,ie:    4    6    1          64
 Near X =   1.3500000     -0.77758166E-07  0.23800512    , d:   0.0000000     -0.48439774      0.74074073
 i,j,k,ie:    5    6    1          64
 Near X =   1.3500000     -0.77758166E-07  0.27669227    , d:   0.0000000     -0.48439774      0.74074073
 i,j,k,ie:    6    6    1          64
 Near X =   1.3500000     -0.77758166E-07  0.29563535    , d:   0.0000000     -0.48439774      0.74074073
 i,j,k,ie:    1    1    2          64
 Near X =   1.1329493     -0.65425504      0.13437970    , d:   0.0000000      -2.4418340      0.74074073
 i,j,k,ie:    2    1    2          64
 Near X =   1.1329493     -0.65425504      0.15332278    , d:   0.0000000      -2.4156132      0.74074073
 i,j,k,ie:    3    1    2          64
 Near X =   1.1329493     -0.65425504      0.19200993    , d:   0.0000000      -2.4156132      0.74074073
 i,j,k,ie:    4    1    2          64
 Near X =   1.1329493     -0.65425504      0.23800512    , d:   0.0000000      -2.4156132      0.74074073
 i,j,k,ie:    5    1    2          64
 Near X =   1.1329493     -0.65425504      0.27669227    , d:   0.0000000      -2.4156132      0.74074073
 i,j,k,ie:    6    1    2          64
 Near X =   1.1329493     -0.65425504      0.29563535    , d:   0.0000000      -2.4156132      0.74074073
 i,j,k,ie:    1    2    2          64
 Near X =   1.1536168     -0.57739818      0.13437970    , d:   0.0000000      -2.4418369      0.74074073
 i,j,k,ie:    1    3    2          64
 Near X =   1.1958258     -0.42043462      0.13437970    , d:   0.0000000      -2.4418427      0.74074073
 i,j,k,ie:    1    4    2          64
 Near X =   1.2460082     -0.23382049      0.13437970    , d:   0.0000000      -2.4418496      0.74074073
 i,j,k,ie:    1    5    2          64
 Near X =   1.2882172     -0.76856934E-01  0.13437970    , d:   0.0000000      -2.4418554      0.74074073
 i,j,k,ie:    1    6    2          64
 Near X =   1.3088847     -0.74046641E-07  0.13437970    , d:   0.0000000      -2.4418583      0.74074073
 i,j,k,ie:    2    6    2          64
 Near X =   1.3088847     -0.74046641E-07  0.15332278    , d:   0.0000000     -0.17591112      0.74074073
 i,j,k,ie:    3    6    2          64
 Near X =   1.3088847     -0.74046641E-07  0.19200993    , d:   0.0000000     -0.17591112      0.74074073
 i,j,k,ie:    4    6    2          64
 Near X =   1.3088847     -0.74046641E-07  0.23800512    , d:   0.0000000     -0.17591112      0.74074073
 i,j,k,ie:    5    6    2          64
 Near X =   1.3088847     -0.74046641E-07  0.27669227    , d:   0.0000000     -0.17591112      0.74074073
 i,j,k,ie:    6    6    2          64
 Near X =   1.3088847     -0.74046641E-07  0.29563535    , d:   0.0000000     -0.17591112      0.74074073
 i,j,k,ie:    1    1    3          64
 Near X =   1.0602670     -0.61228247      0.13437970    , d:   0.0000000      -2.3119130      0.74074073
 i,j,k,ie:    2    1    3          64
 Near X =   1.0602670     -0.61228247      0.15332278    , d:   0.0000000      -2.3119130      0.74074073
 i,j,k,ie:    3    1    3          64
 Near X =   1.0602670     -0.61228247      0.19200993    , d:   0.0000000      -2.3119130      0.74074073
 i,j,k,ie:    4    1    3          64
 Near X =   1.0602670     -0.61228247      0.23800512    , d:   0.0000000      -2.3119130      0.74074073
 i,j,k,ie:    5    1    3          64
 Near X =   1.0602670     -0.61228247      0.27669227    , d:   0.0000000      -2.3119130      0.74074073
 i,j,k,ie:    6    1    3          64
 Near X =   1.0602670     -0.61228247      0.29563535    , d:   0.0000000      -2.3119130      0.74074073
 i,j,k,ie:    1    2    3          64
 Near X =   1.0796086     -0.54035622      0.13437970    , d:   0.0000000      -2.2851852      0.74074073
 i,j,k,ie:    1    3    3          64
 Near X =   1.1191098     -0.39346239      0.13437970    , d:   0.0000000      -2.2851906      0.74074073
 i,j,k,ie:    1    4    3          64
 Near X =   1.1660727     -0.21882015      0.13437970    , d:   0.0000000      -2.2851971      0.74074073
 i,j,k,ie:    1    5    3          64
 Near X =   1.2055739     -0.71926312E-01  0.13437970    , d:   0.0000000      -2.2852025      0.74074073
 i,j,k,ie:    1    6    3          64
 Near X =   1.2249155     -0.66466653E-07  0.13437970    , d:   0.0000000      -2.2852052      0.74074073
 i,j,k,ie:    2    6    3          64
 Near X =   1.2249155     -0.66466653E-07  0.15332278    , d:   0.0000000     -0.16462586      0.74074073
 i,j,k,ie:    3    6    3          64
 Near X =   1.2249155     -0.66466653E-07  0.19200993    , d:   0.0000000     -0.16462586      0.74074073
 i,j,k,ie:    4    6    3          64
 Near X =   1.2249155     -0.66466653E-07  0.23800512    , d:   0.0000000     -0.16462586      0.74074073
 i,j,k,ie:    5    6    3          64
 Near X =   1.2249155     -0.66466653E-07  0.27669227    , d:   0.0000000     -0.16462586      0.74074073
 i,j,k,ie:    6    6    3          64
 Near X =   1.2249155     -0.66466653E-07  0.29563535    , d:   0.0000000     -0.16462586      0.74074073
 i,j,k,ie:    1    1    4          64
 Near X =  0.97385484     -0.56238123      0.13437970    , d:   0.0000000      -2.1886237      0.74074073
 i,j,k,ie:    2    1    4          64
 Near X =  0.97385484     -0.56238123      0.15332278    , d:   0.0000000      -2.1886237      0.74074073
 i,j,k,ie:    3    1    4          64
 Near X =  0.97385484     -0.56238123      0.19200993    , d:   0.0000000      -2.1886237      0.74074073
 i,j,k,ie:    4    1    4          64
 Near X =  0.97385484     -0.56238123      0.23800512    , d:   0.0000000      -2.1886237      0.74074073
 i,j,k,ie:    5    1    4          64
 Near X =  0.97385484     -0.56238123      0.27669227    , d:   0.0000000      -2.1886237      0.74074073
 i,j,k,ie:    6    1    4          64
 Near X =  0.97385484     -0.56238123      0.29563535    , d:   0.0000000      -2.1886237      0.74074073
 i,j,k,ie:    1    2    4          64
 Near X =  0.99162014     -0.49631700      0.13437970    , d:   0.0000000      -2.0989418      0.74074073
 i,j,k,ie:    1    3    4          64
 Near X =   1.0279019     -0.36139506      0.13437970    , d:   0.0000000      -2.0989468      0.74074073
 i,j,k,ie:    1    4    4          64
 Near X =   1.0710374     -0.20098623      0.13437970    , d:   0.0000000      -2.0989527      0.74074073
 i,j,k,ie:    1    5    4          64
 Near X =   1.1073192     -0.66064289E-01  0.13437970    , d:   0.0000000      -2.0989577      0.74074073
 i,j,k,ie:    1    6    4          64
 Near X =   1.1250845     -0.57454798E-07  0.13437970    , d:   0.0000000      -2.0989602      0.74074073
 i,j,k,ie:    2    6    4          64
 Near X =   1.1250845     -0.57454798E-07  0.15332278    , d:   0.0000000     -0.15120879      0.74074073
 i,j,k,ie:    3    6    4          64
 Near X =   1.1250845     -0.57454798E-07  0.19200993    , d:   0.0000000     -0.15120879      0.74074073
 i,j,k,ie:    4    6    4          64
 Near X =   1.1250845     -0.57454798E-07  0.23800512    , d:   0.0000000     -0.15120879      0.74074073
 i,j,k,ie:    5    6    4          64
 Near X =   1.1250845     -0.57454798E-07  0.27669227    , d:   0.0000000     -0.15120879      0.74074073
 i,j,k,ie:    6    6    4          64
 Near X =   1.1250845     -0.57454798E-07  0.29563535    , d:   0.0000000     -0.15120879      0.74074073
 i,j,k,ie:    1    1    5          64
 Near X =  0.90117249     -0.52040866      0.13437970    , d:   0.0000000      -2.0849234      0.74074073
 i,j,k,ie:    2    1    5          64
 Near X =  0.90117249     -0.52040866      0.15332278    , d:   0.0000000      -2.0849234      0.74074073
 i,j,k,ie:    3    1    5          64
 Near X =  0.90117249     -0.52040866      0.19200993    , d:   0.0000000      -2.0849234      0.74074073
 i,j,k,ie:    4    1    5          64
 Near X =  0.90117249     -0.52040866      0.23800512    , d:   0.0000000      -2.0849234      0.74074073
 i,j,k,ie:    5    1    5          64
 Near X =  0.90117249     -0.52040866      0.27669227    , d:   0.0000000      -2.0849234      0.74074073
 i,j,k,ie:    6    1    5          64
 Near X =  0.90117249     -0.52040866      0.29563535    , d:   0.0000000      -2.0849234      0.74074073
 i,j,k,ie:    1    2    5          64
 Near X =  0.91761190     -0.45927505      0.13437970    , d:   0.0000000      -1.9422901      0.74074073
 i,j,k,ie:    1    3    5          64
 Near X =  0.95118586     -0.33442283      0.13437970    , d:   0.0000000      -1.9422947      0.74074073
 i,j,k,ie:    1    4    5          64
 Near X =  0.99110196     -0.18598589      0.13437970    , d:   0.0000000      -1.9423002      0.74074073
 i,j,k,ie:    1    5    5          64
 Near X =   1.0246759     -0.61133666E-01  0.13437970    , d:   0.0000000      -1.9423048      0.74074073
 i,j,k,ie:    1    6    5          64
 Near X =   1.0411153     -0.49874810E-07  0.13437970    , d:   0.0000000      -1.9423071      0.74074073
 i,j,k,ie:    2    6    5          64
 Near X =   1.0411153     -0.49874810E-07  0.15332278    , d:   0.0000000     -0.13992353      0.74074073
 i,j,k,ie:    3    6    5          64
 Near X =   1.0411153     -0.49874810E-07  0.19200993    , d:   0.0000000     -0.13992353      0.74074073
 i,j,k,ie:    4    6    5          64
 Near X =   1.0411153     -0.49874810E-07  0.23800512    , d:   0.0000000     -0.13992353      0.74074073
 i,j,k,ie:    5    6    5          64
 Near X =   1.0411153     -0.49874810E-07  0.27669227    , d:   0.0000000     -0.13992353      0.74074073
 i,j,k,ie:    6    6    5          64
 Near X =   1.0411153     -0.49874810E-07  0.29563535    , d:   0.0000000     -0.13992353      0.74074073
 i,j,k,ie:    1    1    6          64
 Near X =  0.86558374     -0.49985689      0.13437970    , d:  0.30295432      -2.2155838      0.74074073
 i,j,k,ie:    2    1    6          64
 Near X =  0.86558374     -0.49985689      0.15332278    , d:  0.30295432      -2.1634355      0.74074073
 i,j,k,ie:    3    1    6          64
 Near X =  0.86558374     -0.49985689      0.19200993    , d:  0.30295432      -2.1634355      0.74074073
 i,j,k,ie:    4    1    6          64
 Near X =  0.86558374     -0.49985689      0.23800512    , d:  0.30295432      -2.1634355      0.74074073
 i,j,k,ie:    5    1    6          64
 Near X =  0.86558374     -0.49985689      0.27669227    , d:  0.30295432      -2.1634355      0.74074073
 i,j,k,ie:    6    1    6          64
 Near X =  0.86558374     -0.49985689      0.29563535    , d:  0.30295432      -2.1634355      0.74074073
 i,j,k,ie:    1    2    6          64
 Near X =  0.88137393     -0.44113754      0.13437970    , d:  0.30848089      -2.2100601      0.74074073
 i,j,k,ie:    2    2    6          64
 Near X =  0.88137393     -0.44113754      0.15332278    , d:  0.30848089       0.0000000      0.74074073
 i,j,k,ie:    3    2    6          64
 Near X =  0.88137393     -0.44113754      0.19200993    , d:  0.30848089       0.0000000      0.74074073
 i,j,k,ie:    4    2    6          64
 Near X =  0.88137393     -0.44113754      0.23800512    , d:  0.30848089       0.0000000      0.74074073
 i,j,k,ie:    5    2    6          64
 Near X =  0.88137393     -0.44113754      0.27669227    , d:  0.30848089       0.0000000      0.74074073
 i,j,k,ie:    6    2    6          64
 Near X =  0.88137393     -0.44113754      0.29563535    , d:  0.30848089       0.0000000      0.74074073
 i,j,k,ie:    1    3    6          64
 Near X =  0.91362200     -0.32121593      0.13437970    , d:  0.31976771      -2.1987793      0.74074073
 i,j,k,ie:    2    3    6          64
 Near X =  0.91362200     -0.32121593      0.15332278    , d:  0.31976771       0.0000000      0.74074073
 i,j,k,ie:    3    3    6          64
 Near X =  0.91362200     -0.32121593      0.19200993    , d:  0.31976771       0.0000000      0.74074073
 i,j,k,ie:    4    3    6          64
 Near X =  0.91362200     -0.32121593      0.23800512    , d:  0.31976771       0.0000000      0.74074073
 i,j,k,ie:    5    3    6          64
 Near X =  0.91362200     -0.32121593      0.27669227    , d:  0.31976771       0.0000000      0.74074073
 i,j,k,ie:    6    3    6          64
 Near X =  0.91362200     -0.32121593      0.29563535    , d:  0.31976771       0.0000000      0.74074073
 i,j,k,ie:    1    4    6          64
 Near X =  0.95196175     -0.17864100      0.13437970    , d:  0.33318662      -2.1853675      0.74074073
 i,j,k,ie:    2    4    6          64
 Near X =  0.95196175     -0.17864100      0.15332278    , d:  0.33318662       0.0000000      0.74074073
 i,j,k,ie:    3    4    6          64
 Near X =  0.95196175     -0.17864100      0.19200993    , d:  0.33318662       0.0000000      0.74074073
 i,j,k,ie:    4    4    6          64
 Near X =  0.95196175     -0.17864100      0.23800512    , d:  0.33318662       0.0000000      0.74074073
 i,j,k,ie:    5    4    6          64
 Near X =  0.95196175     -0.17864100      0.27669227    , d:  0.33318662       0.0000000      0.74074073
 i,j,k,ie:    6    4    6          64
 Near X =  0.95196175     -0.17864100      0.29563535    , d:  0.33318662       0.0000000      0.74074073
 i,j,k,ie:    1    5    6          64
 Near X =  0.98420982     -0.58719398E-01  0.13437970    , d:  0.34447345      -2.1740867      0.74074073
 i,j,k,ie:    2    5    6          64
 Near X =  0.98420982     -0.58719398E-01  0.15332278    , d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    3    5    6          64
 Near X =  0.98420982     -0.58719398E-01  0.19200993    , d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    4    5    6          64
 Near X =  0.98420982     -0.58719398E-01  0.23800512    , d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    5    5    6          64
 Near X =  0.98420982     -0.58719398E-01  0.27669227    , d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    6    5    6          64
 Near X =  0.98420982     -0.58719398E-01  0.29563535    , d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    1    6    6          64
 Near X =   1.0000000     -0.46163286E-07  0.13437970    , d:  0.35000001      -2.1685631      0.74074073
 i,j,k,ie:    2    6    6          64
 Near X =   1.0000000     -0.46163286E-07  0.15332278    , d:  0.35000001     -0.13439772      0.74074073
 i,j,k,ie:    3    6    6          64
 Near X =   1.0000000     -0.46163286E-07  0.19200993    , d:  0.35000001     -0.13439772      0.74074073
 i,j,k,ie:    4    6    6          64
 Near X =   1.0000000     -0.46163286E-07  0.23800512    , d:  0.35000001     -0.13439772      0.74074073
 i,j,k,ie:    5    6    6          64
 Near X =   1.0000000     -0.46163286E-07  0.27669227    , d:  0.35000001     -0.13439772      0.74074073
 i,j,k,ie:    6    6    6          64
 Near X =   1.0000000     -0.46163286E-07  0.29563535    , d:  0.35000001     -0.13439772      0.74074073
 i,j,k,ie:    1    1    1          65
 Near X =  0.67481330      -1.1685631      0.13437970    , d:   0.0000000     -0.67481346      0.85577016
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    2    1    1          65
 Near X =  0.67481330      -1.1685631      0.15332278    , d:   0.0000000     -0.67481346      0.85577016
 i,j,k,ie:    3    1    1          65
 Near X =  0.67481330      -1.1685631      0.19200993    , d:   0.0000000     -0.67481346      0.85577016
 i,j,k,ie:    4    1    1          65
 Near X =  0.67481330      -1.1685631      0.23800512    , d:   0.0000000     -0.67481346      0.85577016
 i,j,k,ie:    5    1    1          65
 Near X =  0.67481330      -1.1685631      0.27669227    , d:   0.0000000     -0.67481346      0.85577016
 i,j,k,ie:    6    1    1          65
 Near X =  0.67481330      -1.1685631      0.29563535    , d:   0.0000000      -1.3496201      0.85577016
 i,j,k,ie:    1    2    1          65
 Near X =  0.73281230      -1.1105604      0.13437970    , d:   0.0000000     -0.18998838      0.85577016
 i,j,k,ie:    2    2    1          65
 Near X =  0.73281230      -1.1105604      0.15332278    , d:   0.0000000     -0.18998838      0.85577016
 i,j,k,ie:    3    2    1          65
 Near X =  0.73281230      -1.1105604      0.19200993    , d:   0.0000000     -0.18998838      0.85577016
 i,j,k,ie:    4    2    1          65
 Near X =  0.73281230      -1.1105604      0.23800512    , d:   0.0000000     -0.18998838      0.85577016
 i,j,k,ie:    5    2    1          65
 Near X =  0.73281230      -1.1105604      0.27669227    , d:   0.0000000     -0.18998838      0.85577016
 i,j,k,ie:    6    2    1          65
 Near X =  0.73281230      -1.1105604      0.29563535    , d:   0.0000000     -0.67409248      0.85577016
 i,j,k,ie:    1    3    1          65
 Near X =  0.85126275     -0.99210238      0.13437970    , d:   0.0000000     -0.22069775      0.85577016
 i,j,k,ie:    2    3    1          65
 Near X =  0.85126275     -0.99210238      0.15332278    , d:   0.0000000     -0.22069775      0.85577016
 i,j,k,ie:    3    3    1          65
 Near X =  0.85126275     -0.99210238      0.19200993    , d:   0.0000000     -0.22069775      0.85577016
 i,j,k,ie:    4    3    1          65
 Near X =  0.85126275     -0.99210238      0.23800512    , d:   0.0000000     -0.22069775      0.85577016
 i,j,k,ie:    5    3    1          65
 Near X =  0.85126275     -0.99210238      0.27669227    , d:   0.0000000     -0.22069775      0.85577016
 i,j,k,ie:    6    3    1          65
 Near X =  0.85126275     -0.99210238      0.29563535    , d:   0.0000000     -0.67262013      0.85577016
 i,j,k,ie:    1    4    1          65
 Near X =  0.99208861     -0.85126753      0.13437970    , d:   0.0000000     -0.25720816      0.85577016
 i,j,k,ie:    2    4    1          65
 Near X =  0.99208861     -0.85126753      0.15332278    , d:   0.0000000     -0.25720816      0.85577016
 i,j,k,ie:    3    4    1          65
 Near X =  0.99208861     -0.85126753      0.19200993    , d:   0.0000000     -0.25720816      0.85577016
 i,j,k,ie:    4    4    1          65
 Near X =  0.99208861     -0.85126753      0.23800512    , d:   0.0000000     -0.25720816      0.85577016
 i,j,k,ie:    5    4    1          65
 Near X =  0.99208861     -0.85126753      0.27669227    , d:   0.0000000     -0.25720816      0.85577016
 i,j,k,ie:    6    4    1          65
 Near X =  0.99208861     -0.85126753      0.29563535    , d:   0.0000000     -0.67086965      0.85577016
 i,j,k,ie:    1    5    1          65
 Near X =   1.1105391     -0.73280952      0.13437970    , d:   0.0000000     -0.28791754      0.85577016
 i,j,k,ie:    2    5    1          65
 Near X =   1.1105391     -0.73280952      0.15332278    , d:   0.0000000     -0.28791754      0.85577016
 i,j,k,ie:    3    5    1          65
 Near X =   1.1105391     -0.73280952      0.19200993    , d:   0.0000000     -0.28791754      0.85577016
 i,j,k,ie:    4    5    1          65
 Near X =   1.1105391     -0.73280952      0.23800512    , d:   0.0000000     -0.28791754      0.85577016
 i,j,k,ie:    5    5    1          65
 Near X =   1.1105391     -0.73280952      0.27669227    , d:   0.0000000     -0.28791754      0.85577016
 i,j,k,ie:    6    5    1          65
 Near X =   1.1105391     -0.73280952      0.29563535    , d:   0.0000000     -0.66939729      0.85577016
 i,j,k,ie:    1    6    1          65
 Near X =   1.1685381     -0.67480681      0.13437970    , d:  0.18146197     -0.30295432      0.85577016
 i,j,k,ie:    2    6    1          65
 Near X =   1.1685381     -0.67480681      0.15332278    , d:  0.18146197     -0.30295432      0.85577016
 i,j,k,ie:    3    6    1          65
 Near X =   1.1685381     -0.67480681      0.19200993    , d:  0.18146197     -0.30295432      0.85577016
 i,j,k,ie:    4    6    1          65
 Near X =   1.1685381     -0.67480681      0.23800512    , d:  0.18146197     -0.30295432      0.85577016
 i,j,k,ie:    5    6    1          65
 Near X =   1.1685381     -0.67480681      0.27669227    , d:  0.18146197     -0.30295432      0.85577016
 i,j,k,ie:    6    6    1          65
 Near X =   1.1685381     -0.67480681      0.29563535    , d:  0.18146197      -2.3370762      0.85577016
 i,j,k,ie:    1    1    2          65
 Near X =  0.65426133      -1.1329736      0.13437970    , d:   0.0000000     -0.65426148      0.85577016
 i,j,k,ie:    2    1    2          65
 Near X =  0.65426133      -1.1329736      0.15332278    , d:   0.0000000     -0.65426148      0.85577016
 i,j,k,ie:    3    1    2          65
 Near X =  0.65426133      -1.1329736      0.19200993    , d:   0.0000000     -0.65426148      0.85577016
 i,j,k,ie:    4    1    2          65
 Near X =  0.65426133      -1.1329736      0.23800512    , d:   0.0000000     -0.65426148      0.85577016
 i,j,k,ie:    5    1    2          65
 Near X =  0.65426133      -1.1329736      0.27669227    , d:   0.0000000     -0.65426148      0.85577016
 i,j,k,ie:    6    1    2          65
 Near X =  0.65426133      -1.1329736      0.29563535    , d:   0.0000000      -1.3085164      0.85577016
 i,j,k,ie:    6    2    2          65
 Near X =  0.71049392      -1.0767374      0.29563535    , d:   0.0000000     -0.63363645      0.85577016
 i,j,k,ie:    6    3    2          65
 Near X =  0.82533687     -0.96188711      0.29563535    , d:   0.0000000     -0.59151428      0.85577016
 i,j,k,ie:    6    4    2          65
 Near X =  0.96187377     -0.82534150      0.29563535    , d:   0.0000000     -0.54143518      0.85577016
 i,j,k,ie:    6    5    2          65
 Near X =   1.0767167     -0.71049122      0.29563535    , d:   0.0000000     -0.49931301      0.85577016
 i,j,k,ie:    1    6    2          65
 Near X =   1.1329493     -0.65425504      0.13437970    , d:  0.17593540       0.0000000      0.85577016
 i,j,k,ie:    2    6    2          65
 Near X =   1.1329493     -0.65425504      0.15332278    , d:  0.17593540       0.0000000      0.85577016
 i,j,k,ie:    3    6    2          65
 Near X =   1.1329493     -0.65425504      0.19200993    , d:  0.17593540       0.0000000      0.85577016
 i,j,k,ie:    4    6    2          65
 Near X =   1.1329493     -0.65425504      0.23800512    , d:  0.17593540       0.0000000      0.85577016
 i,j,k,ie:    5    6    2          65
 Near X =   1.1329493     -0.65425504      0.27669227    , d:  0.17593540       0.0000000      0.85577016
 i,j,k,ie:    6    6    2          65
 Near X =   1.1329493     -0.65425504      0.29563535    , d:  0.17593540      -2.2658987      0.85577016
 i,j,k,ie:    1    1    3          65
 Near X =  0.61228836      -1.0602897      0.13437970    , d:   0.0000000     -0.61228850      0.85577016
 i,j,k,ie:    2    1    3          65
 Near X =  0.61228836      -1.0602897      0.15332278    , d:   0.0000000     -0.61228850      0.85577016
 i,j,k,ie:    3    1    3          65
 Near X =  0.61228836      -1.0602897      0.19200993    , d:   0.0000000     -0.61228850      0.85577016
 i,j,k,ie:    4    1    3          65
 Near X =  0.61228836      -1.0602897      0.23800512    , d:   0.0000000     -0.61228850      0.85577016
 i,j,k,ie:    5    1    3          65
 Near X =  0.61228836      -1.0602897      0.27669227    , d:   0.0000000     -0.61228850      0.85577016
 i,j,k,ie:    6    1    3          65
 Near X =  0.61228836      -1.0602897      0.29563535    , d:   0.0000000      -1.2245708      0.85577016
 i,j,k,ie:    6    2    3          65
 Near X =  0.66491345      -1.0076612      0.29563535    , d:   0.0000000     -0.59298663      0.85577016
 i,j,k,ie:    6    3    3          65
 Near X =  0.77238885     -0.90017896      0.29563535    , d:   0.0000000     -0.55356673      0.85577016
 i,j,k,ie:    6    4    3          65
 Near X =  0.90016647     -0.77239318      0.29563535    , d:   0.0000000     -0.50670037      0.85577016
 i,j,k,ie:    6    5    3          65
 Near X =   1.0076419     -0.66491092      0.29563535    , d:   0.0000000     -0.46728047      0.85577016
 i,j,k,ie:    1    6    3          65
 Near X =   1.0602670     -0.61228247      0.13437970    , d:  0.16464857       0.0000000      0.85577016
 i,j,k,ie:    2    6    3          65
 Near X =   1.0602670     -0.61228247      0.15332278    , d:  0.16464857       0.0000000      0.85577016
 i,j,k,ie:    3    6    3          65
 Near X =   1.0602670     -0.61228247      0.19200993    , d:  0.16464857       0.0000000      0.85577016
 i,j,k,ie:    4    6    3          65
 Near X =   1.0602670     -0.61228247      0.23800512    , d:  0.16464857       0.0000000      0.85577016
 i,j,k,ie:    5    6    3          65
 Near X =   1.0602670     -0.61228247      0.27669227    , d:  0.16464857       0.0000000      0.85577016
 i,j,k,ie:    6    6    3          65
 Near X =   1.0602670     -0.61228247      0.29563535    , d:  0.16464857      -2.1205340      0.85577016
 i,j,k,ie:    1    1    4          65
 Near X =  0.56238665     -0.97387570      0.13437970    , d:   0.0000000     -0.56238678      0.85577016
 i,j,k,ie:    2    1    4          65
 Near X =  0.56238665     -0.97387570      0.15332278    , d:   0.0000000     -0.56238678      0.85577016
 i,j,k,ie:    3    1    4          65
 Near X =  0.56238665     -0.97387570      0.19200993    , d:   0.0000000     -0.56238678      0.85577016
 i,j,k,ie:    4    1    4          65
 Near X =  0.56238665     -0.97387570      0.23800512    , d:   0.0000000     -0.56238678      0.85577016
 i,j,k,ie:    5    1    4          65
 Near X =  0.56238665     -0.97387570      0.27669227    , d:   0.0000000     -0.56238678      0.85577016
 i,j,k,ie:    6    1    4          65
 Near X =  0.56238665     -0.97387570      0.29563535    , d:   0.0000000      -1.1247679      0.85577016
 i,j,k,ie:    6    2    4          65
 Near X =  0.61072278     -0.92553648      0.29563535    , d:   0.0000000     -0.54465802      0.85577016
 i,j,k,ie:    6    3    4          65
 Near X =  0.70943889     -0.82681406      0.29563535    , d:   0.0000000     -0.50845085      0.85577016
 i,j,k,ie:    6    4    4          65
 Near X =  0.82680259     -0.70944287      0.29563535    , d:   0.0000000     -0.46540412      0.85577016
 i,j,k,ie:    6    5    4          65
 Near X =  0.92551871     -0.61072045      0.29563535    , d:   0.0000000     -0.42919695      0.85577016
 i,j,k,ie:    1    6    4          65
 Near X =  0.97385484     -0.56238123      0.13437970    , d:  0.15122966       0.0000000      0.85577016
 i,j,k,ie:    2    6    4          65
 Near X =  0.97385484     -0.56238123      0.15332278    , d:  0.15122966       0.0000000      0.85577016
 i,j,k,ie:    3    6    4          65
 Near X =  0.97385484     -0.56238123      0.19200993    , d:  0.15122966       0.0000000      0.85577016
 i,j,k,ie:    4    6    4          65
 Near X =  0.97385484     -0.56238123      0.23800512    , d:  0.15122966       0.0000000      0.85577016
 i,j,k,ie:    5    6    4          65
 Near X =  0.97385484     -0.56238123      0.27669227    , d:  0.15122966       0.0000000      0.85577016
 i,j,k,ie:    6    6    4          65
 Near X =  0.97385484     -0.56238123      0.29563535    , d:  0.15122966      -1.9477097      0.85577016
 i,j,k,ie:    1    1    5          65
 Near X =  0.52041367     -0.90119179      0.13437970    , d:   0.0000000     -0.52041380      0.85577016
 i,j,k,ie:    2    1    5          65
 Near X =  0.52041367     -0.90119179      0.15332278    , d:   0.0000000     -0.52041380      0.85577016
 i,j,k,ie:    3    1    5          65
 Near X =  0.52041367     -0.90119179      0.19200993    , d:   0.0000000     -0.52041380      0.85577016
 i,j,k,ie:    4    1    5          65
 Near X =  0.52041367     -0.90119179      0.23800512    , d:   0.0000000     -0.52041380      0.85577016
 i,j,k,ie:    5    1    5          65
 Near X =  0.52041367     -0.90119179      0.27669227    , d:   0.0000000     -0.52041380      0.85577016
 i,j,k,ie:    6    1    5          65
 Near X =  0.52041367     -0.90119179      0.29563535    , d:   0.0000000      -1.0408224      0.85577016
 i,j,k,ie:    6    2    5          65
 Near X =  0.56514230     -0.85646031      0.29563535    , d:   0.0000000     -0.50400820      0.85577016
 i,j,k,ie:    6    3    5          65
 Near X =  0.65649088     -0.76510590      0.29563535    , d:   0.0000000     -0.47050331      0.85577016
 i,j,k,ie:    6    4    5          65
 Near X =  0.76509529     -0.65649455      0.29563535    , d:   0.0000000     -0.43066931      0.85577016
 i,j,k,ie:    6    5    5          65
 Near X =  0.85644386     -0.56514015      0.29563535    , d:   0.0000000     -0.39716442      0.85577016
 i,j,k,ie:    1    6    5          65
 Near X =  0.90117249     -0.52040866      0.13437970    , d:  0.13994284       0.0000000      0.85577016
 i,j,k,ie:    2    6    5          65
 Near X =  0.90117249     -0.52040866      0.15332278    , d:  0.13994284       0.0000000      0.85577016
 i,j,k,ie:    3    6    5          65
 Near X =  0.90117249     -0.52040866      0.19200993    , d:  0.13994284       0.0000000      0.85577016
 i,j,k,ie:    4    6    5          65
 Near X =  0.90117249     -0.52040866      0.23800512    , d:  0.13994284       0.0000000      0.85577016
 i,j,k,ie:    5    6    5          65
 Near X =  0.90117249     -0.52040866      0.27669227    , d:  0.13994284       0.0000000      0.85577016
 i,j,k,ie:    6    6    5          65
 Near X =  0.90117249     -0.52040866      0.29563535    , d:  0.13994284      -1.8023450      0.85577016
 i,j,k,ie:    1    1    6          65
 Near X =  0.49986170     -0.86560228      0.13437970    , d:  0.17495160     -0.49986186      0.85577016
 i,j,k,ie:    2    1    6          65
 Near X =  0.49986170     -0.86560228      0.15332278    , d:  0.17495160     -0.49986186      0.85577016
 i,j,k,ie:    3    1    6          65
 Near X =  0.49986170     -0.86560228      0.19200993    , d:  0.17495160     -0.49986186      0.85577016
 i,j,k,ie:    4    1    6          65
 Near X =  0.49986170     -0.86560228      0.23800512    , d:  0.17495160     -0.49986186      0.85577016
 i,j,k,ie:    5    1    6          65
 Near X =  0.49986170     -0.86560228      0.27669227    , d:  0.17495160     -0.49986186      0.85577016
 i,j,k,ie:    6    1    6          65
 Near X =  0.49986170     -0.86560228      0.29563535    , d:  0.17495160      -1.1746685      0.85577016
 i,j,k,ie:    1    2    6          65
 Near X =  0.54282392     -0.82263731      0.13437970    , d:  0.18998838       0.0000000      0.85577016
 i,j,k,ie:    2    2    6          65
 Near X =  0.54282392     -0.82263731      0.15332278    , d:  0.18998838       0.0000000      0.85577016
 i,j,k,ie:    3    2    6          65
 Near X =  0.54282392     -0.82263731      0.19200993    , d:  0.18998838       0.0000000      0.85577016
 i,j,k,ie:    4    2    6          65
 Near X =  0.54282392     -0.82263731      0.23800512    , d:  0.18998838       0.0000000      0.85577016
 i,j,k,ie:    5    2    6          65
 Near X =  0.54282392     -0.82263731      0.27669227    , d:  0.18998838       0.0000000      0.85577016
 i,j,k,ie:    6    2    6          65
 Near X =  0.54282392     -0.82263731      0.29563535    , d:  0.18998838     -0.48410410      0.85577016
 i,j,k,ie:    1    3    6          65
 Near X =  0.63056499     -0.73489064      0.13437970    , d:  0.22069775       0.0000000      0.85577016
 i,j,k,ie:    2    3    6          65
 Near X =  0.63056499     -0.73489064      0.15332278    , d:  0.22069775       0.0000000      0.85577016
 i,j,k,ie:    3    3    6          65
 Near X =  0.63056499     -0.73489064      0.19200993    , d:  0.22069775       0.0000000      0.85577016
 i,j,k,ie:    4    3    6          65
 Near X =  0.63056499     -0.73489064      0.23800512    , d:  0.22069775       0.0000000      0.85577016
 i,j,k,ie:    5    3    6          65
 Near X =  0.63056499     -0.73489064      0.27669227    , d:  0.22069775       0.0000000      0.85577016
 i,j,k,ie:    6    3    6          65
 Near X =  0.63056499     -0.73489064      0.29563535    , d:  0.22069775     -0.45192238      0.85577016
 i,j,k,ie:    1    4    6          65
 Near X =  0.73488045     -0.63056853      0.13437970    , d:  0.25720816       0.0000000      0.85577016
 i,j,k,ie:    2    4    6          65
 Near X =  0.73488045     -0.63056853      0.15332278    , d:  0.25720816       0.0000000      0.85577016
 i,j,k,ie:    3    4    6          65
 Near X =  0.73488045     -0.63056853      0.19200993    , d:  0.25720816       0.0000000      0.85577016
 i,j,k,ie:    4    4    6          65
 Near X =  0.73488045     -0.63056853      0.23800512    , d:  0.25720816       0.0000000      0.85577016
 i,j,k,ie:    5    4    6          65
 Near X =  0.73488045     -0.63056853      0.27669227    , d:  0.25720816       0.0000000      0.85577016
 i,j,k,ie:    6    4    6          65
 Near X =  0.73488045     -0.63056853      0.29563535    , d:  0.25720816     -0.41366148      0.85577016
 i,j,k,ie:    1    5    6          65
 Near X =  0.82262152     -0.54282185      0.13437970    , d:  0.28791754       0.0000000      0.85577016
 i,j,k,ie:    2    5    6          65
 Near X =  0.82262152     -0.54282185      0.15332278    , d:  0.28791754       0.0000000      0.85577016
 i,j,k,ie:    3    5    6          65
 Near X =  0.82262152     -0.54282185      0.19200993    , d:  0.28791754       0.0000000      0.85577016
 i,j,k,ie:    4    5    6          65
 Near X =  0.82262152     -0.54282185      0.23800512    , d:  0.28791754       0.0000000      0.85577016
 i,j,k,ie:    5    5    6          65
 Near X =  0.82262152     -0.54282185      0.27669227    , d:  0.28791754       0.0000000      0.85577016
 i,j,k,ie:    6    5    6          65
 Near X =  0.82262152     -0.54282185      0.29563535    , d:  0.28791754     -0.38147975      0.85577016
 i,j,k,ie:    1    6    6          65
 Near X =  0.86558374     -0.49985689      0.13437970    , d:  0.48441628       0.0000000      0.85577016
 i,j,k,ie:    2    6    6          65
 Near X =  0.86558374     -0.49985689      0.15332278    , d:  0.48441628       0.0000000      0.85577016
 i,j,k,ie:    3    6    6          65
 Near X =  0.86558374     -0.49985689      0.19200993    , d:  0.48441628       0.0000000      0.85577016
 i,j,k,ie:    4    6    6          65
 Near X =  0.86558374     -0.49985689      0.23800512    , d:  0.48441628       0.0000000      0.85577016
 i,j,k,ie:    5    6    6          65
 Near X =  0.86558374     -0.49985689      0.27669227    , d:  0.48441628       0.0000000      0.85577016
 i,j,k,ie:    6    6    6          65
 Near X =  0.86558374     -0.49985689      0.29563535    , d:  0.48441628      -2.0341218      0.85577016
 i,j,k,ie:    1    1    1          66
 Near X = -0.15931032E-06  -1.3500000      0.13437970    , d:  0.67481346     -0.67480667       1.4818910
 i,j,k,ie:    2    1    1          66
 Near X = -0.15931032E-06  -1.3500000      0.15332278    , d:  0.41302676E-07 -0.67480667       1.4818910
 i,j,k,ie:    3    1    1          66
 Near X = -0.15931032E-06  -1.3500000      0.19200993    , d:  0.41302676E-07 -0.67480667       1.4818910
 i,j,k,ie:    4    1    1          66
 Near X = -0.15931032E-06  -1.3500000      0.23800512    , d:  0.41302676E-07 -0.67480667       1.4818910
 i,j,k,ie:    5    1    1          66
 Near X = -0.15931032E-06  -1.3500000      0.27669227    , d:  0.41302676E-07 -0.67480667       1.4818910
 i,j,k,ie:    6    1    1          66
 Near X = -0.15931032E-06  -1.3500000      0.29563535    , d:  0.67480695      -1.1685629       1.4818910
 i,j,k,ie:    1    2    1          66
 Near X =  0.79271756E-01  -1.3286862      0.13437970    , d:  0.65354055     -0.20551937E-01   1.4818910
 i,j,k,ie:    2    2    1          66
 Near X =  0.79271756E-01  -1.3286862      0.15332278    , d:   0.0000000     -0.20551937E-01   1.4818910
 i,j,k,ie:    3    2    1          66
 Near X =  0.79271756E-01  -1.3286862      0.19200993    , d:   0.0000000     -0.20551937E-01   1.4818910
 i,j,k,ie:    4    2    1          66
 Near X =  0.79271756E-01  -1.3286862      0.23800512    , d:   0.0000000     -0.20551937E-01   1.4818910
 i,j,k,ie:    5    2    1          66
 Near X =  0.79271756E-01  -1.3286862      0.27669227    , d:   0.0000000     -0.20551937E-01   1.4818910
 i,j,k,ie:    6    2    1          66
 Near X =  0.79271756E-01  -1.3286862      0.29563535    , d:  0.51626391     -0.20551937E-01   1.4818910
 i,j,k,ie:    1    3    1          66
 Near X =  0.24116754      -1.2851573      0.13437970    , d:  0.61009521     -0.62524919E-01   1.4818910
 i,j,k,ie:    2    3    1          66
 Near X =  0.24116754      -1.2851573      0.15332278    , d:   0.0000000     -0.62524919E-01   1.4818910
 i,j,k,ie:    3    3    1          66
 Near X =  0.24116754      -1.2851573      0.19200993    , d:   0.0000000     -0.62524919E-01   1.4818910
 i,j,k,ie:    4    3    1          66
 Near X =  0.24116754      -1.2851573      0.23800512    , d:   0.0000000     -0.62524919E-01   1.4818910
 i,j,k,ie:    5    3    1          66
 Near X =  0.24116754      -1.2851573      0.27669227    , d:   0.0000000     -0.62524919E-01   1.4818910
 i,j,k,ie:    6    3    1          66
 Near X =  0.24116754      -1.2851573      0.29563535    , d:  0.19247396     -0.62524919E-01   1.4818910
 i,j,k,ie:    1    4    1          66
 Near X =  0.43364560      -1.2334058      0.13437970    , d:  0.55844301     -0.11242664       1.4818910
 i,j,k,ie:    2    4    1          66
 Near X =  0.43364560      -1.2334058      0.15332278    , d:   0.0000000     -0.11242664       1.4818910
 i,j,k,ie:    3    4    1          66
 Near X =  0.43364560      -1.2334058      0.19200993    , d:   0.0000000     -0.11242664       1.4818910
 i,j,k,ie:    4    4    1          66
 Near X =  0.43364560      -1.2334058      0.23800512    , d:   0.0000000     -0.11242664       1.4818910
 i,j,k,ie:    5    4    1          66
 Near X =  0.43364560      -1.2334058      0.27669227    , d:   0.0000000     -0.11242664       1.4818910
 i,j,k,ie:    6    4    1          66
 Near X =  0.43364560      -1.2334058      0.29563535    , d:   0.0000000     -0.25500461       1.4818910
 i,j,k,ie:    1    5    1          66
 Near X =  0.59554139      -1.1898769      0.13437970    , d:  0.51499767     -0.15439962       1.4818910
 i,j,k,ie:    2    5    1          66
 Near X =  0.59554139      -1.1898769      0.15332278    , d:   0.0000000     -0.15439962       1.4818910
 i,j,k,ie:    3    5    1          66
 Near X =  0.59554139      -1.1898769      0.19200993    , d:   0.0000000     -0.15439962       1.4818910
 i,j,k,ie:    4    5    1          66
 Near X =  0.59554139      -1.1898769      0.23800512    , d:   0.0000000     -0.15439962       1.4818910
 i,j,k,ie:    5    5    1          66
 Near X =  0.59554139      -1.1898769      0.27669227    , d:   0.0000000     -0.15439962       1.4818910
 i,j,k,ie:    6    5    1          66
 Near X =  0.59554139      -1.1898769      0.29563535    , d:   0.0000000     -0.53682200       1.4818910
 i,j,k,ie:    1    6    1          66
 Near X =  0.67481330      -1.1685631      0.13437970    , d:  0.67518672      -1.8433514       1.4818910
 i,j,k,ie:    2    6    1          66
 Near X =  0.67481330      -1.1685631      0.15332278    , d:   0.0000000      -1.8433514       1.4818910
 i,j,k,ie:    3    6    1          66
 Near X =  0.67481330      -1.1685631      0.19200993    , d:   0.0000000      -1.8433514       1.4818910
 i,j,k,ie:    4    6    1          66
 Near X =  0.67481330      -1.1685631      0.23800512    , d:   0.0000000      -1.8433514       1.4818910
 i,j,k,ie:    5    6    1          66
 Near X =  0.67481330      -1.1685631      0.27669227    , d:   0.0000000      -1.8433514       1.4818910
 i,j,k,ie:    6    6    1          66
 Near X =  0.67481330      -1.1685631      0.29563535    , d:   0.0000000      -1.8433514       1.4818910
 i,j,k,ie:    1    1    2          66
 Near X = -0.15445840E-06  -1.3088847      0.13437970    , d:  0.65426148     -0.65425489       1.4818910
 i,j,k,ie:    2    1    2          66
 Near X = -0.15445840E-06  -1.3088847      0.15332278    , d:   0.0000000     -0.65425489       1.4818910
 i,j,k,ie:    3    1    2          66
 Near X = -0.15445840E-06  -1.3088847      0.19200993    , d:   0.0000000     -0.65425489       1.4818910
 i,j,k,ie:    4    1    2          66
 Near X = -0.15445840E-06  -1.3088847      0.23800512    , d:   0.0000000     -0.65425489       1.4818910
 i,j,k,ie:    5    1    2          66
 Near X = -0.15445840E-06  -1.3088847      0.27669227    , d:   0.0000000     -0.65425489       1.4818910
 i,j,k,ie:    6    1    2          66
 Near X = -0.15445840E-06  -1.3088847      0.29563535    , d:  0.65425517      -1.1329734       1.4818910
 i,j,k,ie:    1    2    2          66
 Near X =  0.76857471E-01  -1.2882200      0.13437970    , d:  0.63363645       0.0000000       1.4818910
 i,j,k,ie:    6    2    2          66
 Near X =  0.76857471E-01  -1.2882200      0.29563535    , d:  0.50054068       0.0000000       1.4818910
 i,j,k,ie:    1    3    2          66
 Near X =  0.23382259      -1.2460168      0.13437970    , d:  0.59151428       0.0000000       1.4818910
 i,j,k,ie:    6    3    2          66
 Near X =  0.23382259      -1.2460168      0.29563535    , d:  0.18661201       0.0000000       1.4818910
 i,j,k,ie:    1    4    2          66
 Near X =  0.42043858      -1.1958414      0.13437970    , d:  0.54143518       0.0000000       1.4818910
 i,j,k,ie:    6    4    2          66
 Near X =  0.42043858      -1.1958414      0.29563535    , d:   0.0000000     -0.18661812       1.4818910
 i,j,k,ie:    1    5    2          66
 Near X =  0.57740370      -1.1536383      0.13437970    , d:  0.49931301       0.0000000       1.4818910
 i,j,k,ie:    6    5    2          66
 Near X =  0.57740370      -1.1536383      0.29563535    , d:   0.0000000     -0.50054679       1.4818910
 i,j,k,ie:    1    6    2          66
 Near X =  0.65426133      -1.1329736      0.13437970    , d:  0.65462338      -1.7872107       1.4818910
 i,j,k,ie:    2    6    2          66
 Near X =  0.65426133      -1.1329736      0.15332278    , d:   0.0000000      -1.7872107       1.4818910
 i,j,k,ie:    3    6    2          66
 Near X =  0.65426133      -1.1329736      0.19200993    , d:   0.0000000      -1.7872107       1.4818910
 i,j,k,ie:    4    6    2          66
 Near X =  0.65426133      -1.1329736      0.23800512    , d:   0.0000000      -1.7872107       1.4818910
 i,j,k,ie:    5    6    2          66
 Near X =  0.65426133      -1.1329736      0.27669227    , d:   0.0000000      -1.7872107       1.4818910
 i,j,k,ie:    6    6    2          66
 Near X =  0.65426133      -1.1329736      0.29563535    , d:   0.0000000      -1.7872107       1.4818910
 i,j,k,ie:    1    1    3          66
 Near X = -0.14454939E-06  -1.2249155      0.13437970    , d:  0.61228850     -0.61228234       1.4818910
 i,j,k,ie:    2    1    3          66
 Near X = -0.14454939E-06  -1.2249155      0.15332278    , d:   0.0000000     -0.61228234       1.4818910
 i,j,k,ie:    3    1    3          66
 Near X = -0.14454939E-06  -1.2249155      0.19200993    , d:   0.0000000     -0.61228234       1.4818910
 i,j,k,ie:    4    1    3          66
 Near X = -0.14454939E-06  -1.2249155      0.23800512    , d:   0.0000000     -0.61228234       1.4818910
 i,j,k,ie:    5    1    3          66
 Near X = -0.14454939E-06  -1.2249155      0.27669227    , d:   0.0000000     -0.61228234       1.4818910
 i,j,k,ie:    6    1    3          66
 Near X = -0.14454939E-06  -1.2249155      0.29563535    , d:  0.61228259      -1.0602895       1.4818910
 i,j,k,ie:    1    2    3          66
 Near X =  0.71926817E-01  -1.2055765      0.13437970    , d:  0.59298663       0.0000000       1.4818910
 i,j,k,ie:    6    2    3          66
 Near X =  0.71926817E-01  -1.2055765      0.29563535    , d:  0.46842939       0.0000000       1.4818910
 i,j,k,ie:    1    3    3          66
 Near X =  0.21882212      -1.1660808      0.13437970    , d:  0.55356673       0.0000000       1.4818910
 i,j,k,ie:    6    3    3          66
 Near X =  0.21882212      -1.1660808      0.29563535    , d:  0.17464025       0.0000000       1.4818910
 i,j,k,ie:    1    4    3          66
 Near X =  0.39346609      -1.1191244      0.13437970    , d:  0.50670037       0.0000000       1.4818910
 i,j,k,ie:    6    4    3          66
 Near X =  0.39346609      -1.1191244      0.29563535    , d:   0.0000000     -0.17464597       1.4818910
 i,j,k,ie:    1    5    3          66
 Near X =  0.54036139      -1.0796287      0.13437970    , d:  0.46728047       0.0000000       1.4818910
 i,j,k,ie:    6    5    3          66
 Near X =  0.54036139      -1.0796287      0.29563535    , d:   0.0000000     -0.46843510       1.4818910
 i,j,k,ie:    1    6    3          66
 Near X =  0.61228836      -1.0602897      0.13437970    , d:  0.61262718      -1.6725554       1.4818910
 i,j,k,ie:    2    6    3          66
 Near X =  0.61228836      -1.0602897      0.15332278    , d:   0.0000000      -1.6725554       1.4818910
 i,j,k,ie:    3    6    3          66
 Near X =  0.61228836      -1.0602897      0.19200993    , d:   0.0000000      -1.6725554       1.4818910
 i,j,k,ie:    4    6    3          66
 Near X =  0.61228836      -1.0602897      0.23800512    , d:   0.0000000      -1.6725554       1.4818910
 i,j,k,ie:    5    6    3          66
 Near X =  0.61228836      -1.0602897      0.27669227    , d:   0.0000000      -1.6725554       1.4818910
 i,j,k,ie:    6    6    3          66
 Near X =  0.61228836      -1.0602897      0.29563535    , d:   0.0000000      -1.6725554       1.4818910
 i,j,k,ie:    1    1    4          66
 Near X = -0.13276857E-06  -1.1250845      0.13437970    , d:  0.56238678     -0.56238112       1.4818910
 i,j,k,ie:    2    1    4          66
 Near X = -0.13276857E-06  -1.1250845      0.15332278    , d:   0.0000000     -0.56238112       1.4818910
 i,j,k,ie:    3    1    4          66
 Near X = -0.13276857E-06  -1.1250845      0.19200993    , d:   0.0000000     -0.56238112       1.4818910
 i,j,k,ie:    4    1    4          66
 Near X = -0.13276857E-06  -1.1250845      0.23800512    , d:   0.0000000     -0.56238112       1.4818910
 i,j,k,ie:    5    1    4          66
 Near X = -0.13276857E-06  -1.1250845      0.27669227    , d:   0.0000000     -0.56238112       1.4818910
 i,j,k,ie:    6    1    4          66
 Near X = -0.13276857E-06  -1.1250845      0.29563535    , d:  0.56238135     -0.97387556       1.4818910
 i,j,k,ie:    1    2    4          66
 Near X =  0.66064757E-01  -1.1073216      0.13437970    , d:  0.54465802       0.0000000       1.4818910
 i,j,k,ie:    6    2    4          66
 Near X =  0.66064757E-01  -1.1073216      0.29563535    , d:  0.43025223       0.0000000       1.4818910
 i,j,k,ie:    1    3    4          66
 Near X =  0.20098804      -1.0710449      0.13437970    , d:  0.50845085       0.0000000       1.4818910
 i,j,k,ie:    6    3    4          66
 Near X =  0.20098804      -1.0710449      0.29563535    , d:  0.16040701       0.0000000       1.4818910
 i,j,k,ie:    1    4    4          66
 Near X =  0.36139847      -1.0279153      0.13437970    , d:  0.46540412       0.0000000       1.4818910
 i,j,k,ie:    6    4    4          66
 Near X =  0.36139847      -1.0279153      0.29563535    , d:   0.0000000     -0.16041226       1.4818910
 i,j,k,ie:    1    5    4          66
 Near X =  0.49632176     -0.99163855      0.13437970    , d:  0.42919695       0.0000000       1.4818910
 i,j,k,ie:    6    5    4          66
 Near X =  0.49632176     -0.99163855      0.29563535    , d:   0.0000000     -0.43025748       1.4818910
 i,j,k,ie:    1    6    4          66
 Near X =  0.56238665     -0.97387570      0.13437970    , d:  0.56269785      -1.5362415       1.4818910
 i,j,k,ie:    2    6    4          66
 Near X =  0.56238665     -0.97387570      0.15332278    , d:   0.0000000      -1.5362415       1.4818910
 i,j,k,ie:    3    6    4          66
 Near X =  0.56238665     -0.97387570      0.19200993    , d:   0.0000000      -1.5362415       1.4818910
 i,j,k,ie:    4    6    4          66
 Near X =  0.56238665     -0.97387570      0.23800512    , d:   0.0000000      -1.5362415       1.4818910
 i,j,k,ie:    5    6    4          66
 Near X =  0.56238665     -0.97387570      0.27669227    , d:   0.0000000      -1.5362415       1.4818910
 i,j,k,ie:    6    6    4          66
 Near X =  0.56238665     -0.97387570      0.29563535    , d:   0.0000000      -1.5362415       1.4818910
 i,j,k,ie:    1    1    5          66
 Near X = -0.12285956E-06  -1.0411153      0.13437970    , d:  0.52041380     -0.52040856       1.4818910
 i,j,k,ie:    2    1    5          66
 Near X = -0.12285956E-06  -1.0411153      0.15332278    , d:   0.0000000     -0.52040856       1.4818910
 i,j,k,ie:    3    1    5          66
 Near X = -0.12285956E-06  -1.0411153      0.19200993    , d:   0.0000000     -0.52040856       1.4818910
 i,j,k,ie:    4    1    5          66
 Near X = -0.12285956E-06  -1.0411153      0.23800512    , d:   0.0000000     -0.52040856       1.4818910
 i,j,k,ie:    5    1    5          66
 Near X = -0.12285956E-06  -1.0411153      0.27669227    , d:   0.0000000     -0.52040856       1.4818910
 i,j,k,ie:    6    1    5          66
 Near X = -0.12285956E-06  -1.0411153      0.29563535    , d:  0.52040877     -0.90119166       1.4818910
 i,j,k,ie:    1    2    5          66
 Near X =  0.61134103E-01  -1.0246782      0.13437970    , d:  0.50400820       0.0000000       1.4818910
 i,j,k,ie:    6    2    5          66
 Near X =  0.61134103E-01  -1.0246782      0.29563535    , d:  0.39814093       0.0000000       1.4818910
 i,j,k,ie:    1    3    5          66
 Near X =  0.18598757     -0.99110886      0.13437970    , d:  0.47050331       0.0000000       1.4818910
 i,j,k,ie:    6    3    5          66
 Near X =  0.18598757     -0.99110886      0.29563535    , d:  0.14843525       0.0000000       1.4818910
 i,j,k,ie:    1    4    5          66
 Near X =  0.33442598     -0.95119826      0.13437970    , d:  0.43066931       0.0000000       1.4818910
 i,j,k,ie:    6    4    5          66
 Near X =  0.33442598     -0.95119826      0.29563535    , d:   0.0000000     -0.14844011       1.4818910
 i,j,k,ie:    1    5    5          66
 Near X =  0.45927945     -0.91762894      0.13437970    , d:  0.39716442       0.0000000       1.4818910
 i,j,k,ie:    6    5    5          66
 Near X =  0.45927945     -0.91762894      0.29563535    , d:   0.0000000     -0.39814579       1.4818910
 i,j,k,ie:    1    6    5          66
 Near X =  0.52041367     -0.90119179      0.13437970    , d:  0.52070166      -1.4215862       1.4818910
 i,j,k,ie:    2    6    5          66
 Near X =  0.52041367     -0.90119179      0.15332278    , d:   0.0000000      -1.4215862       1.4818910
 i,j,k,ie:    3    6    5          66
 Near X =  0.52041367     -0.90119179      0.19200993    , d:   0.0000000      -1.4215862       1.4818910
 i,j,k,ie:    4    6    5          66
 Near X =  0.52041367     -0.90119179      0.23800512    , d:   0.0000000      -1.4215862       1.4818910
 i,j,k,ie:    5    6    5          66
 Near X =  0.52041367     -0.90119179      0.27669227    , d:   0.0000000      -1.4215862       1.4818910
 i,j,k,ie:    6    6    5          66
 Near X =  0.52041367     -0.90119179      0.29563535    , d:   0.0000000      -1.4215862       1.4818910
 i,j,k,ie:    1    1    6          66
 Near X = -0.11800764E-06  -1.0000000      0.13437970    , d:  0.67481342     -0.67480671       1.4818910
 i,j,k,ie:    2    1    6          66
 Near X = -0.11800764E-06  -1.0000000      0.15332278    , d:   0.0000000     -0.67480671       1.4818910
 i,j,k,ie:    3    1    6          66
 Near X = -0.11800764E-06  -1.0000000      0.19200993    , d:   0.0000000     -0.67480671       1.4818910
 i,j,k,ie:    4    1    6          66
 Near X = -0.11800764E-06  -1.0000000      0.23800512    , d:   0.0000000     -0.67480671       1.4818910
 i,j,k,ie:    5    1    6          66
 Near X = -0.11800764E-06  -1.0000000      0.27669227    , d:   0.0000000     -0.67480671       1.4818910
 i,j,k,ie:    6    1    6          66
 Near X = -0.11800764E-06  -1.0000000      0.29563535    , d:  0.67480691      -1.1685630       1.4818910
 i,j,k,ie:    1    2    6          66
 Near X =  0.58719818E-01 -0.98421199      0.13437970    , d:  0.67409248       0.0000000       1.4818910
 i,j,k,ie:    2    2    6          66
 Near X =  0.58719818E-01 -0.98421199      0.15332278    , d:  0.20551937E-01   0.0000000       1.4818910
 i,j,k,ie:    3    2    6          66
 Near X =  0.58719818E-01 -0.98421199      0.19200993    , d:  0.20551937E-01   0.0000000       1.4818910
 i,j,k,ie:    4    2    6          66
 Near X =  0.58719818E-01 -0.98421199      0.23800512    , d:  0.20551937E-01   0.0000000       1.4818910
 i,j,k,ie:    5    2    6          66
 Near X =  0.58719818E-01 -0.98421199      0.27669227    , d:  0.20551937E-01   0.0000000       1.4818910
 i,j,k,ie:    6    2    6          66
 Near X =  0.58719818E-01 -0.98421199      0.29563535    , d:  0.53681585       0.0000000       1.4818910
 i,j,k,ie:    1    3    6          66
 Near X =  0.17864262     -0.95196838      0.13437970    , d:  0.67262013       0.0000000       1.4818910
 i,j,k,ie:    2    3    6          66
 Near X =  0.17864262     -0.95196838      0.15332278    , d:  0.62524919E-01   0.0000000       1.4818910
 i,j,k,ie:    3    3    6          66
 Near X =  0.17864262     -0.95196838      0.19200993    , d:  0.62524919E-01   0.0000000       1.4818910
 i,j,k,ie:    4    3    6          66
 Near X =  0.17864262     -0.95196838      0.23800512    , d:  0.62524919E-01   0.0000000       1.4818910
 i,j,k,ie:    5    3    6          66
 Near X =  0.17864262     -0.95196838      0.27669227    , d:  0.62524919E-01   0.0000000       1.4818910
 i,j,k,ie:    6    3    6          66
 Near X =  0.17864262     -0.95196838      0.29563535    , d:  0.25499888       0.0000000       1.4818910
 i,j,k,ie:    1    4    6          66
 Near X =  0.32121896     -0.91363391      0.13437970    , d:  0.67086965       0.0000000       1.4818910
 i,j,k,ie:    2    4    6          66
 Near X =  0.32121896     -0.91363391      0.15332278    , d:  0.11242664       0.0000000       1.4818910
 i,j,k,ie:    3    4    6          66
 Near X =  0.32121896     -0.91363391      0.19200993    , d:  0.11242664       0.0000000       1.4818910
 i,j,k,ie:    4    4    6          66
 Near X =  0.32121896     -0.91363391      0.23800512    , d:  0.11242664       0.0000000       1.4818910
 i,j,k,ie:    5    4    6          66
 Near X =  0.32121896     -0.91363391      0.27669227    , d:  0.11242664       0.0000000       1.4818910
 i,j,k,ie:    6    4    6          66
 Near X =  0.32121896     -0.91363391      0.29563535    , d:  0.11242664     -0.14257797       1.4818910
 i,j,k,ie:    1    5    6          66
 Near X =  0.44114176     -0.88139029      0.13437970    , d:  0.66939729       0.0000000       1.4818910
 i,j,k,ie:    2    5    6          66
 Near X =  0.44114176     -0.88139029      0.15332278    , d:  0.15439962       0.0000000       1.4818910
 i,j,k,ie:    3    5    6          66
 Near X =  0.44114176     -0.88139029      0.19200993    , d:  0.15439962       0.0000000       1.4818910
 i,j,k,ie:    4    5    6          66
 Near X =  0.44114176     -0.88139029      0.23800512    , d:  0.15439962       0.0000000       1.4818910
 i,j,k,ie:    5    5    6          66
 Near X =  0.44114176     -0.88139029      0.27669227    , d:  0.15439962       0.0000000       1.4818910
 i,j,k,ie:    6    5    6          66
 Near X =  0.44114176     -0.88139029      0.29563535    , d:  0.15439962     -0.38242237       1.4818910
 i,j,k,ie:    1    6    6          66
 Near X =  0.49986170     -0.86560228      0.13437970    , d:  0.85013832      -1.6683998       1.4818910
 i,j,k,ie:    2    6    6          66
 Near X =  0.49986170     -0.86560228      0.15332278    , d:  0.17495160      -1.6683998       1.4818910
 i,j,k,ie:    3    6    6          66
 Near X =  0.49986170     -0.86560228      0.19200993    , d:  0.17495160      -1.6683998       1.4818910
 i,j,k,ie:    4    6    6          66
 Near X =  0.49986170     -0.86560228      0.23800512    , d:  0.17495160      -1.6683998       1.4818910
 i,j,k,ie:    5    6    6          66
 Near X =  0.49986170     -0.86560228      0.27669227    , d:  0.17495160      -1.6683998       1.4818910
 i,j,k,ie:    6    6    6          66
 Near X =  0.49986170     -0.86560228      0.29563535    , d:  0.17495160      -1.6683998       1.4818910
 i,j,k,ie:    1    1    1          67
 Near X =  0.67480679       1.1685381      0.13437970    , d:   0.0000000      -1.8433699       1.4819057
 i,j,k,ie:    2    1    1          67
 Near X =  0.67480679       1.1685381      0.15332278    , d:   0.0000000      -1.8433699       1.4819057
 i,j,k,ie:    3    1    1          67
 Near X =  0.67480679       1.1685381      0.19200993    , d:   0.0000000      -1.8433699       1.4819057
 i,j,k,ie:    4    1    1          67
 Near X =  0.67480679       1.1685381      0.23800512    , d:   0.0000000      -1.8433699       1.4819057
 i,j,k,ie:    5    1    1          67
 Near X =  0.67480679       1.1685381      0.27669227    , d:   0.0000000      -1.8433699       1.4819057
 i,j,k,ie:    6    1    1          67
 Near X =  0.67480679       1.1685381      0.29563535    , d:  0.67519323      -1.8433699       1.4819057
 i,j,k,ie:    1    2    1          67
 Near X =  0.59553566       1.1898548      0.13437970    , d:   0.0000000     -0.53681585       1.4819057
 i,j,k,ie:    2    2    1          67
 Near X =  0.59553566       1.1898548      0.15332278    , d:   0.0000000     -0.15439814       1.4819057
 i,j,k,ie:    3    2    1          67
 Near X =  0.59553566       1.1898548      0.19200993    , d:   0.0000000     -0.15439814       1.4819057
 i,j,k,ie:    4    2    1          67
 Near X =  0.59553566       1.1898548      0.23800512    , d:   0.0000000     -0.15439814       1.4819057
 i,j,k,ie:    5    2    1          67
 Near X =  0.59553566       1.1898548      0.27669227    , d:   0.0000000     -0.15439814       1.4819057
 i,j,k,ie:    6    2    1          67
 Near X =  0.59553566       1.1898548      0.29563535    , d:  0.51502473     -0.15439814       1.4819057
 i,j,k,ie:    1    3    1          67
 Near X =  0.43364150       1.2333897      0.13437970    , d:   0.0000000     -0.25499888       1.4819057
 i,j,k,ie:    2    3    1          67
 Near X =  0.43364150       1.2333897      0.15332278    , d:   0.0000000     -0.11242558       1.4819057
 i,j,k,ie:    3    3    1          67
 Near X =  0.43364150       1.2333897      0.19200993    , d:   0.0000000     -0.11242558       1.4819057
 i,j,k,ie:    4    3    1          67
 Near X =  0.43364150       1.2333897      0.23800512    , d:   0.0000000     -0.11242558       1.4819057
 i,j,k,ie:    5    3    1          67
 Near X =  0.43364150       1.2333897      0.27669227    , d:   0.0000000     -0.11242558       1.4819057
 i,j,k,ie:    6    3    1          67
 Near X =  0.43364150       1.2333897      0.29563535    , d:  0.55846088     -0.11242558       1.4819057
 i,j,k,ie:    1    4    1          67
 Near X =  0.24116535       1.2851484      0.13437970    , d:  0.19248026     -0.62524351E-01   1.4819057
 i,j,k,ie:    2    4    1          67
 Near X =  0.24116535       1.2851484      0.15332278    , d:   0.0000000     -0.62524351E-01   1.4819057
 i,j,k,ie:    3    4    1          67
 Near X =  0.24116535       1.2851484      0.19200993    , d:   0.0000000     -0.62524351E-01   1.4819057
 i,j,k,ie:    4    4    1          67
 Near X =  0.24116535       1.2851484      0.23800512    , d:   0.0000000     -0.62524351E-01   1.4819057
 i,j,k,ie:    5    4    1          67
 Near X =  0.24116535       1.2851484      0.27669227    , d:   0.0000000     -0.62524351E-01   1.4819057
 i,j,k,ie:    6    4    1          67
 Near X =  0.24116535       1.2851484      0.29563535    , d:  0.61010217     -0.62524351E-01   1.4819057
 i,j,k,ie:    1    5    1          67
 Near X =  0.79271178E-01   1.3286833      0.13437970    , d:  0.51627021     -0.20551787E-01   1.4819057
 i,j,k,ie:    2    5    1          67
 Near X =  0.79271178E-01   1.3286833      0.15332278    , d:   0.0000000     -0.20551787E-01   1.4819057
 i,j,k,ie:    3    5    1          67
 Near X =  0.79271178E-01   1.3286833      0.19200993    , d:   0.0000000     -0.20551787E-01   1.4819057
 i,j,k,ie:    4    5    1          67
 Near X =  0.79271178E-01   1.3286833      0.23800512    , d:   0.0000000     -0.20551787E-01   1.4819057
 i,j,k,ie:    5    5    1          67
 Near X =  0.79271178E-01   1.3286833      0.27669227    , d:   0.0000000     -0.20551787E-01   1.4819057
 i,j,k,ie:    6    5    1          67
 Near X =  0.79271178E-01   1.3286833      0.29563535    , d:  0.65353832     -0.20551787E-01   1.4819057
 i,j,k,ie:    1    6    1          67
 Near X =  0.53131460E-07   1.3500000      0.13437970    , d:  0.67481325      -1.1685382       1.4819057
 i,j,k,ie:    2    6    1          67
 Near X =  0.53131460E-07   1.3500000      0.15332278    , d:   0.0000000     -0.67481345       1.4819057
 i,j,k,ie:    3    6    1          67
 Near X =  0.53131460E-07   1.3500000      0.19200993    , d:   0.0000000     -0.67481345       1.4819057
 i,j,k,ie:    4    6    1          67
 Near X =  0.53131460E-07   1.3500000      0.23800512    , d:   0.0000000     -0.67481345       1.4819057
 i,j,k,ie:    5    6    1          67
 Near X =  0.53131460E-07   1.3500000      0.27669227    , d:   0.0000000     -0.67481345       1.4819057
 i,j,k,ie:    6    6    1          67
 Near X =  0.53131460E-07   1.3500000      0.29563535    , d:  0.67480674     -0.67481345       1.4819057
 i,j,k,ie:    1    1    2          67
 Near X =  0.65425501       1.1329493      0.13437970    , d:   0.0000000      -1.7872286       1.4819057
 i,j,k,ie:    2    1    2          67
 Near X =  0.65425501       1.1329493      0.15332278    , d:   0.0000000      -1.7872286       1.4819057
 i,j,k,ie:    3    1    2          67
 Near X =  0.65425501       1.1329493      0.19200993    , d:   0.0000000      -1.7872286       1.4819057
 i,j,k,ie:    4    1    2          67
 Near X =  0.65425501       1.1329493      0.23800512    , d:   0.0000000      -1.7872286       1.4819057
 i,j,k,ie:    5    1    2          67
 Near X =  0.65425501       1.1329493      0.27669227    , d:   0.0000000      -1.7872286       1.4819057
 i,j,k,ie:    6    1    2          67
 Near X =  0.65425501       1.1329493      0.29563535    , d:  0.65462969      -1.7872286       1.4819057
 i,j,k,ie:    1    2    2          67
 Near X =  0.57739815       1.1536169      0.13437970    , d:   0.0000000     -0.50054068       1.4819057
 i,j,k,ie:    6    2    2          67
 Near X =  0.57739815       1.1536169      0.29563535    , d:  0.49933924       0.0000000       1.4819057
 i,j,k,ie:    1    3    2          67
 Near X =  0.42043460       1.1958259      0.13437970    , d:   0.0000000     -0.18661201       1.4819057
 i,j,k,ie:    6    3    2          67
 Near X =  0.42043460       1.1958259      0.29563535    , d:  0.54145251       0.0000000       1.4819057
 i,j,k,ie:    1    4    2          67
 Near X =  0.23382047       1.2460082      0.13437970    , d:  0.18661812       0.0000000       1.4819057
 i,j,k,ie:    6    4    2          67
 Near X =  0.23382047       1.2460082      0.29563535    , d:  0.59152102       0.0000000       1.4819057
 i,j,k,ie:    1    5    2          67
 Near X =  0.76856912E-01   1.2882172      0.13437970    , d:  0.50054679       0.0000000       1.4819057
 i,j,k,ie:    6    5    2          67
 Near X =  0.76856912E-01   1.2882172      0.29563535    , d:  0.63363429       0.0000000       1.4819057
 i,j,k,ie:    1    6    2          67
 Near X =  0.51513299E-07   1.3088847      0.13437970    , d:  0.65426128      -1.1329494       1.4819057
 i,j,k,ie:    2    6    2          67
 Near X =  0.51513299E-07   1.3088847      0.15332278    , d:   0.0000000     -0.65426148       1.4819057
 i,j,k,ie:    3    6    2          67
 Near X =  0.51513299E-07   1.3088847      0.19200993    , d:   0.0000000     -0.65426148       1.4819057
 i,j,k,ie:    4    6    2          67
 Near X =  0.51513299E-07   1.3088847      0.23800512    , d:   0.0000000     -0.65426148       1.4819057
 i,j,k,ie:    5    6    2          67
 Near X =  0.51513299E-07   1.3088847      0.27669227    , d:   0.0000000     -0.65426148       1.4819057
 i,j,k,ie:    6    6    2          67
 Near X =  0.51513299E-07   1.3088847      0.29563535    , d:  0.65425496     -0.65426148       1.4819057
 i,j,k,ie:    1    1    3          67
 Near X =  0.61228245       1.0602670      0.13437970    , d:   0.0000000      -1.6725721       1.4819057
 i,j,k,ie:    2    1    3          67
 Near X =  0.61228245       1.0602670      0.15332278    , d:   0.0000000      -1.6725721       1.4819057
 i,j,k,ie:    3    1    3          67
 Near X =  0.61228245       1.0602670      0.19200993    , d:   0.0000000      -1.6725721       1.4819057
 i,j,k,ie:    4    1    3          67
 Near X =  0.61228245       1.0602670      0.23800512    , d:   0.0000000      -1.6725721       1.4819057
 i,j,k,ie:    5    1    3          67
 Near X =  0.61228245       1.0602670      0.27669227    , d:   0.0000000      -1.6725721       1.4819057
 i,j,k,ie:    6    1    3          67
 Near X =  0.61228245       1.0602670      0.29563535    , d:  0.61263309      -1.6725721       1.4819057
 i,j,k,ie:    1    2    3          67
 Near X =  0.54035620       1.0796086      0.13437970    , d:   0.0000000     -0.46842939       1.4819057
 i,j,k,ie:    6    2    3          67
 Near X =  0.54035620       1.0796086      0.29563535    , d:  0.46730502       0.0000000       1.4819057
 i,j,k,ie:    1    3    3          67
 Near X =  0.39346237       1.1191098      0.13437970    , d:   0.0000000     -0.17464025       1.4819057
 i,j,k,ie:    6    3    3          67
 Near X =  0.39346237       1.1191098      0.29563535    , d:  0.50671659       0.0000000       1.4819057
 i,j,k,ie:    1    4    3          67
 Near X =  0.21882013       1.1660727      0.13437970    , d:  0.17464597       0.0000000       1.4819057
 i,j,k,ie:    6    4    3          67
 Near X =  0.21882013       1.1660727      0.29563535    , d:  0.55357304       0.0000000       1.4819057
 i,j,k,ie:    1    5    3          67
 Near X =  0.71926293E-01   1.2055739      0.13437970    , d:  0.46843510       0.0000000       1.4819057
 i,j,k,ie:    6    5    3          67
 Near X =  0.71926293E-01   1.2055739      0.29563535    , d:  0.59298461       0.0000000       1.4819057
 i,j,k,ie:    1    6    3          67
 Near X =  0.48208555E-07   1.2249155      0.13437970    , d:  0.61228831      -1.0602671       1.4819057
 i,j,k,ie:    2    6    3          67
 Near X =  0.48208555E-07   1.2249155      0.15332278    , d:   0.0000000     -0.61228850       1.4819057
 i,j,k,ie:    3    6    3          67
 Near X =  0.48208555E-07   1.2249155      0.19200993    , d:   0.0000000     -0.61228850       1.4819057
 i,j,k,ie:    4    6    3          67
 Near X =  0.48208555E-07   1.2249155      0.23800512    , d:   0.0000000     -0.61228850       1.4819057
 i,j,k,ie:    5    6    3          67
 Near X =  0.48208555E-07   1.2249155      0.27669227    , d:   0.0000000     -0.61228850       1.4819057
 i,j,k,ie:    6    6    3          67
 Near X =  0.48208555E-07   1.2249155      0.29563535    , d:  0.61228240     -0.61228850       1.4819057
 i,j,k,ie:    1    1    4          67
 Near X =  0.56238122      0.97385487      0.13437970    , d:   0.0000000      -1.5362569       1.4819057
 i,j,k,ie:    2    1    4          67
 Near X =  0.56238122      0.97385487      0.15332278    , d:   0.0000000      -1.5362569       1.4819057
 i,j,k,ie:    3    1    4          67
 Near X =  0.56238122      0.97385487      0.19200993    , d:   0.0000000      -1.5362569       1.4819057
 i,j,k,ie:    4    1    4          67
 Near X =  0.56238122      0.97385487      0.23800512    , d:   0.0000000      -1.5362569       1.4819057
 i,j,k,ie:    5    1    4          67
 Near X =  0.56238122      0.97385487      0.27669227    , d:   0.0000000      -1.5362569       1.4819057
 i,j,k,ie:    6    1    4          67
 Near X =  0.56238122      0.97385487      0.29563535    , d:  0.56270328      -1.5362569       1.4819057
 i,j,k,ie:    1    2    4          67
 Near X =  0.49631699      0.99162017      0.13437970    , d:   0.0000000     -0.43025223       1.4819057
 i,j,k,ie:    6    2    4          67
 Near X =  0.49631699      0.99162017      0.29563535    , d:  0.42921950       0.0000000       1.4819057
 i,j,k,ie:    1    3    4          67
 Near X =  0.36139505       1.0279020      0.13437970    , d:   0.0000000     -0.16040701       1.4819057
 i,j,k,ie:    6    3    4          67
 Near X =  0.36139505       1.0279020      0.29563535    , d:  0.46541901       0.0000000       1.4819057
 i,j,k,ie:    1    4    4          67
 Near X =  0.20098621       1.0710374      0.13437970    , d:  0.16041226       0.0000000       1.4819057
 i,j,k,ie:    6    4    4          67
 Near X =  0.20098621       1.0710374      0.29563535    , d:  0.50845665       0.0000000       1.4819057
 i,j,k,ie:    1    5    4          67
 Near X =  0.66064276E-01   1.1073192      0.13437970    , d:  0.43025748       0.0000000       1.4819057
 i,j,k,ie:    6    5    4          67
 Near X =  0.66064276E-01   1.1073192      0.29563535    , d:  0.54465616       0.0000000       1.4819057
 i,j,k,ie:    1    6    4          67
 Near X =  0.44279542E-07   1.1250845      0.13437970    , d:  0.56238660     -0.97385492       1.4819057
 i,j,k,ie:    2    6    4          67
 Near X =  0.44279542E-07   1.1250845      0.15332278    , d:   0.0000000     -0.56238677       1.4819057
 i,j,k,ie:    3    6    4          67
 Near X =  0.44279542E-07   1.1250845      0.19200993    , d:   0.0000000     -0.56238677       1.4819057
 i,j,k,ie:    4    6    4          67
 Near X =  0.44279542E-07   1.1250845      0.23800512    , d:   0.0000000     -0.56238677       1.4819057
 i,j,k,ie:    5    6    4          67
 Near X =  0.44279542E-07   1.1250845      0.27669227    , d:   0.0000000     -0.56238677       1.4819057
 i,j,k,ie:    6    6    4          67
 Near X =  0.44279542E-07   1.1250845      0.29563535    , d:  0.56238117     -0.56238677       1.4819057
 i,j,k,ie:    1    1    5          67
 Near X =  0.52040865      0.90117252      0.13437970    , d:   0.0000000      -1.4216004       1.4819057
 i,j,k,ie:    2    1    5          67
 Near X =  0.52040865      0.90117252      0.15332278    , d:   0.0000000      -1.4216004       1.4819057
 i,j,k,ie:    3    1    5          67
 Near X =  0.52040865      0.90117252      0.19200993    , d:   0.0000000      -1.4216004       1.4819057
 i,j,k,ie:    4    1    5          67
 Near X =  0.52040865      0.90117252      0.23800512    , d:   0.0000000      -1.4216004       1.4819057
 i,j,k,ie:    5    1    5          67
 Near X =  0.52040865      0.90117252      0.27669227    , d:   0.0000000      -1.4216004       1.4819057
 i,j,k,ie:    6    1    5          67
 Near X =  0.52040865      0.90117252      0.29563535    , d:  0.52070668      -1.4216004       1.4819057
 i,j,k,ie:    1    2    5          67
 Near X =  0.45927504      0.91761193      0.13437970    , d:   0.0000000     -0.39814093       1.4819057
 i,j,k,ie:    6    2    5          67
 Near X =  0.45927504      0.91761193      0.29563535    , d:  0.39718528       0.0000000       1.4819057
 i,j,k,ie:    1    3    5          67
 Near X =  0.33442282      0.95118587      0.13437970    , d:   0.0000000     -0.14843525       1.4819057
 i,j,k,ie:    6    3    5          67
 Near X =  0.33442282      0.95118587      0.29563535    , d:  0.43068309       0.0000000       1.4819057
 i,j,k,ie:    1    4    5          67
 Near X =  0.18598588      0.99110197      0.13437970    , d:  0.14844011       0.0000000       1.4819057
 i,j,k,ie:    6    4    5          67
 Near X =  0.18598588      0.99110197      0.29563535    , d:  0.47050867       0.0000000       1.4819057
 i,j,k,ie:    1    5    5          67
 Near X =  0.61133657E-01   1.0246759      0.13437970    , d:  0.39814579       0.0000000       1.4819057
 i,j,k,ie:    6    5    5          67
 Near X =  0.61133657E-01   1.0246759      0.29563535    , d:  0.50400648       0.0000000       1.4819057
 i,j,k,ie:    1    6    5          67
 Near X =  0.40974798E-07   1.0411153      0.13437970    , d:  0.52041363     -0.90117257       1.4819057
 i,j,k,ie:    2    6    5          67
 Near X =  0.40974798E-07   1.0411153      0.15332278    , d:   0.0000000     -0.52041379       1.4819057
 i,j,k,ie:    3    6    5          67
 Near X =  0.40974798E-07   1.0411153      0.19200993    , d:   0.0000000     -0.52041379       1.4819057
 i,j,k,ie:    4    6    5          67
 Near X =  0.40974798E-07   1.0411153      0.23800512    , d:   0.0000000     -0.52041379       1.4819057
 i,j,k,ie:    5    6    5          67
 Near X =  0.40974798E-07   1.0411153      0.27669227    , d:   0.0000000     -0.52041379       1.4819057
 i,j,k,ie:    6    6    5          67
 Near X =  0.40974798E-07   1.0411153      0.29563535    , d:  0.52040861     -0.52041379       1.4819057
 i,j,k,ie:    1    1    6          67
 Near X =  0.49985688      0.86558377      0.13437970    , d:  0.17494991      -1.6684200       1.4819057
 i,j,k,ie:    2    1    6          67
 Near X =  0.49985688      0.86558377      0.15332278    , d:  0.17494991      -1.6684200       1.4819057
 i,j,k,ie:    3    1    6          67
 Near X =  0.49985688      0.86558377      0.19200993    , d:  0.17494991      -1.6684200       1.4819057
 i,j,k,ie:    4    1    6          67
 Near X =  0.49985688      0.86558377      0.23800512    , d:  0.17494991      -1.6684200       1.4819057
 i,j,k,ie:    5    1    6          67
 Near X =  0.49985688      0.86558377      0.27669227    , d:  0.17494991      -1.6684200       1.4819057
 i,j,k,ie:    6    1    6          67
 Near X =  0.49985688      0.86558377      0.29563535    , d:  0.85014315      -1.6684200       1.4819057
 i,j,k,ie:    1    2    6          67
 Near X =  0.44113753      0.88137396      0.13437970    , d:  0.15439814     -0.38241771       1.4819057
 i,j,k,ie:    2    2    6          67
 Near X =  0.44113753      0.88137396      0.15332278    , d:  0.15439814       0.0000000       1.4819057
 i,j,k,ie:    3    2    6          67
 Near X =  0.44113753      0.88137396      0.19200993    , d:  0.15439814       0.0000000       1.4819057
 i,j,k,ie:    4    2    6          67
 Near X =  0.44113753      0.88137396      0.23800512    , d:  0.15439814       0.0000000       1.4819057
 i,j,k,ie:    5    2    6          67
 Near X =  0.44113753      0.88137396      0.27669227    , d:  0.15439814       0.0000000       1.4819057
 i,j,k,ie:    6    2    6          67
 Near X =  0.44113753      0.88137396      0.29563535    , d:  0.66942286       0.0000000       1.4819057
 i,j,k,ie:    1    3    6          67
 Near X =  0.32121592      0.91362201      0.13437970    , d:  0.11242558     -0.14257330       1.4819057
 i,j,k,ie:    2    3    6          67
 Near X =  0.32121592      0.91362201      0.15332278    , d:  0.11242558       0.0000000       1.4819057
 i,j,k,ie:    3    3    6          67
 Near X =  0.32121592      0.91362201      0.19200993    , d:  0.11242558       0.0000000       1.4819057
 i,j,k,ie:    4    3    6          67
 Near X =  0.32121592      0.91362201      0.23800512    , d:  0.11242558       0.0000000       1.4819057
 i,j,k,ie:    5    3    6          67
 Near X =  0.32121592      0.91362201      0.27669227    , d:  0.11242558       0.0000000       1.4819057
 i,j,k,ie:    6    3    6          67
 Near X =  0.32121592      0.91362201      0.29563535    , d:  0.67088645       0.0000000       1.4819057
 i,j,k,ie:    1    4    6          67
 Near X =  0.17864100      0.95196176      0.13437970    , d:  0.25500461       0.0000000       1.4819057
 i,j,k,ie:    2    4    6          67
 Near X =  0.17864100      0.95196176      0.15332278    , d:  0.62524351E-01   0.0000000       1.4819057
 i,j,k,ie:    3    4    6          67
 Near X =  0.17864100      0.95196176      0.19200993    , d:  0.62524351E-01   0.0000000       1.4819057
 i,j,k,ie:    4    4    6          67
 Near X =  0.17864100      0.95196176      0.23800512    , d:  0.62524351E-01   0.0000000       1.4819057
 i,j,k,ie:    5    4    6          67
 Near X =  0.17864100      0.95196176      0.27669227    , d:  0.62524351E-01   0.0000000       1.4819057
 i,j,k,ie:    6    4    6          67
 Near X =  0.17864100      0.95196176      0.29563535    , d:  0.67262652       0.0000000       1.4819057
 i,j,k,ie:    1    5    6          67
 Near X =  0.58719391E-01  0.98420982      0.13437970    , d:  0.53682200       0.0000000       1.4819057
 i,j,k,ie:    2    5    6          67
 Near X =  0.58719391E-01  0.98420982      0.15332278    , d:  0.20551787E-01   0.0000000       1.4819057
 i,j,k,ie:    3    5    6          67
 Near X =  0.58719391E-01  0.98420982      0.19200993    , d:  0.20551787E-01   0.0000000       1.4819057
 i,j,k,ie:    4    5    6          67
 Near X =  0.58719391E-01  0.98420982      0.23800512    , d:  0.20551787E-01   0.0000000       1.4819057
 i,j,k,ie:    5    5    6          67
 Near X =  0.58719391E-01  0.98420982      0.27669227    , d:  0.20551787E-01   0.0000000       1.4819057
 i,j,k,ie:    6    5    6          67
 Near X =  0.58719391E-01  0.98420982      0.29563535    , d:  0.67409011       0.0000000       1.4819057
 i,j,k,ie:    1    6    6          67
 Near X =  0.39356637E-07   1.0000000      0.13437970    , d:  0.67481326      -1.1685381       1.4819057
 i,j,k,ie:    2    6    6          67
 Near X =  0.39356637E-07   1.0000000      0.15332278    , d:  0.13774823E-07 -0.67481344       1.4819057
 i,j,k,ie:    3    6    6          67
 Near X =  0.39356637E-07   1.0000000      0.19200993    , d:  0.13774823E-07 -0.67481344       1.4819057
 i,j,k,ie:    4    6    6          67
 Near X =  0.39356637E-07   1.0000000      0.23800512    , d:  0.13774823E-07 -0.67481344       1.4819057
 i,j,k,ie:    5    6    6          67
 Near X =  0.39356637E-07   1.0000000      0.27669227    , d:  0.13774823E-07 -0.67481344       1.4819057
 i,j,k,ie:    6    6    6          67
 Near X =  0.39356637E-07   1.0000000      0.29563535    , d:  0.67480675     -0.67481344       1.4819057
 i,j,k,ie:    1    1    1          68
 Near X =   1.1685631      0.67481338      0.13437970    , d:  0.18143693      -2.3371262      0.85575182
 i,j,k,ie:    2    1    1          68
 Near X =   1.1685631      0.67481338      0.15332278    , d:  0.18143693     -0.30296081      0.85575182
 i,j,k,ie:    3    1    1          68
 Near X =   1.1685631      0.67481338      0.19200993    , d:  0.18143693     -0.30296081      0.85575182
 i,j,k,ie:    4    1    1          68
 Near X =   1.1685631      0.67481338      0.23800512    , d:  0.18143693     -0.30296081      0.85575182
 i,j,k,ie:    5    1    1          68
 Near X =   1.1685631      0.67481338      0.27669227    , d:  0.18143693     -0.30296081      0.85575182
 i,j,k,ie:    6    1    1          68
 Near X =   1.1685631      0.67481338      0.29563535    , d:  0.18143693     -0.30296081      0.85575182
 i,j,k,ie:    1    2    1          68
 Near X =   1.1105604      0.73281237      0.13437970    , d:   0.0000000     -0.66942286      0.85575182
 i,j,k,ie:    2    2    1          68
 Near X =   1.1105604      0.73281237      0.15332278    , d:   0.0000000     -0.28792307      0.85575182
 i,j,k,ie:    3    2    1          68
 Near X =   1.1105604      0.73281237      0.19200993    , d:   0.0000000     -0.28792307      0.85575182
 i,j,k,ie:    4    2    1          68
 Near X =   1.1105604      0.73281237      0.23800512    , d:   0.0000000     -0.28792307      0.85575182
 i,j,k,ie:    5    2    1          68
 Near X =   1.1105604      0.73281237      0.27669227    , d:   0.0000000     -0.28792307      0.85575182
 i,j,k,ie:    6    2    1          68
 Near X =   1.1105604      0.73281237      0.29563535    , d:   0.0000000     -0.28792307      0.85575182
 i,j,k,ie:    1    3    1          68
 Near X =  0.99210237      0.85126281      0.13437970    , d:   0.0000000     -0.67088645      0.85575182
 i,j,k,ie:    2    3    1          68
 Near X =  0.99210237      0.85126281      0.15332278    , d:   0.0000000     -0.25721173      0.85575182
 i,j,k,ie:    3    3    1          68
 Near X =  0.99210237      0.85126281      0.19200993    , d:   0.0000000     -0.25721173      0.85575182
 i,j,k,ie:    4    3    1          68
 Near X =  0.99210237      0.85126281      0.23800512    , d:   0.0000000     -0.25721173      0.85575182
 i,j,k,ie:    5    3    1          68
 Near X =  0.99210237      0.85126281      0.27669227    , d:   0.0000000     -0.25721173      0.85575182
 i,j,k,ie:    6    3    1          68
 Near X =  0.99210237      0.85126281      0.29563535    , d:   0.0000000     -0.25721173      0.85575182
 i,j,k,ie:    1    4    1          68
 Near X =  0.85126751      0.99208866      0.13437970    , d:   0.0000000     -0.67262652      0.85575182
 i,j,k,ie:    2    4    1          68
 Near X =  0.85126751      0.99208866      0.15332278    , d:   0.0000000     -0.22069899      0.85575182
 i,j,k,ie:    3    4    1          68
 Near X =  0.85126751      0.99208866      0.19200993    , d:   0.0000000     -0.22069899      0.85575182
 i,j,k,ie:    4    4    1          68
 Near X =  0.85126751      0.99208866      0.23800512    , d:   0.0000000     -0.22069899      0.85575182
 i,j,k,ie:    5    4    1          68
 Near X =  0.85126751      0.99208866      0.27669227    , d:   0.0000000     -0.22069899      0.85575182
 i,j,k,ie:    6    4    1          68
 Near X =  0.85126751      0.99208866      0.29563535    , d:   0.0000000     -0.22069899      0.85575182
 i,j,k,ie:    1    5    1          68
 Near X =  0.73280950       1.1105391      0.13437970    , d:   0.0000000     -0.67409011      0.85575182
 i,j,k,ie:    2    5    1          68
 Near X =  0.73280950       1.1105391      0.15332278    , d:   0.0000000     -0.18998765      0.85575182
 i,j,k,ie:    3    5    1          68
 Near X =  0.73280950       1.1105391      0.19200993    , d:   0.0000000     -0.18998765      0.85575182
 i,j,k,ie:    4    5    1          68
 Near X =  0.73280950       1.1105391      0.23800512    , d:   0.0000000     -0.18998765      0.85575182
 i,j,k,ie:    5    5    1          68
 Near X =  0.73280950       1.1105391      0.27669227    , d:   0.0000000     -0.18998765      0.85575182
 i,j,k,ie:    6    5    1          68
 Near X =  0.73280950       1.1105391      0.29563535    , d:   0.0000000     -0.18998765      0.85575182
 i,j,k,ie:    1    6    1          68
 Near X =  0.67480679       1.1685381      0.13437970    , d:   0.0000000      -1.3496202      0.85575182
 i,j,k,ie:    2    6    1          68
 Near X =  0.67480679       1.1685381      0.15332278    , d:   0.0000000     -0.67480675      0.85575182
 i,j,k,ie:    3    6    1          68
 Near X =  0.67480679       1.1685381      0.19200993    , d:   0.0000000     -0.67480675      0.85575182
 i,j,k,ie:    4    6    1          68
 Near X =  0.67480679       1.1685381      0.23800512    , d:   0.0000000     -0.67480675      0.85575182
 i,j,k,ie:    5    6    1          68
 Near X =  0.67480679       1.1685381      0.27669227    , d:   0.0000000     -0.67480675      0.85575182
 i,j,k,ie:    6    6    1          68
 Near X =  0.67480679       1.1685381      0.29563535    , d:   0.0000000     -0.67480675      0.85575182
 i,j,k,ie:    1    1    2          68
 Near X =   1.1329736      0.65426140      0.13437970    , d:  0.17591112      -2.2659471      0.85575182
 i,j,k,ie:    2    1    2          68
 Near X =   1.1329736      0.65426140      0.15332278    , d:  0.17591112       0.0000000      0.85575182
 i,j,k,ie:    3    1    2          68
 Near X =   1.1329736      0.65426140      0.19200993    , d:  0.17591112       0.0000000      0.85575182
 i,j,k,ie:    4    1    2          68
 Near X =   1.1329736      0.65426140      0.23800512    , d:  0.17591112       0.0000000      0.85575182
 i,j,k,ie:    5    1    2          68
 Near X =   1.1329736      0.65426140      0.27669227    , d:  0.17591112       0.0000000      0.85575182
 i,j,k,ie:    6    1    2          68
 Near X =   1.1329736      0.65426140      0.29563535    , d:  0.17591112       0.0000000      0.85575182
 i,j,k,ie:    1    2    2          68
 Near X =   1.0767374      0.71049399      0.13437970    , d:   0.0000000     -0.49933924      0.85575182
 i,j,k,ie:    1    3    2          68
 Near X =  0.96188711      0.82533693      0.13437970    , d:   0.0000000     -0.54145251      0.85575182
 i,j,k,ie:    1    4    2          68
 Near X =  0.82534149      0.96187381      0.13437970    , d:   0.0000000     -0.59152102      0.85575182
 i,j,k,ie:    1    5    2          68
 Near X =  0.71049120       1.0767167      0.13437970    , d:   0.0000000     -0.63363429      0.85575182
 i,j,k,ie:    1    6    2          68
 Near X =  0.65425501       1.1329493      0.13437970    , d:   0.0000000      -1.3085164      0.85575182
 i,j,k,ie:    2    6    2          68
 Near X =  0.65425501       1.1329493      0.15332278    , d:   0.0000000     -0.65425496      0.85575182
 i,j,k,ie:    3    6    2          68
 Near X =  0.65425501       1.1329493      0.19200993    , d:   0.0000000     -0.65425496      0.85575182
 i,j,k,ie:    4    6    2          68
 Near X =  0.65425501       1.1329493      0.23800512    , d:   0.0000000     -0.65425496      0.85575182
 i,j,k,ie:    5    6    2          68
 Near X =  0.65425501       1.1329493      0.27669227    , d:   0.0000000     -0.65425496      0.85575182
 i,j,k,ie:    6    6    2          68
 Near X =  0.65425501       1.1329493      0.29563535    , d:   0.0000000     -0.65425496      0.85575182
 i,j,k,ie:    1    1    3          68
 Near X =   1.0602897      0.61228843      0.13437970    , d:  0.16462586      -2.1205793      0.85575182
 i,j,k,ie:    2    1    3          68
 Near X =   1.0602897      0.61228843      0.15332278    , d:  0.16462586       0.0000000      0.85575182
 i,j,k,ie:    3    1    3          68
 Near X =   1.0602897      0.61228843      0.19200993    , d:  0.16462586       0.0000000      0.85575182
 i,j,k,ie:    4    1    3          68
 Near X =   1.0602897      0.61228843      0.23800512    , d:  0.16462586       0.0000000      0.85575182
 i,j,k,ie:    5    1    3          68
 Near X =   1.0602897      0.61228843      0.27669227    , d:  0.16462586       0.0000000      0.85575182
 i,j,k,ie:    6    1    3          68
 Near X =   1.0602897      0.61228843      0.29563535    , d:  0.16462586       0.0000000      0.85575182
 i,j,k,ie:    1    2    3          68
 Near X =   1.0076612      0.66491352      0.13437970    , d:   0.0000000     -0.46730502      0.85575182
 i,j,k,ie:    1    3    3          68
 Near X =  0.90017895      0.77238891      0.13437970    , d:   0.0000000     -0.50671659      0.85575182
 i,j,k,ie:    1    4    3          68
 Near X =  0.77239317      0.90016651      0.13437970    , d:   0.0000000     -0.55357304      0.85575182
 i,j,k,ie:    1    5    3          68
 Near X =  0.66491090       1.0076419      0.13437970    , d:   0.0000000     -0.59298461      0.85575182
 i,j,k,ie:    1    6    3          68
 Near X =  0.61228245       1.0602670      0.13437970    , d:   0.0000000      -1.2245709      0.85575182
 i,j,k,ie:    2    6    3          68
 Near X =  0.61228245       1.0602670      0.15332278    , d:   0.0000000     -0.61228240      0.85575182
 i,j,k,ie:    3    6    3          68
 Near X =  0.61228245       1.0602670      0.19200993    , d:   0.0000000     -0.61228240      0.85575182
 i,j,k,ie:    4    6    3          68
 Near X =  0.61228245       1.0602670      0.23800512    , d:   0.0000000     -0.61228240      0.85575182
 i,j,k,ie:    5    6    3          68
 Near X =  0.61228245       1.0602670      0.27669227    , d:   0.0000000     -0.61228240      0.85575182
 i,j,k,ie:    6    6    3          68
 Near X =  0.61228245       1.0602670      0.29563535    , d:   0.0000000     -0.61228240      0.85575182
 i,j,k,ie:    1    1    4          68
 Near X =  0.97387571      0.56238671      0.13437970    , d:  0.15120879      -1.9477514      0.85575182
 i,j,k,ie:    2    1    4          68
 Near X =  0.97387571      0.56238671      0.15332278    , d:  0.15120879       0.0000000      0.85575182
 i,j,k,ie:    3    1    4          68
 Near X =  0.97387571      0.56238671      0.19200993    , d:  0.15120879       0.0000000      0.85575182
 i,j,k,ie:    4    1    4          68
 Near X =  0.97387571      0.56238671      0.23800512    , d:  0.15120879       0.0000000      0.85575182
 i,j,k,ie:    5    1    4          68
 Near X =  0.97387571      0.56238671      0.27669227    , d:  0.15120879       0.0000000      0.85575182
 i,j,k,ie:    6    1    4          68
 Near X =  0.97387571      0.56238671      0.29563535    , d:  0.15120879       0.0000000      0.85575182
 i,j,k,ie:    1    2    4          68
 Near X =  0.92553649      0.61072284      0.13437970    , d:   0.0000000     -0.42921950      0.85575182
 i,j,k,ie:    1    3    4          68
 Near X =  0.82681406      0.70943895      0.13437970    , d:   0.0000000     -0.46541901      0.85575182
 i,j,k,ie:    1    4    4          68
 Near X =  0.70944286      0.82680263      0.13437970    , d:   0.0000000     -0.50845665      0.85575182
 i,j,k,ie:    1    5    4          68
 Near X =  0.61072044      0.92551874      0.13437970    , d:   0.0000000     -0.54465616      0.85575182
 i,j,k,ie:    1    6    4          68
 Near X =  0.56238122      0.97385487      0.13437970    , d:   0.0000000      -1.1247679      0.85575182
 i,j,k,ie:    2    6    4          68
 Near X =  0.56238122      0.97385487      0.15332278    , d:   0.0000000     -0.56238117      0.85575182
 i,j,k,ie:    3    6    4          68
 Near X =  0.56238122      0.97385487      0.19200993    , d:   0.0000000     -0.56238117      0.85575182
 i,j,k,ie:    4    6    4          68
 Near X =  0.56238122      0.97385487      0.23800512    , d:   0.0000000     -0.56238117      0.85575182
 i,j,k,ie:    5    6    4          68
 Near X =  0.56238122      0.97385487      0.27669227    , d:   0.0000000     -0.56238117      0.85575182
 i,j,k,ie:    6    6    4          68
 Near X =  0.56238122      0.97385487      0.29563535    , d:   0.0000000     -0.56238117      0.85575182
 i,j,k,ie:    1    1    5          68
 Near X =  0.90119180      0.52041374      0.13437970    , d:  0.13992353      -1.8023836      0.85575182
 i,j,k,ie:    2    1    5          68
 Near X =  0.90119180      0.52041374      0.15332278    , d:  0.13992353       0.0000000      0.85575182
 i,j,k,ie:    3    1    5          68
 Near X =  0.90119180      0.52041374      0.19200993    , d:  0.13992353       0.0000000      0.85575182
 i,j,k,ie:    4    1    5          68
 Near X =  0.90119180      0.52041374      0.23800512    , d:  0.13992353       0.0000000      0.85575182
 i,j,k,ie:    5    1    5          68
 Near X =  0.90119180      0.52041374      0.27669227    , d:  0.13992353       0.0000000      0.85575182
 i,j,k,ie:    6    1    5          68
 Near X =  0.90119180      0.52041374      0.29563535    , d:  0.13992353       0.0000000      0.85575182
 i,j,k,ie:    1    2    5          68
 Near X =  0.85646032      0.56514236      0.13437970    , d:   0.0000000     -0.39718528      0.85575182
 i,j,k,ie:    1    3    5          68
 Near X =  0.76510591      0.65649093      0.13437970    , d:   0.0000000     -0.43068309      0.85575182
 i,j,k,ie:    1    4    5          68
 Near X =  0.65649455      0.76509533      0.13437970    , d:   0.0000000     -0.47050867      0.85575182
 i,j,k,ie:    1    5    5          68
 Near X =  0.56514014      0.85644389      0.13437970    , d:   0.0000000     -0.50400648      0.85575182
 i,j,k,ie:    1    6    5          68
 Near X =  0.52040865      0.90117252      0.13437970    , d:   0.0000000      -1.0408224      0.85575182
 i,j,k,ie:    2    6    5          68
 Near X =  0.52040865      0.90117252      0.15332278    , d:   0.0000000     -0.52040861      0.85575182
 i,j,k,ie:    3    6    5          68
 Near X =  0.52040865      0.90117252      0.19200993    , d:   0.0000000     -0.52040861      0.85575182
 i,j,k,ie:    4    6    5          68
 Near X =  0.52040865      0.90117252      0.23800512    , d:   0.0000000     -0.52040861      0.85575182
 i,j,k,ie:    5    6    5          68
 Near X =  0.52040865      0.90117252      0.27669227    , d:   0.0000000     -0.52040861      0.85575182
 i,j,k,ie:    6    6    5          68
 Near X =  0.52040865      0.90117252      0.29563535    , d:   0.0000000     -0.52040861      0.85575182
 i,j,k,ie:    1    1    6          68
 Near X =  0.86560229      0.49986176      0.13437970    , d:  0.48439774      -2.0341654      0.85575182
 i,j,k,ie:    2    1    6          68
 Near X =  0.86560229      0.49986176      0.15332278    , d:  0.48439774       0.0000000      0.85575182
 i,j,k,ie:    3    1    6          68
 Near X =  0.86560229      0.49986176      0.19200993    , d:  0.48439774       0.0000000      0.85575182
 i,j,k,ie:    4    1    6          68
 Near X =  0.86560229      0.49986176      0.23800512    , d:  0.48439774       0.0000000      0.85575182
 i,j,k,ie:    5    1    6          68
 Near X =  0.86560229      0.49986176      0.27669227    , d:  0.48439774       0.0000000      0.85575182
 i,j,k,ie:    6    1    6          68
 Near X =  0.86560229      0.49986176      0.29563535    , d:  0.48439774       0.0000000      0.85575182
 i,j,k,ie:    1    2    6          68
 Near X =  0.82263732      0.54282398      0.13437970    , d:  0.28792307     -0.38149979      0.85575182
 i,j,k,ie:    2    2    6          68
 Near X =  0.82263732      0.54282398      0.15332278    , d:  0.28792307       0.0000000      0.85575182
 i,j,k,ie:    3    2    6          68
 Near X =  0.82263732      0.54282398      0.19200993    , d:  0.28792307       0.0000000      0.85575182
 i,j,k,ie:    4    2    6          68
 Near X =  0.82263732      0.54282398      0.23800512    , d:  0.28792307       0.0000000      0.85575182
 i,j,k,ie:    5    2    6          68
 Near X =  0.82263732      0.54282398      0.27669227    , d:  0.28792307       0.0000000      0.85575182
 i,j,k,ie:    6    2    6          68
 Near X =  0.82263732      0.54282398      0.29563535    , d:  0.28792307       0.0000000      0.85575182
 i,j,k,ie:    1    3    6          68
 Near X =  0.73489064      0.63056504      0.13437970    , d:  0.25721173     -0.41367472      0.85575182
 i,j,k,ie:    2    3    6          68
 Near X =  0.73489064      0.63056504      0.15332278    , d:  0.25721173       0.0000000      0.85575182
 i,j,k,ie:    3    3    6          68
 Near X =  0.73489064      0.63056504      0.19200993    , d:  0.25721173       0.0000000      0.85575182
 i,j,k,ie:    4    3    6          68
 Near X =  0.73489064      0.63056504      0.23800512    , d:  0.25721173       0.0000000      0.85575182
 i,j,k,ie:    5    3    6          68
 Near X =  0.73489064      0.63056504      0.27669227    , d:  0.25721173       0.0000000      0.85575182
 i,j,k,ie:    6    3    6          68
 Near X =  0.73489064      0.63056504      0.29563535    , d:  0.25721173       0.0000000      0.85575182
 i,j,k,ie:    1    4    6          68
 Near X =  0.63056852      0.73488049      0.13437970    , d:  0.22069899     -0.45192753      0.85575182
 i,j,k,ie:    2    4    6          68
 Near X =  0.63056852      0.73488049      0.15332278    , d:  0.22069899       0.0000000      0.85575182
 i,j,k,ie:    3    4    6          68
 Near X =  0.63056852      0.73488049      0.19200993    , d:  0.22069899       0.0000000      0.85575182
 i,j,k,ie:    4    4    6          68
 Near X =  0.63056852      0.73488049      0.23800512    , d:  0.22069899       0.0000000      0.85575182
 i,j,k,ie:    5    4    6          68
 Near X =  0.63056852      0.73488049      0.27669227    , d:  0.22069899       0.0000000      0.85575182
 i,j,k,ie:    6    4    6          68
 Near X =  0.63056852      0.73488049      0.29563535    , d:  0.22069899       0.0000000      0.85575182
 i,j,k,ie:    1    5    6          68
 Near X =  0.54282185      0.82262155      0.13437970    , d:  0.18998765     -0.48410245      0.85575182
 i,j,k,ie:    2    5    6          68
 Near X =  0.54282185      0.82262155      0.15332278    , d:  0.18998765       0.0000000      0.85575182
 i,j,k,ie:    3    5    6          68
 Near X =  0.54282185      0.82262155      0.19200993    , d:  0.18998765       0.0000000      0.85575182
 i,j,k,ie:    4    5    6          68
 Near X =  0.54282185      0.82262155      0.23800512    , d:  0.18998765       0.0000000      0.85575182
 i,j,k,ie:    5    5    6          68
 Near X =  0.54282185      0.82262155      0.27669227    , d:  0.18998765       0.0000000      0.85575182
 i,j,k,ie:    6    5    6          68
 Near X =  0.54282185      0.82262155      0.29563535    , d:  0.18998765       0.0000000      0.85575182
 i,j,k,ie:    1    6    6          68
 Near X =  0.49985688      0.86558377      0.13437970    , d:  0.17494991      -1.1746703      0.85575182
 i,j,k,ie:    2    6    6          68
 Near X =  0.49985688      0.86558377      0.15332278    , d:  0.17494991     -0.49985684      0.85575182
 i,j,k,ie:    3    6    6          68
 Near X =  0.49985688      0.86558377      0.19200993    , d:  0.17494991     -0.49985684      0.85575182
 i,j,k,ie:    4    6    6          68
 Near X =  0.49985688      0.86558377      0.23800512    , d:  0.17494991     -0.49985684      0.85575182
 i,j,k,ie:    5    6    6          68
 Near X =  0.49985688      0.86558377      0.27669227    , d:  0.17494991     -0.49985684      0.85575182
 i,j,k,ie:    6    6    6          68
 Near X =  0.49985688      0.86558377      0.29563535    , d:  0.17494991     -0.49985684      0.85575182
 i,j,k,ie:    1    1    1          69
 Near X =   1.3500000     -0.77758166E-07  0.13437970    , d:   0.0000000     -0.48441628      0.74074073
 i,j,k,ie:    2    1    1          69
 Near X =   1.3500000     -0.77758166E-07  0.15332278    , d:   0.0000000     -0.48441628      0.74074073
 i,j,k,ie:    3    1    1          69
 Near X =   1.3500000     -0.77758166E-07  0.19200993    , d:   0.0000000     -0.48441628      0.74074073
 i,j,k,ie:    4    1    1          69
 Near X =   1.3500000     -0.77758166E-07  0.23800512    , d:   0.0000000     -0.48441628      0.74074073
 i,j,k,ie:    5    1    1          69
 Near X =   1.3500000     -0.77758166E-07  0.27669227    , d:   0.0000000     -0.48441628      0.74074073
 i,j,k,ie:    6    1    1          69
 Near X =   1.3500000     -0.77758166E-07  0.29563535    , d:   0.0000000      -2.5185381      0.74074073
 i,j,k,ie:    1    2    1          69
 Near X =   1.3286862      0.79271836E-01  0.13437970    , d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    2    2    1          69
 Near X =   1.3286862      0.79271836E-01  0.15332278    , d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    3    2    1          69
 Near X =   1.3286862      0.79271836E-01  0.19200993    , d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    4    2    1          69
 Near X =   1.3286862      0.79271836E-01  0.23800512    , d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    5    2    1          69
 Near X =   1.3286862      0.79271836E-01  0.27669227    , d:   0.0000000     -0.34447421      0.74074073
 i,j,k,ie:    6    2    1          69
 Near X =   1.3286862      0.79271836E-01  0.29563535    , d:   0.0000000      -2.5185411      0.74074073
 i,j,k,ie:    1    3    1          69
 Near X =   1.2851573      0.24116762      0.13437970    , d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    2    3    1          69
 Near X =   1.2851573      0.24116762      0.15332278    , d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    3    3    1          69
 Near X =   1.2851573      0.24116762      0.19200993    , d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    4    3    1          69
 Near X =   1.2851573      0.24116762      0.23800512    , d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    5    3    1          69
 Near X =   1.2851573      0.24116762      0.27669227    , d:   0.0000000     -0.33318894      0.74074073
 i,j,k,ie:    6    3    1          69
 Near X =   1.2851573      0.24116762      0.29563535    , d:   0.0000000      -2.5185471      0.74074073
 i,j,k,ie:    1    4    1          69
 Near X =   1.2334058      0.43364568      0.13437970    , d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    2    4    1          69
 Near X =   1.2334058      0.43364568      0.15332278    , d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    3    4    1          69
 Near X =   1.2334058      0.43364568      0.19200993    , d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    4    4    1          69
 Near X =   1.2334058      0.43364568      0.23800512    , d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    5    4    1          69
 Near X =   1.2334058      0.43364568      0.27669227    , d:   0.0000000     -0.31977188      0.74074073
 i,j,k,ie:    6    4    1          69
 Near X =   1.2334058      0.43364568      0.29563535    , d:   0.0000000      -2.5185542      0.74074073
 i,j,k,ie:    1    5    1          69
 Near X =   1.1898769      0.59554146      0.13437970    , d:   0.0000000     -0.30848662      0.74074073
 i,j,k,ie:    2    5    1          69
 Near X =   1.1898769      0.59554146      0.15332278    , d:   0.0000000     -0.30848662      0.74074073
 i,j,k,ie:    3    5    1          69
 Near X =   1.1898769      0.59554146      0.19200993    , d:   0.0000000     -0.30848662      0.74074073
 i,j,k,ie:    4    5    1          69
 Near X =   1.1898769      0.59554146      0.23800512    , d:   0.0000000     -0.30848662      0.74074073
 i,j,k,ie:    5    5    1          69
 Near X =   1.1898769      0.59554146      0.27669227    , d:   0.0000000     -0.30848662      0.74074073
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    6    5    1          69
 Near X =   1.1898769      0.59554146      0.29563535    , d:   0.0000000      -2.5185602      0.74074073
 i,j,k,ie:    1    6    1          69
 Near X =   1.1685631      0.67481338      0.13437970    , d:   0.0000000      -2.0341469      0.74074073
 i,j,k,ie:    2    6    1          69
 Near X =   1.1685631      0.67481338      0.15332278    , d:   0.0000000      -2.0341469      0.74074073
 i,j,k,ie:    3    6    1          69
 Near X =   1.1685631      0.67481338      0.19200993    , d:   0.0000000      -2.0341469      0.74074073
 i,j,k,ie:    4    6    1          69
 Near X =   1.1685631      0.67481338      0.23800512    , d:   0.0000000      -2.0341469      0.74074073
 i,j,k,ie:    5    6    1          69
 Near X =   1.1685631      0.67481338      0.27669227    , d:   0.0000000      -2.0341469      0.74074073
 i,j,k,ie:    6    6    1          69
 Near X =   1.1685631      0.67481338      0.29563535    , d:   0.0000000      -2.5185631      0.74074073
 i,j,k,ie:    1    1    2          69
 Near X =   1.3088847     -0.74046641E-07  0.13437970    , d:   0.0000000     -0.17593540      0.74074073
 i,j,k,ie:    2    1    2          69
 Near X =   1.3088847     -0.74046641E-07  0.15332278    , d:   0.0000000     -0.17593540      0.74074073
 i,j,k,ie:    3    1    2          69
 Near X =   1.3088847     -0.74046641E-07  0.19200993    , d:   0.0000000     -0.17593540      0.74074073
 i,j,k,ie:    4    1    2          69
 Near X =   1.3088847     -0.74046641E-07  0.23800512    , d:   0.0000000     -0.17593540      0.74074073
 i,j,k,ie:    5    1    2          69
 Near X =   1.3088847     -0.74046641E-07  0.27669227    , d:   0.0000000     -0.17593540      0.74074073
 i,j,k,ie:    6    1    2          69
 Near X =   1.3088847     -0.74046641E-07  0.29563535    , d:   0.0000000      -2.4418341      0.74074073
 i,j,k,ie:    6    2    2          69
 Near X =   1.2882200      0.76857551E-01  0.29563535    , d:   0.0000000      -2.4418369      0.74074073
 i,j,k,ie:    6    3    2          69
 Near X =   1.2460168      0.23382267      0.29563535    , d:   0.0000000      -2.4418427      0.74074073
 i,j,k,ie:    6    4    2          69
 Near X =   1.1958414      0.42043866      0.29563535    , d:   0.0000000      -2.4418496      0.74074073
 i,j,k,ie:    6    5    2          69
 Near X =   1.1536383      0.57740378      0.29563535    , d:   0.0000000      -2.4418554      0.74074073
 i,j,k,ie:    1    6    2          69
 Near X =   1.1329736      0.65426140      0.13437970    , d:   0.0000000      -1.9629686      0.74074073
 i,j,k,ie:    2    6    2          69
 Near X =   1.1329736      0.65426140      0.15332278    , d:   0.0000000      -1.9629686      0.74074073
 i,j,k,ie:    3    6    2          69
 Near X =   1.1329736      0.65426140      0.19200993    , d:   0.0000000      -1.9629686      0.74074073
 i,j,k,ie:    4    6    2          69
 Near X =   1.1329736      0.65426140      0.23800512    , d:   0.0000000      -1.9629686      0.74074073
 i,j,k,ie:    5    6    2          69
 Near X =   1.1329736      0.65426140      0.27669227    , d:   0.0000000      -1.9629686      0.74074073
 i,j,k,ie:    6    6    2          69
 Near X =   1.1329736      0.65426140      0.29563535    , d:   0.0000000      -2.4418583      0.74074073
 i,j,k,ie:    1    1    3          69
 Near X =   1.2249155     -0.66466653E-07  0.13437970    , d:   0.0000000     -0.16464857      0.74074073
 i,j,k,ie:    2    1    3          69
 Near X =   1.2249155     -0.66466653E-07  0.15332278    , d:   0.0000000     -0.16464857      0.74074073
 i,j,k,ie:    3    1    3          69
 Near X =   1.2249155     -0.66466653E-07  0.19200993    , d:   0.0000000     -0.16464857      0.74074073
 i,j,k,ie:    4    1    3          69
 Near X =   1.2249155     -0.66466653E-07  0.23800512    , d:   0.0000000     -0.16464857      0.74074073
 i,j,k,ie:    5    1    3          69
 Near X =   1.2249155     -0.66466653E-07  0.27669227    , d:   0.0000000     -0.16464857      0.74074073
 i,j,k,ie:    6    1    3          69
 Near X =   1.2249155     -0.66466653E-07  0.29563535    , d:   0.0000000      -2.2851825      0.74074073
 i,j,k,ie:    6    2    3          69
 Near X =   1.2055765      0.71926894E-01  0.29563535    , d:   0.0000000      -2.2851852      0.74074073
 i,j,k,ie:    6    3    3          69
 Near X =   1.1660808      0.21882219      0.29563535    , d:   0.0000000      -2.2851906      0.74074073
 i,j,k,ie:    6    4    3          69
 Near X =   1.1191244      0.39346617      0.29563535    , d:   0.0000000      -2.2851971      0.74074073
 i,j,k,ie:    6    5    3          69
 Near X =   1.0796287      0.54036147      0.29563535    , d:   0.0000000      -2.2852025      0.74074073
 i,j,k,ie:    1    6    3          69
 Near X =   1.0602897      0.61228843      0.13437970    , d:   0.0000000      -1.8176023      0.74074073
 i,j,k,ie:    2    6    3          69
 Near X =   1.0602897      0.61228843      0.15332278    , d:   0.0000000      -1.8176023      0.74074073
 i,j,k,ie:    3    6    3          69
 Near X =   1.0602897      0.61228843      0.19200993    , d:   0.0000000      -1.8176023      0.74074073
 i,j,k,ie:    4    6    3          69
 Near X =   1.0602897      0.61228843      0.23800512    , d:   0.0000000      -1.8176023      0.74074073
 i,j,k,ie:    5    6    3          69
 Near X =   1.0602897      0.61228843      0.27669227    , d:   0.0000000      -1.8176023      0.74074073
 i,j,k,ie:    6    6    3          69
 Near X =   1.0602897      0.61228843      0.29563535    , d:   0.0000000      -2.2852052      0.74074073
 i,j,k,ie:    1    1    4          69
 Near X =   1.1250845     -0.57454798E-07  0.13437970    , d:   0.0000000     -0.15122966      0.74074073
 i,j,k,ie:    2    1    4          69
 Near X =   1.1250845     -0.57454798E-07  0.15332278    , d:   0.0000000     -0.15122966      0.74074073
 i,j,k,ie:    3    1    4          69
 Near X =   1.1250845     -0.57454798E-07  0.19200993    , d:   0.0000000     -0.15122966      0.74074073
 i,j,k,ie:    4    1    4          69
 Near X =   1.1250845     -0.57454798E-07  0.23800512    , d:   0.0000000     -0.15122966      0.74074073
 i,j,k,ie:    5    1    4          69
 Near X =   1.1250845     -0.57454798E-07  0.27669227    , d:   0.0000000     -0.15122966      0.74074073
 i,j,k,ie:    6    1    4          69
 Near X =   1.1250845     -0.57454798E-07  0.29563535    , d:   0.0000000      -2.0989394      0.74074073
 i,j,k,ie:    6    2    4          69
 Near X =   1.1073216      0.66064831E-01  0.29563535    , d:   0.0000000      -2.0989418      0.74074073
 i,j,k,ie:    6    3    4          69
 Near X =   1.0710449      0.20098811      0.29563535    , d:   0.0000000      -2.0989468      0.74074073
 i,j,k,ie:    6    4    4          69
 Near X =   1.0279153      0.36139854      0.29563535    , d:   0.0000000      -2.0989528      0.74074073
 i,j,k,ie:    6    5    4          69
 Near X =  0.99163856      0.49632182      0.29563535    , d:   0.0000000      -2.0989578      0.74074073
 i,j,k,ie:    1    6    4          69
 Near X =  0.97387571      0.56238671      0.13437970    , d:   0.0000000      -1.6447762      0.74074073
 i,j,k,ie:    2    6    4          69
 Near X =  0.97387571      0.56238671      0.15332278    , d:   0.0000000      -1.6447762      0.74074073
 i,j,k,ie:    3    6    4          69
 Near X =  0.97387571      0.56238671      0.19200993    , d:   0.0000000      -1.6447762      0.74074073
 i,j,k,ie:    4    6    4          69
 Near X =  0.97387571      0.56238671      0.23800512    , d:   0.0000000      -1.6447762      0.74074073
 i,j,k,ie:    5    6    4          69
 Near X =  0.97387571      0.56238671      0.27669227    , d:   0.0000000      -1.6447762      0.74074073
 i,j,k,ie:    6    6    4          69
 Near X =  0.97387571      0.56238671      0.29563535    , d:   0.0000000      -2.0989602      0.74074073
 i,j,k,ie:    1    1    5          69
 Near X =   1.0411153     -0.49874810E-07  0.13437970    , d:   0.0000000     -0.13994284      0.74074073
 i,j,k,ie:    2    1    5          69
 Near X =   1.0411153     -0.49874810E-07  0.15332278    , d:   0.0000000     -0.13994284      0.74074073
 i,j,k,ie:    3    1    5          69
 Near X =   1.0411153     -0.49874810E-07  0.19200993    , d:   0.0000000     -0.13994284      0.74074073
 i,j,k,ie:    4    1    5          69
 Near X =   1.0411153     -0.49874810E-07  0.23800512    , d:   0.0000000     -0.13994284      0.74074073
 i,j,k,ie:    5    1    5          69
 Near X =   1.0411153     -0.49874810E-07  0.27669227    , d:   0.0000000     -0.13994284      0.74074073
 i,j,k,ie:    6    1    5          69
 Near X =   1.0411153     -0.49874810E-07  0.29563535    , d:   0.0000000      -1.9422879      0.74074073
 i,j,k,ie:    6    2    5          69
 Near X =   1.0246782      0.61134175E-01  0.29563535    , d:   0.0000000      -1.9422901      0.74074073
 i,j,k,ie:    6    3    5          69
 Near X =  0.99110887      0.18598764      0.29563535    , d:   0.0000000      -1.9422947      0.74074073
 i,j,k,ie:    6    4    5          69
 Near X =  0.95119827      0.33442605      0.29563535    , d:   0.0000000      -1.9423002      0.74074073
 i,j,k,ie:    6    5    5          69
 Near X =  0.91762895      0.45927951      0.29563535    , d:   0.0000000      -1.9423049      0.74074073
 i,j,k,ie:    1    6    5          69
 Near X =  0.90119180      0.52041374      0.13437970    , d:   0.0000000      -1.4994100      0.74074073
 i,j,k,ie:    2    6    5          69
 Near X =  0.90119180      0.52041374      0.15332278    , d:   0.0000000      -1.4994100      0.74074073
 i,j,k,ie:    3    6    5          69
 Near X =  0.90119180      0.52041374      0.19200993    , d:   0.0000000      -1.4994100      0.74074073
 i,j,k,ie:    4    6    5          69
 Near X =  0.90119180      0.52041374      0.23800512    , d:   0.0000000      -1.4994100      0.74074073
 i,j,k,ie:    5    6    5          69
 Near X =  0.90119180      0.52041374      0.27669227    , d:   0.0000000      -1.4994100      0.74074073
 i,j,k,ie:    6    6    5          69
 Near X =  0.90119180      0.52041374      0.29563535    , d:   0.0000000      -1.9423071      0.74074073
 i,j,k,ie:    1    1    6          69
 Near X =   1.0000000     -0.46163286E-07  0.13437970    , d:  0.35000001     -0.13441627      0.74074073
 i,j,k,ie:    2    1    6          69
 Near X =   1.0000000     -0.46163286E-07  0.15332278    , d:  0.35000001     -0.13441627      0.74074073
 i,j,k,ie:    3    1    6          69
 Near X =   1.0000000     -0.46163286E-07  0.19200993    , d:  0.35000001     -0.13441627      0.74074073
 i,j,k,ie:    4    1    6          69
 Near X =   1.0000000     -0.46163286E-07  0.23800512    , d:  0.35000001     -0.13441627      0.74074073
 i,j,k,ie:    5    1    6          69
 Near X =   1.0000000     -0.46163286E-07  0.27669227    , d:  0.35000001     -0.13441627      0.74074073
 i,j,k,ie:    6    1    6          69
 Near X =   1.0000000     -0.46163286E-07  0.29563535    , d:  0.35000001      -2.1685381      0.74074073
 i,j,k,ie:    1    2    6          69
 Near X =  0.98421199      0.58719889E-01  0.13437970    , d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    2    2    6          69
 Near X =  0.98421199      0.58719889E-01  0.15332278    , d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    3    2    6          69
 Near X =  0.98421199      0.58719889E-01  0.19200993    , d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    4    2    6          69
 Near X =  0.98421199      0.58719889E-01  0.23800512    , d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    5    2    6          69
 Near X =  0.98421199      0.58719889E-01  0.27669227    , d:  0.34447421       0.0000000      0.74074073
 i,j,k,ie:    6    2    6          69
 Near X =  0.98421199      0.58719889E-01  0.29563535    , d:  0.34447421      -2.1740669      0.74074073
 i,j,k,ie:    1    3    6          69
 Near X =  0.95196838      0.17864269      0.13437970    , d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    2    3    6          69
 Near X =  0.95196838      0.17864269      0.15332278    , d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    3    3    6          69
 Near X =  0.95196838      0.17864269      0.19200993    , d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    4    3    6          69
 Near X =  0.95196838      0.17864269      0.23800512    , d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    5    3    6          69
 Near X =  0.95196838      0.17864269      0.27669227    , d:  0.33318894       0.0000000      0.74074073
 i,j,k,ie:    6    3    6          69
 Near X =  0.95196838      0.17864269      0.29563535    , d:  0.33318894      -2.1853581      0.74074073
 i,j,k,ie:    1    4    6          69
 Near X =  0.91363392      0.32121903      0.13437970    , d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    2    4    6          69
 Near X =  0.91363392      0.32121903      0.15332278    , d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    3    4    6          69
 Near X =  0.91363392      0.32121903      0.19200993    , d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    4    4    6          69
 Near X =  0.91363392      0.32121903      0.23800512    , d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    5    4    6          69
 Near X =  0.91363392      0.32121903      0.27669227    , d:  0.31977188       0.0000000      0.74074073
 i,j,k,ie:    6    4    6          69
 Near X =  0.91363392      0.32121903      0.29563535    , d:  0.31977188      -2.1987823      0.74074073
 i,j,k,ie:    1    5    6          69
 Near X =  0.88139030      0.44114183      0.13437970    , d:  0.30848662       0.0000000      0.74074073
 i,j,k,ie:    2    5    6          69
 Near X =  0.88139030      0.44114183      0.15332278    , d:  0.30848662       0.0000000      0.74074073
 i,j,k,ie:    3    5    6          69
 Near X =  0.88139030      0.44114183      0.19200993    , d:  0.30848662       0.0000000      0.74074073
 i,j,k,ie:    4    5    6          69
 Near X =  0.88139030      0.44114183      0.23800512    , d:  0.30848662       0.0000000      0.74074073
 i,j,k,ie:    5    5    6          69
 Near X =  0.88139030      0.44114183      0.27669227    , d:  0.30848662       0.0000000      0.74074073
 i,j,k,ie:    6    5    6          69
 Near X =  0.88139030      0.44114183      0.29563535    , d:  0.30848662      -2.2100736      0.74074073
 i,j,k,ie:    1    6    6          69
 Near X =  0.86560229      0.49986176      0.13437970    , d:  0.30296081      -1.7311861      0.74074073
 i,j,k,ie:    2    6    6          69
 Near X =  0.86560229      0.49986176      0.15332278    , d:  0.30296081      -1.7311861      0.74074073
 i,j,k,ie:    3    6    6          69
 Near X =  0.86560229      0.49986176      0.19200993    , d:  0.30296081      -1.7311861      0.74074073
 i,j,k,ie:    4    6    6          69
 Near X =  0.86560229      0.49986176      0.23800512    , d:  0.30296081      -1.7311861      0.74074073
 i,j,k,ie:    5    6    6          69
 Near X =  0.86560229      0.49986176      0.27669227    , d:  0.30296081      -1.7311861      0.74074073
 i,j,k,ie:    6    6    6          69
 Near X =  0.86560229      0.49986176      0.29563535    , d:  0.30296081      -2.2156023      0.74074073
 i,j,k,ie:    1    1    1          70
 Near X =  -1.1685381      0.67480674      0.13437970    , d:   2.5185381       0.0000000      0.74074073
 i,j,k,ie:    2    1    1          70
 Near X =  -1.1685381      0.67480674      0.15332278    , d:   1.8433514       0.0000000      0.74074073
 i,j,k,ie:    3    1    1          70
 Near X =  -1.1685381      0.67480674      0.19200993    , d:   1.8433514       0.0000000      0.74074073
 i,j,k,ie:    4    1    1          70
 Near X =  -1.1685381      0.67480674      0.23800512    , d:   1.8433514       0.0000000      0.74074073
 i,j,k,ie:    5    1    1          70
 Near X =  -1.1685381      0.67480674      0.27669227    , d:   1.8433514       0.0000000      0.74074073
 i,j,k,ie:    6    1    1          70
 Near X =  -1.1685381      0.67480674      0.29563535    , d:   1.8433514       0.0000000      0.74074073
 i,j,k,ie:    1    2    1          70
 Near X =  -1.1898549      0.59553562      0.13437970    , d:   2.5185411       0.0000000      0.74074073
 i,j,k,ie:    2    2    1          70
 Near X =  -1.1898549      0.59553562      0.15332278    , d:  0.30848090       0.0000000      0.74074073
 i,j,k,ie:    3    2    1          70
 Near X =  -1.1898549      0.59553562      0.19200993    , d:  0.30848090       0.0000000      0.74074073
 i,j,k,ie:    4    2    1          70
 Near X =  -1.1898549      0.59553562      0.23800512    , d:  0.30848090       0.0000000      0.74074073
 i,j,k,ie:    5    2    1          70
 Near X =  -1.1898549      0.59553562      0.27669227    , d:  0.30848090       0.0000000      0.74074073
 i,j,k,ie:    6    2    1          70
 Near X =  -1.1898549      0.59553562      0.29563535    , d:  0.64703087       0.0000000      0.74074073
 i,j,k,ie:    1    3    1          70
 Near X =  -1.2333897      0.43364145      0.13437970    , d:   2.5185471       0.0000000      0.74074073
 i,j,k,ie:    2    3    1          70
 Near X =  -1.2333897      0.43364145      0.15332278    , d:  0.31976772       0.0000000      0.74074073
 i,j,k,ie:    3    3    1          70
 Near X =  -1.2333897      0.43364145      0.19200993    , d:  0.31976772       0.0000000      0.74074073
 i,j,k,ie:    4    3    1          70
 Near X =  -1.2333897      0.43364145      0.23800512    , d:  0.31976772       0.0000000      0.74074073
 i,j,k,ie:    5    3    1          70
 Near X =  -1.2333897      0.43364145      0.27669227    , d:  0.31976772       0.0000000      0.74074073
 i,j,k,ie:    6    3    1          70
 Near X =  -1.2333897      0.43364145      0.29563535    , d:  0.60282468       0.0000000      0.74074073
 i,j,k,ie:    1    4    1          70
 Near X =  -1.2851484      0.24116530      0.13437970    , d:   2.5185542       0.0000000      0.74074073
 i,j,k,ie:    2    4    1          70
 Near X =  -1.2851484      0.24116530      0.15332278    , d:  0.33318663       0.0000000      0.74074073
 i,j,k,ie:    3    4    1          70
 Near X =  -1.2851484      0.24116530      0.19200993    , d:  0.33318663       0.0000000      0.74074073
 i,j,k,ie:    4    4    1          70
 Near X =  -1.2851484      0.24116530      0.23800512    , d:  0.33318663       0.0000000      0.74074073
 i,j,k,ie:    5    4    1          70
 Near X =  -1.2851484      0.24116530      0.27669227    , d:  0.33318663       0.0000000      0.74074073
 i,j,k,ie:    6    4    1          70
 Near X =  -1.2851484      0.24116530      0.29563535    , d:  0.55026790       0.0000000      0.74074073
 i,j,k,ie:    1    5    1          70
 Near X =  -1.3286833      0.79271126E-01  0.13437970    , d:   2.5185602       0.0000000      0.74074073
 i,j,k,ie:    2    5    1          70
 Near X =  -1.3286833      0.79271126E-01  0.15332278    , d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    3    5    1          70
 Near X =  -1.3286833      0.79271126E-01  0.19200993    , d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    4    5    1          70
 Near X =  -1.3286833      0.79271126E-01  0.23800512    , d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    5    5    1          70
 Near X =  -1.3286833      0.79271126E-01  0.27669227    , d:  0.34447345       0.0000000      0.74074073
 i,j,k,ie:    6    5    1          70
 Near X =  -1.3286833      0.79271126E-01  0.29563535    , d:  0.50606171       0.0000000      0.74074073
 i,j,k,ie:    1    6    1          70
 Near X =  -1.3500000     -0.33065464E-15  0.13437970    , d:   2.5185631       0.0000000      0.74074073
 i,j,k,ie:    2    6    1          70
 Near X =  -1.3500000     -0.33065464E-15  0.15332278    , d:   1.0250899       0.0000000      0.74074073
 i,j,k,ie:    3    6    1          70
 Near X =  -1.3500000     -0.33065464E-15  0.19200993    , d:   1.0250899       0.0000000      0.74074073
 i,j,k,ie:    4    6    1          70
 Near X =  -1.3500000     -0.33065464E-15  0.23800512    , d:   1.0250899       0.0000000      0.74074073
 i,j,k,ie:    5    6    1          70
 Near X =  -1.3500000     -0.33065464E-15  0.27669227    , d:   1.0250899       0.0000000      0.74074073
 i,j,k,ie:    6    6    1          70
 Near X =  -1.3500000     -0.33065464E-15  0.29563535    , d:   1.3500001       0.0000000      0.74074073
 i,j,k,ie:    1    1    2          70
 Near X =  -1.1329494      0.65425497      0.13437970    , d:   2.4418341       0.0000000      0.74074073
 i,j,k,ie:    2    1    2          70
 Near X =  -1.1329494      0.65425497      0.15332278    , d:   1.7872107       0.0000000      0.74074073
 i,j,k,ie:    3    1    2          70
 Near X =  -1.1329494      0.65425497      0.19200993    , d:   1.7872107       0.0000000      0.74074073
 i,j,k,ie:    4    1    2          70
 Near X =  -1.1329494      0.65425497      0.23800512    , d:   1.7872107       0.0000000      0.74074073
 i,j,k,ie:    5    1    2          70
 Near X =  -1.1329494      0.65425497      0.27669227    , d:   1.7872107       0.0000000      0.74074073
 i,j,k,ie:    6    1    2          70
 Near X =  -1.1329494      0.65425497      0.29563535    , d:   1.7872107       0.0000000      0.74074073
 i,j,k,ie:    1    2    2          70
 Near X =  -1.1536169      0.57739811      0.13437970    , d:   2.4418369       0.0000000      0.74074073
 i,j,k,ie:    6    2    2          70
 Near X =  -1.1536169      0.57739811      0.29563535    , d:  0.44312288       0.0000000      0.74074073
 i,j,k,ie:    1    3    2          70
 Near X =  -1.1958259      0.42043455      0.13437970    , d:   2.4418427       0.0000000      0.74074073
 i,j,k,ie:    6    3    2          70
 Near X =  -1.1958259      0.42043455      0.29563535    , d:  0.37048893       0.0000000      0.74074073
 i,j,k,ie:    1    4    2          70
 Near X =  -1.2460082      0.23382042      0.13437970    , d:   2.4418496       0.0000000      0.74074073
 i,j,k,ie:    6    4    2          70
 Near X =  -1.2460082      0.23382042      0.29563535    , d:  0.28413435       0.0000000      0.74074073
 i,j,k,ie:    1    5    2          70
 Near X =  -1.2882172      0.76856861E-01  0.13437970    , d:   2.4418554       0.0000000      0.74074073
 i,j,k,ie:    6    5    2          70
 Near X =  -1.2882172      0.76856861E-01  0.29563535    , d:  0.21150040       0.0000000      0.74074073
 i,j,k,ie:    1    6    2          70
 Near X =  -1.3088847     -0.32058429E-15  0.13437970    , d:   2.4418583       0.0000000      0.74074073
 i,j,k,ie:    2    6    2          70
 Near X =  -1.3088847     -0.32058429E-15  0.15332278    , d:  0.82957491       0.0000000      0.74074073
 i,j,k,ie:    3    6    2          70
 Near X =  -1.3088847     -0.32058429E-15  0.19200993    , d:  0.82957491       0.0000000      0.74074073
 i,j,k,ie:    4    6    2          70
 Near X =  -1.3088847     -0.32058429E-15  0.23800512    , d:  0.82957491       0.0000000      0.74074073
 i,j,k,ie:    5    6    2          70
 Near X =  -1.3088847     -0.32058429E-15  0.27669227    , d:  0.82957491       0.0000000      0.74074073
 i,j,k,ie:    6    6    2          70
 Near X =  -1.3088847     -0.32058429E-15  0.29563535    , d:   1.3088847       0.0000000      0.74074073
 i,j,k,ie:    1    1    3          70
 Near X =  -1.0602670      0.61228241      0.13437970    , d:   2.2851825       0.0000000      0.74074073
 i,j,k,ie:    2    1    3          70
 Near X =  -1.0602670      0.61228241      0.15332278    , d:   1.6725554       0.0000000      0.74074073
 i,j,k,ie:    3    1    3          70
 Near X =  -1.0602670      0.61228241      0.19200993    , d:   1.6725554       0.0000000      0.74074073
 i,j,k,ie:    4    1    3          70
 Near X =  -1.0602670      0.61228241      0.23800512    , d:   1.6725554       0.0000000      0.74074073
 i,j,k,ie:    5    1    3          70
 Near X =  -1.0602670      0.61228241      0.27669227    , d:   1.6725554       0.0000000      0.74074073
 i,j,k,ie:    6    1    3          70
 Near X =  -1.0602670      0.61228241      0.29563535    , d:   1.6725554       0.0000000      0.74074073
 i,j,k,ie:    1    2    3          70
 Near X =  -1.0796087      0.54035616      0.13437970    , d:   2.2851852       0.0000000      0.74074073
 i,j,k,ie:    6    2    3          70
 Near X =  -1.0796087      0.54035616      0.29563535    , d:  0.41469512       0.0000000      0.74074073
 i,j,k,ie:    1    3    3          70
 Near X =  -1.1191098      0.39346232      0.13437970    , d:   2.2851906       0.0000000      0.74074073
 i,j,k,ie:    6    3    3          70
 Near X =  -1.1191098      0.39346232      0.29563535    , d:  0.34672087       0.0000000      0.74074073
 i,j,k,ie:    1    4    3          70
 Near X =  -1.1660727      0.21882008      0.13437970    , d:   2.2851971       0.0000000      0.74074073
 i,j,k,ie:    6    4    3          70
 Near X =  -1.1660727      0.21882008      0.29563535    , d:  0.26590622       0.0000000      0.74074073
 i,j,k,ie:    1    5    3          70
 Near X =  -1.2055739      0.71926246E-01  0.13437970    , d:   2.2852025       0.0000000      0.74074073
 i,j,k,ie:    6    5    3          70
 Near X =  -1.2055739      0.71926246E-01  0.29563535    , d:  0.19793197       0.0000000      0.74074073
 i,j,k,ie:    1    6    3          70
 Near X =  -1.2249155     -0.30001778E-15  0.13437970    , d:   2.2852052       0.0000000      0.74074073
 i,j,k,ie:    2    6    3          70
 Near X =  -1.2249155     -0.30001778E-15  0.15332278    , d:  0.78757872       0.0000000      0.74074073
 i,j,k,ie:    3    6    3          70
 Near X =  -1.2249155     -0.30001778E-15  0.19200993    , d:  0.78757872       0.0000000      0.74074073
 i,j,k,ie:    4    6    3          70
 Near X =  -1.2249155     -0.30001778E-15  0.23800512    , d:  0.78757872       0.0000000      0.74074073
 i,j,k,ie:    5    6    3          70
 Near X =  -1.2249155     -0.30001778E-15  0.27669227    , d:  0.78757872       0.0000000      0.74074073
 i,j,k,ie:    6    6    3          70
 Near X =  -1.2249155     -0.30001778E-15  0.29563535    , d:   1.2249156       0.0000000      0.74074073
 i,j,k,ie:    1    1    4          70
 Near X = -0.97385488      0.56238118      0.13437970    , d:   2.0989394       0.0000000      0.74074073
 i,j,k,ie:    2    1    4          70
 Near X = -0.97385488      0.56238118      0.15332278    , d:   1.5362415       0.0000000      0.74074073
 i,j,k,ie:    3    1    4          70
 Near X = -0.97385488      0.56238118      0.19200993    , d:   1.5362415       0.0000000      0.74074073
 i,j,k,ie:    4    1    4          70
 Near X = -0.97385488      0.56238118      0.23800512    , d:   1.5362415       0.0000000      0.74074073
 i,j,k,ie:    5    1    4          70
 Near X = -0.97385488      0.56238118      0.27669227    , d:   1.5362415       0.0000000      0.74074073
 i,j,k,ie:    6    1    4          70
 Near X = -0.97385488      0.56238118      0.29563535    , d:   1.5362415       0.0000000      0.74074073
 i,j,k,ie:    1    2    4          70
 Near X = -0.99162018      0.49631695      0.13437970    , d:   2.0989418       0.0000000      0.74074073
 i,j,k,ie:    6    2    4          70
 Near X = -0.99162018      0.49631695      0.29563535    , d:  0.38089732       0.0000000      0.74074073
 i,j,k,ie:    1    3    4          70
 Near X =  -1.0279020      0.36139501      0.13437970    , d:   2.0989468       0.0000000      0.74074073
 i,j,k,ie:    6    3    4          70
 Near X =  -1.0279020      0.36139501      0.29563535    , d:  0.31846300       0.0000000      0.74074073
 i,j,k,ie:    1    4    4          70
 Near X =  -1.0710374      0.20098617      0.13437970    , d:   2.0989528       0.0000000      0.74074073
 i,j,k,ie:    6    4    4          70
 Near X =  -1.0710374      0.20098617      0.29563535    , d:  0.24423477       0.0000000      0.74074073
 i,j,k,ie:    1    5    4          70
 Near X =  -1.1073192      0.66064232E-01  0.13437970    , d:   2.0989578       0.0000000      0.74074073
 i,j,k,ie:    6    5    4          70
 Near X =  -1.1073192      0.66064232E-01  0.29563535    , d:  0.18180045       0.0000000      0.74074073
 i,j,k,ie:    1    6    4          70
 Near X =  -1.1250845     -0.27556623E-15  0.13437970    , d:   2.0989602       0.0000000      0.74074073
 i,j,k,ie:    2    6    4          70
 Near X =  -1.1250845     -0.27556623E-15  0.15332278    , d:  0.73764940       0.0000000      0.74074073
 i,j,k,ie:    3    6    4          70
 Near X =  -1.1250845     -0.27556623E-15  0.19200993    , d:  0.73764940       0.0000000      0.74074073
 i,j,k,ie:    4    6    4          70
 Near X =  -1.1250845     -0.27556623E-15  0.23800512    , d:  0.73764940       0.0000000      0.74074073
 i,j,k,ie:    5    6    4          70
 Near X =  -1.1250845     -0.27556623E-15  0.27669227    , d:  0.73764940       0.0000000      0.74074073
 i,j,k,ie:    6    6    4          70
 Near X =  -1.1250845     -0.27556623E-15  0.29563535    , d:   1.1250845       0.0000000      0.74074073
 i,j,k,ie:    1    1    5          70
 Near X = -0.90117253      0.52040862      0.13437970    , d:   1.9422879       0.0000000      0.74074073
 i,j,k,ie:    2    1    5          70
 Near X = -0.90117253      0.52040862      0.15332278    , d:   1.4215862       0.0000000      0.74074073
 i,j,k,ie:    3    1    5          70
 Near X = -0.90117253      0.52040862      0.19200993    , d:   1.4215862       0.0000000      0.74074073
 i,j,k,ie:    4    1    5          70
 Near X = -0.90117253      0.52040862      0.23800512    , d:   1.4215862       0.0000000      0.74074073
 i,j,k,ie:    5    1    5          70
 Near X = -0.90117253      0.52040862      0.27669227    , d:   1.4215862       0.0000000      0.74074073
 i,j,k,ie:    6    1    5          70
 Near X = -0.90117253      0.52040862      0.29563535    , d:   1.4215862       0.0000000      0.74074073
 i,j,k,ie:    1    2    5          70
 Near X = -0.91761194      0.45927500      0.13437970    , d:   1.9422901       0.0000000      0.74074073
 i,j,k,ie:    6    2    5          70
 Near X = -0.91761194      0.45927500      0.29563535    , d:  0.35246956       0.0000000      0.74074073
 i,j,k,ie:    1    3    5          70
 Near X = -0.95118588      0.33442278      0.13437970    , d:   1.9422947       0.0000000      0.74074073
 i,j,k,ie:    6    3    5          70
 Near X = -0.95118588      0.33442278      0.29563535    , d:  0.29469494       0.0000000      0.74074073
 i,j,k,ie:    1    4    5          70
 Near X = -0.99110198      0.18598584      0.13437970    , d:   1.9423002       0.0000000      0.74074073
 i,j,k,ie:    6    4    5          70
 Near X = -0.99110198      0.18598584      0.29563535    , d:  0.22600664       0.0000000      0.74074073
 i,j,k,ie:    1    5    5          70
 Near X =  -1.0246759      0.61133617E-01  0.13437970    , d:   1.9423049       0.0000000      0.74074073
 i,j,k,ie:    6    5    5          70
 Near X =  -1.0246759      0.61133617E-01  0.29563535    , d:  0.16823202       0.0000000      0.74074073
 i,j,k,ie:    1    6    5          70
 Near X =  -1.0411153     -0.25499971E-15  0.13437970    , d:   1.9423071       0.0000000      0.74074073
 i,j,k,ie:    2    6    5          70
 Near X =  -1.0411153     -0.25499971E-15  0.15332278    , d:  0.69565321       0.0000000      0.74074073
 i,j,k,ie:    3    6    5          70
 Near X =  -1.0411153     -0.25499971E-15  0.19200993    , d:  0.69565321       0.0000000      0.74074073
 i,j,k,ie:    4    6    5          70
 Near X =  -1.0411153     -0.25499971E-15  0.23800512    , d:  0.69565321       0.0000000      0.74074073
 i,j,k,ie:    5    6    5          70
 Near X =  -1.0411153     -0.25499971E-15  0.27669227    , d:  0.69565321       0.0000000      0.74074073
 i,j,k,ie:    6    6    5          70
 Near X =  -1.0411153     -0.25499971E-15  0.29563535    , d:   1.0411154       0.0000000      0.74074073
 i,j,k,ie:    1    1    6          70
 Near X = -0.86558378      0.49985684      0.13437970    , d:   2.2155838     -0.30295433      0.74074073
 i,j,k,ie:    2    1    6          70
 Near X = -0.86558378      0.49985684      0.15332278    , d:   1.5403971     -0.30295433      0.74074073
 i,j,k,ie:    3    1    6          70
 Near X = -0.86558378      0.49985684      0.19200993    , d:   1.5403971     -0.30295433      0.74074073
 i,j,k,ie:    4    1    6          70
 Near X = -0.86558378      0.49985684      0.23800512    , d:   1.5403971     -0.30295433      0.74074073
 i,j,k,ie:    5    1    6          70
 Near X = -0.86558378      0.49985684      0.27669227    , d:   1.5403971     -0.30295433      0.74074073
 i,j,k,ie:    6    1    6          70
 Near X = -0.86558378      0.49985684      0.29563535    , d:   1.5403971     -0.30295433      0.74074073
 i,j,k,ie:    1    2    6          70
 Near X = -0.88137396      0.44113749      0.13437970    , d:   2.2100602     -0.30848090      0.74074073
 i,j,k,ie:    2    2    6          70
 Near X = -0.88137396      0.44113749      0.15332278    , d:   0.0000000     -0.30848090      0.74074073
 i,j,k,ie:    3    2    6          70
 Near X = -0.88137396      0.44113749      0.19200993    , d:   0.0000000     -0.30848090      0.74074073
 i,j,k,ie:    4    2    6          70
 Near X = -0.88137396      0.44113749      0.23800512    , d:   0.0000000     -0.30848090      0.74074073
 i,j,k,ie:    5    2    6          70
 Near X = -0.88137396      0.44113749      0.27669227    , d:   0.0000000     -0.30848090      0.74074073
 i,j,k,ie:    6    2    6          70
 Near X = -0.88137396      0.44113749      0.29563535    , d:  0.33854997     -0.30848090      0.74074073
 i,j,k,ie:    1    3    6          70
 Near X = -0.91362202      0.32121588      0.13437970    , d:   2.1987793     -0.31976772      0.74074073
 i,j,k,ie:    2    3    6          70
 Near X = -0.91362202      0.32121588      0.15332278    , d:   0.0000000     -0.31976772      0.74074073
 i,j,k,ie:    3    3    6          70
 Near X = -0.91362202      0.32121588      0.19200993    , d:   0.0000000     -0.31976772      0.74074073
 i,j,k,ie:    4    3    6          70
 Near X = -0.91362202      0.32121588      0.23800512    , d:   0.0000000     -0.31976772      0.74074073
 i,j,k,ie:    5    3    6          70
 Near X = -0.91362202      0.32121588      0.27669227    , d:   0.0000000     -0.31976772      0.74074073
 i,j,k,ie:    6    3    6          70
 Near X = -0.91362202      0.32121588      0.29563535    , d:  0.28305696     -0.31976772      0.74074073
 i,j,k,ie:    1    4    6          70
 Near X = -0.95196177      0.17864096      0.13437970    , d:   2.1853676     -0.33318663      0.74074073
 i,j,k,ie:    2    4    6          70
 Near X = -0.95196177      0.17864096      0.15332278    , d:   0.0000000     -0.33318663      0.74074073
 i,j,k,ie:    3    4    6          70
 Near X = -0.95196177      0.17864096      0.19200993    , d:   0.0000000     -0.33318663      0.74074073
 i,j,k,ie:    4    4    6          70
 Near X = -0.95196177      0.17864096      0.23800512    , d:   0.0000000     -0.33318663      0.74074073
 i,j,k,ie:    5    4    6          70
 Near X = -0.95196177      0.17864096      0.27669227    , d:   0.0000000     -0.33318663      0.74074073
 i,j,k,ie:    6    4    6          70
 Near X = -0.95196177      0.17864096      0.29563535    , d:  0.21708127     -0.33318663      0.74074073
 i,j,k,ie:    1    5    6          70
 Near X = -0.98420982      0.58719352E-01  0.13437970    , d:   2.1740867     -0.34447345      0.74074073
 i,j,k,ie:    2    5    6          70
 Near X = -0.98420982      0.58719352E-01  0.15332278    , d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    3    5    6          70
 Near X = -0.98420982      0.58719352E-01  0.19200993    , d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    4    5    6          70
 Near X = -0.98420982      0.58719352E-01  0.23800512    , d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    5    5    6          70
 Near X = -0.98420982      0.58719352E-01  0.27669227    , d:   0.0000000     -0.34447345      0.74074073
 i,j,k,ie:    6    5    6          70
 Near X = -0.98420982      0.58719352E-01  0.29563535    , d:  0.16158826     -0.34447345      0.74074073
 i,j,k,ie:    1    6    6          70
 Near X =  -1.0000000     -0.24492936E-15  0.13437970    , d:   2.1685631     -0.35000001      0.74074073
 i,j,k,ie:    2    6    6          70
 Near X =  -1.0000000     -0.24492936E-15  0.15332278    , d:  0.67508987     -0.35000001      0.74074073
 i,j,k,ie:    3    6    6          70
 Near X =  -1.0000000     -0.24492936E-15  0.19200993    , d:  0.67508987     -0.35000001      0.74074073
 i,j,k,ie:    4    6    6          70
 Near X =  -1.0000000     -0.24492936E-15  0.23800512    , d:  0.67508987     -0.35000001      0.74074073
 i,j,k,ie:    5    6    6          70
 Near X =  -1.0000000     -0.24492936E-15  0.27669227    , d:  0.67508987     -0.35000001      0.74074073
 i,j,k,ie:    6    6    6          70
 Near X =  -1.0000000     -0.24492936E-15  0.29563535    , d:   1.0000000     -0.35000001      0.74074073
 i,j,k,ie:    1    1    1          71
 Near X = -0.67481340       1.1685631      0.13437970    , d:   1.3496267     -0.49372471      0.85577012
 i,j,k,ie:    2    1    1          71
 Near X = -0.67481340       1.1685631      0.15332278    , d:  0.67481345       0.0000000      0.85577012
 i,j,k,ie:    3    1    1          71
 Near X = -0.67481340       1.1685631      0.19200993    , d:  0.67481345       0.0000000      0.85577012
 i,j,k,ie:    4    1    1          71
 Near X = -0.67481340       1.1685631      0.23800512    , d:  0.67481345       0.0000000      0.85577012
 i,j,k,ie:    5    1    1          71
 Near X = -0.67481340       1.1685631      0.27669227    , d:  0.67481345       0.0000000      0.85577012
 i,j,k,ie:    6    1    1          71
 Near X = -0.67481340       1.1685631      0.29563535    , d:   1.3496202       0.0000000      0.85577012
 i,j,k,ie:    1    2    1          71
 Near X = -0.73281240       1.1105604      0.13437970    , d:  0.18998840     -0.45704247      0.85577012
 i,j,k,ie:    2    2    1          71
 Near X = -0.73281240       1.1105604      0.15332278    , d:  0.18998840       0.0000000      0.85577012
 i,j,k,ie:    3    2    1          71
 Near X = -0.73281240       1.1105604      0.19200993    , d:  0.18998840       0.0000000      0.85577012
 i,j,k,ie:    4    2    1          71
 Near X = -0.73281240       1.1105604      0.23800512    , d:  0.18998840       0.0000000      0.85577012
 i,j,k,ie:    5    2    1          71
 Near X = -0.73281240       1.1105604      0.27669227    , d:  0.18998840       0.0000000      0.85577012
 i,j,k,ie:    6    2    1          71
 Near X = -0.73281240       1.1105604      0.29563535    , d:  0.67409250       0.0000000      0.85577012
 i,j,k,ie:    1    3    1          71
 Near X = -0.85126283      0.99210234      0.13437970    , d:  0.22069778     -0.38212691      0.85577012
 i,j,k,ie:    2    3    1          71
 Near X = -0.85126283      0.99210234      0.15332278    , d:  0.22069778       0.0000000      0.85577012
 i,j,k,ie:    3    3    1          71
 Near X = -0.85126283      0.99210234      0.19200993    , d:  0.22069778       0.0000000      0.85577012
 i,j,k,ie:    4    3    1          71
 Near X = -0.85126283      0.99210234      0.23800512    , d:  0.22069778       0.0000000      0.85577012
 i,j,k,ie:    5    3    1          71
 Near X = -0.85126283      0.99210234      0.27669227    , d:  0.22069778       0.0000000      0.85577012
 i,j,k,ie:    6    3    1          71
 Near X = -0.85126283      0.99210234      0.29563535    , d:  0.67262013       0.0000000      0.85577012
 i,j,k,ie:    1    4    1          71
 Near X = -0.99208868      0.85126747      0.13437970    , d:  0.25720818     -0.29305972      0.85577012
 i,j,k,ie:    2    4    1          71
 Near X = -0.99208868      0.85126747      0.15332278    , d:  0.25720818       0.0000000      0.85577012
 i,j,k,ie:    3    4    1          71
 Near X = -0.99208868      0.85126747      0.19200993    , d:  0.25720818       0.0000000      0.85577012
 i,j,k,ie:    4    4    1          71
 Near X = -0.99208868      0.85126747      0.23800512    , d:  0.25720818       0.0000000      0.85577012
 i,j,k,ie:    5    4    1          71
 Near X = -0.99208868      0.85126747      0.27669227    , d:  0.25720818       0.0000000      0.85577012
 i,j,k,ie:    6    4    1          71
 Near X = -0.99208868      0.85126747      0.29563535    , d:  0.67086964       0.0000000      0.85577012
 i,j,k,ie:    1    5    1          71
 Near X =  -1.1105391      0.73280945      0.13437970    , d:  0.28791755     -0.21814416      0.85577012
 i,j,k,ie:    2    5    1          71
 Near X =  -1.1105391      0.73280945      0.15332278    , d:  0.28791755       0.0000000      0.85577012
 i,j,k,ie:    3    5    1          71
 Near X =  -1.1105391      0.73280945      0.19200993    , d:  0.28791755       0.0000000      0.85577012
 i,j,k,ie:    4    5    1          71
 Near X =  -1.1105391      0.73280945      0.23800512    , d:  0.28791755       0.0000000      0.85577012
 i,j,k,ie:    5    5    1          71
 Near X =  -1.1105391      0.73280945      0.27669227    , d:  0.28791755       0.0000000      0.85577012
 i,j,k,ie:    6    5    1          71
 Near X =  -1.1105391      0.73280945      0.29563535    , d:  0.66939727       0.0000000      0.85577012
 i,j,k,ie:    1    6    1          71
 Near X =  -1.1685381      0.67480674      0.13437970    , d:   1.1685381     -0.18146192      0.85577012
 i,j,k,ie:    2    6    1          71
 Near X =  -1.1685381      0.67480674      0.15332278    , d:   1.1685381       0.0000000      0.85577012
 i,j,k,ie:    3    6    1          71
 Near X =  -1.1685381      0.67480674      0.19200993    , d:   1.1685381       0.0000000      0.85577012
 i,j,k,ie:    4    6    1          71
 Near X =  -1.1685381      0.67480674      0.23800512    , d:   1.1685381       0.0000000      0.85577012
 i,j,k,ie:    5    6    1          71
 Near X =  -1.1685381      0.67480674      0.27669227    , d:   1.1685381       0.0000000      0.85577012
 i,j,k,ie:    6    6    1          71
 Near X =  -1.1685381      0.67480674      0.29563535    , d:   1.6683950       0.0000000      0.85577012
 i,j,k,ie:    1    1    2          71
 Near X = -0.65426142       1.1329736      0.13437970    , d:   1.3085228     -0.47868793      0.85577012
 i,j,k,ie:    2    1    2          71
 Near X = -0.65426142       1.1329736      0.15332278    , d:  0.65426148       0.0000000      0.85577012
 i,j,k,ie:    3    1    2          71
 Near X = -0.65426142       1.1329736      0.19200993    , d:  0.65426148       0.0000000      0.85577012
 i,j,k,ie:    4    1    2          71
 Near X = -0.65426142       1.1329736      0.23800512    , d:  0.65426148       0.0000000      0.85577012
 i,j,k,ie:    5    1    2          71
 Near X = -0.65426142       1.1329736      0.27669227    , d:  0.65426148       0.0000000      0.85577012
 i,j,k,ie:    6    1    2          71
 Near X = -0.65426142       1.1329736      0.29563535    , d:   1.3085164       0.0000000      0.85577012
 i,j,k,ie:    1    2    2          71
 Near X = -0.71049401       1.0767374      0.13437970    , d:   0.0000000     -0.44312288      0.85577012
 i,j,k,ie:    6    2    2          71
 Near X = -0.71049401       1.0767374      0.29563535    , d:  0.63363644       0.0000000      0.85577012
 i,j,k,ie:    1    3    2          71
 Near X = -0.82533695      0.96188708      0.13437970    , d:   0.0000000     -0.37048893      0.85577012
 i,j,k,ie:    6    3    2          71
 Near X = -0.82533695      0.96188708      0.29563535    , d:  0.59151426       0.0000000      0.85577012
 i,j,k,ie:    1    4    2          71
 Near X = -0.96187383      0.82534145      0.13437970    , d:   0.0000000     -0.28413435      0.85577012
 i,j,k,ie:    6    4    2          71
 Near X = -0.96187383      0.82534145      0.29563535    , d:  0.54143515       0.0000000      0.85577012
 i,j,k,ie:    1    5    2          71
 Near X =  -1.0767168      0.71049116      0.13437970    , d:   0.0000000     -0.21150040      0.85577012
 i,j,k,ie:    6    5    2          71
 Near X =  -1.0767168      0.71049116      0.29563535    , d:  0.49931296       0.0000000      0.85577012
 i,j,k,ie:    1    6    2          71
 Near X =  -1.1329494      0.65425497      0.13437970    , d:   1.1329494     -0.17593535      0.85577012
 i,j,k,ie:    2    6    2          71
 Near X =  -1.1329494      0.65425497      0.15332278    , d:   1.1329494       0.0000000      0.85577012
 i,j,k,ie:    3    6    2          71
 Near X =  -1.1329494      0.65425497      0.19200993    , d:   1.1329494       0.0000000      0.85577012
 i,j,k,ie:    4    6    2          71
 Near X =  -1.1329494      0.65425497      0.23800512    , d:   1.1329494       0.0000000      0.85577012
 i,j,k,ie:    5    6    2          71
 Near X =  -1.1329494      0.65425497      0.27669227    , d:   1.1329494       0.0000000      0.85577012
 i,j,k,ie:    6    6    2          71
 Near X =  -1.1329494      0.65425497      0.29563535    , d:   1.6122545       0.0000000      0.85577012
 i,j,k,ie:    1    1    3          71
 Near X = -0.61228845       1.0602897      0.13437970    , d:   1.2245768     -0.44797856      0.85577012
 i,j,k,ie:    2    1    3          71
 Near X = -0.61228845       1.0602897      0.15332278    , d:  0.61228850       0.0000000      0.85577012
 i,j,k,ie:    3    1    3          71
 Near X = -0.61228845       1.0602897      0.19200993    , d:  0.61228850       0.0000000      0.85577012
 i,j,k,ie:    4    1    3          71
 Near X = -0.61228845       1.0602897      0.23800512    , d:  0.61228850       0.0000000      0.85577012
 i,j,k,ie:    5    1    3          71
 Near X = -0.61228845       1.0602897      0.27669227    , d:  0.61228850       0.0000000      0.85577012
 i,j,k,ie:    6    1    3          71
 Near X = -0.61228845       1.0602897      0.29563535    , d:   1.2245709       0.0000000      0.85577012
 i,j,k,ie:    1    2    3          71
 Near X = -0.66491354       1.0076612      0.13437970    , d:   0.0000000     -0.41469512      0.85577012
 i,j,k,ie:    6    2    3          71
 Near X = -0.66491354       1.0076612      0.29563535    , d:  0.59298662       0.0000000      0.85577012
 i,j,k,ie:    1    3    3          71
 Near X = -0.77238892      0.90017892      0.13437970    , d:   0.0000000     -0.34672087      0.85577012
 i,j,k,ie:    6    3    3          71
 Near X = -0.77238892      0.90017892      0.29563535    , d:  0.55356671       0.0000000      0.85577012
 i,j,k,ie:    1    4    3          71
 Near X = -0.90016653      0.77239314      0.13437970    , d:   0.0000000     -0.26590622      0.85577012
 i,j,k,ie:    6    4    3          71
 Near X = -0.90016653      0.77239314      0.29563535    , d:  0.50670034       0.0000000      0.85577012
 i,j,k,ie:    1    5    3          71
 Near X =  -1.0076419      0.66491086      0.13437970    , d:   0.0000000     -0.19793197      0.85577012
 i,j,k,ie:    6    5    3          71
 Near X =  -1.0076419      0.66491086      0.29563535    , d:  0.46728043       0.0000000      0.85577012
 i,j,k,ie:    1    6    3          71
 Near X =  -1.0602670      0.61228241      0.13437970    , d:   1.0602670     -0.16464853      0.85577012
 i,j,k,ie:    2    6    3          71
 Near X =  -1.0602670      0.61228241      0.15332278    , d:   1.0602670       0.0000000      0.85577012
 i,j,k,ie:    3    6    3          71
 Near X =  -1.0602670      0.61228241      0.19200993    , d:   1.0602670       0.0000000      0.85577012
 i,j,k,ie:    4    6    3          71
 Near X =  -1.0602670      0.61228241      0.23800512    , d:   1.0602670       0.0000000      0.85577012
 i,j,k,ie:    5    6    3          71
 Near X =  -1.0602670      0.61228241      0.27669227    , d:   1.0602670       0.0000000      0.85577012
 i,j,k,ie:    6    6    3          71
 Near X =  -1.0602670      0.61228241      0.29563535    , d:   1.4975995       0.0000000      0.85577012
 i,j,k,ie:    1    1    4          71
 Near X = -0.56238673      0.97387568      0.13437970    , d:   1.1247734     -0.41146815      0.85577012
 i,j,k,ie:    2    1    4          71
 Near X = -0.56238673      0.97387568      0.15332278    , d:  0.56238677       0.0000000      0.85577012
 i,j,k,ie:    3    1    4          71
 Near X = -0.56238673      0.97387568      0.19200993    , d:  0.56238677       0.0000000      0.85577012
 i,j,k,ie:    4    1    4          71
 Near X = -0.56238673      0.97387568      0.23800512    , d:  0.56238677       0.0000000      0.85577012
 i,j,k,ie:    5    1    4          71
 Near X = -0.56238673      0.97387568      0.27669227    , d:  0.56238677       0.0000000      0.85577012
 i,j,k,ie:    6    1    4          71
 Near X = -0.56238673      0.97387568      0.29563535    , d:   1.1247679       0.0000000      0.85577012
 i,j,k,ie:    1    2    4          71
 Near X = -0.61072285      0.92553646      0.13437970    , d:   0.0000000     -0.38089732      0.85577012
 i,j,k,ie:    6    2    4          71
 Near X = -0.61072285      0.92553646      0.29563535    , d:  0.54465801       0.0000000      0.85577012
 i,j,k,ie:    1    3    4          71
 Near X = -0.70943896      0.82681403      0.13437970    , d:   0.0000000     -0.31846300      0.85577012
 i,j,k,ie:    6    3    4          71
 Near X = -0.70943896      0.82681403      0.29563535    , d:  0.50845084       0.0000000      0.85577012
 i,j,k,ie:    1    4    4          71
 Near X = -0.82680265      0.70944283      0.13437970    , d:   0.0000000     -0.24423477      0.85577012
 i,j,k,ie:    6    4    4          71
 Near X = -0.82680265      0.70944283      0.29563535    , d:  0.46540409       0.0000000      0.85577012
 i,j,k,ie:    1    5    4          71
 Near X = -0.92551875      0.61072040      0.13437970    , d:   0.0000000     -0.18180045      0.85577012
 i,j,k,ie:    6    5    4          71
 Near X = -0.92551875      0.61072040      0.29563535    , d:  0.42919691       0.0000000      0.85577012
 i,j,k,ie:    1    6    4          71
 Near X = -0.97385488      0.56238118      0.13437970    , d:  0.97385491     -0.15122962      0.85577012
 i,j,k,ie:    2    6    4          71
 Near X = -0.97385488      0.56238118      0.15332278    , d:  0.97385491       0.0000000      0.85577012
 i,j,k,ie:    3    6    4          71
 Near X = -0.97385488      0.56238118      0.19200993    , d:  0.97385491       0.0000000      0.85577012
 i,j,k,ie:    4    6    4          71
 Near X = -0.97385488      0.56238118      0.23800512    , d:  0.97385491       0.0000000      0.85577012
 i,j,k,ie:    5    6    4          71
 Near X = -0.97385488      0.56238118      0.27669227    , d:  0.97385491       0.0000000      0.85577012
 i,j,k,ie:    6    6    4          71
 Near X = -0.97385488      0.56238118      0.29563535    , d:   1.3612862       0.0000000      0.85577012
 i,j,k,ie:    1    1    5          71
 Near X = -0.52041375      0.90119178      0.13437970    , d:   1.0408274     -0.38075878      0.85577012
 i,j,k,ie:    2    1    5          71
 Near X = -0.52041375      0.90119178      0.15332278    , d:  0.52041379       0.0000000      0.85577012
 i,j,k,ie:    3    1    5          71
 Near X = -0.52041375      0.90119178      0.19200993    , d:  0.52041379       0.0000000      0.85577012
 i,j,k,ie:    4    1    5          71
 Near X = -0.52041375      0.90119178      0.23800512    , d:  0.52041379       0.0000000      0.85577012
 i,j,k,ie:    5    1    5          71
 Near X = -0.52041375      0.90119178      0.27669227    , d:  0.52041379       0.0000000      0.85577012
 i,j,k,ie:    6    1    5          71
 Near X = -0.52041375      0.90119178      0.29563535    , d:   1.0408224       0.0000000      0.85577012
 i,j,k,ie:    1    2    5          71
 Near X = -0.56514238      0.85646029      0.13437970    , d:   0.0000000     -0.35246956      0.85577012
 i,j,k,ie:    6    2    5          71
 Near X = -0.56514238      0.85646029      0.29563535    , d:  0.50400819       0.0000000      0.85577012
 i,j,k,ie:    1    3    5          71
 Near X = -0.65649094      0.76510588      0.13437970    , d:   0.0000000     -0.29469494      0.85577012
 i,j,k,ie:    6    3    5          71
 Near X = -0.65649094      0.76510588      0.29563535    , d:  0.47050329       0.0000000      0.85577012
 i,j,k,ie:    1    4    5          71
 Near X = -0.76509534      0.65649452      0.13437970    , d:   0.0000000     -0.22600664      0.85577012
 i,j,k,ie:    6    4    5          71
 Near X = -0.76509534      0.65649452      0.29563535    , d:  0.43066928       0.0000000      0.85577012
 i,j,k,ie:    1    5    5          71
 Near X = -0.85644391      0.56514010      0.13437970    , d:   0.0000000     -0.16823202      0.85577012
 i,j,k,ie:    6    5    5          71
 Near X = -0.85644391      0.56514010      0.29563535    , d:  0.39716438       0.0000000      0.85577012
 i,j,k,ie:    1    6    5          71
 Near X = -0.90117253      0.52040862      0.13437970    , d:  0.90117256     -0.13994280      0.85577012
 i,j,k,ie:    2    6    5          71
 Near X = -0.90117253      0.52040862      0.15332278    , d:  0.90117256       0.0000000      0.85577012
 i,j,k,ie:    3    6    5          71
 Near X = -0.90117253      0.52040862      0.19200993    , d:  0.90117256       0.0000000      0.85577012
 i,j,k,ie:    4    6    5          71
 Near X = -0.90117253      0.52040862      0.23800512    , d:  0.90117256       0.0000000      0.85577012
 i,j,k,ie:    5    6    5          71
 Near X = -0.90117253      0.52040862      0.27669227    , d:  0.90117256       0.0000000      0.85577012
 i,j,k,ie:    6    6    5          71
 Near X = -0.90117253      0.52040862      0.29563535    , d:   1.2466313       0.0000000      0.85577012
 i,j,k,ie:    1    1    6          71
 Near X = -0.49986177      0.86560227      0.13437970    , d:   1.1746751     -0.66867633      0.85577012
 i,j,k,ie:    2    1    6          71
 Near X = -0.49986177      0.86560227      0.15332278    , d:  0.49986183     -0.17495163      0.85577012
 i,j,k,ie:    3    1    6          71
 Near X = -0.49986177      0.86560227      0.19200993    , d:  0.49986183     -0.17495163      0.85577012
 i,j,k,ie:    4    1    6          71
 Near X = -0.49986177      0.86560227      0.23800512    , d:  0.49986183     -0.17495163      0.85577012
 i,j,k,ie:    5    1    6          71
 Near X = -0.49986177      0.86560227      0.27669227    , d:  0.49986183     -0.17495163      0.85577012
 i,j,k,ie:    6    1    6          71
 Near X = -0.49986177      0.86560227      0.29563535    , d:   1.1746686     -0.17495163      0.85577012
 i,j,k,ie:    1    2    6          71
 Near X = -0.54282399      0.82263730      0.13437970    , d:   0.0000000     -0.64703087      0.85577012
 i,j,k,ie:    2    2    6          71
 Near X = -0.54282399      0.82263730      0.15332278    , d:   0.0000000     -0.18998840      0.85577012
 i,j,k,ie:    3    2    6          71
 Near X = -0.54282399      0.82263730      0.19200993    , d:   0.0000000     -0.18998840      0.85577012
 i,j,k,ie:    4    2    6          71
 Near X = -0.54282399      0.82263730      0.23800512    , d:   0.0000000     -0.18998840      0.85577012
 i,j,k,ie:    5    2    6          71
 Near X = -0.54282399      0.82263730      0.27669227    , d:   0.0000000     -0.18998840      0.85577012
 i,j,k,ie:    6    2    6          71
 Near X = -0.54282399      0.82263730      0.29563535    , d:  0.48410410     -0.18998840      0.85577012
 i,j,k,ie:    1    3    6          71
 Near X = -0.63056505      0.73489061      0.13437970    , d:   0.0000000     -0.60282468      0.85577012
 i,j,k,ie:    2    3    6          71
 Near X = -0.63056505      0.73489061      0.15332278    , d:   0.0000000     -0.22069778      0.85577012
 i,j,k,ie:    3    3    6          71
 Near X = -0.63056505      0.73489061      0.19200993    , d:   0.0000000     -0.22069778      0.85577012
 i,j,k,ie:    4    3    6          71
 Near X = -0.63056505      0.73489061      0.23800512    , d:   0.0000000     -0.22069778      0.85577012
 i,j,k,ie:    5    3    6          71
 Near X = -0.63056505      0.73489061      0.27669227    , d:   0.0000000     -0.22069778      0.85577012
 i,j,k,ie:    6    3    6          71
 Near X = -0.63056505      0.73489061      0.29563535    , d:  0.45192236     -0.22069778      0.85577012
 i,j,k,ie:    1    4    6          71
 Near X = -0.73488050      0.63056849      0.13437970    , d:   0.0000000     -0.55026790      0.85577012
 i,j,k,ie:    2    4    6          71
 Near X = -0.73488050      0.63056849      0.15332278    , d:   0.0000000     -0.25720818      0.85577012
 i,j,k,ie:    3    4    6          71
 Near X = -0.73488050      0.63056849      0.19200993    , d:   0.0000000     -0.25720818      0.85577012
 i,j,k,ie:    4    4    6          71
 Near X = -0.73488050      0.63056849      0.23800512    , d:   0.0000000     -0.25720818      0.85577012
 i,j,k,ie:    5    4    6          71
 Near X = -0.73488050      0.63056849      0.27669227    , d:   0.0000000     -0.25720818      0.85577012
 i,j,k,ie:    6    4    6          71
 Near X = -0.73488050      0.63056849      0.29563535    , d:  0.41366146     -0.25720818      0.85577012
 i,j,k,ie:    1    5    6          71
 Near X = -0.82262156      0.54282181      0.13437970    , d:   0.0000000     -0.50606171      0.85577012
 i,j,k,ie:    2    5    6          71
 Near X = -0.82262156      0.54282181      0.15332278    , d:   0.0000000     -0.28791755      0.85577012
 i,j,k,ie:    3    5    6          71
 Near X = -0.82262156      0.54282181      0.19200993    , d:   0.0000000     -0.28791755      0.85577012
 i,j,k,ie:    4    5    6          71
 Near X = -0.82262156      0.54282181      0.23800512    , d:   0.0000000     -0.28791755      0.85577012
 i,j,k,ie:    5    5    6          71
 Near X = -0.82262156      0.54282181      0.27669227    , d:   0.0000000     -0.28791755      0.85577012
 i,j,k,ie:    6    5    6          71
 Near X = -0.82262156      0.54282181      0.29563535    , d:  0.38147972     -0.28791755      0.85577012
 i,j,k,ie:    1    6    6          71
 Near X = -0.86558378      0.49985684      0.13437970    , d:  0.86558381     -0.48441625      0.85577012
 i,j,k,ie:    2    6    6          71
 Near X = -0.86558378      0.49985684      0.15332278    , d:  0.86558381     -0.30295433      0.85577012
 i,j,k,ie:    3    6    6          71
 Near X = -0.86558378      0.49985684      0.19200993    , d:  0.86558381     -0.30295433      0.85577012
 i,j,k,ie:    4    6    6          71
 Near X = -0.86558378      0.49985684      0.23800512    , d:  0.86558381     -0.30295433      0.85577012
 i,j,k,ie:    5    6    6          71
 Near X = -0.86558378      0.49985684      0.27669227    , d:  0.86558381     -0.30295433      0.85577012
 i,j,k,ie:    6    6    6          71
 Near X = -0.86558378      0.49985684      0.29563535    , d:   1.3654407     -0.30295433      0.85577012
 i,j,k,ie:    1    1    1          72
 Near X =  0.53131460E-07   1.3500000      0.13437970    , d:  0.67480674     -0.67481345       1.4818910
 i,j,k,ie:    2    1    1          72
 Near X =  0.53131460E-07   1.3500000      0.15332278    , d:  0.67480674     -0.13774823E-07   1.4818910
 i,j,k,ie:    3    1    1          72
 Near X =  0.53131460E-07   1.3500000      0.19200993    , d:  0.67480674     -0.13774823E-07   1.4818910
 i,j,k,ie:    4    1    1          72
 Near X =  0.53131460E-07   1.3500000      0.23800512    , d:  0.67480674     -0.13774823E-07   1.4818910
 i,j,k,ie:    5    1    1          72
 Near X =  0.53131460E-07   1.3500000      0.27669227    , d:  0.67480674     -0.13774823E-07   1.4818910
 i,j,k,ie:    6    1    1          72
 Near X =  0.53131460E-07   1.3500000      0.29563535    , d:  0.67480674     -0.13774823E-07   1.4818910
 i,j,k,ie:    1    2    1          72
 Near X = -0.79271861E-01   1.3286862      0.13437970    , d:  0.20551964E-01 -0.65354054       1.4818910
 i,j,k,ie:    2    2    1          72
 Near X = -0.79271861E-01   1.3286862      0.15332278    , d:  0.20551964E-01   0.0000000       1.4818910
 i,j,k,ie:    3    2    1          72
 Near X = -0.79271861E-01   1.3286862      0.19200993    , d:  0.20551964E-01   0.0000000       1.4818910
 i,j,k,ie:    4    2    1          72
 Near X = -0.79271861E-01   1.3286862      0.23800512    , d:  0.20551964E-01   0.0000000       1.4818910
 i,j,k,ie:    5    2    1          72
 Near X = -0.79271861E-01   1.3286862      0.27669227    , d:  0.20551964E-01   0.0000000       1.4818910
 i,j,k,ie:    6    2    1          72
 Near X = -0.79271861E-01   1.3286862      0.29563535    , d:  0.20551964E-01   0.0000000       1.4818910
 i,j,k,ie:    1    3    1          72
 Near X = -0.24116764       1.2851573      0.13437970    , d:  0.62524946E-01 -0.61009519       1.4818910
 i,j,k,ie:    2    3    1          72
 Near X = -0.24116764       1.2851573      0.15332278    , d:  0.62524946E-01   0.0000000       1.4818910
 i,j,k,ie:    3    3    1          72
 Near X = -0.24116764       1.2851573      0.19200993    , d:  0.62524946E-01   0.0000000       1.4818910
 i,j,k,ie:    4    3    1          72
 Near X = -0.24116764       1.2851573      0.23800512    , d:  0.62524946E-01   0.0000000       1.4818910
 i,j,k,ie:    5    3    1          72
 Near X = -0.24116764       1.2851573      0.27669227    , d:  0.62524946E-01   0.0000000       1.4818910
 i,j,k,ie:    6    3    1          72
 Near X = -0.24116764       1.2851573      0.29563535    , d:  0.62524946E-01   0.0000000       1.4818910
 i,j,k,ie:    1    4    1          72
 Near X = -0.43364571       1.2334058      0.13437970    , d:  0.11242667     -0.55844297       1.4818910
 i,j,k,ie:    2    4    1          72
 Near X = -0.43364571       1.2334058      0.15332278    , d:  0.11242667       0.0000000       1.4818910
 i,j,k,ie:    3    4    1          72
 Near X = -0.43364571       1.2334058      0.19200993    , d:  0.11242667       0.0000000       1.4818910
 i,j,k,ie:    4    4    1          72
 Near X = -0.43364571       1.2334058      0.23800512    , d:  0.11242667       0.0000000       1.4818910
 i,j,k,ie:    5    4    1          72
 Near X = -0.43364571       1.2334058      0.27669227    , d:  0.11242667       0.0000000       1.4818910
 i,j,k,ie:    6    4    1          72
 Near X = -0.43364571       1.2334058      0.29563535    , d:  0.11242667       0.0000000       1.4818910
 i,j,k,ie:    1    5    1          72
 Near X = -0.59554149       1.1898769      0.13437970    , d:  0.15439965     -0.51499762       1.4818910
 i,j,k,ie:    2    5    1          72
 Near X = -0.59554149       1.1898769      0.15332278    , d:  0.15439965       0.0000000       1.4818910
 i,j,k,ie:    3    5    1          72
 Near X = -0.59554149       1.1898769      0.19200993    , d:  0.15439965       0.0000000       1.4818910
 i,j,k,ie:    4    5    1          72
 Near X = -0.59554149       1.1898769      0.23800512    , d:  0.15439965       0.0000000       1.4818910
 i,j,k,ie:    5    5    1          72
 Near X = -0.59554149       1.1898769      0.27669227    , d:  0.15439965       0.0000000       1.4818910
 i,j,k,ie:    6    5    1          72
 Near X = -0.59554149       1.1898769      0.29563535    , d:  0.15439965       0.0000000       1.4818910
 i,j,k,ie:    1    6    1          72
 Near X = -0.67481340       1.1685631      0.13437970    , d:   1.1746703     -0.49372471       1.4818910
 i,j,k,ie:    2    6    1          72
 Near X = -0.67481340       1.1685631      0.15332278    , d:   1.1746703       0.0000000       1.4818910
 i,j,k,ie:    3    6    1          72
 Near X = -0.67481340       1.1685631      0.19200993    , d:   1.1746703       0.0000000       1.4818910
 i,j,k,ie:    4    6    1          72
 Near X = -0.67481340       1.1685631      0.23800512    , d:   1.1746703       0.0000000       1.4818910
 i,j,k,ie:    5    6    1          72
 Near X = -0.67481340       1.1685631      0.27669227    , d:   1.1746703       0.0000000       1.4818910
 i,j,k,ie:    6    6    1          72
 Near X = -0.67481340       1.1685631      0.29563535    , d:   1.1746703       0.0000000       1.4818910
 i,j,k,ie:    1    1    2          72
 Near X =  0.51513299E-07   1.3088847      0.13437970    , d:  0.65425496     -0.65426148       1.4818910
 i,j,k,ie:    2    1    2          72
 Near X =  0.51513299E-07   1.3088847      0.15332278    , d:  0.65425496       0.0000000       1.4818910
 i,j,k,ie:    3    1    2          72
 Near X =  0.51513299E-07   1.3088847      0.19200993    , d:  0.65425496       0.0000000       1.4818910
 i,j,k,ie:    4    1    2          72
 Near X =  0.51513299E-07   1.3088847      0.23800512    , d:  0.65425496       0.0000000       1.4818910
 i,j,k,ie:    5    1    2          72
 Near X =  0.51513299E-07   1.3088847      0.27669227    , d:  0.65425496       0.0000000       1.4818910
 i,j,k,ie:    6    1    2          72
 Near X =  0.51513299E-07   1.3088847      0.29563535    , d:  0.65425496       0.0000000       1.4818910
 i,j,k,ie:    1    2    2          72
 Near X = -0.76857574E-01   1.2882200      0.13437970    , d:   0.0000000     -0.63363644       1.4818910
 i,j,k,ie:    1    3    2          72
 Near X = -0.23382269       1.2460168      0.13437970    , d:   0.0000000     -0.59151426       1.4818910
 i,j,k,ie:    1    4    2          72
 Near X = -0.42043868       1.1958414      0.13437970    , d:   0.0000000     -0.54143515       1.4818910
 i,j,k,ie:    1    5    2          72
 Near X = -0.57740380       1.1536382      0.13437970    , d:   0.0000000     -0.49931296       1.4818910
 i,j,k,ie:    1    6    2          72
 Near X = -0.65426142       1.1329736      0.13437970    , d:   1.1335665     -0.47868793       1.4818910
 i,j,k,ie:    2    6    2          72
 Near X = -0.65426142       1.1329736      0.15332278    , d:   1.1335665       0.0000000       1.4818910
 i,j,k,ie:    3    6    2          72
 Near X = -0.65426142       1.1329736      0.19200993    , d:   1.1335665       0.0000000       1.4818910
 i,j,k,ie:    4    6    2          72
 Near X = -0.65426142       1.1329736      0.23800512    , d:   1.1335665       0.0000000       1.4818910
 i,j,k,ie:    5    6    2          72
 Near X = -0.65426142       1.1329736      0.27669227    , d:   1.1335665       0.0000000       1.4818910
 i,j,k,ie:    6    6    2          72
 Near X = -0.65426142       1.1329736      0.29563535    , d:   1.1335665       0.0000000       1.4818910
 i,j,k,ie:    1    1    3          72
 Near X =  0.48208555E-07   1.2249155      0.13437970    , d:  0.61228240     -0.61228850       1.4818910
 i,j,k,ie:    2    1    3          72
 Near X =  0.48208555E-07   1.2249155      0.15332278    , d:  0.61228240       0.0000000       1.4818910
 i,j,k,ie:    3    1    3          72
 Near X =  0.48208555E-07   1.2249155      0.19200993    , d:  0.61228240       0.0000000       1.4818910
 i,j,k,ie:    4    1    3          72
 Near X =  0.48208555E-07   1.2249155      0.23800512    , d:  0.61228240       0.0000000       1.4818910
 i,j,k,ie:    5    1    3          72
 Near X =  0.48208555E-07   1.2249155      0.27669227    , d:  0.61228240       0.0000000       1.4818910
 i,j,k,ie:    6    1    3          72
 Near X =  0.48208555E-07   1.2249155      0.29563535    , d:  0.61228240       0.0000000       1.4818910
 i,j,k,ie:    1    2    3          72
 Near X = -0.71926913E-01   1.2055765      0.13437970    , d:   0.0000000     -0.59298662       1.4818910
 i,j,k,ie:    1    3    3          72
 Near X = -0.21882221       1.1660808      0.13437970    , d:   0.0000000     -0.55356671       1.4818910
 i,j,k,ie:    1    4    3          72
 Near X = -0.39346619       1.1191243      0.13437970    , d:   0.0000000     -0.50670034       1.4818910
 i,j,k,ie:    1    5    3          72
 Near X = -0.54036149       1.0796286      0.13437970    , d:   0.0000000     -0.46728043       1.4818910
 i,j,k,ie:    1    6    3          72
 Near X = -0.61228845       1.0602897      0.13437970    , d:   1.0496210     -0.44797856       1.4818910
 i,j,k,ie:    2    6    3          72
 Near X = -0.61228845       1.0602897      0.15332278    , d:   1.0496210       0.0000000       1.4818910
 i,j,k,ie:    3    6    3          72
 Near X = -0.61228845       1.0602897      0.19200993    , d:   1.0496210       0.0000000       1.4818910
 i,j,k,ie:    4    6    3          72
 Near X = -0.61228845       1.0602897      0.23800512    , d:   1.0496210       0.0000000       1.4818910
 i,j,k,ie:    5    6    3          72
 Near X = -0.61228845       1.0602897      0.27669227    , d:   1.0496210       0.0000000       1.4818910
 i,j,k,ie:    6    6    3          72
 Near X = -0.61228845       1.0602897      0.29563535    , d:   1.0496210       0.0000000       1.4818910
 i,j,k,ie:    1    1    4          72
 Near X =  0.44279542E-07   1.1250845      0.13437970    , d:  0.56238117     -0.56238677       1.4818910
 i,j,k,ie:    2    1    4          72
 Near X =  0.44279542E-07   1.1250845      0.15332278    , d:  0.56238117       0.0000000       1.4818910
 i,j,k,ie:    3    1    4          72
 Near X =  0.44279542E-07   1.1250845      0.19200993    , d:  0.56238117       0.0000000       1.4818910
 i,j,k,ie:    4    1    4          72
 Near X =  0.44279542E-07   1.1250845      0.23800512    , d:  0.56238117       0.0000000       1.4818910
 i,j,k,ie:    5    1    4          72
 Near X =  0.44279542E-07   1.1250845      0.27669227    , d:  0.56238117       0.0000000       1.4818910
 i,j,k,ie:    6    1    4          72
 Near X =  0.44279542E-07   1.1250845      0.29563535    , d:  0.56238117       0.0000000       1.4818910
 i,j,k,ie:    1    2    4          72
 Near X = -0.66064845E-01   1.1073216      0.13437970    , d:   0.0000000     -0.54465801       1.4818910
 i,j,k,ie:    1    3    4          72
 Near X = -0.20098813       1.0710449      0.13437970    , d:   0.0000000     -0.50845084       1.4818910
 i,j,k,ie:    1    4    4          72
 Near X = -0.36139856       1.0279153      0.13437970    , d:   0.0000000     -0.46540409       1.4818910
 i,j,k,ie:    1    5    4          72
 Near X = -0.49632184      0.99163854      0.13437970    , d:   0.0000000     -0.42919691       1.4818910
 i,j,k,ie:    1    6    4          72
 Near X = -0.56238673      0.97387568      0.13437970    , d:  0.94981803     -0.41146815       1.4818910
 i,j,k,ie:    2    6    4          72
 Near X = -0.56238673      0.97387568      0.15332278    , d:  0.94981803       0.0000000       1.4818910
 i,j,k,ie:    3    6    4          72
 Near X = -0.56238673      0.97387568      0.19200993    , d:  0.94981803       0.0000000       1.4818910
 i,j,k,ie:    4    6    4          72
 Near X = -0.56238673      0.97387568      0.23800512    , d:  0.94981803       0.0000000       1.4818910
 i,j,k,ie:    5    6    4          72
 Near X = -0.56238673      0.97387568      0.27669227    , d:  0.94981803       0.0000000       1.4818910
 i,j,k,ie:    6    6    4          72
 Near X = -0.56238673      0.97387568      0.29563535    , d:  0.94981803       0.0000000       1.4818910
 i,j,k,ie:    1    1    5          72
 Near X =  0.40974798E-07   1.0411153      0.13437970    , d:  0.52040861     -0.52041379       1.4818910
 i,j,k,ie:    2    1    5          72
 Near X =  0.40974798E-07   1.0411153      0.15332278    , d:  0.52040861       0.0000000       1.4818910
 i,j,k,ie:    3    1    5          72
 Near X =  0.40974798E-07   1.0411153      0.19200993    , d:  0.52040861       0.0000000       1.4818910
 i,j,k,ie:    4    1    5          72
 Near X =  0.40974798E-07   1.0411153      0.23800512    , d:  0.52040861       0.0000000       1.4818910
 i,j,k,ie:    5    1    5          72
 Near X =  0.40974798E-07   1.0411153      0.27669227    , d:  0.52040861       0.0000000       1.4818910
 i,j,k,ie:    6    1    5          72
 Near X =  0.40974798E-07   1.0411153      0.29563535    , d:  0.52040861       0.0000000       1.4818910
 i,j,k,ie:    1    2    5          72
 Near X = -0.61134184E-01   1.0246782      0.13437970    , d:   0.0000000     -0.50400819       1.4818910
 i,j,k,ie:    1    3    5          72
 Near X = -0.18598765      0.99110886      0.13437970    , d:   0.0000000     -0.47050329       1.4818910
 i,j,k,ie:    1    4    5          72
 Near X = -0.33442606      0.95119825      0.13437970    , d:   0.0000000     -0.43066928       1.4818910
 i,j,k,ie:    1    5    5          72
 Near X = -0.45927953      0.91762893      0.13437970    , d:   0.0000000     -0.39716438       1.4818910
 i,j,k,ie:    1    6    5          72
 Near X = -0.52041375      0.90119178      0.13437970    , d:  0.86587248     -0.38075878       1.4818910
 i,j,k,ie:    2    6    5          72
 Near X = -0.52041375      0.90119178      0.15332278    , d:  0.86587248       0.0000000       1.4818910
 i,j,k,ie:    3    6    5          72
 Near X = -0.52041375      0.90119178      0.19200993    , d:  0.86587248       0.0000000       1.4818910
 i,j,k,ie:    4    6    5          72
 Near X = -0.52041375      0.90119178      0.23800512    , d:  0.86587248       0.0000000       1.4818910
 i,j,k,ie:    5    6    5          72
 Near X = -0.52041375      0.90119178      0.27669227    , d:  0.86587248       0.0000000       1.4818910
 i,j,k,ie:    6    6    5          72
 Near X = -0.52041375      0.90119178      0.29563535    , d:  0.86587248       0.0000000       1.4818910
 i,j,k,ie:    1    1    6          72
 Near X =  0.39356637E-07   1.0000000      0.13437970    , d:  0.67480675     -0.67481344       1.4818910
 i,j,k,ie:    2    1    6          72
 Near X =  0.39356637E-07   1.0000000      0.15332278    , d:  0.67480675       0.0000000       1.4818910
 i,j,k,ie:    3    1    6          72
 Near X =  0.39356637E-07   1.0000000      0.19200993    , d:  0.67480675       0.0000000       1.4818910
 i,j,k,ie:    4    1    6          72
 Near X =  0.39356637E-07   1.0000000      0.23800512    , d:  0.67480675       0.0000000       1.4818910
 i,j,k,ie:    5    1    6          72
 Near X =  0.39356637E-07   1.0000000      0.27669227    , d:  0.67480675       0.0000000       1.4818910
 i,j,k,ie:    6    1    6          72
 Near X =  0.39356637E-07   1.0000000      0.29563535    , d:  0.67480675       0.0000000       1.4818910
 i,j,k,ie:    1    2    6          72
 Near X = -0.58719897E-01  0.98421199      0.13437970    , d:   0.0000000     -0.67409250       1.4818910
 i,j,k,ie:    2    2    6          72
 Near X = -0.58719897E-01  0.98421199      0.15332278    , d:   0.0000000     -0.20551964E-01   1.4818910
 i,j,k,ie:    3    2    6          72
 Near X = -0.58719897E-01  0.98421199      0.19200993    , d:   0.0000000     -0.20551964E-01   1.4818910
 i,j,k,ie:    4    2    6          72
 Near X = -0.58719897E-01  0.98421199      0.23800512    , d:   0.0000000     -0.20551964E-01   1.4818910
 i,j,k,ie:    5    2    6          72
 Near X = -0.58719897E-01  0.98421199      0.27669227    , d:   0.0000000     -0.20551964E-01   1.4818910
 i,j,k,ie:    6    2    6          72
 Near X = -0.58719897E-01  0.98421199      0.29563535    , d:   0.0000000     -0.20551964E-01   1.4818910
 i,j,k,ie:    1    3    6          72
 Near X = -0.17864270      0.95196837      0.13437970    , d:   0.0000000     -0.67262013       1.4818910
 i,j,k,ie:    2    3    6          72
 Near X = -0.17864270      0.95196837      0.15332278    , d:   0.0000000     -0.62524946E-01   1.4818910
 i,j,k,ie:    3    3    6          72
 Near X = -0.17864270      0.95196837      0.19200993    , d:   0.0000000     -0.62524946E-01   1.4818910
 i,j,k,ie:    4    3    6          72
 Near X = -0.17864270      0.95196837      0.23800512    , d:   0.0000000     -0.62524946E-01   1.4818910
 i,j,k,ie:    5    3    6          72
 Near X = -0.17864270      0.95196837      0.27669227    , d:   0.0000000     -0.62524946E-01   1.4818910
 i,j,k,ie:    6    3    6          72
 Near X = -0.17864270      0.95196837      0.29563535    , d:   0.0000000     -0.62524946E-01   1.4818910
 i,j,k,ie:    1    4    6          72
 Near X = -0.32121904      0.91363390      0.13437970    , d:   0.0000000     -0.67086964       1.4818910
 i,j,k,ie:    2    4    6          72
 Near X = -0.32121904      0.91363390      0.15332278    , d:   0.0000000     -0.11242667       1.4818910
 i,j,k,ie:    3    4    6          72
 Near X = -0.32121904      0.91363390      0.19200993    , d:   0.0000000     -0.11242667       1.4818910
 i,j,k,ie:    4    4    6          72
 Near X = -0.32121904      0.91363390      0.23800512    , d:   0.0000000     -0.11242667       1.4818910
 i,j,k,ie:    5    4    6          72
 Near X = -0.32121904      0.91363390      0.27669227    , d:   0.0000000     -0.11242667       1.4818910
 i,j,k,ie:    6    4    6          72
 Near X = -0.32121904      0.91363390      0.29563535    , d:   0.0000000     -0.11242667       1.4818910
 i,j,k,ie:    1    5    6          72
 Near X = -0.44114184      0.88139028      0.13437970    , d:   0.0000000     -0.66939727       1.4818910
 i,j,k,ie:    2    5    6          72
 Near X = -0.44114184      0.88139028      0.15332278    , d:   0.0000000     -0.15439965       1.4818910
 i,j,k,ie:    3    5    6          72
 Near X = -0.44114184      0.88139028      0.19200993    , d:   0.0000000     -0.15439965       1.4818910
 i,j,k,ie:    4    5    6          72
 Near X = -0.44114184      0.88139028      0.23800512    , d:   0.0000000     -0.15439965       1.4818910
 i,j,k,ie:    5    5    6          72
 Near X = -0.44114184      0.88139028      0.27669227    , d:   0.0000000     -0.15439965       1.4818910
 i,j,k,ie:    6    5    6          72
 Near X = -0.44114184      0.88139028      0.29563535    , d:   0.0000000     -0.15439965       1.4818910
 i,j,k,ie:    1    6    6          72
 Near X = -0.49986177      0.86560227      0.13437970    , d:  0.99971865     -0.66867633       1.4818910
 i,j,k,ie:    2    6    6          72
 Near X = -0.49986177      0.86560227      0.15332278    , d:  0.99971865     -0.17495163       1.4818910
 i,j,k,ie:    3    6    6          72
 Near X = -0.49986177      0.86560227      0.19200993    , d:  0.99971865     -0.17495163       1.4818910
 i,j,k,ie:    4    6    6          72
 Near X = -0.49986177      0.86560227      0.23800512    , d:  0.99971865     -0.17495163       1.4818910
 i,j,k,ie:    5    6    6          72
 Near X = -0.49986177      0.86560227      0.27669227    , d:  0.99971865     -0.17495163       1.4818910
 i,j,k,ie:    6    6    6          72
 Near X = -0.49986177      0.86560227      0.29563535    , d:  0.99971865     -0.17495163       1.4818910
 i,j,k,ie:    1    1    1          73
 Near X = -0.86558378      0.49985684      0.13437970    , d:   2.0341469       0.0000000      0.99999999
 i,j,k,ie:    2    1    1          73
 Near X = -0.86558378      0.49985684      0.15332278    , d:   2.0341469       0.0000000      0.99999999
 i,j,k,ie:    3    1    1          73
 Near X = -0.86558378      0.49985684      0.19200993    , d:   2.0341469       0.0000000      0.99999999
 i,j,k,ie:    4    1    1          73
 Near X = -0.86558378      0.49985684      0.23800512    , d:   2.0341469       0.0000000      0.99999999
 i,j,k,ie:    5    1    1          73
 Near X = -0.86558378      0.49985684      0.27669227    , d:   2.0341469       0.0000000      0.99999999
 i,j,k,ie:    6    1    1          73
 Near X = -0.86558378      0.49985684      0.29563535    , d:   2.0341469     -0.48441625      0.99999999
 i,j,k,ie:    1    2    1          73
 Near X = -0.88137396      0.44113749      0.13437970    , d:  0.30848091       0.0000000      0.99999999
 i,j,k,ie:    2    2    1          73
 Near X = -0.88137396      0.44113749      0.15332278    , d:  0.30848091       0.0000000      0.99999999
 i,j,k,ie:    3    2    1          73
 Near X = -0.88137396      0.44113749      0.19200993    , d:  0.30848091       0.0000000      0.99999999
 i,j,k,ie:    4    2    1          73
 Near X = -0.88137396      0.44113749      0.23800512    , d:  0.30848091       0.0000000      0.99999999
 i,j,k,ie:    5    2    1          73
 Near X = -0.88137396      0.44113749      0.27669227    , d:  0.30848091       0.0000000      0.99999999
 i,j,k,ie:    6    2    1          73
 Near X = -0.88137396      0.44113749      0.29563535    , d:  0.52853838       0.0000000      0.99999999
 i,j,k,ie:    1    3    1          73
 Near X = -0.91362202      0.32121588      0.13437970    , d:  0.31976773       0.0000000      0.99999999
 i,j,k,ie:    2    3    1          73
 Near X = -0.91362202      0.32121588      0.15332278    , d:  0.31976773       0.0000000      0.99999999
 i,j,k,ie:    3    3    1          73
 Near X = -0.91362202      0.32121588      0.19200993    , d:  0.31976773       0.0000000      0.99999999
 i,j,k,ie:    4    3    1          73
 Near X = -0.91362202      0.32121588      0.23800512    , d:  0.31976773       0.0000000      0.99999999
 i,j,k,ie:    5    3    1          73
 Near X = -0.91362202      0.32121588      0.27669227    , d:  0.31976773       0.0000000      0.99999999
 i,j,k,ie:    6    3    1          73
 Near X = -0.91362202      0.32121588      0.29563535    , d:  0.50375475       0.0000000      0.99999999
 i,j,k,ie:    1    4    1          73
 Near X = -0.95196177      0.17864096      0.13437970    , d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    2    4    1          73
 Near X = -0.95196177      0.17864096      0.15332278    , d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    3    4    1          73
 Near X = -0.95196177      0.17864096      0.19200993    , d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    4    4    1          73
 Near X = -0.95196177      0.17864096      0.23800512    , d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    5    4    1          73
 Near X = -0.95196177      0.17864096      0.27669227    , d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    6    4    1          73
 Near X = -0.95196177      0.17864096      0.29563535    , d:  0.47428946       0.0000000      0.99999999
 i,j,k,ie:    1    5    1          73
 Near X = -0.98420982      0.58719352E-01  0.13437970    , d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    2    5    1          73
 Near X = -0.98420982      0.58719352E-01  0.15332278    , d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    3    5    1          73
 Near X = -0.98420982      0.58719352E-01  0.19200993    , d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    4    5    1          73
 Near X = -0.98420982      0.58719352E-01  0.23800512    , d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    5    5    1          73
 Near X = -0.98420982      0.58719352E-01  0.27669227    , d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    6    5    1          73
 Near X = -0.98420982      0.58719352E-01  0.29563535    , d:  0.44950583       0.0000000      0.99999999
 i,j,k,ie:    1    6    1          73
 Near X =  -1.0000000     -0.24492936E-15  0.13437970    , d:   1.8656023       0.0000000      0.99999999
 i,j,k,ie:    2    6    1          73
 Near X =  -1.0000000     -0.24492936E-15  0.15332278    , d:   1.8656023       0.0000000      0.99999999
 i,j,k,ie:    3    6    1          73
 Near X =  -1.0000000     -0.24492936E-15  0.19200993    , d:   1.8656023       0.0000000      0.99999999
 i,j,k,ie:    4    6    1          73
 Near X =  -1.0000000     -0.24492936E-15  0.23800512    , d:   1.8656023       0.0000000      0.99999999
 i,j,k,ie:    5    6    1          73
 Near X =  -1.0000000     -0.24492936E-15  0.27669227    , d:   1.8656023       0.0000000      0.99999999
 i,j,k,ie:    6    6    1          73
 Near X =  -1.0000000     -0.24492936E-15  0.29563535    , d:   2.0000000       0.0000000      0.99999999
 i,j,k,ie:    1    1    2          73
 Near X = -0.82999502      0.47930507      0.13437970    , d:   1.9629686       0.0000000      0.99999999
 i,j,k,ie:    2    1    2          73
 Near X = -0.82999502      0.47930507      0.15332278    , d:   1.9629686       0.0000000      0.99999999
 i,j,k,ie:    3    1    2          73
 Near X = -0.82999502      0.47930507      0.19200993    , d:   1.9629686       0.0000000      0.99999999
 i,j,k,ie:    4    1    2          73
 Near X = -0.82999502      0.47930507      0.23800512    , d:   1.9629686       0.0000000      0.99999999
 i,j,k,ie:    5    1    2          73
 Near X = -0.82999502      0.47930507      0.27669227    , d:   1.9629686       0.0000000      0.99999999
 i,j,k,ie:    6    1    2          73
 Near X = -0.82999502      0.47930507      0.29563535    , d:   1.9629686     -0.47888968      0.99999999
 i,j,k,ie:    6    2    2          73
 Near X = -0.84513599      0.42299998      0.29563535    , d:  0.32463038       0.0000000      0.99999999
 i,j,k,ie:    6    3    2          73
 Near X = -0.87605816      0.30800899      0.29563535    , d:  0.27141899       0.0000000      0.99999999
 i,j,k,ie:    6    4    2          73
 Near X = -0.91282155      0.17129608      0.29563535    , d:  0.20815590       0.0000000      0.99999999
 i,j,k,ie:    6    5    2          73
 Near X = -0.94374372      0.56305087E-01  0.29563535    , d:  0.15494451       0.0000000      0.99999999
 i,j,k,ie:    1    6    2          73
 Near X = -0.95888469     -0.23485901E-15  0.13437970    , d:   1.7888975       0.0000000      0.99999999
 i,j,k,ie:    2    6    2          73
 Near X = -0.95888469     -0.23485901E-15  0.15332278    , d:   1.7888975       0.0000000      0.99999999
 i,j,k,ie:    3    6    2          73
 Near X = -0.95888469     -0.23485901E-15  0.19200993    , d:   1.7888975       0.0000000      0.99999999
 i,j,k,ie:    4    6    2          73
 Near X = -0.95888469     -0.23485901E-15  0.23800512    , d:   1.7888975       0.0000000      0.99999999
 i,j,k,ie:    5    6    2          73
 Near X = -0.95888469     -0.23485901E-15  0.27669227    , d:   1.7888975       0.0000000      0.99999999
 i,j,k,ie:    6    6    2          73
 Near X = -0.95888469     -0.23485901E-15  0.29563535    , d:   1.9177694       0.0000000      0.99999999
 i,j,k,ie:    1    1    3          73
 Near X = -0.75731267      0.43733250      0.13437970    , d:   1.8176023       0.0000000      0.99999999
 i,j,k,ie:    2    1    3          73
 Near X = -0.75731267      0.43733250      0.15332278    , d:   1.8176023       0.0000000      0.99999999
 i,j,k,ie:    3    1    3          73
 Near X = -0.75731267      0.43733250      0.19200993    , d:   1.8176023       0.0000000      0.99999999
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    4    1    3          73
 Near X = -0.75731267      0.43733250      0.23800512    , d:   1.8176023       0.0000000      0.99999999
 i,j,k,ie:    5    1    3          73
 Near X = -0.75731267      0.43733250      0.27669227    , d:   1.8176023       0.0000000      0.99999999
 i,j,k,ie:    6    1    3          73
 Near X = -0.75731267      0.43733250      0.29563535    , d:   1.8176023     -0.46760287      0.99999999
 i,j,k,ie:    6    2    3          73
 Near X = -0.77112775      0.38595803      0.29563535    , d:  0.29620262       0.0000000      0.99999999
 i,j,k,ie:    6    3    3          73
 Near X = -0.79934207      0.28103676      0.29563535    , d:  0.24765093       0.0000000      0.99999999
 i,j,k,ie:    6    4    3          73
 Near X = -0.83288611      0.15629574      0.29563535    , d:  0.18992777       0.0000000      0.99999999
 i,j,k,ie:    6    5    3          73
 Near X = -0.86110043      0.51374472E-01  0.29563535    , d:  0.14137608       0.0000000      0.99999999
 i,j,k,ie:    1    6    3          73
 Near X = -0.87491551     -0.21429250E-15  0.13437970    , d:   1.6322444       0.0000000      0.99999999
 i,j,k,ie:    2    6    3          73
 Near X = -0.87491551     -0.21429250E-15  0.15332278    , d:   1.6322444       0.0000000      0.99999999
 i,j,k,ie:    3    6    3          73
 Near X = -0.87491551     -0.21429250E-15  0.19200993    , d:   1.6322444       0.0000000      0.99999999
 i,j,k,ie:    4    6    3          73
 Near X = -0.87491551     -0.21429250E-15  0.23800512    , d:   1.6322444       0.0000000      0.99999999
 i,j,k,ie:    5    6    3          73
 Near X = -0.87491551     -0.21429250E-15  0.27669227    , d:   1.6322444       0.0000000      0.99999999
 i,j,k,ie:    6    6    3          73
 Near X = -0.87491551     -0.21429250E-15  0.29563535    , d:   1.7498310       0.0000000      0.99999999
 i,j,k,ie:    1    1    4          73
 Near X = -0.67090054      0.38743127      0.13437970    , d:   1.6447762       0.0000000      0.99999999
 i,j,k,ie:    2    1    4          73
 Near X = -0.67090054      0.38743127      0.15332278    , d:   1.6447762       0.0000000      0.99999999
 i,j,k,ie:    3    1    4          73
 Near X = -0.67090054      0.38743127      0.19200993    , d:   1.6447762       0.0000000      0.99999999
 i,j,k,ie:    4    1    4          73
 Near X = -0.67090054      0.38743127      0.23800512    , d:   1.6447762       0.0000000      0.99999999
 i,j,k,ie:    5    1    4          73
 Near X = -0.67090054      0.38743127      0.27669227    , d:   1.6447762       0.0000000      0.99999999
 i,j,k,ie:    6    1    4          73
 Near X = -0.67090054      0.38743127      0.29563535    , d:   1.6447762     -0.45418396      0.99999999
 i,j,k,ie:    6    2    4          73
 Near X = -0.68313927      0.34191882      0.29563535    , d:  0.26240482       0.0000000      0.99999999
 i,j,k,ie:    6    3    4          73
 Near X = -0.70813424      0.24896944      0.29563535    , d:  0.21939306       0.0000000      0.99999999
 i,j,k,ie:    6    4    4          73
 Near X = -0.73785078      0.13846183      0.29563535    , d:  0.16825632       0.0000000      0.99999999
 i,j,k,ie:    6    5    4          73
 Near X = -0.76284574      0.45512458E-01  0.29563535    , d:  0.12524455       0.0000000      0.99999999
 i,j,k,ie:    1    6    4          73
 Near X = -0.77508447     -0.18984094E-15  0.13437970    , d:   1.4459994       0.0000000      0.99999999
 i,j,k,ie:    2    6    4          73
 Near X = -0.77508447     -0.18984094E-15  0.15332278    , d:   1.4459994       0.0000000      0.99999999
 i,j,k,ie:    3    6    4          73
 Near X = -0.77508447     -0.18984094E-15  0.19200993    , d:   1.4459994       0.0000000      0.99999999
 i,j,k,ie:    4    6    4          73
 Near X = -0.77508447     -0.18984094E-15  0.23800512    , d:   1.4459994       0.0000000      0.99999999
 i,j,k,ie:    5    6    4          73
 Near X = -0.77508447     -0.18984094E-15  0.27669227    , d:   1.4459994       0.0000000      0.99999999
 i,j,k,ie:    6    6    4          73
 Near X = -0.77508447     -0.18984094E-15  0.29563535    , d:   1.5501689       0.0000000      0.99999999
 i,j,k,ie:    1    1    5          73
 Near X = -0.59821819      0.34545871      0.13437970    , d:   1.4994100       0.0000000      0.99999999
 i,j,k,ie:    2    1    5          73
 Near X = -0.59821819      0.34545871      0.15332278    , d:   1.4994100       0.0000000      0.99999999
 i,j,k,ie:    3    1    5          73
 Near X = -0.59821819      0.34545871      0.19200993    , d:   1.4994100       0.0000000      0.99999999
 i,j,k,ie:    4    1    5          73
 Near X = -0.59821819      0.34545871      0.23800512    , d:   1.4994100       0.0000000      0.99999999
 i,j,k,ie:    5    1    5          73
 Near X = -0.59821819      0.34545871      0.27669227    , d:   1.4994100       0.0000000      0.99999999
 i,j,k,ie:    6    1    5          73
 Near X = -0.59821819      0.34545871      0.29563535    , d:   1.4994100     -0.44289714      0.99999999
 i,j,k,ie:    6    2    5          73
 Near X = -0.60913103      0.30487687      0.29563535    , d:  0.23397706       0.0000000      0.99999999
 i,j,k,ie:    6    3    5          73
 Near X = -0.63141815      0.22199721      0.29563535    , d:  0.19562500       0.0000000      0.99999999
 i,j,k,ie:    6    4    5          73
 Near X = -0.65791534      0.12346150      0.29563535    , d:  0.15002819       0.0000000      0.99999999
 i,j,k,ie:    6    5    5          73
 Near X = -0.68020246      0.40581842E-01  0.29563535    , d:  0.11167612       0.0000000      0.99999999
 i,j,k,ie:    1    6    5          73
 Near X = -0.69111530     -0.16927443E-15  0.13437970    , d:   1.2893463       0.0000000      0.99999999
 i,j,k,ie:    2    6    5          73
 Near X = -0.69111530     -0.16927443E-15  0.15332278    , d:   1.2893463       0.0000000      0.99999999
 i,j,k,ie:    3    6    5          73
 Near X = -0.69111530     -0.16927443E-15  0.19200993    , d:   1.2893463       0.0000000      0.99999999
 i,j,k,ie:    4    6    5          73
 Near X = -0.69111530     -0.16927443E-15  0.23800512    , d:   1.2893463       0.0000000      0.99999999
 i,j,k,ie:    5    6    5          73
 Near X = -0.69111530     -0.16927443E-15  0.27669227    , d:   1.2893463       0.0000000      0.99999999
 i,j,k,ie:    6    6    5          73
 Near X = -0.69111530     -0.16927443E-15  0.29563535    , d:   1.3822306       0.0000000      0.99999999
 i,j,k,ie:    1    1    6          73
 Near X = -0.56262943      0.32490693      0.13437970    , d:   1.7311925     -0.30295435      0.99999999
 i,j,k,ie:    2    1    6          73
 Near X = -0.56262943      0.32490693      0.15332278    , d:   1.7311925     -0.30295435      0.99999999
 i,j,k,ie:    3    1    6          73
 Near X = -0.56262943      0.32490693      0.19200993    , d:   1.7311925     -0.30295435      0.99999999
 i,j,k,ie:    4    1    6          73
 Near X = -0.56262943      0.32490693      0.23800512    , d:   1.7311925     -0.30295435      0.99999999
 i,j,k,ie:    5    1    6          73
 Near X = -0.56262943      0.32490693      0.27669227    , d:   1.7311925     -0.30295435      0.99999999
 i,j,k,ie:    6    1    6          73
 Near X = -0.56262943      0.32490693      0.29563535    , d:   1.7311925     -0.78737059      0.99999999
 i,j,k,ie:    1    2    6          73
 Near X = -0.57289305      0.28673936      0.13437970    , d:   0.0000000     -0.30848091      0.99999999
 i,j,k,ie:    2    2    6          73
 Near X = -0.57289305      0.28673936      0.15332278    , d:   0.0000000     -0.30848091      0.99999999
 i,j,k,ie:    3    2    6          73
 Near X = -0.57289305      0.28673936      0.19200993    , d:   0.0000000     -0.30848091      0.99999999
 i,j,k,ie:    4    2    6          73
 Near X = -0.57289305      0.28673936      0.23800512    , d:   0.0000000     -0.30848091      0.99999999
 i,j,k,ie:    5    2    6          73
 Near X = -0.57289305      0.28673936      0.27669227    , d:   0.0000000     -0.30848091      0.99999999
 i,j,k,ie:    6    2    6          73
 Near X = -0.57289305      0.28673936      0.29563535    , d:  0.22005747     -0.30848091      0.99999999
 i,j,k,ie:    1    3    6          73
 Near X = -0.59385429      0.20879032      0.13437970    , d:   0.0000000     -0.31976773      0.99999999
 i,j,k,ie:    2    3    6          73
 Near X = -0.59385429      0.20879032      0.15332278    , d:   0.0000000     -0.31976773      0.99999999
 i,j,k,ie:    3    3    6          73
 Near X = -0.59385429      0.20879032      0.19200993    , d:   0.0000000     -0.31976773      0.99999999
 i,j,k,ie:    4    3    6          73
 Near X = -0.59385429      0.20879032      0.23800512    , d:   0.0000000     -0.31976773      0.99999999
 i,j,k,ie:    5    3    6          73
 Near X = -0.59385429      0.20879032      0.27669227    , d:   0.0000000     -0.31976773      0.99999999
 i,j,k,ie:    6    3    6          73
 Near X = -0.59385429      0.20879032      0.29563535    , d:  0.18398702     -0.31976773      0.99999999
 i,j,k,ie:    1    4    6          73
 Near X = -0.61877512      0.11611662      0.13437970    , d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    2    4    6          73
 Near X = -0.61877512      0.11611662      0.15332278    , d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    3    4    6          73
 Near X = -0.61877512      0.11611662      0.19200993    , d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    4    4    6          73
 Near X = -0.61877512      0.11611662      0.23800512    , d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    5    4    6          73
 Near X = -0.61877512      0.11611662      0.27669227    , d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    6    4    6          73
 Near X = -0.61877512      0.11611662      0.29563535    , d:  0.14110282     -0.33318664      0.99999999
 i,j,k,ie:    1    5    6          73
 Near X = -0.63973636      0.38167577E-01  0.13437970    , d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    2    5    6          73
 Near X = -0.63973636      0.38167577E-01  0.15332278    , d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    3    5    6          73
 Near X = -0.63973636      0.38167577E-01  0.19200993    , d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    4    5    6          73
 Near X = -0.63973636      0.38167577E-01  0.23800512    , d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    5    5    6          73
 Near X = -0.63973636      0.38167577E-01  0.27669227    , d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    6    5    6          73
 Near X = -0.63973636      0.38167577E-01  0.29563535    , d:  0.10503237     -0.34447346      0.99999999
 i,j,k,ie:    1    6    6          73
 Near X = -0.64999998     -0.15920408E-15  0.13437970    , d:   1.5156023     -0.35000003      0.99999999
 i,j,k,ie:    2    6    6          73
 Near X = -0.64999998     -0.15920408E-15  0.15332278    , d:   1.5156023     -0.35000003      0.99999999
 i,j,k,ie:    3    6    6          73
 Near X = -0.64999998     -0.15920408E-15  0.19200993    , d:   1.5156023     -0.35000003      0.99999999
 i,j,k,ie:    4    6    6          73
 Near X = -0.64999998     -0.15920408E-15  0.23800512    , d:   1.5156023     -0.35000003      0.99999999
 i,j,k,ie:    5    6    6          73
 Near X = -0.64999998     -0.15920408E-15  0.27669227    , d:   1.5156023     -0.35000003      0.99999999
 i,j,k,ie:    6    6    6          73
 Near X = -0.64999998     -0.15920408E-15  0.29563535    , d:   1.6500000     -0.35000003      0.99999999
 i,j,k,ie:    1    1    1          74
 Near X = -0.49986177      0.86560227      0.13437970    , d:   1.6684249     -0.85013825       1.1552897
 i,j,k,ie:    2    1    1          74
 Near X = -0.49986177      0.86560227      0.15332278    , d:  0.17495163     -0.85013825       1.1552897
 i,j,k,ie:    3    1    1          74
 Near X = -0.49986177      0.86560227      0.19200993    , d:  0.17495163     -0.85013825       1.1552897
 i,j,k,ie:    4    1    1          74
 Near X = -0.49986177      0.86560227      0.23800512    , d:  0.17495163     -0.85013825       1.1552897
 i,j,k,ie:    5    1    1          74
 Near X = -0.49986177      0.86560227      0.27669227    , d:  0.17495163     -0.85013825       1.1552897
 i,j,k,ie:    6    1    1          74
 Near X = -0.49986177      0.86560227      0.29563535    , d:  0.49986181     -0.85013825       1.1552897
 i,j,k,ie:    1    2    1          74
 Near X = -0.54282399      0.82263730      0.13437970    , d:  0.18998841     -0.33854997       1.1552897
 i,j,k,ie:    2    2    1          74
 Near X = -0.54282399      0.82263730      0.15332278    , d:  0.18998841       0.0000000       1.1552897
 i,j,k,ie:    3    2    1          74
 Near X = -0.54282399      0.82263730      0.19200993    , d:  0.18998841       0.0000000       1.1552897
 i,j,k,ie:    4    2    1          74
 Near X = -0.54282399      0.82263730      0.23800512    , d:  0.18998841       0.0000000       1.1552897
 i,j,k,ie:    5    2    1          74
 Near X = -0.54282399      0.82263730      0.27669227    , d:  0.18998841       0.0000000       1.1552897
 i,j,k,ie:    6    2    1          74
 Near X = -0.54282399      0.82263730      0.29563535    , d:  0.50465606       0.0000000       1.1552897
 i,j,k,ie:    1    3    1          74
 Near X = -0.63056505      0.73489061      0.13437970    , d:  0.22069779     -0.28305696       1.1552897
 i,j,k,ie:    2    3    1          74
 Near X = -0.63056505      0.73489061      0.15332278    , d:  0.22069779       0.0000000       1.1552897
 i,j,k,ie:    3    3    1          74
 Near X = -0.63056505      0.73489061      0.19200993    , d:  0.22069779       0.0000000       1.1552897
 i,j,k,ie:    4    3    1          74
 Near X = -0.63056505      0.73489061      0.23800512    , d:  0.22069779       0.0000000       1.1552897
 i,j,k,ie:    5    3    1          74
 Near X = -0.63056505      0.73489061      0.27669227    , d:  0.22069779       0.0000000       1.1552897
 i,j,k,ie:    6    3    1          74
 Near X = -0.63056505      0.73489061      0.29563535    , d:  0.51444731       0.0000000       1.1552897
 i,j,k,ie:    1    4    1          74
 Near X = -0.73488050      0.63056849      0.13437970    , d:  0.25720819     -0.21708127       1.1552897
 i,j,k,ie:    2    4    1          74
 Near X = -0.73488050      0.63056849      0.15332278    , d:  0.25720819       0.0000000       1.1552897
 i,j,k,ie:    3    4    1          74
 Near X = -0.73488050      0.63056849      0.19200993    , d:  0.25720819       0.0000000       1.1552897
 i,j,k,ie:    4    4    1          74
 Near X = -0.73488050      0.63056849      0.23800512    , d:  0.25720819       0.0000000       1.1552897
 i,j,k,ie:    5    4    1          74
 Near X = -0.73488050      0.63056849      0.27669227    , d:  0.25720819       0.0000000       1.1552897
 i,j,k,ie:    6    4    1          74
 Near X = -0.73488050      0.63056849      0.29563535    , d:  0.52608813       0.0000000       1.1552897
 i,j,k,ie:    1    5    1          74
 Near X = -0.82262156      0.54282181      0.13437970    , d:  0.28791757     -0.16158826       1.1552897
 i,j,k,ie:    2    5    1          74
 Near X = -0.82262156      0.54282181      0.15332278    , d:  0.28791757       0.0000000       1.1552897
 i,j,k,ie:    3    5    1          74
 Near X = -0.82262156      0.54282181      0.19200993    , d:  0.28791757       0.0000000       1.1552897
 i,j,k,ie:    4    5    1          74
 Near X = -0.82262156      0.54282181      0.23800512    , d:  0.28791757       0.0000000       1.1552897
 i,j,k,ie:    5    5    1          74
 Near X = -0.82262156      0.54282181      0.27669227    , d:  0.28791757       0.0000000       1.1552897
 i,j,k,ie:    6    5    1          74
 Near X = -0.82262156      0.54282181      0.29563535    , d:  0.53587937       0.0000000       1.1552897
 i,j,k,ie:    1    6    1          74
 Near X = -0.86558378      0.49985684      0.13437970    , d:   1.8655838     -0.13441623       1.1552897
 i,j,k,ie:    2    6    1          74
 Near X = -0.86558378      0.49985684      0.15332278    , d:   1.8655838       0.0000000       1.1552897
 i,j,k,ie:    3    6    1          74
 Near X = -0.86558378      0.49985684      0.19200993    , d:   1.8655838       0.0000000       1.1552897
 i,j,k,ie:    4    6    1          74
 Near X = -0.86558378      0.49985684      0.23800512    , d:   1.8655838       0.0000000       1.1552897
 i,j,k,ie:    5    6    1          74
 Near X = -0.86558378      0.49985684      0.27669227    , d:   1.8655838       0.0000000       1.1552897
 i,j,k,ie:    6    6    1          74
 Near X = -0.86558378      0.49985684      0.29563535    , d:   1.8655838       0.0000000       1.1552897
 i,j,k,ie:    1    1    2          74
 Near X = -0.47930980      0.83001275      0.13437970    , d:   1.6122834     -0.82957491       1.1552897
 i,j,k,ie:    2    1    2          74
 Near X = -0.47930980      0.83001275      0.15332278    , d:   0.0000000     -0.82957491       1.1552897
 i,j,k,ie:    3    1    2          74
 Near X = -0.47930980      0.83001275      0.19200993    , d:   0.0000000     -0.82957491       1.1552897
 i,j,k,ie:    4    1    2          74
 Near X = -0.47930980      0.83001275      0.23800512    , d:   0.0000000     -0.82957491       1.1552897
 i,j,k,ie:    5    1    2          74
 Near X = -0.47930980      0.83001275      0.27669227    , d:   0.0000000     -0.82957491       1.1552897
 i,j,k,ie:    6    1    2          74
 Near X = -0.47930980      0.83001275      0.29563535    , d:  0.47930983     -0.82957491       1.1552897
 i,j,k,ie:    1    2    2          74
 Near X = -0.52050561      0.78881430      0.13437970    , d:   0.0000000     -0.32463038       1.1552897
 i,j,k,ie:    6    2    2          74
 Near X = -0.52050561      0.78881430      0.29563535    , d:  0.46420000       0.0000000       1.1552897
 i,j,k,ie:    1    3    2          74
 Near X = -0.60463917      0.70467535      0.13437970    , d:   0.0000000     -0.27141899       1.1552897
 i,j,k,ie:    6    3    2          74
 Near X = -0.60463917      0.70467535      0.29563535    , d:  0.43334143       0.0000000       1.1552897
 i,j,k,ie:    1    4    2          74
 Near X = -0.70466565      0.60464247      0.13437970    , d:   0.0000000     -0.20815590       1.1552897
 i,j,k,ie:    6    4    2          74
 Near X = -0.70466565      0.60464247      0.29563535    , d:  0.39665363       0.0000000       1.1552897
 i,j,k,ie:    1    5    2          74
 Near X = -0.78879921      0.52050352      0.13437970    , d:   0.0000000     -0.15494451       1.1552897
 i,j,k,ie:    6    5    2          74
 Near X = -0.78879921      0.52050352      0.29563535    , d:  0.36579506       0.0000000       1.1552897
 i,j,k,ie:    1    6    2          74
 Near X = -0.82999502      0.47930507      0.13437970    , d:   1.7888797     -0.12888967       1.1552897
 i,j,k,ie:    2    6    2          74
 Near X = -0.82999502      0.47930507      0.15332278    , d:   1.7888797       0.0000000       1.1552897
 i,j,k,ie:    3    6    2          74
 Near X = -0.82999502      0.47930507      0.19200993    , d:   1.7888797       0.0000000       1.1552897
 i,j,k,ie:    4    6    2          74
 Near X = -0.82999502      0.47930507      0.23800512    , d:   1.7888797       0.0000000       1.1552897
 i,j,k,ie:    5    6    2          74
 Near X = -0.82999502      0.47930507      0.27669227    , d:   1.7888797       0.0000000       1.1552897
 i,j,k,ie:    6    6    2          74
 Near X = -0.82999502      0.47930507      0.29563535    , d:   1.7888797       0.0000000       1.1552897
 i,j,k,ie:    1    1    3          74
 Near X = -0.43733682      0.75732884      0.13437970    , d:   1.4976265     -0.78757872       1.1552897
 i,j,k,ie:    2    1    3          74
 Near X = -0.43733682      0.75732884      0.15332278    , d:   0.0000000     -0.78757872       1.1552897
 i,j,k,ie:    3    1    3          74
 Near X = -0.43733682      0.75732884      0.19200993    , d:   0.0000000     -0.78757872       1.1552897
 i,j,k,ie:    4    1    3          74
 Near X = -0.43733682      0.75732884      0.23800512    , d:   0.0000000     -0.78757872       1.1552897
 i,j,k,ie:    5    1    3          74
 Near X = -0.43733682      0.75732884      0.27669227    , d:   0.0000000     -0.78757872       1.1552897
 i,j,k,ie:    6    1    3          74
 Near X = -0.43733682      0.75732884      0.29563535    , d:  0.43733685     -0.78757872       1.1552897
 i,j,k,ie:    1    2    3          74
 Near X = -0.47492513      0.71973813      0.13437970    , d:   0.0000000     -0.29620262       1.1552897
 i,j,k,ie:    6    2    3          74
 Near X = -0.47492513      0.71973813      0.29563535    , d:  0.42355018       0.0000000       1.1552897
 i,j,k,ie:    1    3    3          74
 Near X = -0.55169114      0.64296719      0.13437970    , d:   0.0000000     -0.24765093       1.1552897
 i,j,k,ie:    6    3    3          74
 Near X = -0.55169114      0.64296719      0.29563535    , d:  0.39539388       0.0000000       1.1552897
 i,j,k,ie:    1    4    3          74
 Near X = -0.64295834      0.55169415      0.13437970    , d:   0.0000000     -0.18992777       1.1552897
 i,j,k,ie:    6    4    3          74
 Near X = -0.64295834      0.55169415      0.29563535    , d:  0.36191882       0.0000000       1.1552897
 i,j,k,ie:    1    5    3          74
 Near X = -0.71972436      0.47492322      0.13437970    , d:   0.0000000     -0.14137608       1.1552897
 i,j,k,ie:    6    5    3          74
 Near X = -0.71972436      0.47492322      0.29563535    , d:  0.33376252       0.0000000       1.1552897
 i,j,k,ie:    1    6    3          74
 Near X = -0.75731267      0.43733250      0.13437970    , d:   1.6322282     -0.11760285       1.1552897
 i,j,k,ie:    2    6    3          74
 Near X = -0.75731267      0.43733250      0.15332278    , d:   1.6322282       0.0000000       1.1552897
 i,j,k,ie:    3    6    3          74
 Near X = -0.75731267      0.43733250      0.19200993    , d:   1.6322282       0.0000000       1.1552897
 i,j,k,ie:    4    6    3          74
 Near X = -0.75731267      0.43733250      0.23800512    , d:   1.6322282       0.0000000       1.1552897
 i,j,k,ie:    5    6    3          74
 Near X = -0.75731267      0.43733250      0.27669227    , d:   1.6322282       0.0000000       1.1552897
 i,j,k,ie:    6    6    3          74
 Near X = -0.75731267      0.43733250      0.29563535    , d:   1.6322282       0.0000000       1.1552897
 i,j,k,ie:    1    1    4          74
 Near X = -0.38743510      0.67091487      0.13437970    , d:   1.3613108     -0.73764940       1.1552897
 i,j,k,ie:    2    1    4          74
 Near X = -0.38743510      0.67091487      0.15332278    , d:   0.0000000     -0.73764940       1.1552897
 i,j,k,ie:    3    1    4          74
 Near X = -0.38743510      0.67091487      0.19200993    , d:   0.0000000     -0.73764940       1.1552897
 i,j,k,ie:    4    1    4          74
 Near X = -0.38743510      0.67091487      0.23800512    , d:   0.0000000     -0.73764940       1.1552897
 i,j,k,ie:    5    1    4          74
 Near X = -0.38743510      0.67091487      0.27669227    , d:   0.0000000     -0.73764940       1.1552897
 i,j,k,ie:    6    1    4          74
 Near X = -0.38743510      0.67091487      0.29563535    , d:  0.38743513     -0.73764940       1.1552897
 i,j,k,ie:    1    2    4          74
 Near X = -0.42073445      0.63761339      0.13437970    , d:   0.0000000     -0.26240482       1.1552897
 i,j,k,ie:    6    2    4          74
 Near X = -0.42073445      0.63761339      0.29563535    , d:  0.37522157       0.0000000       1.1552897
 i,j,k,ie:    1    3    4          74
 Near X = -0.48874118      0.56960230      0.13437970    , d:   0.0000000     -0.21939306       1.1552897
 i,j,k,ie:    6    3    4          74
 Near X = -0.48874118      0.56960230      0.29563535    , d:  0.35027800       0.0000000       1.1552897
 i,j,k,ie:    1    4    4          74
 Near X = -0.56959446      0.48874384      0.13437970    , d:   0.0000000     -0.16825632       1.1552897
 i,j,k,ie:    6    4    4          74
 Near X = -0.56959446      0.48874384      0.29563535    , d:  0.32062257       0.0000000       1.1552897
 i,j,k,ie:    1    5    4          74
 Near X = -0.63760119      0.42073276      0.13437970    , d:   0.0000000     -0.12524455       1.1552897
 i,j,k,ie:    6    5    4          74
 Near X = -0.63760119      0.42073276      0.29563535    , d:  0.29567900       0.0000000       1.1552897
 i,j,k,ie:    1    6    4          74
 Near X = -0.67090054      0.38743127      0.13437970    , d:   1.4459850     -0.10418394       1.1552897
 i,j,k,ie:    2    6    4          74
 Near X = -0.67090054      0.38743127      0.15332278    , d:   1.4459850       0.0000000       1.1552897
 i,j,k,ie:    3    6    4          74
 Near X = -0.67090054      0.38743127      0.19200993    , d:   1.4459850       0.0000000       1.1552897
 i,j,k,ie:    4    6    4          74
 Near X = -0.67090054      0.38743127      0.23800512    , d:   1.4459850       0.0000000       1.1552897
 i,j,k,ie:    5    6    4          74
 Near X = -0.67090054      0.38743127      0.27669227    , d:   1.4459850       0.0000000       1.1552897
 i,j,k,ie:    6    6    4          74
 Near X = -0.67090054      0.38743127      0.29563535    , d:   1.4459850       0.0000000       1.1552897
 i,j,k,ie:    1    1    5          74
 Near X = -0.34546212      0.59823096      0.13437970    , d:   1.2466539     -0.69565321       1.1552897
 i,j,k,ie:    2    1    5          74
 Near X = -0.34546212      0.59823096      0.15332278    , d:   0.0000000     -0.69565321       1.1552897
 i,j,k,ie:    3    1    5          74
 Near X = -0.34546212      0.59823096      0.19200993    , d:   0.0000000     -0.69565321       1.1552897
 i,j,k,ie:    4    1    5          74
 Near X = -0.34546212      0.59823096      0.23800512    , d:   0.0000000     -0.69565321       1.1552897
 i,j,k,ie:    5    1    5          74
 Near X = -0.34546212      0.59823096      0.27669227    , d:   0.0000000     -0.69565321       1.1552897
 i,j,k,ie:    6    1    5          74
 Near X = -0.34546212      0.59823096      0.29563535    , d:  0.34546214     -0.69565321       1.1552897
 i,j,k,ie:    1    2    5          74
 Near X = -0.37515396      0.56853722      0.13437970    , d:   0.0000000     -0.23397706       1.1552897
 i,j,k,ie:    6    2    5          74
 Near X = -0.37515396      0.56853722      0.29563535    , d:  0.33457175       0.0000000       1.1552897
 i,j,k,ie:    1    3    5          74
 Near X = -0.43579315      0.50789414      0.13437970    , d:   0.0000000     -0.19562500       1.1552897
 i,j,k,ie:    6    3    5          74
 Near X = -0.43579315      0.50789414      0.29563535    , d:  0.31233045       0.0000000       1.1552897
 i,j,k,ie:    1    4    5          74
 Near X = -0.50788715      0.43579553      0.13437970    , d:   0.0000000     -0.15002819       1.1552897
 i,j,k,ie:    6    4    5          74
 Near X = -0.50788715      0.43579553      0.29563535    , d:  0.28588776       0.0000000       1.1552897
 i,j,k,ie:    1    5    5          74
 Near X = -0.56852634      0.37515246      0.13437970    , d:   0.0000000     -0.11167612       1.1552897
 i,j,k,ie:    6    5    5          74
 Near X = -0.56852634      0.37515246      0.29563535    , d:  0.26364647       0.0000000       1.1552897
 i,j,k,ie:    1    6    5          74
 Near X = -0.59821819      0.34545871      0.13437970    , d:   1.2893335     -0.92897115E-01   1.1552897
 i,j,k,ie:    2    6    5          74
 Near X = -0.59821819      0.34545871      0.15332278    , d:   1.2893335       0.0000000       1.1552897
 i,j,k,ie:    3    6    5          74
 Near X = -0.59821819      0.34545871      0.19200993    , d:   1.2893335       0.0000000       1.1552897
 i,j,k,ie:    4    6    5          74
 Near X = -0.59821819      0.34545871      0.23800512    , d:   1.2893335       0.0000000       1.1552897
 i,j,k,ie:    5    6    5          74
 Near X = -0.59821819      0.34545871      0.27669227    , d:   1.2893335       0.0000000       1.1552897
 i,j,k,ie:    6    6    5          74
 Near X = -0.59821819      0.34545871      0.29563535    , d:   1.2893335       0.0000000       1.1552897
 i,j,k,ie:    1    1    6          74
 Near X = -0.32491014      0.56264145      0.13437970    , d:   1.4934732      -1.0250899       1.1552897
 i,j,k,ie:    2    1    6          74
 Near X = -0.32491014      0.56264145      0.15332278    , d:   0.0000000      -1.0250899       1.1552897
 i,j,k,ie:    3    1    6          74
 Near X = -0.32491014      0.56264145      0.19200993    , d:   0.0000000      -1.0250899       1.1552897
 i,j,k,ie:    4    1    6          74
 Near X = -0.32491014      0.56264145      0.23800512    , d:   0.0000000      -1.0250899       1.1552897
 i,j,k,ie:    5    1    6          74
 Near X = -0.32491014      0.56264145      0.27669227    , d:   0.0000000      -1.0250899       1.1552897
 i,j,k,ie:    6    1    6          74
 Near X = -0.32491014      0.56264145      0.29563535    , d:  0.32491018      -1.0250899       1.1552897
 i,j,k,ie:    1    2    6          74
 Near X = -0.35283558      0.53471422      0.13437970    , d:   0.0000000     -0.52853838       1.1552897
 i,j,k,ie:    2    2    6          74
 Near X = -0.35283558      0.53471422      0.15332278    , d:   0.0000000     -0.18998841       1.1552897
 i,j,k,ie:    3    2    6          74
 Near X = -0.35283558      0.53471422      0.19200993    , d:   0.0000000     -0.18998841       1.1552897
 i,j,k,ie:    4    2    6          74
 Near X = -0.35283558      0.53471422      0.23800512    , d:   0.0000000     -0.18998841       1.1552897
 i,j,k,ie:    5    2    6          74
 Near X = -0.35283558      0.53471422      0.27669227    , d:   0.0000000     -0.18998841       1.1552897
 i,j,k,ie:    6    2    6          74
 Near X = -0.35283558      0.53471422      0.29563535    , d:  0.31466765     -0.18998841       1.1552897
 i,j,k,ie:    1    3    6          74
 Near X = -0.40986727      0.47767888      0.13437970    , d:   0.0000000     -0.50375475       1.1552897
 i,j,k,ie:    2    3    6          74
 Near X = -0.40986727      0.47767888      0.15332278    , d:   0.0000000     -0.22069779       1.1552897
 i,j,k,ie:    3    3    6          74
 Near X = -0.40986727      0.47767888      0.19200993    , d:   0.0000000     -0.22069779       1.1552897
 i,j,k,ie:    4    3    6          74
 Near X = -0.40986727      0.47767888      0.23800512    , d:   0.0000000     -0.22069779       1.1552897
 i,j,k,ie:    5    3    6          74
 Near X = -0.40986727      0.47767888      0.27669227    , d:   0.0000000     -0.22069779       1.1552897
 i,j,k,ie:    6    3    6          74
 Near X = -0.40986727      0.47767888      0.29563535    , d:  0.29374952     -0.22069779       1.1552897
 i,j,k,ie:    1    4    6          74
 Near X = -0.47767230      0.40986950      0.13437970    , d:   0.0000000     -0.47428946       1.1552897
 i,j,k,ie:    2    4    6          74
 Near X = -0.47767230      0.40986950      0.15332278    , d:   0.0000000     -0.25720819       1.1552897
 i,j,k,ie:    3    4    6          74
 Near X = -0.47767230      0.40986950      0.19200993    , d:   0.0000000     -0.25720819       1.1552897
 i,j,k,ie:    4    4    6          74
 Near X = -0.47767230      0.40986950      0.23800512    , d:   0.0000000     -0.25720819       1.1552897
 i,j,k,ie:    5    4    6          74
 Near X = -0.47767230      0.40986950      0.27669227    , d:   0.0000000     -0.25720819       1.1552897
 i,j,k,ie:    6    4    6          74
 Near X = -0.47767230      0.40986950      0.29563535    , d:  0.26887994     -0.25720819       1.1552897
 i,j,k,ie:    1    5    6          74
 Near X = -0.53470399      0.35283416      0.13437970    , d:   0.0000000     -0.44950583       1.1552897
 i,j,k,ie:    2    5    6          74
 Near X = -0.53470399      0.35283416      0.15332278    , d:   0.0000000     -0.28791757       1.1552897
 i,j,k,ie:    3    5    6          74
 Near X = -0.53470399      0.35283416      0.19200993    , d:   0.0000000     -0.28791757       1.1552897
 i,j,k,ie:    4    5    6          74
 Near X = -0.53470399      0.35283416      0.23800512    , d:   0.0000000     -0.28791757       1.1552897
 i,j,k,ie:    5    5    6          74
 Near X = -0.53470399      0.35283416      0.27669227    , d:   0.0000000     -0.28791757       1.1552897
 i,j,k,ie:    6    5    6          74
 Near X = -0.53470399      0.35283416      0.29563535    , d:  0.24796181     -0.28791757       1.1552897
 i,j,k,ie:    1    6    6          74
 Near X = -0.56262943      0.32490693      0.13437970    , d:   1.5626294     -0.43737058       1.1552897
 i,j,k,ie:    2    6    6          74
 Near X = -0.56262943      0.32490693      0.15332278    , d:   1.5626294     -0.30295435       1.1552897
 i,j,k,ie:    3    6    6          74
 Near X = -0.56262943      0.32490693      0.19200993    , d:   1.5626294     -0.30295435       1.1552897
 i,j,k,ie:    4    6    6          74
 Near X = -0.56262943      0.32490693      0.23800512    , d:   1.5626294     -0.30295435       1.1552897
 i,j,k,ie:    5    6    6          74
 Near X = -0.56262943      0.32490693      0.27669227    , d:   1.5626294     -0.30295435       1.1552897
 i,j,k,ie:    6    6    6          74
 Near X = -0.56262943      0.32490693      0.29563535    , d:   1.5626294     -0.30295435       1.1552897
 i,j,k,ie:    1    1    1          75
 Near X =  0.39356637E-07   1.0000000      0.13437970    , d:   0.0000000      -1.3500001       2.0005529
 i,j,k,ie:    2    1    1          75
 Near X =  0.39356637E-07   1.0000000      0.15332278    , d:   0.0000000      -1.1685381       2.0005529
 i,j,k,ie:    3    1    1          75
 Near X =  0.39356637E-07   1.0000000      0.19200993    , d:   0.0000000      -1.1685381       2.0005529
 i,j,k,ie:    4    1    1          75
 Near X =  0.39356637E-07   1.0000000      0.23800512    , d:   0.0000000      -1.1685381       2.0005529
 i,j,k,ie:    5    1    1          75
 Near X =  0.39356637E-07   1.0000000      0.27669227    , d:   0.0000000      -1.1685381       2.0005529
 i,j,k,ie:    6    1    1          75
 Near X =  0.39356637E-07   1.0000000      0.29563535    , d:  0.49985684      -1.1685381       2.0005529
 i,j,k,ie:    1    2    1          75
 Near X = -0.58719897E-01  0.98421199      0.13437970    , d:  0.20551965E-01 -0.48410410       2.0005529
 i,j,k,ie:    2    2    1          75
 Near X = -0.58719897E-01  0.98421199      0.15332278    , d:  0.20551965E-01   0.0000000       2.0005529
 i,j,k,ie:    3    2    1          75
 Near X = -0.58719897E-01  0.98421199      0.19200993    , d:  0.20551965E-01   0.0000000       2.0005529
 i,j,k,ie:    4    2    1          75
 Near X = -0.58719897E-01  0.98421199      0.23800512    , d:  0.20551965E-01   0.0000000       2.0005529
 i,j,k,ie:    5    2    1          75
 Near X = -0.58719897E-01  0.98421199      0.27669227    , d:  0.20551965E-01   0.0000000       2.0005529
 i,j,k,ie:    6    2    1          75
 Near X = -0.58719897E-01  0.98421199      0.29563535    , d:  0.49985742       0.0000000       2.0005529
 i,j,k,ie:    1    3    1          75
 Near X = -0.17864270      0.95196837      0.13437970    , d:  0.62524948E-01 -0.45192236       2.0005529
 i,j,k,ie:    2    3    1          75
 Near X = -0.17864270      0.95196837      0.15332278    , d:  0.62524948E-01   0.0000000       2.0005529
 i,j,k,ie:    3    3    1          75
 Near X = -0.17864270      0.95196837      0.19200993    , d:  0.62524948E-01   0.0000000       2.0005529
 i,j,k,ie:    4    3    1          75
 Near X = -0.17864270      0.95196837      0.23800512    , d:  0.62524948E-01   0.0000000       2.0005529
 i,j,k,ie:    5    3    1          75
 Near X = -0.17864270      0.95196837      0.27669227    , d:  0.62524948E-01   0.0000000       2.0005529
 i,j,k,ie:    6    3    1          75
 Near X = -0.17864270      0.95196837      0.29563535    , d:  0.49985862       0.0000000       2.0005529
 i,j,k,ie:    1    4    1          75
 Near X = -0.32121904      0.91363390      0.13437970    , d:  0.11242667     -0.41366146       2.0005529
 i,j,k,ie:    2    4    1          75
 Near X = -0.32121904      0.91363390      0.15332278    , d:  0.11242667       0.0000000       2.0005529
 i,j,k,ie:    3    4    1          75
 Near X = -0.32121904      0.91363390      0.19200993    , d:  0.11242667       0.0000000       2.0005529
 i,j,k,ie:    4    4    1          75
 Near X = -0.32121904      0.91363390      0.23800512    , d:  0.11242667       0.0000000       2.0005529
 i,j,k,ie:    5    4    1          75
 Near X = -0.32121904      0.91363390      0.27669227    , d:  0.11242667       0.0000000       2.0005529
 i,j,k,ie:    6    4    1          75
 Near X = -0.32121904      0.91363390      0.29563535    , d:  0.49986004       0.0000000       2.0005529
 i,j,k,ie:    1    5    1          75
 Near X = -0.44114184      0.88139028      0.13437970    , d:  0.15439966     -0.38147972       2.0005529
 i,j,k,ie:    2    5    1          75
 Near X = -0.44114184      0.88139028      0.15332278    , d:  0.15439966       0.0000000       2.0005529
 i,j,k,ie:    3    5    1          75
 Near X = -0.44114184      0.88139028      0.19200993    , d:  0.15439966       0.0000000       2.0005529
 i,j,k,ie:    4    5    1          75
 Near X = -0.44114184      0.88139028      0.23800512    , d:  0.15439966       0.0000000       2.0005529
 i,j,k,ie:    5    5    1          75
 Near X = -0.44114184      0.88139028      0.27669227    , d:  0.15439966       0.0000000       2.0005529
 i,j,k,ie:    6    5    1          75
 Near X = -0.44114184      0.88139028      0.29563535    , d:  0.49986123       0.0000000       2.0005529
 i,j,k,ie:    1    6    1          75
 Near X = -0.49986177      0.86560227      0.13437970    , d:   1.4998618     -0.36572200       2.0005529
 i,j,k,ie:    2    6    1          75
 Near X = -0.49986177      0.86560227      0.15332278    , d:   1.3654455       0.0000000       2.0005529
 i,j,k,ie:    3    6    1          75
 Near X = -0.49986177      0.86560227      0.19200993    , d:   1.3654455       0.0000000       2.0005529
 i,j,k,ie:    4    6    1          75
 Near X = -0.49986177      0.86560227      0.23800512    , d:   1.3654455       0.0000000       2.0005529
 i,j,k,ie:    5    6    1          75
 Near X = -0.49986177      0.86560227      0.27669227    , d:   1.3654455       0.0000000       2.0005529
 i,j,k,ie:    6    6    1          75
 Near X = -0.49986177      0.86560227      0.29563535    , d:   1.3654455       0.0000000       2.0005529
 i,j,k,ie:    1    1    2          75
 Near X =  0.37738476E-07  0.95888469      0.13437970    , d:   0.0000000      -1.3088847       2.0005529
 i,j,k,ie:    2    1    2          75
 Near X =  0.37738476E-07  0.95888469      0.15332278    , d:   0.0000000      -1.1329494       2.0005529
 i,j,k,ie:    3    1    2          75
 Near X =  0.37738476E-07  0.95888469      0.19200993    , d:   0.0000000      -1.1329494       2.0005529
 i,j,k,ie:    4    1    2          75
 Near X =  0.37738476E-07  0.95888469      0.23800512    , d:   0.0000000      -1.1329494       2.0005529
 i,j,k,ie:    5    1    2          75
 Near X =  0.37738476E-07  0.95888469      0.27669227    , d:   0.0000000      -1.1329494       2.0005529
 i,j,k,ie:    6    1    2          75
 Near X =  0.37738476E-07  0.95888469      0.29563535    , d:  0.47930506      -1.1329494       2.0005529
 i,j,k,ie:    1    2    2          75
 Near X = -0.56305609E-01  0.94374580      0.13437970    , d:   0.0000000     -0.46420000       2.0005529
 i,j,k,ie:    6    2    2          75
 Near X = -0.56305609E-01  0.94374580      0.29563535    , d:  0.47930562       0.0000000       2.0005529
 i,j,k,ie:    1    3    2          75
 Near X = -0.17129774      0.91282789      0.13437970    , d:   0.0000000     -0.43334143       2.0005529
 i,j,k,ie:    6    3    2          75
 Near X = -0.17129774      0.91282789      0.29563535    , d:  0.47930677       0.0000000       2.0005529
 i,j,k,ie:    1    4    2          75
 Near X = -0.30801202      0.87606955      0.13437970    , d:   0.0000000     -0.39665363       2.0005529
 i,j,k,ie:    6    4    2          75
 Near X = -0.30801202      0.87606955      0.29563535    , d:  0.47930813       0.0000000       2.0005529
 i,j,k,ie:    1    5    2          75
 Near X = -0.42300415      0.84515164      0.13437970    , d:   0.0000000     -0.36579506       2.0005529
 i,j,k,ie:    6    5    2          75
 Near X = -0.42300415      0.84515164      0.29563535    , d:  0.47930927       0.0000000       2.0005529
 i,j,k,ie:    1    6    2          75
 Near X = -0.47930980      0.83001275      0.13437970    , d:   1.4381945     -0.35068522       2.0005529
 i,j,k,ie:    2    6    2          75
 Near X = -0.47930980      0.83001275      0.15332278    , d:   1.3093048       0.0000000       2.0005529
 i,j,k,ie:    3    6    2          75
 Near X = -0.47930980      0.83001275      0.19200993    , d:   1.3093048       0.0000000       2.0005529
 i,j,k,ie:    4    6    2          75
 Near X = -0.47930980      0.83001275      0.23800512    , d:   1.3093048       0.0000000       2.0005529
 i,j,k,ie:    5    6    2          75
 Near X = -0.47930980      0.83001275      0.27669227    , d:   1.3093048       0.0000000       2.0005529
 i,j,k,ie:    6    6    2          75
 Near X = -0.47930980      0.83001275      0.29563535    , d:   1.3093048       0.0000000       2.0005529
 i,j,k,ie:    1    1    3          75
 Near X =  0.34433732E-07  0.87491551      0.13437970    , d:   0.0000000      -1.2249156       2.0005529
 i,j,k,ie:    2    1    3          75
 Near X =  0.34433732E-07  0.87491551      0.15332278    , d:   0.0000000      -1.0602670       2.0005529
 i,j,k,ie:    3    1    3          75
 Near X =  0.34433732E-07  0.87491551      0.19200993    , d:   0.0000000      -1.0602670       2.0005529
 i,j,k,ie:    4    1    3          75
 Near X =  0.34433732E-07  0.87491551      0.23800512    , d:   0.0000000      -1.0602670       2.0005529
 i,j,k,ie:    5    1    3          75
 Near X =  0.34433732E-07  0.87491551      0.27669227    , d:   0.0000000      -1.0602670       2.0005529
 i,j,k,ie:    6    1    3          75
 Near X =  0.34433732E-07  0.87491551      0.29563535    , d:  0.43733250      -1.0602670       2.0005529
 i,j,k,ie:    1    2    3          75
 Near X = -0.51374948E-01  0.86110233      0.13437970    , d:   0.0000000     -0.42355018       2.0005529
 i,j,k,ie:    6    2    3          75
 Near X = -0.51374948E-01  0.86110233      0.29563535    , d:  0.43733301       0.0000000       2.0005529
 i,j,k,ie:    1    3    3          75
 Near X = -0.15629726      0.83289189      0.13437970    , d:   0.0000000     -0.39539388       2.0005529
 i,j,k,ie:    6    3    3          75
 Near X = -0.15629726      0.83289189      0.29563535    , d:  0.43733405       0.0000000       2.0005529
 i,j,k,ie:    1    4    3          75
 Near X = -0.28103952      0.79935247      0.13437970    , d:   0.0000000     -0.36191882       2.0005529
 i,j,k,ie:    6    4    3          75
 Near X = -0.28103952      0.79935247      0.29563535    , d:  0.43733530       0.0000000       2.0005529
 i,j,k,ie:    1    5    3          75
 Near X = -0.38596183      0.77114202      0.13437970    , d:   0.0000000     -0.33376252       2.0005529
 i,j,k,ie:    6    5    3          75
 Near X = -0.38596183      0.77114202      0.29563535    , d:  0.43733634       0.0000000       2.0005529
 i,j,k,ie:    1    6    3          75
 Near X = -0.43733682      0.75732884      0.13437970    , d:   1.3122523     -0.31997585       2.0005529
 i,j,k,ie:    2    6    3          75
 Near X = -0.43733682      0.75732884      0.15332278    , d:   1.1946495       0.0000000       2.0005529
 i,j,k,ie:    3    6    3          75
 Near X = -0.43733682      0.75732884      0.19200993    , d:   1.1946495       0.0000000       2.0005529
 i,j,k,ie:    4    6    3          75
 Near X = -0.43733682      0.75732884      0.23800512    , d:   1.1946495       0.0000000       2.0005529
 i,j,k,ie:    5    6    3          75
 Near X = -0.43733682      0.75732884      0.27669227    , d:   1.1946495       0.0000000       2.0005529
 i,j,k,ie:    6    6    3          75
 Near X = -0.43733682      0.75732884      0.29563535    , d:   1.1946495       0.0000000       2.0005529
 i,j,k,ie:    1    1    4          75
 Near X =  0.30504718E-07  0.77508447      0.13437970    , d:   0.0000000      -1.1250845       2.0005529
 i,j,k,ie:    2    1    4          75
 Near X =  0.30504718E-07  0.77508447      0.15332278    , d:   0.0000000     -0.97385491       2.0005529
 i,j,k,ie:    3    1    4          75
 Near X =  0.30504718E-07  0.77508447      0.19200993    , d:   0.0000000     -0.97385491       2.0005529
 i,j,k,ie:    4    1    4          75
 Near X =  0.30504718E-07  0.77508447      0.23800512    , d:   0.0000000     -0.97385491       2.0005529
 i,j,k,ie:    5    1    4          75
 Near X =  0.30504718E-07  0.77508447      0.27669227    , d:   0.0000000     -0.97385491       2.0005529
 i,j,k,ie:    6    1    4          75
 Near X =  0.30504718E-07  0.77508447      0.29563535    , d:  0.38743127     -0.97385491       2.0005529
 i,j,k,ie:    1    2    4          75
 Near X = -0.45512880E-01  0.76284743      0.13437970    , d:   0.0000000     -0.37522157       2.0005529
 i,j,k,ie:    6    2    4          75
 Near X = -0.45512880E-01  0.76284743      0.29563535    , d:  0.38743172       0.0000000       2.0005529
 i,j,k,ie:    1    3    4          75
 Near X = -0.13846318      0.73785590      0.13437970    , d:   0.0000000     -0.35027800       2.0005529
 i,j,k,ie:    6    3    4          75
 Near X = -0.13846318      0.73785590      0.29563535    , d:  0.38743265       0.0000000       2.0005529
 i,j,k,ie:    1    4    4          75
 Near X = -0.24897189      0.70814345      0.13437970    , d:   0.0000000     -0.32062257       2.0005529
 i,j,k,ie:    6    4    4          75
 Near X = -0.24897189      0.70814345      0.29563535    , d:  0.38743375       0.0000000       2.0005529
 i,j,k,ie:    1    5    4          75
 Near X = -0.34192219      0.68315192      0.13437970    , d:   0.0000000     -0.29567900       2.0005529
 i,j,k,ie:    6    5    4          75
 Near X = -0.34192219      0.68315192      0.29563535    , d:  0.38743467       0.0000000       2.0005529
 i,j,k,ie:    1    6    4          75
 Near X = -0.38743510      0.67091487      0.13437970    , d:   1.1625196     -0.28346544       2.0005529
 i,j,k,ie:    2    6    4          75
 Near X = -0.38743510      0.67091487      0.15332278    , d:   1.0583356       0.0000000       2.0005529
 i,j,k,ie:    3    6    4          75
 Near X = -0.38743510      0.67091487      0.19200993    , d:   1.0583356       0.0000000       2.0005529
 i,j,k,ie:    4    6    4          75
 Near X = -0.38743510      0.67091487      0.23800512    , d:   1.0583356       0.0000000       2.0005529
 i,j,k,ie:    5    6    4          75
 Near X = -0.38743510      0.67091487      0.27669227    , d:   1.0583356       0.0000000       2.0005529
 i,j,k,ie:    6    6    4          75
 Near X = -0.38743510      0.67091487      0.29563535    , d:   1.0583356       0.0000000       2.0005529
 i,j,k,ie:    1    1    5          75
 Near X =  0.27199974E-07  0.69111530      0.13437970    , d:   0.0000000      -1.0411154       2.0005529
 i,j,k,ie:    2    1    5          75
 Near X =  0.27199974E-07  0.69111530      0.15332278    , d:   0.0000000     -0.90117256       2.0005529
 i,j,k,ie:    3    1    5          75
 Near X =  0.27199974E-07  0.69111530      0.19200993    , d:   0.0000000     -0.90117256       2.0005529
 i,j,k,ie:    4    1    5          75
 Near X =  0.27199974E-07  0.69111530      0.23800512    , d:   0.0000000     -0.90117256       2.0005529
 i,j,k,ie:    5    1    5          75
 Near X =  0.27199974E-07  0.69111530      0.27669227    , d:   0.0000000     -0.90117256       2.0005529
 i,j,k,ie:    6    1    5          75
 Near X =  0.27199974E-07  0.69111530      0.29563535    , d:  0.34545871     -0.90117256       2.0005529
 i,j,k,ie:    1    2    5          75
 Near X = -0.40582219E-01  0.68020396      0.13437970    , d:   0.0000000     -0.33457175       2.0005529
 i,j,k,ie:    6    2    5          75
 Near X = -0.40582219E-01  0.68020396      0.29563535    , d:  0.34545911       0.0000000       2.0005529
 i,j,k,ie:    1    3    5          75
 Near X = -0.12346270      0.65791990      0.13437970    , d:   0.0000000     -0.31233045       2.0005529
 i,j,k,ie:    6    3    5          75
 Near X = -0.12346270      0.65791990      0.29563535    , d:  0.34545993       0.0000000       2.0005529
 i,j,k,ie:    1    4    5          75
 Near X = -0.22199939      0.63142636      0.13437970    , d:   0.0000000     -0.28588776       2.0005529
 i,j,k,ie:    6    4    5          75
 Near X = -0.22199939      0.63142636      0.29563535    , d:  0.34546092       0.0000000       2.0005529
 i,j,k,ie:    1    5    5          75
 Near X = -0.30487987      0.60914230      0.13437970    , d:   0.0000000     -0.26364647       2.0005529
 i,j,k,ie:    6    5    5          75
 Near X = -0.30487987      0.60914230      0.29563535    , d:  0.34546174       0.0000000       2.0005529
 i,j,k,ie:    1    6    5          75
 Near X = -0.34546212      0.59823096      0.13437970    , d:   1.0365774     -0.25275607       2.0005529
 i,j,k,ie:    2    6    5          75
 Near X = -0.34546212      0.59823096      0.15332278    , d:  0.94368028       0.0000000       2.0005529
 i,j,k,ie:    3    6    5          75
 Near X = -0.34546212      0.59823096      0.19200993    , d:  0.94368028       0.0000000       2.0005529
 i,j,k,ie:    4    6    5          75
 Near X = -0.34546212      0.59823096      0.23800512    , d:  0.94368028       0.0000000       2.0005529
 i,j,k,ie:    5    6    5          75
 Near X = -0.34546212      0.59823096      0.27669227    , d:  0.94368028       0.0000000       2.0005529
 i,j,k,ie:    6    6    5          75
 Near X = -0.34546212      0.59823096      0.29563535    , d:  0.94368028       0.0000000       2.0005529
 i,j,k,ie:    1    1    6          75
 Near X =  0.25581813E-07  0.64999998      0.13437970    , d:  0.13774824E-07  -1.3500000       2.0005529
 i,j,k,ie:    2    1    6          75
 Near X =  0.25581813E-07  0.64999998      0.15332278    , d:  0.13774824E-07  -1.1685381       2.0005529
 i,j,k,ie:    3    1    6          75
 Near X =  0.25581813E-07  0.64999998      0.19200993    , d:  0.13774824E-07  -1.1685381       2.0005529
 i,j,k,ie:    4    1    6          75
 Near X =  0.25581813E-07  0.64999998      0.23800512    , d:  0.13774824E-07  -1.1685381       2.0005529
 i,j,k,ie:    5    1    6          75
 Near X =  0.25581813E-07  0.64999998      0.27669227    , d:  0.13774824E-07  -1.1685381       2.0005529
 i,j,k,ie:    6    1    6          75
 Near X =  0.25581813E-07  0.64999998      0.29563535    , d:  0.49985685      -1.1685381       2.0005529
 i,j,k,ie:    1    2    6          75
 Near X = -0.38167931E-01  0.63973777      0.13437970    , d:   0.0000000     -0.50465606       2.0005529
 i,j,k,ie:    2    2    6          75
 Near X = -0.38167931E-01  0.63973777      0.15332278    , d:   0.0000000     -0.20551965E-01   2.0005529
 i,j,k,ie:    3    2    6          75
 Near X = -0.38167931E-01  0.63973777      0.19200993    , d:   0.0000000     -0.20551965E-01   2.0005529
 i,j,k,ie:    4    2    6          75
 Near X = -0.38167931E-01  0.63973777      0.23800512    , d:   0.0000000     -0.20551965E-01   2.0005529
 i,j,k,ie:    5    2    6          75
 Near X = -0.38167931E-01  0.63973777      0.27669227    , d:   0.0000000     -0.20551965E-01   2.0005529
 i,j,k,ie:    6    2    6          75
 Near X = -0.38167931E-01  0.63973777      0.29563535    , d:  0.47930546     -0.20551965E-01   2.0005529
 i,j,k,ie:    1    3    6          75
 Near X = -0.11611775      0.61877942      0.13437970    , d:   0.0000000     -0.51444731       2.0005529
 i,j,k,ie:    2    3    6          75
 Near X = -0.11611775      0.61877942      0.15332278    , d:   0.0000000     -0.62524948E-01   2.0005529
 i,j,k,ie:    3    3    6          75
 Near X = -0.11611775      0.61877942      0.19200993    , d:   0.0000000     -0.62524948E-01   2.0005529
 i,j,k,ie:    4    3    6          75
 Near X = -0.11611775      0.61877942      0.23800512    , d:   0.0000000     -0.62524948E-01   2.0005529
 i,j,k,ie:    5    3    6          75
 Near X = -0.11611775      0.61877942      0.27669227    , d:   0.0000000     -0.62524948E-01   2.0005529
 i,j,k,ie:    6    3    6          75
 Near X = -0.11611775      0.61877942      0.29563535    , d:  0.43733367     -0.62524948E-01   2.0005529
 i,j,k,ie:    1    4    6          75
 Near X = -0.20879237      0.59386201      0.13437970    , d:   0.0000000     -0.52608813       2.0005529
 i,j,k,ie:    2    4    6          75
 Near X = -0.20879237      0.59386201      0.15332278    , d:   0.0000000     -0.11242667       2.0005529
 i,j,k,ie:    3    4    6          75
 Near X = -0.20879237      0.59386201      0.19200993    , d:   0.0000000     -0.11242667       2.0005529
 i,j,k,ie:    4    4    6          75
 Near X = -0.20879237      0.59386201      0.23800512    , d:   0.0000000     -0.11242667       2.0005529
 i,j,k,ie:    5    4    6          75
 Near X = -0.20879237      0.59386201      0.27669227    , d:   0.0000000     -0.11242667       2.0005529
 i,j,k,ie:    6    4    6          75
 Near X = -0.20879237      0.59386201      0.29563535    , d:  0.38743336     -0.11242667       2.0005529
 i,j,k,ie:    1    5    6          75
 Near X = -0.28674218      0.57290366      0.13437970    , d:   0.0000000     -0.53587937       2.0005529
 i,j,k,ie:    2    5    6          75
 Near X = -0.28674218      0.57290366      0.15332278    , d:   0.0000000     -0.15439966       2.0005529
 i,j,k,ie:    3    5    6          75
 Near X = -0.28674218      0.57290366      0.19200993    , d:   0.0000000     -0.15439966       2.0005529
 i,j,k,ie:    4    5    6          75
 Near X = -0.28674218      0.57290366      0.23800512    , d:   0.0000000     -0.15439966       2.0005529
 i,j,k,ie:    5    5    6          75
 Near X = -0.28674218      0.57290366      0.27669227    , d:   0.0000000     -0.15439966       2.0005529
 i,j,k,ie:    6    5    6          75
 Near X = -0.28674218      0.57290366      0.29563535    , d:  0.34546157     -0.15439966       2.0005529
 i,j,k,ie:    1    6    6          75
 Near X = -0.32491014      0.56264145      0.13437970    , d:   1.3249101     -0.54067364       2.0005529
 i,j,k,ie:    2    6    6          75
 Near X = -0.32491014      0.56264145      0.15332278    , d:   1.1904939     -0.17495163       2.0005529
 i,j,k,ie:    3    6    6          75
 Near X = -0.32491014      0.56264145      0.19200993    , d:   1.1904939     -0.17495163       2.0005529
 i,j,k,ie:    4    6    6          75
 Near X = -0.32491014      0.56264145      0.23800512    , d:   1.1904939     -0.17495163       2.0005529
 i,j,k,ie:    5    6    6          75
 Near X = -0.32491014      0.56264145      0.27669227    , d:   1.1904939     -0.17495163       2.0005529
 i,j,k,ie:    6    6    6          75
 Near X = -0.32491014      0.56264145      0.29563535    , d:   1.1904939     -0.17495163       2.0005529
 i,j,k,ie:    1    1    1          76
 Near X =  0.49985688      0.86558377      0.13437970    , d:   0.0000000      -1.6683950       2.0005727
 i,j,k,ie:    2    1    1          76
 Near X =  0.49985688      0.86558377      0.15332278    , d:   0.0000000      -1.1746703       2.0005727
 i,j,k,ie:    3    1    1          76
 Near X =  0.49985688      0.86558377      0.19200993    , d:   0.0000000      -1.1746703       2.0005727
 i,j,k,ie:    4    1    1          76
 Near X =  0.49985688      0.86558377      0.23800512    , d:   0.0000000      -1.1746703       2.0005727
 i,j,k,ie:    5    1    1          76
 Near X =  0.49985688      0.86558377      0.27669227    , d:   0.0000000      -1.1746703       2.0005727
 i,j,k,ie:    6    1    1          76
 Near X =  0.49985688      0.86558377      0.29563535    , d:   0.0000000      -1.1746703       2.0005727
 i,j,k,ie:    1    2    1          76
 Near X =  0.44113753      0.88137396      0.13437970    , d:   0.0000000     -0.49985742       2.0005727
 i,j,k,ie:    2    2    1          76
 Near X =  0.44113753      0.88137396      0.15332278    , d:   0.0000000     -0.15439815       2.0005727
 i,j,k,ie:    3    2    1          76
 Near X =  0.44113753      0.88137396      0.19200993    , d:   0.0000000     -0.15439815       2.0005727
 i,j,k,ie:    4    2    1          76
 Near X =  0.44113753      0.88137396      0.23800512    , d:   0.0000000     -0.15439815       2.0005727
 i,j,k,ie:    5    2    1          76
 Near X =  0.44113753      0.88137396      0.27669227    , d:   0.0000000     -0.15439815       2.0005727
 i,j,k,ie:    6    2    1          76
 Near X =  0.44113753      0.88137396      0.29563535    , d:   0.0000000     -0.15439815       2.0005727
 i,j,k,ie:    1    3    1          76
 Near X =  0.32121592      0.91362201      0.13437970    , d:   0.0000000     -0.49985862       2.0005727
 i,j,k,ie:    2    3    1          76
 Near X =  0.32121592      0.91362201      0.15332278    , d:   0.0000000     -0.11242558       2.0005727
 i,j,k,ie:    3    3    1          76
 Near X =  0.32121592      0.91362201      0.19200993    , d:   0.0000000     -0.11242558       2.0005727
 i,j,k,ie:    4    3    1          76
 Near X =  0.32121592      0.91362201      0.23800512    , d:   0.0000000     -0.11242558       2.0005727
 i,j,k,ie:    5    3    1          76
 Near X =  0.32121592      0.91362201      0.27669227    , d:   0.0000000     -0.11242558       2.0005727
 i,j,k,ie:    6    3    1          76
 Near X =  0.32121592      0.91362201      0.29563535    , d:   0.0000000     -0.11242558       2.0005727
 i,j,k,ie:    1    4    1          76
 Near X =  0.17864100      0.95196176      0.13437970    , d:   0.0000000     -0.49986004       2.0005727
 i,j,k,ie:    2    4    1          76
 Near X =  0.17864100      0.95196176      0.15332278    , d:   0.0000000     -0.62524354E-01   2.0005727
 i,j,k,ie:    3    4    1          76
 Near X =  0.17864100      0.95196176      0.19200993    , d:   0.0000000     -0.62524354E-01   2.0005727
 i,j,k,ie:    4    4    1          76
 Near X =  0.17864100      0.95196176      0.23800512    , d:   0.0000000     -0.62524354E-01   2.0005727
 i,j,k,ie:    5    4    1          76
 Near X =  0.17864100      0.95196176      0.27669227    , d:   0.0000000     -0.62524354E-01   2.0005727
 i,j,k,ie:    6    4    1          76
 Near X =  0.17864100      0.95196176      0.29563535    , d:   0.0000000     -0.62524354E-01   2.0005727
 i,j,k,ie:    1    5    1          76
 Near X =  0.58719391E-01  0.98420982      0.13437970    , d:   0.0000000     -0.49986123       2.0005727
 i,j,k,ie:    2    5    1          76
 Near X =  0.58719391E-01  0.98420982      0.15332278    , d:   0.0000000     -0.20551788E-01   2.0005727
 i,j,k,ie:    3    5    1          76
 Near X =  0.58719391E-01  0.98420982      0.19200993    , d:   0.0000000     -0.20551788E-01   2.0005727
 i,j,k,ie:    4    5    1          76
 Near X =  0.58719391E-01  0.98420982      0.23800512    , d:   0.0000000     -0.20551788E-01   2.0005727
 i,j,k,ie:    5    5    1          76
 Near X =  0.58719391E-01  0.98420982      0.27669227    , d:   0.0000000     -0.20551788E-01   2.0005727
 i,j,k,ie:    6    5    1          76
 Near X =  0.58719391E-01  0.98420982      0.29563535    , d:   0.0000000     -0.20551788E-01   2.0005727
 i,j,k,ie:    1    6    1          76
 Near X =  0.39356637E-07   1.0000000      0.13437970    , d:  0.86558370     -0.49986181       2.0005727
 i,j,k,ie:    2    6    1          76
 Near X =  0.39356637E-07   1.0000000      0.15332278    , d:  0.49986166     -0.13774824E-07   2.0005727
 i,j,k,ie:    3    6    1          76
 Near X =  0.39356637E-07   1.0000000      0.19200993    , d:  0.49986166     -0.13774824E-07   2.0005727
 i,j,k,ie:    4    6    1          76
 Near X =  0.39356637E-07   1.0000000      0.23800512    , d:  0.49986166     -0.13774824E-07   2.0005727
 i,j,k,ie:    5    6    1          76
 Near X =  0.39356637E-07   1.0000000      0.27669227    , d:  0.49986166     -0.13774824E-07   2.0005727
 i,j,k,ie:    6    6    1          76
 Near X =  0.39356637E-07   1.0000000      0.29563535    , d:  0.49986166     -0.13774824E-07   2.0005727
 i,j,k,ie:    1    1    2          76
 Near X =  0.47930510      0.82999501      0.13437970    , d:   0.0000000      -1.6122545       2.0005727
 i,j,k,ie:    2    1    2          76
 Near X =  0.47930510      0.82999501      0.15332278    , d:   0.0000000      -1.1335665       2.0005727
 i,j,k,ie:    3    1    2          76
 Near X =  0.47930510      0.82999501      0.19200993    , d:   0.0000000      -1.1335665       2.0005727
 i,j,k,ie:    4    1    2          76
 Near X =  0.47930510      0.82999501      0.23800512    , d:   0.0000000      -1.1335665       2.0005727
 i,j,k,ie:    5    1    2          76
 Near X =  0.47930510      0.82999501      0.27669227    , d:   0.0000000      -1.1335665       2.0005727
 i,j,k,ie:    6    1    2          76
 Near X =  0.47930510      0.82999501      0.29563535    , d:   0.0000000      -1.1335665       2.0005727
 i,j,k,ie:    1    2    2          76
 Near X =  0.42300001      0.84513598      0.13437970    , d:   0.0000000     -0.47930562       2.0005727
 i,j,k,ie:    1    3    2          76
 Near X =  0.30800902      0.87605815      0.13437970    , d:   0.0000000     -0.47930677       2.0005727
 i,j,k,ie:    1    4    2          76
 Near X =  0.17129611      0.91282155      0.13437970    , d:   0.0000000     -0.47930813       2.0005727
 i,j,k,ie:    1    5    2          76
 Near X =  0.56305124E-01  0.94374372      0.13437970    , d:   0.0000000     -0.47930927       2.0005727
 i,j,k,ie:    1    6    2          76
 Near X =  0.37738476E-07  0.95888469      0.13437970    , d:  0.82999495     -0.47930983       2.0005727
 i,j,k,ie:    2    6    2          76
 Near X =  0.37738476E-07  0.95888469      0.15332278    , d:  0.47930969       0.0000000       2.0005727
 i,j,k,ie:    3    6    2          76
 Near X =  0.37738476E-07  0.95888469      0.19200993    , d:  0.47930969       0.0000000       2.0005727
 i,j,k,ie:    4    6    2          76
 Near X =  0.37738476E-07  0.95888469      0.23800512    , d:  0.47930969       0.0000000       2.0005727
 i,j,k,ie:    5    6    2          76
 Near X =  0.37738476E-07  0.95888469      0.27669227    , d:  0.47930969       0.0000000       2.0005727
 i,j,k,ie:    6    6    2          76
 Near X =  0.37738476E-07  0.95888469      0.29563535    , d:  0.47930969       0.0000000       2.0005727
 i,j,k,ie:    1    1    3          76
 Near X =  0.43733253      0.75731266      0.13437970    , d:   0.0000000      -1.4975995       2.0005727
 i,j,k,ie:    2    1    3          76
 Near X =  0.43733253      0.75731266      0.15332278    , d:   0.0000000      -1.0496210       2.0005727
 i,j,k,ie:    3    1    3          76
 Near X =  0.43733253      0.75731266      0.19200993    , d:   0.0000000      -1.0496210       2.0005727
 i,j,k,ie:    4    1    3          76
 Near X =  0.43733253      0.75731266      0.23800512    , d:   0.0000000      -1.0496210       2.0005727
 i,j,k,ie:    5    1    3          76
 Near X =  0.43733253      0.75731266      0.27669227    , d:   0.0000000      -1.0496210       2.0005727
 i,j,k,ie:    6    1    3          76
 Near X =  0.43733253      0.75731266      0.29563535    , d:   0.0000000      -1.0496210       2.0005727
 i,j,k,ie:    1    2    3          76
 Near X =  0.38595806      0.77112774      0.13437970    , d:   0.0000000     -0.43733301       2.0005727
 i,j,k,ie:    1    3    3          76
 Near X =  0.28103679      0.79934207      0.13437970    , d:   0.0000000     -0.43733405       2.0005727
 i,j,k,ie:    1    4    3          76
 Near X =  0.15629578      0.83288611      0.13437970    , d:   0.0000000     -0.43733530       2.0005727
 i,j,k,ie:    1    5    3          76
 Near X =  0.51374505E-01  0.86110043      0.13437970    , d:   0.0000000     -0.43733634       2.0005727
 i,j,k,ie:    1    6    3          76
 Near X =  0.34433732E-07  0.87491551      0.13437970    , d:  0.75731260     -0.43733685       2.0005727
 i,j,k,ie:    2    6    3          76
 Near X =  0.34433732E-07  0.87491551      0.15332278    , d:  0.43733672       0.0000000       2.0005727
 i,j,k,ie:    3    6    3          76
 Near X =  0.34433732E-07  0.87491551      0.19200993    , d:  0.43733672       0.0000000       2.0005727
 i,j,k,ie:    4    6    3          76
 Near X =  0.34433732E-07  0.87491551      0.23800512    , d:  0.43733672       0.0000000       2.0005727
 i,j,k,ie:    5    6    3          76
 Near X =  0.34433732E-07  0.87491551      0.27669227    , d:  0.43733672       0.0000000       2.0005727
 i,j,k,ie:    6    6    3          76
 Near X =  0.34433732E-07  0.87491551      0.29563535    , d:  0.43733672       0.0000000       2.0005727
 i,j,k,ie:    1    1    4          76
 Near X =  0.38743130      0.67090053      0.13437970    , d:   0.0000000      -1.3612862       2.0005727
 i,j,k,ie:    2    1    4          76
 Near X =  0.38743130      0.67090053      0.15332278    , d:   0.0000000     -0.94981803       2.0005727
 i,j,k,ie:    3    1    4          76
 Near X =  0.38743130      0.67090053      0.19200993    , d:   0.0000000     -0.94981803       2.0005727
 i,j,k,ie:    4    1    4          76
 Near X =  0.38743130      0.67090053      0.23800512    , d:   0.0000000     -0.94981803       2.0005727
 i,j,k,ie:    5    1    4          76
 Near X =  0.38743130      0.67090053      0.27669227    , d:   0.0000000     -0.94981803       2.0005727
 i,j,k,ie:    6    1    4          76
 Near X =  0.38743130      0.67090053      0.29563535    , d:   0.0000000     -0.94981803       2.0005727
 i,j,k,ie:    1    2    4          76
 Near X =  0.34191884      0.68313926      0.13437970    , d:   0.0000000     -0.38743172       2.0005727
 i,j,k,ie:    1    3    4          76
 Near X =  0.24896947      0.70813423      0.13437970    , d:   0.0000000     -0.38743265       2.0005727
 i,j,k,ie:    1    4    4          76
 Near X =  0.13846186      0.73785077      0.13437970    , d:   0.0000000     -0.38743375       2.0005727
 i,j,k,ie:    1    5    4          76
 Near X =  0.45512488E-01  0.76284574      0.13437970    , d:   0.0000000     -0.38743467       2.0005727
 i,j,k,ie:    1    6    4          76
 Near X =  0.30504718E-07  0.77508447      0.13437970    , d:  0.67090048     -0.38743513       2.0005727
 i,j,k,ie:    2    6    4          76
 Near X =  0.30504718E-07  0.77508447      0.15332278    , d:  0.38743501       0.0000000       2.0005727
 i,j,k,ie:    3    6    4          76
 Near X =  0.30504718E-07  0.77508447      0.19200993    , d:  0.38743501       0.0000000       2.0005727
 i,j,k,ie:    4    6    4          76
 Near X =  0.30504718E-07  0.77508447      0.23800512    , d:  0.38743501       0.0000000       2.0005727
 i,j,k,ie:    5    6    4          76
 Near X =  0.30504718E-07  0.77508447      0.27669227    , d:  0.38743501       0.0000000       2.0005727
 i,j,k,ie:    6    6    4          76
 Near X =  0.30504718E-07  0.77508447      0.29563535    , d:  0.38743501       0.0000000       2.0005727
 i,j,k,ie:    1    1    5          76
 Near X =  0.34545873      0.59821818      0.13437970    , d:   0.0000000      -1.2466313       2.0005727
 i,j,k,ie:    2    1    5          76
 Near X =  0.34545873      0.59821818      0.15332278    , d:   0.0000000     -0.86587248       2.0005727
 i,j,k,ie:    3    1    5          76
 Near X =  0.34545873      0.59821818      0.19200993    , d:   0.0000000     -0.86587248       2.0005727
 i,j,k,ie:    4    1    5          76
 Near X =  0.34545873      0.59821818      0.23800512    , d:   0.0000000     -0.86587248       2.0005727
 i,j,k,ie:    5    1    5          76
 Near X =  0.34545873      0.59821818      0.27669227    , d:   0.0000000     -0.86587248       2.0005727
 i,j,k,ie:    6    1    5          76
 Near X =  0.34545873      0.59821818      0.29563535    , d:   0.0000000     -0.86587248       2.0005727
 i,j,k,ie:    1    2    5          76
 Near X =  0.30487689      0.60913102      0.13437970    , d:   0.0000000     -0.34545911       2.0005727
 i,j,k,ie:    1    3    5          76
 Near X =  0.22199724      0.63141815      0.13437970    , d:   0.0000000     -0.34545993       2.0005727
 i,j,k,ie:    1    4    5          76
 Near X =  0.12346152      0.65791533      0.13437970    , d:   0.0000000     -0.34546092       2.0005727
 i,j,k,ie:    1    5    5          76
 Near X =  0.40581869E-01  0.68020246      0.13437970    , d:   0.0000000     -0.34546174       2.0005727
 i,j,k,ie:    1    6    5          76
 Near X =  0.27199974E-07  0.69111530      0.13437970    , d:  0.59821813     -0.34546214       2.0005727
 i,j,k,ie:    2    6    5          76
 Near X =  0.27199974E-07  0.69111530      0.15332278    , d:  0.34546204       0.0000000       2.0005727
 i,j,k,ie:    3    6    5          76
 Near X =  0.27199974E-07  0.69111530      0.19200993    , d:  0.34546204       0.0000000       2.0005727
 i,j,k,ie:    4    6    5          76
 Near X =  0.27199974E-07  0.69111530      0.23800512    , d:  0.34546204       0.0000000       2.0005727
 i,j,k,ie:    5    6    5          76
 Near X =  0.27199974E-07  0.69111530      0.27669227    , d:  0.34546204       0.0000000       2.0005727
 i,j,k,ie:    6    6    5          76
 Near X =  0.27199974E-07  0.69111530      0.29563535    , d:  0.34546204       0.0000000       2.0005727
 i,j,k,ie:    1    1    6          76
 Near X =  0.32490696      0.56262942      0.13437970    , d:  0.17494992      -1.4934451       2.0005727
 i,j,k,ie:    2    1    6          76
 Near X =  0.32490696      0.56262942      0.15332278    , d:  0.17494992     -0.99972036       2.0005727
 i,j,k,ie:    3    1    6          76
 Near X =  0.32490696      0.56262942      0.19200993    , d:  0.17494992     -0.99972036       2.0005727
 i,j,k,ie:    4    1    6          76
 Near X =  0.32490696      0.56262942      0.23800512    , d:  0.17494992     -0.99972036       2.0005727
 i,j,k,ie:    5    1    6          76
 Near X =  0.32490696      0.56262942      0.27669227    , d:  0.17494992     -0.99972036       2.0005727
 i,j,k,ie:    6    1    6          76
 Near X =  0.32490696      0.56262942      0.29563535    , d:  0.17494992     -0.99972036       2.0005727
 i,j,k,ie:    1    2    6          76
 Near X =  0.28673938      0.57289305      0.13437970    , d:  0.15439815     -0.34545928       2.0005727
 i,j,k,ie:    2    2    6          76
 Near X =  0.28673938      0.57289305      0.15332278    , d:  0.15439815       0.0000000       2.0005727
 i,j,k,ie:    3    2    6          76
 Near X =  0.28673938      0.57289305      0.19200993    , d:  0.15439815       0.0000000       2.0005727
 i,j,k,ie:    4    2    6          76
 Near X =  0.28673938      0.57289305      0.23800512    , d:  0.15439815       0.0000000       2.0005727
 i,j,k,ie:    5    2    6          76
 Near X =  0.28673938      0.57289305      0.27669227    , d:  0.15439815       0.0000000       2.0005727
 i,j,k,ie:    6    2    6          76
 Near X =  0.28673938      0.57289305      0.29563535    , d:  0.15439815       0.0000000       2.0005727
 i,j,k,ie:    1    3    6          76
 Near X =  0.20879034      0.59385428      0.13437970    , d:  0.11242558     -0.38743304       2.0005727
 i,j,k,ie:    2    3    6          76
 Near X =  0.20879034      0.59385428      0.15332278    , d:  0.11242558       0.0000000       2.0005727
 i,j,k,ie:    3    3    6          76
 Near X =  0.20879034      0.59385428      0.19200993    , d:  0.11242558       0.0000000       2.0005727
 i,j,k,ie:    4    3    6          76
 Near X =  0.20879034      0.59385428      0.23800512    , d:  0.11242558       0.0000000       2.0005727
 i,j,k,ie:    5    3    6          76
 Near X =  0.20879034      0.59385428      0.27669227    , d:  0.11242558       0.0000000       2.0005727
 i,j,k,ie:    6    3    6          76
 Near X =  0.20879034      0.59385428      0.29563535    , d:  0.11242558       0.0000000       2.0005727
 i,j,k,ie:    1    4    6          76
 Near X =  0.11611664      0.61877512      0.13437970    , d:  0.62524354E-01 -0.43733568       2.0005727
 i,j,k,ie:    2    4    6          76
 Near X =  0.11611664      0.61877512      0.15332278    , d:  0.62524354E-01   0.0000000       2.0005727
 i,j,k,ie:    3    4    6          76
 Near X =  0.11611664      0.61877512      0.19200993    , d:  0.62524354E-01   0.0000000       2.0005727
 i,j,k,ie:    4    4    6          76
 Near X =  0.11611664      0.61877512      0.23800512    , d:  0.62524354E-01   0.0000000       2.0005727
 i,j,k,ie:    5    4    6          76
 Near X =  0.11611664      0.61877512      0.27669227    , d:  0.62524354E-01   0.0000000       2.0005727
 i,j,k,ie:    6    4    6          76
 Near X =  0.11611664      0.61877512      0.29563535    , d:  0.62524354E-01   0.0000000       2.0005727
 i,j,k,ie:    1    5    6          76
 Near X =  0.38167602E-01  0.63973636      0.13437970    , d:  0.20551788E-01 -0.47930944       2.0005727
 i,j,k,ie:    2    5    6          76
 Near X =  0.38167602E-01  0.63973636      0.15332278    , d:  0.20551788E-01   0.0000000       2.0005727
 i,j,k,ie:    3    5    6          76
 Near X =  0.38167602E-01  0.63973636      0.19200993    , d:  0.20551788E-01   0.0000000       2.0005727
 i,j,k,ie:    4    5    6          76
 Near X =  0.38167602E-01  0.63973636      0.23800512    , d:  0.20551788E-01   0.0000000       2.0005727
 i,j,k,ie:    5    5    6          76
 Near X =  0.38167602E-01  0.63973636      0.27669227    , d:  0.20551788E-01   0.0000000       2.0005727
 i,j,k,ie:    6    5    6          76
 Near X =  0.38167602E-01  0.63973636      0.29563535    , d:  0.20551788E-01   0.0000000       2.0005727
 i,j,k,ie:    1    6    6          76
 Near X =  0.25581813E-07  0.64999998      0.13437970    , d:  0.86558371     -0.49986180       2.0005727
 i,j,k,ie:    2    6    6          76
 Near X =  0.25581813E-07  0.64999998      0.15332278    , d:  0.49986167       0.0000000       2.0005727
 i,j,k,ie:    3    6    6          76
 Near X =  0.25581813E-07  0.64999998      0.19200993    , d:  0.49986167       0.0000000       2.0005727
 i,j,k,ie:    4    6    6          76
 Near X =  0.25581813E-07  0.64999998      0.23800512    , d:  0.49986167       0.0000000       2.0005727
 i,j,k,ie:    5    6    6          76
 Near X =  0.25581813E-07  0.64999998      0.27669227    , d:  0.49986167       0.0000000       2.0005727
 i,j,k,ie:    6    6    6          76
 Near X =  0.25581813E-07  0.64999998      0.29563535    , d:  0.49986167       0.0000000       2.0005727
 i,j,k,ie:    1    1    1          77
 Near X =  0.86560229      0.49986176      0.13437970    , d:   0.0000000      -1.8656023       1.1552650
 i,j,k,ie:    2    1    1          77
 Near X =  0.86560229      0.49986176      0.15332278    , d:   0.0000000      -1.8656023       1.1552650
 i,j,k,ie:    3    1    1          77
 Near X =  0.86560229      0.49986176      0.19200993    , d:   0.0000000      -1.8656023       1.1552650
 i,j,k,ie:    4    1    1          77
 Near X =  0.86560229      0.49986176      0.23800512    , d:   0.0000000      -1.8656023       1.1552650
 i,j,k,ie:    5    1    1          77
 Near X =  0.86560229      0.49986176      0.27669227    , d:   0.0000000      -1.8656023       1.1552650
 i,j,k,ie:    6    1    1          77
 Near X =  0.86560229      0.49986176      0.29563535    , d:  0.13439772      -1.8656023       1.1552650
 i,j,k,ie:    1    2    1          77
 Near X =  0.82263732      0.54282398      0.13437970    , d:   0.0000000     -0.28792308       1.1552650
 i,j,k,ie:    2    2    1          77
 Near X =  0.82263732      0.54282398      0.15332278    , d:   0.0000000     -0.28792308       1.1552650
 i,j,k,ie:    3    2    1          77
 Near X =  0.82263732      0.54282398      0.19200993    , d:   0.0000000     -0.28792308       1.1552650
 i,j,k,ie:    4    2    1          77
 Near X =  0.82263732      0.54282398      0.23800512    , d:   0.0000000     -0.28792308       1.1552650
 i,j,k,ie:    5    2    1          77
 Near X =  0.82263732      0.54282398      0.27669227    , d:   0.0000000     -0.28792308       1.1552650
 i,j,k,ie:    6    2    1          77
 Near X =  0.82263732      0.54282398      0.29563535    , d:  0.16157468     -0.28792308       1.1552650
 i,j,k,ie:    1    3    1          77
 Near X =  0.73489064      0.63056504      0.13437970    , d:   0.0000000     -0.25721174       1.1552650
 i,j,k,ie:    2    3    1          77
 Near X =  0.73489064      0.63056504      0.15332278    , d:   0.0000000     -0.25721174       1.1552650
 i,j,k,ie:    3    3    1          77
 Near X =  0.73489064      0.63056504      0.19200993    , d:   0.0000000     -0.25721174       1.1552650
 i,j,k,ie:    4    3    1          77
 Near X =  0.73489064      0.63056504      0.23800512    , d:   0.0000000     -0.25721174       1.1552650
 i,j,k,ie:    5    3    1          77
 Near X =  0.73489064      0.63056504      0.27669227    , d:   0.0000000     -0.25721174       1.1552650
 i,j,k,ie:    6    3    1          77
 Near X =  0.73489064      0.63056504      0.29563535    , d:  0.21707774     -0.25721174       1.1552650
 i,j,k,ie:    1    4    1          77
 Near X =  0.63056852      0.73488049      0.13437970    , d:   0.0000000     -0.22069900       1.1552650
 i,j,k,ie:    2    4    1          77
 Near X =  0.63056852      0.73488049      0.15332278    , d:   0.0000000     -0.22069900       1.1552650
 i,j,k,ie:    3    4    1          77
 Near X =  0.63056852      0.73488049      0.19200993    , d:   0.0000000     -0.22069900       1.1552650
 i,j,k,ie:    4    4    1          77
 Near X =  0.63056852      0.73488049      0.23800512    , d:   0.0000000     -0.22069900       1.1552650
 i,j,k,ie:    5    4    1          77
 Near X =  0.63056852      0.73488049      0.27669227    , d:   0.0000000     -0.22069900       1.1552650
 i,j,k,ie:    6    4    1          77
 Near X =  0.63056852      0.73488049      0.29563535    , d:  0.28306539     -0.22069900       1.1552650
 i,j,k,ie:    1    5    1          77
 Near X =  0.54282185      0.82262155      0.13437970    , d:   0.0000000     -0.18998766       1.1552650
 i,j,k,ie:    2    5    1          77
 Near X =  0.54282185      0.82262155      0.15332278    , d:   0.0000000     -0.18998766       1.1552650
 i,j,k,ie:    3    5    1          77
 Near X =  0.54282185      0.82262155      0.19200993    , d:   0.0000000     -0.18998766       1.1552650
 i,j,k,ie:    4    5    1          77
 Near X =  0.54282185      0.82262155      0.23800512    , d:   0.0000000     -0.18998766       1.1552650
 i,j,k,ie:    5    5    1          77
 Near X =  0.54282185      0.82262155      0.27669227    , d:   0.0000000     -0.18998766       1.1552650
 i,j,k,ie:    6    5    1          77
 Near X =  0.54282185      0.82262155      0.29563535    , d:  0.33856846     -0.18998766       1.1552650
 i,j,k,ie:    1    6    1          77
 Near X =  0.49985688      0.86558377      0.13437970    , d:   0.0000000     -0.49985699       1.1552650
 i,j,k,ie:    2    6    1          77
 Near X =  0.49985688      0.86558377      0.15332278    , d:   0.0000000     -0.49985699       1.1552650
 i,j,k,ie:    3    6    1          77
 Near X =  0.49985688      0.86558377      0.19200993    , d:   0.0000000     -0.49985699       1.1552650
 i,j,k,ie:    4    6    1          77
 Near X =  0.49985688      0.86558377      0.23800512    , d:   0.0000000     -0.49985699       1.1552650
 i,j,k,ie:    5    6    1          77
 Near X =  0.49985688      0.86558377      0.27669227    , d:   0.0000000     -0.49985699       1.1552650
 i,j,k,ie:    6    6    1          77
 Near X =  0.49985688      0.86558377      0.29563535    , d:  0.36574541     -0.99971378       1.1552650
 i,j,k,ie:    1    1    2          77
 Near X =  0.83001277      0.47930979      0.13437970    , d:   0.0000000      -1.7888975       1.1552650
 i,j,k,ie:    2    1    2          77
 Near X =  0.83001277      0.47930979      0.15332278    , d:   0.0000000      -1.7888975       1.1552650
 i,j,k,ie:    3    1    2          77
 Near X =  0.83001277      0.47930979      0.19200993    , d:   0.0000000      -1.7888975       1.1552650
 i,j,k,ie:    4    1    2          77
 Near X =  0.83001277      0.47930979      0.23800512    , d:   0.0000000      -1.7888975       1.1552650
 i,j,k,ie:    5    1    2          77
 Near X =  0.83001277      0.47930979      0.27669227    , d:   0.0000000      -1.7888975       1.1552650
 i,j,k,ie:    6    1    2          77
 Near X =  0.83001277      0.47930979      0.29563535    , d:  0.12887192      -1.7888975       1.1552650
 i,j,k,ie:    6    2    2          77
 Near X =  0.78881432      0.52050560      0.29563535    , d:  0.15493148       0.0000000       1.1552650
 i,j,k,ie:    6    3    2          77
 Near X =  0.70467538      0.60463916      0.29563535    , d:  0.20815252       0.0000000       1.1552650
 i,j,k,ie:    6    4    2          77
 Near X =  0.60464250      0.70466564      0.29563535    , d:  0.27142707       0.0000000       1.1552650
 i,j,k,ie:    6    5    2          77
 Near X =  0.52050355      0.78879920      0.29563535    , d:  0.32464811       0.0000000       1.1552650
 i,j,k,ie:    1    6    2          77
 Near X =  0.47930510      0.82999501      0.13437970    , d:   0.0000000     -0.47930521       1.1552650
 i,j,k,ie:    2    6    2          77
 Near X =  0.47930510      0.82999501      0.15332278    , d:   0.0000000     -0.47930521       1.1552650
 i,j,k,ie:    3    6    2          77
 Near X =  0.47930510      0.82999501      0.19200993    , d:   0.0000000     -0.47930521       1.1552650
 i,j,k,ie:    4    6    2          77
 Near X =  0.47930510      0.82999501      0.23800512    , d:   0.0000000     -0.47930521       1.1552650
 i,j,k,ie:    5    6    2          77
 Near X =  0.47930510      0.82999501      0.27669227    , d:   0.0000000     -0.47930521       1.1552650
 i,j,k,ie:    6    6    2          77
 Near X =  0.47930510      0.82999501      0.29563535    , d:  0.35070767     -0.95861023       1.1552650
 i,j,k,ie:    1    1    3          77
 Near X =  0.75732886      0.43733681      0.13437970    , d:   0.0000000      -1.6322444       1.1552650
 i,j,k,ie:    2    1    3          77
 Near X =  0.75732886      0.43733681      0.15332278    , d:   0.0000000      -1.6322444       1.1552650
 i,j,k,ie:    3    1    3          77
 Near X =  0.75732886      0.43733681      0.19200993    , d:   0.0000000      -1.6322444       1.1552650
 i,j,k,ie:    4    1    3          77
 Near X =  0.75732886      0.43733681      0.23800512    , d:   0.0000000      -1.6322444       1.1552650
 i,j,k,ie:    5    1    3          77
 Near X =  0.75732886      0.43733681      0.27669227    , d:   0.0000000      -1.6322444       1.1552650
 i,j,k,ie:    6    1    3          77
 Near X =  0.75732886      0.43733681      0.29563535    , d:  0.11758665      -1.6322444       1.1552650
 i,j,k,ie:    6    2    3          77
 Near X =  0.71973815      0.47492512      0.29563535    , d:  0.14136419       0.0000000       1.1552650
 i,j,k,ie:    6    3    3          77
 Near X =  0.64296722      0.55169113      0.29563535    , d:  0.18992468       0.0000000       1.1552650
 i,j,k,ie:    6    4    3          77
 Near X =  0.55169418      0.64295833      0.29563535    , d:  0.24765830       0.0000000       1.1552650
 i,j,k,ie:    6    5    3          77
 Near X =  0.47492325      0.71972435      0.29563535    , d:  0.29621879       0.0000000       1.1552650
 i,j,k,ie:    1    6    3          77
 Near X =  0.43733253      0.75731266      0.13437970    , d:   0.0000000     -0.43733264       1.1552650
 i,j,k,ie:    2    6    3          77
 Near X =  0.43733253      0.75731266      0.15332278    , d:   0.0000000     -0.43733264       1.1552650
 i,j,k,ie:    3    6    3          77
 Near X =  0.43733253      0.75731266      0.19200993    , d:   0.0000000     -0.43733264       1.1552650
 i,j,k,ie:    4    6    3          77
 Near X =  0.43733253      0.75731266      0.23800512    , d:   0.0000000     -0.43733264       1.1552650
 i,j,k,ie:    5    6    3          77
 Near X =  0.43733253      0.75731266      0.27669227    , d:   0.0000000     -0.43733264       1.1552650
 i,j,k,ie:    6    6    3          77
 Near X =  0.43733253      0.75731266      0.29563535    , d:  0.31999633     -0.87466509       1.1552650
 i,j,k,ie:    1    1    4          77
 Near X =  0.67091489      0.38743509      0.13437970    , d:   0.0000000      -1.4459994       1.1552650
 i,j,k,ie:    2    1    4          77
 Near X =  0.67091489      0.38743509      0.15332278    , d:   0.0000000      -1.4459994       1.1552650
 i,j,k,ie:    3    1    4          77
 Near X =  0.67091489      0.38743509      0.19200993    , d:   0.0000000      -1.4459994       1.1552650
 i,j,k,ie:    4    1    4          77
 Near X =  0.67091489      0.38743509      0.23800512    , d:   0.0000000      -1.4459994       1.1552650
 i,j,k,ie:    5    1    4          77
 Near X =  0.67091489      0.38743509      0.27669227    , d:   0.0000000      -1.4459994       1.1552650
 i,j,k,ie:    6    1    4          77
 Near X =  0.67091489      0.38743509      0.29563535    , d:  0.10416959      -1.4459994       1.1552650
 i,j,k,ie:    6    2    4          77
 Near X =  0.63761341      0.42073443      0.29563535    , d:  0.12523402       0.0000000       1.1552650
 i,j,k,ie:    6    3    4          77
 Near X =  0.56960232      0.48874117      0.29563535    , d:  0.16825358       0.0000000       1.1552650
 i,j,k,ie:    6    4    4          77
 Near X =  0.48874387      0.56959445      0.29563535    , d:  0.21939959       0.0000000       1.1552650
 i,j,k,ie:    6    5    4          77
 Near X =  0.42073278      0.63760118      0.29563535    , d:  0.26241915       0.0000000       1.1552650
 i,j,k,ie:    1    6    4          77
 Near X =  0.38743130      0.67090053      0.13437970    , d:   0.0000000     -0.38743139       1.1552650
 i,j,k,ie:    2    6    4          77
 Near X =  0.38743130      0.67090053      0.15332278    , d:   0.0000000     -0.38743139       1.1552650
 i,j,k,ie:    3    6    4          77
 Near X =  0.38743130      0.67090053      0.19200993    , d:   0.0000000     -0.38743139       1.1552650
 i,j,k,ie:    4    6    4          77
 Near X =  0.38743130      0.67090053      0.23800512    , d:   0.0000000     -0.38743139       1.1552650
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    5    6    4          77
 Near X =  0.38743130      0.67090053      0.27669227    , d:   0.0000000     -0.38743139       1.1552650
 i,j,k,ie:    6    6    4          77
 Near X =  0.38743130      0.67090053      0.29563535    , d:  0.28348359     -0.77486262       1.1552650
 i,j,k,ie:    1    1    5          77
 Near X =  0.59823098      0.34546211      0.13437970    , d:   0.0000000      -1.2893463       1.1552650
 i,j,k,ie:    2    1    5          77
 Near X =  0.59823098      0.34546211      0.15332278    , d:   0.0000000      -1.2893463       1.1552650
 i,j,k,ie:    3    1    5          77
 Near X =  0.59823098      0.34546211      0.19200993    , d:   0.0000000      -1.2893463       1.1552650
 i,j,k,ie:    4    1    5          77
 Near X =  0.59823098      0.34546211      0.23800512    , d:   0.0000000      -1.2893463       1.1552650
 i,j,k,ie:    5    1    5          77
 Near X =  0.59823098      0.34546211      0.27669227    , d:   0.0000000      -1.2893463       1.1552650
 i,j,k,ie:    6    1    5          77
 Near X =  0.59823098      0.34546211      0.29563535    , d:  0.92884321E-01  -1.2893463       1.1552650
 i,j,k,ie:    6    2    5          77
 Near X =  0.56853723      0.37515395      0.29563535    , d:  0.11166673       0.0000000       1.1552650
 i,j,k,ie:    6    3    5          77
 Near X =  0.50789416      0.43579314      0.29563535    , d:  0.15002575       0.0000000       1.1552650
 i,j,k,ie:    6    4    5          77
 Near X =  0.43579555      0.50788714      0.29563535    , d:  0.19563082       0.0000000       1.1552650
 i,j,k,ie:    6    5    5          77
 Near X =  0.37515248      0.56852633      0.29563535    , d:  0.23398984       0.0000000       1.1552650
 i,j,k,ie:    1    6    5          77
 Near X =  0.34545873      0.59821818      0.13437970    , d:   0.0000000     -0.34545881       1.1552650
 i,j,k,ie:    2    6    5          77
 Near X =  0.34545873      0.59821818      0.15332278    , d:   0.0000000     -0.34545881       1.1552650
 i,j,k,ie:    3    6    5          77
 Near X =  0.34545873      0.59821818      0.19200993    , d:   0.0000000     -0.34545881       1.1552650
 i,j,k,ie:    4    6    5          77
 Near X =  0.34545873      0.59821818      0.23800512    , d:   0.0000000     -0.34545881       1.1552650
 i,j,k,ie:    5    6    5          77
 Near X =  0.34545873      0.59821818      0.27669227    , d:   0.0000000     -0.34545881       1.1552650
 i,j,k,ie:    6    6    5          77
 Near X =  0.34545873      0.59821818      0.29563535    , d:  0.25277225     -0.69091748       1.1552650
 i,j,k,ie:    1    1    6          77
 Near X =  0.56264146      0.32491013      0.13437970    , d:  0.30296082      -1.5626415       1.1552650
 i,j,k,ie:    2    1    6          77
 Near X =  0.56264146      0.32491013      0.15332278    , d:  0.30296082      -1.5626415       1.1552650
 i,j,k,ie:    3    1    6          77
 Near X =  0.56264146      0.32491013      0.19200993    , d:  0.30296082      -1.5626415       1.1552650
 i,j,k,ie:    4    1    6          77
 Near X =  0.56264146      0.32491013      0.23800512    , d:  0.30296082      -1.5626415       1.1552650
 i,j,k,ie:    5    1    6          77
 Near X =  0.56264146      0.32491013      0.27669227    , d:  0.30296082      -1.5626415       1.1552650
 i,j,k,ie:    6    1    6          77
 Near X =  0.56264146      0.32491013      0.29563535    , d:  0.43735855      -1.5626415       1.1552650
 i,j,k,ie:    1    2    6          77
 Near X =  0.53471424      0.35283557      0.13437970    , d:  0.28792308       0.0000000       1.1552650
 i,j,k,ie:    2    2    6          77
 Near X =  0.53471424      0.35283557      0.15332278    , d:  0.28792308       0.0000000       1.1552650
 i,j,k,ie:    3    2    6          77
 Near X =  0.53471424      0.35283557      0.19200993    , d:  0.28792308       0.0000000       1.1552650
 i,j,k,ie:    4    2    6          77
 Near X =  0.53471424      0.35283557      0.23800512    , d:  0.28792308       0.0000000       1.1552650
 i,j,k,ie:    5    2    6          77
 Near X =  0.53471424      0.35283557      0.27669227    , d:  0.28792308       0.0000000       1.1552650
 i,j,k,ie:    6    2    6          77
 Near X =  0.53471424      0.35283557      0.29563535    , d:  0.44949776       0.0000000       1.1552650
 i,j,k,ie:    1    3    6          77
 Near X =  0.47767890      0.40986726      0.13437970    , d:  0.25721174       0.0000000       1.1552650
 i,j,k,ie:    2    3    6          77
 Near X =  0.47767890      0.40986726      0.15332278    , d:  0.25721174       0.0000000       1.1552650
 i,j,k,ie:    3    3    6          77
 Near X =  0.47767890      0.40986726      0.19200993    , d:  0.25721174       0.0000000       1.1552650
 i,j,k,ie:    4    3    6          77
 Near X =  0.47767890      0.40986726      0.23800512    , d:  0.25721174       0.0000000       1.1552650
 i,j,k,ie:    5    3    6          77
 Near X =  0.47767890      0.40986726      0.27669227    , d:  0.25721174       0.0000000       1.1552650
 i,j,k,ie:    6    3    6          77
 Near X =  0.47767890      0.40986726      0.29563535    , d:  0.47428948       0.0000000       1.1552650
 i,j,k,ie:    1    4    6          77
 Near X =  0.40986952      0.47767229      0.13437970    , d:  0.22069900       0.0000000       1.1552650
 i,j,k,ie:    2    4    6          77
 Near X =  0.40986952      0.47767229      0.15332278    , d:  0.22069900       0.0000000       1.1552650
 i,j,k,ie:    3    4    6          77
 Near X =  0.40986952      0.47767229      0.19200993    , d:  0.22069900       0.0000000       1.1552650
 i,j,k,ie:    4    4    6          77
 Near X =  0.40986952      0.47767229      0.23800512    , d:  0.22069900       0.0000000       1.1552650
 i,j,k,ie:    5    4    6          77
 Near X =  0.40986952      0.47767229      0.27669227    , d:  0.22069900       0.0000000       1.1552650
 i,j,k,ie:    6    4    6          77
 Near X =  0.40986952      0.47767229      0.29563535    , d:  0.50376439       0.0000000       1.1552650
 i,j,k,ie:    1    5    6          77
 Near X =  0.35283418      0.53470398      0.13437970    , d:  0.18998766       0.0000000       1.1552650
 i,j,k,ie:    2    5    6          77
 Near X =  0.35283418      0.53470398      0.15332278    , d:  0.18998766       0.0000000       1.1552650
 i,j,k,ie:    3    5    6          77
 Near X =  0.35283418      0.53470398      0.19200993    , d:  0.18998766       0.0000000       1.1552650
 i,j,k,ie:    4    5    6          77
 Near X =  0.35283418      0.53470398      0.23800512    , d:  0.18998766       0.0000000       1.1552650
 i,j,k,ie:    5    5    6          77
 Near X =  0.35283418      0.53470398      0.27669227    , d:  0.18998766       0.0000000       1.1552650
 i,j,k,ie:    6    5    6          77
 Near X =  0.35283418      0.53470398      0.29563535    , d:  0.52855612       0.0000000       1.1552650
 i,j,k,ie:    1    6    6          77
 Near X =  0.32490696      0.56262942      0.13437970    , d:  0.17494992     -0.32490707       1.1552650
 i,j,k,ie:    2    6    6          77
 Near X =  0.32490696      0.56262942      0.15332278    , d:  0.17494992     -0.32490707       1.1552650
 i,j,k,ie:    3    6    6          77
 Near X =  0.32490696      0.56262942      0.19200993    , d:  0.17494992     -0.32490707       1.1552650
 i,j,k,ie:    4    6    6          77
 Near X =  0.32490696      0.56262942      0.23800512    , d:  0.17494992     -0.32490707       1.1552650
 i,j,k,ie:    5    6    6          77
 Near X =  0.32490696      0.56262942      0.27669227    , d:  0.17494992     -0.32490707       1.1552650
 i,j,k,ie:    6    6    6          77
 Near X =  0.32490696      0.56262942      0.29563535    , d:  0.54069533     -0.82476386       1.1552650
 i,j,k,ie:    1    1    1          78
 Near X =   1.0000000     -0.46163286E-07  0.13437970    , d:   0.0000000      -2.0000000      0.99999999
 i,j,k,ie:    2    1    1          78
 Near X =   1.0000000     -0.46163286E-07  0.15332278    , d:   0.0000000      -1.8655838      0.99999999
 i,j,k,ie:    3    1    1          78
 Near X =   1.0000000     -0.46163286E-07  0.19200993    , d:   0.0000000      -1.8655838      0.99999999
 i,j,k,ie:    4    1    1          78
 Near X =   1.0000000     -0.46163286E-07  0.23800512    , d:   0.0000000      -1.8655838      0.99999999
 i,j,k,ie:    5    1    1          78
 Near X =   1.0000000     -0.46163286E-07  0.27669227    , d:   0.0000000      -1.8655838      0.99999999
 i,j,k,ie:    6    1    1          78
 Near X =   1.0000000     -0.46163286E-07  0.29563535    , d:   0.0000000      -1.8655838      0.99999999
 i,j,k,ie:    1    2    1          78
 Near X =  0.98421199      0.58719889E-01  0.13437970    , d:   0.0000000     -0.44949776      0.99999999
 i,j,k,ie:    2    2    1          78
 Near X =  0.98421199      0.58719889E-01  0.15332278    , d:   0.0000000     -0.34447422      0.99999999
 i,j,k,ie:    3    2    1          78
 Near X =  0.98421199      0.58719889E-01  0.19200993    , d:   0.0000000     -0.34447422      0.99999999
 i,j,k,ie:    4    2    1          78
 Near X =  0.98421199      0.58719889E-01  0.23800512    , d:   0.0000000     -0.34447422      0.99999999
 i,j,k,ie:    5    2    1          78
 Near X =  0.98421199      0.58719889E-01  0.27669227    , d:   0.0000000     -0.34447422      0.99999999
 i,j,k,ie:    6    2    1          78
 Near X =  0.98421199      0.58719889E-01  0.29563535    , d:   0.0000000     -0.41131896      0.99999999
 i,j,k,ie:    1    3    1          78
 Near X =  0.95196838      0.17864269      0.13437970    , d:   0.0000000     -0.47428948      0.99999999
 i,j,k,ie:    2    3    1          78
 Near X =  0.95196838      0.17864269      0.15332278    , d:   0.0000000     -0.33318896      0.99999999
 i,j,k,ie:    3    3    1          78
 Near X =  0.95196838      0.17864269      0.19200993    , d:   0.0000000     -0.33318896      0.99999999
 i,j,k,ie:    4    3    1          78
 Near X =  0.95196838      0.17864269      0.23800512    , d:   0.0000000     -0.33318896      0.99999999
 i,j,k,ie:    5    3    1          78
 Near X =  0.95196838      0.17864269      0.27669227    , d:   0.0000000     -0.33318896      0.99999999
 i,j,k,ie:    6    3    1          78
 Near X =  0.95196838      0.17864269      0.29563535    , d:   0.0000000     -0.35811411      0.99999999
 i,j,k,ie:    1    4    1          78
 Near X =  0.91363392      0.32121903      0.13437970    , d:   0.0000000     -0.50376439      0.99999999
 i,j,k,ie:    2    4    1          78
 Near X =  0.91363392      0.32121903      0.15332278    , d:   0.0000000     -0.31977190      0.99999999
 i,j,k,ie:    3    4    1          78
 Near X =  0.91363392      0.32121903      0.19200993    , d:   0.0000000     -0.31977190      0.99999999
 i,j,k,ie:    4    4    1          78
 Near X =  0.91363392      0.32121903      0.23800512    , d:   0.0000000     -0.31977190      0.99999999
 i,j,k,ie:    5    4    1          78
 Near X =  0.91363392      0.32121903      0.27669227    , d:   0.0000000     -0.31977190      0.99999999
 i,j,k,ie:    6    4    1          78
 Near X =  0.91363392      0.32121903      0.29563535    , d:  0.38327837E-01 -0.31977190      0.99999999
 i,j,k,ie:    1    5    1          78
 Near X =  0.88139030      0.44114183      0.13437970    , d:   0.0000000     -0.52855612      0.99999999
 i,j,k,ie:    2    5    1          78
 Near X =  0.88139030      0.44114183      0.15332278    , d:   0.0000000     -0.30848663      0.99999999
 i,j,k,ie:    3    5    1          78
 Near X =  0.88139030      0.44114183      0.19200993    , d:   0.0000000     -0.30848663      0.99999999
 i,j,k,ie:    4    5    1          78
 Near X =  0.88139030      0.44114183      0.23800512    , d:   0.0000000     -0.30848663      0.99999999
 i,j,k,ie:    5    5    1          78
 Near X =  0.88139030      0.44114183      0.27669227    , d:   0.0000000     -0.30848663      0.99999999
 i,j,k,ie:    6    5    1          78
 Near X =  0.88139030      0.44114183      0.29563535    , d:  0.10281951     -0.30848663      0.99999999
 i,j,k,ie:    1    6    1          78
 Near X =  0.86560229      0.49986176      0.13437970    , d:   0.0000000      -1.3654592      0.99999999
 i,j,k,ie:    2    6    1          78
 Near X =  0.86560229      0.49986176      0.15332278    , d:   0.0000000      -1.3654592      0.99999999
 i,j,k,ie:    3    6    1          78
 Near X =  0.86560229      0.49986176      0.19200993    , d:   0.0000000      -1.3654592      0.99999999
 i,j,k,ie:    4    6    1          78
 Near X =  0.86560229      0.49986176      0.23800512    , d:   0.0000000      -1.3654592      0.99999999
 i,j,k,ie:    5    6    1          78
 Near X =  0.86560229      0.49986176      0.27669227    , d:   0.0000000      -1.3654592      0.99999999
 i,j,k,ie:    6    6    1          78
 Near X =  0.86560229      0.49986176      0.29563535    , d:  0.13439772      -1.7312046      0.99999999
 i,j,k,ie:    1    1    2          78
 Near X =  0.95888469     -0.45029985E-07  0.13437970    , d:   0.0000000      -1.9177694      0.99999999
 i,j,k,ie:    2    1    2          78
 Near X =  0.95888469     -0.45029985E-07  0.15332278    , d:   0.0000000      -1.7888797      0.99999999
 i,j,k,ie:    3    1    2          78
 Near X =  0.95888469     -0.45029985E-07  0.19200993    , d:   0.0000000      -1.7888797      0.99999999
 i,j,k,ie:    4    1    2          78
 Near X =  0.95888469     -0.45029985E-07  0.23800512    , d:   0.0000000      -1.7888797      0.99999999
 i,j,k,ie:    5    1    2          78
 Near X =  0.95888469     -0.45029985E-07  0.27669227    , d:   0.0000000      -1.7888797      0.99999999
 i,j,k,ie:    6    1    2          78
 Near X =  0.95888469     -0.45029985E-07  0.29563535    , d:   0.0000000      -1.7888797      0.99999999
 i,j,k,ie:    1    2    2          78
 Near X =  0.94374580      0.56305601E-01  0.13437970    , d:   0.0000000     -0.15493148      0.99999999
 i,j,k,ie:    6    2    2          78
 Near X =  0.94374580      0.56305601E-01  0.29563535    , d:   0.0000000     -0.98609841E-01  0.99999999
 i,j,k,ie:    1    3    2          78
 Near X =  0.91282790      0.17129774      0.13437970    , d:   0.0000000     -0.20815252      0.99999999
 i,j,k,ie:    6    3    2          78
 Near X =  0.91282790      0.17129774      0.29563535    , d:   0.0000000     -0.36769761E-01  0.99999999
 i,j,k,ie:    1    4    2          78
 Near X =  0.87606956      0.30801201      0.13437970    , d:   0.0000000     -0.27142707      0.99999999
 i,j,k,ie:    6    4    2          78
 Near X =  0.87606956      0.30801201      0.29563535    , d:  0.36751976E-01   0.0000000      0.99999999
 i,j,k,ie:    1    5    2          78
 Near X =  0.84515166      0.42300414      0.13437970    , d:   0.0000000     -0.32464811      0.99999999
 i,j,k,ie:    6    5    2          78
 Near X =  0.84515166      0.42300414      0.29563535    , d:  0.98592056E-01   0.0000000      0.99999999
 i,j,k,ie:    1    6    2          78
 Near X =  0.83001277      0.47930979      0.13437970    , d:   0.0000000      -1.3093179      0.99999999
 i,j,k,ie:    2    6    2          78
 Near X =  0.83001277      0.47930979      0.15332278    , d:   0.0000000      -1.3093179      0.99999999
 i,j,k,ie:    3    6    2          78
 Near X =  0.83001277      0.47930979      0.19200993    , d:   0.0000000      -1.3093179      0.99999999
 i,j,k,ie:    4    6    2          78
 Near X =  0.83001277      0.47930979      0.23800512    , d:   0.0000000      -1.3093179      0.99999999
 i,j,k,ie:    5    6    2          78
 Near X =  0.83001277      0.47930979      0.27669227    , d:   0.0000000      -1.3093179      0.99999999
 i,j,k,ie:    6    6    2          78
 Near X =  0.83001277      0.47930979      0.29563535    , d:  0.12887192      -1.6600255      0.99999999
 i,j,k,ie:    1    1    3          78
 Near X =  0.87491551     -0.42715462E-07  0.13437970    , d:   0.0000000      -1.7498310      0.99999999
 i,j,k,ie:    2    1    3          78
 Near X =  0.87491551     -0.42715462E-07  0.15332278    , d:   0.0000000      -1.6322282      0.99999999
 i,j,k,ie:    3    1    3          78
 Near X =  0.87491551     -0.42715462E-07  0.19200993    , d:   0.0000000      -1.6322282      0.99999999
 i,j,k,ie:    4    1    3          78
 Near X =  0.87491551     -0.42715462E-07  0.23800512    , d:   0.0000000      -1.6322282      0.99999999
 i,j,k,ie:    5    1    3          78
 Near X =  0.87491551     -0.42715462E-07  0.27669227    , d:   0.0000000      -1.6322282      0.99999999
 i,j,k,ie:    6    1    3          78
 Near X =  0.87491551     -0.42715462E-07  0.29563535    , d:   0.0000000      -1.6322282      0.99999999
 i,j,k,ie:    1    2    3          78
 Near X =  0.86110234      0.51374939E-01  0.13437970    , d:   0.0000000     -0.14136419      0.99999999
 i,j,k,ie:    6    2    3          78
 Near X =  0.86110234      0.51374939E-01  0.29563535    , d:   0.0000000     -0.89974615E-01  0.99999999
 i,j,k,ie:    1    3    3          78
 Near X =  0.83289190      0.15629726      0.13437970    , d:   0.0000000     -0.18992468      0.99999999
 i,j,k,ie:    6    3    3          78
 Near X =  0.83289190      0.15629726      0.29563535    , d:   0.0000000     -0.33549847E-01  0.99999999
 i,j,k,ie:    1    4    3          78
 Near X =  0.79935248      0.28103951      0.13437970    , d:   0.0000000     -0.24765830      0.99999999
 i,j,k,ie:    6    4    3          78
 Near X =  0.79935248      0.28103951      0.29563535    , d:  0.33533619E-01   0.0000000      0.99999999
 i,j,k,ie:    1    5    3          78
 Near X =  0.77114204      0.38596182      0.13437970    , d:   0.0000000     -0.29621879      0.99999999
 i,j,k,ie:    6    5    3          78
 Near X =  0.77114204      0.38596182      0.29563535    , d:  0.89958387E-01   0.0000000      0.99999999
 i,j,k,ie:    1    6    3          78
 Near X =  0.75732886      0.43733681      0.13437970    , d:   0.0000000      -1.1946614      0.99999999
 i,j,k,ie:    2    6    3          78
 Near X =  0.75732886      0.43733681      0.15332278    , d:   0.0000000      -1.1946614      0.99999999
 i,j,k,ie:    3    6    3          78
 Near X =  0.75732886      0.43733681      0.19200993    , d:   0.0000000      -1.1946614      0.99999999
 i,j,k,ie:    4    6    3          78
 Near X =  0.75732886      0.43733681      0.23800512    , d:   0.0000000      -1.1946614      0.99999999
 i,j,k,ie:    5    6    3          78
 Near X =  0.75732886      0.43733681      0.27669227    , d:   0.0000000      -1.1946614      0.99999999
 i,j,k,ie:    6    6    3          78
 Near X =  0.75732886      0.43733681      0.29563535    , d:  0.11758665      -1.5146577      0.99999999
 i,j,k,ie:    1    1    4          78
 Near X =  0.77508447     -0.39963724E-07  0.13437970    , d:   0.0000000      -1.5501689      0.99999999
 i,j,k,ie:    2    1    4          78
 Near X =  0.77508447     -0.39963724E-07  0.15332278    , d:   0.0000000      -1.4459850      0.99999999
 i,j,k,ie:    3    1    4          78
 Near X =  0.77508447     -0.39963724E-07  0.19200993    , d:   0.0000000      -1.4459850      0.99999999
 i,j,k,ie:    4    1    4          78
 Near X =  0.77508447     -0.39963724E-07  0.23800512    , d:   0.0000000      -1.4459850      0.99999999
 i,j,k,ie:    5    1    4          78
 Near X =  0.77508447     -0.39963724E-07  0.27669227    , d:   0.0000000      -1.4459850      0.99999999
 i,j,k,ie:    6    1    4          78
 Near X =  0.77508447     -0.39963724E-07  0.29563535    , d:   0.0000000      -1.4459850      0.99999999
 i,j,k,ie:    1    2    4          78
 Near X =  0.76284743      0.45512870E-01  0.13437970    , d:   0.0000000     -0.12523402      0.99999999
 i,j,k,ie:    6    2    4          78
 Near X =  0.76284743      0.45512870E-01  0.29563535    , d:   0.0000000     -0.79708184E-01  0.99999999
 i,j,k,ie:    1    3    4          78
 Near X =  0.73785591      0.13846317      0.13437970    , d:   0.0000000     -0.16825358      0.99999999
 i,j,k,ie:    6    3    4          78
 Near X =  0.73785591      0.13846317      0.29563535    , d:   0.0000000     -0.29721687E-01  0.99999999
 i,j,k,ie:    1    4    4          78
 Near X =  0.70814346      0.24897188      0.13437970    , d:   0.0000000     -0.21939959      0.99999999
 i,j,k,ie:    6    4    4          78
 Near X =  0.70814346      0.24897188      0.29563535    , d:  0.29707311E-01   0.0000000      0.99999999
 i,j,k,ie:    1    5    4          78
 Near X =  0.68315193      0.34192218      0.13437970    , d:   0.0000000     -0.26241915      0.99999999
 i,j,k,ie:    6    5    4          78
 Near X =  0.68315193      0.34192218      0.29563535    , d:  0.79693808E-01   0.0000000      0.99999999
 i,j,k,ie:    1    6    4          78
 Near X =  0.67091489      0.38743509      0.13437970    , d:   0.0000000      -1.0583462      0.99999999
 i,j,k,ie:    2    6    4          78
 Near X =  0.67091489      0.38743509      0.15332278    , d:   0.0000000      -1.0583462      0.99999999
 i,j,k,ie:    3    6    4          78
 Near X =  0.67091489      0.38743509      0.19200993    , d:   0.0000000      -1.0583462      0.99999999
 i,j,k,ie:    4    6    4          78
 Near X =  0.67091489      0.38743509      0.23800512    , d:   0.0000000      -1.0583462      0.99999999
 i,j,k,ie:    5    6    4          78
 Near X =  0.67091489      0.38743509      0.27669227    , d:   0.0000000      -1.0583462      0.99999999
 i,j,k,ie:    6    6    4          78
 Near X =  0.67091489      0.38743509      0.29563535    , d:  0.10416959      -1.3418298      0.99999999
 i,j,k,ie:    1    1    5          78
 Near X =  0.69111530     -0.37649202E-07  0.13437970    , d:   0.0000000      -1.3822306      0.99999999
 i,j,k,ie:    2    1    5          78
 Near X =  0.69111530     -0.37649202E-07  0.15332278    , d:   0.0000000      -1.2893335      0.99999999
 i,j,k,ie:    3    1    5          78
 Near X =  0.69111530     -0.37649202E-07  0.19200993    , d:   0.0000000      -1.2893335      0.99999999
 i,j,k,ie:    4    1    5          78
 Near X =  0.69111530     -0.37649202E-07  0.23800512    , d:   0.0000000      -1.2893335      0.99999999
 i,j,k,ie:    5    1    5          78
 Near X =  0.69111530     -0.37649202E-07  0.27669227    , d:   0.0000000      -1.2893335      0.99999999
 i,j,k,ie:    6    1    5          78
 Near X =  0.69111530     -0.37649202E-07  0.29563535    , d:   0.0000000      -1.2893335      0.99999999
 i,j,k,ie:    1    2    5          78
 Near X =  0.68020396      0.40582208E-01  0.13437970    , d:   0.0000000     -0.11166673      0.99999999
 i,j,k,ie:    6    2    5          78
 Near X =  0.68020396      0.40582208E-01  0.29563535    , d:   0.0000000     -0.71072957E-01  0.99999999
 i,j,k,ie:    1    3    5          78
 Near X =  0.65791991      0.12346269      0.13437970    , d:   0.0000000     -0.15002575      0.99999999
 i,j,k,ie:    6    3    5          78
 Near X =  0.65791991      0.12346269      0.29563535    , d:   0.0000000     -0.26501773E-01  0.99999999
 i,j,k,ie:    1    4    5          78
 Near X =  0.63142637      0.22199938      0.13437970    , d:   0.0000000     -0.19563082      0.99999999
 i,j,k,ie:    6    4    5          78
 Near X =  0.63142637      0.22199938      0.29563535    , d:  0.26488955E-01   0.0000000      0.99999999
 i,j,k,ie:    1    5    5          78
 Near X =  0.60914232      0.30487986      0.13437970    , d:   0.0000000     -0.23398984      0.99999999
 i,j,k,ie:    6    5    5          78
 Near X =  0.60914232      0.30487986      0.29563535    , d:  0.71060138E-01   0.0000000      0.99999999
 i,j,k,ie:    1    6    5          78
 Near X =  0.59823098      0.34546211      0.13437970    , d:   0.0000000     -0.94368973      0.99999999
 i,j,k,ie:    2    6    5          78
 Near X =  0.59823098      0.34546211      0.15332278    , d:   0.0000000     -0.94368973      0.99999999
 i,j,k,ie:    3    6    5          78
 Near X =  0.59823098      0.34546211      0.19200993    , d:   0.0000000     -0.94368973      0.99999999
 i,j,k,ie:    4    6    5          78
 Near X =  0.59823098      0.34546211      0.23800512    , d:   0.0000000     -0.94368973      0.99999999
 i,j,k,ie:    5    6    5          78
 Near X =  0.59823098      0.34546211      0.27669227    , d:   0.0000000     -0.94368973      0.99999999
 i,j,k,ie:    6    6    5          78
 Near X =  0.59823098      0.34546211      0.29563535    , d:  0.92884321E-01  -1.1964619      0.99999999
 i,j,k,ie:    1    1    6          78
 Near X =  0.64999998     -0.36515901E-07  0.13437970    , d:  0.35000003      -1.6500000      0.99999999
 i,j,k,ie:    2    1    6          78
 Near X =  0.64999998     -0.36515901E-07  0.15332278    , d:  0.35000003      -1.5155838      0.99999999
 i,j,k,ie:    3    1    6          78
 Near X =  0.64999998     -0.36515901E-07  0.19200993    , d:  0.35000003      -1.5155838      0.99999999
 i,j,k,ie:    4    1    6          78
 Near X =  0.64999998     -0.36515901E-07  0.23800512    , d:  0.35000003      -1.5155838      0.99999999
 i,j,k,ie:    5    1    6          78
 Near X =  0.64999998     -0.36515901E-07  0.27669227    , d:  0.35000003      -1.5155838      0.99999999
 i,j,k,ie:    6    1    6          78
 Near X =  0.64999998     -0.36515901E-07  0.29563535    , d:  0.35000003      -1.5155838      0.99999999
 i,j,k,ie:    1    2    6          78
 Near X =  0.63973777      0.38167920E-01  0.13437970    , d:  0.34447422     -0.10502353      0.99999999
 i,j,k,ie:    2    2    6          78
 Near X =  0.63973777      0.38167920E-01  0.15332278    , d:  0.34447422       0.0000000      0.99999999
 i,j,k,ie:    3    2    6          78
 Near X =  0.63973777      0.38167920E-01  0.19200993    , d:  0.34447422       0.0000000      0.99999999
 i,j,k,ie:    4    2    6          78
 Near X =  0.63973777      0.38167920E-01  0.23800512    , d:  0.34447422       0.0000000      0.99999999
 i,j,k,ie:    5    2    6          78
 Near X =  0.63973777      0.38167920E-01  0.27669227    , d:  0.34447422       0.0000000      0.99999999
 i,j,k,ie:    6    2    6          78
 Near X =  0.63973777      0.38167920E-01  0.29563535    , d:  0.34447422     -0.66844737E-01  0.99999999
 i,j,k,ie:    1    3    6          78
 Near X =  0.61877942      0.11611774      0.13437970    , d:  0.33318896     -0.14110053      0.99999999
 i,j,k,ie:    2    3    6          78
 Near X =  0.61877942      0.11611774      0.15332278    , d:  0.33318896       0.0000000      0.99999999
 i,j,k,ie:    3    3    6          78
 Near X =  0.61877942      0.11611774      0.19200993    , d:  0.33318896       0.0000000      0.99999999
 i,j,k,ie:    4    3    6          78
 Near X =  0.61877942      0.11611774      0.23800512    , d:  0.33318896       0.0000000      0.99999999
 i,j,k,ie:    5    3    6          78
 Near X =  0.61877942      0.11611774      0.27669227    , d:  0.33318896       0.0000000      0.99999999
 i,j,k,ie:    6    3    6          78
 Near X =  0.61877942      0.11611774      0.29563535    , d:  0.33318896     -0.24925149E-01  0.99999999
 i,j,k,ie:    1    4    6          78
 Near X =  0.59386202      0.20879236      0.13437970    , d:  0.31977190     -0.18399250      0.99999999
 i,j,k,ie:    2    4    6          78
 Near X =  0.59386202      0.20879236      0.15332278    , d:  0.31977190       0.0000000      0.99999999
 i,j,k,ie:    3    4    6          78
 Near X =  0.59386202      0.20879236      0.19200993    , d:  0.31977190       0.0000000      0.99999999
 i,j,k,ie:    4    4    6          78
 Near X =  0.59386202      0.20879236      0.23800512    , d:  0.31977190       0.0000000      0.99999999
 i,j,k,ie:    5    4    6          78
 Near X =  0.59386202      0.20879236      0.27669227    , d:  0.31977190       0.0000000      0.99999999
 i,j,k,ie:    6    4    6          78
 Near X =  0.59386202      0.20879236      0.29563535    , d:  0.35809973       0.0000000      0.99999999
 i,j,k,ie:    1    5    6          78
 Near X =  0.57290367      0.28674217      0.13437970    , d:  0.30848663     -0.22006949      0.99999999
 i,j,k,ie:    2    5    6          78
 Near X =  0.57290367      0.28674217      0.15332278    , d:  0.30848663       0.0000000      0.99999999
 i,j,k,ie:    3    5    6          78
 Near X =  0.57290367      0.28674217      0.19200993    , d:  0.30848663       0.0000000      0.99999999
 i,j,k,ie:    4    5    6          78
 Near X =  0.57290367      0.28674217      0.23800512    , d:  0.30848663       0.0000000      0.99999999
 i,j,k,ie:    5    5    6          78
 Near X =  0.57290367      0.28674217      0.27669227    , d:  0.30848663       0.0000000      0.99999999
 i,j,k,ie:    6    5    6          78
 Near X =  0.57290367      0.28674217      0.29563535    , d:  0.41130614       0.0000000      0.99999999
 i,j,k,ie:    1    6    6          78
 Near X =  0.56264146      0.32491013      0.13437970    , d:  0.30296082      -1.0624984      0.99999999
 i,j,k,ie:    2    6    6          78
 Near X =  0.56264146      0.32491013      0.15332278    , d:  0.30296082      -1.0624984      0.99999999
 i,j,k,ie:    3    6    6          78
 Near X =  0.56264146      0.32491013      0.19200993    , d:  0.30296082      -1.0624984      0.99999999
 i,j,k,ie:    4    6    6          78
 Near X =  0.56264146      0.32491013      0.23800512    , d:  0.30296082      -1.0624984      0.99999999
 i,j,k,ie:    5    6    6          78
 Near X =  0.56264146      0.32491013      0.27669227    , d:  0.30296082      -1.0624984      0.99999999
 i,j,k,ie:    6    6    6          78
 Near X =  0.56264146      0.32491013      0.29563535    , d:  0.43735855      -1.4282437      0.99999999
 i,j,k,ie:    1    1    1          79
 Near X =  0.86558374     -0.49985689      0.13437970    , d:  0.13441627      -1.7311675      0.99999999
 i,j,k,ie:    2    1    1          79
 Near X =  0.86558374     -0.49985689      0.15332278    , d:   0.0000000      -1.3654455      0.99999999
 i,j,k,ie:    3    1    1          79
 Near X =  0.86558374     -0.49985689      0.19200993    , d:   0.0000000      -1.3654455      0.99999999
 i,j,k,ie:    4    1    1          79
 Near X =  0.86558374     -0.49985689      0.23800512    , d:   0.0000000      -1.3654455      0.99999999
 i,j,k,ie:    5    1    1          79
 Near X =  0.86558374     -0.49985689      0.27669227    , d:   0.0000000      -1.3654455      0.99999999
 i,j,k,ie:    6    1    1          79
 Near X =  0.86558374     -0.49985689      0.29563535    , d:   0.0000000      -1.3654455      0.99999999
 i,j,k,ie:    1    2    1          79
 Near X =  0.88137393     -0.44113754      0.13437970    , d:  0.10283806     -0.30848090      0.99999999
 i,j,k,ie:    2    2    1          79
 Near X =  0.88137393     -0.44113754      0.15332278    , d:   0.0000000     -0.30848090      0.99999999
 i,j,k,ie:    3    2    1          79
 Near X =  0.88137393     -0.44113754      0.19200993    , d:   0.0000000     -0.30848090      0.99999999
 i,j,k,ie:    4    2    1          79
 Near X =  0.88137393     -0.44113754      0.23800512    , d:   0.0000000     -0.30848090      0.99999999
 i,j,k,ie:    5    2    1          79
 Near X =  0.88137393     -0.44113754      0.27669227    , d:   0.0000000     -0.30848090      0.99999999
 i,j,k,ie:    6    2    1          79
 Near X =  0.88137393     -0.44113754      0.29563535    , d:   0.0000000     -0.52853840      0.99999999
 i,j,k,ie:    1    3    1          79
 Near X =  0.91362200     -0.32121593      0.13437970    , d:  0.38346385E-01 -0.31976772      0.99999999
 i,j,k,ie:    2    3    1          79
 Near X =  0.91362200     -0.32121593      0.15332278    , d:   0.0000000     -0.31976772      0.99999999
 i,j,k,ie:    3    3    1          79
 Near X =  0.91362200     -0.32121593      0.19200993    , d:   0.0000000     -0.31976772      0.99999999
 i,j,k,ie:    4    3    1          79
 Near X =  0.91362200     -0.32121593      0.23800512    , d:   0.0000000     -0.31976772      0.99999999
 i,j,k,ie:    5    3    1          79
 Near X =  0.91362200     -0.32121593      0.27669227    , d:   0.0000000     -0.31976772      0.99999999
 i,j,k,ie:    6    3    1          79
 Near X =  0.91362200     -0.32121593      0.29563535    , d:   0.0000000     -0.50375477      0.99999999
 i,j,k,ie:    1    4    1          79
 Near X =  0.95196175     -0.17864100      0.13437970    , d:   0.0000000     -0.35809973      0.99999999
 i,j,k,ie:    2    4    1          79
 Near X =  0.95196175     -0.17864100      0.15332278    , d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    3    4    1          79
 Near X =  0.95196175     -0.17864100      0.19200993    , d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    4    4    1          79
 Near X =  0.95196175     -0.17864100      0.23800512    , d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    5    4    1          79
 Near X =  0.95196175     -0.17864100      0.27669227    , d:   0.0000000     -0.33318664      0.99999999
 i,j,k,ie:    6    4    1          79
 Near X =  0.95196175     -0.17864100      0.29563535    , d:   0.0000000     -0.47428948      0.99999999
 i,j,k,ie:    1    5    1          79
 Near X =  0.98420982     -0.58719398E-01  0.13437970    , d:   0.0000000     -0.41130614      0.99999999
 i,j,k,ie:    2    5    1          79
 Near X =  0.98420982     -0.58719398E-01  0.15332278    , d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    3    5    1          79
 Near X =  0.98420982     -0.58719398E-01  0.19200993    , d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    4    5    1          79
 Near X =  0.98420982     -0.58719398E-01  0.23800512    , d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    5    5    1          79
 Near X =  0.98420982     -0.58719398E-01  0.27669227    , d:   0.0000000     -0.34447346      0.99999999
 i,j,k,ie:    6    5    1          79
 Near X =  0.98420982     -0.58719398E-01  0.29563535    , d:   0.0000000     -0.44950585      0.99999999
 i,j,k,ie:    1    6    1          79
 Near X =   1.0000000     -0.46163286E-07  0.13437970    , d:   0.0000000      -1.8656023      0.99999999
 i,j,k,ie:    2    6    1          79
 Near X =   1.0000000     -0.46163286E-07  0.15332278    , d:   0.0000000      -1.8656023      0.99999999
 i,j,k,ie:    3    6    1          79
 Near X =   1.0000000     -0.46163286E-07  0.19200993    , d:   0.0000000      -1.8656023      0.99999999
 i,j,k,ie:    4    6    1          79
 Near X =   1.0000000     -0.46163286E-07  0.23800512    , d:   0.0000000      -1.8656023      0.99999999
 i,j,k,ie:    5    6    1          79
 Near X =   1.0000000     -0.46163286E-07  0.27669227    , d:   0.0000000      -1.8656023      0.99999999
 i,j,k,ie:    6    6    1          79
 Near X =   1.0000000     -0.46163286E-07  0.29563535    , d:   0.0000000      -2.0000000      0.99999999
 i,j,k,ie:    1    1    2          79
 Near X =  0.82999499     -0.47930511      0.13437970    , d:  0.12888970      -1.6599900      0.99999999
 i,j,k,ie:    2    1    2          79
 Near X =  0.82999499     -0.47930511      0.15332278    , d:   0.0000000      -1.3093048      0.99999999
 i,j,k,ie:    3    1    2          79
 Near X =  0.82999499     -0.47930511      0.19200993    , d:   0.0000000      -1.3093048      0.99999999
 i,j,k,ie:    4    1    2          79
 Near X =  0.82999499     -0.47930511      0.23800512    , d:   0.0000000      -1.3093048      0.99999999
 i,j,k,ie:    5    1    2          79
 Near X =  0.82999499     -0.47930511      0.27669227    , d:   0.0000000      -1.3093048      0.99999999
 i,j,k,ie:    6    1    2          79
 Near X =  0.82999499     -0.47930511      0.29563535    , d:   0.0000000      -1.3093048      0.99999999
 i,j,k,ie:    1    2    2          79
 Near X =  0.84513596     -0.42300002      0.13437970    , d:  0.98609841E-01   0.0000000      0.99999999
 i,j,k,ie:    6    2    2          79
 Near X =  0.84513596     -0.42300002      0.29563535    , d:   0.0000000     -0.32463042      0.99999999
 i,j,k,ie:    1    3    2          79
 Near X =  0.87605813     -0.30800903      0.13437970    , d:  0.36769761E-01   0.0000000      0.99999999
 i,j,k,ie:    6    3    2          79
 Near X =  0.87605813     -0.30800903      0.29563535    , d:   0.0000000     -0.27141902      0.99999999
 i,j,k,ie:    1    4    2          79
 Near X =  0.91282154     -0.17129612      0.13437970    , d:   0.0000000     -0.36751976E-01  0.99999999
 i,j,k,ie:    6    4    2          79
 Near X =  0.91282154     -0.17129612      0.29563535    , d:   0.0000000     -0.20815594      0.99999999
 i,j,k,ie:    1    5    2          79
 Near X =  0.94374371     -0.56305132E-01  0.13437970    , d:   0.0000000     -0.98592056E-01  0.99999999
 i,j,k,ie:    6    5    2          79
 Near X =  0.94374371     -0.56305132E-01  0.29563535    , d:   0.0000000     -0.15494454      0.99999999
 i,j,k,ie:    1    6    2          79
 Near X =  0.95888469     -0.45029985E-07  0.13437970    , d:   0.0000000      -1.7888974      0.99999999
 i,j,k,ie:    2    6    2          79
 Near X =  0.95888469     -0.45029985E-07  0.15332278    , d:   0.0000000      -1.7888974      0.99999999
 i,j,k,ie:    3    6    2          79
 Near X =  0.95888469     -0.45029985E-07  0.19200993    , d:   0.0000000      -1.7888974      0.99999999
 i,j,k,ie:    4    6    2          79
 Near X =  0.95888469     -0.45029985E-07  0.23800512    , d:   0.0000000      -1.7888974      0.99999999
 i,j,k,ie:    5    6    2          79
 Near X =  0.95888469     -0.45029985E-07  0.27669227    , d:   0.0000000      -1.7888974      0.99999999
 i,j,k,ie:    6    6    2          79
 Near X =  0.95888469     -0.45029985E-07  0.29563535    , d:   0.0000000      -1.9177694      0.99999999
 i,j,k,ie:    1    1    3          79
 Near X =  0.75731264     -0.43733254      0.13437970    , d:  0.11760288      -1.5146253      0.99999999
 i,j,k,ie:    2    1    3          79
 Near X =  0.75731264     -0.43733254      0.15332278    , d:   0.0000000      -1.1946495      0.99999999
 i,j,k,ie:    3    1    3          79
 Near X =  0.75731264     -0.43733254      0.19200993    , d:   0.0000000      -1.1946495      0.99999999
 i,j,k,ie:    4    1    3          79
 Near X =  0.75731264     -0.43733254      0.23800512    , d:   0.0000000      -1.1946495      0.99999999
 i,j,k,ie:    5    1    3          79
 Near X =  0.75731264     -0.43733254      0.27669227    , d:   0.0000000      -1.1946495      0.99999999
 i,j,k,ie:    6    1    3          79
 Near X =  0.75731264     -0.43733254      0.29563535    , d:   0.0000000      -1.1946495      0.99999999
 i,j,k,ie:    1    2    3          79
 Near X =  0.77112772     -0.38595807      0.13437970    , d:  0.89974615E-01   0.0000000      0.99999999
 i,j,k,ie:    6    2    3          79
 Near X =  0.77112772     -0.38595807      0.29563535    , d:   0.0000000     -0.29620265      0.99999999
 i,j,k,ie:    1    3    3          79
 Near X =  0.79934205     -0.28103680      0.13437970    , d:  0.33549847E-01   0.0000000      0.99999999
 i,j,k,ie:    6    3    3          79
 Near X =  0.79934205     -0.28103680      0.29563535    , d:   0.0000000     -0.24765096      0.99999999
 i,j,k,ie:    1    4    3          79
 Near X =  0.83288610     -0.15629579      0.13437970    , d:   0.0000000     -0.33533619E-01  0.99999999
 i,j,k,ie:    6    4    3          79
 Near X =  0.83288610     -0.15629579      0.29563535    , d:   0.0000000     -0.18992780      0.99999999
 i,j,k,ie:    1    5    3          79
 Near X =  0.86110043     -0.51374514E-01  0.13437970    , d:   0.0000000     -0.89958387E-01  0.99999999
 i,j,k,ie:    6    5    3          79
 Near X =  0.86110043     -0.51374514E-01  0.29563535    , d:   0.0000000     -0.14137611      0.99999999
 i,j,k,ie:    1    6    3          79
 Near X =  0.87491551     -0.42715462E-07  0.13437970    , d:   0.0000000      -1.6322444      0.99999999
 i,j,k,ie:    2    6    3          79
 Near X =  0.87491551     -0.42715462E-07  0.15332278    , d:   0.0000000      -1.6322444      0.99999999
 i,j,k,ie:    3    6    3          79
 Near X =  0.87491551     -0.42715462E-07  0.19200993    , d:   0.0000000      -1.6322444      0.99999999
 i,j,k,ie:    4    6    3          79
 Near X =  0.87491551     -0.42715462E-07  0.23800512    , d:   0.0000000      -1.6322444      0.99999999
 i,j,k,ie:    5    6    3          79
 Near X =  0.87491551     -0.42715462E-07  0.27669227    , d:   0.0000000      -1.6322444      0.99999999
 i,j,k,ie:    6    6    3          79
 Near X =  0.87491551     -0.42715462E-07  0.29563535    , d:   0.0000000      -1.7498310      0.99999999
 i,j,k,ie:    1    1    4          79
 Near X =  0.67090051     -0.38743131      0.13437970    , d:  0.10418396      -1.3418011      0.99999999
 i,j,k,ie:    2    1    4          79
 Near X =  0.67090051     -0.38743131      0.15332278    , d:   0.0000000      -1.0583356      0.99999999
 i,j,k,ie:    3    1    4          79
 Near X =  0.67090051     -0.38743131      0.19200993    , d:   0.0000000      -1.0583356      0.99999999
 i,j,k,ie:    4    1    4          79
 Near X =  0.67090051     -0.38743131      0.23800512    , d:   0.0000000      -1.0583356      0.99999999
 i,j,k,ie:    5    1    4          79
 Near X =  0.67090051     -0.38743131      0.27669227    , d:   0.0000000      -1.0583356      0.99999999
 i,j,k,ie:    6    1    4          79
 Near X =  0.67090051     -0.38743131      0.29563535    , d:   0.0000000      -1.0583356      0.99999999
 i,j,k,ie:    1    2    4          79
 Near X =  0.68313925     -0.34191885      0.13437970    , d:  0.79708184E-01   0.0000000      0.99999999
 i,j,k,ie:    6    2    4          79
 Near X =  0.68313925     -0.34191885      0.29563535    , d:   0.0000000     -0.26240485      0.99999999
 i,j,k,ie:    1    3    4          79
 Near X =  0.70813422     -0.24896948      0.13437970    , d:  0.29721687E-01   0.0000000      0.99999999
 i,j,k,ie:    6    3    4          79
 Near X =  0.70813422     -0.24896948      0.29563535    , d:   0.0000000     -0.21939309      0.99999999
 i,j,k,ie:    1    4    4          79
 Near X =  0.73785077     -0.13846187      0.13437970    , d:   0.0000000     -0.29707311E-01  0.99999999
 i,j,k,ie:    6    4    4          79
 Near X =  0.73785077     -0.13846187      0.29563535    , d:   0.0000000     -0.16825635      0.99999999
 i,j,k,ie:    1    5    4          79
 Near X =  0.76284574     -0.45512497E-01  0.13437970    , d:   0.0000000     -0.79693808E-01  0.99999999
 i,j,k,ie:    6    5    4          79
 Near X =  0.76284574     -0.45512497E-01  0.29563535    , d:   0.0000000     -0.12524458      0.99999999
 i,j,k,ie:    1    6    4          79
 Near X =  0.77508447     -0.39963724E-07  0.13437970    , d:   0.0000000      -1.4459993      0.99999999
 i,j,k,ie:    2    6    4          79
 Near X =  0.77508447     -0.39963724E-07  0.15332278    , d:   0.0000000      -1.4459993      0.99999999
 i,j,k,ie:    3    6    4          79
 Near X =  0.77508447     -0.39963724E-07  0.19200993    , d:   0.0000000      -1.4459993      0.99999999
 i,j,k,ie:    4    6    4          79
 Near X =  0.77508447     -0.39963724E-07  0.23800512    , d:   0.0000000      -1.4459993      0.99999999
 i,j,k,ie:    5    6    4          79
 Near X =  0.77508447     -0.39963724E-07  0.27669227    , d:   0.0000000      -1.4459993      0.99999999
 i,j,k,ie:    6    6    4          79
 Near X =  0.77508447     -0.39963724E-07  0.29563535    , d:   0.0000000      -1.5501689      0.99999999
 i,j,k,ie:    1    1    5          79
 Near X =  0.59821816     -0.34545874      0.13437970    , d:  0.92897140E-01  -1.1964363      0.99999999
 i,j,k,ie:    2    1    5          79
 Near X =  0.59821816     -0.34545874      0.15332278    , d:   0.0000000     -0.94368028      0.99999999
 i,j,k,ie:    3    1    5          79
 Near X =  0.59821816     -0.34545874      0.19200993    , d:   0.0000000     -0.94368028      0.99999999
 i,j,k,ie:    4    1    5          79
 Near X =  0.59821816     -0.34545874      0.23800512    , d:   0.0000000     -0.94368028      0.99999999
 i,j,k,ie:    5    1    5          79
 Near X =  0.59821816     -0.34545874      0.27669227    , d:   0.0000000     -0.94368028      0.99999999
 i,j,k,ie:    6    1    5          79
 Near X =  0.59821816     -0.34545874      0.29563535    , d:   0.0000000     -0.94368028      0.99999999
 i,j,k,ie:    1    2    5          79
 Near X =  0.60913101     -0.30487690      0.13437970    , d:  0.71072957E-01   0.0000000      0.99999999
 i,j,k,ie:    6    2    5          79
 Near X =  0.60913101     -0.30487690      0.29563535    , d:   0.0000000     -0.23397709      0.99999999
 i,j,k,ie:    1    3    5          79
 Near X =  0.63141814     -0.22199725      0.13437970    , d:  0.26501773E-01   0.0000000      0.99999999
 i,j,k,ie:    6    3    5          79
 Near X =  0.63141814     -0.22199725      0.29563535    , d:   0.0000000     -0.19562502      0.99999999
 i,j,k,ie:    1    4    5          79
 Near X =  0.65791533     -0.12346154      0.13437970    , d:   0.0000000     -0.26488955E-01  0.99999999
 i,j,k,ie:    6    4    5          79
 Near X =  0.65791533     -0.12346154      0.29563535    , d:   0.0000000     -0.15002821      0.99999999
 i,j,k,ie:    1    5    5          79
 Near X =  0.68020246     -0.40581880E-01  0.13437970    , d:   0.0000000     -0.71060138E-01  0.99999999
 i,j,k,ie:    6    5    5          79
 Near X =  0.68020246     -0.40581880E-01  0.29563535    , d:   0.0000000     -0.11167614      0.99999999
 i,j,k,ie:    1    6    5          79
 Near X =  0.69111530     -0.37649202E-07  0.13437970    , d:   0.0000000      -1.2893463      0.99999999
 i,j,k,ie:    2    6    5          79
 Near X =  0.69111530     -0.37649202E-07  0.15332278    , d:   0.0000000      -1.2893463      0.99999999
 i,j,k,ie:    3    6    5          79
 Near X =  0.69111530     -0.37649202E-07  0.19200993    , d:   0.0000000      -1.2893463      0.99999999
 i,j,k,ie:    4    6    5          79
 Near X =  0.69111530     -0.37649202E-07  0.23800512    , d:   0.0000000      -1.2893463      0.99999999
 i,j,k,ie:    5    6    5          79
 Near X =  0.69111530     -0.37649202E-07  0.27669227    , d:   0.0000000      -1.2893463      0.99999999
 i,j,k,ie:    6    6    5          79
 Near X =  0.69111530     -0.37649202E-07  0.29563535    , d:   0.0000000      -1.3822306      0.99999999
 i,j,k,ie:    1    1    6          79
 Near X =  0.56262941     -0.32490697      0.13437970    , d:  0.43737060      -1.4282132      0.99999999
 i,j,k,ie:    2    1    6          79
 Near X =  0.56262941     -0.32490697      0.15332278    , d:  0.30295433      -1.0624912      0.99999999
 i,j,k,ie:    3    1    6          79
 Near X =  0.56262941     -0.32490697      0.19200993    , d:  0.30295433      -1.0624912      0.99999999
 i,j,k,ie:    4    1    6          79
 Near X =  0.56262941     -0.32490697      0.23800512    , d:  0.30295433      -1.0624912      0.99999999
 i,j,k,ie:    5    1    6          79
 Near X =  0.56262941     -0.32490697      0.27669227    , d:  0.30295433      -1.0624912      0.99999999
 i,j,k,ie:    6    1    6          79
 Near X =  0.56262941     -0.32490697      0.29563535    , d:  0.30295433      -1.0624912      0.99999999
 i,j,k,ie:    1    2    6          79
 Near X =  0.57289303     -0.28673939      0.13437970    , d:  0.41131896       0.0000000      0.99999999
 i,j,k,ie:    2    2    6          79
 Near X =  0.57289303     -0.28673939      0.15332278    , d:  0.30848090       0.0000000      0.99999999
 i,j,k,ie:    3    2    6          79
 Near X =  0.57289303     -0.28673939      0.19200993    , d:  0.30848090       0.0000000      0.99999999
 i,j,k,ie:    4    2    6          79
 Near X =  0.57289303     -0.28673939      0.23800512    , d:  0.30848090       0.0000000      0.99999999
 i,j,k,ie:    5    2    6          79
 Near X =  0.57289303     -0.28673939      0.27669227    , d:  0.30848090       0.0000000      0.99999999
 i,j,k,ie:    6    2    6          79
 Near X =  0.57289303     -0.28673939      0.29563535    , d:  0.30848090     -0.22005750      0.99999999
 i,j,k,ie:    1    3    6          79
 Near X =  0.59385427     -0.20879035      0.13437970    , d:  0.35811411       0.0000000      0.99999999
 i,j,k,ie:    2    3    6          79
 Near X =  0.59385427     -0.20879035      0.15332278    , d:  0.31976772       0.0000000      0.99999999
 i,j,k,ie:    3    3    6          79
 Near X =  0.59385427     -0.20879035      0.19200993    , d:  0.31976772       0.0000000      0.99999999
 i,j,k,ie:    4    3    6          79
 Near X =  0.59385427     -0.20879035      0.23800512    , d:  0.31976772       0.0000000      0.99999999
 i,j,k,ie:    5    3    6          79
 Near X =  0.59385427     -0.20879035      0.27669227    , d:  0.31976772       0.0000000      0.99999999
 i,j,k,ie:    6    3    6          79
 Near X =  0.59385427     -0.20879035      0.29563535    , d:  0.31976772     -0.18398704      0.99999999
 i,j,k,ie:    1    4    6          79
 Near X =  0.61877511     -0.11611665      0.13437970    , d:  0.33318664     -0.24913093E-01  0.99999999
 i,j,k,ie:    2    4    6          79
 Near X =  0.61877511     -0.11611665      0.15332278    , d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    3    4    6          79
 Near X =  0.61877511     -0.11611665      0.19200993    , d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    4    4    6          79
 Near X =  0.61877511     -0.11611665      0.23800512    , d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    5    4    6          79
 Near X =  0.61877511     -0.11611665      0.27669227    , d:  0.33318664       0.0000000      0.99999999
 i,j,k,ie:    6    4    6          79
 Near X =  0.61877511     -0.11611665      0.29563535    , d:  0.33318664     -0.14110284      0.99999999
 i,j,k,ie:    1    5    6          79
 Near X =  0.63973635     -0.38167613E-01  0.13437970    , d:  0.34447346     -0.66832681E-01  0.99999999
 i,j,k,ie:    2    5    6          79
 Near X =  0.63973635     -0.38167613E-01  0.15332278    , d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    3    5    6          79
 Near X =  0.63973635     -0.38167613E-01  0.19200993    , d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    4    5    6          79
 Near X =  0.63973635     -0.38167613E-01  0.23800512    , d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    5    5    6          79
 Near X =  0.63973635     -0.38167613E-01  0.27669227    , d:  0.34447346       0.0000000      0.99999999
 i,j,k,ie:    6    5    6          79
 Near X =  0.63973635     -0.38167613E-01  0.29563535    , d:  0.34447346     -0.10503239      0.99999999
 i,j,k,ie:    1    6    6          79
 Near X =  0.64999998     -0.36515901E-07  0.13437970    , d:  0.35000003      -1.5156023      0.99999999
 i,j,k,ie:    2    6    6          79
 Near X =  0.64999998     -0.36515901E-07  0.15332278    , d:  0.35000003      -1.5156023      0.99999999
 i,j,k,ie:    3    6    6          79
 Near X =  0.64999998     -0.36515901E-07  0.19200993    , d:  0.35000003      -1.5156023      0.99999999
 i,j,k,ie:    4    6    6          79
 Near X =  0.64999998     -0.36515901E-07  0.23800512    , d:  0.35000003      -1.5156023      0.99999999
 i,j,k,ie:    5    6    6          79
 Near X =  0.64999998     -0.36515901E-07  0.27669227    , d:  0.35000003      -1.5156023      0.99999999
 i,j,k,ie:    6    6    6          79
 Near X =  0.64999998     -0.36515901E-07  0.29563535    , d:  0.35000003      -1.6500000      0.99999999
 i,j,k,ie:    1    1    1          80
 Near X =  0.49986170     -0.86560228      0.13437970    , d:  0.36572204     -0.99972348       1.1552897
 i,j,k,ie:    2    1    1          80
 Near X =  0.49986170     -0.86560228      0.15332278    , d:   0.0000000     -0.49986167       1.1552897
 i,j,k,ie:    3    1    1          80
 Near X =  0.49986170     -0.86560228      0.19200993    , d:   0.0000000     -0.49986167       1.1552897
 i,j,k,ie:    4    1    1          80
 Near X =  0.49986170     -0.86560228      0.23800512    , d:   0.0000000     -0.49986167       1.1552897
 i,j,k,ie:    5    1    1          80
 Near X =  0.49986170     -0.86560228      0.27669227    , d:   0.0000000     -0.49986167       1.1552897
 i,j,k,ie:    6    1    1          80
 Near X =  0.49986170     -0.86560228      0.29563535    , d:   0.0000000     -0.49986167       1.1552897
 i,j,k,ie:    1    2    1          80
 Near X =  0.54282392     -0.82263731      0.13437970    , d:  0.33855001     -0.18998839       1.1552897
 i,j,k,ie:    2    2    1          80
 Near X =  0.54282392     -0.82263731      0.15332278    , d:   0.0000000     -0.18998839       1.1552897
 i,j,k,ie:    3    2    1          80
 Near X =  0.54282392     -0.82263731      0.19200993    , d:   0.0000000     -0.18998839       1.1552897
 i,j,k,ie:    4    2    1          80
 Near X =  0.54282392     -0.82263731      0.23800512    , d:   0.0000000     -0.18998839       1.1552897
 i,j,k,ie:    5    2    1          80
 Near X =  0.54282392     -0.82263731      0.27669227    , d:   0.0000000     -0.18998839       1.1552897
 i,j,k,ie:    6    2    1          80
 Near X =  0.54282392     -0.82263731      0.29563535    , d:   0.0000000     -0.18998839       1.1552897
 i,j,k,ie:    1    3    1          80
 Near X =  0.63056499     -0.73489064      0.13437970    , d:  0.28305700     -0.22069777       1.1552897
 i,j,k,ie:    2    3    1          80
 Near X =  0.63056499     -0.73489064      0.15332278    , d:   0.0000000     -0.22069777       1.1552897
 i,j,k,ie:    3    3    1          80
 Near X =  0.63056499     -0.73489064      0.19200993    , d:   0.0000000     -0.22069777       1.1552897
 i,j,k,ie:    4    3    1          80
 Near X =  0.63056499     -0.73489064      0.23800512    , d:   0.0000000     -0.22069777       1.1552897
 i,j,k,ie:    5    3    1          80
 Near X =  0.63056499     -0.73489064      0.27669227    , d:   0.0000000     -0.22069777       1.1552897
 i,j,k,ie:    6    3    1          80
 Near X =  0.63056499     -0.73489064      0.29563535    , d:   0.0000000     -0.22069777       1.1552897
 i,j,k,ie:    1    4    1          80
 Near X =  0.73488045     -0.63056853      0.13437970    , d:  0.21708131     -0.25720818       1.1552897
 i,j,k,ie:    2    4    1          80
 Near X =  0.73488045     -0.63056853      0.15332278    , d:   0.0000000     -0.25720818       1.1552897
 i,j,k,ie:    3    4    1          80
 Near X =  0.73488045     -0.63056853      0.19200993    , d:   0.0000000     -0.25720818       1.1552897
 i,j,k,ie:    4    4    1          80
 Near X =  0.73488045     -0.63056853      0.23800512    , d:   0.0000000     -0.25720818       1.1552897
 i,j,k,ie:    5    4    1          80
 Near X =  0.73488045     -0.63056853      0.27669227    , d:   0.0000000     -0.25720818       1.1552897
 i,j,k,ie:    6    4    1          80
 Near X =  0.73488045     -0.63056853      0.29563535    , d:   0.0000000     -0.25720818       1.1552897
 i,j,k,ie:    1    5    1          80
 Near X =  0.82262152     -0.54282185      0.13437970    , d:  0.16158830     -0.28791755       1.1552897
 i,j,k,ie:    2    5    1          80
 Near X =  0.82262152     -0.54282185      0.15332278    , d:   0.0000000     -0.28791755       1.1552897
 i,j,k,ie:    3    5    1          80
 Near X =  0.82262152     -0.54282185      0.19200993    , d:   0.0000000     -0.28791755       1.1552897
 i,j,k,ie:    4    5    1          80
 Near X =  0.82262152     -0.54282185      0.23800512    , d:   0.0000000     -0.28791755       1.1552897
 i,j,k,ie:    5    5    1          80
 Near X =  0.82262152     -0.54282185      0.27669227    , d:   0.0000000     -0.28791755       1.1552897
 i,j,k,ie:    6    5    1          80
 Near X =  0.82262152     -0.54282185      0.29563535    , d:   0.0000000     -0.28791755       1.1552897
 i,j,k,ie:    1    6    1          80
 Near X =  0.86558374     -0.49985689      0.13437970    , d:  0.13441627      -1.8655837       1.1552897
 i,j,k,ie:    2    6    1          80
 Near X =  0.86558374     -0.49985689      0.15332278    , d:   0.0000000      -1.8655837       1.1552897
 i,j,k,ie:    3    6    1          80
 Near X =  0.86558374     -0.49985689      0.19200993    , d:   0.0000000      -1.8655837       1.1552897
 i,j,k,ie:    4    6    1          80
 Near X =  0.86558374     -0.49985689      0.23800512    , d:   0.0000000      -1.8655837       1.1552897
 i,j,k,ie:    5    6    1          80
 Near X =  0.86558374     -0.49985689      0.27669227    , d:   0.0000000      -1.8655837       1.1552897
 i,j,k,ie:    6    6    1          80
 Near X =  0.86558374     -0.49985689      0.29563535    , d:   0.0000000      -1.8655837       1.1552897
 i,j,k,ie:    1    1    2          80
 Near X =  0.47930973     -0.83001276      0.13437970    , d:  0.35068526     -0.95861952       1.1552897
 i,j,k,ie:    2    1    2          80
 Near X =  0.47930973     -0.83001276      0.15332278    , d:   0.0000000     -0.47930969       1.1552897
 i,j,k,ie:    3    1    2          80
 Near X =  0.47930973     -0.83001276      0.19200993    , d:   0.0000000     -0.47930969       1.1552897
 i,j,k,ie:    4    1    2          80
 Near X =  0.47930973     -0.83001276      0.23800512    , d:   0.0000000     -0.47930969       1.1552897
 i,j,k,ie:    5    1    2          80
 Near X =  0.47930973     -0.83001276      0.27669227    , d:   0.0000000     -0.47930969       1.1552897
 i,j,k,ie:    6    1    2          80
 Near X =  0.47930973     -0.83001276      0.29563535    , d:   0.0000000     -0.47930969       1.1552897
 i,j,k,ie:    1    2    2          80
 Near X =  0.52050554     -0.78881431      0.13437970    , d:  0.32463042       0.0000000       1.1552897
 i,j,k,ie:    1    3    2          80
 Near X =  0.60463911     -0.70467537      0.13437970    , d:  0.27141902       0.0000000       1.1552897
 i,j,k,ie:    1    4    2          80
 Near X =  0.70466560     -0.60464250      0.13437970    , d:  0.20815594       0.0000000       1.1552897
 i,j,k,ie:    1    5    2          80
 Near X =  0.78879917     -0.52050356      0.13437970    , d:  0.15494454       0.0000000       1.1552897
 i,j,k,ie:    1    6    2          80
 Near X =  0.82999499     -0.47930511      0.13437970    , d:  0.12888970      -1.7888797       1.1552897
 i,j,k,ie:    2    6    2          80
 Near X =  0.82999499     -0.47930511      0.15332278    , d:   0.0000000      -1.7888797       1.1552897
 i,j,k,ie:    3    6    2          80
 Near X =  0.82999499     -0.47930511      0.19200993    , d:   0.0000000      -1.7888797       1.1552897
 i,j,k,ie:    4    6    2          80
 Near X =  0.82999499     -0.47930511      0.23800512    , d:   0.0000000      -1.7888797       1.1552897
 i,j,k,ie:    5    6    2          80
 Near X =  0.82999499     -0.47930511      0.27669227    , d:   0.0000000      -1.7888797       1.1552897
 i,j,k,ie:    6    6    2          80
 Near X =  0.82999499     -0.47930511      0.29563535    , d:   0.0000000      -1.7888797       1.1552897
 i,j,k,ie:    1    1    3          80
 Near X =  0.43733675     -0.75732886      0.13437970    , d:  0.31997588     -0.87467357       1.1552897
 i,j,k,ie:    2    1    3          80
 Near X =  0.43733675     -0.75732886      0.15332278    , d:   0.0000000     -0.43733672       1.1552897
 i,j,k,ie:    3    1    3          80
 Near X =  0.43733675     -0.75732886      0.19200993    , d:   0.0000000     -0.43733672       1.1552897
 i,j,k,ie:    4    1    3          80
 Near X =  0.43733675     -0.75732886      0.23800512    , d:   0.0000000     -0.43733672       1.1552897
 i,j,k,ie:    5    1    3          80
 Near X =  0.43733675     -0.75732886      0.27669227    , d:   0.0000000     -0.43733672       1.1552897
 i,j,k,ie:    6    1    3          80
 Near X =  0.43733675     -0.75732886      0.29563535    , d:   0.0000000     -0.43733672       1.1552897
 i,j,k,ie:    1    2    3          80
 Near X =  0.47492507     -0.71973814      0.13437970    , d:  0.29620265       0.0000000       1.1552897
 i,j,k,ie:    1    3    3          80
 Near X =  0.55169109     -0.64296722      0.13437970    , d:  0.24765096       0.0000000       1.1552897
 i,j,k,ie:    1    4    3          80
 Near X =  0.64295830     -0.55169418      0.13437970    , d:  0.18992780       0.0000000       1.1552897
 i,j,k,ie:    1    5    3          80
 Near X =  0.71972432     -0.47492326      0.13437970    , d:  0.14137611       0.0000000       1.1552897
 i,j,k,ie:    1    6    3          80
 Near X =  0.75731264     -0.43733254      0.13437970    , d:  0.11760288      -1.6322281       1.1552897
 i,j,k,ie:    2    6    3          80
 Near X =  0.75731264     -0.43733254      0.15332278    , d:   0.0000000      -1.6322281       1.1552897
 i,j,k,ie:    3    6    3          80
 Near X =  0.75731264     -0.43733254      0.19200993    , d:   0.0000000      -1.6322281       1.1552897
 i,j,k,ie:    4    6    3          80
 Near X =  0.75731264     -0.43733254      0.23800512    , d:   0.0000000      -1.6322281       1.1552897
 i,j,k,ie:    5    6    3          80
 Near X =  0.75731264     -0.43733254      0.27669227    , d:   0.0000000      -1.6322281       1.1552897
 i,j,k,ie:    6    6    3          80
 Near X =  0.75731264     -0.43733254      0.29563535    , d:   0.0000000      -1.6322281       1.1552897
 i,j,k,ie:    1    1    4          80
 Near X =  0.38743504     -0.67091488      0.13437970    , d:  0.28346547     -0.77487014       1.1552897
 i,j,k,ie:    2    1    4          80
 Near X =  0.38743504     -0.67091488      0.15332278    , d:   0.0000000     -0.38743501       1.1552897
 i,j,k,ie:    3    1    4          80
 Near X =  0.38743504     -0.67091488      0.19200993    , d:   0.0000000     -0.38743501       1.1552897
 i,j,k,ie:    4    1    4          80
 Near X =  0.38743504     -0.67091488      0.23800512    , d:   0.0000000     -0.38743501       1.1552897
 i,j,k,ie:    5    1    4          80
 Near X =  0.38743504     -0.67091488      0.27669227    , d:   0.0000000     -0.38743501       1.1552897
 i,j,k,ie:    6    1    4          80
 Near X =  0.38743504     -0.67091488      0.29563535    , d:   0.0000000     -0.38743501       1.1552897
 i,j,k,ie:    1    2    4          80
 Near X =  0.42073439     -0.63761340      0.13437970    , d:  0.26240485       0.0000000       1.1552897
 i,j,k,ie:    1    3    4          80
 Near X =  0.48874113     -0.56960232      0.13437970    , d:  0.21939309       0.0000000       1.1552897
 i,j,k,ie:    1    4    4          80
 Near X =  0.56959442     -0.48874387      0.13437970    , d:  0.16825635       0.0000000       1.1552897
 i,j,k,ie:    1    5    4          80
 Near X =  0.63760116     -0.42073279      0.13437970    , d:  0.12524458       0.0000000       1.1552897
 i,j,k,ie:    1    6    4          80
 Near X =  0.67090051     -0.38743131      0.13437970    , d:  0.10418396      -1.4459850       1.1552897
 i,j,k,ie:    2    6    4          80
 Near X =  0.67090051     -0.38743131      0.15332278    , d:   0.0000000      -1.4459850       1.1552897
 i,j,k,ie:    3    6    4          80
 Near X =  0.67090051     -0.38743131      0.19200993    , d:   0.0000000      -1.4459850       1.1552897
 i,j,k,ie:    4    6    4          80
 Near X =  0.67090051     -0.38743131      0.23800512    , d:   0.0000000      -1.4459850       1.1552897
 i,j,k,ie:    5    6    4          80
 Near X =  0.67090051     -0.38743131      0.27669227    , d:   0.0000000      -1.4459850       1.1552897
 i,j,k,ie:    6    6    4          80
 Near X =  0.67090051     -0.38743131      0.29563535    , d:   0.0000000      -1.4459850       1.1552897
 i,j,k,ie:    1    1    5          80
 Near X =  0.34546207     -0.59823098      0.13437970    , d:  0.25275610     -0.69092418       1.1552897
 i,j,k,ie:    2    1    5          80
 Near X =  0.34546207     -0.59823098      0.15332278    , d:   0.0000000     -0.34546204       1.1552897
 i,j,k,ie:    3    1    5          80
 Near X =  0.34546207     -0.59823098      0.19200993    , d:   0.0000000     -0.34546204       1.1552897
 i,j,k,ie:    4    1    5          80
 Near X =  0.34546207     -0.59823098      0.23800512    , d:   0.0000000     -0.34546204       1.1552897
 i,j,k,ie:    5    1    5          80
 Near X =  0.34546207     -0.59823098      0.27669227    , d:   0.0000000     -0.34546204       1.1552897
 i,j,k,ie:    6    1    5          80
 Near X =  0.34546207     -0.59823098      0.29563535    , d:   0.0000000     -0.34546204       1.1552897
 i,j,k,ie:    1    2    5          80
 Near X =  0.37515392     -0.56853723      0.13437970    , d:  0.23397709       0.0000000       1.1552897
 i,j,k,ie:    1    3    5          80
 Near X =  0.43579311     -0.50789416      0.13437970    , d:  0.19562502       0.0000000       1.1552897
 i,j,k,ie:    1    4    5          80
 Near X =  0.50788712     -0.43579556      0.13437970    , d:  0.15002821       0.0000000       1.1552897
 i,j,k,ie:    1    5    5          80
 Near X =  0.56852631     -0.37515249      0.13437970    , d:  0.11167614       0.0000000       1.1552897
 i,j,k,ie:    1    6    5          80
 Near X =  0.59821816     -0.34545874      0.13437970    , d:  0.92897140E-01  -1.2893335       1.1552897
 i,j,k,ie:    2    6    5          80
 Near X =  0.59821816     -0.34545874      0.15332278    , d:   0.0000000      -1.2893335       1.1552897
 i,j,k,ie:    3    6    5          80
 Near X =  0.59821816     -0.34545874      0.19200993    , d:   0.0000000      -1.2893335       1.1552897
 i,j,k,ie:    4    6    5          80
 Near X =  0.59821816     -0.34545874      0.23800512    , d:   0.0000000      -1.2893335       1.1552897
 i,j,k,ie:    5    6    5          80
 Near X =  0.59821816     -0.34545874      0.27669227    , d:   0.0000000      -1.2893335       1.1552897
 i,j,k,ie:    6    6    5          80
 Near X =  0.59821816     -0.34545874      0.29563535    , d:   0.0000000      -1.2893335       1.1552897
 i,j,k,ie:    1    1    6          80
 Near X =  0.32491009     -0.56264146      0.13437970    , d:  0.54067365     -0.82477187       1.1552897
 i,j,k,ie:    2    1    6          80
 Near X =  0.32491009     -0.56264146      0.15332278    , d:  0.17495161     -0.32491007       1.1552897
 i,j,k,ie:    3    1    6          80
 Near X =  0.32491009     -0.56264146      0.19200993    , d:  0.17495161     -0.32491007       1.1552897
 i,j,k,ie:    4    1    6          80
 Near X =  0.32491009     -0.56264146      0.23800512    , d:  0.17495161     -0.32491007       1.1552897
 i,j,k,ie:    5    1    6          80
 Near X =  0.32491009     -0.56264146      0.27669227    , d:  0.17495161     -0.32491007       1.1552897
 i,j,k,ie:    6    1    6          80
 Near X =  0.32491009     -0.56264146      0.29563535    , d:  0.17495161     -0.32491007       1.1552897
 i,j,k,ie:    1    2    6          80
 Near X =  0.35283554     -0.53471423      0.13437970    , d:  0.52853840       0.0000000       1.1552897
 i,j,k,ie:    2    2    6          80
 Near X =  0.35283554     -0.53471423      0.15332278    , d:  0.18998839       0.0000000       1.1552897
 i,j,k,ie:    3    2    6          80
 Near X =  0.35283554     -0.53471423      0.19200993    , d:  0.18998839       0.0000000       1.1552897
 i,j,k,ie:    4    2    6          80
 Near X =  0.35283554     -0.53471423      0.23800512    , d:  0.18998839       0.0000000       1.1552897
 i,j,k,ie:    5    2    6          80
 Near X =  0.35283554     -0.53471423      0.27669227    , d:  0.18998839       0.0000000       1.1552897
 i,j,k,ie:    6    2    6          80
 Near X =  0.35283554     -0.53471423      0.29563535    , d:  0.18998839       0.0000000       1.1552897
 i,j,k,ie:    1    3    6          80
 Near X =  0.40986723     -0.47767890      0.13437970    , d:  0.50375477       0.0000000       1.1552897
 i,j,k,ie:    2    3    6          80
 Near X =  0.40986723     -0.47767890      0.15332278    , d:  0.22069777       0.0000000       1.1552897
 i,j,k,ie:    3    3    6          80
 Near X =  0.40986723     -0.47767890      0.19200993    , d:  0.22069777       0.0000000       1.1552897
 i,j,k,ie:    4    3    6          80
 Near X =  0.40986723     -0.47767890      0.23800512    , d:  0.22069777       0.0000000       1.1552897
 i,j,k,ie:    5    3    6          80
 Near X =  0.40986723     -0.47767890      0.27669227    , d:  0.22069777       0.0000000       1.1552897
 i,j,k,ie:    6    3    6          80
 Near X =  0.40986723     -0.47767890      0.29563535    , d:  0.22069777       0.0000000       1.1552897
 i,j,k,ie:    1    4    6          80
 Near X =  0.47767227     -0.40986953      0.13437970    , d:  0.47428948       0.0000000       1.1552897
 i,j,k,ie:    2    4    6          80
 Near X =  0.47767227     -0.40986953      0.15332278    , d:  0.25720818       0.0000000       1.1552897
 i,j,k,ie:    3    4    6          80
 Near X =  0.47767227     -0.40986953      0.19200993    , d:  0.25720818       0.0000000       1.1552897
 i,j,k,ie:    4    4    6          80
 Near X =  0.47767227     -0.40986953      0.23800512    , d:  0.25720818       0.0000000       1.1552897
 i,j,k,ie:    5    4    6          80
 Near X =  0.47767227     -0.40986953      0.27669227    , d:  0.25720818       0.0000000       1.1552897
 i,j,k,ie:    6    4    6          80
 Near X =  0.47767227     -0.40986953      0.29563535    , d:  0.25720818       0.0000000       1.1552897
 i,j,k,ie:    1    5    6          80
 Near X =  0.53470396     -0.35283419      0.13437970    , d:  0.44950585       0.0000000       1.1552897
 i,j,k,ie:    2    5    6          80
 Near X =  0.53470396     -0.35283419      0.15332278    , d:  0.28791755       0.0000000       1.1552897
 i,j,k,ie:    3    5    6          80
 Near X =  0.53470396     -0.35283419      0.19200993    , d:  0.28791755       0.0000000       1.1552897
 i,j,k,ie:    4    5    6          80
 Near X =  0.53470396     -0.35283419      0.23800512    , d:  0.28791755       0.0000000       1.1552897
 i,j,k,ie:    5    5    6          80
 Near X =  0.53470396     -0.35283419      0.27669227    , d:  0.28791755       0.0000000       1.1552897
 i,j,k,ie:    6    5    6          80
 Near X =  0.53470396     -0.35283419      0.29563535    , d:  0.28791755       0.0000000       1.1552897
 i,j,k,ie:    1    6    6          80
 Near X =  0.56262941     -0.32490697      0.13437970    , d:  0.43737060      -1.5626294       1.1552897
 i,j,k,ie:    2    6    6          80
 Near X =  0.56262941     -0.32490697      0.15332278    , d:  0.30295433      -1.5626294       1.1552897
 i,j,k,ie:    3    6    6          80
 Near X =  0.56262941     -0.32490697      0.19200993    , d:  0.30295433      -1.5626294       1.1552897
 i,j,k,ie:    4    6    6          80
 Near X =  0.56262941     -0.32490697      0.23800512    , d:  0.30295433      -1.5626294       1.1552897
 i,j,k,ie:    5    6    6          80
 Near X =  0.56262941     -0.32490697      0.27669227    , d:  0.30295433      -1.5626294       1.1552897
 i,j,k,ie:    6    6    6          80
 Near X =  0.56262941     -0.32490697      0.29563535    , d:  0.30295433      -1.5626294       1.1552897
 i,j,k,ie:    1    1    1          81
 Near X = -0.11800764E-06  -1.0000000      0.13437970    , d:  0.49985699       0.0000000       2.0005529
 i,j,k,ie:    2    1    1          81
 Near X = -0.11800764E-06  -1.0000000      0.15332278    , d:  0.49985699       0.0000000       2.0005529
 i,j,k,ie:    3    1    1          81
 Near X = -0.11800764E-06  -1.0000000      0.19200993    , d:  0.49985699       0.0000000       2.0005529
 i,j,k,ie:    4    1    1          81
 Near X = -0.11800764E-06  -1.0000000      0.23800512    , d:  0.49985699       0.0000000       2.0005529
 i,j,k,ie:    5    1    1          81
 Near X = -0.11800764E-06  -1.0000000      0.27669227    , d:  0.49985699       0.0000000       2.0005529
 i,j,k,ie:    6    1    1          81
 Near X = -0.11800764E-06  -1.0000000      0.29563535    , d:  0.86560241     -0.49985679       2.0005529
 i,j,k,ie:    1    2    1          81
 Near X =  0.58719818E-01 -0.98421199      0.13437970    , d:   0.0000000     -0.20551938E-01   2.0005529
 i,j,k,ie:    2    2    1          81
 Near X =  0.58719818E-01 -0.98421199      0.15332278    , d:   0.0000000     -0.20551938E-01   2.0005529
 i,j,k,ie:    3    2    1          81
 Near X =  0.58719818E-01 -0.98421199      0.19200993    , d:   0.0000000     -0.20551938E-01   2.0005529
 i,j,k,ie:    4    2    1          81
 Near X =  0.58719818E-01 -0.98421199      0.23800512    , d:   0.0000000     -0.20551938E-01   2.0005529
 i,j,k,ie:    5    2    1          81
 Near X =  0.58719818E-01 -0.98421199      0.27669227    , d:   0.0000000     -0.20551938E-01   2.0005529
 i,j,k,ie:    6    2    1          81
 Near X =  0.58719818E-01 -0.98421199      0.29563535    , d:   0.0000000     -0.49985738       2.0005529
 i,j,k,ie:    1    3    1          81
 Near X =  0.17864262     -0.95196838      0.13437970    , d:   0.0000000     -0.62524921E-01   2.0005529
 i,j,k,ie:    2    3    1          81
 Near X =  0.17864262     -0.95196838      0.15332278    , d:   0.0000000     -0.62524921E-01   2.0005529
 i,j,k,ie:    3    3    1          81
 Near X =  0.17864262     -0.95196838      0.19200993    , d:   0.0000000     -0.62524921E-01   2.0005529
 i,j,k,ie:    4    3    1          81
 Near X =  0.17864262     -0.95196838      0.23800512    , d:   0.0000000     -0.62524921E-01   2.0005529
 i,j,k,ie:    5    3    1          81
 Near X =  0.17864262     -0.95196838      0.27669227    , d:   0.0000000     -0.62524921E-01   2.0005529
 i,j,k,ie:    6    3    1          81
 Near X =  0.17864262     -0.95196838      0.29563535    , d:   0.0000000     -0.49985858       2.0005529
 i,j,k,ie:    1    4    1          81
 Near X =  0.32121896     -0.91363391      0.13437970    , d:   0.0000000     -0.11242665       2.0005529
 i,j,k,ie:    2    4    1          81
 Near X =  0.32121896     -0.91363391      0.15332278    , d:   0.0000000     -0.11242665       2.0005529
 i,j,k,ie:    3    4    1          81
 Near X =  0.32121896     -0.91363391      0.19200993    , d:   0.0000000     -0.11242665       2.0005529
 i,j,k,ie:    4    4    1          81
 Near X =  0.32121896     -0.91363391      0.23800512    , d:   0.0000000     -0.11242665       2.0005529
 i,j,k,ie:    5    4    1          81
 Near X =  0.32121896     -0.91363391      0.27669227    , d:   0.0000000     -0.11242665       2.0005529
 i,j,k,ie:    6    4    1          81
 Near X =  0.32121896     -0.91363391      0.29563535    , d:   0.0000000     -0.49986002       2.0005529
 i,j,k,ie:    1    5    1          81
 Near X =  0.44114176     -0.88139029      0.13437970    , d:   0.0000000     -0.15439963       2.0005529
 i,j,k,ie:    2    5    1          81
 Near X =  0.44114176     -0.88139029      0.15332278    , d:   0.0000000     -0.15439963       2.0005529
 i,j,k,ie:    3    5    1          81
 Near X =  0.44114176     -0.88139029      0.19200993    , d:   0.0000000     -0.15439963       2.0005529
 i,j,k,ie:    4    5    1          81
 Near X =  0.44114176     -0.88139029      0.23800512    , d:   0.0000000     -0.15439963       2.0005529
 i,j,k,ie:    5    5    1          81
 Near X =  0.44114176     -0.88139029      0.27669227    , d:   0.0000000     -0.15439963       2.0005529
 i,j,k,ie:    6    5    1          81
 Near X =  0.44114176     -0.88139029      0.29563535    , d:   0.0000000     -0.49986123       2.0005529
 i,j,k,ie:    1    6    1          81
 Near X =  0.49986170     -0.86560228      0.13437970    , d:   0.0000000     -0.82476867       2.0005529
 i,j,k,ie:    2    6    1          81
 Near X =  0.49986170     -0.86560228      0.15332278    , d:   0.0000000     -0.82476867       2.0005529
 i,j,k,ie:    3    6    1          81
 Near X =  0.49986170     -0.86560228      0.19200993    , d:   0.0000000     -0.82476867       2.0005529
 i,j,k,ie:    4    6    1          81
 Near X =  0.49986170     -0.86560228      0.23800512    , d:   0.0000000     -0.82476867       2.0005529
 i,j,k,ie:    5    6    1          81
 Near X =  0.49986170     -0.86560228      0.27669227    , d:   0.0000000     -0.82476867       2.0005529
 i,j,k,ie:    6    6    1          81
 Near X =  0.49986170     -0.86560228      0.29563535    , d:   0.0000000      -1.0625032       2.0005529
 i,j,k,ie:    1    1    2          81
 Near X = -0.11315572E-06 -0.95888469      0.13437970    , d:  0.47930521       0.0000000       2.0005529
 i,j,k,ie:    2    1    2          81
 Near X = -0.11315572E-06 -0.95888469      0.15332278    , d:  0.47930521       0.0000000       2.0005529
 i,j,k,ie:    3    1    2          81
 Near X = -0.11315572E-06 -0.95888469      0.19200993    , d:  0.47930521       0.0000000       2.0005529
 i,j,k,ie:    4    1    2          81
 Near X = -0.11315572E-06 -0.95888469      0.23800512    , d:  0.47930521       0.0000000       2.0005529
 i,j,k,ie:    5    1    2          81
 Near X = -0.11315572E-06 -0.95888469      0.27669227    , d:  0.47930521       0.0000000       2.0005529
 i,j,k,ie:    6    1    2          81
 Near X = -0.11315572E-06 -0.95888469      0.29563535    , d:  0.83001288     -0.47930501       2.0005529
 i,j,k,ie:    6    2    2          81
 Near X =  0.56305534E-01 -0.94374580      0.29563535    , d:   0.0000000     -0.47930558       2.0005529
 i,j,k,ie:    6    3    2          81
 Near X =  0.17129767     -0.91282789      0.29563535    , d:   0.0000000     -0.47930674       2.0005529
 i,j,k,ie:    6    4    2          81
 Near X =  0.30801194     -0.87606956      0.29563535    , d:   0.0000000     -0.47930811       2.0005529
 i,j,k,ie:    6    5    2          81
 Near X =  0.42300408     -0.84515165      0.29563535    , d:   0.0000000     -0.47930927       2.0005529
 i,j,k,ie:    1    6    2          81
 Near X =  0.47930973     -0.83001276      0.13437970    , d:   0.0000000     -0.79549358       2.0005529
 i,j,k,ie:    2    6    2          81
 Near X =  0.47930973     -0.83001276      0.15332278    , d:   0.0000000     -0.79549358       2.0005529
 i,j,k,ie:    3    6    2          81
 Near X =  0.47930973     -0.83001276      0.19200993    , d:   0.0000000     -0.79549358       2.0005529
 i,j,k,ie:    4    6    2          81
 Near X =  0.47930973     -0.83001276      0.23800512    , d:   0.0000000     -0.79549358       2.0005529
 i,j,k,ie:    5    6    2          81
 Near X =  0.47930973     -0.83001276      0.27669227    , d:   0.0000000     -0.79549358       2.0005529
 i,j,k,ie:    6    6    2          81
 Near X =  0.47930973     -0.83001276      0.29563535    , d:   0.0000000      -1.0266769       2.0005529
 i,j,k,ie:    1    1    3          81
 Near X = -0.10324672E-06 -0.87491551      0.13437970    , d:  0.43733264       0.0000000       2.0005529
 i,j,k,ie:    2    1    3          81
 Near X = -0.10324672E-06 -0.87491551      0.15332278    , d:  0.43733264       0.0000000       2.0005529
 i,j,k,ie:    3    1    3          81
 Near X = -0.10324672E-06 -0.87491551      0.19200993    , d:  0.43733264       0.0000000       2.0005529
 i,j,k,ie:    4    1    3          81
 Near X = -0.10324672E-06 -0.87491551      0.23800512    , d:  0.43733264       0.0000000       2.0005529
 i,j,k,ie:    5    1    3          81
 Near X = -0.10324672E-06 -0.87491551      0.27669227    , d:  0.43733264       0.0000000       2.0005529
 i,j,k,ie:    6    1    3          81
 Near X = -0.10324672E-06 -0.87491551      0.29563535    , d:  0.75732897     -0.43733245       2.0005529
 i,j,k,ie:    6    2    3          81
 Near X =  0.51374880E-01 -0.86110233      0.29563535    , d:   0.0000000     -0.43733297       2.0005529
 i,j,k,ie:    6    3    3          81
 Near X =  0.15629720     -0.83289189      0.29563535    , d:   0.0000000     -0.43733403       2.0005529
 i,j,k,ie:    6    4    3          81
 Near X =  0.28103945     -0.79935247      0.29563535    , d:   0.0000000     -0.43733528       2.0005529
 i,j,k,ie:    6    5    3          81
 Near X =  0.38596177     -0.77114204      0.29563535    , d:   0.0000000     -0.43733634       2.0005529
 i,j,k,ie:    1    6    3          81
 Near X =  0.43733675     -0.75732886      0.13437970    , d:   0.0000000     -0.73570553       2.0005529
 i,j,k,ie:    2    6    3          81
 Near X =  0.43733675     -0.75732886      0.15332278    , d:   0.0000000     -0.73570553       2.0005529
 i,j,k,ie:    3    6    3          81
 Near X =  0.43733675     -0.75732886      0.19200993    , d:   0.0000000     -0.73570553       2.0005529
 i,j,k,ie:    4    6    3          81
 Near X =  0.43733675     -0.75732886      0.23800512    , d:   0.0000000     -0.73570553       2.0005529
 i,j,k,ie:    5    6    3          81
 Near X =  0.43733675     -0.75732886      0.27669227    , d:   0.0000000     -0.73570553       2.0005529
 i,j,k,ie:    6    6    3          81
 Near X =  0.43733675     -0.75732886      0.29563535    , d:   0.0000000     -0.95350960       2.0005529
 i,j,k,ie:    1    1    4          81
 Near X = -0.91465890E-07 -0.77508447      0.13437970    , d:  0.38743139       0.0000000       2.0005529
 i,j,k,ie:    2    1    4          81
 Near X = -0.91465890E-07 -0.77508447      0.15332278    , d:  0.38743139       0.0000000       2.0005529
 i,j,k,ie:    3    1    4          81
 Near X = -0.91465890E-07 -0.77508447      0.19200993    , d:  0.38743139       0.0000000       2.0005529
 i,j,k,ie:    4    1    4          81
 Near X = -0.91465890E-07 -0.77508447      0.23800512    , d:  0.38743139       0.0000000       2.0005529
 i,j,k,ie:    5    1    4          81
 Near X = -0.91465890E-07 -0.77508447      0.27669227    , d:  0.38743139       0.0000000       2.0005529
 i,j,k,ie:    6    1    4          81
 Near X = -0.91465890E-07 -0.77508447      0.29563535    , d:  0.67091498     -0.38743123       2.0005529
 i,j,k,ie:    6    2    4          81
 Near X =  0.45512819E-01 -0.76284743      0.29563535    , d:   0.0000000     -0.38743169       2.0005529
 i,j,k,ie:    6    3    4          81
 Near X =  0.13846312     -0.73785590      0.29563535    , d:   0.0000000     -0.38743262       2.0005529
 i,j,k,ie:    6    4    4          81
 Near X =  0.24897183     -0.70814345      0.29563535    , d:   0.0000000     -0.38743374       2.0005529
 i,j,k,ie:    6    5    4          81
 Near X =  0.34192213     -0.68315193      0.29563535    , d:   0.0000000     -0.38743467       2.0005529
 i,j,k,ie:    1    6    4          81
 Near X =  0.38743504     -0.67091488      0.13437970    , d:   0.0000000     -0.66462344       2.0005529
 i,j,k,ie:    2    6    4          81
 Near X =  0.38743504     -0.67091488      0.15332278    , d:   0.0000000     -0.66462344       2.0005529
 i,j,k,ie:    3    6    4          81
 Near X =  0.38743504     -0.67091488      0.19200993    , d:   0.0000000     -0.66462344       2.0005529
 i,j,k,ie:    4    6    4          81
 Near X =  0.38743504     -0.67091488      0.23800512    , d:   0.0000000     -0.66462344       2.0005529
 i,j,k,ie:    5    6    4          81
 Near X =  0.38743504     -0.67091488      0.27669227    , d:   0.0000000     -0.66462344       2.0005529
 i,j,k,ie:    6    6    4          81
 Near X =  0.38743504     -0.67091488      0.29563535    , d:   0.0000000     -0.86652089       2.0005529
 i,j,k,ie:    1    1    5          81
 Near X = -0.81556886E-07 -0.69111530      0.13437970    , d:  0.34545881       0.0000000       2.0005529
 i,j,k,ie:    2    1    5          81
 Near X = -0.81556886E-07 -0.69111530      0.15332278    , d:  0.34545881       0.0000000       2.0005529
 i,j,k,ie:    3    1    5          81
 Near X = -0.81556886E-07 -0.69111530      0.19200993    , d:  0.34545881       0.0000000       2.0005529
 i,j,k,ie:    4    1    5          81
 Near X = -0.81556886E-07 -0.69111530      0.23800512    , d:  0.34545881       0.0000000       2.0005529
 i,j,k,ie:    5    1    5          81
 Near X = -0.81556886E-07 -0.69111530      0.27669227    , d:  0.34545881       0.0000000       2.0005529
 i,j,k,ie:    6    1    5          81
 Near X = -0.81556886E-07 -0.69111530      0.29563535    , d:  0.59823106     -0.34545867       2.0005529
 i,j,k,ie:    6    2    5          81
 Near X =  0.40582165E-01 -0.68020396      0.29563535    , d:   0.0000000     -0.34545908       2.0005529
 i,j,k,ie:    6    3    5          81
 Near X =  0.12346265     -0.65791991      0.29563535    , d:   0.0000000     -0.34545991       2.0005529
 i,j,k,ie:    6    4    5          81
 Near X =  0.22199934     -0.63142637      0.29563535    , d:   0.0000000     -0.34546090       2.0005529
 i,j,k,ie:    6    5    5          81
 Near X =  0.30487982     -0.60914231      0.29563535    , d:   0.0000000     -0.34546174       2.0005529
 i,j,k,ie:    1    6    5          81
 Near X =  0.34546207     -0.59823098      0.13437970    , d:   0.0000000     -0.60483539       2.0005529
 i,j,k,ie:    2    6    5          81
 Near X =  0.34546207     -0.59823098      0.15332278    , d:   0.0000000     -0.60483539       2.0005529
 i,j,k,ie:    3    6    5          81
 Near X =  0.34546207     -0.59823098      0.19200993    , d:   0.0000000     -0.60483539       2.0005529
 i,j,k,ie:    4    6    5          81
 Near X =  0.34546207     -0.59823098      0.23800512    , d:   0.0000000     -0.60483539       2.0005529
 i,j,k,ie:    5    6    5          81
 Near X =  0.34546207     -0.59823098      0.27669227    , d:   0.0000000     -0.60483539       2.0005529
 i,j,k,ie:    6    6    5          81
 Near X =  0.34546207     -0.59823098      0.29563535    , d:   0.0000000     -0.79335356       2.0005529
 i,j,k,ie:    1    1    6          81
 Near X = -0.76704964E-07 -0.64999998      0.13437970    , d:  0.49985695     -0.41302678E-07   2.0005529
 i,j,k,ie:    2    1    6          81
 Near X = -0.76704964E-07 -0.64999998      0.15332278    , d:  0.49985695     -0.41302678E-07   2.0005529
 i,j,k,ie:    3    1    6          81
 Near X = -0.76704964E-07 -0.64999998      0.19200993    , d:  0.49985695     -0.41302678E-07   2.0005529
 i,j,k,ie:    4    1    6          81
 Near X = -0.76704964E-07 -0.64999998      0.23800512    , d:  0.49985695     -0.41302678E-07   2.0005529
 WARNING1 Element mesh mismatch at:
 i,j,k,ie:    5    1    6          81
 Near X = -0.76704964E-07 -0.64999998      0.27669227    , d:  0.49985695     -0.41302678E-07   2.0005529
 i,j,k,ie:    6    1    6          81
 Near X = -0.76704964E-07 -0.64999998      0.29563535    , d:  0.86560236     -0.49985683       2.0005529
 i,j,k,ie:    1    2    6          81
 Near X =  0.38167880E-01 -0.63973777      0.13437970    , d:  0.20551938E-01   0.0000000       2.0005529
 i,j,k,ie:    2    2    6          81
 Near X =  0.38167880E-01 -0.63973777      0.15332278    , d:  0.20551938E-01   0.0000000       2.0005529
 i,j,k,ie:    3    2    6          81
 Near X =  0.38167880E-01 -0.63973777      0.19200993    , d:  0.20551938E-01   0.0000000       2.0005529
 i,j,k,ie:    4    2    6          81
 Near X =  0.38167880E-01 -0.63973777      0.23800512    , d:  0.20551938E-01   0.0000000       2.0005529
 i,j,k,ie:    5    2    6          81
 Near X =  0.38167880E-01 -0.63973777      0.27669227    , d:  0.20551938E-01   0.0000000       2.0005529
 i,j,k,ie:    6    2    6          81
 Near X =  0.38167880E-01 -0.63973777      0.29563535    , d:  0.20551938E-01 -0.47930544       2.0005529
 i,j,k,ie:    1    3    6          81
 Near X =  0.11611770     -0.61877942      0.13437970    , d:  0.62524921E-01   0.0000000       2.0005529
 i,j,k,ie:    2    3    6          81
 Near X =  0.11611770     -0.61877942      0.15332278    , d:  0.62524921E-01   0.0000000       2.0005529
 i,j,k,ie:    3    3    6          81
 Near X =  0.11611770     -0.61877942      0.19200993    , d:  0.62524921E-01   0.0000000       2.0005529
 i,j,k,ie:    4    3    6          81
 Near X =  0.11611770     -0.61877942      0.23800512    , d:  0.62524921E-01   0.0000000       2.0005529
 i,j,k,ie:    5    3    6          81
 Near X =  0.11611770     -0.61877942      0.27669227    , d:  0.62524921E-01   0.0000000       2.0005529
 i,j,k,ie:    6    3    6          81
 Near X =  0.11611770     -0.61877942      0.29563535    , d:  0.62524921E-01 -0.43733366       2.0005529
 i,j,k,ie:    1    4    6          81
 Near X =  0.20879232     -0.59386202      0.13437970    , d:  0.11242665       0.0000000       2.0005529
 i,j,k,ie:    2    4    6          81
 Near X =  0.20879232     -0.59386202      0.15332278    , d:  0.11242665       0.0000000       2.0005529
 i,j,k,ie:    3    4    6          81
 Near X =  0.20879232     -0.59386202      0.19200993    , d:  0.11242665       0.0000000       2.0005529
 i,j,k,ie:    4    4    6          81
 Near X =  0.20879232     -0.59386202      0.23800512    , d:  0.11242665       0.0000000       2.0005529
 i,j,k,ie:    5    4    6          81
 Near X =  0.20879232     -0.59386202      0.27669227    , d:  0.11242665       0.0000000       2.0005529
 i,j,k,ie:    6    4    6          81
 Near X =  0.20879232     -0.59386202      0.29563535    , d:  0.11242665     -0.38743337       2.0005529
 i,j,k,ie:    1    5    6          81
 Near X =  0.28674213     -0.57290367      0.13437970    , d:  0.15439963       0.0000000       2.0005529
 i,j,k,ie:    2    5    6          81
 Near X =  0.28674213     -0.57290367      0.15332278    , d:  0.15439963       0.0000000       2.0005529
 i,j,k,ie:    3    5    6          81
 Near X =  0.28674213     -0.57290367      0.19200993    , d:  0.15439963       0.0000000       2.0005529
 i,j,k,ie:    4    5    6          81
 Near X =  0.28674213     -0.57290367      0.23800512    , d:  0.15439963       0.0000000       2.0005529
 i,j,k,ie:    5    5    6          81
 Near X =  0.28674213     -0.57290367      0.27669227    , d:  0.15439963       0.0000000       2.0005529
 i,j,k,ie:    6    5    6          81
 Near X =  0.28674213     -0.57290367      0.29563535    , d:  0.15439963     -0.34546160       2.0005529
 i,j,k,ie:    1    6    6          81
 Near X =  0.32491009     -0.56264146      0.13437970    , d:  0.17495161     -0.64981707       2.0005529
 i,j,k,ie:    2    6    6          81
 Near X =  0.32491009     -0.56264146      0.15332278    , d:  0.17495161     -0.64981707       2.0005529
 i,j,k,ie:    3    6    6          81
 Near X =  0.32491009     -0.56264146      0.19200993    , d:  0.17495161     -0.64981707       2.0005529
 i,j,k,ie:    4    6    6          81
 Near X =  0.32491009     -0.56264146      0.23800512    , d:  0.17495161     -0.64981707       2.0005529
 i,j,k,ie:    5    6    6          81
 Near X =  0.32491009     -0.56264146      0.27669227    , d:  0.17495161     -0.64981707       2.0005529
 i,j,k,ie:    6    6    6          81
 Near X =  0.32491009     -0.56264146      0.29563535    , d:  0.17495161     -0.88755154       2.0005529
 i,j,k,ie:    1    1    1          82
 Near X = -0.49985690     -0.86558375      0.13437970    , d:   1.3654592       0.0000000       2.0005725
 i,j,k,ie:    2    1    1          82
 Near X = -0.49985690     -0.86558375      0.15332278    , d:   1.3654592       0.0000000       2.0005725
 i,j,k,ie:    3    1    1          82
 Near X = -0.49985690     -0.86558375      0.19200993    , d:   1.3654592       0.0000000       2.0005725
 i,j,k,ie:    4    1    1          82
 Near X = -0.49985690     -0.86558375      0.23800512    , d:   1.3654592       0.0000000       2.0005725
 i,j,k,ie:    5    1    1          82
 Near X = -0.49985690     -0.86558375      0.27669227    , d:   1.3654592       0.0000000       2.0005725
 i,j,k,ie:    6    1    1          82
 Near X = -0.49985690     -0.86558375      0.29563535    , d:   1.4998569     -0.36574537       2.0005725
 i,j,k,ie:    1    2    1          82
 Near X = -0.44113756     -0.88137394      0.13437970    , d:  0.49985738       0.0000000       2.0005725
 i,j,k,ie:    2    2    1          82
 Near X = -0.44113756     -0.88137394      0.15332278    , d:  0.15439816       0.0000000       2.0005725
 i,j,k,ie:    3    2    1          82
 Near X = -0.44113756     -0.88137394      0.19200993    , d:  0.15439816       0.0000000       2.0005725
 i,j,k,ie:    4    2    1          82
 Near X = -0.44113756     -0.88137394      0.23800512    , d:  0.15439816       0.0000000       2.0005725
 i,j,k,ie:    5    2    1          82
 Near X = -0.44113756     -0.88137394      0.27669227    , d:  0.15439816       0.0000000       2.0005725
 i,j,k,ie:    6    2    1          82
 Near X = -0.44113756     -0.88137394      0.29563535    , d:  0.15439816     -0.38149975       2.0005725
 i,j,k,ie:    1    3    1          82
 Near X = -0.32121597     -0.91362200      0.13437970    , d:  0.49985858       0.0000000       2.0005725
 i,j,k,ie:    2    3    1          82
 Near X = -0.32121597     -0.91362200      0.15332278    , d:  0.11242560       0.0000000       2.0005725
 i,j,k,ie:    3    3    1          82
 Near X = -0.32121597     -0.91362200      0.19200993    , d:  0.11242560       0.0000000       2.0005725
 i,j,k,ie:    4    3    1          82
 Near X = -0.32121597     -0.91362200      0.23800512    , d:  0.11242560       0.0000000       2.0005725
 i,j,k,ie:    5    3    1          82
 Near X = -0.32121597     -0.91362200      0.27669227    , d:  0.11242560       0.0000000       2.0005725
 i,j,k,ie:    6    3    1          82
 Near X = -0.32121597     -0.91362200      0.29563535    , d:  0.11242560     -0.41367468       2.0005725
 i,j,k,ie:    1    4    1          82
 Near X = -0.17864106     -0.95196176      0.13437970    , d:  0.49986002       0.0000000       2.0005725
 i,j,k,ie:    2    4    1          82
 Near X = -0.17864106     -0.95196176      0.15332278    , d:  0.62524375E-01   0.0000000       2.0005725
 i,j,k,ie:    3    4    1          82
 Near X = -0.17864106     -0.95196176      0.19200993    , d:  0.62524375E-01   0.0000000       2.0005725
 i,j,k,ie:    4    4    1          82
 Near X = -0.17864106     -0.95196176      0.23800512    , d:  0.62524375E-01   0.0000000       2.0005725
 i,j,k,ie:    5    4    1          82
 Near X = -0.17864106     -0.95196176      0.27669227    , d:  0.62524375E-01   0.0000000       2.0005725
 i,j,k,ie:    6    4    1          82
 Near X = -0.17864106     -0.95196176      0.29563535    , d:  0.62524375E-01 -0.45192748       2.0005725
 i,j,k,ie:    1    5    1          82
 Near X = -0.58719463E-01 -0.98420982      0.13437970    , d:  0.49986123       0.0000000       2.0005725
 i,j,k,ie:    2    5    1          82
 Near X = -0.58719463E-01 -0.98420982      0.15332278    , d:  0.20551814E-01   0.0000000       2.0005725
 i,j,k,ie:    3    5    1          82
 Near X = -0.58719463E-01 -0.98420982      0.19200993    , d:  0.20551814E-01   0.0000000       2.0005725
 i,j,k,ie:    4    5    1          82
 Near X = -0.58719463E-01 -0.98420982      0.23800512    , d:  0.20551814E-01   0.0000000       2.0005725
 i,j,k,ie:    5    5    1          82
 Near X = -0.58719463E-01 -0.98420982      0.27669227    , d:  0.20551814E-01   0.0000000       2.0005725
 i,j,k,ie:    6    5    1          82
 Near X = -0.58719463E-01 -0.98420982      0.29563535    , d:  0.20551814E-01 -0.48410240       2.0005725
 i,j,k,ie:    1    6    1          82
 Near X = -0.11800764E-06  -1.0000000      0.13437970    , d:  0.49986182     -0.56264133       2.0005725
 i,j,k,ie:    2    6    1          82
 Near X = -0.11800764E-06  -1.0000000      0.15332278    , d:  0.41302678E-07 -0.56264133       2.0005725
 i,j,k,ie:    3    6    1          82
 Near X = -0.11800764E-06  -1.0000000      0.19200993    , d:  0.41302678E-07 -0.56264133       2.0005725
 i,j,k,ie:    4    6    1          82
 Near X = -0.11800764E-06  -1.0000000      0.23800512    , d:  0.41302678E-07 -0.56264133       2.0005725
 i,j,k,ie:    5    6    1          82
 Near X = -0.11800764E-06  -1.0000000      0.27669227    , d:  0.41302678E-07 -0.56264133       2.0005725
 i,j,k,ie:    6    6
