[Nek5000-users] constant average velocity at inlet with periodic boundary conditions
Tue Sep 6 11:36:28 CDT 2016
Hi Marco,
If you want to send .rea/.usr off-list, I'll take a look...
Best,
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, September 06, 2016 10:40 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] constant average velocity at inlet with    periodic        boundary conditions
Also, the heat equation is only solved in the fluid domain. I am only interested in the turbulent flow without heat equation for now.
Marco
> On Sep 6, 2016, at 10:44 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Paul,
> there is no heat added to the flow but I do have IFHEAT set to true in the rea file. The temperature profile does not vary though.
> Marco
>> On Sep 6, 2016, at 10:19 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Marco,
>> Does this have conjugate heat transfer ?
>> Paul
>> Sent: Tuesday, September 06, 2016 8:39 AM
>> Subject: [Nek5000-users] constant average velocity at inlet with periodic       boundary conditions
>> Dear nek users,
>> I am simulating the flow in a 7 pin bundle mesh with periodic boundary conditions in Nek5000 and set the parameters p054 and p055 to -3 and 1, respectively. With these settings, the average velocity should be 1 in the geometry. This is however not what I am seeing; the maximum velocity is around 0.32.
>> I used the same set up for a 3-D pipe and the numerical solution behaves as expected.
>> Does anybody has details on how the fix mass flow rate/volumetric velocity are enforced in Nek5000?
>> Thanks,
>> Marco
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
