[Nek5000-users] Using mshconvert With Curves
Thu Aug 10 09:41:45 CDT 2017
Dear Tommy,
Besides the short REAMDE file, there is a detailed explanation on how to
use the script at the end of the file 'mshconvert.py' (starting from line
1385).
Basically, you need to identify the IDs of the curved boundaries in the
.msh file and give it a Nek type (either midpoint 'm' or curve 'C' + some
info: I think that only the radius is required, the rest is optional) and
pass this info to the script in the form of a Python dictionary called
'curves'.
If the problem persists, feel free to share some details about the error
that you get.
Best,
Nicolas
On Wed, Aug 9, 2017 at 10:43 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Greetings,
> I am trying to use the mshconvert script to produce a rea file for a
> helical geometry. I am running into errors when I try to define the
> boundaries that have curved surfaces. Has anyone used it to generate a rea
> file with curved data?
> Thanks,
> Tommy
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170810/57411d34/attachment-0001.html>
