[Nek5000-users] Linearised Navier Stokes
Tue Aug 22 03:11:27 CDT 2017
Hi Adam,
       For running a 3D case , I am setting: parameter (lelg=500). This
gives some compilations errors as follows:
obj/bdry.o: In function `faceiv_..0':
/home/Nek5000/core/bdry.f:(.text+0x8b8c): relocation truncated to fit:
R_X86_64_32S against symbol `screv_' defined in COMMON section in
obj/postpro.o
This does not occur if  lelg<300. Please let me know a higher lelg can be
used.
Thank you
Swarandeep
On Mon, Aug 21, 2017 at 6:41 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Adam,
>         Yes, I had wrongly  set it to  lx2=lx1. I corrected it and now
> the running is correct. The base flow is held in place and the
> perturbations are time stepped.  Thank you very much for this.
>          However the following line
>    call gradm1(DTDX,DTDY,DTDZ,T)
>          which works for the base flow is not working for the perturbation
> if I use the below lines:
>          call gradm1(DTPDX,DTPDY,DTPDZ,TP)
>        call outpost(DTPDX,DTPDY,DTPDZ,PRP,TP,0,'gdtprt')
> Thank you
> Swarandeep
> On Mon, Aug 21, 2017 at 4:41 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi,
>> The first problem I could see is pressure mesh size. From the log file it
>> seems you are using P_n-P_n instead P_n-P_n-2. Only  P_n-P_n-2 has
>> perturbation mode, so please check you SIZE file and compare it with the
>> SIZE file in dfh_cav example. You should have lx2=lx1-2 instead of lx2=lx1.
>> Is it the case?
>> Regards
>> Adam
>> On 18/08/17 15:06, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Adam,
>>        I have send the logfile to your email: adam at mech.kth.se)
>> Swarandeep
>> On Fri, Aug 18, 2017 at 6:14 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Strange. Could you send me your log file? (adam at mech.kth.se)
>>> Regards
>>> Adam
>>> On 18/08/17 14:40, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Adam,
>>>       Thank you for the continued support. I managed to get the base
>>> flow and then I used it in a perturbation calculation following the dfh_cav
>>> case. Peculiarly, I an finding that the basic state is getting time stepped
>>> and the perturbations are not (in contrast to the dfh_cav case). I have
>>> used the same .par file from the dfh_cav case and has used the follwoing
>>> settings:
>>> [PROBLEMTYPE]
>>> perturbations = yes
>>> solveBaseflow = no
>>> variableProperties = yes
>>>    Can you please let me know where I am am mistaken.
>>> Swarandeep
>>> On Fri, Aug 18, 2017 at 4:52 PM, <nek5000-users at lists.mcs.anl.gov>
>>> wrote:
>>>> Hi,
>>>> ###.ma2 is the binary version of ###.map file and you need only one of
>>>> them (it is a new feature). The map (or ma2) is generated by travis during
>>>> testing by running genmap, so we do not keep it in repository.
>>>> regards
>>>> adam
>>>> On 18/08/17 10:49, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi
>>>>     I could no find the ###.ma2 file for the dfh_cav example. Hence I
>>>> suppose I require the ###.box or the ###.map file to proceed for the base
>>>> flow. Please correct me if I have misunderstood.
>>>> Swarandeep
>>>> On Fri, Aug 18, 2017 at 1:03 AM, <nek5000-users at lists.mcs.anl.gov>
>>>> wrote:
>>>>> Hi Swarandeep,
>>>>> For computing the base flow you can use the same mesh and map file.
>>>>> What you need to change is 1) the boundary conditions such that they are
>>>>> valid for the base flow and 2) the flags that you run a nonlinear instead
>>>>> of a linear case.
>>>>> As Clio was saying, in that particular case the base flow was computed
>>>>> using a Newton method. For lower Rayleigh numbers, you should however be
>>>>> able to just run (nonlinear) DNS to reach the steady state.
>>>>> Best regards,
>>>>> Philipp
>>>>> On 2017-08-17 20:23, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>> Hi Clio and Adam,
>>>>>>         Thanks for the information.
>>>>>>   I think in order to compute the base flow I need the ###.box file
>>>>>> as well as a different ###.usr file as I think the boundary and initial
>>>>>> conditions for the ###.usr file in the short_tests/dfh_cav directory is
>>>>>> applicable for the perturbations only. Please send me the ###.box and the
>>>>>> corresponding ###.usr file applicable for the base flow for dfh_cav case.
>>>>>> Swarandeep
>>>>>> On Thu, Aug 17, 2017 at 7:03 PM, <nek5000-users at lists.mcs.anl.gov
>>>>>> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>>>>>>     Hi Swarandeep,
>>>>>>     The baseflow has been computed with a Newton solver (which is not
>>>>>>     available in the nek examples). The additional code had been
>>>>>>     implemented in the version 1040 of nek5000, and there is no .par
>>>>>>     file for that. However, in general, if your case is laminar, to
>>>>>>     compute a baseflow, you just need to evaluate the steady state of
>>>>>>     your nonlinear case. For that, you can use the same .par file, and
>>>>>>     just change to the nonlinear solver (perturbationmodes = 0,
>>>>>>     perturbations = no, solveBaseflow = yes).
>>>>>>     The non dimensionalization is based on Hellums and Churchill
>>>>>> (1962).
>>>>>>     The equations are:
>>>>>>     Pr (du/dt + (U*nabla)u + (u*nabla)U) = 1/sqrt(Ra)laplacian(u)
>>>>>> -grad
>>>>>>     p + e_g theta
>>>>>>     d theta/dt + (u*nabla)Theta + (U*nabla)theta =
>>>>>>     1/sqrt(Ra)laplacian(theta)
>>>>>>     div(u)=0
>>>>>>     where u, theta are respectively the velocity and temperature of
>>>>>> the
>>>>>>     perturbation, U, Theta the velocity and temperature of the
>>>>>> baseflow.
>>>>>>     You can find more information in the paper "Saglietti, Clio, et
>>>>>> al.
>>>>>>     "Adjoint optimization of natural convection problems:
>>>>>> differentially
>>>>>>     heated cavity." Theoretical and Computational Fluid Dynamics
>>>>>> (2016):
>>>>>>     1-17." on which the example is based.
>>>>>>     Regards,
>>>>>>     clio
>>>>>>     Quoting nek5000-users at lists.mcs.anl.gov
>>>>>>     <mailto:nek5000-users at lists.mcs.anl.gov>:
>>>>>>         Hi Adam,
>>>>>>         Thanks for the clarification. Can you please send me a sample
>>>>>>         .par file for
>>>>>>         the baseflow for the case of "dfh_cav". Also is it possible to
>>>>>>         get the
>>>>>>         equations solved for this problem(dfh_cav). I would like to
>>>>>> know
>>>>>>         the way
>>>>>>         that this has been made dimensionless.
>>>>>>         For your kind information I briefly describe my case which I
>>>>>>         have been used
>>>>>>         to solve with the regular non-linear framework using older
>>>>>>         versions (.rea
>>>>>>         files). My setup is as follows:
>>>>>>         Geometry is a 3D cylindrical annullus.
>>>>>>         Temperature are fixed at inner and outer cylinders.
>>>>>>         Gravity is acting in -z direction
>>>>>>         There is a back ground rotation which is constant.
>>>>>>         Please let me know if any other info is required. Thanks for
>>>>>> the
>>>>>>         help.
>>>>>>         Swarandeep
>>>>>>         On Thu, Aug 17, 2017 at 1:48 PM,
>>>>>>             Hi Swarandeep,
>>>>>>             Yes. You generate ###.rea in the standard way. In the old
>>>>>>             version it was
>>>>>>             txt and contained both mesh information and runtime
>>>>>>             parameter. One could
>>>>>>             split mesh information (###.re2, binary file) and runtime
>>>>>>             parameters
>>>>>>             (###.rea with negative number of elements or currently
>>>>>>             ###.par) using
>>>>>>             reatore2 tool. The map file is generated with genmap (can
>>>>>> be
>>>>>>             txt or
>>>>>>             binary). So the procedure is more or less the same. If you
>>>>>>             have ###.rea
>>>>>>             with mesh you split it and generate ###.re2. Next you
>>>>>>             generate ###.map with
>>>>>>             genmap and finally ###.par by hand. Be careful to use
>>>>>> tolls
>>>>>>             from the same
>>>>>>             release, as they've been changed significantly (e.g.
>>>>>> binary
>>>>>>             ###.map file).
>>>>>>             Regards
>>>>>>             Adam
>>>>>>             On 16/08/17 18:52, nek5000-users at lists.mcs.anl.gov
>>>>>>             <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>>>>>>             Hi Adam,
>>>>>>                       Thank you very much for the help.
>>>>>>                       Does the ###.map, ###.box file  and from them
>>>>>> the
>>>>>>             ###.rea file
>>>>>>             (in the dfh_cav case: the ###.re2 files)  are created as
>>>>>>             done for the
>>>>>>             earlier versions i.e., by using genbox and genmap. Please
>>>>>>             clarify.
>>>>>>             Swarandeep
>>>>>>             On Wed, Aug 16, 2017 at 5:35 PM,
>>>>>>                 Hi,
>>>>>>                 The simplest way would be to look into existing
>>>>>> example
>>>>>>                 under
>>>>>>                 Nek5000/short_test/dfh_cav/
>>>>>>                 It is a differentially heated cavity case and covers
>>>>>>                 both direct and
>>>>>>                 adjoint linear solver. It is compatible with the
>>>>>> current
>>>>>>                 git version and
>>>>>>                 uses ###.par file instead of ###.rea.
>>>>>>                 Regards
>>>>>>                 Adam
>>>>>>                 On 11/08/17 11:05, nek5000-users at lists.mcs.anl.gov
>>>>>>                     This information might be outdated (old version)
>>>>>> but
>>>>>>                     previously the base
>>>>>>                     flow was read in using the restart option in the
>>>>>> rea
>>>>>>                     file. The disturbance
>>>>>>                     you can read in yourself in userchk.
>>>>>>                     Philipp
>>>>>>                     On 2017-08-11 10:49,
>>>>>>                         Hi Philipp,
>>>>>>                                That was very much helpful. I have a
>>>>>>                         steady base flow and
>>>>>>                         temperature state. Please let me know where to
>>>>>>                         provide the base flow.
>>>>>>                         Thank you
>>>>>>                         Swarandeep
>>>>>>                         ______________________________
>>>>>> _________________
>>>>>>                         Nek5000-users mailing list
>>>>>>                         Nek5000-users at lists.mcs.anl.gov
>>>>>>                         <mailto:Nek5000-users at lists.mcs.anl.gov>
>>>>>>                         https://lists.mcs.anl.gov/mail
>>>>>> man/listinfo/nek5000-users
>>>>>>                         <https://lists.mcs.anl.gov/mai
>>>>>> lman/listinfo/nek5000-users>
>>>>>> _________________
>>>>>>                 _______________________________________________
>>>>>>             Nek5000-users mailing listNek5000-users at lists.mcs.an
>>>>>>             <mailto:listNek5000-users at lists.mcs.an>l.govhttps://
>>>>>> lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>>>             <http://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>>>>>             https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>>>             <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>>>     Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mc
>>>>>> s.anl.gov>
>>>>>>     <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>>> Nek5000-users mailing listNek5000-users at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170822/2190bc69/attachment-0001.html>
