[Nek5000-users] call quickmv
Thu Aug 10 03:12:34 CDT 2017
It looks like something goes wrong with MPI. Please update your Nek5000 installation to the latest MASTER on GitHub. Can you run one of the short_test e.g. (ethier) to see if there is general problem?
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Wednesday 9th August 2017 22:11
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] call quickmv
> Hello,
> I tried the old SIZE file with the new Nek5000, but again the 3d quickmv cannot go through.
> Attached is the error:
> Rank 113 Fatal error in PMPI_Barrier: Invalid communicator, error stack:
> PMPI_Barrier(425): MPI_Barrier(comm=0x78b58c40) failed
> PMPI_Barrier(385): Invalid communicator
> _pmiu_daemon(SIGCHLD): [NID 00051] [c0-0c1s6n3] PE RANK 113 exit signal Aborted
> [NID 00051]  Apid 24437: initiated application termination
> Nek5000-users mailing list
