[Nek5000-users] constant average velocity at inlet with periodic boundary conditions
Tue Sep 6 12:00:27 CDT 2016
Paul,
I emailed you on your illinoi email. There is a link to download the files.
Thanks for looking into this.
Marco
> On Sep 6, 2016, at 12:36 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Marco,
> If you want to send .rea/.usr off-list, I'll take a look...
> Best,
> Paul
> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Tuesday, September 06, 2016 10:40 AM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] constant average velocity at inlet with    periodic        boundary conditions
> Also, the heat equation is only solved in the fluid domain. I am only interested in the turbulent flow without heat equation for now.
> Marco
>> On Sep 6, 2016, at 10:44 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Paul,
>> there is no heat added to the flow but I do have IFHEAT set to true in the rea file. The temperature profile does not vary though.
>> Marco
>>> On Sep 6, 2016, at 10:19 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Marco,
>>> Does this have conjugate heat transfer ?
>>> Paul
>>> Sent: Tuesday, September 06, 2016 8:39 AM
>>> Subject: [Nek5000-users] constant average velocity at inlet with periodic       boundary conditions
>>> Dear nek users,
>>> I am simulating the flow in a 7 pin bundle mesh with periodic boundary conditions in Nek5000 and set the parameters p054 and p055 to -3 and 1, respectively. With these settings, the average velocity should be 1 in the geometry. This is however not what I am seeing; the maximum velocity is around 0.32.
>>> I used the same set up for a 3-D pipe and the numerical solution behaves as expected.
>>> Does anybody has details on how the fix mass flow rate/volumetric velocity are enforced in Nek5000?
>>> Thanks,
>>> Marco
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
